[0000.208] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 1 from HW fuses.
[0000.217] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.222] I> Boot-mode: Coldboot
[0000.225] I> Chip revision : A02
[0000.228] I> Bootrom patch version : 7 (correctly patched)
[0000.233] I> ATE fuse revision : 0x200
[0000.237] I> Ram repair fuse : 0x0
[0000.240] I> Ram Code : 0x0
[0000.242] I> rst_source : 0x0
[0000.245] I> rst_level : 0x0
[0000.248] I> Boot-device: eMMC
[0000.263] I> sdmmc DDR50 mode
[0000.268] W> No valid slot number is found in scratch register
[0000.273] W> Return default slot: _a
[0000.276] I> Active Boot chain : 0
[0000.279] I> Boot-device: eMMC
[0000.283] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.291] I> Temperature = 35500
[0000.294] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.298] W> Skipping boost for clk: BPMP_APB
[0000.302] W> Skipping boost for clk: AXI_CBB
[0000.306] W> Skipping boost for clk: AON_CPU_NIC
[0000.311] W> Skipping boost for clk: CAN1
[0000.314] W> Skipping boost for clk: CAN2
[0000.319] I> Boot-device: eMMC
[0000.321] I> Boot-device: eMMC
[0000.331] I> Sdmmc: HS400 mode enabled
[0000.335] I> ECC region[0]: Start:0x0, End:0x0
[0000.339] I> ECC region[1]: Start:0x0, End:0x0
[0000.344] I> ECC region[2]: Start:0x0, End:0x0
[0000.348] I> ECC region[3]: Start:0x0, End:0x0
[0000.352] I> ECC region[4]: Start:0x0, End:0x0
[0000.356] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.362] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.366] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.371] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.375] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.380] E> FAILED: Thermal config
[0000.388] E> FAILED: MEMIO rail config
[0000.401] I> Boot-device: eMMC
[0000.410] I> sdmmc bdev is already initialized
[0000.483] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.492] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-2dfe4beb)
[0000.492] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.493] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.493] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.499] W> device prod register failed
[0000.503] I> Boot-device: eMMC
[0000.506] I> Boot_device: SDMMC_BOOT instance: 3
[0000.512] I> sdmmc-3 params source = boot args
[0000.515] I> sdmmc bdev is already initialized
[0000.519] I> sdmmc-3 params source = boot args
[0000.526] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.533] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.535] W> No valid slot number is found in scratch register
[0000.540] W> Return default slot: _a
[0000.543] I> Active Boot chain : 0
[0000.547] I> parsing oem signed section of bpmp-fw header done
[0000.552] I> bpmp-fw binary init read from storage
[0000.557] I> oem authentication of bpmp-fw header done
[0000.564] I> bpmp-fw binary done read from storage
[0000.567] I> bpmp-fw: Authentication init Done
[0000.571] I> parsing oem signed section of cpubl header done
[0000.576] I> cpubl binary init read from storage
[0000.581] I> bpmp-fw: Authentication Finalize Done
[0000.586] I> oem authentication of cpubl header done
[0000.590] I> cpubl binary done read from storage
[0000.595] I> cpubl: Authentication init Done
[0000.600] I> parsing oem signed section of rce header done
[0000.604] I> rce binary init read from storage
[0000.609] I> Relocating BR-BCT
[0000.612] I> cpubl: Authentication Finalize Done
[0000.616] I> oem authentication of rce header done
[0000.620] I> rce binary done read from storage
[0000.625] I> rce: Authentication init Done
[0000.630] I> parsing oem signed section of ape header done
[0000.634] I> ape binary init read from storage
[0000.639] I> rce: Authentication Finalize Done
[0000.643] I> oem authentication of ape header done
[0000.647] I> ape binary done read from storage
[0000.652] I> ape: Authentication init Done
[0000.658] I> parsing oem signed section of tos header done
[0000.661] I> tos binary init read from storage
[0000.665] I> ape: Authentication Finalize Done
[0000.670] I> oem authentication of tos header done
[0000.674] I> tos binary done read from storage
[0000.678] I> tos: Authentication init Done
[0000.683] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.688] I> bpmp-fw-dtb binary init read from storage
[0000.693] I> tos: Authentication Finalize Done
[0000.699] I> oem authentication of bpmp-fw-dtb header done
[0000.706] I> bpmp-fw-dtb binary done read from storage
[0000.708] I> bpmp-fw-dtb: Authentication init Done
[0000.713] I> parsing oem signed section of cpubl-dtb header done
[0000.718] I> cpubl-dtb binary init read from storage
[0000.723] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.761] I> oem authentication of cpubl-dtb header done
[0000.761] I> cpubl-dtb binary done read from storage
[0000.762] I> cpubl-dtb: Authentication init Done
[0000.764] I> parsing oem signed section of eks header done
[0000.764] I> eks binary init read from storage
[0000.765] I> cpubl-dtb: Authentication Finalize Done
[0000.766] I> oem authentication of eks header done
[0000.769] I> eks binary done read from storage
[0000.774] I> eks: Authentication init Done
[0000.777] I> eks: Authentication Finalize Done
[0000.782] I> EKB detected (length: 0x410) @ VA:0x5270a400
▒▒NOTICE: BL31: v1.3(release):41d46a9cf
NOTICE: BL31: Built : 21:14:52, Jun 25 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.251] I> Welcome to Cboot
▒▒fmon_post initialized
▒▒[0001.251] I> Cboot Version: t194-18fdfe28
[0001.251] I> CPU-BL Params @ 0xf2820000
[0001.252] I> 0) Base:0x00000000 Size:0x00000000
[0001.255] I> 1) Base:0xf1100000 Size:0x00100000
[0001.260] I> 2) Base:0xf2000000 Size:0x00200000
▒▒clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
▒▒[0001.264] I> 3) Base:0xf1200000 Size:0x00200000
[0001.369] I> 4) Base:0xf1000000 Size:0x00100000
[0001.374] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.378] I> 6) Base:0xf3800000 Size:0x00400000
[0001.382] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.387] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.391] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.396] I> 10) Base:0xf3000000 Size:0x00800000
[0001.400] I> 11) Base:0x40000000 Size:0x00040000▒▒emc_debugfs initialized
dvs_debugfs initialized
[0001.410] I> 12) Base:0xf0c00000 Size:0x00100000
▒▒fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.414] I> 13) Base:0x40046000 Size:0x00002000
[0001.464] I> 14) Base:0x40048000 Size:0x00002000
[0001.469] I> 15) Base:0xac000000 Size:0x00004000
[0001.473] I> 16) Base:0x4004a000 Size:0x00002000
[0001.478] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.482] I> 18) Base:0x4004c000 Size:0x00002000
[0001.487] I> 19) Base:0xf2200000 Size:0x00600000
[0001.491] I> 20) Base:0x4004e000 Size:0x00002000
[0001.496] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.500] I> 22) Base:0x00000000 Size:0x00000000
[0001.505] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.509] I> 24) Base:0xf6000000 Size:0x02000000
[0001.514] I> 25) Base:0x40050000 Size:0x00002000
[0001.518] I> 26) Base:0x40040000 Size:0x00006000
[0001.522] I> 27) Base:0xf1800000 Size:0x00400000
[0001.527] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.531] I> 29) Base:0xf1400000 Size:0x00400000
[0001.536] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.540] I> 31) Base:0x00000000 Size:0x00000000
[0001.545] I> 32) Base:0xf8000000 Size:0x08000000
[0001.549] I> 33) Base:0x00000000 Size:0x00000000
[0001.554] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.558] I> 35) Base:0xab000000 Size:0x01000000
[0001.563] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.567] I> 37) Base:0xf2800000 Size:0x00800000
[0001.572] I> 38) Base:0x80000000 Size:0x20000000
[0001.576] I> 39) Base:0xb0000000 Size:0x08000000
[0001.580] I> 40) Base:0x00000000 Size:0x00000000
[0001.585] I> 41) Base:0x00000000 Size:0x00000000
[0001.589] I> 42) Base:0x00000000 Size:0x00000000
[0001.594] I> 43) Base:0x00000000 Size:0x00000000
[0001.598] I> 44) Base:0x00000000 Size:0x00000000
[0001.603] I> 45) Base:0x00000000 Size:0x00000000
[0001.607] GIC-SPI Target CPU: 0
[0001.610] Interrupts Init done
[0001.613] calling constructors
[0001.616] initializing heap
[0001.619] I> Heap: [0xa06905a8 … 0xab000000]
[0001.623] initializing threads
[0001.626] initializing timers
[0001.629] creating bootstrap completion thread
[0001.633] top of bootstrap2()
[0001.636] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.640] initializing platform
[0001.643] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.649] W> device prod register failed
[0001.652] I> Bl_dtb @0xaaf00000
[0001.659] W> “plugin-manager” doesn’t exist, creating
[0001.660] W> “ids” doesn’t exist, creating
[0001.665] W> “connection” doesn’t exist, creating
[0001.669] W> “configs” doesn’t exist, creating
[0001.681] I> Find /i2c@3160000’s alias i2c0
[0001.682] I> Reading eeprom i2c=0 address=0x50
[0001.707] I> Device at /i2c@3160000:0x50
[0001.708] I> Reading eeprom i2c=0 address=0x56
[0002.148] E> I2C: Timeout while polling for RX Fifo full. Last value 0x00800000.
[0002.149] E> I2C: Could not read 256 bytes from slave: 0x00ac with repeat start false.
[0002.150] E> I2C_DEV: Could not read data of size 256 at register address 0x00000000.
[0002.151] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0002.156] E> eeprom: Failed to read I2C slave device
[0002.161] I> Eeprom read failed 0x35260606
[0002.166] I> Find /i2c@3180000’s alias i2c2
[0002.169] I> Reading eeprom i2c=2 address=0x54
[0002.574] E> I2C: Timeout while polling for RX Fifo full. Last value 0x00800000.
[0002.574] E> I2C: Could not read 256 bytes from slave: 0x00a8 with repeat start false.
[0002.575] E> I2C_DEV: Could not read data of size 256 at register address 0x00000000.
[0002.576] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0002.581] E> eeprom: Failed to read I2C slave device
[0002.586] I> Eeprom read failed 0x35260606
[0002.590] I> Reading eeprom i2c=2 address=0x57
[0002.993] E> I2C: Timeout while polling for RX Fifo full. Last value 0x00800000.
[0002.994] E> I2C: Could not read 256 bytes from slave: 0x00ae with repeat start false.
[0002.995] E> I2C_DEV: Could not read data of size 256 at register address 0x00000000.
[0002.995] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0003.000] E> eeprom: Failed to read I2C slave device
[0003.005] I> Eeprom read failed 0x35260606
[0003.009] I> Reading eeprom i2c=2 address=0x52
[0003.413] E> I2C: Timeout while polling for RX Fifo full. Last value 0x00800000.
[0003.413] E> I2C: Could not read 256 bytes from slave: 0x00a4 with repeat start false.
[0003.415] E> I2C_DEV: Could not read data of size 256 at register address 0x00000000.
[0003.415] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0003.420] E> eeprom: Failed to read I2C slave device
[0003.425] I> Eeprom read failed 0x35260606
[0003.430] I> Find /i2c@c240000’s alias i2c1
[0003.433] I> Reading eeprom i2c=1 address=0x52
[0003.439] E> I2C: slave not found in slaves.
[0003.441] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0003.449] E> I2C_DEV: Failed to send register address 0x00000000.
[0003.455] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0003.464] E> eeprom: Retry to read I2C slave device.
[0003.469] E> I2C: slave not found in slaves.
[0003.473] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0003.481] E> I2C_DEV: Failed to send register address 0x00000000.
[0003.487] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0003.496] E> eeprom: Failed to read I2C slave device
[0003.501] I> Eeprom read failed 0x3526070d
[0003.505] I> Reading eeprom i2c=1 address=0x50
[0003.509] E> I2C: slave not found in slaves.
[0003.513] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0003.521] E> I2C_DEV: Failed to send register address 0x00000000.
[0003.527] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0003.536] E> eeprom: Retry to read I2C slave device.
[0003.541] E> I2C: slave not found in slaves.
[0003.545] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0003.553] E> I2C_DEV: Failed to send register address 0x00000000.
[0003.559] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0003.568] E> eeprom: Failed to read I2C slave device
[0003.573] I> Eeprom read failed 0x3526070d
[0003.577] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0003.582] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.593] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0003.601] W> “i2c@3160000” doesn’t exist, creating
[0003.605] W> “module@0x50” doesn’t exist, creating
[0003.611] I> Adding plugin-manager/cvm
[0003.613] W> “chip-id” doesn’t exist, creating
[0003.617] I> Adding plugin-manager/chip-id/A02
[0003.622] I> Plugin-manager override starting
[0003.627] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0003.636] I> node /plugin-manager/fragement-soft-wdt matches
[0003.644] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0003.659] I> Disable plugin-manager status in FDT
[0003.660] I> Plugin-manager override finished successfully
[0003.660] I> gpio framework initialized
[0003.662] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0003.665] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0003.671] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0003.680] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0003.687] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0003.693] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0003.699] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0003.707] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0003.715] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0003.721] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0003.729] I> fixed regulator driver initialized
[0003.742] I> register ‘maxim’ power off handle
[0003.744] I> virtual i2c enabled
[0003.744] I> registered ‘maxim,max20024’ pmic
[0003.744] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0003.749] I> Boot-device: eMMC
[0003.752] I> Boot_device: SDMMC_BOOT instance: 3
[0003.761] I> sdmmc-3 params source = boot args
[0003.761] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0003.766] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.777] I> sdmmc bdev is already initialized
[0003.782] I> sdmmc-3 params source = boot args
[0003.812] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0003.825] I> Found 42 partitions in SDMMC_USER (instance 3)
[0003.836] I> enabling ‘vdd-hdmi-p2-5v0’ regulator
[0003.842] I> regulator ‘vdd-hdmi-p2-5v0’ already enabled
[0003.842] I> hdmi cable connected
[0003.845] W> set volts not configured for ‘vdd-1v0’
[0003.847] W> set volts not configured for ‘vdd-1v8-hs’
[0003.854] I> regulator ‘vdd-hdmi-p1-5v0’ already enabled
[0003.860] I> regulator ‘vdd-hdmi-p1-5v0’ already enabled
[0003.860] I> hdmi cable connected
[0003.862] W> set volts not configured for ‘vdd-1v0’
[0003.865] W> set volts not configured for ‘vdd-1v8-hs’
[0003.869] E> invalid display type
[0003.871] E> cannot find any other nvdisp nodes
[0003.886] I> edid read success
[0003.898] I> edid read success
[0003.899] I> width = 640, height = 480, frequency = 25174825
[0003.900] I> width = 640, height = 480, frequency = 25174825
[0003.900] I> width = 1920, height = 1080, frequency = 148500000
[0003.904] I> width = 720, height = 480, frequency = 27000000
[0003.910] I> width = 1920, height = 1080, frequency = 148351648
[0003.915] I> width = 1920, height = 1080, frequency = 148351648
[0003.921] I> width = 1280, height = 720, frequency = 74175824
[0003.927] I> width = 1280, height = 720, frequency = 74175824
[0003.932] I> width = 720, height = 480, frequency = 26973026
[0003.938] I> width = 720, height = 576, frequency = 26973026
[0003.943] I> width = 720, height = 480, frequency = 26973026
[0003.949] I> width = 720, height = 576, frequency = 26973026
[0003.954] I> width = 640, height = 480, frequency = 25174825
[0003.960] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.970] I> hdmi_enable, starting HDMI initialisation
[0003.975] I> hdmi_enable, HDMI initialisation complete
[0003.988] E> I2C: slave not found in slaves.
[0003.989] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0003.990] E> I2C_DEV: Failed to send register address 0x00000000.
[0003.994] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 at 0x00000000 via instance 3.
[0004.003] E> could not read edid
[0004.008] I> hdmi_enable, starting HDMI initialisation
[0004.015] I> hdmi_enable, HDMI initialisation complete
[0004.019] I> Load in CBoot Boot Options partition and parse it
[0004.028] E> Error -9 when finding node with path /boot-configuration
[0004.028] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0004.036] I> Hit any key to stop autoboot: 4 3 2 1
[0006.043] initializing target
[0006.043] calling apps_init()
[0006.044] starting app kernel_boot_app
[0006.063] I> found decompressor handler: lz4-legacy
[0006.064] I> decompressing BMP blob …
[0006.067] I> Kernel type = Normal
[0006.068] I> Loading kernel-bootctrl from partition
[0006.068] I> Loading partition kernel-bootctrl at 0xa52c0000 from device(0x1)
[0006.075] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0006.075] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0006.076] I> ########## SD boot ##########
[0006.080] I> No sdcard
[0006.082] I> -0 params source =
[0006.085] E> Blockdev open: exit error
[0006.088] E> SD boot failed, err: 724238353
[0006.092] I> ########## USB boot ##########
[0006.101] W> No valid slot number is found in scratch register
[0006.102] W> Return default slot: _a
[0006.118] I> USB Firmware Version: 60.06 release
[0006.174] I> regulator of usb2-0 already enabled
[0006.184] I> enabling ‘usb-p9-0-5v0’ regulator
[0006.192] I> regulator of usb2-2 already enabled
[0006.200] I> regulator of usb2-3 already enabled
[0007.205] E> failed to initialize xhci controller
[0007.206] E> Error in init of XUSB host driver, err: 79790026
[0007.206] E> Failed to initialize device 5-0
[0007.206] E> USB boot failed, err: 2037973030
[0007.207] I> ########## Fixed storage boot ##########
[0007.207] I> Already published: 00010003
[0007.207] I> Look for boot partition
[0007.211] I> Fallback: assuming 0th partition is boot partition
[0007.217] I> Detect filesystem
[0007.244] I> Loading extlinux.conf …
[0007.244] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0007.287] I> L4T boot options
[0007.287] I> [1]: “primary kernel”
[0007.287] I> Enter choice:
[0010.289] I> Continuing with default option: 1
[0010.289] I> Loading kernel sig file from rootfs …
[0010.289] I> rootfs path: /sdmmc_user/boot/Image.sig
[0010.308] I> Loading kernel binary from rootfs …
[0010.308] I> rootfs path: /sdmmc_user/boot/Image
[0010.544] I> Validate kernel …
[0010.544] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.873] I> No kernel-dtb binary path
[0010.873] W> No valid slot number is found in scratch register
[0010.874] W> Return default slot: _a
[0010.874] I> A/B: bin_type (38) slot 0
[0010.874] I> Loading kernel-dtb from partition
[0010.875] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0010.887] I> Validate kernel-dtb …
[0010.888] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.892] I> Loading ramdisk from rootfs …
[0010.892] I> rootfs path: /sdmmc_user/boot/initrd
[0010.942] I> Kernel hdr @0xa52c0000
[0010.942] I> Kernel dtb @0x90000000
[0010.942] I> decompressor handler not found
[0010.943] I> Copying kernel image (34334736 bytes) from 0xa52c0000 to 0x80080000 … [0010.953] I> Done
[0010.954] I> Updated bpmp info to DTB
[0010.955] I> Ramdisk: Base: 0x92000000; Size: 0x54ecaf
[0010.955] I> Updated initrd info to DTB
[0010.956] W> WARN: Fail to override “console=none” in commandline
[0010.956] E> tegrabl_linuxboot_add_disp_param, du 2 failed to get display params
[0010.962] W> No valid slot number is found in scratch register
[0010.968] W> Return default slot: _a
[0010.971] I> Active slot suffix:
[0010.974] I> add_boot_slot_suffix: slot_suffix =
[0010.979] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0697000 tegra_fbmem2=0x800000@0xa0ea1000 lut_mem2=0x2008@0xa0e9e000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.014] I> Updated bootarg info to DTB
[0011.018] W> MAC addr invalid!
[0011.020] E> Failed to get WIFI MAC address
[0011.024] W> MAC addr invalid!
[0011.027] E> Failed to get Bluetooth MAC address
[0011.032] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:eb:ec
[0011.038] W> “plugin-manager” doesn’t exist, creating
[0011.043] I> Adding /chosen/plugin-manager/cvm
[0011.047] W> “chip-id” doesn’t exist, creating
[0011.051] I> Adding /chosen/plugin-manager/chip-id
[0011.056] W> “configs” doesn’t exist, creating
[0011.060] I> Adding /chosen/plugin-manager/configs
[0011.065] W> “ids” doesn’t exist, creating
[0011.069] I> Adding /chosen/plugin-manager/ids
[0011.073] W> “odm-data” doesn’t exist, creating
[0011.078] I> Adding /chosen/plugin-manager/odm-data
[0011.085] W> “memory” doesn’t exist, creating
[0011.087] I> [0] START: 0x80000000, END: 0xac000000
[0011.091] I> [1] START: 0xac004000, END: 0xf09d0000
[0011.096] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0011.101] I> dram_block larger than 80000000
[0011.105] I> [3] START: 0x100000000, END: 0x480000000
[0011.110] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.115] I> added [base:0xac200000, size:0x44600000] to /memory
[0011.121] I> added [base:0x100000000, size:0x380000000] to /memory
[0011.128] I> Updated memory info to DTB
[0011.131] E> add_disp_param: failed to get display params for du=2
[0011.138] W> “reset” doesn’t exist, creating
[0011.142] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.146] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.151] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.155] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.160] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.165] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.170] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0011.174] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0011.180] W> “misc-data” doesn’t exist, creating
[0011.183] I> Boot-device: eMMC
[0011.186] I> Add boot-sdmmc to plugin-manager/misc-data
[0011.192] I> Add storage-sdmmc to plugin-manager/misc-data
[0011.197] W> Unknown storage device
[0011.200] I> Add serial number:0424418053500 as DT property
[0011.207] I> Plugin-manager override starting
[0011.210] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.218] I> node /plugin-manager/fragement-soft-wdt matches
[0011.225] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.236] I> Disable plugin-manager status in FDT
[0011.236] I> Plugin-manager override finished successfully
[0011.237] I> tegrabl_load_kernel_and_dtb: Done
[0011.269] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (realtimes@realtimes-IdeaCentre-GeekPro-15ICK) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Aug 7 16:58:47 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069c000
[ 0.000000] Found lut_mem: 00002008@a0697000
[ 0.000000] Found tegra_fbmem2: 00800000@a0ea1000
[ 0.000000] Found lut_mem2: 00002008@a0e9e000
▒▒WARNING: pll_d3 has no dyn ramp
▒▒[ 2.098115] tegradc 15210000.nvdisplay: hdmi: edid read failed
▒▒WARNING: pll_d2 has no dyn ramp
▒▒[ 9.591944] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 9.731562] fusb302 10-0022: fusb_I2C_ReadData - I2C error reading byte data. Address: ‘0x01’, Return: ‘-121’. Attempt #0 / 3…
[ 9.732517] fusb302 10-0022: fusb_I2C_ReadData - I2C error reading byte data. Address: ‘0x01’, Return: ‘-121’. Attempt #1 / 3…
[ 9.733473] fusb302 10-0022: fusb_I2C_ReadData - I2C error reading byte data. Address: ‘0x01’, Return: ‘-121’. Attempt #2 / 3…
[ 9.734418] fusb302 10-0022: fusb_I2C_ReadData - I2C error reading byte data. Address: ‘0x01’, Return: ‘-121’. Attempt #3 / 3…
[ 9.734747] FUSB fusb_IsDeviceValid - Error: Could not communicate with device over I2C!
[ 9.735019] fusb302 10-0022: FUSB fusb30x_probe - Error: Unable to communicate with device!
[ 9.736520] fusb302 11-0022: fusb_I2C_ReadData - I2C error reading byte data. Address: ‘0x01’, Return: ‘-121’. Attempt #0 / 3…
[ 9.737480] fusb302 11-0022: fusb_I2C_ReadData - I2C error reading byte data. Address: ‘0x01’, Return: ‘-121’. Attempt #1 / 3…
[ 9.738436] fusb302 11-0022: fusb_I2C_ReadData - I2C error reading byte data. Address: ‘0x01’, Return: ‘-121’. Attempt #2 / 3…
[ 9.739572] fusb302 11-0022: fusb_I2C_ReadData - I2C error reading byte data. Address: ‘0x01’, Return: ‘-121’. Attempt #3 / 3…
[ 9.750689] FUSB fusb_IsDeviceValid - Error: Could not communicate with device over I2C!
[ 9.759268] fusb302 11-0022: FUSB fusb30x_probe - Error: Unable to communicate with device!
[ 10.474493] tegra-pcie-dw 14100000.pcie: pex_wake already in use
[ 10.993693] tegra-pcie-dw 14120000.pcie: pex_wake already in use
[ 11.510328] tegra-pcie-dw 14140000.pcie: pex_wake already in use
[ 12.025447] tegra-pcie-dw 14160000.pcie: pex_wake already in use
[ 12.542351] tegra-pcie-dw 141a0000.pcie: pex_wake already in use
[ 13.485748] cgroup: cgroup2: unknown option “nsdelegate”
[ 14.836659] random: crng init done
[ 14.836662] random: 7 urandom warning(s) missed due to ratelimiting
[ 17.800017] CPU4: shutdown
[ 18.026729] CPU5: shutdown
[ 18.314673] CPU6: shutdown
[ 18.596208] CPU7: shutdown
[ 20.446760] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 20.927170] net eth0: Failed to reset MAC
Ubuntu 18.04.4 LTS sdx-desktop ttyTCU0
sdx-desktop login:
