Im currently using a JetsonTX2 with a Cogswell carrier board, and I have been having lots of troubles with CUDA, Nvidia and getting other things setup. I have attached below the logs from cuda, nvidia and the output of what I got from flashing. Thanks in advance for any help in solving this issue.
Edit:
I have tried using the .deb files aswell and I get dependency problems
cuda-installer.log (579 Bytes)
nvidia-installer.log (29.4 KB)
CTI FLASH
1. Astro
2. Elroy
3. Orbitty
4. Spacely
5. Sprocket
6. Rudi
7. Cogswell
8. Rosie
9. Graphite VPX
10. Quasar
x. Exit
Enter choice: 7
TX2 Version
1. TX2
2. TX2i
3. TX2-4G
4. Cancel (back to main menu)
Enter choice: 1
# L4T BSP Information:
# R32 , REVISION: 7.2
# Target Board Information:
# Name: cti-tx2-asg007-00, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x18 --applet "/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0175 ] Generating RCM messages
[ 0.0233 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0254 ] RCM 0 is saved as rcm_0.rcm
[ 0.0278 ] RCM 1 is saved as rcm_1.rcm
[ 0.0278 ] List of rcm files are saved in rcm_list.xml
[ 0.0278 ]
[ 0.0278 ] Signing RCM messages
[ 0.0332 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0338 ] Assuming zero filled SBK key
[ 0.0638 ] Copying signature to RCM mesages
[ 0.0681 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0744 ]
[ 0.0754 ] Boot Rom communication
[ 0.0814 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0840 ] RCM version 0X180001
[ 0.1960 ] Boot Rom communication completed
[ 1.2131 ]
[ 2.2198 ] tegrarcm_v2 --isapplet
[ 2.2215 ] Applet version 01.00.0000
[ 2.3589 ]
[ 2.3616 ] Retrieving EEPROM data
[ 2.3617 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 2.3627 ] Applet version 01.00.0000
[ 2.4991 ] Saved platform info in /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 2.6401 ]
Copy /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG007.dtb to /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG007.dtb.rec
copying bctfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)... done.
copying misc_config(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying pmc_config(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img kernel
version 1.0.0
[ 0.0005 ] Generating signature
[ 0.0042 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0043 ] Assuming zero filled SBK key : not reading
[ 0.0043 ] sign_type : 0
[ 0.0043 ] header_magic: 414e4452
[ 0.0075 ] tegrahost_v2 --chip 0x18 --align 1_boot.img
[ 0.0087 ]
[ 0.0114 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_boot.img zerosbk
[ 0.0140 ]
[ 0.0183 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.0184 ] Assuming zero filled SBK key : not reading
[ 0.0381 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 0.0442 ]
[ 0.0459 ] Signed file: /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x18: Don't need to do anything
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.253-tegra
~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra
115334 blocks
Making Recovery image...
copying recdtbfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG007.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000411362 s, 48.6 kB/s
Existing sosfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing cpu_bootloader(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG007.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign kernel_tegra186-tx2-cti-ASG007.dtb kernel_dtb
version 1.0.0
[ 0.0013 ] Generating signature
[ 0.0059 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0061 ] Assuming zero filled SBK key : not reading
[ 0.0059 ] sign_type : 1937076323
[ 0.0059 ] header_magic: d00dfeed
[ 0.0094 ] tegrahost_v2 --chip 0x18 --align 1_kernel_tegra186-tx2-cti-ASG007.dtb
[ 0.0141 ]
[ 0.0199 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_kernel_tegra186-tx2-cti-ASG007.dtb zerosbk
[ 0.0245 ]
[ 0.0361 ] tegrasign_v3.py --key --list 1_kernel_tegra186-tx2-cti-ASG007_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0364 ] Assuming zero filled SBK key : not reading
[ 0.0626 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_kernel_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt 1_kernel_tegra186-tx2-cti-ASG007_sigheader.dtb.hash zerosbk
[ 0.0678 ]
[ 0.0696 ] Signed file: /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt
done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra186-tx2-cti-ASG007.dtb to rootfs... done.
Making system.img...
populating rootfs from /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG007.dtb)... done.
copying cfgfile(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_lpddr4_A02_l4t.cfg --odmdata 0x2090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-tx2-cti-ASG007.dtb"
saving flash command in /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/ecoation/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0219 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0222 ] Assuming zero filled SBK key
[ 0.0052 ] Generating RCM messages
[ 0.0118 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0139 ] RCM 0 is saved as rcm_0.rcm
[ 0.0203 ] RCM 1 is saved as rcm_1.rcm
[ 0.0208 ] List of rcm files are saved in rcm_list.xml
[ 0.0208 ]
[ 0.0208 ] Signing RCM messages
[ 0.0423 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0424 ] Assuming zero filled SBK key
[ 0.0641 ] Copying signature to RCM mesages
[ 0.0686 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0722 ]
[ 0.0723 ] Parsing partition layout
[ 0.0782 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0869 ]
[ 0.0875 ] Using default ramcode: 0
[ 0.0879 ] Disable BPMP dtb trim, using default dtb
[ 0.0880 ]
[ 0.0881 ] Creating list of images to be signed
[ 0.0950 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.3534 ]
[ 0.3535 ] Generating signatures
[ 0.3746 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.3747 ] Assuming zero filled SBK key
[ 2.1434 ] Generating br-bct
[ 2.1513 ] Updating dev and MSS params in BR BCT
[ 2.1515 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 2.2123 ]
[ 2.2125 ] Updating bl info
[ 2.2176 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 2.2237 ]
[ 2.2239 ] Updating smd info
[ 2.2299 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 2.2339 ]
[ 2.2341 ] Updating Odmdata
[ 2.2394 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x2090000
[ 2.2438 ]
[ 2.2439 ] Get Signed section of bct
[ 2.2492 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 2.2539 ]
[ 2.2609 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 2.2645 ] Assuming zero filled SBK key
[ 2.3807 ]
[ 2.3808 ] Updating BCT with signature
[ 2.3850 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 2.3875 ]
[ 2.3877 ] Generating coldboot mb1-bct
[ 2.3921 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 2.3947 ] MB1-BCT version: 0xf
[ 2.3954 ] Packing sdram param for instance[0]
[ 2.4426 ] Packing sdram param for instance[1]
[ 2.4437 ] Packing sdram param for instance[2]
[ 2.4448 ] Packing sdram param for instance[3]
[ 2.4510 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 2.4525 ] Appending platform config data of size :- 3032
[ 2.4538 ] Parsing config file :mobile_scr.cfg
[ 2.4540 ] Appending platform config data of size :- 12240
[ 2.4643 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 2.4659 ] Appending platform config data of size :- 24
[ 2.4707 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 2.4710 ] Appending platform config data of size :- 672
[ 2.4823 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 2.4869 ] Appending platform config data of size :- 64
[ 2.4921 ]
[ 2.4922 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 2.4923 ] Appending platform config data of size :- 1628
[ 2.4924 ]
[ 2.4926 ] Updating mb1-bct with firmware information
[ 2.4987 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.5014 ] MB1-BCT version: 0xf
[ 2.5035 ]
[ 2.5036 ] Updating mb1-bct with storage information
[ 2.5085 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 2.5129 ] MB1-BCT version: 0xf
[ 2.5159 ]
[ 2.5215 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 2.5255 ]
[ 2.5303 ] tegrahost_v2 --chip 0x18 0 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 2.5337 ]
[ 2.5579 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 2.5582 ] Assuming zero filled SBK key
[ 2.5559 ] tegrahost_v2 --chip 0x18 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 2.5585 ]
[ 2.5587 ] Generating recovery mb1-bct
[ 2.5604 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 2.5617 ] MB1-BCT version: 0xf
[ 2.5620 ] Packing sdram param for instance[0]
[ 2.5966 ] Packing sdram param for instance[1]
[ 2.5970 ] Packing sdram param for instance[2]
[ 2.5973 ] Packing sdram param for instance[3]
[ 2.5977 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 2.5981 ] Appending platform config data of size :- 3032
[ 2.5985 ] Parsing config file :minimal_scr.cfg
[ 2.5987 ] Appending platform config data of size :- 12240
[ 2.6050 ]
[ 2.6050 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 2.6051 ] Appending platform config data of size :- 24
[ 2.6051 ]
[ 2.6052 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 2.6052 ] Appending platform config data of size :- 672
[ 2.6052 ]
[ 2.6053 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 2.6053 ] Appending platform config data of size :- 64
[ 2.6053 ]
[ 2.6054 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 2.6054 ] Appending platform config data of size :- 1628
[ 2.6054 ]
[ 2.6055 ] Updating mb1-bct with firmware information
[ 2.6110 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.6132 ] MB1-BCT version: 0xf
[ 2.6143 ]
[ 2.6144 ] Updating mb1-bct with storage information
[ 2.6169 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 2.6191 ] MB1-BCT version: 0xf
[ 2.6290 ]
[ 2.6337 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 2.6360 ]
[ 2.6400 ] tegrahost_v2 --chip 0x18 0 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 2.6441 ]
[ 2.6694 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 2.6696 ] Assuming zero filled SBK key
[ 2.6674 ] tegrahost_v2 --chip 0x18 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 2.6715 ]
[ 2.6720 ] Copying signatures
[ 2.6799 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 3.0315 ]
[ 3.0317 ] Boot Rom communication
[ 3.0365 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 3.0389 ] BootRom is not running
[ 8.6324 ]
[ 9.6388 ] tegrarcm_v2 --isapplet
[ 9.6419 ] Applet version 01.00.0000
[ 10.0981 ]
[ 10.0982 ] Sending BCTs
[ 10.1036 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 10.1065 ] Applet version 01.00.0000
[ 10.2409 ] Sending bct_bootrom
[ 10.2418 ] [................................................] 100%
[ 10.2768 ] Sending bct_mb1
[ 10.2989 ] [................................................] 100%
[ 10.3692 ]
[ 10.3695 ] Generating blob
[ 10.3738 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 10.3781 ]
[ 10.3856 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 10.3908 ]
[ 10.4140 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.4142 ] Assuming zero filled SBK key
[ 10.4282 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 10.4345 ]
[ 10.4384 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 10.4427 ]
[ 10.4470 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 10.4545 ]
[ 10.4783 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.4787 ] Assuming zero filled SBK key
[ 10.4864 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 10.4907 ]
[ 10.4966 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 10.5001 ]
[ 10.5065 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 10.5102 ]
[ 10.5339 ] tegrasign_v3.py --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.5342 ] Assuming zero filled SBK key
[ 10.5293 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 10.5321 ]
[ 10.5373 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 10.5393 ]
[ 10.5431 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 10.5501 ]
[ 10.5731 ] tegrasign_v3.py --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.5732 ] Assuming zero filled SBK key
[ 10.6106 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 10.6217 ]
[ 10.6264 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 10.6288 ]
[ 10.6322 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_bpmp.bin zerosbk
[ 10.6359 ]
[ 10.6584 ] tegrasign_v3.py --key None --list blob_bpmp_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 10.6585 ] Assuming zero filled SBK key
[ 10.6755 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 10.6841 ]
[ 10.6893 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 10.6923 ]
[ 10.6959 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 10.7018 ]
[ 10.7253 ] tegrasign_v3.py --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 10.7254 ] Assuming zero filled SBK key
[ 10.7343 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 10.7386 ]
[ 10.7432 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[ 10.7456 ]
[ 10.7481 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tos-trusty.img zerosbk
[ 10.7538 ]
[ 10.7772 ] tegrasign_v3.py --key None --list blob_tos-trusty_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 10.7775 ] Assuming zero filled SBK key
[ 10.7868 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[ 10.7940 ]
[ 10.7988 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 10.8028 ]
[ 10.8083 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_eks.img zerosbk
[ 10.8122 ]
[ 10.8336 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 10.8340 ] Assuming zero filled SBK key
[ 10.8304 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 10.8329 ]
[ 10.8364 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-tx2-cti-ASG007.dtb
[ 10.8383 ]
[ 10.8420 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tegra186-tx2-cti-ASG007.dtb zerosbk
[ 10.8472 ]
[ 10.8712 ] tegrasign_v3.py --key None --list blob_tegra186-tx2-cti-ASG007_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 10.8715 ] Assuming zero filled SBK key
[ 10.8786 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt blob_tegra186-tx2-cti-ASG007_sigheader.dtb.hash zerosbk
[ 10.8835 ]
[ 10.8895 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 10.8911 ] number of images in blob are 9
[ 10.8918 ] blobsize is 4431304
[ 10.8921 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 225168
[ 10.8945 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 122272
[ 10.8960 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 58384
[ 10.8971 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2236640
[ 10.8978 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 534816
[ 10.8989 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 605120
[ 10.9009 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 403264
[ 10.9009 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 10.9009 ] Added binary blob_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt of size 244048
[ 10.9010 ]
[ 10.9010 ] Sending bootloader and pre-requisite binaries
[ 10.9033 ] tegrarcm_v2 --download blob blob.bin
[ 10.9057 ] Applet version 01.00.0000
[ 11.1922 ] Sending blob
[ 11.1926 ] [................................................] 100%
[ 12.1100 ]
[ 12.1158 ] tegrarcm_v2 --boot recovery
[ 12.1195 ] Applet version 01.00.0000
[ 12.4193 ]
[ 13.4284 ] tegrarcm_v2 --isapplet
[ 13.8360 ]
[ 13.8416 ] tegradevflash_v2 --iscpubl
[ 13.8445 ] Cannot Open USB
[ 13.9989 ]
[ 15.0032 ] tegrarcm_v2 --isapplet
[ 15.1393 ]
[ 15.1415 ] tegradevflash_v2 --iscpubl
[ 15.1435 ] Bootloader version 01.00.0000
[ 15.2914 ] Bootloader version 01.00.0000
[ 15.3490 ]
[ 15.3491 ] Retrieving storage infomation
[ 15.3533 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 15.3551 ] Applet is not running on device. Continue with Bootloader
[ 15.5448 ]
[ 15.5498 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 15.5523 ] Bootloader version 01.00.0000
[ 15.7159 ] Saved platform info in storage_info.bin
[ 15.7760 ]
[ 15.7763 ] Flashing the device
[ 15.7819 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 15.7877 ]
[ 15.7926 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 15.7960 ] Bootloader version 01.00.0000
[ 15.9667 ] Erasing sdmmc_boot: 3 ......... [Done]
[ 16.0135 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin
[ 16.0153 ] [................................................] 100%
[ 16.1216 ] Erasing sdmmc_user: 3 ......... [Done]
[ 18.0418 ] Writing partition master_boot_record with mbr_1_3.bin
[ 18.0435 ] [................................................] 100%
[ 18.0793 ] Writing partition primary_gpt with gpt_primary_1_3.bin
[ 18.1091 ] [................................................] 100%
[ 18.1504 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin
[ 18.1793 ] [................................................] 100%
[ 18.2446 ] Writing partition mb1 with mb1_prod.bin.encrypt
[ 18.2462 ] [................................................] 100%
[ 18.2929 ] Writing partition mb1_b with mb1_prod.bin.encrypt
[ 18.3385 ] [................................................] 100%
[ 18.3745 ] Writing partition spe-fw with spe_sigheader.bin.encrypt
[ 18.4205 ] [................................................] 100%
[ 18.4646 ] Writing partition spe-fw_b with spe_sigheader.bin.encrypt
[ 18.5220 ] [................................................] 100%
[ 18.5710 ] Writing partition mb2 with nvtboot_sigheader.bin.encrypt
[ 18.6206 ] [................................................] 100%
[ 18.6679 ] Writing partition mb2_b with nvtboot_sigheader.bin.encrypt
[ 18.7288 ] [................................................] 100%
[ 18.7743 ] Writing partition mts-preboot with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 18.8400 ] [................................................] 100%
[ 18.8843 ] Writing partition mts-preboot_b with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 18.9553 ] [................................................] 100%
[ 18.9868 ] Writing partition SMD with slot_metadata.bin
[ 19.0607 ] [................................................] 100%
[ 19.0980 ] Writing partition SMD_b with slot_metadata.bin
[ 19.1236 ] [................................................] 100%
[ 19.1574 ] Writing partition VER_b with emmc_bootblob_ver.txt
[ 19.1799 ] [................................................] 100%
[ 19.2136 ] Writing partition VER with emmc_bootblob_ver.txt
[ 19.2796 ] [................................................] 100%
[ 19.3124 ] Writing partition master_boot_record with mbr_1_3.bin
[ 19.3429 ] [................................................] 100%
[ 19.3716 ] Writing partition APP with system.img
[ 19.3944 ] [................................................] 100%
[ 775.2220 ] Writing partition mts-bootpack with mce_mts_d15_prod_cr_sigheader.bin.encrypt
[ 775.2673 ] [................................................] 100%
[ 775.5588 ] Writing partition mts-bootpack_b with mce_mts_d15_prod_cr_sigheader.bin.encrypt
[ 775.5822 ] [................................................] 100%
[ 775.8620 ] Writing partition cpu-bootloader with cboot_sigheader.bin.encrypt
[ 775.8882 ] [................................................] 100%
[ 775.9528 ] Writing partition cpu-bootloader_b with cboot_sigheader.bin.encrypt
[ 775.9809 ] [................................................] 100%
[ 776.0473 ] Writing partition bootloader-dtb with tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt
[ 776.0758 ] [................................................] 100%
[ 776.1374 ] Writing partition bootloader-dtb_b with tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt
[ 776.1660 ] [................................................] 100%
[ 776.2240 ] Writing partition secure-os with tos-trusty_sigheader.img.encrypt
[ 776.2515 ] [................................................] 100%
[ 776.3284 ] Writing partition secure-os_b with tos-trusty_sigheader.img.encrypt
[ 776.3555 ] [................................................] 100%
[ 776.4295 ] Writing partition eks with eks_sigheader.img.encrypt
[ 776.4570 ] [................................................] 100%
[ 776.4933 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt
[ 776.5151 ] [................................................] 100%
[ 776.5554 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt
[ 776.5821 ] [................................................] 100%
[ 776.6231 ] Writing partition bpmp-fw with bpmp_sigheader.bin.encrypt
[ 776.6503 ] [................................................] 100%
[ 776.7397 ] Writing partition bpmp-fw_b with bpmp_sigheader.bin.encrypt
[ 776.7659 ] [................................................] 100%
[ 776.8516 ] Writing partition bpmp-fw-dtb with tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt
[ 776.8836 ] [................................................] 100%
[ 776.9748 ] Writing partition bpmp-fw-dtb_b with tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt
[ 777.0056 ] [................................................] 100%
[ 777.0994 ] Writing partition sce-fw with camera-rtcpu-sce_sigheader.img.encrypt
[ 777.1310 ] [................................................] 100%
[ 777.1759 ] Writing partition sce-fw_b with camera-rtcpu-sce_sigheader.img.encrypt
[ 777.1975 ] [................................................] 100%
[ 777.2435 ] Writing partition sc7 with warmboot_wbheader.bin.encrypt
[ 777.2756 ] [................................................] 100%
[ 777.3075 ] Writing partition sc7_b with warmboot_wbheader.bin.encrypt
[ 777.3283 ] [................................................] 100%
[ 777.3661 ] Writing partition BMP with bmp.blob
[ 777.3822 ] [................................................] 100%
[ 777.4336 ] Writing partition BMP_b with bmp.blob
[ 777.4589 ] [................................................] 100%
[ 777.5059 ] Writing partition recovery with recovery_sigheader.img.encrypt
[ 777.5305 ] [................................................] 100%
[ 784.1160 ] Writing partition recovery-dtb with tegra186-tx2-cti-ASG007.dtb_sigheader.rec.encrypt
[ 784.1516 ] [................................................] 100%
[ 784.2104 ] Writing partition kernel-bootctrl with kernel_bootctrl.bin
[ 784.2341 ] [................................................] 100%
[ 784.2718 ] Writing partition kernel-bootctrl_b with kernel_bootctrl.bin
[ 784.2959 ] [................................................] 100%
[ 784.3289 ] Writing partition kernel with boot_sigheader.img.encrypt
[ 784.3509 ] [................................................] 100%
[ 784.4403 ] Writing partition kernel_b with boot_sigheader.img.encrypt
[ 784.4729 ] [................................................] 100%
[ 784.5613 ] Writing partition kernel-dtb with kernel_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt
[ 784.5948 ] [................................................] 100%
[ 784.6546 ] Writing partition kernel-dtb_b with kernel_tegra186-tx2-cti-ASG007_sigheader.dtb.encrypt
[ 784.6822 ] [................................................] 100%
[ 784.7669 ]
[ 784.7748 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 784.7767 ] Bootloader version 01.00.0000
[ 784.9178 ] Writing partition BCT with br_bct_BR.bct
[ 784.9187 ] [................................................] 100%
[ 785.0288 ]
[ 785.0383 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 785.0406 ] Bootloader version 01.00.0000
[ 785.1793 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 785.1813 ] [................................................] 100%
[ 785.3017 ]
[ 785.3071 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 785.3103 ] Bootloader version 01.00.0000
[ 785.4495 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 785.4519 ] [................................................] 100%
[ 785.5578 ]
[ 785.5580 ] Flashing completed
[ 785.5581 ] Coldbooting the device
[ 785.5630 ] tegradevflash_v2 --reboot coldboot
[ 785.5656 ] Bootloader version 01.00.0000
[ 785.7618 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC
