Recently had a USB port “crash” (Port 2-3 to be exact). Alternating to the other port it still worked. Here is the dmesg log showing a specific tegra-xusb error when moving two cameras between the usb ports.
[ 1324.459403] usb 1-1: USB disconnect, device number 3
[ 1324.478704] ucsi_ccg 1-0008: port0 evt: Type-C Port Disconnect Detected
[ 1324.480728] ucsi_ccg 1-0008: [typec-port0] Cable state:0, cable id:2
[ 1324.602325] usb usb1: usb_suspend_both: status 0
[ 1326.990379] ucsi_ccg 1-0008: port0 evt: Type-C Port Connect Detected
[ 1326.992212] ucsi_ccg 1-0008: [typec-port0] Cable state:1, cable id:2
[ 1332.053669] ucsi_ccg 1-0008: port1 evt: Type-C Port Disconnect Detected
[ 1332.055489] ucsi_ccg 1-0008: [typec-port1] Cable state:0, cable id:2
[ 1332.135929] usb 2-1: USB disconnect, device number 2
[ 1332.281242] usb usb2: usb_suspend_both: status 0
[ 1332.281257] tegra-xusb 3610000.xhci: entering ELPG
[ 1332.281276] tegra-xusb 3610000.xhci: 2-3 is not suspended: 0a000302
[ 1332.281281] tegra-xusb 3610000.xhci: entering ELPG failed
[ 1334.941961] ucsi_ccg 1-0008: port0 evt: Source Disabled State Entered
[ 1343.696363] ucsi_ccg 1-0008: port1 evt: Type-C Port Connect Detected
[ 1343.698183] ucsi_ccg 1-0008: [typec-port1] Cable state:1, cable id:2
[ 1347.597370] usb 2-1: new SuperSpeed USB device number 3 using tegra-xusb
[ 1347.618886] usb 2-1: New USB device found, idVendor=1e10, idProduct=4000
[ 1347.618912] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1347.618916] usb 2-1: Product: Blackfly S BFS-U3-50S5C
[ 1347.618920] usb 2-1: Manufacturer: FLIR
[ 1347.618924] usb 2-1: SerialNumber: 01277BB7
[ 1351.650276] ucsi_ccg 1-0008: port1 evt: Source Disabled State Entered
[ 1640.082944] ucsi_ccg 1-0008: port1 evt: Type-C Port Disconnect Detected
[ 1640.084762] ucsi_ccg 1-0008: [typec-port1] Cable state:0, cable id:2
[ 1640.141570] usb 2-1: USB disconnect, device number 3
[ 1640.285710] usb usb2: usb_suspend_both: status 0
[ 1640.285724] tegra-xusb 3610000.xhci: entering ELPG
[ 1640.285743] tegra-xusb 3610000.xhci: 2-3 is not suspended: 0a000302
[ 1640.285748] tegra-xusb 3610000.xhci: entering ELPG failed
[ 1642.985569] ucsi_ccg 1-0008: port1 evt: Type-C Port Connect Detected
[ 1642.987415] ucsi_ccg 1-0008: [typec-port1] Cable state:1, cable id:2
[ 1646.875107] usb 2-1: new SuperSpeed USB device number 4 using tegra-xusb
[ 1646.896669] usb 2-1: New USB device found, idVendor=1e10, idProduct=4000
[ 1646.896678] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1646.896682] usb 2-1: Product: Blackfly S BFS-U3-50S5C
[ 1646.896685] usb 2-1: Manufacturer: FLIR
[ 1646.896689] usb 2-1: SerialNumber: 01277BB7
[ 1650.933270] ucsi_ccg 1-0008: port1 evt: Source Disabled State Entered
[ 1723.589502] ucsi_ccg 1-0008: port1 evt: Type-C Port Disconnect Detected
[ 1723.591324] ucsi_ccg 1-0008: [typec-port1] Cable state:0, cable id:2
[ 1723.686078] usb 2-1: USB disconnect, device number 4
[ 1723.828812] usb usb2: usb_suspend_both: status 0
[ 1723.828828] tegra-xusb 3610000.xhci: entering ELPG
[ 1723.828864] tegra-xusb 3610000.xhci: 2-3 is not suspended: 0a000302
[ 1723.828868] tegra-xusb 3610000.xhci: entering ELPG failed
[ 1737.424004] ucsi_ccg 1-0008: port1 evt: Type-C Port Connect Detected
[ 1737.425830] ucsi_ccg 1-0008: [typec-port1] Cable state:1, cable id:2
[ 1741.320540] usb 2-1: new SuperSpeed USB device number 5 using tegra-xusb
[ 1741.342065] usb 2-1: New USB device found, idVendor=1e10, idProduct=4000
[ 1741.342072] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1741.342094] usb 2-1: Product: Blackfly S BFS-U3-50S5C
[ 1741.342098] usb 2-1: Manufacturer: FLIR
[ 1741.342101] usb 2-1: SerialNumber: 01277BB7
[ 1745.384278] ucsi_ccg 1-0008: port1 evt: Source Disabled State Entered
[ 1811.714757] ucsi_ccg 1-0008: port0 evt: Type-C Port Disconnect Detected
[ 1811.716779] ucsi_ccg 1-0008: [typec-port0] Cable state:0, cable id:2
[ 1814.209624] ucsi_ccg 1-0008: port1 evt: Type-C Port Disconnect Detected
[ 1814.210846] usb 2-1: USB disconnect, device number 5
[ 1814.211445] ucsi_ccg 1-0008: [typec-port1] Cable state:0, cable id:2
[ 1814.354874] usb usb2: usb_suspend_both: status 0
[ 1814.354888] tegra-xusb 3610000.xhci: entering ELPG
[ 1814.354905] tegra-xusb 3610000.xhci: 2-3 is not suspended: 0a000302
[ 1814.354909] tegra-xusb 3610000.xhci: entering ELPG failed
[ 1829.695666] ucsi_ccg 1-0008: port1 evt: Type-C Port Connect Detected
[ 1829.697542] ucsi_ccg 1-0008: [typec-port1] Cable state:1, cable id:2
[ 1833.610297] usb 2-1: new SuperSpeed USB device number 6 using tegra-xusb
[ 1833.631911] usb 2-1: New USB device found, idVendor=1e10, idProduct=4000
[ 1833.631918] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1833.631923] usb 2-1: Product: Blackfly S BFS-U3-50S5C
[ 1833.631926] usb 2-1: Manufacturer: FLIR
[ 1833.631929] usb 2-1: SerialNumber: 01277BB5
[ 1837.673408] ucsi_ccg 1-0008: port1 evt: Source Disabled State Entered
[ 1840.464740] ucsi_ccg 1-0008: port0 evt: Type-C Port Connect Detected
[ 1840.466622] ucsi_ccg 1-0008: [typec-port0] Cable state:1, cable id:2
[ 1848.438934] ucsi_ccg 1-0008: port0 evt: Source Disabled State Entered
[ 1880.342922] ucsi_ccg 1-0008: port0 evt: Type-C Port Disconnect Detected
[ 1880.344810] ucsi_ccg 1-0008: [typec-port0] Cable state:0, cable id:2
[ 1882.798204] ucsi_ccg 1-0008: port1 evt: Type-C Port Disconnect Detected
[ 1882.800093] ucsi_ccg 1-0008: [typec-port1] Cable state:0, cable id:2
[ 1882.878750] usb 2-1: USB disconnect, device number 6
[ 1883.024220] usb usb2: usb_suspend_both: status 0
[ 1883.024237] tegra-xusb 3610000.xhci: entering ELPG
[ 1883.024257] tegra-xusb 3610000.xhci: 2-3 is not suspended: 0a000302
[ 1883.024262] tegra-xusb 3610000.xhci: entering ELPG failed
[ 1890.384463] ucsi_ccg 1-0008: port1 evt: Type-C Port Connect Detected
[ 1890.386255] ucsi_ccg 1-0008: [typec-port1] Cable state:1, cable id:2
[ 1894.276909] usb 2-1: new SuperSpeed USB device number 7 using tegra-xusb
[ 1894.298556] usb 2-1: New USB device found, idVendor=1e10, idProduct=4000
[ 1894.298580] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1894.298586] usb 2-1: Product: Blackfly S BFS-U3-50S5C
[ 1894.298589] usb 2-1: Manufacturer: FLIR
[ 1894.298593] usb 2-1: SerialNumber: 01277BB7
[ 1898.369804] ucsi_ccg 1-0008: port1 evt: Source Disabled State Entered
[ 1900.777900] ucsi_ccg 1-0008: port0 evt: Type-C Port Connect Detected
[ 1900.779730] ucsi_ccg 1-0008: [typec-port0] Cable state:1, cable id:2
[ 1908.760844] ucsi_ccg 1-0008: port0 evt: Source Disabled State Entered
Any assistance would be good.
