Cannot Flash Jetson AGX Xavier. Video Output only shows blinking NVidiA Logo
Hello. I bought a new Jetson Xavier AGX, and after following the initial instructions I cant get the module to boot, flash or move past just a blinking NVidia Logo.
I tried forced recovery as well, and it didnt seem to do anything different. Still just gets stuck on a blinking Nvidia logo.
Does anyone know how to solve this?
hello jeremy27,
please share logs for reference,
you may use port [J501], it’s micro-USB connector provides access to the UART console.
thanks
Hello Jerry. Here is the output from the UArt console using minicom. Let me know if you need something different.
[0000.085] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0000.093] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0000.098] I> Boot-mode: Coldboot
[0000.101] I> Chip revision : A02P
[0000.104] I> Bootrom patch version : 15 (correctly patched)
[0000.110] I> ATE fuse revision : 0x200
[0000.113] I> Ram repair fuse : 0x0
[0000.116] I> Ram Code : 0x2
[0000.119] I> rst_source : 0x0
[0000.121] I> rst_level : 0x0
[0000.125] I> Boot-device: eMMC
[0000.140] I> sdmmc DDR50 mode
[0000.144] W> No valid slot number is found in scratch register
[0000.149] W> Return default slot: _a
[0000.153] I> Active Boot chain : 0
[0000.156] I> Boot-device: eMMC
[0000.159] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.167] I> Temperature = 35000
[0000.170] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.175] W> Skipping boost for clk: BPMP_APB
[0000.179] W> Skipping boost for clk: AXI_CBB
[0000.183] W> Skipping boost for clk: AON_CPU_NIC
[0000.187] W> Skipping boost for clk: CAN1
[0000.191] W> Skipping boost for clk: CAN2
[0000.195] I> Boot-device: eMMC
[0000.198] I> Boot-device: eMMC
[0000.207] I> Sdmmc: HS400 mode enabled
[0000.212] I> ECC region[0]: Start:0x0, End:0x0
[0000.216] I> ECC region[1]: Start:0x0, End:0x0
[0000.220] I> ECC region[2]: Start:0x0, End:0x0
[0000.224] I> ECC region[3]: Start:0x0, End:0x0
[0000.228] I> ECC region[4]: Start:0x0, End:0x0
[0000.232] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.238] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.242] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.247] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.251] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.257] E> FAILED: Thermal config
[0000.264] E> FAILED: MEMIO rail config
[0000.283] I> Boot-device: eMMC
[0000.292] I> sdmmc bdev is already initialized
[0000.361] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [0000.369] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-fc460)
[0000.370] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.370] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.371] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.377] W> device prod register failed
[0000.381] I> Boot-device: eMMC
[0000.383] I> Boot_device: SDMMC_BOOT instance: 3
[0000.389] I> sdmmc-3 params source = boot args
[0000.392] I> sdmmc bdev is already initialized
[0000.396] I> sdmmc-3 params source = boot args
[0000.403] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.410] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.412] W> No valid slot number is found in scratch register
[0000.417] W> Return default slot: _a
[0000.421] I> Active Boot chain : 0
[0000.424] I> parsing oem signed section of bpmp-fw header done
[0000.430] I> bpmp-fw binary init read from storage
[0000.435] I> oem authentication of bpmp-fw header done
[0000.441] I> bpmp-fw binary done read from storage
[0000.444] I> bpmp-fw: Authentication init Done
[0000.449] I> parsing oem signed section of cpubl header done
[0000.454] I> cpubl binary init read from storage
[0000.458] I> bpmp-fw: Authentication Finalize Done
[0000.463] I> oem authentication of cpubl header done
[0000.468] I> cpubl binary done read from storage
[0000.472] I> cpubl: Authentication init Done
[0000.477] I> parsing oem signed section of rce header done
[0000.482] I> rce binary init read from storage
[0000.486] I> Relocating BR-BCT
[0000.489] I> cpubl: Authentication Finalize Done
[0000.493] I> oem authentication of rce header done
[0000.498] I> rce binary done read from storage
[0000.502] I> rce: Authentication init Done
[0000.507] I> parsing oem signed section of ape header done
[0000.511] I> ape binary init read from storage
[0000.516] I> rce: Authentication Finalize Done
[0000.520] I> oem authentication of ape header done
[0000.525] I> ape binary done read from storage
[0000.529] I> ape: Authentication init Done
[0000.534] I> parsing oem signed section of tos header done
[0000.538] I> tos binary init read from storage
[0000.542] I> ape: Authentication Finalize Done
[0000.547] I> oem authentication of tos header done
[0000.551] I> tos binary done read from storage
[0000.556] I> tos: Authentication init Done
[0000.560] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.566] I> bpmp-fw-dtb binary init read from storage
[0000.571] I> tos: Authentication Finalize Done
[0000.576] I> oem authentication of bpmp-fw-dtb header done
[0000.580] I> bpmp-fw-dtb binary done read from storage
[0000.585] I> bpmp-fw-dtb: Authentication init Done
[0000.591] I> parsing oem signed section of cpubl-dtb header done
[0000.596] I> cpubl-dtb binary init read from storage
[0000.601] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.637] I> oem authentication of cpubl-dtb header done
[0000.638] I> cpubl-dtb binary done read from storage
[0000.638] I> cpubl-dtb: Authentication init Done
[0000.640] I> parsing oem signed section of eks header done
[0000.641] I> eks binary init read from storage
[0000.641] I> cpubl-dtb: Authentication Finalize Done
[0000.642] I> oem authentication of eks header done
[0000.646] I> eks binary done read from storage
[0000.650] I> eks: Authentication init Done
[0000.654] I> eks: Authentication Finalize Done
[0000.658] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE:  BL31: v1.3(release):23b153a63
NOTICE:  BL31: Built : 11:54:09, Dec 16 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea88ed58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is c1b4e372932429f2737cf722e1219e71
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg initialized
mrq initialized
  [0001.073] I> Welcome to Cboot
[0001.073] I> Cboot Version: t194-8a9e8a5a
��fmon_post initialized
��[0001.074] I> CPU-BL Params @ 0xf2820000
[0001.074] I>  0) Base:0x00000000 Size:0x00000000
[0001.075] I>  1) Base:0xf1100000 Size:0x00100000
[0001.080] I>  2) Base:0xf2000000 Size:0x00200000
[0001.084] I>  3) Base:0xf1200000 Size:0x00200000
[0001.089] I>  4) Base:0xf1000000 Size:0x00100000
[0001.093] I>  5) Base:0xf0f00000 Size:0x00100000��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
[0001.162] I>  6) Base:0xf3800000 Size:0x00400000
[0001.167] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.171] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.176] I>  9) Base:0xf0d00000 Size:0x00100000��emc_debugfs initialized
dvs_debugfs initialized
[0001.185] I> 10) Base:0xf3000000 Size:0x00800000��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0001.235] I> 11) Base:0x40000000 Size:0x00040000
[0001.240] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.244] I> 13) Base:0x40046000 Size:0x00002000
[0001.249] I> 14) Base:0x40048000 Size:0x00002000
[0001.253] I> 15) Base:0xac000000 Size:0x00004000
[0001.258] I> 16) Base:0x4004a000 Size:0x00002000
[0001.262] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.267] I> 18) Base:0x4004c000 Size:0x00002000
[0001.271] I> 19) Base:0xf2200000 Size:0x00600000
[0001.276] I> 20) Base:0x4004e000 Size:0x00002000
[0001.280] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.285] I> 22) Base:0x00000000 Size:0x00000000
[0001.289] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.293] I> 24) Base:0xf6000000 Size:0x02000000
[0001.298] I> 25) Base:0x40050000 Size:0x00002000
[0001.302] I> 26) Base:0x40040000 Size:0x00006000
[0001.307] I> 27) Base:0xf1800000 Size:0x00400000
[0001.311] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.316] I> 29) Base:0xf1400000 Size:0x00400000
[0001.320] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.325] I> 31) Base:0x00000000 Size:0x00000000
[0001.329] I> 32) Base:0xf8000000 Size:0x08000000
[0001.334] I> 33) Base:0x00000000 Size:0x00000000
[0001.338] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.343] I> 35) Base:0xab000000 Size:0x01000000
[0001.347] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.351] I> 37) Base:0xf2800000 Size:0x00800000
[0001.356] I> 38) Base:0x80000000 Size:0x20000000
[0001.360] I> 39) Base:0xb0000000 Size:0x08000000
[0001.365] I> 40) Base:0x00000000 Size:0x00000000
[0001.369] I> 41) Base:0x00000000 Size:0x00000000
[0001.374] I> 42) Base:0x00000000 Size:0x00000000
[0001.378] I> 43) Base:0x00000000 Size:0x00000000
[0001.383] I> 44) Base:0x00000000 Size:0x00000000
[0001.387] I> 45) Base:0x00000000 Size:0x00000000
[0001.392] GIC-SPI Target CPU: 0
[0001.395] Interrupts Init done
[0001.397] calling constructors
[0001.400] initializing heap
[0001.403] I> Heap: [0xa0690588 ... 0xab000000]
[0001.407] initializing threads
[0001.410] initializing timers
[0001.413] creating bootstrap completion thread
[0001.417] top of bootstrap2()
[0001.420] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.425] initializing platform
[0001.428] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.433] W> device prod register failed
[0001.437] I> Bl_dtb @0xaaf00000
[0001.444] E> "plugin-manager" doesn't exist, creating
[0001.445] E> "ids" doesn't exist, creating
[0001.449] E> "connection" doesn't exist, creating
[0001.453] E> "configs" doesn't exist, creating
[0001.465] I> Find /i2c@3160000's alias i2c0
[0001.465] I> Reading eeprom i2c=0 address=0x50
[0001.491] I> Device at /i2c@3160000:0x50
[0001.491] I> Reading eeprom i2c=0 address=0x56
[0001.516] I> Device at /i2c@3160000:0x56
[0001.519] I> Find /i2c@3180000's alias i2c2
[0001.520] I> Reading eeprom i2c=2 address=0x54
[0001.521] E> I2C: slave not found in slaves.
[0001.522] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start t.
[0001.523] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.523] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 a.
[0001.530] E> eeprom: Failed to read I2C slave device
[0001.535] I> Eeprom read failed 0x3526070d
[0001.539] I> Reading eeprom i2c=2 address=0x57
[0001.543] E> I2C: slave not found in slaves.
[0001.547] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.555] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.560] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.570] E> eeprom: Failed to read I2C slave device
[0001.575] I> Eeprom read failed 0x3526070d
[0001.579] I> Reading eeprom i2c=2 address=0x52
[0001.583] E> I2C: slave not found in slaves.
[0001.587] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.595] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.601] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.610] E> eeprom: Failed to read I2C slave device
[0001.615] I> Eeprom read failed 0x3526070d
[0001.621] I> Find /i2c@c240000's alias i2c1
[0001.623] I> Reading eeprom i2c=1 address=0x52
[0001.629] E> I2C: slave not found in slaves.
[0001.631] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.639] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.645] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.654] E> eeprom: Retry to read I2C slave device.
[0001.659] E> I2C: slave not found in slaves.
[0001.663] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.671] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.677] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.686] E> eeprom: Failed to read I2C slave device
[0001.691] I> Eeprom read failed 0x3526070d
[0001.695] I> Reading eeprom i2c=1 address=0x50
[0001.699] E> I2C: slave not found in slaves.
[0001.703] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.711] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.717] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.726] E> eeprom: Retry to read I2C slave device.
[0001.731] E> I2C: slave not found in slaves.
[0001.735] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.743] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.748] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.758] E> eeprom: Failed to read I2C slave device
[0001.763] I> Eeprom read failed 0x3526070d
[0001.767] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.772] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.783] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.788] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.799] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.807] E> "i2c@3160000" doesn't exist, creating
[0001.811] E> "module@0x50" doesn't exist, creating
[0001.816] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.823] E> "module@0x56" doesn't exist, creating
[0001.830] I> Adding plugin-manager/cvm
[0001.831] E> "chip-id" doesn't exist, creating
[0001.835] I> Adding plugin-manager/chip-id/A02P
[0001.839] I> Plugin-manager override starting
[0001.845] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.857] I> node /plugin-manager/fragement-soft-wdt matches
[0001.870] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.877] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.898] I> Disable plugin-manager status in FDT
[0001.899] I> Plugin-manager override finished successfully
[0001.899] I> gpio framework initialized
[0001.902] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' drir
[0001.906] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'r
[0001.906] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.911] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.919] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.924] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.930] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.939] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.947] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.952] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.961] I> fixed regulator driver initialized
[0001.980] I> register 'maxim' power off handle
[0001.981] I> virtual i2c enabled
[0001.981] I> registered 'maxim,max20024' pmic
[0001.982] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.982] I> Boot-device: eMMC
[0001.983] I> Boot_device: SDMMC_BOOT instance: 3
[0001.992] I> sdmmc-3 params source = boot args
[0001.992] I> sdmmc bdev is already initialized
[0001.996] I> sdmmc-3 params source = boot args
[0002.027] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.040] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.054] I> enabling 'vdd-hdmi-5v0' regulator
[0002.062] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.062] I> hdmi cable connected
[0002.065] E> set volts not configured for 'vdd-1v0'
[0002.068] E> set volts not configured for 'vdd-1v8-hs'
[0002.075] E> invalid display type
[0002.079] E> invalid display type
[0002.081] E> cannot find any other nvdisp nodes
[0002.096] I> edid read success
[0002.109] I> edid read success
[0002.109] I> width = 640, height = 480, frequency = 25174825
[0002.110] I> width = 640, height = 480, frequency = 25174825
[0002.111] I> width = 3840, height = 2160, frequency = 297000000
[0002.114] I> width = 3840, height = 2160, frequency = 296703296
[0002.120] I> width = 1920, height = 1080, frequency = 148351648
[0002.126] I> width = 1280, height = 720, frequency = 74175824
[0002.131] I> width = 1920, height = 1080, frequency = 148351648
[0002.137] I> width = 1280, height = 720, frequency = 74175824
[0002.143] I> width = 720, height = 480, frequency = 26973026
[0002.148] I> width = 720, height = 576, frequency = 26973026
[0002.154] I> width = 1920, height = 1080, frequency = 74175824
[0002.159] I> width = 1920, height = 1080, frequency = 74175824
[0002.165] I> width = 3840, height = 2160, frequency = 296703296
[0002.171] I> width = 3840, height = 2160, frequency = 296703296
[0002.177] I> width = 3840, height = 2160, frequency = 296703296
[0002.182] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.192] I> hdmi_enable, starting HDMI initialisation
[0002.198] I> hdmi_enable, HDMI initialisation complete
[0002.208] I> Load in CBoot Boot Options partition and parse it
[0002.208] E> Cannot read beyond partition boundary for CPUBL-CFG
[0002.210] E> tegrabl_read_cbo Failed to read CPUBL-CFG partition
[0002.216] W> platform_init: tegrabl_read_cbo failed with error 0xd0d0104
[0002.223] I> Hit any key to stop autoboot:     4       3       2       1
[0004.230] initializing target
[0004.230] calling apps_init()
[0004.231] starting app kernel_boot_app
[0004.250] I> found decompressor handler: lz4-legacy
[0004.251] I> decompressing BMP blob ...
[0004.255] I> Kernel type = Normal
[0004.256] I> Loading partition kernel-bootctrl at 0xa4ab0000 from device(0x1)
[0004.262] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.263] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.263] I> ########## SD boot ##########
[0004.264] I> No sdcard
[0004.264] I> -0 params source =
[0004.267] E> Blockdev open: exit error
[0004.271] E> SD boot failed, err: 724238353
[0004.275] I> ########## USB boot ##########
[0004.283] W> No valid slot number is found in scratch register
[0004.284] W> Return default slot: _a
[0004.300] I> USB Firmware Version: 60.06 release
[0004.356] I> regulator of usb2-0 already enabled
[0004.363] I> regulator of usb2-1 already enabled
[0004.371] I> regulator of usb2-2 already enabled
[0004.381] I> enabling 'vdd-5v-sata' regulator
[0005.386] E> failed to initialize xhci controller
[0005.387] E> Error in init of XUSB host driver, err: 79790026
[0005.387] E> Failed to initialize device 5-0
[0005.387] E> USB boot failed, err: 2037973030
[0005.388] I> ########## Fixed storage boot ##########
[0005.388] I> Already published: 00010003
[0005.388] I> Look for boot partition
[0005.392] I> Fallback: assuming 0th partition is boot partition
[0005.398] I> Detect filesystem
[0005.425] I> Loading extlinux.conf ...
[0005.425] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.462] I> L4T boot options
[0005.462] I> [1]: "primary kernel"
[0005.462] I> Enter choice:
[0008.463] I> Continuing with default option: 1
[0008.463] I> Loading kernel sig file from rootfs ...
[0008.463] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.482] I> Loading kernel binary from rootfs ...
[0008.482] I> rootfs path: /sdmmc_user/boot/Image
[0008.703] I> Validate kernel ...
[0008.703] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.062] I> No kernel-dtb binary path
[0009.063] I> Loading kernel-dtb binary from partition ...
[0009.063] W> No valid slot number is found in scratch register
[0009.063] W> Return default slot: _a
[0009.064] I> A/B: bin_type (38) slot 0
[0009.064] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.075] I> Validate kernel-dtb ...
[0009.075] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.080] I> Loading ramdisk from rootfs ...
[0009.081] I> rootfs path: /sdmmc_user/boot/initrd
[0009.133] I> Kernel hdr @0xa4ab0000
[0009.134] I> Kernel dtb @0x90000000
[0009.134] I> decompressor handler not found
[0009.134] I> Copying kernel image (34191376 bytes) from 0xa4ab0000 to 0x800800e
[0009.153] I> Updated bpmp info to DTB
[0009.155] I> Ramdisk: Base: 0x92000000; Size: 0x54eadd
[0009.155] I> Updated initrd info to DTB
[0009.155] W> WARN: Fail to override "console=none" in commandline
[0009.156] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display paras
[0009.157] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display paras
[0009.162] W> No valid slot number is found in scratch register
[0009.167] W> Return default slot: _a
[0009.171] I> Active slot suffix:
[0009.174] I> add_boot_slot_suffix: slot_suffix =
[0009.178] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 co
[0009.217] I> Updated bootarg info to DTB
[0009.221] W> MAC addr invalid!
[0009.224] E> Failed to get WIFI MAC address
[0009.228] W> MAC addr invalid!
[0009.231] E> Failed to get Bluetooth MAC address
[0009.235] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3a:a6:00
[0009.242] E> "plugin-manager" doesn't exist, creating
[0009.246] I> Adding /chosen/plugin-manager/cvm
[0009.250] E> "chip-id" doesn't exist, creating
[0009.255] I> Adding /chosen/plugin-manager/chip-id
[0009.259] E> "configs" doesn't exist, creating
[0009.264] I> Adding /chosen/plugin-manager/configs
[0009.268] E> "ids" doesn't exist, creating
[0009.272] I> Adding /chosen/plugin-manager/ids
[0009.277] E> "odm-data" doesn't exist, creating
[0009.281] I> Adding /chosen/plugin-manager/odm-data
[0009.289] E> "memory" doesn't exist, creating
[0009.290] I> [0] START: 0x80000000, END: 0xac000000
[0009.294] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.299] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.304] I> dram_block larger than 80000000
[0009.308] I> [3] START: 0x100000000, END: 0x880000000
[0009.313] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.319] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.325] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.332] I> Updated memory info to DTB
[0009.335] E> add_disp_param: failed to get display params for du=1
[0009.341] E> "reset" doesn't exist, creating
[0009.345] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.349] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0009.354] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.359] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0009.363] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.368] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0009.373] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.378] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0009.383] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.387] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0009.392] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.397] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0009.402] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.407] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0009.411] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.416] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0009.423] E> "misc-data" doesn't exist, creating
[0009.426] I> Boot-device: eMMC
[0009.428] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.434] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.439] W> Unknown storage device
[0009.443] I> Add serial number:1561221004595 as DT property
[0009.449] I> Plugin-manager override starting
[0009.453] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.460] I> node /plugin-manager/fragement-soft-wdt matches
[0009.468] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.472] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.486] I> Disable plugin-manager status in FDT
[0009.486] I> Plugin-manager override finished successfully
[0009.487] I> tegrabl_load_kernel_and_dtb: Done
[0009.514] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2390-d3000) (9
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  780000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options)
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] Found tegra_fbmem: 00800000@a069b000
[    0.000000] Found lut_mem: 00002008@a0696000
<hit enter to activate fiq debugger>
��WARNING: pll_d3 has no dyn ramp
��[    5.251918] tegra_cec 3960000.tegra_cec: timeout in tegra_cec_native_write.
[    6.724407] cgroup: cgroup2: unknown option "nsdelegate"
[    9.711414] using random self ethernet address
[    9.711557] using random host ethernet address
[   12.091794] CPU4: shutdown
[   12.483489] CPU5: shutdown
[   12.596820] CPU6: shutdown
[   12.710681] CPU7: shutdown
Ubuntu 18.04.3 LTS localhost ttyTCU0
hello jeremy27,
there’s no error to make boot hang, and it looks the board has already boot into linux kernel.
may I know which JetPack release you’re using, could you please re-flash the board for confirmation,
thanks
