Yesterday I was running some deep learning codes and this morning I find it rebooting itself again and again. I really don’t know what happend.
Here is the startup log file.
startup log.txt (110.2 KB)
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB3, 10:11:54
Press CTRL-A Z for help on special keys
[0000.177] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0000.186] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.191] I> Boot-mode: Coldboot
[0000.194] I> Chip revision : A02P
[0000.197] I> Bootrom patch version : 15 (correctly patched)
[0000.202] I> ATE fuse revision : 0x200
[0000.206] I> Ram repair fuse : 0x0
[0000.209] I> Ram Code : 0x2
[0000.212] I> rst_source : 0x0
[0000.214] I> rst_level : 0x0
[0000.218] I> Boot-device: eMMC
[0000.233] I> sdmmc DDR50 mode
[0000.237] I> Active Boot chain : 1
[0000.240] I> Boot-device: eMMC
[0000.244] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.252] I> Temperature = 25500
[0000.255] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.259] W> Skipping boost for clk: BPMP_APB
[0000.263] W> Skipping boost for clk: AXI_CBB
[0000.267] W> Skipping boost for clk: AON_CPU_NIC
[0000.271] W> Skipping boost for clk: CAN1
[0000.275] W> Skipping boost for clk: CAN2
[0000.279] I> Boot-device: eMMC
[0000.282] I> Boot-device: eMMC
[0000.291] I> Sdmmc: HS400 mode enabled
[0000.296] I> ECC region[0]: Start:0x0, End:0x0
[0000.300] I> ECC region[1]: Start:0x0, End:0x0
[0000.304] I> ECC region[2]: Start:0x0, End:0x0
[0000.308] I> ECC region[3]: Start:0x0, End:0x0
[0000.312] I> ECC region[4]: Start:0x0, End:0x0
[0000.316] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.322] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.327] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.331] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.336] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.341] E> FAILED: Thermal config
[0000.348] E> FAILED: MEMIO rail config
[0000.367] I> Boot-device: eMMC
[0000.376] I> sdmmc bdev is already initialized
[0000.448] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.457] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-38950)
[0000.457] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.458] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.459] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.464] W> device prod register failed
[0000.468] I> Boot-device: eMMC
[0000.471] I> Boot_device: SDMMC_BOOT instance: 3
[0000.477] I> sdmmc-3 params source = boot args
[0000.480] I> sdmmc bdev is already initialized
[0000.484] I> sdmmc-3 params source = boot args
[0000.491] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.498] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.500] I> Active Boot chain : 1
[0000.503] I> parsing oem signed section of bpmp-fw header done
[0000.508] I> bpmp-fw binary init read from storage
[0000.513] I> oem authentication of bpmp-fw header done
[0000.520] I> bpmp-fw binary done read from storage
[0000.523] I> bpmp-fw: Authentication init Done
[0000.527] I> parsing oem signed section of cpubl header done
[0000.532] I> cpubl binary init read from storage
[0000.537] I> bpmp-fw: Authentication Finalize Done
[0000.542] I> oem authentication of cpubl header done
[0000.546] I> cpubl binary done read from storage
[0000.551] I> cpubl: Authentication init Done
[0000.556] I> parsing oem signed section of rce header done
[0000.560] I> rce binary init read from storage
[0000.565] I> Relocating BR-BCT
[0000.568] I> cpubl: Authentication Finalize Done
[0000.572] I> oem authentication of rce header done
[0000.576] I> rce binary done read from storage
[0000.581] I> rce: Authentication init Done
[0000.586] I> parsing oem signed section of ape header done
[0000.590] I> ape binary init read from storage
[0000.595] I> rce: Authentication Finalize Done
[0000.599] I> oem authentication of ape header done
[0000.603] I> ape binary done read from storage
[0000.608] I> ape: Authentication init Done
[0000.612] I> parsing oem signed section of tos header done
[0000.617] I> tos binary init read from storage
[0000.621] I> ape: Authentication Finalize Done
[0000.626] I> oem authentication of tos header done
[0000.630] I> tos binary done read from storage
[0000.634] I> tos: Authentication init Done
[0000.639] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.644] I> bpmp-fw-dtb binary init read from storage
[0000.649] I> tos: Authentication Finalize Done
[0000.655] I> oem authentication of bpmp-fw-dtb header done
[0000.662] I> bpmp-fw-dtb binary done read from storage
[0000.664] I> bpmp-fw-dtb: Authentication init Done
[0000.669] I> parsing oem signed section of cpubl-dtb header done
[0000.674] I> cpubl-dtb binary init read from storage
[0000.679] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.717] I> oem authentication of cpubl-dtb header done
[0000.717] I> cpubl-dtb binary done read from storage
[0000.718] I> cpubl-dtb: Authentication init Done
[0000.720] I> parsing oem signed section of eks header done
[0000.720] I> eks binary init read from storage
[0000.721] I> cpubl-dtb: Authentication Finalize Done
[0000.722] I> oem authentication of eks header done
[0000.725] I> eks binary done read from storage
[0000.730] I> eks: Authentication init Done
[0000.733] I> eks: Authentication Finalize Done
[0000.738] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 20:51:20, Oct 27 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.241] I> Welcome to Cboot
��fmon_post initialized
��[0001.242] I> Cboot Version: t194-aad9d75e
[0001.242] I> CPU-BL Params @ 0xf2820000
[0001.242] I> 0) Base:0x00000000 Size:0x00000000
[0001.246] I> 1) Base:0xf1100000 Size:0x00100000
[0001.250] I> 2) Base:0xf2000000 Size:0x00200000
[0001.255] I> 3) Base:0xf1200000 Size:0x00200000
��clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.259] I> 4) Base:0xf1000000 Size:0x00100000
[0001.364] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.369] I> 6) Base:0xf3800000 Size:0x00400000
[0001.373] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.378] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.382] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.387] I> 10) Base:0xf3000000 Size:0x00800000
[0001.391] I> 11) Base:0x40000000 Size:0x00040000
[0001.395] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.400] I> 13) Base:0x40046000 Size:0x00002000
��emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.404] I> 14) Base:0x40048000 Size:0x00002000
[0001.459] I> 15) Base:0xac000000 Size:0x00004000
[0001.464] I> 16) Base:0x4004a000 Size:0x00002000
[0001.468] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.473] I> 18) Base:0x4004c000 Size:0x00002000
[0001.477] I> 19) Base:0xf2200000 Size:0x00600000
[0001.482] I> 20) Base:0x4004e000 Size:0x00002000
[0001.486] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.491] I> 22) Base:0x00000000 Size:0x00000000
[0001.495] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.499] I> 24) Base:0xf6000000 Size:0x02000000
[0001.504] I> 25) Base:0x40050000 Size:0x00002000
[0001.508] I> 26) Base:0x40040000 Size:0x00006000
[0001.513] I> 27) Base:0xf1800000 Size:0x00400000
[0001.517] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.522] I> 29) Base:0xf1400000 Size:0x00400000
[0001.526] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.531] I> 31) Base:0x00000000 Size:0x00000000
[0001.535] I> 32) Base:0xf8000000 Size:0x08000000
[0001.540] I> 33) Base:0x00000000 Size:0x00000000
[0001.544] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.549] I> 35) Base:0xab000000 Size:0x01000000
[0001.553] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.557] I> 37) Base:0xf2800000 Size:0x00800000
[0001.562] I> 38) Base:0x80000000 Size:0x20000000
[0001.566] I> 39) Base:0xb0000000 Size:0x08000000
[0001.571] I> 40) Base:0x00000000 Size:0x00000000
[0001.575] I> 41) Base:0x00000000 Size:0x00000000
[0001.580] I> 42) Base:0x00000000 Size:0x00000000
[0001.584] I> 43) Base:0x00000000 Size:0x00000000
[0001.589] I> 44) Base:0x00000000 Size:0x00000000
[0001.593] I> 45) Base:0x00000000 Size:0x00000000
[0001.598] GIC-SPI Target CPU: 0
[0001.601] Interrupts Init done
[0001.603] calling constructors
[0001.606] initializing heap
[0001.609] I> Heap: [0xa0691568 … 0xab000000]
[0001.613] initializing threads
[0001.616] initializing timers
[0001.619] creating bootstrap completion thread
[0001.623] top of bootstrap2()
[0001.626] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.631] initializing platform
[0001.634] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.639] W> device prod register failed
[0001.643] I> Bl_dtb @0xaaf00000
[0001.649] W> “plugin-manager” doesn’t exist, creating
[0001.651] W> “ids” doesn’t exist, creating
[0001.655] W> “connection” doesn’t exist, creating
[0001.659] W> “configs” doesn’t exist, creating
[0001.671] I> Find /i2c@3160000’s alias i2c0
[0001.671] I> Reading eeprom i2c=0 address=0x50
[0001.697] I> Device at /i2c@3160000:0x50
[0001.697] I> Reading eeprom i2c=0 address=0x56
[0001.722] I> Device at /i2c@3160000:0x56
[0001.724] I> Find /i2c@3180000’s alias i2c2
[0001.725] I> Reading eeprom i2c=2 address=0x54
[0001.726] E> I2C: slave not found in slaves.
[0001.727] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start t.
[0001.728] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.728] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 a.
[0001.736] E> eeprom: Failed to read I2C slave device
[0001.741] I> Eeprom read failed 0x3526070d
[0001.745] I> Reading eeprom i2c=2 address=0x57
[0001.749] E> I2C: slave not found in slaves.
[0001.753] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.761] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.766] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.776] E> eeprom: Failed to read I2C slave device
[0001.781] I> Eeprom read failed 0x3526070d
[0001.785] I> Reading eeprom i2c=2 address=0x52
[0001.789] E> I2C: slave not found in slaves.
[0001.793] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.801] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.806] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.816] E> eeprom: Failed to read I2C slave device
[0001.821] I> Eeprom read failed 0x3526070d
[0001.826] I> Find /i2c@c240000’s alias i2c1
[0001.829] I> Reading eeprom i2c=1 address=0x52
[0001.834] E> I2C: slave not found in slaves.
[0001.837] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.845] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.851] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.860] E> eeprom: Retry to read I2C slave device.
[0001.865] E> I2C: slave not found in slaves.
[0001.869] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.877] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.882] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.892] E> eeprom: Failed to read I2C slave device
[0001.897] I> Eeprom read failed 0x3526070d
[0001.901] I> Reading eeprom i2c=1 address=0x50
[0001.905] E> I2C: slave not found in slaves.
[0001.909] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.917] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.923] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.932] E> eeprom: Retry to read I2C slave device.
[0001.937] E> I2C: slave not found in slaves.
[0001.941] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.949] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.954] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.964] E> eeprom: Failed to read I2C slave device
[0001.969] I> Eeprom read failed 0x3526070d
[0001.973] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0001.978] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.989] I> create_pm_ids: id: 2822-0000-700-J, len: 15
[0001.994] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.005] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.013] W> “i2c@3160000” doesn’t exist, creating
[0002.017] W> “module@0x50” doesn’t exist, creating
[0002.022] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0002.028] W> “module@0x56” doesn’t exist, creating
[0002.035] I> Adding plugin-manager/cvm
[0002.037] W> “chip-id” doesn’t exist, creating
[0002.041] I> Adding plugin-manager/chip-id/A02P
[0002.045] I> Plugin-manager override starting
[0002.050] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.058] I> node /plugin-manager/fragement-soft-wdt matches
[0002.067] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.071] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.087] I> Disable plugin-manager status in FDT
[0002.087] I> Plugin-manager override finished successfully
[0002.087] I> gpio framework initialized
[0002.089] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ drir
[0002.094] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon’r
[0002.101] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.108] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.116] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.123] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.129] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.136] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.144] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.151] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.158] I> fixed regulator driver initialized
[0002.169] I> register ‘maxim’ power off handle
[0002.170] I> virtual i2c enabled
[0002.170] I> registered ‘maxim,max20024’ pmic
[0002.173] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.179] I> Boot-device: eMMC
[0002.182] I> Boot_device: SDMMC_BOOT instance: 3
[0002.191] I> sdmmc-3 params source = boot args
[0002.191] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.196] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.207] I> create_pm_ids: id: 2822-0000-700-J, len: 15
[0002.212] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.223] I> sdmmc bdev is already initialized
[0002.228] I> sdmmc-3 params source = boot args
[0002.259] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.272] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.280] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.285] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.285] I> hdmi cable connected
[0002.287] W> set volts not configured for ‘vdd-1v0’
[0002.289] W> set volts not configured for ‘vdd-1v8-hs’
[0002.293] E> invalid display type
[0002.296] E> invalid display type
[0002.297] E> cannot find any other nvdisp nodes
[0002.312] I> edid read success
[0002.312] I> width = 640, height = 480, frequency = 25174825
[0002.313] I> width = 640, height = 480, frequency = 25174825
[0002.314] I> width = 640, height = 480, frequency = 25174825
[0002.314] I> width = 1920, height = 1080, frequency = 148500000
[0002.319] I> Best mode Width = 640, Height = 480, freq = 25174825
[0002.329] I> hdmi_enable, starting HDMI initialisation
[0002.334] I> hdmi_enable, HDMI initialisation complete
[0002.337] I> Load in CBoot Boot Options partition and parse it
[0002.347] E> Error -9 when finding node with path /boot-configuration
[0002.347] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO fil.
[0002.354] I> Hit any key to stop autoboot: 4 3 2 1
[0004.362] initializing target
[0004.362] calling apps_init()
[0004.363] starting app kernel_boot_app
[0004.382] I> found decompressor handler: lz4-legacy
[0004.383] I> decompressing BMP blob …
[0004.386] I> Kernel type = Normal
[0004.387] I> Loading kernel-bootctrl from partition
[0004.387] I> Loading partition kernel-bootctrl at 0xa4400000 from device(0x1)
[0004.394] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.394] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.395] I> ########## SD boot ##########
[0004.399] I> Found sdcard
[0004.403] I> enabling ‘vdd-sdmmc1-sw’ regulator
[0004.409] I> regulator ‘vdd-sdmmc1-sw’ already enabled
[0004.610] I> sdmmc SDR mode
[0004.624] I> -0 params source =
[0004.637] W> Cannot find any partition table for 00060000
[0004.637] I> Detect filesystem
[0004.642] I> fs_detect:173: Unsupported or no filesystem present
[0004.642] E> SD boot failed, err: 724238349
[0004.642] I> ########## USB boot ##########
[0004.660] I> USB Firmware Version: 60.06 release
[0004.715] I> regulator of usb2-0 already enabled
[0004.721] I> regulator of usb2-1 already enabled
[0004.727] I> regulator of usb2-2 already enabled
[0004.739] I> enabling ‘vdd-5v-sata’ regulator
[0005.806] I> USB 2.0 port 4 new high-speed USB device detected
[0005.808] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa07e08000
[0005.909] I> Start to enumerate device
[0005.910] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa07e08000
[0005.917] I>
[0005.917] I> Enumerated USB Device 05e3:0610
[0005.917] I>
[0005.918] I> Hub:
[0005.919] I> Downstream ports : 4
[0005.919] I> Power switching : Ganged
[0005.919] I> Compound device : No
[0005.920] I> Over-current protection : Global
[0005.922] I> Hub avg delay : 4 ns
[0005.926] I> Set interface = 1 (alt setting)
[0005.931] I> Enable hub ports
[0005.941] I> Device detected on port 2
[0005.944] I> Device detected on port 4
[0006.457] I> Reset port 2
[0006.512] I> Port 2 device is low speed, skip enumeration
[0006.516] I> Reset port 4
[0006.571] I> Port 4 device is low speed, skip enumeration
[0006.572] E> Enumerated device doesn’t belong to MSD class or protocol is not !
[0006.572] E> USBMSD: Failed to initialize Enumerated USB device either not an .
[0006.574] E> Error opening USBMSD driver 0, err: 7c7c0312
[0006.579] E> Failed to initialize device 5-0
[0006.583] E> USB boot failed, err: 2088502034
[0006.587] I> ########## Fixed storage boot ##########
[0006.592] I> Already published: 00010003
[0006.596] I> Look for boot partition
[0006.599] I> Fallback: assuming 0th partition is boot partition
[0006.605] I> Detect filesystem
[0006.632] I> Loading extlinux.conf …
[0006.633] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0006.669] I> L4T boot options
[0006.670] I> [1]: “primary kernel”
[0006.670] I> Enter choice:
[0009.671] I> Continuing with default option: 1
[0009.671] I> Loading kernel sig file from rootfs …
[0009.671] I> rootfs path: /sdmmc_user/boot/Image.sig
[0009.690] I> Loading kernel binary from rootfs …
[0009.690] I> rootfs path: /sdmmc_user/boot/Image
[0009.929] I> Validate kernel …
[0009.929] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.242] E> digest on binary did not match!!
[0010.242] C> OEM authentication of kernel payload failed!
[0010.243] W> Failed to validate kernel binary (err=1077936152, fail=0)
[0010.243] W> Security fuse not burned, ignore validation failure
[0010.250] I> No kernel-dtb binary path
[0010.257] I> A/B: bin_type (38) slot 1
[0010.258] I> Loading kernel-dtb_b from partition
[0010.258] I> Loading partition kernel-dtb_b at 0x91000000 from device(0x1)
[0010.268] I> Validate kernel-dtb …
[0010.269] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.273] I> Loading ramdisk from rootfs …
[0010.273] I> rootfs path: /sdmmc_user/boot/initrd
[0010.334] I> Kernel hdr @0xa4400000
[0010.334] I> Kernel dtb @0x90000000
[0010.335] I> decompressor handler not found
[0010.335] I> Copying kernel image (34332680 bytes) from 0xa4400000 to 0x800800e
[0010.346] I> Updated bpmp info to DTB
[0010.347] I> Ramdisk: Base: 0x92000000; Size: 0x54eb56
[0010.348] I> Updated initrd info to DTB
[0010.348] W> WARN: Fail to override “console=none” in commandline
[0010.348] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display paras
[0010.354] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display paras
[0010.362] I> Active slot suffix: _b
[0010.365] I> add_boot_slot_suffix: slot_suffix = _b
[0010.370] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_su
[0010.400] I> Updated bootarg info to DTB
[0010.403] W> MAC addr invalid!
[0010.406] E> Failed to get WIFI MAC address
[0010.410] W> MAC addr invalid!
[0010.413] E> Failed to get Bluetooth MAC address
[0010.418] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:b8:1b
[0010.424] W> “plugin-manager” doesn’t exist, creating
[0010.429] I> Adding /chosen/plugin-manager/cvm
[0010.433] W> “chip-id” doesn’t exist, creating
[0010.437] I> Adding /chosen/plugin-manager/chip-id
[0010.442] W> “configs” doesn’t exist, creating
[0010.446] I> Adding /chosen/plugin-manager/configs
[0010.451] W> “ids” doesn’t exist, creating
[0010.455] I> Adding /chosen/plugin-manager/ids
[0010.459] W> “odm-data” doesn’t exist, creating
[0010.463] I> Adding /chosen/plugin-manager/odm-data
[0010.471] W> “memory” doesn’t exist, creating
[0010.473] I> [0] START: 0x80000000, END: 0xac000000
[0010.477] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.482] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.486] I> dram_block larger than 80000000
[0010.490] I> [3] START: 0x100000000, END: 0x880000000
[0010.495] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.501] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.507] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.514] I> Updated memory info to DTB
[0010.517] E> add_disp_param: failed to get display params for du=1
[0010.523] W> “reset” doesn’t exist, creating
[0010.528] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.532] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.536] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.541] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.546] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.551] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.555] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.560] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.566] W> “misc-data” doesn’t exist, creating
[0010.569] I> Boot-device: eMMC
[0010.572] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.577] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.583] W> Unknown storage device
[0010.586] I> Add serial number:1421420031654 as DT property
[0010.593] I> Plugin-manager override starting
[0010.596] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.603] I> node /plugin-manager/fragement-soft-wdt matches
[0010.610] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.615] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0010.626] I> Disable plugin-manager status in FDT
[0010.627] I> Plugin-manager override finished successfully
[0010.629] I> tegrabl_load_kernel_and_dtb: Done
[0010.663] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4294) (gcc ve0
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00140000@a069d000
[ 0.000000] Found lut_mem: 00002008@a0697000
��WARNING: pll_d3 has no dyn ramp
��[ 6.126471] mmc0: RED error 4 !!!
[ 6.126615] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 6.126759] sdhci: Sys addr: 0x00000000 | Version: 0x00000505
[ 6.126905] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000000
[ 6.127046] sdhci: Argument: 0x00020000 | Trn mode: 0x00000023
[ 6.127189] sdhci: Present: 0x11fb00f0 | Host ctl: 0x0000003d
[ 6.127319] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 6.127448] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 6.127578] sdhci: Timeout: 0x0000000e | Int stat: 0x00004000
[ 6.127705] sdhci: Int enab: 0xffff4000 | Sig enab: 0xfffc4000
[ 6.127834] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 6.127966] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f77
[ 6.128100] sdhci: Cmd: 0x00002f3a | Max curr: 0x00000000
[ 6.128241] sdhci: Host ctl2: 0x0000300d
[ 6.128509] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffee3010
[ 6.129030] sdhci: ===========================================
[ 6.129501] kernel BUG at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/!
[ 6.135948] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 6.141281] Modules linked in:
[ 6.144437] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.140-tegra #1
[ 6.150817] Hardware name: Jetson-AGX (DT)
[ 6.154586] task: ffffff8009e713c0 task.stack: ffffff8009e60000
[ 6.160453] PC is at cmdq_irq+0x224/0x230
[ 6.164730] LR is at cmdq_irq+0x224/0x230
[ 6.168681] pc : [] lr : [] pstate: 60405
[ 6.176198] sp : ffffffc7ffc54db0
[ 6.179351] x29: ffffffc7ffc54db0 x28: ffffff8009e713c0
[ 6.185381] x27: ffffff800a09a000 x26: 0000000000000000
[ 6.190903] x25: 000000003fffffff x24: 00000000000001c0
[ 6.196752] x23: ffffffc7db3de800 x22: ffffffc7db3e9000
[ 6.202439] x21: 0000000000004000 x20: 0000000000000004
[ 6.208215] x19: ffffffc7db3de780 x18: 0000000000000010
[ 6.213903] x17: 0000000000000002 x16: 00000000000322c7
[ 6.219427] x15: 0000000000000001 x14: ffffff808a149a02
[ 6.225365] x13: ffffff8008ff1c70 x12: 00000000ffffffff
[ 6.230877] x11: 0000000000000020 x10: 00000000000003b6
[ 6.236477] x9 : ffffff8013293220 x8 : ffffff80083d3768
[ 6.242003] x7 : ffffff8009eb4198 x6 : ffffff80083d2b58
[ 6.247514] x5 : 0000000000000000 x4 : 0000000000000000
[ 6.253102] x3 : ffffffffffffffff x2 : ffffff8009e84110
[ 6.258187] x1 : ffffff8009e713c0 x0 : 0000000000000032
[ 6.263776]
[ 6.264926] Process swapper/0 (pid: 0, stack limit = 0xffffff8009e60000)
[ 6.271307] Call trace:
[ 6.273932] [] cmdq_irq+0x224/0x230
[ 6.278746] [] sdhci_irq+0x98/0xd80
[ 6.283558] [] __handle_irq_event_percpu+0x68/0x288
[ 6.289679] [] handle_irq_event_percpu+0x28/0x60
[ 6.295284] [] handle_irq_event+0x50/0x80
[ 6.300881] [] handle_fasteoi_irq+0xc8/0x1b8
[ 6.306479] [] generic_handle_irq+0x34/0x50
[ 6.311820] [] __handle_domain_irq+0x68/0xc0
[ 6.317420] [] gic_handle_irq+0x5c/0xb0
[ 6.322492] [] el1_irq+0xe8/0x194
[ 6.327047] [] cpuidle_enter_state+0xb8/0x380
[ 6.332995] [] cpuidle_enter+0x34/0x48
[ 6.338243] [] call_cpuidle+0x44/0x70
[ 6.343061] [] cpu_startup_entry+0x1b0/0x200
[ 6.349184] [] rest_init+0x84/0x90
[ 6.353829] [] start_kernel+0x370/0x384
[ 6.359248] [] __primary_switched+0x80/0x94
[ 6.364860] —[ end trace 1461e7e23af5af55 ]—
[ 6.377318] Kernel panic - not syncing: Fatal exception in interrupt
[ 6.378652] SMP: stopping secondary CPUs
[ 6.380167] Kernel Offset: disabled
[ 6.383653] Memory Limit: none
[ 6.386548] trusty-log panic notifier - trusty version Built: 20:53:35 Oct 2.
����Shutdown state requested 1
Rebooting system …
[0000.055] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.063] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.069] I> Boot-mode: Coldboot
[0000.072] I> Chip revision : A02P
[0000.075] I> Bootrom patch version : 15 (correctly patched)
[0000.080] I> ATE fuse revision : 0x200
[0000.083] I> Ram repair fuse : 0x0
[0000.087] I> Ram Code : 0x2
[0000.089] I> rst_source : 0xb
[0000.092] I> rst_level : 0x1
[0000.095] I> Boot-device: eMMC
[0000.110] I> sdmmc DDR50 mode
[0000.114] I> Active Boot chain : 1
[0000.118] I> Boot-device: eMMC
[0000.121] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.127] I> Temperature = 31000
[0000.130] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.135] W> Skipping boost for clk: BPMP_APB
[0000.139] W> Skipping boost for clk: AXI_CBB
[0000.143] W> Skipping boost for clk: AON_CPU_NIC
[0000.147] W> Skipping boost for clk: CAN1
[0000.151] W> Skipping boost for clk: CAN2
[0000.155] I> Boot-device: eMMC
[0000.158] I> Boot-device: eMMC
[0000.167] I> Sdmmc: HS400 mode enabled
[0000.172] I> ECC region[0]: Start:0x0, End:0x0
[0000.176] I> ECC region[1]: Start:0x0, End:0x0
[0000.180] I> ECC region[2]: Start:0x0, End:0x0
[0000.184] I> ECC region[3]: Start:0x0, End:0x0
[0000.188] I> ECC region[4]: Start:0x0, End:0x0
[0000.192] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.198] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.203] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.207] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.212] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.217] E> FAILED: Thermal config
[0000.224] E> FAILED: MEMIO rail config
[0000.243] I> Boot-device: eMMC
[0000.253] I> sdmmc bdev is already initialized
[0000.324] I> MB1 done
����main enter
HW Function test
Start Scheduler.
in late init
[0000.333] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-389501e9)
[0000.334] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.334] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.335] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.341] W> device prod register failed
[0000.344] I> Boot-device: eMMC
[0000.347] I> Boot_device: SDMMC_BOOT instance: 3
[0000.353] I> sdmmc-3 params source = boot args
[0000.356] I> sdmmc bdev is already initialized
[0000.360] I> sdmmc-3 params source = boot args
[0000.367] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.374] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.376] I> Active Boot chain : 1
[0000.379] I> parsing oem signed section of bpmp-fw header done
[0000.385] I> bpmp-fw binary init read from storage
[0000.390] I> oem authentication of bpmp-fw header done
[0000.396] I> bpmp-fw binary done read from storage
[0000.399] I> bpmp-fw: Authentication init Done
[0000.403] I> parsing oem signed section of cpubl header done
[0000.409] I> cpubl binary init read from storage
[0000.413] I> bpmp-fw: Authentication Finalize Done
[0000.418] I> oem authentication of cpubl header done
[0000.422] I> cpubl binary done read from storage
[0000.427] I> cpubl: Authentication init Done
[0000.432] I> parsing oem signed section of rce header done
[0000.436] I> rce binary init read from storage
[0000.441] I> Relocating BR-BCT
[0000.444] I> cpubl: Authentication Finalize Done
[0000.448] I> oem authentication of rce header done
[0000.453] I> rce binary done read from storage
[0000.457] I> rce: Authentication init Done
[0000.462] I> parsing oem signed section of ape header done
[0000.466] I> ape binary init read from storage
[0000.471] I> rce: Authentication Finalize Done
[0000.475] I> oem authentication of ape header done
[0000.479] I> ape binary done read from storage
[0000.484] I> ape: Authentication init Done
[0000.488] I> parsing oem signed section of tos header done
[0000.493] I> tos binary init read from storage
[0000.497] I> ape: Authentication Finalize Done
[0000.502] I> oem authentication of tos header done
[0000.506] I> tos binary done read from storage
[0000.510] I> tos: Authentication init Done
[0000.515] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.520] I> bpmp-fw-dtb binary init read from storage
[0000.525] I> tos: Authentication Finalize Done
[0000.531] I> oem authentication of bpmp-fw-dtb header done
[0000.538] I> bpmp-fw-dtb binary done read from storage
[0000.540] I> bpmp-fw-dtb: Authentication init Done
[0000.545] I> parsing oem signed section of cpubl-dtb header done
[0000.551] I> cpubl-dtb binary init read from storage
[0000.555] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.593] I> oem authentication of cpubl-dtb header done
[0000.593] I> cpubl-dtb binary done read from storage
[0000.594] I> cpubl-dtb: Authentication init Done
[0000.596] I> parsing oem signed section of eks header done
[0000.597] I> eks binary init read from storage
[0000.597] I> cpubl-dtb: Authentication Finalize Done
[0000.598] I> oem authentication of eks header done
[0000.601] I> eks binary done read from storage
[0000.606] I> eks: Authentication init Done
[0000.610] I> eks: Authentication Finalize Done
[0000.614] I> EKB detected (length: 0x410) @ VA:0x5270a400
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
[0001.117] I> Welcome to Cboot
��[0001.117] I> Cboot Version: t194-aad9d75e
[0001.118] I> CPU-BL Params @ 0xf2820000
[0001.118] I> 0) Base:0x00000000 Size:0x00000000
[0001.122] I> 1) Base:0xf1100000 Size:0x00100000
[0001.126] I> 2) Base:0xf2000000 Size:0x00200000
[0001.131] I> 3) Base:0xf1200000 Size:0x00200000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
��[0001.135] I> 4) Base:0xf1000000 Size:0x00100000
[0001.240] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.244] I> 6) Base:0xf3800000 Size:0x00400000
[0001.249] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.253] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.258] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.262] I> 10) Base:0xf3000000 Size:0x00800000
[0001.267] I> 11) Base:0x40000000 Size:0x00040000
[0001.271] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.276] I> 13) Base:0x40046000 Size:0x00002000
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ��[0001.280] I> 14) Base:0x40048000 Size:0x00002000
[0001.335] I> 15) Base:0xac000000 Size:0x00004000
[0001.340] I> 16) Base:0x4004a000 Size:0x00002000
[0001.344] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.348] I> 18) Base:0x4004c000 Size:0x00002000
[0001.353] I> 19) Base:0xf2200000 Size:0x00600000
[0001.357] I> 20) Base:0x4004e000 Size:0x00002000
[0001.362] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.366] I> 22) Base:0x00000000 Size:0x00000000
[0001.371] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.375] I> 24) Base:0xf6000000 Size:0x02000000
[0001.380] I> 25) Base:0x40050000 Size:0x00002000
[0001.384] I> 26) Base:0x40040000 Size:0x00006000
[0001.389] I> 27) Base:0xf1800000 Size:0x00400000
[0001.393] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.398] I> 29) Base:0xf1400000 Size:0x00400000
[0001.402] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.406] I> 31) Base:0x00000000 Size:0x00000000
[0001.411] I> 32) Base:0xf8000000 Size:0x08000000
[0001.415] I> 33) Base:0x00000000 Size:0x00000000
[0001.420] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.424] I> 35) Base:0xab000000 Size:0x01000000
[0001.429] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.433] I> 37) Base:0xf2800000 Size:0x00800000
[0001.438] I> 38) Base:0x80000000 Size:0x20000000
[0001.442] I> 39) Base:0xb0000000 Size:0x08000000
[0001.447] I> 40) Base:0x00000000 Size:0x00000000
[0001.451] I> 41) Base:0x00000000 Size:0x00000000
[0001.456] I> 42) Base:0x00000000 Size:0x00000000
[0001.460] I> 43) Base:0x00000000 Size:0x00000000
[0001.464] I> 44) Base:0x00000000 Size:0x00000000
[0001.469] I> 45) Base:0x00000000 Size:0x00000000
[0001.473] GIC-SPI Target CPU: 0
[0001.476] Interrupts Init done
[0001.479] calling constructors
[0001.482] initializing heap
[0001.485] I> Heap: [0xa0691568 … 0xab000000]
[0001.489] initializing threads
[0001.492] initializing timers
[0001.495] creating bootstrap completion thread
[0001.499] top of bootstrap2()
[0001.502] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.506] initializing platform
[0001.509] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.515] W> device prod register failed
[0001.519] I> Bl_dtb @0xaaf00000
[0001.525] W> “plugin-manager” doesn’t exist, creating
[0001.527] W> “ids” doesn’t exist, creating
[0001.531] W> “connection” doesn’t exist, creating
[0001.535] W> “configs” doesn’t exist, creating
[0001.546] I> Find /i2c@3160000’s alias i2c0
[0001.546] I> Reading eeprom i2c=0 address=0x50
[0001.573] I> Device at /i2c@3160000:0x50
[0001.573] I> Reading eeprom i2c=0 address=0x56
[0001.598] I> Device at /i2c@3160000:0x56
[0001.599] I> Find /i2c@3180000’s alias i2c2
[0001.600] I> Reading eeprom i2c=2 address=0x54
[0001.601] E> I2C: slave not found in slaves.
[0001.602] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.603] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.603] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.612] E> eeprom: Failed to read I2C slave device
[0001.616] I> Eeprom read failed 0x3526070d
[0001.620] I> Reading eeprom i2c=2 address=0x57
[0001.625] E> I2C: slave not found in slaves.
[0001.629] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.637] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.642] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.652] E> eeprom: Failed to read I2C slave device
[0001.657] I> Eeprom read failed 0x3526070d
[0001.661] I> Reading eeprom i2c=2 address=0x52
[0001.665] E> I2C: slave not found in slaves.
[0001.669] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.677] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.682] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.692] E> eeprom: Failed to read I2C slave device
[0001.697] I> Eeprom read failed 0x3526070d
[0001.702] I> Find /i2c@c240000’s alias i2c1
[0001.705] I> Reading eeprom i2c=1 address=0x52
[0001.710] E> I2C: slave not found in slaves.
[0001.713] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.721] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.726] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.736] E> eeprom: Retry to read I2C slave device.
[0001.741] E> I2C: slave not found in slaves.
[0001.745] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.753] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.758] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.768] E> eeprom: Failed to read I2C slave device
[0001.773] I> Eeprom read failed 0x3526070d
[0001.777] I> Reading eeprom i2c=1 address=0x50
[0001.781] E> I2C: slave not found in slaves.
[0001.785] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.793] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.798] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.808] E> eeprom: Retry to read I2C slave device.
[0001.813] E> I2C: slave not found in slaves.
[0001.817] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.825] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.830] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.840] E> eeprom: Failed to read I2C slave device
[0001.845] I> Eeprom read failed 0x3526070d
[0001.848] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0001.854] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.865] I> create_pm_ids: id: 2822-0000-700-J, len: 15
[0001.870] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.881] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.888] W> “i2c@3160000” doesn’t exist, creating
[0001.893] W> “module@0x50” doesn’t exist, creating
[0001.897] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.904] W> “module@0x56” doesn’t exist, creating
[0001.911] I> Adding plugin-manager/cvm
[0001.913] W> “chip-id” doesn’t exist, creating
[0001.917] I> Adding plugin-manager/chip-id/A02P
[0001.921] I> Plugin-manager override starting
[0001.926] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.935] I> node /plugin-manager/fragement-soft-wdt matches
[0001.943] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.948] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.957] I> Disable plugin-manager status in FDT
[0001.957] I> Plugin-manager override finished successfully
[0001.958] I> gpio framework initialized
[0001.963] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.970] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0001.977] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.985] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.992] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.999] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.005] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.012] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.020] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.027] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.034] I> fixed regulator driver initialized
[0002.045] I> register ‘maxim’ power off handle
[0002.046] I> virtual i2c enabled
[0002.046] I> registered ‘maxim,max20024’ pmic
[0002.049] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.055] I> Boot-device: eMMC
[0002.058] I> Boot_device: SDMMC_BOOT instance: 3
[0002.067] I> sdmmc-3 params source = boot args
[0002.067] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.072] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.083] I> create_pm_ids: id: 2822-0000-700-J, len: 15
[0002.088] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.099] I> sdmmc bdev is already initialized
[0002.104] I> sdmmc-3 params source = boot args
[0002.135] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.147] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.156] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.160] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.161] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.161] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.165] E> invalid display type
[0002.168] E> invalid display type
[0002.169] E> cannot find any other nvdisp nodes
[0002.169] E> no valid display unit config found in dtb
[0002.171] W> display init failed
[0002.172] I> Load in CBoot Boot Options partition and parse it
[0002.184] E> Error -9 when finding node with path /boot-configuration
[0002.184] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.191] I> Hit any key to stop autoboot: 4 3 2 1
[0004.199] initializing target
[0004.199] calling apps_init()
[0004.200] starting app kernel_boot_app
[0004.219] I> found decompressor handler: lz4-legacy
[0004.220] I> decompressing BMP blob …
[0004.223] I> Kernel type = Normal
[0004.223] I> Loading kernel-bootctrl from partition
[0004.224] I> Loading partition kernel-bootctrl at 0xa42b0000 from device(0x1)
[0004.230] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.231] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.232] I> ########## SD boot ##########
[0004.236] I> Found sdcard
[0004.240] I> enabling ‘vdd-sdmmc1-sw’ regulator
[0004.246] I> regulator ‘vdd-sdmmc1-sw’ already enabled
[0004.451] I> sdmmc SDR mode
[0004.465] I> -0 params source =
[0004.478] W> Cannot find any partition table for 00060000
[0004.478] I> Detect filesystem
[0004.482] I> fs_detect:173: Unsupported or no filesystem present
[0004.483] E> SD boot failed, err: 724238349
[0004.483] I> ########## USB boot ##########
[0004.501] I> USB Firmware Version: 60.06 release
[0004.556] I> regulator of usb2-0 already enabled
[0004.561] I> regulator of usb2-1 already enabled
[0004.567] I> regulator of usb2-2 already enabled
[0004.575] I> enabling ‘vdd-5v-sata’ regulator
[0005.642] I> USB 2.0 port 4 new high-speed USB device detected
[0005.644] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa069c300, cmd_ring.dma = 0xa069c380
[0005.745] I> Start to enumerate device
[0005.746] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa069c300, cmd_ring.dma = 0xa069c380
[0005.753] I>
[0005.753] I> Enumerated USB Device 05e3:0610
[0005.753] I>
[0005.754] I> Hub:
[0005.755] I> Downstream ports : 4
[0005.755] I> Power switching : Ganged
[0005.755] I> Compound device : No
[0005.756] I> Over-current protection : Global
[0005.758] I> Hub avg delay : 4 ns
[0005.762] I> Set interface = 1 (alt setting)
[0005.767] I> Enable hub ports
[0005.777] I> Device detected on port 2
[0005.780] I> Device detected on port 4
[0006.292] I> Reset port 2
[0006.347] I> Port 2 device is low speed, skip enumeration
[0006.351] I> Reset port 4
[0006.407] I> Port 4 device is low speed, skip enumeration
[0006.408] E> Enumerated device doesn’t belong to MSD class or protocol is not bulk-only!!
[0006.408] E> USBMSD: Failed to initialize Enumerated USB device either not an MSD device or supported protoco[0006.409] E> USBMSD: Failed to open usbmsd open, 0.
[0006.410] E> Error opening USBMSD driver 0, err: 7c7c0312
[0006.415] E> Failed to initialize device 5-0
[0006.419] E> USB boot failed, err: 2088502034
[0006.423] I> ########## Fixed storage boot ##########
[0006.428] I> Already published: 00010003
[0006.432] I> Look for boot partition
[0006.435] I> Fallback: assuming 0th partition is boot partition
[0006.441] I> Detect filesystem
[0006.468] I> Loading extlinux.conf …
[0006.469] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0006.505] I> L4T boot options
[0006.506] I> [1]: “primary kernel”
[0006.506] I> Enter choice:
[0009.507] I> Continuing with default option: 1
[0009.507] I> Loading kernel sig file from rootfs …
[0009.507] I> rootfs path: /sdmmc_user/boot/Image.sig
[0009.526] I> Loading kernel binary from rootfs …
[0009.526] I> rootfs path: /sdmmc_user/boot/Image
[0009.769] I> Validate kernel …
[0009.769] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.082] E> digest on binary did not match!!
[0010.082] C> OEM authentication of kernel payload failed!
[0010.082] W> Failed to validate kernel binary (err=1077936152, fail=0)
[0010.083] W> Security fuse not burned, ignore validation failure
[0010.090] I> No kernel-dtb binary path
[0010.097] I> A/B: bin_type (38) slot 1
[0010.097] I> Loading kernel-dtb_b from partition
[0010.098] I> Loading partition kernel-dtb_b at 0x91000000 from device(0x1)
[0010.108] I> Validate kernel-dtb …
[0010.109] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.112] I> Loading ramdisk from rootfs …
[0010.113] I> rootfs path: /sdmmc_user/boot/initrd
[0010.174] I> Kernel hdr @0xa42b0000
[0010.175] I> Kernel dtb @0x90000000
[0010.175] I> decompressor handler not found
[0010.175] I> Copying kernel image (34332680 bytes) from 0xa42b0000 to 0x80080000 … [0010.185] I> Done
[0010.186] I> Updated bpmp info to DTB
[0010.188] I> Ramdisk: Base: 0x92000000; Size: 0x54eb56
[0010.188] I> Updated initrd info to DTB
[0010.188] W> WARN: Fail to override “console=none” in commandline
[0010.189] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0010.195] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0010.202] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0010.209] I> Active slot suffix: _b
[0010.212] I> add_boot_slot_suffix: slot_suffix = _b
[0010.217] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0
[0010.242] I> Updated bootarg info to DTB
[0010.246] W> MAC addr invalid!
[0010.248] E> Failed to get WIFI MAC address
[0010.252] W> MAC addr invalid!
[0010.255] E> Failed to get Bluetooth MAC address
[0010.260] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:b8:1b
[0010.267] W> “plugin-manager” doesn’t exist, creating
[0010.271] I> Adding /chosen/plugin-manager/cvm
[0010.275] W> “chip-id” doesn’t exist, creating
[0010.279] I> Adding /chosen/plugin-manager/chip-id
[0010.284] W> “configs” doesn’t exist, creating
[0010.288] I> Adding /chosen/plugin-manager/configs
[0010.293] W> “ids” doesn’t exist, creating
[0010.297] I> Adding /chosen/plugin-manager/ids
[0010.302] W> “odm-data” doesn’t exist, creating
[0010.306] I> Adding /chosen/plugin-manager/odm-data
[0010.314] W> “memory” doesn’t exist, creating
[0010.315] I> [0] START: 0x80000000, END: 0xac000000
[0010.319] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.324] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.329] I> dram_block larger than 80000000
[0010.333] I> [3] START: 0x100000000, END: 0x880000000
[0010.338] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.343] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.349] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.357] I> Updated memory info to DTB
[0010.359] E> add_disp_param: failed to get display params for du=0
[0010.366] W> “reset” doesn’t exist, creating
[0010.370] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.374] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.379] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.383] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.388] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.393] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.398] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.402] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.408] W> “misc-data” doesn’t exist, creating
[0010.412] I> Boot-device: eMMC
[0010.414] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.420] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.425] W> Unknown storage device
[0010.429] I> Add serial number:1421420031654 as DT property
[0010.435] I> Plugin-manager override starting
[0010.438] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.445] I> node /plugin-manager/fragement-soft-wdt matches
[0010.452] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.457] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0010.468] I> Disable plugin-manager status in FDT
[0010.469] I> Plugin-manager override finished successfully
[0010.471] I> tegrabl_load_kernel_and_dtb: Done
[0010.475] E> tegrabl_display_clear: display is not initialized
[0010.481] W> Boot logo display failed…
[0010.509] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4294) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro G0
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
��[ 6.388338] mmc0: RED error 4 !!!
[ 6.388658] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 6.388823] sdhci: Sys addr: 0x00000000 | Version: 0x00000505
[ 6.388980] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000048
[ 6.389134] sdhci: Argument: 0x00030000 | Trn mode: 0x00000023
[ 6.389289] sdhci: Present: 0x11fb00f0 | Host ctl: 0x0000003d
[ 6.389431] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 6.389558] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 6.389685] sdhci: Timeout: 0x0000000e | Int stat: 0x00004000
[ 6.389811] sdhci: Int enab: 0xffff4000 | Sig enab: 0xfffc4000
[ 6.389937] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 6.390066] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f77
[ 6.390193] sdhci: Cmd: 0x00000d1e | Max curr: 0x00000000
[ 6.390321] sdhci: Host ctl2: 0x0000300d
[ 6.390564] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffee3810
[ 6.391070] sdhci: ===========================================
[ 6.391533] kernel BUG at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/drivers/mmc/host/cmdq_hci.c:681!
[ 6.397726] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 6.403323] Modules linked in:
[ 6.406472] CPU: 0 PID: 1915 Comm: mmc_cmdq_d/0 Not tainted 4.9.140-tegra #1
[ 6.413383] Hardware name: Jetson-AGX (DT)
[ 6.417151] task: ffffffc7d7833800 task.stack: ffffffc7c6458000
[ 6.423016] PC is at cmdq_irq+0x224/0x230
[ 6.427301] LR is at cmdq_irq+0x224/0x230
[ 6.431245] pc : [] lr : [] pstate: 604001c5
[ 6.438760] sp : ffffffc7ffc55db0
[ 6.442176] x29: ffffffc7ffc55db0 x28: ffffffc7d7833800
[ 6.447945] x27: ffffff800a09a000 x26: 0000000000000000
[ 6.453471] x25: 000000003fffffff x24: 00000000000001c0
[ 6.459320] x23: ffffffc7d7dbf080 x22: ffffffc7db3c4000
[ 6.465006] x21: 0000000000004000 x20: 0000000000000004
[ 6.470781] x19: ffffffc7d7dbf000 x18: 0000000000000010
[ 6.476468] x17: 0000000000004378 x16: 000000000016a69e
[ 6.482243] x15: 0000000000000001 x14: ffffff808a149a02
[ 6.487930] x13: ffffff8008ff1c70 x12: 00000000ffffffff
[ 6.493369] x11: 0000000000000020 x10: 00000000000003b4
[ 6.499043] x9 : ffffff8013293220 x8 : ffffff80083d3768
[ 6.504568] x7 : ffffff8009eb4198 x6 : ffffff80083d2b58
[ 6.510332] x5 : 0000000000000000 x4 : 0000000000000000
[ 6.515668] x3 : ffffffffffffffff x2 : ffffff8009e84110
[ 6.520757] x1 : ffffffc7d7833800 x0 : 0000000000000032
[ 6.526343]
[ 6.527745] Process mmc_cmdq_d/0 (pid: 1915, stack limit = 0xffffffc7c6458000)
[ 6.534660] Call trace:
[ 6.537024] [] cmdq_irq+0x224/0x230
[ 6.541578] [] sdhci_irq+0x98/0xd80
[ 6.546649] [] __handle_irq_event_percpu+0x68/0x288
[ 6.552772] [] handle_irq_event_percpu+0x28/0x60
[ 6.558376] [] handle_irq_event+0x50/0x80
[ 6.563714] [] handle_fasteoi_irq+0xc8/0x1b8
[ 6.569571] [] generic_handle_irq+0x34/0x50
[ 6.574908] [] __handle_domain_irq+0x68/0xc0
[ 6.580511] [] gic_handle_irq+0x5c/0xb0
[ 6.585328] [] el1_irq+0xe8/0x194
[ 6.589792] [] _raw_spin_unlock_irq+0x28/0x58
[ 6.595826] [] mmc_cmdq_thread+0xc4/0x1f0
[ 6.601339] [] kthread+0xec/0xf0
[ 6.606410] [] ret_from_fork+0x10/0x30
[ 6.611495] —[ end trace 01fcb76a5e6e3873 ]—
[ 6.623789] Kernel panic - not syncing: Fatal exception in interrupt
[ 6.623958] SMP: stopping secondary CPUs
[ 6.626549] Kernel Offset: disabled
[ 6.630036] Memory Limit: none
[ 6.633448] trusty-log panic notifier - trusty version Built: 20:53:35 Oct 27 2020 [ 6.648025] Rebooting in 5 seconds…
Rebooting system …
[0000.114] I> Active Boot chain : 0
[0000.127] I> Temperature = 32500
����main enter
HW Function test
Start Scheduler.
in late init
[0000.333] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.334] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.340] W> device prod register failed
[0000.376] I> Active Boot chain : 0
[0000.384] I> bpmp-fw binary init read from storage
[0000.389] I> oem authentication of bpmp-fw header done
[0000.398] I> bpmp-fw: Authentication init Done
[0000.408] I> cpubl binary init read from storage
[0000.433] I> parsing oem signed section of rce header done
[0000.443] I> cpubl: Authentication Finalize Done
[0000.452] I> rce binary done read from storage
[0000.461] I> parsing oem signed section of ape header done
[0000.470] I> rce: Authentication Finalize Done
[0000.483] I> ape: Authentication init Done
[0000.514] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.550] I> cpubl-dtb binary init read from storage
[0000.592] I> oem authentication of cpubl-dtb header done
[0000.596] I> eks binary init read from storage
[0000.597] I> oem authentication of eks header done
[0000.605] I> eks: Authentication init Done
[0000.609] I> eks: Authentication Finalize Done
hello dengxp_1995,
it seems you’ve pass bootloaders and boot into linux kernel, but there’s call stack errors to reboot the system.
did you have your own kernel customization? please check those failures and review your implementation.
thanks
hi JerryChang
thanks for your answer. I don’t have my own customization. Everything remained as the default setting. I just ran some sample codes downloaded from github and it worked well for a long time before.
hello dengxp_1995,
could you please also share what’s this sample code did?
the code is a cost volume pyramid based depth inference framework for Multi-View Stereo. I used this network to train on BlendedMVS dataset. just made some modification on its training parameters and images input module to let the code can run on this dataset.
CVP-MVSNet
邓昕蓬
签名由 网易邮箱大师 定制
On 8/31/2021 13:19,JerryChang via NVIDIA Developer Forumsnvidia@discoursemail.com wrote:
Do you start the script at booting time?
Or Xavier keeps rebooting after the first crash even the inference task doesn’t run on the backend?
I believe that the code was running when the first crash happened
The script requires 11GB of memory, which may not work on Xavier.
Would you mind reflashing the system and run it outside of the booting script first?
