hi,AGX Xavier Module Can not boot normally ,I am successful flashing the Jeston AGX Xavier by SDK Manager.However the module still does not work.and the boot information is as follows:
log.txt (27.4 KB)
Is your module connected to a display of any kind?
If not, can you connect the main HDMI port to a display and see what you can see?
Please follow this to dump the log.
The log is as follows :
[0000.105] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet leve l 2 from HW fuses.
[0000.114] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.119] I> Boot-mode: Coldboot
[0000.122] I> Chip revision : A02P
[0000.125] I> Bootrom patch version : 15 (correctly patched)
[0000.130] I> ATE fuse revision : 0x200
[0000.134] I> Ram repair fuse : 0x1
[0000.137] I> Ram Code : 0x2
[0000.139] I> rst_source : 0x0
[0000.142] I> rst_level : 0x0
[0000.146] I> Boot-device: eMMC
[0000.160] I> sdmmc DDR50 mode
[0000.165] W> No valid slot number is found in scratch register
[0000.170] W> Return default slot: _a
[0000.173] I> Active Boot chain : 0
[0000.177] I> Boot-device: eMMC
[0000.180] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.188] I> Temperature = 32500
[0000.191] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.195] W> Skipping boost for clk: BPMP_APB
[0000.199] W> Skipping boost for clk: AXI_CBB
[0000.203] W> Skipping boost for clk: AON_CPU_NIC
[0000.208] W> Skipping boost for clk: CAN1
[0000.211] W> Skipping boost for clk: CAN2
[0000.216] I> Boot-device: eMMC
[0000.218] I> Boot-device: eMMC
[0000.228] I> Sdmmc: HS400 mode enabled
[0000.232] I> ECC region[0]: Start:0x0, End:0x0
[0000.236] I> ECC region[1]: Start:0x0, End:0x0
[0000.241] I> ECC region[2]: Start:0x0, End:0x0
[0000.245] I> ECC region[3]: Start:0x0, End:0x0
[0000.249] I> ECC region[4]: Start:0x0, End:0x0
[0000.253] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.259] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.263] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.268] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.272] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.277] E> FAILED: Thermal config
[0000.285] E> FAILED: MEMIO rail config
[0000.303] I> Boot-device: eMMC
[0000.312] I> sdmmc bdev is already initialized
[0000.385] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.393] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-feba59 43)
[0000.394] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.394] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.395] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.401] W> device prod register failed
[0000.405] I> Boot-device: eMMC
[0000.407] I> Boot_device: SDMMC_BOOT instance: 3
[0000.413] I> sdmmc-3 params source = boot args
[0000.416] I> sdmmc bdev is already initialized
[0000.420] I> sdmmc-3 params source = boot args
[0000.429] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.435] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.436] W> No valid slot number is found in scratch register
[0000.441] W> Return default slot: _a
[0000.445] I> Active Boot chain : 0
[0000.448] I> parsing oem signed section of bpmp-fw header done
[0000.454] I> bpmp-fw binary init read from storage
[0000.459] I> oem authentication of bpmp-fw header done
[0000.465] I> bpmp-fw binary done read from storage
[0000.468] I> bpmp-fw: Authentication init Done
[0000.473] I> parsing oem signed section of cpubl header done
[0000.478] I> cpubl binary init read from storage
[0000.482] I> bpmp-fw: Authentication Finalize Done
[0000.487] I> oem authentication of cpubl header done
[0000.492] I> cpubl binary done read from storage
[0000.496] I> cpubl: Authentication init Done
[0000.501] I> parsing oem signed section of rce header done
[0000.506] I> rce binary init read from storage
[0000.510] I> Relocating BR-BCT
[0000.513] I> cpubl: Authentication Finalize Done
[0000.517] I> oem authentication of rce header done
[0000.522] I> rce binary done read from storage
[0000.526] I> rce: Authentication init Done
[0000.531] I> parsing oem signed section of ape header done
[0000.535] I> ape binary init read from storage
[0000.540] I> rce: Authentication Finalize Done
[0000.544] I> oem authentication of ape header done
[0000.549] I> ape binary done read from storage
[0000.553] I> ape: Authentication init Done
[0000.558] I> parsing oem signed section of tos header done
[0000.562] I> tos binary init read from storage
[0000.566] I> ape: Authentication Finalize Done
[0000.571] I> oem authentication of tos header done
[0000.575] I> tos binary done read from storage
[0000.580] I> tos: Authentication init Done
[0000.584] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.590] I> bpmp-fw-dtb binary init read from storage
[0000.595] I> tos: Authentication Finalize Done
[0000.601] I> oem authentication of bpmp-fw-dtb header done
[0000.607] I> bpmp-fw-dtb binary done read from storage
[0000.609] I> bpmp-fw-dtb: Authentication init Done
[0000.614] I> parsing oem signed section of cpubl-dtb header done
[0000.620] I> cpubl-dtb binary init read from storage
[0000.625] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.662] I> oem authentication of cpubl-dtb header done
[0000.662] I> cpubl-dtb binary done read from storage
[0000.663] I> cpubl-dtb: Authentication init Done
[0000.665] I> parsing oem signed section of eks header done
[0000.666] I> eks binary init read from storage
[0000.666] I> cpubl-dtb: Authentication Finalize Done
[0000.667] I> oem authentication of eks header done
[0000.670] I> eks binary done read from storage
[0000.675] I> eks: Authentication init Done
[0000.679] I> eks: Authentication Finalize Done
[0000.683] I> EKB detected (length: 0x410) @ VA:0x5270a400
▒▒NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:38:54, Feb 19 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing …
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
▒▒mrq initialized
▒▒[0001.184] I> Welcome to Cboot
▒▒fmon_post initialized
▒▒[0001.184] I> Cboot Version: t194-9efcbc4f
[0001.185] I> CPU-BL Params @ 0xf2820000
[0001.185] I> 0) Base:0x00000000 Size:0x00000000
[0001.189] I> 1) Base:0xf1100000 Size:0x00100000
[0001.193] I> 2) Base:0xf2000000 Size:0x00200000
[0001.198] I> 3) Base:0xf1200000 Size:0x00200000
[0001.202] I> 4) Base:0xf1000000 Size:0x00100000
▒▒clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
▒▒[0001.207] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.286] I> 6) Base:0xf3800000 Size:0x00400000
[0001.291] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.295] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.300] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.304] I> 10) Base:0xf3000000 Size:0x00800000
[0001.308] I> 11) Base:0x40000000 Size:0x00040000
[0001.313] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.317] I> 13) Base:0x40046000 Size:0x00002000
[0001.322] I> 14) Base:0x40048000 Size:0x00002000▒▒emc_debugfs initialized
dvs_debugfs initialized
[0001.331] I> 15) Base:0xac000000 Size:0x00004000▒▒fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0001.381] I> 16) Base:0x4004a000 Size:0x00002000
[0001.386] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.390] I> 18) Base:0x4004c000 Size:0x00002000
[0001.395] I> 19) Base:0xf2200000 Size:0x00600000
[0001.399] I> 20) Base:0x4004e000 Size:0x00002000
[0001.404] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.408] I> 22) Base:0x00000000 Size:0x00000000
[0001.413] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.417] I> 24) Base:0xf6000000 Size:0x02000000
[0001.422] I> 25) Base:0x40050000 Size:0x00002000
[0001.426] I> 26) Base:0x40040000 Size:0x00006000
[0001.431] I> 27) Base:0xf1800000 Size:0x00400000
[0001.435] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.440] I> 29) Base:0xf1400000 Size:0x00400000
[0001.444] I> 30) Base:0x00000000 Size:0x00000000
[0001.448] I> 31) Base:0x00000000 Size:0x00000000
[0001.453] I> 32) Base:0xf8000000 Size:0x08000000
[0001.457] I> 33) Base:0x00000000 Size:0x00000000
[0001.462] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.466] I> 35) Base:0xab000000 Size:0x01000000
[0001.471] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.475] I> 37) Base:0xf2800000 Size:0x00800000
[0001.480] I> 38) Base:0x80000000 Size:0x20000000
[0001.484] I> 39) Base:0xb0000000 Size:0x08000000
[0001.489] I> 40) Base:0x00000000 Size:0x00000000
[0001.493] I> 41) Base:0x00000000 Size:0x00000000
[0001.498] I> 42) Base:0x00000000 Size:0x00000000
[0001.502] I> 43) Base:0x00000000 Size:0x00000000
[0001.506] I> 44) Base:0x00000000 Size:0x00000000
[0001.511] I> 45) Base:0x00000000 Size:0x00000000
[0001.515] GIC-SPI Target CPU: 0
[0001.518] Interrupts Init done
[0001.521] calling constructors
[0001.524] initializing heap
[0001.527] I> Heap: [0xa06945e8 … 0xab000000]
[0001.531] initializing threads
[0001.534] initializing timers
[0001.537] creating bootstrap completion thread
[0001.541] top of bootstrap2()
[0001.544] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.548] initializing platform
[0001.551] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.557] W> device prod register failed
[0001.561] I> Bl_dtb @0xaaf00000
[0001.567] W> “plugin-manager” doesn’t exist, creating
[0001.569] W> “ids” doesn’t exist, creating
[0001.573] W> “connection” doesn’t exist, creating
[0001.577] W> “configs” doesn’t exist, creating
[0001.587] I> Find /i2c@3160000’s alias i2c0
[0001.587] I> Reading eeprom i2c=0 address=0x50
[0001.615] I> Device at /i2c@3160000:0x50
[0001.615] I> Reading eeprom i2c=0 address=0x56
[0001.640] I> Device at /i2c@3160000:0x56
[0001.641] I> Find /i2c@3180000’s alias i2c2
[0001.642] I> Reading eeprom i2c=2 address=0x54
[0001.643] E> I2C: slave not found in slaves.
[0001.644] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start tr ue.
[0001.645] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.645] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.654] E> eeprom: Failed to read I2C slave device
[0001.659] I> Eeprom read failed 0x3526070d
[0001.662] I> Reading eeprom i2c=2 address=0x57
[0001.667] E> I2C: slave not found in slaves.
[0001.671] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start tr ue.
[0001.679] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.684] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.694] E> eeprom: Failed to read I2C slave device
[0001.699] I> Eeprom read failed 0x3526070d
[0001.703] I> Reading eeprom i2c=2 address=0x52
[0001.707] E> I2C: slave not found in slaves.
[0001.711] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.719] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.724] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.734] E> eeprom: Failed to read I2C slave device
[0001.739] I> Eeprom read failed 0x3526070d
[0001.744] I> Find /i2c@c240000’s alias i2c1
[0001.747] I> Reading eeprom i2c=1 address=0x52
[0001.752] E> I2C: slave not found in slaves.
[0001.755] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.763] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.768] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.778] E> eeprom: Retry to read I2C slave device.
[0001.783] E> I2C: slave not found in slaves.
[0001.787] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.795] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.800] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.810] E> eeprom: Failed to read I2C slave device
[0001.815] I> Eeprom read failed 0x3526070d
[0001.819] I> Reading eeprom i2c=1 address=0x50
[0001.823] E> I2C: slave not found in slaves.
[0001.827] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr ue.
[0001.835] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.840] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.850] E> eeprom: Retry to read I2C slave device.
[0001.855] E> I2C: slave not found in slaves.
[0001.859] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr ue.
[0001.867] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.872] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.882] E> eeprom: Failed to read I2C slave device
[0001.887] I> Eeprom read failed 0x3526070d
[0001.890] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.896] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0001.907] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.912] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0001.923] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.930] W> “i2c@3160000” doesn’t exist, creating
[0001.935] W> “module@0x50” doesn’t exist, creating
[0001.939] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.946] W> “module@0x56” doesn’t exist, creating
[0001.953] I> Adding plugin-manager/cvm
[0001.955] W> “chip-id” doesn’t exist, creating
[0001.959] I> Adding plugin-manager/chip-id/A02P
[0001.963] I> Plugin-manager override starting
[0001.969] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.978] I> node /plugin-manager/fragement-soft-wdt matches
[0001.985] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.990] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.003] I> Disable plugin-manager status in FDT
[0002.004] I> Plugin-manager override finished successfully
[0002.004] I> gpio framework initialized
[0002.006] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driv er
[0002.013] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.019] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.027] W> fetch_driver_phandle_from_dt: failed to get node with compatible t i,tca9539
[0002.035] W> fetch_driver_phandle_from_dt: failed to get node with compatible n xp,tca9539
[0002.041] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.047] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.054] W> fetch_driver_phandle_from_dt: failed to get node with compatible t i,tca9539
[0002.062] W> fetch_driver_phandle_from_dt: failed to get node with compatible n xp,tca9539
[0002.069] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.076] I> fixed regulator driver initialized
[0002.087] I> register ‘maxim’ power off handle
[0002.088] I> virtual i2c enabled
[0002.088] I> registered ‘maxim,max20024’ pmic
[0002.091] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.097] I> Boot-device: eMMC
[0002.100] I> Boot_device: SDMMC_BOOT instance: 3
[0002.109] I> sdmmc-3 params source = boot args
[0002.109] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0002.114] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0002.125] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.130] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0002.141] I> sdmmc bdev is already initialized
[0002.146] I> sdmmc-3 params source = boot args
[0002.176] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.189] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.200] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.206] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.206] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.207] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.211] E> invalid display type
[0002.215] E> invalid display type
[0002.216] E> cannot find any other nvdisp nodes
[0002.217] E> no valid display unit config found in dtb
[0002.218] W> display init failed
[0002.218] I> Load in CBoot Boot Options partition and parse it
[0002.229] E> Error -9 when finding node with path /boot-configuration
[0002.229] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file .
[0002.236] I> Using default boot order
[0002.240] I> boot-dev-order :-
[0002.243] I> 1.sd
[0002.245] I> 2.usb
[0002.246] I> 3.nvme
[0002.248] I> 4.emmc
[0002.250] I> 5.net
[0002.252] I> Hit any key to stop autoboot: 4 3 2 1
[0004.260] initializing target
[0004.260] calling apps_init()
[0004.261] starting app kernel_boot_app
[0004.280] I> found decompressor handler: lz4-legacy
[0004.281] I> decompressing BMP blob …
[0004.292] I> Kernel type = Normal
[0004.292] I> Loading kernel-bootctrl from partition
[0004.293] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x1)
[0004.299] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.300] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.300] I> ########## SD (0) boot ##########
[0004.301] I> No sdcard
[0004.302] I> -0 params source =
[0004.305] E> Blockdev open: exit error
[0004.309] E> SD boot failed, err: 724238353
[0004.313] I> ########## USB (0) boot ##########
[0004.322] W> No valid slot number is found in scratch register
[0004.323] W> Return default slot: _a
[0004.339] I> USB Firmware Version: 60.06 release
[0004.394] I> regulator of usb2-0 already enabled
[0004.401] I> regulator of usb2-1 already enabled
[0004.407] I> regulator of usb2-2 already enabled
[0004.416] I> enabling ‘vdd-5v-sata’ regulator
[0005.421] E> failed to initialize xhci controller
[0005.421] E> Error in init of XUSB host driver, err: 79790026
[0005.422] W> Failed to initialize device 5-0
[0005.422] E> USB boot failed, err: 2037973030
[0005.422] I> ########## Fixed storage boot ##########
[0005.429] I> Already published: 00010003
[0005.429] I> Look for boot partition
[0005.429] I> Fallback: assuming 0th partition is boot partition
[0005.432] I> Detect filesystem
[0005.459] I> Loading extlinux.conf …
[0005.459] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.502] I> L4T boot options
[0005.503] I> [1]: “primary kernel”
[0005.503] I> Enter choice:
[0008.504] I> Continuing with default option: 1
[0008.504] I> Loading kernel sig file from rootfs …
[0008.504] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.523] I> Loading kernel binary from rootfs …
[0008.523] I> rootfs path: /sdmmc_user/boot/Image
[0008.746] I> overload load_size to 34338824 (from 34338832)
[0008.763] I> Validate kernel …
[0008.764] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.076] I> Encryption fuse is not ON
[0009.086] I> No kernel-dtb binary path
[0009.086] W> No valid slot number is found in scratch register
[0009.087] W> Return default slot: _a
[0009.087] I> A/B: bin_type (38) slot 0
[0009.087] I> Loading kernel-dtb from partition
[0009.088] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.096] I> Validate kernel-dtb …
[0009.096] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.101] I> Encryption fuse is not ON
[0009.102] I> Loading ramdisk from rootfs …
[0009.106] I> Loading initrd sig file from rootfs …
[0009.111] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0009.140] I> Loading initrd binary from rootfs …
[0009.140] I> rootfs path: /sdmmc_user/boot/initrd
[0009.198] I> overload load_size to 7236840 (from 7236848)
[0009.201] I> Validate initrd …
[0009.201] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0009.267] I> Encryption fuse is not ON
[0009.275] I> Kernel hdr @0xa42d0000
[0009.275] I> Kernel dtb @0x90000000
[0009.276] I> decompressor handler not found
[0009.276] I> Copying kernel image (34338824 bytes) from 0xa42d0000 to 0x80080000 … [0009.282] I> Done
[0009.283] I> Updated bpmp info to DTB
[0009.284] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ce8
[0009.284] I> Updated initrd info to DTB
[0009.284] W> WARN: Fail to override “console=none” in commandline
[0009.288] I> Active rootfs suffix:
[0009.291] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.299] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.306] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.313] W> No valid slot number is found in scratch register
[0009.319] W> Return default slot: _a
[0009.322] I> Active slot suffix:
[0009.325] I> add_boot_slot_suffix: slot_suffix =
[0009.330] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.356] I> Updated bootarg info to DTB
[0009.360] W> MAC addr invalid!
[0009.363] E> Failed to get WIFI MAC address
[0009.367] W> MAC addr invalid!
[0009.370] E> Failed to get Bluetooth MAC address
[0009.374] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3c:86:19
[0009.381] W> “plugin-manager” doesn’t exist, creating
[0009.385] I> Adding /chosen/plugin-manager/cvm
[0009.390] W> “chip-id” doesn’t exist, creating
[0009.394] I> Adding /chosen/plugin-manager/chip-id
[0009.399] W> “configs” doesn’t exist, creating
[0009.403] I> Adding /chosen/plugin-manager/configs
[0009.407] W> “ids” doesn’t exist, creating
[0009.411] I> Adding /chosen/plugin-manager/ids
[0009.416] W> “odm-data” doesn’t exist, creating
[0009.420] I> Adding /chosen/plugin-manager/odm-data
[0009.428] W> “memory” doesn’t exist, creating
[0009.429] I> [0] START: 0x80000000, END: 0xac000000
[0009.434] I> [1] START: 0xac004000, END: 0xf0ad0000
[0009.438] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0009.443] I> dram_block larger than 80000000
[0009.447] I> [3] START: 0x100000000, END: 0x880000000
[0009.452] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.458] I> added [base:0xac200000, size:0x44800000] to /memory
[0009.464] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.471] I> Updated memory info to DTB
[0009.474] E> add_disp_param: failed to get display params for du=0
[0009.480] W> “reset” doesn’t exist, creating
[0009.484] I> Adding ecid(00000001647c98800400000005ff0100) to DT
[0009.490] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.494] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.499] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.504] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.508] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.513] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.518] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.523] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.528] W> “misc-data” doesn’t exist, creating
[0009.532] I> Boot-device: eMMC
[0009.535] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.540] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.545] W> Unknown storage device
[0009.549] I> Add serial number:1420821039706 as DT property
[0009.555] I> Plugin-manager override starting
[0009.558] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.566] I> node /plugin-manager/fragement-soft-wdt matches
[0009.573] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.577] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.589] I> Disable plugin-manager status in FDT
[0009.589] I> Plugin-manager override finished successfully
[0009.591] I> tegrabl_load_kernel_and_dtb: Done
[0009.596] E> tegrabl_display_clear: display is not initialized
[0009.601] W> Boot logo display failed…
[0009.605] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
Are you using a xavier with NV developer kit or it is a custom board? Please note that every non-NV developer kit board is considered as a custom board.
Please go to your (on host) Linux_for_Tegra/rootfs/extlinux/extlinux.conf and remove the “quiet” inside it and directly use flash.sh to flash. And share the log again.
You can follow the quick start guide here.
Linux_for_Tegra is already installed by sdkmanager on ~/nvidia/.
Ok i try, thanks
hi,after flash the NV developer kit board via flash.sh command.the board is still not work.as follows:
▒▒▒▒main enter
HW Function test
Start Scheduler.
in late init
[0000.486] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-feba59 43)
[0000.487] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.487] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.488] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.494] W> device prod register failed
[0000.498] I> Boot-device: eMMC
[0000.500] I> Boot_device: SDMMC_BOOT instance: 3
[0000.506] I> sdmmc-3 params source = boot args
[0000.509] I> sdmmc bdev is already initialized
[0000.513] I> sdmmc-3 params source = boot args
[0000.522] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.528] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.529] W> No valid slot number is found in scratch register
[0000.534] W> Return default slot: _a
[0000.538] I> Active Boot chain : 0
[0000.541] I> parsing oem signed section of bpmp-fw header done
[0000.547] I> bpmp-fw binary init read from storage
[0000.552] I> oem authentication of bpmp-fw header done
[0000.558] I> bpmp-fw binary done read from storage
[0000.561] I> bpmp-fw: Authentication init Done
[0000.566] I> parsing oem signed section of cpubl header done
[0000.571] I> cpubl binary init read from storage
[0000.575] I> bpmp-fw: Authentication Finalize Done
[0000.580] I> oem authentication of cpubl header done
[0000.585] I> cpubl binary done read from storage
[0000.589] I> cpubl: Authentication init Done
[0000.594] I> parsing oem signed section of rce header done
[0000.599] I> rce binary init read from storage
[0000.603] I> Relocating BR-BCT
[0000.606] I> cpubl: Authentication Finalize Done
[0000.610] I> oem authentication of rce header done
[0000.615] I> rce binary done read from storage
[0000.619] I> rce: Authentication init Done
[0000.624] I> parsing oem signed section of ape header done
[0000.628] I> ape binary init read from storage
[0000.633] I> rce: Authentication Finalize Done
[0000.637] I> oem authentication of ape header done
[0000.642] I> ape binary done read from storage
[0000.646] I> ape: Authentication init Done
[0000.651] I> parsing oem signed section of tos header done
[0000.655] I> tos binary init read from storage
[0000.659] I> ape: Authentication Finalize Done
[0000.664] I> oem authentication of tos header done
[0000.668] I> tos binary done read from storage
[0000.673] I> tos: Authentication init Done
[0000.677] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.683] I> bpmp-fw-dtb binary init read from storage
[0000.688] I> tos: Authentication Finalize Done
[0000.694] I> oem authentication of bpmp-fw-dtb header done
[0000.700] I> bpmp-fw-dtb binary done read from storage
[0000.702] I> bpmp-fw-dtb: Authentication init Done
[0000.707] I> parsing oem signed section of cpubl-dtb header done
[0000.713] I> cpubl-dtb binary init read from storage
[0000.718] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.755] I> oem authentication of cpubl-dtb header done
[0000.755] I> cpubl-dtb binary done read from storage
[0000.756] I> cpubl-dtb: Authentication init Done
[0000.758] I> parsing oem signed section of eks header done
[0000.759] I> eks binary init read from storage
[0000.759] I> cpubl-dtb: Authentication Finalize Done
[0000.760] I> oem authentication of eks header done
[0000.763] I> eks binary done read from storage
[0000.768] I> eks: Authentication init Done
[0000.772] I> eks: Authentication Finalize Done
[0000.776] I> EKB detected (length: 0x410) @ VA:0x5270a400
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
[0001.277] I> Welcome to Cboot
▒▒[0001.277] I> Cboot Version: t194-9efcbc4f
[0001.278] I> CPU-BL Params @ 0xf2820000
[0001.278] I> 0) Base:0x00000000 Size:0x00000000
[0001.281] I> 1) Base:0xf1100000 Size:0x00100000
[0001.286] I> 2) Base:0xf2000000 Size:0x00200000
[0001.290] I> 3) Base:0xf1200000 Size:0x00200000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
▒▒[0001.295] I> 4) Base:0xf1000000 Size:0x00100000
[0001.374] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.379] I> 6) Base:0xf3800000 Size:0x00400000
[0001.383] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.388] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.392] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.397] I> 10) Base:0xf3000000 Size:0x00800000
[0001.401] I> 11) Base:0x40000000 Size:0x00040000
[0001.405] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.410] I> 13) Base:0x40046000 Size:0x00002000
[0001.414] I> 14) Base:0x40048000 Size:0x00002000
[0001.419] I> 15) Base:0xac000000 Size:0x00004000
[0001.423] I> 16) Base:0x4004a000 Size:0x00002000
[0001.428] I> 17) Base:0xf0b00000 Size:0x00100000
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ▒▒[0001.432] I> 18) Base:0x4004c000 Size:0x00002000
[0001.487] I> 19) Base:0xf2200000 Size:0x00600000
[0001.492] I> 20) Base:0x4004e000 Size:0x00002000
[0001.496] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.501] I> 22) Base:0x00000000 Size:0x00000000
[0001.505] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.509] I> 24) Base:0xf6000000 Size:0x02000000
[0001.514] I> 25) Base:0x40050000 Size:0x00002000
[0001.518] I> 26) Base:0x40040000 Size:0x00006000
[0001.523] I> 27) Base:0xf1800000 Size:0x00400000
[0001.527] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.532] I> 29) Base:0xf1400000 Size:0x00400000
[0001.536] I> 30) Base:0x00000000 Size:0x00000000
[0001.541] I> 31) Base:0x00000000 Size:0x00000000
[0001.545] I> 32) Base:0xf8000000 Size:0x08000000
[0001.550] I> 33) Base:0x00000000 Size:0x00000000
[0001.554] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.559] I> 35) Base:0xab000000 Size:0x01000000
[0001.563] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.567] I> 37) Base:0xf2800000 Size:0x00800000
[0001.572] I> 38) Base:0x80000000 Size:0x20000000
[0001.576] I> 39) Base:0xb0000000 Size:0x08000000
[0001.581] I> 40) Base:0x00000000 Size:0x00000000
[0001.585] I> 41) Base:0x00000000 Size:0x00000000
[0001.590] I> 42) Base:0x00000000 Size:0x00000000
[0001.594] I> 43) Base:0x00000000 Size:0x00000000
[0001.599] I> 44) Base:0x00000000 Size:0x00000000
[0001.603] I> 45) Base:0x00000000 Size:0x00000000
[0001.608] GIC-SPI Target CPU: 0
[0001.611] Interrupts Init done
[0001.613] calling constructors
[0001.616] initializing heap
[0001.619] I> Heap: [0xa06945e8 … 0xab000000]
[0001.623] initializing threads
[0001.626] initializing timers
[0001.629] creating bootstrap completion thread
[0001.633] top of bootstrap2()
[0001.636] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.641] initializing platform
[0001.644] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.649] W> device prod register failed
[0001.653] I> Bl_dtb @0xaaf00000
[0001.659] W> “plugin-manager” doesn’t exist, creating
[0001.661] W> “ids” doesn’t exist, creating
[0001.665] W> “connection” doesn’t exist, creating
[0001.669] W> “configs” doesn’t exist, creating
[0001.679] I> Find /i2c@3160000’s alias i2c0
[0001.679] I> Reading eeprom i2c=0 address=0x50
[0001.707] I> Device at /i2c@3160000:0x50
[0001.708] I> Reading eeprom i2c=0 address=0x56
[0001.732] I> Device at /i2c@3160000:0x56
[0001.734] I> Find /i2c@3180000’s alias i2c2
[0001.734] I> Reading eeprom i2c=2 address=0x54
[0001.736] E> I2C: slave not found in slaves.
[0001.736] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start tr ue.
[0001.737] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.738] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.746] E> eeprom: Failed to read I2C slave device
[0001.751] I> Eeprom read failed 0x3526070d
[0001.755] I> Reading eeprom i2c=2 address=0x57
[0001.759] E> I2C: slave not found in slaves.
[0001.763] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start tr ue.
[0001.771] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.777] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.786] E> eeprom: Failed to read I2C slave device
[0001.791] I> Eeprom read failed 0x3526070d
[0001.795] I> Reading eeprom i2c=2 address=0x52
[0001.799] E> I2C: slave not found in slaves.
[0001.803] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.811] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.817] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.826] E> eeprom: Failed to read I2C slave device
[0001.831] I> Eeprom read failed 0x3526070d
[0001.836] I> Find /i2c@c240000’s alias i2c1
[0001.839] I> Reading eeprom i2c=1 address=0x52
[0001.845] E> I2C: slave not found in slaves.
[0001.847] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.855] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.861] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.870] E> eeprom: Retry to read I2C slave device.
[0001.875] E> I2C: slave not found in slaves.
[0001.879] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.887] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.893] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.902] E> eeprom: Failed to read I2C slave device
[0001.907] I> Eeprom read failed 0x3526070d
[0001.911] I> Reading eeprom i2c=1 address=0x50
[0001.915] E> I2C: slave not found in slaves.
[0001.919] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr ue.
[0001.927] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.933] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.942] E> eeprom: Retry to read I2C slave device.
[0001.947] E> I2C: slave not found in slaves.
[0001.951] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr ue.
[0001.959] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.964] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.974] E> eeprom: Failed to read I2C slave device
[0001.979] I> Eeprom read failed 0x3526070d
[0001.983] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.988] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0001.999] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.004] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0002.015] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.023] W> “i2c@3160000” doesn’t exist, creating
[0002.027] W> “module@0x50” doesn’t exist, creating
[0002.032] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0002.039] W> “module@0x56” doesn’t exist, creating
[0002.045] I> Adding plugin-manager/cvm
[0002.047] W> “chip-id” doesn’t exist, creating
[0002.051] I> Adding plugin-manager/chip-id/A02P
[0002.055] I> Plugin-manager override starting
[0002.061] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.069] I> node /plugin-manager/fragement-soft-wdt matches
[0002.077] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.080] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.093] I> Disable plugin-manager status in FDT
[0002.093] I> Plugin-manager override finished successfully
[0002.093] I> gpio framework initialized
[0002.097] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driv er
[0002.105] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.111] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.119] W> fetch_driver_phandle_from_dt: failed to get node with compatible t i,tca9539
[0002.127] W> fetch_driver_phandle_from_dt: failed to get node with compatible n xp,tca9539
[0002.133] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.139] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.147] W> fetch_driver_phandle_from_dt: failed to get node with compatible t i,tca9539
[0002.155] W> fetch_driver_phandle_from_dt: failed to get node with compatible n xp,tca9539
[0002.161] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.169] I> fixed regulator driver initialized
[0002.181] I> register ‘maxim’ power off handle
[0002.181] I> virtual i2c enabled
[0002.182] I> registered ‘maxim,max20024’ pmic
[0002.183] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.190] I> Boot-device: eMMC
[0002.192] I> Boot_device: SDMMC_BOOT instance: 3
[0002.201] I> sdmmc-3 params source = boot args
[0002.201] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0002.206] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0002.217] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.223] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0002.234] I> sdmmc bdev is already initialized
[0002.238] I> sdmmc-3 params source = boot args
[0002.268] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.281] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.292] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.297] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.297] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.298] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.302] E> invalid display type
[0002.305] E> invalid display type
[0002.306] E> cannot find any other nvdisp nodes
[0002.307] E> no valid display unit config found in dtb
[0002.308] W> display init failed
[0002.308] I> Load in CBoot Boot Options partition and parse it
[0002.320] E> Error -9 when finding node with path /boot-configuration
[0002.320] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file .
[0002.327] I> Using default boot order
[0002.331] I> boot-dev-order :-
[0002.334] I> 1.sd
[0002.335] I> 2.usb
[0002.337] I> 3.nvme
[0002.339] I> 4.emmc
[0002.341] I> 5.net
[0002.343] I> Hit any key to stop autoboot: 4 3 2 1
[0004.351] initializing target
[0004.351] calling apps_init()
[0004.352] starting app kernel_boot_app
[0004.371] I> found decompressor handler: lz4-legacy
[0004.372] I> decompressing BMP blob …
[0004.383] I> Kernel type = Normal
[0004.383] I> Loading kernel-bootctrl from partition
[0004.384] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x1)
[0004.390] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.391] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.392] I> ########## SD (0) boot ##########
[0004.392] I> No sdcard
[0004.393] I> -0 params source =
[0004.397] E> Blockdev open: exit error
[0004.400] E> SD boot failed, err: 724238353
[0004.404] I> ########## USB (0) boot ##########
[0004.413] W> No valid slot number is found in scratch register
[0004.414] W> Return default slot: _a
[0004.430] I> USB Firmware Version: 60.06 release
[0004.485] I> regulator of usb2-0 already enabled
[0004.492] I> regulator of usb2-1 already enabled
[0004.499] I> regulator of usb2-2 already enabled
[0004.508] I> enabling ‘vdd-5v-sata’ regulator
[0005.512] E> failed to initialize xhci controller
[0005.512] E> Error in init of XUSB host driver, err: 79790026
[0005.513] W> Failed to initialize device 5-0
[0005.513] E> USB boot failed, err: 2037973030
[0005.514] I> ########## Fixed storage boot ##########
[0005.520] I> Already published: 00010003
[0005.520] I> Look for boot partition
[0005.521] I> Fallback: assuming 0th partition is boot partition
[0005.523] I> Detect filesystem
[0005.550] I> Loading extlinux.conf …
[0005.551] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.594] I> L4T boot options
[0005.594] I> [1]: “primary kernel”
[0005.594] I> Enter choice:
[0008.595] I> Continuing with default option: 1
[0008.595] I> Loading kernel sig file from rootfs …
[0008.595] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.614] I> Loading kernel binary from rootfs …
[0008.614] I> rootfs path: /sdmmc_user/boot/Image
[0008.837] I> overload load_size to 34338824 (from 34338832)
[0008.854] I> Validate kernel …
[0008.855] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.168] I> Encryption fuse is not ON
[0009.177] I> No kernel-dtb binary path
[0009.177] W> No valid slot number is found in scratch register
[0009.178] W> Return default slot: _a
[0009.178] I> A/B: bin_type (38) slot 0
[0009.178] I> Loading kernel-dtb from partition
[0009.179] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.187] I> Validate kernel-dtb …
[0009.188] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.192] I> Encryption fuse is not ON
[0009.194] I> Loading ramdisk from rootfs …
[0009.197] I> Loading initrd sig file from rootfs …
[0009.202] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0009.231] I> Loading initrd binary from rootfs …
[0009.232] I> rootfs path: /sdmmc_user/boot/initrd
[0009.289] I> overload load_size to 7236840 (from 7236848)
[0009.292] I> Validate initrd …
[0009.292] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0009.358] I> Encryption fuse is not ON
[0009.366] I> Kernel hdr @0xa42d0000
[0009.366] I> Kernel dtb @0x90000000
[0009.367] I> decompressor handler not found
[0009.367] I> Copying kernel image (34338824 bytes) from 0xa42d0000 to 0x800800009.373] I> Done
[0009.373] I> Updated bpmp info to DTB
[0009.375] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ce8
[0009.375] I> Updated initrd info to DTB
[0009.375] W> WARN: Fail to override “console=none” in commandline
[0009.379] I> Active rootfs suffix:
[0009.382] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.390] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.397] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.404] W> No valid slot number is found in scratch register
[0009.410] W> Return default slot: _a
[0009.413] I> Active slot suffix:
[0009.416] I> add_boot_slot_suffix: slot_suffix =
[0009.421] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_susplycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_schem tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resitegra.en_boot_part_access=1
[0009.447] I> Updated bootarg info to DTB
[0009.451] W> MAC addr invalid!
[0009.454] E> Failed to get WIFI MAC address
[0009.458] W> MAC addr invalid!
[0009.461] E> Failed to get Bluetooth MAC address
[0009.465] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3c:86:19
[0009.472] W> “plugin-manager” doesn’t exist, creating
[0009.476] I> Adding /chosen/plugin-manager/cvm
[0009.480] W> “chip-id” doesn’t exist, creating
[0009.485] I> Adding /chosen/plugin-manager/chip-id
[0009.490] W> “configs” doesn’t exist, creating
[0009.494] I> Adding /chosen/plugin-manager/configs
[0009.498] W> “ids” doesn’t exist, creating
[0009.502] I> Adding /chosen/plugin-manager/ids
[0009.507] W> “odm-data” doesn’t exist, creating
[0009.511] I> Adding /chosen/plugin-manager/odm-data
[0009.519] W> “memory” doesn’t exist, creating
[0009.520] I> [0] START: 0x80000000, END: 0xac000000
[0009.525] I> [1] START: 0xac004000, END: 0xf0ad0000
[0009.529] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0009.534] I> dram_block larger than 80000000
[0009.538] I> [3] START: 0x100000000, END: 0x880000000
[0009.543] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.549] I> added [base:0xac200000, size:0x44800000] to /memory
[0009.555] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.562] I> Updated memory info to DTB
[0009.565] E> add_disp_param: failed to get display params for du=0
[0009.571] W> “reset” doesn’t exist, creating
[0009.575] I> Adding ecid(00000001647c98800400000005ff0100) to DT
[0009.581] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.585] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.590] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.595] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.599] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.604] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.609] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.614] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.619] W> “misc-data” doesn’t exist, creating
[0009.623] I> Boot-device: eMMC
[0009.626] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.631] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.636] W> Unknown storage device
[0009.640] I> Add serial number:1420821039706 as DT property
[0009.646] I> Plugin-manager override starting
[0009.649] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.656] I> node /plugin-manager/fragement-soft-wdt matches
[0009.664] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.668] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.680] I> Disable plugin-manager status in FDT
[0009.681] I> Plugin-manager override finished successfully
[0009.682] I> tegrabl_load_kernel_and_dtb: Done
[0009.687] E> tegrabl_display_clear: display is not initialized
[0009.692] W> Boot logo display failed…
[0009.696] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gc 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f9197naro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ’
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_cabase 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_cabase 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_cabase 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_cabase 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible idamoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nviarveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible ,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total page6
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_consod=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.olfirst=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 v sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ole=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29060(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 byte
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes
[ 0.000000] Memory: 31925664K/33298432K available (15294K kernel code, 2942K r64K rodata, 8576K init, 609K bss, 619104K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf20000000 ( 512 MB
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc800000000 ( 32768 MB
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phy
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 46, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 439804
[ 0.009189] Console: colour dummy device 80x25
[ 0.012697] console [tty0] enabled
[ 0.015868] bootconsole [tegra_comb_uart0] disabled
[0000.105] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level
[0000.188] I> Temperature = 41000
[0000.313] I> sdmmc bdev is already initialized
▒▒▒▒main enter
HW Function test
Start Scheduler.
in late init
[0000.393] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-feba594
[0000.408] I> Boot_device: SDMMC_BOOT instance: 3
[0000.421] I> sdmmc-3 params source = boot args
[0000.436] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.437] W> No valid slot number is found in scratch register
[0000.449] I> parsing oem signed section of bpmp-fw header done
[0000.518] I> oem authentication of rce header done
[0000.536] I> ape binary init read from storage
[0000.567] I> ape: Authentication Finalize Done
[0000.572] I> oem authentication of tos header done
[0000.576] I> tos binary done read from storage
[0000.663] I> cpubl-dtb binary done read from storage
[0000.671] I> eks binary done read from storage
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
▒▒mrq initialized
▒▒[0001.185] I> Cboot Version: t194-9efcbc4f
[0001.186] I> 0) Base:0x00000000 Size:0x00000000
[0001.194] I> 2) Base:0xf2000000 Size:0x00200000
[0001.203] I> 4) Base:0xf1000000 Size:0x00100000
[0001.212] I> 6) Base:0xf3800000 Size:0x00400000
[0001.216] I> 7) Base:0xf1c00000 Size:0x00400000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
▒▒[0001.221] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.305] I> 10) Base:0xf3000000 Size:0x00800000
[0001.309] I> 11) Base:0x40000000 Size:0x00040000
[0001.318] I> 13) Base:0x40046000 Size:0x00002000
[0001.327] I> 15) Base:0xac000000 Size:0x00004000
[0001.331] I> 16) Base:0x4004a000 Size:0x00002000
[0001.336] I> 17) Base:0xf0b00000 Size:0x00100000
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ▒▒[0001.340] I> 18) Base:0x4004c000 Size:0x00002000
[0001.400] I> 20) Base:0x4004e000 Size:0x00002000
[0001.449] I> 31) Base:0x00000000 Size:0x00000000
[0001.458] I> 33) Base:0x00000000 Size:0x00000000
[0001.467] I> 35) Base:0xab000000 Size:0x01000000
[0001.507] I> 44) Base:0x00000000 Size:0x00000000
[0001.516] GIC-SPI Target CPU: 0
[0001.519] Interrupts Init done
[0001.549] initializing platform
[0001.552] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.588] I> Find /i2c@3160000’s alias i2c0
[0001.588] I> Reading eeprom i2c=0 address=0x50
[0001.616] I> Reading eeprom i2c=0 address=0x56
[0001.642] I> Find /i2c@3180000’s alias i2c2
[0001.644] E> I2C: slave not found in slaves.
[0001.644] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start tru
[0001.646] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at
[0001.663] I> Reading eeprom i2c=2 address=0x57
[0001.671] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start tru
[0001.685] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at
[0001.711] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tru
[0001.725] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at
[0001.753] E> I2C: slave not found in slaves.
[0001.755] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tru
[0001.769] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at
[0001.787] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tru
[0001.801] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at
[0001.827] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tru
[0001.841] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at
[0001.859] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tru
[0001.891] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.896] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,
[0001.912] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,
[0001.931] W> “i2c@3160000” doesn’t exist, creating
[0001.940] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.947] W> “module@0x56” doesn’t exist, creating
[0001.976] I> node /plugin-manager/fragement-soft-wdt matches
[0001.984] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.988] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.999] I> Disable plugin-manager status in FDT
[0001.999] I> Plugin-manager override finished successfully
[0002.001] I> gpio framework initialized
[0002.005] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ drive
[0002.027] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti
[0002.035] W> fetch_driver_phandle_from_dt: failed to get node with compatible nx
[0002.055] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti
[0002.063] W> fetch_driver_phandle_from_dt: failed to get node with compatible nx
[0002.077] I> fixed regulator driver initialized
[0002.098] I> Boot-device: eMMC
[0002.114] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,
[0002.131] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,
[0002.142] I> sdmmc bdev is already initialized
[0002.201] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.205] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.206] I> hdmi cable connected
[0002.208] W> set volts not configured for ‘vdd-1v0’
[0002.210] W> set volts not configured for ‘vdd-1v8-hs’
[0002.214] E> invalid display type
[0002.218] E> invalid display type
[0002.219] E> cannot find any other nvdisp nodes
[0002.234] I> edid read success
[0002.247] I> edid read success
[0002.247] I> width = 640, height = 480, frequency = 25174825
[0002.248] I> width = 640, height = 480, frequency = 25174825
[0002.248] I> width = 3440, height = 1440, frequency = 266570000
[0002.249] I> width = 3440, height = 1440, frequency = 533120000
[0002.253] I> width = 640, height = 480, frequency = 25174825
[0002.258] I> width = 720, height = 480, frequency = 26973026
[0002.264] I> width = 720, height = 480, frequency = 26973026
[0002.269] I> width = 1280, height = 720, frequency = 74175824
[0002.275] I> width = 1920, height = 1080, frequency = 148351648
[0002.281] I> width = 720, height = 576, frequency = 26973026
[0002.286] I> width = 720, height = 576, frequency = 26973026
[0002.292] I> width = 1280, height = 720, frequency = 74175824
[0002.297] I> width = 1920, height = 1080, frequency = 148351648
[0002.303] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.313] I> hdmi_enable, starting HDMI initialisation
[0002.318] I> hdmi_enable, HDMI initialisation complete
[0002.329] I> Load in CBoot Boot Options partition and parse it
[0002.335] E> Error -9 when finding node with path /boot-configuration
[0002.336] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.339] I> Using default boot order
[0002.342] I> boot-dev-order :-
[0002.345] I> 1.sd
[0002.347] I> 2.usb
[0002.349] I> 3.nvme
[0002.351] I> 4.emmc
[0002.352] I> 5.net
[0002.354] I> Hit any key to stop autoboot: 4 3 2 1
[0004.362] initializing target
[0004.362] calling apps_init()
[0004.363] starting app kernel_boot_app
[0004.382] I> found decompressor handler: lz4-legacy
[0004.383] I> decompressing BMP blob …
[0004.395] I> Kernel type = Normal
[0004.395] I> Loading kernel-bootctrl from partition
[0004.396] I> Loading partition kernel-bootctrl at 0xa4ad0000 from device(0x1)
[0004.402] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.403] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.403] I> ########## SD (0) boot ##########
[0004.404] I> No sdcard
[0004.405] I> -0 params source =
[0004.408] E> Blockdev open: exit error
[0004.412] E> SD boot failed, err: 724238353
[0004.416] I> ########## USB (0) boot ##########
[0004.425] W> No valid slot number is found in scratch register
[0004.426] W> Return default slot: _a
[0004.442] I> USB Firmware Version: 60.06 release
[0004.497] I> regulator of usb2-0 already enabled
[0004.503] I> regulator of usb2-1 already enabled
[0004.510] I> regulator of usb2-2 already enabled
[0004.521] I> enabling ‘vdd-5v-sata’ regulator
[0005.527] E> failed to initialize xhci controller
[0005.528] E> Error in init of XUSB host driver, err: 79790026
[0005.528] W> Failed to initialize device 5-0
[0005.528] E> USB boot failed, err: 2037973030
[0005.529] I> ########## Fixed storage boot ##########
[0005.535] I> Already published: 00010003
[0005.535] I> Look for boot partition
[0005.536] I> Fallback: assuming 0th partition is boot partition
[0005.538] I> Detect filesystem
[0005.566] I> Loading extlinux.conf …
[0005.566] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.609] I> L4T boot options
[0005.609] I> [1]: “primary kernel”
[0005.609] I> Enter choice:
[0008.610] I> Continuing with default option: 1
[0008.610] I> Loading kernel sig file from rootfs …
[0008.610] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.629] I> Loading kernel binary from rootfs …
[0008.629] I> rootfs path: /sdmmc_user/boot/Image
[0008.848] I> overload load_size to 34338824 (from 34338832)
[0008.871] I> Validate kernel …
[0008.872] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.184] I> Encryption fuse is not ON
[0009.201] I> No kernel-dtb binary path
[0009.201] W> No valid slot number is found in scratch register
[0009.202] W> Return default slot: _a
[0009.202] I> A/B: bin_type (38) slot 0
[0009.202] I> Loading kernel-dtb from partition
[0009.203] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.212] I> Validate kernel-dtb …
[0009.212] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.216] I> Encryption fuse is not ON
[0009.218] I> Loading ramdisk from rootfs …
[0009.221] I> Loading initrd sig file from rootfs …
[0009.226] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0009.255] I> Loading initrd binary from rootfs …
[0009.255] I> rootfs path: /sdmmc_user/boot/initrd
[0009.313] I> overload load_size to 7236840 (from 7236848)
[0009.316] I> Validate initrd …
[0009.316] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0009.383] I> Encryption fuse is not ON
[0009.396] I> Kernel hdr @0xa4ad0000
[0009.396] I> Kernel dtb @0x90000000
[0009.397] I> decompressor handler not found
[0009.397] I> Copying kernel image (34338824 bytes) from 0xa4ad0000 to 0x80080000
[0009.408] I> Updated bpmp info to DTB
[0009.409] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ce8
[0009.410] I> Updated initrd info to DTB
[0009.410] W> WARN: Fail to override “console=none” in commandline
[0009.410] I> Active rootfs suffix:
[0009.412] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.420] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.427] W> No valid slot number is found in scratch register
[0009.433] W> Return default slot: _a
[0009.436] I> Active slot suffix:
[0009.439] I> add_boot_slot_suffix: slot_suffix =
[0009.444] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspfix= tegra_fbmem=0x800000@0xa06a0000 lut_mem=0x2008@0xa069b000 usbcore.old_schemevalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.475] I> Updated bootarg info to DTB
[0009.479] W> MAC addr invalid!
[0009.482] E> Failed to get WIFI MAC address
[0009.486] W> MAC addr invalid!
[0009.489] E> Failed to get Bluetooth MAC address
[0009.493] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3c:86:19
[0009.500] W> “plugin-manager” doesn’t exist, creating
[0009.504] I> Adding /chosen/plugin-manager/cvm
[0009.508] W> “chip-id” doesn’t exist, creating
[0009.513] I> Adding /chosen/plugin-manager/chip-id
[0009.517] W> “configs” doesn’t exist, creating
[0009.522] I> Adding /chosen/plugin-manager/configs
[0009.526] W> “ids” doesn’t exist, creating
[0009.530] I> Adding /chosen/plugin-manager/ids
[0009.535] W> “odm-data” doesn’t exist, creating
[0009.539] I> Adding /chosen/plugin-manager/odm-data
[0009.546] W> “memory” doesn’t exist, creating
[0009.548] I> [0] START: 0x80000000, END: 0xac000000
[0009.552] I> [1] START: 0xac004000, END: 0xf0ad0000
[0009.557] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0009.562] I> dram_block larger than 80000000
[0009.566] I> [3] START: 0x100000000, END: 0x880000000
[0009.571] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.577] I> added [base:0xac200000, size:0x44800000] to /memory
[0009.583] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.590] I> Updated memory info to DTB
[0009.593] E> add_disp_param: failed to get display params for du=1
[0009.599] W> “reset” doesn’t exist, creating
[0009.603] I> Adding ecid(00000001647c98800400000005ff0100) to DT
[0009.609] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.613] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.618] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.622] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.627] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.632] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.637] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.641] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.647] W> “misc-data” doesn’t exist, creating
[0009.651] I> Boot-device: eMMC
[0009.653] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.659] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.664] W> Unknown storage device
[0009.668] I> Add serial number:1420821039706 as DT property
[0009.674] I> Plugin-manager override starting
[0009.677] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.684] I> node /plugin-manager/fragement-soft-wdt matches
[0009.692] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.696] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.708] I> Disable plugin-manager status in FDT
[0009.708] I> Plugin-manager override finished successfully
[0009.710] I> tegrabl_load_kernel_and_dtb: Done
[0009.732] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gcc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19
[ 0.000000] Found tegra_fbmem: 00800000@a06a0000
[ 0.000000] Found lut_mem: 00002008@a069b000
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_consolot_suffix= tegra_fbmem=0x800000@0xa06a0000 lut_mem=0x2008@0xa069b000 usbcore.oldratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 root=/dev/mmctty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
[ 0.000000] early log buf free: 29156(88%)
[ 0.000000] Memory: 31917452K/33290228K available (15294K kernel code, 2942K r cma-reserved)
[ 0.000008] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 439804
[ 0.009328] Console: colour dummy device 80x25
[ 0.012429] console [tty0] enabled
[ 0.015860] bootconsole [tegra_comb_uart0] disabled
Of course… what I asked you to do is just enable more logs.
Is there any peripheral connected on your board?
Please add these to your kernel cmdline (that one in extlinux.conf) and see if more debug print is shown.
console=none keep_bootcon;
This is just for debug. Please don’t expect issue would be resolved by just adding this.
Just only one USB DEBUG interface.no HDMI.no SSD.no micro TF card etc.
After following the above operations, the results are as follows:
[0000.105] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet leve l 2 from HW fuses.
[0000.114] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.119] I> Boot-mode: Coldboot
[0000.122] I> Chip revision : A02P
[0000.125] I> Bootrom patch version : 15 (correctly patched)
[0000.130] I> ATE fuse revision : 0x200
[0000.134] I> Ram repair fuse : 0x1
[0000.137] I> Ram Code : 0x2
[0000.139] I> rst_source : 0x0
[0000.142] I> rst_level : 0x0
[0000.146] I> Boot-device: eMMC
[0000.160] I> sdmmc DDR50 mode
[0000.165] W> No valid slot number is found in scratch register
[0000.170] W> Return default slot: _a
[0000.173] I> Active Boot chain : 0
[0000.177] I> Boot-device: eMMC
[0000.180] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.188] I> Temperature = 26000
[0000.191] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.195] W> Skipping boost for clk: BPMP_APB
[0000.199] W> Skipping boost for clk: AXI_CBB
[0000.203] W> Skipping boost for clk: AON_CPU_NIC
[0000.208] W> Skipping boost for clk: CAN1
[0000.211] W> Skipping boost for clk: CAN2
[0000.216] I> Boot-device: eMMC
[0000.218] I> Boot-device: eMMC
[0000.228] I> Sdmmc: HS400 mode enabled
[0000.232] I> ECC region[0]: Start:0x0, End:0x0
[0000.236] I> ECC region[1]: Start:0x0, End:0x0
[0000.241] I> ECC region[2]: Start:0x0, End:0x0
[0000.245] I> ECC region[3]: Start:0x0, End:0x0
[0000.249] I> ECC region[4]: Start:0x0, End:0x0
[0000.253] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.259] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.263] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.268] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.272] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.277] E> FAILED: Thermal config
[0000.285] E> FAILED: MEMIO rail config
[0000.303] I> Boot-device: eMMC
[0000.312] I> sdmmc bdev is already initialized
[0000.385] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.393] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-feba59 43)
[0000.394] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.394] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.395] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.401] W> device prod register failed
[0000.405] I> Boot-device: eMMC
[0000.407] I> Boot_device: SDMMC_BOOT instance: 3
[0000.413] I> sdmmc-3 params source = boot args
[0000.416] I> sdmmc bdev is already initialized
[0000.420] I> sdmmc-3 params source = boot args
[0000.429] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.435] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.436] W> No valid slot number is found in scratch register
[0000.441] W> Return default slot: _a
[0000.445] I> Active Boot chain : 0
[0000.448] I> parsing oem signed section of bpmp-fw header done
[0000.454] I> bpmp-fw binary init read from storage
[0000.459] I> oem authentication of bpmp-fw header done
[0000.465] I> bpmp-fw binary done read from storage
[0000.468] I> bpmp-fw: Authentication init Done
[0000.473] I> parsing oem signed section of cpubl header done
[0000.478] I> cpubl binary init read from storage
[0000.482] I> bpmp-fw: Authentication Finalize Done
[0000.487] I> oem authentication of cpubl header done
[0000.492] I> cpubl binary done read from storage
[0000.496] I> cpubl: Authentication init Done
[0000.501] I> parsing oem signed section of rce header done
[0000.506] I> rce binary init read from storage
[0000.510] I> Relocating BR-BCT
[0000.513] I> cpubl: Authentication Finalize Done
[0000.522] I> rce binary done read from storage
[0000.526] I> rce: Authentication init Done
[0000.531] I> parsing oem signed section of ape header done
[0000.540] I> rce: Authentication Finalize Done
[0000.544] I> oem authentication of ape header done
[0000.549] I> ape binary done read from storage
[0000.553] I> ape: Authentication init Done
[0000.558] I> parsing oem signed section of tos header done
[0000.562] I> tos binary init read from storage
[0000.571] I> oem authentication of tos header done
[0000.575] I> tos binary done read from storage
[0000.580] I> tos: Authentication init Done
[0000.584] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.590] I> bpmp-fw-dtb binary init read from storage
[0000.595] I> tos: Authentication Finalize Done
[0000.601] I> oem authentication of bpmp-fw-dtb header done
[0000.607] I> bpmp-fw-dtb binary done read from storage
[0000.609] I> bpmp-fw-dtb: Authentication init Done
[0000.614] I> parsing oem signed section of cpubl-dtb header done
[0000.620] I> cpubl-dtb binary init read from storage
[0000.625] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.662] I> oem authentication of cpubl-dtb header done
[0000.662] I> cpubl-dtb binary done read from storage
[0000.663] I> cpubl-dtb: Authentication init Done
[0000.665] I> parsing oem signed section of eks header done
[0000.666] I> eks binary init read from storage
[0000.666] I> cpubl-dtb: Authentication Finalize Done
[0000.667] I> oem authentication of eks header done
[0000.670] I> eks binary done read from storage
[0000.675] I> eks: Authentication init Done
[0000.679] I> eks: Authentication Finalize Done
[0000.683] I> EKB detected (length: 0x410) @ VA:0x5270a400
▒▒NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:38:54, Feb 19 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing …
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
▒▒mrq initialized
▒▒[0001.184] I> Welcome to Cboot
▒▒fmon_post initialized
▒▒[0001.184] I> Cboot Version: t194-9efcbc4f
[0001.184] I> CPU-BL Params @ 0xf2820000
[0001.185] I> 0) Base:0x00000000 Size:0x00000000
[0001.189] I> 1) Base:0xf1100000 Size:0x00100000
[0001.193] I> 2) Base:0xf2000000 Size:0x00200000
[0001.197] I> 3) Base:0xf1200000 Size:0x00200000
▒▒clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
▒▒[0001.202] I> 4) Base:0xf1000000 Size:0x00100000
[0001.281] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.286] I> 6) Base:0xf3800000 Size:0x00400000
[0001.290] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.295] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.299] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.304] I> 10) Base:0xf3000000 Size:0x00800000
[0001.308] I> 11) Base:0x40000000 Size:0x00040000
[0001.313] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.317] I> 13) Base:0x40046000 Size:0x00002000
[0001.322] I> 14) Base:0x40048000 Size:0x00002000▒▒emc_debugfs initialized
dvs_debugfs initialized
[0001.331] I> 15) Base:0xac000000 Size:0x00004000
▒▒fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.335] I> 16) Base:0x4004a000 Size:0x00002000
[0001.386] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.390] I> 18) Base:0x4004c000 Size:0x00002000
[0001.395] I> 19) Base:0xf2200000 Size:0x00600000
[0001.399] I> 20) Base:0x4004e000 Size:0x00002000
[0001.403] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.408] I> 22) Base:0x00000000 Size:0x00000000
[0001.412] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.417] I> 24) Base:0xf6000000 Size:0x02000000
[0001.421] I> 25) Base:0x40050000 Size:0x00002000
[0001.426] I> 26) Base:0x40040000 Size:0x00006000
[0001.430] I> 27) Base:0xf1800000 Size:0x00400000
[0001.435] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.439] I> 29) Base:0xf1400000 Size:0x00400000
[0001.444] I> 30) Base:0x00000000 Size:0x00000000
[0001.448] I> 31) Base:0x00000000 Size:0x00000000
[0001.453] I> 32) Base:0xf8000000 Size:0x08000000
[0001.457] I> 33) Base:0x00000000 Size:0x00000000
[0001.462] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.466] I> 35) Base:0xab000000 Size:0x01000000
[0001.470] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.475] I> 37) Base:0xf2800000 Size:0x00800000
[0001.479] I> 38) Base:0x80000000 Size:0x20000000
[0001.484] I> 39) Base:0xb0000000 Size:0x08000000
[0001.488] I> 40) Base:0x00000000 Size:0x00000000
[0001.493] I> 41) Base:0x00000000 Size:0x00000000
[0001.497] I> 42) Base:0x00000000 Size:0x00000000
[0001.502] I> 43) Base:0x00000000 Size:0x00000000
[0001.506] I> 44) Base:0x00000000 Size:0x00000000
[0001.511] I> 45) Base:0x00000000 Size:0x00000000
[0001.515] GIC-SPI Target CPU: 0
[0001.518] Interrupts Init done
[0001.521] calling constructors
[0001.524] initializing heap
[0001.526] I> Heap: [0xa06945e8 … 0xab000000]
[0001.531] initializing threads
[0001.534] initializing timers
[0001.536] creating bootstrap completion thread
[0001.541] top of bootstrap2()
[0001.544] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.548] initializing platform
[0001.551] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.557] W> device prod register failed
[0001.560] I> Bl_dtb @0xaaf00000
[0001.567] W> “plugin-manager” doesn’t exist, creating
[0001.568] W> “ids” doesn’t exist, creating
[0001.573] W> “connection” doesn’t exist, creating
[0001.577] W> “configs” doesn’t exist, creating
[0001.591] I> Find /i2c@3160000’s alias i2c0
[0001.591] I> Reading eeprom i2c=0 address=0x50
[0001.617] I> Device at /i2c@3160000:0x50
[0001.617] I> Reading eeprom i2c=0 address=0x56
[0001.642] I> Device at /i2c@3160000:0x56
[0001.644] I> Find /i2c@3180000’s alias i2c2
[0001.644] I> Reading eeprom i2c=2 address=0x54
[0001.646] E> I2C: slave not found in slaves.
[0001.646] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start tr ue.
[0001.647] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.647] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.656] E> eeprom: Failed to read I2C slave device
[0001.660] I> Eeprom read failed 0x3526070d
[0001.664] I> Reading eeprom i2c=2 address=0x57
[0001.669] E> I2C: slave not found in slaves.
[0001.673] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start tr ue.
[0001.681] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.686] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.696] E> eeprom: Failed to read I2C slave device
[0001.701] I> Eeprom read failed 0x3526070d
[0001.704] I> Reading eeprom i2c=2 address=0x52
[0001.709] E> I2C: slave not found in slaves.
[0001.713] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.721] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.726] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.736] E> eeprom: Failed to read I2C slave device
[0001.741] I> Eeprom read failed 0x3526070d
[0001.746] I> Find /i2c@c240000’s alias i2c1
[0001.749] I> Reading eeprom i2c=1 address=0x52
[0001.754] E> I2C: slave not found in slaves.
[0001.757] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.765] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.770] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.780] E> eeprom: Retry to read I2C slave device.
[0001.785] E> I2C: slave not found in slaves.
[0001.789] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start tr ue.
[0001.797] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.802] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.812] E> eeprom: Failed to read I2C slave device
[0001.817] I> Eeprom read failed 0x3526070d
[0001.821] I> Reading eeprom i2c=1 address=0x50
[0001.825] E> I2C: slave not found in slaves.
[0001.829] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr ue.
[0001.837] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.842] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.852] E> eeprom: Retry to read I2C slave device.
[0001.857] E> I2C: slave not found in slaves.
[0001.861] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr ue.
[0001.869] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.874] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.884] E> eeprom: Failed to read I2C slave device
[0001.888] I> Eeprom read failed 0x3526070d
[0001.892] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.898] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0001.909] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.914] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0001.925] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.932] W> “i2c@3160000” doesn’t exist, creating
[0001.937] W> “module@0x50” doesn’t exist, creating
[0001.941] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.948] W> “module@0x56” doesn’t exist, creating
[0001.955] I> Adding plugin-manager/cvm
[0001.957] W> “chip-id” doesn’t exist, creating
[0001.961] I> Adding plugin-manager/chip-id/A02P
[0001.965] I> Plugin-manager override starting
[0001.970] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.979] I> node /plugin-manager/fragement-soft-wdt matches
[0001.989] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.995] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.011] I> Disable plugin-manager status in FDT
[0002.012] I> Plugin-manager override finished successfully
[0002.012] I> gpio framework initialized
[0002.014] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driv er
[0002.016] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.021] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.029] W> fetch_driver_phandle_from_dt: failed to get node with compatible t i,tca9539
[0002.037] W> fetch_driver_phandle_from_dt: failed to get node with compatible n xp,tca9539
[0002.043] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.049] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.057] W> fetch_driver_phandle_from_dt: failed to get node with compatible t i,tca9539
[0002.065] W> fetch_driver_phandle_from_dt: failed to get node with compatible n xp,tca9539
[0002.070] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.079] I> fixed regulator driver initialized
[0002.089] I> register ‘maxim’ power off handle
[0002.090] I> virtual i2c enabled
[0002.090] I> registered ‘maxim,max20024’ pmic
[0002.093] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.099] I> Boot-device: eMMC
[0002.102] I> Boot_device: SDMMC_BOOT instance: 3
[0002.111] I> sdmmc-3 params source = boot args
[0002.111] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0002.116] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0002.127] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.132] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0002.143] I> sdmmc bdev is already initialized
[0002.147] I> sdmmc-3 params source = boot args
[0002.178] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.191] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.204] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.212] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.212] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.213] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.223] E> invalid display type
[0002.225] E> cannot find any other nvdisp nodes
[0002.225] E> no valid display unit config found in dtb
[0002.226] W> display init failed
[0002.227] I> Load in CBoot Boot Options partition and parse it
[0002.235] E> Error -9 when finding node with path /boot-configuration
[0002.235] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file .
[0002.242] I> Using default boot order
[0002.246] I> boot-dev-order :-
[0002.249] I> 1.sd
[0002.251] I> 2.usb
[0002.252] I> 3.nvme
[0002.254] I> 4.emmc
[0002.256] I> 5.net
[0002.258] I> Hit any key to stop autoboot: 4 3 2 1
[0004.266] initializing target
[0004.266] calling apps_init()
[0004.267] starting app kernel_boot_app
[0004.286] I> found decompressor handler: lz4-legacy
[0004.287] I> decompressing BMP blob …
[0004.298] I> Kernel type = Normal
[0004.298] I> Loading kernel-bootctrl from partition
[0004.298] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x1)
[0004.305] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.305] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.306] I> ########## SD (0) boot ##########
[0004.306] I> No sdcard
[0004.308] I> -0 params source =
[0004.311] E> Blockdev open: exit error
[0004.315] E> SD boot failed, err: 724238353
[0004.319] I> ########## USB (0) boot ##########
[0004.328] W> No valid slot number is found in scratch register
[0004.329] W> Return default slot: _a
[0004.344] I> USB Firmware Version: 60.06 release
[0004.401] I> regulator of usb2-0 already enabled
[0004.409] I> regulator of usb2-1 already enabled
[0004.418] I> regulator of usb2-2 already enabled
[0004.429] I> enabling ‘vdd-5v-sata’ regulator
[0005.435] E> failed to initialize xhci controller
[0005.435] E> Error in init of XUSB host driver, err: 79790026
[0005.435] W> Failed to initialize device 5-0
[0005.436] E> USB boot failed, err: 2037973030
[0005.436] I> ########## Fixed storage boot ##########
[0005.442] I> Already published: 00010003
[0005.443] I> Look for boot partition
[0005.443] I> Fallback: assuming 0th partition is boot partition
[0005.446] I> Detect filesystem
[0005.473] I> Loading extlinux.conf …
[0005.473] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.516] I> L4T boot options
[0005.516] I> [1]: “primary kernel”
[0005.517] I> Enter choice:
[0008.518] I> Continuing with default option: 1
[0008.518] I> Loading kernel sig file from rootfs …
[0008.518] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.537] I> Loading kernel binary from rootfs …
[0008.537] I> rootfs path: /sdmmc_user/boot/Image
[0008.758] I> overload load_size to 34338824 (from 34338832)
[0008.776] I> Validate kernel …
[0008.776] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.089] I> Encryption fuse is not ON
[0009.098] I> No kernel-dtb binary path
[0009.099] W> No valid slot number is found in scratch register
[0009.099] W> Return default slot: _a
[0009.099] I> A/B: bin_type (38) slot 0
[0009.099] I> Loading kernel-dtb from partition
[0009.100] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.108] I> Validate kernel-dtb …
[0009.109] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.113] I> Encryption fuse is not ON
[0009.115] I> Loading ramdisk from rootfs …
[0009.118] I> Loading initrd sig file from rootfs …
[0009.123] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0009.152] I> Loading initrd binary from rootfs …
[0009.153] I> rootfs path: /sdmmc_user/boot/initrd
[0009.210] I> overload load_size to 7236840 (from 7236848)
[0009.212] I> Validate initrd …
[0009.213] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0009.279] I> Encryption fuse is not ON
[0009.287] I> Kernel hdr @0xa42d0000
[0009.287] I> Kernel dtb @0x90000000
[0009.287] I> decompressor handler not found
[0009.288] I> Copying kernel image (34338824 bytes) from 0xa42d0000 to 0x80080000 … [0009.293] I> Done
[0009.294] I> Updated bpmp info to DTB
[0009.296] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ce8
[0009.296] I> Updated initrd info to DTB
[0009.296] W> WARN: Fail to override “console=none” in commandline
[0009.300] I> Active rootfs suffix:
[0009.303] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.310] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.318] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.325] W> No valid slot number is found in scratch register
[0009.331] W> Return default slot: _a
[0009.334] I> Active slot suffix:
[0009.337] I> add_boot_slot_suffix: slot_suffix =
[0009.342] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.368] I> Updated bootarg info to DTB
[0009.372] W> MAC addr invalid!
[0009.375] E> Failed to get WIFI MAC address
[0009.379] W> MAC addr invalid!
[0009.382] E> Failed to get Bluetooth MAC address
[0009.386] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3c:86:19
[0009.393] W> “plugin-manager” doesn’t exist, creating
[0009.397] I> Adding /chosen/plugin-manager/cvm
[0009.401] W> “chip-id” doesn’t exist, creating
[0009.406] I> Adding /chosen/plugin-manager/chip-id
[0009.410] W> “configs” doesn’t exist, creating
[0009.414] I> Adding /chosen/plugin-manager/configs
[0009.419] W> “ids” doesn’t exist, creating
[0009.423] I> Adding /chosen/plugin-manager/ids
[0009.428] W> “odm-data” doesn’t exist, creating
[0009.432] I> Adding /chosen/plugin-manager/odm-data
[0009.440] W> “memory” doesn’t exist, creating
[0009.441] I> [0] START: 0x80000000, END: 0xac000000
[0009.445] I> [1] START: 0xac004000, END: 0xf0ad0000
[0009.450] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0009.455] I> dram_block larger than 80000000
[0009.459] I> [3] START: 0x100000000, END: 0x880000000
[0009.464] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.470] I> added [base:0xac200000, size:0x44800000] to /memory
[0009.476] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.483] I> Updated memory info to DTB
[0009.486] E> add_disp_param: failed to get display params for du=0
[0009.492] W> “reset” doesn’t exist, creating
[0009.496] I> Adding ecid(00000001647c98800400000005ff0100) to DT
[0009.502] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.506] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.511] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.515] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.520] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.525] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.530] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.534] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.540] W> “misc-data” doesn’t exist, creating
[0009.544] I> Boot-device: eMMC
[0009.546] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.552] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.557] W> Unknown storage device
[0009.561] I> Add serial number:1420821039706 as DT property
[0009.567] I> Plugin-manager override starting
[0009.570] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.578] I> node /plugin-manager/fragement-soft-wdt matches
[0009.585] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.589] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.601] I> Disable plugin-manager status in FDT
[0009.602] I> Plugin-manager override finished successfully
[0009.603] I> tegrabl_load_kernel_and_dtb: Done
[0009.607] E> tegrabl_display_clear: display is not initialized
[0009.613] W> Boot logo display failed…
[0009.616] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8194536
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Memory: 31925664K/33298432K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 619104K reserved, 753664K cma-reserved)
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf20000000 ( 512 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc800000000 ( 32768 MB)
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009423] Console: colour dummy device 80x25
[ 0.012686] console [tty0] enabled
[ 0.016127] bootconsole [tegra_comb_uart0] disabled
You didn’t add that correctly. The log is still same.
