I can’t use bluetooth on nx. I just install the 4.6 system.
I can’t turn on the off button. it’s grey. thank you for your reply!!!. I want to use bluetooth!
How is the result from rfkill command ? Do you see anything got blocked?
I type in terminal : rfkill list
just have
0: phy0: Wireless LAN
no bluetooth device!!
Any dmesg to share?
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:19:28 PDT 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06aa000
[ 0.000000] Found lut_mem: 00002008@a06a4000
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2031101
[ 0.000000] DMA zone: 7160 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 458237 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1999365
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a4000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29964(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7182412K/8124404K available (15358K kernel code, 2956K rwdata, 6692K rodata, 8640K init, 612K bss, 188328K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000712] Console: colour dummy device 80x25
[ 0.000723] console [tty0] enabled
[ 0.000730] bootconsole [tegra_comb_uart0] disabled
[ 0.000744] kmemleak: Kernel memory leak detector disabled
[ 0.000762] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000777] pid_max: default: 32768 minimum: 301
[ 0.001837] Security Framework initialized
[ 0.002415] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002426] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004003] ftrace: allocating 47077 entries in 184 pages
[ 0.402682] sched-energy: Sched-energy-costs installed from DT
[ 0.402702] ASID allocator initialised with 65536 entries
[ 0.437415] tegra-id: chipid=21917.
[ 0.437427] tegra-id: opt_subrevision=1.
[ 0.437455] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.437476] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.437488] DTB Build time: Jul 26 2021 12:22:25
[ 0.485559] CPU1: Booted secondary processor [4e0f0040]
[ 0.517632] CPU2: Booted secondary processor [4e0f0040]
[ 0.549825] CPU3: Booted secondary processor [4e0f0040]
[ 0.582034] CPU4: Booted secondary processor [4e0f0040]
[ 0.614152] CPU5: Booted secondary processor [4e0f0040]
[ 0.614366] Brought up 6 CPUs
[ 0.614376] SMP: Total of 6 processors activated.
[ 0.614385] CPU features: detected feature: Privileged Access Never
[ 0.614392] CPU features: detected feature: LSE atomic instructions
[ 0.614398] CPU features: detected feature: User Access Override
[ 0.614404] CPU features: detected feature: 32-bit EL0 Support
[ 0.615861] CPU: All CPU(s) started at EL2
[ 0.615909] alternatives: patching kernel code
[ 0.622223] devtmpfs: initialized
[ 0.659924] Initilizing CustomIPI irq domain
[ 0.660101] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.660119] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.673192] pinctrl core: initialized pinctrl subsystem
[ 0.673446] OS set in device tree is not L4T.
[ 0.673737] regulator-dummy: no parameters
[ 0.673970] Initializing plugin-manager
[ 0.674015] Plugin module not found
[ 0.674048] Plugin-manager status disabled
[ 0.675265] NET: Registered protocol family 16
[ 0.676542] pstore: using zlib compression
[ 0.676565] console [pstore-1] enabled
[ 0.676573] pstore: Registered ramoops as persistent store backend
[ 0.676582] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.692822] cpuidle: using governor menu
[ 0.693911] bpmp: waiting for handshake
[ 0.693923] bpmp: handshake completed
[ 0.693954] bpmp: synchronizing channels
[ 0.693966] bpmp: channels synchronized
[ 0.693972] bpmp: mail init ok
[ 0.696407] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.696577] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.696583] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.696590] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.696596] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.696601] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.696610] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.696618] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.696625] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.696631] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.696638] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.699696] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[ 0.699725] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.702666] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.703820] tegra_aon_clk_init: ok
[ 0.703838] Registering BPMP clocks…
[ 0.703946] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.704560] Serial: AMBA PL011 UART driver
[ 0.704682] tegra_powergate_init: DONE
[ 0.704770] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.704787] DTB Build time: Jul 26 2021 12:22:25
[ 0.707463] Tegra reboot handler registered.
[ 0.714109] iommu: Adding device 14160000.pcie to group 0
[ 0.714655] iommu: Adding device 141a0000.pcie to group 1
[ 0.715798] iommu: Adding device 2490000.ether_qos to group 2
[ 0.716299] iommu: Adding device 3100000.serial to group 3
[ 0.716726] iommu: Adding device 3110000.serial to group 4
[ 0.717054] iommu: Adding device 3140000.serial to group 5
[ 0.717676] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.717870] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.717896] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.717906] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.717911] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.717963] tegra-pmc: PMC Prod config success
[ 0.718119] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.718133] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.718409] iommu: Adding device 3400000.sdhci to group 6
[ 0.718822] iommu: Adding device 3210000.spi to group 7
[ 0.719155] iommu: Adding device 3230000.spi to group 8
[ 0.719566] iommu: Adding device 3270000.spi to group 9
[ 0.720443] iommu: Adding device 3160000.i2c to group 10
[ 0.720802] iommu: Adding device c240000.i2c to group 11
[ 0.721216] iommu: Adding device 3180000.i2c to group 12
[ 0.721592] iommu: Adding device 3190000.i2c to group 13
[ 0.722051] iommu: Adding device 31b0000.i2c to group 14
[ 0.722433] iommu: Adding device 31c0000.i2c to group 15
[ 0.722788] iommu: Adding device c250000.i2c to group 16
[ 0.723168] iommu: Adding device 31e0000.i2c to group 17
[ 0.723647] iommu: Adding device sound to group 18
[ 0.724123] iommu: Adding device 3510000.hda to group 19
[ 0.724652] iommu: Adding device bc00000.rtcpu to group 20
[ 0.726419] iommu: Adding device 13e10000.host1x to group 21
[ 0.726759] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.727077] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.727401] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.727715] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.728039] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.728424] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.728771] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.729189] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.729693] iommu: Adding device 15340000.vic to group 30
[ 0.730064] iommu: Adding device 15380000.nvjpg to group 31
[ 0.730386] iommu: Adding device 15500000.tsec to group 32
[ 0.730648] iommu: Adding device 15100000.tsecb to group 33
[ 0.730901] iommu: Adding device 15480000.nvdec to group 34
[ 0.731211] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.731463] iommu: Adding device 154c0000.nvenc to group 36
[ 0.731711] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.732106] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.732523] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.733022] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.733202] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06aa000(800000)
[ 0.733214] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a4000(3000)
[ 0.737112] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.737190] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.737732] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.737785] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.739494] iommu: Adding device 15c10000.vi to group 42
[ 0.739654] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.739996] iommu: Adding device 14800000.isp to group 43
[ 0.740921] iommu: Adding device 16000000.pva0 to group 44
[ 0.741430] iommu: Adding device 16800000.pva1 to group 45
[ 0.741849] iommu: Adding device 15810000.se to group 46
[ 0.742214] iommu: Adding device 15820000.se to group 47
[ 0.742479] iommu: Adding device 15830000.se to group 48
[ 0.742848] iommu: Adding device 15840000.se to group 49
[ 0.743221] iommu: Adding device c1a0000.aon to group 50
[ 0.744766] iommu: Adding device d000000.bpmp to group 51
[ 0.745084] bpmp: ping status is 0
[ 0.745211] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.748614] bpmp d000000.bpmp: probe ok
[ 0.750314] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.750723] iommu: Adding device smmu_test to group 52
[ 0.751852] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c10000
[ 0.751874] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c20000
[ 0.751895] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c30000
[ 0.751917] mc: mapped MMIO address: 0xffffff800b010000 → 0x2c40000
[ 0.751935] mc: mapped MMIO address: 0xffffff800b030000 → 0x2c50000
[ 0.751956] mc: mapped MMIO address: 0xffffff800b050000 → 0x2b80000
[ 0.751975] mc: mapped MMIO address: 0xffffff800b070000 → 0x2b90000
[ 0.751993] mc: mapped MMIO address: 0xffffff800b090000 → 0x2ba0000
[ 0.752011] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x2bb0000
[ 0.752029] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1700000
[ 0.752047] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1710000
[ 0.752065] mc: mapped MMIO address: 0xffffff800b110000 → 0x1720000
[ 0.752084] mc: mapped MMIO address: 0xffffff800b130000 → 0x1730000
[ 0.752102] mc: mapped MMIO address: 0xffffff800b150000 → 0x1740000
[ 0.752121] mc: mapped MMIO address: 0xffffff800b170000 → 0x1750000
[ 0.752139] mc: mapped MMIO address: 0xffffff800b190000 → 0x1760000
[ 0.752175] mc: mapped MMIO address: 0xffffff800b1b0000 → 0x1770000
[ 0.752254] mc-err: mcerr ops are set to t19x
[ 0.757662] iommu: Adding device 2600000.dma to group 53
[ 0.762445] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.763639] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.763685] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.763722] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.763998] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.769396] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.769472] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.769512] GPIO line 266 (w-disable1) hogged as output/high
[ 0.769546] GPIO line 264 (w-disable2) hogged as output/high
[ 0.769602] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.769875] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.771928] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.771940] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.771950] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.772885] iommu: Adding device 3550000.xudc to group 54
[ 0.773846] iommu: Adding device 3610000.xhci to group 55
[ 0.775888] arm64_ras arm64_ras: probed
[ 0.776234] ras_fhi_enable: FHI 469 enabled on CPU0
[ 0.776282] ras_fhi_enable: FHI 470 enabled on CPU1
[ 0.776349] ras_fhi_enable: FHI 471 enabled on CPU2
[ 0.776447] ras_fhi_enable: FHI 472 enabled on CPU3
[ 0.776564] ras_fhi_enable: FHI 473 enabled on CPU4
[ 0.776642] ras_fhi_enable: FHI 474 enabled on CPU5
[ 0.776856] carmel_ras_enable: RAS enabled on cpu0
[ 0.777030] carmel_ras_enable: RAS enabled on cpu1
[ 0.777213] carmel_ras_enable: RAS enabled on cpu2
[ 0.777436] carmel_ras_enable: RAS enabled on cpu3
[ 0.777640] carmel_ras_enable: RAS enabled on cpu4
[ 0.777836] carmel_ras_enable: RAS enabled on cpu5
[ 0.777933] carmel_ras carmel_ras: probed
[ 0.779117] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[ 0.779643] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 0.780499] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 0.781398] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 0.782196] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 0.782577] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.783749] vdd-ac-bat: 5000 mV
[ 0.784133] vdd-sdmmc1-sw: 3300 mV
[ 0.784464] vdd-1v8-sd: 1800 mV
[ 0.784840] vdd-3v3-cvb: 3300 mV
[ 0.785141] vdd-1v8-cvb: 1800 mV
[ 0.785437] vdd-epb-1v0: 1000 mV
[ 0.785599] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.785867] avdd-cam-2v8: 2800 mV
[ 0.786240] vdd-fan: 5000 mV
[ 0.786521] vdd-hdmi-5v0: 5000 mV
[ 0.786788] vdd_sys_en: 1200 mV
[ 0.826301] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.831022] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.831319] SCSI subsystem initialized
[ 0.831558] libata version 3.00 loaded.
[ 0.831735] usbcore: registered new interface driver usbfs
[ 0.831768] usbcore: registered new interface driver hub
[ 0.831800] usbcore: registered new device driver usb
[ 0.843137] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.845925] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.853168] vdd-1v0: at 1000 mV
[ 0.857193] vdd-1v8-hs: at 1800 mV
[ 0.861225] vdd-1v8-ls: at 1800 mV
[ 0.865233] vdd-1v8-ao: at 1800 mV
[ 0.869224] vddio-ddr-1v1: at 1100 mV
[ 0.873009] vdd-rtc: at 800 mV
[ 0.874231] spmic-ldo1: at 2375 mV
[ 0.881048] vdd-ao-3v3: at 3300 mV
[ 0.889085] vddio-emmc-3v3: at 3300 mV
[ 0.890438] spmic-ldo4: at 1587 mV
[ 0.897149] vdd-usb-3v3: at 3300 mV
[ 0.905190] vddio-sdmmc1-3v3: at 3300 mV
[ 0.909235] vdd-csi-1v2: at 1200 mV
[ 0.910785] spmic-ldo8: at 1800 mV
[ 0.915548] GPIO line 246 (gpio_default) hogged as output/high
[ 0.916919] GPIO line 247 (gpio_default) hogged as output/high
[ 0.917150] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.917478] max77620 4-003c: max77620 probe successful
[ 0.917951] media: Linux media interface: v0.10
[ 0.917999] Linux video capture interface: v2.00
[ 0.919533] pps_core: LinuxPPS API ver. 1 registered
[ 0.919540] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.919625] PTP clock support registered
[ 0.919970] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.920296] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.920336] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.922788] trusty trusty: trusty version: Built: 12:20:34 Jul 26 2021
[ 0.922855] trusty trusty: selected api version: 3 (requested 3)
[ 0.923811] Advanced Linux Sound Architecture Driver Initialized.
[ 0.924294] Bluetooth: Core ver 2.22
[ 0.924335] NET: Registered protocol family 31
[ 0.924341] Bluetooth: HCI device and connection manager initialized
[ 0.924351] Bluetooth: HCI socket layer initialized
[ 0.924390] Bluetooth: L2CAP socket layer initialized
[ 0.924417] Bluetooth: SCO socket layer initialized
[ 0.927147] camchar: rtcpu character device driver loaded
[ 0.927652] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.927728] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.929150] clocksource: Switched to clocksource arch_sys_counter
[ 0.969184] VFS: Disk quotas dquot_6.6.0
[ 0.969273] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.969607] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.970984] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.971038] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.971221] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.971228] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.971241] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.971249] nvmap_page_pool_init: Total RAM pages: 1984019
[ 0.971256] nvmap_page_pool_init: nvmap page pool size: 248002 pages (968 MB)
[ 0.971409] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.972067] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.973522] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 0.984897] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.985083] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.985389] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 0.985565] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 0.985713] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.986878] la/ptsa driver initialized.
[ 0.987193] NET: Registered protocol family 2
[ 0.988057] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.988390] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.989021] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.989064] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.989224] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.989656] NET: Registered protocol family 1
[ 0.990156] RPC: Registered named UNIX socket transport module.
[ 0.990163] RPC: Registered udp transport module.
[ 0.990168] RPC: Registered tcp transport module.
[ 0.990173] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.990193] PCI: CLS 0 bytes, default 64
[ 0.990453] Trying to unpack rootfs image as initramfs…
[ 1.213605] Freeing initrd memory: 7068K
[ 1.226067] random: fast init done
[ 1.230521] host1x 13e10000.host1x: initialized
[ 1.232136] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.236499] audit: initializing netlink subsys (disabled)
[ 1.236550] audit: type=2000 audit(0.848:1): initialized
[ 1.237285] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.243916] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.245032] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.245659] 9p: Installing v9fs 9p2000 file system support
[ 1.250468] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.250645] io scheduler noop registered
[ 1.250848] io scheduler cfq registered (default)
[ 1.254367] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.291544] iommu: Adding device 2993000.adsp to group 56
[ 1.407421] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.408379] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.420726] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.421180] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.421760] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.422159] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.422564] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.425651] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.425842] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.428649] tsec 15500000.tsec: initialized
[ 1.430425] tsec 15100000.tsecb: initialized
[ 1.434068] nvdec 15480000.nvdec: initialized
[ 1.436645] nvdec 15140000.nvdec1: initialized
[ 1.442295] falcon 15340000.vic: initialized
[ 1.444149] falcon 15380000.nvjpg: initialized
[ 1.446171] falcon 154c0000.nvenc: initialized
[ 1.448072] falcon 15a80000.nvenc1: initialized
[ 1.451165] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.453055] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.454910] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.456666] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.458436] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.460186] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.462019] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.463768] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.467238] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.472670] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.473045] scare-pigeon 14b00000.isp-thi: initialized
[ 1.478562] pva 16000000.pva0: initialized
[ 1.484116] pva 16800000.pva1: initialized
[ 1.488951] nvdla 15880000.nvdla0: initialized
[ 1.493624] nvdla 158c0000.nvdla1: initialized
[ 1.494860] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.494874] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.494907] tegradccommon 15200000.dc_common: dma mapping done
[ 1.495037] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.495048] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.495363] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.495385] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.495606] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.495616] tegra_cec 3960000.tegra_cec: probed
[ 1.496573] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.496631] generic_infoframe_type: 0x87
[ 1.496752] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.496785] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
[ 1.501835] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.501844] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 1.501849] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.502077] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.502091] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.502941] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.505509] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.505571] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.507457] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.508022] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.508031] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.508334] kfuse 3830000.kfuse: initialized
[ 1.508916] tegradc 15200000.nvdisplay: probed
[ 1.516698] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.519211] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.520328] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.521050] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.522211] console [ttyTCU0] enabled
[ 1.522482] [drm] Initialized
[ 1.533275] brd: module loaded
[ 1.538244] loop: module loaded
[ 1.538303] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.538431] tegra_profiler: auth: init
[ 1.539072] THERMAL EST: found 3 subdevs
[ 1.539080] THERMAL EST num_resources: 0
[ 1.539086] [THERMAL EST subdev 0]
[ 1.539093] [THERMAL EST subdev 1]
[ 1.539099] [THERMAL EST subdev 2]
[ 1.539126] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.539403] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.539409] THERMAL EST: thz register success.
[ 1.539591] THERMAL EST: end of probe, return err: 0
[ 1.540344] sd: No Scsi addr parsed to reserve index
[ 1.540373] hisi_sas: driver version v1.6
[ 1.549657] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.549669] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.549680] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.549948] 1 ofpart partitions found on MTD device spi6.0
[ 1.549955] Creating 1 MTD partitions on “spi6.0”:
[ 1.549976] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.552234] libphy: Fixed MDIO Bus: probed
[ 1.552856] Console: switching to colour frame buffer device 240x67
[ 1.552860] tun: Universal TUN/TAP device driver, 1.6
[ 1.552864] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.552994] tegradc 15200000.nvdisplay: fb registered
[ 1.553348] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.553887] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.553896] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.553971] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.553999] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.554004] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.554059] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.554069] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.554074] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.554119] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 1.554147] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 1.558960] Parent Clock set for DC plld2
[ 1.624496] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.625159] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.625174] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.650917] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.650924] Extcon AUX1(HDMI) enable
[ 1.651451] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.651487] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.651587] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.651647] tegradc 15210000.nvdisplay: Display dc.ffffff800d150000 registered with id=1
[ 1.651862] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.651871] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.660174] tegradc 15210000.nvdisplay: probed
[ 1.660558] tegradc 15210000.nvdisplay: fb registered
[ 1.663833] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.663842] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.663854] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.663866] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.663879] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.663884] Extcon DP: HPD disabled
[ 1.663889] hpd: hpd_switch 0
[ 1.663895] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.663907] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.663915] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.784229] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.800165] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.800699] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 7 70 91
[ 1.800715] Using phyrst_lpmode = 1 from DT
[ 1.800811] libphy: dwc_phy: probed
[ 1.803275] PPP generic driver version 2.4.2
[ 1.803701] PPP BSD Compression module registered
[ 1.803707] PPP Deflate Compression module registered
[ 1.803723] PPP MPPE Compression module registered
[ 1.803728] NET: Registered protocol family 24
[ 1.803804] usbcore: registered new interface driver r8152
[ 1.803841] usbcore: registered new interface driver asix
[ 1.803906] usbcore: registered new interface driver ax88179_178a
[ 1.803937] usbcore: registered new interface driver cdc_ether
[ 1.803961] usbcore: registered new interface driver net1080
[ 1.804009] usbcore: registered new interface driver cdc_subset
[ 1.804042] usbcore: registered new interface driver zaurus
[ 1.804099] usbcore: registered new interface driver cdc_ncm
[ 1.804278] VFIO - User Level meta-driver version: 0.3
[ 1.805440] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.805455] ehci-pci: EHCI PCI platform driver
[ 1.805507] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.805515] ohci-pci: OHCI PCI platform driver
[ 1.805541] ohci-platform: OHCI generic platform driver
[ 1.810493] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.812414] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4e22400 id
[ 1.812810] usbcore: registered new interface driver uas
[ 1.812857] usbcore: registered new interface driver usb-storage
[ 1.812915] usbcore: registered new interface driver usbserial
[ 1.815024] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 1.815054] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.815094] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.815431] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.815505] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.815811] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.815845] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 1.816042] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.816048] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.816053] usb usb1: Product: xHCI Host Controller
[ 1.816057] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.816061] usb usb1: SerialNumber: 3610000.xhci
[ 1.816479] hub 1-0:1.0: USB hub found
[ 1.816553] hub 1-0:1.0: 4 ports detected
[ 1.817019] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.817029] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.817061] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.817326] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.817332] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.817337] usb usb2: Product: xHCI Host Controller
[ 1.817341] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.817345] usb usb2: SerialNumber: 3610000.xhci
[ 1.817732] hub 2-0:1.0: USB hub found
[ 1.817770] hub 2-0:1.0: 4 ports detected
[ 1.818620] Wake76 for irq=199
[ 1.818623] Wake77 for irq=199
[ 1.818626] Wake78 for irq=199
[ 1.818628] Wake79 for irq=199
[ 1.818630] Wake80 for irq=199
[ 1.818633] Wake81 for irq=199
[ 1.818635] Wake82 for irq=199
[ 1.818668] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 1.818674] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 1.819000] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.819008] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.819028] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.819233] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.819734] mousedev: PS/2 mouse device common for all mice
[ 1.819857] usbcore: registered new interface driver xpad
[ 1.824893] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.824897] Extcon AUX1(HDMI) disable
[ 1.850344] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.851505] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.873058] tegradc 15200000.nvdisplay: unblank
[ 1.874853] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.875126] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.885803] Parent Clock set for DC plld2
[ 1.890878] tegradc 15200000.nvdisplay: hdmi: tmds rate:85500K prod-setting:prod_c_hdmi_54m_111m
[ 1.892262] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.921458] usb usb2: usb_suspend_both: status 0
[ 1.926776] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.926780] Extcon AUX1(HDMI) enable
[ 1.937803] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.939252] Wake73 for irq=42
[ 1.940509] rtc rtc1: alarm rtc device
[ 1.940524] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.940548] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.940690] i2c /dev entries driver
[ 1.942625] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 1.943034] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.943592] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.943624] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.944112] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.964663] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 1.964669] Extcon HDMI: HPD enabled
[ 1.964693] tegradc 15200000.nvdisplay: hdmi: plugged
[ 1.967605] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 1.967707] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.968053] imx219 9-0010: board setup failed
[ 1.968277] imx219: probe of 9-0010 failed with error -121
[ 1.968735] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.992021] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 1.992093] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.992798] imx219 10-0010: board setup failed
[ 1.993045] imx219: probe of 10-0010 failed with error -121
[ 1.994070] max77620-power max20024-power: Event recorder REG_NVERC : 0x44
[ 2.000096] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 2.000422] FAN dev name: pwm-fan
[ 2.000472] FAN:gpio request success.
[ 2.000484] FAN: can’t find tach_gpio
[ 2.000496] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 2.000523] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 2.000701] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.000708] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.001246] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.001254] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 2.001261] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 2.001268] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 2.001274] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.001280] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.001287] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.001293] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.001300] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.001307] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.001972] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.002877] device-mapper: uevent: version 1.0.3
[ 2.003218] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.006768] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 2.007801] cpuidle: Initializing cpuidle driver
[ 2.008659] sdhci: Secure Digital Host Controller Interface driver
[ 2.008663] sdhci: Copyright(c) Pierre Ossman
[ 2.008667] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.008994] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.009974] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.011839] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 246
[ 2.017278] tegra-se-nvhost 15810000.se: initialized
[ 2.018351] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.019067] tegra-se-nvhost 15820000.se: initialized
[ 2.020183] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.020747] tegra-se-nvhost 15830000.se: initialized
[ 2.021402] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.021928] tegra-se-nvhost 15840000.se: initialized
[ 2.023040] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.024008] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.024112] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.025344] usbcore: registered new interface driver usbhid
[ 2.025348] usbhid: USB HID core driver
[ 2.029127] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.030164] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.030521] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.031097] denver_knobs_init:MTS_VERSION:53250041
[ 2.031382] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 2.032132] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.032508] t19x_cache tegra-cache: probed
[ 2.034656] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.034665] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.035184] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.035601] PLL_AON clock registered
[ 2.036783] Clocks initialized successfully
[ 2.038397] nvpmodel: initialized successfully
[ 2.039384] trusty-virtio trusty:virtio: initializing
[ 2.039576] trusty_ipc virtio0: vring0: va¶ ffffffc1e269c000(0) qsz 32 notifyid 1
[ 2.039586] trusty_ipc virtio0: vring1: va¶ ffffffc1e269e000(0) qsz 32 notifyid 2
[ 2.039718] trusty-virtio trusty:virtio: initializing done
[ 2.040043] trusty_ipc virtio0: is online
[ 2.040352] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.040776] usbcore: registered new interface driver snd-usb-audio
[ 2.060794] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.060953] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.061117] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.061336] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 2.061376] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.061405] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.112786] OPE platform probe
[ 2.112884] OPE platform probe successful
[ 2.149192] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.188366] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.188509] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.188639] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.188769] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.188875] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.189051] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.189192] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.189322] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.189433] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.189537] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.189640] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.189748] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.189849] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.189947] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.190038] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.190044] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.190049] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.190053] usb 1-2: Manufacturer: Generic
[ 2.190210] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.190454] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.190538] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.190718] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.190821] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.190921] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.191466] hub 1-2:1.0: USB hub found
[ 2.192513] hub 1-2:1.0: 4 ports detected
[ 2.220561] u32 classifier
[ 2.220566] Actions configured
[ 2.220667] Initializing XFRM netlink socket
[ 2.221248] NET: Registered protocol family 10
[ 2.221985] NET: Registered protocol family 17
[ 2.221997] NET: Registered protocol family 15
[ 2.222053] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.222129] Bluetooth: RFCOMM socket layer initialized
[ 2.222145] Bluetooth: RFCOMM ver 1.11
[ 2.222151] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.222159] Bluetooth: HIDP socket layer initialized
[ 2.222176] 9pnet: Installing 9P2000 support
[ 2.222211] Key type dns_resolver registered
[ 2.222441] Registered cp15_barrier emulation handler
[ 2.222462] Registered setend emulation handler
[ 2.224147] registered taskstats version 1
[ 2.224601] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.225516] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.225539] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.225548] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.225554] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 2.298040] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 2.326291] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.333883] tegra-pcie-dw 14160000.pcie: link is up
[ 2.334214] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.334223] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.334231] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.334237] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.334242] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.334270] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.334469] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.334686] iommu: Adding device 0004:00:00.0 to group 58
[ 2.335002] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 2.335135] pci 0004:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 2.335140] pci 0004:01:00.0: reg 0x10: [io size 0x0100]
[ 2.335315] pci 0004:01:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit]
[ 2.335407] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 2.335412] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.335431] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 2.335435] usb 2-3: Manufacturer: Generic
[ 2.337397] pci 0004:01:00.0: supports D1 D2
[ 2.337402] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.337819] iommu: Adding device 0004:01:00.0 to group 59
[ 2.352163] hub 2-3:1.0: USB hub found
[ 2.354392] hub 2-3:1.0: 4 ports detected
[ 2.355675] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 2.355682] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.355690] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 2.355773] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.355802] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.355808] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.355817] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 2.355837] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.355916] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.356134] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.356139] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.356146] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.356239] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.357720] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.357903] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[ 2.357917] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[ 2.468340] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.468362] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 2.468371] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 2.468377] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 2.472570] mmc0: hw tuning done …
[ 2.472619] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 2.473057] mmcblk0: mmc0:aaaa SN128 119 GiB
[ 2.483884] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.497204] usb 1-3: new low-speed USB device number 3 using tegra-xusb
[ 2.498243] usb 1-3: Device not responding to setup address.
[ 2.501196] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.565733] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.565740] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.706251] usb 1-3: Device not responding to setup address.
[ 2.913177] usb 1-3: device not accepting address 3, error -71
[ 2.941178] usb 2-3: usb_suspend_both: status 0
[ 2.941357] usb usb2: usb_suspend_both: status 0
[ 2.980707] tegra-pcie-dw 141a0000.pcie: link is down
[ 2.980814] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.980822] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.980829] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.980836] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.980841] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.980867] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.981008] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.981247] iommu: Adding device 0005:00:00.0 to group 60
[ 2.981438] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.981461] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.981651] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.981658] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.981738] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.981871] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.981911] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 2.981982] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 2.982049] iommu: Removing device 0005:00:00.0 from group 60
[ 2.982073] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 2.983694] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 2.992647] tegra-cbb 14040000.cv-noc: noc_secure_irq = 90, noc_nonsecure_irq = 89>
[ 2.993183] usb 1-2.1: new full-speed USB device number 4 using tegra-xusb
[ 3.000708] tegra194-isp5 14800000.isp: initialized
[ 3.007152] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 3.011164] tegra194-vi5 15c10000.vi: initialized
[ 3.015519] usb 1-2.1: New USB device found, idVendor=062a, idProduct=4101
[ 3.015527] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.015531] usb 1-2.1: Product: 2.4G Keyboard Mouse
[ 3.015535] usb 1-2.1: Manufacturer: MOSART Semi.
[ 3.015828] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 3.015933] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 3.016166] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 3.017596] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:062A:4101.0001/input/input4
[ 3.020497] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 3.020527] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 3.020533] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 3.020633] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 3.020671] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 3.020675] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 3.024576] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 3.024601] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 3.024607] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 3.025022] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 3.025057] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 3.025063] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 3.025629] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 3.025675] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 3.025680] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 3.025927] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 3.026677] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.077647] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-3610000.xhci-2.1/input0
[ 3.079850] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:062A:4101.0002/input/input5
[ 3.105949] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 3.106259] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.106449] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 3.106607] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 3.106891] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 3.106953] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 3.107129] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 3.107133] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.108017] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=06bdc710c3c9a48de2881774602bbcf4d0114a58
[ 3.108443] Wake83 for irq=211
[ 3.108510] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 3.108603] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 3.108757] input: gpio-keys as /devices/gpio-keys/input/input6
[ 3.133200] usb 1-3: new low-speed USB device number 5 using tegra-xusb
[ 3.134268] usb 1-3: Device not responding to setup address.
[ 3.137565] hid-generic 0003:062A:4101.0002: input,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-3610000.xhci-2.1/input1
[ 3.170200] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:15 UTC (946688415)
[ 3.170630] mmcblk mmc0:aaaa: Card claimed for testing.
[ 3.203092] bpmp: mounted debugfs mirror
[ 3.209321] ALSA device list:
[ 3.209329] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 3.209333] #1: jetson-xaviernx-ape
[ 3.211143] Freeing unused kernel memory: 8640K
[ 3.250105] Root device found: mmcblk0p1
[ 3.252098] Found dev node: /dev/mmcblk0p1
[ 3.334814] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.337860] Rootfs mounted over mmcblk0p1
[ 3.342251] usb 1-3: Device not responding to setup address.
[ 3.370507] Switching from initrd to actual rootfs
[ 3.549197] usb 1-3: device not accepting address 5, error -71
[ 3.549453] usb usb1-port3: attempt power cycle
[ 3.569554] systemd[1]: System time before build time, advancing clock.
[ 3.594507] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.599270] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.617480] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.618200] systemd[1]: Detected architecture arm64.
[ 3.623556] systemd[1]: Set hostname to .
[ 3.747458] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.747471] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.928944] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.929268] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.929373] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.929397] systemd[1]: Reached target Swap.
[ 3.929440] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.931842] systemd[1]: Created slice System Slice.
[ 3.932090] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.932376] systemd[1]: Listening on udev Control Socket.
[ 3.985195] usb 1-3: new low-speed USB device number 6 using tegra-xusb
[ 3.990959] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.079022] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.105312] usb 1-3: device descriptor read/64, error -71
[ 4.333326] usb 1-3: device descriptor read/64, error -71
[ 4.363063] systemd-journald[2399]: Received request to flush runtime journal from PID 1
[ 4.561279] usb 1-3: new low-speed USB device number 7 using tegra-xusb
[ 4.685303] usb 1-3: device descriptor read/64, error -71
[ 4.913305] usb 1-3: device descriptor read/64, error -71
[ 5.021255] usb usb1-port3: unable to enumerate USB device
[ 5.151053] cpu-throttle-alert cooling device registered.
[ 5.151395] gpu-throttle-alert cooling device registered.
[ 5.151743] aux-throttle-alert cooling device registered.
[ 5.375956] random: crng init done
[ 5.376109] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.599529] rtl88x2ce 0004:01:00.0: enabling device (0000 → 0003)
[ 5.754983] using random self ethernet address
[ 5.755139] using random host ethernet address
[ 6.878759] Mass Storage Function, version: 2009/09/11
[ 6.878772] LUN: removable file: (no medium)
[ 6.885364] using random self ethernet address
[ 6.885558] using random host ethernet address
[ 7.064446] rndis0: HOST MAC 72:59:9e:3f:7d:28
[ 7.064555] rndis0: MAC 72:59:9e:3f:7d:29
[ 7.065122] usb0: HOST MAC 72:59:9e:3f:7d:2a
[ 7.065238] usb0: MAC 72:59:9e:3f:7d:2b
[ 7.065263] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 7.065921] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 7.065949] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 7.065991] tegra-xudc-new 3550000.xudc: entering ELPG
[ 7.066256] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 7.066272] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 7.066711] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 7.066725] tegra-xudc-new 3550000.xudc: entering ELPG
[ 7.066909] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 7.075677] l4tbr0: port 1(rndis0) entered blocking state
[ 7.075685] l4tbr0: port 1(rndis0) entered disabled state
[ 7.076292] device rndis0 entered promiscuous mode
[ 7.082467] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 7.087182] l4tbr0: port 2(usb0) entered blocking state
[ 7.087191] l4tbr0: port 2(usb0) entered disabled state
[ 7.087345] device usb0 entered promiscuous mode
[ 7.093050] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.549462] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.777771] ras_fhi_disable: FHI 473 disabled
[ 7.778484] CPU4: shutdown
[ 7.778623] psci: CPU4 killed (polled 0 ms)
[ 7.829943] ras_fhi_disable: FHI 474 disabled
[ 7.831423] CPU5: shutdown
[ 7.832649] psci: CPU5 killed (polled 0 ms)
[ 7.834671] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 7.862644] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 7.874711] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.889278] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.070460] zram: Added device: zram0
[ 8.073837] zram: Added device: zram1
[ 8.074953] zram: Added device: zram2
[ 8.076112] zram: Added device: zram3
[ 8.093706] zram0: detected capacity change from 0 to 1017831424
[ 8.190532] Adding 993972k swap on /dev/zram0. Priority:5 extents:1 across:993972k SS
[ 8.191772] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.198887] zram1: detected capacity change from 0 to 1017831424
[ 8.217027] Adding 993972k swap on /dev/zram1. Priority:5 extents:1 across:993972k SS
[ 8.219998] zram2: detected capacity change from 0 to 1017831424
[ 8.243312] Adding 993972k swap on /dev/zram2. Priority:5 extents:1 across:993972k SS
[ 8.252221] zram3: detected capacity change from 0 to 1017831424
[ 8.264559] Adding 993972k swap on /dev/zram3. Priority:5 extents:1 across:993972k SS
[ 8.628175] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.749913] Bridge firewalling registered
[ 9.782820] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 10.021766] Netfilter messages via NETLINK v0.30.
[ 10.037395] ctnetlink v0.93: registering with nfnetlink.
[ 10.208342] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 10.662427] tegradc 15200000.nvdisplay: unblank
[ 10.662443] tegradc 15210000.nvdisplay: blank - powerdown
[ 11.646263] fuse init (API version 7.26)
[ 14.727126] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.727144] Bluetooth: BNEP socket layer initialized
[ 26.436512] tegradc 15200000.nvdisplay: blank - powerdown
[ 26.500343] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 26.500414] Extcon AUX1(HDMI) disable
[ 26.517415] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 26.517900] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 26.518067] tegradc 15210000.nvdisplay: blank - powerdown
[ 26.668990] tegradc 15200000.nvdisplay: blank - powerdown
[ 26.669005] tegradc 15200000.nvdisplay: unblank
[ 26.669813] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 26.669928] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 26.673319] Parent Clock set for DC plld2
[ 26.682756] tegradc 15200000.nvdisplay: hdmi: tmds rate:85500K prod-setting:prod_c_hdmi_54m_111m
[ 26.684163] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 26.719196] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 26.719200] Extcon AUX1(HDMI) enable
[ 26.719303] tegradc 15200000.nvdisplay: unblank
[ 26.719318] tegradc 15210000.nvdisplay: blank - powerdown
[ 30.320359] ------------[ cut here ]------------
[ 30.320581] WARNING: CPU: 3 PID: 5910 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/net/wireless/nl80211.c:14153 cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[ 30.320824] Modules linked in: bnep fuse xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack br_netfilter zram overlay rtl8822ce cfg80211 userspace_alert nvgpu ip_tables x_tables
[ 30.320902] CPU: 3 PID: 5910 Comm: RTW_CMD_THREAD Not tainted 4.9.253-tegra #1
[ 30.320905] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 30.320911] task: ffffffc1e263c600 task.stack: ffffffc1de6d0000
[ 30.320975] PC is at cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[ 30.321429] LR is at rtw_cfg80211_ch_switch_notify+0x94/0x98 [rtl8822ce]
[ 30.321433] pc : [] lr : [] pstate: 60c00045
[ 30.321436] sp : ffffffc1de6d3c20
[ 30.321439] x29: ffffffc1de6d3c20 x28: ffffff8001279760
[ 30.321447] x27: ffffff800be4a1bc x26: ffffff800143e578
[ 30.321454] x25: ffffff80014c213c x24: ffffffc1d9304000
[ 30.321462] x23: ffffffc1d374d000 x22: ffffffc1d375c800
[ 30.321469] x21: 0000000000000001 x20: ffffffc1de6d3ca8
[ 30.321476] x19: ffffffc1dc151800 x18: 00000000ffffffe5
[ 30.321484] x17: 0000000000000000 x16: 000000000000000e
[ 30.321491] x15: 0000000000000030 x14: 0000000000000000
[ 30.321498] x13: 000000000000ffff x12: 13196f1a2d000100
[ 30.321506] x11: 0000000000000004 x10: 0000000000000002
[ 30.321516] x9 : 0000000000000004 x8 : ffffffc1de6d3d3a
[ 30.321525] x7 : 0000000000000000 x6 : 0000000000000001
[ 30.321533] x5 : 0000000000000040 x4 : 0000000000000985
[ 30.321540] x3 : 0000097b00000002 x2 : ffffffc1d375d988
[ 30.321551] x1 : 0000097b00000002 x0 : 0000000000000000
[ 30.321562] —[ end trace fb15d9255bf59703 ]—
[ 30.321645] Call trace:
[ 30.321714] [] cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[ 30.322170] [] rtw_cfg80211_ch_switch_notify+0x94/0x98 [rtl8822ce]
[ 30.322615] [] rtw_chk_start_clnt_join+0x43c/0x4d8 [rtl8822ce]
[ 30.323051] [] join_cmd_hdl+0x238/0x330 [rtl8822ce]
[ 30.323481] [] rtw_cmd_thread+0x308/0x608 [rtl8822ce]
[ 30.323495] [] kthread+0xec/0xf0
[ 30.323502] [] ret_from_fork+0x10/0x30
[ 30.588170] tegradc 15200000.nvdisplay: unblank
[ 30.588184] tegradc 15210000.nvdisplay: blank - powerdown
[ 30.828560] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 34.145236] vdd-1v8-sd: disabling
[ 34.145245] vdd-1v8-cvb: disabling
[ 34.145249] vdd-epb-1v0: disabling
[ 34.145252] avdd-cam-2v8: disabling
[ 34.145256] vdd-fan: disabling
[ 34.145259] vdd_sys_en: disabling
