Hello,all.
I try to use a USB-C RJ45 Adapter for ethernet on jetson NX,and the system can find the eth1 device and some network informations(mac、ip、mtu、netmask…)also can be set by ifconfig commands,but the USB-C RJ45 Adapter can not work 。what are the reasons?and how to solove it? is there anyone know or provide some solution?Thanks.
Not quite sure about your problem. Are you saying that eth1 shows up with MAC/IP info but still not able to work?
yes.the eth1 is the USB-C RJ45 Adapter divice identified by system.
If eth1 shows up, it may not be usb side issue.
Any dmesg/ifconfig info to share here?
But when I pull out the USB-C RJ45 Adapter ,there is no eth1 info.
I don’t know what do you try to say here. Since eth1 is coming from USB-C RJ45, isn’t it normal the info gone when you remove the device?
ok,I known that. some dmsg info:
[ 86.174276] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 86.175340] ax88179_178a 2-3.3:2.1 eth2: register ‘ax88179_178a’ at usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, b6:74:a2:94:5a:5e
[ 86.315287] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 86.324531] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 86.336085] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 86.548535] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 86.665147] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0001: -32
[ 86.676723] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0006: -32
[ 86.688484] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0005: -32
[ 86.700080] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 86.711712] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 86.724747] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 86.736481] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 86.748083] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 86.759725] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 86.771469] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 86.784527] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0001: -32
[ 86.796123] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 86.807712] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x001f: -32
[ 86.819494] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0019: -32
[ 86.831060] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x001f: -32
[ 86.844103] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 86.855720] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 86.867507] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 86.879069] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x000e: -32
[ 86.890679] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 86.903758] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 86.915474] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 86.927089] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 86.938715] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0000: -32
[ 86.950453] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0000: -32
[ 86.950983] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 86.964037] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 86.998456] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 87.010086] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 87.224430] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 87.337951] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0001: -32
[ 87.351363] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0006: -32
[ 87.362910] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0005: -32
[ 87.374720] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 87.386440] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 87.398037] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 87.411096] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 87.422686] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 87.434449] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 87.446047] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 87.457640] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0001: -32
[ 87.470706] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 87.482473] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x001f: -32
[ 87.494090] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0019: -32
[ 87.505694] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x001f: -32
[ 87.517438] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 87.530481] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 87.542073] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 87.553673] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x000e: -32
[ 87.565486] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 87.577037] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 87.590080] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 87.601705] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 87.613439] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0000: -32
[ 87.625074] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0000: -32
[ 87.625679] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 88.949018] usb 2-3.3: USB disconnect, device number 3
[ 88.949153] ax88179_178a 2-3.3:2.0 eth1: unregister ‘ax88179_178a’ usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 88.949195] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0002: -19
[ 88.949364] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -19
[ 88.972987] ax88179_178a 2-3.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 88.973181] ax88179_178a 2-3.3:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 88.973338] ax88179_178a 2-3.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 88.974175] ax88179_178a 2-3.3:2.1 eth2: unregister ‘ax88179_178a’ usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 88.974208] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0002: -19
[ 88.974381] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -19
[ 88.996922] ax88179_178a 2-3.3:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -19
[ 88.997129] ax88179_178a 2-3.3:2.1 eth2 (unregistered): Failed to write reg index 0x0001: -19
[ 88.997287] ax88179_178a 2-3.3:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -19
[ 89.333775] usb 2-3.3: new SuperSpeed USB device number 4 using tegra-xusb
[ 89.499836] usb 2-3.3: New USB device found, idVendor=0b95, idProduct=1790
[ 89.499846] usb 2-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 89.499852] usb 2-3.3: Product: AX88179A
[ 89.499856] usb 2-3.3: Manufacturer: ASIX
[ 89.499861] usb 2-3.3: SerialNumber: 00910160
[ 90.175284] ax88179_178a 2-3.3:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[ 90.487773] ax88179_178a 2-3.3:1.0 eth1: register ‘ax88179_178a’ at usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:91:01:60
[ 90.596660] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 91.155828] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 91.470942] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 108.218420] eqos 2490000.ether_qos eth0: Link is Down
[ 121.979168] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 406.718917] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 406.718927] Extcon AUX1(HDMI) disable
[ 406.743129] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 406.744563] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 406.745146] tegradc 15200000.nvdisplay: blank - powerdown
[ 406.745289] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 406.745295] Extcon HDMI: HPD disabled
[ 406.745330] tegradc 15200000.nvdisplay: hdmi: unplugged
[ 406.753120] tegradc 15200000.nvdisplay: blank - powerdown
[ 406.753138] tegradc 15200000.nvdisplay: unblank
[ 406.754001] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 406.754107] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 406.756355] Parent Clock set for DC plld2
[ 406.760566] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 406.761942] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 406.796554] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 406.796559] Extcon AUX1(HDMI) enable
[ 406.796629] tegradc 15200000.nvdisplay: unblank
[ 406.796642] tegradc 15210000.nvdisplay: blank - powerdown
[ 406.884300] tegradc 15200000.nvdisplay: blank - powerdown
[ 406.945597] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 406.945602] Extcon AUX1(HDMI) disable
[ 406.967792] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 406.968885] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 406.969049] tegradc 15200000.nvdisplay: unblank
[ 406.969913] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 406.970028] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 406.971396] Parent Clock set for DC plld2
[ 406.977108] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 406.978624] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 407.013117] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 407.013122] Extcon AUX1(HDMI) enable
[ 407.013228] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 407.013233] Extcon HDMI: HPD enabled
[ 407.013265] tegradc 15200000.nvdisplay: hdmi: plugged
[ 407.023700] tegradc 15200000.nvdisplay: unblank
[ 407.023720] tegradc 15210000.nvdisplay: blank - powerdown
[ 407.089110] tegradc 15200000.nvdisplay: unblank
[ 407.089123] tegradc 15210000.nvdisplay: blank - powerdown
[ 483.072697] Tx0DMA is not suspended
[ 489.073626] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 489.081672] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 491.957165] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 491.957842] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 510.881167] eqos 2490000.ether_qos eth0: Link is Down
[ 516.405942] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control off
[ 524.949148] eqos 2490000.ether_qos eth0: Link is Down
[ 540.015830] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 610.508487] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 610.827275] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 651.467708] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 651.785238] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 663.972165] usb 1-2.4: USB disconnect, device number 4
[ 664.276770] usb 1-2: usb_suspend_both: status 0
[ 664.276864] usb usb1: usb_suspend_both: status 0
[ 667.864748] usb 1-2.4: new low-speed USB device number 6 using tegra-xusb
[ 667.888882] usb 1-2.4: New USB device found, idVendor=093a, idProduct=2510
[ 667.888892] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 667.888899] usb 1-2.4: Product: USB Optical Mouse
[ 667.888904] usb 1-2.4: Manufacturer: PixArt
[ 667.892573] input: PixArt USB Optical Mouse as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:093A:2510.0004/input/input8
[ 667.893519] hid-generic 0003:093A:2510.0004: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3610000.xhci-2.4/input0
[ 703.908134] usb 1-2.4: USB disconnect, device number 6
[ 704.128721] usb 1-2: usb_suspend_both: status 0
[ 704.128796] usb usb1: usb_suspend_both: status 0
[ 708.784717] usb 1-2.4: new low-speed USB device number 7 using tegra-xusb
[ 708.810288] usb 1-2.4: New USB device found, idVendor=046d, idProduct=c31c
[ 708.810298] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 708.810304] usb 1-2.4: Product: USB Keyboard
[ 708.810309] usb 1-2.4: Manufacturer: Logitech
[ 708.816663] input: Logitech USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:046D:C31C.0005/input/input9
[ 708.878114] hid-generic 0003:046D:C31C.0005: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3610000.xhci-2.4/input0
[ 708.886710] input: Logitech USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:046D:C31C.0006/input/input10
[ 708.945522] hid-generic 0003:046D:C31C.0006: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3610000.xhci-2.4/input1
[ 793.819389] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 794.137881] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 833.380614] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 833.697918] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 861.307930] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 861.628261] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 895.193841] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 895.511298] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 915.929623] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 915.935576] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 918.824990] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 918.825652] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 960.972413] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 961.290219] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 1274.056182] tegradc 15200000.nvdisplay: blank - powerdown
[ 1274.112299] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1274.112305] Extcon AUX1(HDMI) disable
[ 1274.136976] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1274.137954] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
How many usb-c RJ45 dongle is in use here? Can you only use one dongle, connect it to the board and share the dmesg?
[ 3.283881] Root device found: mmcblk0p1
[ 3.285606] Found dev node: /dev/mmcblk0p1
[ 3.310125] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.313118] Rootfs mounted over mmcblk0p1
[ 3.335367] Switching from initrd to actual rootfs
[ 3.461396] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.465253] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.473627] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.474268] systemd[1]: Detected architecture arm64.
[ 3.482171] systemd[1]: Set hostname to <nvidia-desktop>.
[ 3.566840] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.566851] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.646805] ax88179_178a 2-3.3:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[ 3.716644] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.719541] systemd[1]: Created slice System Slice.
[ 3.719796] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.720057] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 3.720090] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.720131] systemd[1]: Reached target User and Group Name Lookups.
[ 3.720476] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.720526] systemd[1]: Reached target Swap.
[ 3.752413] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.860203] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 3.873956] cpu-throttle-alert cooling device registered.
[ 3.875788] gpu-throttle-alert cooling device registered.
[ 3.876465] aux-throttle-alert cooling device registered.
[ 3.961348] ax88179_178a 2-3.3:1.0 eth1: register 'ax88179_178a' at usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:91:01:60
[ 4.073344] systemd-journald[2422]: Received request to flush runtime journal from PID 1
[ 4.934398] random: crng init done
[ 4.934546] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.952678] using random self ethernet address
[ 4.952852] using random host ethernet address
[ 5.672432] Mass Storage Function, version: 2009/09/11
[ 5.672503] LUN: removable file: (no medium)
[ 5.679324] using random self ethernet address
[ 5.679486] using random host ethernet address
[ 5.712651] rndis0: HOST MAC 8e:15:5d:ad:25:0c
[ 5.712948] rndis0: MAC 8e:15:5d:ad:25:0d
[ 5.716251] usb0: HOST MAC 8e:15:5d:ad:25:0e
[ 5.716361] usb0: MAC 8e:15:5d:ad:25:0f
[ 5.716386] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.720098] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.720119] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.720165] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.720434] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.720449] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.720908] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.720926] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.721124] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.730309] l4tbr0: port 1(rndis0) entered blocking state
[ 5.730317] l4tbr0: port 1(rndis0) entered disabled state
[ 5.730493] device rndis0 entered promiscuous mode
[ 5.739048] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.746641] l4tbr0: port 2(usb0) entered blocking state
[ 5.746650] l4tbr0: port 2(usb0) entered disabled state
[ 5.751045] device usb0 entered promiscuous mode
[ 5.794429] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.999575] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 6.107856] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.285138] zram: Added device: zram0
[ 6.289539] zram: Added device: zram1
[ 6.293075] zram: Added device: zram2
[ 6.301136] zram: Added device: zram3
[ 6.305347] zram: Added device: zram4
[ 6.308418] zram: Added device: zram5
[ 6.356734] zram0: detected capacity change from 0 to 678567936
[ 6.399767] Adding 662660k swap on /dev/zram0. Priority:5 extents:1 across:662660k SS
[ 6.421661] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 6.429778] zram1: detected capacity change from 0 to 678567936
[ 6.459963] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.480010] Adding 662660k swap on /dev/zram1. Priority:5 extents:1 across:662660k SS
[ 6.486585] zram2: detected capacity change from 0 to 678567936
[ 6.507735] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 6.518749] Adding 662660k swap on /dev/zram2. Priority:5 extents:1 across:662660k SS
[ 6.527909] zram3: detected capacity change from 0 to 678567936
[ 6.562159] Adding 662660k swap on /dev/zram3. Priority:5 extents:1 across:662660k SS
[ 6.567366] zram4: detected capacity change from 0 to 678567936
[ 6.605797] Adding 662660k swap on /dev/zram4. Priority:5 extents:1 across:662660k SS
[ 6.611367] zram5: detected capacity change from 0 to 678567936
[ 6.628886] Adding 662660k swap on /dev/zram5. Priority:5 extents:1 across:662660k SS
[ 7.084981] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 7.426106] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.674534] tegradc 15200000.nvdisplay: unblank
[ 7.674548] tegradc 15210000.nvdisplay: blank - powerdown
[ 8.569481] fuse init (API version 7.26)
[ 9.348810] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9.349452] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.895986] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.896004] Bluetooth: BNEP socket layer initialized
[ 22.879162] tegradc 15200000.nvdisplay: blank - powerdown
[ 22.943366] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 22.943370] Extcon AUX1(HDMI) disable
[ 22.967192] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 22.967985] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 22.968180] tegradc 15210000.nvdisplay: blank - powerdown
[ 23.146494] tegradc 15200000.nvdisplay: blank - powerdown
[ 23.146512] tegradc 15200000.nvdisplay: unblank
[ 23.147301] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 23.147419] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 23.149374] Parent Clock set for DC plld2
[ 23.154360] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 23.155784] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 23.193572] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 23.193576] Extcon AUX1(HDMI) enable
[ 23.193663] tegradc 15200000.nvdisplay: unblank
[ 23.193677] tegradc 15210000.nvdisplay: blank - powerdown
[ 28.891638] tegradc 15200000.nvdisplay: unblank
[ 28.891652] tegradc 15210000.nvdisplay: blank - powerdown
[ 34.140419] vdd-sdmmc1-sw: disabling
[ 34.140427] vdd-1v8-sd: disabling
[ 34.140432] vdd-otg-5v: disabling
[ 34.140437] vdd-1v8-cvb: disabling
[ 34.140440] vdd-epb-1v0: disabling
[ 34.140444] avdd-cam-2v8: disabling
[ 34.140451] vdd_sys_en: disabling
[ 400.465449] tegradc 15200000.nvdisplay: blank - powerdown
[ 400.522731] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 400.522736] Extcon AUX1(HDMI) disable
[ 400.545308] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 400.545888] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 405.276432] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 405.276442] Extcon HDMI: HPD disabled
[ 405.276485] tegradc 15200000.nvdisplay: hdmi: unplugged
[ 405.297916] tegradc 15200000.nvdisplay: blank - powerdown
[ 405.297934] tegradc 15200000.nvdisplay: unblank
[ 405.297954] tegradc 15200000.nvdisplay: unblank
[ 405.297966] tegradc 15210000.nvdisplay: blank - powerdown
[ 405.507515] tegradc 15200000.nvdisplay: blank - powerdown
[ 405.507537] tegradc 15200000.nvdisplay: unblank
[ 405.508704] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 405.508950] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 405.511951] Parent Clock set for DC plld2
[ 405.519352] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 405.520775] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 405.563832] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 405.563836] Extcon AUX1(HDMI) enable
[ 405.564008] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 405.564013] Extcon HDMI: HPD enabled
[ 405.564077] tegradc 15200000.nvdisplay: hdmi: plugged
[ 405.593940] tegradc 15200000.nvdisplay: unblank
[ 405.593955] tegradc 15210000.nvdisplay: blank - powerdown
[ 405.609141] tegradc 15200000.nvdisplay: unblank
[ 405.609158] tegradc 15210000.nvdisplay: blank - powerdown
[ 1115.924440] usb 2-3.3: USB disconnect, device number 3
[ 1115.925141] ax88179_178a 2-3.3:1.0 eth1: unregister 'ax88179_178a' usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 1115.925197] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0002: -19
[ 1115.925387] ax88179_178a 2-3.3:1.0 eth1: Failed to write reg index 0x0002: -19
[ 1115.952387] ax88179_178a 2-3.3:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 1115.952590] ax88179_178a 2-3.3:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 1115.952746] ax88179_178a 2-3.3:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 1116.148300] usb 2-3: usb_suspend_both: status 0
[ 1116.148504] usb usb2: usb_suspend_both: status 0
[ 1120.196301] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 1120.220515] usb 1-2.3: New USB device found, idVendor=093a, idProduct=2510
[ 1120.220525] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1120.220531] usb 1-2.3: Product: USB Optical Mouse
[ 1120.220536] usb 1-2.3: Manufacturer: PixArt
[ 1120.223642] input: PixArt USB Optical Mouse as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:093A:2510.0003/input/input7
[ 1120.224153] hid-generic 0003:093A:2510.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3610000.xhci-2.3/input0
[ 1151.715625] usb 1-2.3: USB disconnect, device number 4
[ 1157.393326] usb 2-3.3: new SuperSpeed USB device number 4 using tegra-xusb
[ 1157.663142] usb 2-3.3: New USB device found, idVendor=0b95, idProduct=1790
[ 1157.663151] usb 2-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1157.663157] usb 2-3.3: Product: AX88179A
[ 1157.663162] usb 2-3.3: Manufacturer: ASIX
[ 1157.663167] usb 2-3.3: SerialNumber: 00910160
[ 1157.757643] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1157.767977] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1157.982863] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.096115] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 1158.106479] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 1158.116845] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.128562] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.138921] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.149286] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.159793] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1158.170160] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.181889] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1158.192239] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 1158.202602] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.212960] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 1158.223465] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 1158.235388] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 1158.245725] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1158.256089] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1158.266598] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1158.276941] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 1158.288838] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1158.299354] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1158.309708] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1158.320059] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1158.330584] ax88179_178a 2-3.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 1158.331817] ax88179_178a 2-3.3:2.0 eth1: register 'ax88179_178a' at usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, 4e:20:71:3e:67:1e
[ 1158.473544] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1158.483893] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1158.695425] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.806817] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 1158.817360] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 1158.827682] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.838046] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.849986] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.860378] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.870703] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1158.881056] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.891580] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1158.903370] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 1158.913709] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1158.924071] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 1158.934428] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 1158.944797] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 1158.956582] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1158.966934] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1158.977472] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1158.987802] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 1158.998452] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1159.010404] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1159.020775] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1159.031434] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1159.041784] ax88179_178a 2-3.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 1159.042980] ax88179_178a 2-3.3:2.1 eth2: register 'ax88179_178a' at usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, 4e:20:71:3e:67:1e
[ 1159.181369] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 1159.189200] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 1159.200759] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 1159.418233] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1159.535051] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0001: -32
[ 1159.546655] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0006: -32
[ 1159.558435] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0005: -32
[ 1159.569999] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1159.581762] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1159.594811] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1159.606414] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1159.618007] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 1159.629775] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1159.641531] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 1159.654594] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0001: -32
[ 1159.666207] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1159.677795] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x001f: -32
[ 1159.689546] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0019: -32
[ 1159.701169] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x001f: -32
[ 1159.714197] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 1159.725991] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 1159.737583] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 1159.749187] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x000e: -32
[ 1159.760766] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 1159.773818] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 1159.785447] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 1159.797030] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 1159.808786] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0000: -32
[ 1159.820560] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0000: -32
[ 1159.821018] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 1159.835192] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 1159.868544] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 1159.880169] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 1160.096886] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1160.214447] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0001: -32
[ 1160.226058] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0006: -32
[ 1160.237665] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0005: -32
[ 1160.249266] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1160.260859] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1160.273930] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1160.285513] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1160.297131] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 1160.308726] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1160.320470] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 1160.333529] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0001: -32
[ 1160.345146] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1160.356727] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x001f: -32
[ 1160.368486] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0019: -32
[ 1160.380086] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x001f: -32
[ 1160.393134] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 1160.404772] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 1160.416528] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 1160.428131] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x000e: -32
[ 1160.439811] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 1160.452765] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 1160.464509] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 1160.476131] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 1160.487735] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0000: -32
[ 1160.499477] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0000: -32
[ 1160.499890] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 1161.828450] usb 2-3.3: USB disconnect, device number 4
[ 1161.828591] ax88179_178a 2-3.3:2.0 eth1: unregister 'ax88179_178a' usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 1161.828636] ax88179_178a 2-3.3:2.0 eth1: Failed to read reg index 0x0002: -19
[ 1161.828807] ax88179_178a 2-3.3:2.0 eth1: Failed to write reg index 0x0002: -19
[ 1161.864418] ax88179_178a 2-3.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 1161.864644] ax88179_178a 2-3.3:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 1161.864797] ax88179_178a 2-3.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 1161.865255] ax88179_178a 2-3.3:2.1 eth2: unregister 'ax88179_178a' usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 1161.865279] ax88179_178a 2-3.3:2.1 eth2: Failed to read reg index 0x0002: -19
[ 1161.865414] ax88179_178a 2-3.3:2.1 eth2: Failed to write reg index 0x0002: -19
[ 1161.900378] ax88179_178a 2-3.3:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -19
[ 1161.900605] ax88179_178a 2-3.3:2.1 eth2 (unregistered): Failed to write reg index 0x0001: -19
[ 1161.900761] ax88179_178a 2-3.3:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -19
[ 1162.201797] usb 2-3.3: new SuperSpeed USB device number 5 using tegra-xusb
[ 1162.367838] usb 2-3.3: New USB device found, idVendor=0b95, idProduct=1790
[ 1162.367847] usb 2-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1162.367852] usb 2-3.3: Product: AX88179A
[ 1162.367856] usb 2-3.3: Manufacturer: ASIX
[ 1162.367861] usb 2-3.3: SerialNumber: 00910160
[ 1163.042419] ax88179_178a 2-3.3:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[ 1163.355056] ax88179_178a 2-3.3:1.0 eth1: register 'ax88179_178a' at usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:91:01:60
[ 1163.463307] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 1164.022653] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 1164.334083] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Why are there always 2 eth on your side? That ethernet dongle provides 2 interfaces?
From the tegra side, looks like usb driver does not respond error log. This looks like vendor driver issue.
Please contact vendor for those “failed to read reg” error.
yes.I only use one.
well. The vendor provides soft driver source code.And I make ax88179_178a.ko kernel file ok.but insmod it fail.
nvidia@nvidia-desktop:~/AX88179_178A_Linux_Driver_v1.20.0_source$ sudo insmod ax88179_178a.ko
[sudo] password for nvidia:
insmod: ERROR: could not insert module ax88179_178a.ko: Device or resource busy
nvidia@nvidia-desktop:~/AX88179_178A_Linux_Driver_v1.20.0_source$ ls
ax88179_178a.c ax88179_178a.h ax88179_178a.ko ax88179_178a.mod.c ax88179_178a.mod.o ax88179_178a.o Makefile modules.order Module.symvers readme
Looks like the driver is already loaded?
nvidia@nvidia-desktop:~/AX88179_178A_Linux_Driver_v1.20.0_source$ lsmod
Module Size Used by
bnep 16562 2
fuse 103969 5
zram 25920 6
overlay 48718 0
spidev 13282 0
userspace_alert 5756 0
nvgpu 1581474 33
bluedroid_pm 13912 0
ip_tables 19441 0
x_tables 28951 1 ip_tables
nvidia@nvidia-desktop:~/AX88179_178A_Linux_Driver_v1.20.0_source$ cat /proc/modules
bnep 16562 2 - Live 0x0000000000000000
fuse 103969 5 - Live 0x0000000000000000
zram 25920 6 - Live 0x0000000000000000
overlay 48718 0 - Live 0x0000000000000000
spidev 13282 0 - Live 0x0000000000000000
userspace_alert 5756 0 - Live 0x0000000000000000
nvgpu 1581474 33 - Live 0x0000000000000000
bluedroid_pm 13912 0 - Live 0x0000000000000000
ip_tables 19441 0 - Live 0x0000000000000000
x_tables 28951 1 ip_tables, Live 0x0000000000000000
Try to reboot the device.
I had tried many times,it‘s the same problem.
What is the dmesg printed after insmod failed?
[ 3.547385] cpu-throttle-alert cooling device registered.
[ 3.548018] gpu-throttle-alert cooling device registered.
[ 3.548538] aux-throttle-alert cooling device registered.
[ 3.672645] ax88179_178a 2-3.3:1.0 eth1: register ‘ax88179_178a’ at usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:91:01:60
[ 3.801629] systemd-journald[2303]: Received request to flush runtime journal from PID 1
[ 4.564898] using random self ethernet address
[ 4.565060] using random host ethernet address
[ 4.597614] random: crng init done
[ 4.597751] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.384970] Mass Storage Function, version: 2009/09/11
[ 5.384979] LUN: removable file: (no medium)
[ 5.390768] using random self ethernet address
[ 5.390929] using random host ethernet address
[ 5.421018] rndis0: HOST MAC 8e:15:5d:ad:25:0c
[ 5.423618] rndis0: MAC 8e:15:5d:ad:25:0d
[ 5.426306] usb0: HOST MAC 8e:15:5d:ad:25:0e
[ 5.426351] usb0: MAC 8e:15:5d:ad:25:0f
[ 5.426377] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.430692] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.430716] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.430756] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.430977] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.430992] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.431448] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.431463] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.431639] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.436919] l4tbr0: port 1(rndis0) entered blocking state
[ 5.436927] l4tbr0: port 1(rndis0) entered disabled state
[ 5.437105] device rndis0 entered promiscuous mode
[ 5.443070] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.451270] l4tbr0: port 2(usb0) entered blocking state
[ 5.451280] l4tbr0: port 2(usb0) entered disabled state
[ 5.451684] device usb0 entered promiscuous mode
[ 5.472977] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.816862] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 6.036710] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.269808] zram: Added device: zram0
[ 6.273570] zram: Added device: zram1
[ 6.278349] zram: Added device: zram2
[ 6.285953] zram: Added device: zram3
[ 6.291756] zram: Added device: zram4
[ 6.293452] zram: Added device: zram5
[ 6.363637] zram0: detected capacity change from 0 to 678567936
[ 6.371285] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 6.378323] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.397778] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 6.404942] Adding 662660k swap on /dev/zram0. Priority:5 extents:1 across:662660k SS
[ 6.409947] zram1: detected capacity change from 0 to 678567936
[ 6.442006] Adding 662660k swap on /dev/zram1. Priority:5 extents:1 across:662660k SS
[ 6.445443] zram2: detected capacity change from 0 to 678567936
[ 6.474107] Adding 662660k swap on /dev/zram2. Priority:5 extents:1 across:662660k SS
[ 6.481316] zram3: detected capacity change from 0 to 678567936
[ 6.500365] Adding 662660k swap on /dev/zram3. Priority:5 extents:1 across:662660k SS
[ 6.504272] zram4: detected capacity change from 0 to 678567936
[ 6.535604] Adding 662660k swap on /dev/zram4. Priority:5 extents:1 across:662660k SS
[ 6.565025] zram5: detected capacity change from 0 to 678567936
[ 6.649052] Adding 662660k swap on /dev/zram5. Priority:5 extents:1 across:662660k SS
[ 6.978609] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 7.326549] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.889999] tegradc 15200000.nvdisplay: unblank
[ 7.890015] tegradc 15210000.nvdisplay: blank - powerdown
[ 8.628721] fuse init (API version 7.26)
[ 9.395999] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9.396650] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.791904] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.791923] Bluetooth: BNEP socket layer initialized
[ 22.553975] tegradc 15200000.nvdisplay: blank - powerdown
[ 22.611657] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 22.611662] Extcon AUX1(HDMI) disable
[ 22.635344] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 22.636189] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 22.636434] tegradc 15210000.nvdisplay: blank - powerdown
[ 22.807086] tegradc 15200000.nvdisplay: blank - powerdown
[ 22.807106] tegradc 15200000.nvdisplay: unblank
[ 22.808193] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 22.808375] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 22.810528] Parent Clock set for DC plld2
[ 22.815506] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 22.816927] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 22.856998] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 22.857003] Extcon AUX1(HDMI) enable
[ 22.857086] tegradc 15200000.nvdisplay: unblank
[ 22.857100] tegradc 15210000.nvdisplay: blank - powerdown
[ 28.524425] tegradc 15200000.nvdisplay: unblank
[ 28.524439] tegradc 15210000.nvdisplay: blank - powerdown
[ 34.141881] vdd-sdmmc1-sw: disabling
[ 34.141921] vdd-1v8-sd: disabling
[ 34.141926] vdd-otg-5v: disabling
[ 34.141931] vdd-1v8-cvb: disabling
[ 34.141936] vdd-epb-1v0: disabling
[ 34.141941] avdd-cam-2v8: disabling
[ 34.141947] vdd_sys_en: disabling
[ 66.363373] usb 2-3.3: USB disconnect, device number 3
[ 66.364110] ax88179_178a 2-3.3:1.0 eth1: unregister ‘ax88179_178a’ usb-3610000.xhci-3.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 66.364153] ax88179_178a 2-3.3:1.0 eth1: Failed to read reg index 0x0002: -19
[ 66.364335] ax88179_178a 2-3.3:1.0 eth1: Failed to write reg index 0x0002: -19
[ 66.389826] ax88179_178a 2-3.3:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 66.390027] ax88179_178a 2-3.3:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 66.390187] ax88179_178a 2-3.3:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 66.585789] usb 2-3: usb_suspend_both: status 0
[ 66.586023] usb usb2: usb_suspend_both: status 0
[ 71.849718] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 71.873796] usb 1-2.3: New USB device found, idVendor=093a, idProduct=2510
[ 71.873806] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 71.873812] usb 1-2.3: Product: USB Optical Mouse
[ 71.873817] usb 1-2.3: Manufacturer: PixArt
[ 71.877153] input: PixArt USB Optical Mouse as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:093A:2510.0003/input/input7
[ 71.878775] hid-generic 0003:093A:2510.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3610000.xhci-2.3/input0
[ 398.772231] tegradc 15200000.nvdisplay: blank - powerdown
[ 398.833955] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 398.833960] Extcon AUX1(HDMI) disable
[ 398.856630] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 398.857133] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 537.933938] EXT4-fs (nvme0n1): mounted filesystem with ordered data mode. Opts: (null)
[ 5850.298703] tegradc 15200000.nvdisplay: unblank
[ 5850.299567] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 5850.299716] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 5850.301866] Parent Clock set for DC plld2
[ 5850.306843] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 5850.308338] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 5850.345286] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 5850.345291] Extcon AUX1(HDMI) enable
[ 5850.367024] tegradc 15200000.nvdisplay: unblank
[ 5850.367039] tegradc 15210000.nvdisplay: blank - powerdown
[ 6160.679648] tegradc 15200000.nvdisplay: blank - powerdown
[ 6160.741994] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 6160.741999] Extcon AUX1(HDMI) disable
[ 6160.764315] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 6160.764811] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 8824.234762] tegradc 15200000.nvdisplay: unblank
[ 8824.235544] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 8824.235678] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 8824.237765] Parent Clock set for DC plld2
[ 8824.243299] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 8824.244733] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 8824.282243] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 8824.282247] Extcon AUX1(HDMI) enable
[ 8824.319280] tegradc 15200000.nvdisplay: unblank
[ 8824.319293] tegradc 15210000.nvdisplay: blank - powerdown
[ 9134.606554] tegradc 15200000.nvdisplay: blank - powerdown
[ 9134.661662] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 9134.661719] Extcon AUX1(HDMI) disable
[ 9134.685497] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 9134.686425] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
It looks like there is already a driver built inside kernel. That is why your .ko file cannot work.
