I believe my Jetson Xavier NX is stuck in Force Recovery Mode. I was able to flash my device before using the ./flash.sh script. But after setting up my device for Secure Boot and then flashing it, the Jetson would not boot up. I believe it’s stuck in Force Recovery Mode because I am able to flash my device successfully without putting a jumper pins 9 and 10 of J14.
I used the following command to fuse with PKC, SBK, and KEK2:
sudo ./odmfuse.sh --test -i 0x19 -k RSA_Key.pem -S SBK.txt --KEK2 KEK2.txt jetson-xavier-nx-devkit.
I then used the following command to sign and flash in one step using the user, SBK, and PKC keys:
sudo ./flash.sh -u RSA_Key.pem -v SBK.txt --user_key User_Key.txt jetson-xavier-nx-devkit mmcblk0p1
Both scripts ran successfully, but my device did not boot up after removing the jumper and resetting the it. I read in some other forums regarding other jetsons (Nana and TX2) being stuck in Force Recovery Mode. The solution that was recommended for those posts were to create a RMA. It was suggested that there is something wrong with the hardware. Can someone please assist me? Thank you.
hello dcapers44,
is this Jetson Xavier NX devkit a sd-card version?
Jetson security only supports with eMMC, you CANNOT program fuse to enable secureBoot with a SD-card version.
I don’t get your question? My Jetson Xavier NX devkit takes a sd-card, but I have a 970 EVO Plus NVMe M.2 SSD install on it. Not sure why you are saying that I CANNOT program fuse to enable secureBoot with a SD-card version. Can you please explain, because I have not seen any documentation stating that. I don’t see anything supporting your statement in the Sercureboot section of the NVIDIA Jetson Linux Developers Guide.
hello dcapers44,
check examples below odmfuse.sh Switch Examples session.
the content shows it only supports with production modules,
and also for Jetson Xavier NX, it’s jetson-xavier-nx-devkit-emmc.
I checked out the link you provided to the odmfuse.sh Switch Examples. This is where I got my ./odmfuse.sh command to burn the fuses on my device. I understand what you are saying, but the documentation does not state what you are saying… there is one example being used. But nothing that states that jetson-xavier-nx-devkit cannot burn fuses.
I still don’t understand, because I was able to burn the fuses that I specified above. Are you saying that I can burn fuses on the board that I have? Because I believe that I did. Is there a solution for the issue that I’m having?
hello dcapers44,
I’m agree with you that documentation isn’t perfect to indicate the scenario.
please refer to Topic 158361; you may broken your board once you’d program fuse with Xavier NX devkit.
hello dcapers44,
FYI,
we had an internal request for device checking mechanism to prevent SD-card version being fused.
this request is still under discussion.
This doesn’t make any sense… why have fuses on a board that I can’t use? Is there a solution to my issue or someone that resolve this issue. I appreciate your feedback, but I’m not alright that you said that I broke my board because I was allow to burn fuses that my board did not support. I just trying to resolve this issue.
that’s why we initial an internal feature request to avoid that.
I understand, but what am I suppose to do with a broken board? Is there a resolution?
hello dcapers44,
please contact with NVIDIA Customer Care team for RMA process if you believe that your Jetson product is defective.
thanks
I thought you said that it’s defective… once I burnt the fuses on my board. If this is the reason that I cannot get the board out of Force Recovery Mode… then we both can agree that it is defective… because the jetson cannot boot up in Force Recovery Mode.
hello dcapers44,
FYI, it’s also mentioned in Jetson Xavier NX FAQ,
Secureboot is only supported on production module. (i.e. Jetson Xavier NX with eMMC).
hello dcapers44,
did you actually program the fuse?
it seems you’re adding --test to the odmfuse.sh, your command-line should NOT burn the fuse because --test is added.
hence,
the later flash command should also failed since your board should be none SBK nor PKC protected target.
may I have your detail steps?
you may also share serial console logs for reference,
thanks
Thanks for showing me where secureboot is only supported on production module with Jetson Xavier NX with eMMC… but a an inset in a FAQ and an example is not a clear documenation of your point. Additionally, I just went onto the Nvidia website to shop for a Jetson Xavier NX, but I do not see the option to select one with a SD versus one with an eMMC. Can you please point me to the right place which I can purchase either of the two types of Jetson Xavier NX…
I did actually program the fuse… I did not include the --test option with the ./odmfuse.sh script when I ran it. That was a typo in my original chat to you.
Below is the console output after running the following without a jumper across pin 9 and 10 of J14 on the Jestson:
sudo ./odmfuse.sh -i 0x19 -k RSA_Key.pem -S SBK.txt --KEK2 KEK2.txt jetson-xavier-nx-devkit
dcapers@NUC-Ubuntu-18.04:~/nvidia/Linux_for_Tegra$ sudo ./odmfuse.sh -i 0x19 -k RSA_Key.pem -S SBK.txt --KEK2 KEK2.txt jetson-xavier-nx-devkit
[sudo] password for dcapers:
copying soft_fuses(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery" --encrypt_key "/home/dcapers/nvidia/Linux_for_Tegra/SBK.txt" --key "/home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0042 ] Generating RCM messages
[ 0.0054 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin --offset 4096
[ 0.0064 ] Key is a SBK key
[ 0.0068 ] Key Size is 16 bytes
[ 0.0227 ]
[ 0.0241 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt.bin zerosbk
[ 0.0251 ] Header already present for /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt.bin
[ 0.0295 ]
[ 0.0307 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0321 ] PKC key in Open SSL format
[ 0.0325 ] Key size is 256 bytes
[ 0.0328 ] Valid PKC key
[ 0.0349 ]
[ 0.0363 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0373 ] PKC key in Open SSL format
[ 0.0376 ] Key size is 256 bytes
[ 0.0378 ] Valid PKC key
[ 0.0395 ] Saving pkc public key in pub_key.key
[ 0.1106 ]
[ 0.1119 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.sig oem-rsa
[ 0.1170 ]
[ 0.1185 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.1197 ]
[ 0.1208 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin 0 0
[ 0.1220 ] RCM 0 is saved as rcm_0.rcm
[ 0.1264 ] RCM 1 is saved as rcm_1.rcm
[ 0.1265 ] RCM 2 is saved as rcm_2.rcm
[ 0.1265 ] List of rcm files are saved in rcm_list.xml
[ 0.1265 ]
[ 0.1265 ] Signing RCM messages
[ 0.1277 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.1287 ] PKC key in Open SSL format
[ 0.1290 ] Key size is 256 bytes
[ 0.1292 ] Valid PKC key
[ 0.1308 ] Saving pkc public key in pub_key.key
[ 0.3426 ]
[ 0.3426 ] Copying signature to RCM mesages
[ 0.3441 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key
[ 0.3459 ]
[ 0.3460 ] Boot Rom communication
[ 0.3471 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.3481 ] RCM version 0X190001
[ 0.3523 ] Boot Rom communication completed
[ 1.3811 ]
[ 2.3871 ] tegrarcm_v2 --isapplet
[ 2.3911 ] Applet version 01.00.0000
[ 2.3943 ]
[ 2.3985 ] tegrarcm_v2 --ismb2
[ 2.4389 ]
[ 2.4429 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.4468 ]
[ 2.4476 ] header_magic: 50000ea
[ 2.4555 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_applet_t194.bin_list.xml
[ 2.4590 ] Key is a SBK key
[ 2.4601 ] Key Size is 16 bytes
[ 2.4815 ]
[ 2.4847 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194.bin.encrypt nvtboot_applet_t194.bin.hash zerosbk
[ 2.4869 ]
[ 2.4887 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin.encrypt
[ 2.4905 ]
[ 2.4923 ] tegrahost_v2 --appendsigheader nvtboot_applet_t194.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid PLDT
[ 2.4939 ] adding BCH for nvtboot_applet_t194.bin.encrypt
[ 2.4990 ]
[ 2.4992 ] header_magic: 3e918cce
[ 2.5014 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_applet_t194.bin_sigheader.encrypt_list.xml
[ 2.5029 ] PKC key in Open SSL format
[ 2.5034 ] Key size is 256 bytes
[ 2.5036 ] Valid PKC key
[ 2.5053 ] Saving pkc public key in pub_key.key
[ 2.5763 ]
[ 2.5778 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194.bin_sigheader.encrypt.signed nvtboot_applet_t194.bin_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 2.5806 ]
[ 2.5818 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194.bin_sigheader.encrypt.signed
[ 2.5829 ] Applet version 01.00.0000
[ 2.5984 ] Sending mb2
[ 2.5985 ] [................................................] 100%
[ 2.6136 ]
[ 2.6147 ] tegrarcm_v2 --boot recovery
[ 2.6160 ] Applet version 01.00.0000
[ 2.6384 ]
[ 3.6435 ] tegrarcm_v2 --isapplet
[ 3.6478 ]
[ 3.6492 ] tegrarcm_v2 --ismb2
[ 3.6504 ] MB2 Applet version 01.00.0000
[ 3.6836 ]
[ 3.6872 ] tegrarcm_v2 --ismb2
[ 3.6904 ] MB2 Applet version 01.00.0000
[ 3.7276 ]
[ 3.7314 ] Retrieving board information
[ 3.7349 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.7396 ] MB2 Applet version 01.00.0000
[ 3.7623 ] Saved platform info in chip_info.bin
[ 3.7665 ] Chip minor revision: 2
[ 3.7665 ] Bootrom revision: 0xf
[ 3.7666 ] Ram code: 0x0
[ 3.7666 ] Chip sku: 0xde
[ 3.7666 ] Chip Sample: non es
[ 3.7666 ]
[ 3.7675 ] Retrieving EEPROM data
[ 3.7677 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/dcapers/nvidia/Linux_for_Tegra/bootloader/cvm.bin
[ 3.7713 ] MB2 Applet version 01.00.0000
[ 3.7937 ] Saved platform info in /home/dcapers/nvidia/Linux_for_Tegra/bootloader/cvm.bin
[ 3.8281 ]
[ 3.8284 ] Rebooting to recovery mode
[ 3.8325 ] tegrarcm_v2 --ismb2
[ 3.8364 ] MB2 Applet version 01.00.0000
[ 3.8554 ]
[ 3.8556 ] Rebooting to recovery mode
[ 3.8593 ] tegrarcm_v2 --reboot recovery
[ 3.8625 ] MB2 Applet version 01.00.0000
[ 3.9062 ]
Board ID(3668) version(200) sku(0000) revision(J.0)
copying sdram_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying sdram_config1(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying misc_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying scr_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying pmc_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying pmic_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying br_cmd_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying prod_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying dev_params(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)... done.
copying misc_cold_boot_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying device_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying gpioint_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
Existing mb2_bootloader(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mts_preboot(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mts_mce(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mts_proper(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
copying bootloader_dtb(/home/dcapers/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
Existing bpmp_fw(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpmp_fw_dtb(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)... done.
Existing tlk(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eks(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/eks.img) reused.
Existing spe_fw(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing mb1file(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing spefile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing tegraboot(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing tbcfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
Existing scefile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing wb0boot(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
done.
Existing cfg(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/flash.xml) reused.
Existing bl(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing applet(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
./tegraflash.py --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00.dtb; tlk tos-trusty_t194.img; eks eks.img; kernel boot.img; kernel_dtb tegra194-p3668-all-p3509-0000.dtb; spe_fw spe_t194.bin" --cfg flash.xml --bl nvtboot_recovery_cpu_t194.bin --odmdata 0xB8190000 --chip 0x19 --applet mb1_t194_prod.bin --key "/home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem" --encrypt_key "/home/dcapers/nvidia/Linux_for_Tegra/SBK.txt" --cmd "sign"
version 1.0.0
[ 0.0093 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0104 ] PKC key in Open SSL format
[ 0.0108 ] Key size is 256 bytes
[ 0.0110 ] Valid PKC key
[ 0.0127 ]
[ 0.0129 ] Generating RCM messages
[ 0.0140 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file mb1_t194_prod.bin --offset 4096
[ 0.0150 ] Key is a SBK key
[ 0.0152 ] Key Size is 16 bytes
[ 0.0315 ]
[ 0.0328 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod_encrypt.bin zerosbk
[ 0.0339 ] Header already present for mb1_t194_prod_encrypt.bin
[ 0.0387 ]
[ 0.0403 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0417 ] PKC key in Open SSL format
[ 0.0420 ] Key size is 256 bytes
[ 0.0422 ] Valid PKC key
[ 0.0440 ]
[ 0.0451 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --file mb1_t194_prod_encrypt_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0461 ] PKC key in Open SSL format
[ 0.0464 ] Key size is 256 bytes
[ 0.0466 ] Valid PKC key
[ 0.0482 ] Saving pkc public key in pub_key.key
[ 0.1190 ]
[ 0.1204 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader mb1_t194_prod_encrypt_sigheader.bin mb1_t194_prod_encrypt_sigheader.sig oem-rsa
[ 0.1257 ]
[ 0.1268 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.1281 ]
[ 0.1292 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_encrypt_sigheader.bin 0 0
[ 0.1304 ] RCM 0 is saved as rcm_0.rcm
[ 0.1345 ] RCM 1 is saved as rcm_1.rcm
[ 0.1345 ] RCM 2 is saved as rcm_2.rcm
[ 0.1345 ] List of rcm files are saved in rcm_list.xml
[ 0.1345 ]
[ 0.1346 ] Signing RCM messages
[ 0.1357 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.1366 ] PKC key in Open SSL format
[ 0.1370 ] Key size is 256 bytes
[ 0.1373 ] Valid PKC key
[ 0.1390 ] Saving pkc public key in pub_key.key
[ 0.3502 ]
[ 0.3503 ] Copying signature to RCM mesages
[ 0.3517 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key
[ 0.3534 ]
[ 0.3536 ] Parsing partition layout
[ 0.3548 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.3566 ]
[ 0.3566 ] Creating list of images to be signed
[ 0.3577 ] tegrahost_v2 --chip 0x19 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.3587 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.3595 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.3601 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.3649 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.3659 ] adding BCH for spe_t194.bin
[ 0.3694 ] adding BCH for spe_t194.bin
[ 0.3726 ] adding BCH for nvtboot_t194.bin
[ 0.3755 ] adding BCH for nvtboot_t194.bin
[ 0.3809 ] Header already present for preboot_c10_prod_cr.bin
[ 0.3862 ] Header already present for preboot_c10_prod_cr.bin
[ 0.3867 ] Header already present for mce_c10_prod_cr.bin
[ 0.3872 ] Header already present for mce_c10_prod_cr.bin
[ 0.3901 ] adding BCH for mts_c10_prod_cr.bin
[ 0.3948 ] adding BCH for mts_c10_prod_cr.bin
[ 0.4970 ] Header already present for warmboot_t194_prod.bin
[ 0.5985 ] Header already present for warmboot_t194_prod.bin
[ 0.5995 ] adding BCH for cboot_t194.bin
[ 0.6004 ] adding BCH for cboot_t194.bin
[ 0.6136 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.6274 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.6333 ] adding BCH for tos-trusty_t194.img
[ 0.6397 ] adding BCH for tos-trusty_t194.img
[ 0.6513 ] adding BCH for eks.img
[ 0.6627 ] adding BCH for eks.img
[ 0.6630 ] adding BCH for adsp-fw.bin
[ 0.6633 ] adding BCH for adsp-fw.bin
[ 0.6654 ] adding BCH for camera-rtcpu-rce.img
[ 0.6686 ] adding BCH for camera-rtcpu-rce.img
[ 0.6782 ] adding BCH for bpmp_t194.bin
[ 0.6867 ] adding BCH for bpmp_t194.bin
[ 0.7137 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 0.7397 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 0.7461 ] adding BCH for boot.img
[ 0.7527 ] adding BCH for boot.img
[ 0.7530 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.7536 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.7652 ]
[ 0.7666 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list images_list.xml --pubkeyhash pub_key.key
[ 0.7677 ] PKC key in Open SSL format
[ 0.7681 ] Key size is 256 bytes
[ 0.7686 ] Valid PKC key
[ 0.7701 ] Saving pkc public key in pub_key.key
[ 3.1792 ]
[ 3.1792 ] Generating br-bct
[ 3.1805 ] Performing cfg overlay
[ 3.1806 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 3.1812 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg
[ 3.2217 ]
[ 3.2219 ] Updating dev and MSS params in BR BCT
[ 3.2220 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.2678 ]
[ 3.2679 ] Updating bl info
[ 3.2692 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 3.2720 ]
[ 3.2741 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin
[ 3.2752 ]
[ 3.2754 ] header_magic: 4e564441
[ 3.2767 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mb1_t194_prod_sigheader.bin_list.xml
[ 3.2778 ] Key is a SBK key
[ 3.2781 ] Key Size is 16 bytes
[ 3.2950 ]
[ 3.2968 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt mb1_t194_prod_sigheader.bin.hash zerosbk
[ 3.3023 ]
[ 3.3037 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 3.3050 ]
[ 3.3063 ] tegrahost_v2 --appendsigheader mb1_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 3.3077 ] Header already present for mb1_t194_prod_sigheader.bin.encrypt
[ 3.3121 ]
[ 3.3122 ] header_magic: 4e564441
[ 3.3137 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_t194_prod_sigheader.bin.encrypt_list.xml
[ 3.3147 ] PKC key in Open SSL format
[ 3.3151 ] Key size is 256 bytes
[ 3.3153 ] Valid PKC key
[ 3.3169 ] Saving pkc public key in pub_key.key
[ 3.3881 ]
[ 3.3897 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 3.3948 ]
[ 3.3965 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin
[ 3.3977 ]
[ 3.3978 ] header_magic: 4e564441
[ 3.3993 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mb1_t194_prod_sigheader.bin_list.xml
[ 3.4006 ] Key is a SBK key
[ 3.4009 ] Key Size is 16 bytes
[ 3.4174 ]
[ 3.4193 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt mb1_t194_prod_sigheader.bin.hash zerosbk
[ 3.4246 ]
[ 3.4259 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 3.4272 ]
[ 3.4283 ] tegrahost_v2 --appendsigheader mb1_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 3.4293 ] Header already present for mb1_t194_prod_sigheader.bin.encrypt
[ 3.4335 ]
[ 3.4336 ] header_magic: 4e564441
[ 3.4352 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_t194_prod_sigheader.bin.encrypt_list.xml
[ 3.4363 ] PKC key in Open SSL format
[ 3.4366 ] Key size is 256 bytes
[ 3.4368 ] Valid PKC key
[ 3.4385 ] Saving pkc public key in pub_key.key
[ 3.5099 ]
[ 3.5114 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 3.5165 ]
[ 3.5182 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin
[ 3.5194 ]
[ 3.5196 ] header_magic: 4e564441
[ 3.5209 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list spe_t194_sigheader.bin_list.xml
[ 3.5221 ] Key is a SBK key
[ 3.5224 ] Key Size is 16 bytes
[ 3.5285 ]
[ 3.5300 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[ 3.5327 ]
[ 3.5339 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin.encrypt
[ 3.5351 ]
[ 3.5362 ] tegrahost_v2 --appendsigheader spe_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid SPEF
[ 3.5375 ] Header already present for spe_t194_sigheader.bin.encrypt
[ 3.5396 ]
[ 3.5398 ] header_magic: 4e564441
[ 3.5415 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list spe_t194_sigheader.bin.encrypt_list.xml
[ 3.5428 ] PKC key in Open SSL format
[ 3.5432 ] Key size is 256 bytes
[ 3.5434 ] Valid PKC key
[ 3.5450 ] Saving pkc public key in pub_key.key
[ 3.6165 ]
[ 3.6181 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt.signed spe_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 3.6207 ]
[ 3.6223 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin
[ 3.6234 ]
[ 3.6236 ] header_magic: 4e564441
[ 3.6250 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list spe_t194_sigheader.bin_list.xml
[ 3.6260 ] Key is a SBK key
[ 3.6263 ] Key Size is 16 bytes
[ 3.6327 ]
[ 3.6341 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[ 3.6369 ]
[ 3.6382 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin.encrypt
[ 3.6395 ]
[ 3.6411 ] tegrahost_v2 --appendsigheader spe_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid SPEF
[ 3.6426 ] Header already present for spe_t194_sigheader.bin.encrypt
[ 3.6447 ]
[ 3.6449 ] header_magic: 4e564441
[ 3.6466 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list spe_t194_sigheader.bin.encrypt_list.xml
[ 3.6478 ] PKC key in Open SSL format
[ 3.6482 ] Key size is 256 bytes
[ 3.6484 ] Valid PKC key
[ 3.6501 ] Saving pkc public key in pub_key.key
[ 3.7224 ]
[ 3.7239 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt.signed spe_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 3.7266 ]
[ 3.7281 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin
[ 3.7292 ]
[ 3.7294 ] header_magic: 4e564441
[ 3.7308 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_t194_sigheader.bin_list.xml
[ 3.7318 ] Key is a SBK key
[ 3.7321 ] Key Size is 16 bytes
[ 3.7434 ]
[ 3.7448 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt nvtboot_t194_sigheader.bin.hash zerosbk
[ 3.7487 ]
[ 3.7502 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin.encrypt
[ 3.7518 ]
[ 3.7531 ] tegrahost_v2 --appendsigheader nvtboot_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B
[ 3.7542 ] Header already present for nvtboot_t194_sigheader.bin.encrypt
[ 3.7574 ]
[ 3.7576 ] header_magic: 4e564441
[ 3.7590 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_t194_sigheader.bin.encrypt_list.xml
[ 3.7600 ] PKC key in Open SSL format
[ 3.7604 ] Key size is 256 bytes
[ 3.7606 ] Valid PKC key
[ 3.7622 ] Saving pkc public key in pub_key.key
[ 3.8364 ]
[ 3.8383 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt.signed nvtboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 3.8423 ]
[ 3.8439 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin
[ 3.8450 ]
[ 3.8452 ] header_magic: 4e564441
[ 3.8466 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_t194_sigheader.bin_list.xml
[ 3.8478 ] Key is a SBK key
[ 3.8481 ] Key Size is 16 bytes
[ 3.8596 ]
[ 3.8611 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt nvtboot_t194_sigheader.bin.hash zerosbk
[ 3.8655 ]
[ 3.8670 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin.encrypt
[ 3.8683 ]
[ 3.8695 ] tegrahost_v2 --appendsigheader nvtboot_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B
[ 3.8705 ] Header already present for nvtboot_t194_sigheader.bin.encrypt
[ 3.8737 ]
[ 3.8739 ] header_magic: 4e564441
[ 3.8754 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_t194_sigheader.bin.encrypt_list.xml
[ 3.8765 ] PKC key in Open SSL format
[ 3.8768 ] Key size is 256 bytes
[ 3.8770 ] Valid PKC key
[ 3.8787 ] Saving pkc public key in pub_key.key
[ 3.9512 ]
[ 3.9528 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt.signed nvtboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 3.9568 ]
[ 3.9589 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin
[ 3.9602 ]
[ 3.9604 ] header_magic: 4e564441
[ 3.9618 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list preboot_c10_prod_cr_sigheader.bin_list.xml
[ 3.9628 ] Key is a SBK key
[ 3.9631 ] Key Size is 16 bytes
[ 3.9645 ]
[ 3.9660 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 3.9676 ]
[ 3.9688 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin.encrypt
[ 3.9699 ]
[ 3.9712 ] tegrahost_v2 --appendsigheader preboot_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSP
[ 3.9726 ] Header already present for preboot_c10_prod_cr_sigheader.bin.encrypt
[ 3.9735 ]
[ 3.9737 ] header_magic: 4e564441
[ 3.9751 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list preboot_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 3.9762 ] PKC key in Open SSL format
[ 3.9765 ] Key size is 256 bytes
[ 3.9768 ] Valid PKC key
[ 3.9784 ] Saving pkc public key in pub_key.key
[ 4.0498 ]
[ 4.0514 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt.signed preboot_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 4.0530 ]
[ 4.0544 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin
[ 4.0555 ]
[ 4.0557 ] header_magic: 4e564441
[ 4.0571 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list preboot_c10_prod_cr_sigheader.bin_list.xml
[ 4.0582 ] Key is a SBK key
[ 4.0585 ] Key Size is 16 bytes
[ 4.0599 ]
[ 4.0615 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 4.0634 ]
[ 4.0649 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin.encrypt
[ 4.0662 ]
[ 4.0673 ] tegrahost_v2 --appendsigheader preboot_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSP
[ 4.0683 ] Header already present for preboot_c10_prod_cr_sigheader.bin.encrypt
[ 4.0690 ]
[ 4.0691 ] header_magic: 4e564441
[ 4.0705 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list preboot_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 4.0716 ] PKC key in Open SSL format
[ 4.0720 ] Key size is 256 bytes
[ 4.0722 ] Valid PKC key
[ 4.0740 ] Saving pkc public key in pub_key.key
[ 4.1457 ]
[ 4.1472 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt.signed preboot_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 4.1488 ]
[ 4.1502 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin
[ 4.1514 ]
[ 4.1516 ] header_magic: 4e564441
[ 4.1529 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mce_c10_prod_cr_sigheader.bin_list.xml
[ 4.1540 ] Key is a SBK key
[ 4.1542 ] Key Size is 16 bytes
[ 4.1636 ]
[ 4.1651 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 4.1685 ]
[ 4.1697 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin.encrypt
[ 4.1709 ]
[ 4.1726 ] tegrahost_v2 --appendsigheader mce_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSM
[ 4.1741 ] Header already present for mce_c10_prod_cr_sigheader.bin.encrypt
[ 4.1768 ]
[ 4.1769 ] header_magic: 4e564441
[ 4.1784 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mce_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 4.1794 ] PKC key in Open SSL format
[ 4.1798 ] Key size is 256 bytes
[ 4.1800 ] Valid PKC key
[ 4.1816 ] Saving pkc public key in pub_key.key
[ 4.2531 ]
[ 4.2546 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt.signed mce_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 4.2581 ]
[ 4.2597 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin
[ 4.2608 ]
[ 4.2610 ] header_magic: 4e564441
[ 4.2624 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mce_c10_prod_cr_sigheader.bin_list.xml
[ 4.2634 ] Key is a SBK key
[ 4.2637 ] Key Size is 16 bytes
[ 4.2742 ]
[ 4.2759 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 4.2795 ]
[ 4.2812 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin.encrypt
[ 4.2825 ]
[ 4.2841 ] tegrahost_v2 --appendsigheader mce_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSM
[ 4.2853 ] Header already present for mce_c10_prod_cr_sigheader.bin.encrypt
[ 4.2878 ]
[ 4.2880 ] header_magic: 4e564441
[ 4.2898 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mce_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 4.2912 ] PKC key in Open SSL format
[ 4.2918 ] Key size is 256 bytes
[ 4.2920 ] Valid PKC key
[ 4.2935 ] Saving pkc public key in pub_key.key
[ 4.3649 ]
[ 4.3664 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt.signed mce_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 4.3699 ]
[ 4.3715 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin
[ 4.3726 ]
[ 4.3728 ] header_magic: 4e564441
[ 4.3742 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mts_c10_prod_cr_sigheader.bin_list.xml
[ 4.3752 ] Key is a SBK key
[ 4.3755 ] Key Size is 16 bytes
[ 4.5975 ]
[ 4.5990 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 4.6541 ]
[ 4.6556 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin.encrypt
[ 4.6571 ]
[ 4.6586 ] tegrahost_v2 --appendsigheader mts_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSB
[ 4.6598 ] Header already present for mts_c10_prod_cr_sigheader.bin.encrypt
[ 4.7135 ]
[ 4.7137 ] header_magic: 4e564441
[ 4.7151 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mts_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 4.7162 ] PKC key in Open SSL format
[ 4.7165 ] Key size is 256 bytes
[ 4.7168 ] Valid PKC key
[ 4.7188 ] Saving pkc public key in pub_key.key
[ 4.7978 ]
[ 4.7992 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt.signed mts_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 4.8548 ]
[ 4.8610 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin
[ 4.8622 ]
[ 4.8624 ] header_magic: 4e564441
[ 4.8638 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mts_c10_prod_cr_sigheader.bin_list.xml
[ 4.8648 ] Key is a SBK key
[ 4.8650 ] Key Size is 16 bytes
[ 5.0880 ]
[ 5.0895 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 5.1451 ]
[ 5.1466 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin.encrypt
[ 5.1482 ]
[ 5.1497 ] tegrahost_v2 --appendsigheader mts_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSB
[ 5.1508 ] Header already present for mts_c10_prod_cr_sigheader.bin.encrypt
[ 5.2054 ]
[ 5.2055 ] header_magic: 4e564441
[ 5.2070 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mts_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 5.2083 ] PKC key in Open SSL format
[ 5.2087 ] Key size is 256 bytes
[ 5.2090 ] Valid PKC key
[ 5.2107 ] Saving pkc public key in pub_key.key
[ 5.2877 ]
[ 5.2894 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt.signed mts_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 5.3448 ]
[ 5.3511 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin
[ 5.3523 ]
[ 5.3525 ] header_magic: 4e564441
[ 5.3538 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list warmboot_t194_prod_sigheader.bin_list.xml
[ 5.3552 ] Key is a SBK key
[ 5.3555 ] Key Size is 16 bytes
[ 5.3598 ]
[ 5.3613 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt warmboot_t194_prod_sigheader.bin.hash zerosbk
[ 5.3635 ]
[ 5.3647 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin.encrypt
[ 5.3658 ]
[ 5.3669 ] tegrahost_v2 --appendsigheader warmboot_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 5.3681 ] Header already present for warmboot_t194_prod_sigheader.bin.encrypt
[ 5.3694 ]
[ 5.3695 ] header_magic: 4e564441
[ 5.3709 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list warmboot_t194_prod_sigheader.bin.encrypt_list.xml
[ 5.3718 ] PKC key in Open SSL format
[ 5.3721 ] Key size is 256 bytes
[ 5.3723 ] Valid PKC key
[ 5.3740 ] Saving pkc public key in pub_key.key
[ 5.4451 ]
[ 5.4467 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt.signed warmboot_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 5.4490 ]
[ 5.4505 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin
[ 5.4516 ]
[ 5.4518 ] header_magic: 4e564441
[ 5.4532 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list warmboot_t194_prod_sigheader.bin_list.xml
[ 5.4543 ] Key is a SBK key
[ 5.4545 ] Key Size is 16 bytes
[ 5.4591 ]
[ 5.4605 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt warmboot_t194_prod_sigheader.bin.hash zerosbk
[ 5.4629 ]
[ 5.4643 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin.encrypt
[ 5.4654 ]
[ 5.4666 ] tegrahost_v2 --appendsigheader warmboot_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 5.4676 ] Header already present for warmboot_t194_prod_sigheader.bin.encrypt
[ 5.4689 ]
[ 5.4691 ] header_magic: 4e564441
[ 5.4705 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list warmboot_t194_prod_sigheader.bin.encrypt_list.xml
[ 5.4717 ] PKC key in Open SSL format
[ 5.4721 ] Key size is 256 bytes
[ 5.4723 ] Valid PKC key
[ 5.4741 ] Saving pkc public key in pub_key.key
[ 5.5458 ]
[ 5.5474 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt.signed warmboot_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 5.5496 ]
[ 5.5511 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin
[ 5.5523 ]
[ 5.5525 ] header_magic: 4e564441
[ 5.5538 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list cboot_t194_sigheader.bin_list.xml
[ 5.5549 ] Key is a SBK key
[ 5.5552 ] Key Size is 16 bytes
[ 5.5841 ]
[ 5.5857 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt cboot_t194_sigheader.bin.hash zerosbk
[ 5.5943 ]
[ 5.5956 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin.encrypt
[ 5.5967 ]
[ 5.5979 ] tegrahost_v2 --appendsigheader cboot_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 5.5989 ] Header already present for cboot_t194_sigheader.bin.encrypt
[ 5.6062 ]
[ 5.6064 ] header_magic: 4e564441
[ 5.6078 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list cboot_t194_sigheader.bin.encrypt_list.xml
[ 5.6089 ] PKC key in Open SSL format
[ 5.6093 ] Key size is 256 bytes
[ 5.6095 ] Valid PKC key
[ 5.6110 ] Saving pkc public key in pub_key.key
[ 5.6836 ]
[ 5.6851 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt.signed cboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 5.6932 ]
[ 5.6952 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin
[ 5.6969 ]
[ 5.6971 ] header_magic: 4e564441
[ 5.6988 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list cboot_t194_sigheader.bin_list.xml
[ 5.7001 ] Key is a SBK key
[ 5.7004 ] Key Size is 16 bytes
[ 5.7302 ]
[ 5.7316 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt cboot_t194_sigheader.bin.hash zerosbk
[ 5.7679 ]
[ 5.7701 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin.encrypt
[ 5.7721 ]
[ 5.7744 ] tegrahost_v2 --appendsigheader cboot_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 5.7766 ] Header already present for cboot_t194_sigheader.bin.encrypt
[ 5.7935 ]
[ 5.7938 ] header_magic: 4e564441
[ 5.7960 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list cboot_t194_sigheader.bin.encrypt_list.xml
[ 5.7990 ] PKC key in Open SSL format
[ 5.7995 ] Key size is 256 bytes
[ 5.7998 ] Valid PKC key
[ 5.8018 ] Saving pkc public key in pub_key.key
[ 5.8739 ]
[ 5.8755 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt.signed cboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 5.8836 ]
[ 5.8860 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 5.8874 ]
[ 5.8876 ] header_magic: 4e564441
[ 5.8893 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 5.8908 ] Key is a SBK key
[ 5.8910 ] Key Size is 16 bytes
[ 5.9046 ]
[ 5.9066 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 5.9112 ]
[ 5.9125 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 5.9136 ]
[ 5.9148 ] tegrahost_v2 --appendsigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 5.9158 ] Header already present for tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 5.9192 ]
[ 5.9194 ] header_magic: 4e564441
[ 5.9207 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml
[ 5.9217 ] PKC key in Open SSL format
[ 5.9221 ] Key size is 256 bytes
[ 5.9224 ] Valid PKC key
[ 5.9238 ] Saving pkc public key in pub_key.key
[ 5.9944 ]
[ 5.9960 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.0003 ]
[ 6.0021 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 6.0033 ]
[ 6.0035 ] header_magic: 4e564441
[ 6.0049 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 6.0063 ] Key is a SBK key
[ 6.0067 ] Key Size is 16 bytes
[ 6.0197 ]
[ 6.0213 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 6.0266 ]
[ 6.0279 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 6.0291 ]
[ 6.0302 ] tegrahost_v2 --appendsigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.0312 ] Header already present for tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 6.0349 ]
[ 6.0351 ] header_magic: 4e564441
[ 6.0366 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml
[ 6.0376 ] PKC key in Open SSL format
[ 6.0380 ] Key size is 256 bytes
[ 6.0382 ] Valid PKC key
[ 6.0400 ] Saving pkc public key in pub_key.key
[ 6.1111 ]
[ 6.1127 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.1171 ]
[ 6.1188 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img
[ 6.1200 ]
[ 6.1201 ] header_magic: 4e564441
[ 6.1214 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tos-trusty_t194_sigheader.img_list.xml
[ 6.1226 ] Key is a SBK key
[ 6.1229 ] Key Size is 16 bytes
[ 6.1492 ]
[ 6.1508 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[ 6.1585 ]
[ 6.1599 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img.encrypt
[ 6.1610 ]
[ 6.1621 ] tegrahost_v2 --appendsigheader tos-trusty_t194_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.1632 ] Header already present for tos-trusty_t194_sigheader.img.encrypt
[ 6.1702 ]
[ 6.1704 ] header_magic: 4e564441
[ 6.1722 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tos-trusty_t194_sigheader.img.encrypt_list.xml
[ 6.1738 ] PKC key in Open SSL format
[ 6.1742 ] Key size is 256 bytes
[ 6.1746 ] Valid PKC key
[ 6.1759 ] Saving pkc public key in pub_key.key
[ 6.2472 ]
[ 6.2488 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt.signed tos-trusty_t194_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.2562 ]
[ 6.2582 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img
[ 6.2595 ]
[ 6.2597 ] header_magic: 4e564441
[ 6.2611 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tos-trusty_t194_sigheader.img_list.xml
[ 6.2622 ] Key is a SBK key
[ 6.2625 ] Key Size is 16 bytes
[ 6.2894 ]
[ 6.2913 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[ 6.2988 ]
[ 6.3001 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img.encrypt
[ 6.3013 ]
[ 6.3025 ] tegrahost_v2 --appendsigheader tos-trusty_t194_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.3035 ] Header already present for tos-trusty_t194_sigheader.img.encrypt
[ 6.3102 ]
[ 6.3103 ] header_magic: 4e564441
[ 6.3118 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tos-trusty_t194_sigheader.img.encrypt_list.xml
[ 6.3129 ] PKC key in Open SSL format
[ 6.3133 ] Key size is 256 bytes
[ 6.3135 ] Valid PKC key
[ 6.3150 ] Saving pkc public key in pub_key.key
[ 6.3867 ]
[ 6.3882 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt.signed tos-trusty_t194_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.3957 ]
[ 6.3976 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img
[ 6.3990 ]
[ 6.3992 ] header_magic: 4e564441
[ 6.4006 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list eks_sigheader.img_list.xml
[ 6.4015 ] Key is a SBK key
[ 6.4018 ] Key Size is 16 bytes
[ 6.4019 ]
[ 6.4033 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 6.4044 ]
[ 6.4062 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img.encrypt
[ 6.4078 ]
[ 6.4090 ] tegrahost_v2 --appendsigheader eks_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.4100 ] Header already present for eks_sigheader.img.encrypt
[ 6.4102 ]
[ 6.4103 ] header_magic: 4e564441
[ 6.4117 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list eks_sigheader.img.encrypt_list.xml
[ 6.4127 ] PKC key in Open SSL format
[ 6.4130 ] Key size is 256 bytes
[ 6.4132 ] Valid PKC key
[ 6.4152 ] Saving pkc public key in pub_key.key
[ 6.4864 ]
[ 6.4880 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt.signed eks_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.4893 ]
[ 6.4907 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img
[ 6.4919 ]
[ 6.4921 ] header_magic: 4e564441
[ 6.4934 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list eks_sigheader.img_list.xml
[ 6.4945 ] Key is a SBK key
[ 6.4947 ] Key Size is 16 bytes
[ 6.4949 ]
[ 6.4963 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 6.4980 ]
[ 6.4993 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img.encrypt
[ 6.5004 ]
[ 6.5016 ] tegrahost_v2 --appendsigheader eks_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.5026 ] Header already present for eks_sigheader.img.encrypt
[ 6.5029 ]
[ 6.5030 ] header_magic: 4e564441
[ 6.5043 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list eks_sigheader.img.encrypt_list.xml
[ 6.5057 ] PKC key in Open SSL format
[ 6.5062 ] Key size is 256 bytes
[ 6.5065 ] Valid PKC key
[ 6.5081 ] Saving pkc public key in pub_key.key
[ 6.5786 ]
[ 6.5801 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt.signed eks_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.5814 ]
[ 6.5828 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin
[ 6.5840 ]
[ 6.5842 ] header_magic: 4e564441
[ 6.5855 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list adsp-fw_sigheader.bin_list.xml
[ 6.5865 ] Key is a SBK key
[ 6.5868 ] Key Size is 16 bytes
[ 6.5925 ]
[ 6.5941 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt adsp-fw_sigheader.bin.hash zerosbk
[ 6.5966 ]
[ 6.5979 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin.encrypt
[ 6.5990 ]
[ 6.6001 ] tegrahost_v2 --appendsigheader adsp-fw_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.6012 ] Header already present for adsp-fw_sigheader.bin.encrypt
[ 6.6028 ]
[ 6.6029 ] header_magic: 4e564441
[ 6.6042 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list adsp-fw_sigheader.bin.encrypt_list.xml
[ 6.6064 ] PKC key in Open SSL format
[ 6.6069 ] Key size is 256 bytes
[ 6.6071 ] Valid PKC key
[ 6.6088 ] Saving pkc public key in pub_key.key
[ 6.6802 ]
[ 6.6817 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt.signed adsp-fw_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.6842 ]
[ 6.6857 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin
[ 6.6868 ]
[ 6.6870 ] header_magic: 4e564441
[ 6.6884 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list adsp-fw_sigheader.bin_list.xml
[ 6.6894 ] Key is a SBK key
[ 6.6897 ] Key Size is 16 bytes
[ 6.6956 ]
[ 6.6970 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt adsp-fw_sigheader.bin.hash zerosbk
[ 6.6995 ]
[ 6.7007 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin.encrypt
[ 6.7019 ]
[ 6.7030 ] tegrahost_v2 --appendsigheader adsp-fw_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.7041 ] Header already present for adsp-fw_sigheader.bin.encrypt
[ 6.7059 ]
[ 6.7061 ] header_magic: 4e564441
[ 6.7081 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list adsp-fw_sigheader.bin.encrypt_list.xml
[ 6.7094 ] PKC key in Open SSL format
[ 6.7098 ] Key size is 256 bytes
[ 6.7101 ] Valid PKC key
[ 6.7116 ] Saving pkc public key in pub_key.key
[ 6.7834 ]
[ 6.7856 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt.signed adsp-fw_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.7902 ]
[ 6.7917 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img
[ 6.7928 ]
[ 6.7930 ] header_magic: 4e564441
[ 6.7944 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list camera-rtcpu-rce_sigheader.img_list.xml
[ 6.7958 ] Key is a SBK key
[ 6.7961 ] Key Size is 16 bytes
[ 6.8145 ]
[ 6.8161 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt camera-rtcpu-rce_sigheader.img.hash zerosbk
[ 6.8216 ]
[ 6.8232 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img.encrypt
[ 6.8246 ]
[ 6.8257 ] tegrahost_v2 --appendsigheader camera-rtcpu-rce_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.8268 ] Header already present for camera-rtcpu-rce_sigheader.img.encrypt
[ 6.8312 ]
[ 6.8313 ] header_magic: 4e564441
[ 6.8327 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list camera-rtcpu-rce_sigheader.img.encrypt_list.xml
[ 6.8337 ] PKC key in Open SSL format
[ 6.8341 ] Key size is 256 bytes
[ 6.8344 ] Valid PKC key
[ 6.8360 ] Saving pkc public key in pub_key.key
[ 6.9072 ]
[ 6.9087 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt.signed camera-rtcpu-rce_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 6.9141 ]
[ 6.9159 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img
[ 6.9170 ]
[ 6.9172 ] header_magic: 4e564441
[ 6.9191 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list camera-rtcpu-rce_sigheader.img_list.xml
[ 6.9202 ] Key is a SBK key
[ 6.9205 ] Key Size is 16 bytes
[ 6.9390 ]
[ 6.9408 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt camera-rtcpu-rce_sigheader.img.hash zerosbk
[ 6.9463 ]
[ 6.9476 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img.encrypt
[ 6.9487 ]
[ 6.9499 ] tegrahost_v2 --appendsigheader camera-rtcpu-rce_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 6.9509 ] Header already present for camera-rtcpu-rce_sigheader.img.encrypt
[ 6.9556 ]
[ 6.9557 ] header_magic: 4e564441
[ 6.9572 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list camera-rtcpu-rce_sigheader.img.encrypt_list.xml
[ 6.9582 ] PKC key in Open SSL format
[ 6.9586 ] Key size is 256 bytes
[ 6.9588 ] Valid PKC key
[ 6.9604 ] Saving pkc public key in pub_key.key
[ 7.0326 ]
[ 7.0341 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt.signed camera-rtcpu-rce_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 7.0397 ]
[ 7.0415 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin
[ 7.0426 ]
[ 7.0428 ] header_magic: 4e564441
[ 7.0446 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list bpmp_t194_sigheader.bin_list.xml
[ 7.0457 ] Key is a SBK key
[ 7.0460 ] Key Size is 16 bytes
[ 7.1013 ]
[ 7.1029 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[ 7.1177 ]
[ 7.1189 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin.encrypt
[ 7.1201 ]
[ 7.1214 ] tegrahost_v2 --appendsigheader bpmp_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 7.1229 ] Header already present for bpmp_t194_sigheader.bin.encrypt
[ 7.1371 ]
[ 7.1373 ] header_magic: 4e564441
[ 7.1390 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list bpmp_t194_sigheader.bin.encrypt_list.xml
[ 7.1404 ] PKC key in Open SSL format
[ 7.1409 ] Key size is 256 bytes
[ 7.1411 ] Valid PKC key
[ 7.1428 ] Saving pkc public key in pub_key.key
[ 7.2148 ]
[ 7.2164 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt.signed bpmp_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 7.2311 ]
[ 7.2337 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin
[ 7.2349 ]
[ 7.2350 ] header_magic: 4e564441
[ 7.2365 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list bpmp_t194_sigheader.bin_list.xml
[ 7.2375 ] Key is a SBK key
[ 7.2378 ] Key Size is 16 bytes
[ 7.2937 ]
[ 7.2954 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[ 7.3100 ]
[ 7.3112 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin.encrypt
[ 7.3125 ]
[ 7.3136 ] tegrahost_v2 --appendsigheader bpmp_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 7.3147 ] Header already present for bpmp_t194_sigheader.bin.encrypt
[ 7.3289 ]
[ 7.3290 ] header_magic: 4e564441
[ 7.3305 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list bpmp_t194_sigheader.bin.encrypt_list.xml
[ 7.3317 ] PKC key in Open SSL format
[ 7.3321 ] Key size is 256 bytes
[ 7.3323 ] Valid PKC key
[ 7.3338 ] Saving pkc public key in pub_key.key
[ 7.4060 ]
[ 7.4075 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt.signed bpmp_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 7.4225 ]
[ 7.4255 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb
[ 7.4267 ]
[ 7.4269 ] header_magic: 4e564441
[ 7.4282 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml
[ 7.4293 ] Key is a SBK key
[ 7.4296 ] Key Size is 16 bytes
[ 7.4447 ]
[ 7.4462 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 7.4509 ]
[ 7.4522 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 7.4534 ]
[ 7.4545 ] tegrahost_v2 --appendsigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 7.4556 ] Header already present for tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 7.4594 ]
[ 7.4595 ] header_magic: 4e564441
[ 7.4609 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt_list.xml
[ 7.4620 ] PKC key in Open SSL format
[ 7.4623 ] Key size is 256 bytes
[ 7.4625 ] Valid PKC key
[ 7.4648 ] Saving pkc public key in pub_key.key
[ 7.5363 ]
[ 7.5378 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 7.5425 ]
[ 7.5442 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb
[ 7.5453 ]
[ 7.5455 ] header_magic: 4e564441
[ 7.5470 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml
[ 7.5481 ] Key is a SBK key
[ 7.5485 ] Key Size is 16 bytes
[ 7.5634 ]
[ 7.5652 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 7.5704 ]
[ 7.5719 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 7.5735 ]
[ 7.5748 ] tegrahost_v2 --appendsigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 7.5758 ] Header already present for tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 7.5797 ]
[ 7.5798 ] header_magic: 4e564441
[ 7.5812 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt_list.xml
[ 7.5823 ] PKC key in Open SSL format
[ 7.5826 ] Key size is 256 bytes
[ 7.5828 ] Valid PKC key
[ 7.5845 ] Saving pkc public key in pub_key.key
[ 7.6571 ]
[ 7.6587 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 7.6634 ]
[ 7.6651 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img
[ 7.6663 ]
[ 7.6665 ] header_magic: 4e564441
[ 7.6679 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list boot_sigheader.img_list.xml
[ 7.6694 ] Key is a SBK key
[ 7.6697 ] Key Size is 16 bytes
[ 7.6697 ]
[ 7.6710 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt boot_sigheader.img.hash zerosbk
[ 7.6727 ]
[ 7.6744 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img.encrypt
[ 7.6756 ]
[ 7.6767 ] tegrahost_v2 --appendsigheader boot_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 7.6778 ] Header already present for boot_sigheader.img.encrypt
[ 7.6780 ]
[ 7.6781 ] header_magic: 4e564441
[ 7.6794 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list boot_sigheader.img.encrypt_list.xml
[ 7.6805 ] PKC key in Open SSL format
[ 7.6809 ] Key size is 256 bytes
[ 7.6811 ] Valid PKC key
[ 7.6826 ] Saving pkc public key in pub_key.key
[ 7.7534 ]
[ 7.7549 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt.signed boot_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 7.7563 ]
[ 7.7577 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img
[ 7.7588 ]
[ 7.7590 ] header_magic: 4e564441
[ 7.7604 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list boot_sigheader.img_list.xml
[ 7.7614 ] Key is a SBK key
[ 7.7618 ] Key Size is 16 bytes
[ 7.7619 ]
[ 7.7632 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt boot_sigheader.img.hash zerosbk
[ 7.7643 ]
[ 7.7660 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img.encrypt
[ 7.7673 ]
[ 7.7685 ] tegrahost_v2 --appendsigheader boot_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 7.7695 ] Header already present for boot_sigheader.img.encrypt
[ 7.7698 ]
[ 7.7699 ] header_magic: 4e564441
[ 7.7713 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list boot_sigheader.img.encrypt_list.xml
[ 7.7729 ] PKC key in Open SSL format
[ 7.7733 ] Key size is 256 bytes
[ 7.7737 ] Valid PKC key
[ 7.7750 ] Saving pkc public key in pub_key.key
[ 7.8478 ]
[ 7.8493 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt.signed boot_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 7.8507 ]
[ 7.8521 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 7.8532 ]
[ 7.8534 ] header_magic: 4e564441
[ 7.8548 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 7.8558 ] Key is a SBK key
[ 7.8561 ] Key Size is 16 bytes
[ 7.8694 ]
[ 7.8709 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 7.8764 ]
[ 7.8780 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 7.8792 ]
[ 7.8803 ] tegrahost_v2 --appendsigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 7.8813 ] Header already present for tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 7.8848 ]
[ 7.8850 ] header_magic: 4e564441
[ 7.8865 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml
[ 7.8875 ] PKC key in Open SSL format
[ 7.8879 ] Key size is 256 bytes
[ 7.8881 ] Valid PKC key
[ 7.8899 ] Saving pkc public key in pub_key.key
[ 7.9610 ]
[ 7.9625 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 7.9669 ]
[ 7.9686 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 7.9698 ]
[ 7.9700 ] header_magic: 4e564441
[ 7.9713 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 7.9725 ] Key is a SBK key
[ 7.9727 ] Key Size is 16 bytes
[ 7.9860 ]
[ 7.9877 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 7.9935 ]
[ 7.9948 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 7.9959 ]
[ 7.9970 ] tegrahost_v2 --appendsigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 7.9980 ] Header already present for tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 8.0016 ]
[ 8.0017 ] header_magic: 4e564441
[ 8.0032 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml
[ 8.0042 ] PKC key in Open SSL format
[ 8.0045 ] Key size is 256 bytes
[ 8.0047 ] Valid PKC key
[ 8.0064 ] Saving pkc public key in pub_key.key
[ 8.0774 ]
[ 8.0790 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 8.0834 ]
[ 8.0898 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin
[ 8.0911 ]
[ 8.0913 ] header_magic: 50000ea
[ 8.0926 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_recovery_t194.bin_list.xml
[ 8.0936 ] Key is a SBK key
[ 8.0940 ] Key Size is 16 bytes
[ 8.1021 ]
[ 8.1035 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194.bin.encrypt nvtboot_recovery_t194.bin.hash zerosbk
[ 8.1053 ]
[ 8.1071 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin.encrypt
[ 8.1086 ]
[ 8.1100 ] tegrahost_v2 --appendsigheader nvtboot_recovery_t194.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B
[ 8.1112 ] adding BCH for nvtboot_recovery_t194.bin.encrypt
[ 8.1153 ]
[ 8.1154 ] header_magic: 3e918cce
[ 8.1168 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_recovery_t194.bin_sigheader.encrypt_list.xml
[ 8.1179 ] PKC key in Open SSL format
[ 8.1183 ] Key size is 256 bytes
[ 8.1185 ] Valid PKC key
[ 8.1201 ] Saving pkc public key in pub_key.key
[ 8.1918 ]
[ 8.1933 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194.bin_sigheader.encrypt.signed nvtboot_recovery_t194.bin_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 8.1966 ]
[ 8.1979 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin
[ 8.1991 ]
[ 8.1993 ] header_magic: 9000014
[ 8.2006 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_recovery_cpu_t194.bin_list.xml
[ 8.2016 ] Key is a SBK key
[ 8.2019 ] Key Size is 16 bytes
[ 8.2199 ]
[ 8.2217 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194.bin.encrypt nvtboot_recovery_cpu_t194.bin.hash zerosbk
[ 8.2238 ]
[ 8.2252 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin.encrypt
[ 8.2268 ]
[ 8.2282 ] tegrahost_v2 --appendsigheader nvtboot_recovery_cpu_t194.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid CPBL
[ 8.2293 ] adding BCH for nvtboot_recovery_cpu_t194.bin.encrypt
[ 8.2372 ]
[ 8.2373 ] header_magic: 572127db
[ 8.2387 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_recovery_cpu_t194.bin_sigheader.encrypt_list.xml
[ 8.2398 ] PKC key in Open SSL format
[ 8.2401 ] Key size is 256 bytes
[ 8.2403 ] Valid PKC key
[ 8.2420 ] Saving pkc public key in pub_key.key
[ 8.3131 ]
[ 8.3147 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 8.3199 ]
[ 8.3201 ] Copying signed file in /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x
[ 8.3211 ] Generating br-bct
[ 8.3222 ] Performing cfg overlay
[ 8.3223 ] ['/home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg']
[ 8.3223 ] Updating dev and MSS params in BR BCT
[ 8.3224 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 8.3675 ]
[ 8.3676 ] Updating bl info
[ 8.3690 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 8.3720 ]
[ 8.3720 ] Generating br-bct
[ 8.3736 ] Performing cfg overlay
[ 8.3737 ] ['/home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg']
[ 8.3737 ] Updating dev and MSS params in BR BCT
[ 8.3738 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 8.4195 ]
[ 8.4195 ] Updating bl info
[ 8.4209 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 8.4246 ]
[ 8.4247 ] Updating smd info
[ 8.4259 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 8.4273 ]
[ 8.4274 ] Updating Odmdata
[ 8.4286 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 8.4300 ]
[ 8.4301 ] Get encrypted section of bct
[ 8.4312 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listencbct bct_list.xml
[ 8.4325 ]
[ 8.4325 ] Signing BCT
[ 8.4339 ] Generating signatures with encryption
[ 8.4355 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --offset 2328 --file br_bct_BR.bct
[ 8.4370 ] Key is a SBK key
[ 8.4374 ] Key Size is 16 bytes
[ 8.4374 ]
[ 8.4374 ] Updating BCT with signature
[ 8.4379 ] Get Signed section of bct
[ 8.4394 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 8.4410 ]
[ 8.4422 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 8.4433 ] PKC key in Open SSL format
[ 8.4436 ] Key size is 256 bytes
[ 8.4438 ] Valid PKC key
[ 8.4455 ] Saving pkc public key in pub_key.key
[ 8.5162 ]
[ 8.5162 ] Updating BCT with signature
[ 8.5175 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key
[ 8.5190 ]
[ 8.5191 ] Generating coldboot mb1-bct
[ 8.5206 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 8.5217 ] MB1-BCT version: 0x1
[ 8.5221 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 8.5226 ] Added Platform Config 0 data with size :- 2496
[ 8.5246 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 8.5251 ] Added Platform Config 1 data with size :- 19640
[ 8.5469 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 8.5475 ] Added Platform Config 2 data with size :- 24
[ 8.5478 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 8.5484 ] Added Platform Config 4 data with size :- 348
[ 8.5488 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 8.5493 ] Added Platform Config 3 data with size :- 92
[ 8.5497 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 8.5502 ] Added Platform Config 5 data with size :- 128
[ 8.5503 ]
[ 8.5503 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 8.5503 ] Added Platform Config 7 data with size :- 392
[ 8.5503 ]
[ 8.5503 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 8.5503 ] Added Platform Config 9 data with size :- 40
[ 8.5503 ]
[ 8.5504 ] Updating mb1-bct with firmware information
[ 8.5518 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 8.5529 ] MB1-BCT version: 0x1
[ 8.5534 ]
[ 8.5535 ] Updating mb1-bct with storage information
[ 8.5547 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 8.5562 ] MB1-BCT version: 0x1
[ 8.5569 ]
[ 8.5583 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 8.5595 ]
[ 8.5596 ] header_magic: c0660000
[ 8.5610 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mb1_cold_boot_bct_MB1.bct_list.xml
[ 8.5621 ] Key is a SBK key
[ 8.5624 ] Key Size is 16 bytes
[ 8.5642 ]
[ 8.5656 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1.bct.encrypt mb1_cold_boot_bct_MB1.bct.hash zerosbk
[ 8.5669 ]
[ 8.5682 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct.encrypt
[ 8.5694 ]
[ 8.5706 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT
[ 8.5717 ] adding BCH for mb1_cold_boot_bct_MB1.bct.encrypt
[ 8.5729 ]
[ 8.5731 ] header_magic: 61a13e4a
[ 8.5747 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_cold_boot_bct_MB1.bct_sigheader.encrypt_list.xml
[ 8.5761 ] PKC key in Open SSL format
[ 8.5765 ] Key size is 256 bytes
[ 8.5767 ] Valid PKC key
[ 8.5784 ] Saving pkc public key in pub_key.key
[ 8.6494 ]
[ 8.6510 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 8.6527 ]
[ 8.6528 ] Generating recovery mb1-bct
[ 8.6544 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 8.6555 ] MB1-BCT version: 0x1
[ 8.6560 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 8.6566 ] Added Platform Config 0 data with size :- 2496
[ 8.6587 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 8.6594 ] Added Platform Config 1 data with size :- 19640
[ 8.6810 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 8.6816 ] Added Platform Config 2 data with size :- 24
[ 8.6820 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 8.6827 ] Added Platform Config 4 data with size :- 348
[ 8.6831 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 8.6838 ] Added Platform Config 3 data with size :- 92
[ 8.6841 ]
[ 8.6841 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 8.6841 ] Added Platform Config 5 data with size :- 128
[ 8.6841 ]
[ 8.6841 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 8.6841 ] Added Platform Config 7 data with size :- 392
[ 8.6841 ]
[ 8.6841 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 8.6842 ] Added Platform Config 9 data with size :- 40
[ 8.6842 ]
[ 8.6842 ] Updating mb1-bct with firmware information
[ 8.6855 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 8.6867 ] MB1-BCT version: 0x1
[ 8.6888 ]
[ 8.6889 ] Updating mb1-bct with storage information
[ 8.6903 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 8.6919 ] MB1-BCT version: 0x1
[ 8.6925 ]
[ 8.6938 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 8.6950 ]
[ 8.6951 ] header_magic: c0660000
[ 8.6965 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mb1_bct_MB1.bct_list.xml
[ 8.6975 ] Key is a SBK key
[ 8.6978 ] Key Size is 16 bytes
[ 8.6997 ]
[ 8.7011 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1.bct.encrypt mb1_bct_MB1.bct.hash zerosbk
[ 8.7025 ]
[ 8.7038 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct.encrypt
[ 8.7050 ]
[ 8.7062 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT
[ 8.7073 ] adding BCH for mb1_bct_MB1.bct.encrypt
[ 8.7085 ]
[ 8.7086 ] header_magic: 61a13e4a
[ 8.7104 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_bct_MB1.bct_sigheader.encrypt_list.xml
[ 8.7117 ] PKC key in Open SSL format
[ 8.7121 ] Key size is 256 bytes
[ 8.7124 ] Valid PKC key
[ 8.7138 ] Saving pkc public key in pub_key.key
[ 8.7853 ]
[ 8.7869 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1.bct_sigheader.encrypt.signed mb1_bct_MB1.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 8.7937 ]
[ 8.7938 ] Generating coldboot mem-bct
[ 8.7951 ] tegrabct_v2 --chip 0x19 0 --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg --membct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_1.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_2.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_3.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_4.bct
[ 8.7960 ] Packing sdram param for instance[0]
[ 8.8414 ] Packing sdram param for instance[1]
[ 8.8418 ] Packing sdram param for instance[2]
[ 8.8419 ] Packing sdram param for instance[3]
[ 8.8419 ] Packing sdram param for instance[4]
[ 8.8419 ] Packing sdram param for instance[5]
[ 8.8419 ] Packing sdram param for instance[6]
[ 8.8419 ] Packing sdram param for instance[7]
[ 8.8419 ] Packing sdram param for instance[8]
[ 8.8419 ] Packing sdram param for instance[9]
[ 8.8419 ] Packing sdram param for instance[10]
[ 8.8420 ] Packing sdram param for instance[11]
[ 8.8420 ] Packing sdram param for instance[12]
[ 8.8420 ] Packing sdram param for instance[13]
[ 8.8420 ] Packing sdram param for instance[14]
[ 8.8420 ] Packing sdram param for instance[15]
[ 8.8420 ]
[ 8.8420 ] Getting sector size from pt
[ 8.8436 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 8.8452 ]
[ 8.8453 ] BlockSize read from layout is 200
[ 8.8468 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_1.bct
[ 8.8480 ] Key is a SBK key
[ 8.8483 ] Key Size is 16 bytes
[ 8.8515 ]
[ 8.8527 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_2.bct
[ 8.8537 ] Key is a SBK key
[ 8.8540 ] Key Size is 16 bytes
[ 8.8574 ]
[ 8.8587 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_3.bct
[ 8.8598 ] Key is a SBK key
[ 8.8601 ] Key Size is 16 bytes
[ 8.8632 ]
[ 8.8643 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_4.bct
[ 8.8654 ] Key is a SBK key
[ 8.8657 ] Key Size is 16 bytes
[ 8.8689 ]
[ 8.8701 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_1_encrypt.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_2_encrypt.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_3_encrypt.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_4_encrypt.bct
[ 8.8712 ] adding BCH for /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_1_encrypt.bct
[ 8.8745 ]
[ 8.8761 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 8.8776 ]
[ 8.8789 ] tegrahost_v2 --appendsigheader mem_coldboot.bct oem-rsa-sbk --chip 0x19 0 --magicid MEMB
[ 8.8800 ] Header already present for mem_coldboot.bct
[ 8.8804 ]
[ 8.8805 ] header_magic: 4e564441
[ 8.8819 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mem_coldboot.bct_list.xml
[ 8.8830 ] PKC key in Open SSL format
[ 8.8834 ] Key size is 256 bytes
[ 8.8836 ] Valid PKC key
[ 8.8851 ] Saving pkc public key in pub_key.key
[ 8.9568 ]
[ 8.9583 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot.bct.signed mem_coldboot.bct.sig oem-rsa --pubkeyhash pub_key.key
[ 8.9599 ]
[ 8.9611 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 8.9623 ]
[ 8.9634 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct oem-rsa
[ 8.9645 ] Header already present for mem_coldboot.bct
[ 8.9650 ]
[ 8.9665 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 8.9676 ] PKC key in Open SSL format
[ 8.9679 ] Key size is 256 bytes
[ 8.9682 ] Valid PKC key
[ 8.9700 ] Saving pkc public key in pub_key.key
[ 9.0423 ]
[ 9.0438 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --updatesigheader mem_coldboot_sigheader.bct.signed mem_coldboot_sigheader.bct.sig oem-rsa
[ 9.0454 ]
[ 9.0456 ] Generating recovery mem-bct
[ 9.0468 ] tegrabct_v2 --chip 0x19 0 --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91.cfg --membct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_1.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_2.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_3.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/29215/tmpuwgij6s91_4.bct
[ 9.0478 ] Packing sdram param for instance[0]
[ 9.0924 ] Packing sdram param for instance[1]
[ 9.0928 ] Packing sdram param for instance[2]
[ 9.0930 ] Packing sdram param for instance[3]
[ 9.0930 ] Packing sdram param for instance[4]
[ 9.0930 ] Packing sdram param for instance[5]
[ 9.0930 ] Packing sdram param for instance[6]
[ 9.0930 ] Packing sdram param for instance[7]
[ 9.0930 ] Packing sdram param for instance[8]
[ 9.0930 ] Packing sdram param for instance[9]
[ 9.0930 ] Packing sdram param for instance[10]
[ 9.0930 ] Packing sdram param for instance[11]
[ 9.0930 ] Packing sdram param for instance[12]
[ 9.0930 ] Packing sdram param for instance[13]
[ 9.0931 ] Packing sdram param for instance[14]
[ 9.0931 ] Packing sdram param for instance[15]
[ 9.0931 ]
[ 9.0932 ] Reading ramcode from backup chip_info.bin file
[ 9.0933 ] RAMCODE Read from Device: 0
[ 9.0933 ] Disabled BPMP dtb trim, using default dtb
[ 9.0933 ]
[ 9.0947 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 9.0958 ]
[ 9.0960 ] header_magic: 3000000
[ 9.0973 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mem_rcm.bct_list.xml
[ 9.0983 ] Key is a SBK key
[ 9.0986 ] Key Size is 16 bytes
[ 9.1024 ]
[ 9.1040 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm.bct.encrypt mem_rcm.bct.hash zerosbk
[ 9.1060 ]
[ 9.1074 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct.encrypt
[ 9.1086 ]
[ 9.1097 ] tegrahost_v2 --appendsigheader mem_rcm.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MEMB
[ 9.1108 ] adding BCH for mem_rcm.bct.encrypt
[ 9.1125 ]
[ 9.1126 ] header_magic: 72aa2959
[ 9.1140 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mem_rcm.bct_sigheader.encrypt_list.xml
[ 9.1151 ] PKC key in Open SSL format
[ 9.1154 ] Key size is 256 bytes
[ 9.1156 ] Valid PKC key
[ 9.1172 ] Saving pkc public key in pub_key.key
[ 9.1882 ]
[ 9.1898 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm.bct_sigheader.encrypt.signed mem_rcm.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 9.1919 ]
[ 9.1929 ] nvtboot_recovery_t194.bin_sigheader.encrypt.signed
[ 9.1932 ] preboot_c10_prod_cr.bin
[ 9.1933 ] mce_c10_prod_cr.bin
[ 9.1936 ] mts_c10_prod_cr.bin
[ 9.1975 ] tegra194-p3668-all-p3509-0000.dtb
[ 9.1979 ] bpmp_t194.bin
[ 9.1990 ] tegra194-a02-bpmp-p3668-a00.dtb
[ 9.1994 ] tos-trusty_t194.img
[ 9.2002 ] eks.img
[ 9.2004 ] boot.img
[ 9.2005 ] tegra194-p3668-all-p3509-0000.dtb
[ 9.2424 ] spe_t194.bin
[ 9.2429 ] nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed
[ 9.2460 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 9.2491 ]
[ 9.2518 ] tegrahost_v2 --appendsigheader mb1_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB1B
[ 9.2540 ] Header already present for mb1_t194_prod_sigheader.bin.encrypt
[ 9.2628 ]
[ 9.2631 ] header_magic: 4e564441
[ 9.2658 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_t194_prod_sigheader.bin.encrypt_list.xml
[ 9.2678 ] PKC key in Open SSL format
[ 9.2686 ] Key size is 256 bytes
[ 9.2690 ] Valid PKC key
[ 9.2721 ] Saving pkc public key in pub_key.key
[ 9.3484 ]
[ 9.3500 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 9.3551 ]
[ 9.3568 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 9.3584 ]
[ 9.3654 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x/flash.xml.tmp flash.idx
[ 9.5444 ]
./tegraflash.py --securedev --bins "mb2_bootloader encrypted_signed_t19x/nvtboot_recovery_t194.bin_sigheader.encrypt.signed; mts_preboot encrypted_signed_t19x/preboot_c10_prod_cr_sigheader.bin.encrypt.signed; mts_mce encrypted_signed_t19x/mce_c10_prod_cr_sigheader.bin.encrypt.signed; mts_proper encrypted_signed_t19x/mts_c10_prod_cr_sigheader.bin.encrypt.signed; bootloader_dtb encrypted_signed_t19x/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed; bpmp_fw encrypted_signed_t19x/bpmp_t194_sigheader.bin.encrypt.signed; bpmp_fw_dtb encrypted_signed_t19x/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed; tlk encrypted_signed_t19x/tos-trusty_t194_sigheader.img.encrypt.signed; eks encrypted_signed_t19x/eks_sigheader.img.encrypt.signed; spe_fw encrypted_signed_t19x/spe_t194_sigheader.bin.encrypt.signed" --bl encrypted_signed_t19x/nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed --bct encrypted_signed_t19x/br_bct_BR.bct --mb1_bct encrypted_signed_t19x/mb1_bct_MB1.bct_sigheader.encrypt.signed --mem_bct encrypted_signed_t19x/mem_rcm.bct_sigheader.encrypt.signed --mb1_cold_boot_bct encrypted_signed_t19x/mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed --mem_bct_cold_boot encrypted_signed_t19x/mem_coldboot_sigheader.bct.signed --applet encrypted_signed_t19x/rcm_2_signed.rcm --applet_softfuse encrypted_signed_t19x/rcm_1_signed.rcm --odmdata 0xB8190000 --chip 0x19 --cmd "readfuses fuse_info.txt fuses_to_read.xml; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0044 ] Reading fuses
[ 0.0044 ] Boot Rom communication
[ 0.0055 ] tegrarcm_v2 --chip 0x19 0 --rcm /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x/rcm_1_signed.rcm --rcm /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x/rcm_2_signed.rcm
[ 0.0065 ] BR_CID: 0xd8021911647147031400000003ff0040
[ 0.0074 ] Boot Rom communication completed
[ 1.0555 ]
[ 2.0604 ] tegrarcm_v2 --isapplet
[ 2.0632 ] Applet version 01.00.0000
[ 2.0805 ]
[ 2.0809 ] Parsing fuse info as per xml file
[ 2.0841 ] tegraparser_v2 --get_fuse_names fuses_to_read.xml read_fuse_names.txt
[ 2.0871 ] MagicId=0x45535546 version=0x1
[ 2.0878 ]
[ 2.0884 ] trying to read fuse with CPU binary
[ 2.0886 ] Updating Odmdata
[ 2.0927 ] tegrabct_v2 --brbct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x/br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 2.0974 ]
[ 2.0976 ] Sending BCTs
[ 2.1009 ] tegrarcm_v2 --download bct_bootrom /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x/br_bct_BR.bct --download bct_mb1 /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x/mb1_bct_MB1.bct_sigheader.encrypt.signed --download bct_mem /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x/mem_rcm.bct_sigheader.encrypt.signed
[ 2.1038 ] Applet version 01.00.0000
[ 2.1209 ] Sending bct_bootrom
[ 2.1215 ] [................................................] 100%
[ 2.1235 ] Sending bct_mb1
[ 2.1283 ] [................................................] 100%
[ 2.1329 ] Sending bct_mem
[ 2.1815 ] [................................................] 100%
[ 2.2571 ]
[ 2.2572 ] Generating blob
[ 2.2655 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 2.2686 ] number of images in blob are 11
[ 2.2704 ] blobsize is 5778776
[ 2.2713 ] Added binary blob_nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed of size 260032
[ 2.2820 ] Added binary blob_nvtboot_recovery_t194.bin_sigheader.encrypt.signed of size 130928
[ 2.2842 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt.signed of size 24016
[ 2.2864 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt.signed of size 143200
[ 2.2895 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt.signed of size 3430416
[ 2.2923 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed of size 203920
[ 2.2954 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt.signed of size 856352
[ 2.2980 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed of size 227264
[ 2.3002 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt.signed of size 402368
[ 2.3020 ] Added binary blob_eks_sigheader.img.encrypt.signed of size 5136
[ 2.3034 ] Added binary blob_spe_t194_sigheader.bin.encrypt.signed of size 94960
[ 2.3080 ]
[ 2.3081 ] Sending bootloader and pre-requisite binaries
[ 2.3099 ] tegrarcm_v2 --download blob blob.bin
[ 2.3112 ] Applet version 01.00.0000
[ 2.3325 ] Sending blob
[ 2.3327 ] [................................................] 100%
[ 3.1456 ]
[ 3.1521 ] tegrarcm_v2 --boot recovery
[ 3.1577 ] Applet version 01.00.0000
[ 3.1648 ]
[ 4.1695 ] tegrarcm_v2 --isapplet
[ 4.3575 ]
[ 4.3617 ] tegrarcm_v2 --ismb2
[ 4.3801 ]
[ 4.3841 ] tegradevflash_v2 --iscpubl
[ 4.3879 ] Bootloader version 01.00.0000
[ 4.4063 ] Bootloader version 01.00.0000
[ 4.4064 ]
[ 4.4108 ] tegraparser_v2 --read_fusetype PublicKeyHash read_fuse.bin
[ 4.4146 ]
[ 4.4184 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.4221 ] Bootloader version 01.00.0000
[ 4.4256 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.4273 ] Fuse read successful
[ 4.4274 ]
[ 4.4302 ] tegraparser_v2 --read_fusetype SecureBootKey read_fuse.bin
[ 4.4328 ]
[ 4.4347 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.4362 ] Bootloader version 01.00.0000
[ 4.4384 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.4404 ] Fuse read successful
[ 4.4404 ]
[ 4.4419 ] tegraparser_v2 --read_fusetype Kek0 read_fuse.bin
[ 4.4433 ]
[ 4.4445 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.4455 ] Bootloader version 01.00.0000
[ 4.4596 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.4613 ] Fuse read successful
[ 4.4616 ]
[ 4.4628 ] tegraparser_v2 --read_fusetype Kek1 read_fuse.bin
[ 4.4639 ]
[ 4.4649 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.4658 ] Bootloader version 01.00.0000
[ 4.4839 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.4855 ] Fuse read successful
[ 4.4858 ]
[ 4.4875 ] tegraparser_v2 --read_fusetype Kek2 read_fuse.bin
[ 4.4891 ]
[ 4.4903 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.4913 ] Bootloader version 01.00.0000
[ 4.5078 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.5096 ] Fuse read successful
[ 4.5098 ]
[ 4.5115 ] tegraparser_v2 --read_fusetype Kek256 read_fuse.bin
[ 4.5133 ]
[ 4.5154 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.5167 ] Bootloader version 01.00.0000
[ 4.5329 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.5343 ] Fuse read successful
[ 4.5343 ]
[ 4.5369 ] tegraparser_v2 --read_fusetype BootSecurityInfo read_fuse.bin
[ 4.5390 ]
[ 4.5414 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.5435 ] Bootloader version 01.00.0000
[ 4.5461 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.5480 ] Fuse read successful
[ 4.5481 ]
[ 4.5503 ] tegraparser_v2 --read_fusetype JtagDisable read_fuse.bin
[ 4.5525 ]
[ 4.5553 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.5574 ] Bootloader version 01.00.0000
[ 4.5600 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.5619 ] Fuse read successful
[ 4.5619 ]
[ 4.5640 ] tegraparser_v2 --read_fusetype SecurityMode read_fuse.bin
[ 4.5663 ]
[ 4.5686 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.5707 ] Bootloader version 01.00.0000
[ 4.5733 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.5758 ] Fuse read successful
[ 4.5758 ]
[ 4.5788 ] tegraparser_v2 --read_fusetype SwReserved read_fuse.bin
[ 4.5817 ]
[ 4.5839 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.5855 ] Bootloader version 01.00.0000
[ 4.5878 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.5897 ] Fuse read successful
[ 4.5905 ]
[ 4.5922 ] tegraparser_v2 --read_fusetype DebugAuthentication read_fuse.bin
[ 4.5937 ]
[ 4.5950 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.5960 ] Bootloader version 01.00.0000
[ 4.6118 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.6134 ] Fuse read successful
[ 4.6137 ]
[ 4.6149 ] tegraparser_v2 --read_fusetype OdmId read_fuse.bin
[ 4.6161 ]
[ 4.6173 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.6183 ] Bootloader version 01.00.0000
[ 4.6359 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.6379 ] Fuse read successful
[ 4.6380 ]
[ 4.6396 ] tegraparser_v2 --read_fusetype OdmLock read_fuse.bin
[ 4.6410 ]
[ 4.6422 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.6432 ] Bootloader version 01.00.0000
[ 4.6639 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.6658 ] Fuse read successful
[ 4.6658 ]
[ 4.6675 ] tegraparser_v2 --read_fusetype ReservedOdm0 read_fuse.bin
[ 4.6699 ]
[ 4.6716 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.6732 ] Bootloader version 01.00.0000
[ 4.6882 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.6904 ] Fuse read successful
[ 4.6904 ]
[ 4.6929 ] tegraparser_v2 --read_fusetype ReservedOdm1 read_fuse.bin
[ 4.6949 ]
[ 4.6967 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.6982 ] Bootloader version 01.00.0000
[ 4.7006 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.7029 ] Fuse read successful
[ 4.7029 ]
[ 4.7054 ] tegraparser_v2 --read_fusetype ReservedOdm2 read_fuse.bin
[ 4.7076 ]
[ 4.7093 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.7109 ] Bootloader version 01.00.0000
[ 4.7134 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.7152 ] Fuse read successful
[ 4.7153 ]
[ 4.7171 ] tegraparser_v2 --read_fusetype ReservedOdm3 read_fuse.bin
[ 4.7190 ]
[ 4.7208 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.7223 ] Bootloader version 01.00.0000
[ 4.7249 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.7266 ] Fuse read successful
[ 4.7267 ]
[ 4.7285 ] tegraparser_v2 --read_fusetype ReservedOdm4 read_fuse.bin
[ 4.7302 ]
[ 4.7322 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.7343 ] Bootloader version 01.00.0000
[ 4.7367 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.7389 ] Fuse read successful
[ 4.7389 ]
[ 4.7409 ] tegraparser_v2 --read_fusetype ReservedOdm5 read_fuse.bin
[ 4.7427 ]
[ 4.7445 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.7461 ] Bootloader version 01.00.0000
[ 4.7483 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.7502 ] Fuse read successful
[ 4.7503 ]
[ 4.7522 ] tegraparser_v2 --read_fusetype ReservedOdm6 read_fuse.bin
[ 4.7541 ]
[ 4.7559 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.7575 ] Bootloader version 01.00.0000
[ 4.7721 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.7740 ] Fuse read successful
[ 4.7740 ]
[ 4.7759 ] tegraparser_v2 --read_fusetype ReservedOdm7 read_fuse.bin
[ 4.7776 ]
[ 4.7793 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.7808 ] Bootloader version 01.00.0000
[ 4.8003 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.8019 ] Fuse read successful
[ 4.8019 ]
[ 4.8043 ] tegraparser_v2 --read_fusetype ReservedOdm8 read_fuse.bin
[ 4.8069 ]
[ 4.8087 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.8103 ] Bootloader version 01.00.0000
[ 4.8129 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.8148 ] Fuse read successful
[ 4.8149 ]
[ 4.8168 ] tegraparser_v2 --read_fusetype ReservedOdm9 read_fuse.bin
[ 4.8188 ]
[ 4.8206 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.8223 ] Bootloader version 01.00.0000
[ 4.8248 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.8268 ] Fuse read successful
[ 4.8270 ]
[ 4.8291 ] tegraparser_v2 --read_fusetype ReservedOdm10 read_fuse.bin
[ 4.8311 ]
[ 4.8329 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.8345 ] Bootloader version 01.00.0000
[ 4.8369 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.8391 ] Fuse read successful
[ 4.8391 ]
[ 4.8410 ] tegraparser_v2 --read_fusetype ReservedOdm11 read_fuse.bin
[ 4.8426 ]
[ 4.8440 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 4.8452 ] Bootloader version 01.00.0000
[ 4.8599 ] Saved read fuses in file __fuse_read_scatter.bin
[ 4.8618 ] Fuse read successful
[ 4.8618 ]
[ 4.8620 ] Rebooting to recovery mode
[ 4.8633 ] tegrarcm_v2 --ismb2
[ 4.8958 ]
[ 4.8978 ] tegradevflash_v2 --reboot recovery
[ 4.8998 ] Bootloader version 01.00.0000
[ 4.9170 ]
Fuse reading is done. The fuse values have been saved in: /home/dcapers/nvidia/Linux_for_Tegra/bootloader/fuse_info.txt
PublicKeyHash: 9c2b1440c40fe6f12fe5a3f3810b4a426f8780ee21d4b2d67a6f4297feaf3193
SecureBootKey: 0123456789abcdeffedcba9876543210
Kek0: 00000000000000000000000000000000
Kek1: 00000000000000000000000000000000
Kek2: 0e2c4a681f3d5b7986a4c2e097b5d3f1
Kek256: 0000000000000000000000000000000000000000000000000000000000000000
BootSecurityInfo: 00000005
JtagDisable: 00000000
SecurityMode: 00000000
SwReserved: 00000000
DebugAuthentication: 00000000
OdmId: 0000000000000000
OdmLock: 00000000
ReservedOdm0: 00000000
ReservedOdm1: 00000000
ReservedOdm2: 00000000
ReservedOdm3: 00000000
ReservedOdm4: 00000000
ReservedOdm5: 00000000
ReservedOdm6: 00000000
ReservedOdm7: 00000000
ReservedOdm8: 00000000
ReservedOdm9: 00000000
ReservedOdm10: 00000000
ReservedOdm11: 00000000
The KEK2 has been burned. You can't burn it again.
Add --force if you really want to do it.
Error: check fuse values failed.
@JerryChang
Below is the console output after running the following without a jumper across pin 9 and 10 of J14 on the Jestson:
sudo ./flash.sh -u RSA_Key.pem -v SBK.txt --user_key User_Key.txt jetson-xavier-nx-devkit mmcblk0p1
dcapers@NUC-Ubuntu-18.04:~/nvidia/Linux_for_Tegra$ sudo ./flash.sh -u RSA_Key.pem -v SBK.txt --user_key User_Key.txt jetson-xavier-nx-devkit mmcblk0p1
[sudo] password for dcapers:
# L4T BSP Information:
# R32 , REVISION: 5.0
# Target Board Information:
# Name: jetson-xavier-nx-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: SBKPKC,
# Disk encryption: disabled ,
copying soft_fuses(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery" --key "/home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem" --encrypt_key "/home/dcapers/nvidia/Linux_for_Tegra/SBK.txt"
version 1.0.0
[ 0.0043 ] Generating RCM messages
[ 0.0054 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin --offset 4096
[ 0.0065 ] Key is a SBK key
[ 0.0068 ] Key Size is 16 bytes
[ 0.0227 ]
[ 0.0240 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt.bin zerosbk
[ 0.0250 ] Header already present for /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt.bin
[ 0.0292 ]
[ 0.0303 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0316 ] PKC key in Open SSL format
[ 0.0320 ] Key size is 256 bytes
[ 0.0323 ] Valid PKC key
[ 0.0340 ]
[ 0.0358 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0370 ] PKC key in Open SSL format
[ 0.0375 ] Key size is 256 bytes
[ 0.0377 ] Valid PKC key
[ 0.0392 ] Saving pkc public key in pub_key.key
[ 0.1103 ]
[ 0.1116 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.sig oem-rsa
[ 0.1167 ]
[ 0.1182 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.1196 ]
[ 0.1207 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin 0 0
[ 0.1219 ] RCM 0 is saved as rcm_0.rcm
[ 0.1261 ] RCM 1 is saved as rcm_1.rcm
[ 0.1261 ] RCM 2 is saved as rcm_2.rcm
[ 0.1261 ] List of rcm files are saved in rcm_list.xml
[ 0.1261 ]
[ 0.1262 ] Signing RCM messages
[ 0.1274 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.1284 ] PKC key in Open SSL format
[ 0.1288 ] Key size is 256 bytes
[ 0.1289 ] Valid PKC key
[ 0.1306 ] Saving pkc public key in pub_key.key
[ 0.3427 ]
[ 0.3428 ] Copying signature to RCM mesages
[ 0.3441 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key
[ 0.3459 ]
[ 0.3460 ] Boot Rom communication
[ 0.3471 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.3481 ] RCM version 0X190001
[ 0.3525 ] Boot Rom communication completed
[ 1.3814 ]
[ 2.3875 ] tegrarcm_v2 --isapplet
[ 2.3916 ] Applet version 01.00.0000
[ 2.4107 ]
[ 2.4120 ] tegrarcm_v2 --ismb2
[ 2.4465 ]
[ 2.4505 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.4541 ]
[ 2.4548 ] header_magic: 50000ea
[ 2.4622 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_applet_t194.bin_list.xml
[ 2.4658 ] Key is a SBK key
[ 2.4668 ] Key Size is 16 bytes
[ 2.4887 ]
[ 2.4912 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194.bin.encrypt nvtboot_applet_t194.bin.hash zerosbk
[ 2.4933 ]
[ 2.4954 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin.encrypt
[ 2.4969 ]
[ 2.4983 ] tegrahost_v2 --appendsigheader nvtboot_applet_t194.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid PLDT
[ 2.4996 ] adding BCH for nvtboot_applet_t194.bin.encrypt
[ 2.5029 ]
[ 2.5030 ] header_magic: 3e918cce
[ 2.5044 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_applet_t194.bin_sigheader.encrypt_list.xml
[ 2.5056 ] PKC key in Open SSL format
[ 2.5061 ] Key size is 256 bytes
[ 2.5064 ] Valid PKC key
[ 2.5083 ] Saving pkc public key in pub_key.key
[ 2.5803 ]
[ 2.5817 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194.bin_sigheader.encrypt.signed nvtboot_applet_t194.bin_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 2.5845 ]
[ 2.5857 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194.bin_sigheader.encrypt.signed
[ 2.5867 ] Applet version 01.00.0000
[ 2.6014 ] Sending mb2
[ 2.6017 ] [................................................] 100%
[ 2.6165 ]
[ 2.6180 ] tegrarcm_v2 --boot recovery
[ 2.6192 ] Applet version 01.00.0000
[ 2.6408 ]
[ 3.6459 ] tegrarcm_v2 --isapplet
[ 3.6667 ]
[ 3.6704 ] tegrarcm_v2 --ismb2
[ 3.6739 ] MB2 Applet version 01.00.0000
[ 3.7062 ]
[ 3.7099 ] tegrarcm_v2 --ismb2
[ 3.7132 ] MB2 Applet version 01.00.0000
[ 3.7466 ]
[ 3.7505 ] Retrieving board information
[ 3.7557 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.7593 ] MB2 Applet version 01.00.0000
[ 3.7808 ] Saved platform info in chip_info.bin
[ 3.7861 ] Chip minor revision: 2
[ 3.7862 ] Bootrom revision: 0xf
[ 3.7862 ] Ram code: 0x0
[ 3.7863 ] Chip sku: 0xde
[ 3.7864 ] Chip Sample: non es
[ 3.7864 ]
[ 3.7876 ] Retrieving EEPROM data
[ 3.7878 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/dcapers/nvidia/Linux_for_Tegra/bootloader/cvm.bin
[ 3.7911 ] MB2 Applet version 01.00.0000
[ 3.8129 ] Saved platform info in /home/dcapers/nvidia/Linux_for_Tegra/bootloader/cvm.bin
[ 3.8474 ]
[ 3.8478 ] Rebooting to recovery mode
[ 3.8512 ] tegrarcm_v2 --ismb2
[ 3.8542 ] MB2 Applet version 01.00.0000
[ 3.8703 ]
[ 3.8705 ] Rebooting to recovery mode
[ 3.8744 ] tegrarcm_v2 --reboot recovery
[ 3.8778 ] MB2 Applet version 01.00.0000
[ 3.9213 ]
Board ID(3668) version(200) sku(0000) revision(J.0)
creating dummy /home/dcapers/nvidia/Linux_for_Tegra/bootloader/badpage.bin
1+0 records in
1+0 records out
4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000145349 s, 28.2 MB/s
Copy /home/dcapers/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to /home/dcapers/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec
copying bctfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying device_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)... done.
Existing bootloader(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
/home/dcapers/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --encrypt_key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --cmd sign /home/dcapers/nvidia/Linux_for_Tegra/rootfs/boot/Image
version 1.0.0
[ 0.0042 ] Generating signature
[ 0.0052 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0062 ] PKC key in Open SSL format
[ 0.0066 ] Key size is 256 bytes
[ 0.0069 ] Valid PKC key
[ 0.0088 ]
[ 0.0090 ] header_magic: 5614
[ 0.0091 ] Encrypting file
[ 0.0101 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0112 ]
[ 0.0114 ] header_magic: 5614
[ 0.0134 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --list 1_Image_list.xml
[ 0.0144 ] Key is a SBK key
[ 0.0147 ] Key Size is 16 bytes
[ 2.2083 ]
[ 2.2098 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image.encrypt 1_Image.hash zerosbk
[ 2.4884 ]
[ 2.4914 ] tegrahost_v2 --chip 0x19 --align 1_Image.encrypt
[ 2.4940 ]
[ 2.4968 ] tegrahost_v2 --appendsigheader 1_Image.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 2.4995 ] adding BCH for 1_Image.encrypt
[ 3.5371 ]
[ 3.5372 ] header_magic: 6fedc3dd
[ 3.5386 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list 1_Image_sigheader.encrypt_list.xml
[ 3.5396 ] PKC key in Open SSL format
[ 3.5399 ] Key size is 256 bytes
[ 3.5401 ] Valid PKC key
[ 3.5418 ] Saving pkc public key in pub_key.key
[ 3.6601 ]
[ 3.6616 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt.signed 1_Image_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 4.4984 ]
[ 4.5765 ] Signed and encrypted file: /home/dcapers/nvidia/Linux_for_Tegra/bootloader/Image_sigheader.encrypt.signed
l4t_sign_image.sh: Generate header for Image_sigheader.encrypt.signed
l4t_sign_image.sh: chip 0x19: add 0x20bf808 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt.signed
l4t_sign_image.sh: the sign header is saved at /home/dcapers/nvidia/Linux_for_Tegra/rootfs/boot/Image.sig
done.
populating initrd to rootfs... done.
/home/dcapers/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --encrypt_key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --cmd sign /home/dcapers/nvidia/Linux_for_Tegra/rootfs/boot/initrd
version 1.0.0
[ 0.0053 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0063 ] PKC key in Open SSL format
[ 0.0068 ] Key size is 256 bytes
[ 0.0071 ] Valid PKC key
[ 0.0086 ]
[ 0.0088 ] header_magic: 1f8b0800
[ 0.0089 ] Encrypting file
[ 0.0099 ] tegrahost_v2 --chip 0x19 --align 1_initrd
[ 0.0110 ]
[ 0.0112 ] header_magic: 1f8b0800
[ 0.0131 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --list 1_initrd_list.xml
[ 0.0140 ] Key is a SBK key
[ 0.0143 ] Key Size is 16 bytes
[ 0.4777 ]
[ 0.4791 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd.encrypt 1_initrd.hash zerosbk
[ 0.4922 ]
[ 0.4935 ] tegrahost_v2 --chip 0x19 --align 1_initrd.encrypt
[ 0.4945 ]
[ 0.4958 ] tegrahost_v2 --appendsigheader 1_initrd.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 0.4968 ] adding BCH for 1_initrd.encrypt
[ 0.7129 ]
[ 0.7130 ] header_magic: 60c14cf2
[ 0.7144 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list 1_initrd_sigheader.encrypt_list.xml
[ 0.7154 ] PKC key in Open SSL format
[ 0.7158 ] Key size is 256 bytes
[ 0.7160 ] Valid PKC key
[ 0.7176 ] Saving pkc public key in pub_key.key
[ 0.8003 ]
[ 0.8017 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt.signed 1_initrd_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 0.9156 ]
[ 0.9225 ] Signed and encrypted file: /home/dcapers/nvidia/Linux_for_Tegra/bootloader/initrd_sigheader.encrypt.signed
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt.signed
l4t_sign_image.sh: chip 0x19: add 0x6e6cb6 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt.signed
l4t_sign_image.sh: the sign header is saved at /home/dcapers/nvidia/Linux_for_Tegra/rootfs/boot/initrd.sig
done.
populating /home/dcapers/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to rootfs... done.
Making Boot image... done.
/home/dcapers/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --encrypt_key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --cmd sign boot.img
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0016 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0025 ] PKC key in Open SSL format
[ 0.0030 ] Key size is 256 bytes
[ 0.0033 ] Valid PKC key
[ 0.0049 ]
[ 0.0051 ] header_magic: 414e4452
[ 0.0052 ] Encrypting file
[ 0.0063 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0075 ]
[ 0.0077 ] header_magic: 414e4452
[ 0.0097 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --list 1_boot.img_list.xml
[ 0.0106 ] Key is a SBK key
[ 0.0110 ] Key Size is 16 bytes
[ 2.7859 ]
[ 2.7875 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot.img.encrypt 1_boot.img.hash zerosbk
[ 3.2379 ]
[ 3.2411 ] tegrahost_v2 --chip 0x19 --align 1_boot.img.encrypt
[ 3.2440 ]
[ 3.2469 ] tegrahost_v2 --appendsigheader 1_boot.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 3.2493 ] adding BCH for 1_boot.img.encrypt
[ 4.5332 ]
[ 4.5334 ] header_magic: a8380e96
[ 4.5351 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list 1_boot.img_sigheader.encrypt_list.xml
[ 4.5364 ] PKC key in Open SSL format
[ 4.5368 ] Key size is 256 bytes
[ 4.5370 ] Valid PKC key
[ 4.5386 ] Saving pkc public key in pub_key.key
[ 4.6781 ]
[ 4.6800 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot.img_sigheader.encrypt.signed 1_boot.img_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 5.7642 ]
[ 5.8252 ] Signed and encrypted file: /home/dcapers/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/boot.img_sigheader.encrypt.signed
l4t_sign_image.sh: Generate header for boot.img_sigheader.encrypt.signed
l4t_sign_image.sh: chip 0x19: add 0x27a7800 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot.img_sigheader.encrypt.signed
l4t_sign_image.sh: the signed file is /home/dcapers/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt.signed
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/Linux_for_Tegra/bootloader ~/nvidia/Linux_for_Tegra
30402 blocks
_BASE_KERNEL_VERSION=4.9.201-tegra
~/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/Linux_for_Tegra/bootloader ~/nvidia/Linux_for_Tegra
65752 blocks
Making Recovery image...
copying recdtbfile(/home/dcapers/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000548335 s, 36.5 kB/s
Existing sosfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)... done.
Existing scefile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing drameccfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing wb0boot(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/dcapers/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/dcapers/nvidia/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --encrypt_key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --cmd sign kernel_tegra194-p3668-all-p3509-0000.dtb
version 1.0.0
[ 0.0007 ] Generating signature
[ 0.0017 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0028 ] PKC key in Open SSL format
[ 0.0032 ] Key size is 256 bytes
[ 0.0036 ] Valid PKC key
[ 0.0051 ]
[ 0.0054 ] header_magic: d00dfeed
[ 0.0055 ] Encrypting file
[ 0.0065 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0076 ]
[ 0.0078 ] header_magic: d00dfeed
[ 0.0097 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --list 1_kernel_tegra194-p3668-all-p3509-0000.dtb_list.xml
[ 0.0250 ]
[ 0.0264 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000.dtb.hash zerosbk
[ 0.0280 ]
[ 0.0292 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb.encrypt
[ 0.0304 ]
[ 0.0318 ] tegrahost_v2 --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 0.0332 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb.encrypt
[ 0.0403 ]
[ 0.0404 ] header_magic: 67c86dbe
[ 0.0419 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list 1_kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt_list.xml
[ 0.0428 ] PKC key in Open SSL format
[ 0.0432 ] Key size is 256 bytes
[ 0.0434 ] Valid PKC key
[ 0.0451 ] Saving pkc public key in pub_key.key
[ 0.1169 ]
[ 0.1183 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt.signed 1_kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 0.1226 ]
[ 0.1232 ] Signed and encrypted file: /home/dcapers/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt.signed
l4t_sign_image.sh: Generate header for kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt.signed
l4t_sign_image.sh: chip 0x19: add 0x30c8e to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt.signed
l4t_sign_image.sh: the sign header is saved at kernel_tegra194-p3668-all-p3509-0000.dtb.sig
done.
version 1.0.0
[ 0.0023 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0038 ] PKC key in Open SSL format
[ 0.0043 ] Key size is 256 bytes
[ 0.0046 ] Valid PKC key
[ 0.0061 ]
[ 0.0063 ] header_magic: d00dfeed
[ 0.0064 ] Encrypting file
[ 0.0075 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0086 ]
[ 0.0087 ] header_magic: d00dfeed
[ 0.0107 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/User_Key.txt --list 1_kernel_tegra194-p3668-all-p3509-0000.dtb_list.xml
[ 0.0116 ] Key is a SBK key
[ 0.0119 ] Key Size is 16 bytes
[ 0.0248 ]
[ 0.0265 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000.dtb.hash zerosbk
[ 0.0280 ]
[ 0.0293 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb.encrypt
[ 0.0310 ]
[ 0.0327 ] tegrahost_v2 --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 0.0341 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb.encrypt
[ 0.0405 ]
[ 0.0406 ] header_magic: 67c86dbe
[ 0.0420 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list 1_kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt_list.xml
[ 0.0430 ] PKC key in Open SSL format
[ 0.0434 ] Key size is 256 bytes
[ 0.0436 ] Valid PKC key
[ 0.0452 ] Saving pkc public key in pub_key.key
[ 0.1172 ]
[ 0.1186 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt.signed 1_kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 0.1229 ]
[ 0.1235 ] Signed and encrypted file: /home/dcapers/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000.dtb_sigheader.encrypt.signed
l4t_sign_image.sh: the signed file is /home/dcapers/nvidia/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed
done.
Making system.img...
populating rootfs from /home/dcapers/nvidia/Linux_for_Tegra/rootfs ... done.
populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/dcapers/nvidia/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
copying cfgfile(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t194_spi_sd_p3668.xml) to flash.xml... done.
Existing flasher(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/dcapers/nvidia/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0xB8190000 --applet mb1_t194_prod.bin --cmd "sign" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb" --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --encrypt_key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt
version 1.0.0
[ 0.0773 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.0808 ] PKC key in Open SSL format
[ 0.0998 ] Key size is 256 bytes
[ 0.1005 ] Valid PKC key
[ 0.1062 ]
[ 0.1068 ] Generating RCM messages
[ 0.1100 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file mb1_t194_prod.bin --offset 4096
[ 0.1135 ] Key is a SBK key
[ 0.1201 ] Key Size is 16 bytes
[ 0.1535 ]
[ 0.1670 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod_encrypt.bin zerosbk
[ 0.1682 ] Header already present for mb1_t194_prod_encrypt.bin
[ 0.1732 ]
[ 0.1750 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --getmode mode.txt
[ 0.1767 ] PKC key in Open SSL format
[ 0.1777 ] Key size is 256 bytes
[ 0.1783 ] Valid PKC key
[ 0.1792 ]
[ 0.1805 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --file mb1_t194_prod_encrypt_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.1814 ] PKC key in Open SSL format
[ 0.1818 ] Key size is 256 bytes
[ 0.1821 ] Valid PKC key
[ 0.1837 ] Saving pkc public key in pub_key.key
[ 0.2545 ]
[ 0.2558 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader mb1_t194_prod_encrypt_sigheader.bin mb1_t194_prod_encrypt_sigheader.sig oem-rsa
[ 0.2609 ]
[ 0.2946 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.3054 ]
[ 0.3174 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_encrypt_sigheader.bin 0 0
[ 0.3192 ] RCM 0 is saved as rcm_0.rcm
[ 0.3250 ] RCM 1 is saved as rcm_1.rcm
[ 0.3250 ] RCM 2 is saved as rcm_2.rcm
[ 0.3250 ] List of rcm files are saved in rcm_list.xml
[ 0.3250 ]
[ 0.3251 ] Signing RCM messages
[ 0.3267 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.3282 ] PKC key in Open SSL format
[ 0.3286 ] Key size is 256 bytes
[ 0.3289 ] Valid PKC key
[ 0.3312 ] Saving pkc public key in pub_key.key
[ 0.5452 ]
[ 0.5452 ] Copying signature to RCM mesages
[ 0.5465 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key
[ 0.5483 ]
[ 0.5485 ] Parsing partition layout
[ 0.5626 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.5654 ]
[ 0.5655 ] Creating list of images to be signed
[ 0.5669 ] tegrahost_v2 --chip 0x19 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.5681 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.5691 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.5698 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.5739 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.5750 ] adding BCH for spe_t194.bin
[ 0.5926 ] adding BCH for spe_t194.bin
[ 0.5953 ] adding BCH for nvtboot_t194.bin
[ 0.6121 ] adding BCH for nvtboot_t194.bin
[ 0.6177 ] Header already present for preboot_c10_prod_cr.bin
[ 0.6281 ] Header already present for preboot_c10_prod_cr.bin
[ 0.6286 ] Header already present for mce_c10_prod_cr.bin
[ 0.6409 ] Header already present for mce_c10_prod_cr.bin
[ 0.6475 ] adding BCH for mts_c10_prod_cr.bin
[ 0.7346 ] adding BCH for mts_c10_prod_cr.bin
[ 0.8594 ] Header already present for warmboot_t194_prod.bin
[ 1.0129 ] Header already present for warmboot_t194_prod.bin
[ 1.0143 ] adding BCH for cboot_t194.bin
[ 1.0155 ] adding BCH for cboot_t194.bin
[ 1.0330 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 1.0500 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 1.0561 ] adding BCH for tos-trusty_t194.img
[ 1.0812 ] adding BCH for tos-trusty_t194.img
[ 1.0930 ] adding BCH for eks.img
[ 1.1186 ] adding BCH for eks.img
[ 1.1189 ] adding BCH for adsp-fw.bin
[ 1.1250 ] adding BCH for adsp-fw.bin
[ 1.1274 ] adding BCH for camera-rtcpu-rce.img
[ 1.1477 ] adding BCH for camera-rtcpu-rce.img
[ 1.1684 ] adding BCH for bpmp_t194.bin
[ 1.2120 ] adding BCH for bpmp_t194.bin
[ 1.2406 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 1.3004 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 1.3222 ] adding BCH for boot.img
[ 1.8176 ] adding BCH for boot.img
[ 3.0744 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[ 4.7482 ] adding BCH for kernel_tegra194-p3668-all-p3509-0000.dtb
[ 4.7628 ] adding BCH for recovery.img
[ 5.3725 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb.rec
[ 6.8430 ]
[ 6.8444 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list images_list.xml --pubkeyhash pub_key.key
[ 6.8455 ] PKC key in Open SSL format
[ 6.8459 ] Key size is 256 bytes
[ 6.8462 ] Valid PKC key
[ 6.8476 ] Saving pkc public key in pub_key.key
[ 9.9936 ]
[ 9.9936 ] Generating br-bct
[ 9.9948 ] Performing cfg overlay
[ 9.9948 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 9.9953 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg
[ 10.3427 ]
[ 10.3429 ] Updating dev and MSS params in BR BCT
[ 10.3430 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 10.3888 ]
[ 10.3888 ] Updating bl info
[ 10.3901 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 10.3929 ]
[ 10.3949 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin
[ 10.3961 ]
[ 10.3963 ] header_magic: 4e564441
[ 10.3976 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mb1_t194_prod_sigheader.bin_list.xml
[ 10.3987 ] Key is a SBK key
[ 10.3989 ] Key Size is 16 bytes
[ 10.4153 ]
[ 10.4167 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt mb1_t194_prod_sigheader.bin.hash zerosbk
[ 10.4227 ]
[ 10.4239 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 10.4250 ]
[ 10.4261 ] tegrahost_v2 --appendsigheader mb1_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 10.4272 ] Header already present for mb1_t194_prod_sigheader.bin.encrypt
[ 10.4320 ]
[ 10.4321 ] header_magic: 4e564441
[ 10.4335 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_t194_prod_sigheader.bin.encrypt_list.xml
[ 10.4347 ] PKC key in Open SSL format
[ 10.4351 ] Key size is 256 bytes
[ 10.4354 ] Valid PKC key
[ 10.4374 ] Saving pkc public key in pub_key.key
[ 10.5093 ]
[ 10.5108 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 10.5158 ]
[ 10.5175 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin
[ 10.5186 ]
[ 10.5188 ] header_magic: 4e564441
[ 10.5201 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mb1_t194_prod_sigheader.bin_list.xml
[ 10.5215 ] Key is a SBK key
[ 10.5218 ] Key Size is 16 bytes
[ 10.5383 ]
[ 10.5398 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt mb1_t194_prod_sigheader.bin.hash zerosbk
[ 10.5448 ]
[ 10.5460 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 10.5472 ]
[ 10.5484 ] tegrahost_v2 --appendsigheader mb1_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 10.5494 ] Header already present for mb1_t194_prod_sigheader.bin.encrypt
[ 10.5538 ]
[ 10.5540 ] header_magic: 4e564441
[ 10.5554 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_t194_prod_sigheader.bin.encrypt_list.xml
[ 10.5564 ] PKC key in Open SSL format
[ 10.5568 ] Key size is 256 bytes
[ 10.5571 ] Valid PKC key
[ 10.5585 ] Saving pkc public key in pub_key.key
[ 10.6306 ]
[ 10.6321 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 10.6371 ]
[ 10.6399 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin
[ 10.6410 ]
[ 10.6412 ] header_magic: 4e564441
[ 10.6429 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list spe_t194_sigheader.bin_list.xml
[ 10.6439 ] Key is a SBK key
[ 10.6442 ] Key Size is 16 bytes
[ 10.6501 ]
[ 10.6518 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[ 10.6547 ]
[ 10.6559 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin.encrypt
[ 10.6570 ]
[ 10.6584 ] tegrahost_v2 --appendsigheader spe_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid SPEF
[ 10.6596 ] Header already present for spe_t194_sigheader.bin.encrypt
[ 10.6613 ]
[ 10.6615 ] header_magic: 4e564441
[ 10.6628 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list spe_t194_sigheader.bin.encrypt_list.xml
[ 10.6640 ] PKC key in Open SSL format
[ 10.6644 ] Key size is 256 bytes
[ 10.6646 ] Valid PKC key
[ 10.6661 ] Saving pkc public key in pub_key.key
[ 10.7396 ]
[ 10.7413 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt.signed spe_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 10.7439 ]
[ 10.7454 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin
[ 10.7466 ]
[ 10.7468 ] header_magic: 4e564441
[ 10.7481 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list spe_t194_sigheader.bin_list.xml
[ 10.7492 ] Key is a SBK key
[ 10.7495 ] Key Size is 16 bytes
[ 10.7558 ]
[ 10.7572 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[ 10.7599 ]
[ 10.7610 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin.encrypt
[ 10.7621 ]
[ 10.7633 ] tegrahost_v2 --appendsigheader spe_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid SPEF
[ 10.7644 ] Header already present for spe_t194_sigheader.bin.encrypt
[ 10.7663 ]
[ 10.7664 ] header_magic: 4e564441
[ 10.7680 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list spe_t194_sigheader.bin.encrypt_list.xml
[ 10.7692 ] PKC key in Open SSL format
[ 10.7696 ] Key size is 256 bytes
[ 10.7698 ] Valid PKC key
[ 10.7717 ] Saving pkc public key in pub_key.key
[ 10.8428 ]
[ 10.8443 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt.signed spe_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 10.8470 ]
[ 10.8485 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin
[ 10.8496 ]
[ 10.8498 ] header_magic: 4e564441
[ 10.8511 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_t194_sigheader.bin_list.xml
[ 10.8521 ] Key is a SBK key
[ 10.8524 ] Key Size is 16 bytes
[ 10.8635 ]
[ 10.8650 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt nvtboot_t194_sigheader.bin.hash zerosbk
[ 10.8690 ]
[ 10.8705 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin.encrypt
[ 10.8718 ]
[ 10.8729 ] tegrahost_v2 --appendsigheader nvtboot_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B
[ 10.8739 ] Header already present for nvtboot_t194_sigheader.bin.encrypt
[ 10.8767 ]
[ 10.8769 ] header_magic: 4e564441
[ 10.8782 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_t194_sigheader.bin.encrypt_list.xml
[ 10.8792 ] PKC key in Open SSL format
[ 10.8796 ] Key size is 256 bytes
[ 10.8799 ] Valid PKC key
[ 10.8814 ] Saving pkc public key in pub_key.key
[ 10.9523 ]
[ 10.9538 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt.signed nvtboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 10.9576 ]
[ 10.9591 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin
[ 10.9603 ]
[ 10.9605 ] header_magic: 4e564441
[ 10.9618 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_t194_sigheader.bin_list.xml
[ 10.9628 ] Key is a SBK key
[ 10.9631 ] Key Size is 16 bytes
[ 10.9744 ]
[ 10.9758 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt nvtboot_t194_sigheader.bin.hash zerosbk
[ 10.9798 ]
[ 10.9813 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin.encrypt
[ 10.9824 ]
[ 10.9835 ] tegrahost_v2 --appendsigheader nvtboot_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B
[ 10.9847 ] Header already present for nvtboot_t194_sigheader.bin.encrypt
[ 10.9880 ]
[ 10.9882 ] header_magic: 4e564441
[ 10.9896 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_t194_sigheader.bin.encrypt_list.xml
[ 10.9906 ] PKC key in Open SSL format
[ 10.9910 ] Key size is 256 bytes
[ 10.9913 ] Valid PKC key
[ 10.9927 ] Saving pkc public key in pub_key.key
[ 11.0653 ]
[ 11.0668 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt.signed nvtboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 11.0706 ]
[ 11.0722 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin
[ 11.0734 ]
[ 11.0736 ] header_magic: 4e564441
[ 11.0749 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list preboot_c10_prod_cr_sigheader.bin_list.xml
[ 11.0759 ] Key is a SBK key
[ 11.0761 ] Key Size is 16 bytes
[ 11.0778 ]
[ 11.0792 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 11.0807 ]
[ 11.0818 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin.encrypt
[ 11.0829 ]
[ 11.0840 ] tegrahost_v2 --appendsigheader preboot_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSP
[ 11.0853 ] Header already present for preboot_c10_prod_cr_sigheader.bin.encrypt
[ 11.0860 ]
[ 11.0861 ] header_magic: 4e564441
[ 11.0879 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list preboot_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 11.0889 ] PKC key in Open SSL format
[ 11.0894 ] Key size is 256 bytes
[ 11.0896 ] Valid PKC key
[ 11.0911 ] Saving pkc public key in pub_key.key
[ 11.1638 ]
[ 11.1653 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt.signed preboot_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 11.1669 ]
[ 11.1683 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin
[ 11.1694 ]
[ 11.1696 ] header_magic: 4e564441
[ 11.1710 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list preboot_c10_prod_cr_sigheader.bin_list.xml
[ 11.1720 ] Key is a SBK key
[ 11.1723 ] Key Size is 16 bytes
[ 11.1737 ]
[ 11.1755 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 11.1772 ]
[ 11.1783 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin.encrypt
[ 11.1794 ]
[ 11.1806 ] tegrahost_v2 --appendsigheader preboot_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSP
[ 11.1817 ] Header already present for preboot_c10_prod_cr_sigheader.bin.encrypt
[ 11.1823 ]
[ 11.1824 ] header_magic: 4e564441
[ 11.1838 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list preboot_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 11.1850 ] PKC key in Open SSL format
[ 11.1854 ] Key size is 256 bytes
[ 11.1857 ] Valid PKC key
[ 11.1875 ] Saving pkc public key in pub_key.key
[ 11.2590 ]
[ 11.2606 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt.signed preboot_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 11.2621 ]
[ 11.2636 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin
[ 11.2647 ]
[ 11.2649 ] header_magic: 4e564441
[ 11.2662 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mce_c10_prod_cr_sigheader.bin_list.xml
[ 11.2672 ] Key is a SBK key
[ 11.2675 ] Key Size is 16 bytes
[ 11.2769 ]
[ 11.2783 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 11.2818 ]
[ 11.2830 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin.encrypt
[ 11.2842 ]
[ 11.2857 ] tegrahost_v2 --appendsigheader mce_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSM
[ 11.2874 ] Header already present for mce_c10_prod_cr_sigheader.bin.encrypt
[ 11.2900 ]
[ 11.2901 ] header_magic: 4e564441
[ 11.2914 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mce_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 11.2924 ] PKC key in Open SSL format
[ 11.2928 ] Key size is 256 bytes
[ 11.2930 ] Valid PKC key
[ 11.2947 ] Saving pkc public key in pub_key.key
[ 11.3675 ]
[ 11.3699 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt.signed mce_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 11.3733 ]
[ 11.3749 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin
[ 11.3762 ]
[ 11.3764 ] header_magic: 4e564441
[ 11.3778 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mce_c10_prod_cr_sigheader.bin_list.xml
[ 11.3792 ] Key is a SBK key
[ 11.3795 ] Key Size is 16 bytes
[ 11.3887 ]
[ 11.3901 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 11.3936 ]
[ 11.3953 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin.encrypt
[ 11.3965 ]
[ 11.3977 ] tegrahost_v2 --appendsigheader mce_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSM
[ 11.3987 ] Header already present for mce_c10_prod_cr_sigheader.bin.encrypt
[ 11.4016 ]
[ 11.4018 ] header_magic: 4e564441
[ 11.4034 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mce_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 11.4045 ] PKC key in Open SSL format
[ 11.4049 ] Key size is 256 bytes
[ 11.4051 ] Valid PKC key
[ 11.4067 ] Saving pkc public key in pub_key.key
[ 11.4776 ]
[ 11.4792 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt.signed mce_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 11.4826 ]
[ 11.4842 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin
[ 11.4853 ]
[ 11.4855 ] header_magic: 4e564441
[ 11.4868 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mts_c10_prod_cr_sigheader.bin_list.xml
[ 11.4878 ] Key is a SBK key
[ 11.4881 ] Key Size is 16 bytes
[ 11.7088 ]
[ 11.7103 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 11.7648 ]
[ 11.7661 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin.encrypt
[ 11.7676 ]
[ 11.7688 ] tegrahost_v2 --appendsigheader mts_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSB
[ 11.7699 ] Header already present for mts_c10_prod_cr_sigheader.bin.encrypt
[ 11.8237 ]
[ 11.8239 ] header_magic: 4e564441
[ 11.8253 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mts_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 11.8263 ] PKC key in Open SSL format
[ 11.8267 ] Key size is 256 bytes
[ 11.8269 ] Valid PKC key
[ 11.8286 ] Saving pkc public key in pub_key.key
[ 11.9043 ]
[ 11.9057 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt.signed mts_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 11.9606 ]
[ 11.9676 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin
[ 11.9689 ]
[ 11.9692 ] header_magic: 4e564441
[ 11.9710 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mts_c10_prod_cr_sigheader.bin_list.xml
[ 11.9725 ] Key is a SBK key
[ 11.9728 ] Key Size is 16 bytes
[ 12.1960 ]
[ 12.1974 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 12.2518 ]
[ 12.2532 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin.encrypt
[ 12.2547 ]
[ 12.2560 ] tegrahost_v2 --appendsigheader mts_c10_prod_cr_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MTSB
[ 12.2571 ] Header already present for mts_c10_prod_cr_sigheader.bin.encrypt
[ 12.3114 ]
[ 12.3116 ] header_magic: 4e564441
[ 12.3130 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mts_c10_prod_cr_sigheader.bin.encrypt_list.xml
[ 12.3142 ] PKC key in Open SSL format
[ 12.3145 ] Key size is 256 bytes
[ 12.3147 ] Valid PKC key
[ 12.3164 ] Saving pkc public key in pub_key.key
[ 12.3951 ]
[ 12.3966 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt.signed mts_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 12.4995 ]
[ 12.5067 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin
[ 12.5085 ]
[ 12.5088 ] header_magic: 4e564441
[ 12.5108 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list warmboot_t194_prod_sigheader.bin_list.xml
[ 12.5133 ] Key is a SBK key
[ 12.5139 ] Key Size is 16 bytes
[ 12.5221 ]
[ 12.5247 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt warmboot_t194_prod_sigheader.bin.hash zerosbk
[ 12.5295 ]
[ 12.5320 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin.encrypt
[ 12.5342 ]
[ 12.5369 ] tegrahost_v2 --appendsigheader warmboot_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 12.5394 ] Header already present for warmboot_t194_prod_sigheader.bin.encrypt
[ 12.5418 ]
[ 12.5420 ] header_magic: 4e564441
[ 12.5440 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list warmboot_t194_prod_sigheader.bin.encrypt_list.xml
[ 12.5455 ] PKC key in Open SSL format
[ 12.5461 ] Key size is 256 bytes
[ 12.5464 ] Valid PKC key
[ 12.5482 ] Saving pkc public key in pub_key.key
[ 12.6202 ]
[ 12.6217 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt.signed warmboot_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 12.6239 ]
[ 12.6253 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin
[ 12.6265 ]
[ 12.6266 ] header_magic: 4e564441
[ 12.6280 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list warmboot_t194_prod_sigheader.bin_list.xml
[ 12.6290 ] Key is a SBK key
[ 12.6293 ] Key Size is 16 bytes
[ 12.6341 ]
[ 12.6357 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt warmboot_t194_prod_sigheader.bin.hash zerosbk
[ 12.6380 ]
[ 12.6391 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin.encrypt
[ 12.6406 ]
[ 12.6424 ] tegrahost_v2 --appendsigheader warmboot_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 12.6435 ] Header already present for warmboot_t194_prod_sigheader.bin.encrypt
[ 12.6450 ]
[ 12.6451 ] header_magic: 4e564441
[ 12.6465 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list warmboot_t194_prod_sigheader.bin.encrypt_list.xml
[ 12.6479 ] PKC key in Open SSL format
[ 12.6483 ] Key size is 256 bytes
[ 12.6485 ] Valid PKC key
[ 12.6502 ] Saving pkc public key in pub_key.key
[ 12.7215 ]
[ 12.7231 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt.signed warmboot_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 12.7253 ]
[ 12.7267 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin
[ 12.7279 ]
[ 12.7280 ] header_magic: 4e564441
[ 12.7294 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list cboot_t194_sigheader.bin_list.xml
[ 12.7304 ] Key is a SBK key
[ 12.7307 ] Key Size is 16 bytes
[ 12.7598 ]
[ 12.7612 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt cboot_t194_sigheader.bin.hash zerosbk
[ 12.7693 ]
[ 12.7706 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin.encrypt
[ 12.7717 ]
[ 12.7729 ] tegrahost_v2 --appendsigheader cboot_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 12.7739 ] Header already present for cboot_t194_sigheader.bin.encrypt
[ 12.7813 ]
[ 12.7814 ] header_magic: 4e564441
[ 12.7829 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list cboot_t194_sigheader.bin.encrypt_list.xml
[ 12.7840 ] PKC key in Open SSL format
[ 12.7843 ] Key size is 256 bytes
[ 12.7846 ] Valid PKC key
[ 12.7863 ] Saving pkc public key in pub_key.key
[ 12.8584 ]
[ 12.8600 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt.signed cboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 12.8680 ]
[ 12.8700 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin
[ 12.8715 ]
[ 12.8717 ] header_magic: 4e564441
[ 12.8731 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list cboot_t194_sigheader.bin_list.xml
[ 12.8741 ] Key is a SBK key
[ 12.8744 ] Key Size is 16 bytes
[ 12.9049 ]
[ 12.9063 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt cboot_t194_sigheader.bin.hash zerosbk
[ 12.9144 ]
[ 12.9157 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin.encrypt
[ 12.9172 ]
[ 12.9185 ] tegrahost_v2 --appendsigheader cboot_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 12.9195 ] Header already present for cboot_t194_sigheader.bin.encrypt
[ 12.9266 ]
[ 12.9267 ] header_magic: 4e564441
[ 12.9282 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list cboot_t194_sigheader.bin.encrypt_list.xml
[ 12.9292 ] PKC key in Open SSL format
[ 12.9296 ] Key size is 256 bytes
[ 12.9299 ] Valid PKC key
[ 12.9313 ] Saving pkc public key in pub_key.key
[ 13.0045 ]
[ 13.0061 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt.signed cboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.0153 ]
[ 13.0172 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 13.0183 ]
[ 13.0185 ] header_magic: 4e564441
[ 13.0198 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 13.0208 ] Key is a SBK key
[ 13.0211 ] Key Size is 16 bytes
[ 13.0341 ]
[ 13.0359 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 13.0409 ]
[ 13.0422 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 13.0432 ]
[ 13.0444 ] tegrahost_v2 --appendsigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.0455 ] Header already present for tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 13.0489 ]
[ 13.0490 ] header_magic: 4e564441
[ 13.0504 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml
[ 13.0515 ] PKC key in Open SSL format
[ 13.0518 ] Key size is 256 bytes
[ 13.0520 ] Valid PKC key
[ 13.0536 ] Saving pkc public key in pub_key.key
[ 13.1263 ]
[ 13.1281 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.1328 ]
[ 13.1348 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 13.1363 ]
[ 13.1365 ] header_magic: 4e564441
[ 13.1383 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 13.1396 ] Key is a SBK key
[ 13.1399 ] Key Size is 16 bytes
[ 13.1533 ]
[ 13.1549 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 13.1593 ]
[ 13.1605 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 13.1616 ]
[ 13.1628 ] tegrahost_v2 --appendsigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.1638 ] Header already present for tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 13.1676 ]
[ 13.1678 ] header_magic: 4e564441
[ 13.1695 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml
[ 13.1706 ] PKC key in Open SSL format
[ 13.1710 ] Key size is 256 bytes
[ 13.1712 ] Valid PKC key
[ 13.1729 ] Saving pkc public key in pub_key.key
[ 13.2451 ]
[ 13.2467 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.2510 ]
[ 13.2527 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img
[ 13.2539 ]
[ 13.2540 ] header_magic: 4e564441
[ 13.2554 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tos-trusty_t194_sigheader.img_list.xml
[ 13.2569 ] Key is a SBK key
[ 13.2572 ] Key Size is 16 bytes
[ 13.2847 ]
[ 13.2864 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[ 13.2939 ]
[ 13.2952 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img.encrypt
[ 13.2963 ]
[ 13.2975 ] tegrahost_v2 --appendsigheader tos-trusty_t194_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.2986 ] Header already present for tos-trusty_t194_sigheader.img.encrypt
[ 13.3054 ]
[ 13.3055 ] header_magic: 4e564441
[ 13.3069 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tos-trusty_t194_sigheader.img.encrypt_list.xml
[ 13.3079 ] PKC key in Open SSL format
[ 13.3083 ] Key size is 256 bytes
[ 13.3085 ] Valid PKC key
[ 13.3102 ] Saving pkc public key in pub_key.key
[ 13.3823 ]
[ 13.3838 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt.signed tos-trusty_t194_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.3912 ]
[ 13.3931 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img
[ 13.3946 ]
[ 13.3948 ] header_magic: 4e564441
[ 13.3962 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tos-trusty_t194_sigheader.img_list.xml
[ 13.3972 ] Key is a SBK key
[ 13.3976 ] Key Size is 16 bytes
[ 13.4240 ]
[ 13.4254 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[ 13.4328 ]
[ 13.4341 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img.encrypt
[ 13.4352 ]
[ 13.4364 ] tegrahost_v2 --appendsigheader tos-trusty_t194_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.4373 ] Header already present for tos-trusty_t194_sigheader.img.encrypt
[ 13.4443 ]
[ 13.4445 ] header_magic: 4e564441
[ 13.4459 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tos-trusty_t194_sigheader.img.encrypt_list.xml
[ 13.4470 ] PKC key in Open SSL format
[ 13.4474 ] Key size is 256 bytes
[ 13.4476 ] Valid PKC key
[ 13.4491 ] Saving pkc public key in pub_key.key
[ 13.5214 ]
[ 13.5229 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt.signed tos-trusty_t194_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.5303 ]
[ 13.5323 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img
[ 13.5337 ]
[ 13.5340 ] header_magic: 4e564441
[ 13.5359 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list eks_sigheader.img_list.xml
[ 13.5372 ] Key is a SBK key
[ 13.5375 ] Key Size is 16 bytes
[ 13.5376 ]
[ 13.5389 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
@JerryChang
[ 13.5401 ]
[ 13.5412 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img.encrypt
[ 13.5424 ]
[ 13.5435 ] tegrahost_v2 --appendsigheader eks_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.5446 ] Header already present for eks_sigheader.img.encrypt
[ 13.5447 ]
[ 13.5449 ] header_magic: 4e564441
[ 13.5462 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list eks_sigheader.img.encrypt_list.xml
[ 13.5473 ] PKC key in Open SSL format
[ 13.5477 ] Key size is 256 bytes
[ 13.5479 ] Valid PKC key
[ 13.5496 ] Saving pkc public key in pub_key.key
[ 13.6212 ]
[ 13.6227 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt.signed eks_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.6240 ]
[ 13.6253 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img
[ 13.6265 ]
[ 13.6266 ] header_magic: 4e564441
[ 13.6280 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list eks_sigheader.img_list.xml
[ 13.6291 ] Key is a SBK key
[ 13.6293 ] Key Size is 16 bytes
[ 13.6295 ]
[ 13.6308 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 13.6320 ]
[ 13.6332 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img.encrypt
[ 13.6344 ]
[ 13.6355 ] tegrahost_v2 --appendsigheader eks_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.6365 ] Header already present for eks_sigheader.img.encrypt
[ 13.6367 ]
[ 13.6368 ] header_magic: 4e564441
[ 13.6382 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list eks_sigheader.img.encrypt_list.xml
[ 13.6392 ] PKC key in Open SSL format
[ 13.6396 ] Key size is 256 bytes
[ 13.6397 ] Valid PKC key
[ 13.6419 ] Saving pkc public key in pub_key.key
[ 13.7144 ]
[ 13.7159 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt.signed eks_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.7172 ]
[ 13.7186 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin
[ 13.7197 ]
[ 13.7199 ] header_magic: 4e564441
[ 13.7212 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list adsp-fw_sigheader.bin_list.xml
[ 13.7223 ] Key is a SBK key
[ 13.7226 ] Key Size is 16 bytes
[ 13.7279 ]
[ 13.7293 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt adsp-fw_sigheader.bin.hash zerosbk
[ 13.7318 ]
[ 13.7330 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin.encrypt
[ 13.7342 ]
[ 13.7357 ] tegrahost_v2 --appendsigheader adsp-fw_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.7371 ] Header already present for adsp-fw_sigheader.bin.encrypt
[ 13.7386 ]
[ 13.7387 ] header_magic: 4e564441
[ 13.7400 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list adsp-fw_sigheader.bin.encrypt_list.xml
[ 13.7412 ] PKC key in Open SSL format
[ 13.7415 ] Key size is 256 bytes
[ 13.7417 ] Valid PKC key
[ 13.7435 ] Saving pkc public key in pub_key.key
[ 13.8145 ]
[ 13.8161 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt.signed adsp-fw_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.8185 ]
[ 13.8200 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin
[ 13.8211 ]
[ 13.8213 ] header_magic: 4e564441
[ 13.8227 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list adsp-fw_sigheader.bin_list.xml
[ 13.8237 ] Key is a SBK key
[ 13.8240 ] Key Size is 16 bytes
[ 13.8296 ]
[ 13.8310 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt adsp-fw_sigheader.bin.hash zerosbk
[ 13.8335 ]
[ 13.8347 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin.encrypt
[ 13.8362 ]
[ 13.8377 ] tegrahost_v2 --appendsigheader adsp-fw_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.8388 ] Header already present for adsp-fw_sigheader.bin.encrypt
[ 13.8404 ]
[ 13.8405 ] header_magic: 4e564441
[ 13.8423 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list adsp-fw_sigheader.bin.encrypt_list.xml
[ 13.8434 ] PKC key in Open SSL format
[ 13.8437 ] Key size is 256 bytes
[ 13.8439 ] Valid PKC key
[ 13.8455 ] Saving pkc public key in pub_key.key
[ 13.9167 ]
[ 13.9182 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt.signed adsp-fw_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 13.9207 ]
[ 13.9221 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img
[ 13.9232 ]
[ 13.9234 ] header_magic: 4e564441
[ 13.9247 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list camera-rtcpu-rce_sigheader.img_list.xml
[ 13.9258 ] Key is a SBK key
[ 13.9260 ] Key Size is 16 bytes
[ 13.9445 ]
[ 13.9459 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt camera-rtcpu-rce_sigheader.img.hash zerosbk
[ 13.9514 ]
[ 13.9526 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img.encrypt
[ 13.9537 ]
[ 13.9548 ] tegrahost_v2 --appendsigheader camera-rtcpu-rce_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 13.9559 ] Header already present for camera-rtcpu-rce_sigheader.img.encrypt
[ 13.9603 ]
[ 13.9604 ] header_magic: 4e564441
[ 13.9618 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list camera-rtcpu-rce_sigheader.img.encrypt_list.xml
[ 13.9628 ] PKC key in Open SSL format
[ 13.9632 ] Key size is 256 bytes
[ 13.9634 ] Valid PKC key
[ 13.9650 ] Saving pkc public key in pub_key.key
[ 14.0369 ]
[ 14.0384 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt.signed camera-rtcpu-rce_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 14.0444 ]
[ 14.0461 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img
[ 14.0473 ]
[ 14.0475 ] header_magic: 4e564441
[ 14.0492 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list camera-rtcpu-rce_sigheader.img_list.xml
[ 14.0503 ] Key is a SBK key
[ 14.0506 ] Key Size is 16 bytes
[ 14.0699 ]
[ 14.0715 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt camera-rtcpu-rce_sigheader.img.hash zerosbk
[ 14.0769 ]
[ 14.0781 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img.encrypt
[ 14.0792 ]
[ 14.0804 ] tegrahost_v2 --appendsigheader camera-rtcpu-rce_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 14.0815 ] Header already present for camera-rtcpu-rce_sigheader.img.encrypt
[ 14.0860 ]
[ 14.0862 ] header_magic: 4e564441
[ 14.0876 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list camera-rtcpu-rce_sigheader.img.encrypt_list.xml
[ 14.0886 ] PKC key in Open SSL format
[ 14.0890 ] Key size is 256 bytes
[ 14.0892 ] Valid PKC key
[ 14.0908 ] Saving pkc public key in pub_key.key
[ 14.1631 ]
[ 14.1645 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt.signed camera-rtcpu-rce_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 14.1699 ]
[ 14.1717 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin
[ 14.1728 ]
[ 14.1730 ] header_magic: 4e564441
[ 14.1748 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list bpmp_t194_sigheader.bin_list.xml
[ 14.1759 ] Key is a SBK key
[ 14.1761 ] Key Size is 16 bytes
[ 14.2328 ]
[ 14.2343 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[ 14.2486 ]
[ 14.2499 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin.encrypt
[ 14.2515 ]
[ 14.2529 ] tegrahost_v2 --appendsigheader bpmp_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 14.2540 ] Header already present for bpmp_t194_sigheader.bin.encrypt
[ 14.2674 ]
[ 14.2675 ] header_magic: 4e564441
[ 14.2691 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list bpmp_t194_sigheader.bin.encrypt_list.xml
[ 14.2703 ] PKC key in Open SSL format
[ 14.2706 ] Key size is 256 bytes
[ 14.2709 ] Valid PKC key
[ 14.2725 ] Saving pkc public key in pub_key.key
[ 14.3443 ]
[ 14.3460 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt.signed bpmp_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 14.3607 ]
[ 14.3630 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin
[ 14.3641 ]
[ 14.3643 ] header_magic: 4e564441
[ 14.3657 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list bpmp_t194_sigheader.bin_list.xml
[ 14.3667 ] Key is a SBK key
[ 14.3670 ] Key Size is 16 bytes
[ 14.4226 ]
[ 14.4242 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[ 14.4391 ]
[ 14.4403 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin.encrypt
[ 14.4415 ]
[ 14.4426 ] tegrahost_v2 --appendsigheader bpmp_t194_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 14.4437 ] Header already present for bpmp_t194_sigheader.bin.encrypt
[ 14.4576 ]
[ 14.4578 ] header_magic: 4e564441
[ 14.4592 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list bpmp_t194_sigheader.bin.encrypt_list.xml
[ 14.4603 ] PKC key in Open SSL format
[ 14.4607 ] Key size is 256 bytes
[ 14.4610 ] Valid PKC key
[ 14.4624 ] Saving pkc public key in pub_key.key
[ 14.5346 ]
[ 14.5361 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt.signed bpmp_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 14.5513 ]
[ 14.5539 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb
[ 14.5550 ]
[ 14.5552 ] header_magic: 4e564441
[ 14.5565 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml
[ 14.5576 ] Key is a SBK key
[ 14.5579 ] Key Size is 16 bytes
[ 14.5734 ]
[ 14.5749 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 14.5797 ]
[ 14.5809 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 14.5821 ]
[ 14.5833 ] tegrahost_v2 --appendsigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 14.5843 ] Header already present for tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 14.5882 ]
[ 14.5883 ] header_magic: 4e564441
[ 14.5897 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt_list.xml
[ 14.5907 ] PKC key in Open SSL format
[ 14.5911 ] Key size is 256 bytes
[ 14.5913 ] Valid PKC key
[ 14.5930 ] Saving pkc public key in pub_key.key
[ 14.6647 ]
[ 14.6662 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 14.6709 ]
[ 14.6726 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb
[ 14.6738 ]
[ 14.6739 ] header_magic: 4e564441
[ 14.6753 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml
[ 14.6769 ] Key is a SBK key
[ 14.6772 ] Key Size is 16 bytes
[ 14.6919 ]
[ 14.6935 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 14.6982 ]
[ 14.6995 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 14.7007 ]
[ 14.7020 ] tegrahost_v2 --appendsigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 14.7033 ] Header already present for tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 14.7073 ]
[ 14.7074 ] header_magic: 4e564441
[ 14.7088 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt_list.xml
[ 14.7098 ] PKC key in Open SSL format
[ 14.7105 ] Key size is 256 bytes
[ 14.7109 ] Valid PKC key
[ 14.7126 ] Saving pkc public key in pub_key.key
[ 14.7854 ]
[ 14.7869 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 14.7916 ]
[ 14.7933 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img
[ 14.7944 ]
[ 14.7946 ] header_magic: 4e564441
[ 14.7960 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list boot_sigheader.img_list.xml
[ 14.7973 ] Key is a SBK key
[ 14.7976 ] Key Size is 16 bytes
[ 17.4481 ]
[ 17.4496 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt boot_sigheader.img.hash zerosbk
[ 18.4513 ]
[ 18.4546 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img.encrypt
[ 18.4576 ]
[ 18.4602 ] tegrahost_v2 --appendsigheader boot_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 18.4625 ] Header already present for boot_sigheader.img.encrypt
[ 19.0966 ]
[ 19.0968 ] header_magic: 4e564441
[ 19.0983 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list boot_sigheader.img.encrypt_list.xml
[ 19.0993 ] PKC key in Open SSL format
[ 19.0997 ] Key size is 256 bytes
[ 19.1000 ] Valid PKC key
[ 19.1015 ] Saving pkc public key in pub_key.key
[ 19.2299 ]
[ 19.2314 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt.signed boot_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 20.2555 ]
[ 20.6289 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img
[ 20.6318 ]
[ 20.6322 ] header_magic: 4e564441
[ 20.6356 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list boot_sigheader.img_list.xml
[ 20.6382 ] Key is a SBK key
[ 20.6389 ] Key Size is 16 bytes
[ 23.9477 ]
[ 23.9492 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt boot_sigheader.img.hash zerosbk
[ 25.7459 ]
[ 25.7473 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img.encrypt
[ 25.7486 ]
[ 25.7499 ] tegrahost_v2 --appendsigheader boot_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 25.7510 ] Header already present for boot_sigheader.img.encrypt
[ 27.2505 ]
[ 27.2506 ] header_magic: 4e564441
[ 27.4086 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list boot_sigheader.img.encrypt_list.xml
[ 27.4108 ] PKC key in Open SSL format
[ 27.4112 ] Key size is 256 bytes
[ 27.4114 ] Valid PKC key
[ 27.4131 ] Saving pkc public key in pub_key.key
[ 28.7560 ]
[ 28.7606 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt.signed boot_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 30.1089 ]
[ 30.4615 ] tegrahost_v2 --chip 0x19 --align kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 30.4648 ]
[ 30.4653 ] header_magic: 4e564441
[ 30.4691 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 30.4721 ] Key is a SBK key
[ 30.4728 ] Key Size is 16 bytes
[ 30.5073 ]
[ 30.5090 ] tegrahost_v2 --chip 0x19 0 --updatesigheader kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 30.5138 ]
[ 30.5152 ] tegrahost_v2 --chip 0x19 --align kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 30.5164 ]
[ 30.5175 ] tegrahost_v2 --appendsigheader kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 30.5185 ] Header already present for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 30.5223 ]
[ 30.5224 ] header_magic: 4e564441
[ 30.5239 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml
[ 30.5249 ] PKC key in Open SSL format
[ 30.5253 ] Key size is 256 bytes
[ 30.5255 ] Valid PKC key
[ 30.5272 ] Saving pkc public key in pub_key.key
[ 30.5991 ]
[ 30.6006 ] tegrahost_v2 --chip 0x19 0 --updatesigheader kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 30.6049 ]
[ 30.6065 ] tegrahost_v2 --chip 0x19 --align kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 30.6076 ]
[ 30.6078 ] header_magic: 4e564441
[ 30.6092 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 30.6102 ] Key is a SBK key
[ 30.6105 ] Key Size is 16 bytes
[ 30.6239 ]
[ 30.6254 ] tegrahost_v2 --chip 0x19 0 --updatesigheader kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 30.6297 ]
[ 30.6310 ] tegrahost_v2 --chip 0x19 --align kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 30.6322 ]
[ 30.6333 ] tegrahost_v2 --appendsigheader kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 30.6343 ] Header already present for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 30.6380 ]
[ 30.6381 ] header_magic: 4e564441
[ 30.6395 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml
[ 30.6406 ] PKC key in Open SSL format
[ 30.6410 ] Key size is 256 bytes
[ 30.6412 ] Valid PKC key
[ 30.6429 ] Saving pkc public key in pub_key.key
[ 30.7153 ]
[ 30.7168 ] tegrahost_v2 --chip 0x19 0 --updatesigheader kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 30.7211 ]
[ 30.7228 ] tegrahost_v2 --chip 0x19 --align recovery_sigheader.img
[ 30.7239 ]
[ 30.7241 ] header_magic: 4e564441
[ 30.7254 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list recovery_sigheader.img_list.xml
[ 30.7268 ] Key is a SBK key
[ 30.7271 ] Key Size is 16 bytes
[ 33.8627 ]
[ 33.8641 ] tegrahost_v2 --chip 0x19 0 --updatesigheader recovery_sigheader.img.encrypt recovery_sigheader.img.hash zerosbk
[ 35.0870 ]
[ 35.0900 ] tegrahost_v2 --chip 0x19 --align recovery_sigheader.img.encrypt
[ 35.0926 ]
[ 35.0954 ] tegrahost_v2 --appendsigheader recovery_sigheader.img.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 35.0978 ] Header already present for recovery_sigheader.img.encrypt
[ 35.8485 ]
[ 35.8486 ] header_magic: 4e564441
[ 35.8500 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list recovery_sigheader.img.encrypt_list.xml
[ 35.8511 ] PKC key in Open SSL format
[ 35.8515 ] Key size is 256 bytes
[ 35.8517 ] Valid PKC key
[ 35.8532 ] Saving pkc public key in pub_key.key
[ 35.9938 ]
[ 35.9952 ] tegrahost_v2 --chip 0x19 0 --updatesigheader recovery_sigheader.img.encrypt.signed recovery_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 37.1892 ]
[ 37.2393 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000.dtb_sigheader.rec
[ 37.2404 ]
[ 37.2406 ] header_magic: 4e564441
[ 37.2420 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list tegra194-p3668-all-p3509-0000.dtb_sigheader.rec_list.xml
[ 37.2430 ] Key is a SBK key
[ 37.2433 ] Key Size is 16 bytes
[ 37.2565 ]
[ 37.2578 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.hash zerosbk
[ 37.2622 ]
[ 37.2634 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt
[ 37.2646 ]
[ 37.2658 ] tegrahost_v2 --appendsigheader tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt oem-rsa-sbk --chip 0x19 0 --magicid DATA
[ 37.2668 ] Header already present for tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt
[ 37.2702 ]
[ 37.2703 ] header_magic: 4e564441
[ 37.2717 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt_list.xml
[ 37.2728 ] PKC key in Open SSL format
[ 37.2732 ] Key size is 256 bytes
[ 37.2734 ] Valid PKC key
[ 37.2749 ] Saving pkc public key in pub_key.key
[ 37.3455 ]
[ 37.3471 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt.signed tegra194-p3668-all-p3509-0000.dtb_sigheader.rec.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 37.3514 ]
[ 37.3575 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin
[ 37.3588 ]
[ 37.3738 ] header_magic: 50000ea
[ 37.3752 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_recovery_t194.bin_list.xml
[ 37.3763 ] Key is a SBK key
[ 37.3766 ] Key Size is 16 bytes
[ 37.3852 ]
[ 37.3867 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194.bin.encrypt nvtboot_recovery_t194.bin.hash zerosbk
[ 37.3883 ]
[ 37.3895 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin.encrypt
[ 37.3906 ]
[ 37.3918 ] tegrahost_v2 --appendsigheader nvtboot_recovery_t194.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B
[ 37.3928 ] adding BCH for nvtboot_recovery_t194.bin.encrypt
[ 37.3970 ]
[ 37.3971 ] header_magic: 3e918cce
[ 37.3986 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_recovery_t194.bin_sigheader.encrypt_list.xml
[ 37.3997 ] PKC key in Open SSL format
[ 37.4000 ] Key size is 256 bytes
[ 37.4002 ] Valid PKC key
[ 37.4019 ] Saving pkc public key in pub_key.key
[ 37.4723 ]
[ 37.4739 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194.bin_sigheader.encrypt.signed nvtboot_recovery_t194.bin_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 37.4771 ]
[ 37.4783 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin
[ 37.4795 ]
[ 37.4797 ] header_magic: 9000014
[ 37.4811 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list nvtboot_recovery_cpu_t194.bin_list.xml
[ 37.4824 ] Key is a SBK key
[ 37.4827 ] Key Size is 16 bytes
[ 37.4996 ]
[ 37.5012 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194.bin.encrypt nvtboot_recovery_cpu_t194.bin.hash zerosbk
[ 37.5033 ]
[ 37.5049 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin.encrypt
[ 37.5061 ]
[ 37.5072 ] tegrahost_v2 --appendsigheader nvtboot_recovery_cpu_t194.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid CPBL
[ 37.5082 ] adding BCH for nvtboot_recovery_cpu_t194.bin.encrypt
[ 37.5162 ]
[ 37.5164 ] header_magic: 572127db
[ 37.5179 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list nvtboot_recovery_cpu_t194.bin_sigheader.encrypt_list.xml
[ 37.5193 ] PKC key in Open SSL format
[ 37.5197 ] Key size is 256 bytes
[ 37.5199 ] Valid PKC key
[ 37.5214 ] Saving pkc public key in pub_key.key
[ 37.5931 ]
[ 37.5946 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 37.5998 ]
[ 37.6000 ] Copying signed file in /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x
[ 37.6009 ] Generating br-bct
[ 37.6020 ] Performing cfg overlay
[ 37.6021 ] ['/home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg']
[ 37.6021 ] Updating dev and MSS params in BR BCT
[ 37.6022 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 37.6466 ]
[ 37.6467 ] Updating bl info
[ 37.6480 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 37.6507 ]
[ 37.6508 ] Generating br-bct
[ 37.6524 ] Performing cfg overlay
[ 37.6525 ] ['/home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg']
[ 37.6525 ] Updating dev and MSS params in BR BCT
[ 37.6526 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 37.7001 ]
[ 37.7002 ] Updating bl info
[ 37.7015 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 37.7054 ]
[ 37.7054 ] Updating smd info
[ 37.7067 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 37.7083 ]
[ 37.7083 ] Updating Odmdata
[ 37.7095 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 37.7112 ]
[ 37.7112 ] Get encrypted section of bct
[ 37.7124 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listencbct bct_list.xml
[ 37.7142 ]
[ 37.7142 ] Signing BCT
[ 37.7154 ] Generating signatures with encryption
[ 37.7166 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --offset 2328 --file br_bct_BR.bct
[ 37.7177 ] Key is a SBK key
[ 37.7180 ] Key Size is 16 bytes
[ 37.7181 ]
[ 37.7181 ] Updating BCT with signature
[ 37.7185 ] Get Signed section of bct
[ 37.7199 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 37.7213 ]
[ 37.7225 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 37.7236 ] PKC key in Open SSL format
[ 37.7240 ] Key size is 256 bytes
[ 37.7243 ] Valid PKC key
[ 37.7257 ] Saving pkc public key in pub_key.key
[ 37.7973 ]
[ 37.7973 ] Updating BCT with signature
[ 37.7986 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key
[ 37.8001 ]
[ 37.8002 ] Generating coldboot mb1-bct
[ 37.8081 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 37.8097 ] MB1-BCT version: 0x1
[ 37.8101 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 37.8106 ] Added Platform Config 0 data with size :- 2496
[ 37.8127 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 37.8133 ] Added Platform Config 1 data with size :- 19640
[ 37.8416 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 37.8421 ] Added Platform Config 2 data with size :- 24
[ 37.8425 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 37.8430 ] Added Platform Config 4 data with size :- 348
[ 37.8435 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 37.8440 ] Added Platform Config 3 data with size :- 92
[ 37.8444 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 37.8449 ] Added Platform Config 5 data with size :- 128
[ 37.8453 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 37.8455 ] Added Platform Config 7 data with size :- 392
[ 37.8455 ]
[ 37.8456 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 37.8456 ] Added Platform Config 9 data with size :- 40
[ 37.8456 ]
[ 37.8456 ] Updating mb1-bct with firmware information
[ 37.8469 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 37.8481 ] MB1-BCT version: 0x1
[ 37.8486 ]
[ 37.8487 ] Updating mb1-bct with storage information
[ 37.8499 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 37.8510 ] MB1-BCT version: 0x1
[ 37.8515 ]
[ 37.8527 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 37.8538 ]
[ 37.8540 ] header_magic: c0660000
[ 37.8557 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mb1_cold_boot_bct_MB1.bct_list.xml
[ 37.8568 ] Key is a SBK key
[ 37.8571 ] Key Size is 16 bytes
[ 37.8589 ]
[ 37.8603 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1.bct.encrypt mb1_cold_boot_bct_MB1.bct.hash zerosbk
[ 37.8615 ]
[ 37.8628 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct.encrypt
[ 37.8639 ]
[ 37.8651 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT
[ 37.8661 ] adding BCH for mb1_cold_boot_bct_MB1.bct.encrypt
[ 37.8673 ]
[ 37.8674 ] header_magic: 61a13e4a
[ 37.8690 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_cold_boot_bct_MB1.bct_sigheader.encrypt_list.xml
[ 37.8702 ] PKC key in Open SSL format
[ 37.8706 ] Key size is 256 bytes
[ 37.8708 ] Valid PKC key
[ 37.8725 ] Saving pkc public key in pub_key.key
[ 37.9431 ]
[ 37.9446 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 37.9463 ]
[ 37.9464 ] Generating recovery mb1-bct
[ 37.9478 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 37.9489 ] MB1-BCT version: 0x1
[ 37.9494 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 37.9500 ] Added Platform Config 0 data with size :- 2496
[ 37.9521 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 37.9527 ] Added Platform Config 1 data with size :- 19640
[ 37.9736 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 37.9742 ] Added Platform Config 2 data with size :- 24
[ 37.9747 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 37.9754 ] Added Platform Config 4 data with size :- 348
[ 37.9759 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 37.9765 ] Added Platform Config 3 data with size :- 92
[ 37.9766 ]
[ 37.9767 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 37.9767 ] Added Platform Config 5 data with size :- 128
[ 37.9767 ]
[ 37.9767 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 37.9767 ] Added Platform Config 7 data with size :- 392
[ 37.9767 ]
[ 37.9767 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 37.9767 ] Added Platform Config 9 data with size :- 40
[ 37.9767 ]
[ 37.9768 ] Updating mb1-bct with firmware information
[ 37.9779 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 37.9790 ] MB1-BCT version: 0x1
[ 37.9796 ]
[ 37.9796 ] Updating mb1-bct with storage information
[ 37.9808 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 37.9820 ] MB1-BCT version: 0x1
[ 37.9825 ]
[ 37.9837 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 37.9848 ]
[ 37.9850 ] header_magic: c0660000
[ 37.9864 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mb1_bct_MB1.bct_list.xml
[ 37.9874 ] Key is a SBK key
[ 37.9877 ] Key Size is 16 bytes
[ 37.9895 ]
[ 37.9909 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1.bct.encrypt mb1_bct_MB1.bct.hash zerosbk
[ 37.9922 ]
[ 37.9934 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct.encrypt
[ 37.9945 ]
[ 37.9957 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT
[ 37.9967 ] adding BCH for mb1_bct_MB1.bct.encrypt
[ 37.9979 ]
[ 37.9980 ] header_magic: 61a13e4a
[ 37.9994 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_bct_MB1.bct_sigheader.encrypt_list.xml
[ 38.0028 ] PKC key in Open SSL format
[ 38.0032 ] Key size is 256 bytes
[ 38.0034 ] Valid PKC key
[ 38.0035 ] Saving pkc public key in pub_key.key
[ 38.0775 ]
[ 38.0808 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1.bct_sigheader.encrypt.signed mb1_bct_MB1.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 38.0839 ]
[ 38.0841 ] Generating coldboot mem-bct
[ 38.0859 ] tegrabct_v2 --chip 0x19 0 --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg --membct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_1.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_2.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_3.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_4.bct
[ 38.0874 ] Packing sdram param for instance[0]
[ 38.1333 ] Packing sdram param for instance[1]
[ 38.1337 ] Packing sdram param for instance[2]
[ 38.1341 ] Packing sdram param for instance[3]
[ 38.1341 ] Packing sdram param for instance[4]
[ 38.1341 ] Packing sdram param for instance[5]
[ 38.1341 ] Packing sdram param for instance[6]
[ 38.1341 ] Packing sdram param for instance[7]
[ 38.1341 ] Packing sdram param for instance[8]
[ 38.1341 ] Packing sdram param for instance[9]
[ 38.1341 ] Packing sdram param for instance[10]
[ 38.1341 ] Packing sdram param for instance[11]
[ 38.1341 ] Packing sdram param for instance[12]
[ 38.1342 ] Packing sdram param for instance[13]
[ 38.1342 ] Packing sdram param for instance[14]
[ 38.1342 ] Packing sdram param for instance[15]
[ 38.1342 ]
[ 38.1342 ] Getting sector size from pt
[ 38.1358 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 38.1369 ]
[ 38.1370 ] BlockSize read from layout is 200
[ 38.1381 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_1.bct
[ 38.1391 ] Key is a SBK key
[ 38.1394 ] Key Size is 16 bytes
[ 38.1425 ]
[ 38.1436 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_2.bct
[ 38.1446 ] Key is a SBK key
[ 38.1449 ] Key Size is 16 bytes
[ 38.1481 ]
[ 38.1495 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_3.bct
[ 38.1531 ] Key is a SBK key
[ 38.1534 ] Key Size is 16 bytes
[ 38.1566 ]
[ 38.1578 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --file /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_4.bct
[ 38.1588 ] Key is a SBK key
[ 38.1591 ] Key Size is 16 bytes
[ 38.1623 ]
[ 38.1634 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_1_encrypt.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_2_encrypt.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_3_encrypt.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_4_encrypt.bct
[ 38.1644 ] adding BCH for /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_1_encrypt.bct
[ 38.1684 ]
[ 38.1699 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 38.1713 ]
[ 38.1725 ] tegrahost_v2 --appendsigheader mem_coldboot.bct oem-rsa-sbk --chip 0x19 0 --magicid MEMB
[ 38.1735 ] Header already present for mem_coldboot.bct
[ 38.1739 ]
[ 38.1741 ] header_magic: 4e564441
[ 38.1755 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mem_coldboot.bct_list.xml
[ 38.1765 ] PKC key in Open SSL format
[ 38.1769 ] Key size is 256 bytes
[ 38.1772 ] Valid PKC key
[ 38.1788 ] Saving pkc public key in pub_key.key
[ 38.2495 ]
[ 38.2511 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot.bct.signed mem_coldboot.bct.sig oem-rsa --pubkeyhash pub_key.key
[ 38.2526 ]
[ 38.2539 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 38.2550 ]
[ 38.2562 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct oem-rsa
[ 38.2572 ] Header already present for mem_coldboot.bct
[ 38.2577 ]
[ 38.2592 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 38.2602 ] PKC key in Open SSL format
[ 38.2606 ] Key size is 256 bytes
[ 38.2608 ] Valid PKC key
[ 38.2626 ] Saving pkc public key in pub_key.key
[ 38.3338 ]
[ 38.3353 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --updatesigheader mem_coldboot_sigheader.bct.signed mem_coldboot_sigheader.bct.sig oem-rsa
[ 38.3369 ]
[ 38.3370 ] Generating recovery mem-bct
[ 38.3382 ] tegrabct_v2 --chip 0x19 0 --sdram /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1.cfg --membct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_1.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_2.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_3.bct /home/dcapers/nvidia/Linux_for_Tegra/bootloader/31758/tmp8k1v7jkc1_4.bct
[ 38.3393 ] Packing sdram param for instance[0]
[ 38.3840 ] Packing sdram param for instance[1]
[ 38.3844 ] Packing sdram param for instance[2]
[ 38.3847 ] Packing sdram param for instance[3]
[ 38.3849 ] Packing sdram param for instance[4]
[ 38.3849 ] Packing sdram param for instance[5]
[ 38.3849 ] Packing sdram param for instance[6]
[ 38.3850 ] Packing sdram param for instance[7]
[ 38.3850 ] Packing sdram param for instance[8]
[ 38.3850 ] Packing sdram param for instance[9]
[ 38.3850 ] Packing sdram param for instance[10]
[ 38.3850 ] Packing sdram param for instance[11]
[ 38.3850 ] Packing sdram param for instance[12]
[ 38.3850 ] Packing sdram param for instance[13]
[ 38.3850 ] Packing sdram param for instance[14]
[ 38.3850 ] Packing sdram param for instance[15]
[ 38.3850 ]
[ 38.3852 ] Reading ramcode from backup chip_info.bin file
[ 38.3888 ] RAMCODE Read from Device: 0
[ 38.3889 ] Disabled BPMP dtb trim, using default dtb
[ 38.3889 ]
[ 38.3902 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 38.3918 ]
[ 38.3920 ] header_magic: 3000000
[ 38.3934 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/SBK.txt --list mem_rcm.bct_list.xml
[ 38.3944 ] Key is a SBK key
[ 38.3947 ] Key Size is 16 bytes
[ 38.3979 ]
[ 38.3993 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm.bct.encrypt mem_rcm.bct.hash zerosbk
[ 38.4006 ]
[ 38.4019 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct.encrypt
[ 38.4033 ]
[ 38.4045 ] tegrahost_v2 --appendsigheader mem_rcm.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MEMB
[ 38.4056 ] adding BCH for mem_rcm.bct.encrypt
[ 38.4074 ]
[ 38.4075 ] header_magic: 72aa2959
[ 38.4089 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mem_rcm.bct_sigheader.encrypt_list.xml
[ 38.4099 ] PKC key in Open SSL format
[ 38.4103 ] Key size is 256 bytes
[ 38.4106 ] Valid PKC key
[ 38.4121 ] Saving pkc public key in pub_key.key
[ 38.4845 ]
[ 38.4860 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm.bct_sigheader.encrypt.signed mem_rcm.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 38.4880 ]
[ 38.4890 ] nvtboot_recovery_t194.bin_sigheader.encrypt.signed
[ 38.4892 ] preboot_c10_prod_cr.bin
[ 38.4894 ] mce_c10_prod_cr.bin
[ 38.4896 ] mts_c10_prod_cr.bin
[ 38.4931 ] bpmp_t194.bin
[ 38.4941 ] tegra194-a02-bpmp-p3668-a00.dtb
[ 38.4944 ] spe_t194.bin
[ 38.4946 ] tos-trusty_t194.img
[ 38.4953 ] eks.img
[ 38.4955 ] tegra194-p3668-all-p3509-0000.dtb
[ 38.4959 ] nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed
[ 38.4975 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 38.4987 ]
[ 38.4999 ] tegrahost_v2 --appendsigheader mb1_t194_prod_sigheader.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB1B
[ 38.5011 ] Header already present for mb1_t194_prod_sigheader.bin.encrypt
[ 38.5060 ]
[ 38.5061 ] header_magic: 4e564441
[ 38.5075 ] tegrasign_v2 --key /home/dcapers/nvidia/Linux_for_Tegra/RSA_Key.pem --pubkeyhash pub_key.key --list mb1_t194_prod_sigheader.bin.encrypt_list.xml
[ 38.5086 ] PKC key in Open SSL format
[ 38.5089 ] Key size is 256 bytes
[ 38.5091 ] Valid PKC key
[ 38.5109 ] Saving pkc public key in pub_key.key
[ 38.5841 ]
[ 38.5857 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key
[ 38.5907 ]
[ 38.5924 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 38.5939 ]
[ 38.6015 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/dcapers/nvidia/Linux_for_Tegra/bootloader/encrypted_signed_t19x/flash.xml.tmp flash.idx
[ 40.7924 ]
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed --bct br_bct_BR.bct --applet rcm_2_signed.rcm --applet_softfuse rcm_1_signed.rcm --cmd "secureflash;reboot" --cfg secureflash.xml --chip 0x19 --mb1_bct mb1_bct_MB1.bct_sigheader.encrypt.signed --mem_bct mem_rcm.bct_sigheader.encrypt.signed --mb1_cold_boot_bct mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed --mem_bct_cold_boot mem_coldboot_sigheader.bct.signed --bins "mb2_bootloader nvtboot_recovery_t194.bin_sigheader.encrypt.signed; mts_preboot preboot_c10_prod_cr_sigheader.bin.encrypt.signed; mts_mce mce_c10_prod_cr_sigheader.bin.encrypt.signed; mts_proper mts_c10_prod_cr_sigheader.bin.encrypt.signed; bpmp_fw bpmp_t194_sigheader.bin.encrypt.signed; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed; spe_fw spe_t194_sigheader.bin.encrypt.signed; tlk tos-trusty_t194_sigheader.img.encrypt.signed; eks eks_sigheader.img.encrypt.signed; bootloader_dtb tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed"
saving flash command in flashcmd.txt
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0096 ] Parsing partition layout
[ 0.0107 ] tegraparser_v2 --pt secureflash.xml.tmp
[ 0.0126 ]
[ 0.0126 ] Boot Rom communication
[ 0.0137 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_1_signed.rcm --rcm rcm_2_signed.rcm
[ 0.0147 ] BR_CID: 0xd8021911647147031400000003ff0040
[ 0.0157 ] Boot Rom communication completed
[ 1.0573 ]
[ 2.0625 ] tegrarcm_v2 --isapplet
[ 2.0657 ] Applet version 01.00.0000
[ 2.0826 ]
[ 2.0829 ] Sending BCTs
[ 2.0871 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1.bct_sigheader.encrypt.signed --download bct_mem mem_rcm.bct_sigheader.encrypt.signed
[ 2.0917 ] Applet version 01.00.0000
[ 2.1109 ] Sending bct_bootrom
[ 2.1117 ] [................................................] 100%
[ 2.1139 ] Sending bct_mb1
[ 2.1184 ] [................................................] 100%
[ 2.1234 ] Sending bct_mem
[ 2.1721 ] [................................................] 100%
[ 2.2479 ]
[ 2.2481 ] Generating blob
[ 2.2541 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 2.2570 ] number of images in blob are 11
[ 2.2584 ] blobsize is 5778776
[ 2.2589 ] Added binary blob_nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed of size 260032
[ 2.2704 ] Added binary blob_nvtboot_recovery_t194.bin_sigheader.encrypt.signed of size 130928
[ 2.2726 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt.signed of size 24016
[ 2.2751 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt.signed of size 143200
[ 2.2776 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt.signed of size 3430416
[ 2.2800 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt.signed of size 856352
[ 2.2844 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed of size 227264
[ 2.2870 ] Added binary blob_spe_t194_sigheader.bin.encrypt.signed of size 94960
[ 2.2910 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt.signed of size 402368
[ 2.2945 ] Added binary blob_eks_sigheader.img.encrypt.signed of size 5136
[ 2.2945 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed of size 203920
[ 2.2946 ]
[ 2.2947 ] Sending bootloader and pre-requisite binaries
[ 2.2967 ] tegrarcm_v2 --download blob blob.bin
[ 2.2980 ] Applet version 01.00.0000
[ 2.3193 ] Sending blob
[ 2.3198 ] [................................................] 100%
[ 3.1356 ]
[ 3.1387 ] tegrarcm_v2 --boot recovery
[ 3.1415 ] Applet version 01.00.0000
[ 3.1670 ]
[ 4.1723 ] tegrarcm_v2 --isapplet
[ 4.3621 ]
[ 4.3658 ] tegrarcm_v2 --ismb2
[ 4.3871 ]
[ 4.4078 ] tegradevflash_v2 --iscpubl
[ 4.4122 ] Bootloader version 01.00.0000
[ 4.4163 ] Bootloader version 01.00.0000
[ 4.4163 ]
[ 4.4165 ] Retrieving storage infomation
[ 4.4210 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 4.4249 ] Applet is not running on device. Continue with Bootloader
[ 4.4435 ]
[ 4.4476 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 4.4506 ] Bootloader version 01.00.0000
[ 4.4685 ] Saved platform info in storage_info.bin
[ 4.4702 ]
[ 4.4704 ] Flashing the device
[ 4.4736 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt secureflash.xml.bin
[ 4.4782 ]
[ 4.4815 ] tegradevflash_v2 --pt secureflash.xml.bin --create
[ 4.4840 ] Bootloader version 01.00.0000
[ 4.4871 ] Erasing spi: 0 ......... [Done]
[ 72.4939 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin
[ 72.4961 ] [................................................] 100%
[ 72.6092 ] Erasing sdcard: 0 ......... [Done]
[ 76.9455 ] Writing partition master_boot_record with mbr_6_0.bin
[ 76.9470 ] [................................................] 100%
[ 76.9483 ] Writing partition primary_gpt with gpt_primary_6_0.bin
[ 76.9610 ] [................................................] 100%
[ 76.9632 ] Writing partition secondary_gpt with gpt_secondary_6_0.bin
[ 76.9781 ] [................................................] 100%
[ 76.9914 ] Writing partition mb1 with mb1_t194_prod_sigheader.bin.encrypt.signed
[ 76.9938 ] [................................................] 100%
[ 77.0039 ] Writing partition mb1_b with mb1_t194_prod_sigheader.bin.encrypt.signed
[ 78.5892 ] [................................................] 100%
[ 78.5985 ] Writing partition spe-fw with spe_t194_sigheader.bin.encrypt.signed
[ 80.1840 ] [................................................] 100%
[ 80.1878 ] Writing partition spe-fw_b with spe_t194_sigheader.bin.encrypt.signed
[ 80.7995 ] [................................................] 100%
[ 80.8027 ] Writing partition mb2 with nvtboot_t194_sigheader.bin.encrypt.signed
[ 81.4135 ] [................................................] 100%
[ 81.4200 ] Writing partition mb2_b with nvtboot_t194_sigheader.bin.encrypt.signed
[ 82.5161 ] [................................................] 100%
[ 82.5219 ] Writing partition mts-preboot with preboot_c10_prod_cr_sigheader.bin.encrypt.signed
[ 83.6167 ] [................................................] 100%
[ 83.6184 ] Writing partition mts-preboot_b with preboot_c10_prod_cr_sigheader.bin.encrypt.signed
[ 83.7794 ] [................................................] 100%
[ 83.7807 ] Writing partition mts-mce with mce_c10_prod_cr_sigheader.bin.encrypt.signed
[ 83.9428 ] [................................................] 100%
[ 83.9475 ] Writing partition mts-mce_b with mce_c10_prod_cr_sigheader.bin.encrypt.signed
[ 84.8622 ] [................................................] 100%
[ 84.8664 ] Writing partition mts-proper with mts_c10_prod_cr_sigheader.bin.encrypt.signed
[ 85.7794 ] [................................................] 100%
[ 105.7124 ] Writing partition mts-proper_b with mts_c10_prod_cr_sigheader.bin.encrypt.signed
[ 107.5170 ] [................................................] 100%
[ 127.4446 ] Writing partition sc7 with warmboot_t194_prod_sigheader.bin.encrypt.signed
[ 129.2459 ] [................................................] 100%
[ 129.2488 ] Writing partition sc7_b with warmboot_t194_prod_sigheader.bin.encrypt.signed
[ 129.6743 ] [................................................] 100%
[ 129.6770 ] Writing partition SMD with slot_metadata.bin
[ 130.0996 ] [................................................] 100%
[ 130.1022 ] Writing partition SMD_b with slot_metadata.bin
[ 130.1078 ] [................................................] 100%
[ 130.1090 ] Writing partition xusb-fw with xusb_sil_rel_fw
[ 130.1178 ] [................................................] 100%
[ 130.1228 ] Writing partition xusb-fw_b with xusb_sil_rel_fw
[ 130.9142 ] [................................................] 100%
[ 130.9193 ] Writing partition cpu-bootloader with cboot_t194_sigheader.bin.encrypt.signed
[ 131.7119 ] [................................................] 100%
[ 131.7273 ] Writing partition cpu-bootloader_b with cboot_t194_sigheader.bin.encrypt.signed
[ 134.5489 ] [................................................] 100%
[ 134.5640 ] Writing partition bootloader-dtb with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed
[ 137.3874 ] [................................................] 100%
[ 137.3937 ] Writing partition bootloader-dtb_b with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed
[ 138.6911 ] [................................................] 100%
[ 138.6970 ] Writing partition BMP with bmp.blob
[ 139.9926 ] [................................................] 100%
[ 139.9991 ] Writing partition BMP_b with bmp.blob
[ 140.9514 ] [................................................] 100%
[ 140.9580 ] Writing partition secure-os with tos-trusty_t194_sigheader.img.encrypt.signed
[ 141.9145 ] [................................................] 100%
[ 141.9278 ] Writing partition secure-os_b with tos-trusty_t194_sigheader.img.encrypt.signed
[ 144.4689 ] [................................................] 100%
[ 144.4828 ] Writing partition eks with eks_sigheader.img.encrypt.signed
[ 147.0259 ] [................................................] 100%
[ 147.0284 ] Writing partition eks_b with eks_sigheader.img.encrypt.signed
[ 147.0722 ] [................................................] 100%
[ 147.0744 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt.signed
[ 147.1191 ] [................................................] 100%
[ 147.1220 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt.signed
[ 147.6446 ] [................................................] 100%
[ 147.6475 ] Writing partition rce-fw with camera-rtcpu-rce_sigheader.img.encrypt.signed
[ 148.1697 ] [................................................] 100%
[ 148.1792 ] Writing partition rce-fw_b with camera-rtcpu-rce_sigheader.img.encrypt.signed
[ 149.9094 ] [................................................] 100%
[ 149.9174 ] Writing partition bpmp-fw with bpmp_t194_sigheader.bin.encrypt.signed
[ 151.6473 ] [................................................] 100%
[ 151.6732 ] Writing partition bpmp-fw_b with bpmp_t194_sigheader.bin.encrypt.signed
[ 157.0709 ] [................................................] 100%
[ 157.0987 ] Writing partition bpmp-fw-dtb with tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed
[ 162.4970 ] [................................................] 100%
[ 162.5034 ] Writing partition bpmp-fw-dtb_b with tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed
[ 163.9468 ] [................................................] 100%
[ 163.9528 ] Writing partition VER with qspi_bootblob_ver.txt
[ 165.3919 ] [................................................] 100%
[ 165.3926 ] Writing partition VER_b with qspi_bootblob_ver.txt
[ 165.4015 ] [................................................] 100%
[ 165.4029 ] Writing partition master_boot_record with mbr_6_0.bin
[ 165.4120 ] [................................................] 100%
[ 165.4126 ] Writing partition kernel with boot_sigheader.img.encrypt.signed
[ 165.4171 ] [................................................] 100%
[ 170.4552 ] Writing partition kernel_b with boot_sigheader.img.encrypt.signed
[ 170.5178 ] [................................................] 100%
[ 175.6314 ] Writing partition kernel-dtb with kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed
[ 175.6965 ] [................................................] 100%
[ 175.7013 ] Writing partition kernel-dtb_b with kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed
[ 175.7337 ] [................................................] 100%
[ 175.7383 ] Writing partition recovery with recovery_sigheader.img.encrypt.signed
[ 175.7802 ] [................................................] 100%
[ 181.7889 ] Writing partition recovery-dtb with tegra194-p3668-all-p3509-0000.dtb.rec
[ 181.8779 ] [................................................] 100%
[ 181.8840 ] Writing partition kernel-bootctrl with kernel_bootctrl.bin
[ 181.9231 ] [................................................] 100%
[ 181.9245 ] Writing partition kernel-bootctrl_b with kernel_bootctrl.bin
[ 181.9325 ] [................................................] 100%
[ 181.9341 ] Writing partition APP with system.img
[ 181.9429 ] [................................................] 100%
[ 792.8467 ]
[ 792.8512 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 792.8549 ] Bootloader version 01.00.0000
[ 792.8583 ] Writing partition BCT with br_bct_BR.bct
[ 792.8601 ] [................................................] 100%
[ 793.0011 ]
[ 793.0103 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed
[ 793.0152 ] Bootloader version 01.00.0000
[ 793.0224 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed
[ 793.0291 ] [................................................] 100%
[ 793.2248 ]
[ 793.2284 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed
[ 793.2314 ] Bootloader version 01.00.0000
[ 793.2356 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed
[ 793.2386 ] [................................................] 100%
[ 793.4411 ]
[ 793.4489 ] tegradevflash_v2 --write MEM_BCT mem_coldboot_sigheader.bct.signed
[ 793.4521 ] Bootloader version 01.00.0000
[ 793.4555 ] Writing partition MEM_BCT with mem_coldboot_sigheader.bct.signed
[ 793.4580 ] [................................................] 100%
[ 794.7175 ]
[ 794.7208 ] tegradevflash_v2 --write MEM_BCT_b mem_coldboot_sigheader.bct.signed
[ 794.7234 ] Bootloader version 01.00.0000
[ 794.7272 ] Writing partition MEM_BCT_b with mem_coldboot_sigheader.bct.signed
[ 794.7298 ] [................................................] 100%
[ 795.9890 ]
[ 795.9892 ] Flashing completed
[ 795.9894 ] Coldbooting the device
[ 795.9937 ] tegrarcm_v2 --ismb2
[ 796.0002 ]
[ 796.0059 ] tegradevflash_v2 --reboot coldboot
[ 796.0084 ] Bootloader version 01.00.0000
[ 796.0111 ]
hello dcapers44,
the image flashing has completed according to those message, the device should be booting-up after that.
since you think your platform has no response, could you please share bootloader messages for reference?
thanks
I’m am not sure what you are referring to. Where do I locate the bootloader messages?
