Here are two commands I tried to execute
sudo ./flash.sh -r jetson-agx-xavier-devkit mmcblk0p1
sudo ./flash.sh -r jetson-xavier mmcblk0p1
Here is the storage of my machine
Which jetpack release is in use here?
jp4.6.1
Could you share what did you see under /dev/disk/by-partlabel?
I just checked 2 of my jetson AGX devices with rel-32.7.1 and none of them has such issue.
Could you share me the dmesg as a text file and attach it here?
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (root@sunxuehu-Latitude-5421) #1 SMP PREEMPT Wed Apr 20 11:28:29 CST 2022 tztek_version: [product:geac91s, hardware:510g-3.4, jetpack:jp4.6.1, soft:v3.1, type:release]
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06ab000
[ 0.000000] Found lut_mem: 00002008@a06a6000
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 8322557
[ 0.000000] DMA zone: 7160 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 458237 pages, LIFO batch:31
[ 0.000000] Normal zone: 122880 pages used for memmap
[ 0.000000] Normal zone: 7864320 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8192517
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06ab000 lut_mem=0x2008@0xa06a6000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29772(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Memory: 31899520K/33290228K available (16254K kernel code, 2948K rwdata, 7028K rodata, 8768K init, 639K bss, 637044K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8009060000 ( 16256 KB)
[ 0.000000] .rodata : 0xffffff8009060000 - 0xffffff8009750000 ( 7104 KB)
[ 0.000000] .init : 0xffffff8009750000 - 0xffffff8009fe0000 ( 8768 KB)
[ 0.000000] .data : 0xffffff8009fe0000 - 0xffffff800a2c1008 ( 2949 KB)
[ 0.000000] .bss : 0xffffff800a2c1008 - 0xffffff800a360dd4 ( 640 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf20000000 ( 512 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc800000000 ( 32768 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000856] Console: colour dummy device 80x25
[ 0.000869] console [tty0] enabled
[ 0.000876] bootconsole [tegra_comb_uart0] disabled
[ 0.000891] kmemleak: Kernel memory leak detector disabled
[ 0.000909] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000924] pid_max: default: 32768 minimum: 301
[ 0.001992] Security Framework initialized
[ 0.002568] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.002580] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.004634] ftrace: allocating 50453 entries in 198 pages
[ 0.435830] sched-energy: Sched-energy-costs installed from DT
[ 0.435851] ASID allocator initialised with 65536 entries
[ 0.474747] tegra-id: chipid=21917.
[ 0.474759] tegra-id: opt_subrevision=1.
[ 0.474785] Tegra Revision: A02p SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.474815] DTS File Name: /home/sunxuehu/work/510g_4.6.1/code/source/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.474824] DTB Build time: Apr 20 2022 11:22:52
[ 0.476088] DTB Build version: geac91s_510g-3.4_jp4.6.1_v3.1_release
[ 0.524108] CPU1: Booted secondary processor [4e0f0040]
[ 0.556279] CPU2: Booted secondary processor [4e0f0040]
[ 0.588448] CPU3: Booted secondary processor [4e0f0040]
[ 0.620609] CPU4: Booted secondary processor [4e0f0040]
[ 0.652560] CPU5: Booted secondary processor [4e0f0040]
[ 0.685039] CPU6: Booted secondary processor [4e0f0040]
[ 0.716954] CPU7: Booted secondary processor [4e0f0040]
[ 0.717169] Brought up 8 CPUs
[ 0.717178] SMP: Total of 8 processors activated.
[ 0.717187] CPU features: detected feature: Privileged Access Never
[ 0.717192] CPU features: detected feature: LSE atomic instructions
[ 0.717198] CPU features: detected feature: User Access Override
[ 0.717204] CPU features: detected feature: 32-bit EL0 Support
[ 0.718993] CPU: All CPU(s) started at EL2
[ 0.719066] alternatives: patching kernel code
[ 0.728436] devtmpfs: initialized
[ 0.791628] Initilizing CustomIPI irq domain
[ 0.791863] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.791876] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.802718] pinctrl core: initialized pinctrl subsystem
[ 0.802948] OS set in device tree is not L4T.
[ 0.803282] regulator-dummy: no parameters
[ 0.803568] Initializing plugin-manager
[ 0.803652] Plugin module not found
[ 0.803719] Plugin-manager not available
[ 0.805547] NET: Registered protocol family 16
[ 0.807335] pstore: using zlib compression
[ 0.807359] console [pstore-1] enabled
[ 0.807368] pstore: Registered ramoops as persistent store backend
[ 0.807377] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.825189] cpuidle: using governor menu
[ 0.827432] bpmp: waiting for handshake
[ 0.827471] bpmp: handshake completed
[ 0.827491] bpmp: synchronizing channels
[ 0.827503] bpmp: channels synchronized
[ 0.827516] bpmp: mail init ok
[ 0.831914] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.832161] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.832167] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.832174] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.832179] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.832185] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.832194] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.832202] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.832208] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.832218] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.832250] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.836808] vdso: 2 pages (1 code @ ffffff8009067000, 1 data @ ffffff8009fe4000)
[ 0.836841] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.839628] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.841778] tegra_aon_clk_init: ok
[ 0.841793] Registering BPMP clocks...
[ 0.841910] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.842678] Serial: AMBA PL011 UART driver
[ 0.842786] tegra_powergate_init: DONE
[ 0.843946] DTS File Name: /home/sunxuehu/work/510g_4.6.1/code/source/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.843961] DTB Build time: Apr 20 2022 11:22:52
[ 0.847591] Tegra reboot handler registered.
[ 0.855966] tegra194-pinctrl 2430000.pinmux: function 'shutdown' not supported
[ 0.856002] tegra194-pinctrl 2430000.pinmux: invalid function shutdown in map table
[ 0.856034] tegra194-pinctrl 2430000.pinmux: Failed to add default setting: -22
[ 0.864905] iommu: Adding device 14180000.pcie to group 0
[ 0.865717] iommu: Adding device 14100000.pcie to group 1
[ 0.866578] iommu: Adding device 14140000.pcie to group 2
[ 0.867444] iommu: Adding device 14160000.pcie to group 3
[ 0.868222] iommu: Adding device 141a0000.pcie to group 4
[ 0.869994] iommu: Adding device 2490000.ether_qos to group 5
[ 0.870604] iommu: Adding device 3100000.serial to group 6
[ 0.871336] iommu: Adding device 3110000.serial to group 7
[ 0.871903] iommu: Adding device 3140000.serial to group 8
[ 0.872621] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.873071] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.873091] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.873096] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.873101] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.873155] tegra-pmc: PMC Prod config success
[ 0.873423] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.873436] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.873881] iommu: Adding device 3460000.sdhci to group 9
[ 0.874499] iommu: Adding device 3400000.sdhci to group 10
[ 0.875103] iommu: Adding device 3210000.spi to group 11
[ 0.875572] iommu: Adding device c260000.spi to group 12
[ 0.876034] iommu: Adding device 3230000.spi to group 13
[ 0.877130] iommu: Adding device 3160000.i2c to group 14
[ 0.877671] iommu: Adding device c240000.i2c to group 15
[ 0.878117] iommu: Adding device 3180000.i2c to group 16
[ 0.878583] iommu: Adding device 3190000.i2c to group 17
[ 0.879266] iommu: Adding device 31b0000.i2c to group 18
[ 0.879740] iommu: Adding device 31c0000.i2c to group 19
[ 0.880174] iommu: Adding device c250000.i2c to group 20
[ 0.880665] iommu: Adding device 31e0000.i2c to group 21
[ 0.881545] iommu: Adding device sound to group 22
[ 0.882240] iommu: Adding device 3510000.hda to group 23
[ 0.882835] iommu: Adding device bc00000.rtcpu to group 24
[ 0.885502] iommu: Adding device 13e10000.host1x to group 25
[ 0.886127] iommu: Adding device 13e10000.host1x:ctx0 to group 26
[ 0.886545] iommu: Adding device 13e10000.host1x:ctx1 to group 27
[ 0.887012] iommu: Adding device 13e10000.host1x:ctx2 to group 28
[ 0.887521] iommu: Adding device 13e10000.host1x:ctx3 to group 29
[ 0.887933] iommu: Adding device 13e10000.host1x:ctx4 to group 30
[ 0.888382] iommu: Adding device 13e10000.host1x:ctx5 to group 31
[ 0.888861] iommu: Adding device 13e10000.host1x:ctx6 to group 32
[ 0.889307] iommu: Adding device 13e10000.host1x:ctx7 to group 33
[ 0.889954] iommu: Adding device 15340000.vic to group 34
[ 0.890433] iommu: Adding device 15380000.nvjpg to group 35
[ 0.890730] iommu: Adding device 15500000.tsec to group 36
[ 0.891029] iommu: Adding device 15100000.tsecb to group 37
[ 0.891336] iommu: Adding device 15480000.nvdec to group 38
[ 0.891677] iommu: Adding device 15140000.nvdec1 to group 39
[ 0.891976] iommu: Adding device 154c0000.nvenc to group 40
[ 0.892317] iommu: Adding device 15a80000.nvenc1 to group 41
[ 0.892811] iommu: Adding device 15880000.nvdla0 to group 42
[ 0.893257] iommu: Adding device 158c0000.nvdla1 to group 43
[ 0.893927] iommu: Adding device 15200000.nvdisplay to group 44
[ 0.894127] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06ab000(800000)
[ 0.894139] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a6000(3000)
[ 0.898040] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.898108] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.899294] iommu: Adding device 15c10000.vi to group 45
[ 0.899557] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.900054] iommu: Adding device 14800000.isp to group 46
[ 0.901098] iommu: Adding device 16000000.pva0 to group 47
[ 0.901723] iommu: Adding device 16800000.pva1 to group 48
[ 0.902189] iommu: Adding device 15810000.se to group 49
[ 0.902680] iommu: Adding device 15820000.se to group 50
[ 0.903015] iommu: Adding device 15830000.se to group 51
[ 0.903306] iommu: Adding device 15840000.se to group 52
[ 0.903589] iommu: Adding device c1a0000.aon to group 53
[ 0.905703] iommu: Adding device d000000.bpmp to group 54
[ 0.906103] bpmp: ping status is 0
[ 0.906233] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.909415] bpmp d000000.bpmp: probe ok
[ 0.911290] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.911833] iommu: Adding device smmu_test to group 55
[ 0.913116] mc: mapped MMIO address: 0xffffff800a740000 -> 0x2c10000
[ 0.913137] mc: mapped MMIO address: 0xffffff800a760000 -> 0x2c20000
[ 0.913155] mc: mapped MMIO address: 0xffffff800a780000 -> 0x2c30000
[ 0.913174] mc: mapped MMIO address: 0xffffff800a7a0000 -> 0x2c40000
[ 0.913192] mc: mapped MMIO address: 0xffffff800a7c0000 -> 0x2c50000
[ 0.913208] mc: mapped MMIO address: 0xffffff800a7e0000 -> 0x2b80000
[ 0.913224] mc: mapped MMIO address: 0xffffff800a9b0000 -> 0x2b90000
[ 0.913239] mc: mapped MMIO address: 0xffffff800a9d0000 -> 0x2ba0000
[ 0.913255] mc: mapped MMIO address: 0xffffff800a9f0000 -> 0x2bb0000
[ 0.913274] mc: mapped MMIO address: 0xffffff800aa10000 -> 0x1700000
[ 0.913312] mc: mapped MMIO address: 0xffffff800aa30000 -> 0x1710000
[ 0.913328] mc: mapped MMIO address: 0xffffff800aa50000 -> 0x1720000
[ 0.913346] mc: mapped MMIO address: 0xffffff800aa70000 -> 0x1730000
[ 0.913362] mc: mapped MMIO address: 0xffffff800aa90000 -> 0x1740000
[ 0.913399] mc: mapped MMIO address: 0xffffff800aab0000 -> 0x1750000
[ 0.913417] mc: mapped MMIO address: 0xffffff800aad0000 -> 0x1760000
[ 0.913432] mc: mapped MMIO address: 0xffffff800aaf0000 -> 0x1770000
[ 0.913520] mc-err: mcerr ops are set to t19x
[ 0.920793] iommu: Adding device 2600000.dma to group 56
[ 0.927004] gpio gpiochip0: gpio-line-names specifies 210 line names but there are 224 lines on the chip
[ 0.928051] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.928360] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.935940] gpio gpiochip1: gpio-line-names specifies 30 line names but there are 40 lines on the chip
[ 0.936267] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.938443] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.938455] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.938466] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.939412] iommu: Adding device 3550000.xudc to group 57
[ 0.940242] iommu: Adding device 3610000.xhci to group 58
[ 0.943029] arm64_ras arm64_ras: probed
[ 0.943502] ras_fhi_enable: FHI 474 enabled on CPU0
[ 0.943554] ras_fhi_enable: FHI 475 enabled on CPU1
[ 0.943638] ras_fhi_enable: FHI 476 enabled on CPU2
[ 0.943687] ras_fhi_enable: FHI 477 enabled on CPU3
[ 0.943735] ras_fhi_enable: FHI 478 enabled on CPU4
[ 0.943790] ras_fhi_enable: FHI 479 enabled on CPU5
[ 0.943893] ras_fhi_enable: FHI 480 enabled on CPU6
[ 0.943943] ras_fhi_enable: FHI 481 enabled on CPU7
[ 0.944145] carmel_ras_enable: RAS enabled on cpu0
[ 0.944362] carmel_ras_enable: RAS enabled on cpu1
[ 0.944584] carmel_ras_enable: RAS enabled on cpu2
[ 0.944778] carmel_ras_enable: RAS enabled on cpu3
[ 0.944952] carmel_ras_enable: RAS enabled on cpu4
[ 0.945163] carmel_ras_enable: RAS enabled on cpu5
[ 0.945371] carmel_ras_enable: RAS enabled on cpu6
[ 0.945604] carmel_ras_enable: RAS enabled on cpu7
[ 0.945693] carmel_ras carmel_ras: probed
[ 0.947383] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.948021] tegra-cbb c600000.aon-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.949170] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[ 0.950203] tegra-cbb be00000.rce-noc: noc_secure_irq = 489, noc_nonsecure_irq = 488>
[ 0.951295] tegra-cbb b600000.sce-noc: noc_secure_irq = 491, noc_nonsecure_irq = 490>
[ 0.951777] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.955441] vdd-3v3-cvb: 3300 mV
[ 0.955844] vdd-1v8-cvb: 1800 mV
[ 0.956252] vdd-1v8-sd: 1800 mV
[ 0.956605] vdd-epb-1v0: 1000 mV
[ 0.956798] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.957107] vdd-sdmmc1-sw: 3300 mV
[ 0.957519] avdd-cam-2v8: 2800 mV
[ 0.957822] vdd-sata-1v5: 1500 mV
[ 0.958111] vdd-1v8-slt: 1800 mV
[ 0.958420] vdd-3v3-slt: 3300 mV
[ 0.958732] vdd-fan: 5000 mV
[ 0.959096] vdd-hdmi-5v0: 5000 mV
[ 0.959468] vdd_sys_en: 1200 mV
[ 0.959776] vdd-5v-sata: 5000 mV
[ 0.960210] vdd-3v3-pcie: 3300 mV
[ 0.960593] vdd-12v-pcie: 1200 mV
[ 0.960980] vdd-ac-bat: 5000 mV
[ 0.961180] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.002228] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.004674] tz_gpio_class_init
[ 1.004702] tz_gpio_class_init: init is successful
[ 1.007523] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.007843] SCSI subsystem initialized
[ 1.008038] libata version 3.00 loaded.
[ 1.008222] usbcore: registered new interface driver usbfs
[ 1.008294] usbcore: registered new interface driver hub
[ 1.008336] usbcore: registered new device driver usb
[ 1.012034] gpiochip_setup_dev: registered GPIOs 232 to 247 on device: gpiochip2 (tca9539)
[ 1.022842] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.025718] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.033851] vdd-1v0: at 1000 mV
[ 1.041853] vdd-1v8-hs: at 1800 mV
[ 1.049859] vdd-1v8-ls: at 1800 mV
[ 1.057923] vdd-1v8-ao: at 1800 mV
[ 1.065917] vddio-ddr-1v1: at 1100 mV
[ 1.073696] vdd-rtc: at 800 mV
[ 1.074688] spmic-ldo1: at 2375 mV
[ 1.085735] vdd-ao-3v3: at 3300 mV
[ 1.093762] vddio-emmc-3v3: at 3300 mV
[ 1.094899] spmic-ldo4: at 1587 mV
[ 1.105805] vdd-usb-3v3: at 3300 mV
[ 1.113832] vddio-sdmmc1-3v3: at 3300 mV
[ 1.117856] vdd-csi-1v2: at 1200 mV
[ 1.119018] spmic-ldo8: at 1800 mV
[ 1.123344] GPIO line 230 (gpio_default) hogged as output/high
[ 1.124281] GPIO line 231 (gpio_default) hogged as output/high
[ 1.124549] gpiochip_setup_dev: registered GPIOs 224 to 231 on device: gpiochip3 (max77620-gpio)
[ 1.124810] max77620 4-003c: max77620 probe successful
[ 1.125499] media: Linux media interface: v0.10
[ 1.125531] Linux video capture interface: v2.00
[ 1.127127] pps_core: LinuxPPS API ver. 1 registered
[ 1.127133] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.127197] PTP clock support registered
[ 1.130647] trusty trusty: trusty version: Built: 08:57:16 Feb 19 2022
[ 1.130708] trusty trusty: selected api version: 3 (requested 3)
[ 1.132134] Advanced Linux Sound Architecture Driver Initialized.
[ 1.132925] Bluetooth: Core ver 2.22
[ 1.132962] NET: Registered protocol family 31
[ 1.132968] Bluetooth: HCI device and connection manager initialized
[ 1.132977] Bluetooth: HCI socket layer initialized
[ 1.132985] Bluetooth: L2CAP socket layer initialized
[ 1.133009] Bluetooth: SCO socket layer initialized
[ 1.133642] tztek_info: tz_gpio_general_probe
[ 1.133650] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is m2-ewake
[ 1.133656] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.133689] tztek_info: tz_gpio_general_pin_init: m2-ewake
[ 1.133696] tztek_info: tz_gpio_general_pin_init : m2-ewake default mode is output
[ 1.134360] tztek_info: tz_gpio_general_pin_init: m2-ewake successful
[ 1.134551] tztek_info: tz_gpio_general_probe: m2-ewake init is successful
[ 1.134591] tztek_info: tz_gpio_general_probe
[ 1.134599] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is 4g-5g-power
[ 1.134605] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.134661] tztek_info: tz_gpio_general_pin_init: 4g-5g-power
[ 1.134689] tztek_info: tz_gpio_general_pin_init : 4g-5g-power default mode is output
[ 1.134712] tztek_info: tz_gpio_general_pin_init: 4g-5g-power successful
[ 1.134971] tztek_info: tz_gpio_general_probe: 4g-5g-power init is successful
[ 1.135009] tztek_info: tz_gpio_general_probe
[ 1.135022] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is 4g-reset
[ 1.135028] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.135052] tztek_info: tz_gpio_general_pin_init: 4g-reset
[ 1.135058] tztek_info: tz_gpio_general_pin_init : 4g-reset default mode is output
[ 1.135702] tztek_info: tz_gpio_general_pin_init: 4g-reset successful
[ 1.135866] tztek_info: tz_gpio_general_probe: 4g-reset init is successful
[ 1.135904] tztek_info: tz_gpio_general_probe
[ 1.135912] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is ovtemp-shutd
[ 1.135919] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.135943] tztek_info: tz_gpio_general_pin_init: ovtemp-shutd
[ 1.135950] tztek_info: tz_gpio_general_pin_init : ovtemp-shutd default mode is output
[ 1.136476] tztek_info: tz_gpio_general_pin_init: ovtemp-shutd successful
[ 1.136683] tztek_info: tz_gpio_general_probe: ovtemp-shutd init is successful
[ 1.136722] tztek_info: tz_gpio_general_probe
[ 1.136730] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is u2-det
[ 1.136736] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is input
[ 1.136755] tztek_info: tz_gpio_general_pin_init: u2-det
[ 1.136761] tztek_info: tz_gpio_general_pin_init : u2-det default mode is input
[ 1.137021] tztek_info: tz_gpio_general_pin_init,input_interrupt_disable
[ 1.137027] tztek_info: tz_gpio_general_pin_init: u2-det successful
[ 1.137158] tztek_info: tz_gpio_general_probe: u2-det init is successful
[ 1.137195] tztek_info: tz_gpio_general_probe
[ 1.137203] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is line-out-sns-l
[ 1.137209] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.137227] tztek_info: tz_gpio_general_pin_init: line-out-sns-l
[ 1.137234] tztek_info: tz_gpio_general_pin_init : line-out-sns-l default mode is output
[ 1.137743] tztek_info: tz_gpio_general_pin_init: line-out-sns-l successful
[ 1.137870] tztek_info: tz_gpio_general_probe: line-out-sns-l init is successful
[ 1.137960] tztek_info: tz_gpio_general_probe
[ 1.137968] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is gpio-led
[ 1.137974] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.137993] tztek_info: tz_gpio_general_pin_init: gpio-led
[ 1.137999] tztek_info: tz_gpio_general_pin_init : gpio-led default mode is output
[ 1.138528] tztek_info: tz_gpio_general_pin_init: gpio-led successful
[ 1.138715] tztek_info: tz_gpio_general_probe: gpio-led init is successful
[ 1.138758] tztek_info: tz_gpio_general_probe
[ 1.138766] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is mic1-sns-l
[ 1.138773] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.138792] tztek_info: tz_gpio_general_pin_init: mic1-sns-l
[ 1.138801] tztek_info: tz_gpio_general_pin_init : mic1-sns-l default mode is output
[ 1.139376] tztek_info: tz_gpio_general_pin_init: mic1-sns-l successful
[ 1.139651] tztek_info: tz_gpio_general_probe: mic1-sns-l init is successful
[ 1.139749] tztek_info: tz_gpio_general_probe
[ 1.139759] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is rs485-ctrl-sw
[ 1.139766] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.139815] tztek_info: tz_gpio_general_pin_init: rs485-ctrl-sw
[ 1.139822] tztek_info: tz_gpio_general_pin_init : rs485-ctrl-sw default mode is output
[ 1.140388] tztek_info: tz_gpio_general_pin_init: rs485-ctrl-sw successful
[ 1.140569] tztek_info: tz_gpio_general_probe: rs485-ctrl-sw init is successful
[ 1.140616] tztek_info: tz_gpio_general_probe
[ 1.140627] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is usb-vdd
[ 1.140633] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.140655] tztek_info: tz_gpio_general_pin_init: usb-vdd
[ 1.140661] tztek_info: tz_gpio_general_pin_init : usb-vdd default mode is output
[ 1.141125] tztek_info: tz_gpio_general_pin_init: usb-vdd successful
[ 1.141296] tztek_info: tz_gpio_general_probe: usb-vdd init is successful
[ 1.141345] tztek_info: tz_gpio_general_probe
[ 1.141353] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is spi_can-reset
[ 1.141360] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.141380] tztek_info: tz_gpio_general_pin_init: spi_can-reset
[ 1.141387] tztek_info: tz_gpio_general_pin_init : spi_can-reset default mode is output
[ 1.141880] tztek_info: tz_gpio_general_pin_init: spi_can-reset successful
[ 1.142081] tztek_info: tz_gpio_general_probe: spi_can-reset init is successful
[ 1.142126] tztek_info: tz_gpio_general_probe
[ 1.142134] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is cpld-reset
[ 1.142141] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.142185] tztek_info: tz_gpio_general_pin_init: cpld-reset
[ 1.142216] tztek_info: tz_gpio_general_pin_init : cpld-reset default mode is output
[ 1.142269] tztek_info: tz_gpio_general_pin_init: cpld-reset successful
[ 1.142434] tztek_info: tz_gpio_general_probe: cpld-reset init is successful
[ 1.142502] tztek_info: tz_gpio_general_probe
[ 1.142510] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is 5g-reset
[ 1.142516] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.142561] tztek_info: tz_gpio_general_pin_init: 5g-reset
[ 1.142590] tztek_info: tz_gpio_general_pin_init : 5g-reset default mode is output
[ 1.142614] tztek_info: tz_gpio_general_pin_init: 5g-reset successful
[ 1.142802] tztek_info: tz_gpio_general_probe: 5g-reset init is successful
[ 1.142873] tztek_info: tz_gpio_general_probe
[ 1.142880] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is force-recovery
[ 1.142886] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is input
[ 1.142932] tztek_info: tz_gpio_general_pin_init: force-recovery
[ 1.142955] tztek_info: tz_gpio_general_pin_init : force-recovery default mode is input
[ 1.142981] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 1.143030] tztek_info: tz_gpio_general_pin_init : force-recovery request_irq_flag is 0x1
[ 1.143035] tztek_info: tz_gpio_general_pin_init: force-recovery successful
[ 1.143264] tztek_info: tz_gpio_general_probe: force-recovery init is successful
[ 1.143303] tztek_info: tz_gpio_general_probe
[ 1.143311] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is line-in-sns-l
[ 1.143317] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is input
[ 1.143360] tztek_info: tz_gpio_general_pin_init: line-in-sns-l
[ 1.143382] tztek_info: tz_gpio_general_pin_init : line-in-sns-l default mode is input
[ 1.143402] tztek_info: tz_gpio_general_pin_init,input_interrupt_disable
[ 1.143407] tztek_info: tz_gpio_general_pin_init: line-in-sns-l successful
[ 1.143556] tztek_info: tz_gpio_general_probe: line-in-sns-l init is successful
[ 1.143594] tztek_info: tz_gpio_general_probe
[ 1.143601] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is cpld-done-ls
[ 1.143607] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is input
[ 1.143647] tztek_info: tz_gpio_general_pin_init: cpld-done-ls
[ 1.143668] tztek_info: tz_gpio_general_pin_init : cpld-done-ls default mode is input
[ 1.143686] tztek_info: tz_gpio_general_pin_init,input_interrupt_disable
[ 1.143692] tztek_info: tz_gpio_general_pin_init: cpld-done-ls successful
[ 1.143827] tztek_info: tz_gpio_general_probe: cpld-done-ls init is successful
[ 1.143864] tztek_info: tz_gpio_general_probe
[ 1.143871] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is switch-uart_0
[ 1.143877] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.143915] tztek_info: tz_gpio_general_pin_init: switch-uart_0
[ 1.143936] tztek_info: tz_gpio_general_pin_init : switch-uart_0 default mode is output
[ 1.143957] tztek_info: tz_gpio_general_pin_init: switch-uart_0 successful
[ 1.144088] tztek_info: tz_gpio_general_probe: switch-uart_0 init is successful
[ 1.144128] tztek_info: tz_gpio_general_probe
[ 1.144136] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is switch-uart_1
[ 1.144142] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.144180] tztek_info: tz_gpio_general_pin_init: switch-uart_1
[ 1.144202] tztek_info: tz_gpio_general_pin_init : switch-uart_1 default mode is output
[ 1.144223] tztek_info: tz_gpio_general_pin_init: switch-uart_1 successful
[ 1.144415] tztek_info: tz_gpio_general_probe: switch-uart_1 init is successful
[ 1.144484] tztek_info: tz_gpio_general_probe
[ 1.144492] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is switch-pcie_x8-clk
[ 1.144498] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.144541] tztek_info: tz_gpio_general_pin_init: switch-pcie_x8-clk
[ 1.144562] tztek_info: tz_gpio_general_pin_init : switch-pcie_x8-clk default mode is output
[ 1.144583] tztek_info: tz_gpio_general_pin_init: switch-pcie_x8-clk successful
[ 1.144731] tztek_info: tz_gpio_general_probe: switch-pcie_x8-clk init is successful
[ 1.144768] tztek_info: tz_gpio_general_probe
[ 1.144775] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is led-power
[ 1.144782] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.144822] tztek_info: tz_gpio_general_pin_init: led-power
[ 1.144874] tztek_info: tz_gpio_general_pin_init : led-power default mode is output
[ 1.144899] tztek_info: tz_gpio_general_pin_init: led-power successful
[ 1.145092] tztek_info: tz_gpio_general_probe: led-power init is successful
[ 1.145131] tztek_info: tz_gpio_general_probe
[ 1.145139] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is gpio-host_power
[ 1.145145] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.145185] tztek_info: tz_gpio_general_pin_init: gpio-host_power
[ 1.145208] tztek_info: tz_gpio_general_pin_init : gpio-host_power default mode is output
[ 1.145258] tztek_info: tz_gpio_general_pin_init: gpio-host_power successful
[ 1.145420] tztek_info: tz_gpio_general_probe: gpio-host_power init is successful
[ 1.145487] tztek_info: tz_gpio_general_probe
[ 1.145494] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is gpio-output_1
[ 1.145500] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.145538] tztek_info: tz_gpio_general_pin_init: gpio-output_1
[ 1.145560] tztek_info: tz_gpio_general_pin_init : gpio-output_1 default mode is output
[ 1.145581] tztek_info: tz_gpio_general_pin_init: gpio-output_1 successful
[ 1.145711] tztek_info: tz_gpio_general_probe: gpio-output_1 init is successful
[ 1.145746] tztek_info: tz_gpio_general_probe
[ 1.145754] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is gpio-output_2
[ 1.145759] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.145798] tztek_info: tz_gpio_general_pin_init: gpio-output_2
[ 1.145819] tztek_info: tz_gpio_general_pin_init : gpio-output_2 default mode is output
[ 1.145839] tztek_info: tz_gpio_general_pin_init: gpio-output_2 successful
[ 1.145965] tztek_info: tz_gpio_general_probe: gpio-output_2 init is successful
[ 1.146005] tztek_info: tz_gpio_general_probe
[ 1.146013] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is gpio-input_1
[ 1.146019] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is input
[ 1.146058] tztek_info: tz_gpio_general_pin_init: gpio-input_1
[ 1.146082] tztek_info: tz_gpio_general_pin_init : gpio-input_1 default mode is input
[ 1.146116] gpio tegra-gpio wake58 for gpio=196(Y:4)
[ 1.146168] tztek_info: tz_gpio_general_pin_init : gpio-input_1 request_irq_flag is 0x1
[ 1.146173] tztek_info: tz_gpio_general_pin_init: gpio-input_1 successful
[ 1.146297] tztek_info: tz_gpio_general_probe: gpio-input_1 init is successful
[ 1.146339] tztek_info: tz_gpio_general_probe
[ 1.146347] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is gpio-input_2
[ 1.146353] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is input
[ 1.146392] tztek_info: tz_gpio_general_pin_init: gpio-input_2
[ 1.146414] tztek_info: tz_gpio_general_pin_init : gpio-input_2 default mode is input
[ 1.146474] tztek_info: tz_gpio_general_pin_init : gpio-input_2 request_irq_flag is 0x1
[ 1.146479] tztek_info: tz_gpio_general_pin_init: gpio-input_2 successful
[ 1.146629] tztek_info: tz_gpio_general_probe: gpio-input_2 init is successful
[ 1.146665] tztek_info: tz_gpio_general_probe
[ 1.146673] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is camera_0_1-power
[ 1.146678] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.146716] tztek_info: tz_gpio_general_pin_init: camera_0_1-power
[ 1.146738] tztek_info: tz_gpio_general_pin_init : camera_0_1-power default mode is output
[ 1.146780] tztek_info: tz_gpio_general_pin_init: camera_0_1-power successful
[ 1.146910] tztek_info: tz_gpio_general_probe: camera_0_1-power init is successful
[ 1.146971] tztek_info: tz_gpio_general_probe
[ 1.146978] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is camera_2_3-power
[ 1.146984] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.147021] tztek_info: tz_gpio_general_pin_init: camera_2_3-power
[ 1.147047] tztek_info: tz_gpio_general_pin_init : camera_2_3-power default mode is output
[ 1.147075] tztek_info: tz_gpio_general_pin_init: camera_2_3-power successful
[ 1.147245] tztek_info: tz_gpio_general_probe: camera_2_3-power init is successful
[ 1.147306] tztek_info: tz_gpio_general_probe
[ 1.147313] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is camera_4_5-power
[ 1.147319] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.147357] tztek_info: tz_gpio_general_pin_init: camera_4_5-power
[ 1.147382] tztek_info: tz_gpio_general_pin_init : camera_4_5-power default mode is output
[ 1.147406] tztek_info: tz_gpio_general_pin_init: camera_4_5-power successful
[ 1.147561] tztek_info: tz_gpio_general_probe: camera_4_5-power init is successful
[ 1.147596] tztek_info: tz_gpio_general_probe
[ 1.147604] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is camera_6_7-power
[ 1.147610] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.147647] tztek_info: tz_gpio_general_pin_init: camera_6_7-power
[ 1.147669] tztek_info: tz_gpio_general_pin_init : camera_6_7-power default mode is output
[ 1.147690] tztek_info: tz_gpio_general_pin_init: camera_6_7-power successful
[ 1.147830] tztek_info: tz_gpio_general_probe: camera_6_7-power init is successful
[ 1.147870] tztek_info: tz_gpio_general_probe
[ 1.147877] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is tca9548-reset
[ 1.147884] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.147926] tztek_info: tz_gpio_general_pin_init: tca9548-reset
[ 1.147948] tztek_info: tz_gpio_general_pin_init : tca9548-reset default mode is output
[ 1.147969] tztek_info: tz_gpio_general_pin_init: tca9548-reset successful
[ 1.148108] tztek_info: tz_gpio_general_probe: tca9548-reset init is successful
[ 1.148157] tztek_info: tz_gpio_general_probe
[ 1.148165] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is fan_1-power
[ 1.148171] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.148212] tztek_info: tz_gpio_general_pin_init: fan_1-power
[ 1.148230] tztek_info: tz_gpio_general_pin_init : fan_1-power default mode is output
[ 1.148250] tztek_info: tz_gpio_general_pin_init: fan_1-power successful
[ 1.148418] tztek_info: tz_gpio_general_probe: fan_1-power init is successful
[ 1.148454] tztek_info: tz_gpio_general_probe
[ 1.148462] tztek_info: tz_gpio_general_get_parameters_from_dt: get name is fan_2-power
[ 1.148468] tztek_info: tz_gpio_general_get_parameters_from_dt: get direction is output
[ 1.148507] tztek_info: tz_gpio_general_pin_init: fan_2-power
[ 1.148525] tztek_info: tz_gpio_general_pin_init : fan_2-power default mode is output
[ 1.148544] tztek_info: tz_gpio_general_pin_init: fan_2-power successful
[ 1.148712] tztek_info: tz_gpio_general_probe: fan_2-power init is successful
[ 1.149091] tztek_info: tz_gpio_power_reset_probe
[ 1.149098] tztek_info: tz_gpio_power_reset_probe: can not get reset_name from device tree
[ 1.149120] tztek_info: tz_gpio_power_reset_probe: can not get reset_delay from device tree
[ 1.149132] tztek_info: tz_gpio_power_reset_probe: can not get reset_polarity from device tree
[ 1.149141] tztek_info: tz_gpio_power_reset_probe: set led-power pin to 0
[ 1.255761] tztek_info: tz_gpio_power_reset_probe: set led-power pin to 1
[ 1.255834] tztek_info: tz_gpio_power_reset_probe
[ 1.255842] tztek_info: tz_gpio_power_reset_probe: can not get power_name from device tree
[ 1.255859] tztek_info: tz_gpio_power_reset_probe: can not get power_delay from device tree
[ 1.255893] tztek_info: tz_gpio_power_reset_probe: can not get power_polarity from device tree
[ 1.255901] tztek_info: tz_gpio_power_reset_probe: set cpld-reset pin to 0
[ 1.364187] tztek_info: tz_gpio_power_reset_probe: set cpld-reset pin to 1
[ 1.364254] tztek_info: tz_gpio_power_reset_probe
[ 1.364267] tztek_info: tz_gpio_power_reset_probe: set 4g-5g-power pin to 0
[ 1.364646] tztek_info: tz_gpio_power_reset_probe: set 4g-reset pin to 0
[ 2.396699] tztek_info: tz_gpio_power_reset_probe: set 4g-5g-power pin to 1
[ 2.505618] tztek_info: tz_gpio_power_reset_probe: set 4g-reset pin to 1
[ 2.505741] tztek_info: tz_gpio_power_reset_probe
[ 2.505750] tztek_info: tz_gpio_power_reset_probe: can not get power_name from device tree
[ 2.505766] tztek_info: tz_gpio_power_reset_probe: can not get power_delay from device tree
[ 2.505778] tztek_info: tz_gpio_power_reset_probe: can not get power_polarity from device tree
[ 2.505787] tztek_info: tz_gpio_power_reset_probe: set 5g-reset pin to 0
[ 2.613757] tztek_info: tz_gpio_power_reset_probe: set 5g-reset pin to 1
[ 2.613852] tztek_info: tz_gpio_power_reset_probe
[ 2.613860] tztek_info: tz_gpio_power_reset_probe: can not get power_name from device tree
[ 2.613884] tztek_info: tz_gpio_power_reset_probe: can not get power_delay from device tree
[ 2.613891] tztek_info: tz_gpio_power_reset_probe: can not get power_polarity from device tree
[ 2.613900] tztek_info: tz_gpio_power_reset_probe: set tca9548-reset pin to 0
[ 2.722320] tztek_info: tz_gpio_power_reset_probe: set tca9548-reset pin to 1
[ 2.722407] tztek_info: tz_gpio_power_reset_probe
[ 2.722415] tztek_info: tz_gpio_power_reset_probe: can not get reset_name from device tree
[ 2.722429] tztek_info: tz_gpio_power_reset_probe: can not get reset_delay from device tree
[ 2.722436] tztek_info: tz_gpio_power_reset_probe: can not get reset_polarity from device tree
[ 2.722444] tztek_info: tz_gpio_power_reset_probe: set camera_0_1-power pin to 0
[ 2.830890] tztek_info: tz_gpio_power_reset_probe: set camera_0_1-power pin to 1
[ 2.830973] tztek_info: tz_gpio_power_reset_probe
[ 2.830981] tztek_info: tz_gpio_power_reset_probe: can not get reset_name from device tree
[ 2.830988] tztek_info: tz_gpio_power_reset_probe: can not get reset_delay from device tree
[ 2.830995] tztek_info: tz_gpio_power_reset_probe: can not get reset_polarity from device tree
[ 2.831003] tztek_info: tz_gpio_power_reset_probe: set camera_2_3-power pin to 0
[ 2.939439] tztek_info: tz_gpio_power_reset_probe: set camera_2_3-power pin to 1
[ 2.939519] tztek_info: tz_gpio_power_reset_probe
[ 2.939527] tztek_info: tz_gpio_power_reset_probe: can not get reset_name from device tree
[ 2.939535] tztek_info: tz_gpio_power_reset_probe: can not get reset_delay from device tree
[ 2.939540] tztek_info: tz_gpio_power_reset_probe: can not get reset_polarity from device tree
[ 2.939548] tztek_info: tz_gpio_power_reset_probe: set camera_4_5-power pin to 0
[ 3.047969] tztek_info: tz_gpio_power_reset_probe: set camera_4_5-power pin to 1
[ 3.048033] tztek_info: tz_gpio_power_reset_probe
[ 3.048074] tztek_info: tz_gpio_power_reset_probe: can not get reset_name from device tree
[ 3.048080] tztek_info: tz_gpio_power_reset_probe: can not get reset_delay from device tree
[ 3.048091] tztek_info: tz_gpio_power_reset_probe: can not get reset_polarity from device tree
[ 3.048099] tztek_info: tz_gpio_power_reset_probe: set camera_6_7-power pin to 0
[ 3.156465] tztek_info: tz_gpio_power_reset_probe: set camera_6_7-power pin to 1
[ 3.159534] camchar: rtcpu character device driver loaded
[ 3.160003] gpio tegra-gpio wake35 for gpio=128(Q:0)
[ 3.160094] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 3.160667] max9296_class_init
[ 3.160719] max9296_class_init: init is successful
[ 3.161724] clocksource: Switched to clocksource arch_sys_counter
[ 3.203128] VFS: Disk quotas dquot_6.6.0
[ 3.203241] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 3.203639] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 3.205589] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 3.205667] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 3.206016] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 3.206022] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 3.206038] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 3.206045] nvmap_page_pool_init: Total RAM pages: 8163296
[ 3.206051] nvmap_page_pool_init: nvmap page pool size: 1020412 pages (3985 MB)
[ 3.206367] nvmap_background_zero_thread: PP zeroing thread starting.
[ 3.206764] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 3.207943] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 3.221947] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 3.222226] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 3.222518] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 3.222735] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 3.222919] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 3.223017] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 3.223110] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 3.224321] la/ptsa driver initialized.
[ 3.224672] NET: Registered protocol family 2
[ 3.224761] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 3.230537] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 3.231654] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 3.232281] TCP: Hash tables configured (established 262144 bind 65536)
[ 3.232343] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 3.232811] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 3.233598] NET: Registered protocol family 1
[ 3.234238] RPC: Registered named UNIX socket transport module.
[ 3.234243] RPC: Registered udp transport module.
[ 3.234249] RPC: Registered tcp transport module.
[ 3.234254] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.234265] PCI: CLS 0 bytes, default 64
[ 3.234487] Trying to unpack rootfs image as initramfs...
[ 4.019308] Freeing initrd memory: 23388K
[ 4.037885] host1x 13e10000.host1x: initialized
[ 4.040694] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 4.045742] audit: initializing netlink subsys (disabled)
[ 4.045802] audit: type=2000 audit(3.628:1): initialized
[ 4.046422] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 4.052706] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 4.053820] ntfs: driver 2.1.32 [Flags: R/W].
[ 4.054407] 9p: Installing v9fs 9p2000 file system support
[ 4.059314] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 485)
[ 4.059477] io scheduler noop registered
[ 4.059663] io scheduler cfq registered (default)
[ 4.061268] random: fast init done
[ 4.063512] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 4.099793] iommu: Adding device 2993000.adsp to group 59
[ 4.217877] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[ 4.218990] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 4.232242] gpio tegra-gpio-aon wake46 for gpio=6(AA:6)
[ 4.232668] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 4.233183] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 4.233813] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 4.234257] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 4.237673] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 4.237834] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 4.237844] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=7500000, max_bw=7500000
[ 4.240985] tsec 15500000.tsec: initialized
[ 4.242691] tsec 15100000.tsecb: initialized
[ 4.246941] nvdec 15480000.nvdec: initialized
[ 4.249869] nvdec 15140000.nvdec1: initialized
[ 4.256916] falcon 15340000.vic: initialized
[ 4.259053] falcon 15380000.nvjpg: initialized
[ 4.261121] falcon 154c0000.nvenc: initialized
[ 4.262986] falcon 15a80000.nvenc1: initialized
[ 4.265720] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 4.267600] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 4.268856] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 4.270051] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 4.271326] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 4.272582] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 4.273883] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 4.275216] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 4.278832] t194-nvcsi 15a00000.nvcsi: initialized
[ 4.284547] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 4.284858] scare-pigeon 14b00000.isp-thi: initialized
[ 4.295475] pva 16000000.pva0: initialized
[ 4.326646] pva 16800000.pva1: initialized
[ 4.357164] nvdla 15880000.nvdla0: initialized
[ 4.386984] nvdla 158c0000.nvdla1: initialized
[ 4.388832] tegradccommon 15200000.dc_common: host1x channel mapped
[ 4.388845] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 4.388882] tegradccommon 15200000.dc_common: dma mapping done
[ 4.389972] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 4.390050] generic_infoframe_type: 0x87
[ 4.390222] tegradc 15200000.nvdisplay: DT parsed successfully
[ 4.390271] tegradc 15200000.nvdisplay: Display dc.ffffff800bbb0000 registered with id=0
[ 4.395345] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 4.395353] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 4.395358] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 4.395646] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 4.395654] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 4.397507] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 4.404210] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 4.404218] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 4.404444] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 4.405557] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 4.405589] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 4.406100] kfuse 3830000.kfuse: initialized
[ 4.408480] tegradc 15200000.nvdisplay: probed
[ 4.411280] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 4.413958] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 53, base_baud = 0) is a TEGRA_UART
[ 4.415300] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 54, base_baud = 0) is a TEGRA_UART
[ 4.416172] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 55, base_baud = 0) is a TEGRA_UART
[ 4.417735] console [ttyTCU0] enabled
[ 4.418040] [drm] Initialized
[ 4.419116] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.429202] brd: module loaded
[ 4.434345] loop: module loaded
[ 4.435150] at24 2-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 4.435243] tegra_profiler: version: 1.145, samples/io: 49/28
[ 4.435383] tegra_profiler: auth: init
[ 4.435871] nct1008_nct72 4-004c: starting parse dt
[ 4.436011] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.436019] nct1008_nct72 4-004c: success parsing dt
[ 4.436130] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.436205] THERMAL EST: found 3 subdevs
[ 4.436212] THERMAL EST num_resources: 0
[ 4.436218] [THERMAL EST subdev 0]
[ 4.436225] [THERMAL EST subdev 1]
[ 4.436230] [THERMAL EST subdev 2]
[ 4.436241] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.436503] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.436508] THERMAL EST: thz register success.
[ 4.436712] THERMAL EST: end of probe, return err: 0
[ 4.437468] sd: No Scsi addr parsed to reserve index
[ 4.437506] hisi_sas: driver version v1.6
[ 4.448727] Console: switching to colour frame buffer device 240x67
[ 4.448859] tegradc 15200000.nvdisplay: fb registered
[ 4.449207] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.471695] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 4.472369] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 4.509015] nct1008_nct72 4-004c: initial LOC temp: 37000
[ 4.509508] nct1008_nct72 4-004c: initial EXT temp: 39000
[ 4.510470] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 4.511422] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 4.512429] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.512580] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.527692] tegra_spi_set_cmd2:command2_reg = 0x11, real_reg = 0x11
[ 4.528262] Parent Clock set for DC plld3
[ 4.532152] nvidia-xavier-510g
[ 4.533954] wk2xxx_probe() GENA = 0x30
[ 4.534098] wk2xxx_probe() GENA = 0x35
[ 4.534272] wk2xxx_probe() GENA = 0x30
[ 4.534378] wk2xxx_serial_init.
[ 4.534390] ttysWK0 at I/O 0x1 (irq = 350, base_baud = 460800) is a wk2xxx
[ 4.534584] ttysWK1 at I/O 0x2 (irq = 350, base_baud = 460800) is a wk2xxx
[ 4.534725] ttysWK2 at I/O 0x3 (irq = 350, base_baud = 460800) is a wk2xxx
[ 4.534902] ttysWK3 at I/O 0x4 (irq = 350, base_baud = 460800) is a wk2xxx
[ 4.535088] wk2xxx_init,register spi return v = :0
[ 4.535140] tztek_info: tztek_spi_probe: the platform-name is nvidia-xavier
[ 4.535193] tztek_info: tztek_spi_probe: switch_gpio of_get_named_gpio_flags is 412.
[ 4.535253] tztek_info: tztek_spi_probe: reset_gpio of_get_named_gpio_flags is 420.
[ 4.536506] libphy: Fixed MDIO Bus: probed
[ 4.536981] tun: Universal TUN/TAP device driver, 1.6
[ 4.536986] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.537206] CAN device driver interface
[ 4.539854] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x000009c0|
| rxbc_rbsa |0x000009c0|
| txefc_efsa |0x000009c0|
| txbc_tbsa |0x00000a40|
| tmc_tmsa |0x00000ec0|
[ 4.539994] Release 3.2.0 from 19.12.2014
[ 4.540356] net can0: mttcan device registered (regs=ffffff800a5ee000, irq=70)
[ 4.542481] Message RAM Configuration
| base addr |0x0c322000|
[ 4.542586] Release 3.2.0 from 19.12.2014
[ 4.542877] net can1: mttcan device registered (regs=ffffff800a71c000, irq=71)
[ 4.543648] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.543653] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.543686] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.543690] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.543751] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.543756] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.543791] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 4.543795] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 4.556785] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 4.557279] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3a 87 9b
[ 4.557301] Using phyrst_lpmode = 1 from DT
[ 4.557385] libphy: dwc_phy: probed
[ 4.559630] PPP generic driver version 2.4.2
[ 4.559859] PPP BSD Compression module registered
[ 4.559866] PPP Deflate Compression module registered
[ 4.559883] PPP MPPE Compression module registered
[ 4.559888] NET: Registered protocol family 24
[ 4.559972] usbcore: registered new interface driver r8152
[ 4.560046] usbcore: registered new interface driver asix
[ 4.560149] usbcore: registered new interface driver ax88179_178a
[ 4.560224] usbcore: registered new interface driver cdc_ether
[ 4.560321] usbcore: registered new interface driver net1080
[ 4.560399] usbcore: registered new interface driver cdc_subset
[ 4.560481] usbcore: registered new interface driver zaurus
[ 4.560568] usbcore: registered new interface driver cdc_ncm
[ 4.560653] usbcore: registered new interface driver qmi_wwan
[ 4.560733] GobiNet: GobiNet-fastdial-v3.2
[ 4.560811] usbcore: registered new interface driver GobiNet-LS
[ 4.561031] VFIO - User Level meta-driver version: 0.3
[ 4.562104] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.562129] ehci-pci: EHCI PCI platform driver
[ 4.562167] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.562175] ohci-pci: OHCI PCI platform driver
[ 4.562218] ohci-platform: OHCI generic platform driver
[ 4.569447] tegra-xusb 3610000.xhci: No USB port has OTG_CAP
[ 4.570252] set USB3 0 GEN2
[ 4.570714] set USB3 2 GEN1
[ 4.571179] set USB3 3 GEN1
[ 4.572789] usbcore: registered new interface driver cdc_wdm
[ 4.572993] usbcore: registered new interface driver uas
[ 4.573041] usbcore: registered new interface driver usb-storage
[ 4.573105] usbcore: registered new interface driver usbserial
[ 4.573133] usbcore: registered new interface driver option
[ 4.573150] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.574055] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 4.574114] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.574132] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 4.574807] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 4.574842] tegra-xusb 3610000.xhci: irq 469, io mem 0x03610000
[ 4.575054] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.575062] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.575068] usb usb1: Product: xHCI Host Controller
[ 4.575074] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.575079] usb usb1: SerialNumber: 3610000.xhci
[ 4.575720] hub 1-0:1.0: USB hub found
[ 4.575765] hub 1-0:1.0: 4 ports detected
[ 4.576222] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.576235] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 4.576245] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.576401] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.576466] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.576473] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.576479] usb usb2: Product: xHCI Host Controller
[ 4.576484] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.576489] usb usb2: SerialNumber: 3610000.xhci
[ 4.576506] tegra-xudc-new 3550000.xudc: device count: 1
[ 4.576993] hub 2-0:1.0: USB hub found
[ 4.577049] hub 2-0:1.0: 4 ports detected
[ 4.577356] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 4.577365] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 4.577477] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.577692] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.578180] Wake76 for irq=199
[ 4.578185] Wake77 for irq=199
[ 4.578189] Wake78 for irq=199
[ 4.578192] Wake79 for irq=199
[ 4.578196] Wake80 for irq=199
[ 4.578199] Wake81 for irq=199
[ 4.578203] Wake82 for irq=199
[ 4.578232] mousedev: PS/2 mouse device common for all mice
[ 4.578240] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 4.578247] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 4.578314] usbcore: registered new interface driver xpad
[ 4.585092] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 4.585643] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.585656] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.611110] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.611116] Extcon AUX2(HDMI) enable
[ 4.681686] usb usb2: usb_suspend_both: status 0
[ 4.708401] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.709886] Wake73 for irq=42
[ 4.711103] rtc rtc1: alarm rtc device
[ 4.711118] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.711142] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.711281] i2c /dev entries driver
[ 4.712887] pca954x 2-0070: vcc-pullup regulator not found
[ 4.713333] i2c i2c-2: Added multiplexed i2c bus 9
[ 4.713713] i2c i2c-2: Added multiplexed i2c bus 10
[ 4.715928] i2c i2c-2: Added multiplexed i2c bus 11
[ 4.716293] i2c i2c-2: Added multiplexed i2c bus 12
[ 4.716562] i2c i2c-2: Added multiplexed i2c bus 13
[ 4.716810] i2c i2c-2: Added multiplexed i2c bus 14
[ 4.717018] i2c i2c-2: Added multiplexed i2c bus 15
[ 4.717256] i2c i2c-2: Added multiplexed i2c bus 16
[ 4.717264] pca954x 2-0070: registered 8 multiplexed busses for I2C switch pca9548
[ 4.718038] pps_core: source pps.-1 got cdev (248:0)
[ 4.718047] pps pps0: new PPS source pps.-1
[ 4.718106] pps pps0: Registered IRQ 431 as PPS source
[ 4.718615] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 4.719795] lm75 2-004b: hwmon1: sensor 'lm75b'
[ 4.726673] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 4.727091] FAN dev name: pwm-fan
[ 4.727156] FAN:gpio request success.
[ 4.727166] FAN: can't find tach_gpio
[ 4.727176] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 4.727204] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 4.727399] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 4.727406] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.727957] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.727966] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 4.727972] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.727978] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.727984] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.727990] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.727996] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.728002] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.728009] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.728015] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.728760] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 4.729832] softdog-platform soft_watchdog: Software Watchdog Timer: initialized
[ 4.730288] device-mapper: uevent: version 1.0.3
[ 4.730743] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.734306] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.736149] cpuidle: Initializing cpuidle driver
[ 4.737096] sdhci: Secure Digital Host Controller Interface driver
[ 4.737100] sdhci: Copyright(c) Pierre Ossman
[ 4.737103] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.739341] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.742683] CMDQ: cmdq_platfm_init successful
[ 4.743088] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.746678] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.747947] tegradc 15200000.nvdisplay: blank - powerdown
[ 4.748945] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 253
[ 4.753454] tegra-se-nvhost 15810000.se: initialized
[ 4.754656] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.755434] tegra-se-nvhost 15820000.se: initialized
[ 4.756368] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.757109] tegra-se-nvhost 15830000.se: initialized
[ 4.757658] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.758432] tegra-se-nvhost 15840000.se: initialized
[ 4.759215] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.760207] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.760380] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.761383] usbcore: registered new interface driver usbhid
[ 4.761385] usbhid: USB HID core driver
[ 4.767749] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.768660] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.769036] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.769566] denver_knobs_init:MTS_VERSION:54811859
[ 4.769766] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 4.770874] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.771162] t19x_cache tegra-cache: probed
[ 4.777530] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.777536] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.777898] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 4.778213] Clocks initialized successfully
[ 4.778569] tztek_info: max9296_probe
[ 4.778654] tztek_info: max9296_probe,max9296_info->name = max9296_a
[ 4.778654] tztek_info: success,max9296_probe
[ 4.778699] tztek_info: max9296_probe
[ 4.778778] tztek_info: max9296_probe,max9296_info->name = max9296_b
[ 4.778779] tztek_info: success,max9296_probe
[ 4.778806] tztek_info: max9296_probe
[ 4.778870] tztek_info: max9296_probe,max9296_info->name = max9296_c
[ 4.778870] tztek_info: success,max9296_probe
[ 4.778895] tztek_info: max9296_probe
[ 4.778961] tztek_info: max9296_probe,max9296_info->name = max9296_d
[ 4.778961] tztek_info: success,max9296_probe
[ 4.780177] nvpmodel: initialized successfully
[ 4.781223] trusty-virtio trusty:virtio: initializing
[ 4.781454] trusty_ipc virtio0: vring0: va(pa) ffffffc7c43b8000(0) qsz 32 notifyid 1
[ 4.781461] trusty_ipc virtio0: vring1: va(pa) ffffffc7c43ba000(0) qsz 32 notifyid 2
[ 4.781590] trusty-virtio trusty:virtio: initializing done
[ 4.781781] trusty_ipc virtio0: is online
[ 4.782238] tegra-hda 3510000.hda: Override SDO lines to 4
[ 4.782533] usbcore: registered new interface driver snd-usb-audio
[ 4.785450] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 4.785453] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.785455] Extcon AUX2(HDMI) disable
[ 4.794620] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 4.794687] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.801119] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.801274] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.801381] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 4.801562] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 4.808114] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.808879] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.820307] tegradc 15200000.nvdisplay: unblank
[ 4.821978] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.822225] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.826448] Parent Clock set for DC plld3
[ 4.835981] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 4.838178] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.855091] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 4.869536] mmc0: periodic cache flush enabled
[ 4.869550] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.870015] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 4.870230] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 4.870385] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 4.870527] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 4.876212] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.876215] Extcon AUX2(HDMI) enable
[ 4.883416] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37 p38 p39 p40 p41 p42
Could you share the flash log when you flash your board?
Are you sure this is pure jetpack release? I see you have customized kernel, are you sure you didn’t change the partition size?
[ 4.887467] partno=1,start_sect=40,nr_sects=58720256,name=APP===
[ 4.887471] partno=2,start_sect=58720296,nr_sects=320,name=mts-mce===
[ 4.887474] partno=3,start_sect=58720616,nr_sects=320,name=mts-mce_b===
[ 4.887477] partno=4,start_sect=58720936,nr_sects=8192,name=mts-proper===
[ 4.887479] partno=5,start_sect=58729128,nr_sects=8192,name=mts-proper_b===
[ 4.887481] partno=6,start_sect=58737320,nr_sects=2752,name=cpu-bootloader===
[ 4.887484] partno=7,start_sect=58740072,nr_sects=2752,name=cpu-bootloader_b===
[ 4.887486] partno=8,start_sect=58742824,nr_sects=1024,name=bootloader-dtb===
[ 4.887490] partno=9,start_sect=58743848,nr_sects=1024,name=bootloader-dtb_b===
[ 4.887519] partno=10,start_sect=58744872,nr_sects=5120,name=secure-os===
[ 4.887521] partno=11,start_sect=58749992,nr_sects=5120,name=secure-os_b===
[ 4.887524] partno=12,start_sect=58755112,nr_sects=128,name=eks===
[ 4.887526] partno=13,start_sect=58755240,nr_sects=128,name=eks_b===
[ 4.887528] partno=14,start_sect=58755368,nr_sects=3072,name=bpmp-fw===
[ 4.887530] partno=15,start_sect=58758440,nr_sects=3072,name=bpmp-fw_b===
[ 4.887537] partno=16,start_sect=58761512,nr_sects=2048,name=bpmp-fw-dtb===
[ 4.887540] partno=17,start_sect=58763560,nr_sects=2048,name=bpmp-fw-dtb_b===
[ 4.887542] partno=18,start_sect=58765608,nr_sects=320,name=xusb-fw===
[ 4.887544] partno=19,start_sect=58765928,nr_sects=320,name=xusb-fw_b===
[ 4.887546] partno=20,start_sect=58766248,nr_sects=2048,name=rce-fw===
[ 4.887548] partno=21,start_sect=58768296,nr_sects=2048,name=rce-fw_b===
[ 4.887550] partno=22,start_sect=58770344,nr_sects=4096,name=adsp-fw===
[ 4.887553] partno=23,start_sect=58774440,nr_sects=4096,name=adsp-fw_b===
[ 4.887555] partno=24,start_sect=58778536,nr_sects=2048,name=sce-fw===
[ 4.887557] partno=25,start_sect=58780584,nr_sects=2048,name=sce-fw_b===
[ 4.887559] partno=26,start_sect=58782632,nr_sects=256,name=sc7===
[ 4.887561] partno=27,start_sect=58782888,nr_sects=256,name=sc7_b===
[ 4.887576] partno=28,start_sect=58783144,nr_sects=262144,name=BMP===
[ 4.887578] partno=29,start_sect=59045288,nr_sects=262144,name=BMP_b===
[ 4.887581] partno=30,start_sect=59307432,nr_sects=129024,name=recovery===
[ 4.887583] partno=31,start_sect=59436456,nr_sects=1024,name=recovery-dtb===
[ 4.887585] partno=32,start_sect=59437480,nr_sects=128,name=kernel-bootctrl===
[ 4.887587] partno=33,start_sect=59437608,nr_sects=128,name=kernel-bootctrl_b===
[ 4.887589] partno=34,start_sect=59437736,nr_sects=163840,name=kernel===
[ 4.887592] partno=35,start_sect=59601576,nr_sects=163840,name=kernel_b===
[ 4.887594] partno=36,start_sect=59765416,nr_sects=1024,name=kernel-dtb===
[ 4.887596] partno=37,start_sect=59766440,nr_sects=1024,name=kernel-dtb_b===
[ 4.887598] partno=38,start_sect=59767464,nr_sects=8,name=CPUBL-CFG===
[ 4.887600] partno=39,start_sect=59767472,nr_sects=16384,name=RP1===
[ 4.887603] partno=40,start_sect=59783856,nr_sects=16384,name=RP2===
[ 4.887605] partno=41,start_sect=59800240,nr_sects=614400,name=RECROOTFS===
[ 4.887607] partno=42,start_sect=60414640,nr_sects=664879,name=UDA===
[ 4.888881] tegradc 15200000.nvdisplay: sync windows ret = 247
[ 4.890645] OPE platform probe
[ 4.890738] OPE platform probe successful
[ 4.901447] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.915045] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 4.915049] Extcon HDMI: HPD enabled
[ 4.915073] tegradc 15200000.nvdisplay: hdmi: plugged
[ 4.927462] usb 1-2: New USB device found, idVendor=2109, idProduct=2817
[ 4.927467] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.927471] usb 1-2: Product: USB2.0 Hub
[ 4.927474] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 4.928394] hub 1-2:1.0: USB hub found
[ 4.928504] hub 1-2:1.0: 4 ports detected
[ 4.947198] tegra-i2c c250000.i2c: no acknowledge from address 0x10
[ 4.947264] max98090 7-0010: Failed to reset codec: -121
[ 4.947535] tegra-i2c c250000.i2c: no acknowledge from address 0x10
[ 4.947584] max98090 7-0010: Failed to read device revision: -1
[ 4.947713] max98090 7-0010: ASoC: failed to probe component -1
[ 4.947882] tegra-asoc: sound: ASoC: failed to instantiate card -1
[ 4.950333] tegra-asoc: sound: snd_soc_register_card failed (-1)
[ 4.950554] tegra-asoc:: probe of sound failed with error -1
[ 4.950829] u32 classifier
[ 4.950832] Actions configured
[ 4.950914] Initializing XFRM netlink socket
[ 4.951347] NET: Registered protocol family 10
[ 4.952032] NET: Registered protocol family 17
[ 4.952043] NET: Registered protocol family 15
[ 4.952102] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.952105] can: controller area network core (rev 20120528 abi 9)
[ 4.952159] NET: Registered protocol family 29
[ 4.952180] can: raw protocol (rev 20120528)
[ 4.952183] can: broadcast manager protocol (rev 20161123 t)
[ 4.952188] can: netlink gateway (rev 20130117) max_hops=1
[ 4.952349] Bluetooth: RFCOMM socket layer initialized
[ 4.952359] Bluetooth: RFCOMM ver 1.11
[ 4.952365] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.952377] Bluetooth: HIDP socket layer initialized
[ 4.952393] 9pnet: Installing 9P2000 support
[ 4.952430] Key type dns_resolver registered
[ 4.952766] Registered cp15_barrier emulation handler
[ 4.952779] Registered setend emulation handler
[ 4.954451] registered taskstats version 1
[ 4.954910] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 4.956691] OF: PCI: host bridge /pcie@14180000 ranges:
[ 4.956712] OF: PCI: IO 0x38100000..0x381fffff -> 0x38100000
[ 4.956723] OF: PCI: MEM 0x1b40000000..0x1bffffffff -> 0x40000000
[ 4.956729] OF: PCI: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 5.045679] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.066481] usb 2-3: New USB device found, idVendor=1058, idProduct=2623
[ 5.066487] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.066490] usb 2-3: Product: Elements SE 2623
[ 5.066494] usb 2-3: Manufacturer: Western Digital
[ 5.066498] usb 2-3: SerialNumber: 5758513245373139564C4D53
[ 5.068572] usb-storage 2-3:1.0: USB Mass Storage device detected
[ 5.068848] scsi host0: usb-storage 2-3:1.0
[ 5.329815] usb 2-1: new SuperSpeed USB device number 3 using tegra-xusb
[ 5.351625] usb 2-1: New USB device found, idVendor=2109, idProduct=0817
[ 5.351630] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.351634] usb 2-1: Product: USB3.0 Hub
[ 5.351637] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 5.354485] hub 2-1:1.0: USB hub found
[ 5.354992] hub 2-1:1.0: 4 ports detected
[ 5.470435] tegra-pcie-dw 14180000.pcie: link is down
[ 5.470549] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 5.470557] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 5.470564] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 5.470569] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 5.470573] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 5.470597] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.470744] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.470992] iommu: Adding device 0000:00:00.0 to group 61
[ 5.471166] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 5.471186] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.471377] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.471383] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.471472] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 5.471597] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
[ 5.471645] aer 0000:00:00.0:pcie002: unloading service driver aer
[ 5.471721] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 5.471778] iommu: Removing device 0000:00:00.0 from group 61
[ 5.471801] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 5.473020] tegra-pcie-dw 14180000.pcie: PCIe link is not up...!
[ 5.473673] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 5.474451] OF: PCI: host bridge /pcie@14100000 ranges:
[ 5.474467] OF: PCI: IO 0x30100000..0x301fffff -> 0x30100000
[ 5.474490] OF: PCI: MEM 0x1230000000..0x123fffffff -> 0x40000000
[ 5.474495] OF: PCI: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 5.581431] tegra-pcie-dw 14100000.pcie: link is up
[ 5.581624] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.581631] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.581638] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 5.581643] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 5.581647] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 5.581668] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 5.581782] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.581984] iommu: Adding device 0001:00:00.0 to group 61
[ 5.582348] pci 0001:01:00.0: [8086:1521] type 00 class 0x020000
[ 5.582440] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 5.582546] pci 0001:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 5.582593] pci 0001:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 5.583305] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[ 5.583532] pci 0001:01:00.0: reg 0x184: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.583538] pci 0001:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR0 for 8 VFs)
[ 5.583660] pci 0001:01:00.0: reg 0x190: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.583665] pci 0001:01:00.0: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR3 for 8 VFs)
[ 5.584158] iommu: Adding device 0001:01:00.0 to group 62
[ 5.584366] pci 0001:01:00.1: [8086:1521] type 00 class 0x020000
[ 5.584457] pci 0001:01:00.1: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 5.584561] pci 0001:01:00.1: reg 0x18: [io 0x0000-0x001f]
[ 5.584607] pci 0001:01:00.1: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 5.585288] pci 0001:01:00.1: PME# supported from D0 D3hot D3cold
[ 5.585542] pci 0001:01:00.1: reg 0x184: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.585547] pci 0001:01:00.1: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR0 for 8 VFs)
[ 5.585670] pci 0001:01:00.1: reg 0x190: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.585674] pci 0001:01:00.1: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR3 for 8 VFs)
[ 5.586150] iommu: Adding device 0001:01:00.1 to group 63
[ 5.586331] pci 0001:01:00.2: [8086:1521] type 00 class 0x020000
[ 5.586421] pci 0001:01:00.2: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 5.586510] pci 0001:01:00.2: reg 0x18: [io 0x0000-0x001f]
[ 5.586572] pci 0001:01:00.2: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 5.587234] pci 0001:01:00.2: PME# supported from D0 D3hot D3cold
[ 5.587465] pci 0001:01:00.2: reg 0x184: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.587470] pci 0001:01:00.2: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR0 for 8 VFs)
[ 5.587592] pci 0001:01:00.2: reg 0x190: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.587597] pci 0001:01:00.2: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR3 for 8 VFs)
[ 5.588056] iommu: Adding device 0001:01:00.2 to group 64
[ 5.588211] pci 0001:01:00.3: [8086:1521] type 00 class 0x020000
[ 5.588301] pci 0001:01:00.3: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 5.588392] pci 0001:01:00.3: reg 0x18: [io 0x0000-0x001f]
[ 5.588438] pci 0001:01:00.3: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 5.589099] pci 0001:01:00.3: PME# supported from D0 D3hot D3cold
[ 5.589323] pci 0001:01:00.3: reg 0x184: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.589327] pci 0001:01:00.3: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR0 for 8 VFs)
[ 5.589468] pci 0001:01:00.3: reg 0x190: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.589473] pci 0001:01:00.3: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit pref] (contains BAR3 for 8 VFs)
[ 5.589937] iommu: Adding device 0001:01:00.3 to group 65
[ 5.602349] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[ 5.602355] pci 0001:00:00.0: BAR 15: assigned [mem 0x1200000000-0x12000fffff 64bit pref]
[ 5.602359] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 5.602374] pci 0001:01:00.0: BAR 0: assigned [mem 0x1230000000-0x123001ffff]
[ 5.602396] pci 0001:01:00.1: BAR 0: assigned [mem 0x1230020000-0x123003ffff]
[ 5.602432] pci 0001:01:00.2: BAR 0: assigned [mem 0x1230040000-0x123005ffff]
[ 5.602453] pci 0001:01:00.3: BAR 0: assigned [mem 0x1230060000-0x123007ffff]
[ 5.602474] pci 0001:01:00.0: BAR 3: assigned [mem 0x1230080000-0x1230083fff]
[ 5.602496] pci 0001:01:00.0: BAR 7: assigned [mem 0x1200000000-0x120001ffff 64bit pref]
[ 5.602525] pci 0001:01:00.0: BAR 10: assigned [mem 0x1200020000-0x120003ffff 64bit pref]
[ 5.602555] pci 0001:01:00.1: BAR 3: assigned [mem 0x1230084000-0x1230087fff]
[ 5.602576] pci 0001:01:00.1: BAR 7: assigned [mem 0x1200040000-0x120005ffff 64bit pref]
[ 5.602606] pci 0001:01:00.1: BAR 10: assigned [mem 0x1200060000-0x120007ffff 64bit pref]
[ 5.602636] pci 0001:01:00.2: BAR 3: assigned [mem 0x1230088000-0x123008bfff]
[ 5.602671] pci 0001:01:00.2: BAR 7: assigned [mem 0x1200080000-0x120009ffff 64bit pref]
[ 5.602701] pci 0001:01:00.2: BAR 10: assigned [mem 0x12000a0000-0x12000bffff 64bit pref]
[ 5.602730] pci 0001:01:00.3: BAR 3: assigned [mem 0x123008c000-0x123008ffff]
[ 5.602752] pci 0001:01:00.3: BAR 7: assigned [mem 0x12000c0000-0x12000dffff 64bit pref]
[ 5.602781] pci 0001:01:00.3: BAR 10: assigned [mem 0x12000e0000-0x12000fffff 64bit pref]
[ 5.602810] pci 0001:01:00.0: BAR 2: assigned [io 0x100000-0x10001f]
[ 5.602831] pci 0001:01:00.1: BAR 2: assigned [io 0x100020-0x10003f]
[ 5.602852] pci 0001:01:00.2: BAR 2: assigned [io 0x100040-0x10005f]
[ 5.602889] pci 0001:01:00.3: BAR 2: assigned [io 0x100060-0x10007f]
[ 5.602915] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.602920] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 5.602926] pci 0001:00:00.0: bridge window [mem 0x1230000000-0x12300fffff]
[ 5.602932] pci 0001:00:00.0: bridge window [mem 0x1200000000-0x12000fffff 64bit pref]
[ 5.602944] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.602990] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.603036] pci 0001:01:00.1: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.603082] pci 0001:01:00.2: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.603128] pci 0001:01:00.3: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.603365] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.603369] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
[ 5.603372] pci 0001:01:00.1: Signaling PME through PCIe PME interrupt
[ 5.603375] pci 0001:01:00.2: Signaling PME through PCIe PME interrupt
[ 5.603378] pci 0001:01:00.3: Signaling PME through PCIe PME interrupt
[ 5.603383] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.603462] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 5.603710] igb 0001:01:00.0: enabling device (0000 -> 0002)
[ 5.637464] usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
[ 5.661890] usb 1-2.1: New USB device found, idVendor=413c, idProduct=301a
[ 5.661896] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.661900] usb 1-2.1: Product: Dell MS116 USB Optical Mouse
[ 5.661903] usb 1-2.1: Manufacturer: PixArt
[ 5.663573] igb 0001:01:00.0: added PHC on eth1
[ 5.663579] igb 0001:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 5.663583] igb 0001:01:00.0: eth1: (PCIe:5.0Gb/s:Width x1) 00:54:5a:23:01:e9
[ 5.663670] igb 0001:01:00.0: eth1: PBA No: 106300-000
[ 5.663673] igb 0001:01:00.0: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 5.663884] igb 0001:01:00.1: enabling device (0000 -> 0002)
[ 5.664547] input: PixArt Dell MS116 USB Optical Mouse as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:413C:301A.0001/input/input4
[ 5.664838] hid-generic 0003:413C:301A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-3610000.xhci-2.1/input0
[ 5.722547] igb 0001:01:00.1: added PHC on eth2
[ 5.722552] igb 0001:01:00.1: Intel(R) Gigabit Ethernet Network Connection
[ 5.722557] igb 0001:01:00.1: eth2: (PCIe:5.0Gb/s:Width x1) 00:54:5a:23:01:ea
[ 5.722644] igb 0001:01:00.1: eth2: PBA No: 106300-000
[ 5.722648] igb 0001:01:00.1: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 5.722891] igb 0001:01:00.2: enabling device (0000 -> 0002)
[ 5.777445] usb 2-1: usb_suspend_both: status 0
[ 5.782160] igb 0001:01:00.2: added PHC on eth3
[ 5.782165] igb 0001:01:00.2: Intel(R) Gigabit Ethernet Network Connection
[ 5.782169] igb 0001:01:00.2: eth3: (PCIe:5.0Gb/s:Width x1) 00:54:5a:23:01:eb
[ 5.782255] igb 0001:01:00.2: eth3: PBA No: 106300-000
[ 5.782259] igb 0001:01:00.2: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 5.782527] igb 0001:01:00.3: enabling device (0000 -> 0002)
[ 5.793435] usb 1-2.2: new low-speed USB device number 4 using tegra-xusb
[ 5.824608] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c31c
[ 5.824614] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.824618] usb 1-2.2: Product: USB Keyboard
[ 5.824631] usb 1-2.2: Manufacturer: Logitech
[ 5.831436] input: Logitech USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:046D:C31C.0002/input/input5
[ 5.841096] igb 0001:01:00.3: added PHC on eth4
[ 5.841101] igb 0001:01:00.3: Intel(R) Gigabit Ethernet Network Connection
[ 5.841105] igb 0001:01:00.3: eth4: (PCIe:5.0Gb/s:Width x1) 00:54:5a:23:01:ec
[ 5.841190] igb 0001:01:00.3: eth4: PBA No: 106300-000
[ 5.841194] igb 0001:01:00.3: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 5.841360] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 5.842340] OF: PCI: host bridge /pcie@14140000 ranges:
[ 5.842356] OF: PCI: IO 0x34100000..0x341fffff -> 0x34100000
[ 5.842364] OF: PCI: MEM 0x12b0000000..0x12bfffffff -> 0x40000000
[ 5.842368] OF: PCI: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 5.893892] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3610000.xhci-2.2/input0
[ 5.897854] input: Logitech USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C31C.0003/input/input6
[ 5.949450] tegra-pcie-dw 14140000.pcie: link is up
[ 5.949599] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 5.949620] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 5.949627] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 5.949635] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 5.949640] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 5.949679] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 5.949818] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.950019] iommu: Adding device 0003:00:00.0 to group 66
[ 5.950286] pci 0003:01:00.0: [8086:4232] type 00 class 0x028000
[ 5.950439] pci 0003:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 5.951141] pci 0003:01:00.0: PME# supported from D0 D3hot D3cold
[ 5.951423] iommu: Adding device 0003:01:00.0 to group 67
[ 5.957627] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3610000.xhci-2.2/input1
[ 5.963101] pci 0003:00:00.0: BAR 14: assigned [mem 0x12b0000000-0x12b00fffff]
[ 5.963128] pci 0003:01:00.0: BAR 0: assigned [mem 0x12b0000000-0x12b0001fff 64bit]
[ 5.963208] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 5.963215] pci 0003:00:00.0: bridge window [mem 0x12b0000000-0x12b00fffff]
[ 5.963230] pci 0003:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 5.963287] pci 0003:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 5.963558] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.963562] pci 0003:01:00.0: Signaling PME through PCIe PME interrupt
[ 5.963568] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.963671] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 5.964084] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 5.964918] OF: PCI: host bridge /pcie@14160000 ranges:
[ 5.964930] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 5.964937] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 5.964941] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 6.073448] tegra-pcie-dw 14160000.pcie: link is up
[ 6.073674] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.073686] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.073693] pci_bus 0004:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x36100000-0x361fffff])
[ 6.073698] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 6.073702] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 6.073725] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 6.073873] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.074048] iommu: Adding device 0004:00:00.0 to group 68
[ 6.074435] pci 0004:01:00.0: [2646:2263] type 00 class 0x010802
[ 6.074596] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 6.075768] iommu: Adding device 0004:01:00.0 to group 69
[ 6.078298] scsi 0:0:0:0: Direct-Access WD Elements SE 2623 1034 PQ: 0 ANSI: 6
[ 6.079315] scsi 0:0:0:1: Enclosure WD SES Device 1034 PQ: 0 ANSI: 6
[ 6.079500] sd 0:0:0:0: [sda] 3906963456 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 6.080485] sd 0:0:0:0: [sda] Write Protect is off
[ 6.080492] sd 0:0:0:0: [sda] Mode Sense: 47 00 10 08
[ 6.081463] sd 0:0:0:0: [sda] No Caching mode page found
[ 6.081612] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 6.087134] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 6.087159] pci 0004:01:00.0: BAR 0: assigned [mem 0x1740000000-0x1740003fff 64bit]
[ 6.087241] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 6.087248] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 6.087265] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.087325] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.087596] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.087600] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.087605] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 6.087687] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 6.088032] nvme nvme0: pci function 0004:01:00.0
[ 6.088234] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 6.088408] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 6.088500] sda: sda1 sda2
[ 6.091361] sd 0:0:0:0: [sda] Attached SCSI disk
[ 6.197215] nvme0n1: p1
[ 6.306033] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 6.306055] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 6.306065] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 6.306071] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 6.413457] tegra-pcie-dw 141a0000.pcie: link is up
[ 6.413616] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 6.413631] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 6.413638] pci_bus 0005:00: root bus resource [io 0x400000-0x4fffff] (bus address [0x3a100000-0x3a1fffff])
[ 6.413657] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 6.413661] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 6.413683] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 6.413818] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.413998] iommu: Adding device 0005:00:00.0 to group 70
[ 6.414243] pci 0005:01:00.0: [8086:10fb] type 00 class 0x020000
[ 6.414362] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff 64bit]
[ 6.414405] pci 0005:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 6.414516] pci 0005:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 6.414558] pci 0005:01:00.0: reg 0x30: [mem 0x00000000-0x0007ffff pref]
[ 6.415020] pci 0005:01:00.0: PME# supported from D0 D3hot
[ 6.415234] pci 0005:01:00.0: reg 0x184: [mem 0x00000000-0x00003fff 64bit]
[ 6.415240] pci 0005:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x000fffff 64bit] (contains BAR0 for 64 VFs)
[ 6.415351] pci 0005:01:00.0: reg 0x190: [mem 0x00000000-0x00003fff 64bit]
[ 6.415355] pci 0005:01:00.0: VF(n) BAR3 space: [mem 0x00000000-0x000fffff 64bit] (contains BAR3 for 64 VFs)
[ 6.417082] iommu: Adding device 0005:01:00.0 to group 71
[ 6.417226] pci 0005:01:00.1: [8086:10fb] type 00 class 0x020000
[ 6.417356] pci 0005:01:00.1: reg 0x10: [mem 0x00000000-0x0007ffff 64bit]
[ 6.417445] pci 0005:01:00.1: reg 0x18: [io 0x0000-0x001f]
[ 6.417556] pci 0005:01:00.1: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 6.417599] pci 0005:01:00.1: reg 0x30: [mem 0x00000000-0x0007ffff pref]
[ 6.418057] pci 0005:01:00.1: PME# supported from D0 D3hot
[ 6.418270] pci 0005:01:00.1: reg 0x184: [mem 0x00000000-0x00003fff 64bit]
[ 6.418275] pci 0005:01:00.1: VF(n) BAR0 space: [mem 0x00000000-0x000fffff 64bit] (contains BAR0 for 64 VFs)
[ 6.418386] pci 0005:01:00.1: reg 0x190: [mem 0x00000000-0x00003fff 64bit]
[ 6.418390] pci 0005:01:00.1: VF(n) BAR3 space: [mem 0x00000000-0x000fffff 64bit] (contains BAR3 for 64 VFs)
[ 6.420107] iommu: Adding device 0005:01:00.1 to group 72
[ 6.431083] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f406fffff]
[ 6.431090] pci 0005:00:00.0: BAR 13: assigned [io 0x400000-0x400fff]
[ 6.431102] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f4007ffff 64bit]
[ 6.431165] pci 0005:01:00.0: BAR 6: assigned [mem 0x1f40080000-0x1f400fffff pref]
[ 6.431170] pci 0005:01:00.1: BAR 0: assigned [mem 0x1f40100000-0x1f4017ffff 64bit]
[ 6.431229] pci 0005:01:00.1: BAR 6: assigned [mem 0x1f40180000-0x1f401fffff pref]
[ 6.431233] pci 0005:01:00.0: BAR 4: assigned [mem 0x1f40200000-0x1f40203fff 64bit]
[ 6.431307] pci 0005:01:00.0: BAR 7: assigned [mem 0x1f40204000-0x1f40303fff 64bit]
[ 6.431335] pci 0005:01:00.0: BAR 10: assigned [mem 0x1f40304000-0x1f40403fff 64bit]
[ 6.431363] pci 0005:01:00.1: BAR 4: assigned [mem 0x1f40404000-0x1f40407fff 64bit]
[ 6.431430] pci 0005:01:00.1: BAR 7: assigned [mem 0x1f40408000-0x1f40507fff 64bit]
[ 6.431459] pci 0005:01:00.1: BAR 10: assigned [mem 0x1f40508000-0x1f40607fff 64bit]
[ 6.431486] pci 0005:01:00.0: BAR 2: assigned [io 0x400000-0x40001f]
[ 6.431505] pci 0005:01:00.1: BAR 2: assigned [io 0x400020-0x40003f]
[ 6.431528] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 6.431533] pci 0005:00:00.0: bridge window [io 0x400000-0x400fff]
[ 6.431539] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f406fffff]
[ 6.431553] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.431595] pci 0005:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.431646] pci 0005:01:00.1: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.431852] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.431856] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.431859] pci 0005:01:00.1: Signaling PME through PCIe PME interrupt
[ 6.431865] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 6.431944] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 6.432186] ixgbe 0005:01:00.0: enabling device (0000 -> 0002)
[ 6.769670] usb 2-1.3: new SuperSpeed USB device number 4 using tegra-xusb
[ 6.790270] usb 2-1.3: New USB device found, idVendor=0bda, idProduct=8153
[ 6.790275] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 6.790294] usb 2-1.3: Product: USB 10/100/1000 LAN
[ 6.790297] usb 2-1.3: Manufacturer: Realtek
[ 6.790300] usb 2-1.3: SerialNumber: 001000001
[ 6.881828] usb 2-1.3: reset SuperSpeed USB device number 4 using tegra-xusb
[ 6.942091] r8152 2-1.3:1.0 eth5: v2.09.00 (2017/08/21)
[ 6.942097] r8152 2-1.3:1.0 eth5: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 7.900815] ixgbe 0005:01:00.0: Multiqueue Enabled: Rx Queue count = 8, Tx Queue count = 8
[ 7.900978] ixgbe 0005:01:00.0: PCI Express bandwidth of 32GT/s available
[ 7.900982] ixgbe 0005:01:00.0: (Speed:5.0GT/s, Width: x8, Encoding Loss:20%)
[ 7.901121] ixgbe 0005:01:00.0: MAC: 2, PHY: 1, PBA No: Unknown
[ 7.901124] ixgbe 0005:01:00.0: 00:1b:21:bc:fc:48
[ 7.904625] ixgbe 0005:01:00.0: Intel(R) 10 Gigabit Network Connection
[ 7.905009] ixgbe 0005:01:00.1: enabling device (0000 -> 0002)
[ 9.090760] ixgbe 0005:01:00.1: Multiqueue Enabled: Rx Queue count = 8, Tx Queue count = 8
[ 9.090911] ixgbe 0005:01:00.1: PCI Express bandwidth of 32GT/s available
[ 9.090917] ixgbe 0005:01:00.1: (Speed:5.0GT/s, Width: x8, Encoding Loss:20%)
[ 9.091050] ixgbe 0005:01:00.1: MAC: 2, PHY: 1, PBA No: Unknown
[ 9.091054] ixgbe 0005:01:00.1: 00:1b:21:bc:fc:49
[ 9.095304] ixgbe 0005:01:00.1: Intel(R) 10 Gigabit Network Connection
[ 9.108746] tegra-cbb 14040000.cv-noc: noc_secure_irq = 97, noc_nonsecure_irq = 96>
[ 9.113313] tegra194-isp5 14800000.isp: initialized
[ 9.118826] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 9.121574] tegra194-vi5 15c10000.vi: initialized
[ 9.125072] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--8 bound
[ 9.125165] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--7 bound
[ 9.125227] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--6 bound
[ 9.125288] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--5 bound
[ 9.125349] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--4 bound
[ 9.125456] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--3 bound
[ 9.125522] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 9.125583] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 9.125805] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 9.179817] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 9.179858] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 9.179863] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 9.179942] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 9.179988] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 9.179992] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 9.185058] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 9.185095] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 9.185099] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 9.185413] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 9.185439] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 9.185443] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 9.185883] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 9.185926] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 9.185931] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 9.186229] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 9.187038] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 9.261271] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 9.261586] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 9.261821] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 9.261993] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 9.262335] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 9.262400] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 9.262614] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (73)
[ 9.262618] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 9.263546] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=1d7bd17f78528535d57449fa59ec355e37add4f8
[ 9.267016] ERROR: could not get clock /spi@c260000:osc(2)
[ 9.267616] ERROR: could not get clock /spi@c260000:osc(2)
[ 9.277133] mcp25xxfd spi1.0: Cannot initialize MCP2517. Wrong wiring?
[ 9.277320] mcp25xxfd spi1.0: Probe failed, err=19
[ 9.311774] tegra_rtc c2a0000.rtc: setting system clock to 2022-04-21 03:34:33 UTC (1650512073)
[ 9.311960] imx185 2-001b: probing v4l2 sensor
[ 9.312359] imx185 2-001b: tegracam sensor driver:imx185_v2.0.6
[ 9.312777] tegra194-vi5 15c10000.vi: subdev imx185 2-001b bound
[ 9.314229] imx185 2-001b: Detected IMX185 sensor
[ 9.314279] imx185 2-001c: probing v4l2 sensor
[ 9.314483] imx185 2-001c: tegracam sensor driver:imx185_v2.0.6
[ 9.315348] tegra194-vi5 15c10000.vi: subdev imx185 2-001c bound
[ 9.315886] imx185 2-001c: Detected IMX185 sensor
[ 9.315963] imx185 2-001d: probing v4l2 sensor
[ 9.316159] imx185 2-001d: tegracam sensor driver:imx185_v2.0.6
[ 9.317268] tegra194-vi5 15c10000.vi: subdev imx185 2-001d bound
[ 9.317665] imx185 2-001d: Detected IMX185 sensor
[ 9.317707] imx185 2-001e: probing v4l2 sensor
[ 9.317846] imx185 2-001e: tegracam sensor driver:imx185_v2.0.6
[ 9.318514] tegra194-vi5 15c10000.vi: subdev imx185 2-001e bound
[ 9.319054] imx185 2-001e: Detected IMX185 sensor
[ 9.319107] imx185 2-001f: probing v4l2 sensor
[ 9.319374] imx185 2-001f: tegracam sensor driver:imx185_v2.0.6
[ 9.320442] tegra194-vi5 15c10000.vi: subdev imx185 2-001f bound
[ 9.320865] imx185 2-001f: Detected IMX185 sensor
[ 9.320909] imx185 2-0020: probing v4l2 sensor
[ 9.321075] imx185 2-0020: tegracam sensor driver:imx185_v2.0.6
[ 9.321848] tegra194-vi5 15c10000.vi: subdev imx185 2-0020 bound
[ 9.322331] imx185 2-0020: Detected IMX185 sensor
[ 9.322368] imx185 2-0021: probing v4l2 sensor
[ 9.322496] imx185 2-0021: tegracam sensor driver:imx185_v2.0.6
[ 9.322968] tegra194-vi5 15c10000.vi: subdev imx185 2-0021 bound
[ 9.323463] imx185 2-0021: Detected IMX185 sensor
[ 9.323516] imx185 2-0022: probing v4l2 sensor
[ 9.323671] imx185 2-0022: tegracam sensor driver:imx185_v2.0.6
[ 9.324178] tegra194-vi5 15c10000.vi: subdev imx185 2-0022 bound
[ 9.324702] imx185 2-0022: Detected IMX185 sensor
[ 9.325226] mmcblk mmc0:0001: Card claimed for testing.
[ 9.365895] bpmp: mounted debugfs mirror
[ 9.371824] ALSA device list:
[ 9.371830] #0: tegra-hda-galen-t194 at 0x3518000 irq 72
[ 9.373238] Freeing unused kernel memory: 8768K
[ 9.397773] tztek_initrd Starting L4T initial RAM disk
[ 9.400054] tztek_initrd TZTEK initrd Version: 2.0.0
[ 10.094293] tztek_initrd Get Rootdev = /dev/mmcblk0p1
[ 10.098352] tztek_initrd Set Rootdev : /dev/mmcblk0p1
[ 10.102231] tztek_initrd Operated Rootdev = /dev/mmcblk0p1
[ 10.106255] tztek_initrd Found dev node: /dev/mmcblk0p1
[ 10.114606] tztek_initrd tztek--- /dev/mmcblk0p1
[ 10.142400] /dev/mmcblk0p1: clean, 170020/1835008 files, 1760945/7340032 blocks
[ 10.164638] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.168765] tztek_initrd SUCCESS: /dev/mmcblk0p1 mount success
[ 10.172444] tztek_initrd SUCCESS: /dev/mmcblk0p1 mount ok!
[ 10.176532] tztek_initrd Rootfs mounted over /dev/mmcblk0p1
[ 10.319176] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.322759] cgroup: cgroup2: unknown option "nsdelegate"
[ 10.331656] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 10.332272] systemd[1]: Detected architecture arm64.
[ 10.338673] systemd[1]: Set hostname to <nvidia-desktop>.
[ 10.432674] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 10.432685] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 10.561979] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.564407] systemd[1]: Created slice User and Session Slice.
[ 10.564539] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.564571] systemd[1]: Reached target User and Group Name Lookups.
[ 10.564604] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.564622] systemd[1]: Reached target Swap.
[ 10.564745] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.565738] systemd[1]: Created slice System Slice.
[ 10.604611] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 10.956850] systemd-journald[3014]: Received request to flush runtime journal from PID 1
[ 11.578817] using random self ethernet address
[ 11.580645] using random host ethernet address
[ 11.697146] random: crng init done
[ 11.698659] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.820170] Intel(R) Wireless WiFi driver for Linux
[ 11.820177] Copyright(c) 2003- 2015 Intel Corporation
[ 11.826742] iwlwifi 0003:01:00.0: enabling device (0000 -> 0002)
[ 11.838527] iwlwifi 0003:01:00.0: loaded firmware version 8.83.5.1 build 33692 op_mode iwldvm
[ 11.984040] iwlwifi 0003:01:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 11.984047] iwlwifi 0003:01:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 11.984051] iwlwifi 0003:01:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
[ 11.984055] iwlwifi 0003:01:00.0: Detected Intel(R) WiFi Link 5100 AGN, REV=0x54
[ 11.985516] iwlwifi 0003:01:00.0: L1 Disabled - LTR Disabled
[ 12.015908] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 12.134385] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 12.137282] net eth0: get_configure_l3v4_filter -->
[ 12.138602] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.156294] Mass Storage Function, version: 2009/09/11
[ 12.156303] LUN: removable file: (no medium)
[ 12.162972] using random self ethernet address
[ 12.164816] using random host ethernet address
[ 12.271103] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 12.388728] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 12.521585] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
[ 12.643470] IPv6: ADDRCONF(NETDEV_UP): eth4: link is not ready
[ 12.661323] IPv6: ADDRCONF(NETDEV_UP): eth5: link is not ready
[ 12.709090] ixgbe 0005:01:00.0: registered PHC device on eth6
[ 12.744021] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 12.815881] IPv6: ADDRCONF(NETDEV_UP): eth6: link is not ready
[ 12.872914] ixgbe 0005:01:00.1: registered PHC device on eth7
[ 12.980453] IPv6: ADDRCONF(NETDEV_UP): eth7: link is not ready
[ 12.982499] rndis0: HOST MAC 2a:48:35:85:26:1c
[ 12.982623] rndis0: MAC 2a:48:35:85:26:1d
[ 12.983750] usb0: HOST MAC 2a:48:35:85:26:1e
[ 12.983792] usb0: MAC 2a:48:35:85:26:1f
[ 12.983817] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 13.016796] iwlwifi 0003:01:00.0: L1 Disabled - LTR Disabled
[ 13.020900] iwlwifi 0003:01:00.0: L1 Disabled - LTR Disabled
[ 13.021070] iwlwifi 0003:01:00.0: Radio type=0x1-0x2-0x0
[ 13.044736] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 13.044766] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 13.044813] tegra-xudc-new 3550000.xudc: entering ELPG
[ 13.131258] iwlwifi 0003:01:00.0: L1 Disabled - LTR Disabled
[ 13.134371] iwlwifi 0003:01:00.0: L1 Disabled - LTR Disabled
[ 13.134506] iwlwifi 0003:01:00.0: Radio type=0x1-0x2-0x0
[ 13.194212] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 13.200086] l4tbr0: port 1(rndis0) entered blocking state
[ 13.200096] l4tbr0: port 1(rndis0) entered disabled state
[ 13.200321] device rndis0 entered promiscuous mode
[ 13.208519] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 13.214699] l4tbr0: port 2(usb0) entered blocking state
[ 13.214711] l4tbr0: port 2(usb0) entered disabled state
[ 13.215497] device usb0 entered promiscuous mode
[ 13.222488] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 13.225020] l4tbr0: port 2(usb0) entered blocking state
[ 13.225031] l4tbr0: port 2(usb0) entered forwarding state
[ 13.225508] l4tbr0: port 1(rndis0) entered blocking state
[ 13.225522] l4tbr0: port 1(rndis0) entered forwarding state
[ 13.257321] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 13.257359] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 13.392884] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 13.392907] tegra-xudc-new 3550000.xudc: entering ELPG
[ 13.393799] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 13.601011] zram: Added device: zram0
[ 13.602247] zram: Added device: zram1
[ 13.603066] zram: Added device: zram2
[ 13.606434] zram: Added device: zram3
[ 13.607500] zram: Added device: zram4
[ 13.613062] zram: Added device: zram5
[ 13.614474] zram: Added device: zram6
[ 13.617437] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.622789] zram: Added device: zram7
[ 13.642355] zram0: detected capacity change from 0 to 2091864064
[ 13.643752] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 13.684773] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 13.721052] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
[ 13.737822] Adding 2042832k swap on /dev/zram0. Priority:5 extents:1 across:2042832k SS
[ 13.744004] zram1: detected capacity change from 0 to 2091864064
[ 13.777216] IPv6: ADDRCONF(NETDEV_UP): eth4: link is not ready
[ 13.782285] Adding 2042832k swap on /dev/zram1. Priority:5 extents:1 across:2042832k SS
[ 13.786646] zram2: detected capacity change from 0 to 2091864064
[ 13.816166] Adding 2042832k swap on /dev/zram2. Priority:5 extents:1 across:2042832k SS
[ 13.821122] zram3: detected capacity change from 0 to 2091864064
[ 13.823224] IPv6: ADDRCONF(NETDEV_UP): eth5: link is not ready
[ 13.838087] Adding 2042832k swap on /dev/zram3. Priority:5 extents:1 across:2042832k SS
[ 13.845642] zram4: detected capacity change from 0 to 2091864064
[ 13.856820] IPv6: ADDRCONF(NETDEV_UP): eth6: link is not ready
[ 13.862607] Adding 2042832k swap on /dev/zram4. Priority:5 extents:1 across:2042832k SS
[ 13.867877] zram5: detected capacity change from 0 to 2091864064
[ 13.882966] Adding 2042832k swap on /dev/zram5. Priority:5 extents:1 across:2042832k SS
[ 13.887161] zram6: detected capacity change from 0 to 2091864064
[ 13.894361] IPv6: ADDRCONF(NETDEV_UP): eth7: link is not ready
[ 13.905683] Adding 2042832k swap on /dev/zram6. Priority:5 extents:1 across:2042832k SS
[ 13.910229] zram7: detected capacity change from 0 to 2091864064
[ 13.928180] Adding 2042832k swap on /dev/zram7. Priority:5 extents:1 across:2042832k SS
[ 13.938694] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 13.981655] l4tbr0: port 1(rndis0) entered disabled state
[ 13.981934] l4tbr0: port 2(usb0) entered disabled state
[ 14.341611] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 14.656587] Bridge firewalling registered
[ 14.698793] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 14.937736] Netfilter messages via NETLINK v0.30.
[ 14.945954] ctnetlink v0.93: registering with nfnetlink.
[ 14.971842] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 15.155903] tegradc 15200000.nvdisplay: unblank
[ 15.809576] usb 1-4: new high-speed USB device number 6 using tegra-xusb
[ 15.856881] usb 1-4: New USB device found, idVendor=1c9e, idProduct=9b3c
[ 15.856896] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 15.856902] usb 1-4: Product: USB Modem
[ 15.856908] usb 1-4: Manufacturer: LONGSUNG
[ 15.906126] option 1-4:1.0: GSM modem (1-port) converter detected
[ 15.906691] usb 1-4: GSM modem (1-port) converter now attached to ttyUSB0
[ 15.907074] option 1-4:1.1: GSM modem (1-port) converter detected
[ 15.907535] usb 1-4: GSM modem (1-port) converter now attached to ttyUSB1
[ 15.907879] option 1-4:1.2: GSM modem (1-port) converter detected
[ 15.908224] usb 1-4: GSM modem (1-port) converter now attached to ttyUSB2
[ 15.908642] option 1-4:1.3: GSM modem (1-port) converter detected
[ 15.909000] usb 1-4: GSM modem (1-port) converter now attached to ttyUSB3
[ 15.910057] GobiNet-LS 1-4:1.4: work on RawIP mode
[ 15.911524] GobiNet-LS 1-4:1.4 eth40: register 'GobiNet-LS' at usb-3610000.xhci-4, GobiNet Ethernet Device, 32:a9:3b:26:c9:af
[ 15.912139] creating qcqmi40
[ 15.912364] Create QmiDevice end ...
[ 15.912370] GobiNet is initializing...
[ 16.034886] GobiNet-LS 1-4:1.4 eth40: kevent 12 may have been dropped
[ 16.035168] GobiNet-LS 1-4:1.4 eth40: kevent 12 may have been dropped
[ 16.035298] GobiNet-LS 1-4:1.4 eth40: kevent 12 may have been dropped
[ 16.035523] GobiNet-LS 1-4:1.4 eth40: kevent 12 may have been dropped
[ 16.035705] GobiNet-LS 1-4:1.4 eth40: kevent 12 may have been dropped
[ 16.077351] fuse init (API version 7.26)
[ 18.634245] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.634270] Bluetooth: BNEP socket layer initialized
[ 23.692578] QMI CTL Sync Procedure Successful.....
[ 24.044605] GobiNet init OK...
[ 29.942358] tegradc 15200000.nvdisplay: blank - powerdown
[ 30.005237] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 30.005242] Extcon AUX2(HDMI) disable
[ 30.028140] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 30.028793] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 30.243557] tegradc 15200000.nvdisplay: blank - powerdown
[ 30.243579] tegradc 15200000.nvdisplay: unblank
[ 30.244819] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 30.244980] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 30.256110] Parent Clock set for DC plld3
[ 30.260552] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 30.262009] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 30.299484] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 30.299488] Extcon AUX2(HDMI) enable
[ 30.299555] tegradc 15200000.nvdisplay: unblank
[ 35.783591] tegradc 15200000.nvdisplay: unblank
[ 38.438549] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 40.317625] vdd-1v8-cvb: disabling
[ 40.317636] vdd-1v8-sd: disabling
[ 40.317640] vdd-epb-1v0: disabling
[ 40.317644] vdd-sdmmc1-sw: disabling
[ 40.317649] avdd-cam-2v8: disabling
[ 40.317654] vdd-sata-1v5: disabling
[ 40.317658] vdd-3v3-slt: disabling
[ 40.317662] vdd-fan: disabling
[ 40.317667] vdd_sys_en: disabling
[ 40.317670] vdd-5v-sata: disabling
err… no. I mean the log when you run flash.sh on your host machine…
Hello, I have found the reason. We changed the compilation environment, resulting in that 16g and 32g use the same dtsi file. Thank you for your help. I wish you good health
