Failed to flash customized kernel dtb
I tried to flash my own dtb to the customized board.
First I modified the config in p3668.conf.common with my own dtb file:
Before:
#DTB_FILE=tegra194-p3668-all-p3509-0000.dtb;
After:
DTB_FILE=tegra194-p3668-tly-jtnx.dtb;
The flash log:
L4T BSP Information:
R32 , REVISION: 6.1
Target Board Information:
Name: jetson-xavier-nx-devkit, Board Family: t186ref, SoC: Tegra 194,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying soft_fuses(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
./tegraflash.py --chip 0x19 --applet “/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0050 ] Generating RCM messages
[ 0.0082 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0099 ] Header already present for /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0212 ]
[ 0.0247 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0248 ] Assuming zero filled SBK key
[ 0.0285 ] tegrasign_v3.py --file /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0287 ] Assuming zero filled SBK key
[ 0.0401 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0537 ]
[ 0.0588 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0617 ]
[ 0.0660 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0689 ] RCM 0 is saved as rcm_0.rcm
[ 0.0807 ] RCM 1 is saved as rcm_1.rcm
[ 0.0807 ] RCM 2 is saved as rcm_2.rcm
[ 0.0807 ] List of rcm files are saved in rcm_list.xml
[ 0.0807 ]
[ 0.0808 ] Signing RCM messages
[ 0.0854 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0856 ] Assuming zero filled SBK key
[ 0.1118 ] Copying signature to RCM mesages
[ 0.1164 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1210 ]
[ 0.1212 ] Boot Rom communication
[ 0.1255 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1283 ] RCM version 0X190001
[ 0.4514 ] Boot Rom communication completed
[ 1.4663 ]
[ 2.4722 ] tegrarcm_v2 --isapplet
[ 2.4750 ] Applet version 01.00.0000
[ 2.9938 ]
[ 2.9984 ] tegrarcm_v2 --ismb2
[ 3.6817 ]
[ 3.6866 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 3.6896 ]
[ 3.6941 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 3.6970 ] adding BCH for nvtboot_applet_t194.bin
[ 3.7079 ]
[ 3.7157 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.7160 ] Assuming zero filled SBK key
[ 3.7299 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 3.7385 ]
[ 3.7430 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 3.7456 ] Applet version 01.00.0000
[ 4.4142 ] Sending mb2
[ 4.4145 ] […] 100%
[ 4.4310 ]
[ 4.4357 ] tegrarcm_v2 --boot recovery
[ 4.4385 ] Applet version 01.00.0000
[ 5.1098 ]
[ 6.1158 ] tegrarcm_v2 --isapplet
[ 6.7859 ]
[ 6.7905 ] tegrarcm_v2 --ismb2
[ 6.7933 ] MB2 Applet version 01.00.0000
[ 7.4738 ]
[ 7.4786 ] tegrarcm_v2 --ismb2
[ 7.4815 ] MB2 Applet version 01.00.0000
[ 8.1619 ]
[ 8.1665 ] Retrieving board information
[ 8.1709 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 8.1737 ] MB2 Applet version 01.00.0000
[ 8.8455 ] Saved platform info in chip_info.bin
[ 8.8506 ] Chip minor revision: 2
[ 8.8510 ] Bootrom revision: 0xf
[ 8.8514 ] Ram code: 0x0
[ 8.8514 ] Chip sku: 0xde
[ 8.8514 ] Chip Sample: non es
[ 8.8514 ]
[ 8.8521 ] Retrieving EEPROM data
[ 8.8522 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 8.8550 ] MB2 Applet version 01.00.0000
[ 9.3776 ] Saved platform info in /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 9.4126 ]
[ 9.4129 ] Rebooting to recovery mode
[ 9.4175 ] tegrarcm_v2 --ismb2
[ 9.4205 ] MB2 Applet version 01.00.0000
[ 10.0978 ]
[ 10.0979 ] Rebooting to recovery mode
[ 10.1026 ] tegrarcm_v2 --reboot recovery
[ 10.1053 ] MB2 Applet version 01.00.0000
[ 10.7943 ]
Board ID(3668) version(300) sku(0001) revision(B.0)
copying bctfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)… done.
copying bctfile1(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)… done.
copying device_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)… done.
copying misc_cold_boot_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)… done.
copying misc_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)… done.
copying pinmux_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)… done.
copying gpioint_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)… done.
copying pmic_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)… done.
copying pmc_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)… done.
copying prod_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)… done.
copying scr_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)… done.
copying scr_cold_boot_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)… done.
copying bootrom_config(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)… done.
copying dev_params(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)… done.
Existing bootloader(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0005 ] Generating signature
[ 0.0044 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0047 ] Assuming zero filled SBK key : not reading
[ 0.0046 ] Generating ratchet blob
[ 0.0076 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0097 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0103 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0104 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0105 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0105 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0105 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0105 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0105 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0105 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0105 ]
[ 0.0106 ] header_magic: 414e4452
[ 0.0138 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0162 ]
[ 0.0199 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[ 0.0225 ] adding BCH for 1_boot.img
[ 1.0995 ]
[ 1.1066 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 1.1069 ] Assuming zero filled SBK key : not reading
[ 1.2306 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 1.8429 ]
[ 1.8943 ] Signed file: /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27cb800 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Existing sosfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)… done.
Existing scefile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra194-p3668-tly-jtnx.dtb)… done.
Copying nv_boot_control.conf to rootfs
/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign kernel_tegra194-p3668-tly-jtnx.dtb kernel_dtb
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0042 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0043 ] Assuming zero filled SBK key : not reading
[ 0.0042 ] Generating ratchet blob
[ 0.0073 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0093 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0099 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0101 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0101 ]
[ 0.0103 ] header_magic: d00dfeed
[ 0.0135 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-tly-jtnx.dtb
[ 0.0157 ]
[ 0.0188 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-tly-jtnx.dtb zerosbk
[ 0.0205 ] adding BCH for 1_kernel_tegra194-p3668-tly-jtnx.dtb
[ 0.0361 ]
[ 0.0417 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0420 ] Assuming zero filled SBK key : not reading
[ 0.0565 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.hash zerosbk
[ 0.0681 ]
[ 0.0695 ] Signed file: /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x2f90b to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt
done.
Reusing existing system.img…
done.
Existing tbcfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra194-p3668-tly-jtnx.dtb)… done.
copying cfgfile(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t194_spi_sd_p3668.xml) to flash.xml… done.
Existing flasher(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Updating [kernel-dtb] with kernel_tegra194-p3668-tly-jtnx.dtb ***
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --chip 0x19 --applet mb1_t194_prod.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --bin “mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p3668-tly-jtnx.dtb” --odmdata 0xB8190000 --cmd “erase kernel-dtb; signwrite kernel-dtb kernel_tegra194-p3668-tly-jtnx.dtb; reboot”
version 1.0.0
[ 0.0082 ] Generating RCM messages
[ 0.0114 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0130 ] Header already present for mb1_t194_prod.bin
[ 0.0241 ]
[ 0.0282 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0283 ] Assuming zero filled SBK key
[ 0.0305 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0306 ] Assuming zero filled SBK key
[ 0.0416 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0546 ]
[ 0.0590 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0621 ]
[ 0.0661 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0688 ] RCM 0 is saved as rcm_0.rcm
[ 0.0792 ] RCM 1 is saved as rcm_1.rcm
[ 0.0793 ] RCM 2 is saved as rcm_2.rcm
[ 0.0793 ] List of rcm files are saved in rcm_list.xml
[ 0.0793 ]
[ 0.0794 ] Signing RCM messages
[ 0.0841 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0843 ] Assuming zero filled SBK key
[ 0.1079 ] Copying signature to RCM mesages
[ 0.1122 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1168 ]
[ 0.1169 ] Boot Rom communication
[ 0.1206 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 0.1230 ] BR_CID: 0x88021911647c64000c00000007018240
[ 0.3213 ] RCM version 0X190001
[ 0.5135 ] Boot Rom communication completed
[ 1.5283 ]
[ 2.5343 ] tegrarcm_v2 --isapplet
[ 2.5371 ] Applet version 01.00.0000
[ 3.0040 ]
[ 3.0091 ] tegrasign_v3.py --getmode mode.txt --key None
[ 3.0093 ] Assuming zero filled SBK key
[ 3.0098 ] Parsing partition layout
[ 3.0141 ] tegraparser_v2 --pt flash.xml.tmp
[ 3.0195 ]
[ 3.0197 ] Creating list of images to be signed
[ 3.0240 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 3.0269 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 3.0285 ] Header already present for mb1_t194_prod_sigheader.bin
[ 3.0301 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 3.0402 ] Header already present for mb1_t194_prod_sigheader.bin
[ 3.0412 ] adding BCH for spe_t194.bin
[ 3.0483 ] adding BCH for spe_t194.bin
[ 3.0526 ] adding BCH for nvtboot_t194.bin
[ 3.0564 ] adding BCH for nvtboot_t194.bin
[ 3.0619 ] Header already present for preboot_c10_prod_cr.bin
[ 3.0680 ] Header already present for preboot_c10_prod_cr.bin
[ 3.0688 ] Header already present for mce_c10_prod_cr.bin
[ 3.0696 ] Header already present for mce_c10_prod_cr.bin
[ 3.0709 ] adding BCH for mts_c10_prod_cr.bin
[ 3.0760 ] adding BCH for mts_c10_prod_cr.bin
[ 3.1691 ] Header already present for warmboot_t194_prod.bin
[ 3.2557 ] Header already present for warmboot_t194_prod.bin
[ 3.2566 ] adding BCH for xusb_sil_rel_fw
[ 3.2573 ] adding BCH for xusb_sil_rel_fw
[ 3.2610 ] adding BCH for cboot_t194.bin
[ 3.2646 ] adding BCH for cboot_t194.bin
[ 3.2777 ] adding BCH for tegra194-p3668-tly-jtnx.dtb
[ 3.2909 ] adding BCH for tegra194-p3668-tly-jtnx.dtb
[ 3.2969 ] adding BCH for tos-trusty_t194.img
[ 3.3032 ] adding BCH for tos-trusty_t194.img
[ 3.3148 ] adding BCH for eks.img
[ 3.3264 ] adding BCH for eks.img
[ 3.3268 ] adding BCH for adsp-fw.bin
[ 3.3273 ] adding BCH for adsp-fw.bin
[ 3.3292 ] adding BCH for camera-rtcpu-rce.img
[ 3.3318 ] adding BCH for camera-rtcpu-rce.img
[ 3.3401 ] adding BCH for bpmp_t194.bin
[ 3.3484 ] adding BCH for bpmp_t194.bin
[ 3.3724 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 3.3958 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 3.4043 ] adding BCH for boot.img
[ 3.4423 ] adding BCH for boot.img
[ 4.4577 ] adding BCH for kernel_tegra194-p3668-tly-jtnx.dtb
[ 5.4584 ] adding BCH for kernel_tegra194-p3668-tly-jtnx.dtb
[ 5.4701 ]
[ 5.4702 ] Filling MB1 storage info
[ 5.4702 ] Generating br-bct
[ 5.4749 ] Performing cfg overlay
[ 5.4750 ] [‘tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg’, ‘tegra194-memcfg-sw-override.cfg’]
[ 5.4759 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1.cfg
[ 5.5269 ]
[ 5.5273 ] Updating dev and MSS params in BR BCT
[ 5.5275 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.5869 ]
[ 5.5870 ] Updating bl info
[ 5.5913 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 5.5973 ]
[ 5.5974 ] Generating signatures
[ 5.6019 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 5.6022 ] Assuming zero filled SBK key
[ 6.1600 ] Send BCT from Host
[ 6.1601 ] Generating br-bct
[ 6.1636 ] Performing cfg overlay
[ 6.1637 ] [‘/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1.cfg’]
[ 6.1638 ] Updating dev and MSS params in BR BCT
[ 6.1639 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 6.2247 ]
[ 6.2248 ] Updating bl info
[ 6.2295 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.2381 ]
[ 6.2382 ] Updating smd info
[ 6.2429 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 6.2463 ]
[ 6.2465 ] Updating Odmdata
[ 6.2510 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 6.2546 ]
[ 6.2547 ] Get Signed section of bct
[ 6.2591 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 6.2627 ]
[ 6.2673 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 6.2703 ] Assuming zero filled SBK key
[ 6.3214 ]
[ 6.3215 ] Updating BCT with signature
[ 6.3245 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 6.3276 ]
[ 6.3277 ] Generating coldboot mb1-bct
[ 6.3331 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 6.3359 ] MB1-BCT version: 0x1
[ 6.3376 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 6.3386 ] Added Platform Config 0 data with size :- 2496
[ 6.3446 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 6.3456 ] Added Platform Config 1 data with size :- 19640
[ 6.3752 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 6.3762 ] Added Platform Config 2 data with size :- 24
[ 6.3772 ]
[ 6.3772 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 6.3772 ] Added Platform Config 4 data with size :- 348
[ 6.3772 ]
[ 6.3772 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 6.3773 ] Added Platform Config 3 data with size :- 92
[ 6.3773 ]
[ 6.3773 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 6.3773 ] Added Platform Config 5 data with size :- 128
[ 6.3773 ]
[ 6.3773 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 6.3774 ] Added Platform Config 7 data with size :- 392
[ 6.3774 ]
[ 6.3774 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 6.3774 ] Added Platform Config 9 data with size :- 40
[ 6.3774 ]
[ 6.3776 ] Updating mb1-bct with firmware information
[ 6.3822 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 6.3845 ] MB1-BCT version: 0x1
[ 6.3850 ]
[ 6.3851 ] Updating mb1-bct with storage information
[ 6.3893 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 6.3914 ] MB1-BCT version: 0x1
[ 6.3922 ]
[ 6.3964 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 6.3986 ]
[ 6.4028 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 6.4055 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 6.4083 ]
[ 6.4133 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 6.4136 ] Assuming zero filled SBK key
[ 6.4270 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 6.4313 ]
[ 6.4316 ] Generating recovery mb1-bct
[ 6.4361 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 6.4391 ] MB1-BCT version: 0x1
[ 6.4407 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 6.4418 ] Added Platform Config 0 data with size :- 2496
[ 6.4475 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 6.4486 ] Added Platform Config 1 data with size :- 19640
[ 6.4802 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 6.4812 ] Added Platform Config 2 data with size :- 24
[ 6.4821 ]
[ 6.4821 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 6.4821 ] Added Platform Config 4 data with size :- 348
[ 6.4821 ]
[ 6.4822 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 6.4822 ] Added Platform Config 3 data with size :- 92
[ 6.4822 ]
[ 6.4822 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 6.4822 ] Added Platform Config 5 data with size :- 128
[ 6.4822 ]
[ 6.4822 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 6.4823 ] Added Platform Config 7 data with size :- 392
[ 6.4823 ]
[ 6.4823 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 6.4823 ] Added Platform Config 9 data with size :- 40
[ 6.4823 ]
[ 6.4825 ] Updating mb1-bct with firmware information
[ 6.4869 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 6.4892 ] MB1-BCT version: 0x1
[ 6.4901 ]
[ 6.4901 ] Updating mb1-bct with storage information
[ 6.4946 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 6.4970 ] MB1-BCT version: 0x1
[ 6.4979 ]
[ 6.5007 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 6.5037 ]
[ 6.5079 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 6.5109 ] adding BCH for mb1_bct_MB1.bct
[ 6.5136 ]
[ 6.5187 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 6.5190 ] Assuming zero filled SBK key
[ 6.5323 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 6.5371 ]
[ 6.5375 ] Generating coldboot mem-bct
[ 6.5420 ] tegrabct_v2 --chip 0x19 0 --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1.cfg --membct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_1.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_2.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_3.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_4.bct
[ 6.5445 ] Packing sdram param for instance[0]
[ 6.5999 ] Packing sdram param for instance[1]
[ 6.5999 ] Packing sdram param for instance[2]
[ 6.6000 ] Packing sdram param for instance[3]
[ 6.6000 ] Packing sdram param for instance[4]
[ 6.6000 ] Packing sdram param for instance[5]
[ 6.6000 ] Packing sdram param for instance[6]
[ 6.6000 ] Packing sdram param for instance[7]
[ 6.6000 ] Packing sdram param for instance[8]
[ 6.6001 ] Packing sdram param for instance[9]
[ 6.6001 ] Packing sdram param for instance[10]
[ 6.6001 ] Packing sdram param for instance[11]
[ 6.6001 ] Packing sdram param for instance[12]
[ 6.6001 ] Packing sdram param for instance[13]
[ 6.6001 ] Packing sdram param for instance[14]
[ 6.6002 ] Packing sdram param for instance[15]
[ 6.6002 ]
[ 6.6003 ] Getting sector size from pt
[ 6.6046 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 6.6078 ]
[ 6.6081 ] BlockSize read from layout is 200
[ 6.6110 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_1.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_2.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_3.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_4.bct
[ 6.6140 ] adding BCH for /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_1.bct
[ 6.6235 ]
[ 6.6264 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 6.6294 ]
[ 6.6342 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 6.6368 ] Header already present for mem_coldboot.bct
[ 6.6379 ]
[ 6.6432 ] tegrasign_v3.py --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 6.6435 ] Assuming zero filled SBK key
[ 6.6571 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 6.6610 ]
[ 6.6613 ] Generating recovery mem-bct
[ 6.6653 ] tegrabct_v2 --chip 0x19 0 --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1.cfg --membct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_1.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_2.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_3.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmphpdvu0tq1_4.bct
[ 6.6679 ] Packing sdram param for instance[0]
[ 6.7241 ] Packing sdram param for instance[1]
[ 6.7241 ] Packing sdram param for instance[2]
[ 6.7242 ] Packing sdram param for instance[3]
[ 6.7242 ] Packing sdram param for instance[4]
[ 6.7242 ] Packing sdram param for instance[5]
[ 6.7242 ] Packing sdram param for instance[6]
[ 6.7242 ] Packing sdram param for instance[7]
[ 6.7243 ] Packing sdram param for instance[8]
[ 6.7243 ] Packing sdram param for instance[9]
[ 6.7243 ] Packing sdram param for instance[10]
[ 6.7243 ] Packing sdram param for instance[11]
[ 6.7243 ] Packing sdram param for instance[12]
[ 6.7243 ] Packing sdram param for instance[13]
[ 6.7244 ] Packing sdram param for instance[14]
[ 6.7244 ] Packing sdram param for instance[15]
[ 6.7244 ]
[ 6.7248 ] Reading ramcode from backup chip_info.bin file
[ 6.7249 ] RAMCODE Read from Device: 0
[ 6.7300 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 6.7324 ]
[ 6.7353 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 6.7384 ] adding BCH for mem_rcm.bct
[ 6.7430 ]
[ 6.7466 ] tegrasign_v3.py --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 6.7468 ] Assuming zero filled SBK key
[ 6.7614 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 6.7666 ]
[ 6.7670 ] Sending BCTs
[ 6.7711 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 6.7740 ] Applet version 01.00.0000
[ 7.3840 ] Sending bct_bootrom
[ 7.3844 ] […] 100%
[ 7.3866 ] Sending bct_mb1
[ 7.3914 ] […] 100%
[ 7.3961 ] Sending bct_mem
[ 7.4460 ] […] 100%
[ 7.5205 ]
[ 7.5207 ] Generating blob
[ 7.5258 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 7.5290 ]
[ 7.5340 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 7.5370 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 7.5572 ]
[ 7.5615 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.5618 ] Assuming zero filled SBK key
[ 7.5776 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 7.5929 ]
[ 7.5965 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 7.6000 ]
[ 7.6046 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 7.6074 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 7.6224 ]
[ 7.6280 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.6283 ] Assuming zero filled SBK key
[ 7.6425 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 7.6536 ]
[ 7.6574 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 7.6606 ]
[ 7.6653 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 7.6682 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 7.6698 ]
[ 7.6755 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.6758 ] Assuming zero filled SBK key
[ 7.6883 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.6932 ]
[ 7.6979 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 7.7007 ]
[ 7.7053 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 7.7079 ] Header already present for blob_mce_c10_prod_cr.bin
[ 7.7143 ]
[ 7.7199 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.7202 ] Assuming zero filled SBK key
[ 7.7355 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.7448 ]
[ 7.7498 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 7.7531 ]
[ 7.7578 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 7.7607 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 7.8654 ]
[ 7.8714 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.8717 ] Assuming zero filled SBK key
[ 7.9006 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.9643 ]
[ 7.9693 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 7.9724 ]
[ 7.9769 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader blob_bpmp_t194.bin zerosbk
[ 7.9791 ] adding BCH for blob_bpmp_t194.bin
[ 8.0080 ]
[ 8.0134 ] tegrasign_v3.py --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.0137 ] Assuming zero filled SBK key
[ 8.0305 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 8.0598 ]
[ 8.0646 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p3668-a00.dtb
[ 8.0678 ]
[ 8.0707 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader blob_tegra194-a02-bpmp-p3668-a00.dtb zerosbk
[ 8.0735 ] adding BCH for blob_tegra194-a02-bpmp-p3668-a00.dtb
[ 8.0933 ]
[ 8.0989 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.0992 ] Assuming zero filled SBK key
[ 8.1133 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 8.1269 ]
[ 8.1318 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 8.1345 ]
[ 8.1391 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader blob_spe_t194.bin zerosbk
[ 8.1425 ] adding BCH for blob_spe_t194.bin
[ 8.1499 ]
[ 8.1557 ] tegrasign_v3.py --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.1560 ] Assuming zero filled SBK key
[ 8.1708 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 8.1779 ]
[ 8.1830 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[ 8.1863 ]
[ 8.1910 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader blob_tos-trusty_t194.img zerosbk
[ 8.1940 ] adding BCH for blob_tos-trusty_t194.img
[ 8.2190 ]
[ 8.2246 ] tegrasign_v3.py --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.2249 ] Assuming zero filled SBK key
[ 8.2404 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[ 8.2602 ]
[ 8.2652 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 8.2683 ]
[ 8.2728 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader blob_eks.img zerosbk
[ 8.2759 ] adding BCH for blob_eks.img
[ 8.2764 ]
[ 8.2820 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.2823 ] Assuming zero filled SBK key
[ 8.2962 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 8.2997 ]
[ 8.3046 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p3668-tly-jtnx.dtb
[ 8.3082 ]
[ 8.3126 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader blob_tegra194-p3668-tly-jtnx.dtb zerosbk
[ 8.3154 ] adding BCH for blob_tegra194-p3668-tly-jtnx.dtb
[ 8.3308 ]
[ 8.3364 ] tegrasign_v3.py --key None --list blob_tegra194-p3668-tly-jtnx_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.3367 ] Assuming zero filled SBK key
[ 8.3520 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt blob_tegra194-p3668-tly-jtnx_sigheader.dtb.hash zerosbk
[ 8.3638 ]
[ 8.3692 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 8.3723 ] number of images in blob are 11
[ 8.3732 ] blobsize is 5890728
[ 8.3737 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 263840
[ 8.3838 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 181152
[ 8.3851 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 8.3864 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[ 8.3878 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[ 8.3905 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[ 8.3923 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt of size 281984
[ 8.3938 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[ 8.3949 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[ 8.3961 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 8.3970 ] Added binary blob_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt of size 198928
[ 8.3989 ]
[ 8.3990 ] Sending bootloader and pre-requisite binaries
[ 8.4033 ] tegrarcm_v2 --download blob blob.bin
[ 8.4055 ] Applet version 01.00.0000
[ 8.8724 ] Sending blob
[ 8.8726 ] […] 100%
[ 9.6694 ]
[ 9.6742 ] tegrarcm_v2 --boot recovery
[ 9.6775 ] Applet version 01.00.0000
[ 10.3541 ]
[ 11.3606 ] tegrarcm_v2 --isapplet
[ 11.9669 ]
[ 11.9718 ] tegrarcm_v2 --ismb2
[ 12.3668 ]
[ 12.3717 ] tegradevflash_v2 --iscpubl
[ 12.3747 ] Bootloader version 01.00.0000
[ 12.5751 ] Bootloader version 01.00.0000
[ 12.5764 ]
[ 12.5766 ] Writing partition
[ 12.5813 ] tegradevflash_v2 --erase kernel-dtb
[ 12.5843 ] Bootloader version 01.00.0000
[ 12.8290 ] 000000000d0d000d: o open partition %s.
[ 12.8310 ]
[ 12.8310 ] [Failed]
[ 12.8310 ]
Error: Return value 13
Command tegradevflash_v2 --erase kernel-dtb
[ 12.8366 ] tegrasign_v3.py --getmode mode.txt --key None
[ 12.8369 ] Assuming zero filled SBK key
[ 12.8375 ] header_magic: d00dfeed
[ 12.8422 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-tly-jtnx.dtb
[ 12.8454 ]
[ 12.8501 ] tegrahost_v2 --chip 0x19 0 --magicid --appendsigheader 1_kernel_tegra194-p3668-tly-jtnx.dtb zerosbk
[ 12.8531 ] adding BCH for 1_kernel_tegra194-p3668-tly-jtnx.dtb
[ 12.8699 ]
[ 12.8757 ] tegrasign_v3.py --key None --list 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 12.8760 ] Assuming zero filled SBK key
[ 12.8906 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.hash zerosbk
[ 12.9027 ]
[ 12.9031 ] Generating RCM messages
[ 12.9075 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 12.9104 ] Header already present for mb1_t194_prod.bin
[ 12.9219 ]
[ 12.9273 ] tegrasign_v3.py --getmode mode.txt --key None
[ 12.9275 ] Assuming zero filled SBK key
[ 12.9326 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 12.9329 ] Assuming zero filled SBK key
[ 12.9471 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 12.9608 ]
[ 12.9654 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 12.9690 ]
[ 12.9736 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 12.9766 ] RCM 0 is saved as rcm_0.rcm
[ 12.9883 ] RCM 1 is saved as rcm_1.rcm
[ 12.9884 ] RCM 2 is saved as rcm_2.rcm
[ 12.9884 ] List of rcm files are saved in rcm_list.xml
[ 12.9884 ]
[ 12.9885 ] Signing RCM messages
[ 12.9917 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 12.9920 ] Assuming zero filled SBK key
[ 13.0164 ] Copying signature to RCM mesages
[ 13.0205 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 13.0251 ]
[ 13.0252 ] Boot Rom communication
[ 13.0291 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 13.0317 ] BootRom is not running
[ 18.3743 ]
[ 19.3795 ] tegrarcm_v2 --isapplet
[ 20.0526 ]
[ 20.0575 ] tegrarcm_v2 --ismb2
[ 20.7447 ]
[ 20.7496 ] tegradevflash_v2 --iscpubl
[ 20.7526 ] Bootloader version 01.00.0000
[ 21.0969 ] Bootloader version 01.00.0000
[ 21.0985 ]
[ 21.1037 ] tegrasign_v3.py --getmode mode.txt --key None
[ 21.1040 ] Assuming zero filled SBK key
[ 21.1044 ] Parsing partition layout
[ 21.1090 ] tegraparser_v2 --pt flash.xml.tmp
[ 21.1148 ]
[ 21.1150 ] Creating list of images to be signed
[ 21.1195 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 21.1226 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 21.1242 ] Header already present for mb1_t194_prod_sigheader.bin
[ 21.1258 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 21.1360 ] Header already present for mb1_t194_prod_sigheader.bin
[ 21.1370 ] adding BCH for spe_t194.bin
[ 21.1440 ] adding BCH for spe_t194.bin
[ 21.1487 ] adding BCH for nvtboot_t194.bin
[ 21.1521 ] adding BCH for nvtboot_t194.bin
[ 21.1577 ] Header already present for preboot_c10_prod_cr.bin
[ 21.1635 ] Header already present for preboot_c10_prod_cr.bin
[ 21.1644 ] Header already present for mce_c10_prod_cr.bin
[ 21.1652 ] Header already present for mce_c10_prod_cr.bin
[ 21.1665 ] adding BCH for mts_c10_prod_cr.bin
[ 21.1718 ] adding BCH for mts_c10_prod_cr.bin
[ 21.2595 ] Header already present for warmboot_t194_prod.bin
[ 21.3490 ] Header already present for warmboot_t194_prod.bin
[ 21.3500 ] adding BCH for xusb_sil_rel_fw
[ 21.3563 ] adding BCH for xusb_sil_rel_fw
[ 21.3693 ] adding BCH for cboot_t194.bin
[ 21.3774 ] adding BCH for cboot_t194.bin
[ 21.3941 ] adding BCH for tegra194-p3668-tly-jtnx.dtb
[ 21.4071 ] adding BCH for tegra194-p3668-tly-jtnx.dtb
[ 21.4130 ] adding BCH for tos-trusty_t194.img
[ 21.4193 ] adding BCH for tos-trusty_t194.img
[ 21.4304 ] adding BCH for eks.img
[ 21.4414 ] adding BCH for eks.img
[ 21.4418 ] adding BCH for adsp-fw.bin
[ 21.4423 ] adding BCH for adsp-fw.bin
[ 21.4449 ] adding BCH for camera-rtcpu-rce.img
[ 21.4476 ] adding BCH for camera-rtcpu-rce.img
[ 21.4556 ] adding BCH for bpmp_t194.bin
[ 21.4629 ] adding BCH for bpmp_t194.bin
[ 21.4856 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 21.5088 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 21.5175 ] adding BCH for boot.img
[ 21.5591 ] adding BCH for boot.img
[ 22.5851 ] adding BCH for kernel_tegra194-p3668-tly-jtnx.dtb
[ 23.5892 ] adding BCH for kernel_tegra194-p3668-tly-jtnx.dtb
[ 23.6728 ]
[ 23.6729 ] Filling MB1 storage info
[ 23.6730 ] Generating br-bct
[ 23.6775 ] Performing cfg overlay
[ 23.6776 ] [‘tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg’, ‘tegra194-memcfg-sw-override.cfg’]
[ 23.6783 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41.cfg
[ 23.7353 ]
[ 23.7357 ] Updating dev and MSS params in BR BCT
[ 23.7358 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 23.7971 ]
[ 23.7972 ] Updating bl info
[ 23.8021 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 23.8088 ]
[ 23.8089 ] Generating signatures
[ 23.8138 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 23.8141 ] Assuming zero filled SBK key
[ 24.4755 ] Send BCT from Host
[ 24.4756 ] Generating br-bct
[ 24.4802 ] Performing cfg overlay
[ 24.4803 ] [‘/home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41.cfg’]
[ 24.4803 ] Updating dev and MSS params in BR BCT
[ 24.4805 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 24.5404 ]
[ 24.5406 ] Updating bl info
[ 24.5434 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 24.5503 ]
[ 24.5504 ] Updating smd info
[ 24.5548 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 24.5584 ]
[ 24.5586 ] Updating Odmdata
[ 24.5631 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 24.5665 ]
[ 24.5667 ] Get Signed section of bct
[ 24.5711 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 24.5752 ]
[ 24.5800 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 24.5833 ] Assuming zero filled SBK key
[ 24.6340 ]
[ 24.6341 ] Updating BCT with signature
[ 24.6395 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 24.6426 ]
[ 24.6428 ] Generating coldboot mb1-bct
[ 24.6479 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 24.6509 ] MB1-BCT version: 0x1
[ 24.6526 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 24.6542 ] Added Platform Config 0 data with size :- 2496
[ 24.6601 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 24.6618 ] Added Platform Config 1 data with size :- 19640
[ 24.6901 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 24.6918 ] Added Platform Config 2 data with size :- 24
[ 24.6918 ]
[ 24.6919 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 24.6919 ] Added Platform Config 4 data with size :- 348
[ 24.6919 ]
[ 24.6920 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 24.6920 ] Added Platform Config 3 data with size :- 92
[ 24.6920 ]
[ 24.6920 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 24.6921 ] Added Platform Config 5 data with size :- 128
[ 24.6921 ]
[ 24.6921 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 24.6921 ] Added Platform Config 7 data with size :- 392
[ 24.6922 ]
[ 24.6922 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 24.6922 ] Added Platform Config 9 data with size :- 40
[ 24.6922 ]
[ 24.6924 ] Updating mb1-bct with firmware information
[ 24.6970 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 24.7008 ] MB1-BCT version: 0x1
[ 24.7016 ]
[ 24.7017 ] Updating mb1-bct with storage information
[ 24.7060 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 24.7089 ] MB1-BCT version: 0x1
[ 24.7100 ]
[ 24.7143 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 24.7172 ]
[ 24.7215 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 24.7242 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 24.7270 ]
[ 24.7326 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 24.7329 ] Assuming zero filled SBK key
[ 24.7463 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 24.7510 ]
[ 24.7514 ] Generating recovery mb1-bct
[ 24.7565 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 24.7597 ] MB1-BCT version: 0x1
[ 24.7612 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 24.7624 ] Added Platform Config 0 data with size :- 2496
[ 24.7685 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 24.7700 ] Added Platform Config 1 data with size :- 19640
[ 24.7983 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 24.7993 ] Added Platform Config 2 data with size :- 24
[ 24.8003 ]
[ 24.8004 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 24.8004 ] Added Platform Config 4 data with size :- 348
[ 24.8004 ]
[ 24.8004 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 24.8005 ] Added Platform Config 3 data with size :- 92
[ 24.8005 ]
[ 24.8005 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 24.8005 ] Added Platform Config 5 data with size :- 128
[ 24.8006 ]
[ 24.8006 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 24.8006 ] Added Platform Config 7 data with size :- 392
[ 24.8006 ]
[ 24.8006 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 24.8007 ] Added Platform Config 9 data with size :- 40
[ 24.8007 ]
[ 24.8009 ] Updating mb1-bct with firmware information
[ 24.8060 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 24.8091 ] MB1-BCT version: 0x1
[ 24.8099 ]
[ 24.8100 ] Updating mb1-bct with storage information
[ 24.8144 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 24.8174 ] MB1-BCT version: 0x1
[ 24.8190 ]
[ 24.8233 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 24.8263 ]
[ 24.8306 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 24.8339 ] adding BCH for mb1_bct_MB1.bct
[ 24.8366 ]
[ 24.8426 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 24.8429 ] Assuming zero filled SBK key
[ 24.8567 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 24.8611 ]
[ 24.8615 ] Generating coldboot mem-bct
[ 24.8659 ] tegrabct_v2 --chip 0x19 0 --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41.cfg --membct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_1.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_2.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_3.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_4.bct
[ 24.8690 ] Packing sdram param for instance[0]
[ 24.9254 ] Packing sdram param for instance[1]
[ 24.9254 ] Packing sdram param for instance[2]
[ 24.9254 ] Packing sdram param for instance[3]
[ 24.9254 ] Packing sdram param for instance[4]
[ 24.9255 ] Packing sdram param for instance[5]
[ 24.9255 ] Packing sdram param for instance[6]
[ 24.9255 ] Packing sdram param for instance[7]
[ 24.9255 ] Packing sdram param for instance[8]
[ 24.9255 ] Packing sdram param for instance[9]
[ 24.9256 ] Packing sdram param for instance[10]
[ 24.9256 ] Packing sdram param for instance[11]
[ 24.9256 ] Packing sdram param for instance[12]
[ 24.9256 ] Packing sdram param for instance[13]
[ 24.9256 ] Packing sdram param for instance[14]
[ 24.9257 ] Packing sdram param for instance[15]
[ 24.9257 ]
[ 24.9258 ] Getting sector size from pt
[ 24.9286 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 24.9320 ]
[ 24.9323 ] BlockSize read from layout is 200
[ 24.9367 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_1.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_2.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_3.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_4.bct
[ 24.9397 ] adding BCH for /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_1.bct
[ 24.9489 ]
[ 24.9539 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 24.9571 ]
[ 24.9616 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 24.9651 ] Header already present for mem_coldboot.bct
[ 24.9665 ]
[ 24.9725 ] tegrasign_v3.py --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 24.9727 ] Assuming zero filled SBK key
[ 24.9869 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 24.9911 ]
[ 24.9914 ] Generating recovery mem-bct
[ 24.9953 ] tegrabct_v2 --chip 0x19 0 --sdram /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41.cfg --membct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_1.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_2.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_3.bct /home/share/igs/JETSON_NX/Jetson_Linux_R32.6.1_aarch64/Linux_for_Tegra/bootloader/2673/tmpdgcapow41_4.bct
[ 24.9982 ] Packing sdram param for instance[0]
[ 25.0577 ] Packing sdram param for instance[1]
[ 25.0577 ] Packing sdram param for instance[2]
[ 25.0578 ] Packing sdram param for instance[3]
[ 25.0578 ] Packing sdram param for instance[4]
[ 25.0578 ] Packing sdram param for instance[5]
[ 25.0578 ] Packing sdram param for instance[6]
[ 25.0578 ] Packing sdram param for instance[7]
[ 25.0579 ] Packing sdram param for instance[8]
[ 25.0579 ] Packing sdram param for instance[9]
[ 25.0579 ] Packing sdram param for instance[10]
[ 25.0579 ] Packing sdram param for instance[11]
[ 25.0579 ] Packing sdram param for instance[12]
[ 25.0580 ] Packing sdram param for instance[13]
[ 25.0580 ] Packing sdram param for instance[14]
[ 25.0580 ] Packing sdram param for instance[15]
[ 25.0580 ]
[ 25.0633 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 25.0665 ]
[ 25.0694 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 25.0719 ] adding BCH for mem_rcm.bct
[ 25.0739 ]
[ 25.0789 ] tegrasign_v3.py --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 25.0791 ] Assuming zero filled SBK key
[ 25.0910 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 25.0961 ]
[ 25.0964 ] Sending BCTs
[ 25.1003 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 25.1028 ] Applet is not running on device. Continue with Bootloader
[ 25.4906 ]
[ 25.4907 ] Generating blob
[ 25.4957 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 25.4989 ]
[ 25.5037 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 25.5066 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 25.5249 ]
[ 25.5290 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 25.5293 ] Assuming zero filled SBK key
[ 25.5417 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 25.5563 ]
[ 25.5596 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 25.5628 ]
[ 25.5675 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 25.5703 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 25.5865 ]
[ 25.5926 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 25.5928 ] Assuming zero filled SBK key
[ 25.6055 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 25.6165 ]
[ 25.6213 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 25.6243 ]
[ 25.6292 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 25.6319 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 25.6332 ]
[ 25.6385 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 25.6387 ] Assuming zero filled SBK key
[ 25.6512 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 25.6553 ]
[ 25.6596 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 25.6626 ]
[ 25.6668 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 25.6696 ] Header already present for blob_mce_c10_prod_cr.bin
[ 25.6763 ]
[ 25.6821 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 25.6823 ] Assuming zero filled SBK key
[ 25.6978 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 25.7081 ]
[ 25.7130 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 25.7164 ]
[ 25.7213 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 25.7243 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 25.8292 ]
[ 25.8337 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 25.8340 ] Assuming zero filled SBK key
[ 25.8621 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 25.9289 ]
[ 25.9338 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 25.9362 ]
[ 25.9406 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader blob_bpmp_t194.bin zerosbk
[ 25.9427 ] adding BCH for blob_bpmp_t194.bin
[ 25.9763 ]
[ 25.9821 ] tegrasign_v3.py --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 25.9824 ] Assuming zero filled SBK key
[ 25.9981 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 26.0282 ]
[ 26.0314 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p3668-a00.dtb
[ 26.0345 ]
[ 26.0391 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader blob_tegra194-a02-bpmp-p3668-a00.dtb zerosbk
[ 26.0420 ] adding BCH for blob_tegra194-a02-bpmp-p3668-a00.dtb
[ 26.0643 ]
[ 26.0703 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 26.0706 ] Assuming zero filled SBK key
[ 26.0860 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 26.1010 ]
[ 26.1059 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 26.1090 ]
[ 26.1136 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader blob_spe_t194.bin zerosbk
[ 26.1165 ] adding BCH for blob_spe_t194.bin
[ 26.1257 ]
[ 26.1316 ] tegrasign_v3.py --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 26.1319 ] Assuming zero filled SBK key
[ 26.1468 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 26.1543 ]
[ 26.1590 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[ 26.1621 ]
[ 26.1667 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader blob_tos-trusty_t194.img zerosbk
[ 26.1697 ] adding BCH for blob_tos-trusty_t194.img
[ 26.1944 ]
[ 26.2003 ] tegrasign_v3.py --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 26.2006 ] Assuming zero filled SBK key
[ 26.2171 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[ 26.2354 ]
[ 26.2402 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 26.2434 ]
[ 26.2481 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader blob_eks.img zerosbk
[ 26.2510 ] adding BCH for blob_eks.img
[ 26.2516 ]
[ 26.2570 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 26.2573 ] Assuming zero filled SBK key
[ 26.2703 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 26.2734 ]
[ 26.2782 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p3668-tly-jtnx.dtb
[ 26.2811 ]
[ 26.2856 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader blob_tegra194-p3668-tly-jtnx.dtb zerosbk
[ 26.2885 ] adding BCH for blob_tegra194-p3668-tly-jtnx.dtb
[ 26.3042 ]
[ 26.3104 ] tegrasign_v3.py --key None --list blob_tegra194-p3668-tly-jtnx_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 26.3108 ] Assuming zero filled SBK key
[ 26.3265 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt blob_tegra194-p3668-tly-jtnx_sigheader.dtb.hash zerosbk
[ 26.3775 ]
[ 26.3833 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 26.3866 ] number of images in blob are 11
[ 26.3875 ] blobsize is 5890728
[ 26.3879 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 263840
[ 26.3975 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 181152
[ 26.3989 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 26.4002 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[ 26.4014 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[ 26.4042 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[ 26.4058 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt of size 281984
[ 26.4072 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[ 26.4083 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[ 26.4094 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 26.4104 ] Added binary blob_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt of size 198928
[ 26.4150 ]
[ 26.4152 ] Sending bootloader and pre-requisite binaries
[ 26.4195 ] tegrarcm_v2 --download blob blob.bin
[ 26.4222 ] Applet is not running on device. Continue with Bootloader
[ 27.0886 ]
[ 27.0934 ] tegrarcm_v2 --boot recovery
[ 27.0965 ] Applet is not running on device. Continue with Bootloader
[ 27.5548 ]
[ 28.5610 ] tegrarcm_v2 --isapplet
[ 29.2287 ]
[ 29.2336 ] tegrarcm_v2 --ismb2
[ 29.9167 ]
[ 29.9216 ] tegradevflash_v2 --iscpubl
[ 29.9248 ] Bootloader version 01.00.0000
[ 30.2690 ] Bootloader version 01.00.0000
[ 30.2706 ]
[ 30.2707 ] Writing partition
[ 30.2755 ] tegradevflash_v2 --write kernel-dtb 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt
[ 30.2786 ] Bootloader version 01.00.0000
[ 30.6053 ] Writing partition kernel-dtb with 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt
[ 30.6070 ] 000000000d0d000d: o open partition %s.
[ 30.6073 ]
[ 30.6073 ]
Command tegradevflash_v2 --write kernel-dtb 1_kernel_tegra194-p3668-tly-jtnx_sigheader.dtb.encrypt
Failed to flash/read t186ref.
Any suggestion?
You can narrow down it first. Will it fail if you just put this dtb file in the original board conf?
I did not got a original board.
I tried to use the default conf file to flash the kernel dtb to the customized board.It also failed.
Will The version of l4t pgk make difference?
Should I pay more attention on hardware design?
Which part could more possibly be the reason?
I think it is hardware problem. But I am not hardware guy so cannot comment here.
You can check the NX product design guide first.
