Hi
1)There are two TX1 take same mac addr as 00:90:4c:16:70:01.
2)AS I konw, wifi/ble MAC should read from eeprom; how to config dts? which one to config.
ALL of my system is base on tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
3) wifi-config-check.sh seemed not work which from https://devtalk.nvidia.com/default/topic/925629/?comment=4840077
"This utility is for Jetson-TX1 only."
"Usage on any other platform can cause system damage. Exiting."
- command “sudo i2cdump -y 7 0x50” was also not worked from https://devtalk.nvidia.com/default/topic/1031379/?comment=5247713
root@tegra-ubuntu:/home/nvidia# i2cdump -y 7 0x50
No size specified (using byte-data access)
Error: Could not open file `/dev/i2c-7' or `/dev/i2c/7': No such file or directory
5)dmesg as follow:
David S. Miller
[ 4.988620] Initializing XFRM netlink socket
[ 4.989441] NET: Registered protocol family 10
[ 4.991014] mip6: Mobile IPv6
[ 4.991048] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.991276] sit: IPv6 over IPv4 tunneling driver
[ 4.992665] NET: Registered protocol family 17
[ 4.992701] NET: Registered protocol family 15
[ 4.992751] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.992800] Key type dns_resolver registered
[ 4.995055] Registered cp15_barrier emulation handler
[ 5.006203] isp 54600000.isp: initialized
[ 5.007773] isp 54680000.isp: initialized
[ 5.014118] clk_cbus_recalc_rate: no gbus parent
[ 5.014133] clk_cbus_round_rate: no gbus parent
[ 5.014136] clk_cbus_round_rate: no gbus parent
[ 5.014150] clk_cbus_recalc_rate: no gbus parent
[ 5.034563] clk_cbus_recalc_rate: no gbus parent
[ 5.034569] clk_cbus_round_rate: no gbus parent
[ 5.034572] clk_cbus_round_rate: no gbus parent
[ 5.034578] clk_cbus_recalc_rate: no gbus parent
[ 5.034603] tegra_dvfs: GPU-cap: registered
[ 5.034786] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 5.034790] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 5.034795] tegra dvfs: vdd-gpu: nominal 1110mV, offset 710000uV, step 10000uV, scaling enabled
[ 5.132714] tegra_dvfs: vdd-gpu-vts: registered
[ 5.136181] xhci-tegra 70090000.xusb: can't get usb3-0 phy (-517)
[ 5.137492] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 5.137509] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x8208c11
[ 5.137516] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 5.139057] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 5.139071] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 5.139081] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 5.139096] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 5.139111] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 5.139117] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 5.139130] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 5.139142] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 5.139161] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 5.139179] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 5.139195] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 5.139211] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 5.139226] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 5.139243] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 5.140157] usb-vbus1: supplied by vdd-3v3
[ 5.142710] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 5.145966] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 5.146278] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 5.147369] clk_cbus_round_rate: no gbus parent
[ 5.147376] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 5.147482] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 5.148380] tegra-ahci 70027000.sata: Missing devslp-active state
[ 5.150622] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 5.151369] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 5.153442] gk20a 57000000.gpu: failed to allocate secure buffer -12
[ 5.154225] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 5.154238] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 5.160279] scsi host0: tegra_ahci
[ 5.161352] scsi host1: tegra_ahci
[ 5.161623] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 370
[ 5.161626] ata2: DUMMY
[ 5.166328] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 5.166623] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 5.167290] tegra21x-padctl-uphy 7009f000.pinctrl: trying to assert IDDQ while XUSB partitions are on
[ 5.167719] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 5.212898] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 5.276020] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 5.276679] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 5.297418] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 5.352103] tegra124-dfll 70110000.clock: entered closed loop mode
[ 5.390172] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 5.390177] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 5.394854] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 5.394858] xhci-tegra 70090000.xusb: Falling back to user helper
[ 5.411935] input: gpio-keys as /devices/gpio-keys/input/input1
[ 5.474495] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:01:24 UTC (946688484)
[ 5.476671] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.477830] vi 54080000.vi: vi_probe: ++
[ 5.594192] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 5.803538] vi 54080000.vi: initialized
[ 5.914427] vi 54080000.vi: subdev nvcsi-0 bound
[ 5.914435] vi 54080000.vi: subdev ov4689 30-0036 bound
[ 5.914928] vi 54080000.vi: subdev nvcsi-1 bound
[ 5.914931] vi 54080000.vi: subdev ov4689 31-0036 bound
[ 5.915304] vi 54080000.vi: subdev nvcsi-2 bound
[ 5.915308] vi 54080000.vi: subdev ov4689 32-0036 bound
[ 5.915699] vi 54080000.vi: subdev nvcsi-3 bound
[ 5.915703] vi 54080000.vi: subdev ov4689 33-0036 bound
[ 5.920597] Disable partitions left on by BL
[ 5.920606] disb
[ 5.945177] DRAM derating cdev registered.
[ 5.948242] vdd-cpu-fixed: disabling
[ 5.948274] vdd-cam-hv: disabling
[ 5.951873] avdd-ts-hv: disabling
[ 5.957967] vdd-ts: disabling
[ 5.963990] max77620-gpio7: disabling
[ 5.979733] lcd-bl-en: disabling
[ 5.979772] aux-3v3: disabling
[ 5.979778] snsr_pm: disabling
[ 5.979784] vdd-disp-3v0: disabling
[ 5.979803] usb-vbus1: disabling
[ 5.979808] en-vdd-ts-1v8: disabling
[ 5.979815] en-vdd-ts-hv-3v3: disabling
[ 5.979820] en-vdd-disp-3v3: disabling
[ 5.990782] en-mdm-pwr-3v7: disabling
[ 5.990790] en-vdd-disp-1v8: disabling
[ 6.000516] en-vdd-cam-hv-2v8: disabling
[ 6.000522] rtl-5v0: disabling
[ 6.000529] en-usb-vbus2: disabling
[ 6.000535] en-vdd-cam-1v2: disabling
[ 6.000539] en-vdd-vcm-2v8: disabling
[ 6.000545] en-vdd-cam-1v2-alt: disabling
[ 6.018564] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 6.036284] ALSA device list:
[ 6.036289] #0: tegra-snd-t210ref-mobile-rt565x
[ 6.440603] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 6.442735] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 6.657665] tegradc tegradc.1: hdmi: plugged
[ 6.666322] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 6.677027] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 6.775172] mmc1 tuning done saved tap delay=47
[ 6.780737] mmc1: hw tuning done ...
[ 6.785319] mmc1: tuning_window[0]: 0xc7ffffff
[ 6.790734] mmc1: tuning_window[1]: 0xffffffff
[ 6.796074] mmc1: tuning_window[2]: 0xfffffff3
[ 6.801472] mmc1: tuning_window[3]: 0x7ffff8ff
[ 6.806818] mmc1: tuning_window[4]: 0x0
[ 6.811582] mmc1: tuning_window[5]: 0x0
[ 6.816369] mmc1: tuning_window[6]: 0x0
[ 6.821084] mmc1: tuning_window[7]: 0x0
[ 6.825782] sdhci: Tap value: 47 | Trim value: 8
[ 6.831313] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 6.845061] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 6.851796] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 6.897512] EXT4-fs (mmcblk0p1): 6 orphan inodes deleted
[ 6.903927] EXT4-fs (mmcblk0p1): recovery complete
[ 6.921361] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.927539] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 6.938034] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.946761] devtmpfs: mounted
[ 6.951973] Freeing unused kernel memory: 1192K (ffffffc001178000 - ffffffc0012a2000)
[ 6.961039] Freeing alternatives memory: 76K (ffffffc0012a2000 - ffffffc0012b5000)
[ 6.983776] btb inv war enabled
[ 7.043463] systemd[1]: System time before build time, advancing clock.
[ 7.113724] random: systemd: uninitialized urandom read (16 bytes read, 106 bits of entropy available)
[ 7.126440] random: systemd: uninitialized urandom read (16 bytes read, 106 bits of entropy available)
[ 7.137066] random: systemd: uninitialized urandom read (16 bytes read, 106 bits of entropy available)
[ 7.149535] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 7.170937] systemd[1]: Detected architecture arm64.
[ 7.189059] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 7.215987] random: systemd: uninitialized urandom read (16 bytes read, 108 bits of entropy available)
[ 7.231675] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 108 bits of entropy available)
[ 7.237562] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 109 bits of entropy available)
[ 7.237730] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 109 bits of entropy available)
[ 7.237756] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 109 bits of entropy available)
[ 7.237963] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 109 bits of entropy available)
[ 7.242525] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 109 bits of entropy available)
[ 7.343732] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 7.412330] systemd[1]: Listening on Syslog Socket.
[ 7.421013] systemd[1]: Listening on Journal Socket.
[ 7.429369] systemd[1]: Listening on Journal Audit Socket.
[ 7.438051] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.448351] systemd[1]: Listening on udev Kernel Socket.
[ 7.457011] systemd[1]: Reached target User and Group Name Lookups.
[ 7.467111] systemd[1]: Created slice System Slice.
[ 7.477316] systemd[1]: Mounting Debug File System...
[ 7.488852] systemd[1]: Created slice system-getty.slice.
[ 7.500788] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 7.516413] systemd[1]: Started Braille Device Support.
[ 7.532423] systemd[1]: Starting Load Kernel Modules...
[ 7.546145] systemd[1]: Mounting RPC Pipe File System...
[ 7.559410] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.571259] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.573340] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.589467] systemd[1]: Listening on udev Control Socket.
[ 7.598912] systemd[1]: Created slice User and Session Slice.
[ 7.608574] systemd[1]: Reached target Slices.
[ 7.616775] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.628200] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.640077] systemd[1]: Starting Journal Service...
[ 7.652712] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.666553] systemd[1]: Reached target Encrypted Volumes.
[ 7.682348] systemd[1]: Reached target Swap.
[ 7.683552] random: nonblocking pool is initialized
[ 7.702378] systemd[1]: Mounted RPC Pipe File System.
[ 7.712160] systemd[1]: Mounted Debug File System.
[ 7.721168] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.732610] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 7.748126] systemd[1]: Started Load Kernel Modules.
[ 7.755666] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 7.757840] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 7.757930] tegra-pcie 1003000.pcie-controller: PCIE: no end points detected
[ 7.759106] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[ 7.793731] systemd[1]: Started Remount Root and Kernel File Systems.
[ 7.805282] systemd[1]: Started Journal Service.
[ 7.971905] systemd-journald[229]: Received request to flush runtime journal from PID 1
[ 8.389248] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x36
[ 8.408964] regmap_util_write_table_8:regmap_util_write_table:-121
[ 8.427894] vi 54080000.vi: calibration failed with -121 error
[ 8.500312] xhci-tegra 70090000.xusb: cannot find firmware....retry after 1 second
[ 8.824027] dhd_module_init in
[ 8.832786] found wifi platform device bcmdhd_wlan
[ 8.857022] Power-up adapter 'DHD generic adapter'
[ 8.873013] wifi_platform_set_power = 1
[ 9.087593] wifi_platform_bus_enumerate device present 1
[ 9.117840] wifi_platform_bus_enumerate device present 0
[ 9.128264] F1 signature read @0x18000000=0x17214354
[ 9.147052] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.156129] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.165100] wifi_platform_prealloc: failed to alloc static mem section 7
[ 9.178382] wifi_platform_get_mac_addr
[ 9.178786] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 9.195736] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 9.206374] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 9.213335] wl_create_event_handler(): thread:wl_event_handler:1d5 started
[ 9.213453] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc07b021a70
[ 9.213579] dhd_attach(): thread:dhd_watchdog_thread:1d6 started
[ 9.213633] dhd_attach(): thread:dhd_dpc:1d7 started
[ 9.213729] dhd_attach(): thread:dhd_rxf:1d8 started
[ 9.213745] dhd_deferred_work_init: work queue initialized
[ 9.224600] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Mar 1 2018 at 20:43:08
[ 9.225568] tegra_sysfs_register
[ 9.225663] Register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 9.225673] dhd_prot_ioctl : bus is down. we have nothing to do
[ 9.249166] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 47
[ 9.250230] wifi_platform_set_power = 0
[ 9.516706] xhci-tegra 70090000.xusb: Firmware timestamp: 2017-10-20 11:40:00 UTC, Version: 50.19 release
[ 9.543640] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 9.565869] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[ 9.592559] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[ 9.612961] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[ 9.613564] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.613568] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.613572] usb usb1: Product: xHCI Host Controller
[ 9.613574] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 9.613576] usb usb1: SerialNumber: 70090000.xusb
[ 9.617868] hub 1-0:1.0: USB hub found
[ 9.617955] hub 1-0:1.0: 5 ports detected
[ 9.644422] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 9.644452] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[ 9.644684] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.644690] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.644694] usb usb2: Product: xHCI Host Controller
[ 9.644697] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 9.644699] usb usb2: SerialNumber: 70090000.xusb
[ 9.645591] hub 2-0:1.0: USB hub found
[ 9.645644] hub 2-0:1.0: 4 ports detected
[ 9.800442] allen set tas5751 val:284, max: 879 reg:7
[ 9.808423] allen set 11 tas5751 val:17b
[ 9.816254] allen set 22 tas5751 val:7b01
[ 9.822859] allen set 33 tas5751 val:5501
[ 9.845129] cfg80211: World regulatory domain updated:
[ 9.852854] cfg80211: DFS Master region: unset
[ 9.857797] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.870950] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.882844] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.892639] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.902797] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.914040] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.925353] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.935135] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.944931] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 9.957082] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 9.981982] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 9.991689] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 10.000752] usb 2-1: Product: USB 10/100/1000 LAN
[ 10.007388] usb 2-1: Manufacturer: Nvidia
[ 10.013218] usb 2-1: SerialNumber: 000001000000
[ 10.026699] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 10.044623] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 10.152594] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
[ 10.205292] r8152 2-1:1.0 (unnamed net_device) (uninitialized): bad mac address at /chosen/nvidia,ethernet-mac: missing.
[ 10.298277] r8152 2-1:1.0 eth0: v2.09.00 (2017/08/21)
[ 10.306942] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 10.478716] allen set tas5751 val:284, max: 879 reg:7
[ 10.487494] allen set 11 tas5751 val:17b
[ 10.495601] allen set 22 tas5751 val:7b01
[ 10.504846] allen set 33 tas5751 val:7b01
[ 11.128767] IPVS: Creating netns size=1424 id=1
[ 11.251450] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.259983]
[ 11.279606] wl_android_wifi_on in
[ 11.284980] wifi_platform_set_power = 1
[ 11.548014] tegradc tegradc.1: blank - powerdown
[ 11.564712] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 11.624121] tegradc tegradc.1: unblank
[ 11.629217] tegradc tegradc.1: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 11.631153] tegradc tegradc.1: hdmi: pclk:74250K, set prod-setting:prod_c_hdmi_54m_75m
[ 11.638543] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 47
[ 11.639303] F1 signature read @0x18000000=0x17214354
[ 11.643696] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 11.644307] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 11.684090] tegradc tegradc.1: unblank
[ 11.702593] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 11.771756] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 11.778627] wifi_platform_get_mac_addr
[ 11.782746] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 11.791073] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 11.800355] Firmware up: op_mode=0x0005, MAC=00:90:4c:16:70:02
[ 11.812309] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 11.823833] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[ 11.835856] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 11.842556] tegra_sysfs_on
[ 11.897453] dhd_set_mcast_list_handler: interface info not available/down
[ 11.904413] dhd_set_mcast_list_handler: interface info not available/down
[ 11.911342] dhd_set_mcast_list_handler: interface info not available/down
[ 11.918270] dhd_set_mcast_list_handler: interface info not available/down
[ 11.943997] wl_android_wifi_off in
[ 11.948090] tegra_sysfs_off
[ 11.950904] tegra_sysfs_rf_test_disable
[ 11.957241] dhd_wlfc_deinit():3438, maintain HOST RXRERODER flag in tvl
[ 11.969444] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 47
[ 11.980918] wifi_platform_set_power = 0
[ 12.200752] dhd_set_mac_addr_handler: interface info not available/down
[ 12.208461]
[ 12.222570] wl_android_wifi_on in
[ 12.226583] wifi_platform_set_power = 1
[ 12.511318] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 12.603400] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 47
[ 12.618422] F1 signature read @0x18000000=0x17214354
[ 12.629008] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 12.636215] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 12.716125] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 12.785395] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 12.792446] wifi_platform_get_mac_addr
[ 12.796719] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 12.805281] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 12.814738] Firmware up: op_mode=0x0005, MAC=00:90:4c:16:70:02
[ 12.826698] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 12.839126] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[ 12.851205] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 12.858046] tegra_sysfs_on
[ 12.996743] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.015823] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.111185] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 13.137441] WLC_E_IF: NO_IF set, event Ignored
[ 14.807825] wl_android_wifi_off in
[ 14.811350] tegra_sysfs_off
[ 14.814954] tegra_sysfs_rf_test_disable
[ 14.821156] dhd_wlfc_deinit():3438, maintain HOST RXRERODER flag in tvl
[ 14.828905] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 47
[ 14.838910] wifi_platform_set_power = 0
[ 15.049715] dhd_set_mac_addr_handler: interface info not available/down
[ 15.058244]
[ 15.072292] wl_android_wifi_on in
[ 15.075797] wifi_platform_set_power = 1
[ 15.352969] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 15.428045] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 47
[ 15.437615] F1 signature read @0x18000000=0x17214354
[ 15.447077] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 15.454210] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 15.511248] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 15.580271] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 15.587376] wifi_platform_get_mac_addr
[ 15.591573] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 15.599927] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 15.608932] Firmware up: op_mode=0x0005, MAC=00:90:4c:16:70:02
[ 15.620247] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 15.632718] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[ 15.645549] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 15.652455] tegra_sysfs_on
[ 15.775633] wl_android_wifi_off in
[ 15.779071] tegra_sysfs_off
[ 15.782331] tegra_sysfs_rf_test_disable
[ 15.796579] dhd_wlfc_deinit():3438, maintain HOST RXRERODER flag in tvl
[ 15.810597] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 47
[ 15.836360] wifi_platform_set_power = 0
[ 16.057312] dhd_set_mac_addr_handler: interface info not available/down
[ 16.066266]
[ 16.098368] wl_android_wifi_on in
[ 16.106429] wifi_platform_set_power = 1
[ 16.412541] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 16.519831] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 47
[ 16.540939] F1 signature read @0x18000000=0x17214354
[ 16.589524] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 16.604296] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 16.793448] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 16.889356] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 16.925315] wifi_platform_get_mac_addr
[ 16.935352] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 16.971786] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 17.005728] Firmware up: op_mode=0x0005, MAC=00:90:4c:16:70:02
[ 17.024129] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 17.072414] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[ 17.109129] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 17.134127] tegra_sysfs_on
[ 17.200819] tegradc tegradc.1: blank - powerdown
[ 17.287015] tegradc tegradc.1: unblank
[ 17.291514] tegradc tegradc.1: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 17.296213] tegradc tegradc.1: hdmi: pclk:74250K, set prod-setting:prod_c_hdmi_54m_75m
[ 17.343424] tegradc tegradc.1: unblank
[ 17.354642] CFG80211-ERROR) wl_cfg80211_connect : Connectting with50:fa:84:5f:ac:ba channel (6) ssid "Penguinsinnovate", len (16)
[ 17.541816] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[ 17.577705] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[ 17.691757] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[ 17.699809] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 17.730773] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[ 17.759512] IPVS: Creating netns size=1424 id=2
[ 18.015745] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 18.022640] allen tas5751_set_dai_sysclk clk_id:1, freq:44100
[ 18.032047] allen xx tas5751_set_dai_sysclk 66
[ 18.051635] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[ 18.059807] duwei rate:44100, channels:1, formats:4
[ 18.065583] tegra210-i2s tegra210-i2s.0: -------->clk_enable clk_i2s: 0
[ 18.072331] tegra210-i2s tegra210-i2s.0: --------->clk_enable clk_i2s_sync: 0
[ 18.097344] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_audio_sync : 0
[ 18.148346] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_i2s_source : 0
[ 18.217060] tegra210-i2s tegra210-i2s.0: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.256327] allen get 11 tas5751 val:7b01 reg:7
[ 18.261134] allen get 22 tas5751 val:eb
[ 18.265292] allen get tas5751 val:284
[ 18.338407] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 18.345472] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[ 18.345491] allen tas5751_set_dai_sysclk clk_id:1, freq:44100
[ 18.345843] allen xx tas5751_set_dai_sysclk 66
[ 18.359602] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[ 18.359607] duwei rate:44100, channels:2, formats:4
[ 18.360255] tegra210-i2s tegra210-i2s.0: -------->clk_enable clk_i2s: 0
[ 18.360262] tegra210-i2s tegra210-i2s.0: --------->clk_enable clk_i2s_sync: 0
[ 18.360266] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_audio_sync : 0
[ 18.360269] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_i2s_source : 0
[ 18.360381] tegra210-i2s tegra210-i2s.0: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.368756] allen get 11 tas5751 val:7b01 reg:7
[ 18.368758] allen get 22 tas5751 val:eb
[ 18.368760] allen get tas5751 val:284
[ 18.406532] Setting pll_a = 49152000 Hz clk_out = 12288000 Hz
[ 18.407322] allen tas5751_set_dai_sysclk clk_id:1, freq:48000
[ 18.408085] allen xx tas5751_set_dai_sysclk 66
[ 18.423633] Setting clk_rate = 48000 Hz pll_a_out0 = 49152000 Hz clk_out = 24576000 Hz
[ 18.423639] duwei rate:48000, channels:1, formats:4
[ 18.424345] tegra210-i2s tegra210-i2s.4: -------->clk_enable clk_i2s: 0
[ 18.424351] tegra210-i2s tegra210-i2s.4: --------->clk_enable clk_i2s_sync: 0
[ 18.424356] tegra210-i2s tegra210-i2s.4: -------------->clk_enable clk_audio_sync : 0
[ 18.424359] tegra210-i2s tegra210-i2s.4: -------------->clk_enable clk_i2s_source : 0
[ 18.424616] tegra210-i2s tegra210-i2s.4: --------->set I2S sync clock rate:3072000
[ 18.424705] tegra210-i2s tegra210-i2s.4: set I2S clock rate:3072000
[ 18.424708] tegra210-i2s tegra210-i2s.4: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.424721] allen tas5751_hw_params
[ 18.468466] allen get 11 tas5751 val:7b01 reg:7
[ 18.468468] allen get 22 tas5751 val:eb
[ 18.468469] allen get tas5751 val:284
[ 18.496783] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 18.497571] allen tas5751_set_dai_sysclk clk_id:1, freq:44100
[ 18.498950] allen xx tas5751_set_dai_sysclk 66
[ 18.511630] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[ 18.511635] duwei rate:44100, channels:1, formats:4
[ 18.512268] tegra210-i2s tegra210-i2s.0: -------->clk_enable clk_i2s: 0
[ 18.512273] tegra210-i2s tegra210-i2s.0: --------->clk_enable clk_i2s_sync: 0
[ 18.512277] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_audio_sync : 0
[ 18.512280] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_i2s_source : 0
[ 18.512394] tegra210-i2s tegra210-i2s.0: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.516461] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 18.516774] allen tas5751_set_dai_sysclk clk_id:1, freq:44100
[ 18.519374] allen xx tas5751_set_dai_sysclk 66
[ 18.531621] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[ 18.531628] duwei rate:44100, channels:2, formats:4
[ 18.532229] tegra210-i2s tegra210-i2s.0: -------->clk_enable clk_i2s: 0
[ 18.532235] tegra210-i2s tegra210-i2s.0: --------->clk_enable clk_i2s_sync: 0
[ 18.532240] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_audio_sync : 0
[ 18.532244] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_i2s_source : 0
[ 18.532351] tegra210-i2s tegra210-i2s.0: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.570313] Setting pll_a = 49152000 Hz clk_out = 12288000 Hz
[ 18.571054] allen tas5751_set_dai_sysclk clk_id:1, freq:48000
[ 18.571414] allen xx tas5751_set_dai_sysclk 66
[ 18.583621] Setting clk_rate = 48000 Hz pll_a_out0 = 49152000 Hz clk_out = 24576000 Hz
[ 18.583626] duwei rate:48000, channels:2, formats:4
[ 18.584155] tegra210-i2s tegra210-i2s.4: -------->clk_enable clk_i2s: 0
[ 18.584160] tegra210-i2s tegra210-i2s.4: --------->clk_enable clk_i2s_sync: 0
[ 18.584165] tegra210-i2s tegra210-i2s.4: -------------->clk_enable clk_audio_sync : 0
[ 18.584169] tegra210-i2s tegra210-i2s.4: -------------->clk_enable clk_i2s_source : 0
[ 18.584292] tegra210-i2s tegra210-i2s.4: --------->set I2S sync clock rate:3072000
[ 18.584368] tegra210-i2s tegra210-i2s.4: set I2S clock rate:3072000
[ 18.584371] tegra210-i2s tegra210-i2s.4: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.584383] allen tas5751_hw_params
[ 18.621859] allen get 11 tas5751 val:7b01 reg:7
[ 18.621861] allen get 22 tas5751 val:eb
[ 18.621863] allen get tas5751 val:284
[ 18.646419] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 18.647128] allen tas5751_set_dai_sysclk clk_id:1, freq:44100
[ 18.647820] allen xx tas5751_set_dai_sysclk 66
[ 18.663610] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[ 18.663615] duwei rate:44100, channels:1, formats:4
[ 18.666549] tegra210-i2s tegra210-i2s.0: -------->clk_enable clk_i2s: 0
[ 18.666556] tegra210-i2s tegra210-i2s.0: --------->clk_enable clk_i2s_sync: 0
[ 18.666561] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_audio_sync : 0
[ 18.666565] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_i2s_source : 0
[ 18.666714] tegra210-i2s tegra210-i2s.0: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.671702] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 18.671997] allen tas5751_set_dai_sysclk clk_id:1, freq:44100
[ 18.672345] allen xx tas5751_set_dai_sysclk 66
[ 18.687605] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[ 18.687610] duwei rate:44100, channels:2, formats:4
[ 18.688160] tegra210-i2s tegra210-i2s.0: -------->clk_enable clk_i2s: 0
[ 18.688167] tegra210-i2s tegra210-i2s.0: --------->clk_enable clk_i2s_sync: 0
[ 18.688172] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_audio_sync : 0
[ 18.688176] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_i2s_source : 0
[ 18.688290] tegra210-i2s tegra210-i2s.0: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.740823] Setting pll_a = 49152000 Hz clk_out = 12288000 Hz
[ 18.741564] allen tas5751_set_dai_sysclk clk_id:1, freq:48000
[ 18.741964] allen xx tas5751_set_dai_sysclk 66
[ 18.755597] Setting clk_rate = 48000 Hz pll_a_out0 = 49152000 Hz clk_out = 24576000 Hz
[ 18.755601] duwei rate:48000, channels:2, formats:4
[ 18.756337] tegra210-i2s tegra210-i2s.4: -------->clk_enable clk_i2s: 0
[ 18.756342] tegra210-i2s tegra210-i2s.4: --------->clk_enable clk_i2s_sync: 0
[ 18.756347] tegra210-i2s tegra210-i2s.4: -------------->clk_enable clk_audio_sync : 0
[ 18.756351] tegra210-i2s tegra210-i2s.4: -------------->clk_enable clk_i2s_source : 0
[ 18.756463] tegra210-i2s tegra210-i2s.4: --------->set I2S sync clock rate:3072000
[ 18.756573] tegra210-i2s tegra210-i2s.4: set I2S clock rate:3072000
[ 18.756576] tegra210-i2s tegra210-i2s.4: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.756589] allen tas5751_hw_params
[ 18.794512] allen get 11 tas5751 val:7b01 reg:7
[ 18.794514] allen get 22 tas5751 val:eb
[ 18.794516] allen get tas5751 val:284
[ 18.852449] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 18.853165] allen tas5751_set_dai_sysclk clk_id:1, freq:44100
[ 18.853730] allen xx tas5751_set_dai_sysclk 66
[ 18.867597] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[ 18.867603] duwei rate:44100, channels:2, formats:4
[ 18.868196] tegra210-i2s tegra210-i2s.0: -------->clk_enable clk_i2s: 0
[ 18.868202] tegra210-i2s tegra210-i2s.0: --------->clk_enable clk_i2s_sync: 0
[ 18.868207] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_audio_sync : 0
[ 18.868210] tegra210-i2s tegra210-i2s.0: -------------->clk_enable clk_i2s_source : 0
[ 18.868938] tegra210-i2s tegra210-i2s.0: ----------> enalbe clk manunlly I2S clock rate: 0
[ 18.871760] allen get 11 tas5751 val:7b01 reg:7
[ 18.871762] allen get 22 tas5751 val:eb
[ 18.871763] allen get tas5751 val:284
[ 19.348051] IPVS: Creating netns size=1424 id=3
[ 53.982694] Setting pll_a = 49152000 Hz clk_out = 12288000 Hz
[ 53.989736] allen tas5751_set_dai_sysclk clk_id:1, freq:48000
[ 53.996270] allen xx tas5751_set_dai_sysclk 66
[ 54.015778] Setting clk_rate = 48000 Hz pll_a_out0 = 49152000 Hz clk_out = 24576000 Hz
[ 54.023712] duwei rate:48000, channels:2, formats:4
[ 54.029206] tegra210-i2s tegra210-i2s.4: -------->clk_enable clk_i2s: 0
[ 54.037054] tegra210-i2s tegra210-i2s.4: --------->clk_enable clk_i2s_sync: 0
[ 54.044823] tegra210-i2s tegra210-i2s.4: -------------->clk_enable clk_audio_sync : 0
[ 54.053123] tegra210-i2s tegra210-i2s.4: -------------->clk_enable clk_i2s_source : 0
[ 54.061555] tegra210-i2s tegra210-i2s.4: --------->set I2S sync clock rate:3072000
[ 54.069189] tegra210-i2s tegra210-i2s.4: set I2S clock rate:3072000
[ 54.075462] tegra210-i2s tegra210-i2s.4: ----------> enalbe clk manunlly I2S clock rate: 0
[ 54.083731] allen tas5751_hw_params
[ 334.471322] tegradc tegradc.1: blank - powerdown
[ 2373.738813] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 2373.745900] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:fa:84:5f:ac:ba
[ 2373.772934] CFG80211-ERROR) wl_cfg80211_connect : Connectting with48:7d:2e:fa:36:2e channel (11) ssid "Penguinsinnovate", len (16)
[ 2373.893007] CFG80211-ERROR) wl_run_escan : Escan set error (-16)
[ 2373.900046] CFG80211-ERROR) wl_run_escan : error (-16)
[ 2373.909147] CFG80211-ERROR) __wl_cfg80211_scan : Scan err = (-16), busy?-16
[ 2373.917833] CFG80211-ERROR) wl_cfg80211_scan :
[ 2373.918250] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 48:7d:2e:fa:36:2e
[ 2373.930979] scan error (-16)
[ 2373.936772] cfg80211: World regulatory domain updated:
wifi-config-check.sh.txt (6.58 KB)
