I tried to flash a version of kernel and the different version of rootfs together into the carried board.
I replaced the Image, kernel_headers.tbz2 and kernel_supplements.tbz2 of 32.3.1 with R32.2 in "JetPack_4.2.1_Linux_GA_P2888",then I ran apply_binaries.sh & “sudo ./flash.sh jetson-xavier mmcblk0p1”, the carried board could power on and enter desktop system.
However, I replaced the Image, kernel_headers.tbz2 and kernel_supplements.tbz2 of 32.2 with 32.3.1 in "JetPack_4.3_Linux_P2888", after I ran apply_binaries.sh & “sudo ./flash.sh jetson-xavier mmcblk0p1”, the carried board just blocked at "WARNING: at platform/drivers/mailbox/mail_mach.c" when loading the kernel, and then cycled to restart. The kernel log:
[0000.055] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.063] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0000.069] I> Boot-mode: Coldboot
[0000.071] I> Chip revision : A02
[0000.074] I> Bootrom patch version : 15 (correctly patched)
[0000.080] I> ATE fuse revision : 0x200
[0000.083] I> Ram repair fuse : 0x0
[0000.086] I> Ram Code : 0x0
[0000.089] I> rst_source : 0x2
[0000.091] I> rst_level : 0x1
[0000.095] I> Boot-device: eMMC
[0000.110] I> sdmmc DDR50 mode
[0000.114] W> No valid slot number is found in scratch register
[0000.120] W> Return default slot: _a
[0000.123] I> Active Boot chain : 0
[0000.126] I> Boot-device: eMMC
[0000.130] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.136] I> Temperature = 41500
[0000.139] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.143] W> Skipping boost for clk: BPMP_APB
[0000.147] W> Skipping boost for clk: AXI_CBB
[0000.151] W> Skipping boost for clk: AON_CPU_NIC
[0000.156] W> Skipping boost for clk: CAN1
[0000.159] W> Skipping boost for clk: CAN2
[0000.164] I> Boot-device: eMMC
[0000.166] I> Boot-device: eMMC
[0000.176] I> Sdmmc: HS400 mode enabled
[0000.180] I> ECC region[0]: Start:0x0, End:0x0
[0000.184] I> ECC region[1]: Start:0x0, End:0x0
[0000.189] I> ECC region[2]: Start:0x0, End:0x0
[0000.193] I> ECC region[3]: Start:0x0, End:0x0
[0000.197] I> ECC region[4]: Start:0x0, End:0x0
[0000.201] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.207] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.211] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.216] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.220] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.225] E> FAILED: Thermal config
[0000.233] E> FAILED: MEMIO rail config
[0000.246] I> Boot-device: eMMC
[0000.255] I> sdmmc bdev is already initialized
[0000.322] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.330] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-fc4604fb)
[0000.331] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.332] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.332] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.338] W> device prod register failed
[0000.342] I> Boot-device: eMMC
[0000.345] I> Boot_device: SDMMC_BOOT instance: 3
[0000.351] I> sdmmc-3 params source = boot args
[0000.354] I> sdmmc bdev is already initialized
[0000.358] I> sdmmc-3 params source = boot args
[0000.364] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.371] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.374] W> No valid slot number is found in scratch register
[0000.379] W> Return default slot: _a
[0000.382] I> Active Boot chain : 0
[0000.386] I> parsing oem signed section of bpmp-fw header done
[0000.391] I> bpmp-fw binary init read from storage
[0000.396] I> oem authentication of bpmp-fw header done
[0000.403] I> bpmp-fw binary done read from storage
[0000.405] I> bpmp-fw: Authentication init Done
[0000.410] I> parsing oem signed section of cpubl header done
[0000.415] I> cpubl binary init read from storage
[0000.420] I> bpmp-fw: Authentication Finalize Done
[0000.425] I> oem authentication of cpubl header done
[0000.429] I> cpubl binary done read from storage
[0000.434] I> cpubl: Authentication init Done
[0000.439] I> parsing oem signed section of rce header done
[0000.443] I> rce binary init read from storage
[0000.448] I> Relocating BR-BCT
[0000.450] I> cpubl: Authentication Finalize Done
[0000.455] I> oem authentication of rce header done
[0000.459] I> rce binary done read from storage
[0000.464] I> rce: Authentication init Done
[0000.468] I> parsing oem signed section of ape header done
[0000.473] I> ape binary init read from storage
[0000.477] I> rce: Authentication Finalize Done
[0000.482] I> oem authentication of ape header done
[0000.486] I> ape binary done read from storage
[0000.490] I> ape: Authentication init Done
[0000.495] I> parsing oem signed section of tos header done
[0000.500] I> tos binary init read from storage
[0000.504] I> ape: Authentication Finalize Done
[0000.509] I> oem authentication of tos header done
[0000.513] I> tos binary done read from storage
[0000.517] I> tos: Authentication init Done
[0000.522] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.527] I> bpmp-fw-dtb binary init read from storage
[0000.532] I> tos: Authentication Finalize Done
[0000.538] I> oem authentication of bpmp-fw-dtb header done
[0000.542] I> bpmp-fw-dtb binary done read from storage
[0000.547] I> bpmp-fw-dtb: Authentication init Done
[0000.552] I> parsing oem signed section of cpubl-dtb header done
[0000.557] I> cpubl-dtb binary init read from storage
[0000.562] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.599] I> oem authentication of cpubl-dtb header done
[0000.599] I> cpubl-dtb binary done read from storage
[0000.600] I> cpubl-dtb: Authentication init Done
[0000.602] I> parsing oem signed section of eks header done
[0000.602] I> eks binary init read from storage
[0000.603] I> cpubl-dtb: Authentication Finalize Done
[0000.604] I> oem authentication of eks header done
[0000.607] I> eks binary done read from storage
[0000.612] I> eks: Authentication init Done
[0000.615] I> eks: Authentication Finalize Done
[0000.620] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:43:07, Dec 9 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea88ed58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is c1b4e372932429f2737cf722e1219e71
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg initialized
mrq initialized
[0001.082] I> Welcome to Cboot
[0001.083] I> Cboot Version: t194-8a9e8a5a
��fmon_post initialized
��[0001.083] I> CPU-BL Params @ 0xf2820000
[0001.083] I> 0) Base:0x00000000 Size:0x00000000
[0001.085] I> 1) Base:0xf1100000 Size:0x00100000
[0001.089] I> 2) Base:0xf2000000 Size:0x00200000
[0001.094] I> 3) Base:0xf1200000 Size:0x00200000
[0001.098] I> 4) Base:0xf1000000 Size:0x00100000
[0001.102] I> 5) Base:0xf0f00000 Size:0x00100000
��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.107] I> 6) Base:0xf3800000 Size:0x00400000
[0001.176] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.181] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.185] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.190] I> 10) Base:0xf3000000 Size:0x00800000
[0001.194] I> 11) Base:0x40000000 Size:0x00040000
[0001.199] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.203] I> 13) Base:0x40046000 Size:0x00002000
[0001.207] I> 14) Base:0x40048000 Size:0x00002000
[0001.212] I> 15) Base:0xac000000 Size:0x00004000
[0001.216] I> 16) Base:0x4004a000 Size:0x00002000
��emc_debugfs initialized
��[0001.221] I> 17) Base:0xf0b00000 Size:0x00100000��dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0001.276] I> 18) Base:0x4004c000 Size:0x00002000
[0001.281] I> 19) Base:0xf2200000 Size:0x00600000
[0001.285] I> 20) Base:0x4004e000 Size:0x00002000
[0001.289] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.294] I> 22) Base:0x00000000 Size:0x00000000
[0001.298] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.303] I> 24) Base:0xf6000000 Size:0x02000000
[0001.307] I> 25) Base:0x40050000 Size:0x00002000
[0001.312] I> 26) Base:0x40040000 Size:0x00006000
[0001.316] I> 27) Base:0xf1800000 Size:0x00400000
[0001.321] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.325] I> 29) Base:0xf1400000 Size:0x00400000
[0001.330] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.334] I> 31) Base:0x00000000 Size:0x00000000
[0001.339] I> 32) Base:0xf8000000 Size:0x08000000
[0001.343] I> 33) Base:0x00000000 Size:0x00000000
[0001.347] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.352] I> 35) Base:0xab000000 Size:0x01000000
[0001.356] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.361] I> 37) Base:0xf2800000 Size:0x00800000
[0001.365] I> 38) Base:0x80000000 Size:0x20000000
[0001.370] I> 39) Base:0xb0000000 Size:0x08000000
[0001.374] I> 40) Base:0x00000000 Size:0x00000000
[0001.379] I> 41) Base:0x00000000 Size:0x00000000
[0001.383] I> 42) Base:0x00000000 Size:0x00000000
[0001.388] I> 43) Base:0x00000000 Size:0x00000000
[0001.392] I> 44) Base:0x00000000 Size:0x00000000
[0001.397] I> 45) Base:0x00000000 Size:0x00000000
[0001.401] GIC-SPI Target CPU: 0
[0001.404] Interrupts Init done
[0001.407] calling constructors
[0001.410] initializing heap
[0001.412] I> Heap: [0xa0690588 ... 0xab000000]
[0001.417] initializing threads
[0001.420] initializing timers
[0001.422] creating bootstrap completion thread
[0001.427] top of bootstrap2()
[0001.429] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.434] initializing platform
[0001.437] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.442] W> device prod register failed
[0001.446] I> Bl_dtb @0xaaf00000
[0001.454] E> "plugin-manager" doesn't exist, creating
[0001.454] E> "ids" doesn't exist, creating
[0001.459] E> "connection" doesn't exist, creating
[0001.463] E> "configs" doesn't exist, creating
[0001.474] I> Find /i2c@3160000's alias i2c0
[0001.475] I> Reading eeprom i2c=0 address=0x50
[0001.500] I> Device at /i2c@3160000:0x50
[0001.501] I> Reading eeprom i2c=0 address=0x56
[0001.525] I> Device at /i2c@3160000:0x56
[0001.528] I> Find /i2c@3180000's alias i2c2
[0001.528] I> Reading eeprom i2c=2 address=0x54
[0001.530] E> I2C: slave not found in slaves.
[0001.530] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.531] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.532] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.539] E> eeprom: Failed to read I2C slave device
[0001.544] I> Eeprom read failed 0x3526070d
[0001.548] I> Reading eeprom i2c=2 address=0x57
[0001.552] E> I2C: slave not found in slaves.
[0001.556] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.564] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.570] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.579] E> eeprom: Failed to read I2C slave device
[0001.584] I> Eeprom read failed 0x3526070d
[0001.588] I> Reading eeprom i2c=2 address=0x52
[0001.593] E> I2C: slave not found in slaves.
[0001.597] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.604] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.610] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.619] E> eeprom: Failed to read I2C slave device
[0001.624] I> Eeprom read failed 0x3526070d
[0001.630] I> Find /i2c@c240000's alias i2c1
[0001.632] I> Reading eeprom i2c=1 address=0x52
[0001.638] E> I2C: slave not found in slaves.
[0001.641] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.649] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.654] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.664] E> eeprom: Retry to read I2C slave device.
[0001.669] E> I2C: slave not found in slaves.
[0001.672] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.680] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.686] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.695] E> eeprom: Failed to read I2C slave device
[0001.700] I> Eeprom read failed 0x3526070d
[0001.704] I> Reading eeprom i2c=1 address=0x50
[0001.709] E> I2C: slave not found in slaves.
[0001.713] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.720] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.726] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.735] E> eeprom: Retry to read I2C slave device.
[0001.740] E> I2C: slave not found in slaves.
[0001.744] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.752] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.758] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.767] E> eeprom: Failed to read I2C slave device
[0001.772] I> Eeprom read failed 0x3526070d
[0001.776] I> create_pm_ids: id: 2888-0001-400-L, len: 15
[0001.781] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.792] I> create_pm_ids: id: 2822-0000-600-G, len: 15
[0001.797] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.808] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0001.816] E> "i2c@3160000" doesn't exist, creating
[0001.820] E> "module@0x50" doesn't exist, creating
[0001.825] I> Adding plugin-manager/ids/2822-0000-600=/i2c@3160000:module@0x56
[0001.832] E> "module@0x56" doesn't exist, creating
[0001.840] I> Adding plugin-manager/cvm
[0001.841] E> "chip-id" doesn't exist, creating
[0001.844] I> Adding plugin-manager/chip-id/A02
[0001.849] I> Plugin-manager override starting
[0001.855] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.864] I> node /plugin-manager/fragement-soft-wdt matches
[0001.873] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.878] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.897] I> Disable plugin-manager status in FDT
[0001.897] I> Plugin-manager override finished successfully
[0001.898] I> gpio framework initialized
[0001.900] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.902] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.904] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.913] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.921] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.926] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.932] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.940] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.948] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.954] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.962] I> fixed regulator driver initialized
[0001.972] I> register 'maxim' power off handle
[0001.973] I> virtual i2c enabled
[0001.973] I> registered 'maxim,max20024' pmic
[0001.976] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.983] I> Boot-device: eMMC
[0001.986] I> Boot_device: SDMMC_BOOT instance: 3
[0001.994] I> sdmmc-3 params source = boot args
[0001.995] I> sdmmc bdev is already initialized
[0001.999] I> sdmmc-3 params source = boot args
[0002.029] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.042] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.053] I> enabling 'vdd-hdmi-5v0' regulator
[0002.059] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.059] I> hdmi cable connected
[0002.062] E> set volts not configured for 'vdd-1v0'
[0002.064] E> set volts not configured for 'vdd-1v8-hs'
[0002.068] E> invalid display type
[0002.073] E> invalid display type
[0002.074] E> cannot find any other nvdisp nodes
[0002.090] I> edid read success
[0002.102] I> edid read success
[0002.102] I> width = 640, height = 480, frequency = 25174825
[0002.103] I> width = 640, height = 480, frequency = 25174825
[0002.103] I> width = 1920, height = 1080, frequency = 148500000
[0002.104] I> width = 1920, height = 1080, frequency = 148500000
[0002.104] I> width = 1920, height = 1080, frequency = 148351648
[0002.108] I> width = 1280, height = 720, frequency = 74175824
[0002.114] I> width = 720, height = 480, frequency = 26973026
[0002.119] I> width = 720, height = 480, frequency = 26973026
[0002.125] I> width = 1920, height = 1080, frequency = 148351648
[0002.131] I> width = 1280, height = 720, frequency = 74175824
[0002.136] I> width = 720, height = 576, frequency = 26973026
[0002.142] I> width = 720, height = 576, frequency = 26973026
[0002.147] I> width = 640, height = 480, frequency = 25174825
[0002.153] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.163] I> hdmi_enable, starting HDMI initialisation
[0002.168] I> hdmi_enable, HDMI initialisation complete
[0002.178] I> Load in CBoot Boot Options partition and parse it
[0002.178] E> Cannot read beyond partition boundary for CPUBL-CFG
[0002.181] E> tegrabl_read_cbo Failed to read CPUBL-CFG partition
[0002.186] W> platform_init: tegrabl_read_cbo failed with error 0xd0d0104
[0002.193] I> Hit any key to stop autoboot: 4 3 2 1
[0004.201] initializing target
[0004.201] calling apps_init()
[0004.202] starting app kernel_boot_app
[0004.221] I> found decompressor handler: lz4-legacy
[0004.222] I> decompressing BMP blob ...
[0004.227] I> Kernel type = Normal
[0004.227] I> Loading partition kernel-bootctrl at 0xa4ab0000 from device(0x1)
[0004.234] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.234] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.235] I> ########## SD boot ##########
[0004.235] I> No sdcard
[0004.235] I> -0 params source =
[0004.238] E> Blockdev open: exit error
[0004.242] E> SD boot failed, err: 724238353
[0004.246] I> ########## USB boot ##########
[0004.255] W> No valid slot number is found in scratch register
[0004.256] W> Return default slot: _a
[0004.271] I> USB Firmware Version: 60.06 release
[0004.327] I> regulator of usb2-0 already enabled
[0004.335] I> regulator of usb2-1 already enabled
[0004.343] I> regulator of usb2-2 already enabled
[0004.354] I> enabling 'vdd-5v-sata' regulator
[0005.359] E> failed to initialize xhci controller
[0005.360] E> Error in init of XUSB host driver, err: 79790026
[0005.360] E> Failed to initialize device 5-0
[0005.360] E> USB boot failed, err: 2037973030
[0005.361] I> ########## Fixed storage boot ##########
[0005.361] I> Already published: 00010003
[0005.361] I> Look for boot partition
[0005.365] I> Fallback: assuming 0th partition is boot partition
[0005.371] I> Detect filesystem
[0005.398] I> Loading extlinux.conf ...
[0005.398] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.435] I> L4T boot options
[0005.435] I> [1]: "primary kernel"
[0005.435] I> Enter choice:
[0008.436] I> Continuing with default option: 1
[0008.436] I> Loading kernel sig file from rootfs ...
[0008.436] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.455] I> Loading kernel binary from rootfs ...
[0008.455] I> rootfs path: /sdmmc_user/boot/Image
[0008.671] I> Validate kernel ...
[0008.672] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.024] I> No kernel-dtb binary path
[0009.024] I> Loading kernel-dtb binary from partition ...
[0009.024] W> No valid slot number is found in scratch register
[0009.025] W> Return default slot: _a
[0009.025] I> A/B: bin_type (38) slot 0
[0009.025] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.036] I> Validate kernel-dtb ...
[0009.036] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.041] I> Loading ramdisk from rootfs ...
[0009.042] I> rootfs path: /sdmmc_user/boot/initrd
[0009.093] I> Kernel hdr @0xa4ab0000
[0009.094] I> Kernel dtb @0x90000000
[0009.094] I> decompressor handler not found
[0009.094] I> Copying kernel image (34179088 bytes) from 0xa4ab0000 to 0x80080000 ... [0009.108] I> Done
[0009.109] I> Updated bpmp info to DTB
[0009.111] I> Ramdisk: Base: 0x92000000; Size: 0x54ead4
[0009.111] I> Updated initrd info to DTB
[0009.111] W> WARN: Fail to override "console=none" in commandline
[0009.112] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.114] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.121] W> No valid slot number is found in scratch register
[0009.127] W> Return default slot: _a
[0009.130] I> Active slot suffix:
[0009.133] I> add_boot_slot_suffix: slot_suffix =
[0009.138] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069b000 lut_mem=0x2008@0xa0696000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.177] I> Updated bootarg info to DTB
[0009.180] W> MAC addr invalid!
[0009.183] E> Failed to get WIFI MAC address
[0009.187] W> MAC addr invalid!
[0009.190] E> Failed to get Bluetooth MAC address
[0009.195] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:e5:7c:2f
[0009.201] E> "plugin-manager" doesn't exist, creating
[0009.206] I> Adding /chosen/plugin-manager/cvm
[0009.210] E> "chip-id" doesn't exist, creating
[0009.214] I> Adding /chosen/plugin-manager/chip-id
[0009.219] E> "configs" doesn't exist, creating
[0009.223] I> Adding /chosen/plugin-manager/configs
[0009.228] E> "ids" doesn't exist, creating
[0009.232] I> Adding /chosen/plugin-manager/ids
[0009.236] E> "odm-data" doesn't exist, creating
[0009.240] I> Adding /chosen/plugin-manager/odm-data
[0009.249] E> "memory" doesn't exist, creating
[0009.250] I> [0] START: 0x80000000, END: 0xac000000
[0009.254] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.259] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.263] I> dram_block larger than 80000000
[0009.267] I> [3] START: 0x100000000, END: 0x480000000
[0009.272] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.278] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.284] I> added [base:0x100000000, size:0x380000000] to /memory
[0009.291] I> Updated memory info to DTB
[0009.294] E> add_disp_param: failed to get display params for du=1
[0009.300] E> "reset" doesn't exist, creating
[0009.304] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.309] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0009.313] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.318] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0009.323] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.328] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0009.332] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.337] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0009.342] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.347] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0009.352] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.356] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0009.361] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.366] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0009.371] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.376] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0009.382] E> "misc-data" doesn't exist, creating
[0009.385] I> Boot-device: eMMC
[0009.388] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.393] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.398] W> Unknown storage device
[0009.402] I> Add serial number:0420719091307 as DT property
[0009.409] I> Plugin-manager override starting
[0009.412] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.419] I> node /plugin-manager/fragement-soft-wdt matches
[0009.427] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.431] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.442] I> Disable plugin-manager status in FDT
[0009.442] I> Plugin-manager override finished successfully
[0009.445] I> tegrabl_load_kernel_and_dtb: Done
[0009.472] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-922) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jul 16 17:09:53 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069b000
[ 0.000000] Found lut_mem: 00002008@a0696000
<hit enter to activate fiq debugger>
��WARNING: pll_d3 has no dyn ramp
WARNING: at platform/drivers/mailbox/mail_mach.c:148
WARNING: at platform/drivers/mailbox/mail_mach.c:161
WARNING: at platform/drivers/mailbox/mail_mach.c:177
