I know there was a lot of similar topics, but I couldn’t find a solution for my problem.
When I powered up a fresh bought Jetson TX2 with developers kit there was no signal at HDMI. I ignored that and started flashing tegra with JetPack 3.2 from host ubuntu machine. Flashing completed successfuly, but there still was no signal from HDMI cable connected to developers kit. I have checked different cable and different displays but with no effect. Im have connected to Jetson via SSH. That is what I’ve got after using a dmesg command (part of it):
[ 4.239974] mmc1: hw tuning done ...
[ 4.239980] mmc1: tuning_window[0]: 0xffffffff
[ 4.239985] mmc1: tuning_window[1]: 0xfffffe3f
[ 4.239989] mmc1: tuning_window[2]: 0xfff8ffff
[ 4.239993] mmc1: tuning_window[3]: 0x63ffffff
[ 4.239998] mmc1: tuning_window[4]: 0x0
[ 4.240002] mmc1: tuning_window[5]: 0x0
[ 4.240029] mmc1: tuning_window[6]: 0x0
[ 4.240033] mmc1: tuning_window[7]: 0x0
[ 4.240035] sdhci: Tap value: 60 | Trim value: 5
[ 4.240038] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.243172] ALSA device list:
[ 4.243174] #0: tegra-hda at 0x3518000 irq 400
[ 4.243175] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.244525] tegra-vi4 15700000.vi: initialized
[ 4.245139] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.245180] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.245845] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 4.245848] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 4.330865] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 4.330867] tegra-usb-cd usb_cd: set current 0ma
[ 4.330874] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 4.331873] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 4.331876] tegra-xudc-new 3550000.xudc: device mode on
[ 4.615978] mmc2 tuning done saved tap delay=108
[ 4.615981] mmc2: hw tuning done ...
[ 4.615991] mmc2: tuning_window[0]: 0xffffffff
[ 4.615997] mmc2: tuning_window[1]: 0xf80fffff
[ 4.616002] mmc2: tuning_window[2]: 0xffffffff
[ 4.616006] mmc2: tuning_window[3]: 0xffffffff
[ 4.616011] mmc2: tuning_window[4]: 0x7fffffff
[ 4.616035] mmc2: tuning_window[5]: 0xffffffc0
[ 4.616040] mmc2: tuning_window[6]: 0xffffffff
[ 4.616045] mmc2: tuning_window[7]: 0x7fffffff
[ 4.616047] sdhci: Tap value: 108 | Trim value: 5
[ 4.616050] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.616069] mmc2: new ultra high speed SDR50 SDHC card at address 0007
[ 4.616538] mmcblk1: mmc2:0007 SS08G 7.21 GiB
[ 4.618139] mmcblk1: p1
[ 6.924781] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.978842] tegradc 15210000.nvdisplay: sor_poll_register 0x15: timeout
[ 6.986037] tegradc 15210000.nvdisplay: dc timeout waiting for OR MODE = SAFE
[ 7.042893] tegradc 15210000.nvdisplay: sor_poll_register 0x16: timeout
[ 7.050104] tegradc 15210000.nvdisplay: dc timeout waiting for HEAD MODE = SLEEP
[ 7.335843] EXT4-fs (mmcblk0p1): 8 orphan inodes deleted
[ 7.341778] EXT4-fs (mmcblk0p1): recovery complete
[ 7.355464] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.364748] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.373259] devtmpfs: mounted
[ 7.377161] Freeing unused kernel memory: 1168K (ffffffc001128000 - ffffffc00124c000)
[ 7.385703] Freeing alternatives memory: 96K (ffffffc00124c000 - ffffffc001264000)
[ 7.432766] systemd[1]: System time before build time, advancing clock.
[ 7.452810] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 7.473472] systemd[1]: Detected architecture arm64.
[ 7.484030] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 7.601606] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.611413] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 7.619785] systemd[1]: Created slice System Slice.
[ 7.626816] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.634807] systemd[1]: Created slice system-getty.slice.
[ 7.642459] systemd[1]: Listening on udev Kernel Socket.
[ 7.650110] systemd[1]: Created slice User and Session Slice.
[ 7.658729] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.666664] systemd[1]: Reached target Encrypted Volumes.
[ 7.673638] systemd[1]: Reached target User and Group Name Lookups.
[ 7.681642] systemd[1]: Listening on udev Control Socket.
[ 7.688587] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.696031] systemd[1]: Listening on Journal Socket.
[ 7.703975] systemd[1]: Mounting Debug File System...
[ 7.712088] systemd[1]: Started Braille Device Support.
[ 7.721938] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.730165] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.739716] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 7.753005] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.763077] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.775388] systemd[1]: Starting Load Kernel Modules...
[ 7.782626] systemd[1]: Reached target Slices.
[ 7.789024] systemd[1]: Listening on Journal Audit Socket.
[ 7.798081] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 7.811879] systemd[1]: Listening on Syslog Socket.
[ 7.820194] systemd[1]: Starting Journal Service...
[ 7.826975] systemd[1]: Reached target Remote File Systems (Pre).
[ 7.834873] systemd[1]: Reached target Remote File Systems.
[ 7.842314] systemd[1]: Reached target Swap.
[ 7.851986] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.859823] systemd[1]: Mounted Debug File System.
[ 7.868308] systemd[1]: Started Remount Root and Kernel File Systems.
[ 7.876980] systemd[1]: Started Load Kernel Modules.
[ 7.884202] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 7.896239] systemd[1]: Started Journal Service.
[ 8.019975] systemd-journald[292]: Received request to flush runtime journal from PID 1
[ 8.106837] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 8.114743] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 8.170826] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 8.178710] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 8.190704] PD DISP2 index4 DOWN
[ 8.195169] PD DISP1 index3 DOWN
[ 8.199922] PD DISP0 index2 DOWN
[ 8.201299] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 8.203105] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 8.203496] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 8.205693] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 8.238050] tegradc 15210000.nvdisplay: blank - powerdown
[ 8.244204] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 8.258542] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[ 8.402910] dhd_module_init in
[ 8.405996] tegra_net_perf_init: cannot get wifi sclk
[ 8.411645] found wifi platform device bcmdhd_wlan
[ 8.421622] wifi_platform_get_country_code_map: could not get country_code_map
[ 8.428859] wifi_plat_dev_drv_probe:platform country code map is not available
[ 8.436322] Unsupported HDMI VIC 15, ignoring
[ 8.440694] Unsupported HDMI VIC 140, ignoring
[ 8.441767] Power-up adapter 'DHD generic adapter'
[ 8.441773] wifi_platform_set_power = 1
[ 8.458316] Unsupported HDMI VIC 10, ignoring
[ 8.462844] Unsupported HDMI VIC 208, ignoring
[ 8.470800] Unsupported HDMI VIC 138, ignoring
[ 8.475777] Unsupported HDMI VIC 32, ignoring
[ 8.483976] tegradc 15210000.nvdisplay: blank - powerdown
[ 8.486921] tegradc 15210000.nvdisplay: unblank
[ 8.486934] PD DISP0 index2 UP
[ 8.491907] PD DISP1 index3 UP
[ 8.492000] PD DISP2 index4 UP
[ 8.494346] Parent Clock set for DC plld2
[ 8.546822] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 8.546824] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 8.598823] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 8.598825] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 8.642831] wifi_platform_bus_enumerate device present 1
[ 8.644840] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.650818] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 8.650820] tegradc 15210000.nvdisplay: timeout waiting for postcomp init state to promote
[ 8.651611] tegradc 15210000.nvdisplay: hdmi: pclk:27027K, set prod-setting:prod_c_54M
[ 8.661058] wifi_platform_bus_enumerate device present 0
[ 8.661406] F1 signature read @0x18000000=0x17214354
[ 8.664845] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.665321] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.665373] wifi_platform_prealloc: failed to alloc static mem section 7
[ 8.665380] wifi_platform_get_mac_addr
[ 8.666808] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 8.702821] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 8.702824] tegradc 15210000.nvdisplay: timeout waiting for win assignments to promote
[ 8.704806] wl_create_event_handler(): thread:wl_event_handler:1bf started
[ 8.704810] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1dfcc1a70
[ 8.704892] dhd_attach(): thread:dhd_watchdog_thread:1c0 started
[ 8.704913] dhd_attach(): thread:dhd_dpc:1c1 started
[ 8.704934] dhd_attach(): thread:dhd_rxf:1c2 started
[ 8.704938] dhd_deferred_work_init: work queue initialized
[ 8.705317] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Dec 1 2017 at 06:06:28
[ 8.705602] tegra_sysfs_register
[ 8.705627] Register interface [wlan0] MAC: 00:04:4b:a7:c2:d3
[ 8.705629] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.705709] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 60
[ 8.706748] wifi_platform_set_power = 0
[ 9.051095] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 9.264868] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 9.266840] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 9.266855] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 9.267638] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 9.267660] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 9.267771] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.267774] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.267776] usb usb1: Product: xHCI Host Controller
[ 9.267777] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 9.267779] usb usb1: SerialNumber: 3530000.xhci
[ 9.268041] hub 1-0:1.0: USB hub found
[ 9.268063] hub 1-0:1.0: 4 ports detected
[ 9.282962] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 9.282968] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 9.283082] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.283085] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.283087] usb usb2: Product: xHCI Host Controller
[ 9.283088] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 9.283090] usb usb2: SerialNumber: 3530000.xhci
[ 9.283320] hub 2-0:1.0: USB hub found
[ 9.283337] hub 2-0:1.0: 3 ports detected
[ 9.283693] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 9.382975] xhci-tegra 3530000.xhci: entering ELPG
[ 9.385536] xhci-tegra 3530000.xhci: entering ELPG done
[ 9.453623] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 9.455644] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 9.858024] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.913986] cfg80211: World regulatory domain updated:
[ 9.913992] cfg80211: DFS Master region: unset
[ 9.913992] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.913998] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.914001] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.914003] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.914006] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.914010] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.914013] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.914016] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.914019] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 10.247350] tegradc 15210000.nvdisplay: hdmi: plugged
[ 10.262841] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 10.455273] using random self ethernet address
[ 10.460600] using random host ethernet address
[ 10.474417] Mass Storage Function, version: 2009/09/11
[ 10.480590] LUN: removable file: (no medium)
[ 10.491177] using random self ethernet address
[ 10.496465] using random host ethernet address
[ 10.507027] usb0: HOST MAC 0e:c0:6b:24:c6:ba
[ 10.512310] usb0: MAC be:01:97:78:79:93
[ 10.517343] usb1: HOST MAC 9e:21:a6:7b:bb:eb
[ 10.522590] usb1: MAC e6:98:2d:48:e6:35
[ 10.527338] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 10.548598] device usb0 entered promiscuous mode
[ 10.558472] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 10.569211] device usb1 entered promiscuous mode
[ 10.579550] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 10.592775] l4tbr0: port 2(usb1) entered forwarding state
[ 10.598838] l4tbr0: port 2(usb1) entered forwarding state
[ 10.690840] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 10.692863] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 10.692869] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 10.693042] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 10.852137] android_work: did not send uevent (0 0 (null))
[ 10.922856] android_work: sent uevent USB_STATE=CONNECTED
[ 10.935791] android_work: sent uevent USB_STATE=DISCONNECTED
[ 11.003209] IPVS: Creating netns size=1424 id=1
[ 11.026982] android_work: sent uevent USB_STATE=CONNECTED
[ 11.034709] configfs-gadget gadget: high-speed config #1: c
[ 11.041169] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 11.041185] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 11.041201] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 11.041280] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 11.041296] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 11.041311] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 11.041338] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 11.041356] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 11.041375] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 11.041505] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 11.041580] l4tbr0: port 1(usb0) entered forwarding state
[ 11.041596] l4tbr0: port 1(usb0) entered forwarding state
[ 11.041683] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.041761] tegra-xudc-new 3550000.xudc: setup request failed: -95
[ 11.044376] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 11.044392] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 11.044623] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 11.077980] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.080500] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.088026] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.088099]
[ 11.088101] wl_android_wifi_on in
[ 11.088103] wifi_platform_set_power = 1
[ 11.335351] gk20a 17000000.gp10b: railgate is disabled.
[ 11.359397] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 11.433782] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 60
[ 11.443172] F1 signature read @0x18000000=0x17214354
[ 11.452486] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 11.459707] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 11.488000] tegradc 15210000.nvdisplay: blank - powerdown
[ 11.516884] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 11.558638] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 11.558905] Enabling wake69
[ 11.559894] wifi_platform_get_mac_addr
[ 11.561483] Firmware up: op_mode=0x0005, MAC=00:04:4b:a7:c2:d3
[ 11.567397] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 11.572237] Firmware version = wl0: May 4 2017 13:48:00 version 7.35.221.21 (r697384) FWID 01-58d9d0b3
[ 11.574772] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 11.574989] tegra_sysfs_on
[ 11.847126] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 11.872609] WLC_E_IF: NO_IF set, event Ignored
[ 12.538848] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 12.538856] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 12.590875] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 12.590885] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 12.598313] PD DISP2 index4 DOWN
[ 12.598516] PD DISP1 index3 DOWN
[ 12.598660] PD DISP0 index2 DOWN
[ 12.705327] tegradc 15210000.nvdisplay: unblank
[ 12.705339] PD DISP0 index2 UP
[ 12.706447] PD DISP1 index3 UP
[ 12.706537] PD DISP2 index4 UP
[ 12.710420] Parent Clock set for DC plld2
[ 12.762837] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 12.762841] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 12.814830] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 12.814834] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 12.866838] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 12.866844] tegradc 15210000.nvdisplay: timeout waiting for postcomp init state to promote
[ 12.867692] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_200M
[ 12.867703] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_300M
[ 12.922850] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 12.922854] tegradc 15210000.nvdisplay: timeout waiting for win assignments to promote
[ 13.927773] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.929068] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.027649] tegradc 15210000.nvdisplay: unblank
[ 14.083541] CPU1: shutdown
[ 14.086262] psci: CPU1 killed.
[ 14.098868] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 14.105860] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 14.116396] CPU2: shutdown
[ 14.119380] psci: CPU2 killed.
[ 15.162853] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 15.169435] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 16.030900] tegradc 15210000.nvdisplay: tegra_nvdisp_wait_for_common_channel_to_promote: DC 1 timed out waiting for COMMON promotion
[ 17.644000] fuse init (API version 7.23)
[ 19.241767] IPVS: Creating netns size=1424 id=2
[ 19.326831] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 19.333375] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 20.394879] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 20.401602] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 21.414004] tegradc 15210000.nvdisplay: blank - powerdown
[ 22.462909] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 22.462923] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 22.514859] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 22.514869] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 22.527855] PD DISP2 index4 DOWN
[ 22.528933] PD DISP1 index3 DOWN
[ 22.529470] PD DISP0 index2 DOWN
[ 22.578352] tegradc 15210000.nvdisplay: unblank
[ 22.578386] PD DISP0 index2 UP
[ 22.579819] PD DISP1 index3 UP
[ 22.579959] PD DISP2 index4 UP
[ 22.585364] Parent Clock set for DC plld2
[ 22.638856] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 22.638863] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 22.690837] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 22.690843] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 22.742843] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 22.742850] tegradc 15210000.nvdisplay: timeout waiting for postcomp init state to promote
[ 22.743727] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_200M
[ 22.743741] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_300M
[ 22.806850] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 22.806859] tegradc 15210000.nvdisplay: timeout waiting for win assignments to promote
[ 23.897117] tegradc 15210000.nvdisplay: unblank
[ 23.958833] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 23.965378] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 24.902894] tegradc 15210000.nvdisplay: tegra_nvdisp_wait_for_common_channel_to_promote: DC 1 timed out waiting for COMMON promotion
[ 25.022853] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 25.029511] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 25.642824] l4tbr0: port 2(usb1) entered forwarding state
[ 26.090827] l4tbr0: port 1(usb0) entered forwarding state
[ 26.329323] IPVS: Creating netns size=1424 id=3
[ 26.786831] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 26.793928] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 26.914840] tegradc 15210000.nvdisplay: tegra_nvdisp_wait_for_common_channel_to_promote: DC 1 timed out waiting for COMMON promotion
[ 27.859986] EXT4-fs (mmcblk1p1): recovery complete
[ 27.864846] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 957.367648] tegradc 15210000.nvdisplay: blank - powerdown
[ 959.426921] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 959.426936] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 959.478859] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 959.478869] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 959.492753] PD DISP2 index4 DOWN
[ 959.493823] PD DISP1 index3 DOWN
[ 959.494441] PD DISP0 index2 DOWN
[ 1314.063746] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 1314.093161] tegradc 15210000.nvdisplay: blank - powerdown
[ 1314.098689] tegradc 15210000.nvdisplay: unblank
[ 1314.103316] tegradc 15210000.nvdisplay: unblank
[ 1317.347900] Unsupported HDMI VIC 15, ignoring
[ 1317.352317] Unsupported HDMI VIC 140, ignoring
[ 1317.356846] Unsupported HDMI VIC 10, ignoring
[ 1317.361347] Unsupported HDMI VIC 208, ignoring
[ 1317.365852] Unsupported HDMI VIC 138, ignoring
[ 1317.370371] Unsupported HDMI VIC 32, ignoring
[ 1317.374876] tegradc 15210000.nvdisplay: blank - powerdown
[ 1317.380465] tegradc 15210000.nvdisplay: hdmi: plugged
[ 1317.393104] tegradc 15210000.nvdisplay: Invalid out_w + out_x (1920) > hActive (720)
OR/AND out_h + out_y (1200) > vActive (480)
for WIN 0
[ 1317.411712] tegradc 15210000.nvdisplay: blank - powerdown
[ 1317.417188] tegradc 15210000.nvdisplay: unblank
[ 1317.417205] PD DISP0 index2 UP
[ 1317.418259] PD DISP1 index3 UP
[ 1317.418358] PD DISP2 index4 UP
[ 1317.420559] Parent Clock set for DC plld2
[ 1317.474846] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1317.474854] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1317.526834] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1317.526841] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1317.578845] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1317.578855] tegradc 15210000.nvdisplay: timeout waiting for postcomp init state to promote
[ 1317.579766] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_200M
[ 1317.579784] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_300M
[ 1317.634838] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1317.634844] tegradc 15210000.nvdisplay: timeout waiting for win assignments to promote
[ 1318.725145] tegradc 15210000.nvdisplay: unblank
[ 1318.786830] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1318.793418] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1319.730902] tegradc 15210000.nvdisplay: tegra_nvdisp_wait_for_common_channel_to_promote: DC 1 timed out waiting for COMMON promotion
[ 1319.854857] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1319.861510] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1320.883085] tegradc 15210000.nvdisplay: blank - powerdown
[ 1321.742902] tegradc 15210000.nvdisplay: tegra_nvdisp_wait_for_common_channel_to_promote: DC 1 timed out waiting for COMMON promotion
[ 1322.798909] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1322.798924] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1322.850850] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1322.850861] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1322.863498] PD DISP2 index4 DOWN
[ 1322.864652] PD DISP1 index3 DOWN
[ 1322.865137] PD DISP0 index2 DOWN
[ 1322.926245] tegradc 15210000.nvdisplay: unblank
[ 1322.926277] PD DISP0 index2 UP
[ 1322.927665] PD DISP1 index3 UP
[ 1322.927808] PD DISP2 index4 UP
[ 1322.933219] Parent Clock set for DC plld2
[ 1322.986845] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1322.986852] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1323.038835] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1323.038841] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1323.090850] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1323.090861] tegradc 15210000.nvdisplay: timeout waiting for postcomp init state to promote
[ 1323.091783] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_200M
[ 1323.091802] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_300M
[ 1323.154849] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1323.154858] tegradc 15210000.nvdisplay: timeout waiting for win assignments to promote
[ 1324.245206] tegradc 15210000.nvdisplay: unblank
[ 1324.302836] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1324.309380] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1325.246889] tegradc 15210000.nvdisplay: tegra_nvdisp_wait_for_common_channel_to_promote: DC 1 timed out waiting for COMMON promotion
[ 1325.370876] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1325.377534] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1326.462821] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1326.469349] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 1327.258897] tegradc 15210000.nvdisplay: tegra_nvdisp_wait_for_common_channel_to_promote: DC 1 timed out waiting for COMMON promotion
[ 1327.926852] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 1327.933431] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
nvidia@tegra-ubuntu:~$ sudo get-edid | edid-decode
-bash: edid-decode: command not found
[sudo] password for nvidia:
This is read-edid version 3.0.2. Prepare for some fun.
Attempting to use i2c interface
No EDID on bus 0
No EDID on bus 1
No EDID on bus 2
No EDID on bus 3
No EDID on bus 4
No EDID on bus 5
No EDID on bus 6
No EDID on bus 8
1 potential busses found: 7
Bus 7 doesn't really have an EDID...
Couldn't find an accessible EDID on this computer.
Can anyone help me with solving this problem?
Thanks,
Marcin
