Jetson Xavier NX can not flash after falling down
Hi, everyone
Now my NX can not boot, it would enter recovery mode when I boot, though I don’t pull the recovery pin down.
And when I reflashed the whole board, it shows
[   5.2461 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[   5.2500 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   5.2510 ] adding BCH for mem_rcm_aligned.bct
[   5.2570 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   5.2573 ] Assuming zero filled SBK key
[   5.2605 ] Warning: pub_key.key is not found
[   5.2615 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   5.2636 ] Sending BCTs
[   5.2658 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   5.2668 ] Applet version 01.00.0000
[   5.7011 ] Sending bct_bootrom
[   5.7019 ] [................................................] 100%
[   5.7039 ] Sending bct_mb1
[   5.7068 ] [................................................] 100%
[   5.7121 ] Sending bct_mem
[   5.7579 ] [................................................] 100%
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   5.8387 ] Generating RCM messages
[   5.8456 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   5.8473 ] Header already present for mb1_t194_prod.bin
[   5.8567 ] tegrasign_v3.py --key None --getmode mode.txt
[   5.8572 ] Assuming zero filled SBK key
[   5.8605 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   5.8608 ] Assuming zero filled SBK key
[   5.8644 ] Warning: pub_key.key is not found
[   5.8661 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   5.8743 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   5.8786 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   5.8798 ] FwIndex: 1, MinRatchetLevel: 0
[   5.8802 ] FwIndex: 2, MinRatchetLevel: 0
[   5.8802 ] FwIndex: 3, MinRatchetLevel: 0
[   5.8802 ] FwIndex: 4, MinRatchetLevel: 0
[   5.8802 ] FwIndex: 5, MinRatchetLevel: 0
[   5.8802 ] FwIndex: 6, MinRatchetLevel: 0
[   5.8802 ] FwIndex: 7, MinRatchetLevel: 0
[   5.8802 ] FwIndex: 11, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 12, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 13, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 14, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 15, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 16, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 17, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 18, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 19, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 30, MinRatchetLevel: 0
[   5.8803 ] FwIndex: 31, MinRatchetLevel: 0
[   5.8803 ]
[   5.8830 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   5.8844 ] RCM 0 is saved as rcm_0.rcm
[   5.8877 ] RCM 1 is saved as rcm_1.rcm
[   5.8879 ] RCM 2 is saved as rcm_2.rcm
[   5.8881 ] List of rcm files are saved in rcm_list.xml
[   5.8881 ]
[   5.8881 ] Signing RCM messages
[   5.8936 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   5.8939 ] Assuming zero filled SBK key
[   5.9010 ] Warning: pub_key.key is not found
[   5.8992 ] Copying signature to RCM mesages
[   5.9016 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   5.9035 ] Boot Rom communication
[   5.9066 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   5.9084 ] BootRom is not running
[   7.3192 ] tegrarcm_v2 --isapplet
Could some people give me some suggestions?
Please dump the UART log during flashing:
Are you using a custom board or a DevKit?
Did you flash with the correct config file?
Hi @DaveYYY
The serial UART output garbled characters. like this:
Ể1��������ʫ��Z��b�k�fA�kK�N�H�[��7i��WŴ,+� k��ҠV�� j2��Y.��[��Ү&S��I>j��B��dKW���KҎ�1������r0KW���Sړӓ E
�1&I���J�������r�W�� �׍ճn�[��7I�9Wy u�uWJ�� ��Ku�YW�c��+� [��ѥ'*�W�Ů�W�1U�S�Y*��r�.j�d]�� �(z5S*��� >"����
���[0�������
emphasized text*Are you using a custom board or a DevKit?
DevKit
I used the config file which flashed successfully before
Can you please share the full flashing log instead of a cropped one?
Did you enable secure boot or things like that on the device?
OK, the whole log
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
# Target Board Information:
# Name: jetson-xavier-nx-devkit-emmc, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0172 ] Generating RCM messages
[   0.0184 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[   0.0192 ] Header already present for /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[   0.0261 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0265 ] Assuming zero filled SBK key
[   0.0287 ] tegrasign_v3.py --file /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0290 ] Assuming zero filled SBK key
[   0.0324 ] Warning: pub_key.key is not found
[   0.0336 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0400 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0435 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0450 ] RCM 0 is saved as rcm_0.rcm
[   0.0484 ] RCM 1 is saved as rcm_1.rcm
[   0.0484 ] RCM 2 is saved as rcm_2.rcm
[   0.0484 ] List of rcm files are saved in rcm_list.xml
[   0.0484 ]
[   0.0485 ] Signing RCM messages
[   0.0527 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0530 ] Assuming zero filled SBK key
[   0.0592 ] Warning: pub_key.key is not found
[   0.0576 ] Copying signature to RCM mesages
[   0.0598 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0614 ] Boot Rom communication
[   0.0625 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0635 ] RCM version 0X190001
[   0.2699 ] Boot Rom communication completed
[   2.2909 ] tegrarcm_v2 --isapplet
[   2.2940 ] Applet version 01.00.0000
[   2.7241 ] tegrarcm_v2 --ismb2
[   3.1724 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[   3.1807 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[   3.1844 ] adding BCH for nvtboot_applet_t194_aligned.bin
[   3.2062 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   3.2072 ] Assuming zero filled SBK key
[   3.2155 ] Warning: pub_key.key is not found
[   3.2200 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[   3.2353 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   3.2376 ] Applet version 01.00.0000
[   3.6636 ] Sending mb2
[   3.6636 ] [................................................] 100%
[   3.6823 ] tegrarcm_v2 --boot recovery
[   3.6841 ] Applet version 01.00.0000
[   5.1200 ] tegrarcm_v2 --isapplet
[   5.5475 ] tegrarcm_v2 --ismb2
[   5.5506 ] MB2 Applet version 01.00.0000
[   5.9968 ] tegrarcm_v2 --ismb2
[   5.9998 ] MB2 Applet version 01.00.0000
[   6.4292 ] Retrieving board information
[   6.4342 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   6.4376 ] MB2 Applet version 01.00.0000
[   6.8709 ] Saved platform info in chip_info.bin
[   6.8759 ] Chip minor revision: 2
[   6.8760 ] Bootrom revision: 0xf
[   6.8760 ] Ram code: 0x1
[   6.8760 ] Chip sku: 0xde
[   6.8760 ] Chip Sample: non es
[   6.8761 ]
[   6.8770 ] Retrieving EEPROM data
[   6.8772 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/cvm.bin
[   6.8811 ] MB2 Applet version 01.00.0000
[   7.3060 ] Saved platform info in /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/cvm.bin
[   7.3461 ] Rebooting to recovery mode
[   7.3495 ] tegrarcm_v2 --ismb2
[   7.3515 ] MB2 Applet version 01.00.0000
[   7.7718 ] Rebooting to recovery mode
[   7.7776 ] tegrarcm_v2 --reboot recovery
[   7.7809 ] MB2 Applet version 01.00.0000
Board ID(3668) version(301) sku(0001) revision(G.0)
lz4c installed at /usr/bin/lz4c
Compressing /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb ...
copying bctfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying minratchet_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
copying device_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi-l4t.cfg)... done.
copying dev_params_b(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct_b-qspi-l4t.cfg)... done.
Existing bootloader(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Existing sosfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/bpmp-2_t194.bin) reused.
Existing bpfdtbfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/tegra194-a02-bpmp-p3668-a00_lz4.dtb) reused.
Existing scefile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing apefile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/tos-optee_t194.img) reused.
Existing eksfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/eks_t194.img) reused.
copying dtbfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/kernel/dtb/tegra194-p3668-0001-p3509-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.81526 s, 82.3 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/kernel/dtb/tegra194-p3668-0001-p3509-0000.dtb)... done.
copying cfgfile(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t194_spi_emmc_p3668.xml) to flash.xml... done.
done.
Existing flasher(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Updating [APP] with /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/speye.img ***
copying overlay_dtb(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/ultwcz/repo/5.1.1/Linux_for_Tegra/kernel/dtb/tegra194-p3668-p3509-overlay.dtbo)... done.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --bldtb tegra194-p3668-0001-p3509-0000.dtb  --chip 0x19 --applet mb1_t194_prod.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi-l4t.cfg,tegra194-br-bct_b-qspi-l4t.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --cfg  flash.xml --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_lz4.dtb; spe_fw spe_t194.bin; tos tos-optee_t194.img; eks eks_t194.img; bootloader_dtb tegra194-p3668-0001-p3509-0000.dtb"  --odmdata 0xB8190000  --overlay_dtb L4TConfiguration.dtbo,tegra194-p3668-p3509-overlay.dtbo, --bldtb tegra194-p3668-0001-p3509-0000.dtb  --cmd "erase APP; write APP /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/speye.img; reboot"  --bct_backup  --boot_chain A
version 1.0.0
[   0.0217 ] Generating RCM messages
[   0.0240 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0247 ] Header already present for mb1_t194_prod.bin
[   0.0320 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0324 ] Assuming zero filled SBK key
[   0.0351 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0355 ] Assuming zero filled SBK key
[   0.0387 ] Warning: pub_key.key is not found
[   0.0391 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0448 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0483 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   0.0491 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0496 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0497 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0497 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0497 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0497 ]
[   0.0506 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0514 ] RCM 0 is saved as rcm_0.rcm
[   0.0541 ] RCM 1 is saved as rcm_1.rcm
[   0.0542 ] RCM 2 is saved as rcm_2.rcm
[   0.0542 ] List of rcm files are saved in rcm_list.xml
[   0.0542 ]
[   0.0542 ] Signing RCM messages
[   0.0584 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0587 ] Assuming zero filled SBK key
[   0.0642 ] Warning: pub_key.key is not found
[   0.0622 ] Copying signature to RCM mesages
[   0.0646 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0668 ] Boot Rom communication
[   0.0700 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.0709 ] BR_CID: 0x880219116451c2461000000006018280
[   0.2736 ] RCM version 0X190001
[   0.5069 ] Boot Rom communication completed
[   2.5281 ] tegrarcm_v2 --isapplet
[   2.5301 ] Applet version 01.00.0000
[   2.9760 ] tegrasign_v3.py --key None --getmode mode.txt
[   2.9771 ] Assuming zero filled SBK key
[   2.9759 ] odmdata (to decode) = 3088646144
[   2.9760 ] Odmdata strings: PCIE_XBAR_8_1_1_0_1,UFS_DISABLED,NVHS_PCIE,enable-debug-console,enable-denver-wdt
[   2.9761 ] Bpmp odmdata config: {'pcie-xbar-config': [0, 1, 'PCIE_XBAR_8_1_1_0_1'], 'pcie-c0-endpoint-enable': [1, 0, ''], 'pcie-c4-endpoint-enable': [1, 0, ''], 'ufs-config': [0, 1, 'UFS_DISABLED'], 'sata-enable': [1, 0, ''], 'nvhs-owner': [0, 1, 'PCIE'], 'pcie-c5-endpoint-enable': [1, 0, '']}
[   2.9820 ] bpmp_dtb is compressed; decompressing...
[   2.9820 ] lz4c -df tegra194-a02-bpmp-p3668-a00_lz4.dtb tegra194-a02-bpmp-p3668-a00_lz4_with_odm.dtb
[   2.9900 ] Successfully decoded 442560 bytes
[   2.9900 ]
[   3.2013 ] Re-compressing updated bpmp_dtb
[   3.2013 ] lz4c -zf tegra194-a02-bpmp-p3668-a00_lz4_with_odm.dtb tegra194-a02-bpmp-p3668-a00_lz4.dtb
[   3.2035 ] Compressed 442529 bytes into 32067 bytes ==> 7.25%
[   3.2035 ]
[   3.6683 ] Concatenating L4TConfiguration.dtbo,tegra194-p3668-p3509-overlay.dtbo to tegra194-p3668-0001-p3509-0000_with_odm_overlay.dtb
[   3.6691 ] Parsing partition layout
[   3.6715 ] tegraparser_v2 --pt flash.xml.tmp
[   3.6735 ] Creating list of images to be signed
[   3.6768 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   3.6788 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[   3.6804 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[   3.6809 ] MB1: Nvheader already present is mb1_b_t194_prod_aligned.bin
[   3.6834 ] Header already present for mb1_b_t194_prod_aligned_sigheader.bin
[   3.6838 ] adding BCH for spe_t194_aligned.bin
[   3.6864 ] adding BCH for nvtboot_t194_aligned.bin
[   3.6887 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   3.6936 ] Header already present for mce_c10_prod_cr_aligned.bin
[   3.6942 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   3.7064 ] Header already present for warmboot_t194_prod_aligned.bin
[   3.7801 ] adding BCH for uefi_jetson_aligned.bin
[   3.7862 ] adding BCH for tegra194-p3668-0001-p3509-0000_aligned.dtb
[   3.8369 ] adding BCH for tos-optee_t194_aligned.img
[   3.8483 ] adding BCH for eks_t194_aligned.img
[   3.8655 ] adding BCH for adsp-fw_aligned.bin
[   3.8661 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   3.8782 ] adding BCH for bpmp-2_t194_aligned.bin
[   3.8913 ] adding BCH for tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb
[   3.9119 ] adding BCH for spe_t194_aligned.bin
[   3.9127 ] adding BCH for nvtboot_t194_aligned.bin
[   3.9156 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   3.9205 ] Header already present for mce_c10_prod_cr_aligned.bin
[   3.9210 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   3.9314 ] Header already present for warmboot_t194_prod_aligned.bin
[   4.0024 ] adding BCH for uefi_jetson_aligned.bin
[   4.0093 ] adding BCH for tegra194-p3668-0001-p3509-0000_aligned.dtb
[   4.0621 ] adding BCH for tos-optee_t194_aligned.img
[   4.0706 ] adding BCH for eks_t194_aligned.img
[   4.0908 ] adding BCH for adsp-fw_aligned.bin
[   4.0917 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   4.1012 ] adding BCH for bpmp-2_t194_aligned.bin
[   4.1133 ] adding BCH for tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb
[   4.1373 ] Filling MB1 storage info
[   4.1373 ] Parsing dev params for multi chains
[   4.1373 ] Generating br-bct
[   4.1399 ] Performing cfg overlay
[   4.1399 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[   4.1403 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg
[   4.1888 ] Updating dev and MSS params in BR BCT
[   4.1889 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.2532 ] Updating bl info
[   4.2557 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   4.2577 ] Generating br-bct
[   4.2599 ] Performing cfg overlay
[   4.2600 ] ['/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg']
[   4.2600 ] Updating dev and MSS params in BR BCT
[   4.2600 ] tegrabct_v2 --dev_param tegra194-br-bct_b-qspi-l4t.cfg --sdram /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.3207 ] Updating bl info
[   4.3237 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   4.3259 ] Generating BCT backup image
[   4.3259 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   4.3269 ] 32768+0 records in
[   4.4218 ] 32768+0 records out
[   4.4218 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0942153 s, 348 kB/s
[   4.4219 ]
[   4.4219 ] Concatenating BCT for chain A to bct_backup.img
[   4.4219 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   4.4232 ] 2888+0 records in
[   4.4312 ] 2888+0 records out
[   4.4312 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00749493 s, 385 kB/s
[   4.4312 ]
[   4.4313 ] Concatenating BCT for chain B to bct_backup.img
[   4.4313 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   4.4324 ] 2888+0 records in
[   4.4409 ] 2888+0 records out
[   4.4410 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00803402 s, 359 kB/s
[   4.4410 ]
[   4.4411 ] Generating signatures
[   4.4462 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   4.4466 ] Assuming zero filled SBK key
[   4.6346 ] Warning: pub_key.key is not found
[   4.6328 ] Send BCT from Host
[   4.6328 ] Parsing dev params for multi chains
[   4.6329 ] Generating br-bct
[   4.6382 ] Performing cfg overlay
[   4.6383 ] ['/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg']
[   4.6383 ] Updating dev and MSS params in BR BCT
[   4.6386 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.7499 ] Updating bl info
[   4.7563 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.8167 ] Updating smd info
[   4.8225 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   4.8523 ] Updating Odmdata
[   4.8558 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[   4.9259 ] Signing BCT
[   4.9260 ] Get Signed section of bct
[   4.9327 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   4.9469 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   4.9487 ] Assuming zero filled SBK key
[   4.9571 ] Warning: pub_key.key is not found
[   4.9552 ] Updating BCT with signature
[   4.9616 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   4.9854 ] Generating br-bct
[   4.9888 ] Performing cfg overlay
[   4.9888 ] ['/home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg']
[   4.9888 ] Updating dev and MSS params in BR BCT
[   4.9890 ] tegrabct_v2 --dev_param tegra194-br-bct_b-qspi-l4t.cfg --sdram /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   5.0382 ] Updating bl info
[   5.0409 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   5.0446 ] Updating smd info
[   5.0476 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   5.0495 ] Updating Odmdata
[   5.0521 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[   5.0542 ] Signing BCT
[   5.0542 ] Get Signed section of bct
[   5.0565 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   5.0623 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   5.0625 ] Assuming zero filled SBK key
[   5.0646 ] Warning: pub_key.key is not found
[   5.0626 ] Updating BCT with signature
[   5.0656 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   5.0695 ] Generating BCT backup image
[   5.0697 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   5.0719 ] 32768+0 records in
[   5.1731 ] 32768+0 records out
[   5.1731 ] 32768 bytes (33 kB, 32 KiB) copied, 0.10023 s, 327 kB/s
[   5.1731 ]
[   5.1732 ] Concatenating BCT for chain A to bct_backup.img
[   5.1732 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   5.1746 ] 2888+0 records in
[   5.1823 ] 2888+0 records out
[   5.1823 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00714605 s, 404 kB/s
[   5.1823 ]
[   5.1823 ] Concatenating BCT for chain B to bct_backup.img
[   5.1824 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   5.1834 ] 2888+0 records in
[   5.1934 ] 2888+0 records out
[   5.1934 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00940122 s, 307 kB/s
[   5.1934 ]
[   5.1934 ] Generating coldboot mb1-bct
[   5.1967 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[   5.1980 ] MB1-BCT version: 0x1
[   5.1984 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[   5.1987 ] Added Platform Config 0 data with size :- 2496
[   5.2011 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[   5.2014 ] Added Platform Config 1 data with size :- 19640
[   5.2276 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[   5.2279 ] Added Platform Config 2 data with size :- 24
[   5.2283 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[   5.2288 ] Added Platform Config 4 data with size :- 348
[   5.2293 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[   5.2300 ] Added Platform Config 3 data with size :- 92
[   5.2305 ]
[   5.2305 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[   5.2305 ] Added Platform Config 5 data with size :- 140
[   5.2305 ]
[   5.2305 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[   5.2305 ] Added Platform Config 7 data with size :- 392
[   5.2305 ]
[   5.2306 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[   5.2306 ] Added Platform Config 9 data with size :- 40
[   5.2306 ]
[   5.2307 ] Updating mb1-bct with firmware information
[   5.2335 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   5.2355 ] Updating mb1-bct with storage information
[   5.2382 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   5.2402 ] Updating mb1-bct with ratchet information
[   5.2426 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   5.2436 ] FwIndex: 1, MinRatchetLevel: 0
[   5.2439 ] FwIndex: 2, MinRatchetLevel: 0
[   5.2439 ] FwIndex: 3, MinRatchetLevel: 0
[   5.2439 ] FwIndex: 4, MinRatchetLevel: 0
[   5.2439 ] FwIndex: 5, MinRatchetLevel: 0
[   5.2439 ] FwIndex: 6, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 7, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 11, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 12, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 13, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 14, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 15, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 16, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 17, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 18, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 19, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 30, MinRatchetLevel: 0
[   5.2440 ] FwIndex: 31, MinRatchetLevel: 0
[   5.2440 ]
[   5.2466 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[   5.2505 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   5.2515 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   5.2568 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   5.2571 ] Assuming zero filled SBK key
[   5.2591 ] Warning: pub_key.key is not found
[   5.2594 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.2612 ] Generating recovery mb1-bct
[   5.2637 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[   5.2655 ] MB1-BCT version: 0x1
[   5.2659 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[   5.2661 ] Added Platform Config 0 data with size :- 2496
[   5.2685 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[   5.2690 ] Added Platform Config 1 data with size :- 19640
[   5.2897 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[   5.2901 ] Added Platform Config 2 data with size :- 24
[   5.2903 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[   5.2907 ] Added Platform Config 4 data with size :- 348
[   5.2910 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[   5.2913 ] Added Platform Config 3 data with size :- 92
[   5.2916 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[   5.2920 ] Added Platform Config 5 data with size :- 140
[   5.2923 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[   5.2928 ] Added Platform Config 7 data with size :- 392
[   5.2929 ]
[   5.2929 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[   5.2929 ] Added Platform Config 9 data with size :- 40
[   5.2929 ]
[   5.2929 ] Updating mb1-bct with firmware information
[   5.2964 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   5.2986 ] Updating mb1-bct with storage information
[   5.3013 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   5.3029 ] Updating mb1-bct with ratchet information
[   5.3052 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   5.3062 ] FwIndex: 1, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 2, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 3, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 4, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 5, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 6, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 7, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 11, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 12, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 13, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 14, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 15, MinRatchetLevel: 0
[   5.3066 ] FwIndex: 16, MinRatchetLevel: 0
[   5.3067 ] FwIndex: 17, MinRatchetLevel: 0
[   5.3067 ] FwIndex: 18, MinRatchetLevel: 0
[   5.3067 ] FwIndex: 19, MinRatchetLevel: 0
[   5.3067 ] FwIndex: 30, MinRatchetLevel: 0
[   5.3067 ] FwIndex: 31, MinRatchetLevel: 0
[   5.3067 ]
[   5.3092 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[   5.3141 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   5.3156 ] adding BCH for mb1_bct_MB1_aligned.bct
[   5.3223 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   5.3226 ] Assuming zero filled SBK key
[   5.3246 ] Warning: pub_key.key is not found
[   5.3251 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.3268 ] Generating coldboot mem-bct
[   5.3291 ] tegrabct_v2 --chip 0x19 0 --sdram /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg --membct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_1.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_2.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_3.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_4.bct
[   5.3311 ] Packing sdram param for instance[0]
[   5.3845 ] Packing sdram param for instance[1]
[   5.3847 ] Packing sdram param for instance[2]
[   5.3849 ] Packing sdram param for instance[3]
[   5.3850 ] Packing sdram param for instance[4]
[   5.3850 ] Packing sdram param for instance[5]
[   5.3850 ] Packing sdram param for instance[6]
[   5.3850 ] Packing sdram param for instance[7]
[   5.3850 ] Packing sdram param for instance[8]
[   5.3850 ] Packing sdram param for instance[9]
[   5.3850 ] Packing sdram param for instance[10]
[   5.3850 ] Packing sdram param for instance[11]
[   5.3850 ] Packing sdram param for instance[12]
[   5.3850 ] Packing sdram param for instance[13]
[   5.3851 ] Packing sdram param for instance[14]
[   5.3851 ] Packing sdram param for instance[15]
[   5.3851 ]
[   5.3851 ] Getting sector size from pt
[   5.3877 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   5.3897 ] BlockSize read from layout is 200
[   5.3927 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_1.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_2.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_3.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_4.bct
[   5.3945 ] adding BCH for /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_1.bct
[   5.4025 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[   5.4064 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   5.4080 ] Header already present for mem_coldboot_aligned.bct
[   5.4136 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   5.4140 ] Assuming zero filled SBK key
[   5.4168 ] Warning: pub_key.key is not found
[   5.4166 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   5.4193 ] Generating recovery mem-bct
[   5.4235 ] tegrabct_v2 --chip 0x19 0 --sdram /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1.cfg --membct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_1.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_2.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_3.bct /home/ultwcz/repo/5.1.1/Linux_for_Tegra/bootloader/19897/tmpwf6kioht1_4.bct
[   5.4254 ] Packing sdram param for instance[0]
[   5.5017 ] Packing sdram param for instance[1]
[   5.5020 ] Packing sdram param for instance[2]
[   5.5023 ] Packing sdram param for instance[3]
[   5.5024 ] Packing sdram param for instance[4]
[   5.5024 ] Packing sdram param for instance[5]
[   5.5024 ] Packing sdram param for instance[6]
[   5.5024 ] Packing sdram param for instance[7]
[   5.5024 ] Packing sdram param for instance[8]
[   5.5024 ] Packing sdram param for instance[9]
[   5.5024 ] Packing sdram param for instance[10]
[   5.5024 ] Packing sdram param for instance[11]
[   5.5024 ] Packing sdram param for instance[12]
[   5.5024 ] Packing sdram param for instance[13]
[   5.5024 ] Packing sdram param for instance[14]
[   5.5024 ] Packing sdram param for instance[15]
[   5.5024 ]
[   5.5026 ] Reading ramcode from backup chip_info.bin file
[   5.5027 ] RAMCODE Read from Device: 1
[   5.5059 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[   5.5093 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   5.5103 ] adding BCH for mem_rcm_aligned.bct
[   5.5171 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   5.5174 ] Assuming zero filled SBK key
[   5.5200 ] Warning: pub_key.key is not found
[   5.5205 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   5.5229 ] Sending BCTs
[   5.5249 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   5.5265 ] Applet version 01.00.0000
[   5.9472 ] Sending bct_bootrom
[   5.9475 ] [................................................] 100%
[   5.9487 ] Sending bct_mb1
[   5.9532 ] [................................................] 100%
[   5.9569 ] Sending bct_mem
[   6.0037 ] [................................................] 100%
[   6.0845 ] Generating RCM messages
[   6.0872 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   6.0892 ] Header already present for mb1_t194_prod.bin
[   6.0985 ] tegrasign_v3.py --key None --getmode mode.txt
[   6.0990 ] Assuming zero filled SBK key
[   6.1023 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   6.1027 ] Assuming zero filled SBK key
[   6.1058 ] Warning: pub_key.key is not found
[   6.1063 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   6.1138 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   6.1182 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   6.1196 ] FwIndex: 1, MinRatchetLevel: 0
[   6.1199 ] FwIndex: 2, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 3, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 4, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 5, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 6, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 7, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 11, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 12, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 13, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 14, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 15, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 16, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 17, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 18, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 19, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 30, MinRatchetLevel: 0
[   6.1200 ] FwIndex: 31, MinRatchetLevel: 0
[   6.1200 ]
[   6.1226 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   6.1238 ] RCM 0 is saved as rcm_0.rcm
[   6.1276 ] RCM 1 is saved as rcm_1.rcm
[   6.1278 ] RCM 2 is saved as rcm_2.rcm
[   6.1278 ] List of rcm files are saved in rcm_list.xml
[   6.1278 ]
[   6.1279 ] Signing RCM messages
[   6.1330 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   6.1333 ] Assuming zero filled SBK key
[   6.1429 ] Warning: pub_key.key is not found
[   6.1408 ] Copying signature to RCM mesages
[   6.1436 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   6.1455 ] Boot Rom communication
[   6.1486 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   6.1502 ] BootRom is not running
[   7.5473 ] tegrarcm_v2 --isapplet
Does flashing with other L4T versions make any difference?
If it still does not succeed, then I’d say maybe the module itself is broken.
Hi, @DaveYYY
The same of before
How do I fix it, or how to clear data in NX?
I think there’s little we can do here given that it does not even output proper log from UART.
I’d say RMA or get a new module.
OK, thank you. I think it was caused by damage to the boot-ROM
Hi, @DaveYYY,
I used Jetpack 32.4.3, which shows
Invalid value MemBct dram size: 0MB for slot: 1
Are there memory issues?
See if you need this:
https://developer.download.nvidia.com/assets/embedded/secure/jetson/Xavier%20NX/Jetson_Xavier_NX_PCN_206980_DRAM_eMMC_Manufacturing_BOM_Expansion_v3.pdf?H-FgaKhtPII519Yu8UHx_3L7q4El6Y85PtemKXVyxDXr8eYlYtWKXAPP-gZo8mKjTCPtxu9vfXaOKCoGZ1fTNGKUwuQllgcEFE4p9jrxIx2RQT-x7ItmFQysqDlYKKGG5fyd5xjJGG6F-yetkpEQXu3mOCH5oKGxqUAPAWdotO4WpZEAC60XqysIScme2O2fsAoNAhczOrXZKNw6Qg2LTSkbfM9VG1QbMm25YLiKL4Lz&t=eyJscyI6ImdzZW8iLCJsc2QiOiJodHRwczovL3d3dy5nb29nbGUuY29tLyJ9
Sorry , File Not Found or Link has Expired
Jetson_Xavier_NX_PCN_206980_DRAM_eMMC_Manufacturing_BOM_Expansion_v3.pdf (630.6 KB)
Or check for other PCN at our download center:
Thank you.
