We’re experiencing boot problems on our TX2i solution (using the Spacely carrier from Connect Tech) if we try to run the board headless. I’ve attached a kernel log from the serial port below. It appears to fault when trying to read EDID parameters from the HDMI port. If we connect a monitor to the HDMI port, booting works perfectly.
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (root@TX1-DEV2) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #1 SMP PREEMPT Mon May 6 07:40:50 CDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 145600000
[ 0.000000] OF: fdt: - 235e00000 , 200000
[ 0.000000] OF: fdt: - 236600000 , 200000
[ 0.000000] OF: fdt: - 237000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1b704b000 s53400 r8192 d32616 u94208
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1764920
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2372e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x235840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29480(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6943488K/7172096K available (15038K kernel code, 2912K rwdata, 6672K rodata, 8512K init, 607K bss, 163072K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f30000 ( 15040 KB)
[ 0.000000] .rodata : 0xffffff8008f30000 - 0xffffff80095c0000 ( 6720 KB)
[ 0.000000] .init : 0xffffff80095c0000 - 0xffffff8009e10000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e10000 - 0xffffff800a0e8008 ( 2913 KB)
[ 0.000000] .bss : 0xffffff800a0e8008 - 0xffffff800a17fe3c ( 608 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf06dc8000 ( 109 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1b7200000 ( 7026 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009356] Console: colour dummy device 80x25
[ 0.013997] console [tty0] enabled
[ 0.017538] bootconsole [uart8250] disabled
[ 0.021895] kmemleak: Kernel memory leak detector disabled
[ 0.021912] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.021926] pid_max: default: 32768 minimum: 301
[ 0.022247] Security Framework initialized
[ 0.022410] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022421] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023035] ftrace: allocating 46769 entries in 183 pages
[ 0.148473] sched-energy: Sched-energy-costs installed from DT
[ 0.148495] ASID allocator initialised with 65536 entries
[ 0.181676] tegra-id: chipid=21817.
[ 0.181692] tegra-id: opt_subrevision=1.
[ 0.181711] Tegra Revision: A02p SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.181726] DTS File Name: tegra186-tx2-cti-ASG006-base.dts
[ 0.181737] DTB Build time: May 6 2019 07:49:53
[ 0.229854] CPU1: Booted secondary processor [4e0f0030]
[ 0.261475] CPU2: Booted secondary processor [4e0f0030]
[ 0.293316] CPU3: Booted secondary processor [411fd073]
[ 0.325311] CPU4: Booted secondary processor [411fd073]
[ 0.357308] CPU5: Booted secondary processor [411fd073]
[ 0.357367] Brought up 6 CPUs
[ 0.357408] SMP: Total of 6 processors activated.
[ 0.357422] CPU features: detected feature: 32-bit EL0 Support
[ 0.358222] CPU: All CPU(s) started at EL2
[ 0.358266] alternatives: patching kernel code
[ 0.367436] devtmpfs: initialized
[ 0.391939] Initilizing CustomIPI irq domain
[ 0.392174] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.392202] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.393140] pinctrl core: initialized pinctrl subsystem
[ 0.393350] OS set in device tree is not L4T.
[ 0.393510] regulator-dummy: no parameters
[ 0.393648] Initializing plugin-manager
[ 0.393707] Plugin module not found
[ 0.393751] Plugin-manager status disabled
[ 0.394961] NET: Registered protocol family 16
[ 0.395722] pstore: using zlib compression
[ 0.396143] console [pstore-1] enabled
[ 0.396155] pstore: Registered ramoops as persistent store backend
[ 0.396169] ramoops: attached 0x200000@0x235880000, ecc: 0/0
[ 0.412928] cpuidle: using governor menu
[ 0.413952] bpmp: waiting for handshake
[ 0.413968] bpmp: handshake completed
[ 0.413989] bpmp: synchronizing channels
[ 0.414008] bpmp: channels synchronized
[ 0.414021] bpmp: mail init ok
[ 0.415636] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.415656] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.415670] arm-smmu 12000000.iommu: stage 1 translation
[ 0.415684] arm-smmu 12000000.iommu: stage 2 translation
[ 0.415697] arm-smmu 12000000.iommu: nested translation
[ 0.415712] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.415733] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.415754] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.415770] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.415784] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.417607] vdso: 2 pages (1 code @ ffffff8008f37000, 1 data @ ffffff8009e14000)
[ 0.417639] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.420752] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.421778] Registering BPMP clocks...
[ 0.421881] tegra_bpmp_clk_init: clock init ok (636 clks)
[ 0.422202] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.423629] tegra_powergate_init: DONE
[ 0.423649] DTS File Name: tegra186-tx2-cti-ASG006-base.dts
[ 0.423666] DTB Build time: May 6 2019 07:49:53
[ 0.425043] Tegra reboot handler registered.
[ 0.426283] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.426364] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.426388] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.426402] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.426415] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.426584] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.426614] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.426920] iommu: Adding device 3460000.sdhci to group 0
[ 0.427586] iommu: Adding device 3400000.sdhci to group 1
[ 0.428683] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.428710] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.429184] iommu: Adding device 3160000.i2c to group 3
[ 0.429624] iommu: Adding device c240000.i2c to group 4
[ 0.429955] iommu: Adding device 3180000.i2c to group 5
[ 0.430280] iommu: Adding device 3190000.i2c to group 6
[ 0.430698] iommu: Adding device 31b0000.i2c to group 7
[ 0.431020] iommu: Adding device 31c0000.i2c to group 8
[ 0.431338] iommu: Adding device c250000.i2c to group 9
[ 0.431659] iommu: Adding device 31e0000.i2c to group 10
[ 0.433184] iommu: Adding device 3210000.spi to group 11
[ 0.433515] iommu: Adding device c260000.spi to group 12
[ 0.433840] iommu: Adding device 3240000.spi to group 13
[ 0.434540] iommu: Adding device 3100000.serial to group 14
[ 0.434871] iommu: Adding device 3110000.serial to group 15
[ 0.435189] iommu: Adding device c280000.serial to group 16
[ 0.435507] iommu: Adding device 3130000.serial to group 17
[ 0.436753] iommu: Adding device 2490000.ether_qos to group 18
[ 0.436778] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.437405] iommu: Adding device b000000.rtcpu to group 19
[ 0.439327] iommu: Adding device 13e10000.host1x to group 20
[ 0.439643] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.439950] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.440268] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.440580] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.440892] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.441237] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.441566] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.441892] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.442355] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.442977] iommu: Adding device 15700000.vi to group 30
[ 0.443318] iommu: Adding device 15600000.isp to group 31
[ 0.443765] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.444306] iommu: Adding device 15340000.vic to group 33
[ 0.444528] iommu: Adding device 154c0000.nvenc to group 34
[ 0.444743] iommu: Adding device 15480000.nvdec to group 35
[ 0.445108] iommu: Adding device 15380000.nvjpg to group 36
[ 0.445340] iommu: Adding device 15500000.tsec to group 37
[ 0.445553] iommu: Adding device 15100000.tsecb to group 38
[ 0.446182] iommu: Adding device 15810000.se to group 39
[ 0.446393] iommu: Adding device 15820000.se to group 40
[ 0.446605] iommu: Adding device 15830000.se to group 41
[ 0.446811] iommu: Adding device 15840000.se to group 42
[ 0.447614] iommu: Adding device smmu_test to group 43
[ 0.448210] mc: mapped MMIO address: 0xffffff800a680000 -> 0x2c10000
[ 0.448236] mc: mapped MMIO address: 0xffffff800a6a0000 -> 0x2c20000
[ 0.448258] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c30000
[ 0.448280] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c40000
[ 0.448301] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c50000
[ 0.448322] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.448346] mc-err: mcerr ops are set to t18x
[ 0.448496] dram-ecc: DRAM ECC enabled-MC_ECC_CONTROL:0x0000000d
[ 0.448533] dram-ecc: SCE-R5 is booted with Camera FW
[ 0.448547] dram-ecc: DRAM ECC interrupts handled in Kernel
[ 0.448619] dram-ecc: ecc_err_irq = 67
[ 0.448734] dram-ecc: EMC_INTMASK = 0x00001c00
[ 0.448749] dram-ecc: EMC_NONCRITICAL_INTMASK = 0x00001800
[ 0.448762] dram-ecc: EMC_CRITICAL_INTMASK = 0x00000400
[ 0.449853] iommu: Adding device 3530000.xhci to group 44
[ 0.449879] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.450304] iommu: Adding device 3550000.xudc to group 45
[ 0.450328] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.451065] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.451085] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.451643] iommu: Adding device 17000000.gp10b to group 46
[ 0.452637] tegra-reset 5000000.clock: registered 193 resets.
[ 0.454694] iommu: Adding device d000000.bpmp to group 47
[ 0.454930] bpmp: ping status is 0
[ 0.455031] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[ 0.457099] bpmp d000000.bpmp: probe ok
[ 0.459916] iommu: Adding device 2600000.dma to group 48
[ 0.461049] GPIO line 459 (pcie0_lane2_mux) hogged as output/low
[ 0.461089] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.461121] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.461152] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.461361] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.465089] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.465274] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.466848] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.466879] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.467210] iommu: Adding device sound to group 50
[ 0.467559] iommu: Adding device 3510000.hda to group 51
[ 0.474779] iommu: Adding device c1a0000.aon to group 52
[ 0.475250] vdd-ac-bat: 5000 mV
[ 0.477023] vdd-1v8-ap: 1800 mV
[ 0.506957] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.513437] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.514080] SCSI subsystem initialized
[ 0.514579] usbcore: registered new interface driver usbfs
[ 0.514663] usbcore: registered new interface driver hub
[ 0.514808] usbcore: registered new device driver usb
[ 0.517508] random: fast init done
[ 0.529999] max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
[ 0.538043] vddio-ddr: at 925 mV
[ 0.541895] avdd_dsi_csi: 1200 mV
[ 0.545512] vdd-1v8: 1800 mV
[ 0.549601] vdd-3v3-sys: 3300 mV
[ 0.550884] spmic-ldo0: at 1800 mV
[ 0.551736] spmic-ldo1: at 800 mV
[ 0.553511] vddio-3v3: 3300 mV
[ 0.554255] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.557515] vdd-rtc: at 800 mV
[ 0.558398] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.561513] spmic-ldo6: at 1500 mV
[ 0.565517] vdd-pex-1v00: 1000 mV
[ 0.566342] dvdd-pex: 1000 mV
[ 0.567035] GPIO line 253 (spmic_gpio_input) hogged as input
[ 0.567239] GPIO line 254 (spmic_gpio_input) hogged as input
[ 0.567524] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 0.569816] max77620 4-003c: max77620 probe successful
[ 0.570328] media: Linux media interface: v0.10
[ 0.570439] Linux video capture interface: v2.00
[ 0.574832] pps_core: LinuxPPS API ver. 1 registered
[ 0.574882] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.574958] PTP clock support registered
[ 0.575666] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.575733] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.578601] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.583175] Advanced Linux Sound Architecture Driver Initialized.
[ 0.583807] Bluetooth: Core ver 2.22
[ 0.583877] NET: Registered protocol family 31
[ 0.583908] Bluetooth: HCI device and connection manager initialized
[ 0.583948] Bluetooth: HCI socket layer initialized
[ 0.583980] Bluetooth: L2CAP socket layer initialized
[ 0.584050] Bluetooth: SCO socket layer initialized
[ 0.584982] en-vdd-sd: 3300 mV
[ 0.585644] vdd-usb0-5v: 5000 mV
[ 0.586075] vdd-usb1-5v: 5000 mV
[ 0.586758] vdd-3v3: 3300 mV
[ 0.587117] en-vdd-vcm-2v8: 2800 mV
[ 0.587492] vdd-sys-bl: 3300 mV
[ 0.590271] camchar: rtcpu character device driver loaded
[ 0.590923] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.592886] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 0.594647] clocksource: Switched to clocksource arch_sys_counter
[ 0.636269] VFS: Disk quotas dquot_6.6.0
[ 0.636545] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.637797] tegra-pcie 10003000.pcie-controller: wrong configuration updated in DT, switching to default 2x1, 1x1, 1x1 configuration
[ 0.639007] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.639699] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.639743] nvmap_page_pool_init: Total RAM pages: 1752256
[ 0.639778] nvmap_page_pool_init: nvmap page pool size: 219032 pages (855 MB)
[ 0.639837] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.639927] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.640311] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[ 0.642572] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.645024] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.657399] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.657661] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.658092] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.658239] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.658419] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.658630] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.658909] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.659144] la/ptsa driver initialized.
[ 0.659178] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.659211] pre_t19x_iso_plat_init(): max_iso_bw=7680000KB
[ 0.660372] NET: Registered protocol family 2
[ 0.662430] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.663260] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.663961] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.664073] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.664320] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.665199] NET: Registered protocol family 1
[ 0.666253] RPC: Registered named UNIX socket transport module.
[ 0.666291] RPC: Registered udp transport module.
[ 0.666320] RPC: Registered tcp transport module.
[ 0.666348] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.667552] GPIO line 233 (touch-rails) hogged as output/high
[ 0.667820] GPIO line 234 (touch-rails) hogged as output/high
[ 0.668089] GPIO line 233 (camera-rst) hogged as output/low
[ 0.668373] GPIO line 235 (camera-rst) hogged as output/low
[ 0.668634] GPIO line 237 (camera-rst) hogged as output/low
[ 0.668895] GPIO line 239 (camera-rst) hogged as output/low
[ 0.669222] gpiochip_setup_dev: registered GPIOs 232 to 247 on device: gpiochip3 (tca9539)
[ 0.670169] GPIO line 220 (lcd-bias-rails) hogged as output/high
[ 0.670477] gpiochip_setup_dev: registered GPIOs 216 to 231 on device: gpiochip4 (tca9539)
[ 0.670896] Trying to unpack rootfs image as initramfs...
[ 0.690229] host1x 13e10000.host1x: initialized
[ 0.692468] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.697311] audit: initializing netlink subsys (disabled)
[ 0.697383] audit: type=2000 audit(0.580:1): initialized
[ 0.698085] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.710959] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.713727] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.715429] 9p: Installing v9fs 9p2000 file system support
[ 0.721941] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.722138] io scheduler noop registered
[ 0.722848] io scheduler cfq registered (default)
[ 0.728040] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.761337] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 0.764866] iommu: Adding device 2993000.adsp to group 54
[ 0.765085] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.767940] tegra-xusb-padctl 3520000.xusb_padctl: Invalid OC pin: 2
[ 0.768452] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.772809] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.774375] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.775806] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.777142] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.783043] tsec 15500000.tsec: initialized
[ 0.784355] tsec 15100000.tsecb: initialized
[ 0.787598] nvdec 15480000.nvdec: initialized
[ 0.793585] falcon 15340000.vic: initialized
[ 0.795219] falcon 154c0000.nvenc: initialized
[ 0.796594] falcon 15380000.nvjpg: initialized
[ 0.800809] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.802445] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.804193] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.805985] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.807761] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.809354] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.810997] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.812545] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.816409] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.816455] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.816516] tegradccommon 15200000.dc_common: dma mapping done
[ 0.817558] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.817650] generic_infoframe_type: 0x87
[ 0.817795] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.817862] tegradc 15210000.nvdisplay: Display dc.ffffff800b4a0000 registered with id=0
[ 0.818213] of_fixed_clk: probe of can_clock failed with error -17
[ 0.827225] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 5924200 KB/s
[ 0.827272] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 204000000 Hz
[ 0.827306] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 207380000 Hz
[ 0.827638] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.827671] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.828935] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.829084] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 0.829981] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.831071] kfuse 3830000.kfuse: initialized
[ 0.832623] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 0.832662] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 0.832971] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.837592] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 0.837644] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.840967] console [ttyS0] disabled
[ 0.841032] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 0.844766] tegradc 15210000.nvdisplay: probed
[ 1.206399] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 1.613434] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.020602] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.022670] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 2.023040] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.023048] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.023056] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[ 2.023061] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[ 2.023067] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.023395] iommu: Adding device 0000:00:01.0 to group 55
[ 2.023406] arm-smmu: forcing sodev map for 0000:00:01.0
[ 2.023514] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.024323] iommu: Adding device 0000:01:00.0 to group 56
[ 2.024328] arm-smmu: forcing sodev map for 0000:01:00.0
[ 2.034811] pci 0000:00:01.0: BAR 14: assigned [mem 0x40100000-0x401fffff]
[ 2.034816] pci 0000:00:01.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.034825] pci 0000:01:00.0: BAR 0: assigned [mem 0x40100000-0x4011ffff]
[ 2.034839] pci 0000:01:00.0: BAR 3: assigned [mem 0x40120000-0x40123fff]
[ 2.034852] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 2.034866] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 2.034872] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 2.034887] pci 0000:00:01.0: bridge window [mem 0x40100000-0x401fffff]
[ 2.035908] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 2.035912] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.220185] console [ttyS0] enabled
[ 3.220728] Console: switching to colour frame buffer device 80x30
[ 3.230626] tegradc 15210000.nvdisplay: fb registered
[ 3.231378] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 3.235730] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.242838] serial-tegra 3130000.serial: RX in PIO mode
[ 3.243816] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.244845] [drm] Initialized
[ 3.270455] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.275622] brd: module loaded
[ 3.277118] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 3.277219] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 3.277317] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 3.279057] Parent Clock set for DC plld2
[ 3.282347] edid invalid
[ 3.283101] tegradc 15210000.nvdisplay: hdmi: tmds rate:25200K prod-setting:prod_c_hdmi_0m_54m
[ 3.284507] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 3.284524] Unable to handle kernel read from unreadable memory at virtual address 00000063
[ 3.284526] Mem abort info:
[ 3.284529] ESR = 0x96000005
[ 3.284532] Exception class = DABT (current EL), IL = 32 bits
[ 3.284534] SET = 0, FnV = 0
[ 3.284536] EA = 0, S1PTW = 0
[ 3.284537] Data abort info:
[ 3.284540] ISV = 0, ISS = 0x00000005
[ 3.284542] CM = 0, WnR = 0
[ 3.284544] [0000000000000063] user address but active_mm is swapper
[ 3.284550] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 3.284556] Modules linked in:
[ 3.284564] CPU: 2 PID: 86 Comm: kworker/u12:3 Not tainted 4.9.140-tegra #1
[ 3.284566] Hardware name: quill (DT)
[ 3.284635] Workqueue: events_unbound async_run_entry_fn
[ 3.284639] task: ffffffc1ac400000 task.stack: ffffffc1ac408000
[ 3.284649] PC is at tegra_edid_is_rgb_quantization_selectable+0x4/0x10
[ 3.284657] LR is at tegra_hdmi_avi_infoframe+0x368/0xa18
[ 3.284662] pc : [<ffffff80085d2dd4>] lr : [<ffffff800861b880>] pstate: 80400045
[ 3.284665] sp : ffffffc1ac40b8b0
[ 3.284671] x29: ffffffc1ac40b8b0 x28: ffffffc1ab02e000
[ 3.284677] x27: 0000000001808580 x26: ffffff80093ff0a8
[ 3.284683] x25: 0000000000006270 x24: 0000000000000000
[ 3.284688] x23: ffffffc1ab78f018 x22: 0000000000000000
[ 3.284693] x21: ffffffc1ab018840 x20: ffffffc1ab78f018
[ 3.284698] x19: ffffffc1ab018818 x18: 0000000000000000
[ 3.284703] x17: 0000000000000001 x16: 0000000000000000
[ 3.284708] x15: ffffffffffffffff x14: 3a676e6974746573
[ 3.284713] x13: 0000000000000000 x12: 0000000000000000
[ 3.284718] x11: ffffff8009e34000 x10: ffffff800a0f3000
[ 3.284723] x9 : ffffff800a0f30d0 x8 : ffffffc1b70138c8
[ 3.284728] x7 : 0000000000000000 x6 : 00000000173feaba
[ 3.284733] x5 : 00ffffffffffffff x4 : 0000000000000015
[ 3.284737] x3 : 0000000000000000 x2 : 0000000000000000
[ 3.284742] x1 : ffffffc1ac400000 x0 : 0000000000000000
[ 3.284743]
[ 3.284747] Process kworker/u12:3 (pid: 86, stack limit = 0xffffffc1ac408000)
[ 3.284749] Call trace:
[ 3.284757] [<ffffff80085d2dd4>] tegra_edid_is_rgb_quantization_selectable+0x4/0x10
[ 3.284774] [<ffffff800861cc48>] tegra_hdmi_controller_enable+0x250/0xbc8
[ 3.284779] [<ffffff800861d604>] tegra_dc_hdmi_enable+0x44/0xb0
[ 3.284786] [<ffffff800864be78>] tegra_nvdisp_head_enable+0x590/0x14b8
[ 3.284801] [<ffffff80085b1bf0>] _tegra_dc_enable+0xc8/0x108
[ 3.284807] [<ffffff80085b82ec>] tegra_dc_probe+0xfbc/0x16a8
[ 3.284816] [<ffffff8008759748>] platform_drv_probe+0x60/0xc8
[ 3.284828] [<ffffff8008756d10>] driver_probe_device+0xd0/0x3f8
[ 3.284833] [<ffffff800875715c>] __driver_attach+0x124/0x128
[ 3.284839] [<ffffff8008754844>] bus_for_each_dev+0x74/0xb0
[ 3.284844] [<ffffff8008756508>] driver_attach+0x30/0x40
[ 3.284848] [<ffffff8008754e08>] driver_attach_async+0x20/0x60
[ 3.284854] [<ffffff80080df8a0>] async_run_entry_fn+0x48/0x160
[ 3.284885] [<ffffff80080d4e58>] process_one_work+0x1e8/0x490
[ 3.284891] [<ffffff80080d5158>] worker_thread+0x58/0x4c0
[ 3.284895] [<ffffff80080dbb28>] kthread+0xd8/0xf0
[ 3.284902] [<ffffff8008083850>] ret_from_fork+0x10/0x40
[ 3.284910] ---[ end trace c5260e3d1147d1cf ]---
[ 3.292860] Unable to handle kernel paging request at virtual address ffffffffffffffd8
[ 3.292862] Mem abort info:
[ 3.292864] ESR = 0x96000005
[ 3.292867] Exception class = DABT (current EL), IL = 32 bits
[ 3.292868] SET = 0, FnV = 0
[ 3.292871] EA = 0, S1PTW = 0
[ 3.292872] Data abort info:
[ 3.292874] ISV = 0, ISS = 0x00000005
[ 3.292876] CM = 0, WnR = 0
[ 3.292880] swapper pgtable: 4k pages, 39-bit VAs, pgd = ffffff800a183000
[ 3.292887] [ffffffffffffffd8] *pgd=0000000000000000, *pud=0000000000000000
[ 3.292890] Internal error: Oops: 96000005 [#2] PREEMPT SMP
[ 3.292894] Modules linked in:
[ 3.292900] CPU: 2 PID: 86 Comm: kworker/u12:3 Tainted: G D 4.9.140-tegra #1
[ 3.292902] Hardware name: quill (DT)
[ 3.292930] task: ffffffc1ac400000 task.stack: ffffffc1ac408000
[ 3.292961] PC is at kthread_data+0x24/0x30
[ 3.292966] LR is at wq_worker_sleeping+0x20/0xd0
[ 3.292970] pc : [<ffffff80080dc74c>] lr : [<ffffff80080d5ff0>] pstate: 804000c5
[ 3.292972] sp : ffffffc1ac40b4b0
[ 3.292978] x29: ffffffc1ac40b4b0 x28: ffffffc1ac400000
[ 3.292983] x27: ffffff80080eb93c x26: ffffffc1b7084cc0
[ 3.292988] x25: ffffffc1ac4006d0 x24: 0000000000000000
[ 3.292997] x23: ffffff80097e4000 x22: ffffffc1ac400000
[ 3.293001] x21: ffffff8009e18000 x20: ffffff80097ef000
[ 3.293006] x19: ffffffc1ac400000 x18: 000000000000000e
[ 3.293010] x17: 0000000000000000 x16: 0000000000000000
[ 3.293015] x15: 0000000000000019 x14: 0000000000000033
[ 3.293019] x13: 000000000000004c x12: 0000000000000068
[ 3.293023] x11: 00000000020cca45 x10: 00000000022c1863
[ 3.293028] x9 : 00000000020cc9f2 x8 : 0000000000000400
[ 3.293032] x7 : 0000000000000000 x6 : 0000000000000400
[ 3.293037] x5 : ffffffc1ac4000c0 x4 : 0000000000005c00
[ 3.293041] x3 : 0000000000000000 x2 : 0000000000000000
[ 3.293045] x1 : ffffffc1b7084cc0 x0 : 0000000000000000
[ 3.293047]
[ 3.293050] Process kworker/u12:3 (pid: 86, stack limit = 0xffffffc1ac408000)
[ 3.293052] Call trace:
[ 3.293059] [<ffffff80080dc74c>] kthread_data+0x24/0x30
[ 3.293068] [<ffffff8008f1b0f8>] __schedule+0x4f8/0x770
[ 3.293074] [<ffffff80080eb93c>] do_task_dead+0x74/0x78
[ 3.293080] [<ffffff80080b9bdc>] do_exit+0x5c4/0x9d8
[ 3.293086] [<ffffff800808c438>] die+0x188/0x1a0
[ 3.293094] [<ffffff80080a3628>] __do_kernel_fault.isra.1+0x140/0x218
[ 3.293099] [<ffffff80080a39b4>] do_page_fault+0x1d4/0x4c0
[ 3.293104] [<ffffff80080a3d0c>] do_translation_fault+0x6c/0x80
[ 3.293109] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 3.293113] [<ffffff8008082904>] el1_da+0x24/0xb4
[ 3.293119] [<ffffff800861cc48>] tegra_hdmi_controller_enable+0x250/0xbc8
[ 3.293123] [<ffffff800861d604>] tegra_dc_hdmi_enable+0x44/0xb0
[ 3.293128] [<ffffff800864be78>] tegra_nvdisp_head_enable+0x590/0x14b8
[ 3.293134] [<ffffff80085b1bf0>] _tegra_dc_enable+0xc8/0x108
[ 3.293144] [<ffffff80085b82ec>] tegra_dc_probe+0xfbc/0x16a8
[ 3.293149] [<ffffff8008759748>] platform_drv_probe+0x60/0xc8
[ 3.293158] [<ffffff8008756d10>] driver_probe_device+0xd0/0x3f8
[ 3.293163] [<ffffff800875715c>] __driver_attach+0x124/0x128
[ 3.293167] [<ffffff8008754844>] bus_for_each_dev+0x74/0xb0
[ 3.293172] [<ffffff8008756508>] driver_attach+0x30/0x40
[ 3.293176] [<ffffff8008754e08>] driver_attach_async+0x20/0x60
[ 3.293182] [<ffffff80080df8a0>] async_run_entry_fn+0x48/0x160
[ 3.293187] [<ffffff80080d4e58>] process_one_work+0x1e8/0x490
[ 3.293192] [<ffffff80080d5158>] worker_thread+0x58/0x4c0
[ 3.293196] [<ffffff80080dbb28>] kthread+0xd8/0xf0
[ 3.293200] [<ffffff8008083850>] ret_from_fork+0x10/0x40
[ 3.293204] ---[ end trace c5260e3d1147d1d0 ]---
[ 3.301279] Fixing recursive fault but reboot is needed!
