I have a Xavier dev kit that won’t complete the boot process. It gets most of the way through, then powers off. One time it got as far as letting me log in before powering off, but usually the last message on the console is tegra-i2c 3160000.i2c: no acknowledge from address 0x74
. Full console output is below.
I’m powering it with a laptop power supply that’s 19.5V and rated for 4.62A (90 watts).
Any thoughts?
000.103] I> MB1 (prd-version: 1.5.1.0-t194-41334769-59d8a47d)
[0000.109] I> Boot-mode: Coldboot
[0000.112] I> Chip revision : A02
[0000.115] I> Bootrom patch version : 7 (correctly patched)
[0000.120] I> ATE fuse revision : 0x200
[0000.123] I> Ram repair fuse : 0x0
[0000.126] I> Ram Code : 0x0
[0000.129] I> rst_source : 0x0
[0000.132] I> rst_level : 0x0
[0000.135] I> Boot-device: eMMC
[0000.138] W> DEVICE_PROD: device prod is not initialized.
[0000.143] W> DEVICE_PROD: device prod is not initialized.
[0000.160] I> sdmmc DDR50 mode
[0000.164] W> DEVICE_PROD: device prod is not initialized.
[0000.169] W> No valid slot number is found in scratch register
[0000.175] W> Return default slot: _a
[0000.178] I> Active Boot chain : 0
[0000.181] I> Boot-device: eMMC
[0000.185] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.191] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0000.198] I> Temperature = 28000
[0000.201] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.206] W> Skipping boost for clk: BPMP_APB
[0000.210] W> Skipping boost for clk: AXI_CBB
[0000.214] W> Skipping boost for clk: AON_CPU_NIC
[0000.218] W> Skipping boost for clk: CAN1
[0000.222] W> Skipping boost for clk: CAN2
[0000.226] I> Boot-device: eMMC
[0000.229] I> Boot-device: eMMC
[0000.238] I> Sdmmc: HS400 mode enabled
[0000.243] I> ECC region[0]: Start:0x0, End:0x0
[0000.247] I> ECC region[1]: Start:0x0, End:0x0
[0000.251] I> ECC region[2]: Start:0x0, End:0x0
[0000.255] I> ECC region[3]: Start:0x0, End:0x0
[0000.259] I> ECC region[4]: Start:0x0, End:0x0
[0000.263] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.269] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.274] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.278] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.282] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.288] W> MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.295] E> FAILED: Thermal config
[0000.298] W> DEVICE_PROD: device prod is not initialized.
[0000.307] W> MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.314] E> FAILED: MEMIO rail config
[0000.326] I> scrub mode: full dram
[0000.329] E> FUSE: Failed to verify ECID.
[0000.333] I> Boot-device: eMMC
[0000.342] I> sdmmc bdev is already initialized
[0000.380] W> No fuse-bypass data
[0000.387] W> MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.420] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.428] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-28aef4f2)
[0000.429] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.429] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.430] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.436] W> device prod register failed
[0000.440] I> Boot-device: eMMC
[0000.443] I> Boot_device: SDMMC_BOOT instance: 3
[0000.449] I> sdmmc-3 params source = boot args
[0000.451] I> sdmmc bdev is already initialized
[0000.456] I> sdmmc-3 params source = boot args
[0000.462] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0000.469] I> Found 37 partitions in SDMMC_USER (instance 3)
[0000.471] W> No valid slot number is found in scratch register
[0000.477] W> Return default slot: _a
[0000.480] I> Active Boot chain : 0
[0000.484] I> parsing oem signed section of bpmp-fw header done
[0000.489] I> bpmp-fw binary init read from storage
[0000.494] I> oem authentication of bpmp-fw header done
[0000.500] I> bpmp-fw binary done read from storage
[0000.503] I> bpmp-fw: Authentication init Done
[0000.508] I> parsing oem signed section of cpubl header done
[0000.513] I> cpubl binary init read from storage
[0000.518] I> bpmp-fw: Authentication Finalize Done
[0000.522] I> oem authentication of cpubl header done
[0000.527] I> cpubl binary done read from storage
[0000.531] I> cpubl: Authentication init Done
[0000.536] I> parsing oem signed section of rce header done
[0000.541] I> rce binary init read from storage
[0000.545] I> Relocating BR-BCT
[0000.548] I> cpubl: Authentication Finalize Done
[0000.553] I> oem authentication of rce header done
[0000.557] I> rce binary done read from storage
[0000.561] I> rce: Authentication init Done
[0000.566] I> parsing oem signed section of tos header done
[0000.571] I> tos binary init read from storage
[0000.575] I> rce: Authentication Finalize Done
[0000.580] I> oem authentication of tos header done
[0000.584] I> tos binary done read from storage
[0000.588] I> tos: Authentication init Done
[0000.592] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.598] I> bpmp-fw-dtb binary init read from storage
[0000.603] I> tos: Authentication Finalize Done
[0000.609] I> oem authentication of bpmp-fw-dtb header done
[0000.616] I> bpmp-fw-dtb binary done read from storage
[0000.618] I> bpmp-fw-dtb: Authentication init Done
[0000.623] I> parsing oem signed section of cpubl-dtb header done
[0000.628] I> cpubl-dtb binary init read from storage
[0000.633] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.671] I> oem authentication of cpubl-dtb header done
[0000.672] I> cpubl-dtb binary done read from storage
[0000.672] I> cpubl-dtb: Authentication init Done
[0000.674] I> parsing oem signed section of eks header done
[0000.675] I> eks binary init read from storage
[0000.675] I> cpubl-dtb: Authentication Finalize Done
[0000.676] I> oem authentication of eks header done
[0000.680] I> eks binary done read from storage
[0000.684] I> eks: Authentication init Done
[0000.688] I> eks: Authentication Finalize Done
[0000.692] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 16:56:20, Jul 16 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea88ed58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is c1b4e372932429f2737cf722e1219e71
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg initialized
mrq initialized
[0001.167] I> Welcome to Cboot
��fmon_post initialized
��[0001.167] I> Cboot Version: t194-fd5a836a
[0001.167] I> CPU-BL Params @ 0xea820000
[0001.168] I> 0) Base:0x00000000 Size:0x00000000
[0001.168] I> 1) Base:0xe9100000 Size:0x00100000
[0001.173] I> 2) Base:0xea000000 Size:0x00200000
[0001.177] I> 3) Base:0xe9200000 Size:0x00200000
[0001.182] I> 4) Base:0xe9000000 Size:0x00100000
[0001.186] I> 5) Base:0xe8f00000 Size:0x00100000
[0001.191] I> 6) Base:0xeb800000 Size:0x00400000
[0001.195] I> 7) Base:0xe9c00000 Size:0x00400000
��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.200] I> 8) Base:0xe8e00000 Size:0x00100000
[0001.269] I> 9) Base:0xe8d00000 Size:0x00100000
[0001.273] I> 10) Base:0xeb000000 Size:0x00800000
[0001.278] I> 11) Base:0x40000000 Size:0x00040000
[0001.282] I> 12) Base:0xe8c00000 Size:0x00100000
[0001.287] I> 13) Base:0x40046000 Size:0x00002000
[0001.291] I> 14) Base:0x40048000 Size:0x00002000
[0001.296] I> 15) Base:0xab000000 Size:0x00004000
[0001.300] I> 16) Base:0x4004a000 Size:0x00002000
[0001.305] I> 17) Base:0xe8b00000 Size:0x00100000
[0001.309] I> 18) Base:0x4004c000 Size:0x00002000
[0001.314] I> 19) Base:0xea200000 Size:0x00600000
[0001.318] I> 20) Base:0x4004e000 Size:0x00002000
[0001.323] I> 21) Base:0xe8ad0000 Size:0x0000c000
��emc_debugfs initialized
dvs_debugfs initialized
��[0001.327] I> 22) Base:0x00000000 Size:0x00000000
��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.336] I> 23) Base:0xe8ae0000 Size:0x00020000
[0001.387] I> 24) Base:0xee000000 Size:0x02000000
[0001.391] I> 25) Base:0x40050000 Size:0x00002000
[0001.396] I> 26) Base:0x40040000 Size:0x00006000
[0001.400] I> 27) Base:0xe9800000 Size:0x00400000
[0001.405] I> 28) Base:0xecc00000 Size:0x01400000
[0001.409] I> 29) Base:0xe9400000 Size:0x00400000
[0001.413] I> 30) Base:0x00000000 Size:0x00000000
[0001.418] I> 31) Base:0x00000000 Size:0x00000000
[0001.422] I> 32) Base:0xf8000000 Size:0x08000000
[0001.427] I> 33) Base:0xf0000000 Size:0x08000000
[0001.431] I> 34) Base:0xebc00000 Size:0x01000000
[0001.436] I> 35) Base:0xaa000000 Size:0x01000000
[0001.440] I> 36) Base:0xa0000000 Size:0x0a000000
[0001.445] I> 37) Base:0xea800000 Size:0x00800000
[0001.449] I> 38) Base:0x80000000 Size:0x20000000
[0001.454] I> 39) Base:0xb0000000 Size:0x08000000
[0001.458] I> 40) Base:0x00000000 Size:0x00000000
[0001.463] I> 41) Base:0x00000000 Size:0x00000000
[0001.467] I> 42) Base:0x00000000 Size:0x00000000
[0001.471] I> 43) Base:0x00000000 Size:0x00000000
[0001.476] I> 44) Base:0x00000000 Size:0x00000000
[0001.480] I> 45) Base:0x00000000 Size:0x00000000
[0001.485] GIC-SPI Target CPU: 0
[0001.488] Interrupts Init done
[0001.491] calling constructors
[0001.494] initializing heap
[0001.496] I> Heap: [0xa068d470 ... 0xaa000000]
[0001.501] initializing threads
[0001.503] initializing timers
[0001.506] creating bootstrap completion thread
[0001.511] top of bootstrap2()
[0001.513] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.518] initializing platform
[0001.521] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.526] W> device prod register failed
[0001.530] I> Bl_dtb @0xa9f00000
[0001.533] I> gpio framework initialized
[0001.544] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.551] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.552] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.565] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.571] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.574] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.580] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.590] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.597] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.601] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.612] I> fixed regulator driver initialized
[0001.636] I> register 'maxim' power off handle
[0001.638] I> virtual i2c enabled
[0001.638] I> registered 'maxim,max20024' pmic
[0001.639] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.639] I> Boot-device: eMMC
[0001.640] I> Boot_device: SDMMC_BOOT instance: 3
[0001.642] I> sdmmc-3 params source = boot args
[0001.642] I> sdmmc bdev is already initialized
[0001.646] I> sdmmc-3 params source = boot args
[0001.652] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0001.658] I> Found 37 partitions in SDMMC_USER (instance 3)
[0001.663] E> "plugin-manager" doesn't exist, creating
[0001.666] E> "ids" doesn't exist, creating
[0001.671] E> "connection" doesn't exist, creating
[0001.675] E> "configs" doesn't exist, creating
[0001.682] I> Find /i2c@3160000's alias i2c0
[0001.683] I> Reading eeprom i2c=0 address=0x50
[0001.712] I> Device at /i2c@3160000:0x50
[0001.713] I> Reading eeprom i2c=0 address=0x56
[0001.737] I> Device at /i2c@3160000:0x56
[0001.738] I> Find /i2c@3180000's alias i2c2
[0001.739] I> Reading eeprom i2c=2 address=0x54
[0001.741] E> I2C: slave not found in slaves.
[0001.741] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.742] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.742] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.751] E> eeprom: Failed to read I2C slave device
[0001.756] I> Eeprom read failed 0x3526070d
[0001.760] I> Reading eeprom i2c=2 address=0x57
[0001.764] E> I2C: slave not found in slaves.
[0001.768] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.776] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.782] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.791] E> eeprom: Failed to read I2C slave device
[0001.796] I> Eeprom read failed 0x3526070d
[0001.800] I> Reading eeprom i2c=2 address=0x52
[0001.805] E> I2C: slave not found in slaves.
[0001.808] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.816] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.822] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.831] E> eeprom: Failed to read I2C slave device
[0001.836] I> Eeprom read failed 0x3526070d
[0001.841] I> Find /i2c@c240000's alias i2c1
[0001.844] I> Reading eeprom i2c=1 address=0x52
[0001.850] E> I2C: slave not found in slaves.
[0001.853] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.861] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.866] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.876] E> eeprom: Retry to read I2C slave device.
[0001.880] E> I2C: slave not found in slaves.
[0001.884] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.892] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.898] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.907] E> eeprom: Failed to read I2C slave device
[0001.912] I> Eeprom read failed 0x3526070d
[0001.916] I> Reading eeprom i2c=1 address=0x50
[0001.921] E> I2C: slave not found in slaves.
[0001.925] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.932] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.938] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.947] E> eeprom: Retry to read I2C slave device.
[0001.952] E> I2C: slave not found in slaves.
[0001.956] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.964] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.970] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.979] E> eeprom: Failed to read I2C slave device
[0001.984] I> Eeprom read failed 0x3526070d
[0001.988] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0001.993] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.004] I> create_pm_ids: id: 2822-0000-600-D, len: 15
[0002.009] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.020] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0002.028] E> "i2c@3160000" doesn't exist, creating
[0002.032] E> "module@0x50" doesn't exist, creating
[0002.037] I> Adding plugin-manager/ids/2822-0000-600=/i2c@3160000:module@0x56
[0002.044] E> "module@0x56" doesn't exist, creating
[0002.050] I> Adding plugin-manager/cvm
[0002.052] E> "chip-id" doesn't exist, creating
[0002.056] I> Adding plugin-manager/chip-id/A02
[0002.061] I> Plugin-manager override starting
[0002.066] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.074] I> node /plugin-manager/fragement-soft-wdt matches
[0002.081] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.085] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.092] I> node /plugin-manager/fragment-p2888@0 matches
[0002.106] I> Disable plugin-manager status in FDT
[0002.106] I> Plugin-manager override finished successfully
[0002.117] I> enabling 'vdd-hdmi-5v0' regulator
[0002.122] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.122] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.123] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.129] E> invalid display type
[0002.134] E> invalid display type
[0002.135] E> cannot find any other nvdisp nodes
[0002.136] E> no valid display unit config found in dtb
[0002.142] W> display init failed
[0002.144] I> Load in CBoot Boot Options partition and parse it
[0002.151] E> Error -9 when finding node with path /boot-configuration
[0002.156] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.163] I> Hit any key to stop autoboot: 4 3 2 1
[0004.171] initializing target
[0004.171] calling apps_init()
[0004.172] starting app kernel_boot_app
[0004.175] I> found decompressor handler: lz4-legacy
[0004.176] I> decompressing BMP blob ...
[0004.180] I> Kernel type = Normal
[0004.181] I> Loading kernel & kernel-dtb from removable storage (5)
[0004.181] I> No sdcard
[0004.181] I> -0 params source =
[0004.182] E> Blockdev open: exit error
[0004.182] I> Loading kernel & kernel-dtb from removable storage (6)
[0004.193] W> No valid slot number is found in scratch register
[0004.193] W> Return default slot: _a
[0004.198] I> USB Firmware Version: 60.05 release
[0004.653] E> failed to initialize xhci controller
[0004.654] E> Error in init of XUSB host driver, err: 79790026
[0004.654] W> Failed to initialize device 6-0
[0004.654] I> Loading kernel from partition ...
[0004.655] W> No valid slot number is found in scratch register
[0004.655] W> Return default slot: _a
[0004.656] I> A/B: bin_type (37) slot 0
[0004.659] I> Loading partition kernel at 0xa42d0000 from device(0x1)
[0005.044] I> T19x: Authenticate kernel (bin_type: 37), max size 0x4000000
[0005.425] I> Loading kernel-dtb from partition ...
[0005.426] W> No valid slot number is found in scratch register
[0005.426] W> Return default slot: _a
[0005.426] I> A/B: bin_type (38) slot 0
[0005.427] I> Loading partition kernel-dtb at 0x90000000 from device(0x1)
[0005.431] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0005.435] I> Kernel hdr @0xa42d0000
[0005.436] I> Kernel dtb @0x90000000
[0005.438] I> Checking boot.img header magic ... [0005.442] I> [OK]
[0005.444] I> Valid boot.img @ 0xa42d0000
[0005.447] I> decompressor handler not found
[0005.452] I> Copying kernel image (34310152 bytes) from 0xa42d0800 to 0x80080000 ... [0005.466] I> Done
[0005.466] I> Move ramdisk (len: 5564673) from 0xa6389800 to 0x91000000
[0005.469] I> Updated bpmp info to DTB
[0005.472] I> Ramdisk: Base: 0x91000000; Size: 0x54e901
[0005.476] I> Updated initrd info to DTB
[0005.479] W> WARN: Fail to override "console=none" in commandline
[0005.485] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0005.493] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0005.500] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0005.507] W> No valid slot number is found in scratch register
[0005.513] W> Return default slot: _a
[0005.516] I> Active slot suffix:
[0005.519] I> add_boot_slot_suffix: slot_suffix =
[0005.524] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[0005.559] I> Updated bootarg info to DTB
[0005.563] W> MAC addr invalid!
[0005.565] E> Failed to get WIFI MAC address
[0005.569] W> MAC addr invalid!
[0005.572] E> Failed to get Bluetooth MAC address
[0005.577] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:a6:8c
[0005.584] E> "plugin-manager" doesn't exist, creating
[0005.588] I> Adding /chosen/plugin-manager/cvm
[0005.592] E> "chip-id" doesn't exist, creating
[0005.596] I> Adding /chosen/plugin-manager/chip-id
[0005.601] E> "configs" doesn't exist, creating
[0005.605] I> Adding /chosen/plugin-manager/configs
[0005.610] E> "ids" doesn't exist, creating
[0005.614] I> Adding /chosen/plugin-manager/ids
[0005.619] E> "odm-data" doesn't exist, creating
[0005.623] I> Adding /chosen/plugin-manager/odm-data
[0005.631] E> "memory" doesn't exist, creating
[0005.632] I> [0] START: 0x80000000, END: 0xab000000
[0005.636] I> [1] START: 0xab004000, END: 0xe8ad0000
[0005.641] I> [2] START: 0xe8adc000, END: 0xe8ae0000
[0005.646] I> dram_block larger than 80000000
[0005.650] I> [3] START: 0x100000000, END: 0x480000000
[0005.655] I> added [base:0x80000000, size:0x2b000000] to /memory
[0005.660] I> added [base:0xab200000, size:0x3d800000] to /memory
[0005.666] I> added [base:0x100000000, size:0x380000000] to /memory
[0005.674] I> Updated memory info to DTB
[0005.676] E> add_disp_param: failed to get display params for du=0
[0005.683] E> "reset" doesn't exist, creating
[0005.687] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0005.691] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0005.696] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0005.700] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0005.705] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0005.710] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0005.715] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0005.719] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0005.724] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0005.729] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0005.734] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0005.739] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0005.744] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0005.748] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0005.753] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0005.758] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0005.764] E> "misc-data" doesn't exist, creating
[0005.767] I> Boot-device: eMMC
[0005.770] I> Add boot-sdmmc to plugin-manager/misc-data
[0005.775] I> Add storage-sdmmc to plugin-manager/misc-data
[0005.781] W> Unknown storage device
[0005.784] I> Add serial number:0423418049866 as DT property
[0005.791] I> Plugin-manager override starting
[0005.794] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0005.801] I> node /plugin-manager/fragement-soft-wdt matches
[0005.809] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0005.813] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0005.821] I> node /plugin-manager/fragment-p2888@0 matches
[0005.832] I> Disable plugin-manager status in FDT
[0005.833] I> Plugin-manager override finished successfully
[0005.833] I> tegrabl_load_kernel_and_dtb: Done
[0005.837] E> tegrabl_display_clear: display is not initialized
[0005.842] W> Boot logo display failed...
[0005.846] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-xxx+ (root@excalibur) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Mar 10 15:06:01 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2b000000
[ 0.000000] OF: fdt: - ab200000 , 3d800000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found vpr, start=0xf0000000 size=8000000[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc3ffd99000 s61592 r8192 d32616 u102400
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4033512
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29124(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15995212K/16390144K available (15230K kernel code, 2914K rwdata, 6724K rodata, 8576K init, 609K bss, 329396K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff8009600000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a138808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a138808 - 0xffffff800a1d0dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000007] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009098] Console: colour dummy device 80x25
[ 0.012428] console [tty0] enabled
[ 0.015638] bootconsole [tegra_comb_uart0] disabled
<hit enter to activate fiq debugger>
[ 0.020628] kmemleak: Kernel memory leak detector disabled
[ 0.020703] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.020770] pid_max: default: 32768 minimum: 301
[ 0.022171] Security Framework initialized
[ 0.022917] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.022981] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025372] ftrace: allocating 46936 entries in 184 pages
[ 0.494222] sched-energy: Sched-energy-costs installed from DT
[ 0.494317] ASID allocator initialised with 65536 entries
[ 0.534864] tegra-id: chipid=21917.
[ 0.534935] tegra-id: opt_subrevision=0.
[ 0.535011] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.535099] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.535154] DTB Build time: Mar 10 2020 15:14:26
[ 0.583317] CPU1: Booted secondary processor [4e0f0040]
[ 0.615399] CPU2: Booted secondary processor [4e0f0040]
[ 0.647906] CPU3: Booted secondary processor [4e0f0040]
[ 0.680121] CPU4: Booted secondary processor [4e0f0040]
[ 0.712416] CPU5: Booted secondary processor [4e0f0040]
[ 0.744863] CPU6: Booted secondary processor [4e0f0040]
[ 0.776985] CPU7: Booted secondary processor [4e0f0040]
[ 0.777317] Brought up 8 CPUs
[ 0.777670] SMP: Total of 8 processors activated.
[ 0.777710] CPU features: detected feature: Privileged Access Never
[ 0.777760] CPU features: detected feature: LSE atomic instructions
[ 0.777798] CPU features: detected feature: User Access Override
[ 0.777846] CPU features: detected feature: 32-bit EL0 Support
[ 0.780529] CPU: All CPU(s) started at EL2
[ 0.780648] alternatives: patching kernel code
[ 0.791284] devtmpfs: initialized
[ 0.879773] Initilizing CustomIPI irq domain
[ 0.880238] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.880323] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.882256] pinctrl core: initialized pinctrl subsystem
[ 0.882720] OS set in device tree is not L4T.
[ 0.883049] regulator-dummy: no parameters
[ 0.883344] Initializing plugin-manager
[ 0.883503] Plugin module not found
[ 0.883599] Plugin-manager status disabled
[ 0.885215] NET: Registered protocol family 16
[ 0.888003] pstore: using zlib compression
[ 0.889243] console [pstore-1] enabled
[ 0.889286] pstore: Registered ramoops as persistent store backend
[ 0.889340] ramoops: attached 0x200000@0xe8800000, ecc: 0/0
[ 0.907734] cpuidle: using governor menu
[ 0.909282] bpmp: waiting for handshake
[ 0.909356] bpmp: handshake completed
[ 0.909450] bpmp: synchronizing channels
[ 0.909496] bpmp: channels synchronized
[ 0.909538] bpmp: mail init ok
[ 0.913540] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.913871] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.914012] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.914064] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.914117] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.914168] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.914221] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.914294] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.914373] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.914431] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.914488] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.919538] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e64000)
[ 0.919957] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.924534] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.925956] Registering BPMP clocks...
[ 0.926178] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.927376] tegra_powergate_init: DONE
[ 0.927530] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.927693] DTB Build time: Mar 10 2020 15:14:26
[ 0.931855] Tegra reboot handler registered.
[ 0.941894] iommu: Adding device 14180000.pcie to group 0
[ 0.942927] iommu: Adding device 14100000.pcie to group 1
[ 0.943952] iommu: Adding device 14140000.pcie to group 2
[ 0.944952] iommu: Adding device 141a0000.pcie to group 3
[ 0.947189] iommu: Adding device 2490000.ether_qos to group 4
[ 0.947945] iommu: Adding device 3100000.serial to group 5
[ 0.948736] iommu: Adding device 3110000.serial to group 6
[ 0.949323] iommu: Adding device 3140000.serial to group 7
[ 0.950141] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.950433] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.950527] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.950592] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.950657] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.950797] tegra-pmc: PMC Prod config success
[ 0.951170] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.951278] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.951882] iommu: Adding device 3460000.sdhci to group 8
[ 0.952770] iommu: Adding device 3400000.sdhci to group 9
[ 0.953538] iommu: Adding device 2450000.ufshci to group 10
[ 0.954334] iommu: Adding device c260000.spi to group 11
[ 0.955629] iommu: Adding device 3160000.i2c to group 12
[ 0.956190] iommu: Adding device c240000.i2c to group 13
[ 0.956852] iommu: Adding device 3180000.i2c to group 14
[ 0.957437] iommu: Adding device 3190000.i2c to group 15
[ 0.958234] iommu: Adding device 31b0000.i2c to group 16
[ 0.958847] iommu: Adding device 31c0000.i2c to group 17
[ 0.959464] iommu: Adding device c250000.i2c to group 18
[ 0.960090] iommu: Adding device 31e0000.i2c to group 19
[ 0.961283] iommu: Adding device sound to group 20
[ 0.962033] iommu: Adding device 3510000.hda to group 21
[ 0.962842] iommu: Adding device bc00000.rtcpu to group 22
[ 0.965755] iommu: Adding device 13e10000.host1x to group 23
[ 0.966551] iommu: Adding device 13e10000.host1x:ctx0 to group 24
[ 0.967516] iommu: Adding device 13e10000.host1x:ctx1 to group 25
[ 0.968212] iommu: Adding device 13e10000.host1x:ctx2 to group 26
[ 0.968841] iommu: Adding device 13e10000.host1x:ctx3 to group 27
[ 0.969489] iommu: Adding device 13e10000.host1x:ctx4 to group 28
[ 0.970081] iommu: Adding device 13e10000.host1x:ctx5 to group 29
[ 0.970769] iommu: Adding device 13e10000.host1x:ctx6 to group 30
[ 0.971426] iommu: Adding device 13e10000.host1x:ctx7 to group 31
[ 0.972272] iommu: Adding device 15340000.vic to group 32
[ 0.972902] iommu: Adding device 15380000.nvjpg to group 33
[ 0.973359] iommu: Adding device 15500000.tsec to group 34
[ 0.973814] iommu: Adding device 15100000.tsecb to group 35
[ 0.974309] iommu: Adding device 15480000.nvdec to group 36
[ 0.974775] iommu: Adding device 15140000.nvdec1 to group 37
[ 0.975213] iommu: Adding device 154c0000.nvenc to group 38
[ 0.975697] iommu: Adding device 15a80000.nvenc1 to group 39
[ 0.976284] iommu: Adding device 15880000.nvdla0 to group 40
[ 0.976923] iommu: Adding device 158c0000.nvdla1 to group 41
[ 0.977800] iommu: Adding device 15200000.nvdisplay to group 42
[ 0.979648] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 0.979740] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.980399] iommu: Adding device 15210000.nvdisplay to group 43
[ 0.980536] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.981221] iommu: Adding device 15220000.nvdisplay to group 44
[ 0.981338] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.984165] iommu: Adding device 15c10000.vi to group 45
[ 0.984476] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.985114] iommu: Adding device 14800000.isp to group 46
[ 0.986993] iommu: Adding device 16000000.pva0 to group 47
[ 0.987851] iommu: Adding device 16800000.pva1 to group 48
[ 0.988509] iommu: Adding device 15810000.se to group 49
[ 0.989214] iommu: Adding device 15820000.se to group 50
[ 0.989630] iommu: Adding device 15830000.se to group 51
[ 0.990087] iommu: Adding device 15840000.se to group 52
[ 0.990492] iommu: Adding device c1a0000.aon to group 53
[ 0.992757] iommu: Adding device d000000.bpmp to group 54
[ 0.993364] bpmp: ping status is 0
[ 0.993556] bpmp d000000.bpmp: firmware tag is c1b4e372932429f2737cf722e1219e71
[ 0.997784] bpmp d000000.bpmp: probe ok
[ 0.999903] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 1.000611] iommu: Adding device smmu_test to group 55
[ 1.002151] mc: mapped MMIO address: 0xffffff800a590000 -> 0x2c10000
[ 1.002253] mc: mapped MMIO address: 0xffffff800a5b0000 -> 0x2c20000
[ 1.002348] mc: mapped MMIO address: 0xffffff800a5d0000 -> 0x2c30000
[ 1.002443] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 1.002536] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 1.002642] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b80000
[ 1.002765] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b90000
[ 1.002912] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2ba0000
[ 1.003006] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2bb0000
[ 1.003100] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1700000
[ 1.003192] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1710000
[ 1.003290] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1720000
[ 1.003386] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1730000
[ 1.003479] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1740000
[ 1.003572] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1750000
[ 1.003665] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1760000
[ 1.003786] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1770000
[ 1.004003] mc-err: mcerr ops are set to t19x
[ 1.011919] iommu: Adding device 2600000.dma to group 56
[ 1.019039] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 1.019160] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 1.019268] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.019855] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.029591] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.030313] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.033668] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.033747] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.034799] iommu: Adding device 3550000.xudc to group 57
[ 1.035802] iommu: Adding device 3610000.xhci to group 58
[ 1.038871] arm64_ras arm64_ras: probed
[ 1.039501] ras_fhi_enable: FHI 477 enabled on CPU0
[ 1.039617] ras_fhi_enable: FHI 478 enabled on CPU1
[ 1.039783] ras_fhi_enable: FHI 479 enabled on CPU2
[ 1.039936] ras_fhi_enable: FHI 480 enabled on CPU3
[ 1.040097] ras_fhi_enable: FHI 481 enabled on CPU4
[ 1.040243] ras_fhi_enable: FHI 482 enabled on CPU5
[ 1.040388] ras_fhi_enable: FHI 483 enabled on CPU6
[ 1.040532] ras_fhi_enable: FHI 484 enabled on CPU7
[ 1.040856] carmel_ras_enable: RAS enabled on cpu0
[ 1.041195] carmel_ras_enable: RAS enabled on cpu1
[ 1.041517] carmel_ras_enable: RAS enabled on cpu2
[ 1.041892] carmel_ras_enable: RAS enabled on cpu3
[ 1.042244] carmel_ras_enable: RAS enabled on cpu4
[ 1.042521] carmel_ras_enable: RAS enabled on cpu5
[ 1.042866] carmel_ras_enable: RAS enabled on cpu6
[ 1.043215] carmel_ras_enable: RAS enabled on cpu7
[ 1.043492] carmel_ras carmel_ras: probed
[ 1.045221] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.046144] tegra-cbb c600000.aon-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.047385] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 1.048633] tegra-cbb be00000.rce-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[ 1.050116] tegra-cbb b600000.sce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
[ 1.050890] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.054828] vdd-3v3-cvb: 3300 mV
[ 1.055381] vdd-1v8-cvb: 1800 mV
[ 1.055957] vdd-1v8-sd: 1800 mV
[ 1.056604] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.056718] vdd-epb-1v0: 1000 mV
[ 1.057266] vdd-sdmmc1-sw: 3300 mV
[ 1.057811] avdd-cam-2v8: 2800 mV
[ 1.058324] vdd-sata-1v5: 1500 mV
[ 1.058823] vdd-1v8-slt: 1800 mV
[ 1.059355] vdd-3v3-slt: 3300 mV
[ 1.059834] vdd-fan: 5000 mV
[ 1.060404] vdd-hdmi-5v0: 5000 mV
[ 1.060985] vdd_sys_en: 1200 mV
[ 1.061656] vdd-5v-sata: 5000 mV
[ 1.062195] vdd-ac-bat: 5000 mV
[ 1.062504] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.102096] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.107967] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.108536] SCSI subsystem initialized
[ 1.109382] usbcore: registered new interface driver usbfs
[ 1.109556] usbcore: registered new interface driver hub
[ 1.109760] usbcore: registered new device driver usb
[ 1.123220] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.126521] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.134220] vdd-1v0: at 1000 mV
[ 1.138290] vdd-1v8-hs: at 1800 mV
[ 1.142352] vdd-1v8-ls: at 1800 mV
[ 1.146413] vdd-1v8-ao: at 1800 mV
[ 1.150436] vddio-ddr-1v1: at 1100 mV
[ 1.154255] vdd-rtc: at 800 mV
[ 1.155776] spmic-ldo1: at 2375 mV
[ 1.162373] vdd-ao-3v3: at 3300 mV
[ 1.170465] vddio-emmc-3v3: at 3300 mV
[ 1.172101] spmic-ldo4: at 1587 mV
[ 1.178527] vdd-usb-3v3: at 3300 mV
[ 1.186573] vddio-sdmmc1-3v3: at 3300 mV
[ 1.193705] vdd-csi-1v2: at 1200 mV
[ 1.195518] spmic-ldo8: at 1800 mV
[ 1.197830] GPIO line 246 (gpio_default) hogged as output/high
[ 1.199545] GPIO line 247 (gpio_default) hogged as output/high
[ 1.200121] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.203891] max77620 4-003c: max77620 probe successful
[ 1.204697] media: Linux media interface: v0.10
[ 1.204836] Linux video capture interface: v2.00
[ 1.206558] pps_core: LinuxPPS API ver. 1 registered
[ 1.206638] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.206789] PTP clock support registered
[ 1.207486] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.207615] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.209433] tegra_fiq_debugger_init: found FIQ source (IRQ 469)
[ 1.213101] trusty trusty: trusty version: Built: 16:57:18 Jul 16 2019
[ 1.213274] trusty trusty: selected api version: 3 (requested 3)
[ 1.214706] Advanced Linux Sound Architecture Driver Initialized.
[ 1.215495] Bluetooth: Core ver 2.22
[ 1.215606] NET: Registered protocol family 31
[ 1.215667] Bluetooth: HCI device and connection manager initialized
[ 1.215769] Bluetooth: HCI socket layer initialized
[ 1.215846] Bluetooth: L2CAP socket layer initialized
[ 1.215935] Bluetooth: SCO socket layer initialized
[ 1.219250] camchar: rtcpu character device driver loaded
[ 1.220683] clocksource: Switched to clocksource arch_sys_counter
[ 1.273413] VFS: Disk quotas dquot_6.6.0
[ 1.273689] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.274225] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.276103] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.276286] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 1.276417] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.276516] nvmap_page_pool_init: Total RAM pages: 4015187
[ 1.276583] nvmap_page_pool_init: nvmap page pool size: 501898 pages (1960 MB)
[ 1.276955] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.277509] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 1.279785] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.297159] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.297672] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.298101] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.298466] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.299035] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.299408] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.299669] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.301328] la/ptsa driver initialized.
[ 1.301996] NET: Registered protocol family 2
[ 1.303508] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.304430] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.305306] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.305459] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.305823] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.306626] NET: Registered protocol family 1
[ 1.307698] RPC: Registered named UNIX socket transport module.
[ 1.307804] RPC: Registered udp transport module.
[ 1.307863] RPC: Registered tcp transport module.
[ 1.307922] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.308318] Trying to unpack rootfs image as initramfs...
[ 1.546001] Freeing initrd memory: 5432K
[ 1.567776] random: fast init done
[ 1.573724] host1x 13e10000.host1x: initialized
[ 1.576597] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.582737] audit: initializing netlink subsys (disabled)
[ 1.582840] audit: type=2000 audit(1.132:1): initialized
[ 1.583912] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.596015] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.597825] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.598712] 9p: Installing v9fs 9p2000 file system support
[ 1.605632] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.605964] io scheduler noop registered
[ 1.606318] io scheduler cfq registered (default)
[ 1.610658] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.651267] iommu: Adding device 2993000.adsp to group 59
[ 1.753317] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[ 1.754331] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.772045] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.772739] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.773694] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.774239] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.777508] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.777834] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.777913] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.782523] tsec 15500000.tsec: initialized
[ 1.785139] tsec 15100000.tsecb: initialized
[ 1.790791] nvdec 15480000.nvdec: initialized
[ 1.794332] nvdec 15140000.nvdec1: initialized
[ 1.801175] falcon 15340000.vic: initialized
[ 1.803378] falcon 15380000.nvjpg: initialized
[ 1.805613] falcon 154c0000.nvenc: initialized
[ 1.807873] falcon 15a80000.nvenc1: initialized
[ 1.812361] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.816316] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.818924] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.820849] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.822730] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.824781] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.826704] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.828595] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.833159] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.839324] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.839766] scare-pigeon 14b00000.isp-thi: initialized
[ 1.850052] pva 16000000.pva0: initialized
[ 1.882258] pva 16800000.pva1: initialized
[ 1.913465] nvdla 15880000.nvdla0: initialized
[ 1.944000] nvdla 158c0000.nvdla1: initialized
[ 1.948079] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.948287] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.948337] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.948390] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.949625] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.949687] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.949785] tegradccommon 15200000.dc_common: dma mapping done
[ 1.951243] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.951367] generic_infoframe_type: 0x87
[ 1.951540] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.951630] tegradc 15200000.nvdisplay: Display dc.ffffff800bd90000 registered with id=0
[ 1.956709] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.956778] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.956836] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.957111] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.957161] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.962150] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.962225] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.966659] tegradc 15200000.nvdisplay: probed
[ 1.967008] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.968056] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.968764] kfuse 3830000.kfuse: initialized
[ 1.978447] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.983151] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.985289] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.986705] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.459930] console [ttyTCU0] enabled
[ 4.460469] [drm] Initialized
[ 4.460786] Console: switching to colour frame buffer device 80x30
[ 4.472483] tegradc 15200000.nvdisplay: fb registered
[ 4.478386] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.484451] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 4.489951] brd: module loaded
[ 4.490312] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 4.506620] loop: module loaded
[ 4.506869] tegra_profiler: version: 1.134, samples/io: 47/26
[ 4.508285] tegra_profiler: auth: init
[ 4.512309] nct1008_nct72 4-004c: starting parse dt
[ 4.512645] THERMAL EST: found 3 subdevs
[ 4.512702] THERMAL EST num_resources: 0
[ 4.512717] [THERMAL EST subdev 0]
[ 4.512728] [THERMAL EST subdev 1]
[ 4.512737] [THERMAL EST subdev 2]
[ 4.512753] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.513169] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.513176] THERMAL EST: thz register success.
[ 4.513371] THERMAL EST: end of probe, return err: 0
[ 4.514401] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.514413] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.516989] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 459
[ 4.517008] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.588449] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.594735] nct1008_nct72 4-004c: success parsing dt
[ 4.599620] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.614715] scsi host0: ufshcd
[ 4.625601] hisi_sas: driver version v1.6
[ 4.632860] libphy: Fixed MDIO Bus: probed
[ 4.633600] tun: Universal TUN/TAP device driver, 1.6
[ 4.633730] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.634889] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.635054] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.638621] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 4.639638] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 4.651881] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.658467] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.664406] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.672233] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.673003] nct1008_nct72 4-004c: initial LOC temp: 31000
[ 4.673524] nct1008_nct72 4-004c: initial EXT temp: 43500
[ 4.674618] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 4.675664] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 4.699175] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.705996] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.717388] eqos 2490000.ether_qos: Setting local MAC: xxxxxx
[ 4.717671] libphy: dwc_phy: probed
[ 4.725258] PPP generic driver version 2.4.2
[ 4.725939] PPP BSD Compression module registered
[ 4.730275] PPP Deflate Compression module registered
[ 4.735520] PPP MPPE Compression module registered
[ 4.740490] NET: Registered protocol family 24
[ 4.744718] usbcore: registered new interface driver r8152
[ 4.750432] usbcore: registered new interface driver asix
[ 4.755762] usbcore: registered new interface driver ax88179_178a
[ 4.761979] usbcore: registered new interface driver cdc_ether
[ 4.767940] usbcore: registered new interface driver net1080
[ 4.773611] usbcore: registered new interface driver cdc_subset
[ 4.779913] usbcore: registered new interface driver zaurus
[ 4.785454] usbcore: registered new interface driver cdc_ncm
[ 4.791616] VFIO - User Level meta-driver version: 0.3
[ 4.798021] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.802475] ehci-pci: EHCI PCI platform driver
[ 4.807052] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.813293] ohci-pci: OHCI PCI platform driver
[ 4.817803] ohci-platform: OHCI generic platform driver
[ 4.830317] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.830455] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 4.837388] Could not get extcon-dev /xhci@3610000:id(0)
[ 4.842821] usbcore: registered new interface driver uas
[ 4.845130] usbcore: registered new interface driver usb-storage
[ 4.850914] usbcore: registered new interface driver usbserial
[ 4.860601] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.862823] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 4.871613] ucsi_ccg 1-0008: FW1 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.874532] ucsi_ccg 1-0008: FW2 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.882407] ucsi_ccg 1-0008: fw_mode: 2
[ 4.885177] ucsi_ccg 1-0008: fw1_invalid: 0
[ 4.889162] ucsi_ccg 1-0008: fw2_invalid: 0
[ 4.893613] ucsi_ccg 1-0008: silicon_id: 0x1f00
[ 4.898514] ucsi_ccg 1-0008: typec-port0 extcon dev created
[ 4.904132] ucsi_ccg 1-0008: typec-port1 extcon dev created
[ 4.909464] ucsi_ccg 1-0008: typec-pd extcon dev created
[ 4.915052] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
[ 4.926126] ucsi_ccg 1-0008: HPI Command Success.
[ 4.928698] ucsi_ccg 1-0008: HPI Command Success.
[ 4.929627] ucsi_ccg 1-0008: ucsi_ccg_init: complete
[ 4.935569] mousedev: PS/2 mouse device common for all mice
[ 4.940550] usbcore: registered new interface driver xpad
[ 5.067625] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 5.069915] Wake73 for irq=42
[ 5.071400] rtc rtc1: alarm rtc device
[ 5.071568] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 5.071750] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 5.072171] i2c /dev entries driver
[ 5.077290] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 5.086395] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 5.141119] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 5.141407] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 5.141593] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 5.141930] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 5.142159] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 5.142349] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 5.142877] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 5.143114] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 5.143290] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 5.143802] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 5.144056] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 5.145846] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 5.156271] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 5.164389] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 5.173336] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 5.182487] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 5.190863] FAN dev name: pwm-fan
[ 5.193311] FAN:gpio request success.
[ 5.197253] FAN: can't find tach_gpio
[ 5.200870] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 5.208205] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 5.213804] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 5.220333] pwm_fan_driver pwm-fan: tach period: 1000
[ 5.226088] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 5.232864] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 5.240570] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 5.248246] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 5.256284] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 5.264033] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 5.271693] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 5.279723] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 5.287345] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 5.295309] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 5.304170] device-mapper: uevent: version 1.0.3
[ 5.308474] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 5.324425] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 5.325918] cpuidle: Initializing cpuidle driver
[ 5.329196] sdhci: Secure Digital Host Controller Interface driver
[ 5.334568] sdhci: Copyright(c) Pierre Ossman
[ 5.338999] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.345861] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 5.355040] CMDQ: cmdq_platfm_init successful
[ 5.357241] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.362980] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 5.370758] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 254
[ 5.378992] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 5.382322] tegra-se-nvhost 15810000.se: initialized
[ 5.387240] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 5.393246] tegra-se-nvhost 15820000.se: initialized
[ 5.398421] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 5.404189] tegra-se-nvhost 15830000.se: initialized
[ 5.409124] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 5.412748] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.424485] tegra-se-nvhost 15840000.se: initialized
[ 5.428763] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 5.431712] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 5.431886] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.432872] usbcore: registered new interface driver usbhid
[ 5.432874] usbhid: USB HID core driver
[ 5.454966] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.468620] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 5.472773] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 5.477902] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 5.483639] denver_knobs_init:MTS_VERSION:45309758
[ 5.488311] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 5.495685] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 5.502630] t19x_cache tegra-cache: probed
[ 5.513201] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 5.514085] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 5.523668] nvpmodel: initialized successfully
[ 5.527244] trusty-virtio trusty:virtio: initializing
[ 5.531544] trusty_ipc virtio0: vring0: va(pa) ffffffc3d90a0000(0) qsz 32 notifyid 1
[ 5.539072] trusty_ipc virtio0: vring1: va(pa) ffffffc3d90a2000(0) qsz 32 notifyid 2
[ 5.542495] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 5.553769] mmc0: periodic cache flush enabled
[ 5.553785] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.554245] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 5.554450] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 5.554675] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 5.554855] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 5.557503] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37
[ 5.602129] trusty-virtio trusty:virtio: initializing done
[ 5.602277] trusty_ipc virtio0: is online
[ 5.612543] tegra-hda 3510000.hda: Override SDO lines to 4
[ 5.616233] usbcore: registered new interface driver snd-usb-audio
[ 5.635563] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 5.635902] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 5.640973] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 5.649789] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 7.438555] gpio tegra-gpio wake12 for gpio=149(S:5)
[ 7.532809] OPE platform probe
[ 7.533059] OPE platform probe successful
[ 7.665019] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 7.665301] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 7.665525] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 7.665756] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 7.665992] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 7.666219] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 7.666433] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 7.666630] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 7.666868] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 7.667071] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 7.667268] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 7.667460] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 7.667655] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 7.667864] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 7.668099] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 7.668339] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 7.668603] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 7.673399] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 7.679387] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 7.685410] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 7.722641] input: tegra-snd-t19x-mobile-rt565x Headset Jack as /devices/sound/sound/card1/input4
[ 7.724014] u32 classifier
[ 7.724098] Actions configured
[ 7.724239] Initializing XFRM netlink socket
[ 7.724689] NET: Registered protocol family 10
[ 7.725402] NET: Registered protocol family 17
[ 7.725511] NET: Registered protocol family 15
[ 7.725632] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 7.736953] Bluetooth: RFCOMM socket layer initialized
[ 7.742103] Bluetooth: RFCOMM ver 1.11
[ 7.745912] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7.751866] Bluetooth: HIDP socket layer initialized
[ 7.756867] 9pnet: Installing 9P2000 support
[ 7.761266] Key type dns_resolver registered
[ 7.765864] Registered cp15_barrier emulation handler
[ 7.770768] Registered setend emulation handler
[ 7.776679] registered taskstats version 1
[ 7.780072] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 7.787386] OF: PCI: host bridge /pcie@14180000 ranges:
[ 7.791628] OF: PCI: IO 0x38100000..0x381fffff -> 0x38100000
[ 7.797636] OF: PCI: MEM 0x1b40000000..0x1bffffffff -> 0x40000000
[ 7.803842] OF: PCI: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 7.920747] tegra-pcie-dw 14180000.pcie: link is up
[ 7.921176] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 7.921323] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 7.921430] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 7.921598] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 7.921781] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 7.922310] iommu: Adding device 0000:00:00.0 to group 61
[ 7.923890] iommu: Adding device 0000:01:00.0 to group 62
[ 7.933711] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[ 7.933877] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[ 7.934092] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 7.934202] pci 0000:00:00.0: bridge window [mem 0x1b40000000-0x1b400fffff]
[ 7.934364] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.934556] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 7.934953] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.937054] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 7.943881] nvme nvme0: pci function 0000:01:00.0
[ 7.948124] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.948380] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 7.949161] OF: PCI: host bridge /pcie@14100000 ranges:
[ 7.949184] OF: PCI: IO 0x30100000..0x301fffff -> 0x30100000
[ 7.949195] OF: PCI: MEM 0x1230000000..0x123fffffff -> 0x40000000
[ 7.949202] OF: PCI: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 8.056759] tegra-pcie-dw 14100000.pcie: link is up
[ 8.057118] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.057282] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.057399] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 8.057573] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 8.057754] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 8.058244] iommu: Adding device 0001:00:00.0 to group 63
[ 8.059738] iommu: Adding device 0001:01:00.0 to group 64
[ 8.069553] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[ 8.069726] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 8.069886] pci 0001:01:00.0: BAR 6: assigned [mem 0x1230000000-0x123000ffff pref]
[ 8.070030] pci 0001:01:00.0: BAR 5: assigned [mem 0x1230010000-0x12300101ff]
[ 8.070216] pci 0001:01:00.0: BAR 4: assigned [io 0x100000-0x10000f]
[ 8.075813] pci 0001:01:00.0: BAR 0: assigned [io 0x100010-0x100017]
[ 8.082276] pci 0001:01:00.0: BAR 2: assigned [io 0x100018-0x10001f]
[ 8.088430] pci 0001:01:00.0: BAR 1: assigned [io 0x100020-0x100023]
[ 8.095313] pci 0001:01:00.0: BAR 3: assigned [io 0x100024-0x100027]
[ 8.101564] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.106728] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 8.113203] pci 0001:00:00.0: bridge window [mem 0x1230000000-0x12300fffff]
[ 8.120498] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.129295] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 8.138054] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.144623] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
[ 8.152170] ahci 0001:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 8.159164] ahci 0001:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 8.167833] scsi host1: ahci
[ 8.169864] ata1: SATA max UDMA/133 abar m512@0x1230010000 port 0x1230010100 irq 819
[ 8.178047] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 8.185134] OF: PCI: host bridge /pcie@14140000 ranges:
[ 8.185152] nvme0n1: p1 p2
[ 8.192532] OF: PCI: IO 0x34100000..0x341fffff -> 0x34100000
[ 8.198418] OF: PCI: MEM 0x12b0000000..0x12bfffffff -> 0x40000000
[ 8.204272] OF: PCI: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 8.492175] ata1: SATA link down (SStatus 0 SControl 300)
[ 8.724562] tegra-pcie-dw 14140000.pcie: link is down
[ 8.724899] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 8.725035] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 8.725149] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 8.725320] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 8.725500] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 8.725962] iommu: Adding device 0003:00:00.0 to group 65
[ 8.726285] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 8.726415] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.726775] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.727497] iommu: Removing device 0003:00:00.0 from group 65
[ 8.728789] tegra-pcie-dw 14140000.pcie: PCIe link is not up...!
[ 8.729506] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 8.730705] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 8.730817] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 8.734452] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 8.740851] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 9.261248] tegra-pcie-dw 141a0000.pcie: link is down
[ 9.261614] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.261745] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.261846] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.262023] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 9.262205] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 9.262757] iommu: Adding device 0005:00:00.0 to group 65
[ 9.263188] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 9.263301] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.263709] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 9.264292] iommu: Removing device 0005:00:00.0 from group 65
[ 9.265554] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 9.278689] tegra-cbb 14040000.cv-noc: noc_secure_irq = 98, noc_nonsecure_irq = 97>
[ 9.284197] tegra194-isp5 14800000.isp: initialized
[ 9.291629] tegra194-vi5 15c10000.vi: initialized
[ 9.297242] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
[ 9.297445] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@1/endpoint.
[ 9.298588] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 9.298829] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 9.300094] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 9.300096] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 9.302724] tegra-xusb 3610000.xhci: extcon 0: ffffffc3d9dd1c00 id
[ 9.303280] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 9.303303] tegra-xudc-new 3550000.xudc: device count: 1
[ 9.304184] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 9.304188] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 9.304712] tegra-xusb 3610000.xhci: Firmware timestamp: 2018-03-29 14:24:42 UTC, Version: 60.05 release
[ 9.304739] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 9.304750] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 9.305965] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 9.306003] tegra-xusb 3610000.xhci: irq 472, io mem 0x03610000
[ 9.306184] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.306189] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.306192] usb usb1: Product: xHCI Host Controller
[ 9.306194] usb usb1: Manufacturer: Linux 4.9.140-xxx+ xhci-hcd
[ 9.306211] usb usb1: SerialNumber: 3610000.xhci
[ 9.306510] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 9.306819] hub 1-0:1.0: USB hub found
[ 9.306846] hub 1-0:1.0: 4 ports detected
[ 9.307108] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 9.307114] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 9.307119] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 9.307297] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.307300] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.307302] usb usb2: Product: xHCI Host Controller
[ 9.307304] usb usb2: Manufacturer: Linux 4.9.140-xxx+ xhci-hcd
[ 9.307307] usb usb2: SerialNumber: 3610000.xhci
[ 9.307576] tegra-xudc-new 3550000.xudc: entering ELPG
[ 9.307669] hub 2-0:1.0: USB hub found
[ 9.307723] hub 2-0:1.0: 4 ports detected
[ 9.307857] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 9.382317] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 9.382634] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 9.382816] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 9.382982] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 9.383351] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 9.383420] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 9.383627] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (69)
[ 9.383630] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 9.384405] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 9.384830] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 9.384883] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 9.384978] input: gpio-keys as /devices/gpio-keys/input/input5
[ 9.408916] usb usb1: usb_suspend_both: status 0
[ 9.420606] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 9.421073] mmcblk mmc0:0001: Card claimed for testing.
[ 9.461342] bpmp: mounted debugfs mirror
[ 9.467042] vdd-1v8-cvb: disabling
[ 9.467046] vdd-1v8-sd: disabling
[ 9.467048] vdd-epb-1v0: disabling
[ 9.467050] avdd-cam-2v8: disabling
[ 9.467052] vdd-sata-1v5: disabling
[ 9.467054] vdd-3v3-slt: disabling
[ 9.467056] vdd-fan: disabling
[ 9.467058] vdd_sys_en: disabling
[ 9.467064] ALSA device list:
[ 9.467067] #0: tegra-hda-galen-t194 at 0x3518000 irq 68
[ 9.467069] #1: tegra-snd-t19x-mobile-rt565x
[ 9.663537] tegradc 15210000.nvdisplay: DT parsed successfully
[ 9.669429] tegradc 15210000.nvdisplay: Display dc.ffffff800ff10000 registered with id=1
[ 9.677651] tegradc 15210000.nvdisplay: vblank syncpt # 15 for dc 1
[ 9.683727] tegradc 15210000.nvdisplay: vpulse3 syncpt # 16 for dc 1
[ 9.699983] tegradc 15210000.nvdisplay: probed
[ 9.721484] tegradc 15210000.nvdisplay: fb registered
[ 9.725033] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 9.725183] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 9.725352] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 9.725464] tegradc 15210000.nvdisplay: blank - powerdown
[ 9.725583] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 9.728942] tegradc 15220000.nvdisplay: disp2 connected to head2->/host1x/sor1
[ 9.728962] tegradc 15220000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 9.729026] tegradc 15220000.nvdisplay: DT parsed successfully
[ 9.729072] tegradc 15220000.nvdisplay: Display dc.ffffff8011410000 registered with id=2
[ 9.729254] tegradc 15220000.nvdisplay: vblank syncpt # 17 for dc 2
[ 9.729257] tegradc 15220000.nvdisplay: vpulse3 syncpt # 18 for dc 2
[ 9.774917] Extcon DP: HPD disabled
[ 9.778880] hpd: hpd_switch 0
[ 9.782013] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 9.788593] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 9.794532] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 9.803568] tegradc 15220000.nvdisplay: probed
[ 9.825670] tegradc 15220000.nvdisplay: fb registered
[ 9.829182] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 9.829331] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 9.829481] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 9.831942] tegradc 15220000.nvdisplay: blank - powerdown
[ 9.834732] Freeing unused kernel memory: 8576K
[ 9.842044] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 9.850067] Extcon DP: HPD disabled
[ 9.853476] hpd: hpd_switch 0
[ 9.856437] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 9.863384] L4T-INITRD Build DATE: Sat Jan 1 01:00:16 UTC 2000
[ 9.869027] Root device found: mmcblk0p1
[ 9.870318] Found dev node: /dev/mmcblk0p1
[ 9.877283] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 9.883339] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 9.906886] EXT4-fs (mmcblk0p1): recovery complete
[ 9.907823] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.909042] Rootfs mounted over mmcblk0p1
[ 9.926909] Switching from initrd to actual rootfs
[ 10.032214] systemd[1]: System time before build time, advancing clock.
[ 10.058269] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.062035] cgroup: cgroup2: unknown option "nsdelegate"
[ 10.071501] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 10.072500] systemd[1]: Detected architecture arm64.
[ 10.079362] systemd[1]: Set hostname to <john_test>.
[ 10.150510] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 10.150861] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 10.265173] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.265667] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.266165] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.269007] systemd[1]: Created slice System Slice.
[ 10.269402] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.270701] systemd[1]: Created slice system-getty.slice.
[ 10.271415] systemd[1]: Listening on Journal Audit Socket.
[ 10.271919] systemd[1]: Listening on Journal Socket.
[ 10.309412] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 10.317687] gpio tegra-gpio wake44 for gpio=192(Y:0)
[ 10.482206] systemd-journald[2381]: Received request to flush runtime journal from PID 1
[ 10.510695] systemd-journald[2381]: File /var/log/journal/2f3c4d7d66157f60927092ad5e68021b/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 10.869941] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 10.869941]
[ 11.424465] using random self ethernet address
[ 11.424583] using random host ethernet address
[ 11.457449] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
