sudo SKIP_EEPROM_CHECK = 1 ./flash.sh BOARDID=3668 FAB=100 BOARDSKU=0000 jetson-xavier-nx-devkit mmcblk0p1
i try above command
and i get this result
# L4T BSP Information:
# R32 , REVISION: 7.3
# Target Board Information:
# Name: jetson-xavier-nx-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0030 ] Generating RCM messages
[ 0.0043 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0049 ] Header already present for /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0105 ]
[ 0.0130 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0131 ] Assuming zero filled SBK key
[ 0.0150 ] tegrasign_v3.py --file /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0151 ] Assuming zero filled SBK key
[ 0.0231 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0265 ]
[ 0.0291 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0313 ]
[ 0.0333 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0341 ] RCM 0 is saved as rcm_0.rcm
[ 0.0369 ] RCM 1 is saved as rcm_1.rcm
[ 0.0370 ] RCM 2 is saved as rcm_2.rcm
[ 0.0370 ] List of rcm files are saved in rcm_list.xml
[ 0.0370 ]
[ 0.0370 ] Signing RCM messages
[ 0.0392 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0392 ] Assuming zero filled SBK key
[ 0.0445 ] Copying signature to RCM mesages
[ 0.0463 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0473 ]
[ 0.0473 ] Boot Rom communication
[ 0.0491 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0497 ] RCM version 0X190001
[ 0.0751 ] Boot Rom communication completed
[ 1.0919 ]
[ 2.0974 ] tegrarcm_v2 --isapplet
[ 2.0998 ] Applet version 01.00.0000
[ 2.1293 ]
[ 2.1333 ] tegrarcm_v2 --ismb2
[ 2.1811 ]
[ 2.1852 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.1877 ]
[ 2.1917 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.1940 ] adding BCH for nvtboot_applet_t194.bin
[ 2.2058 ]
[ 2.2119 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.2121 ] Assuming zero filled SBK key
[ 2.2227 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.2301 ]
[ 2.2337 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.2356 ] Applet version 01.00.0000
[ 2.3102 ] Sending mb2
[ 2.3104 ] [................................................] 100%
[ 2.3271 ]
[ 2.3310 ] tegrarcm_v2 --boot recovery
[ 2.3331 ] Applet version 01.00.0000
[ 2.4094 ]
[ 3.4153 ] tegrarcm_v2 --isapplet
[ 3.4900 ]
[ 3.4943 ] tegrarcm_v2 --ismb2
[ 3.4964 ] MB2 Applet version 01.00.0000
[ 3.5862 ]
[ 3.5886 ] tegrarcm_v2 --ismb2
[ 3.5893 ] MB2 Applet version 01.00.0000
[ 3.6781 ]
[ 3.6820 ] Retrieving board information
[ 3.6856 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.6877 ] MB2 Applet version 01.00.0000
[ 3.7640 ] Saved platform info in chip_info.bin
[ 3.7686 ] Chip minor revision: 2
[ 3.7687 ] Bootrom revision: 0xf
[ 3.7689 ] Ram code: 0x0
[ 3.7690 ] Chip sku: 0xde
[ 3.7691 ] Chip Sample: non es
[ 3.7693 ]
[ 3.7695 ] Retrieving EEPROM data
[ 3.7696 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 3.7704 ] MB2 Applet version 01.00.0000
[ 3.8478 ] Saved platform info in /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 3.8822 ]
[ 3.8824 ] Rebooting to recovery mode
[ 3.8862 ] tegrarcm_v2 --ismb2
[ 3.8884 ] MB2 Applet version 01.00.0000
[ 3.9628 ]
[ 3.9629 ] Rebooting to recovery mode
[ 3.9671 ] tegrarcm_v2 --reboot recovery
[ 3.9694 ] MB2 Applet version 01.00.0000
[ 4.0692 ]
Board ID() version() sku() revision()
lz4c installed at /usr/bin/lz4c
Compressing /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb ...
Copy /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec
copying bctfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying minratchet_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
copying device_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-sd-l4t.cfg)... done.
copying misc_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)... done.
Existing bootloader(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0004 ] Generating signature
[ 0.0026 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0026 ] Assuming zero filled SBK key : not reading
[ 0.0025 ] Generating ratchet blob
[ 0.0044 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0052 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0057 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0057 ]
[ 0.0058 ] header_magic: 414e4452
[ 0.0076 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0082 ]
[ 0.0099 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[ 0.0104 ] adding BCH for 1_boot.img
[ 0.7897 ]
[ 0.7924 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.7924 ] Assuming zero filled SBK key : not reading
[ 0.8572 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 1.2880 ]
[ 1.3114 ] Signed file: /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27ef000 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.299-tegra
~/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
66033 blocks
Making Recovery image...
copying recdtbfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)... done.
20+0 레코드 들어옴
20+0 레코드 나감
20 bytes copied, 0.000298465 s, 67.0 kB/s
Existing sosfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
Existing bpfdtbfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegra194-a02-bpmp-p3668-a00_lz4.dtb) reused.
Existing scefile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[ 0.0005 ] Generating signature
[ 0.0027 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0027 ] Assuming zero filled SBK key : not reading
[ 0.0026 ] Generating ratchet blob
[ 0.0050 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0053 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0053 ]
[ 0.0054 ] header_magic: d00dfeed
[ 0.0073 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0079 ]
[ 0.0098 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 0.0104 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0155 ]
[ 0.0182 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0183 ] Assuming zero filled SBK key : not reading
[ 0.0234 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 0.0264 ]
[ 0.0267 ] Signed file: /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x31f5f to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra194-p3668-all-p3509-0000.dtb to rootfs... done.
Making system.img...
populating rootfs from /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
generating sig file of Image ... /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign ./boot/Image kernel
version 1.0.0
[ 0.0028 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0028 ] Assuming zero filled SBK key : not reading
[ 0.0027 ] Generating ratchet blob
[ 0.0048 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0054 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0056 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0057 ]
[ 0.0061 ] header_magic: c05614
[ 0.0082 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0090 ]
[ 0.0109 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_Image zerosbk
[ 0.0115 ] adding BCH for 1_Image
[ 0.6741 ]
[ 0.6768 ] tegrasign_v3.py --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.6769 ] Assuming zero filled SBK key : not reading
[ 0.7353 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 1.0697 ]
[ 1.0913 ] Signed file: /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/Image_sigheader.encrypt
l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x2106808 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/Image.sig
done.
done.
generating sig file of kernel_tegra194-p3668-all-p3509-0000.dtb ... /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign ./boot/dtb/kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[ 0.0007 ] Generating signature
[ 0.0029 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0030 ] Assuming zero filled SBK key : not reading
[ 0.0029 ] Generating ratchet blob
[ 0.0047 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0053 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0055 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0055 ]
[ 0.0059 ] header_magic: d00dfeed
[ 0.0078 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0087 ]
[ 0.0107 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 0.0113 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0169 ]
[ 0.0198 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0199 ] Assuming zero filled SBK key : not reading
[ 0.0244 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 0.0278 ]
[ 0.0282 ] Signed file: /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/dtb/kernel_tegra194-p3668-all-p3509-0000.dtb.sig
done.
done.
generating sig file of initrd ... /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/initrd data
version 1.0.0
[ 0.0031 ] header_magic: 1f8b0800
[ 0.0049 ] tegrahost_v2 --chip 0x19 --align 1_initrd
[ 0.0058 ]
[ 0.0077 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
[ 0.0083 ] adding BCH for 1_initrd
[ 0.1518 ]
[ 0.1546 ] tegrasign_v3.py --key --list 1_initrd_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.1546 ] Assuming zero filled SBK key : not reading
[ 0.1687 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
[ 0.2426 ]
[ 0.2473 ] Signed file: /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/initrd_sigheader.encrypt
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x6e7533 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/initrd.sig
done.
done.
generating sig file of extlinux.conf ... /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/extlinux/extlinux.conf data
version 1.0.0
[ 0.0027 ] header_magic: 54494d45
[ 0.0046 ] tegrahost_v2 --chip 0x19 --align 1_extlinux.conf
[ 0.0052 ]
[ 0.0071 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_extlinux.conf zerosbk
[ 0.0078 ] adding BCH for 1_extlinux.conf
[ 0.0079 ]
[ 0.0105 ] tegrasign_v3.py --key --list 1_extlinux_sigheader.conf_list.xml --pubkeyhash pub_key.key
[ 0.0105 ] Assuming zero filled SBK key : not reading
[ 0.0143 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_extlinux_sigheader.conf.encrypt 1_extlinux_sigheader.conf.hash zerosbk
[ 0.0150 ]
[ 0.0153 ] Signed file: /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mnt/extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: Generate header for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: chip 0x19: add 0x350 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/extlinux/extlinux.conf.sig
done.
done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
copying cfgfile(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t194_spi_sd_p3668.xml) to flash.xml... done.
Existing flasher(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0xB8190000 --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-sd-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_lz4.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb"
saving flash command in /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0078 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0079 ] Assuming zero filled SBK key
[ 0.0023 ] Generating RCM messages
[ 0.0044 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0050 ] Header already present for mb1_t194_prod.bin
[ 0.0083 ]
[ 0.0160 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0161 ] Assuming zero filled SBK key
[ 0.0182 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0166 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0202 ]
[ 0.0224 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0233 ]
[ 0.0251 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0257 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0259 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0260 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0260 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0260 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0260 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0260 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0260 ]
[ 0.0285 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0294 ] RCM 0 is saved as rcm_0.rcm
[ 0.0338 ] RCM 1 is saved as rcm_1.rcm
[ 0.0340 ] RCM 2 is saved as rcm_2.rcm
[ 0.0340 ] List of rcm files are saved in rcm_list.xml
[ 0.0340 ]
[ 0.0340 ] Signing RCM messages
[ 0.0419 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0420 ] Assuming zero filled SBK key
[ 0.0434 ] Copying signature to RCM mesages
[ 0.0455 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0468 ]
[ 0.0469 ] Parsing partition layout
[ 0.0495 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0518 ]
[ 0.0519 ] Reading ramcode from backup chip_info.bin file
[ 0.0521 ] RAMCODE Read from Device: 0
[ 0.0521 ] Disable BPMP dtb trim, using default dtb
[ 0.0521 ]
[ 0.0521 ] Creating list of images to be signed
[ 0.0541 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.0549 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.0555 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.0558 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.0595 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.0598 ] adding BCH for spe_t194.bin
[ 0.0637 ] adding BCH for spe_t194.bin
[ 0.0662 ] adding BCH for nvtboot_t194.bin
[ 0.0696 ] adding BCH for nvtboot_t194.bin
[ 0.0744 ] Header already present for preboot_c10_prod_cr.bin
[ 0.0796 ] Header already present for preboot_c10_prod_cr.bin
[ 0.0800 ] Header already present for mce_c10_prod_cr.bin
[ 0.0807 ] Header already present for mce_c10_prod_cr.bin
[ 0.0825 ] adding BCH for mts_c10_prod_cr.bin
[ 0.0882 ] adding BCH for mts_c10_prod_cr.bin
[ 0.1551 ] Header already present for warmboot_t194_prod.bin
[ 0.2237 ] Header already present for warmboot_t194_prod.bin
[ 0.2244 ] adding BCH for xusb_sil_rel_fw
[ 0.2255 ] adding BCH for xusb_sil_rel_fw
[ 0.2280 ] adding BCH for cboot_t194.bin
[ 0.2307 ] adding BCH for cboot_t194.bin
[ 0.2403 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.2493 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.2546 ] adding BCH for tos-trusty_t194.img
[ 0.2595 ] adding BCH for tos-trusty_t194.img
[ 0.2673 ] adding BCH for eks.img
[ 0.2760 ] adding BCH for eks.img
[ 0.2761 ] adding BCH for adsp-fw.bin
[ 0.2765 ] adding BCH for adsp-fw.bin
[ 0.2781 ] adding BCH for camera-rtcpu-rce.img
[ 0.2804 ] adding BCH for camera-rtcpu-rce.img
[ 0.2869 ] adding BCH for bpmp_t194.bin
[ 0.2944 ] adding BCH for bpmp_t194.bin
[ 0.3108 ] adding BCH for tegra194-a02-bpmp-p3668-a00_lz4.dtb
[ 0.3290 ] adding BCH for tegra194-a02-bpmp-p3668-a00_lz4.dtb
[ 0.3298 ] adding BCH for boot.img
[ 0.3490 ] adding BCH for boot.img
[ 1.1274 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[ 1.9601 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[ 1.9663 ] adding BCH for recovery.img
[ 2.0157 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb.rec
[ 2.9201 ]
[ 2.9202 ] Filling MB1 storage info
[ 2.9202 ] Generating br-bct
[ 2.9223 ] Performing cfg overlay
[ 2.9223 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 2.9229 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01.cfg
[ 2.9752 ]
[ 2.9753 ] Updating dev and MSS params in BR BCT
[ 2.9754 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.0344 ]
[ 3.0345 ] Updating bl info
[ 3.0365 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 3.0379 ]
[ 3.0380 ] Generating signatures
[ 3.0457 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 3.0458 ] Assuming zero filled SBK key
[ 3.3554 ] Generating br-bct
[ 3.3574 ] Performing cfg overlay
[ 3.3575 ] ['/home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01.cfg']
[ 3.3575 ] Updating dev and MSS params in BR BCT
[ 3.3576 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.4205 ]
[ 3.4206 ] Updating bl info
[ 3.4227 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.4245 ]
[ 3.4245 ] Updating smd info
[ 3.4264 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 3.4273 ]
[ 3.4273 ] Updating Odmdata
[ 3.4292 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 3.4300 ]
[ 3.4300 ] Get Signed section of bct
[ 3.4319 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 3.4330 ]
[ 3.4349 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 3.4361 ] Assuming zero filled SBK key
[ 3.4769 ]
[ 3.4770 ] Updating BCT with signature
[ 3.4790 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 3.4803 ]
[ 3.4803 ] Generating coldboot mb1-bct
[ 3.4837 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01.cfg --misc tegra194-mb1-bct-misc-sd-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 3.4863 ] MB1-BCT version: 0x1
[ 3.4877 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 3.4886 ] Added Platform Config 0 data with size :- 2496
[ 3.4926 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 3.4935 ] Added Platform Config 1 data with size :- 19640
[ 3.5246 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 3.5250 ] Added Platform Config 2 data with size :- 24
[ 3.5252 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 3.5256 ] Added Platform Config 4 data with size :- 348
[ 3.5259 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 3.5263 ] Added Platform Config 3 data with size :- 92
[ 3.5266 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 3.5268 ] Added Platform Config 5 data with size :- 128
[ 3.5268 ]
[ 3.5268 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 3.5268 ] Added Platform Config 7 data with size :- 392
[ 3.5268 ]
[ 3.5268 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 3.5268 ] Added Platform Config 9 data with size :- 40
[ 3.5268 ]
[ 3.5269 ] Updating mb1-bct with firmware information
[ 3.5292 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.5300 ] MB1-BCT version: 0x1
[ 3.5302 ]
[ 3.5302 ] Updating mb1-bct with storage information
[ 3.5324 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 3.5332 ] MB1-BCT version: 0x1
[ 3.5334 ]
[ 3.5334 ] Updating mb1-bct with ratchet information
[ 3.5353 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 3.5360 ] MB1-BCT version: 0x1
[ 3.5362 ] FwIndex: 1, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 2, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 3, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 4, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 5, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 6, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 7, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 11, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 12, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 13, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 14, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 15, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 16, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 17, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 18, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 19, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 30, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 31, MinRatchetLevel: 0
[ 3.5363 ] FwIndex: 32, MinRatchetLevel: 0
[ 3.5364 ]
[ 3.5383 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 3.5391 ]
[ 3.5410 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 3.5420 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 3.5431 ]
[ 3.5512 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.5513 ] Assuming zero filled SBK key
[ 3.5498 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 3.5509 ]
[ 3.5510 ] Generating recovery mb1-bct
[ 3.5532 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 3.5541 ] MB1-BCT version: 0x1
[ 3.5544 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 3.5547 ] Added Platform Config 0 data with size :- 2496
[ 3.5557 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 3.5560 ] Added Platform Config 1 data with size :- 19640
[ 3.5679 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 3.5681 ] Added Platform Config 2 data with size :- 24
[ 3.5683 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 3.5686 ] Added Platform Config 4 data with size :- 348
[ 3.5688 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 3.5691 ] Added Platform Config 3 data with size :- 92
[ 3.5691 ]
[ 3.5691 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 3.5691 ] Added Platform Config 5 data with size :- 128
[ 3.5691 ]
[ 3.5691 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 3.5691 ] Added Platform Config 7 data with size :- 392
[ 3.5691 ]
[ 3.5691 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 3.5691 ] Added Platform Config 9 data with size :- 40
[ 3.5691 ]
[ 3.5691 ] Updating mb1-bct with firmware information
[ 3.5712 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.5720 ] MB1-BCT version: 0x1
[ 3.5722 ]
[ 3.5722 ] Updating mb1-bct with storage information
[ 3.5743 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 3.5753 ] MB1-BCT version: 0x1
[ 3.5756 ]
[ 3.5756 ] Updating mb1-bct with ratchet information
[ 3.5777 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 3.5784 ] MB1-BCT version: 0x1
[ 3.5786 ] FwIndex: 1, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 2, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 3, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 4, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 5, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 6, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 7, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 11, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 12, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 13, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 14, MinRatchetLevel: 0
[ 3.5787 ] FwIndex: 15, MinRatchetLevel: 0
[ 3.5788 ] FwIndex: 16, MinRatchetLevel: 0
[ 3.5788 ] FwIndex: 17, MinRatchetLevel: 0
[ 3.5788 ] FwIndex: 18, MinRatchetLevel: 0
[ 3.5788 ] FwIndex: 19, MinRatchetLevel: 0
[ 3.5788 ] FwIndex: 30, MinRatchetLevel: 0
[ 3.5788 ] FwIndex: 31, MinRatchetLevel: 0
[ 3.5788 ] FwIndex: 32, MinRatchetLevel: 0
[ 3.5788 ]
[ 3.5808 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 3.5816 ]
[ 3.5836 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1.bct zerosbk
[ 3.5843 ] adding BCH for mb1_bct_MB1.bct
[ 3.5851 ]
[ 3.5931 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.5932 ] Assuming zero filled SBK key
[ 3.5921 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 3.5933 ]
[ 3.5934 ] Generating coldboot mem-bct
[ 3.5953 ] tegrabct_v2 --chip 0x19 0 --sdram /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01.cfg --membct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_1.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_2.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_3.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_4.bct
[ 3.5960 ] Packing sdram param for instance[0]
[ 3.6555 ] Packing sdram param for instance[1]
[ 3.6557 ] Packing sdram param for instance[2]
[ 3.6559 ] Packing sdram param for instance[3]
[ 3.6559 ] Packing sdram param for instance[4]
[ 3.6559 ] Packing sdram param for instance[5]
[ 3.6559 ] Packing sdram param for instance[6]
[ 3.6559 ] Packing sdram param for instance[7]
[ 3.6559 ] Packing sdram param for instance[8]
[ 3.6560 ] Packing sdram param for instance[9]
[ 3.6560 ] Packing sdram param for instance[10]
[ 3.6560 ] Packing sdram param for instance[11]
[ 3.6560 ] Packing sdram param for instance[12]
[ 3.6560 ] Packing sdram param for instance[13]
[ 3.6560 ] Packing sdram param for instance[14]
[ 3.6560 ] Packing sdram param for instance[15]
[ 3.6560 ]
[ 3.6560 ] Getting sector size from pt
[ 3.6581 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 3.6589 ]
[ 3.6590 ] BlockSize read from layout is 200
[ 3.6609 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_1.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_2.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_3.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_4.bct
[ 3.6615 ] adding BCH for /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_1.bct
[ 3.6636 ]
[ 3.6655 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 3.6663 ]
[ 3.6683 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct zerosbk
[ 3.6692 ] Header already present for mem_coldboot.bct
[ 3.6697 ]
[ 3.6783 ] tegrasign_v3.py --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.6785 ] Assuming zero filled SBK key
[ 3.6852 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 3.6893 ]
[ 3.6896 ] Generating recovery mem-bct
[ 3.6935 ] tegrabct_v2 --chip 0x19 0 --sdram /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01.cfg --membct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_1.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_2.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_3.bct /home/kys/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/14797/tmp7wgvxja01_4.bct
[ 3.6958 ] Packing sdram param for instance[0]
[ 3.7668 ] Packing sdram param for instance[1]
[ 3.7670 ] Packing sdram param for instance[2]
[ 3.7672 ] Packing sdram param for instance[3]
[ 3.7673 ] Packing sdram param for instance[4]
[ 3.7673 ] Packing sdram param for instance[5]
[ 3.7674 ] Packing sdram param for instance[6]
[ 3.7674 ] Packing sdram param for instance[7]
[ 3.7674 ] Packing sdram param for instance[8]
[ 3.7674 ] Packing sdram param for instance[9]
[ 3.7674 ] Packing sdram param for instance[10]
[ 3.7674 ] Packing sdram param for instance[11]
[ 3.7674 ] Packing sdram param for instance[12]
[ 3.7674 ] Packing sdram param for instance[13]
[ 3.7674 ] Packing sdram param for instance[14]
[ 3.7674 ] Packing sdram param for instance[15]
[ 3.7674 ]
[ 3.7696 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 3.7703 ]
[ 3.7722 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm.bct zerosbk
[ 3.7728 ] adding BCH for mem_rcm.bct
[ 3.7740 ]
[ 3.7819 ] tegrasign_v3.py --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.7820 ] Assuming zero filled SBK key
[ 3.7806 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 3.7819 ]
[ 3.7820 ] Copying signatures
[ 3.7840 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 5.3122 ]
[ 5.3123 ] Boot Rom communication
[ 5.3144 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 5.3151 ] BR_CID: 0x880219116471b504200000000d020140
[ 5.3447 ] RCM version 0X190001
[ 5.3888 ] Boot Rom communication completed
[ 6.4048 ]
[ 7.4109 ] tegrarcm_v2 --isapplet
[ 7.4138 ] Applet version 01.00.0000
[ 7.4859 ]
[ 7.4860 ] Sending BCTs
[ 7.4900 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 7.4922 ] Applet version 01.00.0000
[ 7.5821 ] Sending bct_bootrom
[ 7.5825 ] [................................................] 100%
[ 7.5838 ] Sending bct_mb1
[ 7.5882 ] [................................................] 100%
[ 7.5921 ] Sending bct_mem
[ 7.6421 ] [................................................] 100%
[ 7.7168 ]
[ 7.7170 ] Generating blob
[ 7.7213 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 7.7237 ]
[ 7.7275 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 7.7298 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 7.7395 ]
[ 7.7477 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.7477 ] Assuming zero filled SBK key
[ 7.7465 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 7.7503 ]
[ 7.7523 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 7.7557 ]
[ 7.7576 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 7.7583 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 7.7630 ]
[ 7.7711 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.7712 ] Assuming zero filled SBK key
[ 7.7697 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 7.7727 ]
[ 7.7749 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 7.7757 ]
[ 7.7776 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 7.7783 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 7.7787 ]
[ 7.7869 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.7871 ] Assuming zero filled SBK key
[ 7.7916 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.7948 ]
[ 7.7990 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 7.8013 ]
[ 7.8051 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 7.8075 ] Header already present for blob_mce_c10_prod_cr.bin
[ 7.8131 ]
[ 7.8232 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.8234 ] Assuming zero filled SBK key
[ 7.8290 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.8367 ]
[ 7.8409 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 7.8432 ]
[ 7.8468 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 7.8489 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 7.9330 ]
[ 7.9411 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.9412 ] Assuming zero filled SBK key
[ 7.9439 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.9814 ]
[ 7.9833 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 7.9839 ]
[ 7.9861 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t194.bin zerosbk
[ 7.9879 ] adding BCH for blob_bpmp_t194.bin
[ 8.0164 ]
[ 8.0245 ] tegrasign_v3.py --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.0245 ] Assuming zero filled SBK key
[ 8.0247 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 8.0338 ]
[ 8.0363 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p3668-a00_lz4.dtb
[ 8.0384 ]
[ 8.0423 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p3668-a00_lz4.dtb zerosbk
[ 8.0441 ] adding BCH for blob_tegra194-a02-bpmp-p3668-a00_lz4.dtb
[ 8.0459 ]
[ 8.0546 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.0547 ] Assuming zero filled SBK key
[ 8.0556 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.hash zerosbk
[ 8.0578 ]
[ 8.0605 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 8.0617 ]
[ 8.0642 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194.bin zerosbk
[ 8.0653 ] adding BCH for blob_spe_t194.bin
[ 8.0692 ]
[ 8.0778 ] tegrasign_v3.py --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.0779 ] Assuming zero filled SBK key
[ 8.0784 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 8.0817 ]
[ 8.0844 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[ 8.0858 ]
[ 8.0884 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-trusty_t194.img zerosbk
[ 8.0898 ] adding BCH for blob_tos-trusty_t194.img
[ 8.1058 ]
[ 8.1144 ] tegrasign_v3.py --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.1144 ] Assuming zero filled SBK key
[ 8.1147 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[ 8.1228 ]
[ 8.1254 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 8.1264 ]
[ 8.1287 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks.img zerosbk
[ 8.1296 ] adding BCH for blob_eks.img
[ 8.1298 ]
[ 8.1381 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.1382 ] Assuming zero filled SBK key
[ 8.1377 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 8.1389 ]
[ 8.1413 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p3668-all-p3509-0000.dtb
[ 8.1422 ]
[ 8.1445 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 8.1456 ] adding BCH for blob_tegra194-p3668-all-p3509-0000.dtb
[ 8.1524 ]
[ 8.1609 ] tegrasign_v3.py --key None --list blob_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.1610 ] Assuming zero filled SBK key
[ 8.1611 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 8.1656 ]
[ 8.1681 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 8.1690 ] number of images in blob are 11
[ 8.1694 ] blobsize is 5659368
[ 8.1695 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 264432
[ 8.1722 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 185296
[ 8.1727 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 8.1731 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[ 8.1735 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[ 8.1745 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[ 8.1758 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt of size 36080
[ 8.1764 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[ 8.1768 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[ 8.1772 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 8.1775 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of size 208736
[ 8.1798 ]
[ 8.1798 ] Sending bootloader and pre-requisite binaries
[ 8.1821 ] tegrarcm_v2 --download blob blob.bin
[ 8.1829 ] Applet version 01.00.0000
[ 8.2592 ] Sending blob
[ 8.2592 ] [................................................] 100%
[ 9.0832 ]
[ 9.0875 ] tegrarcm_v2 --boot recovery
[ 9.0901 ] Applet version 01.00.0000
[ 9.1228 ]
[ 10.1291 ] tegrarcm_v2 --isapplet
[ 10.4269 ]
[ 10.4314 ] tegrarcm_v2 --ismb2
[ 10.5058 ]
[ 10.5157 ] tegradevflash_v2 --iscpubl
[ 10.5182 ] Bootloader version 01.00.0000
[ 10.5510 ] Bootloader version 01.00.0000
[ 10.5517 ]
[ 10.5518 ] Retrieving storage infomation
[ 10.5560 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 10.5585 ] Applet is not running on device. Continue with Bootloader
[ 10.6485 ]
[ 10.6508 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 10.6516 ] Bootloader version 01.00.0000
[ 10.6996 ] Saved platform info in storage_info.bin
[ 10.7012 ]
[ 10.7013 ] Flashing the device
[ 10.7057 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 10.7097 ]
[ 10.7141 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 10.7167 ] Bootloader version 01.00.0000
[ 10.7467 ] Erasing spi: 0 ......... [Done]
[ 68.7563 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin
[ 68.7573 ] [................................................] 100%
[ 68.8740 ] Erasing sdcard: 0 ......... [Done]
[ 82.6674 ] Writing partition master_boot_record with mbr_6_0.bin
[ 82.6683 ] [................................................] 100%
[ 82.6696 ] Writing partition primary_gpt with gpt_primary_6_0.bin
[ 82.8237 ] [................................................] 100%
[ 82.8252 ] Writing partition secondary_gpt with gpt_secondary_6_0.bin
[ 82.8429 ] [................................................] 100%
[ 82.8571 ] Writing partition mb1 with mb1_t194_prod_sigheader.bin.encrypt
[ 82.8580 ] [................................................] 100%
[ 82.8692 ] Writing partition mb1_b with mb1_t194_prod_sigheader.bin.encrypt
[ 84.4660 ] [................................................] 100%
[ 84.4773 ] Writing partition spe-fw with spe_t194_sigheader.bin.encrypt
[ 86.0739 ] [................................................] 100%
[ 86.0788 ] Writing partition spe-fw_b with spe_t194_sigheader.bin.encrypt
[ 86.6917 ] [................................................] 100%
[ 86.6959 ] Writing partition mb2 with nvtboot_t194_sigheader.bin.encrypt
[ 87.3082 ] [................................................] 100%
[ 87.3165 ] Writing partition mb2_b with nvtboot_t194_sigheader.bin.encrypt
[ 88.5007 ] [................................................] 100%
[ 88.5083 ] Writing partition mts-preboot with preboot_c10_prod_cr_sigheader.bin.encrypt
[ 89.6919 ] [................................................] 100%
[ 89.6936 ] Writing partition mts-preboot_b with preboot_c10_prod_cr_sigheader.bin.encrypt
[ 89.8575 ] [................................................] 100%
[ 89.8591 ] Writing partition mts-mce with mce_c10_prod_cr_sigheader.bin.encrypt
[ 90.0228 ] [................................................] 100%
[ 90.0290 ] Writing partition mts-mce_b with mce_c10_prod_cr_sigheader.bin.encrypt
[ 90.9445 ] [................................................] 100%
[ 90.9507 ] Writing partition mts-proper with mts_c10_prod_cr_sigheader.bin.encrypt
[ 91.8656 ] [................................................] 100%
[ 111.8164 ] Writing partition mts-proper_b with mts_c10_prod_cr_sigheader.bin.encrypt
[ 113.6207 ] [................................................] 100%
[ 133.5677 ] Writing partition sc7 with warmboot_t194_prod_sigheader.bin.encrypt
[ 135.3733 ] [................................................] 100%
[ 135.3766 ] Writing partition sc7_b with warmboot_t194_prod_sigheader.bin.encrypt
[ 135.8012 ] [................................................] 100%
[ 135.8043 ] Writing partition SMD with slot_metadata.bin
[ 136.2283 ] [................................................] 100%
[ 136.2338 ] Writing partition SMD_b with slot_metadata.bin
[ 136.2421 ] [................................................] 100%
[ 136.2434 ] Writing partition xusb-fw with xusb_sil_rel_fw_sigheader.encrypt
[ 136.2519 ] [................................................] 100%
[ 136.2567 ] Writing partition xusb-fw_b with xusb_sil_rel_fw_sigheader.encrypt
[ 137.1011 ] [................................................] 100%
[ 137.1063 ] Writing partition cpu-bootloader with cboot_t194_sigheader.bin.encrypt
[ 137.9498 ] [................................................] 100%
[ 137.9682 ] Writing partition cpu-bootloader_b with cboot_t194_sigheader.bin.encrypt
[ 141.0224 ] [................................................] 100%
[ 141.0404 ] Writing partition bootloader-dtb with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 144.0944 ] [................................................] 100%
[ 144.1016 ] Writing partition bootloader-dtb_b with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 145.4271 ] [................................................] 100%
[ 145.4341 ] Writing partition BMP with bmp.blob
[ 146.7576 ] [................................................] 100%
[ 146.7640 ] Writing partition BMP_b with bmp.blob
[ 147.7185 ] [................................................] 100%
[ 147.7250 ] Writing partition secure-os with tos-trusty_t194_sigheader.img.encrypt
[ 148.6792 ] [................................................] 100%
[ 148.6937 ] Writing partition secure-os_b with tos-trusty_t194_sigheader.img.encrypt
[ 151.2884 ] [................................................] 100%
[ 151.3040 ] Writing partition eks with eks_sigheader.img.encrypt
[ 153.8972 ] [................................................] 100%
[ 153.8988 ] Writing partition eks_b with eks_sigheader.img.encrypt
[ 153.9443 ] [................................................] 100%
[ 153.9460 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt
[ 153.9920 ] [................................................] 100%
[ 153.9956 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt
[ 154.5200 ] [................................................] 100%
[ 154.5236 ] Writing partition rce-fw with camera-rtcpu-rce_sigheader.img.encrypt
[ 155.0480 ] [................................................] 100%
[ 155.0582 ] Writing partition rce-fw_b with camera-rtcpu-rce_sigheader.img.encrypt
[ 156.7832 ] [................................................] 100%
[ 156.7937 ] Writing partition bpmp-fw with bpmp_t194_sigheader.bin.encrypt
[ 158.5187 ] [................................................] 100%
[ 158.5515 ] Writing partition bpmp-fw_b with bpmp_t194_sigheader.bin.encrypt
[ 163.9500 ] [................................................] 100%
[ 163.9829 ] Writing partition bpmp-fw-dtb with tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt
[ 169.3818 ] [................................................] 100%
[ 169.3840 ] Writing partition bpmp-fw-dtb_b with tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt
[ 169.6249 ] [................................................] 100%
[ 169.6267 ] Writing partition VER with qspi_bootblob_ver.txt
[ 169.8675 ] [................................................] 100%
[ 169.9211 ] Writing partition VER_b with qspi_bootblob_ver.txt
[ 169.9300 ] [................................................] 100%
[ 169.9313 ] Writing partition master_boot_record with mbr_6_0.bin
[ 169.9401 ] [................................................] 100%
[ 169.9412 ] Writing partition kernel with boot_sigheader.img.encrypt
[ 169.9459 ] [................................................] 100%
[ 175.3599 ] Writing partition kernel_b with boot_sigheader.img.encrypt
[ 175.4489 ] [................................................] 100%
[ 180.8563 ] Writing partition kernel-dtb with kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 180.9465 ] [................................................] 100%
[ 180.9538 ] Writing partition kernel-dtb_b with kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 180.9868 ] [................................................] 100%
[ 180.9945 ] Writing partition recovery with recovery_sigheader.img.encrypt
[ 181.0322 ] [................................................] 100%
[ 187.4808 ] Writing partition recovery-dtb with tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt
[ 187.5181 ] [................................................] 100%
[ 187.5263 ] Writing partition kernel-bootctrl with kernel_bootctrl.bin
[ 187.5628 ] [................................................] 100%
[ 187.5659 ] Writing partition kernel-bootctrl_b with kernel_bootctrl.bin
[ 187.5753 ] [................................................] 100%
[ 187.5763 ] Writing partition APP with system.img
[ 187.5858 ] [................................................] 100%
[ 843.7301 ]
[ 843.7351 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 843.7380 ] Bootloader version 01.00.0000
[ 843.7675 ] Writing partition BCT with br_bct_BR.bct
[ 843.7686 ] [................................................] 100%
[ 843.9126 ]
[ 843.9198 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 843.9209 ] Bootloader version 01.00.0000
[ 843.9507 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 843.9524 ] [................................................] 100%
[ 844.1573 ]
[ 844.1627 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 844.1661 ] Bootloader version 01.00.0000
[ 844.1953 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 844.1970 ] [................................................] 100%
[ 844.4013 ]
[ 844.4089 ] tegradevflash_v2 --write MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 844.4103 ] Bootloader version 01.00.0000
[ 844.4394 ] Writing partition MEM_BCT with mem_coldboot_sigheader.bct.encrypt
[ 844.4410 ] [................................................] 100%
[ 845.7047 ]
[ 845.7101 ] tegradevflash_v2 --write MEM_BCT_b mem_coldboot_sigheader.bct.encrypt
[ 845.7129 ] Bootloader version 01.00.0000
[ 845.7465 ] Writing partition MEM_BCT_b with mem_coldboot_sigheader.bct.encrypt
[ 845.7483 ] [................................................] 100%
[ 847.0098 ]
[ 847.0100 ] Flashing completed
[ 847.0102 ] Coldbooting the device
[ 847.0145 ] tegrarcm_v2 --ismb2
[ 847.0461 ]
[ 847.0503 ] tegradevflash_v2 --reboot coldboot
[ 847.0525 ] Bootloader version 01.00.0000
[ 847.0990 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
and I booted jetson xavier and the result is same as before
