Xavier changed sor0 to HDMI and display nothing
hi,
on ours design carrier board,we only use sor0 connect to HDMI interface,and i confirm the hardware signal is ok,I have changed device tree(list below) and disable other DP port.
#include <dt-bindings/display/tegra-dc.h>
#include <dt-bindings/display/tegra-panel.h>
#include <t19x-common-platforms/tegra194-hdmi.dtsi>
#include <t19x-common-platforms/tegra194-dp.dtsi>
#include “tegra194-fixed-regulator-p2822-1000.dtsi”
#include “tegra194-spmic-p2888-0001.dtsi”
&head0 {
status = “okay”;
nvidia,fb-bpp = <32>;
nvidia,fbmem-size = <265420800>; /* 8K (76804320) 32bpp double buffered /
nvidia,fb-flags = <TEGRA_FB_FLIP_ON_PROBE>;
win-mask = <0x3>;
nvidia,fb-win = <0>;
nvidia,dc-connector = <&sor0>; /changed by shqli,oldval:sor2/
nvidia,dc-flags = <TEGRA_DC_FLAG_ENABLED>;
avdd_hdmi-supply = <&p2888_spmic_sd0>; /
1v0 /
avdd_hdmi_pll-supply = <&p2888_spmic_sd1>; /
1v8 /
vdd_hdmi_5v0-supply = <&p2822_vdd_hdmi_5v0>; /
5v0
&head1 {
status = “disabled”; /changed by shqli,oldval:okay/
nvidia,fbmem-size = <265420800>; /* 8K (7680*4320) 32bpp double buffered /
win-mask = <0xC>;
nvidia,fb-win = <2>;
nvidia,dc-connector = <&sor2>; /changed by shqli,oldval:sor0/
1v0 /
1v8 */
//vdd-dp-pwr-supply = <&p2888_spmic_sd0>;
//avdd-dp-pll-supply = <&p2888_spmic_sd1>;
//vdd-edp-sec-mode-supply = <&battery_reg>;
//vdd-dp-pad-supply = <&battery_reg>;
vdd_hdmi_5v0-supply = <&p2822_vdd_hdmi_5v0>; /deleted by shqli/
&head2 {
nvidia,fbmem-size = <265420800>; /* 8K (7680*4320) 32bpp double buffered */
win-mask = <0x30>;
nvidia,fb-win = <4>;
nvidia,dc-connector = <&sor1>;
/vdd_hdmi_5v0-supply = <&p2822_vdd_hdmi_5v0>;/ /deleted by shqli/
&sor0 {
status = “okay”;
nvidia,active-panel = <&sor0_hdmi_display>;
&sor0_hdmi_display {
status = “okay”;
disp-default-out {
nvidia,out-flags = <TEGRA_DC_OUT_HOTPLUG_LOW>;
&sor1 {
nvidia,active-panel = <&sor1_dp_display>;
&sor1_dp_display {
nvidia,is_ext_dp_panel = <1>;
&sor2 {
nvidia,active-panel = <&sor2_hdmi_display>;
&sor2_hdmi_display {
disp-default-out {
&dpaux0 {
status = “okay”;
/deleted by shqli start./
&dpaux1 {
&dpaux2 {
&dpaux3 {
/deleted by shqli end./
&tegra_cec {
status = “okay”;constantly
but when i powerup the board,during the period of powerup,the monitor can display kernel info but stuck in display info “started update UTMP about system Runlevel changes”,do not display unbunt user and passwd interface,and the uart0 constantly print below info:
[ 244.621665] Extcon AUX0(HDMI) enable
[ 247.905928] tegradc 15200000.nvdisplay: blank - powerdown
[ 247.950428] extcon-disp-state external-connection:disp-state: cable 46 state 0
[ 247.950430] Extcon AUX0(HDMI) disable
[ 247.974641] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 247.975954] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 247.976114] tegradc 15200000.nvdisplay: unblank
[ 247.976837] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 247.976945] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 247.978401] Parent Clock set for DC pll_d
[ 247.986776] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 247.988128] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 247.988152] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 247.998378] extcon-disp-state external-connection:disp-state: cable 46 state 1
[ 247.998380] Extcon AUX0(HDMI) enable
[ 251.308266] tegradc 15200000.nvdisplay: blank - powerdown
[ 251.355063] extcon-disp-state external-connection:disp-state: cable 46 state 0
[ 251.355065] Extcon AUX0(HDMI) disable
[ 251.386489] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 251.387483] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 251.387614] tegradc 15200000.nvdisplay: unblank
[ 251.388489] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 251.388622] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 251.392284] Parent Clock set for DC pll_d
[ 251.400417] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 251.401888] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 251.401895] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 251.407750] extcon-disp-state external-connection:disp-state: cable 46 state 1
[ 251.407751] Extcon AUX0(HDMI) enable
[ 254.742426] tegradc 15200000.nvdisplay: blank - powerdown
[ 254.785450] extcon-disp-state external-connection:disp-state: cable 46 state 0
[ 254.785452] Extcon AUX0(HDMI) disable
[ 254.807635] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 254.808140] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 254.808317] tegradc 15200000.nvdisplay: unblank
[ 254.809057] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 254.809165] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 254.810717] Parent Clock set for DC pll_d
[ 254.819154] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 254.820538] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 254.820555] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 254.824058] extcon-disp-state external-connection:disp-state: cable 46 state 1
[ 254.824060] Extcon AUX0(HDMI) enableindent preformatted text by 4 spaces
btw, i input ‘xinit’ in uart0,just print below info:
nvidia@jetson-0423818077174:~$ xinit
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-138-generic aarch64 Ubuntu
Current Operating System: Linux jetson-0423818077174 4.9.140 #210 SMP PREEMPT Wed Apr 1 12:00:40 CST 2020 aarch64
Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 OS=l4t video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0791000 lut_mem=0x2008@0xa068d000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 sdhci_tegra.en_boot_part_access=1
Build Date: 25 October 2018 04:10:37PM
xorg-server 2:1.19.6-1ubuntu4.2 (For technical support please see Enterprise open source support | Ubuntu)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jan 28 16:03:14 2018
(==) Using config file: “/etc/X11/xorg.conf”
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
i think the fatel error is “no screens found”,but i do not known why?
hello:
by the way,below is powerup log:
0000.292] I> MB1 (prd-version: 1.0.0.0-t194-41334769-a3872862)
[0000.298] I> Boot-mode: L0 coldboot
[0000.301] I> chip revision : A02
[0000.304] I> Bootrom patch version : 7 (correctly patched)
[0000.309] I> ATE fuse revision : 0x200
[0000.312] I> Ram repair fuse : 0x0
[0000.315] I> Ram Code : 0x0
[0000.318] I> rst_source : 0x0
[0000.321] I> rst_level : 0x0
[0000.324] I> Boot-device: eMMC
[0000.327] W> DEVICE_PROD: device prod is not initialized.
[0000.332] W> DEVICE_PROD: device prod is not initialized.
[0000.349] I> Sdmmc: DDR50 mode
[0000.353] W> DEVICE_PROD: device prod is not initialized.
[0000.359] I> Active boot chain: 0
[0000.362] I> Active boot chain: 0
[0000.365] I> magic:0x43424e00, version: 3, num_slots: 1
[0000.370] W> No valid slot number is found in scratch register
[0000.375] W> Return default slot: _a
[0000.378] I> Boot chain slot 0
[0000.381] I> Boot-device: eMMC
[0000.385] E> No fuse-bypass data
[0000.388] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.395] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0000.402] I> temperature = 41500
[0000.405] W> Skipping boost for clk:bpmp_cpu_nic
[0000.409] W> Skipping boost for clk:bpmp_apb
[0000.413] W> Skipping boost for clk:axi_cbb
[0000.417] W> Skipping boost for clk:aon_cpu_nic
[0000.421] W> Skipping boost for clk:aon_can0
[0000.425] W> Skipping boost for clk:aon_can1
[0000.430] I> Boot-device: eMMC
[0000.433] I> Boot-device: eMMC
[0000.442] I> Sdmmc: HS400 mode enabled
[0000.450] I> ECC region[0]: Start:0x0, End:0x0
[0000.455] I> ECC region[1]: Start:0x0, End:0x0
[0000.459] I> ECC region[2]: Start:0x0, End:0x0
[0000.463] I> ECC region[3]: Start:0x0, End:0x0
[0000.467] I> ECC region[4]: Start:0x0, End:0x0
[0000.471] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.477] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.481] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.486] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.490] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.496] W> MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.503] E> FAILED: Thermal config
[0000.506] W> DEVICE_PROD: device prod is not initialized.
[0000.512] W> DEVICE_PROD: device prod is not initialized.
[0000.521] W> MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.528] E> FAILED: MEMIO rail config
[0000.542] I> scrub mode: full dram
[0000.545] E> FUSE: Failed to verify ECID.
[0000.558] I> WP-0 triggered
[0000.561] I> WP-0 ACK received :)
[0000.564] I> sdmmc bdev is already initialized
[0000.597] I> WP-1 triggered
[0000.603] W> No fuse-bypass data
[0000.606] I> SC7 context save done
[0000.613] I> WP-1 ACK received :)
[0000.616] W> MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.623] I> MTS carveout BOM: 0xf8000000
[0000.627] I> WP1.5 triggered
[0000.679] I> WP1.5 ACK received :)
[0000.683] I> MB1 done
main enter
SPE VERSION #: R01.00.10 Created: May 31 2018 @ 13:05:12
HW Function test
Start Scheduler.
in late init
0000.691] I> Welcome to MB2(TBoot-BPMP)
[0000.691] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.692] W> Device prod registration failed
[0000.692] I> Boot-device: eMMC
[0000.693] I> Boot_device: SDMMC_BOOT instance: 3
[0000.700] I> sdmmc-3 params source = boot args
[0000.701] I> sdmmc bdev is already initialized
[0000.706] I> sdmmc-3 params source = boot args
[0000.712] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0000.719] I> Found 36 partitions in SDMMC_BOOT (instance 3)
[0000.721] W> No valid slot number is found in scratch register
[0000.726] W> Return default slot: _a
[0000.730] I> Active Boot chain : 0
[0000.733] I> Binary@ device:1/3 block-58750712 (partition size: 0x100000)
[0000.749] I> Binary@ device:1/3 block-58754808 (partition size: 0x100000)
[0000.788] I> Binary@ device:1/3 block-58759928 (partition size: 0x80000)
[0000.793] I> Binary@ device:1/3 block-58738680 (partition size: 0x80000)
[0000.798] I> Binary@ device:1/3 block-58740728 (partition size: 0x60000)
[0000.801] I> BL-DTB loaded successfully
[0000.802] I> Relocating BR-BCT
[0000.803] I> Binary@ device:1/3 block-58742264 (partition size: 0x200000)
[0000.811] I> Unhalting RCE
TICE: BL31: v1.3(release):9fc2cdf
NOTICE: BL31: Built : 15:08:58, Oct 31 2018
ERROR: Error initializing runtime service trusty_fast
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 588c62054ecdba8a44cb9d6ff5d04cb0
tag_show initialized
dt initialized
WARNING: at platform/drivers/mailbox/mail_mach.c:514
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
vmon_soc_self_check: vmon_vsoc: self-check passed
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
warning: aon_cpu_nic do not permit ‘allowed-parents’ property
387 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
mrq initialized
0001.325] I> Welcome to Cboot
[0001.325] I> Cboot Version: 4e3f0bea4cf94837f65ddb512d987e4e8589e811.10.31.2018.43-t194-3d46n_post initialized
001.326] I> CPU-BL Params @ 0xf2820000
[0001.326] I> 0) Base:0x00000000 Size:0x00000000
[0001.329] I> 1) Base:0xf2100000 Size:0x00100000
[0001.333] I> 2) Base:0xf2000000 Size:0x00100000
[0001.338] I> 3) Base:0xf1300000 Size:0x00100000
[0001.342] I> 4) Base:0xf1200000 Size:0x00100000
[0001.347] I> 5) Base:0xf1100000 Size:0x00100000
[0001.351] I> 6) Base:0xf3800000 Size:0x00400000
[0001.356] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.360] I> 8) Base:0xf1000000 Size:0x00100000
k_dt_late initialized
001.365] I> 9) Base:0xf0f00000 Size:0x00100000
rveout 25 misconfigured: 0x0@0x000000000
001.372] I> 10) Base:0xf3000000 Size:0x00800000
rveout 25 access not ok (reg 0x2610 = 0x0, bit 27)
veout 25 access not ok (reg 0x2610 = 0x0, bit 28)
001.380] I> 11) Base:0x40000000 Size:0x00040000
rveout 25 access not ok (reg 0x2610 = 0x0, bit 19)
veout 25 access not ok (reg 0x2610 = 0x0, bit 20)
001.394] I> 12) Base:0xf0e00000 Size:0x00100000
chine_check initialized
001.408] I> 13) Base:0x40046000 Size:0x00002000
_post initialized
001.415] I> 14) Base:0x40048000 Size:0x00002000
ells initialized
001.422] I> 15) Base:0xaa000000 Size:0x00004000
fs_clk_platform_post initialized
001.429] I> 16) Base:0x4004a000 Size:0x00002000
ce initialized
001.437] I> 17) Base:0xf0d00000 Size:0x00100000
c initialized
001.443] I> 18) Base:0x4004c000 Size:0x00002000
plex_avfs_hw_init: nafll_cluster0: not monitored
001.449] I> 19) Base:0xf2200000 Size:0x00600000
plex_avfs_hw_init: nafll_cluster1: not monitored
001.459] I> 20) Base:0x4004e000 Size:0x00002000
plex_avfs_hw_init: nafll_cluster2: not monitored
001.468] I> 21) Base:0xf0cd0000 Size:0x0000c000
plex_avfs_hw_init: nafll_cluster3: not monitored
001.477] I> 22) Base:0x00000000 Size:0x00000000
fs_clk_mach_post initialized
001.487] I> 23) Base:0xf0ce0000 Size:0x00020000
gulator_post initialized
001.494] I> 24) Base:0xf6000000 Size:0x02000000
initialized
001.502] I> 25) Base:0x00000000 Size:0x00000000
7_diag initialized
001.508] I> 26) Base:0x40040000 Size:0x00006000
ermal_test initialized
001.514] I> 27) Base:0xf1800000 Size:0x00400000
rial_late initialized
001.522] I> 28) Base:0xf4c00000 Size:0x01400000
k_post initialized
001.529] I> 29) Base:0xf1400000 Size:0x00400000
k_dt_post initialized
001.535] I> 30) Base:0x00000000 Size:0x00000000
_pcie initialized
001.542] I> 31) Base:0x00000000 Size:0x00000000
[0001.549] I> 32) Base:0xf8000000 Size:0x08000000
_post initialized
001.553] I> 33) Base:0x00000000 Size:0x00000000
u_debugfs initialized
001.560] I> 34) Base:0xf3c00000 Size:0x01000000
eedo_debugfs initialized
001.567] I> 35) Base:0x00000000 Size:0x00000000
c_debugfs initialized
001.574] I> 36) Base:0xa0000000 Size:0x09000000
[0001.581] I> 37) Base:0xf2800000 Size:0x00800000
[0001.586] I> 38) Base:0x80000000 Size:0x20000000
[0001.590] I> 39) Base:0xb0000000 Size:0x08000000
[0001.595] I> 40) Base:0x00000000 Size:0x00000000
[0001.599] I> 41) Base:0x00000000 Size:0x00000000
k_debugfs initialized
001.604] I> 42) Base:0x00000000 Size:0x00000000
[0001.611] I> 43) Base:0x00000000 Size:0x00000000
[0001.615] I> 44) Base:0x00000000 Size:0x00000000
[0001.620] I> 45) Base:0x00000000 Size:0x00000000
[0001.624] GIC-SPI Target CPU: 0
[0001.627] Interrupts Init done
[0001.630] calling constructors
[0001.633] initializing heap
[0001.635] I> Heap: [0xa06872c8 … 0xa8f00000]
[0001.640] initializing threads
[0001.643] initializing timers
[0001.645] creating bootstrap completion thread
[0001.650] top of bootstrap2()
[0001.652] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.657] initializing platform
[0001.660] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.666] W> device prod register failed
[0001.669] I> Bl_dtb @0xa8f00000
[0001.672] I> gpio framework initialized
001.682] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
s_debugfs initialized
001.689] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
on_debugfs initialized
001.696] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
pg_debugfs initialized
001.708] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
ofile_fs initialized
ugfs_cons initialized
001.720] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
il_fs initialized
file initialized
001.730] W> tegrabl_tca9539_init: failed to fetch phandle from dtc_debugfs initialized
ce_debugfs initialized
001.742] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44_debugfs initialized
ctherm_debug initialized
001.755] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539_reader initialized
s initialized
_fs initialized
001.769] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539bugfs_mrq initialized
tializing target
lling apps_init()
001.781] W> tegrabl_tca9539_init: failed to fetch phandle from dtarting app shell
tering main console loop
001.793] I> fixed regulator driver initialized
001.805] I> register ‘maxim’ power off handle
[0001.806] I> virtual i2c enabled
[0001.807] I> registered ‘maxim,max20024’ pmic
[0001.811] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0001.818] I> Boot-device: eMMC
[0001.821] I> Boot_device: SDMMC_BOOT instance: 3
[0001.827] I> sdmmc-3 params source = boot args
[0001.829] I> sdmmc bdev is already initialized
[0001.834] I> sdmmc-3 params source = boot args
[0001.840] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0001.846] I> Found 36 partitions in SDMMC_BOOT (instance 3)
[0001.849] I> Load in CBoot Boot Options partition and parse it
[0001.862] E> Error -9 when finding node with path /boot-configuration
[0001.862] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0001.869] E> “plugin-manager” doesn’t exist, creating
[0001.873] E> “ids” doesn’t exist, creating
[0001.877] E> “connection” doesn’t exist, creating
[0001.882] E> “configs” doesn’t exist, creating
[0001.887] I> Find /i2c@3160000’s alias i2c0
[0001.890] I> Reading eeprom i2c=0 address=0x50
[0001.920] I> Device at /i2c@3160000:0x50
[0001.921] I> Reading eeprom i2c=0 address=0x56
[0001.921] E> I2C: slave not found in slaves.
[0001.922] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0001.923] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.923] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0001.930] E> eeprom: Failed to read I2C slave device
[0001.935] I> Eeprom read failed 0x3526070d
[0001.940] I> Find /i2c@3180000’s alias i2c2
[0001.943] I> Reading eeprom i2c=2 address=0x54
[0001.949] E> I2C: slave not found in slaves.
[0001.952] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.960] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.965] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.975] E> eeprom: Failed to read I2C slave device
[0001.979] I> Eeprom read failed 0x3526070d
[0001.983] I> Reading eeprom i2c=2 address=0x57
[0001.988] E> I2C: slave not found in slaves.
[0001.992] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.000] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.005] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0002.015] E> eeprom: Failed to read I2C slave device
[0002.019] I> Eeprom read failed 0x3526070d
[0002.023] I> Reading eeprom i2c=2 address=0x52
[0002.028] E> I2C: slave not found in slaves.
[0002.032] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.040] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.045] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0002.055] E> eeprom: Failed to read I2C slave device
[0002.060] I> Eeprom read failed 0x3526070d
[0002.064] I> Find /i2c@c240000’s alias i2c1
[0002.068] I> Reading eeprom i2c=1 address=0x52
[0002.073] E> I2C: slave not found in slaves.
[0002.076] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.084] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.089] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.099] E> eeprom: Retry to read I2C slave device.
[0002.104] E> I2C: slave not found in slaves.
[0002.108] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.116] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.121] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.131] E> eeprom: Failed to read I2C slave device
[0002.136] I> Eeprom read failed 0x3526070d
[0002.139] I> Reading eeprom i2c=1 address=0x50
[0002.144] E> I2C: slave not found in slaves.
[0002.148] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.156] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.161] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.171] E> eeprom: Retry to read I2C slave device.
[0002.176] E> I2C: slave not found in slaves.
[0002.180] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.188] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.193] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.203] E> eeprom: Failed to read I2C slave device
[0002.207] I> Eeprom read failed 0x3526070d
[0002.211] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0002.217] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.228] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0002.235] E> “i2c@3160000” doesn’t exist, creating
[0002.239] E> “module@0x50” doesn’t exist, creating
[0002.245] I> Adding plugin-manager/cvm
[0002.248] E> “chip-id” doesn’t exist, creating
[0002.252] I> Adding plugin-manager/chip-id/A02
[0002.256] I> Plugin-manager override starting
[0002.261] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.268] I> node /plugin-manager/fragement-soft-wdt matches
[0002.275] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.281] I> Disable plugin-manager status in FDT
[0002.282] I> Plugin-manager override finished successfully
[0002.295] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.299] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.299] I> hdmi cable connected
[0002.301] E> set volts not configured for ‘vdd-1v0’
[0002.305] E> set volts not configured for ‘vdd-1v8-hs’
[0002.310] E> cannot find any other nvdisp nodes
[0002.329] I> edid read success
[0002.342] I> edid read success
[0002.343] I> width = 640, height = 480, frequency = 25174825
[0002.344] I> width = 640, height = 480, frequency = 25174825
[0002.344] I> width = 1920, height = 1080, frequency = 148500000
[0002.348] I> width = 1920, height = 1080, frequency = 148500000
[0002.354] I> width = 1920, height = 1080, frequency = 148351648
[0002.360] I> width = 1280, height = 720, frequency = 74175824
[0002.365] I> width = 720, height = 480, frequency = 26973026
[0002.371] I> width = 720, height = 480, frequency = 26973026
[0002.376] I> width = 640, height = 480, frequency = 25174825
[0002.382] I> width = 1920, height = 1080, frequency = 148351648
[0002.388] I> width = 1280, height = 720, frequency = 74175824
[0002.393] I> width = 720, height = 576, frequency = 26973026
[0002.399] I> width = 720, height = 576, frequency = 26973026
[0002.404] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.415] I> hdmi_enable, starting HDMI initialisation
[0002.420] I> hdmi_enable, HDMI initialisation complete
[0002.427] initializing target
[0002.428] calling apps_init()
[0002.428] starting app kernel_boot_app
[0002.487] I> decompressor handler not found
[0002.487] I> Kernel type = Normal
[0002.488] I> Loading kernel & kernel-dtb from removable storage (5)
[0002.488] E> no regulator info present for vmmc-supply
[0002.489] W> Error: failed to get sd-card params
[0002.489] I> -0 params source =
[0002.489] W> Failed to initialize device 5-0
[0002.492] I> Loading kernel & kernel-dtb from removable storage (6)
[0002.504] W> No valid slot number is found in scratch register
[0002.504] W> Return default slot: _a
[0002.509] I> USB Firmware Version: 60.05 release
[0002.964] E> failed to initialize xhci controller
[0002.964] E> Error in init of XUSB host driver, err: 79790026
[0002.965] W> Failed to initialize device 6-0
[0002.965] I> Loading kernel/boot.img from built-in storage …
[0002.965] W> No valid slot number is found in scratch register
[0002.966] W> Return default slot: _a
[0002.968] I> A/B: bin_type (37) slot 0
[0002.971] I> Loading partition kernel at 0xa1930000 from device(0x1)
[0003.353] I> T19x: Authenticate kernel (bin_type: 37), max size 0x4000000
[0003.687] W> No valid slot number is found in scratch register
[0003.687] W> Return default slot: _a
[0003.687] I> A/B: bin_type (38) slot 0
[0003.688] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0003.692] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x80000
[0003.695] I> Kernel hdr @0xa1930000
[0003.695] I> Kernel dtb @0x91000000
[0003.696] I> Checking boot.img header magic … [0003.699] I> [OK]
[0003.700] I> Valid boot.img @ 0xa1930000
[0003.704] I> decompressor handler not found
[0003.708] I> Copying kernel image (33792008 bytes) from 0xa1930800 to 0x80080000 … [0003.729] I> Done
[0003.729] I> Move ramdisk (len: 0) from 0xa396b000 to 0x92000000
[0003.731] I> Updated bpmp info to DTB
[0003.732] I> Ramdisk: Base: 0x92000000; Size: 0x0
[0003.732] I> Updated initrd info to DTB
[0003.735] W> WARN: Fail to override “console=none” in commandline
[0003.741] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.748] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.756] W> No valid slot number is found in scratch register
[0003.761] W> Return default slot: _a
[0003.765] I> Active slot suffix:
[0003.768] I> add_boot_slot_suffix: slot_suffix =
[0003.772] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 OS=l4t video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0791000 lut_mem=0x2008@0xa068d000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 sdhci_tegra.en_boot_part_access=1
[0003.809] I> Updated bootarg info to DTB
[0003.813] W> MAC addr invalid!
[0003.816] E> Failed to get WIFI MAC address
[0003.820] W> MAC addr invalid!
[0003.823] E> Failed to get Bluetooth MAC address
[0003.827] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:e0:5d
[0003.834] E> “plugin-manager” doesn’t exist, creating
[0003.839] I> Adding /chosen/plugin-manager/cvm
[0003.843] E> “chip-id” doesn’t exist, creating
[0003.847] I> Adding /chosen/plugin-manager/chip-id
[0003.852] E> “configs” doesn’t exist, creating
[0003.856] I> Adding /chosen/plugin-manager/configs
[0003.860] E> “ids” doesn’t exist, creating
[0003.864] I> Adding /chosen/plugin-manager/ids
[0003.869] E> “odm-data” doesn’t exist, creating
[0003.873] I> Adding /chosen/plugin-manager/odm-data
[0003.881] E> “memory” doesn’t exist, creating
[0003.882] I> [0] START: 0x80000000, END: 0xaa000000
[0003.887] I> [1] START: 0xaa004000, END: 0xf0cd0000
[0003.891] I> [2] START: 0xf0cdc000, END: 0xf0ce0000
[0003.896] I> dram_block larger than 80000000
[0003.900] I> [3] START: 0x100000000, END: 0x480000000
[0003.905] I> added [base:0x80000000, size:0x2a000000] to /memory
[0003.911] I> added [base:0xaa200000, size:0x46a00000] to /memory
[0003.917] I> added [base:0x100000000, size:0x380000000] to /memory
[0003.923] I> Updated memory info to DTB
[0003.927] E> “reset” doesn’t exist, creating
[0003.931] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0003.936] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0003.940] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0003.945] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0003.950] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0003.954] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0003.959] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0003.964] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0003.969] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0003.974] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0003.978] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0003.983] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0003.988] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0003.993] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0003.998] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0004.002] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0004.008] E> “misc-data” doesn’t exist, creating
[0004.012] I> Boot-device: eMMC
[0004.015] I> Add boot-sdmmc to plugin-manager/misc-data
[0004.020] I> Add storage-sdmmc to plugin-manager/misc-data
[0004.025] W> Unknown storage device
[0004.028] I> Add serial number as DT property
[0004.034] I> Plugin-manager override starting
[0004.037] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0004.044] I> node /plugin-manager/fragement-soft-wdt matches
[0004.051] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0004.057] I> Disable plugin-manager status in FDT
[0004.058] I> Plugin-manager override finished successfully
[0004.087] I> Filling next stage params: ep: 0x80080000, dtb: 0x91000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (root@shqli) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #210 SMP PREEMPT Wed Apr 1 12:00:40 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2a000000
[ 0.000000] OF: fdt: - aa200000 , 46a00000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a0791000
[ 0.000000] Found lut_mem: 00002008@a068d000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000ec800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffe19000 s53400 r8192 d32616 u94208
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4066272
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 OS=l4t video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0791000 lut_mem=0x2008@0xa068d000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29140(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 16126648K/16523264K available (14974K kernel code, 2856K rwdata, 6576K rodata, 8512K init, 607K bss, 331080K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f20000 ( 14976 KB)
[ 0.000000] .rodata : 0xffffff8008f20000 - 0xffffff80095a0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095a0000 - 0xffffff8009df0000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009df0000 - 0xffffff800a0ba008 ( 2857 KB)
[ 0.000000] .bss : 0xffffff800a0ba008 - 0xffffff800a151e54 ( 608 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000010] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008985] Console: colour dummy device 80x25
[ 0.012688] console [tty0] enabled
[ 0.016171] bootconsole [tegra_comb_uart0] disabled
[ 0.021283] kmemleak: Kernel memory leak detector disabled
[ 0.021382] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.021429] pid_max: default: 32768 minimum: 301
[ 0.022818] Security Framework initialized
[ 0.023608] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023660] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.026213] ftrace: allocating 46635 entries in 183 pages
[ 0.485377] sched-energy: Sched-energy-costs installed from DT
[ 0.485577] ASID allocator initialised with 65536 entries
[ 0.525536] tegra-id: chipid=21917.
[ 0.525579] tegra-id: opt_subrevision=0.
[ 0.525627] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.525726] DTS File Name: /home/shqli/shqli/code/nvidia/agxos/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.525800] DTB Build time: Apr 1 2020 11:58:49
[ 0.575508] CPU1: Booted secondary processor [4e0f0040]
[ 0.607740] CPU2: Booted secondary processor [4e0f0040]
[ 0.640058] CPU3: Booted secondary processor [4e0f0040]
[ 0.672381] CPU4: Booted secondary processor [4e0f0040]
[ 0.704761] CPU5: Booted secondary processor [4e0f0040]
[ 0.737366] CPU6: Booted secondary processor [4e0f0040]
[ 0.769380] CPU7: Booted secondary processor [4e0f0040]
[ 0.770426] Brought up 8 CPUs
[ 0.770815] SMP: Total of 8 processors activated.
[ 0.770856] CPU features: detected feature: Privileged Access Never
[ 0.770893] CPU features: detected feature: LSE atomic instructions
[ 0.770931] CPU features: detected feature: User Access Override
[ 0.770967] CPU features: detected feature: 32-bit EL0 Support
[ 0.776275] CPU: All CPU(s) started at EL2
[ 0.776490] alternatives: patching kernel code
[ 0.791952] devtmpfs: initialized
[ 0.853560] Initilizing CustomIPI irq domain
[ 0.854325] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.854406] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.856300] pinctrl core: initialized pinctrl subsystem
[ 0.856562] OS set in device tree is not L4T.
[ 0.856911] regulator-dummy: no parameters
[ 0.857252] Initializing plugin-manager
[ 0.857343] Plugin module not found
[ 0.857409] Plugin-manager status disabled
[ 0.858730] NET: Registered protocol family 16
[ 0.865913] pstore: using zlib compression
[ 0.867207] console [pstore-1] enabled
[ 0.867253] pstore: Registered ramoops as persistent store backend
[ 0.867303] ramoops: attached 0x200000@0xf0a00000, ecc: 0/0
[ 0.886428] cpuidle: using governor menu
[ 0.887767] bpmp: waiting for handshake
[ 0.887832] bpmp: handshake completed
[ 0.887917] bpmp: synchronizing channels
[ 0.888035] bpmp: channels synchronized
[ 0.888074] bpmp: mail init ok
[ 0.892204] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.892656] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.892716] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.892761] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.892808] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.892853] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.892901] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.892972] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.893044] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.893096] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.893146] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.897658] vdso: 2 pages (1 code @ ffffff8008f27000, 1 data @ ffffff8009df4000)
[ 0.898154] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.902684] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.903711] Registering BPMP clocks…
[ 0.903885] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.904288] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.904802] tegra_powergate_init: DONE
[ 0.904995] DTS File Name: /home/shqli/shqli/code/nvidia/agxos/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.905121] DTB Build time: Apr 1 2020 11:58:49
[ 0.908776] Tegra reboot handler registered.
[ 0.919149] iommu: Adding device 14180000.pcie to group 0
[ 0.920095] iommu: Adding device 14100000.pcie to group 1
[ 0.920989] iommu: Adding device 14140000.pcie to group 2
[ 0.921858] iommu: Adding device 141a0000.pcie to group 3
[ 0.923761] iommu: Adding device 2490000.ether_qos to group 4
[ 0.924560] iommu: Adding device 3100000.serial to group 5
[ 0.925451] iommu: Adding device 3110000.serial to group 6
[ 0.926112] iommu: Adding device 3140000.serial to group 7
[ 0.927033] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.927329] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.927412] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.927461] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.927508] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.927618] tegra-pmc: PMC Prod config success
[ 0.927925] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.928008] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.928730] iommu: Adding device 3460000.sdhci to group 8
[ 0.929517] iommu: Adding device 3400000.sdhci to group 9
[ 0.930821] iommu: Adding device 3160000.i2c to group 10
[ 0.931445] iommu: Adding device c240000.i2c to group 11
[ 0.931998] iommu: Adding device 3180000.i2c to group 12
[ 0.932606] iommu: Adding device 3190000.i2c to group 13
[ 0.933320] iommu: Adding device 31b0000.i2c to group 14
[ 0.933936] iommu: Adding device 31c0000.i2c to group 15
[ 0.934512] iommu: Adding device c250000.i2c to group 16
[ 0.935120] iommu: Adding device 31e0000.i2c to group 17
[ 0.936590] iommu: Adding device 3510000.hda to group 18
[ 0.937382] iommu: Adding device bc00000.rtcpu to group 19
[ 0.940343] iommu: Adding device 13e10000.host1x to group 20
[ 0.940943] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.941592] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.942194] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.942746] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.943380] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.943925] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.944538] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.945090] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.945855] iommu: Adding device 15340000.vic to group 29
[ 0.946428] iommu: Adding device 15380000.nvjpg to group 30
[ 0.946912] iommu: Adding device 15500000.tsec to group 31
[ 0.947322] iommu: Adding device 15100000.tsecb to group 32
[ 0.947783] iommu: Adding device 15480000.nvdec to group 33
[ 0.948192] iommu: Adding device 15140000.nvdec1 to group 34
[ 0.948617] iommu: Adding device 154c0000.nvenc to group 35
[ 0.949156] iommu: Adding device 15a80000.nvenc1 to group 36
[ 0.949783] iommu: Adding device 15880000.nvdla0 to group 37
[ 0.950459] iommu: Adding device 158c0000.nvdla1 to group 38
[ 0.951334] iommu: Adding device 15200000.nvdisplay to group 39
[ 0.951701] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0791000(800000)
[ 0.951784] platform 15200000.nvdisplay: IOVA linear map 0x00000000a068d000(3000)
[ 0.951846] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.954268] iommu: Adding device 15c10000.vi to group 40
[ 0.954532] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.955189] iommu: Adding device 14800000.isp to group 41
[ 0.956532] iommu: Adding device 16000000.pva0 to group 42
[ 0.957345] iommu: Adding device 16800000.pva1 to group 43
[ 0.957952] iommu: Adding device 15810000.se to group 44
[ 0.958634] iommu: Adding device 15820000.se to group 45
[ 0.959118] iommu: Adding device 15830000.se to group 46
[ 0.959565] iommu: Adding device 15840000.se to group 47
[ 0.959982] iommu: Adding device c1a0000.aon to group 48
[ 0.962204] iommu: Adding device d000000.bpmp to group 49
[ 0.962670] bpmp: ping status is 0
[ 0.962864] bpmp d000000.bpmp: firmware tag is 588c62054ecdba8a44cb9d6ff5d04cb0
[ 0.966750] bpmp d000000.bpmp: probe ok
[ 0.969207] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 0.969864] iommu: Adding device smmu_test to group 50
[ 0.971367] mc: mapped MMIO address: 0xffffff800a510000 → 0x2c10000
[ 0.971454] mc: mapped MMIO address: 0xffffff800a530000 → 0x2c20000
[ 0.971529] mc: mapped MMIO address: 0xffffff800a550000 → 0x2c30000
[ 0.971601] mc: mapped MMIO address: 0xffffff800a570000 → 0x2c40000
[ 0.971671] mc: mapped MMIO address: 0xffffff800a590000 → 0x2c50000
[ 0.971743] mc: mapped MMIO address: 0xffffff800a5b0000 → 0x2b80000
[ 0.971813] mc: mapped MMIO address: 0xffffff800a5d0000 → 0x2b90000
[ 0.971883] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2ba0000
[ 0.971952] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2bb0000
[ 0.972034] mc: mapped MMIO address: 0xffffff800b010000 → 0x1700000
[ 0.972140] mc: mapped MMIO address: 0xffffff800b030000 → 0x1710000
[ 0.972214] mc: mapped MMIO address: 0xffffff800b050000 → 0x1720000
[ 0.972291] mc: mapped MMIO address: 0xffffff800b070000 → 0x1730000
[ 0.972361] mc: mapped MMIO address: 0xffffff800b090000 → 0x1740000
[ 0.972431] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1750000
[ 0.972502] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1760000
[ 0.972573] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1770000
[ 0.972714] mc-err: mcerr ops are set to t19x
[ 0.982461] iommu: Adding device 2600000.dma to group 51
[ 0.990290] GPIO line 347 (camera-control-output-low) hogged as output/low
[ 0.990444] GPIO line 350 (camera-control-output-low) hogged as output/low
[ 0.990542] GPIO line 446 (camera-control-output-low) hogged as output/low
[ 0.990631] GPIO line 445 (camera-control-output-low) hogged as output/low
[ 0.990726] GPIO line 481 (camera-control-output-low) hogged as output/low
[ 0.991391] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.001265] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.004923] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.004984] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.006235] iommu: Adding device 3550000.xudc to group 52
[ 1.007222] iommu: Adding device 3610000.xhci to group 53
[ 1.010666] arm64_ras arm64_ras: probed
[ 1.011677] ras_fhi_enable: FHI 471 enabled on CPU0
[ 1.011783] ras_fhi_enable: FHI 472 enabled on CPU1
[ 1.011934] ras_fhi_enable: FHI 473 enabled on CPU2
[ 1.012054] ras_fhi_enable: FHI 474 enabled on CPU3
[ 1.012164] ras_fhi_enable: FHI 475 enabled on CPU4
[ 1.012289] ras_fhi_enable: FHI 476 enabled on CPU5
[ 1.012410] ras_fhi_enable: FHI 477 enabled on CPU6
[ 1.012609] ras_fhi_enable: FHI 478 enabled on CPU7
[ 1.012935] carmel_ras_enable: RAS enabled on cpu0
[ 1.013277] carmel_ras_enable: RAS enabled on cpu1
[ 1.013600] carmel_ras_enable: RAS enabled on cpu2
[ 1.013905] carmel_ras_enable: RAS enabled on cpu3
[ 1.014224] carmel_ras_enable: RAS enabled on cpu4
[ 1.014480] carmel_ras_enable: RAS enabled on cpu5
[ 1.014745] carmel_ras_enable: RAS enabled on cpu6
[ 1.015203] carmel_ras_enable: RAS enabled on cpu7
[ 1.015393] carmel_ras carmel_ras: probed
[ 1.017248] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 1.018082] tegra-cbb c600000.aon-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 1.019360] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 1.020619] tegra-cbb be00000.rce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.021893] tegra-cbb b600000.sce-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.022567] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.026489] vdd-3v3-cvb: 3300 mV
[ 1.027062] vdd-1v8-cvb: 1800 mV
[ 1.027834] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.027948] vdd-epb-1v0: 1000 mV
[ 1.028420] vdd-sata-1v5: 1500 mV
[ 1.029062] vdd-1v8-slt: 1800 mV
[ 1.029561] vdd-3v3-slt: 3300 mV
[ 1.030166] vdd-fan: 5000 mV
[ 1.031016] vdd-hdmi-5v0: 5000 mV
[ 1.031837] vdd-5v-sata: 5000 mV
[ 1.032786] vdd-ac-bat: 5000 mV
[ 1.033154] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.075492] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.081730] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.082361] SCSI subsystem initialized
[ 1.083205] usbcore: registered new interface driver usbfs
[ 1.083368] usbcore: registered new interface driver hub
[ 1.083592] usbcore: registered new device driver usb
[ 1.084116] tegra_i2c_probe pdev:3160000.i2c id=-1,membase:0x0000000003160000
[ 1.086620] tegra_i2c_probe register i2c-bus-0 successfully.
[ 1.086882] tegra_i2c_probe pdev:c240000.i2c id=-1,membase:0x000000000c240000
[ 1.089233] tegra_i2c_probe register i2c-bus-1 successfully.
[ 1.089430] tegra_i2c_probe pdev:3180000.i2c id=-1,membase:0x0000000003180000
[ 1.091112] tegra_i2c_probe register i2c-bus-2 successfully.
[ 1.091266] tegra-i2c 3190000.i2c: could not find pctldev for node /host1x/dpaux@155D0000/pinmux@0, deferring probe
[ 1.091439] tegra_i2c_probe pdev:31b0000.i2c id=-1,membase:0x00000000031b0000
[ 1.092927] tegra_i2c_probe register i2c-bus-5 successfully.
[ 1.093083] tegra-i2c 31c0000.i2c: could not find pctldev for node /host1x/dpaux@155E0000/pinmux@0, deferring probe
[ 1.093294] tegra_i2c_probe pdev:c250000.i2c id=-1,membase:0x000000000c250000
[ 1.095683] tegra_i2c_probe register i2c-bus-7 successfully.
[ 1.095826] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.099480] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.108519] vdd-1v0: at 1000 mV
[ 1.112583] vdd-1v8-hs: at 1800 mV
[ 1.116606] vdd-1v8-ls: at 1800 mV
[ 1.120664] vdd-1v8-ao: at 1800 mV
[ 1.124725] vddio-ddr-1v1: at 1100 mV
[ 1.128520] vdd-rtc: at 800 mV
[ 1.129987] spmic-ldo1: at 2375 mV
[ 1.136601] vdd-ao-3v3: at 3300 mV
[ 1.144691] vddio-emmc-3v3: at 3300 mV
[ 1.146530] spmic-ldo4: at 1587 mV
[ 1.152771] vdd-usb-3v3: at 3300 mV
[ 1.160839] vddio-sdmmc1-3v3: at 3300 mV
[ 1.164882] vdd-csi-1v2: at 1200 mV
[ 1.167135] spmic-ldo8: at 1800 mV
[ 1.169842] GPIO line 246 (gpio_default) hogged as output/high
[ 1.171360] GPIO line 247 (gpio_default) hogged as output/high
[ 1.172040] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.176249] max77620 4-003c: max77620 probe successful
[ 1.177031] media: Linux media interface: v0.10
[ 1.177154] Linux video capture interface: v2.00
[ 1.178945] pps_core: LinuxPPS API ver. 1 registered
[ 1.178991] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.179127] PTP clock support registered
[ 1.179889] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.180012] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.181662] tegra_fiq_debugger_init: found FIQ source (IRQ 463)
[ 1.183547] Advanced Linux Sound Architecture Driver Initialized.
[ 1.184361] Bluetooth: Core ver 2.22
[ 1.184444] NET: Registered protocol family 31
[ 1.184478] Bluetooth: HCI device and connection manager initialized
[ 1.184535] Bluetooth: HCI socket layer initialized
[ 1.184583] Bluetooth: L2CAP socket layer initialized
[ 1.184664] Bluetooth: SCO socket layer initialized
[ 1.187784] camchar: rtcpu character device driver loaded
[ 1.189423] clocksource: Switched to clocksource arch_sys_counter
[ 1.244731] VFS: Disk quotas dquot_6.6.0
[ 1.244951] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.245728] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.247827] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.247979] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.248032] nvmap_page_pool_init: Total RAM pages: 4048046
[ 1.248109] nvmap_page_pool_init: nvmap page pool size: 506005 pages (1976 MB)
[ 1.248421] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.251292] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.268051] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.268454] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.269027] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.269435] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.270205] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.270563] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.270774] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.272218] la/ptsa driver initialized.
[ 1.272719] NET: Registered protocol family 2
[ 1.273906] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.274767] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.275660] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.275748] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.276093] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.276821] NET: Registered protocol family 1
[ 1.277963] RPC: Registered named UNIX socket transport module.
[ 1.278009] RPC: Registered udp transport module.
[ 1.278042] RPC: Registered tcp transport module.
[ 1.278075] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.278388] Trying to unpack rootfs image as initramfs…
[ 1.307073] host1x 13e10000.host1x: initialized
[ 1.310366] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.317271] audit: initializing netlink subsys (disabled)
[ 1.317401] audit: type=2000 audit(0.884:1): initialized
[ 1.318790] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.332907] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.334817] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.335653] 9p: Installing v9fs 9p2000 file system support
[ 1.343123] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.343383] io scheduler noop registered
[ 1.343729] io scheduler cfq registered (default)
[ 1.348215] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.388453] iommu: Adding device 2993000.adsp to group 54
[ 1.490766] iommu: Adding device aconnect@2a41000:adsp_audio to group 55
[ 1.492046] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.510654] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.511405] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.512028] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.516434] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.517038] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.517098] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1920000, vi_iso_bw=7200000, max_bw=7200000
[ 1.521205] tsec 15500000.tsec: initialized
[ 1.523885] tsec 15100000.tsecb: initialized
[ 1.529761] nvdec 15480000.nvdec: initialized
[ 1.533546] nvdec 15140000.nvdec1: initialized
[ 1.539542] falcon 15340000.vic: initialized
[ 1.542135] falcon 15380000.nvjpg: initialized
[ 1.544617] falcon 154c0000.nvenc: initialized
[ 1.547241] falcon 15a80000.nvenc1: initialized
[ 1.550644] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.553319] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.555975] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.558771] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.561588] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.563532] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.565503] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.567694] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.568979] t194-nvcsi 15a00000.nvcsi: mem:start:0x15a00000 end:0x15a4ffff
[ 1.569048] t194-nvcsi 15a00000.nvcsi: irq:80
[ 1.572730] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.573139] t194-nvcsi 15a00000.nvcsi: nvcsi channel:4
[ 1.579218] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.579883] scare-pigeon 14b00000.isp-thi: initialized
[ 1.591003] pva 16000000.pva0: initialized
[ 1.624513] pva 16800000.pva1: initialized
[ 1.656102] nvdla 15880000.nvdla0: initialized
[ 1.687941] nvdla 158c0000.nvdla1: initialized
[ 1.689982] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.690043] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.690131] tegradccommon 15200000.dc_common: dma mapping done
[ 1.691152] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor
[ 1.691274] generic_infoframe_type: 0x87
[ 1.691477] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.691610] tegradc 15200000.nvdisplay: Display dc.ffffff800bc90000 registered with id=0
[ 1.698654] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.698716] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.698765] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.699244] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.699307] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.702923] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.702981] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.704022] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.704903] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.705455] kfuse 3830000.kfuse: initialized
[ 1.714586] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.718307] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.719912] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.721474] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 1.736661] Reserved SVD code 0
[ 1.736666] Reserved SVD code 0
[ 1.736668] Reserved SVD code 0
[ 1.741279] tegradc 15200000.nvdisplay: probed
[ 4.215333] console [ttyTCU0] enabled
[ 4.216020] [drm] Initialized
[ 4.216537] Console: switching to colour frame buffer device 240x67
[ 4.227847] tegradc 15200000.nvdisplay: fb registered
[ 4.233570] gpio tegra-gpio wake60 for gpio=96(M:0)
[ 4.239265] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.244122] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.250726] brd: module loaded
[ 4.261628] loop: module loaded
[ 4.261879] tegra_profiler: version: 1.132, samples/io: 46/26
[ 4.262269] tegra_profiler: auth: init
[ 4.265072] Parent Clock set for DC pll_d
[ 4.270373] nct1008_nct72 4-004c: starting parse dt
[ 4.270960] THERMAL EST: found 3 subdevs
[ 4.270965] THERMAL EST num_resources: 0
[ 4.270978] [THERMAL EST subdev 0]
[ 4.270983] [THERMAL EST subdev 1]
[ 4.270987] [THERMAL EST subdev 2]
[ 4.271496] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.271499] THERMAL EST: thz register success.
[ 4.271750] THERMAL EST: end of probe, return err: 0
[ 4.272769] hisi_sas: driver version v1.6
[ 4.276121] libphy: Fixed MDIO Bus: probed
[ 4.276843] tun: Universal TUN/TAP device driver, 1.6
[ 4.276846] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.277715] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.277718] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.277800] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.277802] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.277951] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.277953] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.278009] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.278012] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.279547] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.283916] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb e0 5d
[ 4.284053] libphy: dwc_phy: probed
[ 4.287050] PPP generic driver version 2.4.2
[ 4.289136] PPP BSD Compression module registered
[ 4.289142] PPP Deflate Compression module registered
[ 4.289160] PPP MPPE Compression module registered
[ 4.289164] NET: Registered protocol family 24
[ 4.289230] usbcore: registered new interface driver r8152
[ 4.289281] usbcore: registered new interface driver asix
[ 4.289359] usbcore: registered new interface driver ax88179_178a
[ 4.289400] usbcore: registered new interface driver cdc_ether
[ 4.289438] usbcore: registered new interface driver net1080
[ 4.289474] usbcore: registered new interface driver cdc_subset
[ 4.289512] usbcore: registered new interface driver zaurus
[ 4.289584] usbcore: registered new interface driver cdc_ncm
[ 4.289943] VFIO - User Level meta-driver version: 0.3
[ 4.294559] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.294580] ehci-pci: EHCI PCI platform driver
[ 4.294643] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.294655] ohci-pci: OHCI PCI platform driver
[ 4.294708] ohci-platform: OHCI generic platform driver
[ 4.303385] tegra-xusb 3610000.xhci: No USB pRNING: pll_d has no dyn ramp
t has OTG_CAP
[ 4.306985] tegra-xusb 3610000.xhci: Direct firmware load for tegra19x_xusb_firmware failed with error -2
[ 4.306991] tegra-xusb 3610000.xhci: Falling back to user helper
[ 4.307452] usbcore: registered new interface driver uas
[ 4.307554] usbcore: registered new interface driver usb-storage
[ 4.307772] usbcore: registered new interface driver usbserial
[ 4.311476] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.311516] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 4.312313] mousedev: PS/2 mouse device common for all mice
[ 4.312390] usbcore: registered new interface driver xpad
[ 4.344624] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 4.346271] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 4.346281] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.350042] extcon-disp-state external-connection:disp-state: cable 46 state 1
[ 4.350045] Extcon AUX0(HDMI) enable
[ 4.436398] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.438612] Wake73 for irq=42
[ 4.440070] rtc rtc1: alarm rtc device
[ 4.440125] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.440155] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.440314] i2c /dev entries driver
[ 4.442634] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 4.447839] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.448200] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
[ 4.451257] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 4.506157] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 4.506208] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 4.506213] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 4.506482] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 4.506651] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 4.506656] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 4.507102] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 4.507167] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 4.507172] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 4.507770] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 4.507877] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 4.507882] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 4.508343] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 4.508405] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 4.508410] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 4.508753] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 4.509545] FAN dev name: pwm-fan
[ 4.509613] FAN:gpio request success.
[ 4.509623] FAN: can’t find tach_gpio
[ 4.509664] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.510020] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 4.510026] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.510494] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.510531] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 4.510537] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.510541] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.510546] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.510551] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.510555] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.510560] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.510565] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.510570] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.511642] device-mapper: uevent: version 1.0.3
[ 4.512346] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.522234] Reserved SVD code 0
[ 4.522236] Reserved SVD code 0
[ 4.522237] Reserved SVD code 0
[ 4.525243] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.530189] cpuidle: Initializing cpuidle driver
[ 4.542720] sdhci: Secure Digital Host Controller Interface driver
[ 4.542721] sdhci: Copyright(c) Pierre Ossman
[ 4.542722] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.543859] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.545677] CMDQ: cmdq_platfm_init successful
[ 4.546109] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.547561] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.549480] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 193
[ 4.553246] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.554180] tegra-se-nvhost 15810000.se: initialized
[ 4.555141] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.555884] tegra-se-nvhost 15820000.se: initialized
[ 4.556980] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.557940] tegra-se-nvhost 15830000.se: initialized
[ 4.558578] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.559534] tegra-se-nvhost 15840000.se: initialized
[ 4.560359] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.560605] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.561780] usbcore: registered new interface driver usbhid
[ 4.561782] usbhid: USB HID core driver
[ 4.567450] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.568492] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.568907] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.569385] denver_knobs_init:MTS_VERSION:43306594
[ 4.569539] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 4.570225] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.570569] t19x_cache tegra-cache: probed
[ 4.576717] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.576729] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.597361] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.597871] nvpmodel: initialized successfully
[ 4.598958] tegra-hda 3510000.hda: Override SDO lines to 4
[ 4.599261] usbcore: registered new interface driver snd-usb-audio
[ 4.605541] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.618498] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.618648] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.618791] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 4.618928] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 4.687168] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 4.698884] mmc0: periodic cache flush enabled
[ 4.698895] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.699404] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 4.699617] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 4.699815] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 4.700021] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 4.702828] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36
[ 4.950045] rt5659 7-001a: Device with ID register ffffffc3 is not rt5659
[ 5.038404] OPE platform probe
[ 5.038537] OPE platform probe successful
[ 5.049075] u32 classifier
[ 5.049076] Actions configured
[ 5.049152] Initializing XFRM netlink socket
[ 5.049768] NET: Registered protocol family 10
[ 5.050506] NET: Registered protocol family 17
[ 5.050515] NET: Registered protocol family 15
[ 5.050571] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.050655] Bluetooth: RFCOMM socket layer initialized
[ 5.050663] Bluetooth: RFCOMM ver 1.11
[ 5.050666] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.050689] Bluetooth: HIDP socket layer initialized
[ 5.050710] 9pnet: Installing 9P2000 support
[ 5.050740] Key type dns_resolver registered
[ 5.050959] Registered cp15_barrier emulation handler
[ 5.058639] Registered setend emulation handler
[ 5.060859] registered taskstats version 1
[ 5.061268] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 5.062327] OF: PCI: host bridge /pcie@14180000 ranges:
[ 5.062353] OF: PCI: IO 0x38100000…0x381fffff → 0x38100000
[ 5.062367] OF: PCI: MEM 0x38200000…0x39ffffff → 0x38200000
[ 5.062371] OF: PCI: MEM 0x1800000000…0x1bffffffff → 0x1800000000
[ 5.357109] tegradc 15200000.nvdisplay: blank - powerdown
[ 5.357179] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 5.357186] nct1008_nct72 4-004c: success parsing dt
[ 5.357284] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 5.391424] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 5.392864] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 5.393445] extcon-disp-state external-connection:disp-state: cable 46 state 0
[ 5.393446] Extcon AUX0(HDMI) disable
[ 5.416174] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 5.416677] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 5.426788] nct1008_nct72 4-004c: initial LOC temp: 39000
[ 5.426803] tegradc 15200000.nvdisplay: unblank
[ 5.427609] nct1008_nct72 4-004c: initial EXT temp: 53250
[ 5.427852] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 5.428115] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 5.429071] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 5.430544] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 5.430789] Parent Clock set for DC pll_d
[ 5.439392] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 5.440717] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 5.440727] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 5.444295] extcon-disp-state external-connection:disp-state: cable 46 state 1
[ 5.444296] Extcon AUX0(HDMI) enable
[ 5.568992] tegra-pcie-dw 14180000.pcie: link is down
[ 5.569235] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 5.569241] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 5.569247] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 5.569250] pci_bus 0000:00: root bus resource [mem 0x38200000-0x39ffffff]
[ 5.569252] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1bffffffff pref]
[ 5.569779] iommu: Adding device 0000:00:00.0 to group 56
[ 5.570059] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 5.570085] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.570357] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.570836] iommu: Removing device 0000:00:00.0 from group 56
[ 5.571139] tegra-pcie-dw 14180000.pcie: PCIe link is not up…!
[ 5.572272] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 5.573671] OF: PCI: host bridge /pcie@14100000 ranges:
[ 5.573695] OF: PCI: IO 0x30100000…0x301fffff → 0x30100000
[ 5.573728] OF: PCI: MEM 0x30200000…0x31ffffff → 0x30200000
[ 5.573732] OF: PCI: MEM 0x1200000000…0x123fffffff → 0x1200000000
[ 6.085281] tegra-pcie-dw 14100000.pcie: link is down
[ 6.085577] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.085583] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.085589] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 6.085591] pci_bus 0001:00: root bus resource [mem 0x30200000-0x31ffffff]
[ 6.085593] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x123fffffff pref]
[ 6.086045] iommu: Adding device 0001:00:00.0 to group 56
[ 6.086363] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.086396] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.086723] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.087289] iommu: Removing device 0001:00:00.0 from group 56
[ 6.087642] tegra-pcie-dw 14100000.pcie: PCIe link is not up…!
[ 6.088132] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 6.089132] OF: PCI: host bridge /pcie@14140000 ranges:
[ 6.089150] OF: PCI: IO 0x34100000…0x341fffff → 0x34100000
[ 6.089156] OF: PCI: MEM 0x34200000…0x35ffffff → 0x34200000
[ 6.089159] OF: PCI: MEM 0x1280000000…0x12bfffffff → 0x1280000000
[ 6.600892] tegra-pcie-dw 14140000.pcie: link is down
[ 6.601132] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 6.601159] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 6.601165] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 6.601168] pci_bus 0003:00: root bus resource [mem 0x34200000-0x35ffffff]
[ 6.601170] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12bfffffff pref]
[ 6.601674] iommu: Adding device 0003:00:00.0 to group 56
[ 6.602030] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 6.602051] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.602317] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.602874] iommu: Removing device 0003:00:00.0 from group 56
[ 6.603135] tegra-pcie-dw 14140000.pcie: PCIe link is not up…!
[ 6.603756] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 6.604841] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 6.604855] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 6.604861] OF: PCI: MEM 0x3a200000…0x3bffffff → 0x3a200000
[ 6.604868] OF: PCI: MEM 0x1c00000000…0x1fffffffff → 0x1c00000000
[ 6.713389] tegra-pcie-dw 141a0000.pcie: link is up
[ 6.713624] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 6.713629] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 6.713634] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 6.713636] pci_bus 0005:00: root bus resource [mem 0x3a200000-0x3bffffff]
[ 6.713639] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1fffffffff pref]
[ 6.713999] iommu: Adding device 0005:00:00.0 to group 56
[ 6.715460] pci 0005:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x000fffff 64bit pref] (contains BAR0 for 64 VFs)
[ 6.715574] pci 0005:01:00.0: VF(n) BAR3 space: [mem 0x00000000-0x000fffff 64bit pref] (contains BAR3 for 64 VFs)
[ 6.717422] iommu: Adding device 0005:01:00.0 to group 57
[ 6.718642] pci 0005:01:00.1: VF(n) BAR0 space: [mem 0x00000000-0x000fffff 64bit pref] (contains BAR0 for 64 VFs)
[ 6.718756] pci 0005:01:00.1: VF(n) BAR3 space: [mem 0x00000000-0x000fffff 64bit pref] (contains BAR3 for 64 VFs)
[ 6.720563] iommu: Adding device 0005:01:00.1 to group 58
[ 6.730377] pci 0005:00:00.0: BAR 14: assigned [mem 0x3a200000-0x3a2fffff]
[ 6.730396] pci 0005:00:00.0: BAR 15: assigned [mem 0x1c00000000-0x1c003fffff 64bit pref]
[ 6.730399] pci 0005:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 6.730424] pci 0005:01:00.0: BAR 0: assigned [mem 0x3a200000-0x3a21ffff 64bit]
[ 6.730482] pci 0005:01:00.1: BAR 0: assigned [mem 0x3a220000-0x3a23ffff 64bit]
[ 6.730554] pci 0005:01:00.0: BAR 4: assigned [mem 0x3a240000-0x3a243fff 64bit]
[ 6.730611] pci 0005:01:00.0: BAR 7: assigned [mem 0x1c00000000-0x1c000fffff 64bit pref]
[ 6.730637] pci 0005:01:00.0: BAR 10: assigned [mem 0x1c00100000-0x1c001fffff 64bit pref]
[ 6.730664] pci 0005:01:00.1: BAR 4: assigned [mem 0x3a244000-0x3a247fff 64bit]
[ 6.730721] pci 0005:01:00.1: BAR 7: assigned [mem 0x1c00200000-0x1c002fffff 64bit pref]
[ 6.730747] pci 0005:01:00.1: BAR 10: assigned [mem 0x1c00300000-0x1c003fffff 64bit pref]
[ 6.730772] pci 0005:01:00.0: BAR 2: assigned [io 0x300000-0x30001f]
[ 6.730790] pci 0005:01:00.1: BAR 2: assigned [io 0x300020-0x30003f]
[ 6.730810] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 6.730813] pci 0005:00:00.0: bridge window [io 0x300000-0x300fff]
[ 6.730818] pci 0005:00:00.0: bridge window [mem 0x3a200000-0x3a2fffff]
[ 6.730822] pci 0005:00:00.0: bridge window [mem 0x1c00000000-0x1c003fffff 64bit pref]
[ 6.730834] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.730875] pci 0005:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.730916] pci 0005:01:00.1: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.731175] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.731177] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.731179] pci 0005:01:00.1: Signaling PME through PCIe PME interrupt
[ 6.731529] ixgbe 0005:01:00.0: enabling device (0000 → 0002)
[ 6.731688] pcie device [0x00000000] hardaddr: 0x000000003a200000 len:131072 virtaddr:0xffffff8011360000
[ 6.904169] ixgbe 0005:01:00.0: PCI Express bandwidth of 32GT/s available
[ 6.904173] ixgbe 0005:01:00.0: (Speed:5.0GT/s, Width: x8, Encoding Loss:20%)
[ 6.904263] ixgbe 0005:01:00.0 eth1: MAC: 2, PHY: 18, SFP+: 5, PBA No: FFFFFF-0FF
[ 6.904268] ixgbe 0005:01:00.0: 00:a0:c9:4e:98:80
[ 6.904272] ixgbe 0005:01:00.0 eth1: Enabled Features: RxQ: 8 TxQ: 8 FdirHash
[ 6.904380] ixgbe 0005:01:00.0 eth1: Intel(R) 10 Gigabit Network Connection
[ 6.904688] ixgbe 0005:01:00.1: enabling device (0000 → 0002)
[ 6.904855] pcie device [0x00000001] hardaddr: 0x000000003a220000 len:131072 virtaddr:0xffffff80113a0000
[ 7.075844] ixgbe 0005:01:00.1: PCI Express bandwidth of 32GT/s available
[ 7.075848] ixgbe 0005:01:00.1: (Speed:5.0GT/s, Width: x8, Encoding Loss:20%)
[ 7.075939] ixgbe 0005:01:00.1 eth2: MAC: 2, PHY: 18, SFP+: 6, PBA No: FFFFFF-0FF
[ 7.075943] ixgbe 0005:01:00.1: 00:a0:c9:4e:98:81
[ 7.075946] ixgbe 0005:01:00.1 eth2: Enabled Features: RxQ: 8 TxQ: 8 FdirHash
[ 7.076047] ixgbe 0005:01:00.1 eth2: Intel(R) 10 Gigabit Network Connection
[ 7.088454] tegra-cbb 14040000.cv-noc: noc_secure_irq = 92, noc_nonsecure_irq = 91>
[ 7.088937] tegra_i2c_probe pdev:3190000.i2c id=-1,membase:0x0000000003190000
[ 7.091666] tegra_i2c_probe register i2c-bus-3 successfully.
[ 7.092421] tegra_i2c_probe pdev:31c0000.i2c id=-1,membase:0x00000000031c0000
[ 7.094728] tegra_i2c_probe register i2c-bus-6 successfully.
[ 7.095120] tegra_i2c_probe pdev:31e0000.i2c id=-1,membase:0x00000000031e0000
[ 7.096468] tegra_i2c_probe register i2c-bus-8 successfully.
[ 7.098777] tegra194-isp5 14800000.isp: initialized
[ 7.106993] tegra194-vi5 15c10000.vi: initialized
[ 7.112746] tegra194-vi5 15c10000.vi: vi4 channel:4
[ 7.112778] tegra194-vi5 15c10000.vi: handling endpoint /host1x/vi@15c10000/ports/port@0/endpoint
[ 7.112821] tegra194-vi5 15c10000.vi: parsing node /host1x/nvcsi@15a00000/channel@0
[ 7.112825] tegra194-vi5 15c10000.vi: handling endpoint /host1x/nvcsi@15a00000/channel@0/ports/port@0/endpoint@0
[ 7.112902] tegra194-vi5 15c10000.vi: parsing node /camera_channel0
[ 7.112905] tegra194-vi5 15c10000.vi: handling endpoint /camera_channel0/ports/port@0/endpoint
[ 7.112926] tegra194-vi5 15c10000.vi: handling endpoint /host1x/nvcsi@15a00000/channel@0/ports/port@1/endpoint@1
[ 7.112947] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–4 bound
[ 7.112961] tegra194-vi5 15c10000.vi: handling endpoint /host1x/vi@15c10000/ports/port@1/endpoint
[ 7.112975] tegra194-vi5 15c10000.vi: parsing node /host1x/nvcsi@15a00000/channel@1
[ 7.112978] tegra194-vi5 15c10000.vi: handling endpoint /host1x/nvcsi@15a00000/channel@1/ports/port@0/endpoint@2
[ 7.113012] tegra194-vi5 15c10000.vi: parsing node /camera_channel1
[ 7.113016] tegra194-vi5 15c10000.vi: handling endpoint /camera_channel1/ports/port@0/endpoint
[ 7.113035] tegra194-vi5 15c10000.vi: handling endpoint /host1x/nvcsi@15a00000/channel@1/ports/port@1/endpoint@3
[ 7.113049] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–3 bound
[ 7.113055] tegra194-vi5 15c10000.vi: handling endpoint /host1x/vi@15c10000/ports/port@2/endpoint
[ 7.113069] tegra194-vi5 15c10000.vi: parsing node /host1x/nvcsi@15a00000/channel@2
[ 7.113072] tegra194-vi5 15c10000.vi: handling endpoint /host1x/nvcsi@15a00000/channel@2/ports/port@0/endpoint@4
[ 7.113120] tegra194-vi5 15c10000.vi: parsing node /camera_channel2
[ 7.113124] tegra194-vi5 15c10000.vi: handling endpoint /camera_channel2/ports/port@0/endpoint
[ 7.113175] tegra194-vi5 15c10000.vi: handling endpoint /host1x/nvcsi@15a00000/channel@2/ports/port@1/endpoint@5
[ 7.113216] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 7.113221] tegra194-vi5 15c10000.vi: handling endpoint /host1x/vi@15c10000/ports/port@3/endpoint
[ 7.113247] tegra194-vi5 15c10000.vi: parsing node /host1x/nvcsi@15a00000/channel@3
[ 7.113250] tegra194-vi5 15c10000.vi: handling endpoint /host1x/nvcsi@15a00000/channel@3/ports/port@0/endpoint@6
[ 7.113280] tegra194-vi5 15c10000.vi: parsing node /camera_channel3
[ 7.113283] tegra194-vi5 15c10000.vi: handling endpoint /camera_channel3/ports/port@0/endpoint
[ 7.113302] tegra194-vi5 15c10000.vi: handling endpoint /host1x/nvcsi@15a00000/channel@3/ports/port@1/endpoint@7
[ 7.113341] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 7.113346] tegra194-vi5 15c10000.vi: mem:start:0x15c10000 end:0x15e3ffff
[ 7.113349] tegra194-vi5 15c10000.vi: mem:start:0x15f00000 end:0x15ffffff
[ 7.113358] vi5 sysctl register success.
[ 7.114113] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 7.117401] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 7.117751] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 7.117949] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 7.118067] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 7.118400] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 7.118492] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 7.118708] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (67)
[ 7.118710] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 7.119615] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=5d9f1c48356a1dad5a597123920f5319cb04aa87
[ 7.120186] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 7.120243] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 7.120384] input: gpio-keys as /devices/gpio-keys/input/input4
[ 7.150495] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:11 UTC (946688411)
[ 7.150931] mmcblk mmc0:0001: Card claimed for testing.
[ 7.191618] bpmp: mounted debugfs mirror
[ 7.196808] vdd-1v8-cvb: disabling
[ 7.196812] vdd-epb-1v0: disabling
[ 7.196813] vdd-sata-1v5: disabling
[ 7.196815] vdd-3v3-slt: disabling
[ 7.196816] vdd-fan: disabling
[ 7.196817] vdd-5v-sata: disabling
[ 7.196824] ALSA device list:
[ 7.196826] #0: tegra-hda-galen-t194 at 0x3518000 irq 66
ok
nobady help me,but i have solved it.
well done!
Hey, Could you please share the solution you have found. I am also stuck with the similar issue. Thanks!
Sorry for late reply. Missed this post.
To change hdmi to SOR0, you should also remove the " nvidia,typec-port" in tegra194-p2888-0001-p2822-0000-common.dtsi. We use that for type C → DP port on devkit. No need it when you are using custom carrier.
Other changes should be similar to sor2 from original HDMI setting in DT.
hi waynewww
Thank you for your reply, and i has solved it,below is my summary.
there are three steps(list below) to check hardware and software:
1.make sure whether hardware uses dp and hdmi interface,dp and hdmi interface’s data signal have a little difference.
2.make sure kernel’version and sdk version is corresponding.
3.make sure that device tree has modified cerrectly,you should primarily make sure the connection bettwen head and sor has configed rightly and the power has configed rightly,and remove “nvidia,typec-port”
  • dts config
    &head0 {
    status = “okay”;
    nvidia,fb-bpp = <32>;
    nvidia,fbmem-size = <265420800>; /* 8K (7680 4320) 32bpp double buffered /
    nvidia,fb-flags = <TEGRA_FB_FLIP_ON_PROBE>;
    win-mask = <0x3>;
    nvidia,fb-win = <0>;
    nvidia,dc-connector = <&sor0>; / changed by shqli,oldval:sor2 /
    nvidia,dc-flags = <TEGRA_DC_FLAG_ENABLED>;
    avdd_hdmi-supply = <&p2888_spmic_sd0>; /
    1v0 /
    avdd_hdmi_pll-supply = <&p2888_spmic_sd1>; /
    1v8 /
    vdd_hdmi_5v0-supply = <&p2822_vdd_hdmi_5v0>; /
    5v0
&sor0 {
status = “okay”;
nvidia,active-panel = <&sor0_hdmi_display>;
&sor0_hdmi_display {
status = “okay”;
disp-default-out {
nvidia,out-flags = <TEGRA_DC_OUT_HOTPLUG_LOW>;
