I don’t know how to attach a file to this thread. So I paste the output of dmesg command here.
admin@nvidia:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (chailibao@ubuntu) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #213 SMP PREEMPT Fri May 24 14:45:05 CST 2019 nvidia_V1.0.0
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[ 0.000000] On node 0 totalpages: 1043456
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31256 r8192 d30184 u69632
[ 0.000000] pcpu-alloc: s31256 r8192 d30184 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[ 0.000000] Kernel command line: root=/dev/mmcblk0p18 rw rootwait console=tty0 console=ttyS0,115200n8 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03216170583460c003fe androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3363176K/4173824K available (11434K kernel code, 1864K rwdata, 6556K rodata, 1204K init, 768K bss, 106136K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
.init : 0xffffffc001213000 - 0xffffffc001340000 ( 1204 KB)
.text : 0xffffffc000080000 - 0xffffffc001212084 ( 17993 KB)
.data : 0xffffffc00135a000 - 0xffffffc00152c110 ( 1865 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001272] Console: colour dummy device 80x25
[ 0.001420] console [tty0] enabled
[ 0.001440] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001453] pid_max: default: 32768 minimum: 301
[ 0.001526] Security Framework initialized
[ 0.001535] SELinux: Initializing.
[ 0.001592] SELinux: Starting in permissive mode
[ 0.001626] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.001636] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002304] Initializing cgroup subsys freezer
[ 0.002321] Initializing cgroup subsys debug
[ 0.002581] CPU0 ipc=1024
[ 0.002604] CPU1 ipc=1024
[ 0.002625] CPU2 ipc=1024
[ 0.002645] CPU3 ipc=1024
[ 0.002698] ASID allocator initialised with 65536 entries
[ 0.026346] tegra-id: chipid=22117.
[ 0.026359] tegra-id: opt_subrevision=0.
[ 0.026380] Tegra Speedo/IDDQ fuse revision 4
[ 0.026388] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.026396] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.026403] Tegra: CPU Speedo Value 2023, SoC Speedo Value 1928, GPU Speedo Value 2034
[ 0.026410] Tegra: CPU IDDQ Value 1584, SoC IDDQ Value 1836, GPU IDDQ Value 2145
[ 0.026433] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 0
[ 0.027554] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-nvidia-9550K.dts
[ 0.027565] DTB Build time: May 8 2019 15:02:51
[ 0.040781] CPU1: Booted secondary processor [411fd071]
[ 0.052748] CPU2: Booted secondary processor [411fd071]
[ 0.064749] CPU3: Booted secondary processor [411fd071]
[ 0.064825] Brought up 4 CPUs
[ 0.064844] SMP: Total of 4 processors activated.
[ 0.064856] CPU: All CPU(s) started at EL2
[ 0.064886] alternatives: patching kernel code
[ 0.067281] devtmpfs: initialized
[ 0.123105] Initilizing CustomIPI irq domain
[ 0.123421] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.136406] pinctrl core: initialized pinctrl subsystem
[ 0.136615] OS set in device tree is L4T.
[ 0.136984] regulator-dummy: no parameters
[ 0.137196] Initializing plugin-manager
[ 0.137266] Plugin module not found
[ 0.137450] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[ 0.138200] node /plugin-manager/fragement@4 match with odm-data l4t
[ 0.138296] Removing Prop nvidia,pmc-wakeup from target /bcmdhd_wlan
[ 0.138783] Adding domain ape-pd to PM domain mc-clk-pd
[ 0.138814] Adding domain adsp-pd to PM domain ape-pd
[ 0.142730] NET: Registered protocol family 16
[ 0.147181] console [pstore-1] enabled
[ 0.147188] pstore: Registered ramoops as persistent store backend
[ 0.147197] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.156232] cpuidle: using governor ladder
[ 0.168222] cpuidle: using governor menu
[ 0.168565] bpmp: mail init ok
[ 0.169716] vdso: 2 pages (1 code @ ffffffc001361000, 1 data @ ffffffc001360000)
[ 0.169749] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.172052] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.173000] tegra_powergate_init: DONE
[ 0.173027] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-nvidia-9550K.dts
[ 0.173036] DTB Build time: May 8 2019 15:02:51
[ 0.174054] Error: Driver ‘tegra-mc’ is already registered, aborting…
[ 0.175559] platform tegra-carveouts: SMMU isn’t ready yet
[ 0.176296] platform tegra-carveouts: domain=ffffffc0fa017318 allocates as[0]=ffffffc0fa0580a8
[ 0.176344] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.176561] platform smmu_test: domain=ffffffc0fa017618 allocates as[0]=ffffffc0fa058110
[ 0.176852] platform 70016000.bpmp: domain=ffffffc0fa017918 allocates as[0]=ffffffc0fa058178
[ 0.177500] bpmp: ping status is 0
[ 0.177605] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[ 0.177829] bpmp 70016000.bpmp: probe ok
[ 0.178448] mc: mapped MMIO address: 0xffffff800007e000 -> 0x70019000
[ 0.178531] mc: mapped MMIO address: 0xffffff80000b6000 -> 0x7001c000
[ 0.178607] mc: mapped MMIO address: 0xffffff80000dc000 -> 0x7001d000
[ 0.178701] mc-err: Set intmask: 0x23d40
[ 0.190235] GPIO line 58 (wlan-default-input-h2) hogged as input
[ 0.190263] GPIO line 65 (wlan-default-input-i1) hogged as input
[ 0.190293] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[ 0.190318] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[ 0.190581] GPIO line 85 (fpga-gpio) hogged as output/high
[ 0.190604] GPIO line 65 (uart3-gpio) hogged as output/low
[ 0.190698] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.193094] platform 70006000.serial: domain=ffffffc0fa0ace18 allocates as[0]=ffffffc0fa0581e0
[ 0.194194] platform sound: domain=ffffffc0fa115718 allocates as[0]=ffffffc0fa058248
[ 0.196851] platform tegradc.0: domain=ffffffc0fa119b18 allocates as[0]=ffffffc0fa0582b0
[ 0.197483] platform tegradc.0: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.197864] platform tegradc.1: domain=ffffffc0fa119e18 allocates as[0]=ffffffc0fa058318
[ 0.198509] platform tegradc.1: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.201247] platform 57000000.gpu: domain=ffffffc0fa127218 allocates as[0]=ffffffc0fa058380
[ 0.201298] platform 57000000.gpu: domain=ffffffc0fa127218 allocates as[1]=ffffffc0fa0583e8
[ 0.201347] platform 57000000.gpu: domain=ffffffc0fa127218 allocates as[2]=ffffffc0fa058450
[ 0.201406] platform 57000000.gpu: domain=ffffffc0fa127218 allocates as[3]=ffffffc0fa0584b8
[ 0.202063] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.202079] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.202089] tegra-pmc: ### PMC reset source: Watchdog
[ 0.202095] tegra-pmc: ### PMC reset status reg: 0x1
[ 0.202410] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.202419] tegra-pmc: Clear bootloader IO dpd settings
[ 0.204336] tegra-pmc 7000e400.pmc: PMC: IO pad audio voltage is 1800000
[ 0.208315] tegra-pmc 7000e400.pmc: PMC: IO pad cam voltage is 1800000
[ 0.212314] tegra-pmc 7000e400.pmc: PMC: IO pad dbg voltage is 1800000
[ 0.216313] tegra-pmc 7000e400.pmc: PMC: IO pad dmic voltage is 1800000
[ 0.216327] tegra-pmc 7000e400.pmc: PMC: IO pad pex-ctrl voltage is 1800000
[ 0.220312] tegra-pmc 7000e400.pmc: PMC: IO pad spi voltage is 1800000
[ 0.224312] tegra-pmc 7000e400.pmc: PMC: IO pad uart voltage is 1800000
[ 0.224323] tegra-pmc 7000e400.pmc: PMC: IO pad audio-hv voltage is 1800000
[ 0.224333] tegra-pmc 7000e400.pmc: PMC: IO pad spi-hv voltage is 1800000
[ 0.228313] tegra-pmc 7000e400.pmc: PMC: IO pad gpio voltage is 1800000
[ 0.232312] tegra-pmc 7000e400.pmc: PMC: IO pad sdmmc3 voltage is 1800000
[ 0.232322] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.232378] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.235489] platform 1003000.pcie-controller: domain=ffffffc0fa194318 allocates as[0]=ffffffc0fa058520
[ 0.237772] platform sdhci-tegra.3: domain=ffffffc0fa19b418 allocates as[0]=ffffffc0fa058588
[ 0.238348] platform sdhci-tegra.0: domain=ffffffc0fa19b818 allocates as[0]=ffffffc0fa0585f0
[ 0.243732] vdd-ac-bat: 5000 mV
[ 0.244928] vdd-cpu-fixed: 1000 mV
[ 0.248978] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.249287] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.273484] ACPI: Interpreter disabled.
[ 0.274280] SCSI subsystem initialized
[ 0.274336] libata version 3.00 loaded.
[ 0.274548] usbcore: registered new interface driver usbfs
[ 0.274604] usbcore: registered new interface driver hub
[ 0.274690] usbcore: registered new device driver usb
[ 0.277475] tegra-i2c 7000c400.i2c: no acknowledge from address 0x74
[ 0.277534] pca953x 1-0074: failed reading register
[ 0.277615] pca953x: probe of 1-0074 failed with error -121
[ 0.277647] i2c i2c-1: Failed to register i2c client tca9539 at 0x77 (-16)
[ 0.277667] i2c i2c-1: of_i2c: Failure registering /i2c@7000c400/tca9539@77
[ 0.280268] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[ 0.281938] GPIO line 506 (spmic-default-output-high) hogged as output/high
[ 0.282038] gpiochip_add_data: registered GPIOs 504 to 511 on device: max77620-gpio
[ 0.288389] vdd-core: 600 <–> 1400 mV at 1125 mV
[ 0.292342] vddio-ddr: at 1125 mV
[ 0.293063] vdd-pre-reg: 1350 mV
[ 0.296217] vdd-1v8: 1800 mV
[ 0.300219] avdd-sys: 1200 mV
[ 0.304218] vdd-pex: 1050 mV
[ 0.304819] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.305503] vdd-cam-hv: 2800 mV
[ 0.308219] vdd-rtc: 850 mV
[ 0.308940] avdd-ts-hv: 3300 mV
[ 0.309640] vdd-ts: 1800 mV
[ 0.312219] vdd-gen-pll-edp: 1050 mV
[ 0.316218] vdd-hdmi-dp: 1050 mV
[ 0.316795] max77620 4-003c: max77620 probe successful
[ 0.318746] media: Linux media interface: v0.10
[ 0.318796] Linux video capture interface: v2.00
[ 0.326081] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[ 0.326399] Advanced Linux Sound Architecture Driver Initialized.
[ 0.326984] Bluetooth: Core ver 2.21
[ 0.327019] NET: Registered protocol family 31
[ 0.327027] Bluetooth: HCI device and connection manager initialized
[ 0.327041] Bluetooth: HCI socket layer initialized
[ 0.327052] Bluetooth: L2CAP socket layer initialized
[ 0.327080] Bluetooth: SCO socket layer initialized
[ 0.329905] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.329938] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.330018] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.330047] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.332307] regulator_get() failed for (dvfs,vdd-cpu), -19
[ 0.332331] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.336221] vdd-3v3: 3300 mV
[ 0.340215] max77620-gpio7: 1050 mV
[ 0.340505] lcd-bl-en: 1800 mV
[ 0.340784] en-vdd-sd: 3300 mV
[ 0.344216] vdd-sys-boost: 5000 mV
[ 0.344560] aux-3v3: 3300 mV
[ 0.344795] snsr_pm: 3300 mV
[ 0.348218] vdd-disp-3v0: 3000 mV
[ 0.348604] usb-vbus1: 5000 mV
[ 0.349528] rtl-5v0: 5000 mV
[ 0.349806] en-usb-vbus2: 5000 mV
[ 0.350179] en-vdd-vcm-2v8: 2800 mV
[ 0.352954] extcon-gpio-states extcon:extcon@1: Cable state 1
[ 0.354327] clocksource: Switched to clocksource arch_sys_counter
[ 0.394751] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.395098] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.395258] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.395269] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[ 0.395282] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.395310] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.395320] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.395609] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.396316] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.397037] pnp: PnP ACPI: disabled
[ 0.408617] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.410195] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.410605] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.410771] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.412176] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 0.412398] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 0.412592] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.413927] isomgr_init(): iso emc max clk=1600000KHz
[ 0.413934] isomgr_init(): max_iso_bw=11520000KB
[ 0.414063] NET: Registered protocol family 2
[ 0.414638] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.414798] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.415032] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.415109] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.415155] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.415383] NET: Registered protocol family 1
[ 0.415669] RPC: Registered named UNIX socket transport module.
[ 0.415679] RPC: Registered udp transport module.
[ 0.415686] RPC: Registered tcp transport module.
[ 0.415692] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.415717] PCI: CLS 0 bytes, default 128
[ 0.415922] Trying to unpack rootfs image as initramfs…
[ 0.877457] Freeing initrd memory: 8936K (ffffffc003200000 - ffffffc003aba000)
[ 0.887963] host1x 50000000.host1x: initialized
[ 0.889732] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.892909] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.893016] audit: initializing netlink subsys (disabled)
[ 0.893065] audit: type=2000 audit(0.887:1): initialized
[ 0.904286] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.905009] SELinux: Registering netfilter hooks
[ 0.907236] io scheduler noop registered (default)
[ 0.907254] io scheduler deadline registered
[ 0.907553] io scheduler cfq registered
[ 0.912670] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 0.912688] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x92a9c15
[ 0.912701] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 0.914042] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 0.914059] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 0.914072] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 0.914092] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 0.914112] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 0.914123] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 0.914140] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 0.914157] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 0.914177] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 0.914199] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 0.914220] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 0.914241] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 0.914261] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 0.914283] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 0.914713] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[ 0.915713] tegra-pwm 7000a000.pwm: PWM clk can sleep in ops
[ 0.916764] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.917484] Adding domain pcie-pd to PM domain mc-clk-pd
[ 0.921363] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.921410] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[ 0.921436] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[ 0.924457] tsec 54500000.tsec: initialized
[ 0.925700] tsec 54100000.tsecb: initialized
[ 0.928289] nvdec 54480000.nvdec: initialized
[ 0.932826] falcon 54340000.vic: initialized
[ 0.934472] falcon 544c0000.nvenc: initialized
[ 0.935591] falcon 54380000.nvjpg: initialized
[ 0.937531] DC OR NODE connected to /host1x/dsi
[ 0.937612] display board info: id 0xffff, fab 0x0
[ 0.937679] display board info: id 0xffff, fab 0x0
[ 0.937851] parse_disp_default_out: No parent clk. dft clk will be used.
[ 0.938004] tegradc tegradc.0: DT parsed successfully
[ 0.938050] tegradc tegradc.0: Display dc.ffffff8000980000 registered with id=0
[ 0.938701] tegradc tegradc.0: DSI: HS clock rate is 445500
[ 0.938851] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.939057] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=25600000, max_bw=25600000
[ 0.939068] max_iso_bw is relaxed to 25600000KB from 11520000KB
[ 0.939120] ------------[ cut here ]------------
[ 0.939128] WARNING: at /home/chailibao/work/kernel_9550Av3/kernel/kernel-4.4/drivers/platform/tegra/mc/isomgr.c:703
[ 0.939134] Modules linked in:
[ 0.939154] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.4.38 #213
[ 0.939161] Hardware name: jetson_tx1 (DT)
[ 0.939169] task: ffffffc0fb2d0000 ti: ffffffc0fb28c000 task.ti: ffffffc0fb28c000
[ 0.939184] PC is at __tegra_isomgr_register+0x1bc/0x500
[ 0.939193] LR is at __tegra_isomgr_register+0x1bc/0x500
[ 0.939201] pc : [] lr : [] pstate: 60000045
[ 0.939206] sp : ffffffc0fb28fb40
[ 0.939212] x29: ffffffc0fb28fb40 x28: 000000000186a000
[ 0.939224] x27: 0000000000000000 x26: 0000000000000000
[ 0.939233] x25: ffffffc0015d06c8 x24: ffffffc0015d0a48
[ 0.939243] x23: ffffffc0015d0a48 x22: 0000000000000000
[ 0.939252] x21: 0000000000000000 x20: 0000000000000008
[ 0.939261] x19: 000000000186a000 x18: 0000000069bcd9eb
[ 0.939270] x17: 000000000000001b x16: 0000000000000007
[ 0.939278] x15: 040772181f0a1010 x14: 3d77625f6f73695f
[ 0.939287] x13: 7073692072657473 x12: 696765725f72676d
[ 0.939296] x11: 6f73695f6172656d x10: 61635f6172676574
[ 0.939305] x9 : 203a6c7274635f61 x8 : 3030303235313120
[ 0.939314] x7 : 6d6f726620424b30 x6 : ffffffc00155530a
[ 0.939323] x5 : 0000000000000001 x4 : 0000000000000042
[ 0.939332] x3 : 0000000000000000 x2 : 0000000000000699
[ 0.939341] x1 : ffffffc0fb28c000 x0 : 0000000000000033
[ 0.939367] —[ end trace 6c0c402f30afb941 ]—
[ 0.939373] Call trace:
[ 0.939393] [] __tegra_isomgr_register+0x1bc/0x500
[ 0.939403] [] tegra_isomgr_register+0x18/0x2c
[ 0.939415] [] tegra_camera_isomgr_register+0x2b8/0x2fc
[ 0.939423] [] tegra_camera_probe+0xe4/0x1c4
[ 0.939435] [] platform_drv_probe+0x50/0xa8
[ 0.939445] [] really_probe+0x134/0x2e0
[ 0.939453] [] driver_probe_device+0x88/0xc8
[ 0.939462] [] __driver_attach+0x60/0x8c
[ 0.939470] [] bus_for_each_dev+0x54/0x98
[ 0.939478] [] driver_attach+0x20/0x28
[ 0.939487] [] bus_add_driver+0x13c/0x228
[ 0.939496] [] driver_register+0x90/0xd4
[ 0.939506] [] __platform_driver_register+0x54/0x5c
[ 0.939515] [] tegra_camera_init+0x18/0x20
[ 0.939524] [] do_one_initcall+0x4c/0xe8
[ 0.939535] [] do_initcall_level+0xa8/0xc4
[ 0.939543] [] do_initcalls+0x18/0x30
[ 0.939553] [] do_basic_setup+0x20/0x2c
[ 0.939562] [] kernel_init_freeable+0x80/0x100
[ 0.939573] [] kernel_init+0xc/0xd4
[ 0.939581] [] ret_from_fork+0x10/0x40
[ 0.939609] __tegra_isomgr_register(): ISO BW usage:
[ 0.939618] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 0.939625] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 0.939631] __tegra_isomgr_register(): client=vi_0, iso dedi bw=0KB
[ 0.939638] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 0.939644] __tegra_isomgr_register(): client=isp_b, iso dedi bw=0KB
[ 0.939651] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=25600000KB
[ 0.939657] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 0.939780] max_iso_bw is relaxed to 26248088KB from 25600000KB
[ 0.939838] ------------[ cut here ]------------
[ 0.939847] WARNING: at /home/chailibao/work/kernel_9550Av3/kernel/kernel-4.4/drivers/platform/tegra/mc/isomgr.c:703
[ 0.939853] Modules linked in:
[ 0.939871] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: G W 4.4.38 #213
[ 0.939878] Hardware name: jetson_tx1 (DT)
[ 0.939892] Workqueue: events_unbound async_run_entry_fn
[ 0.939902] task: ffffffc0fb2d3e80 ti: ffffffc0fb308000 task.ti: ffffffc0fb308000
[ 0.939913] PC is at __tegra_isomgr_register+0x1bc/0x500
[ 0.939922] LR is at __tegra_isomgr_register+0x1bc/0x500
[ 0.939930] pc : [] lr : [] pstate: 60000045
[ 0.939936] sp : ffffffc0fb30ba40
[ 0.939942] x29: ffffffc0fb30ba40 x28: 000000000009e398
[ 0.939954] x27: ffffffc030224380 x26: ffffff8000980000
[ 0.939965] x25: ffffffc0015d06c8 x24: ffffffc0015d06c8
[ 0.939974] x23: ffffffc0015d06c8 x22: ffffffc030238000
[ 0.939984] x21: ffffffc000463a68 x20: 0000000000000000
[ 0.939994] x19: 000000000009e398 x18: 000000000000037f
[ 0.940003] x17: 0000000000000000 x16: 0000000000000000
[ 0.940013] x15: ffffffffffffffff x14: 0ffffffffffffffe
[ 0.940022] x13: 0000000000000008 x12: 0000000000000018
[ 0.940031] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 0.940041] x9 : fefefefeff726c5e x8 : 3030303036353220
[ 0.940051] x7 : 6d6f726620424b38 x6 : ffffffc00155530a
[ 0.940060] x5 : 0000000000000001 x4 : 0000000000000042
[ 0.940070] x3 : 0000000000000000 x2 : 000000000000082b
[ 0.940079] x1 : ffffffc0fb308000 x0 : 0000000000000033
[ 0.940094] —[ end trace 6c0c402f30afb942 ]—
[ 0.940100] Call trace:
[ 0.940118] [] __tegra_isomgr_register+0x1bc/0x500
[ 0.940127] [] tegra_isomgr_register+0x18/0x2c
[ 0.940141] [] tegra_dc_probe+0x8ac/0x1064
[ 0.940151] [] platform_drv_probe+0x50/0xa8
[ 0.940161] [] really_probe+0x134/0x2e0
[ 0.940171] [] driver_probe_device+0x88/0xc8
[ 0.940180] [] __driver_attach+0x60/0x8c
[ 0.940189] [] bus_for_each_dev+0x54/0x98
[ 0.940198] [] driver_attach+0x20/0x28
[ 0.940207] [] driver_attach_async+0x14/0x50
[ 0.940215] [] async_run_entry_fn+0x84/0x180
[ 0.940227] [] process_one_work+0x258/0x434
[ 0.940236] [] worker_thread+0x160/0x288
[ 0.940247] [] kthread+0x100/0x108
[ 0.940256] [] ret_from_fork+0x10/0x40
[ 0.940271] __tegra_isomgr_register(): ISO BW usage:
[ 0.940279] __tegra_isomgr_register(): client=disp_0, iso dedi bw=648088KB
[ 0.940285] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 0.940292] __tegra_isomgr_register(): client=vi_0, iso dedi bw=0KB
[ 0.940299] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 0.940305] __tegra_isomgr_register(): client=isp_b, iso dedi bw=0KB
[ 0.940312] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=25600000KB
[ 0.940318] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 0.940425] tegradc tegradc.0: probed
[ 0.946371] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.948421] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[ 0.949977] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.950257] kfuse 7000fc00.kfuse: initialized
[ 0.952069] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.953046] clk_cbus_round_rate: no gbus parent
[ 0.953059] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 0.953586] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.953601] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.953650] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.954820] vdd-gpu: applied init 1000000uV constraint
[ 0.954835] vdd-gpu: 710 <–> 1320 mV at 1000 mV
[ 0.954884] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.955283] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.955401] No Device Node present for smmu client: serial8250 !!
[ 0.955413] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.955425] No Device Node present for smmu client: serial8250 !!
[ 0.955434] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.956488] No Device Node present for smmu client: serial8250 !!
[ 0.956501] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.956524] No Device Node present for smmu client: serial8250 !!
[ 0.956534] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.957167] console [ttyS0] disabled
[ 0.957228] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[ 1.013119] console [ttyS0] enabled
[ 1.014427] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[ 1.014862] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[ 1.015189] serial-tegra 70006300.serial: RX in PIO mode
[ 1.015293] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[ 1.017522] gk20a 57000000.gpu: platform probe failed
[ 1.042178] tegradc tegradc.0: DSI: HS clock rate is 482625
[ 1.042910] tegradc tegradc.0: DSI: HS clock rate is 482625
[ 1.061426] brd: module loaded
[ 1.066128] Console: switching to colour frame buffer device 240x67
[ 1.070761] loop: module loaded
[ 1.071353] zram: Added device: zram0
[ 1.071364] Silicon Labs C2 port support v. 0.51.0 - © 2007 Rodolfo Giometti
[ 1.071560] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 1.071566] nct1008_nct72 0-004c: starting parse dt
[ 1.071645] nct1008_nct72 0-004c: success parsing dt
[ 1.071821] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[ 1.087998] tegradc tegradc.0: fb registered
[ 1.090773] tegradc tegradc.0: nominal-pclk:162022000 parent:162021093 div:1.0 pclk:162021093 160401780~176603980
[ 1.106697] tmp451: Enabled overheat logging at 102.00C
[ 1.106849] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 1.109561] THERMAL EST: found 2 subdevs
[ 1.109574] THERMAL EST num_resources: 0
[ 1.109583] [THERMAL EST subdev 0]
[ 1.109593] [THERMAL EST subdev 1]
[ 1.109916] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.109924] THERMAL EST: thz register success.
[ 1.110064] THERMAL EST: end of probe, return err: 0
[ 1.110159] tegra_profiler: Branch: Dev
[ 1.110167] tegra_profiler: Version: 1.109
[ 1.110174] tegra_profiler: Samples version: 37
[ 1.110180] tegra_profiler: IO version: 21
[ 1.110190] armv8_pmu: imp: 0x41, idcode: 0x1
[ 1.110197] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 1.110205] armv8_pmu: imp: 0x41, idcode: 0x1
[ 1.110212] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 1.110219] armv8_pmu: imp: 0x41, idcode: 0x1
[ 1.110226] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 1.110233] armv8_pmu: imp: 0x41, idcode: 0x1
[ 1.110240] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 1.110514] tegra_profiler: auth: init
[ 1.111032] tegra-ahci 70027000.sata: Missing devslp-active state
[ 1.112080] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 1.112652] spi-tegra114 7000d400.spi: Static pin configuration used
[ 1.114241] spi-tegra114 7000d600.spi: Static pin configuration used
[ 1.115804] spi-tegra114 7000da00.spi: Static pin configuration used
[ 1.117797] libphy: Fixed MDIO Bus: probed
[ 1.117851] tun: Universal TUN/TAP device driver, 1.6
[ 1.117859] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.118278] PPP generic driver version 2.4.2
[ 1.118476] PPP BSD Compression module registered
[ 1.118491] PPP Deflate Compression module registered
[ 1.118519] PPP MPPE Compression module registered
[ 1.118540] NET: Registered protocol family 24
[ 1.118630] usbcore: registered new interface driver r8152
[ 1.118692] usbcore: registered new interface driver asix
[ 1.118748] usbcore: registered new interface driver ax88179_178a
[ 1.118797] usbcore: registered new interface driver cdc_ether
[ 1.118863] usbcore: registered new interface driver smsc95xx
[ 1.118912] usbcore: registered new interface driver net1080
[ 1.118961] usbcore: registered new interface driver cdc_subset
[ 1.119014] usbcore: registered new interface driver zaurus
[ 1.119092] usbcore: registered new interface driver cdc_ncm
[ 1.119231] usbcore: registered new interface driver usb-storage
[ 1.119340] usbcore: registered new interface driver usbserial
[ 1.119386] usbcore: registered new interface driver ftdi_sio
[ 1.119421] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.119466] usbcore: registered new interface driver option
[ 1.119504] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.119549] usbcore: registered new interface driver pl2303
[ 1.119581] usbserial: USB Serial support registered for pl2303
[ 1.120583] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
[ 1.125324] [FTS]fts_ts_init: Enter
[ 1.129030] [FTS]fts_ts_probe: Enter
[ 1.132693] [FTS]fts_parse_dt: Enter
[ 1.136456] [FTS]max_touch_number=5
[ 1.140025] [FTS]fts_parse_dt: Exit(1018)
[ 1.144125] [FTS]fts_input_dev_init: Enter
[ 1.148491] input: fts_ts as /devices/7000c000.i2c/i2c-0/0-0038/input/input0
[ 1.148686] [FTS]fts_input_dev_init: Exit(254)
[ 1.153228] [FTS]fts_ctpm_get_upgrade_array: Enter
[ 1.158115] [FTS][Info]CHIP TYPE ID = 0x5422
[ 1.162561] tegra-i2c 7000c000.i2c: no acknowledge from address 0x38
[ 1.162620] [FTS][Error]fts_i2c_write: i2c_transfer(write) error, ret=-121
[ 1.182427] tegra-i2c 7000c000.i2c: no acknowledge from address 0x38
[ 1.182479] [FTS][Error][IIC]: i2c_transfer(read) error, ret=-121!!
[ 1.188869] [FTS][Error]hidi2c change to stdi2c error!!
[ 1.194196] [FTS]fts_ctpm_get_upgrade_array: Exit(182)
[ 1.199432] [FTS]fts_gpio_configure: Enter
[ 1.203651] [FTS]fts_gpio_configure: Exit(873)
[ 1.434505] [FTS][Info]TP Ready, Device ID = 0x54
[ 1.439445] [FTS][Info]Create proc entry success!
[ 1.444293] [FTS][Info][EX]: sysfs_create_group() succeeded!!
[ 1.450149] [FTS][Mode]create sysfs succeeded
[ 1.454592] [FTS]fts_gesture_init: Enter
[ 1.458605] [FTS]fts_gesture_init: Exit(652)
[ 1.462962] [FTS]fts_ctpm_upgrade_init: Enter
[ 1.471509] [FTS]fts_ctpm_upgrade_init: Exit(758)
[ 1.471520] [FTS][UPGRADE]FTS enter upgrade
[ 1.471525] [FTS][UPGRADE]check upgrade need or not
[ 1.471529] [FTS]fts_ctpm_check_need_upgrade: Enter
[ 1.471845] [FTS][UPGRADE]: chip_id = 5422, chip_types.chip_idh = 5422
[ 1.471849] [FTS][UPGRADE]: fw_status = 1!!
[ 1.471851] [FTS][Info][UPGRADE]FW APP valid
[ 1.471854] [FTS][UPGRADE]FW FILE:CTPM_FW, SIZE:0
[ 1.472008] [FTS][Error][UPGRADE]: FW length(0) error
[ 1.472012] [FTS][UPGRADE]: uc_tp_fm_ver = 0x1, uc_host_fm_ver = 0x0!!
[ 1.472014] [FTS][UPGRADE]Don’t need upgrade fw
[ 1.472018] [FTS]fts_ctpm_check_need_upgrade: Exit(640)
[ 1.472021] [FTS][UPGRADE]bUpgradeFlag = 0x0
[ 1.472022] [FTS][UPGRADE]No Upgrade, exit
[ 1.472027] [FTS][UPGRADE]FTS exit upgrade
[ 1.543006] DC OR NODE connected to /host1x/sor1
[ 1.543250] tegradc tegradc.1: DT parsed successfully
[ 1.543293] tegradc tegradc.1: Display dc.ffffff8007480000 registered with id=1
[ 1.543623] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 1.545956] max_iso_bw is relaxed to 28649048KB from 26248088KB
[ 1.545957] ------------[ cut here ]------------
[ 1.545960] WARNING: at /home/chailibao/work/kernel_9550Av3/kernel/kernel-4.4/drivers/platform/tegra/mc/isomgr.c:703
[ 1.545965] Modules linked in:
[ 1.545975] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: G W 4.4.38 #213
[ 1.545978] Hardware name: jetson_tx1 (DT)
[ 1.545992] Workqueue: events_unbound async_run_entry_fn
[ 1.545996] task: ffffffc0fb2d3e80 ti: ffffffc0fb308000 task.ti: ffffffc0fb308000
[ 1.546006] PC is at __tegra_isomgr_register+0x1bc/0x500
[ 1.546011] LR is at __tegra_isomgr_register+0x1bc/0x500
[ 1.546016] pc : [] lr : [] pstate: 20000045
[ 1.546018] sp : ffffffc0fb30ba40
[ 1.546025] x29: ffffffc0fb30ba40 x28: 000000000024a2c0
[ 1.546031] x27: ffffffc0303c8800 x26: ffffff8007480000
[ 1.546036] x25: ffffffc0015d06c8 x24: ffffffc0015d0738
[ 1.546041] x23: ffffffc0015d0738 x22: ffffffc0f87c0000
[ 1.546046] x21: ffffffc000463a68 x20: 0000000000000001
[ 1.546051] x19: 000000000024a2c0 x18: 000000000000037f
[ 1.546056] x17: 0000000000000000 x16: 0000000000000000
[ 1.546061] x15: ffffffffffffffff x14: 0ffffffffffffffe
[ 1.546065] x13: 0000000000000008 x12: 0000000000000018
[ 1.546070] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 1.546075] x9 : fefefefeff726c5e x8 : 6d6f726620424b38
[ 1.546080] x7 : 3430393436383220 x6 : ffffffc001534db3
[ 1.546085] x5 : 0000000000000001 x4 : 0000000000000008
[ 1.546090] x3 : 0000000000000000 x2 : 00000000000004e1
[ 1.546094] x1 : ffffffc0fb308000 x0 : 0000000000000033
[ 1.546099] —[ end trace 6c0c402f30afb943 ]—
[ 1.546101] Call trace:
[ 1.546108] [] __tegra_isomgr_register+0x1bc/0x500
[ 1.546115] [] tegra_isomgr_register+0x18/0x2c
[ 1.546125] [] tegra_dc_probe+0x8ac/0x1064
[ 1.546134] [] platform_drv_probe+0x50/0xa8
[ 1.546141] [] really_probe+0x134/0x2e0
[ 1.546146] [] driver_probe_device+0x88/0xc8
[ 1.546151] [] __driver_attach+0x60/0x8c
[ 1.546157] [] bus_for_each_dev+0x54/0x98
[ 1.546163] [] driver_attach+0x20/0x28
[ 1.546168] [] driver_attach_async+0x14/0x50
[ 1.546173] [] async_run_entry_fn+0x84/0x180
[ 1.546181] [] process_one_work+0x258/0x434
[ 1.546187] [] worker_thread+0x160/0x288
[ 1.546194] [] kthread+0x100/0x108
[ 1.546201] [] ret_from_fork+0x10/0x40
[ 1.546204] __tegra_isomgr_register(): ISO BW usage:
[ 1.546208] __tegra_isomgr_register(): client=disp_0, iso dedi bw=648088KB
[ 1.546211] __tegra_isomgr_register(): client=disp_1, iso dedi bw=2400960KB
[ 1.546215] __tegra_isomgr_register(): client=vi_0, iso dedi bw=0KB
[ 1.546218] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 1.546221] __tegra_isomgr_register(): client=isp_b, iso dedi bw=0KB
[ 1.546224] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=25600000KB
[ 1.546227] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 1.546377] tegradc tegradc.1: probed
[ 1.574436] [FTS][TEST]fts_test_init: Enter(504)
[ 1.579145] [FTS][TEST][Info]fts_test_init. line: 506. [focal] Test version: V1.0.0–2016-12-28, (sync version of FT_MultipleTest: V4.0.0.0 ------ 2016-07-18)
[ 1.593741] [FTS] [TEST]fts_test_init. line: 518. [focal] fts_test_init() - sysfs_create_group() succeeded.
[ 1.603740] [FTS][TEST]fts_test_init: Exit(521)
[ 1.608359] [FTS]fts_ts_probe: Exit(1248)
[ 1.612551] [FTS]fts_ts_init: Exit(1493)
[ 1.647570] tegradc tegradc.1: fb registered
[ 1.672866] tegradc tegradc.1: nominal-pclk:297000000 parent:297000000 div:1.0 pclk:297000000 294030000~323730000
[ 1.673738] tegradc tegradc.1: hdmi: pclk:297000K, set prod-setting:prod_c_hdmi_150m_300m
[ 1.747889] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[ 1.750177] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
[ 1.750213] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.750714] i2c /dev entries driver
[ 1.752606] IR NEC protocol handler initialized
[ 1.752621] IR Sharp protocol handler initialized
[ 1.752634] IR XMP protocol handler initialized
[ 1.752717] usbcore: registered new interface driver uvcvideo
[ 1.752724] USB Video Class driver (1.1.1)
[ 1.753015] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.754923] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.754936] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
[ 1.755449] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.755465] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.755662] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.755678] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.755690] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.755919] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.755929] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[ 1.755941] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.755951] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.756327] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.757762] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.757830] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.757841] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.757852] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.758648] FAN: coudln’t get the regulator
[ 1.764249] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 0)
[ 1.764580] device-mapper: uevent: version 1.0.3
[ 1.764906] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.769048] Bluetooth: HCI UART driver ver 2.3
[ 1.769059] Bluetooth: HCI UART protocol H4 registered
[ 1.769137] usbcore: registered new interface driver btusb
[ 1.772134] sdhci: Secure Digital Host Controller Interface driver
[ 1.772144] sdhci: Copyright© Pierre Ossman
[ 1.772158] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.772825] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 1.772891] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 1.772919] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.774756] [FTS]fts_ts_resume: Enter
[ 1.774758] [FTS]Already in awake state
[ 1.774764] [FTS]fts_ts_resume: Exit(1401)
[ 1.777851] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.778624] hidraw: raw HID events driver © Jiri Kosina
[ 1.781401] usbcore: registered new interface driver usbhid
[ 1.781403] usbhid: USB HID core driver
[ 1.786737] tegradc tegradc.1: hdmi: plugged
[ 1.787701] tegra-i2c 7000c400.i2c: no acknowledge from address 0x42
[ 1.787767] ina3221x 1-0042: ina3221 reset failure status: 0xffffff87
[ 1.794673] ina3221x: probe of 1-0042 failed with error -121
[ 1.795396] tegra-i2c 7000c400.i2c: no acknowledge from address 0x43
[ 1.795457] ina3221x 1-0043: ina3221 reset failure status: 0xffffff87
[ 1.806661] ina3221x: probe of 1-0043 failed with error -121
[ 1.807400] parse_throttle_dt_data: Num cap clks = 6
[ 1.807414] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.807428] parse_throttle_dt_data: clk=gpu type=4
[ 1.807479] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.807517] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.807561] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.807568] parse_throttle_dt_data: clk=emc type=3
[ 1.808367] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.808667] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.809890] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.811433] tegra124-dfll 70110000.clock: config PMU interface as PWM
[ 1.814811] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.814825] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.814838] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.814848] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.815087] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.815098] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.815130] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.815139] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.818466] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 1.818779] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 1.818804] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[ 1.828536] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input1
[ 1.854439] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[ 1.855240] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.855305] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[ 1.855390] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 1.855448] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
[ 1.855476] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.857419] en-vdd-sd: supplied by vdd-3v3
[ 1.860828] OPE platform probe
[ 1.861025] OPE platform probe successful
[ 1.861427] OPE platform probe
[ 1.861624] OPE platform probe successful
[ 1.876694] mmc0: MAN_BKOPS_EN bit is not set
[ 1.883539] mmc0: Skipping tuning since strobe enabled
[ 1.889443] mmc0: new HS400 MMC card at address 0001
[ 1.890362] mmcblk0: mmc0:0001 016G32 14.7 GiB
[ 1.890849] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 1.892428] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[ 1.894714] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.894845] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.894988] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.895232] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.895470] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.895706] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.895968] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.896208] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.896468] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.896759] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.896994] tegra-snd-t210ref-nvidia-dummy sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.918778] tegra-snd-t210ref-nvidia-dummy sound: codec-dai “dummy-hifi” registered
[ 1.918792] tegra-snd-t210ref-nvidia-dummy sound: This is a dummy codec
[ 1.918805] tegra-snd-t210ref-nvidia-dummy sound: codec-dai “dummy-hifi” registered
[ 1.918814] tegra-snd-t210ref-nvidia-dummy sound: This is a dummy codec
[ 1.918826] tegra-snd-t210ref-nvidia-dummy sound: codec-dai “dummy-hifi” registered
[ 1.918835] tegra-snd-t210ref-nvidia-dummy sound: This is a dummy codec
[ 1.919320] GACT probability NOT on
[ 1.919340] Mirror/redirect action on
[ 1.919363] u32 classifier
[ 1.919368] Actions configured
[ 1.919385] Netfilter messages via NETLINK v0.30.
[ 1.919443] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.919878] ctnetlink v0.93: registering with nfnetlink.
[ 1.920622] xt_time: kernel timezone is -0000
[ 1.920805] ipip: IPv4 over IPv4 tunneling driver
[ 1.921503] ip_tables: © 2000-2006 Netfilter Core Team
[ 1.921693] arp_tables: © 2002 David S. Miller
[ 1.921774] Initializing XFRM netlink socket
[ 1.922663] NET: Registered protocol family 10
[ 1.923818] mip6: Mobile IPv6
[ 1.923849] ip6_tables: © 2000-2006 Netfilter Core Team
[ 1.924051] sit: IPv6 over IPv4 tunneling driver
[ 1.925168] NET: Registered protocol family 17
[ 1.925199] NET: Registered protocol family 15
[ 1.925239] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.925466] Bluetooth: RFCOMM TTY layer initialized
[ 1.925481] Bluetooth: RFCOMM socket layer initialized
[ 1.925503] Bluetooth: RFCOMM ver 1.11
[ 1.925522] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.925529] Bluetooth: BNEP filters: protocol multicast
[ 1.925540] Bluetooth: BNEP socket layer initialized
[ 1.925552] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.925562] Bluetooth: HIDP socket layer initialized
[ 1.925924] Key type dns_resolver registered
[ 1.927135] Registered cp15_barrier emulation handler
[ 1.934363] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 1.935378] isp 54600000.isp: initialized
[ 1.937008] isp 54680000.isp: initialized
[ 1.940828] clk_cbus_recalc_rate: no gbus parent
[ 1.940842] clk_cbus_round_rate: no gbus parent
[ 1.940850] clk_cbus_round_rate: no gbus parent
[ 1.940861] clk_cbus_recalc_rate: no gbus parent
[ 1.941394] clk_cbus_recalc_rate: no gbus parent
[ 1.941406] clk_cbus_round_rate: no gbus parent
[ 1.941414] clk_cbus_round_rate: no gbus parent
[ 1.941424] clk_cbus_recalc_rate: no gbus parent
[ 1.941450] tegra_dvfs: GPU-cap: registered
[ 1.941547] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.941556] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.941563] tegra dvfs: vdd-gpu: nominal 1110mV, offset 710000uV, step 10000uV, scaling enabled
[ 1.943906] tegra_dvfs: vdd-gpu-vts: registered
[ 1.948261] xhci-tegra 70090000.xusb: can’t get usb3-0 phy (-517)
[ 1.948878] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 1.948895] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x92a9c15
[ 1.948907] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 1.950139] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 1.950154] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 1.950165] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 1.950185] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 1.950204] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 1.950214] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 1.950230] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 1.950246] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 1.950266] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 1.950287] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 1.950308] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 1.950363] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 1.950383] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 1.950405] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 1.951063] usb-vbus1: supplied by vdd-3v3
[ 1.953439] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 1.955963] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 1.956189] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 1.956892] clk_cbus_round_rate: no gbus parent
[ 1.956905] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 1.967274] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 1.969203] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 1.969539] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 1.969990] tegra-ahci 70027000.sata: Missing devslp-active state
[ 1.975336] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.975356] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.976736] scsi host0: tegra_ahci
[ 1.977304] scsi host1: tegra_ahci
[ 1.977563] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 372
[ 1.977572] ata2: DUMMY
[ 1.982227] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.982371] tegra-xudc-new 700d0000.xudc: device mode on
[ 1.983181] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.984856] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.985284] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.986012] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.989696] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 1.989702] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 1.993207] xhci-tegra 70090000.xusb: Firmware timestamp: 2016-11-24 02:31:08 UTC, Version: 50.18 release
[ 1.994349] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 1.994362] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.995192] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[ 1.995217] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[ 1.995362] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.995367] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.995371] usb usb1: Product: xHCI Host Controller
[ 1.995377] usb usb1: Manufacturer: Linux 4.4.38 xhci-hcd
[ 1.995381] usb usb1: SerialNumber: 70090000.xusb
[ 1.995704] hub 1-0:1.0: USB hub found
[ 1.995730] hub 1-0:1.0: 5 ports detected
[ 1.998367] input: gpio-keys as /devices/gpio-keys/input/input2
[ 2.014343] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 2.014356] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[ 2.014474] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.014479] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.014483] usb usb2: Product: xHCI Host Controller
[ 2.014487] usb usb2: Manufacturer: Linux 4.4.38 xhci-hcd
[ 2.014490] usb usb2: SerialNumber: 70090000.xusb
[ 2.015000] hub 2-0:1.0: USB hub found
[ 2.015024] hub 2-0:1.0: 4 ports detected
[ 2.016930] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 05:48:53 UTC (946705733)
[ 2.018604] Disable partitions left on by BL
[ 2.018610] disb
[ 2.028386] DRAM derating cdev registered.
[ 2.029086] vdd-cpu-fixed: disabling
[ 2.029100] vdd-cam-hv: disabling
[ 2.029185] avdd-ts-hv: disabling
[ 2.029256] vdd-ts: disabling
[ 2.029327] max77620-gpio7: disabling
[ 2.029475] lcd-bl-en: disabling
[ 2.029482] aux-3v3: disabling
[ 2.029485] snsr_pm: disabling
[ 2.029488] vdd-disp-3v0: disabling
[ 2.029491] usb-vbus1: disabling
[ 2.029496] en-vdd-vcm-2v8: disabling
[ 2.030381] ALSA device list:
[ 2.030386] #0: tegra-hda at 0x70038000 irq 350
[ 2.030389] #1: tegra-snd-t210ref-nvidia-dummy
[ 2.139437] mmc1 tuning done saved tap delay=47
[ 2.139441] mmc1: hw tuning done …
[ 2.139447] mmc1: tuning_window[0]: 0xcfffffff
[ 2.139454] mmc1: tuning_window[1]: 0xffffffff
[ 2.139459] mmc1: tuning_window[2]: 0xfffffff1
[ 2.139464] mmc1: tuning_window[3]: 0x7ffffe7f
[ 2.139470] mmc1: tuning_window[4]: 0x0
[ 2.139475] mmc1: tuning_window[5]: 0x0
[ 2.139480] mmc1: tuning_window[6]: 0x0
[ 2.139485] mmc1: tuning_window[7]: 0x0
[ 2.139489] sdhci: Tap value: 47 | Trim value: 8
[ 2.139492] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 2.142768] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.142795] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 2.302552] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.303122] Freeing unused kernel memory: 1204K (ffffffc001213000 - ffffffc001340000)
[ 2.303146] Freeing alternatives memory: 76K (ffffffc001340000 - ffffffc001353000)
[ 2.330958] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 2.351957] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 2.351963] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 2.351967] usb 2-1: Product: USB 10/100/1000 LAN
[ 2.351971] usb 2-1: Manufacturer: Nvidia
[ 2.351974] usb 2-1: SerialNumber: 000001000000
[ 2.352569] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 2.354734] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 2.355274] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 2.359376] EXT4-fs (mmcblk0p1): recovery complete
[ 2.360038] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.422349] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.467269] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
[ 2.519419] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[ 2.519426] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 2.606007] EXT4-fs (mmcblk0p18): 4 orphan inodes deleted
[ 2.606013] EXT4-fs (mmcblk0p18): recovery complete
[ 2.610519] EXT4-fs (mmcblk0p18): mounted filesystem with ordered data mode. Opts: (null)
[ 2.707777] systemd[1]: System time before build time, advancing clock.
[ 2.724067] random: systemd: uninitialized urandom read (16 bytes read, 73 bits of entropy available)
[ 2.725349] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 2.725675] systemd[1]: Detected architecture arm64.
[ 2.726151] systemd[1]: Set hostname to .
[ 2.733642] random: systemd: uninitialized urandom read (16 bytes read, 73 bits of entropy available)
[ 2.734624] random: systemd: uninitialized urandom read (16 bytes read, 73 bits of entropy available)
[ 2.738450] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 74 bits of entropy available)
[ 2.742900] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 75 bits of entropy available)
[ 2.751508] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 75 bits of entropy available)
[ 2.752185] systemd-fstab-generator[241]: Checking was requested for “/media/root-ro/”, but it is not a device.
[ 2.762653] systemd-sysv-generator[242]: [/lib/systemd/system/networking.service:2] Missing ‘=’.
[ 2.768784] random: systemd: uninitialized urandom read (16 bytes read, 77 bits of entropy available)
[ 2.768820] random: systemd: uninitialized urandom read (16 bytes read, 77 bits of entropy available)
[ 2.768889] random: systemd: uninitialized urandom read (16 bytes read, 77 bits of entropy available)
[ 2.769180] random: systemd: uninitialized urandom read (16 bytes read, 77 bits of entropy available)
[ 2.817966] systemd[1]: [/lib/systemd/system/networking.service:2] Missing ‘=’.
[ 2.836516] systemd[1]: -.mount: Found ordering cycle on -.mount/start
[ 2.836525] systemd[1]: -.mount: Found dependency on media-root\x2dro.mount/start
[ 2.836531] systemd[1]: -.mount: Found dependency on -.mount/start
[ 2.836537] systemd[1]: Unable to break cycle
[ 2.842670] systemd[1]: Requested transaction contains an unfixable cyclic ordering dependency: Resource deadlock avoided
[ 2.843278] systemd[1]: networking.service: Cannot add dependency job, ignoring: Unit networking.service is not loaded properly: Invalid argument.
[ 2.843290] systemd[1]: networking.service: Cannot add dependency job, ignoring: Unit networking.service is not loaded properly: Invalid argument.
[ 2.844301] systemd[1]: Listening on udev Control Socket.
[ 2.844474] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.844494] systemd[1]: Reached target Encrypted Volumes.
[ 2.844511] systemd[1]: Reached target Swap.
[ 2.844591] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.844667] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.844766] systemd[1]: Created slice User and Session Slice.
[ 2.844929] systemd[1]: Listening on Journal Audit Socket.
[ 2.844986] systemd[1]: Listening on Syslog Socket.
[ 2.845062] systemd[1]: Listening on Journal Socket.
[ 2.845099] systemd[1]: Reached target Network.
[ 2.845172] systemd[1]: Created slice System Slice.
[ 2.845815] systemd[1]: Mounting POSIX Message Queue File System…
[ 2.846483] systemd[1]: Mounting RPC Pipe File System…
[ 2.846656] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.846715] systemd[1]: Reached target Slices.
[ 2.847515] systemd[1]: Starting Journal Service…
[ 2.847642] systemd[1]: Created slice system-getty.slice.
[ 2.852497] tegra-pcie 1003000.pcie-controller: link 0 down, retryin
