Add log.
Blockquote[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] W> No valid slot number is found in scratch register
[0000.091] W> Return default slot: _a
[0000.094] I> Active Boot chain : 0
[0000.097] I> Boot-device: QSPI
[0000.100] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.113] I> Temperature = 30500
[0000.116] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.121] W> Skipping boost for clk: BPMP_APB
[0000.125] W> Skipping boost for clk: AXI_CBB
[0000.129] W> Skipping boost for clk: AON_CPU_NIC
[0000.133] W> Skipping boost for clk: CAN1
[0000.137] W> Skipping boost for clk: CAN2
[0000.141] I> Boot-device: QSPI
[0000.144] I> Boot-device: QSPI
[0000.147] I> Qspi flash params source = mb1bct
[0000.151] I> Qspi using bpmp-dma
[0000.154] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.160] I> Qspi flash params source = mb1bct
[0000.166] I> ECC region[0]: Start:0x0, End:0x0
[0000.170] I> ECC region[1]: Start:0x0, End:0x0
[0000.174] I> ECC region[2]: Start:0x0, End:0x0
[0000.178] I> ECC region[3]: Start:0x0, End:0x0
[0000.182] I> ECC region[4]: Start:0x0, End:0x0
[0000.186] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.192] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.197] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.201] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.206] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.211] E> FAILED: Thermal config
[0000.218] E> FAILED: MEMIO rail config
[0000.229] I> Boot-device: QSPI
[0000.231] I> Qspi flash params source = mb1bct
[0000.241] I> Qspi flash params source = mb1bct
[0000.252] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.328] I> Qspi flash params source = mb1bct
[0000.355] I> Qspi flash params source = mb1bct
[0000.366] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.375] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-aa987a31)
[0000.375] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.376] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.376] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.382] W> device prod register failed
[0000.386] I> Boot-device: QSPI
[0000.389] I> Boot_device: QSPI_FLASH instance: 0
[0000.394] I> QSPI Flash Size = 32 MB
[0000.397] I> Qspi initialized successfully
[0000.401] I> qspi flash-0 params source = boot args
[0000.795] I> sdmmc DDR50 mode
[0000.797] I> sdmmc-3 params source = safe params
[0000.801] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.802] W> Cannot find any partition table for 00000003
[0000.805] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.806] W> No valid slot number is found in scratch register
[0000.806] W> Return default slot: _a
[0000.807] I> Active Boot chain : 0
[0000.808] I> parsing oem signed section of bpmp-fw header done
[0000.811] I> bpmp-fw binary init read from storage
[0000.816] I> oem authentication of bpmp-fw header done
[0000.830] I> bpmp-fw binary done read from storage
[0000.831] I> bpmp-fw: Authentication init Done
[0000.832] I> parsing oem signed section of cpubl header done
[0000.835] I> cpubl binary init read from storage
[0000.840] I> bpmp-fw: Authentication Finalize Done
[0000.845] I> oem authentication of cpubl header done
[0000.852] I> cpubl binary done read from storage
[0000.854] I> cpubl: Authentication init Done
[0000.858] I> parsing oem signed section of rce header done
[0000.863] I> rce binary init read from storage
[0000.868] I> Relocating BR-BCT
[0000.870] I> cpubl: Authentication Finalize Done
[0000.875] I> oem authentication of rce header done
[0000.880] I> rce binary done read from storage
[0000.884] I> rce: Authentication init Done
[0000.888] I> parsing oem signed section of ape header done
[0000.893] I> ape binary init read from storage
[0000.897] I> rce: Authentication Finalize Done
[0000.902] I> oem authentication of ape header done
[0000.906] I> ape binary done read from storage
[0000.910] I> ape: Authentication init Done
[0000.915] I> parsing oem signed section of tos header done
[0000.920] I> tos binary init read from storage
[0000.924] I> ape: Authentication Finalize Done
[0000.929] I> oem authentication of tos header done
[0000.935] I> tos binary done read from storage
[0000.937] I> tos: Authentication init Done
[0000.942] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.947] I> bpmp-fw-dtb binary init read from storage
[0000.952] I> tos: Authentication Finalize Done
[0000.958] I> oem authentication of bpmp-fw-dtb header done
[0000.962] I> bpmp-fw-dtb binary done read from storage
[0000.967] I> bpmp-fw-dtb: Authentication init Done
[0000.972] I> parsing oem signed section of cpubl-dtb header done
[0000.977] I> cpubl-dtb binary init read from storage
[0000.982] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.028] I> oem authentication of cpubl-dtb header done
[0001.029] I> cpubl-dtb binary done read from storage
[0001.029] I> cpubl-dtb: Authentication init Done
[0001.030] I> parsing oem signed section of eks header done
[0001.031] I> eks binary init read from storage
[0001.032] I> cpubl-dtb: Authentication Finalize Done
[0001.032] I> oem authentication of eks header done
[0001.037] I> eks binary done read from storage
[0001.041] I> eks: Authentication init Done
[0001.045] I> eks: Authentication Finalize Done
[0001.049] I> EKB detected (length: 0x410) @ VA:0x52714400
��NOTICE: BL31: v1.3(release):fe06da916
NOTICE: BL31: Built : 18:06:49, Apr 8 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.390] I> Welcome to Cboot
��WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.391] I> Cboot Version: t194-d00c695c
[0001.393] I> CPU-BL Params @ 0xf2820000
[0001.396] I> 0) Base:0x00000000 Size:0x00000000
[0001.401] I> 1) Base:0xf1100000 Size:0x00100000
[0001.405] I> 2) Base:0xf2000000 Size:0x00200000
[0001.410] I> 3) Base:0xf1200000 Size:0x00200000
��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.414] I> 4) Base:0xf1000000 Size:0x00100000
[0001.558] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.563] I> 6) Base:0xf3800000 Size:0x00400000
[0001.567] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.572] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.576] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.581] I> 10) Base:0xf3000000 Size:0x00800000
[0001.585] I> 11) Base:0x40000000 Size:0x00040000
[0001.590] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.594] I> 13) Base:0x40046000 Size:0x00002000
[0001.598] I> 14) Base:0x40048000 Size:0x00002000
[0001.603] I> 15) Base:0xac000000 Size:0x00004000
[0001.607] I> 16) Base:0x4004a000 Size:0x00002000
[0001.612] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.616] I> 18) Base:0x4004c000 Size:0x00002000
[0001.621] I> 19) Base:0xf2200000 Size:0x00600000
[0001.625] I> 20) Base:0x4004e000 Size:0x00002000
[0001.630] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.634] I> 22) Base:0x00000000 Size:0x00000000
[0001.639] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.643] I> 24) Base:0xf6000000 Size:0x02000000
[0001.648] I> 25) Base:0x40050000 Size:0x00002000
[0001.652] I> 26) Base:0x40040000 Size:0x00006000
[0001.656] I> 27) Base:0xf1800000 Size:0x00400000
[0001.661] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.665] I> 29) Base:0xf1400000 Size:0x00400000
[0001.670] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.674] I> 31) Base:0x00000000 Size:0x00000000
[0001.679] I> 32) Base:0xf8000000 Size:0x08000000
[0001.683] I> 33) Base:0x00000000 Size:0x00000000
[0001.688] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.692] I> 35) Base:0xab000000 Size:0x01000000
[0001.697] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.701] I> 37) Base:0xf2800000 Size:0x00800000
[0001.706] I> 38) Base:0x80000000 Size:0x20000000
[0001.710] I> 39) Base:0xb0000000 Size:0x08000000
[0001.714] I> 40) Base:0x00000000 Size:0x00000000
[0001.719] I> 41) Base:0x00000000 Size:0x00000000
[0001.723] I> 42) Base:0x00000000 Size:0x00000000
[0001.728] I> 43) Base:0x00000000 Size:0x00000000
[0001.732] I> 44) Base:0x00000000 Size:0x00000000
[0001.737] I> 45) Base:0x00000000 Size:0x00000000
[0001.741] GIC-SPI Target CPU: 0
[0001.744] Interrupts Init done
[0001.747] calling constructors
[0001.750] initializing heap
[0001.753] I> Heap: [0xa06905a8 … 0xab000000]
[0001.757] initializing threads
[0001.760] initializing timers
[0001.763] creating bootstrap completion thread
[0001.767] top of bootstrap2()
[0001.770] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.774] initializing platform
[0001.777] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.783] W> device prod register failed
[0001.786] I> Bl_dtb @0xaaf00000
[0001.792] E> “plugin-manager” doesn’t exist, creating
[0001.794] E> “ids” doesn’t exist, creating
[0001.799] E> “connection” doesn’t exist, creating
[0001.803] E> “configs” doesn’t exist, creating
[0001.814] I> Find /i2c@3160000’s alias i2c0
[0001.814] I> Reading eeprom i2c=0 address=0x50
[0001.841] I> Device at /i2c@3160000:0x50
[0001.841] I> Reading eeprom i2c=0 address=0x57
[0001.865] I> Device at /i2c@3160000:0x57
[0001.867] I> Find /i2c@c240000’s alias i2c1
[0001.868] I> Reading eeprom i2c=1 address=0x50
[0001.869] E> I2C: slave not found in slaves.
[0001.870] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.871] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.871] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.880] E> eeprom: Retry to read I2C slave device.
[0001.884] E> I2C: slave not found in slaves.
[0001.888] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.896] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.902] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.911] E> eeprom: Failed to read I2C slave device
[0001.916] I> Eeprom read failed 0x3526070d
[0001.920] I> create_pm_ids: id: 3668-0001-200-G, len: 15
[0001.925] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.936] I> create_pm_ids: id: 3449-0000-400-D, len: 15
[0001.941] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.953] I> Adding plugin-manager/ids/3668-0001-200=/i2c@3160000:module@0x50
[0001.960] E> “i2c@3160000” doesn’t exist, creating
[0001.964] E> “module@0x50” doesn’t exist, creating
[0001.969] I> Adding plugin-manager/ids/3449-0000-400=/i2c@3160000:module@0x57
[0001.976] E> “module@0x57” doesn’t exist, creating
[0001.982] I> Adding plugin-manager/cvm
[0001.984] E> “chip-id” doesn’t exist, creating
[0001.988] I> Adding plugin-manager/chip-id/A02P
[0001.993] I> Plugin-manager override starting
[0001.998] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.006] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.012] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0002.017] I> node /plugin-manager/fragement-tegra-pcie-c5-num-lanes matches
[0002.023] I> node /plugin-manager/fragement-tegra-pcie-c4-dis matches
[0002.030] I> Disable plugin-manager status in FDT
[0002.032] I> Plugin-manager override finished successfully
[0002.038] I> gpio framework initialized
[0002.042] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0002.050] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.056] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.064] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.071] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.078] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.084] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.091] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.099] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.106] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.113] I> fixed regulator driver initialized
[0002.122] I> register ‘maxim’ power off handle
[0002.123] I> virtual i2c enabled
[0002.124] I> registered ‘maxim,max20024’ pmic
[0002.128] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.135] I> Boot-device: QSPI
[0002.138] I> Boot_device: QSPI_FLASH instance: 0
[0002.143] I> QSPI source rate = 204000 Khz
[0002.146] I> Requested rate for QSPI clock = 34000 Khz
[0002.151] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.156] I> QSPI Flash Size = 32 MB
[0002.159] I> Qspi initialized successfully
[0002.163] I> qspi flash-0 params source = boot args
[0002.168] I> create_pm_ids: id: 3668-0001-200-G, len: 15
[0002.173] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.184] I> create_pm_ids: id: 3449-0000-400-D, len: 15
[0002.189] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.204] I> sdmmc-3 params source = safe params
[0002.206] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.226] W> Cannot find any partition table for 00000003
[0002.239] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.247] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.251] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.252] I> hdmi cable connected
[0002.253] E> set volts not configured for ‘vdd-1v0’
[0002.254] E> set volts not configured for ‘vdd-1v8-hs’
[0002.257] E> invalid display type
[0002.258] E> cannot find any other nvdisp nodes
[0002.272] I> edid read success
[0002.285] I> edid read success
[0002.285] I> width = 640, height = 480, frequency = 25174825
[0002.286] I> width = 640, height = 480, frequency = 25174825
[0002.286] I> width = 1920, height = 1080, frequency = 148500000
[0002.287] I> width = 1920, height = 1080, frequency = 148351648
[0002.291] I> width = 1280, height = 720, frequency = 74175824
[0002.297] I> width = 720, height = 480, frequency = 26973026
[0002.302] I> width = 720, height = 480, frequency = 26973026
[0002.308] I> width = 640, height = 480, frequency = 25174825
[0002.313] I> width = 1920, height = 1080, frequency = 148351648
[0002.319] I> width = 720, height = 576, frequency = 26973026
[0002.325] I> width = 1280, height = 720, frequency = 74175824
[0002.330] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.340] I> hdmi_enable, starting HDMI initialisation
[0002.345] I> hdmi_enable, HDMI initialisation complete
[0002.355] I> Load in CBoot Boot Options partition and parse it
[0002.356] E> Error -9 when finding node with path /boot-configuration
[0002.358] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.366] I> Hit any key to stop autoboot: 4 3 2 1
[0004.373] initializing target
[0004.373] calling apps_init()
[0004.374] starting app kernel_boot_app
[0004.380] I> found decompressor handler: lz4-legacy
[0004.380] I> decompressing BMP blob …
[0004.384] I> Kernel type = Normal
[0004.384] I> Loading kernel-bootctrl from partition
[0004.384] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.392] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.393] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.394] I> ########## SD boot ##########
[0004.398] W> Error: failed to get sd-card params
[0004.403] I> -0 params source =
[0004.406] E> Failed to initialize device 6-0
[0004.410] E> SD boot failed, err: 252641293
[0004.414] I> ########## USB boot ##########
[0004.423] W> No valid slot number is found in scratch register
[0004.424] W> Return default slot: _a
[0004.435] I> USB Firmware Version: 60.06 release
[0004.489] I> regulator of usb2-0 already enabled
[0004.494] I> regulator of usb2-1 already enabled
[0004.499] I> enabling ‘vdd-usb2-5v’ regulator
[0005.563] I> USB 2.0 port 2 new high-speed USB device detected
[0005.564] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.565] E> slot id is 1
[0005.566] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.574] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.576] I>
[0005.576] I> Enumerated USB Device 0bda:5411
[0005.580] I>
[0005.581] E> Enumerated device doesn’t belong to MSD class or protocol is not bulk-only!!
[0005.589] E> USBMSD: Failed to initialize Enumerated USB device either not an MSD device or supported protoco[0005.599] E> USBMSD: Failed to open usbmsd open, 0.
[0005.603] E> Error opening USBMSD driver 0, err: 7c7c0312
[0005.609] E> Failed to initialize device 5-0
[0005.613] E> USB boot failed, err: 2088502034
[0005.617] I> ########## Fixed storage boot ##########
[0005.622] I> Already published: 00010003
[0005.626] I> Look for boot partition
[0005.629] I> Fallback: assuming 0th partition is boot partition
[0005.635] I> Detect filesystem
[0005.662] I> Loading extlinux.conf …
[0005.662] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.693] I> L4T boot options
[0005.693] I> [1]: “primary kernel”
[0005.693] I> Enter choice:
[0008.695] I> Continuing with default option: 1
[0008.695] I> Loading kernel sig file from rootfs …
[0008.695] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.714] I> Loading kernel binary from rootfs …
[0008.714] I> rootfs path: /sdmmc_user/boot/Image
[0009.133] I> Validate kernel …
[0009.134] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.462] I> No kernel-dtb binary path
[0009.462] W> No valid slot number is found in scratch register
[0009.463] W> Return default slot: _a
[0009.463] I> A/B: bin_type (38) slot 0
[0009.463] I> Loading kernel-dtb from partition
[0009.464] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.475] I> Validate kernel-dtb …
[0009.475] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.479] I> Loading ramdisk from rootfs …
[0009.479] I> rootfs path: /sdmmc_user/boot/initrd
[0009.560] I> Kernel hdr @0xa4ac0000
[0009.560] I> Kernel dtb @0x90000000
[0009.561] I> decompressor handler not found
[0009.561] I> Copying kernel image (34265104 bytes) from 0xa4ac0000 to 0x80080000 … [0009.571] I> Done
[0009.572] I> Updated bpmp info to DTB
[0009.573] I> Ramdisk: Base: 0x92000000; Size: 0x54ec8f
[0009.573] I> Updated initrd info to DTB
[0009.574] W> WARN: Fail to override “console=none” in commandline
[0009.574] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.580] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.588] W> No valid slot number is found in scratch register
[0009.593] W> Return default slot: _a
[0009.597] I> Active slot suffix:
[0009.600] I> add_boot_slot_suffix: slot_suffix =
[0009.604] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio
[0009.642] I> Updated bootarg info to DTB
[0009.646] W> MAC addr invalid!
[0009.648] E> Failed to get WIFI MAC address
[0009.652] W> MAC addr invalid!
[0009.655] E> Failed to get Bluetooth MAC address
[0009.660] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:a2:e9
[0009.666] E> “plugin-manager” doesn’t exist, creating
[0009.671] I> Adding /chosen/plugin-manager/cvm
[0009.675] E> “chip-id” doesn’t exist, creating
[0009.679] I> Adding /chosen/plugin-manager/chip-id
[0009.684] E> “configs” doesn’t exist, creating
[0009.688] I> Adding /chosen/plugin-manager/configs
[0009.693] E> “ids” doesn’t exist, creating
[0009.697] I> Adding /chosen/plugin-manager/ids
[0009.701] E> “odm-data” doesn’t exist, creating
[0009.706] I> Adding /chosen/plugin-manager/odm-data
[0009.713] E> “memory” doesn’t exist, creating
[0009.715] I> [0] START: 0x80000000, END: 0xac000000
[0009.719] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.724] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.729] I> dram_block larger than 80000000
[0009.733] I> [3] START: 0x100000000, END: 0x280000000
[0009.738] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.743] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.749] I> added [base:0x100000000, size:0x180000000] to /memory
[0009.756] I> Updated memory info to DTB
[0009.759] E> add_disp_param: failed to get display params for du=1
[0009.765] E> “reset” doesn’t exist, creating
[0009.770] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.774] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.779] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.783] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.788] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.793] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.798] I> Deleted cpu@6 node in DT
[0009.801] I> Deleted cpu@7 node in DT
[0009.805] I> Deleted cluster3 node in FDT
[0009.809] I> Update arm-pmu in FDT
[0009.812] I> - update property: interrupts
[0009.816] I> - update property: interrupt-affinity
[0009.821] E> “misc-data” doesn’t exist, creating
[0009.825] I> Boot-device: QSPI
[0009.828] W> Unknown boot device
[0009.831] I> Add storage-qspi to plugin-manager/misc-data
[0009.836] W> Unknown storage device
[0009.839] I> Add serial number:1421320003894 as DT property
[0009.846] I> Plugin-manager override starting
[0009.849] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.856] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.862] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0009.868] I> node /plugin-manager/fragement-tegra-pcie-c5-num-lanes matches
[0009.874] I> node /plugin-manager/fragement-tegra-pcie-c4-dis matches
[0009.881] I> Disable plugin-manager status in FDT
[0009.884] I> Plugin-manager override finished successfully
[0009.890] I> tegrabl_load_kernel_and_dtb: Done
[0009.912] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3193) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP 0
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069c000
[ 0.000000] Found lut_mem: 00002008@a0696000
��WARNING: at platform/drivers/pg/pg-cv-t194.c:73
WARNING: pll_d2 has no dyn ramp
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
��[ 1.959164] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.959208] imx219 9-0010: board setup failed
[ 1.982951] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.983007] imx219 10-0010: board setup failed
[ 3.168738] usb 1-2.1.1: device not accepting address 5, error -71
[ 3.664727] usb 1-2.1.1: device not accepting address 6, error -71
[ 4.240649] cgroup: cgroup2: unknown option “nsdelegate”
[ 4.348857] usb 1-2.1.1: device descriptor read/64, error -32
[ 4.540887] usb 1-2.1.1: device descriptor read/64, error -32
��WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
��[ 4.812914] usb 1-2.1.1: device descriptor read/64, error -32
[ 5.603761] random: crng init done
[ 5.603923] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.624640] using random self ethernet address
[ 5.624883] using random host ethernet address
[ 6.127658] using random self ethernet address
[ 6.127928] using random host ethernet address
[ 7.571788] Please complete system configuration setup on desktop to proceed…
