Xavier NX Developer Kit, Native SSD Boot Problem
Hi there
I am trying to Install Jetpack 4.6.1 on Xavier NX Developer kit (P3668-0000 + P3518-0000)
I tried Download and extracting these via with commands in documentation
sudo tar xpvf Jetson_Linux_R32.7.1_aarch64.tbz2
cd Linux_for_Tegra/rootfs/
sudo tar xpvf ../../Tegra_Linux_Sample-Root-Filesystem_R32.7.1_aarch64.tbz2
cd ../..
sudo tar xvjf secureboot_R32.7.1_aarch64.tbz2
sudo ./apply_binaries.sh
sudo ./nvsdkmanager_flash.sh --storage "nvme0n1p1"
but after i start my device i get:
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.9-t194-41334769-73a9b7ef)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x0
[0000.059] I> rst_source : 0x0
[0000.062] I> rst_level : 0x0
[0000.066] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] W> No valid slot number is found in scratch register
[0000.092] W> Return default slot: _a
[0000.095] I> Active Boot chain : 0
[0000.098] I> Boot-device: QSPI
[0000.101] I> Qspi flash params source = brbct
[0000.107] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.114] I> Temperature = 28500
[0000.117] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.122] W> Skipping boost for clk: BPMP_APB
[0000.126] W> Skipping boost for clk: AXI_CBB
[0000.130] W> Skipping boost for clk: AON_CPU_NIC
[0000.134] W> Skipping boost for clk: CAN1
[0000.138] W> Skipping boost for clk: CAN2
[0000.142] I> Boot-device: QSPI
[0000.145] I> Boot-device: QSPI
[0000.148] I> Qspi flash params source = mb1bct
[0000.152] I> Qspi using bpmp-dma
[0000.155] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.161] I> Qspi flash params source = mb1bct
[0000.167] I> ECC region[0]: Start:0x0, End:0x0
[0000.171] I> ECC region[1]: Start:0x0, End:0x0
[0000.175] I> ECC region[2]: Start:0x0, End:0x0
[0000.179] I> ECC region[3]: Start:0x0, End:0x0
[0000.183] I> ECC region[4]: Start:0x0, End:0x0
[0000.187] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.193] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.198] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.202] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.207] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.212] E> FAILED: Thermal config
[0000.219] E> FAILED: MEMIO rail config
[0000.229] I> Boot-device: QSPI
[0000.232] I> Qspi flash params source = mb1bct
[0000.241] I> Qspi flash params source = mb1bct
[0000.253] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.328]�V-$+��[0000.359] I> Qspi flash params source = mb1bct
[0000.371] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [0000.379] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-6fc80c72)
[0000.380] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.381] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.381] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.387] W> device prod register failed
[0000.391] I> gpio framework initialized
[0000.395] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.402] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.410] I> sdcard_params [0, 55, 0, 50] in mb1_bct
[0000.415] I> Boot-device: QSPI
[0000.417] I> Boot_device: QSPI_FLASH instance: 0
[0000.423] I> QSPI Flash Size = 32 MB
[0000.428] I> Qspi initialized successfully
[0000.429] I> qspi flash-0 params source = boot args
[0000.439] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.440] W> No valid slot number is found in scratch register
[0000.445] W> Return default slot: _a
[0000.448] I> Active Boot chain : 0
[0000.452] I> parsing oem signed section of bpmp-fw header done
[0000.458] I> bpmp-fw binary init read from storage
[0000.463] I> oem authentication of bpmp-fw header done
[0000.476] I> bpmp-fw binary done read from storage
[0000.477] I> bpmp-fw: Authentication init Done
[0000.478] I> parsing oem signed section of cpubl header done
[0000.482] I> cpubl binary init read from storage
[0000.486] I> bpmp-fw: Authentication Finalize Done
[0000.491] I> oem authentication of cpubl header done
[0000.499] I> cpubl binary done read from storage
[0000.500] I> cpubl: Authentication init Done
[0000.504] I> parsing oem signed section of rce header done
[0000.510] I> rce binary init read from storage
[0000.514] I> Relocating BR-BCT
[0000.517] I> cpubl: Authentication Finalize Done
[0000.521] I> oem authentication of rce header done
[0000.526] I> rce binary done read from storage
[0000.530] I> rce: Authentication init Done
[0000.534] I> parsing oem signed section of ape header done
[0000.539] I> ape binary init read from storage
[0000.544] I> rce: Authentication Finalize Done
[0000.548] I> oem authentication of ape header done
[0000.552] I> ape binary done read from storage
[0000.557] I> ape: Authentication init Done
[0000.561] I> parsing oem signed section of tos header done
[0000.566] I> tos binary init read from storage
[0000.570] I> ape: Authentication Finalize Done
[0000.575] I> oem authentication of tos header done
[0000.582] I> tos binary done read from storage
[0000.584] I> tos: Authentication init Done
[0000.588] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.594] I> bpmp-fw-dtb binary init read from storage
[0000.598] I> tos: Authentication Finalize Done
[0000.605] I> oem authentication of bpmp-fw-dtb header done
[0000.610] I> bpmp-fw-dtb binary done read from storage
[0000.613] I> bpmp-fw-dtb: Authentication init Done
[0000.618] I> parsing oem signed section of cpubl-dtb header done
[0000.624] I> cpubl-dtb binary init read from storage
[0000.628] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.718] I> oem authentication of cpubl-dtb header done
[0000.718] I> cpubl-dtb binary done read from storage
[0000.719] I> cpubl-dtb: Authentication init Done
[0000.720] I> parsing oem signed section of eks header done
[0000.721] I> eks binary init read from storage
[0000.721] I> cpubl-dtb: Authentication Finalize Done
[0000.722] I> oem authentication of eks header done
[0000.726] I> eks binary done read from storage
[0000.731] I> eks: Authentication init Done
[0000.735] I> eks: Authentication Finalize Done
[0000.739] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE:  BL31: v1.3(release):b5eeb33f7
NOTICE:  BL31: Built : 08:55:29, Feb 19 2022
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing .......
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
  [0001.098] I> Welcome to Cboot��mrq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
[0001.099] I> Cboot Version: t194-63226c45
[0001.101] I> CPU-BL Params @ 0xf2820000
[0001.104] I>  0) Base:0x00000000 Size:0x00000000
[0001.109] I>  1) Base:0xf1100000 Size:0x00100000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.113] I>  2) Base:0xf2000000 Size:0x00200000
[0001.268] I>  3) Base:0xf1200000 Size:0x00200000
[0001.272] I>  4) Base:0xf1000000 Size:0x00100000
[0001.276] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.281] I>  6) Base:0xf3800000 Size:0x00400000
[0001.285] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.290] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.294] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.299] I> 10) Base:0xf3000000 Size:0x00800000
[0001.303] I> 11) Base:0x40000000 Size:0x00040000
[0001.308] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.312] I> 13) Base:0x40046000 Size:0x00002000
[0001.317] I> 14) Base:0x40048000 Size:0x00002000
[0001.321] I> 15) Base:0xac000000 Size:0x00004000
[0001.326] I> 16) Base:0x4004a000 Size:0x00002000
[0001.330] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.334] I> 18) Base:0x4004c000 Size:0x00002000
[0001.339] I> 19) Base:0xf2200000 Size:0x00600000
[0001.343] I> 20) Base:0x4004e000 Size:0x00002000
[0001.348] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.352] I> 22) Base:0x00000000 Size:0x00000000
[0001.357] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.361] I> 24) Base:0xf6000000 Size:0x02000000
[0001.366] I> 25) Base:0x40050000 Size:0x00002000
[0001.370] I> 26) Base:0x40040000 Size:0x00006000
[0001.375] I> 27) Base:0xf1800000 Size:0x00400000
[0001.379] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.384] I> 29) Base:0xf1400000 Size:0x00400000
[0001.388] I> 30) Base:0x00000000 Size:0x00000000
[0001.392] I> 31) Base:0x00000000 Size:0x00000000
[0001.397] I> 32) Base:0xf8000000 Size:0x08000000
[0001.401] I> 33) Base:0x00000000 Size:0x00000000
[0001.406] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.410] I> 35) Base:0xab000000 Size:0x01000000
[0001.415] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.419] I> 37) Base:0xf2800000 Size:0x00800000
[0001.424] I> 38) Base:0x80000000 Size:0x20000000
[0001.428] I> 39) Base:0xb0000000 Size:0x08000000
[0001.433] I> 40) Base:0x00000000 Size:0x00000000
[0001.437] I> 41) Base:0x00000000 Size:0x00000000
[0001.442] I> 42) Base:0x00000000 Size:0x00000000
[0001.446] I> 43) Base:0x00000000 Size:0x00000000
[0001.451] I> 44) Base:0x00000000 Size:0x00000000
[0001.455] I> 45) Base:0x00000000 Size:0x00000000
[0001.459] GIC-SPI Target CPU: 0
[0001.462] Interrupts Init done
[0001.465] calling constructors
[0001.468] initializing heap
[0001.471] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.475] initializing threads
[0001.478] initializing timers
[0001.481] creating bootstrap completion thread
[0001.485] top of bootstrap2()
[0001.488] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.492] initializing platform
[0001.495] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.501] W> device prod register failed
[0001.505] I> Bl_dtb @0xaaf00000
[0001.510] W> "plugin-manager" doesn't exist, creating
[0001.513] W> "ids" doesn't exist, creating
[0001.517] W> "connection" doesn't exist, creating
[0001.521] W> "configs" doesn't exist, creating
[0001.533] E> failed to read label property for node 158736: 13
[0001.536] E> failed to read reg property for node 158800: 13
[0001.539] E> failed to read reg property for node 158852: 13
[0001.543] E> failed to read reg property for node 158936: 13
[0001.550] I> Find /i2c@3160000's alias i2c0
[0001.552] I> Reading eeprom i2c=0 address=0x50
[0001.581] I> Device at /i2c@3160000:0x50
[0001.581] I> Reading eeprom i2c=0 address=0x57
[0001.606] I> Device at /i2c@3160000:0x57
[0001.607] I> Find /i2c@c240000's alias i2c1
[0001.608] I> Reading eeprom i2c=1 address=0x50
[0001.610] E> I2C: slave not found in slaves.
[0001.610] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.611] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.611] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.620] E> eeprom: Retry to read I2C slave device.
[0001.625] E> I2C: slave not found in slaves.
[0001.629] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.637] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.642] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.652] E> eeprom: Failed to read I2C slave device
[0001.657] I> Eeprom read failed 0x3526070d
[0001.661] I> create_pm_ids: id: 3668-0000-300-B, len: 15
[0001.666] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:03
[0001.677] I> create_pm_ids: id: 3509-0000-100-J, len: 15
[0001.682] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:03
[0001.693] I> Adding plugin-manager/ids/3668-0000-300=/i2c@3160000:module@0x50
[0001.700] W> "i2c@3160000" doesn't exist, creating
[0001.705] W> "module@0x50" doesn't exist, creating
[0001.709] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.716] W> "module@0x57" doesn't exist, creating
[0001.722] I> Adding plugin-manager/cvm
[0001.725] W> "chip-id" doesn't exist, creating
[0001.729] I> Adding plugin-manager/chip-id/A02P
[0001.733] I> Plugin-manager override starting
[0001.738] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.746] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.752] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.758] I> Disable plugin-manager status in FDT
[0001.760] I> Plugin-manager override finished successfully
[0001.765] I> gpio framework initialized
[0001.770] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.777] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.784] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.791] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.799] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.806] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.812] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.819] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.827] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.834] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.841] I> fixed regulator driver initialized
[0001.848] I> register 'maxim' power off handle
[0001.849] I> virtual i2c enabled
[0001.851] I> registered 'maxim,max20024' pmic
[0001.856] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.862] I> Boot-device: QSPI
[0001.865] I> Boot_device: QSPI_FLASH instance: 0
[0001.870] I> QSPI source rate = 204000 Khz
[0001.874] I> Requested rate for QSPI clock = 34000 Khz
[0001.879] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.884] I> QSPI Flash Size = 32 MB
[0001.891] I> Qspi initialized successfully
[0001.891] I> qspi flash-0 params source = boot args
[0001.895] I> create_pm_ids: id: 3668-0000-300-B, len: 15
[0001.900] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:03
[0001.911] I> create_pm_ids: id: 3509-0000-100-J, len: 15
[0001.917] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:03
[0001.928] I> Found sdcard
[0001.932] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.938] I> regulator 'vdd-sdmmc1-sw' already enabled
[0001.950] W> Error opening sdcard-0
[0001.950] I> sdcard-0 params source = DT-BL
[0001.951] E> Failed to initialize device 6-0
[0001.951] E> Error config_storage
[0001.954] HALT: spinning forever...
any idea what i am doing wrong?
Please directly use the SDKmanager GUI to select the NVMe.
Have done it, Already.
No success
Do you have a SDcard connected on the module? If there is, please remove it.
