Does NVML fully support Jetson Orin GPU devices
As the title suggests, I found that the nvidia-smi command cannot display GPU usage information. I wrote a Python script to retrieve GPU usage information through nvml, but it also failed. The device is Jetson AGX ORIN
Thanks for visiting the NVIDIA Developer forums. Your topic will be best served in the Jetson category.
I have moved this post for better visibility.
Cheers,
Tom
NVIDIA management library (NVML) library is not supported on Jetson but you can use tegrastats to monitor the device status instead:
$ sudo tegrastats
You can find the related info in our document below:
