I ran: sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1 2>&1 > log.txt
this got spit out to stdout:
iouri@iouri-XPS-15-9500:~/devel/nvidia/Linux_for_Tegra$ sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1 2>&1 > log.txt
[sudo] password for iouri:
30412 blocks
66121 blocks
20+0 records in
20+0 records out
20 bytes copied, 0.000371232 s, 53.9 kB/s
File "./tegraflash.py", line 1296, in <module>
tegraflash_run_commands()
File "./tegraflash.py", line 1155, in tegraflash_run_commands
interpreter.onecmd(command)
File "/usr/lib/python3.8/cmd.py", line 217, in onecmd
return func(arg)
File "./tegraflash.py", line 216, in do_flash
tegraflash_flash(exports)
File "/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 266, in tegraflash_flash
tegraflash_generate_bct()
File "/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 4004, in tegraflash_generate_bct
tegraflash_generate_br_bct(True)
File "/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 3510, in tegraflash_generate_br_bct
run_command(command)
File "/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 202, in run_command
log = print_process(process, enable_print)
File "/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 164, in print_process
outputchar = output.decode('ascii')
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 0: ordinal not in range(128)
this is the log:
L4T BSP Information:
R32 , REVISION: 6.1
Target Board Information:
Name: jetson-xavier-nx-devkit-emmc, Board Family: t186ref, SoC: Tegra 194,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying soft_fuses(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
./tegraflash.py --chip 0x19 --applet “/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0166 ] Generating RCM messages
[ 0.0208 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0239 ] Header already present for /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0283 ]
[ 0.0328 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0330 ] Assuming zero filled SBK key
[ 0.0385 ] tegrasign_v3.py --file /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0386 ] Assuming zero filled SBK key
[ 0.0535 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0607 ]
[ 0.0654 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0692 ]
[ 0.0734 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0764 ] RCM 0 is saved as rcm_0.rcm
[ 0.0801 ] RCM 1 is saved as rcm_1.rcm
[ 0.0804 ] RCM 2 is saved as rcm_2.rcm
[ 0.0810 ] List of rcm files are saved in rcm_list.xml
[ 0.0812 ]
[ 0.0812 ] Signing RCM messages
[ 0.0856 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0857 ] Assuming zero filled SBK key
[ 0.1100 ] Copying signature to RCM mesages
[ 0.1143 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1201 ]
[ 0.1202 ] Boot Rom communication
[ 0.1244 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1276 ] RCM version 0X190001
[ 0.5068 ] Boot Rom communication completed
[ 1.5247 ]
[ 2.5376 ] tegrarcm_v2 --isapplet
[ 2.5408 ] Applet version 01.00.0000
[ 2.9475 ]
[ 2.9521 ] tegrarcm_v2 --ismb2
[ 3.1838 ]
[ 3.1891 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 3.1933 ]
[ 3.1984 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 3.2028 ] adding BCH for nvtboot_applet_t194.bin
[ 3.2082 ]
[ 3.2156 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.2157 ] Assuming zero filled SBK key
[ 3.2343 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 3.2422 ]
[ 3.2481 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 3.2525 ] Applet version 01.00.0000
[ 4.1117 ] Sending mb2
[ 4.1125 ] […] 100%
[ 4.1308 ]
[ 4.1447 ] tegrarcm_v2 --boot recovery
[ 4.1560 ] Applet version 01.00.0000
[ 4.7796 ]
[ 5.7893 ] tegrarcm_v2 --isapplet
[ 6.6139 ]
[ 6.6188 ] tegrarcm_v2 --ismb2
[ 6.6220 ] MB2 Applet version 01.00.0000
[ 6.8519 ]
[ 6.8633 ] tegrarcm_v2 --ismb2
[ 6.8667 ] MB2 Applet version 01.00.0000
[ 7.5235 ]
[ 7.5352 ] Retrieving board information
[ 7.5400 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 7.5434 ] MB2 Applet version 01.00.0000
[ 7.9858 ] Saved platform info in chip_info.bin
[ 7.9900 ] Chip minor revision: 2
[ 7.9904 ] Bootrom revision: 0xf
[ 7.9908 ] Ram code: 0x0
[ 7.9908 ] Chip sku: 0xde
[ 7.9908 ] Chip Sample: non es
[ 7.9908 ]
[ 7.9913 ] Retrieving EEPROM data
[ 7.9913 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/cvm.bin
[ 7.9944 ] MB2 Applet version 01.00.0000
[ 8.6546 ] Saved platform info in /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/cvm.bin
[ 8.6916 ]
[ 8.6919 ] Rebooting to recovery mode
[ 8.6983 ] tegrarcm_v2 --ismb2
[ 8.7020 ] MB2 Applet version 01.00.0000
[ 9.1307 ]
[ 9.1307 ] Rebooting to recovery mode
[ 9.1357 ] tegrarcm_v2 --reboot recovery
[ 9.1394 ] MB2 Applet version 01.00.0000
[ 9.5748 ]
Board ID(3668) version(000) sku(0001) revision(F.0)
Copy /home/iouri/devel/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to /home/iouri/devel/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec
copying bctfile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)… done.
copying bctfile1(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)… done.
copying minratchet_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)… done.
copying device_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)… done.
copying misc_cold_boot_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)… done.
copying misc_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)… done.
copying pinmux_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)… done.
copying gpioint_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)… done.
copying pmic_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)… done.
copying pmc_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)… done.
copying prod_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)… done.
copying scr_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)… done.
copying scr_cold_boot_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)… done.
copying bootrom_config(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)… done.
copying dev_params(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)… done.
Existing bootloader(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0007 ] Generating signature
[ 0.0054 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0055 ] Assuming zero filled SBK key : not reading
[ 0.0059 ] Generating ratchet blob
[ 0.0100 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0130 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0136 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0139 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0139 ]
[ 0.0141 ] header_magic: 414e4452
[ 0.0179 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0211 ]
[ 0.0253 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[ 0.0283 ] adding BCH for 1_boot.img
[ 1.0322 ]
[ 1.0379 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 1.0379 ] Assuming zero filled SBK key : not reading
[ 1.4072 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 2.0642 ]
[ 2.2175 ] Signed file: /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27cb800 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader /home/iouri/devel/nvidia/Linux_for_Tegra
_BASE_KERNEL_VERSION=4.9.253-tegra
/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp/lib /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader /home/iouri/devel/nvidia/Linux_for_Tegra
Making Recovery image…
copying recdtbfile(/home/iouri/devel/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)… done.
Existing sosfile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)… done.
Existing scefile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/iouri/devel/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)… done.
Copying nv_boot_control.conf to rootfs
/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[ 0.0010 ] Generating signature
[ 0.0057 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0058 ] Assuming zero filled SBK key : not reading
[ 0.0062 ] Generating ratchet blob
[ 0.0104 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0135 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0141 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0143 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0144 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0144 ]
[ 0.0146 ] header_magic: d00dfeed
[ 0.0184 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0216 ]
[ 0.0258 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 0.0286 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0343 ]
[ 0.0407 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0409 ] Assuming zero filled SBK key : not reading
[ 0.0592 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 0.0661 ]
[ 0.0675 ] Signed file: /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x31f5f to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra194-p3668-all-p3509-0000.dtb to rootfs… done.
Making system.img…
populating rootfs from /home/iouri/devel/nvidia/Linux_for_Tegra/rootfs … populating /boot/extlinux/extlinux.conf … done.
generating sig file of Image … /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign ./boot/Image kernel
version 1.0.0
[ 0.0012 ] Generating signature
[ 0.0059 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0060 ] Assuming zero filled SBK key : not reading
[ 0.0065 ] Generating ratchet blob
[ 0.0107 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0136 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0143 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0146 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0146 ]
[ 0.0148 ] header_magic: 405614
[ 0.0194 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0232 ]
[ 0.0278 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_Image zerosbk
[ 0.0309 ] adding BCH for 1_Image
[ 0.9318 ]
[ 0.9374 ] tegrasign_v3.py --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.9375 ] Assuming zero filled SBK key : not reading
[ 1.3113 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 1.9170 ]
[ 2.0769 ] Signed file: /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mnt/Image_sigheader.encrypt
l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x20e3008 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/Image.sig
done.
done.
generating sig file of kernel_tegra194-p3668-all-p3509-0000.dtb … /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign ./boot/dtb/kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[ 0.0011 ] Generating signature
[ 0.0056 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0057 ] Assuming zero filled SBK key : not reading
[ 0.0108 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0183 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0197 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0202 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0202 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0203 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0203 ]
[ 0.0205 ] header_magic: d00dfeed
[ 0.0270 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0316 ]
[ 0.0367 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 0.0402 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0459 ]
[ 0.0521 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0522 ] Assuming zero filled SBK key : not reading
[ 0.0682 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 0.0750 ]
[ 0.0766 ] Signed file: /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mnt/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/dtb/kernel_tegra194-p3668-all-p3509-0000.dtb.sig
done.
done.
generating sig file of initrd … /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/initrd data
version 1.0.0
[ 0.0009 ] Generating signature
[ 0.0065 ] header_magic: 1f8b0800
[ 0.0108 ] tegrahost_v2 --chip 0x19 --align 1_initrd
[ 0.0144 ]
[ 0.0182 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
[ 0.0209 ] adding BCH for 1_initrd
[ 0.2024 ]
[ 0.2081 ] tegrasign_v3.py --key --list 1_initrd_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.2082 ] Assuming zero filled SBK key : not reading
[ 0.2849 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
[ 0.3998 ]
[ 0.4271 ] Signed file: /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mnt/initrd_sigheader.encrypt
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x6e72c8 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/initrd.sig
done.
done.
generating sig file of extlinux.conf … /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/extlinux/extlinux.conf data
version 1.0.0
[ 0.0064 ] header_magic: 54494d45
[ 0.0109 ] tegrahost_v2 --chip 0x19 --align 1_extlinux.conf
[ 0.0145 ]
[ 0.0182 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_extlinux.conf zerosbk
[ 0.0209 ] adding BCH for 1_extlinux.conf
[ 0.0215 ]
[ 0.0268 ] tegrasign_v3.py --key --list 1_extlinux_sigheader.conf_list.xml --pubkeyhash pub_key.key
[ 0.0269 ] Assuming zero filled SBK key : not reading
[ 0.0405 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_extlinux_sigheader.conf.encrypt 1_extlinux_sigheader.conf.hash zerosbk
[ 0.0452 ]
[ 0.0458 ] Signed file: /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/mnt/extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: Generate header for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: chip 0x19: add 0x350 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/extlinux/extlinux.conf.sig
done.
done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/iouri/devel/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)… done.
copying cfgfile(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t194_spi_emmc_p3668.xml) to flash.xml… done.
Existing flasher(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0xB8190000 --applet mb1_t194_prod.bin --cmd “flash; reboot” --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi.cfg --bin “mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb” --trim_bpmp_dtb
saving flash command in /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0272 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0273 ] Assuming zero filled SBK key
[ 0.0048 ] Generating RCM messages
[ 0.0089 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0116 ] Header already present for mb1_t194_prod.bin
[ 0.0158 ]
[ 0.0431 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0432 ] Assuming zero filled SBK key
[ 0.0476 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0477 ] Assuming zero filled SBK key
[ 0.0395 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0472 ]
[ 0.0517 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0560 ]
[ 0.0603 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0633 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0643 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0643 ]
[ 0.0684 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0712 ] RCM 0 is saved as rcm_0.rcm
[ 0.0750 ] RCM 1 is saved as rcm_1.rcm
[ 0.0755 ] RCM 2 is saved as rcm_2.rcm
[ 0.0760 ] List of rcm files are saved in rcm_list.xml
[ 0.0760 ]
[ 0.0760 ] Signing RCM messages
[ 0.1034 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1034 ] Assuming zero filled SBK key
[ 0.1052 ] Copying signature to RCM mesages
[ 0.1094 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1161 ]
[ 0.1162 ] Parsing partition layout
[ 0.1221 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.1277 ]
[ 0.1280 ] Reading ramcode from backup chip_info.bin file
[ 0.1282 ] RAMCODE Read from Device: 0
[ 0.1284 ] Generating BPMP dtb for ramcode - 0
[ 0.2146 ] Old BPMP dtb size - 277874 bytes
[ 0.2146 ] New BPMP dtb size - 195698 bytes
[ 0.2150 ]
[ 0.2155 ] Creating list of images to be signed
[ 0.2199 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.2227 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.2242 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.2264 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.2299 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.2326 ] adding BCH for spe_t194.bin
[ 0.2357 ] adding BCH for spe_t194.bin
[ 0.2378 ] adding BCH for nvtboot_t194.bin
[ 0.2401 ] adding BCH for nvtboot_t194.bin
[ 0.2440 ] Header already present for preboot_c10_prod_cr.bin
[ 0.2485 ] Header already present for preboot_c10_prod_cr.bin
[ 0.2493 ] Header already present for mce_c10_prod_cr.bin
[ 0.2500 ] Header already present for mce_c10_prod_cr.bin
[ 0.2512 ] adding BCH for mts_c10_prod_cr.bin
[ 0.2578 ] adding BCH for mts_c10_prod_cr.bin
[ 0.3411 ] Header already present for warmboot_t194_prod.bin
[ 0.4258 ] Header already present for warmboot_t194_prod.bin
[ 0.4270 ] adding BCH for xusb_sil_rel_fw
[ 0.4280 ] adding BCH for xusb_sil_rel_fw
[ 0.4310 ] adding BCH for cboot_t194.bin
[ 0.4344 ] adding BCH for cboot_t194.bin
[ 0.4452 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.4573 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.4620 ] adding BCH for tos-trusty_t194.img
[ 0.4675 ] adding BCH for tos-trusty_t194.img
[ 0.4771 ] adding BCH for eks.img
[ 0.4868 ] adding BCH for eks.img
[ 0.4872 ] adding BCH for adsp-fw.bin
[ 0.4876 ] adding BCH for adsp-fw.bin
[ 0.4897 ] adding BCH for camera-rtcpu-rce.img
[ 0.4930 ] adding BCH for camera-rtcpu-rce.img
[ 0.4992 ] adding BCH for bpmp_t194.bin
[ 0.5072 ] adding BCH for bpmp_t194.bin
[ 0.5286 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 0.5510 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 0.5554 ] adding BCH for boot.img
[ 0.6330 ] adding BCH for boot.img
[ 1.6814 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[ 2.7083 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[ 2.7128 ] adding BCH for recovery.img
[ 2.9357 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb.rec
[ 4.1150 ]
[ 4.1150 ] Filling MB1 storage info
[ 4.1150 ] Generating br-bct
[ 4.1206 ] Performing cfg overlay
[ 4.1206 ] [‘tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg’, ‘tegra194-memcfg-sw-override.cfg’]
[ 4.1211 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/954856/tmptbfvbc931.cfg
[ 4.1690 ]
[ 4.1692 ] Updating dev and MSS params in BR BCT
[ 4.1692 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/954856/tmptbfvbc931.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 4.1991 ]
[ 4.1992 ] Updating bl info
[ 4.2037 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 4.2121 ]
[ 4.2122 ] Generating signatures
[ 4.2395 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 4.2396 ] Assuming zero filled SBK key
[ 5.8727 ] Generating br-bct
[ 5.8773 ] Performing cfg overlay
[ 5.8773 ] [‘/home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/954856/tmptbfvbc931.cfg’]
[ 5.8774 ] Updating dev and MSS params in BR BCT
[ 5.8774 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/iouri/devel/nvidia/Linux_for_Tegra/bootloader/954856/tmptbfvbc931.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.9062 ]
[ 5.9062 ] Updating bl info
[ 5.9108 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 5.9214 ]
[ 5.9215 ] Updating smd info
[ 5.9261 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 5.9303 ]
[ 5.9304 ] Updating Odmdata
[ 5.9349 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 5.9393 ]
[ 5.9393 ] Get Signed section of bct
[ 5.9439 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 5.9480 ]
[ 5.9526 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 5.9558 ] /usr/bin/env: Failed flashing t186ref.
