I have a customized carrier board on a customized BSP for NX based on Jetson L4T 32.4.3 (emmc based).
Our this BSP by default, does not installed Nvidia/Jetpack software.
I have tried to install jetpack as below command
sudo apt update
sudp apt install nvidia-jetpack.
These instruction show there are no space to install software in eMMC storage. What is the minimum memory space required?
what is the suggestion to install jetpack in this scenario?
They also tried using below command to install jet-pack 4.4
sudo apt depends nvidia-jetpack | awk â{print $2}â | xargs -I {} sudo apt install -y {}
and result of disk space is :
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk0p1 14318640 12850392 717864 95% /
none 3594592 0 3594592 0% /dev
tmpfs 3978428 4 3978424 1% /dev/shm
tmpfs 3978428 31116 3947312 1% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 3978428 0 3978428 0% /sys/fs/cgroup
tmpfs 795684 20 795664 1% /run/user/120
tmpfs 795684 160 795524 1% /run/user/1000
there is no error to install jetpack .
However, after reboot system, Floyd/NX does not appear login prompt on screen.
(but can login using ssh )
I tried to install jetpack normally.
sudo apt install nvidia-jetpacl
This result met install error as below and no free spcace on Floyd.
Errors were encountered while processing:
/tmp/apt-dpkg-install-NUPMGj/122-vpi_0.4.4_arm64.deb
/tmp/apt-dpkg-install-NUPMGj/123-cmake-data_3.10.2-1ubuntu2.18.04.1_all.deb
/tmp/apt-dpkg-install-NUPMGj/128-cmake_3.10.2-1ubuntu2.18.04.1_arm64.deb
/tmp/apt-dpkg-install-NUPMGj/130-vpi-samples_0.4.4_arm64.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
Here we have installed our BSP already and it is up and running, we want to install jetpack on top of it (say some components) without loosing our applied patch changes
Finally, I have used SDK manager to install jetpack 4.4.1 into Floyd/NX and Nano.
As result, I have succeeded it without error message and storage size as below.
[NX]
/dev/mmcblk0p1 14318640 13413272 154984 99% /
[Nano]
/dev/mmcblk0p1 14318640 13158792 409464 97% /
However, I have met some problem which does not see SD or/and NVME card.
On nano board, there are no SD(/dev/mmcblk1) and NvME(/dev/nvme0n1) device.
On NX board, NvME device is available but SD card is not seen.
[NX] reslt of lsblk command on using SDKManager (jetpack 4.4.1)
nvidia@nvidia-desktop:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
sda 8:0 1 116.5G 0 disk â USB SD card
âsda1 8:1 1 116.5G 0 part
mtdblock0 31:0 0 32M 0 disk
mmcblk0 179:0 0 14.7G 0 disk <-eMMC internal 16G
âmmcblk0p1 179:1 0 14G 0 part /
âmmcblk0p2 179:2 0 64M 0 part
âmmcblk0p3 179:3 0 64M 0 part
âmmcblk0p4 179:4 0 448K 0 part
âmmcblk0p5 179:5 0 448K 0 part
âmmcblk0p6 179:6 0 63M 0 part
âmmcblk0p7 179:7 0 512K 0 part
âmmcblk0p8 179:8 0 256K 0 part
âmmcblk0p9 179:9 0 256K 0 part
âmmcblk0p10 179:10 0 300M 0 part
âmmcblk0p11 179:11 0 199.1M 0 part
mmcblk0boot0 179:32 0 4M 1 disk
mmcblk0boot1 179:64 0 4M 1 disk
mmcblk0rpmb 179:96 0 4M 0 disk
zram0 252:0 0 1.9G 0 disk [SWAP]
zram1 252:1 0 1.9G 0 disk [SWAP]
nvme0n1 259:0 0 238.5G 0 disk <-NVME Card
ânvme0n1p1 259:1 0 238.5G 0 part
[NX] result of lsblk command on NX
nvidia@nvidia-emmc:~$ lsblk
tqmmcblk0p1 179:1 0 14G 0 part /
tqmmcblk0p2 179:2 0 64M 0 part
tqmmcblk0p3 179:3 0 64M 0 part
tqmmcblk0p4 179:4 0 448K 0 part
tqmmcblk0p5 179:5 0 448K 0 part
tqmmcblk0p6 179:6 0 63M 0 part
tqmmcblk0p7 179:7 0 512K 0 part
tqmmcblk0p8 179:8 0 256K 0 part
tqmmcblk0p9 179:9 0 256K 0 part
tqmmcblk0p10 179:10 0 300M 0 part
mqmmcblk0p11 179:11 0 199.1M 0 part
mmcblk1 179:128 0 116.5G 0 disk
âmmcblk1p1 179:129 0 116.5G 0 part
nvme0n1 259:0 0 232.9G 0 disk
ânvme0n1p1 259:1 0 232.9G 0 part
Can you suggest on how to see SD/NVME device when using SDK manager ?
