alanz:
dmesg > dmesg.txt
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06aa000
[ 0.000000] Found lut_mem: 00002008@a06a4000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2031101
[ 0.000000] DMA zone: 7160 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 458237 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1999365
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a4000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29200(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7182572K/8124404K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 188168K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000658] Console: colour dummy device 80x25
[ 0.000669] console [tty0] enabled
[ 0.000677] bootconsole [tegra_comb_uart0] disabled
[ 0.000691] kmemleak: Kernel memory leak detector disabled
[ 0.000710] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000726] pid_max: default: 32768 minimum: 301
[ 0.001811] Security Framework initialized
[ 0.002393] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002403] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004027] ftrace: allocating 47208 entries in 185 pages
[ 0.403001] sched-energy: Sched-energy-costs installed from DT
[ 0.403021] ASID allocator initialised with 65536 entries
[ 0.437507] tegra-id: chipid=21917.
[ 0.437518] tegra-id: opt_subrevision=1.
[ 0.437545] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.437557] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.437568] DTB Build time: Jul 26 2021 12:22:25
[ 0.485740] CPU1: Booted secondary processor [4e0f0040]
[ 0.517795] CPU2: Booted secondary processor [4e0f0040]
[ 0.549912] CPU3: Booted secondary processor [4e0f0040]
[ 0.582187] CPU4: Booted secondary processor [4e0f0040]
[ 0.614282] CPU5: Booted secondary processor [4e0f0040]
[ 0.614516] Brought up 6 CPUs
[ 0.614526] SMP: Total of 6 processors activated.
[ 0.614535] CPU features: detected feature: Privileged Access Never
[ 0.614542] CPU features: detected feature: LSE atomic instructions
[ 0.614548] CPU features: detected feature: User Access Override
[ 0.614554] CPU features: detected feature: 32-bit EL0 Support
[ 0.616064] CPU: All CPU(s) started at EL2
[ 0.616155] alternatives: patching kernel code
[ 0.622546] devtmpfs: initialized
[ 0.662413] Initilizing CustomIPI irq domain
[ 0.662694] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.662708] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.674554] pinctrl core: initialized pinctrl subsystem
[ 0.674755] OS set in device tree is not L4T.
[ 0.675090] regulator-dummy: no parameters
[ 0.675292] Initializing plugin-manager
[ 0.675335] Plugin module not found
[ 0.675372] Plugin-manager status disabled
[ 0.676640] NET: Registered protocol family 16
[ 0.677883] pstore: using zlib compression
[ 0.677902] console [pstore-1] enabled
[ 0.677907] pstore: Registered ramoops as persistent store backend
[ 0.677913] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.693011] cpuidle: using governor menu
[ 0.694081] bpmp: waiting for handshake
[ 0.694090] bpmp: handshake completed
[ 0.694111] bpmp: synchronizing channels
[ 0.694120] bpmp: channels synchronized
[ 0.694126] bpmp: mail init ok
[ 0.696684] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.696881] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.696889] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.696898] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.696926] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.696932] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.696941] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.696950] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.697016] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.697025] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.697031] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.700228] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.700253] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.702751] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.704625] tegra_aon_clk_init: ok
[ 0.704633] Registering BPMP clocks…
[ 0.704734] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.705571] Serial: AMBA PL011 UART driver
[ 0.705684] tegra_powergate_init: DONE
[ 0.705750] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.705762] DTB Build time: Jul 26 2021 12:22:25
[ 0.709005] Tegra reboot handler registered.
[ 0.716901] iommu: Adding device 14160000.pcie to group 0
[ 0.717634] iommu: Adding device 141a0000.pcie to group 1
[ 0.718992] iommu: Adding device 2490000.ether_qos to group 2
[ 0.719534] iommu: Adding device 3100000.serial to group 3
[ 0.719982] iommu: Adding device 3110000.serial to group 4
[ 0.720383] iommu: Adding device 3140000.serial to group 5
[ 0.721019] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.721484] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.721504] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.721509] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.721514] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.721571] tegra-pmc: PMC Prod config success
[ 0.721767] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.721780] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.722107] iommu: Adding device 3400000.sdhci to group 6
[ 0.722630] iommu: Adding device 3210000.spi to group 7
[ 0.722997] iommu: Adding device 3230000.spi to group 8
[ 0.723384] iommu: Adding device 3270000.spi to group 9
[ 0.724498] iommu: Adding device 3160000.i2c to group 10
[ 0.725041] iommu: Adding device c240000.i2c to group 11
[ 0.725581] iommu: Adding device 3180000.i2c to group 12
[ 0.726048] iommu: Adding device 3190000.i2c to group 13
[ 0.726566] iommu: Adding device 31b0000.i2c to group 14
[ 0.727002] iommu: Adding device 31c0000.i2c to group 15
[ 0.727402] iommu: Adding device c250000.i2c to group 16
[ 0.727811] iommu: Adding device 31e0000.i2c to group 17
[ 0.728449] iommu: Adding device sound to group 18
[ 0.728969] iommu: Adding device 3510000.hda to group 19
[ 0.729576] iommu: Adding device bc00000.rtcpu to group 20
[ 0.731629] iommu: Adding device 13e10000.host1x to group 21
[ 0.732074] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.732648] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.733073] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.733507] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.733953] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.734303] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.734685] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.735031] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.735566] iommu: Adding device 15340000.vic to group 30
[ 0.736097] iommu: Adding device 15380000.nvjpg to group 31
[ 0.736542] iommu: Adding device 15500000.tsec to group 32
[ 0.736850] iommu: Adding device 15100000.tsecb to group 33
[ 0.737129] iommu: Adding device 15480000.nvdec to group 34
[ 0.737412] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.737719] iommu: Adding device 154c0000.nvenc to group 36
[ 0.737984] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.738441] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.738827] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.739392] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.739549] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06aa000(800000)
[ 0.739559] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a4000(3000)
[ 0.743516] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.743596] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.744258] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.744305] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.746129] iommu: Adding device 15c10000.vi to group 42
[ 0.746279] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.746743] iommu: Adding device 14800000.isp to group 43
[ 0.747677] iommu: Adding device 16000000.pva0 to group 44
[ 0.748171] iommu: Adding device 16800000.pva1 to group 45
[ 0.748597] iommu: Adding device 15810000.se to group 46
[ 0.749142] iommu: Adding device 15820000.se to group 47
[ 0.749438] iommu: Adding device 15830000.se to group 48
[ 0.749740] iommu: Adding device 15840000.se to group 49
[ 0.750029] iommu: Adding device c1a0000.aon to group 50
[ 0.751629] iommu: Adding device d000000.bpmp to group 51
[ 0.751937] bpmp: ping status is 0
[ 0.752094] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.755499] bpmp d000000.bpmp: probe ok
[ 0.757368] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.757774] iommu: Adding device smmu_test to group 52
[ 0.758905] mc: mapped MMIO address: 0xffffff800a590000 → 0x2c10000
[ 0.758924] mc: mapped MMIO address: 0xffffff800a5b0000 → 0x2c20000
[ 0.758941] mc: mapped MMIO address: 0xffffff800a5d0000 → 0x2c30000
[ 0.758957] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c40000
[ 0.758974] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c50000
[ 0.758992] mc: mapped MMIO address: 0xffffff800b010000 → 0x2b80000
[ 0.759009] mc: mapped MMIO address: 0xffffff800b030000 → 0x2b90000
[ 0.759030] mc: mapped MMIO address: 0xffffff800b050000 → 0x2ba0000
[ 0.759047] mc: mapped MMIO address: 0xffffff800b070000 → 0x2bb0000
[ 0.759063] mc: mapped MMIO address: 0xffffff800b090000 → 0x1700000
[ 0.759079] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1710000
[ 0.759095] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1720000
[ 0.759111] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1730000
[ 0.759127] mc: mapped MMIO address: 0xffffff800b110000 → 0x1740000
[ 0.759143] mc: mapped MMIO address: 0xffffff800b130000 → 0x1750000
[ 0.759159] mc: mapped MMIO address: 0xffffff800b150000 → 0x1760000
[ 0.759174] mc: mapped MMIO address: 0xffffff800b170000 → 0x1770000
[ 0.759251] mc-err: mcerr ops are set to t19x
[ 0.764744] iommu: Adding device 2600000.dma to group 53
[ 0.769913] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.771113] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.771155] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.771194] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.771501] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.778544] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.778646] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.778684] GPIO line 266 (w-disable1) hogged as output/high
[ 0.778717] GPIO line 264 (w-disable2) hogged as output/high
[ 0.778786] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.779119] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.781493] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.781505] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.781516] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.782350] iommu: Adding device 3550000.xudc to group 54
[ 0.783013] iommu: Adding device 3610000.xhci to group 55
[ 0.785048] arm64_ras arm64_ras: probed
[ 0.785489] ras_fhi_enable: FHI 469 enabled on CPU0
[ 0.785548] ras_fhi_enable: FHI 470 enabled on CPU1
[ 0.785616] ras_fhi_enable: FHI 471 enabled on CPU2
[ 0.785681] ras_fhi_enable: FHI 472 enabled on CPU3
[ 0.785770] ras_fhi_enable: FHI 473 enabled on CPU4
[ 0.785837] ras_fhi_enable: FHI 474 enabled on CPU5
[ 0.786057] carmel_ras_enable: RAS enabled on cpu0
[ 0.786230] carmel_ras_enable: RAS enabled on cpu1
[ 0.786419] carmel_ras_enable: RAS enabled on cpu2
[ 0.786616] carmel_ras_enable: RAS enabled on cpu3
[ 0.786813] carmel_ras_enable: RAS enabled on cpu4
[ 0.787019] carmel_ras_enable: RAS enabled on cpu5
[ 0.787094] carmel_ras carmel_ras: probed
[ 0.788308] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[ 0.788877] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 0.789827] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 0.790762] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 0.791819] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 0.792263] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.793771] vdd-ac-bat: 5000 mV
[ 0.794228] vdd-sdmmc1-sw: 3300 mV
[ 0.794589] vdd-1v8-sd: 1800 mV
[ 0.794920] vdd-3v3-cvb: 3300 mV
[ 0.795255] vdd-1v8-cvb: 1800 mV
[ 0.795605] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.795645] vdd-epb-1v0: 1000 mV
[ 0.796003] avdd-cam-2v8: 2800 mV
[ 0.796399] vdd-fan: 5000 mV
[ 0.796716] vdd-hdmi-5v0: 5000 mV
[ 0.797023] vdd_sys_en: 1200 mV
[ 0.835929] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.841568] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.841895] SCSI subsystem initialized
[ 0.842150] libata version 3.00 loaded.
[ 0.842348] usbcore: registered new interface driver usbfs
[ 0.842398] usbcore: registered new interface driver hub
[ 0.842530] usbcore: registered new device driver usb
[ 0.853573] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.856742] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.863559] vdd-1v0: at 1000 mV
[ 0.867551] vdd-1v8-hs: at 1800 mV
[ 0.871571] vdd-1v8-ls: at 1800 mV
[ 0.875644] vdd-1v8-ao: at 1800 mV
[ 0.879626] vddio-ddr-1v1: at 1100 mV
[ 0.883417] vdd-rtc: at 800 mV
[ 0.884696] spmic-ldo1: at 2375 mV
[ 0.891447] vdd-ao-3v3: at 3300 mV
[ 0.899489] vddio-emmc-3v3: at 3300 mV
[ 0.900969] spmic-ldo4: at 1587 mV
[ 0.907549] vdd-usb-3v3: at 3300 mV
[ 0.915581] vddio-sdmmc1-3v3: at 3300 mV
[ 0.919603] vdd-csi-1v2: at 1200 mV
[ 0.921336] spmic-ldo8: at 1800 mV
[ 0.926153] GPIO line 246 (gpio_default) hogged as output/high
[ 0.927595] GPIO line 247 (gpio_default) hogged as output/high
[ 0.927911] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.928182] max77620 4-003c: max77620 probe successful
[ 0.928958] media: Linux media interface: v0.10
[ 0.929052] Linux video capture interface: v2.00
[ 0.930689] pps_core: LinuxPPS API ver. 1 registered
[ 0.930701] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.930730] PTP clock support registered
[ 0.931053] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.931371] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.931417] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.934214] trusty trusty: trusty version: Built: 12:20:34 Jul 26 2021
[ 0.934272] trusty trusty: selected api version: 3 (requested 3)
[ 0.935584] Advanced Linux Sound Architecture Driver Initialized.
[ 0.936286] Bluetooth: Core ver 2.22
[ 0.936396] NET: Registered protocol family 31
[ 0.936408] Bluetooth: HCI device and connection manager initialized
[ 0.936438] Bluetooth: HCI socket layer initialized
[ 0.936451] Bluetooth: L2CAP socket layer initialized
[ 0.936504] Bluetooth: SCO socket layer initialized
[ 0.939575] camchar: rtcpu character device driver loaded
[ 0.940061] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.940187] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.941729] clocksource: Switched to clocksource arch_sys_counter
[ 0.988187] VFS: Disk quotas dquot_6.6.0
[ 0.988301] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.988706] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.990129] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.990187] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.990520] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.990531] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.990551] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.990565] nvmap_page_pool_init: Total RAM pages: 1984059
[ 0.990578] nvmap_page_pool_init: nvmap page pool size: 248007 pages (968 MB)
[ 0.990910] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.991276] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.993188] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.005080] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.005292] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.005494] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.005673] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.005886] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.007121] la/ptsa driver initialized.
[ 1.007534] NET: Registered protocol family 2
[ 1.008467] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.008840] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.009469] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.009550] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.009672] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.010210] NET: Registered protocol family 1
[ 1.010910] RPC: Registered named UNIX socket transport module.
[ 1.010917] RPC: Registered udp transport module.
[ 1.010922] RPC: Registered tcp transport module.
[ 1.010927] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.010939] PCI: CLS 0 bytes, default 64
[ 1.011163] Trying to unpack rootfs image as initramfs…
[ 1.242611] Freeing initrd memory: 7064K
[ 1.259127] random: fast init done
[ 1.263269] host1x 13e10000.host1x: initialized
[ 1.265627] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.270477] audit: initializing netlink subsys (disabled)
[ 1.270548] audit: type=2000 audit(0.888:1): initialized
[ 1.271242] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.280440] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.281817] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.282490] 9p: Installing v9fs 9p2000 file system support
[ 1.287495] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.287692] io scheduler noop registered
[ 1.287969] io scheduler cfq registered (default)
[ 1.291598] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.325844] iommu: Adding device 2993000.adsp to group 56
[ 1.435305] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.436316] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.449203] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.449709] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.450297] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.450711] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.451123] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.454481] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.454693] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.457558] tsec 15500000.tsec: initialized
[ 1.459296] tsec 15100000.tsecb: initialized
[ 1.463052] nvdec 15480000.nvdec: initialized
[ 1.465639] nvdec 15140000.nvdec1: initialized
[ 1.471144] falcon 15340000.vic: initialized
[ 1.473258] falcon 15380000.nvjpg: initialized
[ 1.475300] falcon 154c0000.nvenc: initialized
[ 1.477348] falcon 15a80000.nvenc1: initialized
[ 1.481529] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.482882] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.484191] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.485591] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.486904] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.488202] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.489635] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.491005] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.494790] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.500106] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.500470] scare-pigeon 14b00000.isp-thi: initialized
[ 1.506280] pva 16000000.pva0: initialized
[ 1.511943] pva 16800000.pva1: initialized
[ 1.516961] nvdla 15880000.nvdla0: initialized
[ 1.521640] nvdla 158c0000.nvdla1: initialized
[ 1.523080] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.523093] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.523129] tegradccommon 15200000.dc_common: dma mapping done
[ 1.523271] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.523281] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.523573] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.523609] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.523862] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.523871] tegra_cec 3960000.tegra_cec: probed
[ 1.524563] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.524612] generic_infoframe_type: 0x87
[ 1.524720] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.524762] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.529946] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.529964] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 1.529974] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.530274] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.530285] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.531225] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.533663] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.533670] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.536661] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.537415] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.537424] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.537755] tegradc 15200000.nvdisplay: probed
[ 1.537796] kfuse 3830000.kfuse: initialized
[ 1.542898] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.545867] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.547036] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.547887] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.549187] console [ttyTCU0] enabled
[ 1.549502] [drm] Initialized
[ 1.562181] brd: module loaded
[ 1.567839] loop: module loaded
[ 1.567945] tegra_profiler: version: 1.143, samples/io: 48/28
[ 1.568103] tegra_profiler: auth: init
[ 1.568802] THERMAL EST: found 3 subdevs
[ 1.568816] THERMAL EST num_resources: 0
[ 1.568832] [THERMAL EST subdev 0]
[ 1.568842] [THERMAL EST subdev 1]
[ 1.568851] [THERMAL EST subdev 2]
[ 1.568866] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.569164] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.569173] THERMAL EST: thz register success.
[ 1.569388] THERMAL EST: end of probe, return err: 0
[ 1.570305] sd: No Scsi addr parsed to reserve index
[ 1.570337] hisi_sas: driver version v1.6
[ 1.581269] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.581311] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.581321] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.581670] 1 ofpart partitions found on MTD device spi6.0
[ 1.581684] Creating 1 MTD partitions on “spi6.0”:
[ 1.581722] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.583051] Console: switching to colour frame buffer device 240x67
[ 1.583171] tegradc 15200000.nvdisplay: fb registered
[ 1.583472] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.584033] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.584145] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.584242] libphy: Fixed MDIO Bus: probed
[ 1.584776] tun: Universal TUN/TAP device driver, 1.6
[ 1.584785] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.585887] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.585897] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.585951] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.585959] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.586008] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.586016] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.586053] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.586060] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.589114] Parent Clock set for DC plld2
[ 1.644629] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.645313] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.645351] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.671033] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.671039] Extcon AUX1(HDMI) enable
[ 1.671457] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.671487] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.671564] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.671637] tegradc 15210000.nvdisplay: Display dc.ffffff800d150000 registered with id=1
[ 1.671821] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.671852] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.680088] tegradc 15210000.nvdisplay: probed
[ 1.680406] tegradc 15210000.nvdisplay: fb registered
[ 1.683742] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.683752] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.683764] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.683780] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.683794] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.683800] Extcon DP: HPD disabled
[ 1.683805] hpd: hpd_switch 0
[ 1.683810] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.683821] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.683829] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.804908] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.832911] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.833482] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3d 77 87
[ 1.833585] libphy: dwc_phy: probed
[ 1.835913] PPP generic driver version 2.4.2
[ 1.836389] PPP BSD Compression module registered
[ 1.836394] PPP Deflate Compression module registered
[ 1.836409] PPP MPPE Compression module registered
[ 1.836413] NET: Registered protocol family 24
[ 1.836466] usbcore: registered new interface driver r8152
[ 1.836500] usbcore: registered new interface driver asix
[ 1.836557] usbcore: registered new interface driver ax88179_178a
[ 1.836579] usbcore: registered new interface driver cdc_ether
[ 1.836602] usbcore: registered new interface driver net1080
[ 1.836645] usbcore: registered new interface driver cdc_subset
[ 1.836670] usbcore: registered new interface driver zaurus
[ 1.836705] usbcore: registered new interface driver cdc_ncm
[ 1.837183] VFIO - User Level meta-driver version: 0.3
[ 1.838418] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.838436] ehci-pci: EHCI PCI platform driver
[ 1.838467] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.838476] ohci-pci: OHCI PCI platform driver
[ 1.838501] ohci-platform: OHCI generic platform driver
[ 1.843811] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.845021] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.845024] Extcon AUX1(HDMI) disable
[ 1.845828] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4e3a000 id
[ 1.846095] usbcore: registered new interface driver uas
[ 1.846137] usbcore: registered new interface driver usb-storage
[ 1.846566] usbcore: registered new interface driver usbserial
[ 1.848614] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.848666] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.848682] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.849379] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.849418] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 1.849644] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.849650] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.849654] usb usb1: Product: xHCI Host Controller
[ 1.849658] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.849662] usb usb1: SerialNumber: 3610000.xhci
[ 1.850160] hub 1-0:1.0: USB hub found
[ 1.850255] hub 1-0:1.0: 4 ports detected
[ 1.850718] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.850728] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.850736] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.851041] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.851046] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.851050] usb usb2: Product: xHCI Host Controller
[ 1.851054] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.851058] usb usb2: SerialNumber: 3610000.xhci
[ 1.852126] hub 2-0:1.0: USB hub found
[ 1.852171] hub 2-0:1.0: 4 ports detected
[ 1.852634] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.852743] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.853064] Wake76 for irq=199
[ 1.853067] Wake77 for irq=199
[ 1.853070] Wake78 for irq=199
[ 1.853072] Wake79 for irq=199
[ 1.853074] Wake80 for irq=199
[ 1.853076] Wake81 for irq=199
[ 1.853078] Wake82 for irq=199
[ 1.853113] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 1.853119] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 1.853602] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.853610] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.853947] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.854238] mousedev: PS/2 mouse device common for all mice
[ 1.854314] usbcore: registered new interface driver xpad
[ 1.854503] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.870964] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.872094] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.892629] tegradc 15200000.nvdisplay: unblank
[ 1.894225] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.894465] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.905160] Parent Clock set for DC plld2
[ 1.909873] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.911330] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.946074] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.946078] Extcon AUX1(HDMI) enable
[ 1.954262] usb usb2: usb_suspend_both: status 0
[ 1.961558] tegradc 15200000.nvdisplay: sync windows ret = 247
[ 1.971264] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.972772] Wake73 for irq=42
[ 1.974047] rtc rtc1: alarm rtc device
[ 1.974061] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.974094] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.974253] i2c /dev entries driver
[ 1.976356] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.976709] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.976714] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.977148] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.987778] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 1.987784] Extcon HDMI: HPD enabled
[ 1.987808] tegradc 15200000.nvdisplay: hdmi: plugged
[ 2.000648] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.000705] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.001445] imx219 9-0010: board setup failed
[ 2.001664] imx219: probe of 9-0010 failed with error -121
[ 2.002192] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.027946] max77620-power max20024-power: Event recorder REG_NVERC : 0x4
[ 2.034770] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 2.035161] FAN dev name: pwm-fan
[ 2.035209] FAN:gpio request success.
[ 2.035219] FAN: can’t find tach_gpio
[ 2.035229] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 2.035261] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 2.035482] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.035489] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.036116] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.036125] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 2.036131] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 2.036138] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 2.036143] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.036149] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.036154] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.036160] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.036167] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.036173] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.036885] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.037904] device-mapper: uevent: version 1.0.3
[ 2.038358] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.042169] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 2.043419] cpuidle: Initializing cpuidle driver
[ 2.044217] sdhci: Secure Digital Host Controller Interface driver
[ 2.044221] sdhci: Copyright(c) Pierre Ossman
[ 2.044224] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.044480] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.045290] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.047276] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 246
[ 2.051726] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.052932] tegra-se-nvhost 15810000.se: initialized
[ 2.053993] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.054615] tegra-se-nvhost 15820000.se: initialized
[ 2.055823] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.056530] tegra-se-nvhost 15830000.se: initialized
[ 2.057198] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.058324] tegra-se-nvhost 15840000.se: initialized
[ 2.059206] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.059451] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.060612] usbcore: registered new interface driver usbhid
[ 2.060616] usbhid: USB HID core driver
[ 2.064514] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.065562] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.066041] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.066632] denver_knobs_init:MTS_VERSION:53250041
[ 2.066784] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 2.067637] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.067987] t19x_cache tegra-cache: probed
[ 2.071262] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.071270] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.071711] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.072083] PLL_AON clock registered
[ 2.073630] Clocks initialized successfully
[ 2.075387] nvpmodel: initialized successfully
[ 2.076442] trusty-virtio trusty:virtio: initializing
[ 2.076673] trusty_ipc virtio0: vring0: va¶ ffffffc1e26f0000(0) qsz 32 notifyid 1
[ 2.076683] trusty_ipc virtio0: vring1: va¶ ffffffc1e26f2000(0) qsz 32 notifyid 2
[ 2.076857] trusty-virtio trusty:virtio: initializing done
[ 2.077072] trusty_ipc virtio0: is online
[ 2.077575] usbcore: registered new interface driver snd-usb-audio
[ 2.078163] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.093927] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 2.093995] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.107928] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.108175] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.108488] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.108691] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.181760] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.205673] OPE platform probe
[ 2.205891] OPE platform probe successful
[ 2.222513] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.222520] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.222525] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.222529] usb 1-2: Manufacturer: Generic
[ 2.223849] hub 1-2:1.0: USB hub found
[ 2.224918] hub 1-2:1.0: 4 ports detected
[ 2.255242] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.285985] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 2.286100] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 2.286210] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 2.286316] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 2.286436] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 2.286571] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 2.286691] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 2.286788] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 2.286885] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 2.286985] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 2.287082] tegra-asoc: sound: ADMAIF11 ↔ ADMAIF11 mapping ok
[ 2.287187] tegra-asoc: sound: ADMAIF12 ↔ ADMAIF12 mapping ok
[ 2.287340] tegra-asoc: sound: ADMAIF13 ↔ ADMAIF13 mapping ok
[ 2.287448] tegra-asoc: sound: ADMAIF14 ↔ ADMAIF14 mapping ok
[ 2.287601] tegra-asoc: sound: ADMAIF15 ↔ ADMAIF15 mapping ok
[ 2.287726] tegra-asoc: sound: ADMAIF16 ↔ ADMAIF16 mapping ok
[ 2.287835] tegra-asoc: sound: ADMAIF17 ↔ ADMAIF17 mapping ok
[ 2.287939] tegra-asoc: sound: ADMAIF18 ↔ ADMAIF18 mapping ok
[ 2.288037] tegra-asoc: sound: ADMAIF19 ↔ ADMAIF19 mapping ok
[ 2.288136] tegra-asoc: sound: ADMAIF20 ↔ ADMAIF20 mapping ok
[ 2.316514] u32 classifier
[ 2.316520] Actions configured
[ 2.316623] Initializing XFRM netlink socket
[ 2.317312] NET: Registered protocol family 10
[ 2.318209] NET: Registered protocol family 17
[ 2.318222] NET: Registered protocol family 15
[ 2.318291] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.318357] Bluetooth: RFCOMM socket layer initialized
[ 2.318373] Bluetooth: RFCOMM ver 1.11
[ 2.318381] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.318387] Bluetooth: HIDP socket layer initialized
[ 2.318405] 9pnet: Installing 9P2000 support
[ 2.318441] Key type dns_resolver registered
[ 2.319512] Registered cp15_barrier emulation handler
[ 2.319533] Registered setend emulation handler
[ 2.321233] registered taskstats version 1
[ 2.321704] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.322835] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.322855] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.322866] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.322872] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 2.330561] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 2.367586] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 2.367593] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.367597] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 2.367601] usb 2-3: Manufacturer: Generic
[ 2.377655] hub 2-3:1.0: USB hub found
[ 2.379490] hub 2-3:1.0: 4 ports detected
[ 2.396476] mmc0: hw tuning done …
[ 2.396507] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 2.396960] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 2.402956] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.433761] tegra-pcie-dw 14160000.pcie: link is up
[ 2.433972] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.433980] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.433989] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.433996] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.434001] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.434042] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.434213] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.434435] iommu: Adding device 0004:00:00.0 to group 58
[ 2.434752] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 2.434867] pci 0004:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 2.434872] pci 0004:01:00.0: reg 0x10: [io size 0x0100]
[ 2.435029] pci 0004:01:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit]
[ 2.435758] pci 0004:01:00.0: supports D1 D2
[ 2.435762] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.436087] iommu: Adding device 0004:01:00.0 to group 59
[ 2.447240] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 2.447246] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.447255] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 2.447336] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.447363] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.447368] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.447376] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 2.447395] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.447457] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.447651] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.447655] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.447661] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.447742] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.448515] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.449693] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.449711] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 2.449747] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 2.449752] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 2.553761] tegra_cec 3960000.tegra_cec: physical address: 20:00.
[ 2.557759] tegra-pcie-dw 141a0000.pcie: link is up
[ 2.557969] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.557977] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.557985] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.557991] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.557996] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.558019] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.558138] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.558336] iommu: Adding device 0005:00:00.0 to group 60
[ 2.558700] pci 0005:01:00.0: [144d:a808] type 00 class 0x010802
[ 2.558829] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 2.559780] iommu: Adding device 0005:01:00.0 to group 61
[ 2.571109] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 2.571119] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 2.571177] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.571184] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 2.571200] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.571242] pci 0005:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 2.571552] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.571557] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.571564] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.571642] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.572037] nvme nvme0: pci function 0005:01:00.0
[ 2.572074] nvme 0005:01:00.0: enabling device (0000 → 0002)
[ 2.582255] tegra-cbb 14040000.cv-noc: noc_secure_irq = 90, noc_nonsecure_irq = 89>
[ 2.586976] tegra194-isp5 14800000.isp: initialized
[ 2.593363] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 2.596247] tegra194-vi5 15c10000.vi: initialized
[ 2.597759] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.600481] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 2.600604] tegra194-vi5 15c10000.vi: subdev imx219 10-0010 bound
[ 2.600614] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 2.602040] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 2.606303] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 2.606318] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 2.606323] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 2.606389] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 2.606429] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 2.606433] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 2.610489] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 2.610525] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 2.610530] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 2.610925] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 2.610961] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 2.610965] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 2.611537] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 2.611577] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 2.611581] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 2.611864] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 2.612651] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 2.618287] tegra_cec 3960000.tegra_cec: Sent res: 0.
[ 2.618840] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 2.618846] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.618851] usb 1-3: Product: Bluetooth Radio
[ 2.618854] usb 1-3: Manufacturer: Realtek
[ 2.618858] usb 1-3: SerialNumber: 00e04c000001
[ 2.690692] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 2.691083] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.691279] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 2.691430] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 2.691823] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 2.691893] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 2.692111] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 2.692116] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.693093] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=06bdc710c3c9a48de2881774602bbcf4d0114a58
[ 2.693539] Wake83 for irq=211
[ 2.693604] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 2.693698] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 2.693868] input: gpio-keys as /devices/gpio-keys/input/input4
[ 2.726809] tegra_rtc c2a0000.rtc: setting system clock to 2021-08-26 07:55:03 UTC (1629964503)
[ 2.727259] mmcblk mmc0:aaaa: Card claimed for testing.
[ 2.735606] tegra_cec 3960000.tegra_cec: Broadcast res: 0.
[ 2.735612] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.765283] bpmp: mounted debugfs mirror
[ 2.771223] ALSA device list:
[ 2.771228] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 2.771232] #1: jetson-xaviernx-ape
[ 2.773518] Freeing unused kernel memory: 8576K
[ 2.810797] Root device found: mmcblk0p1
[ 2.812678] Found dev node: /dev/mmcblk0p1
[ 2.853643] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.856365] Rootfs mounted over mmcblk0p1
[ 2.881865] Switching from initrd to actual rootfs
[ 2.937810] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 2.961961] usb 1-2.3: New USB device found, idVendor=24ae, idProduct=2013
[ 2.961967] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.961972] usb 1-2.3: Product: Rapoo 2.4G Wireless Device
[ 2.961975] usb 1-2.3: Manufacturer: RAPOO
[ 2.964495] input: RAPOO Rapoo 2.4G Wireless Device as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:24AE:2013.0001/input/input5
[ 2.964863] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-3610000.xhci-2.3/input0
[ 2.966819] input: RAPOO Rapoo 2.4G Wireless Device as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:24AE:2013.0002/input/input6
[ 2.969776] usb 2-3: usb_suspend_both: status 0
[ 2.969988] usb usb2: usb_suspend_both: status 0
[ 3.026062] hid-generic 0003:24AE:2013.0002: input,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-3610000.xhci-2.3/input1
[ 3.027624] input: RAPOO Rapoo 2.4G Wireless Device as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.2/0003:24AE:2013.0003/input/input7
[ 3.086274] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-3610000.xhci-2.3/input2
[ 3.113088] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.117357] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.136905] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.137538] systemd[1]: Detected architecture arm64.
[ 3.146290] systemd[1]: Set hostname to .
[ 3.279728] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.279741] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.456532] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.456585] systemd[1]: Reached target User and Group Name Lookups.
[ 3.456937] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.457310] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.457398] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.460158] systemd[1]: Created slice User and Session Slice.
[ 3.461295] systemd[1]: Created slice System Slice.
[ 3.461796] systemd[1]: Listening on Journal Socket.
[ 3.561216] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.617656] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 3.630414] cpu-throttle-alert cooling device registered.
[ 3.630821] gpu-throttle-alert cooling device registered.
[ 3.631075] aux-throttle-alert cooling device registered.
[ 3.639339] EXT4-fs (nvme0n1): mounted filesystem with ordered data mode. Opts: errors=remount-ro,discard
[ 3.779534] systemd-journald[2380]: Received SIGTERM from PID 1 (systemd).
[ 3.814845] systemd: 38 output lines suppressed due to ratelimiting
[ 3.894819] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.895360] systemd[1]: Detected architecture arm64.
[ 3.896571] systemd[1]: Set hostname to .
[ 3.928274] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 3.928279] Extcon AUX1(HDMI) disable
[ 3.954731] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 3.955460] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 3.955612] tegradc 15200000.nvdisplay: blank - powerdown
[ 3.955800] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 3.955804] Extcon HDMI: HPD disabled
[ 3.955820] tegradc 15200000.nvdisplay: hdmi: unplugged
[ 3.985480] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.985882] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.118164] systemd[1]: Started Journal Service.
[ 4.125981] systemd[1]: systemd-udevd.service: Failed with result ‘protocol’.
[ 4.127825] systemd[1]: systemd-udev-trigger.service: Main process exited, code=killed, status=15/TERM
[ 4.128240] systemd[1]: systemd-udev-trigger.service: Failed with result ‘signal’.
[ 4.130061] systemd[1]: sys-kernel-config.mount: Mount process finished, but there is no mount.
[ 4.540281] systemd-journald[3181]: Received request to flush runtime journal from PID 1
[ 4.852195] Adding 8388604k swap on /swapfile. Priority:-1 extents:17 across:16572412k SS
[ 5.220717] tegradc 15200000.nvdisplay: blank - powerdown
[ 5.227314] tegradc 15200000.nvdisplay: unblank
[ 5.227339] tegradc 15200000.nvdisplay: update windows ret = -14
[ 5.227343] tegradc 15200000.nvdisplay: sync windows ret = -14
[ 5.234488] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 5.234492] Extcon HDMI: HPD enabled
[ 5.234522] tegradc 15200000.nvdisplay: hdmi: plugged
[ 5.305848] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 5.305855] Extcon HDMI: HPD disabled
[ 5.305883] tegradc 15200000.nvdisplay: hdmi: unplugged
[ 5.391774] random: crng init done
[ 5.391941] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.776177] using random self ethernet address
[ 5.779039] using random host ethernet address
[ 6.301834] Mass Storage Function, version: 2009/09/11
[ 6.301838] LUN: removable file: (no medium)
[ 6.309148] using random self ethernet address
[ 6.309151] using random host ethernet address
[ 6.332575] rndis0: HOST MAC 22:f3:63:02:ee:dc
[ 6.332824] rndis0: MAC 22:f3:63:02:ee:dd
[ 6.334776] usb0: HOST MAC 22:f3:63:02:ee:de
[ 6.334958] usb0: MAC 22:f3:63:02:ee:df
[ 6.334982] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 6.335787] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 6.335808] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.335845] tegra-xudc-new 3550000.xudc: entering ELPG
[ 6.336129] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.336143] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 6.336672] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 6.336680] tegra-xudc-new 3550000.xudc: entering ELPG
[ 6.336879] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.343928] l4tbr0: port 1(rndis0) entered blocking state
[ 6.343932] l4tbr0: port 1(rndis0) entered disabled state
[ 6.345625] device rndis0 entered promiscuous mode
[ 6.352698] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.358960] l4tbr0: port 2(usb0) entered blocking state
[ 6.358964] l4tbr0: port 2(usb0) entered disabled state
[ 6.359600] device usb0 entered promiscuous mode
[ 6.365807] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.536884] tegradc 15200000.nvdisplay: blank - powerdown
[ 6.550100] tegradc 15200000.nvdisplay: unblank
[ 6.552282] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 6.552397] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 6.556702] Parent Clock set for DC plld2
[ 6.561028] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 6.562388] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 6.596804] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 6.596807] Extcon AUX1(HDMI) enable
[ 6.612617] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 6.643782] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 6.643786] Extcon HDMI: HPD enabled
[ 6.643813] tegradc 15200000.nvdisplay: hdmi: plugged
[ 6.771332] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.817174] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 7.098650] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 7.105909] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.498661] tegradc 15200000.nvdisplay: unblank
[ 8.498676] tegradc 15210000.nvdisplay: blank - powerdown
[ 10.056505] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 10.057690] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.549402] tegradc 15200000.nvdisplay: unblank
[ 14.549417] tegradc 15210000.nvdisplay: blank - powerdown
[ 17.298756] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 34.137899] vdd-1v8-sd: disabling
[ 34.137939] vdd-1v8-cvb: disabling
[ 34.137943] vdd-epb-1v0: disabling
[ 34.137948] avdd-cam-2v8: disabling
[ 34.137952] vdd-fan: disabling
[ 34.137957] vdd_sys_en: disabling
