Hey, I’ve got a new Xavier AGX.
Flashed it with a default images from SDK.
Don’t see any output from HDMI (tried it with two different displays).
Is there anything suspicious in the following boot log? Thank you
[0000.055] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0000.063] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.068] I> Boot-mode: Coldboot
[0000.071] I> Chip revision : A02
[0000.074] I> Bootrom patch version : 7 (correctly patched)
[0000.079] I> ATE fuse revision : 0x200
[0000.083] I> Ram repair fuse : 0x0
[0000.086] I> Ram Code : 0x0
[0000.089] I> rst_source : 0x0
[0000.091] I> rst_level : 0x0
[0000.095] I> Boot-device: eMMC
[0000.110] I> sdmmc DDR50 mode
[0000.114] W> No valid slot number is found in scratch register
[0000.119] W> Return default slot: _a
[0000.123] I> Active Boot chain : 0
[0000.126] I> Boot-device: eMMC
[0000.129] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.137] I> Temperature = 34000
[0000.140] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.145] W> Skipping boost for clk: BPMP_APB
[0000.149] W> Skipping boost for clk: AXI_CBB
[0000.153] W> Skipping boost for clk: AON_CPU_NIC
[0000.157] W> Skipping boost for clk: CAN1
[0000.161] W> Skipping boost for clk: CAN2
[0000.165] I> Boot-device: eMMC
[0000.168] I> Boot-device: eMMC
[0000.177] I> Sdmmc: HS400 mode enabled
[0000.182] I> ECC region[0]: Start:0x0, End:0x0
[0000.186] I> ECC region[1]: Start:0x0, End:0x0
[0000.190] I> ECC region[2]: Start:0x0, End:0x0
[0000.194] I> ECC region[3]: Start:0x0, End:0x0
[0000.198] I> ECC region[4]: Start:0x0, End:0x0
[0000.202] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.208] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.212] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.217] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.221] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.227] E> FAILED: Thermal config
[0000.234] E> FAILED: MEMIO rail config
[0000.247] I> Boot-device: eMMC
[0000.257] I> sdmmc bdev is already initialized
[0000.328] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.336] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-38950)
[0000.337] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.337] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.338] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.344] W> device prod register failed
[0000.348] I> Boot-device: eMMC
[0000.351] I> Boot_device: SDMMC_BOOT instance: 3
[0000.357] I> sdmmc-3 params source = boot args
[0000.359] I> sdmmc bdev is already initialized
[0000.364] I> sdmmc-3 params source = boot args
[0000.372] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.379] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.380] W> No valid slot number is found in scratch register
[0000.385] W> Return default slot: _a
[0000.388] I> Active Boot chain : 0
[0000.392] I> parsing oem signed section of bpmp-fw header done
[0000.397] I> bpmp-fw binary init read from storage
[0000.402] I> oem authentication of bpmp-fw header done
[0000.409] I> bpmp-fw binary done read from storage
[0000.411] I> bpmp-fw: Authentication init Done
[0000.416] I> parsing oem signed section of cpubl header done
[0000.421] I> cpubl binary init read from storage
[0000.426] I> bpmp-fw: Authentication Finalize Done
[0000.430] I> oem authentication of cpubl header done
[0000.435] I> cpubl binary done read from storage
[0000.439] I> cpubl: Authentication init Done
[0000.444] I> parsing oem signed section of rce header done
[0000.449] I> rce binary init read from storage
[0000.453] I> Relocating BR-BCT
[0000.456] I> cpubl: Authentication Finalize Done
[0000.461] I> oem authentication of rce header done
[0000.465] I> rce binary done read from storage
[0000.469] I> rce: Authentication init Done
[0000.474] I> parsing oem signed section of ape header done
[0000.479] I> ape binary init read from storage
[0000.483] I> rce: Authentication Finalize Done
[0000.488] I> oem authentication of ape header done
[0000.492] I> ape binary done read from storage
[0000.496] I> ape: Authentication init Done
[0000.501] I> parsing oem signed section of tos header done
[0000.506] I> tos binary init read from storage
[0000.510] I> ape: Authentication Finalize Done
[0000.515] I> oem authentication of tos header done
[0000.519] I> tos binary done read from storage
[0000.523] I> tos: Authentication init Done
[0000.527] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.533] I> bpmp-fw-dtb binary init read from storage
[0000.538] I> tos: Authentication Finalize Done
[0000.544] I> oem authentication of bpmp-fw-dtb header done
[0000.550] I> bpmp-fw-dtb binary done read from storage
[0000.553] I> bpmp-fw-dtb: Authentication init Done
[0000.558] I> parsing oem signed section of cpubl-dtb header done
[0000.563] I> cpubl-dtb binary init read from storage
[0000.568] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.605] I> oem authentication of cpubl-dtb header done
[0000.606] I> cpubl-dtb binary done read from storage
[0000.606] I> cpubl-dtb: Authentication init Done
[0000.608] I> parsing oem signed section of eks header done
[0000.609] I> eks binary init read from storage
[0000.610] I> cpubl-dtb: Authentication Finalize Done
[0000.610] I> oem authentication of eks header done
[0000.614] I> eks binary done read from storage
[0000.618] I> eks: Authentication init Done
[0000.622] I> eks: Authentication Finalize Done
[0000.626] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 12:15:31, Oct 16 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
��mrq initialized
��[0001.095] I> Welcome to Cboot
��fmon_post initialized
��[0001.095] I> Cboot Version: t194-aad9d75e
[0001.096] I> CPU-BL Params @ 0xf2820000
[0001.096] I> 0) Base:0x00000000 Size:0x00000000
[0001.100] I> 1) Base:0xf1100000 Size:0x00100000
[0001.104] I> 2) Base:0xf2000000 Size:0x00200000
��clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.109] I> 3) Base:0xf1200000 Size:0x00200000
[0001.214] I> 4) Base:0xf1000000 Size:0x00100000
[0001.218] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.223] I> 6) Base:0xf3800000 Size:0x00400000
[0001.227] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.231] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.236] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.240] I> 10) Base:0xf3000000 Size:0x00800000
[0001.245] I> 11) Base:0x40000000 Size:0x00040000��emc_debugfs initialized
dvs_debugfs initialized
��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.254] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.305] I> 13) Base:0x40046000 Size:0x00002000
[0001.309] I> 14) Base:0x40048000 Size:0x00002000
[0001.313] I> 15) Base:0xac000000 Size:0x00004000
[0001.318] I> 16) Base:0x4004a000 Size:0x00002000
[0001.322] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.327] I> 18) Base:0x4004c000 Size:0x00002000
[0001.331] I> 19) Base:0xf2200000 Size:0x00600000
[0001.336] I> 20) Base:0x4004e000 Size:0x00002000
[0001.340] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.345] I> 22) Base:0x00000000 Size:0x00000000
[0001.349] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.354] I> 24) Base:0xf6000000 Size:0x02000000
[0001.358] I> 25) Base:0x40050000 Size:0x00002000
[0001.363] I> 26) Base:0x40040000 Size:0x00006000
[0001.367] I> 27) Base:0xf1800000 Size:0x00400000
[0001.371] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.376] I> 29) Base:0xf1400000 Size:0x00400000
[0001.380] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.385] I> 31) Base:0x00000000 Size:0x00000000
[0001.389] I> 32) Base:0xf8000000 Size:0x08000000
[0001.394] I> 33) Base:0x00000000 Size:0x00000000
[0001.398] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.403] I> 35) Base:0xab000000 Size:0x01000000
[0001.407] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.412] I> 37) Base:0xf2800000 Size:0x00800000
[0001.416] I> 38) Base:0x80000000 Size:0x20000000
[0001.421] I> 39) Base:0xb0000000 Size:0x08000000
[0001.425] I> 40) Base:0x00000000 Size:0x00000000
[0001.429] I> 41) Base:0x00000000 Size:0x00000000
[0001.434] I> 42) Base:0x00000000 Size:0x00000000
[0001.438] I> 43) Base:0x00000000 Size:0x00000000
[0001.443] I> 44) Base:0x00000000 Size:0x00000000
[0001.447] I> 45) Base:0x00000000 Size:0x00000000
[0001.452] GIC-SPI Target CPU: 0
[0001.455] Interrupts Init done
[0001.458] calling constructors
[0001.461] initializing heap
[0001.463] I> Heap: [0xa0691568 … 0xab000000]
[0001.467] initializing threads
[0001.470] initializing timers
[0001.473] creating bootstrap completion thread
[0001.477] top of bootstrap2()
[0001.480] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.485] initializing platform
[0001.488] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.493] W> device prod register failed
[0001.497] I> Bl_dtb @0xaaf00000
[0001.504] W> “plugin-manager” doesn’t exist, creating
[0001.505] W> “ids” doesn’t exist, creating
[0001.509] W> “connection” doesn’t exist, creating
[0001.513] W> “configs” doesn’t exist, creating
[0001.523] I> Find /i2c@3160000’s alias i2c0
[0001.523] I> Reading eeprom i2c=0 address=0x50
[0001.551] I> Device at /i2c@3160000:0x50
[0001.552] I> Reading eeprom i2c=0 address=0x56
[0001.552] E> I2C: slave not found in slaves.
[0001.552] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start t.
[0001.553] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.554] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac a.
[0001.561] E> eeprom: Failed to read I2C slave device
[0001.566] I> Eeprom read failed 0x3526070d
[0001.571] I> Find /i2c@3180000’s alias i2c2
[0001.574] I> Reading eeprom i2c=2 address=0x54
[0001.580] E> I2C: slave not found in slaves.
[0001.583] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start t.
[0001.590] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.596] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 a.
[0001.605] E> eeprom: Failed to read I2C slave device
[0001.610] I> Eeprom read failed 0x3526070d
[0001.614] I> Reading eeprom i2c=2 address=0x57
[0001.619] E> I2C: slave not found in slaves.
[0001.623] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.631] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.636] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.646] E> eeprom: Failed to read I2C slave device
[0001.650] I> Eeprom read failed 0x3526070d
[0001.654] I> Reading eeprom i2c=2 address=0x52
[0001.659] E> I2C: slave not found in slaves.
[0001.663] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.671] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.676] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.686] E> eeprom: Failed to read I2C slave device
[0001.690] I> Eeprom read failed 0x3526070d
[0001.696] I> Find /i2c@c240000’s alias i2c1
[0001.698] I> Reading eeprom i2c=1 address=0x52
[0001.704] E> I2C: slave not found in slaves.
[0001.707] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.715] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.720] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.730] E> eeprom: Retry to read I2C slave device.
[0001.735] E> I2C: slave not found in slaves.
[0001.739] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.747] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.752] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.762] E> eeprom: Failed to read I2C slave device
[0001.766] I> Eeprom read failed 0x3526070d
[0001.770] I> Reading eeprom i2c=1 address=0x50
[0001.775] E> I2C: slave not found in slaves.
[0001.779] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.787] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.792] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.802] E> eeprom: Retry to read I2C slave device.
[0001.807] E> I2C: slave not found in slaves.
[0001.811] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.818] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.824] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.833] E> eeprom: Failed to read I2C slave device
[0001.838] I> Eeprom read failed 0x3526070d
[0001.842] I> create_pm_ids: id: 2888-0001-400-L, len: 15
[0001.847] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.858] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0001.866] W> “i2c@3160000” doesn’t exist, creating
[0001.870] W> “module@0x50” doesn’t exist, creating
[0001.877] I> Adding plugin-manager/cvm
[0001.879] W> “chip-id” doesn’t exist, creating
[0001.883] I> Adding plugin-manager/chip-id/A02
[0001.887] I> Plugin-manager override starting
[0001.892] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.902] I> node /plugin-manager/fragement-soft-wdt matches
[0001.911] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.917] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.927] I> Disable plugin-manager status in FDT
[0001.927] I> Plugin-manager override finished successfully
[0001.928] I> gpio framework initialized
[0001.929] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ drir
[0001.937] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon’r
[0001.943] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.951] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.958] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.965] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.971] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.978] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.986] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.992] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.000] I> fixed regulator driver initialized
[0002.010] I> register ‘maxim’ power off handle
[0002.011] I> virtual i2c enabled
[0002.012] I> registered ‘maxim,max20024’ pmic
[0002.014] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.021] I> Boot-device: eMMC
[0002.024] I> Boot_device: SDMMC_BOOT instance: 3
[0002.033] I> sdmmc-3 params source = boot args
[0002.033] I> create_pm_ids: id: 2888-0001-400-L, len: 15
[0002.038] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.049] I> sdmmc bdev is already initialized
[0002.053] I> sdmmc-3 params source = boot args
[0002.084] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.097] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.106] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.111] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.112] I> hdmi cable connected
[0002.114] W> set volts not configured for ‘vdd-1v0’
[0002.116] W> set volts not configured for ‘vdd-1v8-hs’
[0002.120] E> invalid display type
[0002.124] E> invalid display type
[0002.125] E> cannot find any other nvdisp nodes
[0002.130] E> I2C: Timeout while polling for bus clear. Last value 0x00000000.
[0002.130] E> I2C: Failed to clear bus for instance 6.
[0002.131] E> I2C: Failed to clear bus for instance 6.
[0002.132] E> I2C_DEV: Failed to initialize instance 6.
[0002.136] E> read_edid, invalid i2c handle
[0002.144] I> hdmi_enable, starting HDMI initialisation
[0002.149] I> hdmi_enable, HDMI initialisation complete
[0002.158] I> Load in CBoot Boot Options partition and parse it
[0002.165] E> Error -9 when finding node with path /boot-configuration
[0002.165] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO fil.
[0002.169] I> Hit any key to stop autoboot: 4 3 2 1
[0004.177] initializing target
[0004.177] calling apps_init()
[0004.178] starting app kernel_boot_app
[0004.197] I> found decompressor handler: lz4-legacy
[0004.198] I> decompressing BMP blob …
[0004.202] I> Kernel type = Normal
[0004.202] I> Loading kernel-bootctrl from partition
[0004.203] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.209] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.210] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.210] I> ########## SD boot ##########
[0004.214] I> No sdcard
[0004.216] I> -0 params source =
[0004.219] E> Blockdev open: exit error
[0004.222] E> SD boot failed, err: 724238353
[0004.226] I> ########## USB boot ##########
[0004.235] W> No valid slot number is found in scratch register
[0004.236] W> Return default slot: _a
[0004.252] I> USB Firmware Version: 60.06 release
[0004.307] I> regulator of usb2-0 already enabled
[0004.315] I> regulator of usb2-1 already enabled
[0004.323] I> regulator of usb2-2 already enabled
[0004.333] I> enabling ‘vdd-5v-sata’ regulator
[0005.337] E> failed to initialize xhci controller
[0005.338] E> Error in init of XUSB host driver, err: 79790026
[0005.338] E> Failed to initialize device 5-0
[0005.339] E> USB boot failed, err: 2037973030
[0005.339] I> ########## Fixed storage boot ##########
[0005.339] I> Already published: 00010003
[0005.340] I> Look for boot partition
[0005.343] I> Fallback: assuming 0th partition is boot partition
[0005.349] I> Detect filesystem
[0005.376] I> Loading extlinux.conf …
[0005.376] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.419] I> L4T boot options
[0005.419] I> [1]: “primary kernel”
[0005.420] I> Enter choice:
[0008.421] I> Continuing with default option: 1
[0008.421] I> Loading kernel sig file from rootfs …
[0008.421] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.440] I> Loading kernel binary from rootfs …
[0008.440] I> rootfs path: /sdmmc_user/boot/Image
[0008.684] I> Validate kernel …
[0008.684] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.013] I> No kernel-dtb binary path
[0009.013] W> No valid slot number is found in scratch register
[0009.014] W> Return default slot: _a
[0009.014] I> A/B: bin_type (38) slot 0
[0009.014] I> Loading kernel-dtb from partition
[0009.015] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.023] I> Validate kernel-dtb …
[0009.024] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.029] I> Loading ramdisk from rootfs …
[0009.029] I> rootfs path: /sdmmc_user/boot/initrd
[0009.082] I> Kernel hdr @0xa4ac0000
[0009.082] I> Kernel dtb @0x90000000
[0009.083] I> decompressor handler not found
[0009.083] I> Copying kernel image (34332688 bytes) from 0xa4ac0000 to 0x800800e
[0009.094] I> Updated bpmp info to DTB
[0009.096] I> Ramdisk: Base: 0x92000000; Size: 0x54eb56
[0009.096] I> Updated initrd info to DTB
[0009.096] W> WARN: Fail to override “console=none” in commandline
[0009.097] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display paras
[0009.102] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display paras
[0009.110] W> No valid slot number is found in scratch register
[0009.115] W> Return default slot: _a
[0009.119] I> Active slot suffix:
[0009.122] I> add_boot_slot_suffix: slot_suffix =
[0009.127] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_su
[0009.156] I> Updated bootarg info to DTB
[0009.160] W> MAC addr invalid!
[0009.163] E> Failed to get WIFI MAC address
[0009.167] W> MAC addr invalid!
[0009.170] E> Failed to get Bluetooth MAC address
[0009.174] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cc:12:18
[0009.181] W> “plugin-manager” doesn’t exist, creating
[0009.185] I> Adding /chosen/plugin-manager/cvm
[0009.189] W> “chip-id” doesn’t exist, creating
[0009.194] I> Adding /chosen/plugin-manager/chip-id
[0009.198] W> “configs” doesn’t exist, creating
[0009.203] I> Adding /chosen/plugin-manager/configs
[0009.207] W> “ids” doesn’t exist, creating
[0009.211] I> Adding /chosen/plugin-manager/ids
[0009.216] W> “odm-data” doesn’t exist, creating
[0009.220] I> Adding /chosen/plugin-manager/odm-data
[0009.227] W> “memory” doesn’t exist, creating
[0009.229] I> [0] START: 0x80000000, END: 0xac000000
[0009.233] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.238] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.243] I> dram_block larger than 80000000
[0009.247] I> [3] START: 0x100000000, END: 0x480000000
[0009.252] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.258] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.264] I> added [base:0x100000000, size:0x380000000] to /memory
[0009.271] I> Updated memory info to DTB
[0009.274] E> add_disp_param: failed to get display params for du=1
[0009.280] W> “reset” doesn’t exist, creating
[0009.284] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.288] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.293] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.298] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.302] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.307] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.312] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.317] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.322] W> “misc-data” doesn’t exist, creating
[0009.326] I> Boot-device: eMMC
[0009.329] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.334] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.339] W> Unknown storage device
[0009.343] I> Add serial number:0420419040209 as DT property
[0009.349] I> Plugin-manager override starting
[0009.353] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.360] I> node /plugin-manager/fragement-soft-wdt matches
[0009.367] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.371] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.383] I> Disable plugin-manager status in FDT
[0009.383] I> Plugin-manager override finished successfully
[0009.385] I> tegrabl_load_kernel_and_dtb: Done
[0009.408] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4255) (gcc ve0
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069d000
[ 0.000000] Found lut_mem: 00002008@a0697000
[ 1.730091] ucsi_ccg 1-0008: read version failed
[ 1.730211] ucsi_ccg 1-0008: get_fw_info fail, err=-121
[ 11.861175] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 11.861324] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 11.861437] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 11.861523] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.861646] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 11.861739] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 11.861835] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 11.861946] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 11.862048] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 11.862154] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 11.862251] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 11.862348] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
[ 12.243721] rt5659 7-001a: Device with ID register ffffff80 is not rt5659
[ 12.353411] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 12.353604] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 14.185757] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 14.185942] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 14.199316] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 14.199484] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 14.607529] cgroup: cgroup2: unknown option “nsdelegate”
[ 14.870930] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 14.871148] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 14.991158] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 14.991342] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 15.607872] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 15.608056] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 15.612750] Could not get extcon-dev /xhci@3610000:id(0)
[ 15.616415] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 15.617923] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 15.618637] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 15.619783] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 15.619934] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 15.624275] Could not get extcon-dev /xhci@3610000:id(0)
[ 15.808241] random: crng init done
[ 15.808349] random: 7 urandom warning(s) missed due to ratelimiting
[ 22.101153] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 22.101313] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 22.101428] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 22.101520] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 22.101633] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 22.101726] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 22.101823] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 22.101930] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 22.102038] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 22.102147] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 22.102256] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 22.102355] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
[ 32.341153] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 32.341329] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 32.341455] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 32.341560] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 32.341674] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 32.341768] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 32.341880] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 32.341981] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 32.342086] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 32.342208] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 32.342297] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 32.342394] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
[ 42.581144] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 42.581319] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 42.581438] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 42.581527] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 42.581639] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 42.581744] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 42.581846] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 42.581944] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 42.582052] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 42.582158] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 42.582253] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 42.582365] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
[ 52.821177] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 52.821347] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 52.821464] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 52.821570] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 52.821681] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 52.821781] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 52.821894] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 52.821995] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 52.822100] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 52.822223] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 52.822311] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 52.822408] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
[ 63.061148] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 63.061309] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 63.061425] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 63.061512] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 63.061624] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 63.061716] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 63.061811] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 63.061911] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 63.062017] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 63.062125] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 63.062226] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 63.062322] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
[ 73.301186] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 73.301344] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 73.301479] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 73.301572] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 73.301684] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 73.301787] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 73.301886] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 73.301987] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 73.302092] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 73.302215] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 73.302303] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 73.302403] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
[ 80.029763] Please complete system configuration setup on desktop to proceed.
[ 83.541193] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 83.541348] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 83.541464] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 83.541552] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 83.541667] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 83.541764] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 83.541882] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 83.542003] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 83.542109] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 83.542219] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 83.542323] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 83.542420] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
��WARNING: pll_d3 has no dyn ramp
��[ 84.015916] edid invalid
[ 93.781150] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 93.781156] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 93.781165] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 93.781169] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 93.781173] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 93.781177] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 93.781181] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 93.781184] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 93.781187] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 93.781191] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 93.781194] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 93.781206] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
[ 104.021161] tegra-i2c 31c0000.i2c: rx dma timeout txlen:28 rxlen:128
[ 104.021167] tegra-i2c 31c0000.i2c: — register dump for debugging ----
[ 104.021175] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 104.021179] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 104.021183] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 104.021186] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 104.021190] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70
[ 104.021193] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 104.021196] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 104.021200] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x6c
[ 104.021203] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 104.021214] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
