I ve some issues with my jetson tx2 board. A couple of days ago, it s startet not to give hdmi output to monitors (tried with both hdmi-to-vga connector and directly hdmi cable to a projetor). Together with this there is no usb3.0 connection. I also noticed that fan is not working. when i try to run “sudo ./jetson_clocks.sh”, it says “can’t access fan”.
TX2 is running on its own developer carrier board, and i ve flash several times with both jetpack 3 and 3.1. No result. Now it s running jetpack3.1 and i have control over ssh connection.
It just means the default mode was something the monitor supported. Sometimes you can trick the system by plugging in an HDMI monitor with a mode the VGA monitor can work with, and then switching to the VGA monitor…the previous mode is kept until new EDID data is found.
[ 3.611795] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.611885] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.611973] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.612064] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.615519] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 3.615612] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 3.615637] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 3.615660] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 3.647699] input: tegra-snd-t186ref-mobile-rt565x headphone Jack as /devices/sound/sound/card1/input2
[ 3.648354] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 3.648357] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.648825] GACT probability NOT on
[ 3.648832] Mirror/redirect action on
[ 3.648841] u32 classifier
[ 3.648842] Actions configured
[ 3.648864] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.649557] ipip: IPv4 over IPv4 tunneling driver
[ 3.649906] Initializing XFRM netlink socket
[ 3.650206] NET: Registered protocol family 10
[ 3.650916] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.650990] NET: Registered protocol family 17
[ 3.651003] NET: Registered protocol family 15
[ 3.651025] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.651029] 8021q: 802.1Q VLAN Support v1.8
[ 3.654553] Registered cp15_barrier emulation handler
[ 3.666574] Registered setend emulation handler
[ 3.667832] registered taskstats version 1
[ 3.670976] isp 15600000.isp: initialized
[ 3.674517] nvcsi 150c0000.nvcsi: initialized
[ 3.676261] Wake76 for irq=199
[ 3.676262] Wake77 for irq=199
[ 3.676263] Wake78 for irq=199
[ 3.676264] Wake79 for irq=199
[ 3.676264] Wake80 for irq=199
[ 3.676265] Wake81 for irq=199
[ 3.676266] Wake82 for irq=199
[ 3.676473] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 3.676811] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.677438] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.678092] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.678610] Wake76 for irq=199
[ 3.678611] Wake77 for irq=199
[ 3.678612] Wake78 for irq=199
[ 3.678613] Wake79 for irq=199
[ 3.678613] Wake80 for irq=199
[ 3.678614] Wake81 for irq=199
[ 3.678615] Wake82 for irq=199
[ 3.678640] tegra-xotg xotg: usb2 phy is not available yet
[ 3.678783] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.679150] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.679289] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.679294] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.679332] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 3.679335] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.680044] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.682061] Wake76 for irq=199
[ 3.682062] Wake77 for irq=199
[ 3.682062] Wake78 for irq=199
[ 3.682063] Wake79 for irq=199
[ 3.682064] Wake80 for irq=199
[ 3.682064] Wake81 for irq=199
[ 3.682065] Wake82 for irq=199
[ 3.682247] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 3.682957] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 3.683055] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 3.683115] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 3.683234] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.683535] Wake76 for irq=199
[ 3.683536] Wake77 for irq=199
[ 3.683537] Wake78 for irq=199
[ 3.683537] Wake79 for irq=199
[ 3.683538] Wake80 for irq=199
[ 3.683539] Wake81 for irq=199
[ 3.683539] Wake82 for irq=199
[ 3.683564] tegra-xotg xotg: usb2 phy is not available yet
[ 3.683687] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.684034] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.684168] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.684172] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.684205] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 3.684208] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.684917] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.686739] Wake76 for irq=199
[ 3.686740] Wake77 for irq=199
[ 3.686741] Wake78 for irq=199
[ 3.686741] Wake79 for irq=199
[ 3.686742] Wake80 for irq=199
[ 3.686743] Wake81 for irq=199
[ 3.686743] Wake82 for irq=199
[ 3.686913] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 3.721182] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 02:02:23 UTC (946692143)
[ 3.751112] bpmp: mounted debugfs mirror
[ 3.751606] [dram-timers] DRAM derating cdev registered.
[ 3.755566] spmic-ldo0: disabling
[ 3.755748] spmic-ldo1: disabling
[ 3.755894] vddio-sdmmc1: disabling
[ 3.756068] avdd-ts-hv: disabling
[ 3.756221] en-vdd-sd: disabling
[ 3.756222] en-vdd-cam: disabling
[ 3.756224] vdd-usb0-5v: disabling
[ 3.756225] vdd-usb1-5v: disabling
[ 3.756227] en-vdd-cam-1v2: disabling
[ 3.756228] vdd-3v3: disabling
[ 3.756230] en-vdd-vcm-2v8: disabling
[ 3.756231] vdd-sys-bl: disabling
[ 3.756232] en-vdd-sys: disabling
[ 3.763707] ALSA device list:
[ 3.763709] #0: tegra-hda at 0x3518000 irq 400
[ 3.763710] #1: tegra-snd-t186ref-mobile-rt565x
[ 3.764538] tegra-vi4 15700000.vi: initialized
[ 3.765669] tegra-vi4 15700000.vi: all channel register failed
[ 3.765943] Wake76 for irq=199
[ 3.765944] Wake77 for irq=199
[ 3.765944] Wake78 for irq=199
[ 3.765945] Wake79 for irq=199
[ 3.765946] Wake80 for irq=199
[ 3.765946] Wake81 for irq=199
[ 3.765947] Wake82 for irq=199
[ 3.765979] tegra-xotg xotg: usb2 phy is not available yet
[ 3.766174] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.766606] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.766767] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.766771] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.766812] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 3.766815] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.767538] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.769616] Wake76 for irq=199
[ 3.769616] Wake77 for irq=199
[ 3.769617] Wake78 for irq=199
[ 3.769618] Wake79 for irq=199
[ 3.769618] Wake80 for irq=199
[ 3.769619] Wake81 for irq=199
[ 3.769620] Wake82 for irq=199
[ 3.769806] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 5.108210] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 5.116754] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 5.157746] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.168046] Wake76 for irq=199
[ 5.168076] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 5.168326] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 5.187102] Wake77 for irq=199
[ 5.190804] Wake78 for irq=199
[ 5.194475] Wake79 for irq=199
[ 5.198107] Wake80 for irq=199
[ 5.201702] Wake81 for irq=199
[ 5.201737] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.201937] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.201978] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 5.202031] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 5.202051] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 5.202316] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 5.227715] mmc0: MAN_BKOPS_EN bit is not set
[ 5.234945] mmc0: Skipping tuning since strobe enabled
[ 5.241766] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 5.241795] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.242222] Waiting for root device /dev/mmcblk0p1...
[ 5.242405] mmc0: periodic cache flush enabled
[ 5.242411] mmc0: new HS400 MMC card at address 0001
[ 5.242649] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 5.242765] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 5.242871] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 5.242994] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 5.244227] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 5.282049] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 5.330873] Wake82 for irq=199
[ 5.334718] tegra-xotg xotg: usb2 phy is not available yet
[ 5.341240] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.348192] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.355369] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.365724] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.375812] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 5.383191] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.390971] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.400359] Wake76 for irq=199
[ 5.403883] Wake77 for irq=199
[ 5.407369] Wake78 for irq=199
[ 5.410828] Wake79 for irq=199
[ 5.414272] Wake80 for irq=199
[ 5.417706] Wake81 for irq=199
[ 5.421130] Wake82 for irq=199
[ 5.424770] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 5.431935] Wake76 for irq=199
[ 5.435395] Wake77 for irq=199
[ 5.438824] Wake78 for irq=199
[ 5.442232] Wake79 for irq=199
[ 5.446695] Wake80 for irq=199
[ 5.450085] Wake81 for irq=199
[ 5.453442] Wake82 for irq=199
[ 5.456946] tegra-xotg xotg: usb2 phy is not available yet
[ 5.479704] mmc1 tuning done saved tap delay=57
[ 5.484538] mmc1: hw tuning done ...
[ 5.488393] mmc1: tuning_window[0]: 0xffffffff
[ 5.493105] mmc1: tuning_window[1]: 0xffffff8f
[ 5.497791] mmc1: tuning_window[2]: 0xffff8fff
[ 5.502457] mmc1: tuning_window[3]: 0x7fcfffff
[ 5.507102] mmc1: tuning_window[4]: 0x0
[ 5.511138] mmc1: tuning_window[5]: 0x0
[ 5.515165] mmc1: tuning_window[6]: 0x0
[ 5.519174] mmc1: tuning_window[7]: 0x0
[ 5.523182] sdhci: Tap value: 57 | Trim value: 5
[ 5.527982] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 5.539341] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.545112] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.559096] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.568025] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.577008] devtmpfs: mounted
[ 5.580696] Freeing unused kernel memory: 1164K (ffffffc0010cd000 - ffffffc0011f0000)
[ 5.589582] Freeing alternatives memory: 96K (ffffffc0011f0000 - ffffffc001208000)
[ 5.646032] systemd[1]: System time before build time, advancing clock.
[ 5.671214] random: systemd: uninitialized urandom read (16 bytes read, 85 bits of entropy available)
[ 5.683860] random: systemd: uninitialized urandom read (16 bytes read, 86 bits of entropy available)
[ 5.694869] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.715531] systemd[1]: Detected architecture arm64.
[ 5.730814] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 5.747967] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[ 5.751930] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[ 5.752032] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[ 5.752091] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[ 5.752107] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[ 5.752196] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[ 5.768369] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[ 5.768455] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[ 5.931115] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 5.939451] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 5.948052] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.957089] systemd[1]: Reached target Encrypted Volumes.
[ 5.964614] systemd[1]: Reached target Swap.
[ 5.971041] systemd[1]: Listening on Journal Audit Socket.
[ 5.978610] systemd[1]: Listening on Syslog Socket.
[ 5.985487] systemd[1]: Listening on udev Kernel Socket.
[ 5.993178] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.002990] systemd[1]: Created slice User and Session Slice.
[ 6.010324] systemd[1]: Listening on Journal Socket.
[ 6.016716] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.024020] systemd[1]: Created slice System Slice.
[ 6.030366] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.039061] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 6.050747] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.059459] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 6.073450] systemd[1]: Mounting Debug File System...
[ 6.081265] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.090308] systemd[1]: Created slice system-getty.slice.
[ 6.098471] systemd[1]: Started Braille Device Support.
[ 6.106013] systemd[1]: Reached target User and Group Name Lookups.
[ 6.115362] systemd[1]: Starting Journal Service...
[ 6.122024] systemd[1]: Reached target Slices.
[ 6.128291] systemd[1]: Listening on udev Control Socket.
[ 6.142247] systemd[1]: Starting Load Kernel Modules...
[ 6.148934] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.156237] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 6.156458] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.157006] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 6.157223] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 6.157229] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 6.157267] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 6.157270] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 6.158078] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 6.160341] Wake76 for irq=199
[ 6.160342] Wake77 for irq=199
[ 6.160343] Wake78 for irq=199
[ 6.160344] Wake79 for irq=199
[ 6.160344] Wake80 for irq=199
[ 6.160345] Wake81 for irq=199
[ 6.160345] Wake82 for irq=199
[ 6.160577] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 6.160966] Wake76 for irq=199
[ 6.160967] Wake77 for irq=199
[ 6.160968] Wake78 for irq=199
[ 6.160968] Wake79 for irq=199
[ 6.160969] Wake80 for irq=199
[ 6.160970] Wake81 for irq=199
[ 6.160970] Wake82 for irq=199
[ 6.161009] tegra-xotg xotg: usb2 phy is not available yet
[ 6.280478] systemd[1]: Reached target Remote File Systems.
[ 6.292481] systemd[1]: Mounted Debug File System.
[ 6.298347] systemd[1]: Started Journal Service.
[ 6.367304] systemd-journald[273]: Received request to flush runtime journal from PID 1
[ 6.591138] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 6.599919] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.599921] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 6.600720] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 6.603602] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 6.634883] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 6.642564] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 6.642571] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 6.642610] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 6.642613] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 6.643525] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 6.648101] Wake76 for irq=199
[ 6.648102] Wake77 for irq=199
[ 6.648103] Wake78 for irq=199
[ 6.648104] Wake79 for irq=199
[ 6.648104] Wake80 for irq=199
[ 6.648105] Wake81 for irq=199
[ 6.648105] Wake82 for irq=199
[ 6.648309] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 6.648603] Wake76 for irq=199
[ 6.648603] Wake77 for irq=199
[ 6.648604] Wake78 for irq=199
[ 6.648605] Wake79 for irq=199
[ 6.648605] Wake80 for irq=199
[ 6.648606] Wake81 for irq=199
[ 6.648607] Wake82 for irq=199
[ 6.648634] tegra-xotg xotg: usb2 phy is not available yet
[ 6.649729] random: nonblocking pool is initialized
[ 6.754641] dhd_module_init in
[ 6.754672] tegra_net_perf_init: cannot get wifi sclk
[ 6.754756] found wifi platform device bcmdhd_wlan
[ 6.757416] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 6.757425] wifi_platform_get_country_code_map: could not get country_code_map
[ 6.757427] wifi_plat_dev_drv_probe:platform country code map is not available
[ 6.757440] Power-up adapter 'DHD generic adapter'
[ 6.757445] wifi_platform_set_power = 1
[ 6.957743] wifi_platform_bus_enumerate device present 1
[ 6.965268] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.965807] cfg80211: World regulatory domain updated:
[ 6.965812] cfg80211: DFS Master region: unset
[ 6.965813] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.965819] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.965822] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.965824] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.965827] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.965830] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.965833] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.965835] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.965837] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.056807] wifi_platform_bus_enumerate device present 0
[ 7.084394] F1 signature read @0x18000000=0x17214354
[ 7.084906] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 7.085088] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 7.085100] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 7.085151] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 7.085155] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 7.086043] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 7.088067] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 7.088538] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 7.088592] wifi_platform_prealloc: failed to alloc static mem section 7
[ 7.088598] wifi_platform_get_mac_addr
[ 7.088883] Wake76 for irq=199
[ 7.088885] Wake77 for irq=199
[ 7.088886] Wake78 for irq=199
[ 7.088887] Wake79 for irq=199
[ 7.088888] Wake80 for irq=199
[ 7.088889] Wake81 for irq=199
[ 7.088890] Wake82 for irq=199
[ 7.089183] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 7.089662] Wake76 for irq=199
[ 7.089664] Wake77 for irq=199
[ 7.089665] Wake78 for irq=199
[ 7.089666] Wake79 for irq=199
[ 7.089667] Wake80 for irq=199
[ 7.089668] Wake81 for irq=199
[ 7.089669] Wake82 for irq=199
[ 7.089721] tegra-xotg xotg: usb2 phy is not available yet
[ 7.089855] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.090147] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 7.090337] wl_create_event_handler(): thread:wl_event_handler:1d2 started
[ 7.090341] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e0ec1a70
[ 7.090419] dhd_attach(): thread:dhd_watchdog_thread:1d3 started
[ 7.090440] dhd_attach(): thread:dhd_dpc:1d4 started
[ 7.090477] dhd_attach(): thread:dhd_rxf:1d5 started
[ 7.090482] dhd_deferred_work_init: work queue initialized
[ 7.090634] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Jul 20 2017 at 00:47:12
[ 7.090888] tegra_sysfs_register
[ 7.090911] Register interface [wlan0] MAC: 00:04:4b:8c:fe:c9
[ 7.090913] dhd_prot_ioctl : bus is down. we have nothing to do
[ 7.090993] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 57
[ 7.092033] wifi_platform_set_power = 0
[ 7.159753] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.294425] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 7.294702] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 7.294708] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 7.294746] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 7.294749] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 7.296037] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 7.298855] Wake76 for irq=199
[ 7.298856] Wake77 for irq=199
[ 7.298857] Wake78 for irq=199
[ 7.298858] Wake79 for irq=199
[ 7.298858] Wake80 for irq=199
[ 7.298859] Wake81 for irq=199
[ 7.298860] Wake82 for irq=199
[ 7.299068] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 7.299363] Wake76 for irq=199
[ 7.299364] Wake77 for irq=199
[ 7.299365] Wake78 for irq=199
[ 7.299366] Wake79 for irq=199
[ 7.299366] Wake80 for irq=199
[ 7.299367] Wake81 for irq=199
[ 7.299368] Wake82 for irq=199
[ 7.299396] tegra-xotg xotg: usb2 phy is not available yet
[ 7.299513] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.571738] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.985304] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.993604] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 7.997721] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.999746] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 8.015328] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.031882] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.031953]
[ 8.031954] wl_android_wifi_on in
[ 8.031957] wifi_platform_set_power = 1
[ 8.216881] gk20a 17000000.gp10b: railgate is disabled.
[ 8.306232] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 8.378025] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 57
[ 8.387112] F1 signature read @0x18000000=0x17214354
[ 8.396427] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.403094] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.410002] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.476671] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 8.526087] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 8.532270] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 8.537736] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 8.543044] Enabling wake69
[ 8.552949] wifi_platform_get_mac_addr
[ 8.558508] Firmware up: op_mode=0x0005, MAC=00:04:4b:8c:fe:c9
[ 8.571253] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 8.583037] Firmware version = wl0: May 4 2017 13:48:00 version 7.35.221.21 (r697384) FWID 01-58d9d0b3
[ 8.595043] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 8.601777] tegra_sysfs_on
[ 8.723343] CPU1: shutdown
[ 8.726327] psci: CPU1 killed.
[ 8.748917] CPU2: shutdown
[ 8.751808] psci: CPU2 killed.
[ 8.817325] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.826886] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 8.845265] WLC_E_IF: NO_IF set, event Ignored
[ 9.231737] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.241109] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 9.247908] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 9.255266] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 9.516997] fuse init (API version 7.23)
[ 9.717178] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 9.726475] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
and here you can see the ports were powered at first and disabling after a while somehow.
Not just hdmi or usb, but also sdmmc, cam and some other voltages were being disabled.
+0.000064] Linux video capture interface: v2.00
[ +0.004008] pps_core: LinuxPPS API ver. 1 registered
[ +0.000034] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ +0.000049] PTP clock support registered
[ +0.001025] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ +0.000042] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ +0.001507] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ +0.001968] GPIO line 237 (spmic_gpio_input_5) hogged as input
[ +0.000190] GPIO line 238 (spmic_gpio_input_6) hogged as input
[ +0.000123] gpiochip_add_data: registered GPIOs 232 to 239 on device: max77620-g
[ +0.007422] vddio-ddr: at 1125 mV
[ +0.003836] avdd_dsi_csi: 1200 mV
[ +0.004001] vdd-1v8: 1800 mV
[ +0.003999] vdd-3v3-sys: 3300 mV
[ +0.001107] spmic-ldo0: at 1800 mV
[ +0.000819] spmic-ldo1: at 800 mV
[ +0.006072] vddio-3v3: 3300 mV
[ +0.000620] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ +0.002125] vdd-rtc: at 800 mV
[ +0.000699] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ +0.003298] spmic-ldo6: at 1500 mV
[ +0.004000] vdd-pex-1v05: 1000 mV
[ +0.000538] dvdd-pex: 1000 mV
[ +0.000265] max77620 4-003c: max77620 probe successful
[ +0.000246] Advanced Linux Sound Architecture Driver Initialized.
[ +0.000956] en-vdd-sd: 3300 mV
[ +0.000615] en-vdd-cam: 1800 mV
[ +0.000214] vdd-usb0-5v: 5000 mV
[ +0.000180] vdd-usb1-5v: 5000 mV
[ +0.000706] en-vdd-cam-1v2: 1200 mV
[ +0.000136] vdd-3v3: 3300 mV
[ +0.000138] en-vdd-vcm-2v8: 2800 mV
[ +0.000137] vdd-sys-bl: 3300 mV
[ +0.000521] en-vdd-sys: 1200 mV
[ +0.001657] gpio tegra-gpio wake53 for gpio=159(X:7)
[ +0.001662] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ +0.000358] clocksource: Switched to clocksource arch_sys_counter
[ +0.019235] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ +0.000280] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache
[ +0.000497] nvmap_page_pool_init: Total RAM pages: 2009467
[ +0.000017] nvmap_page_pool_init: nvmap page pool size: 251183 pages (981 MB)
[ +0.000188] nvmap_background_zero_thread: PP zeroing thread starting.
[ +0.004553] Wake76 for irq=199
[ +0.000012] Wake77 for irq=199
[ +0.000010] Wake78 for irq=199
[ +0.000009] Wake79 for irq=199
[ +0.000009] Wake80 for irq=199
[ +0.000009] Wake81 for irq=199
[ +0.000008] Wake82 for irq=199
[ +0.000737] thermal thermal_zone0: Registering thermal zone thermal_zone0 for ty
[ +0.000201] thermal thermal_zone1: Registering thermal zone thermal_zone1 for ty
[ +0.000115] thermal thermal_zone2: Registering thermal zone thermal_zone2 for ty
[ +0.000077] thermal thermal_zone3: Registering thermal zone thermal_zone3 for ty
[ +0.000394] thermal thermal_zone4: Registering thermal zone thermal_zone4 for ty
[ +0.000142] thermal thermal_zone5: Registering thermal zone thermal_zone5 for ty
[ +0.000143] thermal thermal_zone6: Registering thermal zone thermal_zone6 for ty
[ +0.000152] thermal thermal_zone7: Registering thermal zone thermal_zone7 for ty
[ +0.000296] isomgr_init(): iso emc max clk=1866000KHz
[ +0.000011] isomgr_init(): max_iso_bw=26870400KB
[ +0.000081] NET: Registered protocol family 2
[ +0.000355] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ +0.000224] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ +0.000325] TCP: Hash tables configured (established 65536 bind 65536)
[ +0.000060] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ +0.000052] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ +0.000158] NET: Registered protocol family 1
[ +0.000193] RPC: Registered named UNIX socket transport module.
[ +0.000013] RPC: Registered udp transport module.
[ +0.000011] RPC: Registered tcp transport module.
[ +0.000011] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ +0.000019] PCI: CLS 0 bytes, default 128
[ +0.000091] Trying to unpack rootfs image as initramfs...
[ +0.014068] host1x 13e10000.host1x: initialized
[ +0.000801] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters avail
[ +0.002147] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ +0.000094] audit: initializing netlink subsys (disabled)
[ +0.000029] audit: type=2000 audit(0.408:1): initialized
[ +0.006475] io scheduler noop registered (default)
[ +0.002959] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ +0.001228] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ +0.001076] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ +0.001062] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ +0.003448] tsec 15500000.tsec: initialized
[ +0.001131] tsec 15100000.tsecb: initialized
[ +0.002342] nvdec 15480000.nvdec: initialized
[ +0.003647] falcon 15340000.vic: initialized
[ +0.001004] falcon 154c0000.nvenc: initialized
[ +0.000998] falcon 15380000.nvjpg: initialized
[ +0.000762] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ +0.000506] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ +0.000497] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ +0.000492] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ +0.000493] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ +0.000495] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ +0.000493] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ +0.000512] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ +0.002577] DC OR NODE connected to /host1x/sor1
[ +0.000162] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:came
[ +0.000048] tegradc 15210000.nvdisplay: DT parsed successfully
[ +0.000046] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered w
[ +0.000004] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3
[ +0.000004] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687
[ +0.007790] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 1672
[ +0.000019] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 6
[ +0.000011] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ +0.000014] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 3576
[ +0.000043] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ +0.000014] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ +0.000406] hdmi: couldn't get regulator vdd_hdmi_5v0: -517
[ +0.001775] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initializ
[ +0.000261] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use defau
[ +0.000021] PD DISP0 index2 UP
[ +0.000076] kfuse 3830000.kfuse: initialized
[ +0.000740] PD DISP1 index3 UP
[ +0.000159] PD DISP2 index4 UP
[ +0.000297] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ +0.000491] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ +0.001878] console [ttyS0] disabled
[ +0.000041] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500
[ +1.995697] tegra-i2c 3190000.i2c: pio xfer timed out addr: 0x50
[ +0.000003] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ +0.000003] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ +0.000003] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ +0.000003] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ +0.000003] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ +0.000004] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ +0.000003] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ +0.000004] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ +0.000602] PD DISP2 index4 DOWN
[ +0.000157] PD DISP1 index3 DOWN
[ +0.000145] PD DISP0 index2 DOWN
[ +0.001904] tegradc 15210000.nvdisplay: probed
[ +0.102155] console [ttyS0] enabled
[ +0.001894] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0)
[ +0.000437] Console: switching to colour frame buffer device 80x30
[ +0.000632] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0)
[ +0.000247] serial-tegra 3130000.serial: RX in PIO mode
[ +0.000893] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0)
[ +0.026037] brd: module loaded
[ +0.008365] loop: module loaded
[ +0.000209] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ +0.000017] nct1008_nct72 7-004c: find device tree node, parsing dt
[ +0.000004] nct1008_nct72 7-004c: starting parse dt
[ +0.000079] nct1008_nct72 7-004c: success parsing dt
[ +0.000120] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ +0.060173] tegradc 15210000.nvdisplay: fb registered
[ +0.014034] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ +0.000087] gpio tegra-gpio wake21 for gpio=121(P:1)
[ +0.026237] tmp451: Enabled overheat logging at 104.00C
[ +0.006530] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ +0.006426] nct1008_nct72 7-004c: nct1008_probe: initialized
[ +0.008959] THERMAL EST: found 3 subdevs
[ +0.005050] THERMAL EST num_resources: 0
[ +0.004999] [THERMAL EST subdev 0]
[ +0.004489] [THERMAL EST subdev 1]
[ +0.004417] [THERMAL EST subdev 2]
[ +0.004582] thermal thermal_zone8: Registering thermal zone thermal_zone8 for ty
[ +0.011018] THERMAL EST: thz register success.
[ +0.005499] THERMAL EST: end of probe, return err: 0
[ +0.006073] tegra_profiler: Branch: Dev
[ +0.004781] tegra_profiler: Version: 1.109
[ +0.006454] tegra_profiler: Samples version: 37
[ +0.006163] tegra_profiler: IO version: 21
[ +0.004870] armv8_pmu: imp: 0x41, idcode: 0x1
[ +0.005022] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ +0.007643] armv8_pmu: imp: 0x4e, idcode: 0x1
[ +0.005040] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ +0.007773] armv8_pmu: imp: 0x4e, idcode: 0x1
[ +0.005044] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ +0.007776] armv8_pmu: imp: 0x41, idcode: 0x1
[ +0.005030] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ +0.007652] armv8_pmu: imp: 0x41, idcode: 0x1
[ +0.005049] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ +0.007640] armv8_pmu: imp: 0x41, idcode: 0x1
[ +0.005044] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ +0.007917] tegra_profiler: auth: init
[ +0.008093] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps
[ +0.010848] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio s
[ +0.011984] scsi host0: tegra_ahci
[ +0.004492] scsi host1: tegra_ahci
[ +0.004286] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100
[ +0.009337] ata2: DUMMY
[ +0.004352] spi-tegra114 3210000.spi: Static pin configuration used
[ +0.007594] spi-tegra114 c260000.spi: Static pin configuration used
[ +0.007451] spi-tegra114 3240000.spi: Static pin configuration used
[ +0.007862] tun: Universal TUN/TAP device driver, 1.6
[ +0.005793] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ +0.007125] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ +0.006569] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ +0.006741] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ +0.007695] igb: Copyright (c) 2007-2014 Intel Corporation.
[ +0.007646] PPP generic driver version 2.4.2
[ +0.002834] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c fe cb
[ +0.000473] libphy: dwc_phy: probed
[ +0.013326] PPP BSD Compression module registered
[ +0.005431] PPP Deflate Compression module registered
[ +0.005806] PPP MPPE Compression module registered
[ +0.005501] NET: Registered protocol family 24
[ +0.005180] usbcore: registered new interface driver r8152
[ +0.006224] usbcore: registered new interface driver asix
[ +0.006078] usbcore: registered new interface driver ax88179_178a
[ +0.006742] usbcore: registered new interface driver cdc_ether
[ +0.006532] usbcore: registered new interface driver smsc95xx
[ +0.003625] gpio tegra-gpio wake18 for gpio=101(M:5)
[ +0.000146] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ +0.014497] usbcore: registered new interface driver net1080
[ +0.006288] usbcore: registered new interface driver cdc_subset
[ +0.006526] usbcore: registered new interface driver zaurus
[ +0.006248] usbcore: registered new interface driver cdc_ncm
[ +0.006602] Wake76 for irq=199
[ +0.003616] Wake77 for irq=199
[ +0.003582] Wake78 for irq=199
[ +0.003555] Wake79 for irq=199
[ +0.003531] Wake80 for irq=199
[ +0.003505] Wake81 for irq=199
[ +0.003473] Wake82 for irq=199
[ +0.003536] tegra-xotg xotg: usb2 phy is not available yet
[ +0.006486] usbcore: registered new interface driver usb-storage
[ +0.006560] usbcore: registered new interface driver usbserial
[ +0.006310] usbcore: registered new interface driver ftdi_sio
[ +0.006177] usbserial: USB Serial support registered for FTDI USB Serial Device
[ +0.008148] usbcore: registered new interface driver option
[ +0.006047] usbserial: USB Serial support registered for GSM modem (1-port)
[ +0.007477] usbcore: registered new interface driver pl2303
[ +0.006084] usbserial: USB Serial support registered for pl2303
[ +0.006761] tegra-usb-cd usb_cd: otg phy is not available yet
[ +0.008443] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ +0.049404] ata1: SATA link down (SStatus 0 SControl 300)
[ +0.090192] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ +0.011233] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ +0.007896] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ +0.007187] i2c /dev entries driver
[ +0.005187] gspca_main: v2.14.0 registered
[ +0.005113] usbcore: registered new interface driver gspca_zc3xx
[ +0.007254] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ +0.009679] FAN: coudln't get the regulator
[ +0.005987] device-mapper: uevent: version 1.0.3
[ +0.005928] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-deve
[ +0.011167] sdhci: Secure Digital Host Controller Interface driver
[ +0.007439] sdhci: Copyright(c) Pierre Ossman
[ +0.005640] sdhci-pltfm: SDHCI platform and OF driver helper
[ +0.006796] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ +0.001286] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ +0.000142] hidraw: raw HID events driver (C) Jiri Kosina
[ +0.001983] usbcore: registered new interface driver usbhid
[ +0.000002] usbhid: USB HID core driver
[ +0.003822] nvadsp 2993000.adsp: in probe()...
[ +0.001198] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ +0.000051] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ +0.000236] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ +0.000814] Denver: backdoor interface is NOT available.
[ +0.002570] coresight-tmc 8030000.etf: TMC initialized
[ +0.001393] coresight-tmc 8050000.etr: TMC initialized
[ +0.000442] coresight-tpiu 8060000.tpiu: TPIU initialized
[ +0.000638] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ +0.000546] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ +0.000564] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ +0.000532] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ +0.000803] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ +0.006105] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ +0.000716] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ +0.000668] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ +0.000058] Module initialized successfully
[ +0.003361] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0x
[ +0.001728] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ +0.000349] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f si
[ +0.000518] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x10
[ +0.000090] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[
[ +0.000046] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x
[ +0.000044] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1
[ +0.000049] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1
[ +0.000048] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8
[ +0.000048] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9
[ +0.000184] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ +0.000004] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is success
[ +0.001433] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ +0.000005] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missin
[ +0.000005] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ +0.000003] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver miss
[ +0.000004] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver miss
[ +0.000003] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ +0.000003] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ +0.000060] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha
[ +0.004968] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ +0.000947] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ +0.000175] camchar: rtcpu character device driver loaded
[ +0.003789] tegra186-aondbg aondbg: aondbg driver probe() OK
[ +0.000248] register_ari_mca_banks: Registered MCA ROC:IOB
[ +0.000082] register_ari_mca_banks: Registered MCA ROC:CCE
[ +0.000322] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ +0.000035] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ +0.000031] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ +0.000033] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ +0.000030] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ +0.000030] tegra18-bridge 2100000.axip2p: bridge probed OK
[ +0.000030] tegra18-bridge 2110000.axip2p: bridge probed OK
[ +0.000031] tegra18-bridge 2120000.axip2p: bridge probed OK
[ +0.000030] tegra18-bridge 2130000.axip2p: bridge probed OK
[ +0.000028] tegra18-bridge 2140000.axip2p: bridge probed OK
[ +0.000029] tegra18-bridge 2150000.axip2p: bridge probed OK
[ +0.000031] tegra18-bridge 2160000.axip2p: bridge probed OK
[ +0.000033] tegra18-bridge 2170000.axip2p: bridge probed OK
[ +0.000031] tegra18-bridge 2180000.axip2p: bridge probed OK
[ +0.000060] tegra18-bridge 2190000.axip2p: bridge probed OK
[ +0.000047] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ +0.000128] parse_throttle_dt_data: Num cap clks = 4
[ +0.000004] parse_throttle_dt_data: clk=mcpu type=1
[ +0.000003] parse_throttle_dt_data: clk=bcpu type=2
[ +0.000007] parse_throttle_dt_data: clk=gpu type=4
[ +0.000003] parse_throttle_dt_data: clk=emc type=3
[ +0.000567] tegra_throttle_probe: probe successful. #cdevs=4
[ +0.000091] tegra18x_actmon d230000.actmon: in actmon_register()...
[ +0.000576] tegra18x_actmon d230000.actmon: initialization Completed for the dev
[ +0.000341] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counte
[ +0.002571] tegra-se-nvhost 15810000.se: initialized
[ +0.000521] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ +0.000372] tegra-se-nvhost 15820000.se: initialized
[ +0.000650] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ +0.000346] tegra-se-nvhost 15830000.se: initialized
[ +0.000166] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ +0.000338] tegra-se-nvhost 15840000.se: initialized
[ +0.000570] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ +0.005332] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ +0.003900] cpufreq: platform driver Initialization: pass
[ +0.000115] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[ +0.000096] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ +0.000145] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000000000352000
[ +0.000008] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 en
[ +0.000051] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ +0.000004] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ +0.001370] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ +0.001447] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ +0.002888] cpuidle: Initializing cpuidle driver init for Denver cluster
[ +0.000133] cpuidle: Initializing cpuidle driver init for A57 cluster
[ +0.001057] tachometer tegra-tachometer: Tachometer driver tegra-tachometer regi
[ +0.000004] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ +0.003982] tegra210_adsp_audio_platform_probe: platform probe started
[ +0.001106] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ +0.005028] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/i
[ +0.000135] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/i
[ +0.000168] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ +0.001026] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ +0.000654] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ +0.000541] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ +0.000006] tegra210-adsp adsp_audio: adma channel page address dt entry not fou
[ +0.000002] tegra210-adsp adsp_audio: using adma channel page 0
[ +0.011851] tegra210_adsp_audio_platform_probe probe successfull.
[ +0.000001] OPE platform probe
[ +0.000098] OPE platform probe successful
[ +0.016039] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, sh
[ +0.078240] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping o
[ +0.000104] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping o
[ +0.000107] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping o
[ +0.000112] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping o
[ +0.000087] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping o
[ +0.000091] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping o
[ +0.000089] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping o
[ +0.000089] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping o
[ +0.000096] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping o
[ +0.000090] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping
[ +0.000107] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping
[ +0.000099] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping
[ +0.000088] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping
[ +0.000089] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping
[ +0.000112] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping
[ +0.000091] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping
[ +0.000094] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping
[ +0.000090] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping
[ +0.000089] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping
[ +0.000112] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping
[ +0.003523] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mappin
[ +0.000114] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mappin
[ +0.000027] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ +0.000023] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ +0.031727] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/so
[ +0.000728] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" register
[ +0.000003] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ +0.000444] GACT probability NOT on
[ +0.000008] Mirror/redirect action on
[ +0.000010] u32 classifier
[ +0.000001] Actions configured
[ +0.000020] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ +0.000704] ipip: IPv4 over IPv4 tunneling driver
[ +0.000300] Initializing XFRM netlink socket
[ +0.000313] NET: Registered protocol family 10
[ +0.000706] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ +0.000075] NET: Registered protocol family 17
[ +0.000012] NET: Registered protocol family 15
[ +0.000024] bridge: automatic filtering via arp/ip/ip6tables has been deprecated
[ +0.000005] 8021q: 802.1Q VLAN Support v1.8
[ +0.003527] Registered cp15_barrier emulation handler
[ +0.012021] Registered setend emulation handler
[ +0.001233] registered taskstats version 1
[ +0.003248] isp 15600000.isp: initialized
[ +0.003898] nvcsi 150c0000.nvcsi: initialized
[ +0.001777] Wake76 for irq=199
[ +0.000001] Wake77 for irq=199
[ +0.000001] Wake78 for irq=199
[ +0.000001] Wake79 for irq=199
[ +0.000001] Wake80 for irq=199
[ +0.000000] Wake81 for irq=199
[ +0.000001] Wake82 for irq=199
[ +0.000193] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ +0.000330] spi-tegra114 3210000.spi: Static pin configuration used
[ +0.000640] spi-tegra114 c260000.spi: Static pin configuration used
[ +0.000636] spi-tegra114 3240000.spi: Static pin configuration used
[ +0.000506] Wake76 for irq=199
[ +0.000000] Wake80 for irq=199
[ +0.000001] Wake81 for irq=199
[ +0.000024] tegra-xotg xotg: usb2 phy is not available yet
[ +0.000133] tegra-usb-cd usb_cd: otg phy is not available yet
[ +0.000369] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ +0.000143] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000000000352000
[ +0.000005] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 en
[ +0.000033] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ +0.000003] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ +0.000708] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ +0.002041] Wake76 for irq=199
[ +0.000165] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ +0.000761] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ +0.000102] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ +0.000056] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ +0.000121] input: gpio-keys as /devices/gpio-keys/input/input3
[ +0.000313] Wake76 for irq=199
[ +0.000000] Wake82 for irq=199
[ +0.000135] tegra-usb-cd usb_cd: otg phy is not available yet
[ +0.000353] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ +0.000136] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000000000352000
[ +0.000004] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 en
[ +0.000031] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ +0.000711] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ +0.001798] Wake76 for irq=199
[ +0.000000] Wake78 for irq=199
[ +0.000153] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ +0.033797] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 02:35:19 U
[ +0.029822] bpmp: mounted debugfs mirror
[ +0.000488] [dram-timers] DRAM derating cdev registered.
[ +0.004075] spmic-ldo0: disabling
[ +0.000177] spmic-ldo1: disabling
[ +0.000144] vddio-sdmmc1: disabling
[ +0.000170] avdd-ts-hv: disabling
[ +0.000168] en-vdd-sd: disabling
[ +0.000002] en-vdd-cam: disabling
[ +0.000002] vdd-usb0-5v: disabling
[ +0.000001] vdd-usb1-5v: disabling
[ +0.000002] en-vdd-cam-1v2: disabling
[ +0.000001] vdd-3v3: disabling
[ +0.000001] en-vdd-vcm-2v8: disabling
[ +0.000002] vdd-sys-bl: disabling
[ +0.000001] en-vdd-sys: disabling
[ +0.006626] ALSA device list:
[ +0.000003] #0: tegra-hda at 0x3518000 irq 400
[ +0.000001] #1: tegra-snd-t186ref-mobile-rt565x
[ +0.000784] tegra-vi4 15700000.vi: initialized
[ +0.001128] tegra-vi4 15700000.vi: all channel register failed
[ +0.000253] Wake76 for irq=199
[ +0.000000] Wake79 for irq=199
[ +0.000035] tegra-xotg xotg: usb2 phy is not available yet
[ +0.000198] tegra-usb-cd usb_cd: otg phy is not available yet
[ +0.000425] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ +0.000163] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000000000352000
[ +0.000036] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ +0.000723] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ +0.002077] Wake76 for irq=199
[ +0.000000] Wake77 for irq=199
[ +0.000178] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ +1.339345] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ +0.008575] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ +0.040656] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 6
[ +0.010324] Wake76 for irq=199
[ +0.000035] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ +0.000275] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ +0.018751] Wake77 for irq=199
[ +0.003704] Wake78 for irq=199
[ +0.003674] Wake79 for irq=199
[ +0.003635] Wake80 for irq=199
[ +0.003598] Wake81 for irq=199
here after sending Jetson_clocks command
[code][ 3.653813] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.654465] ipip: IPv4 over IPv4 tunneling driver
[ 3.654776] Initializing XFRM netlink socket
[ 3.655063] NET: Registered protocol family 10
[ 3.655734] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.655792] NET: Registered protocol family 17
[ 3.655804] NET: Registered protocol family 15
[ 3.655824] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.655829] 8021q: 802.1Q VLAN Support v1.8
[ 3.659065] Registered cp15_barrier emulation handler
[ 3.671087] Registered setend emulation handler
[ 3.672316] registered taskstats version 1
[ 3.675529] isp 15600000.isp: initialized
[ 3.679298] nvcsi 150c0000.nvcsi: initialized
[ 3.681056] Wake76 for irq=199
[ 3.681057] Wake77 for irq=199
[ 3.681058] Wake78 for irq=199
[ 3.681058] Wake79 for irq=199
[ 3.681059] Wake80 for irq=199
[ 3.681060] Wake81 for irq=199
[ 3.681060] Wake82 for irq=199
[ 3.681259] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 3.681598] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.682221] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.682825] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.683319] Wake76 for irq=199
[ 3.683320] Wake77 for irq=199
[ 3.683321] Wake78 for irq=199
[ 3.683321] Wake79 for irq=199
[ 3.683322] Wake80 for irq=199
[ 3.683323] Wake81 for irq=199
[ 3.683323] Wake82 for irq=199
[ 3.683347] tegra-xotg xotg: usb2 phy is not available yet
[ 3.683483] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.683848] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.683983] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.683988] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.684023] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 3.684026] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.684734] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.686738] Wake76 for irq=199
[ 3.686739] Wake77 for irq=199
[ 3.686740] Wake78 for irq=199
[ 3.686741] Wake80 for irq=199
[ 3.686742] Wake81 for irq=199
[ 3.686742] Wake82 for irq=199
[ 3.686917] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 3.687715] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 3.687805] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 3.687861] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 3.687981] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.688304] Wake76 for irq=199
[ 3.688305] Wake77 for irq=199
[ 3.688306] Wake78 for irq=199
[ 3.688307] Wake79 for irq=199
[ 3.688307] Wake80 for irq=199
[ 3.688308] Wake81 for irq=199
[ 3.688309] Wake82 for irq=199
[ 3.688334] tegra-xotg xotg: usb2 phy is not available yet
[ 3.688457] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.688800] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.688926] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.688930] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.688962] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 3.688964] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.689662] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.691463] Wake76 for irq=199
[ 3.691464] Wake77 for irq=199
[ 3.691464] Wake78 for irq=199
[ 3.691465] Wake79 for irq=199
[ 3.691466] Wake80 for irq=199
[ 3.691466] Wake81 for irq=199
[ 3.691467] Wake82 for irq=199
[ 3.691634] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 3.725698] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 03:01:13 UTC (946695673)
[ 3.755617] bpmp: mounted debugfs mirror
[ 3.756111] [dram-timers] DRAM derating cdev registered.
[ 3.760023] spmic-ldo0: disabling
[ 3.760203] spmic-ldo1: disabling
[ 3.760349] vddio-sdmmc1: disabling
[ 3.760518] avdd-ts-hv: disabling
[ 3.760678] en-vdd-sd: disabling
[ 3.760680] en-vdd-cam: disabling
[ 3.760682] vdd-usb0-5v: disabling
[ 3.760683] vdd-usb1-5v: disabling
[ 3.760685] en-vdd-cam-1v2: disabling
[ 3.760686] vdd-3v3: disabling
[ 3.760688] en-vdd-vcm-2v8: disabling
[ 3.760689] vdd-sys-bl: disabling
[ 3.760691] en-vdd-sys: disabling
[ 3.768155] ALSA device list:
[ 3.768157] #0: tegra-hda at 0x3518000 irq 400
[ 3.768158] #1: tegra-snd-t186ref-mobile-rt565x
[ 3.768977] tegra-vi4 15700000.vi: initialized
[ 3.770124] tegra-vi4 15700000.vi: all channel register failed
[ 3.770396] Wake76 for irq=199
[ 3.770397] Wake77 for irq=199
[ 3.770398] Wake78 for irq=199
[ 3.770398] Wake79 for irq=199
[ 3.770399] Wake80 for irq=199
[ 3.770400] Wake81 for irq=199
[ 3.770400] Wake82 for irq=199
[ 3.770433] tegra-xotg xotg: usb2 phy is not available yet
[ 3.770626] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.771047] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.771198] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.771202] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.771240] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 3.771243] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.771970] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.774096] Wake76 for irq=199
[ 3.774097] Wake77 for irq=199
[ 3.774098] Wake78 for irq=199
[ 3.774098] Wake79 for irq=199
[ 3.774099] Wake80 for irq=199
[ 3.774100] Wake81 for irq=199
[ 3.774100] Wake82 for irq=199
[ 3.774278] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 5.112548] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 5.121170] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 5.161848] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.172263] Wake76 for irq=199
[ 5.172321] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 5.172586] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 5.191304] Wake77 for irq=199
[ 5.195007] Wake78 for irq=199
[ 5.198681] Wake79 for irq=199
[ 5.202316] Wake80 for irq=199
[ 5.205782] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.206002] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.206045] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 5.206102] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 5.206123] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 5.206396] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 5.231754] mmc0: MAN_BKOPS_EN bit is not set
[ 5.238960] mmc0: Skipping tuning since strobe enabled
[ 5.245809] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 5.245838] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.246264] Waiting for root device /dev/mmcblk0p1…
[ 5.246392] mmc0: periodic cache flush enabled
[ 5.246399] mmc0: new HS400 MMC card at address 0001
[ 5.246643] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 5.246760] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 5.246885] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 5.247001] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 5.248234] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 5.286100] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 5.331968] Wake81 for irq=199
[ 5.335683] Wake82 for irq=199
[ 5.339523] tegra-xotg xotg: usb2 phy is not available yet
[ 5.346064] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.352799] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.359992] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.370394] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.380532] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb915
[ 5.387927] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.400175] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.412762] Wake76 for irq=199
[ 5.416301] Wake77 for irq=199
We have changed tha onboard cam of the dev kit with HDMI2CSI board for a while. However, it has been worked with that for 3-4 weeks. During taking the logs, there was no other component on carrier board (no hdmi2csi board).
The logs are correct yes. I will make sure again when i connect it.
This looks like a hardware issue on usb3-0.
In the beginning, I thought your carrier board does not have pin out for usb3-0. But turns out not correct because you said it was working for 3~4 weeks. You have tested usb3.0 port on this carrier board in past, right?
there s no change if usb/hdmi plug connected or disconnected.
ubuntu@tegra-ubuntu:~$ sudo cat /sys/kernel/debug/gpio
[sudo] password for ubuntu:
GPIOs 232-239, platform/max77620-gpio, max77620-gpio, can sleep:
gpio-232 ( |external-connection:) in hi
gpio-237 ( |spmic_gpio_input_5 ) in lo
gpio-238 ( |spmic_gpio_input_6 ) in hi
GPIOs 240-255, i2c/0-0077, tca9539, can sleep:
gpio-243 ( |en-vdd-sys ) out lo
gpio-244 ( |lcd-bias-en-rail ) out hi
gpio-249 ( |en-vdd-cam ) out lo
gpio-250 ( |en-vdd-cam-1v2 ) out lo
GPIOs 256-319, platform/c2f0000.gpio, tegra-gpio-aon:
gpio-272 ( |temp_alert ) in hi
gpio-312 ( |Power ) in hi
gpio-313 ( |Volume Up ) in hi
gpio-314 ( |Volume Down ) in hi
gpio-315 ( |wifi-wake-ap ) in lo
gpio-316 ( |bt_host_wake ) in lo
GPIOs 320-511, platform/2200000.gpio, tegra-gpio:
gpio-381 ( |reset_gpio ) out lo
gpio-412 ( |vdd-usb0-5v ) out lo
gpio-413 ( |vdd-usb1-5v ) out lo
gpio-420 ( |eqos_phy_reset ) out hi
gpio-421 ( |eqos_phy_intr ) in hi
gpio-424 ( |wlan_pwr ) out hi
gpio-426 ( |cam1-pwdn ) out lo
gpio-441 ( |hdmi2.0_hpd ) in hi
gpio-444 ( |wp ) in hi
gpio-445 ( |cd ) in hi
gpio-446 ( |en-vdd-sd ) out lo
gpio-456 ( |cam0-pwdn ) out lo
gpio-457 ( |cam1-rst ) out lo
gpio-461 ( |cam0-rst ) out lo
gpio-479 ( |external-connection:) in lo
gpio-484 ( |bt_ext_wake ) out hi
Do you mean toggling DP1_HPD pin and HDMI_CEC pin?
DP1_HPD DP_AUX_CH1_HPD Display Port 1 Hot Plug Detect
HDMI_CEC HDMI_CEC HDMI CEC7
Edit: How do i send signal (or toggle) from HDMI_HPD? - this is the 19th pin of the hdmi port on developer carrier board.
