Jetson Xavier NX FAQ
Q: How to install old version JetPack from SDK Manager?
A: Run below commands:
$ sdkmanager --archivedversions
Q: R32.5.2 BSP is not listed in SDKManager. How to install SDK Components?
A: Please install through apt commands. Install all SDK Components:
$ sudo apt install nvidia-jetpack
Only install MMAPI packages:
$ sudo apt list -a nvidia-l4t-jetson-multimedia-api
$ sudo apt install nvidia-l4t-jetson-multimedia-api=32.5.2-20210709090156
Q: My Xavier NX is with emmc and 16GB is a bit insufficient. Any suggestion?
A: There is a M.2 slot on Xavier NX developer kit. You may consider to buy a NVMe PCIe M.2 SSD card and move the rootfs to it.
After Jetpack 4.6, please check developer guide
On Jetpack 4.5 or 4.4, please refer to the steps in
Making sure you're not a bot!
And further explanation in : Boot from external drive
Q: I hit an issue and need to have a solution. Could you help?
A: We have quick solutions for some known issues. Please check
For TensorRT/VPI, please check Making sure you're not a bot!
Q: My Xavier NX is with sd card slot. Can I use it to verify secureboot?
A: No. Secureboot is only supported on production module(Xavier NX with emmc).
Q: I always get same name in calling Argus getModuleString(). Any idea for this?
A: This is known. Please use this function:
Multiple CSI cameras show same module string - #9 by ShaneCCC
If you have > 6 cameras, please use Jetpack 4.6.2, 5.0.2, or later release(s).
Q: Has anyone tried Vulkan?
A: A contributor has shared some tips. Please refer to
Vulkan tutorial first steps
Q: I have a USB camera. How can I launch it on Xavier NX?
Q: Is there any example of running RTSP streaming?
Q: Is there any example of running UDP streaming?
Q: How to autorun an app or commands at startup?
A: Please refer to Jetson Nano FAQ
Q: How to run jetson-utils with VPI in python?
A: Please refer to this page link
Q: I have some issues when using TensorRT/VPI libraries.
A: Please check this page link for some common issues/examples for TensorRT and VPI libraries.
Q: How to adjust HS_CURR_LEVEL in usb tuning?
A: Please refer to this post HS_CURR_LEVEL Offset Adjustment Procedure issue
Q: VS Code is not working on Xavier NX
A: Please refer to this topic
