Serial Output on Minicom:-
[0000.000] [TegraBoot] (version UNDEF_BUILD)
[0000.004] Reset reason: power on reset
[0000.008] Processing in recovery mode
[0000.011] Established communication link with host
[0001.193] Downloaded bct successfully
[0001.209] No Battery Present
[0001.213] Sdram initialization is successful
[0001.223] Downloaded DTB successfully
[0001.249] No Battery Present
[0001.321] Downloaded bootloader successfully
[0001.326] CPU-bootloader entry address: 0x83d88000
[0001.330] BoardId: 375
[0001.332] Vpr Carveout Base=0x0f4600000 Size=0x00ba00000
[0001.337] Tsec Carveout Base=0x0f2600000 Size=0x002000000
[0001.343] Lp0 Carveout Base=0x0f25ff000 Size=0x000001000
[0001.348] Xusb Carveout Base=0x0f2300000 Size=0x000200000
[0001.353] Platform-DebugCarveout: 0
[0001.380] CPU power rail is up
[0001.383] Performing RAM repair
[0001.386] CPU clock init successful
[0001.389] Starting CPU & Halting co-processor
NVRM Initialized shmoo database
NVRM CLOCKS: PLLX0: 696000 Khz
NVRM CLOCKS: PLLM0: 924000 Khz
NVRM CLOCKS: PLLC0: 0 Khz
NVRM CLOCKS: PLLP0: 408000 Khz
NVRM CLOCKS: PLLA0: 11289 Khz
NVRM CLOCKS: CPU: 696000 Khz
NVRM CLOCKS: AVP: 48000 Khz
NVRM CLOCKS: System Bus: 48000 Khz
NVRM CLOCKS: Memory Controller: 924000
NVRM CLOCKS: External Memory Controller: 924000
EEPROM instance-5: No slave at this instance.
EEPROM instance-0: No slave at this instance.
EEPROM instance-0: Querying board info from BCT.
EEPROM instance-0: No board info available for this instance in BCT.
EEPROM instance-1: No slave at this instance.
EEPROM instance-1: Querying board info from BCT.
EEPROM instance-1: Board info present in BCT is invalid.
EEPROM instance-2: No slave at this instance.
EEPROM instance-2: Querying board info from BCT.
EEPROM instance-2: No board info available for this instance in BCT.
EEPROM instance-3: No slave at this instance.
EEPROM instance-3: Querying board info from BCT.
EEPROM instance-3: No board info available for this instance in BCT.
EEPROM instance-4: No slave at this instance.
EEPROM instance-4: Querying board info from BCT.
EEPROM instance-4: Board info present in BCT is invalid.
EEPROM instance-5: Querying board info from BCT.
EEPROM instance-5: Board info present in BCT is invalid.
EEPROM instance-6: BoardInfo: 0x0001:0x0007:0375:0000:03:E:00:0xff:0xff:0xff:0xf
EEPROM instance-7: No slave at this instance.
EEPROM instance-7: Querying board info from BCT.
EEPROM instance-7: No board info available for this instance in BCT.
Final BoardID: proc: 375 and pmu 375
ADJUSTED CLOCKS:
MC clock is set to 924000 KHz
EMC clock is set to 924000 KHz (DDR clock is at 924000 KHz)
PLLX0 clock is set to 696000 KHz
PLLC0 clock is set to 0 KHz
CPU clock is set to 696000 KHz
System and AVP clock is set to 48000 KHz
GraphicsHost clock is set to 163200 KHz
MSENC clock is set to 92400 KHz
Vde clock is set to 204000 KHz
Bootloader-Cpu Init at (time stamp): 90292847 us
Pinmux changes applied in kernel way
[bootloader] (version UNDEF_BUILD)
Platform Pre Boot configuration...
NvDdkUsbhBlockDevInit..
Initializing Display
The proc BoardInfo: 0x0177:0x0000:0x03:0x45:0x00
This Pmu Module is not present.
The best display mode is 2560x1600/60Hz, pclk: 268627Khz
DSI PAD calibration done
Entering NvFlash recovery mode / Nv3p Server
Nv3pServer Version 4.13.0000
***: DecodeCSD:
: readBlkBits=9, readBlkSize=512 Bytes
: nSectors=(CSIZE+1)*(2**(CSizeMult+2))=4096 * 512 = 2097152 Sectors
: writeBlkBits=9, writeBlkSize=512 Bytes
: ERASE_GRP_SIZE=31, ERASE_GRP_MULT=31
: EraseGrpSize=(31+1)*(31+1)=1024 Sectors (524288 Bytes)
: WPGrpSize=31744 Sectors (16252928 Bytes)
***: ReadExtCSD:
: overriding USER Sectors = 30777344 Sectors
: keep CSD EraseGrpSize = 1024 Sectors (524288 Bytes)
: keep CSD WPGrpSize = 31744 wBlks (16252928 Bytes)
: BootPartSize = 4194304 Bytes (8192 Sectors)
***: SetBlockSize to 512 Bytes SKIPPED because CMD16 is illegal for DDR50...
***: SdGetDevInfo: PagesPerBlock = 32 pages (256 Sectors)
***: SdGetDevInfo: TotSecs=TotBlk(120288)*PgPerBlk(32)*SecsPerPg(8)=30793728
Region=1 SD Erase start 512B-sector=0,512B-sector-num=8192
Region=2 SD Erase start 512B-sector=0,512B-sector-num=8192
Region=0 SD Erase start 512B-sector=0,512B-sector-num=30777344
SD Alloc Partid=2, start sector=0,num=2048
SD Alloc Partid=3, start sector=2048,num=512
SD Alloc Partid=4, start sector=2560,num=512
SD Alloc Partid=5, start sector=3072,num=1024
SD Alloc Partid=6, start sector=4096,num=4096
SD Alloc Partid=7, start sector=8192,num=1536
SD Alloc Partid=8, start sector=9728,num=512
SD Alloc Partid=9, start sector=10240,num=1536
SD Alloc Partid=10, start sector=11776,num=1536
SD Alloc Partid=11, start sector=13312,num=512
SD Alloc Partid=12, start sector=13824,num=3732480
SD Alloc Partid=13, start sector=3746304,num=1024
SD Alloc Partid=14, start sector=3747328,num=16384
SD Alloc Partid=15, start sector=3763712,num=1024
SD Alloc Partid=16, start sector=3764736,num=1024
SD Alloc Partid=17, start sector=3765760,num=1024
SD Alloc Partid=18, start sector=3766784,num=1024
SD Alloc Partid=19, start sector=3767808,num=512
SD Alloc Partid=20, start sector=3768320,num=80384
SD Alloc Partid=21, start sector=3848704,num=512
Region=0 SD Erase start 512B-sector=4096,512B-sector-num=4096
Start Downloading PPT
Parallel write enabled
End Downloading PPT
Time taken to download partition: 197 ms
Start Downloading EBT
End Downloading EBT
Time taken to download partition: 193 ms
Start Downloading APP
End Downloading APP
Time taken to download partition: 168529 ms
Start Downloading DTB
End Downloading DTB
Time taken to download partition: 19 ms
Start Downloading GPT
End Downloading GPT
Time taken to download partition: 180 ms
WriterThread: Exiting
Rebooting device after flashing.
U-Boot SPL 2018.05-gc50329da15 (Oct 31 2019 - 13:48:20 -0700)
Trying to boot from RAM
U-Boot 2018.05-gc50329da15 (Oct 31 2019 - 13:48:20 -0700)
TEGRA124
Model: NVIDIA Jetson TK1
Board: NVIDIA Jetson TK1
DRAM: 2 GiB
MMC: sdhci@700b0400: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Failed (-5)
In: serial
Out: serial
Err: serial
CPU is in NS mode
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
827 bytes read in 177 ms (3.9 KiB/s)
Jetson-TK1 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/zImage
6230800 bytes read in 268 ms (22.2 MiB/s)
append: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0t
Retrieving file: /boot/tegra124-jetson_tk1-pm375-000-c00-00.dtb
59966 bytes read in 306 ms (190.4 KiB/s)
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 82011a3d
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-ge16a41a05c9e (buildbrain@mobile-u64-1258)9
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
[ 0.000000] Found tsec, start=0xf4900000 size=2000000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f8500000 - f96fffff
[ 0.000000] 2nd Framebuffer: f9700000 - fdefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: f4900000 - f68fffff
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm/bs
[ 0.000000] get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] Tegra12: CPU Speedo value 2301, Soc Speedo value 2258, Gpu Speed3
[ 0.000000] Tegra12: CPU Speedo ID 1, Soc Speedo ID 1, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 1,Soc Process ID 1,Gpu Process ID 1
[ 0.000000] Tegra Revision: A01 SKU: 0x81 CPU Process: 1 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1092000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 384000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 828000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 828000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 528000000
[ 0.000000] Lowering se maximum rate from 600000000 to 528000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 528000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 444000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2065500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df3000 s15168 r8192 d13504 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa8
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_const
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1923MB = 1923MB total
[ 0.000000] Memory: 1920996k/1920996k available, 142364k reserved, 1190908K m
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b5b7d4 (11598 kB)
[ 0.000000] .init : 0xc0b5c000 - 0xc0bd8b40 ( 499 kB)
[ 0.000000] .data : 0xc0bda000 - 0xc0d3ef68 (1428 kB)
[ 0.000000] .bss : 0xc0d3ef68 - 0xc0dd9d8c ( 620 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863s
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.003744] Calibrating delay loop (skipped), value calculated using timer f0
[ 0.003816] pid_max: default: 32768 minimum: 301
[ 0.004115] Mount-cache hash table entries: 512
[ 0.027800] Initializing cgroup subsys debug
[ 0.027844] Initializing cgroup subsys freezer
[ 0.027932] CPU: Testing write buffer coherency: ok
[ 0.028004] ftrace: allocating 33504 entries in 66 pages
[ 0.071326] /cpus/cpu@0 missing clock-frequency property
[ 0.071357] /cpus/cpu@1 missing clock-frequency property
[ 0.071378] /cpus/cpu@2 missing clock-frequency property
[ 0.071399] /cpus/cpu@3 missing clock-frequency property
[ 0.0714
[ 5.783183] usbcore: registered new interface driver snd-usb-audio
[ 5.792173] MAX98090 driver built on Oct 31 2019 at 13:50:04
[ 5.800789] tegra_offload_platform probe successfull.
[ 5.808720] succefully registered offload opstegra30_avp_audio_platform_prob*
[ 5.868700] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.868706] win[0]: 0(0) - 80(1)
[ 5.868710] win[1]: 86(0) - 168(1)
[ 5.868714] win[2]: 174(0) - 255(1)
[ 5.868722] ***************************************
[ 5.868739] ********tuning windows after inserting holes*****
[ 5.868742] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.868746] win[0]:-2(0) - 47(2)
[ 5.868750] win[1]:49(2) - 80(1)
[ 5.868754] win[2]:86(0) - 135(2)
[ 5.868758] win[3]:137(2) - 168(1)
[ 5.868761] win[4]:174(0) - 223(2)
[ 5.868765] win[5]:225(2) - 255(1)
[ 5.868768] ***********************************************
[ 5.868772] **********Tuning values*********
[ 5.868775] **estimated values**
[ 5.868779] T2T_Vmax 57, T2T_Vmin 79, 1'st_hole_Vmax 47, UI_Vmax 87
[ 5.868782] **Calculated values**
[ 5.868785] T2T_Vmax 56, 1'st_hole_Vmax 48, UI_Vmax 88
[ 5.868789] T2T_Vmin 56, 1'st_hole_Vmin 48, UI_Vmin 89
[ 5.868791] ***********************************
[ 5.868798] ***********final tuning windows**********
[ 5.868801] win[0]: 15 - 37
[ 5.868804] win[1]: 60 - 63
[ 5.868807] win[2]: 103 - 120
[ 5.868810] win[3]: 154 - 151
[ 5.868813] win[4]: 191 - 203
[ 5.868816] win[5]: 248 - 238
[ 5.868818] ********************************
[ 5.868823] best tap win - (15-37), best tap value 26 prev_best_tap 0
[ 6.084086] rt5639 0-001c: read 0xfd=0x6
[ 6.104585] rt5639 0-001c: ASoC: mux INR Mux has no paths
[ 6.111343] rt5639 0-001c: ASoC: mux INL Mux has no paths
[ 6.118700] gpio wake49 for gpio=143
[ 6.412244] **********Auto tuning windows*************
[ 6.418686] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 6.425475] win[0]: 0(0) - 80(1)
[ 6.430021] win[1]: 87(0) - 167(1)
[ 6.434750] win[2]: 175(0) - 255(1)
[ 6.439569] ***************************************
[ 6.445846] ********tuning windows after inserting holes*****
[ 6.453030] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 6.459960] win[0]:-87(0) - -1(1)
[ 6.464709] win[1]:0(0) - 0(1)
[ 6.469182] win[2]:1(0) - 46(2)
[ 6.473691] win[3]:48(2) - 80(1)
[ 6.478242] win[4]:87(0) - 133(2)
[ 6.482852] win[5]:135(2) - 167(1)
[ 6.487562] win[6]:175(0) - 220(2)
[ 6.492234] win[7]:222(2) - 255(1)
[ 6.496888] ***********************************************
[ 6.503753] **********Tuning values*********
[ 6.509335] **estimated values**
[ 6.513891] T2T_Vmax 57, T2T_Vmin 79, 1'st_hole_Vmax 47, UI_Vmax 87
[ 6.521585] **Calculated values**
[ 6.526349] T2T_Vmax 57, 1'st_hole_Vmax 47, UI_Vmax 87
[ 6.533007] T2T_Vmin 57, 1'st_hole_Vmin 47, UI_Vmin 87
[ 6.539637] ***********************************
[ 6.545647] ***********final tuning windows**********
[ 6.552136] win[0]: -70 - -18
[ 6.556531] win[1]: 17 - -17
[ 6.560800] win[2]: 18 - 37
[ 6.564988] win[3]: 58 - 63
[ 6.569129] win[4]: 104 - 118
[ 6.573414] win[5]: 151 - 150
[ 6.577644] win[6]: 192 - 199
[ 6.581825] win[7]: 244 - 238
[ 6.585997] ********************************
[ 6.591513] best tap win - (18-37), best tap value 27 prev_best_tap 26
[ 6.599345] sdhci-tegra sdhci-tegra.3: sdhci_tegra_verify_best_tap: tuning f7
[ 6.613952] mmc0: new HS200 MMC card at address 0001
[ 6.620482] mmcblk mmc0:0001: Card claimed for testing.
[ 6.627261] mmcblk0: mmc0:0001 SEM16G 14.6 GiB
[ 6.633352] mmcblk0rpmb: mmc0:0001 SEM16G partition 3 4.00 MiB
[ 6.643195] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 7.125567] rt5639 0-001c: rt5639_headset_detect RT5639_PWR_ANLG1(0x63) = 0x4
[ 7.136312] rt5639 0-001c: rt5639_headset_detect RT5639_IRQ_CTRL2(0xbe) = 0x0
[ 7.207426] rt5639 0-001c: rt5639_headset_detect jack_type = 2
[ 7.215299] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2k
[ 7.227751] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-spdifk
[ 7.240105] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-i2s.3k
[ 7.252657] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> dit-hifi mk
[ 7.265212] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> dit-hifi mappk
[ 7.277634] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playbk
[ 7.289473] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream captue
[ 7.301569] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegrk
[ 7.316374] compress asoc: snd-soc-dummy-dai <-> tegra-offload-compr mappingk
[ 7.329642] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playbk
[ 7.342315] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream captue
[ 7.355025] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegrk
[ 7.370289] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2k
[ 7.388039] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-sn0
[ 7.404419] sysedp_create_consumer: unable to create speaker, no consumer_dad
[ 7.416764] oprofile: using timer interrupt.
[ 7.427051] GACT probability NOT on
[ 7.433361] Mirror/redirect action on
[ 7.439778] u32 classifier
[ 7.445167] Actions configured
[ 7.451232] Netfilter messages via NETLINK v0.30.
[ 7.458600] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 7.467730] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 7.477329] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 7.486004] xt_time: kernel timezone is -0000
[ 7.493171] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.501168] arp_tables: (C) 2002 David S. Miller
[ 7.508274] TCP: cubic registered
[ 7.514158] NET: Registered protocol family 10
[ 7.521850] mip6: Mobile IPv6
[ 7.527150] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 7.534974] sit: IPv6 over IPv4 tunneling driver
[ 7.542835] NET: Registered protocol family 17
[ 7.549546] NET: Registered protocol family 15
[ 7.556184] NET: Registered protocol family 35
[ 7.562781] NET: Registered protocol family 37
[ 7.569183] NET: Registered protocol family 41
[ 7.576842] VFP support v0.3: implementor 41 architecture 4 part 30 variant 0
[ 7.611757] Registering SWP/SWPB emulation handler
[ 7.618396] last reset is due to software reset
[ 7.618396]
[ 7.627876] Disabling clocks left on by bootloader:
[ 7.634421] audio_2x
[ 7.638482] audio
[ 7.642237] audio4
[ 7.646032] audio3
[ 7.649826] audio2
[ 7.653564] audio1
[ 7.657274] audio0
[ 7.661020] hdmi_audio
[ 7.664989] entropy
[ 7.668637] dsi2-fixed
[ 7.672518] dsi1-fixed
[ 7.676333] nor
[ 7.679475] trace
[ 7.682749] sdmmc4_ddr
[ 7.686429] sdmmc3_ddr
[ 7.690105] cclk_lp
[ 7.693485] pll_x_out0
[ 7.697057] pll_u_12M
[ 7.700500] pll_m_out1
[ 7.704114] tegra_dvfs: vdd_cpu connected to regulator
[ 7.710257] tegra_dvfs: vdd_core connected to regulator
[ 7.716562] tegra_dvfs: vdd_gpu connected to regulator
[ 7.724026] cpu_cold cooling device is registered
[ 7.729945] cpu_hot cooling device is registered
[ 7.730022] Tegra CPU DFLL is initialized with use_dfll = 1
[ 7.730086] CPU rate: 696 MHz
[ 7.905398] tegra dvfs: tegra sysfs cap interface is initialized
[ 7.912376] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 7.920329] tegra_actmon.emc: Completed initialization (0)
[ 7.926927] tegra_actmon.avp: Completed initialization (0)
[ 7.933397] tegra_mon.cpu_emc: Completed initialization (0)
[ 7.942512] reg-aon-1v2: incomplete constraints, leaving on
[ 7.949052] reg-aon-1v8: incomplete constraints, leaving on
[ 7.955635] sdmmc-en-supply: incomplete constraints, leaving on
[ 7.962567] reg-dcdc-1v2: incomplete constraints, leaving on
[ 7.969329] reg-5v0-supply: incomplete constraints, leaving on
[ 7.976273] usb0-vbus: incomplete constraints, leaving on
[ 7.982892] vpp-fuse: incomplete constraints, leaving on
[ 7.989391] vdd-2v7-cam: incomplete constraints, leaving on
[ 7.996250] avdd-spi: incomplete constraints, leaving on
[ 8.003017] vdd-1v1-cam: incomplete constraints, leaving on
[ 8.009938] vddio-sdmmc-2: incomplete constraints, leaving on
[ 8.017075] vdd-1v2-cam: incomplete constraints, leaving on
[ 8.024070] avdd-cam: incomplete constraints, leaving on
[ 8.030855] vdd-cam: incomplete constraints, leaving on
[ 8.037585] as3722-sd3: incomplete constraints, leaving on
[ 8.044615] vdd-3v3-aon: incomplete constraints, leaving on
[ 8.051778] vdd-ac-bat: incomplete constraints, leaving on
[ 8.058891] regulator-dummy: incomplete constraints, leaving on
[ 8.067117] gpio wake51 for gpio=128
[ 8.072582] input: gpio-keys.4 as /devices/platform/gpio-keys.4/input/input1
[ 8.082101] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 01:2)
[ 8.095019] ALSA device list:
[ 8.099440] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 8.106299] #1: tegra-rt5639
[ 8.111849] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incoms
[ 8.123592] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incoms
[ 8.139753] JBD2: Unrecognised features on journal
[ 8.146317] EXT4-fs (mmcblk0p1): error loading journal
[ 8.154397] List of all partitions:
[ 8.159612] b300 15388672 mmcblk0 driver: mmcblk
[ 8.166757] b301 14929920 mmcblk0p1 7369c667-ff51-ec4a-29cd-baabf2f6
[ 8.177994] b302 4096 mmcblk0p2 f854c27c-e81b-8de7-765a-2e63339a
[ 8.189109] b303 65536 mmcblk0p3 b70d3266-5831-5aa3-255d-051758e4
[ 8.200307] b304 4096 mmcblk0p4 c6cdb2ab-b49b-1154-0e82-74412137
[ 8.211601] b305 4096 mmcblk0p5 a13ee970-e141-67fc-3e01-7e97ead6
[ 8.222944] b306 4096 mmcblk0p6 2a5c388f-b0ec-fb3b-32af-3c54ec1c
[ 8.234465] b307 4096 mmcblk0p7 43fe1a02-fafb-3aaa-fb29-d1e60534
[ 8.246053] b308 2048 mmcblk0p8 61bed875-f989-bb5c-a899-0f95b1e3
[ 8.257650] b309 321536 mmcblk0p9 00f7ef05-a1e9-e53a-ca0b-cbd0484d
[ 8.269315] b310 4096 mmcblk0rpmb (driver?)
[ 8.276730] No filesystem could mount root, tried: ext3 ext2 ext4 vfat ntfsk
[ 8.288898] Kernel panic - not syncing: VFS: Unable to mount root fs le_call)
[ 9.492893] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.492901] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.492904] ---[ end trace 93f1712e5671427b ]---
[ 9.492910] bad: scheduling from the idle thread!
[ 9.492914] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.492924] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.492934] [<c0013260>] (show_stack+0x18/0x1c) from [<c00a41bc>] (dequeue_t)
[ 9.492945] [<c00a41bc>] (dequeue_task_idle+0x24/0x30) from [<c009d2d8>] (de)
[ 9.492957] [<c009d2d8>] (dequeue_task+0xd0/0xf0) from [<c08227dc>] (__sched)
[ 9.492967] [<c08227dc>] (__schedule+0x4f8/0x764) from [<c08208f0>] (schedul)
[ 9.492977] [<c08208f0>] (schedule_timeout+0x130/0x238) from [<c00792c8>] (m)
[ 9.492986] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.492996] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.493004] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.493012] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.493016] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.493022] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.493028] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.493031] df00: 20000113 ffffffff
[ 9.493042] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.493052] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.493062] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.493071] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.493082] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.493093] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.493102] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.493110] ------------[ cut here ]------------
[ 9.493117] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel/timer.)
[ 9.493120] Modules linked in:
[ 9.493125] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.493135] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.493145] [<c0013260>] (show_stack+0x18/0x1c) from [<c00683d0>] (warn_slow)
[ 9.493156] [<c00683d0>] (warn_slowpath_common+0x54/0x70) from [<c0068410>] )
[ 9.493166] [<c0068410>] (warn_slowpath_null+0x24/0x2c) from [<c00791c8>] (d)
[ 9.493177] [<c00791c8>] (del_timer_sync+0x4c/0x74) from [<c08208f8>] (sched)
[ 9.493187] [<c08208f8>] (schedule_timeout+0x138/0x238) from [<c00792c8>] (m)
[ 9.493196] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.493205] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.493213] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.493223] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.493226] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.493232] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.493238] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.493241] df00: 20000113 ffffffff
[ 9.493252] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.493262] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.493272] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.493281] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.493293] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.493304] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.493312] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.493315] ---[ end trace 93f1712e5671427c ]---
[ 9.493320] bad: scheduling from the idle thread!
[ 9.493325] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.493335] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.493344] [<c0013260>] (show_stack+0x18/0x1c) from [<c00a41bc>] (dequeue_t)
[ 9.493355] [<c00a41bc>] (dequeue_task_idle+0x24/0x30) from [<c009d2d8>] (de)
[ 9.493367] [<c009d2d8>] (dequeue_task+0xd0/0xf0) from [<c08227dc>] (__sched)
[ 9.493378] [<c08227dc>] (__schedule+0x4f8/0x764) from [<c08208f0>] (schedul)
[ 9.493387] [<c08208f0>] (schedule_timeout+0x130/0x238) from [<c00792c8>] (m)
[ 9.493397] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.493406] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.493414] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.493423] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.493426] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.493432] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.493438] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.493442] df00: 20000113 ffffffff
[ 9.493451] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.493461] [<c003ecec>] (tegra_idle[ 9.495482] dee0: ee28df08 c0d2a1e0 cc
[ 9.495485] df00: 20000113 ffffffff
[ 9.495495] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.495505] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.495515] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.495525] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.495536] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.495547] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.495555] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.495563] ------------[ cut here ]------------
[ 9.495570] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel/timer.)
[ 9.495574] Modules linked in:
[ 9.495578] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.495588] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.495599] [<c0013260>] (show_stack+0x18/0x1c) from [<c00683d0>] (warn_slow)
[ 9.495610] [<c00683d0>] (warn_slowpath_common+0x54/0x70) from [<c0068410>] )
[ 9.495620] [<c0068410>] (warn_slowpath_null+0x24/0x2c) from [<c00791c8>] (d)
[ 9.495631] [<c00791c8>] (del_timer_sync+0x4c/0x74) from [<c08208f8>] (sched)
[ 9.495640] [<c08208f8>] (schedule_timeout+0x138/0x238) from [<c00792c8>] (m)
[ 9.495649] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.495658] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.495666] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.495675] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.495678] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.495685] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.495691] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.495694] df00: 20000113 ffffffff
[ 9.495704] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.495714] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.495724] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.495734] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.495745] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.495756] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.495764] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.495767] ---[ end trace 93f1712e56714282 ]---
[ 9.495772] bad: scheduling from the idle thread!
[ 9.495777] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.495787] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.495796] [<c0013260>] (show_stack+0x18/0x1c) from [<c00a41bc>] (dequeue_t)
[ 9.495807] [<c00a41bc>] (dequeue_task_idle+0x24/0x30) from [<c009d2d8>] (de)
[ 9.495820] [<c009d2d8>] (dequeue_task+0xd0/0xf0) from [<c08227dc>] (__sched)
[ 9.495831] [<c08227dc>] (__schedule+0x4f8/0x764) from [<c08208f0>] (schedul)
[ 9.495840] [<c08208f0>] (schedule_timeout+0x130/0x238) from [<c00792c8>] (m)
[ 9.495850] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.495859] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.495867] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.495876] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.495879] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.495885] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.495891] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.495894] df00: 20000113 ffffffff
[ 9.495905] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.495914] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.495924] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.495934] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.495945] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.495956] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.495964] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.495973] ------------[ cut here ]------------
[ 9.495980] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel/timer.)
[ 9.495983] Modules linked in:
[ 9.495988] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.495998] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.496008] [<c0013260>] (show_stack+0x18/0x1c) from [<c00683d0>] (warn_slow)
[ 9.496020] [<c00683d0>] (warn_slowpath_common+0x54/0x70) from [<c0068410>] )
[ 9.496029] [<c0068410>] (warn_slowpath_null+0x24/0x2c) from [<c00791c8>] (d)
[ 9.496040] [<c00791c8>] (del_timer_sync+0x4c/0x74) from [<c08208f8>] (sched)
[ 9.496049] [<c08208f8>] (schedule_timeout+0x138/0x238) from [<c00792c8>] (m)
[ 9.496058] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.498075] [<c0068410>] (warn_slowpath_null+0x24/0x2c) from [<c00791c8>] (d)
[ 9.498085] [<c00791c8>] (del_timer_sync+0x4c/0x74) from [<c08208f8>] (sched)
[ 9.498095] [<c08208f8>] (schedule_timeout+0x138/0x238) from [<c00792c8>] (m)
[ 9.498104] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.498113] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.498121] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.498130] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.498133] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.498139] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.498145] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.498149] df00: 20000113 ffffffff
[ 9.498159] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.498169] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.498179] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.498189] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.498200] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.498211] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.498219] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.498222] ---[ end trace 93f1712e56714288 ]---
[ 9.498227] bad: scheduling from the idle thread!
[ 9.498232] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.498242] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.498251] [<c0013260>] (show_stack+0x18/0x1c) from [<c00a41bc>] (dequeue_t)
[ 9.498262] [<c00a41bc>] (dequeue_task_idle+0x24/0x30) from [<c009d2d8>] (de)
[ 9.498274] [<c009d2d8>] (dequeue_task+0xd0/0xf0) from [<c08227dc>] (__sched)
[ 9.498285] [<c08227dc>] (__schedule+0x4f8/0x764) from [<c08208f0>] (schedul)
[ 9.498295] [<c08208f0>] (schedule_timeout+0x130/0x238) from [<c00792c8>] (m)
[ 9.498304] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.498313] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.498321] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.498330] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.498333] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.498339] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.498345] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.498348] df00: 20000113 ffffffff
[ 9.498359] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.498368] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.498379] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.498388] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.498399] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.498410] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.498418] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.498426] ------------[ cut here ]------------
[ 9.498433] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel/timer.)
[ 9.498437] Modules linked in:
[ 9.498441] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.498451] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.498462] [<c0013260>] (show_stack+0x18/0x1c) from [<c00683d0>] (warn_slow)
[ 9.498473] [<c00683d0>] (warn_slowpath_common+0x54/0x70) from [<c0068410>] )
[ 9.498483] [<c0068410>] (warn_slowpath_null+0x24/0x2c) from [<c00791c8>] (d)
[ 9.498494] [<c00791c8>] (del_timer_sync+0x4c/0x74) from [<c08208f8>] (sched)
[ 9.498503] [<c08208f8>] (schedule_timeout+0x138/0x238) from [<c00792c8>] (m)
[ 9.498512] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.498521] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.498529] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.498538] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.498541] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.498547] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.498553] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.498556] df00: 20000113 ffffffff
[ 9.498566] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.498576] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.498586] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.498596] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.498607] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.498618] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.498626] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.498629] ---[ end trace 93f1712e56714289 ]---
[ 9.498634] bad: scheduling from the if00: 20000113 ffffffff
[ 9.500616] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.500626] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.500636] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.500646] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.500657] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.500668] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.500676] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.500680] ---[ end trace 93f1712e5671428e ]---
[ 9.500685] bad: scheduling from the idle thread!
[ 9.500690] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.500700] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.500709] [<c0013260>] (show_stack+0x18/0x1c) from [<c00a41bc>] (dequeue_t)
[ 9.500720] [<c00a41bc>] (dequeue_task_idle+0x24/0x30) from [<c009d2d8>] (de)
[ 9.500733] [<c009d2d8>] (dequeue_task+0xd0/0xf0) from [<c08227dc>] (__sched)
[ 9.500743] [<c08227dc>] (__schedule+0x4f8/0x764) from [<c08208f0>] (schedul)
[ 9.500753] [<c08208f0>] (schedule_timeout+0x130/0x238) from [<c00792c8>] (m)
[ 9.500763] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.500772] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.500780] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.500790] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.500792] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.500799] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.500805] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.500808] df00: 20000113 ffffffff
[ 9.500819] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.500828] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.500839] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.500849] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.500860] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.500870] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.500878] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.500886] ------------[ cut here ]------------
[ 9.500893] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel/timer.)
[ 9.500897] Modules linked in:
[ 9.500902] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.500912] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.500922] [<c0013260>] (show_stack+0x18/0x1c) from [<c00683d0>] (warn_slow)
[ 9.500933] [<c00683d0>] (warn_slowpath_common+0x54/0x70) from [<c0068410>] )
[ 9.500943] [<c0068410>] (warn_slowpath_null+0x24/0x2c) from [<c00791c8>] (d)
[ 9.500954] [<c00791c8>] (del_timer_sync+0x4c/0x74) from [<c08208f8>] (sched)
[ 9.500964] [<c08208f8>] (schedule_timeout+0x138/0x238) from [<c00792c8>] (m)
[ 9.500973] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.500983] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.500991] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.501000] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 9.501004] Exception stack(0xee28dec0 to 0xee28df08)
[ 9.501010] dec0: ee28df10 00000000 00000000 000f4240 00021329 00000000 00008
[ 9.501016] dee0: ee28df08 c0d2a1e0 c1e0e3e8 c08356e0 3b9ac9ff ee28df08 c02cc
[ 9.501020] df00: 20000113 ffffffff
[ 9.501030] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 9.501040] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 9.501050] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 9.501060] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 9.501071] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 9.501082] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 9.501090] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 9.501094] ---[ end trace 93f1712e5671428f ]---
[ 9.501099] bad: scheduling from the idle thread!
[ 9.501104] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W 3.10.40-ge11
[ 9.501114] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 9.501123] [<c0013260>] (show_stack+0x18/0x1c) from [<c00a41bc>] (dequeue_t)
[ 9.501134] [<c00a41bc>] (dequeue_task_idle+0x24/0x30) from [<c009d2d8>] (de)
[ 9.501147] [<c009d2d8>] (dequeue_task+0xd0/0xf0) from [<c08227dc>] (__sched)
[ 9.501158] [<c08227dc>] (__schedule+0x4f8/0x764) from [<c08208f0>] (schedul)
[ 9.501168] [<c08208f0>] (schedule_timeout+0x130/0x238) from [<c00792c8>] (m)
[ 9.501177] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 9.501186] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 9.501195] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 9.50120
[ 26.873051] [<c0015864>] (handle_IPI+0x178/0x1a8) from [<c000853)
[ 26.886579] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 26.899902] Exception stack(0xee289ec0 to 0xee289f08)
[ 26.907398] 9ec0: ee289f10 00000000 00000000 000f4240 0002130e 00000000 00008
[ 26.920415] 9ee0: ee289f08 c0d2a1e0 c1dfc3e8 c08356e0 3b9ac9ff ee289f08 c02cc
[ 26.933530] 9f00: 20000113 ffffffff
[ 26.939454] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 26.953962] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 26.969441] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 26.984129] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 26.998727] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 27.012714] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 27.026258] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 27.038732] CPU2: stopping
[ 27.038737] BUG: scheduling while atomic: swapper/1/0/0x00010002
[ 27.040138] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 27.054146] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 27.067607] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 27.082242] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W 3.10.40-ge11
[ 27.095175] [<c00791c8>] (del_timer_sync+0x4c/0x74) from [<c08208f8>] (sched)
[ 27.109178] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 27.122657] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 27.136237] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 27.150915] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 27.164403] ---[ end trace 93f1712e5671435a ]---
[ 27.171499] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 27.185026] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 27.198318] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 27.211859] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 27.225390] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 27.238785] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 27.252927] [<c05c5a24>] (cpuidle_enter_state+0x48/0x104) from [<c05c5c38>] )
[ 27.267744] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 27.283419] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 27.297146] bad: scheduling from the idle thread!
[ 27.304369] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 27.317959] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 27.331679] [<c08208f8>] (schedule_timeout+0x138/0x238) from [<c00792c8>] (m)
[ 27.345089] [<c05c5c38>] (cpuidle_idle_call+0x158/0x298) from [<c0010118>] ()
[ 27.359220] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 27.374094] [<c0016900>] (unwind_backtrace+0x0/0x140) from [<c0013260>] (sho)
[ 27.387744] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 27.402739] [<c0008530>] (gic_handle_irq+0x7c/0x160) from [<c000ed40>] (__ir)
[ 27.416193] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 27.429952] [<c0015848>] (handle_IPI+0x15c/0x1a8) from [<c0008530>] (gic_han)
[ 27.443738] 9ee0: ee289f08 c0d2a1e0 c1dfc3e8 c08356e0 3b9ac9ff ee289f08 c02cc
[ 27.457000] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 27.470219] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 27.482844] [<c003ecec>] (tegra_idle_enter_clock_gating+0x6c/0x7c) from [<c0)
[ 27.498581] ---[ end trace 93f1712e56714569 ]---
[ 27.505732] [<c00b70b4>] (cpu_idle_loop+0x9c/0x23c) from [<8081cb64>] (0x808)
[ 27.518321] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 27.533273] [<c08208f8>] (schedule_timeout+0x138/0x238) from [<c00792c8>] (m)
[ 27.546767] [<c08208f0>] (schedule_timeout+0x130/0x238) from [<c00792c8>] (m)
[ 27.560276] [<c00792c8>] (msleep+0x1c/0x28) from [<c003e608>] (tegra_cpu_kil)
[ 27.573443] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 27.588431] [<c003e608>] (tegra_cpu_kill+0x90/0x148) from [<c0015848>] (hand)
[ 27.602174] [<c003ea78>] (tegra_idle_enter_pd+0x58/0x260) from [<c05c5a24>] )
[ 27.617075] [<c0822a08>] (__schedule+0x724/0x764) from [<c08208f0>] (schedul)
[ 27.631063] Exception stack(0xee289ec0 to 0xee289f08)
[ 27.638654] [<c08208f0>] (schedule_timeout+0x130/0x238) from [<c00792c8>] (m)
[ 27.652075] [<c0010118>] (arch_cpu_idle+0x10/0x40) from [<c00b70b4>] (cpu_id)
[ 27.665767] [<c000ed40>] (__irq_svc+0x40/0x70) from [<c003ecec>] (tegra_idle)
[ 27.680426] ---[ end trace 93f1712e56714688 ]---
[ 27.687509] Exception stack(0xee289ec0 to 0xee289f08)
[ 27.695018] ---[ end trace 93f1712e5671469f ]---
[ 27.702061] [<c0822a08>] (__schedule+0x724/0x764) from [<c08208f0>] (schedul)
[ 27.715855] 9ec0: ee289f10 00000000 00000000 000f4240 0002130e 00000000 00008
[ 27.728870] [<c009d2d8>] (
