Jetson AGX Xavier Showing only blank screen when powered on with JP 4.6
I have successfully flashed the os and restared the board.
The board is not starting since, no logo/boot.
But able to flash os in recovery mood but the board is not starting to boot.
Lack of video is not a reliable method of knowing the system did not boot. What you’d want is the serial console boot log (uses the micro-B USB cable and the host PC runs a serial console program, e.g., minicom…there should be some documents on serial console available). This would tell you if it is just a video issue, or if the unit truly did not boot. You might also want to mention if the monitor is truly pure HDMI, or if any adapters are involved.
hello shravan.anand007,
may I know the SKU of your Jetson AGX Xavier, and, which JetPack release you’re used.
you should use the NVIDIA SDK Manager | NVIDIA Developer to setup the environment, installing JetPack release image to your local host and flashing the target.
in addition,
there’s port J501 on Jetson AGX Xavier DevKit to access the serial console, you should use the serial port utility to fetch the bootloader messages to check the details.
thanks
Hi jerry, linuxdev,
The part number is 945-82972-0047-000, serial no: 1421621044344
I am using the NVIDIA SDK Manager 1.7.0.8846 on virtualbox with ubuntu 18,
The monitor is pure HDMI and it was working properly initially. This issue has started after i flashed the jetpack 4.6 (rev.2).
This is the serial log as you requested:
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.372] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-fc460)
[0000.372] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.373] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.373] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.379] W> device prod register failed
[0000.383] I> Boot-device: eMMC
[0000.386] I> Boot_device: SDMMC_BOOT instance: 3
[0000.392] I> sdmmc-3 params source = boot args
[0000.395] I> sdmmc bdev is already initialized
[0000.399] I> sdmmc-3 params source = boot args
[0000.406] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.413] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.415] W> No valid slot number is found in scratch register
[0000.420] W> Return default slot: _a
[0000.423] I> Active Boot chain : 0
[0000.427] I> parsing oem signed section of bpmp-fw header done
[0000.432] I> bpmp-fw binary init read from storage
[0000.437] I> oem authentication of bpmp-fw header done
[0000.444] I> bpmp-fw binary done read from storage
[0000.447] I> bpmp-fw: Authentication init Done
[0000.451] I> parsing oem signed section of cpubl header done
[0000.456] I> cpubl binary init read from storage
[0000.461] I> bpmp-fw: Authentication Finalize Done
[0000.466] I> oem authentication of cpubl header done
[0000.470] I> cpubl binary done read from storage
[0000.475] I> cpubl: Authentication init Done
[0000.480] I> parsing oem signed section of rce header done
[0000.484] I> rce binary init read from storage
[0000.489] I> Relocating BR-BCT
[0000.492] I> cpubl: Authentication Finalize Done
[0000.496] I> oem authentication of rce header done
[0000.500] I> rce binary done read from storage
[0000.505] I> rce: Authentication init Done
[0000.510] I> parsing oem signed section of ape header done
[0000.514] I> ape binary init read from storage
[0000.519] I> rce: Authentication Finalize Done
[0000.523] I> oem authentication of ape header done
[0000.527] I> ape binary done read from storage
[0000.532] I> ape: Authentication init Done
[0000.536] I> parsing oem signed section of tos header done
[0000.541] I> tos binary init read from storage
[0000.545] I> ape: Authentication Finalize Done
[0000.550] I> oem authentication of tos header done
[0000.554] I> tos binary done read from storage
[0000.558] I> tos: Authentication init Done
[0000.563] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.568] I> bpmp-fw-dtb binary init read from storage
[0000.573] I> tos: Authentication Finalize Done
[0000.579] I> oem authentication of bpmp-fw-dtb header done
[0000.583] I> bpmp-fw-dtb binary done read from storage
[0000.588] I> bpmp-fw-dtb: Authentication init Done
[0000.593] I> parsing oem signed section of cpubl-dtb header done
[0000.598] I> cpubl-dtb binary init read from storage
[0000.603] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.640] I> oem authentication of cpubl-dtb header done
[0000.640] I> cpubl-dtb binary done read from storage
[0000.641] I> cpubl-dtb: Authentication init Done
[0000.643] I> parsing oem signed section of eks header done
[0000.644] I> eks binary init read from storage
[0000.644] I> cpubl-dtb: Authentication Finalize Done
[0000.645] I> oem authentication of eks header done
[0000.649] I> eks binary done read from storage
[0000.653] I> eks: Authentication init Done
[0000.657] I> eks: Authentication Finalize Done
[0000.661] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 11:54:09, Dec 16 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea88ed58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is c1b4e372932429f2737cf722e1219e71
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg initialized
mrq initialized
[0001.076] I> Welcome to Cboot
[0001.076] I> Cboot Version: t194-8a9e8a5a
��fmon_post initialized
��[0001.076] I> CPU-BL Params @ 0xf2820000
[0001.077] I> 0) Base:0x00000000 Size:0x00000000
[0001.078] I> 1) Base:0xf1100000 Size:0x00100000
[0001.082] I> 2) Base:0xf2000000 Size:0x00200000
[0001.087] I> 3) Base:0xf1200000 Size:0x00200000
[0001.091] I> 4) Base:0xf1000000 Size:0x00100000
[0001.096] I> 5) Base:0xf0f00000 Size:0x00100000��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
[0001.165] I> 6) Base:0xf3800000 Size:0x00400000
[0001.169] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.174] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.178] I> 9) Base:0xf0d00000 Size:0x00100000��emc_debugfs initialized
dvs_debugfs initialized
[0001.188] I> 10) Base:0xf3000000 Size:0x00800000
��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.192] I> 11) Base:0x40000000 Size:0x00040000
[0001.243] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.247] I> 13) Base:0x40046000 Size:0x00002000
[0001.251] I> 14) Base:0x40048000 Size:0x00002000
[0001.256] I> 15) Base:0xac000000 Size:0x00004000
[0001.260] I> 16) Base:0x4004a000 Size:0x00002000
[0001.265] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.269] I> 18) Base:0x4004c000 Size:0x00002000
[0001.274] I> 19) Base:0xf2200000 Size:0x00600000
[0001.278] I> 20) Base:0x4004e000 Size:0x00002000
[0001.283] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.287] I> 22) Base:0x00000000 Size:0x00000000
[0001.292] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.296] I> 24) Base:0xf6000000 Size:0x02000000
[0001.301] I> 25) Base:0x40050000 Size:0x00002000
[0001.305] I> 26) Base:0x40040000 Size:0x00006000
[0001.309] I> 27) Base:0xf1800000 Size:0x00400000
[0001.314] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.318] I> 29) Base:0xf1400000 Size:0x00400000
[0001.323] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.327] I> 31) Base:0x00000000 Size:0x00000000
[0001.332] I> 32) Base:0xf8000000 Size:0x08000000
[0001.336] I> 33) Base:0x00000000 Size:0x00000000
[0001.341] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.345] I> 35) Base:0xab000000 Size:0x01000000
[0001.350] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.354] I> 37) Base:0xf2800000 Size:0x00800000
[0001.359] I> 38) Base:0x80000000 Size:0x20000000
[0001.363] I> 39) Base:0xb0000000 Size:0x08000000
[0001.367] I> 40) Base:0x00000000 Size:0x00000000
[0001.372] I> 41) Base:0x00000000 Size:0x00000000
[0001.376] I> 42) Base:0x00000000 Size:0x00000000
[0001.381] I> 43) Base:0x00000000 Size:0x00000000
[0001.385] I> 44) Base:0x00000000 Size:0x00000000
[0001.390] I> 45) Base:0x00000000 Size:0x00000000
[0001.394] GIC-SPI Target CPU: 0
[0001.397] Interrupts Init done
[0001.400] calling constructors
[0001.403] initializing heap
[0001.406] I> Heap: [0xa0690588 … 0xab000000]
[0001.410] initializing threads
[0001.413] initializing timers
[0001.416] creating bootstrap completion thread
[0001.420] top of bootstrap2()
[0001.423] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.427] initializing platform
[0001.430] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.436] W> device prod register failed
[0001.439] I> Bl_dtb @0xaaf00000
[0001.447] E> “plugin-manager” doesn’t exist, creating
[0001.447] E> “ids” doesn’t exist, creating
[0001.452] E> “connection” doesn’t exist, creating
[0001.456] E> “configs” doesn’t exist, creating
[0001.468] I> Find /i2c@3160000’s alias i2c0
[0001.468] I> Reading eeprom i2c=0 address=0x50
[0001.494] I> Device at /i2c@3160000:0x50
[0001.494] I> Reading eeprom i2c=0 address=0x56
[0001.518] I> Device at /i2c@3160000:0x56
[0001.521] I> Find /i2c@3180000’s alias i2c2
[0001.522] I> Reading eeprom i2c=2 address=0x54
[0001.523] E> I2C: slave not found in slaves.
[0001.524] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start t.
[0001.525] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.525] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 a.
[0001.532] E> eeprom: Failed to read I2C slave device
[0001.537] I> Eeprom read failed 0x3526070d
[0001.541] I> Reading eeprom i2c=2 address=0x57
[0001.546] E> I2C: slave not found in slaves.
[0001.550] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.558] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.563] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.573] E> eeprom: Failed to read I2C slave device
[0001.577] I> Eeprom read failed 0x3526070d
[0001.581] I> Reading eeprom i2c=2 address=0x52
[0001.586] E> I2C: slave not found in slaves.
[0001.590] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.598] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.603] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.613] E> eeprom: Failed to read I2C slave device
[0001.617] I> Eeprom read failed 0x3526070d
[0001.623] I> Find /i2c@c240000’s alias i2c1
[0001.625] I> Reading eeprom i2c=1 address=0x52
[0001.631] E> I2C: slave not found in slaves.
[0001.634] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.642] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.647] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.657] E> eeprom: Retry to read I2C slave device.
[0001.662] E> I2C: slave not found in slaves.
[0001.666] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.674] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.679] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.689] E> eeprom: Failed to read I2C slave device
[0001.693] I> Eeprom read failed 0x3526070d
[0001.697] I> Reading eeprom i2c=1 address=0x50
[0001.702] E> I2C: slave not found in slaves.
[0001.706] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.714] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.719] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.729] E> eeprom: Retry to read I2C slave device.
[0001.734] E> I2C: slave not found in slaves.
[0001.738] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.746] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.751] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.761] E> eeprom: Failed to read I2C slave device
[0001.765] I> Eeprom read failed 0x3526070d
[0001.769] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.774] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.785] I> create_pm_ids: id: 2822-0000-700-L, len: 15
[0001.791] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.802] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.809] E> “i2c@3160000” doesn’t exist, creating
[0001.813] E> “module@0x50” doesn’t exist, creating
[0001.818] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.825] E> “module@0x56” doesn’t exist, creating
[0001.833] I> Adding plugin-manager/cvm
[0001.834] E> “chip-id” doesn’t exist, creating
[0001.837] I> Adding plugin-manager/chip-id/A02P
[0001.842] I> Plugin-manager override starting
[0001.848] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.857] I> node /plugin-manager/fragement-soft-wdt matches
[0001.869] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.873] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.888] I> Disable plugin-manager status in FDT
[0001.888] I> Plugin-manager override finished successfully
[0001.889] I> gpio framework initialized
[0001.891] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ drir
[0001.893] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon’r
[0001.898] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.906] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.913] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.920] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.926] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.933] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.941] E> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0001.947] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.955] I> fixed regulator driver initialized
[0001.965] I> register ‘maxim’ power off handle
[0001.966] I> virtual i2c enabled
[0001.966] I> registered ‘maxim,max20024’ pmic
[0001.969] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0001.976] I> Boot-device: eMMC
[0001.979] I> Boot_device: SDMMC_BOOT instance: 3
[0001.988] I> sdmmc-3 params source = boot args
[0001.988] I> sdmmc bdev is already initialized
[0001.992] I> sdmmc-3 params source = boot args
[0002.022] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.035] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.045] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.051] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.051] I> hdmi cable connected
[0002.053] E> set volts not configured for ‘vdd-1v0’
[0002.056] E> set volts not configured for ‘vdd-1v8-hs’
[0002.060] E> invalid display type
[0002.065] E> invalid display type
[0002.066] E> cannot find any other nvdisp nodes
[0002.070] E> I2C: slave not found in slaves.
[0002.070] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0002.071] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.072] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 a.
[0002.081] E> could not read edid
[0002.088] I> hdmi_enable, starting HDMI initialisation
[0002.093] I> hdmi_enable, HDMI initialisation complete
[0002.103] I> Load in CBoot Boot Options partition and parse it
[0002.104] E> Cannot read beyond partition boundary for CPUBL-CFG
[0002.106] E> tegrabl_read_cbo Failed to read CPUBL-CFG partition
[0002.112] W> platform_init: tegrabl_read_cbo failed with error 0xd0d0104
[0002.118] I> Hit any key to stop autoboot: 4 3 2 1
[0004.126] initializing target
[0004.126] calling apps_init()
[0004.127] starting app kernel_boot_app
[0004.146] I> found decompressor handler: lz4-legacy
[0004.147] I> decompressing BMP blob …
[0004.152] I> Kernel type = Normal
[0004.152] I> Loading partition kernel-bootctrl at 0xa4ab0000 from device(0x1)
[0004.159] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.159] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.160] I> ########## SD boot ##########
[0004.160] I> Found sdcard
[0004.163] I> enabling ‘vdd-sdmmc1-sw’ regulator
[0004.170] I> regulator ‘vdd-sdmmc1-sw’ already enabled
[0004.374] I> sdmmc SDR mode
[0004.388] I> -0 params source =
[0004.397] W> Cannot find any partition table for 00060000
[0004.397] I> Detect filesystem
[0004.401] I> fs_detect:173: Unsupported or no filesystem present
[0004.402] E> SD boot failed, err: 724238349
[0004.402] I> ########## USB boot ##########
[0004.407] W> No valid slot number is found in scratch register
[0004.407] W> Return default slot: _a
[0004.420] I> USB Firmware Version: 60.06 release
[0004.476] I> regulator of usb2-0 already enabled
[0004.484] I> regulator of usb2-1 already enabled
[0004.492] I> regulator of usb2-2 already enabled
[0004.502] I> enabling ‘vdd-5v-sata’ regulator
[0005.508] E> failed to initialize xhci controller
[0005.508] E> Error in init of XUSB host driver, err: 79790026
[0005.509] E> Failed to initialize device 5-0
[0005.509] E> USB boot failed, err: 2037973030
[0005.509] I> ########## Fixed storage boot ##########
[0005.510] I> Already published: 00010003
[0005.510] I> Look for boot partition
[0005.513] I> Fallback: assuming 0th partition is boot partition
[0005.519] I> Detect filesystem
[0005.546] I> Loading extlinux.conf …
[0005.546] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.583] I> L4T boot options
[0005.584] I> [1]: “primary kernel”
[0005.584] I> Enter choice:
[0008.585] I> Continuing with default option: 1
[0008.585] I> Loading kernel sig file from rootfs …
[0008.585] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.604] I> Loading kernel binary from rootfs …
[0008.604] I> rootfs path: /sdmmc_user/boot/Image
[0014.814] I> lookup_linear_dir:436: Invalid file block num
[0014.815] I> ext2_walk:142: ‘Image’ lookup failed
[0014.815] I> ext4_open_file:638: ‘/boot/Image’ lookup failed
[0014.815] E> file /sdmmc_user/boot/Image open failed!!
[0014.816] W> Failed to load kernel binary from rootfs (err=202113041)
[0014.816] I> Loading kernel binary from partition …
[0014.821] W> No valid slot number is found in scratch register
[0014.826] W> Return default slot: _a
[0014.830] I> A/B: bin_type (37) slot 0
[0014.833] I> Loading partition kernel at 0xa4ab0000 from device(0x1)
[0015.321] I> Validate kernel …
[0015.321] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0015.725] I> No kernel-dtb binary path
[0015.725] I> Loading kernel-dtb binary from partition …
[0015.726] W> No valid slot number is found in scratch register
[0015.726] W> Return default slot: _a
[0015.726] I> A/B: bin_type (38) slot 0
[0015.727] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0015.737] I> Validate kernel-dtb …
[0015.737] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0015.743] I> Loading ramdisk from rootfs …
[0015.743] I> rootfs path: /sdmmc_user/boot/initrd
[0021.969] I> lookup_linear_dir:436: Invalid file block num
[0021.969] I> ext2_walk:142: ‘initrd’ lookup failed
[0021.969] I> ext4_open_file:638: ‘/boot/initrd’ lookup failed
[0021.970] E> file /sdmmc_user/boot/initrd open failed!!
[0021.970] E> kernel boot failed
there’s failure to boot kernel, may I know what’s the modification you’ve done.
have you revise the image or this could reproduce with the native JP-4.6 release image?
Hi Jerry,
I have not done any modification, it is the native image and the issue repeates even after multiple flashes.
I dual booted my host system to ubuntu, and flashed the board with with JP 4.5.1 and i am able to boot now.
I am not sure weather the issue was with virtualbox/sdk manager/JP 4.6.
Can you edit your post with the serial console log? Use the “pencil” icon. Then add formatting and scrollbars to the log by placing a line with only three backquotes before and after the log. Will look like this:
(the same key as the tilde key in the upper left)
Or you could highlight the log and click the “code” icon (looks like “</>”).
Note that VMs are not officially supported. It doesn’t mean they can’t work, but configuring them correctly for USB passthrough is something you’d have to take up with the VM docs or help. What often happens is that USB disconnects and reconnects during the flash, and the VM does not pick up the reconnect. Don’t know if that is related, but if the flash completed and the flash logs show it flashed without error, then the VM would be unrelated to the problem.
Note that much of the fail logs are about not finding fundamental parts of the files which would have been flashed in to the Jetson. Such might fail if the USB failed during the flash at that point, or if for some reason host or device lacked storage space.
Your best bet would be to add dual boot to your system to add Ubuntu 18.04, or else to find a system with native Ubuntu on it. Barring that, then I’d suggest command line flash as a test from the VM (you can always use JetPack/SDK Manager again at a later date, but tell it to install packages while unchecking flash so it doesn’t reflash…command line is only for flash, not optional packages). Example with the Jetson in recovery mode and showing up on the host with lsusb, run from the “Linux_for_Tegra/” directory of the flash software:
sudo ./flash.sh jetson-xavier mmcblk0p1
