Fails to boot, i2c/eeprom issues
One of my Jetson boards is not behaving properly. When trying to run Jetpack 4.6.1 imaged to a microSD card, the jetson boots to a minimal terminal with a couple of error messages, see attached. I tried using recovery mode and the sdkmanager utility to flash 4.6.1 and 5.0.1. Version 5 would boot sometimes, version 4.6.1 would not boot. I believe the was an issue with the eeprom. After using i2cdump, I found that the CRC byte was incorrect, so I wrote the proper value to the eeprom. This still did not fix the issue.
Have you reflashed the board with sdkmanager after you update the eeprom?
yes, I get the same result as shown in image
Better dumping the boot log from the uart after you do a clean flash with the sdkmanager.
boot log is attached
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet leve        l 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.9-t194-41334769-73a9b7ef)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.059] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] W> No valid slot number is found in scratch register
[0000.091] W> Return default slot: _a
[0000.094] I> Active Boot chain : 0
[0000.097] I> Boot-device: QSPI
[0000.100] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.114] I> Temperature = 21500
[0000.117] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.121] W> Skipping boost for clk: BPMP_APB
[0000.125] W> Skipping boost for clk: AXI_CBB
[0000.129] W> Skipping boost for clk: AON_CPU_NIC
[0000.133] W> Skipping boost for clk: CAN1
[0000.137] W> Skipping boost for clk: CAN2
[0000.141] I> Boot-device: QSPI
[0000.144] I> Boot-device: QSPI
[0000.147] I> Qspi flash params source = mb1bct
[0000.151] I> Qspi using bpmp-dma
[0000.154] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.161] I> Qspi flash params source = mb1bct
[0000.166] I> ECC region[0]: Start:0x0, End:0x0
[0000.170] I> ECC region[1]: Start:0x0, End:0x0
[0000.174] I> ECC region[2]: Start:0x0, End:0x0
[0000.178] I> ECC region[3]: Start:0x0, End:0x0
[0000.183] I> ECC region[4]: Start:0x0, End:0x0
[0000.187] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.192] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.197] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.201] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.206] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.211] E> FAILED: Thermal config
[0000.219] E> FAILED: MEMIO rail config
[0000.228] I> Boot-device: QSPI
[0000.231] I> Qspi flash params source = mb1bct
[0000.240] I> Qspi flash params source = mb1bct
[0000.252] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.328] I> Qspi flash params source = mb1bct
[0000.359] I> Qspi flash params source = mb1bct
[0000.371] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [0000.379] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-6fc80c        72)
[0000.379] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.380] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.380] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.386] W> device prod register failed
[0000.390] I> gpio framework initialized
[0000.394] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driv        er
[0000.401] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'        driver
[0000.409] I> sdcard_params [0, 55, 0, 50] in mb1_bct
[0000.414] I> Boot-device: QSPI
[0000.417] I> Boot_device: QSPI_FLASH instance: 0
[0000.422] I> QSPI Flash Size = 32 MB
[0000.427] I> Qspi initialized successfully
[0000.428] I> qspi flash-0 params source = boot args
[0000.433] I> Found sdcard
[0000.567] I> sdmmc SDR mode
[0000.582] I> sdcard-0 params source = mb1 bct
[0000.587] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.598] I> Found 11 partitions in SDCARD (instance 0)
[0000.599] W> No valid slot number is found in scratch register
[0000.600] W> Return default slot: _a
[0000.600] I> Active Boot chain : 0
[0000.601] I> parsing oem signed section of bpmp-fw header done
[0000.602] I> bpmp-fw binary init read from storage
[0000.603] I> oem authentication of bpmp-fw header done
[0000.615] I> bpmp-fw binary done read from storage
[0000.616] I> bpmp-fw: Authentication init Done
[0000.617] I> parsing oem signed section of cpubl header done
[0000.621] I> cpubl binary init read from storage
[0000.625] I> bpmp-fw: Authentication Finalize Done
[0000.630] I> oem authentication of cpubl header done
[0000.638] I> cpubl binary done read from storage
[0000.639] I> cpubl: Authentication init Done
[0000.643] I> parsing oem signed section of rce header done
[0000.649] I> rce binary init read from storage
[0000.653] I> Relocating BR-BCT
[0000.656] I> cpubl: Authentication Finalize Done
[0000.660] I> oem authentication of rce header done
[0000.665] I> rce binary done read from storage
[0000.669] I> rce: Authentication init Done
[0000.673] I> parsing oem signed section of ape header done
[0000.678] I> ape binary init read from storage
[0000.683] I> rce: Authentication Finalize Done
[0000.687] I> oem authentication of ape header done
[0000.691] I> ape binary done read from storage
[0000.696] I> ape: Authentication init Done
[0000.700] I> parsing oem signed section of tos header done
[0000.705] I> tos binary init read from storage
[0000.709] I> ape: Authentication Finalize Done
[0000.714] I> oem authentication of tos header done
[0000.721] I> tos binary done read from storage
[0000.723] I> tos: Authentication init Done
[0000.727] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.733] I> bpmp-fw-dtb binary init read from storage
[0000.737] I> tos: Authentication Finalize Done
[0000.744] I> oem authentication of bpmp-fw-dtb header done
[0000.749] I> bpmp-fw-dtb binary done read from storage
[0000.752] I> bpmp-fw-dtb: Authentication init Done
[0000.757] I> parsing oem signed section of cpubl-dtb header done
[0000.763] I> cpubl-dtb binary init read from storage
[0000.767] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.858] I> oem authentication of cpubl-dtb header done
[0000.859] I> cpubl-dtb binary done read from storage
[0000.859] I> cpubl-dtb: Authentication init Done
[0000.860] I> parsing oem signed section of eks header done
[0000.861] I> eks binary init read from storage
[0000.862] I> cpubl-dtb: Authentication Finalize Done
[0000.862] I> oem authentication of eks header done
[0000.867] I> eks binary done read from storage
[0000.871] I> eks: Authentication init Done
[0000.875] I> eks: Authentication Finalize Done
[0000.879] I> EKB detected (length: 0x410) @ VA:0x52700400
▒▒NOTICE:  BL31: v1.3(release):b5eeb33f7
NOTICE:  BL31: Built : 08:55:29, Feb 19 2022
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing .......
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
  [0001.240] I> Welcome to Cboot▒▒mrq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
[0001.241] I> Cboot Version: t194-63226c45
[0001.242] I> CPU-BL Params @ 0xf2820000
[0001.246] I>  0) Base:0x00000000 Size:0x00000000
[0001.250] I>  1) Base:0xf1100000 Size:0x00100000
[0001.255] I>  2) Base:0xf2000000 Size:0x00200000
▒▒clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.259] I>  3) Base:0xf1200000 Size:0x00200000
[0001.413] I>  4) Base:0xf1000000 Size:0x00100000
[0001.418] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.422] I>  6) Base:0xf3800000 Size:0x00400000
[0001.427] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.431] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.436] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.440] I> 10) Base:0xf3000000 Size:0x00800000
[0001.444] I> 11) Base:0x40000000 Size:0x00040000
[0001.449] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.453] I> 13) Base:0x40046000 Size:0x00002000
[0001.458] I> 14) Base:0x40048000 Size:0x00002000
[0001.462] I> 15) Base:0xac000000 Size:0x00004000
[0001.467] I> 16) Base:0x4004a000 Size:0x00002000
[0001.471] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.476] I> 18) Base:0x4004c000 Size:0x00002000
[0001.480] I> 19) Base:0xf2200000 Size:0x00600000
[0001.485] I> 20) Base:0x4004e000 Size:0x00002000
[0001.489] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.494] I> 22) Base:0x00000000 Size:0x00000000
[0001.498] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.502] I> 24) Base:0xf6000000 Size:0x02000000
[0001.507] I> 25) Base:0x40050000 Size:0x00002000
[0001.511] I> 26) Base:0x40040000 Size:0x00006000
[0001.516] I> 27) Base:0xf1800000 Size:0x00400000
[0001.520] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.525] I> 29) Base:0xf1400000 Size:0x00400000
[0001.529] I> 30) Base:0x00000000 Size:0x00000000
[0001.534] I> 31) Base:0x00000000 Size:0x00000000
[0001.538] I> 32) Base:0xf8000000 Size:0x08000000
[0001.543] I> 33) Base:0x00000000 Size:0x00000000
[0001.547] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.552] I> 35) Base:0xab000000 Size:0x01000000
[0001.556] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.560] I> 37) Base:0xf2800000 Size:0x00800000
[0001.565] I> 38) Base:0x80000000 Size:0x20000000
[0001.569] I> 39) Base:0xb0000000 Size:0x08000000
[0001.574] I> 40) Base:0x00000000 Size:0x00000000
[0001.578] I> 41) Base:0x00000000 Size:0x00000000
[0001.583] I> 42) Base:0x00000000 Size:0x00000000
[0001.587] I> 43) Base:0x00000000 Size:0x00000000
[0001.592] I> 44) Base:0x00000000 Size:0x00000000
[0001.596] I> 45) Base:0x00000000 Size:0x00000000
[0001.601] GIC-SPI Target CPU: 0
[0001.604] Interrupts Init done
[0001.607] calling constructors
[0001.609] initializing heap
[0001.612] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.616] initializing threads
[0001.619] initializing timers
[0001.622] creating bootstrap completion thread
[0001.626] top of bootstrap2()
[0001.629] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.634] initializing platform
[0001.637] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.642] W> device prod register failed
[0001.646] I> Bl_dtb @0xaaf00000
[0001.651] W> "plugin-manager" doesn't exist, creating
[0001.654] W> "ids" doesn't exist, creating
[0001.658] W> "connection" doesn't exist, creating
[0001.662] W> "configs" doesn't exist, creating
[0001.673] E> failed to read label property for node 158736: 13
[0001.675] E> failed to read reg property for node 158800: 13
[0001.679] E> failed to read reg property for node 158852: 13
[0001.684] E> failed to read reg property for node 158936: 13
[0001.690] I> Find /i2c@3160000's alias i2c0
[0001.693] I> Reading eeprom i2c=0 address=0x50
[0001.722] E> verify_cvm_eeprom_version: EEPROM incompatible version found
[0001.723] I> Eeprom read failed 0x35360018
[0001.723] I> Reading eeprom i2c=0 address=0x57
[0001.748] I> Device at /i2c@3160000:0x57
[0001.749] I> Find /i2c@c240000's alias i2c1
[0001.749] I> Reading eeprom i2c=1 address=0x50
[0001.751] E> I2C: slave not found in slaves.
[0001.751] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr        ue.
[0001.752] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.753] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at        0x00000000 via instance 1.
[0001.762] E> eeprom: Retry to read I2C slave device.
[0001.767] E> I2C: slave not found in slaves.
[0001.771] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr        ue.
[0001.779] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.784] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at        0x00000000 via instance 1.
[0001.794] E> eeprom: Failed to read I2C slave device
[0001.798] I> Eeprom read failed 0x3526070d
[0001.802] I> create_pm_ids: id: 3509-0000-100-F, len: 15
[0001.807] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00        ,touch-config:00,display-config:00,, len: 93
[0001.818] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.826] W> "i2c@3160000" doesn't exist, creating
[0001.830] W> "module@0x57" doesn't exist, creating
[0001.836] W> "chip-id" doesn't exist, creating
[0001.839] I> Adding plugin-manager/chip-id/A02
[0001.843] I> Plugin-manager override starting
[0001.848] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.856] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.864] I> Disable plugin-manager status in FDT
[0001.864] I> Plugin-manager override finished successfully
[0001.869] I> gpio framework initialized
[0001.873] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driv        er
[0001.881] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'        driver
[0001.888] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.895] W> fetch_driver_phandle_from_dt: failed to get node with compatible t        i,tca9539
[0001.903] W> fetch_driver_phandle_from_dt: failed to get node with compatible n        xp,tca9539
[0001.909] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.915] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.922] W> fetch_driver_phandle_from_dt: failed to get node with compatible t        i,tca9539
[0001.930] W> fetch_driver_phandle_from_dt: failed to get node with compatible n        xp,tca9539
[0001.937] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.944] I> fixed regulator driver initialized
[0001.952] I> register 'maxim' power off handle
[0001.952] I> virtual i2c enabled
[0001.955] I> registered 'maxim,max20024' pmic
[0001.959] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.966] I> Boot-device: QSPI
[0001.969] I> Boot_device: QSPI_FLASH instance: 0
[0001.974] I> QSPI source rate = 204000 Khz
[0001.977] I> Requested rate for QSPI clock = 34000 Khz
[0001.982] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.987] I> QSPI Flash Size = 32 MB
[0001.995] I> Qspi initialized successfully
[0001.995] I> qspi flash-0 params source = boot args
[0001.999] I> create_pm_ids: id: 3509-0000-100-F, len: 15
[0002.004] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00        ,touch-config:00,display-config:00,, len: 93
[0002.015] I> Found sdcard
[0002.019] I> enabling 'vdd-sdmmc1-sw' regulator
[0002.026] I> regulator 'vdd-sdmmc1-sw' already enabled
[0002.054] I> sdmmc SDR mode
[0002.068] I> sdcard-0 params source = DT-BL
[0002.070] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.079] I> Found 11 partitions in SDCARD (instance 0)
[0002.085] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.088] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.088] I> hdmi cable connected
[0002.089] W> set volts not configured for 'vdd-1v0'
[0002.090] W> set volts not configured for 'vdd-1v8-hs'
[0002.091] I> retrieved tmds range from prod_list_hdmi_soc
[0002.093] E> invalid display type
[0002.094] E> cannot find any other nvdisp nodes
[0002.109] I> edid read success
[0002.122] I> edid read success
[0002.122] I> width = 1920, height = 1080, frequency = 148500000
[0002.123] I> width = 1366, height = 768, frequency = 85750000
[0002.123] I> width = 1920, height = 1080, frequency = 148500000
[0002.123] I> width = 1920, height = 1080, frequency = 148351648
[0002.124] I> width = 1280, height = 720, frequency = 74175824
[0002.129] I> width = 720, height = 480, frequency = 26973026
[0002.135] I> width = 720, height = 480, frequency = 26973026
[0002.140] I> width = 1920, height = 1080, frequency = 148351648
[0002.146] I> width = 1280, height = 720, frequency = 74175824
[0002.152] I> width = 720, height = 576, frequency = 26973026
[0002.157] I> width = 720, height = 576, frequency = 26973026
[0002.163] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.173] I> hdmi_enable, starting HDMI initialisation
[0002.178] I> hdmi_enable, HDMI initialisation complete
[0002.188] I> Load in CBoot Boot Options partition and parse it
[0002.189] E> Error -9 when finding node with path /boot-configuration
[0002.191] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file        .
[0002.198] I> Using default boot order
[0002.202] I> boot-dev-order :-
[0002.205] I> 1.sd
[0002.206] I> 2.usb
[0002.208] I> 3.nvme
[0002.210] I> 4.emmc
[0002.212] I> 5.net
[0002.214] I> Hit any key to stop autoboot:     4       3       2       1
[0004.222] initializing target
[0004.222] calling apps_init()
[0004.223] starting app kernel_boot_app
[0004.234] I> found decompressor handler: lz4-legacy
[0004.234] I> decompressing BMP blob ...
[0004.245] I> Kernel type = Normal
[0004.246] I> ########## SD (0) boot ##########
[0004.246] I> Found sdcard
[0004.248] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.251] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.278] I> sdmmc SDR mode
[0004.292] I> sdcard-0 params source = DT-BL
[0004.292] I> Already published: 00060000
[0004.293] I> Look for boot partition
[0004.293] I> Fallback: assuming 0th partition is boot partition
[0004.293] I> Detect filesystem
[0004.310] I> Loading kernel-bootctrl from partition
[0004.310] I> Loading partition kernel-bootctrl at 0xa4ae0000 from device(0x6)
[0004.335] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.335] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.336] I> Loading extlinux.conf ...
[0004.336] I> Loading extlinux.conf binary from rootfs ...
[0004.336] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.366] I> Loading extlinux.conf sig file from rootfs ...
[0004.366] I> rootfs path: /sd/boot/extlinux/extlinux.conf.sig
[0004.383] I> Validate extlinux.conf ...
[0004.383] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0004.384] I> Encryption fuse is not ON
[0004.384] I> L4T boot options
[0004.384] I> [1]: "primary kernel"
[0004.385] I> Enter choice:
[0007.386] I> Continuing with default option: 1
[0007.386] I> Loading kernel ...
[0007.386] I> Loading kernel binary from rootfs ...
[0007.387] I> rootfs path: /sd/boot/Image
[0010.185] I> Loading kernel sig file from rootfs ...
[0010.186] I> rootfs path: /sd/boot/Image.sig
[0010.198] I> overload load_size to 34484232 (from 34484240)
[0010.199] I> Validate kernel ...
[0010.199] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.513] I> Encryption fuse is not ON
[0010.544] I> Loading kernel-dtb ...
[0010.545] I> No kernel-dtb binary path
[0010.545] I> Continue to load from partition ...
[0010.545] W> No valid slot number is found in scratch register
[0010.546] W> Return default slot: _a
[0010.546] I> A/B: bin_type (38) slot 0
[0010.546] I> Loading kernel-dtb from partition
[0010.548] I> Loading partition kernel-dtb at 0x91000000 from device(0x6)
[0010.595] I> Validate kernel-dtb ...
[0010.595] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.598] I> Encryption fuse is not ON
[0010.599] I> Loading ramdisk from rootfs ...
[0010.599] I> Loading ramdisk binary from rootfs ...
[0010.600] I> rootfs path: /sd/boot/initrd
[0011.194] I> Loading ramdisk sig file from rootfs ...
[0011.195] I> rootfs path: /sd/boot/initrd.sig
[0011.207] I> overload load_size to 7238358 (from 7238368)
[0011.208] I> Validate ramdisk ...
[0011.208] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0011.274] I> Encryption fuse is not ON
[0011.288] I> Kernel hdr @0xa4ae0000
[0011.288] I> Kernel dtb @0x90000000
[0011.288] I> decompressor handler not found
[0011.289] I> Copying kernel image (34484232 bytes) from 0xa4ae0000 to 0x80080000 ... [0011.299] I> Done
[0011.300] I> Updated bpmp info to DTB
[0011.301] I> Ramdisk: Base: 0x92000000; Size: 0x6e72d6
[0011.301] I> Updated initrd info to DTB
[0011.301] W> WARN: Fail to override "console=none" in commandline
[0011.302] I> Active rootfs suffix:
[0011.304] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.311] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.319] W> No valid slot number is found in scratch register
[0011.324] W> Return default slot: _a
[0011.328] I> Active slot suffix:
[0011.331] I> add_boot_slot_suffix: slot_suffix =
[0011.335] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06a9000 lut_mem=0x2008@0xa06a4000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.365] I> Updated bootarg info to DTB
[0011.369] E> Error 892665857: Failed to get CVM EEPROM contents
[0011.374] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0011.381] E> Failed to get WIFI MAC address
[0011.385] E> Error 892665857: Failed to get CVM EEPROM contents
[0011.390] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0011.397] E> Failed to get Bluetooth MAC address
[0011.401] E> Error 892665857: Failed to get CVM EEPROM contents
[0011.407] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0011.413] E> Failed to get Ethernet MAC address
[0011.418] W> "plugin-manager" doesn't exist, creating
[0011.422] W> "chip-id" doesn't exist, creating
[0011.427] I> Adding /chosen/plugin-manager/chip-id
[0011.431] W> "configs" doesn't exist, creating
[0011.436] I> Adding /chosen/plugin-manager/configs
[0011.440] W> "ids" doesn't exist, creating
[0011.444] I> Adding /chosen/plugin-manager/ids
[0011.449] W> "odm-data" doesn't exist, creating
[0011.453] I> Adding /chosen/plugin-manager/odm-data
[0011.460] W> "memory" doesn't exist, creating
[0011.462] I> [0] START: 0x80000000, END: 0xac000000
[0011.466] I> [1] START: 0xac004000, END: 0xf0ad0000
[0011.471] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0011.476] I> dram_block larger than 80000000
[0011.480] I> [3] START: 0x100000000, END: 0x280000000
[0011.485] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.491] I> added [base:0xac200000, size:0x44800000] to /memory
[0011.497] I> added [base:0x100000000, size:0x180000000] to /memory
[0011.503] I> Updated memory info to DTB
[0011.507] E> add_disp_param: failed to get display params for du=1
[0011.513] W> "reset" doesn't exist, creating
[0011.517] I> Adding ecid(00000001644578840400000010fd8180) to DT
[0011.522] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.527] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.532] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.536] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.541] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.546] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.551] I> Deleted cpu@6 node in DT
[0011.554] I> Deleted cpu@7 node in DT
[0011.558] I> Deleted cluster3 node in FDT
[0011.562] I> Update arm-pmu in FDT
[0011.565] I> - update property: interrupts
[0011.569] I> - update property: interrupt-affinity
[0011.574] W> "misc-data" doesn't exist, creating
[0011.578] I> Boot-device: QSPI
[0011.581] W> Unknown boot device
[0011.584] I> Add storage-qspi to plugin-manager/misc-data
[0011.589] W> Unknown storage device
[0011.592] E> Error 892665857: Failed to read CVM EEPROM
[0011.597] E> Failed to get serial number
[0011.601] I> Plugin-manager override starting
[0011.606] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.612] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.620] I> Disable plugin-manager status in FDT
[0011.621] I> Plugin-manager override finished successfully
[0011.627] I> tegrabl_load_kernel_and_dtb: Done
[0011.649] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5403-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Sat Feb 19 08:58:27 PST 2022
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44800000
[    0.000000] OF: fdt: - 100000000 ,  180000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] Found tegra_fbmem: 00800000@a06a9000
[    0.000000] Found lut_mem: 00002008@a06a4000
▒▒WARNING: pll_d2 has no dyn ramp
▒▒[    1.786769] eqos_get_mac_address_dtb: bad mac address at /chosen/nvidia,ether-mac: null.
[    1.786779] eqos 2490000.ether_qos (unnamed net_device) (uninitialized): ether-mac read from DT failed -99
[    1.951613] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.951738] imx219 9-0010: board setup failed
[    1.975618] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.975950] imx219 10-0010: board setup failed
▒▒WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
boot_log.txt (30.8 KB)
I was able to get the device to boot to Jetpack 4.6.1 by copying the values of the eeprom from another jetson xavier nx. The only original values I kept were the MAC addresses.
@WayneWWW is this a proper solution, or should I investigate further?
It is okay. But are you able to boot up now?
Yes, it boots now
