hi,
Below is the full dmesg infor:
[0000.279] I> MB1 (prd-version: 1.1.0.0-t194-41334769-514a1108)
[0000.285] I> Boot-mode: L0 coldboot
[0000.288] I> Chip revision : A02
[0000.291] I> Bootrom patch version : 7 (correctly patched)
[0000.296] I> ATE fuse revision : 0x200
[0000.300] I> Ram repair fuse : 0x0
[0000.303] I> Ram Code : 0x0
[0000.305] I> rst_source : 0x0
[0000.308] I> rst_level : 0x0
[0000.311] I> Boot-device: eMMC
[0000.314] W> DEVICE_PROD: device prod is not initialized.
[0000.319] W> DEVICE_PROD: device prod is not initialized.
[0000.336] I> sdmmc DDR50 mode
[0000.340] W> DEVICE_PROD: device prod is not initialized.
[0000.346] W> No valid slot number is found in scratch register
[0000.351] W> Return default slot: _a
[0000.354] I> Active Boot chain : 0
[0000.358] I> Boot-device: eMMC
[0000.361] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.367] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0000.375] I> Temperature = 27000
[0000.378] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.382] W> Skipping boost for clk: BPMP_APB
[0000.386] W> Skipping boost for clk: AXI_CBB
[0000.390] W> Skipping boost for clk: AON_CPU_NIC
[0000.394] W> Skipping boost for clk: CAN1
[0000.398] W> Skipping boost for clk: CAN2
[0000.402] I> Boot-device: eMMC
[0000.405] I> Boot-device: eMMC
[0000.415] I> Sdmmc: HS400 mode enabled
[0000.423] I> ECC region[0]: Start:0x0, End:0x0
[0000.427] I> ECC region[1]: Start:0x0, End:0x0
[0000.431] I> ECC region[2]: Start:0x0, End:0x0
[0000.435] I> ECC region[3]: Start:0x0, End:0x0
[0000.439] I> ECC region[4]: Start:0x0, End:0x0
[0000.443] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.449] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.453] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.458] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.462] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.468] W> MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.475] E> FAILED: Thermal config
[0000.478] W> DEVICE_PROD: device prod is not initialized.
[0000.483] W> DEVICE_PROD: device prod is not initialized.
[0000.492] W> MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.499] E> FAILED: MEMIO rail config
[0000.514] I> scrub mode: full dram
[0000.517] E> FUSE: Failed to verify ECID.
[0000.531] I> sdmmc bdev is already initialized
[0000.567] W> No fuse-bypass data
[0000.575] W> MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.600] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.608] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-30577644)
[0000.609] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.609] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.610] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.616] W> device prod register failed
[0000.620] I> Boot-device: eMMC
[0000.623] I> Boot_device: SDMMC_BOOT instance: 3
[0000.630] I> sdmmc-3 params source = boot args
[0000.631] I> sdmmc bdev is already initialized
[0000.636] I> sdmmc-3 params source = boot args
[0000.642] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0000.649] I> Found 37 partitions in SDMMC_USER (instance 3)
[0000.651] W> No valid slot number is found in scratch register
[0000.656] W> Return default slot: _a
[0000.660] I> Active Boot chain : 0
[0000.664] I> parsing oem signed section of bpmp-fw header done
[0000.669] I> bpmp-fw binary init read from storage
[0000.674] I> oem authentication of bpmp-fw header done
[0000.680] I> bpmp-fw binary done read from storage
[0000.683] I> bpmp-fw: Authentication init Done
[0000.688] I> parsing oem signed section of cpubl header done
[0000.693] I> cpubl binary init read from storage
[0000.697] I> bpmp-fw: Authentication Finalize Done
[0000.702] I> oem authentication of cpubl header done
[0000.707] I> cpubl binary done read from storage
[0000.711] I> cpubl: Authentication init Done
[0000.716] I> parsing oem signed section of rce header done
[0000.721] I> rce binary init read from storage
[0000.725] I> Relocating BR-BCT
[0000.728] I> cpubl: Authentication Finalize Done
[0000.733] I> oem authentication of rce header done
[0000.737] I> rce binary done read from storage
[0000.741] I> rce: Authentication init Done
[0000.746] I> parsing oem signed section of tos header done
[0000.751] I> tos binary init read from storage
[0000.755] I> rce: Authentication Finalize Done
[0000.759] I> oem authentication of tos header done
[0000.764] I> tos binary done read from storage
[0000.768] I> tos: Authentication init Done
[0000.773] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.778] I> bpmp-fw-dtb binary init read from storage
[0000.783] I> tos: Authentication Finalize Done
[0000.788] I> oem authentication of bpmp-fw-dtb header done
[0000.796] I> bpmp-fw-dtb binary done read from storage
[0000.798] I> bpmp-fw-dtb: Authentication init Done
[0000.803] I> parsing oem signed section of cpubl-dtb header done
[0000.808] I> cpubl-dtb binary init read from storage
[0000.813] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.850] I> oem authentication of cpubl-dtb header done
[0000.851] I> cpubl-dtb binary done read from storage
[0000.851] I> cpubl-dtb: Authentication init Done
[0000.852] I> cpubl-dtb: Authentication Finalize Done
▒▒NOTICE: BL31: v1.3(release):eca0c5e
NOTICE: BL31: Built : 00:20:29, Mar 13 2019
ERROR: Error initializing runtime service trusty_fast
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 1c1b2165fe52a0a54ad7caf60d40cdc3
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
387 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
mrq initialized
[0001.312] I> Welcome to Cboot
[0001.312] I> Cboot Version▒▒fmon_post initialized
▒▒: t194-187516be
[0001.313] I> CPU-BL Params @ 0xea820000
[0001.313] I> 0) Base:0x00000000 Size:0x00000000
[0001.314] I> 1) Base:0xea100000 Size:0x00100000
[0001.318] I> 2) Base:0xea000000 Size:0x00100000
[0001.322] I> 3) Base:0xe9300000 Size:0x00100000
[0001.326] I> 4) Base:0xe9200000 Size:0x00100000
[0001.331] I> 5) Base:0xe9100000 Size:0x00100000
[0001.335] I> 6) Base:0xeb800000 Size:0x00400000
[0001.339] I> 7) Base:0xe9c00000 Size:0x00400000▒▒clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_pcie initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
[0001.409] I> 8) Base:0xe9000000 Size:0x00100000
[0001.413] I> 9) Base:0xe8f00000 Size:0x00100000
[0001.418] I> 10) Base:0xeb000000 Size:0x00800000
[0001.422] I> 11) Base:0x40000000 Size:0x00040000
[0001.427] I> 12) Base:0xe8e00000 Size:0x00100000
[0001.431] I> 13) Base:0x40046000 Size:0x00002000
[0001.436] I> 14) Base:0x40048000 Size:0x00002000
[0001.440] I> 15) Base:0xab000000 Size:0x00004000
[0001.445] I> 16) Base:0x4004a000 Size:0x00002000
[0001.449] I> 17) Base:0xe8d00000 Size:0x00100000
[0001.453] I> 18) Base:0x4004c000 Size:0x00002000
[0001.458] I> 19) Base:0xea200000 Size:0x00600000
[0001.462] I> 20) Base:0x4004e000 Size:0x00002000
▒▒emc_debugfs initialized
▒▒[0001.467] I> 21) Base:0xe8cd0000 Size:0x0000c000
▒▒dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.474] I> 22) Base:0x00000000 Size:0x00000000
[0001.524] I> 23) Base:0xe8ce0000 Size:0x00020000
[0001.529] I> 24) Base:0xee000000 Size:0x02000000
[0001.533] I> 25) Base:0x40050000 Size:0x00002000
[0001.538] I> 26) Base:0x40040000 Size:0x00006000
[0001.542] I> 27) Base:0xe9800000 Size:0x00400000
[0001.546] I> 28) Base:0xecc00000 Size:0x01400000
[0001.551] I> 29) Base:0xe9400000 Size:0x00400000
[0001.555] I> 30) Base:0x00000000 Size:0x00000000
[0001.560] I> 31) Base:0x00000000 Size:0x00000000
[0001.564] I> 32) Base:0xf8000000 Size:0x08000000
[0001.569] I> 33) Base:0xf0000000 Size:0x08000000
[0001.573] I> 34) Base:0xebc00000 Size:0x01000000
[0001.578] I> 35) Base:0xaa000000 Size:0x01000000
[0001.582] I> 36) Base:0xa0000000 Size:0x0a000000
[0001.587] I> 37) Base:0xea800000 Size:0x00800000
[0001.591] I> 38) Base:0x80000000 Size:0x20000000
[0001.596] I> 39) Base:0xb0000000 Size:0x08000000
[0001.600] I> 40) Base:0x00000000 Size:0x00000000
[0001.604] I> 41) Base:0x00000000 Size:0x00000000
[0001.609] I> 42) Base:0x00000000 Size:0x00000000
[0001.613] I> 43) Base:0x00000000 Size:0x00000000
[0001.618] I> 44) Base:0x00000000 Size:0x00000000
[0001.622] I> 45) Base:0x00000000 Size:0x00000000
[0001.627] GIC-SPI Target CPU: 0
[0001.630] Interrupts Init done
[0001.633] calling constructors
[0001.636] initializing heap
[0001.638] I> Heap: [0xa068d430 ... 0xaa000000]
[0001.642] initializing threads
[0001.645] initializing timers
[0001.648] creating bootstrap completion thread
[0001.652] top of bootstrap2()
[0001.655] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.660] initializing platform
[0001.663] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.668] W> device prod register failed
[0001.672] I> Bl_dtb @0xa9f00000
[0001.675] I> gpio framework initialized
[0001.686] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.692] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.694] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.704] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.711] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.716] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.722] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.730] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.737] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.743] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.751] I> fixed regulator driver initialized
[0001.763] I> register 'maxim' power off handle
[0001.764] I> virtual i2c enabled
[0001.764] I> registered 'maxim,max20024' pmic
[0001.766] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.772] I> Boot-device: eMMC
[0001.775] I> Boot_device: SDMMC_BOOT instance: 3
[0001.781] I> sdmmc-3 params source = boot args
[0001.784] I> sdmmc bdev is already initialized
[0001.788] I> sdmmc-3 params source = boot args
[0001.794] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0001.800] I> Found 37 partitions in SDMMC_USER (instance 3)
[0001.804] E> "plugin-manager" doesn't exist, creating
[0001.808] E> "ids" doesn't exist, creating
[0001.812] E> "connection" doesn't exist, creating
[0001.817] E> "configs" doesn't exist, creating
[0001.822] I> Find /i2c@3160000's alias i2c0
[0001.825] I> Reading eeprom i2c=0 address=0x50
[0001.855] I> Device at /i2c@3160000:0x50
[0001.856] I> Reading eeprom i2c=0 address=0x56
[0001.881] I> Device at /i2c@3160000:0x56
[0001.882] I> Find /i2c@3180000's alias i2c2
[0001.883] I> Reading eeprom i2c=2 address=0x54
[0001.884] E> I2C: slave not found in slaves.
[0001.885] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.886] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.886] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.895] E> eeprom: Failed to read I2C slave device
[0001.900] I> Eeprom read failed 0x3526070d
[0001.904] I> Reading eeprom i2c=2 address=0x57
[0001.908] E> I2C: slave not found in slaves.
[0001.912] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.920] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.926] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.935] E> eeprom: Failed to read I2C slave device
[0001.940] I> Eeprom read failed 0x3526070d
[0001.944] I> Reading eeprom i2c=2 address=0x52
[0001.948] E> I2C: slave not found in slaves.
[0001.952] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.960] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.966] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.975] E> eeprom: Failed to read I2C slave device
[0001.980] I> Eeprom read failed 0x3526070d
[0001.985] I> Find /i2c@c240000's alias i2c1
[0001.988] I> Reading eeprom i2c=1 address=0x52
[0001.994] E> I2C: slave not found in slaves.
[0001.996] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.004] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.010] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.019] E> eeprom: Retry to read I2C slave device.
[0002.024] E> I2C: slave not found in slaves.
[0002.028] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.036] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.042] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.051] E> eeprom: Failed to read I2C slave device
[0002.056] I> Eeprom read failed 0x3526070d
[0002.060] I> Reading eeprom i2c=1 address=0x50
[0002.065] E> I2C: slave not found in slaves.
[0002.068] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.076] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.082] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.091] E> eeprom: Retry to read I2C slave device.
[0002.096] E> I2C: slave not found in slaves.
[0002.100] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.108] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.114] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.123] E> eeprom: Failed to read I2C slave device
[0002.128] I> Eeprom read failed 0x3526070d
[0002.132] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0002.137] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.148] I> create_pm_ids: id: 2822-0000-600-D, len: 15
[0002.153] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.164] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0002.173] E> "i2c@3160000" doesn't exist, creating
[0002.176] E> "module@0x50" doesn't exist, creating
[0002.181] I> Adding plugin-manager/ids/2822-0000-600=/i2c@3160000:module@0x56
[0002.188] E> "module@0x56" doesn't exist, creating
[0002.193] I> Adding plugin-manager/cvm
[0002.196] E> "chip-id" doesn't exist, creating
[0002.200] I> Adding plugin-manager/chip-id/A02
[0002.205] I> Plugin-manager override starting
[0002.209] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.218] I> node /plugin-manager/fragement-soft-wdt matches
[0002.223] I> node /plugin-manager/fragment-pcie-c1-rp matches
[0002.226] I> node /plugin-manager/fragment-pcie-p2822-B00 matches
[0002.236] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.241] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.244] I> node /plugin-manager/pwm-fan-polarity matches
[0002.255] I> node /plugin-manager/ufs-cd matches
[0002.258] I> node /plugin-manager/fragment-p2888@0 matches
[0002.269] I> Disable plugin-manager status in FDT
[0002.270] I> Plugin-manager override finished successfully
[0002.280] I> enabling 'vdd-hdmi-5v0' regulator
[0002.285] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.286] I> hdmi cable connected
[0002.288] E> set volts not configured for 'vdd-1v0'
[0002.291] E> set volts not configured for 'vdd-1v8-hs'
[0002.296] E> invalid display type
[0002.302] E> invalid display type
[0002.304] E> cannot find any other nvdisp nodes
[0002.310] E> I2C: slave not found in slaves.
[0002.310] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.313] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.318] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 at 0x00000000 via instance 6.
[0002.328] E> could not read edid
[0002.335] I> hdmi_enable, starting HDMI initialisation
[0002.340] I> hdmi_enable, HDMI initialisation complete
[0002.352] I> Load in CBoot Boot Options partition and parse it
[0002.354] E> Error -9 when finding node with path /boot-configuration
[0002.355] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.360] I> Hit any key to stop autoboot: 4 3 2 1
[0004.368] initializing target
[0004.368] calling apps_init()
[0004.369] starting app kernel_boot_app
[0004.372] I> found decompressor handler: lz4-legacy
[0004.373] I> decompressing BMP blob ...
[0004.378] I> Kernel type = Normal
[0004.378] I> Loading kernel & kernel-dtb from removable storage (5)
[0004.379] I> No sdcard
[0004.379] I> -0 params source =
[0004.379] E> Blockdev open: exit error
[0004.379] I> Loading kernel & kernel-dtb from removable storage (6)
[0004.390] W> No valid slot number is found in scratch register
[0004.390] W> Return default slot: _a
[0004.395] I> USB Firmware Version: 60.05 release
[0004.850] E> failed to initialize xhci controller
[0004.851] E> Error in init of XUSB host driver, err: 79790026
[0004.851] W> Failed to initialize device 6-0
[0004.851] I> Loading kernel/boot.img from built-in storage ...
[0004.852] W> No valid slot number is found in scratch register
[0004.852] W> Return default slot: _a
[0004.854] I> A/B: bin_type (37) slot 0
[0004.858] I> Loading partition kernel at 0xa4ad0000 from device(0x1)
[0005.245] W> No valid slot number is found in scratch register
[0005.245] W> Return default slot: _a
[0005.245] I> A/B: bin_type (38) slot 0
[0005.246] I> Loading partition kernel-dtb at 0x90000000 from device(0x1)
[0005.249] I> T19x: Authenticate boot.img (bin_type: 37), max size 0x4000000
[0005.596] I> T19x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type: 38), max size 0x400000
[0005.601] I> Kernel hdr @0xa4ad0000
[0005.601] I> Kernel dtb @0x90000000
[0005.602] I> Checking boot.img header magic ... [0005.602] I> [OK]
[0005.602] I> Valid boot.img @ 0xa4ad0000
[0005.602] I> decompressor handler not found
[0005.603] I> Copying kernel image (34048008 bytes) from 0xa4ad0800 to 0x80080000 ... [0005.625] I> Done
[0005.625] I> Move ramdisk (len: 0) from 0xa6b49800 to 0x91000000
[0005.626] I> Updated bpmp info to DTB
[0005.628] I> Ramdisk: Base: 0x91000000; Size: 0x0
[0005.628] I> Updated initrd info to DTB
[0005.628] W> WARN: Fail to override "console=none" in commandline
[0005.633] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0005.640] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0005.647] W> No valid slot number is found in scratch register
[0005.653] W> Return default slot: _a
[0005.656] I> Active slot suffix:
[0005.660] I> add_boot_slot_suffix: slot_suffix =
[0005.664] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0697000 lut_mem=0x2008@0xa0692000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[0005.703] I> Updated bootarg info to DTB
[0005.707] W> MAC addr invalid!
[0005.709] E> Failed to get WIFI MAC address
[0005.713] W> MAC addr invalid!
[0005.716] E> Failed to get Bluetooth MAC address
[0005.721] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:ad:2f
[0005.728] E> "plugin-manager" doesn't exist, creating
[0005.732] I> Adding /chosen/plugin-manager/cvm
[0005.736] E> "chip-id" doesn't exist, creating
[0005.740] I> Adding /chosen/plugin-manager/chip-id
[0005.745] E> "configs" doesn't exist, creating
[0005.749] I> Adding /chosen/plugin-manager/configs
[0005.754] E> "ids" doesn't exist, creating
[0005.758] I> Adding /chosen/plugin-manager/ids
[0005.763] E> "odm-data" doesn't exist, creating
[0005.767] I> Adding /chosen/plugin-manager/odm-data
[0005.775] E> "memory" doesn't exist, creating
[0005.776] I> [0] START: 0x80000000, END: 0xab000000
[0005.780] I> [1] START: 0xab004000, END: 0xe8cd0000
[0005.785] I> [2] START: 0xe8cdc000, END: 0xe8ce0000
[0005.790] I> dram_block larger than 80000000
[0005.794] I> [3] START: 0x100000000, END: 0x480000000
[0005.799] I> added [base:0x80000000, size:0x2b000000] to /memory
[0005.804] I> added [base:0xab200000, size:0x3da00000] to /memory
[0005.810] I> added [base:0x100000000, size:0x380000000] to /memory
[0005.818] I> Updated memory info to DTB
[0005.820] E> add_disp_param: failed to get display params for du=1
[0005.826] E> "reset" doesn't exist, creating
[0005.831] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0005.835] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0005.840] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0005.844] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0005.849] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0005.854] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0005.859] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0005.863] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0005.868] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0005.873] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0005.878] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0005.883] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0005.888] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0005.892] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0005.897] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0005.902] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0005.908] E> "misc-data" doesn't exist, creating
[0005.911] I> Boot-device: eMMC
[0005.914] I> Add boot-sdmmc to plugin-manager/misc-data
[0005.919] I> Add storage-sdmmc to plugin-manager/misc-data
[0005.925] W> Unknown storage device
[0005.928] I> Add serial number:0423518031540 as DT property
[0005.935] I> Plugin-manager override starting
[0005.938] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0005.946] I> node /plugin-manager/fragement-soft-wdt matches
[0005.952] I> node /plugin-manager/fragment-pcie-c1-rp matches
[0005.955] I> node /plugin-manager/fragment-pcie-p2822-B00 matches
[0005.965] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0005.970] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0005.973] I> node /plugin-manager/pwm-fan-polarity matches
[0005.984] I> node /plugin-manager/ufs-cd matches
[0005.988] I> node /plugin-manager/fragment-p2888@0 matches
[0006.000] I> Disable plugin-manager status in FDT
[0006.000] I> Plugin-manager override finished successfully
[0006.001] I> tegrabl_load_kernel_and_dtb: Done
[0006.002] I> Sending TOS params
[0006.004] I> Sending NS DRAM Ranges to TOS
[0006.008] W> Failed to send NS DRAM Ranges to TOS
[0006.013] W> Failed to lock interface between BL and TOS
[0006.044] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2988) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:30:11 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2b000000
[ 0.000000] OF: fdt: - ab200000 , 3da00000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a0697000
[ 0.000000] Found lut_mem: 00002008@a0692000
[ 0.000000] Found vpr, start=0xf0000000 size=8000000[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffda5000 s53400 r8192 d32616 u94208
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4031997
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0697000 lut_mem=0x2008@0xa0692000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29232(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15994800K/16383988K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 323652K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000034] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009044] Console: colour dummy device 80x25
[ 0.012171] console [tty0] enabled
[ 0.015878] bootconsole [tegra_comb_uart0] disabled
<hit enter to activate fiq debugger>
[ 0.020862] kmemleak: Kernel memory leak detector disabled
[ 0.020933] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.021022] pid_max: default: 32768 minimum: 301
[ 0.022512] Security Framework initialized
[ 0.023243] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023312] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025576] ftrace: allocating 46802 entries in 183 pages
[ 0.470775] sched-energy: Sched-energy-costs installed from DT
[ 0.470987] ASID allocator initialised with 65536 entries
[ 0.513848] tegra-id: chipid=21917.
[ 0.513886] tegra-id: opt_subrevision=0.
[ 0.513943] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.514035] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.514113] DTB Build time: Mar 13 2019 00:34:33
[ 0.561603] CPU1: Booted secondary processor [4e0f0040]
[ 0.593783] CPU2: Booted secondary processor [4e0f0040]
[ 0.626016] CPU3: Booted secondary processor [4e0f0040]
[ 0.658686] CPU4: Booted secondary processor [4e0f0040]
[ 0.690913] CPU5: Booted secondary processor [4e0f0040]
[ 0.723940] CPU6: Booted secondary processor [4e0f0040]
[ 0.755916] CPU7: Booted secondary processor [4e0f0040]
[ 0.756786] Brought up 8 CPUs
[ 0.757497] SMP: Total of 8 processors activated.
[ 0.757556] CPU features: detected feature: Privileged Access Never
[ 0.757620] CPU features: detected feature: LSE atomic instructions
[ 0.757693] CPU features: detected feature: User Access Override
[ 0.757755] CPU features: detected feature: 32-bit EL0 Support
[ 0.763855] CPU: All CPU(s) started at EL2
[ 0.763999] alternatives: patching kernel code
[ 0.783101] devtmpfs: initialized
[ 0.861348] Initilizing CustomIPI irq domain
[ 0.861790] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.861893] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.864002] pinctrl core: initialized pinctrl subsystem
[ 0.864306] OS set in device tree is not L4T.
[ 0.864683] regulator-dummy: no parameters
[ 0.864977] Initializing plugin-manager
[ 0.865073] Plugin module not found
[ 0.865144] Plugin-manager status disabled
[ 0.867102] NET: Registered protocol family 16
[ 0.876180] pstore: using zlib compression
[ 0.877564] console [pstore-1] enabled
[ 0.877613] pstore: Registered ramoops as persistent store backend
[ 0.877675] ramoops: attached 0x200000@0xe8a00000, ecc: 0/0
[ 0.896917] cpuidle: using governor menu
[ 0.898578] bpmp: waiting for handshake
[ 0.898646] bpmp: handshake completed
[ 0.898721] bpmp: synchronizing channels
[ 0.898776] bpmp: channels synchronized
[ 0.898832] bpmp: mail init ok
[ 0.903226] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.903604] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.903742] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.903799] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.903858] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.903917] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.903979] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.904069] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.904168] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.904235] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.904301] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.909464] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.909906] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.914505] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.915947] Registering BPMP clocks...
[ 0.916155] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.916721] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.917348] tegra_powergate_init: DONE
[ 0.917567] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.917790] DTB Build time: Mar 13 2019 00:34:33
[ 0.922129] Tegra reboot handler registered.
[ 0.931701] iommu: Adding device 14180000.pcie to group 0
[ 0.932693] iommu: Adding device 14100000.pcie to group 1
[ 0.933723] iommu: Adding device 14140000.pcie to group 2
[ 0.934628] iommu: Adding device 141a0000.pcie to group 3
[ 0.936402] iommu: Adding device 2490000.ether_qos to group 4
[ 0.937362] iommu: Adding device 3100000.serial to group 5
[ 0.938135] iommu: Adding device 3110000.serial to group 6
[ 0.938739] iommu: Adding device 3140000.serial to group 7
[ 0.939568] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.940183] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.940281] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.940345] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.940405] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.940511] tegra-pmc: PMC Prod config success
[ 0.940871] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.940975] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.941533] iommu: Adding device 3460000.sdhci to group 8
[ 0.942353] iommu: Adding device 3400000.sdhci to group 9
[ 0.943152] iommu: Adding device 2450000.ufshci to group 10
[ 0.943993] iommu: Adding device c260000.spi to group 11
[ 0.945023] iommu: Adding device 3160000.i2c to group 12
[ 0.945631] iommu: Adding device c240000.i2c to group 13
[ 0.946280] iommu: Adding device 3180000.i2c to group 14
[ 0.946827] iommu: Adding device 3190000.i2c to group 15
[ 0.947558] iommu: Adding device 31b0000.i2c to group 16
[ 0.948115] iommu: Adding device 31c0000.i2c to group 17
[ 0.948690] iommu: Adding device c250000.i2c to group 18
[ 0.949392] iommu: Adding device 31e0000.i2c to group 19
[ 0.950580] iommu: Adding device sound to group 20
[ 0.951303] iommu: Adding device 3510000.hda to group 21
[ 0.952079] iommu: Adding device bc00000.rtcpu to group 22
[ 0.955106] iommu: Adding device 13e10000.host1x to group 23
[ 0.955677] iommu: Adding device 13e10000.host1x:ctx0 to group 24
[ 0.956215] iommu: Adding device 13e10000.host1x:ctx1 to group 25
[ 0.956777] iommu: Adding device 13e10000.host1x:ctx2 to group 26
[ 0.957374] iommu: Adding device 13e10000.host1x:ctx3 to group 27
[ 0.958013] iommu: Adding device 13e10000.host1x:ctx4 to group 28
[ 0.958570] iommu: Adding device 13e10000.host1x:ctx5 to group 29
[ 0.959168] iommu: Adding device 13e10000.host1x:ctx6 to group 30
[ 0.959850] iommu: Adding device 13e10000.host1x:ctx7 to group 31
[ 0.960681] iommu: Adding device 15340000.vic to group 32
[ 0.961279] iommu: Adding device 15380000.nvjpg to group 33
[ 0.961732] iommu: Adding device 15500000.tsec to group 34
[ 0.962186] iommu: Adding device 15100000.tsecb to group 35
[ 0.962591] iommu: Adding device 15480000.nvdec to group 36
[ 0.963060] iommu: Adding device 15140000.nvdec1 to group 37
[ 0.963533] iommu: Adding device 154c0000.nvenc to group 38
[ 0.963945] iommu: Adding device 15a80000.nvenc1 to group 39
[ 0.964597] iommu: Adding device 15880000.nvdla0 to group 40
[ 0.965298] iommu: Adding device 158c0000.nvdla1 to group 41
[ 0.966091] iommu: Adding device 15200000.nvdisplay to group 42
[ 0.966530] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0697000(800000)
[ 0.966613] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0692000(3000)
[ 0.967874] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 0.967941] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.968728] iommu: Adding device 15210000.nvdisplay to group 43
[ 0.968825] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.969588] iommu: Adding device 15220000.nvdisplay to group 44
[ 0.969692] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.972317] iommu: Adding device 15c10000.vi to group 45
[ 0.972608] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.973114] iommu: Adding device 14800000.isp to group 46
[ 0.975082] iommu: Adding device 16000000.pva0 to group 47
[ 0.975963] iommu: Adding device 16800000.pva1 to group 48
[ 0.976544] iommu: Adding device 15810000.se to group 49
[ 0.977188] iommu: Adding device 15820000.se to group 50
[ 0.977635] iommu: Adding device 15830000.se to group 51
[ 0.978092] iommu: Adding device 15840000.se to group 52
[ 0.978481] iommu: Adding device c1a0000.aon to group 53
[ 0.980502] iommu: Adding device d000000.bpmp to group 54
[ 0.981033] bpmp: ping status is 0
[ 0.981273] bpmp d000000.bpmp: firmware tag is 1c1b2165fe52a0a54ad7caf60d40cdc3
[ 0.985563] bpmp d000000.bpmp: probe ok
[ 0.987529] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 0.988291] iommu: Adding device smmu_test to group 55
[ 0.989800] mc: mapped MMIO address: 0xffffff800a560000 -> 0x2c10000
[ 0.989890] mc: mapped MMIO address: 0xffffff800a580000 -> 0x2c20000
[ 0.989968] mc: mapped MMIO address: 0xffffff800a5a0000 -> 0x2c30000
[ 0.990042] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c40000
[ 0.990120] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c50000
[ 0.990195] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2b80000
[ 0.990276] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2b90000
[ 0.990387] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2ba0000
[ 0.990461] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2bb0000
[ 0.990537] mc: mapped MMIO address: 0xffffff800b050000 -> 0x1700000
[ 0.990610] mc: mapped MMIO address: 0xffffff800b070000 -> 0x1710000
[ 0.990684] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1720000
[ 0.990757] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1730000
[ 0.990830] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1740000
[ 0.990903] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1750000
[ 0.990976] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1760000
[ 0.991048] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1770000
[ 0.991202] mc-err: mcerr ops are set to t19x
[ 0.999082] iommu: Adding device 2600000.dma to group 56
[ 1.006474] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 1.006569] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 1.006657] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.007112] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.014757] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.015099] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.017538] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.017606] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.018672] iommu: Adding device 3550000.xudc to group 57
[ 1.019697] iommu: Adding device 3610000.xhci to group 58
[ 1.023344] arm64_ras arm64_ras: probed
[ 1.024074] ras_fhi_enable: FHI 477 enabled on CPU0
[ 1.024189] ras_fhi_enable: FHI 478 enabled on CPU1
[ 1.024345] ras_fhi_enable: FHI 479 enabled on CPU2
[ 1.024530] ras_fhi_enable: FHI 480 enabled on CPU3
[ 1.024702] ras_fhi_enable: FHI 481 enabled on CPU4
[ 1.024816] ras_fhi_enable: FHI 482 enabled on CPU5
[ 1.024922] ras_fhi_enable: FHI 483 enabled on CPU6
[ 1.025075] ras_fhi_enable: FHI 484 enabled on CPU7
[ 1.025388] carmel_ras_enable: RAS enabled on cpu0
[ 1.025757] carmel_ras_enable: RAS enabled on cpu1
[ 1.026062] carmel_ras_enable: RAS enabled on cpu2
[ 1.026393] carmel_ras_enable: RAS enabled on cpu3
[ 1.026753] carmel_ras_enable: RAS enabled on cpu4
[ 1.027053] carmel_ras_enable: RAS enabled on cpu5
[ 1.027325] carmel_ras_enable: RAS enabled on cpu6
[ 1.027608] carmel_ras_enable: RAS enabled on cpu7
[ 1.027760] carmel_ras carmel_ras: probed
[ 1.029500] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.030336] tegra-cbb c600000.aon-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.031575] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 1.032775] tegra-cbb be00000.rce-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[ 1.033909] tegra-cbb b600000.sce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
[ 1.034544] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.037913] vdd-3v3-cvb: 3300 mV
[ 1.038303] vdd-1v8-cvb: 1800 mV
[ 1.038922] vdd-1v8-sd: 1800 mV
[ 1.039455] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.039555] vdd-epb-1v0: 1000 mV
[ 1.040001] vdd-sdmmc1-sw: 3300 mV
[ 1.040512] avdd-cam-2v8: 2800 mV
[ 1.040889] vdd-sata-1v5: 1500 mV
[ 1.041269] vdd-1v8-slt: 1800 mV
[ 1.041632] vdd-3v3-slt: 3300 mV
[ 1.042059] vdd-fan: 5000 mV
[ 1.042515] vdd-hdmi-5v0: 5000 mV
[ 1.042967] vdd_sys_en: 1200 mV
[ 1.043710] vdd-5v-sata: 5000 mV
[ 1.044218] vdd-ac-bat: 5000 mV
[ 1.044477] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.077796] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.083908] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.084433] SCSI subsystem initialized
[ 1.085144] usbcore: registered new interface driver usbfs
[ 1.085262] usbcore: registered new interface driver hub
[ 1.085430] usbcore: registered new device driver usb
[ 1.098206] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.101335] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.107192] vdd-1v0: at 1000 mV
[ 1.111211] vdd-1v8-hs: at 1800 mV
[ 1.115265] vdd-1v8-ls: at 1800 mV
[ 1.119398] vdd-1v8-ao: at 1800 mV
[ 1.123411] vddio-ddr-1v1: at 1100 mV
[ 1.127191] vdd-rtc: at 800 mV
[ 1.128672] spmic-ldo1: at 2375 mV
[ 1.135452] vdd-ao-3v3: at 3300 mV
[ 1.143545] vddio-emmc-3v3: at 3300 mV
[ 1.145032] spmic-ldo4: at 1587 mV
[ 1.151620] vdd-usb-3v3: at 3300 mV
[ 1.159797] vddio-sdmmc1-3v3: at 3300 mV
[ 1.163791] vdd-csi-1v2: at 1200 mV
[ 1.165444] spmic-ldo8: at 1800 mV
[ 1.167663] GPIO line 246 (gpio_default) hogged as output/high
[ 1.169246] GPIO line 247 (gpio_default) hogged as output/high
[ 1.169797] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.173565] max77620 4-003c: max77620 probe successful
[ 1.174324] media: Linux media interface: v0.10
[ 1.174409] Linux video capture interface: v2.00
[ 1.176160] pps_core: LinuxPPS API ver. 1 registered
[ 1.176200] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.176316] PTP clock support registered
[ 1.177073] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.177163] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.178657] tegra_fiq_debugger_init: found FIQ source (IRQ 469)
[ 1.180723] Advanced Linux Sound Architecture Driver Initialized.
[ 1.181227] Bluetooth: Core ver 2.22
[ 1.181308] NET: Registered protocol family 31
[ 1.181343] Bluetooth: HCI device and connection manager initialized
[ 1.181387] Bluetooth: HCI socket layer initialized
[ 1.181425] Bluetooth: L2CAP socket layer initialized
[ 1.181484] Bluetooth: SCO socket layer initialized
[ 1.184624] camchar: rtcpu character device driver loaded
[ 1.186044] clocksource: Switched to clocksource arch_sys_counter
[ 1.251280] VFS: Disk quotas dquot_6.6.0
[ 1.251470] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.251921] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.254141] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.254326] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 1.254389] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.254438] nvmap_page_pool_init: Total RAM pages: 4015084
[ 1.254473] nvmap_page_pool_init: nvmap page pool size: 501885 pages (1960 MB)
[ 1.254836] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.255372] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 1.256628] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.272375] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.272724] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.273043] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.273387] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.273901] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.274311] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.274510] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.276050] la/ptsa driver initialized.
[ 1.276522] NET: Registered protocol family 2
[ 1.277709] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.278588] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.279375] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.279469] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.279817] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.280480] NET: Registered protocol family 1
[ 1.281359] RPC: Registered named UNIX socket transport module.
[ 1.281403] RPC: Registered udp transport module.
[ 1.281436] RPC: Registered tcp transport module.
[ 1.281469] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.281750] Trying to unpack rootfs image as initramfs...
[ 1.298715] random: fast init done
[ 1.303959] host1x 13e10000.host1x: initialized
[ 1.307405] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.313992] audit: initializing netlink subsys (disabled)
[ 1.314339] audit: type=2000 audit(0.892:1): initialized
[ 1.315397] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.325458] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.326963] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.327754] 9p: Installing v9fs 9p2000 file system support
[ 1.334584] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.334949] io scheduler noop registered
[ 1.335258] io scheduler cfq registered (default)
[ 1.339254] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.344410] iommu: Adding device 2993000.adsp to group 59
[ 1.410507] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[ 1.411616] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.427723] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.428330] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.428953] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.432646] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.433002] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.433057] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.437285] tsec 15500000.tsec: initialized
[ 1.439583] tsec 15100000.tsecb: initialized
[ 1.445211] nvdec 15480000.nvdec: initialized
[ 1.449001] nvdec 15140000.nvdec1: initialized
[ 1.456724] falcon 15340000.vic: initialized
[ 1.459486] falcon 15380000.nvjpg: initialized
[ 1.462294] falcon 154c0000.nvenc: initialized
[ 1.464805] falcon 15a80000.nvenc1: initialized
[ 1.469569] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.473594] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.477494] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.480037] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.482584] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.485001] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.487519] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.489985] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.494465] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.500907] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.501423] scare-pigeon 14b00000.isp-thi: initialized
[ 1.512510] pva 16000000.pva0: initialized
[ 1.545670] pva 16800000.pva1: initialized
[ 1.577119] nvdla 15880000.nvdla0: initialized
[ 1.608212] nvdla 158c0000.nvdla1: initialized
[ 1.612800] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.613091] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.613134] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.613179] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.614678] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.614738] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.614824] tegradccommon 15200000.dc_common: dma mapping done
[ 1.616600] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.616712] generic_infoframe_type: 0x87
[ 1.616918] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.617014] tegradc 15200000.nvdisplay: Display dc.ffffff800bd90000 registered with id=0
[ 1.624228] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.624282] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.624328] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.624631] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.624675] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.626229] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.627426] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.627819] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.628215] kfuse 3830000.kfuse: initialized
[ 1.630587] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.630649] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.636347] tegradc 15200000.nvdisplay: probed
[ 1.637196] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.640833] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.642407] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.643702] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.125472] console [ttyTCU0] enabled
[ 4.126173] [drm] Initialized
[ 4.126253] Console: switching to colour frame buffer device 240x67
[ 4.138627] tegradc 15200000.nvdisplay: fb registered
[ 4.144256] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.149521] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.154642] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.156629] brd: module loaded
[ 4.164783] loop: module loaded
[ 4.166985] tegra_profiler: version: 1.132, samples/io: 46/26
[ 4.172457] tegra_profiler: auth: init
[ 4.176857] nct1008_nct72 4-004c: starting parse dt
[ 4.177259] THERMAL EST: found 3 subdevs
[ 4.177264] THERMAL EST num_resources: 0
[ 4.177268] [THERMAL EST subdev 0]
[ 4.177274] [THERMAL EST subdev 1]
[ 4.177278] [THERMAL EST subdev 2]
[ 4.177681] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.177684] THERMAL EST: thz register success.
[ 4.178726] Parent Clock set for DC plld3
[ 4.182016] THERMAL EST: end of probe, return err: 0
[ 4.183295] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.183308] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.184254] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 459
[ 4.184264] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.198019] scsi host0: ufshcd
[ 4.214825] hisi_sas: driver version v1.6
[ 4.220120] libphy: Fixed MDIO Bus: probed
[ 4.220657] tun: Universal TUN/TAP device driver, 1.6
[ 4.220660] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.221506] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.221508] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.221544] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.221546] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.221580] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.221582] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.221618] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.221620] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.227397] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.230283] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 4.231246] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.231261] tegradc 15200000.nvdisplay: hdmi: BL set VIC 0
[ 4.231266] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.231689] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb ad 2f
[ 4.231797] libphy: dwc_phy: probed
[ 4.232250] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.232253] Extcon AUX2(HDMI) enable
[ 4.233002] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 4.233449] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 4.234640] PPP generic driver version 2.4.2
[ 4.234890] PPP BSD Compression module registered
[ 4.234894] PPP Deflate Compression module registered
[ 4.234915] PPP MPPE Compression module registered
[ 4.234920] NET: Registered protocol family 24
[ 4.234980] usbcore: registered new interface driver r8152
[ 4.235022] usbcore: registered new interface driver asix
[ 4.235057] usbcore: registered new interface driver ax88179_178a
[ 4.235094] usbcore: registered new interface driver cdc_ether
[ 4.235125] usbcore: registered new interface
