[OPERATING] XAVIER DEB KIT and SOM board
Dear
we are testing for a detail function.
and we have some problem, I will attach the file.
when we did not connect to HDMI connector, occurs the error message(‘edid invalid’)
Xavier devkit (no problem)
[code]
¢Æ¢Æ
[0000.331] I> MB1 (prd-version: 1.1.0.0-t194-41334769-514a1108)
[0000.336] I> Boot-mode: L0 coldboot
[0000.340] I> Chip revision : A02
[0000.343] I> Bootrom patch version : 7 (correctly patched)
[0000.348] I> ATE fuse revision : 0x200
[0000.351] I> Ram repair fuse : 0x0
[0000.354] I> Ram Code : 0x0
[0000.357] I> rst_source : 0x0
[0000.360] I> rst_level : 0x0
[0000.363] I> Boot-device: eMMC
[0000.366] W> DEVICE_PROD: device prod is not initialized.
[0000.371] W> DEVICE_PROD: device prod is not initialized.
[0000.388] I> sdmmc DDR50 mode
[0000.392] W> DEVICE_PROD: device prod is not initialized.
[0000.397] W> No valid slot number is found in scratch register
[0000.403] W> Return default slot: _a
[0000.406] I> Active Boot chain : 0
[0000.409] I> Boot-device: eMMC
[0000.413] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.419] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0000.426] I> Temperature = 35000
[0000.429] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.434] W> Skipping boost for clk: BPMP_APB
[0000.438] W> Skipping boost for clk: AXI_CBB
[0000.442] W> Skipping boost for clk: AON_CPU_NIC
[0000.446] W> Skipping boost for clk: CAN1
[0000.450] W> Skipping boost for clk: CAN2
[0000.454] I> Boot-device: eMMC
[0000.457] I> Boot-device: eMMC
[0000.466] I> Sdmmc: HS400 mode enabled
[0000.474] I> ECC region[0]: Start:0x0, End:0x0
[0000.478] I> ECC region[1]: Start:0x0, End:0x0
[0000.482] I> ECC region[2]: Start:0x0, End:0x0
[0000.487] I> ECC region[3]: Start:0x0, End:0x0
[0000.491] I> ECC region[4]: Start:0x0, End:0x0
[0000.495] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.501] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.505] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.509] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.514] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.519] W> MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.526] E> FAILED: Thermal config
[0000.530] W> DEVICE_PROD: device prod is not initialized.
[0000.535] W> DEVICE_PROD: device prod is not initialized.
[0000.544] W> MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.551] E> FAILED: MEMIO rail config
[0000.565] I> scrub mode: full dram
[0000.568] E> FUSE: Failed to verify ECID.
[0000.582] I> sdmmc bdev is already initialized
[0000.619] W> No fuse-bypass data
[0000.626] W> MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.651] I> MB1 done
¢Æ¢Æ¢Æ¢Æmain enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
¢Æ¢Æ
[0000.659] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-30577644)
[0000.660] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.661] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.661] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.667] W> device prod register failed
[0000.671] I> Boot-device: eMMC
[0000.674] I> Boot_device: SDMMC_BOOT instance: 3
[0000.681] I> sdmmc-3 params source = boot args
[0000.683] I> sdmmc bdev is already initialized
[0000.687] I> sdmmc-3 params source = boot args
[0000.693] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0000.700] I> Found 37 partitions in SDMMC_USER (instance 3)
[0000.703] W> No valid slot number is found in scratch register
[0000.708] W> Return default slot: _a
[0000.711] I> Active Boot chain : 0
[0000.715] I> parsing oem signed section of bpmp-fw header done
[0000.720] I> bpmp-fw binary init read from storage
[0000.725] I> oem authentication of bpmp-fw header done
[0000.732] I> bpmp-fw binary done read from storage
[0000.735] I> bpmp-fw: Authentication init Done
[0000.739] I> parsing oem signed section of cpubl header done
[0000.744] I> cpubl binary init read from storage
[0000.749] I> bpmp-fw: Authentication Finalize Done
[0000.754] I> oem authentication of cpubl header done
[0000.758] I> cpubl binary done read from storage
[0000.763] I> cpubl: Authentication init Done
[0000.768] I> parsing oem signed section of rce header done
[0000.772] I> rce binary init read from storage
[0000.777] I> Relocating BR-BCT
[0000.780] I> cpubl: Authentication Finalize Done
[0000.784] I> oem authentication of rce header done
[0000.788] I> rce binary done read from storage
[0000.793] I> rce: Authentication init Done
[0000.797] I> parsing oem signed section of tos header done
[0000.802] I> tos binary init read from storage
[0000.806] I> rce: Authentication Finalize Done
[0000.811] I> oem authentication of tos header done
[0000.815] I> tos binary done read from storage
[0000.819] I> tos: Authentication init Done
[0000.824] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.829] I> bpmp-fw-dtb binary init read from storage
[0000.834] I> tos: Authentication Finalize Done
[0000.839] I> oem authentication of bpmp-fw-dtb header done
[0000.847] I> bpmp-fw-dtb binary done read from storage
[0000.849] I> bpmp-fw-dtb: Authentication init Done
[0000.854] I> parsing oem signed section of cpubl-dtb header done
[0000.860] I> cpubl-dtb binary init read from storage
[0000.864] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.901] I> oem authentication of cpubl-dtb header done
[0000.902] I> cpubl-dtb binary done read from storage
[0000.903] I> cpubl-dtb: Authentication init Done
[0000.903] I> cpubl-dtb: Authentication Finalize Done
¢Æ¢ÆNOTICE: BL31: v1.3(release):eca0c5e
NOTICE: BL31: Built : 00:20:29, Mar 13 2019
ERROR: Error initializing runtime service trusty_fast
¢Æ¢Æ
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 1c1b2165fe52a0a54ad7caf60d40cdc3
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
387 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
mrq initialized
¢Æ¢Æ
[0001.362] I> Welcome to Cboot
[0001.363] I> Cboot Version: t194-187516be
¢Æ¢Æfmon_post initialized
¢Æ¢Æ[0001.363] I> CPU-BL Params @ 0xea820000
[0001.363] I> 0) Base:0x00000000 Size:0x00000000
[0001.364] I> 1) Base:0xea100000 Size:0x00100000
[0001.367] I> 2) Base:0xea000000 Size:0x00100000
[0001.372] I> 3) Base:0xe9300000 Size:0x00100000
[0001.376] I> 4) Base:0xe9200000 Size:0x00100000
[0001.381] I> 5) Base:0xe9100000 Size:0x00100000
[0001.385] I> 6) Base:0xeb800000 Size:0x00400000
[0001.390] I> 7) Base:0xe9c00000 Size:0x00400000
¢Æ¢Æclk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_pcie initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
¢Æ¢Æ[0001.394] I> 8) Base:0xe9000000 Size:0x00100000
[0001.464] I> 9) Base:0xe8f00000 Size:0x00100000
[0001.468] I> 10) Base:0xeb000000 Size:0x00800000
[0001.472] I> 11) Base:0x40000000 Size:0x00040000
[0001.477] I> 12) Base:0xe8e00000 Size:0x00100000
[0001.481] I> 13) Base:0x40046000 Size:0x00002000
[0001.486] I> 14) Base:0x40048000 Size:0x00002000
[0001.490] I> 15) Base:0xab000000 Size:0x00004000
[0001.495] I> 16) Base:0x4004a000 Size:0x00002000
[0001.499] I> 17) Base:0xe8d00000 Size:0x00100000
[0001.504] I> 18) Base:0x4004c000 Size:0x00002000
[0001.508] I> 19) Base:0xea200000 Size:0x00600000
[0001.513] I> 20) Base:0x4004e000 Size:0x00002000
¢Æ¢Æemc_debugfs initialized
¢Æ¢Æ[0001.517] I> 21) Base:0xe8cd0000 Size:0x0000c000¢Æ¢Ædvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ¢Æ¢Æ
[0001.570] I> 22) Base:0x00000000 Size:0x00000000
[0001.574] I> 23) Base:0xe8ce0000 Size:0x00020000
[0001.579] I> 24) Base:0xee000000 Size:0x02000000
[0001.583] I> 25) Base:0x40050000 Size:0x00002000
[0001.588] I> 26) Base:0x40040000 Size:0x00006000
[0001.592] I> 27) Base:0xe9800000 Size:0x00400000
[0001.597] I> 28) Base:0xecc00000 Size:0x01400000
[0001.601] I> 29) Base:0xe9400000 Size:0x00400000
[0001.606] I> 30) Base:0x00000000 Size:0x00000000
[0001.610] I> 31) Base:0x00000000 Size:0x00000000
[0001.615] I> 32) Base:0xf8000000 Size:0x08000000
[0001.619] I> 33) Base:0xf0000000 Size:0x08000000
[0001.623] I> 34) Base:0xebc00000 Size:0x01000000
[0001.628] I> 35) Base:0xaa000000 Size:0x01000000
[0001.632] I> 36) Base:0xa0000000 Size:0x0a000000
[0001.637] I> 37) Base:0xea800000 Size:0x00800000
[0001.641] I> 38) Base:0x80000000 Size:0x20000000
[0001.646] I> 39) Base:0xb0000000 Size:0x08000000
[0001.650] I> 40) Base:0x00000000 Size:0x00000000
[0001.655] I> 41) Base:0x00000000 Size:0x00000000
[0001.659] I> 42) Base:0x00000000 Size:0x00000000
[0001.664] I> 43) Base:0x00000000 Size:0x00000000
[0001.668] I> 44) Base:0x00000000 Size:0x00000000
[0001.673] I> 45) Base:0x00000000 Size:0x00000000
[0001.677] GIC-SPI Target CPU: 0
[0001.680] Interrupts Init done
[0001.683] calling constructors
[0001.686] initializing heap
[0001.688] I> Heap: [0xa068d430 … 0xaa000000]
[0001.693] initializing threads
[0001.696] initializing timers
[0001.698] creating bootstrap completion thread
[0001.703] top of bootstrap2()
[0001.705] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.710] initializing platform
[0001.713] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.718] W> device prod register failed
[0001.722] I> Bl_dtb @0xa9f00000
[0001.725] I> gpio framework initialized
[0001.734] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.740] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0001.744] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.754] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.762] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.766] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.772] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.780] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.788] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.794] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.802] I> fixed regulator driver initialized
[0001.817] I> register ‘maxim’ power off handle
[0001.818] I> virtual i2c enabled
[0001.818] I> registered ‘maxim,max20024’ pmic
[0001.819] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0001.822] I> Boot-device: eMMC
[0001.825] I> Boot_device: SDMMC_BOOT instance: 3
[0001.831] I> sdmmc-3 params source = boot args
[0001.834] I> sdmmc bdev is already initialized
[0001.838] I> sdmmc-3 params source = boot args
[0001.844] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0001.850] I> Found 37 partitions in SDMMC_USER (instance 3)
[0001.854] E> “plugin-manager” doesn’t exist, creating
[0001.858] E> “ids” doesn’t exist, creating
[0001.863] E> “connection” doesn’t exist, creating
[0001.867] E> “configs” doesn’t exist, creating
[0001.873] I> Find /i2c@3160000’s alias i2c0
[0001.875] I> Reading eeprom i2c=0 address=0x50
[0001.906] I> Device at /i2c@3160000:0x50
[0001.906] I> Reading eeprom i2c=0 address=0x56
[0001.931] I> Device at /i2c@3160000:0x56
[0001.933] I> Find /i2c@3180000’s alias i2c2
[0001.933] I> Reading eeprom i2c=2 address=0x54
[0001.935] E> I2C: slave not found in slaves.
[0001.935] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.936] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.936] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.945] E> eeprom: Failed to read I2C slave device
[0001.950] I> Eeprom read failed 0x3526070d
[0001.954] I> Reading eeprom i2c=2 address=0x57
[0001.958] E> I2C: slave not found in slaves.
[0001.962] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.970] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.976] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.985] E> eeprom: Failed to read I2C slave device
[0001.990] I> Eeprom read failed 0x3526070d
[0001.994] I> Reading eeprom i2c=2 address=0x52
[0001.999] E> I2C: slave not found in slaves.
[0002.003] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.010] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.016] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0002.025] E> eeprom: Failed to read I2C slave device
[0002.030] I> Eeprom read failed 0x3526070d
[0002.035] I> Find /i2c@c240000’s alias i2c1
[0002.038] I> Reading eeprom i2c=1 address=0x52
[0002.044] E> I2C: slave not found in slaves.
[0002.047] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.054] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.060] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.070] E> eeprom: Retry to read I2C slave device.
[0002.074] E> I2C: slave not found in slaves.
[0002.078] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.086] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.092] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.101] E> eeprom: Failed to read I2C slave device
[0002.106] I> Eeprom read failed 0x3526070d
[0002.110] I> Reading eeprom i2c=1 address=0x50
[0002.115] E> I2C: slave not found in slaves.
[0002.119] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.127] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.132] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.141] E> eeprom: Retry to read I2C slave device.
[0002.146] E> I2C: slave not found in slaves.
[0002.150] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.158] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.164] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.173] E> eeprom: Failed to read I2C slave device
[0002.178] I> Eeprom read failed 0x3526070d
[0002.182] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0002.187] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.198] I> create_pm_ids: id: 2822-0000-600-D, len: 15
[0002.203] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.214] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0002.223] E> “i2c@3160000” doesn’t exist, creating
[0002.226] E> “module@0x50” doesn’t exist, creating
[0002.231] I> Adding plugin-manager/ids/2822-0000-600=/i2c@3160000:module@0x56
[0002.238] E> “module@0x56” doesn’t exist, creating
[0002.243] I> Adding plugin-manager/cvm
[0002.246] E> “chip-id” doesn’t exist, creating
[0002.250] I> Adding plugin-manager/chip-id/A02
[0002.255] I> Plugin-manager override starting
[0002.259] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.268] I> node /plugin-manager/fragement-soft-wdt matches
[0002.274] I> node /plugin-manager/fragment-pcie-c1-rp matches
[0002.276] I> node /plugin-manager/fragment-pcie-p2822-B00 matches
[0002.286] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.291] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.294] I> node /plugin-manager/pwm-fan-polarity matches
[0002.304] I> node /plugin-manager/ufs-cd matches
[0002.307] I> Disable plugin-manager status in FDT
[0002.308] I> Plugin-manager override finished successfully
[0002.321] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.325] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.325] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.329] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.338] E> invalid display type
[0002.342] E> invalid display type
[0002.343] E> cannot find any other nvdisp nodes
[0002.346] E> no valid display unit config found in dtb
[0002.352] W> display init failed
[0002.354] I> Load in CBoot Boot Options partition and parse it
[0002.361] E> Error -9 when finding node with path /boot-configuration
[0002.366] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.373] I> Hit any key to stop autoboot: 4 3 2 1
[0004.381] initializing target
[0004.381] calling apps_init()
[0004.382] starting app kernel_boot_app
[0004.385] I> found decompressor handler: lz4-legacy
[0004.386] I> decompressing BMP blob …
[0004.391] I> Kernel type = Normal
[0004.391] I> Loading kernel & kernel-dtb from removable storage (5)
[0004.392] I> No sdcard
[0004.392] I> -0 params source =
[0004.392] E> Blockdev open: exit error
[0004.393] I> Loading kernel & kernel-dtb from removable storage (6)
[0004.403] W> No valid slot number is found in scratch register
[0004.403] W> Return default slot: _a
[0004.409] I> USB Firmware Version: 60.05 release
[0004.863] E> failed to initialize xhci controller
[0004.864] E> Error in init of XUSB host driver, err: 79790026
[0004.864] W> Failed to initialize device 6-0
[0004.864] I> Loading kernel/boot.img from built-in storage …
[0004.865] W> No valid slot number is found in scratch register
[0004.865] W> Return default slot: _a
[0004.867] I> A/B: bin_type (37) slot 0
[0004.871] I> Loading partition kernel at 0xa42d0000 from device(0x1)
[0005.258] W> No valid slot number is found in scratch register
[0005.258] W> Return default slot: _a
[0005.259] I> A/B: bin_type (38) slot 0
[0005.259] I> Loading partition kernel-dtb at 0x90000000 from device(0x1)
[0005.263] I> T19x: Authenticate boot.img (bin_type: 37), max size 0x4000000
[0005.592] I> T19x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type: 38), max size 0x400000
[0005.595] I> Kernel hdr @0xa42d0000
[0005.596] I> Kernel dtb @0x90000000
[0005.596] I> Checking boot.img header magic … [0005.596] I> [OK]
[0005.596] I> Valid boot.img @ 0xa42d0000
[0005.597] I> decompressor handler not found
[0005.597] I> Copying kernel image (34048008 bytes) from 0xa42d0800 to 0x80080000 … [0005.610] I> Done
[0005.610] I> Move ramdisk (len: 0) from 0xa6349800 to 0x91000000
[0005.612] I> Updated bpmp info to DTB
[0005.616] I> Ramdisk: Base: 0x91000000; Size: 0x0
[0005.620] I> Updated initrd info to DTB
[0005.623] W> WARN: Fail to override “console=none” in commandline
[0005.629] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0005.637] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0005.644] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0005.651] W> No valid slot number is found in scratch register
[0005.657] W> Return default slot: _a
[0005.660] I> Active slot suffix:
[0005.663] I> add_boot_slot_suffix: slot_suffix =
[0005.668] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[0005.701] I> Updated bootarg info to DTB
[0005.705] W> MAC addr invalid!
[0005.708] E> Failed to get WIFI MAC address
[0005.712] W> MAC addr invalid!
[0005.715] E> Failed to get Bluetooth MAC address
[0005.719] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:db:d4
[0005.726] E> “plugin-manager” doesn’t exist, creating
[0005.731] I> Adding /chosen/plugin-manager/cvm
[0005.735] E> “chip-id” doesn’t exist, creating
[0005.739] I> Adding /chosen/plugin-manager/chip-id
[0005.744] E> “configs” doesn’t exist, creating
[0005.748] I> Adding /chosen/plugin-manager/configs
[0005.752] E> “ids” doesn’t exist, creating
[0005.756] I> Adding /chosen/plugin-manager/ids
[0005.761] E> “odm-data” doesn’t exist, creating
[0005.765] I> Adding /chosen/plugin-manager/odm-data
[0005.773] E> “memory” doesn’t exist, creating
[0005.774] I> [0] START: 0x80000000, END: 0xab000000
[0005.779] I> [1] START: 0xab004000, END: 0xe8cd0000
[0005.783] I> [2] START: 0xe8cdc000, END: 0xe8ce0000
[0005.788] I> dram_block larger than 80000000
[0005.792] I> [3] START: 0x100000000, END: 0x480000000
[0005.797] I> added [base:0x80000000, size:0x2b000000] to /memory
[0005.803] I> added [base:0xab200000, size:0x3da00000] to /memory
[0005.809] I> added [base:0x100000000, size:0x380000000] to /memory
[0005.816] I> Updated memory info to DTB
[0005.819] E> add_disp_param: failed to get display params for du=0
[0005.825] E> “reset” doesn’t exist, creating
[0005.829] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0005.834] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0005.838] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0005.843] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0005.848] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0005.852] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0005.857] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0005.862] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0005.867] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0005.872] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0005.877] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0005.881] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0005.886] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0005.891] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0005.896] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0005.901] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0005.906] E> “misc-data” doesn’t exist, creating
[0005.910] I> Boot-device: eMMC
[0005.913] I> Add boot-sdmmc to plugin-manager/misc-data
[0005.918] I> Add storage-sdmmc to plugin-manager/misc-data
[0005.923] W> Unknown storage device
[0005.926] I> Add serial number:0423818077212 as DT property
[0005.933] I> Plugin-manager override starting
[0005.937] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0005.944] I> node /plugin-manager/fragement-soft-wdt matches
[0005.950] I> node /plugin-manager/fragment-pcie-c1-rp matches
[0005.954] I> node /plugin-manager/fragment-pcie-p2822-B00 matches
[0005.962] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0005.967] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0005.972] I> node /plugin-manager/pwm-fan-polarity matches
[0005.980] I> node /plugin-manager/ufs-cd matches
[0005.983] I> Disable plugin-manager status in FDT
[0005.985] I> Plugin-manager override finished successfully
[0005.990] I> tegrabl_load_kernel_and_dtb: Done
[0005.995] I> Sending TOS params
[0005.998] I> Sending NS DRAM Ranges to TOS
[0006.002] W> Failed to send NS DRAM Ranges to TOS
[0006.006] W> Failed to lock interface between BL and TOS
[0006.011] E> tegrabl_display_clear: display is not initialized
[0006.017] W> Boot logo display failed…
[0006.021] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (nestor@nestor) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #2 SMP PREEMPT Tue Oct 29 14:41:38 KST 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2b000000
[ 0.000000] OF: fdt: - ab200000 , 3da00000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found vpr, start=0xf0000000 size=8000000[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffe26000 s53400 r8192 d32616 u94208
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4034016
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29152(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 16003596K/16392192K available (15166K kernel code, 2914K rwdata, 6632K rodata, 8512K init, 605K bss, 323060K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000008] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008742] Console: colour dummy device 80x25
[ 0.012758] console [tty0] enabled
[ 0.016100] bootconsole [tegra_comb_uart0] disabled
[ 0.021285] kmemleak: Kernel memory leak detector disabled
[ 0.021362] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.021411] pid_max: default: 32768 minimum: 301
[ 0.022849] Security Framework initialized
[ 0.023629] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023677] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.026252] ftrace: allocating 46817 entries in 183 pages
[ 0.523600] sched-energy: Sched-energy-costs installed from DT
[ 0.523774] ASID allocator initialised with 65536 entries
[ 0.561931] tegra-id: chipid=21917.
[ 0.561972] tegra-id: opt_subrevision=0.
[ 0.562063] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.562144] DTS File Name: /home/nestor/working/adas_logger_kernel/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.562248] DTB Build time: Oct 29 2019 14:43:04
[ 0.612280] CPU1: Booted secondary processor [4e0f0040]
[ 0.644150] CPU2: Booted secondary processor [4e0f0040]
[ 0.676257] CPU3: Booted secondary processor [4e0f0040]
[ 0.708857] CPU4: Booted secondary processor [4e0f0040]
[ 0.741025] CPU5: Booted secondary processor [4e0f0040]
[ 0.773779] CPU6: Booted secondary processor [4e0f0040]
[ 0.805674] CPU7: Booted secondary processor [4e0f0040]
[ 0.807043] Brought up 8 CPUs
[ 0.807566] SMP: Total of 8 processors activated.
[ 0.807622] CPU features: detected feature: Privileged Access Never
[ 0.807677] CPU features: detected feature: LSE atomic instructions
[ 0.807729] CPU features: detected feature: User Access Override
[ 0.807808] CPU features: detected feature: 32-bit EL0 Support
[ 0.814669] CPU: All CPU(s) started at EL2
[ 0.814833] alternatives: patching kernel code
[ 0.830166] devtmpfs: initialized
[ 0.882691] Initilizing CustomIPI irq domain
[ 0.883109] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.883192] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.885110] pinctrl core: initialized pinctrl subsystem
[ 0.885379] OS set in device tree is not L4T.
[ 0.885692] regulator-dummy: no parameters
[ 0.886022] Initializing plugin-manager
[ 0.886112] Plugin module not found
[ 0.886188] Plugin-manager status disabled
[ 0.887957] NET: Registered protocol family 16
[ 0.895548] pstore: using zlib compression
[ 0.897252] console [pstore-1] enabled
[ 0.897295] pstore: Registered ramoops as persistent store backend
[ 0.897349] ramoops: attached 0x200000@0xe8a00000, ecc: 0/0
[ 0.915998] cpuidle: using governor menu
[ 0.917667] bpmp: waiting for handshake
[ 0.917772] bpmp: handshake completed
[ 0.917836] bpmp: synchronizing channels
[ 0.917882] bpmp: channels synchronized
[ 0.917928] bpmp: mail init ok
[ 0.922000] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.922312] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.922375] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.922443] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.922533] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.922617] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.922674] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.922749] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.922830] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.922891] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.922950] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.928098] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.928534] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.932977] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.933939] Registering BPMP clocks…
[ 0.934180] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.934600] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.935204] tegra_powergate_init: DONE
[ 0.935444] DTS File Name: /home/nestor/working/adas_logger_kernel/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.935641] DTB Build time: Oct 29 2019 14:43:04
[ 0.939493] Tegra reboot handler registered.
[ 0.950252] iommu: Adding device 14180000.pcie to group 0
[ 0.951259] iommu: Adding device 14100000.pcie to group 1
[ 0.952320] iommu: Adding device 14140000.pcie to group 2
[ 0.953333] iommu: Adding device 141a0000.pcie to group 3
[ 0.955378] iommu: Adding device 2490000.ether_qos to group 4
[ 0.956260] iommu: Adding device 3100000.serial to group 5
[ 0.957094] iommu: Adding device 3110000.serial to group 6
[ 0.957742] iommu: Adding device 3140000.serial to group 7
[ 0.958617] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.958935] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.959037] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.959098] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.959156] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.959271] tegra-pmc: PMC Prod config success
[ 0.959634] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.959770] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.960392] iommu: Adding device 3460000.sdhci to group 8
[ 0.961250] iommu: Adding device 3400000.sdhci to group 9
[ 0.962056] iommu: Adding device 2450000.ufshci to group 10
[ 0.963443] iommu: Adding device 3160000.i2c to group 11
[ 0.964086] iommu: Adding device c240000.i2c to group 12
[ 0.964719] iommu: Adding device 3180000.i2c to group 13
[ 0.965392] iommu: Adding device 3190000.i2c to group 14
[ 0.966153] iommu: Adding device 31b0000.i2c to group 15
[ 0.966737] iommu: Adding device 31c0000.i2c to group 16
[ 0.967351] iommu: Adding device c250000.i2c to group 17
[ 0.967960] iommu: Adding device 31e0000.i2c to group 18
[ 0.969574] iommu: Adding device 3510000.hda to group 19
[ 0.970478] iommu: Adding device bc00000.rtcpu to group 20
[ 0.973422] iommu: Adding device 13e10000.host1x to group 21
[ 0.974076] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.974691] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.975282] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.975908] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.976566] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.977214] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.977839] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.978420] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.979303] iommu: Adding device 15340000.vic to group 30
[ 0.979977] iommu: Adding device 15380000.nvjpg to group 31
[ 0.980462] iommu: Adding device 15500000.tsec to group 32
[ 0.980966] iommu: Adding device 15100000.tsecb to group 33
[ 0.981420] iommu: Adding device 15480000.nvdec to group 34
[ 0.981873] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.982319] iommu: Adding device 154c0000.nvenc to group 36
[ 0.982785] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.983434] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.984098] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.984984] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.986453] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 0.986536] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.987190] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.987307] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.987918] iommu: Adding device 15220000.nvdisplay to group 42
[ 0.988070] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.991133] iommu: Adding device 15c10000.vi to group 43
[ 0.991432] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.992016] iommu: Adding device 14800000.isp to group 44
[ 0.993455] iommu: Adding device 16000000.pva0 to group 45
[ 0.994229] iommu: Adding device 16800000.pva1 to group 46
[ 0.994886] iommu: Adding device 15810000.se to group 47
[ 0.995555] iommu: Adding device 15820000.se to group 48
[ 0.996008] iommu: Adding device 15830000.se to group 49
[ 0.996457] iommu: Adding device 15840000.se to group 50
[ 0.996950] iommu: Adding device c1a0000.aon to group 51
[ 0.999428] iommu: Adding device d000000.bpmp to group 52
[ 0.999965] bpmp: ping status is 0
[ 1.000198] bpmp d000000.bpmp: firmware tag is 1c1b2165fe52a0a54ad7caf60d40cdc3
[ 1.004765] bpmp d000000.bpmp: probe ok
[ 1.006873] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 1.007655] iommu: Adding device smmu_test to group 53
[ 1.009395] mc: mapped MMIO address: 0xffffff800a560000 → 0x2c10000
[ 1.009494] mc: mapped MMIO address: 0xffffff800a580000 → 0x2c20000
[ 1.009596] mc: mapped MMIO address: 0xffffff800a5a0000 → 0x2c30000
[ 1.009686] mc: mapped MMIO address: 0xffffff800a5c0000 → 0x2c40000
[ 1.009775] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c50000
[ 1.009865] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2b80000
[ 1.009962] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2b90000
[ 1.010064] mc: mapped MMIO address: 0xffffff800b010000 → 0x2ba0000
[ 1.010185] mc: mapped MMIO address: 0xffffff800b030000 → 0x2bb0000
[ 1.010273] mc: mapped MMIO address: 0xffffff800b050000 → 0x1700000
[ 1.010360] mc: mapped MMIO address: 0xffffff800b070000 → 0x1710000
[ 1.010448] mc: mapped MMIO address: 0xffffff800b090000 → 0x1720000
[ 1.010535] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1730000
[ 1.010622] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1740000
[ 1.010720] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1750000
[ 1.010816] mc: mapped MMIO address: 0xffffff800b110000 → 0x1760000
[ 1.010905] mc: mapped MMIO address: 0xffffff800b130000 → 0x1770000
[ 1.011081] mc-err: mcerr ops are set to t19x
[ 1.020216] iommu: Adding device 2600000.dma to group 54
[ 1.028269] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 1.028390] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.029026] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.040000] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.040481] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.043743] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.043816] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.045085] iommu: Adding device 3550000.xudc to group 55
[ 1.046222] iommu: Adding device 3610000.xhci to group 56
[ 1.049690] arm64_ras arm64_ras: probed
[ 1.050351] ras_fhi_enable: FHI 474 enabled on CPU0
[ 1.050464] ras_fhi_enable: FHI 475 enabled on CPU1
[ 1.050638] ras_fhi_enable: FHI 476 enabled on CPU2
[ 1.050826] ras_fhi_enable: FHI 477 enabled on CPU3
[ 1.050965] ras_fhi_enable: FHI 478 enabled on CPU4
[ 1.051130] ras_fhi_enable: FHI 479 enabled on CPU5
[ 1.051274] ras_fhi_enable: FHI 480 enabled on CPU6
[ 1.051413] ras_fhi_enable: FHI 481 enabled on CPU7
[ 1.051771] carmel_ras_enable: RAS enabled on cpu0
[ 1.052145] carmel_ras_enable: RAS enabled on cpu1
[ 1.052443] carmel_ras_enable: RAS enabled on cpu2
[ 1.052762] carmel_ras_enable: RAS enabled on cpu3
[ 1.053024] carmel_ras_enable: RAS enabled on cpu4
[ 1.053305] carmel_ras_enable: RAS enabled on cpu5
[ 1.053601] carmel_ras_enable: RAS enabled on cpu6
[ 1.053876] carmel_ras_enable: RAS enabled on cpu7
[ 1.054010] carmel_ras carmel_ras: probed
[ 1.055565] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 1.056343] tegra-cbb c600000.aon-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 1.057416] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[ 1.058492] tegra-cbb be00000.rce-noc: noc_secure_irq = 489, noc_nonsecure_irq = 488>
[ 1.059656] tegra-cbb b600000.sce-noc: noc_secure_irq = 491, noc_nonsecure_irq = 490>
[ 1.060217] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.064304] vdd-3v3-cvb: 3300 mV
[ 1.064830] vdd-1v8-cvb: 1800 mV
[ 1.065394] vdd-1v8-sd: 1800 mV
[ 1.065942] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.066038] vdd-epb-1v0: 1000 mV
[ 1.066568] vdd-sdmmc1-sw: 3300 mV
[ 1.067172] avdd-cam-2v8: 2800 mV
[ 1.067684] vdd-sata-1v5: 1500 mV
[ 1.068144] vdd-1v8-slt: 1800 mV
[ 1.068795] vdd-3v3-slt: 3300 mV
[ 1.069279] vdd-fan: 5000 mV
[ 1.069828] vdd-hdmi-5v0: 5000 mV
[ 1.070365] vdd_sys_en: 1200 mV
[ 1.071038] vdd-5v-sata: 5000 mV
[ 1.071634] vdd-ac-bat: 5000 mV
[ 1.071924] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.108878] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.115053] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.115518] SCSI subsystem initialized
[ 1.116280] usbcore: registered new interface driver usbfs
[ 1.116441] usbcore: registered new interface driver hub
[ 1.116640] usbcore: registered new device driver usb
[ 1.131800] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.135349] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.143812] vdd-1v0: at 1000 mV
[ 1.147837] vdd-1v8-hs: at 1800 mV
[ 1.151864] vdd-1v8-ls: at 1800 mV
[ 1.155888] vdd-1v8-ao: at 1800 mV
[ 1.164029] vddio-ddr-1v1: at 1100 mV
[ 1.171826] vdd-rtc: at 800 mV
[ 1.173420] spmic-ldo1: at 2375 mV
[ 1.183872] vdd-ao-3v3: at 3300 mV
[ 1.190175] vddio-emmc-3v3: at 3300 mV
[ 1.191641] spmic-ldo4: at 1587 mV
[ 1.198251] vdd-usb-3v3: at 3300 mV
[ 1.206395] vddio-sdmmc1-3v3: at 3300 mV
[ 1.210505] vdd-csi-1v2: at 1200 mV
[ 1.212494] spmic-ldo8: at 1800 mV
[ 1.214832] GPIO line 246 (gpio_default) hogged as output/high
[ 1.216420] GPIO line 247 (gpio_default) hogged as output/high
[ 1.217084] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.220850] max77620 4-003c: max77620 probe successful
[ 1.221811] media: Linux media interface: v0.10
[ 1.221930] Linux video capture interface: v2.00
[ 1.223609] pps_core: LinuxPPS API ver. 1 registered
[ 1.223657] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.223846] PTP clock support registered
[ 1.224641] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.224746] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.226468] tegra_fiq_debugger_init: found FIQ source (IRQ 466)
[ 1.228595] Advanced Linux Sound Architecture Driver Initialized.
[ 1.229328] Bluetooth: Core ver 2.22
[ 1.229411] NET: Registered protocol family 31
[ 1.229452] Bluetooth: HCI device and connection manager initialized
[ 1.229522] Bluetooth: HCI socket layer initialized
[ 1.229580] Bluetooth: L2CAP socket layer initialized
[ 1.229651] Bluetooth: SCO socket layer initialized
[ 1.233779] camchar: rtcpu character device driver loaded
[ 1.236292] clocksource: Switched to clocksource arch_sys_counter
[ 1.305335] VFS: Disk quotas dquot_6.6.0
[ 1.305549] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.306048] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.307969] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.308132] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 1.308289] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.308350] nvmap_page_pool_init: Total RAM pages: 4017283
[ 1.308394] nvmap_page_pool_init: nvmap page pool size: 502160 pages (1961 MB)
[ 1.308815] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.309364] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 1.312136] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.329215] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.329743] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.330178] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.330537] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.331197] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.331572] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.331818] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.333410] la/ptsa driver initialized.
[ 1.333934] NET: Registered protocol family 2
[ 1.335190] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.336063] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.336950] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.337056] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.337420] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.338146] NET: Registered protocol family 1
[ 1.339127] RPC: Registered named UNIX socket transport module.
[ 1.339179] RPC: Registered udp transport module.
[ 1.339220] RPC: Registered tcp transport module.
[ 1.339260] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.339610] Trying to unpack rootfs image as initramfs…
[ 1.364940] random: fast init done
[ 1.370387] host1x 13e10000.host1x: initialized
[ 1.373513] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.381224] audit: initializing netlink subsys (disabled)
[ 1.381353] audit: type=2000 audit(0.892:1): initialized
[ 1.382656] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.398421] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.400594] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.401747] 9p: Installing v9fs 9p2000 file system support
[ 1.409744] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.410135] io scheduler noop registered
[ 1.410541] io scheduler cfq registered (default)
[ 1.415186] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.454080] iommu: Adding device 2993000.adsp to group 57
[ 1.559196] iommu: Adding device aconnect@2a41000:adsp_audio to group 58
[ 1.560465] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.578552] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.579164] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.579784] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.583461] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.583819] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[ 1.583888] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=4166665, max_bw=4166665
[ 1.587832] tsec 15500000.tsec: initialized
[ 1.590493] tsec 15100000.tsecb: initialized
[ 1.595273] nvdec 15480000.nvdec: initialized
[ 1.598758] nvdec 15140000.nvdec1: initialized
[ 1.604998] falcon 15340000.vic: initialized
[ 1.607861] falcon 15380000.nvjpg: initialized
[ 1.610164] falcon 154c0000.nvenc: initialized
[ 1.612629] falcon 15a80000.nvenc1: initialized
[ 1.617322] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.621450] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.624486] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.627083] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.629598] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.632052] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.634554] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.637009] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.641861] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.648185] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.648889] scare-pigeon 14b00000.isp-thi: initialized
[ 1.659316] pva 16000000.pva0: initialized
[ 1.692761] pva 16800000.pva1: initialized
[ 1.723351] nvdla 15880000.nvdla0: initialized
[ 1.754413] nvdla 158c0000.nvdla1: initialized
[ 1.756309] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.756401] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.756501] tegradccommon 15200000.dc_common: dma mapping done
[ 1.757835] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.757955] generic_infoframe_type: 0x87
[ 1.758153] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.758245] tegradc 15200000.nvdisplay: Display dc.ffffff800bc90000 registered with id=0
[ 1.764061] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.764165] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.764244] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.764735] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.764793] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.769452] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.769521] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.774056] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.775110] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.775644] tegradc 15200000.nvdisplay: probed
[ 1.775702] kfuse 3830000.kfuse: initialized
[ 1.785127] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.789220] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.790924] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.792170] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.215019] console [ttyTCU0] enabled
[ 4.215503] Console: switching to colour frame buffer device 80x30
[ 4.215699] [drm] Initialized
[ 4.227805] tegradc 15200000.nvdisplay: fb registered
[ 4.233312] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.238938] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 4.245414] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 4.246090] brd: module loaded
[ 4.255519] loop: module loaded
[ 4.257652] tegra_profiler: version: 1.132, samples/io: 46/26
[ 4.263637] tegra_profiler: auth: init
[ 4.267453] nct1008_nct72 4-004c: starting parse dt
[ 4.267853] THERMAL EST: found 3 subdevs
[ 4.267858] THERMAL EST num_resources: 0
[ 4.267862] [THERMAL EST subdev 0]
[ 4.267868] [THERMAL EST subdev 1]
[ 4.267873] [THERMAL EST subdev 2]
[ 4.268513] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.268516] THERMAL EST: thz register success.
[ 4.268814] THERMAL EST: end of probe, return err: 0
[ 4.270199] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.270209] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.272113] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 456
[ 4.272125] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.337576] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.343285] nct1008_nct72 4-004c: success parsing dt
[ 4.348688] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.365368] scsi host0: ufshcd
[ 4.377098] hisi_sas: driver version v1.6
[ 4.381560] libphy: Fixed MDIO Bus: probed
[ 4.382618] tun: Universal TUN/TAP device driver, 1.6
[ 4.382736] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.384133] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.384314] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.387715] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 4.388636] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 4.400592] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.407568] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.413014] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.421045] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.422039] nct1008_nct72 4-004c: initial LOC temp: 35000
[ 4.422563] nct1008_nct72 4-004c: initial EXT temp: 47250
[ 4.423533] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 4.424806] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 4.448392] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.455086] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.462072] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.470059] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb db d4
[ 4.472158] libphy: dwc_phy: probed
[ 4.479398] PPP generic driver version 2.4.2
[ 4.480041] PPP BSD Compression module registered
[ 4.484575] PPP Deflate Compression module registered
[ 4.489830] PPP MPPE Compression module registered
[ 4.494451] NET: Registered protocol family 24
[ 4.499081] usbcore: registered new interface driver r8152
[ 4.504551] usbcore: registered new interface driver asix
[ 4.510051] usbcore: registered new interface driver ax88179_178a
[ 4.516482] usbcore: registered new interface driver cdc_ether
[ 4.522171] usbcore: registered new interface driver net1080
[ 4.527973] usbcore: registered new interface driver cdc_subset
[ 4.533990] usbcore: registered new interface driver zaurus
[ 4.540071] usbcore: registered new interface driver cdc_ncm
[ 4.546377] VFIO - User Level meta-driver version: 0.3
[ 4.552661] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.556817] ehci-pci: EHCI PCI platform driver
[ 4.561372] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.567615] ohci-pci: OHCI PCI platform driver
[ 4.572130] ohci-platform: OHCI generic platform dr
MobaXterm_dev_COM8USBSerialPortCOM8_20191111_155820_no_problem.txt (88.8 KB)
MobaXterm_som_COM8USBSerialPortCOM8_20191111_113427_error.txt (458 KB)
MobaXterm_som_COM8USBSerialPortCOM8_20191111_170836_error.txt (165 KB)
I can not correct the page.
MobaXterm_dev_COM8USBSerialPortCOM8_20191111_155820_no_problem : no problem
MobaXterm_som_COM8USBSerialPortCOM8_20191111_170836_error : problem
attach the file.
The real cause of this issue is as below.
[    4.180469] gpio tegra-gpio wake71 for gpio=98(M:2)
[    4.186045] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[    4.190181] edid invalid
[    4.195181] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[    4.196992] brd: module loaded
Please comment out below in device tree.
&head0 {
extcon-cables = <&typec_port0 2 &typec_port1 2>;
extcon-cable-names = "typec0", "typec1";
#extcon-cells = <1>;
&head1 {
&head2 {
thank you wayne,
we were debug gpio=98(M:2) pin for stable,
so we can solve the problem,
thanks.:)
