Jetson AGX Xavier Developer kit - HDMI
Hi Team,
We are encountering an HDMI disconnection issue (black screen appears) after the boot process. We have observed the following data logs:
[ 368.406146] Extcon AUX2(HDMI) enable
[ 368.421301] tegradc 15200000.nvdisplay: sync windows ret = 247
[ 368.995695] tegradc 15200000.nvdisplay: unblank
[ 368.995710] tegradc 15210000.nvdisplay: blank - powerdown
[ 368.995717] tegradc 15220000.nvdisplay: blank - powerdown
[ 369.101864] tegradc 15200000.nvdisplay: blank - powerdown
[ 369.158217] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 369.158221] Extcon AUX2(HDMI) disable
[ 369.179416] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 369.179967] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 369.180117] tegradc 15210000.nvdisplay: blank - powerdown
[ 369.180124] tegradc 15220000.nvdisplay: blank - powerdown
[ 369.181373] tegradc 15200000.nvdisplay: blank - powerdown
[ 369.181399] tegradc 15200000.nvdisplay: unblank
[ 369.182123] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 369.182224] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 369.183939] Parent Clock set for DC plld3
[ 369.188008] tegradc 15200000.nvdisplay: hdmi: tmds rate:85500K prod-setting:prod_c_hdmi_54m_111m
[ 369.189289] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 369.223524] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 369.223527] Extcon AUX2(HDMI) enable
[ 369.239589] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 369.785774] tegradc 15200000.nvdisplay: unblank
[ 369.785790] tegradc 15210000.nvdisplay: blank - powerdown
[ 369.785798] tegradc 15220000.nvdisplay: blank - powerdown
[ 369.892165] tegradc 15200000.nvdisplay: blank - powerdown
[ 369.959620] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 369.959623] Extcon AUX2(HDMI) disable
[ 369.980777] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 369.981285] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 369.981437] tegradc 15210000.nvdisplay: blank - powerdown
[ 369.981445] tegradc 15220000.nvdisplay: blank - powerdown
[ 369.982659] tegradc 15200000.nvdisplay: blank - powerdown
[ 369.982685] tegradc 15200000.nvdisplay: unblank
[ 369.983366] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 369.983464] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 369.985251] Parent Clock set for DC plld3
[ 369.989333] tegradc 15200000.nvdisplay: hdmi: tmds rate:85500K prod-setting:prod_c_hdmi_54m_111m
[ 369.990636] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 370.024951] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 370.024954] Extcon AUX2(HDMI) enable
[Thu Jul 22 00:29:30 2021] tegradc 15200000.nvdisplay: unblank
[Thu Jul 22 00:29:30 2021] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[Thu Jul 22 00:29:30 2021] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[Thu Jul 22 00:29:30 2021] Parent Clock set for DC plld3
[Thu Jul 22 00:29:30 2021] tegradc 15200000.nvdisplay: hdmi: tmds rate:85500K prod-setting:prod_c_hdmi_54m_111m
[Thu Jul 22 00:29:30 2021] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[Thu Jul 22 00:29:30 2021] extcon-disp-state external-connection:disp-state: cable 48 state 1
[Thu Jul 22 00:29:30 2021] Extcon AUX2(HDMI) enable
[Thu Jul 22 00:29:30 2021] tegradc 15200000.nvdisplay: sync windows ret = 246
[Thu Jul 22 00:39:37 2021] tegradc 15200000.nvdisplay: blank - normal
[Thu Jul 22 00:40:09 2021] tegra-gpcdma 2600000.dma: DMA pause timed out
[Thu Jul 22 00:40:39 2021] tegra-gpcdma 2600000.dma: DMA pause timed out
Regards,
Kannan M
Actually I don’t see any error from the log you provided. Is this a custom board or NV devkit? or you are not sure about what does my question mean?
This one is Jetson AGX Xavier Dev Kit
What is the monitor you are using there? The 85500K in the log indicates it seems a low resolution one.
Thanks for your immediate response.
Monitor Spec: LG - 19M38HB, 19 Inch (47cm) 1366 X 768 Pixels , Led HD Ready Monitor
Could you share the log of /var/log/Xorg.0.log?
Hi Team,
Regards,
Kannan M
Why are you repeating something that I didn’t ask for…?
On the Jetson Xavier AGX, the system boots and the HDMI display works when using either the eMMC or the SD card by setting the primary and secondary boot options in the /boot/extlinux.conf file (located on the SD card). However, when I remove the SD card and attempt to boot directly from eMMC, the HDMI display does not work and shows an above shared error in dmesg. I have shared the /var/log/Xorg.0.log when I remove SD card and try to boot directly from eMMC. Xorg.0.log (8.3 KB)
