Also when I use this command:
sudo ./flash.sh -k BMP --image ./bootloader/bmp.blob jetson-xavier mmcblk0p1
L4T BSP Information:
R32 , REVISION: 4.3
Target Board Information:
Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
OpMode: production, Boot Authentication: NS,
copying soft_fuses(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
./tegraflash.py --chip 0x19 --applet “/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0025 ] Generating RCM messages
[ 0.0032 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0038 ] Header already present for /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0061 ]
[ 0.0068 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0073 ] Assuming zero filled SBK key
[ 0.0074 ]
[ 0.0080 ] tegrasign_v2 --key None --file /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0086 ] Assuming zero filled SBK key
[ 0.0091 ]
[ 0.0097 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0124 ]
[ 0.0132 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0138 ]
[ 0.0144 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0149 ] RCM 0 is saved as rcm_0.rcm
[ 0.0177 ] RCM 1 is saved as rcm_1.rcm
[ 0.0177 ] RCM 2 is saved as rcm_2.rcm
[ 0.0177 ] List of rcm files are saved in rcm_list.xml
[ 0.0177 ]
[ 0.0178 ] Signing RCM messages
[ 0.0183 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0189 ] Assuming zero filled SBK key
[ 0.0193 ]
[ 0.0193 ] Copying signature to RCM mesages
[ 0.0199 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0207 ]
[ 0.0208 ] Boot Rom communication
[ 0.0213 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0218 ] RCM version 0X190001
[ 0.0226 ] Boot Rom communication completed
[ 1.0396 ]
[ 2.0443 ] tegrarcm_v2 --isapplet
[ 2.0470 ] Applet version 01.00.0000
[ 2.0675 ]
[ 2.0705 ] tegrarcm_v2 --ismb2
[ 2.1063 ]
[ 2.1094 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.1120 ]
[ 2.1147 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.1174 ] adding BCH for nvtboot_applet_t194.bin
[ 2.1264 ]
[ 2.1318 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.1343 ] Assuming zero filled SBK key
[ 2.1355 ]
[ 2.1390 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.1465 ]
[ 2.1493 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.1518 ] Applet version 01.00.0000
[ 2.1709 ] Sending mb2
[ 2.1713 ] […] 100%
[ 2.1843 ]
[ 2.1875 ] tegrarcm_v2 --boot recovery
[ 2.1899 ] Applet version 01.00.0000
[ 2.2096 ]
[ 3.2144 ] tegrarcm_v2 --isapplet
[ 3.2359 ]
[ 3.2371 ] tegrarcm_v2 --ismb2
[ 3.2379 ] MB2 Applet version 01.00.0000
[ 3.2712 ]
[ 3.2748 ] tegrarcm_v2 --ismb2
[ 3.2776 ] MB2 Applet version 01.00.0000
[ 3.3153 ]
[ 3.3188 ] Retrieving EEPROM data
[ 3.3191 ] tegrarcm_v2 --oem platformdetails eeprom cvm /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 3.3216 ] MB2 Applet version 01.00.0000
[ 3.3579 ] Saved platform info in /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 3.3923 ]
[ 3.3925 ] Rebooting to recovery mode
[ 3.3953 ] tegrarcm_v2 --ismb2
[ 3.3977 ] MB2 Applet version 01.00.0000
[ 3.4160 ]
[ 3.4161 ] Rebooting to recovery mode
[ 3.4189 ] tegrarcm_v2 --reboot recovery
[ 3.4213 ] MB2 Applet version 01.00.0000
[ 3.4661 ]
Board ID(3668) version(200) sku(0000) revision(H.0)
copying bctfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)… done.
copying bctfile1(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)… done.
copying uphy_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)… done.
copying device_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)… done.
copying misc_cold_boot_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)… done.
copying misc_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)… done.
copying pinmux_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)… done.
copying gpioint_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)… done.
copying pmic_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg)… done.
copying pmc_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)… done.
copying prod_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)… done.
copying scr_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)… done.
copying scr_cold_boot_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)… done.
copying bootrom_config(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)… done.
copying dev_params(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)… done.
Existing bootloader(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
version 1.0.0
[ 0.0023 ] Generating signature
[ 0.0031 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0036 ] Assuming zero filled SBK key
[ 0.0037 ]
[ 0.0038 ] header_magic: 5614
[ 0.0044 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0049 ]
[ 0.0055 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
[ 0.0060 ] adding BCH for 1_Image
[ 0.5995 ]
[ 0.6008 ] tegrasign_v2 --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.6013 ] Assuming zero filled SBK key
[ 0.6290 ]
[ 0.6299 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 0.9777 ]
[ 0.9981 ] Signed file: /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/Image_sigheader.encrypt
Generate header for Image_sigheader.encrypt
Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
Remove temporary file
done.
populating initrd to rootfs… done.
populating /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to rootfs… done.
Making Boot image… done.
Existing sosfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a01.dtb)… done.
Existing scefile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing drameccfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing wb0boot(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)… done.
Copying nv_boot_control.conf to rootfs
version 1.0.0
[ 0.0026 ] Generating signature
[ 0.0033 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0038 ] Assuming zero filled SBK key
[ 0.0038 ]
[ 0.0039 ] header_magic: d00dfeed
[ 0.0045 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0051 ]
[ 0.0057 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0062 ] adding BCH for 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0112 ]
[ 0.0122 ] tegrasign_v2 --key --list 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0126 ] Assuming zero filled SBK key
[ 0.0130 ]
[ 0.0137 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0171 ]
[ 0.0174 ] Signed file: /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate header for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate 16-byte-size-aligned base file for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
Existing tbcfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)… done.
copying cfgfile(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml… done.
Existing flasher(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Updating [BMP] with /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/bmp.blob ***
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --chip 0x19 --applet mb1_t194_prod.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --bin “mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a01.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb” --odmdata 0x9190000 --cmd “write BMP /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/bmp.blob; reboot”
version 1.0.0
[ 0.0051 ] Generating RCM messages
[ 0.0057 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0063 ] Header already present for mb1_t194_prod.bin
[ 0.0087 ]
[ 0.0092 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0098 ] Assuming zero filled SBK key
[ 0.0099 ]
[ 0.0105 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0111 ] Assuming zero filled SBK key
[ 0.0116 ]
[ 0.0122 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0151 ]
[ 0.0156 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0162 ]
[ 0.0168 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0173 ] RCM 0 is saved as rcm_0.rcm
[ 0.0196 ] RCM 1 is saved as rcm_1.rcm
[ 0.0196 ] RCM 2 is saved as rcm_2.rcm
[ 0.0196 ] List of rcm files are saved in rcm_list.xml
[ 0.0197 ]
[ 0.0197 ] Signing RCM messages
[ 0.0202 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0208 ] Assuming zero filled SBK key
[ 0.0212 ]
[ 0.0212 ] Copying signature to RCM mesages
[ 0.0218 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0228 ]
[ 0.0229 ] Boot Rom communication
[ 0.0234 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 0.0239 ] BR_CID: 0x88021911647076c20800000013fd0140
[ 0.0244 ] RCM version 0X190001
[ 0.0400 ] Boot Rom communication completed
[ 1.0591 ]
[ 2.0636 ] tegrarcm_v2 --isapplet
[ 2.0660 ] Applet version 01.00.0000
[ 2.0819 ]
[ 2.0850 ] tegrasign_v2 --key None --getmode mode.txt
[ 2.0874 ] Assuming zero filled SBK key
[ 2.0879 ]
[ 2.0882 ] Parsing partition layout
[ 2.0933 ] tegraparser_v2 --pt flash.xml.tmp
[ 2.0980 ]
[ 2.0981 ] Creating list of images to be signed
[ 2.1008 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 2.1032 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 2.1049 ] Header already present for mb1_t194_prod_sigheader.bin
[ 2.1068 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 2.1194 ] Header already present for mb1_t194_prod_sigheader.bin
[ 2.1211 ] adding BCH for spe_t194.bin
[ 2.1307 ] adding BCH for spe_t194.bin
[ 2.1358 ] adding BCH for nvtboot_t194.bin
[ 2.1397 ] adding BCH for nvtboot_t194.bin
[ 2.1452 ] Header already present for preboot_c10_prod_cr.bin
[ 2.1501 ] Header already present for preboot_c10_prod_cr.bin
[ 2.1504 ] Header already present for mce_c10_prod_cr.bin
[ 2.1508 ] Header already present for mce_c10_prod_cr.bin
[ 2.1526 ] adding BCH for mts_c10_prod_cr.bin
[ 2.1559 ] adding BCH for mts_c10_prod_cr.bin
[ 2.2183 ] adding BCH for cboot_t194.bin
[ 2.2772 ] adding BCH for cboot_t194.bin
[ 2.2846 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 2.2920 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 2.2967 ] adding BCH for tos-trusty_t194.img
[ 2.3013 ] adding BCH for tos-trusty_t194.img
[ 2.3075 ] adding BCH for eks.img
[ 2.3136 ] adding BCH for eks.img
[ 2.3137 ] adding BCH for bpmp_t194.bin
[ 2.3141 ] adding BCH for bpmp_t194.bin
[ 2.3288 ] adding BCH for tegra194-a02-bpmp-p2888-a01.dtb
[ 2.3438 ] adding BCH for tegra194-a02-bpmp-p2888-a01.dtb
[ 2.3566 ] adding BCH for camera-rtcpu-rce.img
[ 2.3694 ] adding BCH for camera-rtcpu-rce.img
[ 2.3739 ] adding BCH for adsp-fw.bin
[ 2.3796 ] adding BCH for adsp-fw.bin
[ 2.3814 ] Header already present for warmboot_t194_prod.bin
[ 2.3833 ] Header already present for warmboot_t194_prod.bin
[ 2.3839 ] adding BCH for boot.img
[ 2.4006 ] adding BCH for boot.img
[ 3.0883 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 3.8084 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 3.8177 ]
[ 3.8177 ] Filling MB1 storage info
[ 3.8177 ] Generating br-bct
[ 3.8184 ] Performing cfg overlay
[ 3.8184 ] [‘tegra194-mb1-bct-memcfg-p2888.cfg’, ‘tegra194-memcfg-sw-override.cfg’]
[ 3.8186 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1.cfg
[ 3.8471 ]
[ 3.8471 ] Updating dev and MSS params in BR BCT
[ 3.8472 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.8856 ]
[ 3.8856 ] Updating bl info
[ 3.8863 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 3.8876 ]
[ 3.8877 ] Generating signatures
[ 3.8883 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 3.8888 ] Assuming zero filled SBK key
[ 4.0173 ]
[ 4.0174 ] Send BCT from Host
[ 4.0175 ] Generating br-bct
[ 4.0202 ] Performing cfg overlay
[ 4.0203 ] [‘/Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1.cfg’]
[ 4.0204 ] Updating dev and MSS params in BR BCT
[ 4.0205 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 4.0989 ]
[ 4.0990 ] Updating bl info
[ 4.0996 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 4.1013 ]
[ 4.1013 ] Updating smd info
[ 4.1018 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 4.1025 ]
[ 4.1025 ] Updating Odmdata
[ 4.1030 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 4.1037 ]
[ 4.1038 ] Get Signed section of bct
[ 4.1043 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 4.1049 ]
[ 4.1055 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 4.1060 ] Assuming zero filled SBK key
[ 4.1062 ]
[ 4.1062 ] Updating BCT with signature
[ 4.1069 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 4.1076 ]
[ 4.1076 ] Generating coldboot mb1-bct
[ 4.1083 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.1088 ] MB1-BCT version: 0x1
[ 4.1091 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.1093 ] Added Platform Config 0 data with size :- 3008
[ 4.1104 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.1106 ] Added Platform Config 1 data with size :- 19640
[ 4.1194 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.1196 ] Added Platform Config 2 data with size :- 24
[ 4.1198 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg
[ 4.1200 ] File read failed
[ 4.1201 ] File read failed
[ 4.1201 ] Added Platform Config 4 data with size :- 380
[ 4.1203 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.1206 ] Added Platform Config 3 data with size :- 92
[ 4.1207 ]
[ 4.1207 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.1207 ] Added Platform Config 5 data with size :- 56
[ 4.1208 ]
[ 4.1208 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.1208 ] Added Platform Config 7 data with size :- 392
[ 4.1208 ]
[ 4.1208 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.1208 ] Added Platform Config 8 data with size :- 12
[ 4.1208 ]
[ 4.1208 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.1208 ] Added Platform Config 9 data with size :- 32
[ 4.1208 ]
[ 4.1208 ] Updating mb1-bct with firmware information
[ 4.1216 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.1221 ] MB1-BCT version: 0x1
[ 4.1223 ]
[ 4.1223 ] Updating mb1-bct with storage information
[ 4.1229 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.1234 ] MB1-BCT version: 0x1
[ 4.1236 ]
[ 4.1241 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 4.1247 ]
[ 4.1253 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 4.1258 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 4.1264 ]
[ 4.1273 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.1279 ] Assuming zero filled SBK key
[ 4.1283 ]
[ 4.1291 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 4.1304 ]
[ 4.1305 ] Generating recovery mb1-bct
[ 4.1311 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.1317 ] MB1-BCT version: 0x1
[ 4.1319 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.1322 ] Added Platform Config 0 data with size :- 3008
[ 4.1333 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.1335 ] Added Platform Config 1 data with size :- 19640
[ 4.1435 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.1438 ] Added Platform Config 2 data with size :- 24
[ 4.1439 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a01-p2822-0000.cfg
[ 4.1442 ] File read failed
[ 4.1443 ] File read failed
[ 4.1443 ] Added Platform Config 4 data with size :- 380
[ 4.1445 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.1447 ] Added Platform Config 3 data with size :- 92
[ 4.1449 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.1450 ] Added Platform Config 5 data with size :- 56
[ 4.1450 ]
[ 4.1450 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.1450 ] Added Platform Config 7 data with size :- 392
[ 4.1450 ]
[ 4.1450 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.1450 ] Added Platform Config 8 data with size :- 12
[ 4.1450 ]
[ 4.1450 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.1450 ] Added Platform Config 9 data with size :- 32
[ 4.1451 ]
[ 4.1451 ] Updating mb1-bct with firmware information
[ 4.1457 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.1463 ] MB1-BCT version: 0x1
[ 4.1466 ]
[ 4.1467 ] Updating mb1-bct with storage information
[ 4.1472 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.1477 ] MB1-BCT version: 0x1
[ 4.1479 ]
[ 4.1485 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 4.1490 ]
[ 4.1496 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 4.1502 ] adding BCH for mb1_bct_MB1.bct
[ 4.1507 ]
[ 4.1514 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.1520 ] Assuming zero filled SBK key
[ 4.1522 ]
[ 4.1529 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 4.1538 ]
[ 4.1538 ] Generating coldboot mem-bct
[ 4.1544 ] tegrabct_v2 --chip 0x19 0 --sdram /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1.cfg --membct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_1.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_2.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_3.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_4.bct
[ 4.1548 ] Packing sdram param for instance[0]
[ 4.1930 ] Packing sdram param for instance[1]
[ 4.1931 ] Packing sdram param for instance[2]
[ 4.1933 ] Packing sdram param for instance[3]
[ 4.1933 ] Packing sdram param for instance[4]
[ 4.1933 ] Packing sdram param for instance[5]
[ 4.1934 ] Packing sdram param for instance[6]
[ 4.1934 ] Packing sdram param for instance[7]
[ 4.1934 ] Packing sdram param for instance[8]
[ 4.1934 ] Packing sdram param for instance[9]
[ 4.1934 ] Packing sdram param for instance[10]
[ 4.1934 ] Packing sdram param for instance[11]
[ 4.1934 ] Packing sdram param for instance[12]
[ 4.1934 ] Packing sdram param for instance[13]
[ 4.1934 ] Packing sdram param for instance[14]
[ 4.1934 ] Packing sdram param for instance[15]
[ 4.1934 ]
[ 4.1934 ] Getting sector size from pt
[ 4.1941 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 4.1946 ]
[ 4.1947 ] BlockSize read from layout is 200
[ 4.1952 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_1.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_2.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_3.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_4.bct
[ 4.1957 ] adding BCH for /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_1.bct
[ 4.1976 ]
[ 4.1981 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 4.1987 ]
[ 4.1992 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 4.1997 ] Header already present for mem_coldboot.bct
[ 4.1999 ]
[ 4.2006 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.2011 ] Assuming zero filled SBK key
[ 4.2014 ]
[ 4.2020 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 4.2029 ]
[ 4.2030 ] Generating recovery mem-bct
[ 4.2037 ] tegrabct_v2 --chip 0x19 0 --sdram /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1.cfg --membct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_1.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_2.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_3.bct /Documents/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/8617/tmpjw0y8i2e1_4.bct
[ 4.2043 ] Packing sdram param for instance[0]
[ 4.2457 ] Packing sdram param for instance[1]
[ 4.2459 ] Packing sdram param for instance[2]
[ 4.2461 ] Packing sdram param for instance[3]
[ 4.2461 ] Packing sdram param for instance[4]
[ 4.2461 ] Packing sdram param for instance[5]
[ 4.2461 ] Packing sdram param for instance[6]
[ 4.2461 ] Packing sdram param for instance[7]
[ 4.2461 ] Packing sdram param for instance[8]
[ 4.2461 ] Packing sdram param for instance[9]
[ 4.2461 ] Packing sdram param for instance[10]
[ 4.2461 ] Packing sdram param for instance[11]
[ 4.2461 ] Packing sdram param for instance[12]
[ 4.2461 ] Packing sdram param for instance[13]
[ 4.2461 ] Packing sdram param for instance[14]
[ 4.2461 ] Packing sdram param for instance[15]
[ 4.2461 ]
[ 4.2471 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 4.2479 ]
[ 4.2485 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 4.2492 ] adding BCH for mem_rcm.bct
[ 4.2503 ]
[ 4.2511 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.2517 ] Assuming zero filled SBK key
[ 4.2519 ]
[ 4.2526 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 4.2538 ]
[ 4.2539 ] Sending BCTs
[ 4.2545 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 4.2550 ] Applet version 01.00.0000
[ 4.2772 ] Sending bct_bootrom
[ 4.2774 ] […] 100%
[ 4.2784 ] Sending bct_mb1
[ 4.2832 ] […] 100%
[ 4.2868 ] Sending bct_mem
[ 4.3455 ] […] 100%
[ 4.4638 ]
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed to flash/read t186ref.
