SDK Manager unable to install Jetpack 5.0.1 because of lack of space
We currently use the 4.6.2 Jetpack on our Jetson Xavier NX (16Gb emmc and 8Gb RAM), which works fine. We would like to switch to a 16Gb RAM version. According to this [I have stucked When I use jetson-inference on xavier nx 16GB], because of TensorRT, we are being forced to change to the 5.0.1 jetpack.
However, the SDK Manager is unable to install Jetpack 5.0.1 on Jetson Xavier NX with 16Gb emmc because of lack of space. We have also tried doing this manually i.e. using ‘sudo apt install nvidia-jetpack’ with the same problem. One thing we have also tried, is using the ‘sudo apt-get purge $(cat nvubuntu-focal-packages_only-in-desktop)’ command to remove GUI as suggested here [Guide to Minimizing Jetson Disk Usage] but we are still running out of space.
So we would like to know if there is something we are doing wrong here. Is there a way to get TensorRT to work with the 16Gb RAM Xavier NX or a way to fully install the 5.0.1 jetpack on the Xavier NX?
Hello @remibasaru,
Welcome to the NVIDIA Developer forums! I’m moving this topic to the Jetson Xavier NX category so the support team has visibility.
Tom
We suggest to directly flash the OS and jetpack to nvme drive. Sdkmanager is able to do for JetPack 5.0.1
Or you can boot from the usb drive, see
Flashing Support — Jetson Linux<br/>Developer Guide 34.1 documentation.
Yes, but we still need this to fit on a production module that still only has 16Gb emmc space. Are you suggesting that we create the system on the nvme drive, reduce the size by following this [Guide to Minimizing Jetson Disk Usage] and then reflash it into a 16Gb emmc production device?
No, we are talking about directly use nvme as system disk.
So, we won’t be able to use the emmc-based production modules that we have as is? Without using an external drive.
If you want to install the full software (OS + SDK), then it is not possible. Sorry about that.
Ok Thanks
So to confirm. The new SDK provided by NVIDIA’s Jetpack 5.0.1 is not meant to work with its emmc-based production version of NVIDIA’s Jetson NX. Am I missing something here? Doing tasks such as deep learning inference is dependent on the SDK, is it not?
Those SDKs can be selected to install for what you need on your product, not doing the full installation.
Hi, I’m having the same issue. Can I use a 128GB SD card instead of NVME ?
Hi kayccc
Thanks for the reply. Are referring to using the SDK manager? If this is the case I am yet to find the appropriate configuration that was installable (size-wise) on the 16Gb emmc version. What I have been able to do is create the original image on a 128 Gb sd card and then reduce the size using this [Guide to Minimizing Jetson Disk Usage] to less than 16 Gb. This seems like the only path I can think of. However, I am now not sure of how to convert the sd card-based image to an image that is installable on the production version.
At the very least is there documentation on how to implement an inference module on a 5.0.1 jetpack based 16Gb NX card? My initial question still remains, is there a way to only install the necessary modules (i.e. TensorRT etc.), which are required for inference, using the SDK manager?
Thanks in advance for your time.
