Dear All!
I have used a tool python tool gpu-utils
to control how much each process running tensorflow-gpu takes memory.
It uses nvidia-smi which does not seem to be in jetson nano.
Can one install nvidia-smi on jetson nano or are there other tools to obtain info about gpu usage?
Terveisin, Markus
Hi Markus, nvidia-smi isn’t supported on Tegra-based platforms. Instead please try the tegrastats utility, you can launch it by running “sudo tegrastats” from the terminal.
See here for the documentation on tegrastats tool: [url]Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
Hi dusty_nv
I have read the documentation on tegrastats tool.
but the follow param don’t explain:
POM_5V_IN 1402/1793 POM_5V_GPU 40/45
Thanks for your help.
Hi southcamel, POM_5V_IN is the total power that the board is consuming. POM_5V_GPU is the power rail feeding the GPU, so it reports only how much power the GPU is consuming.
Hi dusty_nv
Thanks for your quickly reply.
Can we know the memory-usage on GPU, like the information shows use nvidia-smi.
Thanks very much.
try with ‘jtop’, better as sudo as themself says
that is exactly what i need. I salute you @pedro.valdes.guzman
