I reflashed rel 34. It doesn’t work. I also flashed back to rel32.7.2, jetpack 4.6.2. Two USB C are still not working. But the errors showing in rel34 are not there any more. vdd-usb-3v3- is now “at 3300mV”. The output of command dmesg | grep usb of rel32 is this:
[ 0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 nv-auto-config video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x140000@0xa06ab000 lut_mem=0x2008@0xa06a6000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[ 0.975151] usbcore: registered new interface driver usbfs
[ 0.975219] usbcore: registered new interface driver hub
[ 0.975295] usbcore: registered new device driver usb
[ 1.073487] vdd-usb-3v3: at 3300 mV
[ 4.620464] usbcore: registered new interface driver r8152
[ 4.620501] usbcore: registered new interface driver asix
[ 4.620529] usbcore: registered new interface driver ax88179_178a
[ 4.620553] usbcore: registered new interface driver cdc_ether
[ 4.620577] usbcore: registered new interface driver net1080
[ 4.620602] usbcore: registered new interface driver cdc_subset
[ 4.620655] usbcore: registered new interface driver zaurus
[ 4.620722] usbcore: registered new interface driver cdc_ncm
[ 4.627705] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.627709] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 4.633983] usbcore: registered new interface driver uas
[ 4.634021] usbcore: registered new interface driver usb-storage
[ 4.634072] usbcore: registered new interface driver usbserial
[ 4.661480] usbcore: registered new interface driver xpad
[ 5.565603] usbcore: registered new interface driver usbhid
[ 5.570347] usbhid: USB HID core driver
[ 5.654831] usbcore: registered new interface driver snd-usb-audio
[ 9.427728] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 9.427732] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 9.430310] tegra-xusb 3610000.xhci: extcon 0: ffffffc7c7aa4800 id
[ 9.433048] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 9.433089] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 9.433114] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 9.433780] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 9.433805] tegra-xusb 3610000.xhci: irq 474, io mem 0x03610000
[ 9.433933] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.433936] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.433938] usb usb1: Product: xHCI Host Controller
[ 9.433940] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 9.433942] usb usb1: SerialNumber: 3610000.xhci
[ 9.434479] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 9.434485] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 9.434490] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 9.434622] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.434624] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.434627] usb usb2: Product: xHCI Host Controller
[ 9.434642] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 9.434644] usb usb2: SerialNumber: 3610000.xhci
[ 9.435412] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 9.435415] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 9.538876] usb usb1: usb_suspend_both: status 0
[ 9.542881] usb usb2: usb_suspend_both: status 0
[ 10.316887] usb 2-4: new SuperSpeed USB device number 2 using tegra-xusb
[ 10.366609] usb 2-4: New USB device found, idVendor=2109, idProduct=0815
[ 10.368263] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.369736] usb 2-4: Product: USB3.0 Hub
[ 10.371151] usb 2-4: Manufacturer: VIA Labs, Inc.
[ 10.546743] usb 1-4: new high-speed USB device number 2 using tegra-xusb
[ 10.568324] usb 1-4: New USB device found, idVendor=2109, idProduct=2815
[ 10.569889] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.571404] usb 1-4: Product: USB2.0 Hub
[ 10.572882] usb 1-4: Manufacturer: VIA Labs, Inc.
[ 11.055071] usb 2-4.2: new SuperSpeed USB device number 3 using tegra-xusb
[ 11.077689] usb 2-4.2: New USB device found, idVendor=05e3, idProduct=0612
[ 11.077698] usb 2-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.077702] usb 2-4.2: Product: USB3.1 Hub
[ 11.077707] usb 2-4.2: Manufacturer: GenesysLogic
[ 11.206716] usb 2-4.2: usb_suspend_both: status 0
[ 11.290734] usb 2-4: usb_suspend_both: status 0
[ 11.290962] usb usb2: usb_suspend_both: status 0
[ 11.318728] usb 1-4.1: new high-speed USB device number 3 using tegra-xusb
[ 11.339311] usb 1-4.1: New USB device found, idVendor=2357, idProduct=0138
[ 11.339320] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 11.339324] usb 1-4.1: Product: 802.11ac NIC
[ 11.339327] usb 1-4.1: Manufacturer: Realtek
[ 11.339330] usb 1-4.1: SerialNumber: 123456
[ 11.470729] usb 1-4.2: new high-speed USB device number 4 u[ 0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 nv-auto-config video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x140000@0xa06ab000 lut_mem=0x2008@0xa06a6000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[ 11.470729] usb 1-4.2: new high-speed USB device number 4 using tegra-xusb
[ 11.493818] usb 1-4.2: New USB device found, idVendor=05e3, idProduct=0610
[ 11.493826] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.493830] usb 1-4.2: Product: USB2.0 Hub
[ 11.493833] usb 1-4.2: Manufacturer: GenesysLogic
[ 11.630734] usb 1-4.3: new low-speed USB device number 5 using tegra-xusb
[ 11.656325] usb 1-4.3: New USB device found, idVendor=046a, idProduct=0023
[ 11.656333] usb 1-4.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 11.896660] usb0: HOST MAC 72:fd:50:0f:c0:ae
[ 11.896699] usb0: MAC 72:fd:50:0f:c0:af
[ 11.920848] l4tbr0: port 2(usb0) entered blocking state
[ 11.920855] l4tbr0: port 2(usb0) entered disabled state
[ 11.920988] device usb0 entered promiscuous mode
[ 11.925615] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 12.454128] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 12.930727] usb 1-4.2.3: new low-speed USB device number 7 using tegra-xusb
[ 12.956912] usb 1-4.2.3: New USB device found, idVendor=046d, idProduct=c050
[ 12.956920] usb 1-4.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 12.956923] usb 1-4.2.3: Product: USB-PS/2 Optical Mouse
[ 12.956927] usb 1-4.2.3: Manufacturer: Logitech
[ 12.961683] input: Logitech USB-PS/2 Optical Mouse as /devices/3610000.xhci/usb1/1-4/1-4.2/1-4.2.3/1-4.2.3:1.0/0003:046D:C050.0003/input/input6
[ 12.962058] hid-generic 0003:046D:C050.0003: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-3610000.xhci-4.2.3/input0
[ 13.330566] input: HID 046a:0023 as /devices/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.0/0003:046A:0023.0001/input/input7
[ 13.387449] cherry 0003:046A:0023.0001: input,hidraw1: USB HID v1.11 Keyboard [HID 046a:0023] on usb-3610000.xhci-4.3/input0
[ 13.389316] input: HID 046a:0023 as /devices/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046A:0023.0002/input/input8
[ 13.507112] cherry 0003:046A:0023.0002: input,hidraw2: USB HID v1.11 Device [HID 046a:0023] on usb-3610000.xhci-4.3/input1
[ 14.930957] l4tbr0: port 2(usb0) entered blocking state
[ 14.930963] l4tbr0: port 2(usb0) entered forwarding state
[ 88.983933] l4tbr0: port 2(usb0) entered disabled state
[ 90.380393] device usb0 left promiscuous mode
[ 90.380425] l4tbr0: port 2(usb0) entered disabled state
[ 93.103511] usb0: HOST MAC 72:fd:50:0f:c0:ae
[ 93.103621] usb0: MAC 72:fd:50:0f:c0:af
[ 93.119440] l4tbr0: port 2(usb0) entered blocking state
[ 93.119446] l4tbr0: port 2(usb0) entered disabled state
[ 93.119746] device usb0 entered promiscuous mode
[ 93.124556] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 93.539228] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 96.082634] l4tbr0: port 2(usb0) entered blocking state
[ 96.082642] l4tbr0: port 2(usb0) entered forwarding state
[ 184.513938] l4tbr0: port 2(usb0) entered disabled state
sing tegra-xusb
I am concerned about these lines. They show when I connect my host laptop to jetson via the front USB C.
One thing to note is that I can flash jetson via the front USB -C. My laptop can detect jetson when connect to it via usb-c, but meanwhile, jetson cannot detect any changes in the USB connection.
The full dmesg boot log and device tree of rel32 are attached.
boot_rel32.log (1.8 MB)
devicetree_rel32.dts (359.5 KB)
dmesg_rel32.log (166.6 KB)
