[0000.085] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0000.094] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.099] I> Boot-mode: Coldboot
[0000.102] I> Chip revision : A02P
[0000.105] I> Bootrom patch version : 15 (correctly patched)
[0000.110] I> ATE fuse revision : 0x200
[0000.114] I> Ram repair fuse : 0x0
[0000.117] I> Ram Code : 0x2
[0000.119] I> rst_source : 0x0
[0000.122] I> rst_level : 0x0
[0000.126] I> Boot-device: eMMC
[0000.141] I> sdmmc DDR50 mode
[0000.145] W> No valid slot number is found in scratch register
[0000.150] W> Return default slot: _a
[0000.154] I> Active Boot chain : 0
[0000.157] I> Boot-device: eMMC
[0000.160] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.168] I> Temperature = 31500
[0000.171] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.175] W> Skipping boost for clk: BPMP_APB
[0000.180] W> Skipping boost for clk: AXI_CBB
[0000.183] W> Skipping boost for clk: AON_CPU_NIC
[0000.188] W> Skipping boost for clk: CAN1
[0000.191] W> Skipping boost for clk: CAN2
[0000.196] I> Boot-device: eMMC
[0000.199] I> Boot-device: eMMC
[0000.208] I> Sdmmc: HS400 mode enabled
[0000.212] I> ECC region[0]: Start:0x0, End:0x0
[0000.217] I> ECC region[1]: Start:0x0, End:0x0
[0000.221] I> ECC region[2]: Start:0x0, End:0x0
[0000.225] I> ECC region[3]: Start:0x0, End:0x0
[0000.229] I> ECC region[4]: Start:0x0, End:0x0
[0000.233] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.239] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.243] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.248] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.252] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.258] E> FAILED: Thermal config
[0000.265] E> FAILED: MEMIO rail config
[0000.283] I> Boot-device: eMMC
[0000.292] I> sdmmc bdev is already initialized
[0000.365] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.373] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8)
[0000.374] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.375] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.375] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.381] W> device prod register failed
[0000.385] I> Boot-device: eMMC
[0000.388] I> Boot_device: SDMMC_BOOT instance: 3
[0000.394] I> sdmmc-3 params source = boot args
[0000.397] I> sdmmc bdev is already initialized
[0000.401] I> sdmmc-3 params source = boot args
[0000.409] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.416] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.417] W> No valid slot number is found in scratch register
[0000.422] W> Return default slot: _a
[0000.425] I> Active Boot chain : 0
[0000.429] I> parsing oem signed section of bpmp-fw header done
[0000.434] I> bpmp-fw binary init read from storage
[0000.439] I> oem authentication of bpmp-fw header done
[0000.446] I> bpmp-fw binary done read from storage
[0000.448] I> bpmp-fw: Authentication init Done
[0000.454] I> parsing oem signed section of cpubl header done
[0000.458] I> cpubl binary init read from storage
[0000.463] I> bpmp-fw: Authentication Finalize Done
[0000.467] I> oem authentication of cpubl header done
[0000.472] I> cpubl binary done read from storage
[0000.476] I> cpubl: Authentication init Done
[0000.483] I> parsing oem signed section of rce header done
[0000.486] I> rce binary init read from storage
[0000.491] I> Relocating BR-BCT
[0000.493] I> cpubl: Authentication Finalize Done
[0000.498] I> oem authentication of rce header done
[0000.502] I> rce binary done read from storage
[0000.507] I> rce: Authentication init Done
[0000.513] I> parsing oem signed section of ape header done
[0000.516] I> ape binary init read from storage
[0000.520] I> rce: Authentication Finalize Done
[0000.525] I> oem authentication of ape header done
[0000.529] I> ape binary done read from storage
[0000.533] I> ape: Authentication init Done
[0000.538] I> parsing oem signed section of tos header done
[0000.543] I> tos binary init read from storage
[0000.547] I> ape: Authentication Finalize Done
[0000.552] I> oem authentication of tos header done
[0000.556] I> tos binary done read from storage
[0000.560] I> tos: Authentication init Done
[0000.564] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.570] I> bpmp-fw-dtb binary init read from storage
[0000.575] I> tos: Authentication Finalize Done
[0000.581] I> oem authentication of bpmp-fw-dtb header done
[0000.588] I> bpmp-fw-dtb binary done read from storage
[0000.590] I> bpmp-fw-dtb: Authentication init Done
[0000.596] I> parsing oem signed section of cpubl-dtb header done
[0000.600] I> cpubl-dtb binary init read from storage
[0000.605] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.643] I> oem authentication of cpubl-dtb header done
[0000.644] I> cpubl-dtb binary done read from storage
[0000.644] I> cpubl-dtb: Authentication init Done
[0000.646] I> parsing oem signed section of eks header done
[0000.647] I> eks binary init read from storage
[0000.647] I> cpubl-dtb: Authentication Finalize Done
[0000.648] I> oem authentication of eks header done
[0000.652] I> eks binary done read from storage
[0000.656] I> eks: Authentication init Done
[0000.660] I> eks: Authentication Finalize Done
[0000.664] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing …
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.168] I> Welcome to Cboot
��fmon_post initialized
��[0001.168] I> Cboot Version: t194-cfa2bc91
[0001.168] I> CPU-BL Params @ 0xf2820000
[0001.169] I> 0) Base:0x00000000 Size:0x00000000
[0001.172] I> 1) Base:0xf1100000 Size:0x00100000
[0001.177] I> 2) Base:0xf2000000 Size:0x00200000
[0001.181] I> 3) Base:0xf1200000 Size:0x00200000
[0001.186] I> 4) Base:0xf1000000 Size:0x00100000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.190] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.269] I> 6) Base:0xf3800000 Size:0x00400000
[0001.274] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.278] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.283] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.287] I> 10) Base:0xf3000000 Size:0x00800000
[0001.292] I> 11) Base:0x40000000 Size:0x00040000
[0001.296] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.301] I> 13) Base:0x40046000 Size:0x00002000
[0001.305] I> 14) Base:0x40048000 Size:0x00002000
��emc_debugfs initialized
dvs_debugfs initialized
��[0001.310] I> 15) Base:0xac000000 Size:0x00004000
��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.319] I> 16) Base:0x4004a000 Size:0x00002000
[0001.369] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.374] I> 18) Base:0x4004c000 Size:0x00002000
[0001.378] I> 19) Base:0xf2200000 Size:0x00600000
[0001.383] I> 20) Base:0x4004e000 Size:0x00002000
[0001.387] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.392] I> 22) Base:0x00000000 Size:0x00000000
[0001.396] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.401] I> 24) Base:0xf6000000 Size:0x02000000
[0001.405] I> 25) Base:0x40050000 Size:0x00002000
[0001.409] I> 26) Base:0x40040000 Size:0x00006000
[0001.414] I> 27) Base:0xf1800000 Size:0x00400000
[0001.418] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.423] I> 29) Base:0xf1400000 Size:0x00400000
[0001.427] I> 30) Base:0x00000000 Size:0x00000000
[0001.432] I> 31) Base:0x00000000 Size:0x00000000
[0001.436] I> 32) Base:0xf8000000 Size:0x08000000
[0001.441] I> 33) Base:0x00000000 Size:0x00000000
[0001.445] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.450] I> 35) Base:0xab000000 Size:0x01000000
[0001.454] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.459] I> 37) Base:0xf2800000 Size:0x00800000
[0001.463] I> 38) Base:0x80000000 Size:0x20000000
[0001.467] I> 39) Base:0xb0000000 Size:0x08000000
[0001.472] I> 40) Base:0x00000000 Size:0x00000000
[0001.476] I> 41) Base:0x00000000 Size:0x00000000
[0001.481] I> 42) Base:0x00000000 Size:0x00000000
[0001.485] I> 43) Base:0x00000000 Size:0x00000000
[0001.490] I> 44) Base:0x00000000 Size:0x00000000
[0001.494] I> 45) Base:0x00000000 Size:0x00000000
[0001.499] GIC-SPI Target CPU: 0
[0001.502] Interrupts Init done
[0001.505] calling constructors
[0001.507] initializing heap
[0001.510] I> Heap: [0xa0699b80 … 0xab000000]
[0001.514] initializing threads
[0001.517] initializing timers
[0001.520] creating bootstrap completion thread
[0001.524] top of bootstrap2()
[0001.527] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.532] initializing platform
[0001.535] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.540] W> device prod register failed
[0001.544] I> Bl_dtb @0xaaf00000
[0001.550] W> “plugin-manager” doesn’t exist, creating
[0001.552] W> “ids” doesn’t exist, creating
[0001.556] W> “connection” doesn’t exist, creating
[0001.560] W> “configs” doesn’t exist, creating
[0001.574] E> failed to read label property for node 227172: 13
[0001.577] E> failed to read reg property for node 227260: 13
[0001.579] E> failed to read label property for node 227312: 13
[0001.583] E> failed to read label property for node 227380: 13
[0001.588] E> failed to read label property for node 227416: 13
[0001.594] E> failed to read label property for node 227452: 13
[0001.599] E> failed to read reg property for node 227520: 13
[0001.605] E> failed to read label property for node 227572: 13
[0001.612] I> Find /i2c@3160000’s alias i2c0
[0001.614] I> Reading eeprom i2c=0 address=0x50
[0001.643] I> Device at /i2c@3160000:0x50
[0001.644] I> Reading eeprom i2c=0 address=0x56
[0001.668] I> Device at /i2c@3160000:0x56
[0001.669] I> Find /i2c@3180000’s alias i2c2
[0001.669] I> Reading eeprom i2c=2 address=0x54
[0001.671] E> I2C: slave not found in slaves.
[0001.671] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start t.
[0001.672] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.673] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 a.
[0001.682] E> eeprom: Failed to read I2C slave device
[0001.687] I> Eeprom read failed 0x3526070d
[0001.691] I> Reading eeprom i2c=2 address=0x57
[0001.695] E> I2C: slave not found in slaves.
[0001.699] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.707] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.713] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.722] E> eeprom: Failed to read I2C slave device
[0001.727] I> Eeprom read failed 0x3526070d
[0001.731] I> Reading eeprom i2c=2 address=0x52
[0001.735] E> I2C: slave not found in slaves.
[0001.739] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.747] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.753] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.762] E> eeprom: Failed to read I2C slave device
[0001.767] I> Eeprom read failed 0x3526070d
[0001.772] I> Find /i2c@c240000’s alias i2c1
[0001.775] I> Reading eeprom i2c=1 address=0x52
[0001.781] E> I2C: slave not found in slaves.
[0001.783] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.791] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.797] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.806] E> eeprom: Retry to read I2C slave device.
[0001.811] E> I2C: slave not found in slaves.
[0001.815] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.823] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.829] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.838] E> eeprom: Failed to read I2C slave device
[0001.843] I> Eeprom read failed 0x3526070d
[0001.847] I> Reading eeprom i2c=1 address=0x50
[0001.851] E> I2C: slave not found in slaves.
[0001.855] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.863] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.869] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.878] E> eeprom: Retry to read I2C slave device.
[0001.883] E> I2C: slave not found in slaves.
[0001.887] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.895] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.901] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.910] E> eeprom: Failed to read I2C slave device
[0001.915] I> Eeprom read failed 0x3526070d
[0001.919] I> create_pm_ids: id: 2888-0004-400-N, len: 15
[0001.924] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.935] I> create_pm_ids: id: 2822-0000-700-M, len: 15
[0001.940] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.951] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.959] W> “i2c@3160000” doesn’t exist, creating
[0001.963] W> “module@0x50” doesn’t exist, creating
[0001.968] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.975] W> “module@0x56” doesn’t exist, creating
[0001.981] I> Adding plugin-manager/cvm
[0001.983] W> “chip-id” doesn’t exist, creating
[0001.987] I> Adding plugin-manager/chip-id/A02P
[0001.992] I> Plugin-manager override starting
[0001.996] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.004] I> node /plugin-manager/fragement-soft-wdt matches
[0002.012] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.016] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.028] I> Disable plugin-manager status in FDT
[0002.029] I> Plugin-manager override finished successfully
[0002.029] I> gpio framework initialized
[0002.033] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ drir
[0002.041] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon’r
[0002.047] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.055] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.063] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.069] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.075] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.083] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.090] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.097] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.104] I> fixed regulator driver initialized
[0002.117] I> register ‘maxim’ power off handle
[0002.117] I> virtual i2c enabled
[0002.118] I> registered ‘maxim,max20024’ pmic
[0002.119] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.126] I> Boot-device: eMMC
[0002.129] I> Boot_device: SDMMC_BOOT instance: 3
[0002.137] I> sdmmc-3 params source = boot args
[0002.138] I> create_pm_ids: id: 2888-0004-400-N, len: 15
[0002.142] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.154] I> create_pm_ids: id: 2822-0000-700-M, len: 15
[0002.159] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.170] I> sdmmc bdev is already initialized
[0002.174] I> sdmmc-3 params source = boot args
[0002.205] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.218] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.227] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.232] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.232] I> hdmi cable connected
[0002.234] W> set volts not configured for ‘vdd-1v0’
[0002.236] W> set volts not configured for ‘vdd-1v8-hs’
[0002.236] I> retrieved tmds range from prod_list_hdmi_soc
[0002.240] E> invalid display type
[0002.243] E> invalid display type
[0002.244] E> cannot find any other nvdisp nodes
[0002.260] I> edid read success
[0002.272] I> edid read success
[0002.272] I> width = 640, height = 480, frequency = 25174825
[0002.273] I> width = 1920, height = 1080, frequency = 148500000
[0002.273] I> width = 1366, height = 768, frequency = 85500000
[0002.274] I> width = 720, height = 480, frequency = 27000000
[0002.274] I> width = 720, height = 576, frequency = 27000000
[0002.278] I> width = 640, height = 480, frequency = 25174825
[0002.283] I> width = 720, height = 480, frequency = 26973026
[0002.289] I> width = 1280, height = 720, frequency = 74175824
[0002.294] I> width = 1920, height = 1080, frequency = 148351648
[0002.300] I> width = 720, height = 576, frequency = 26973026
[0002.306] I> width = 1280, height = 720, frequency = 74175824
[0002.311] I> width = 1920, height = 1080, frequency = 148351648
[0002.317] I> width = 1920, height = 1080, frequency = 74175824
[0002.323] I> width = 1920, height = 1080, frequency = 74175824
[0002.328] I> width = 1920, height = 1080, frequency = 74175824
[0002.334] I> width = 3840, height = 2160, frequency = 296703296
[0002.340] I> width = 3840, height = 2160, frequency = 296703296
[0002.346] I> width = 3840, height = 2160, frequency = 296703296
[0002.351] I> width = 4096, height = 2160, frequency = 296703296
[0002.357] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.367] I> hdmi_enable, starting HDMI initialisation
[0002.372] I> hdmi_enable, HDMI initialisation complete
[0002.383] I> Load in CBoot Boot Options partition and parse it
[0002.390] E> Error -9 when finding node with path /boot-configuration
[0002.390] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO fil.
[0002.393] I> Using default boot order
[0002.396] I> boot-dev-order :-
[0002.399] I> 1.sd
[0002.401] I> 2.usb
[0002.403] I> 3.nvme
[0002.405] I> 4.emmc
[0002.406] I> 5.net
[0002.408] I> Hit any key to stop autoboot: 4 3 2 1
[0004.416] initializing target
[0004.416] calling apps_init()
[0004.417] starting app kernel_boot_app
[0004.437] I> found decompressor handler: lz4-legacy
[0004.437] I> decompressing BMP blob …
[0004.448] I> Kernel type = Normal
[0004.449] I> ########## SD (0) boot ##########
[0004.449] I> No sdcard
[0004.449] I> -0 params source =
[0004.450] E> Blockdev open: exit error
[0004.450] E> SD boot failed, err: 724238353
[0004.450] I> ########## USB (0) boot ##########
[0004.455] W> No valid slot number is found in scratch register
[0004.456] W> Return default slot: _a
[0004.463] I> Validate XUSB-FW …
[0004.464] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x28000
[0004.468] I> Encryption fuse is not ON
[0004.471] I> USB Firmware Version: 60.09 release
[0004.530] I> regulator of usb2-0 already enabled
[0004.536] I> regulator of usb2-1 already enabled
[0004.543] I> regulator of usb2-2 already enabled
[0004.551] I> enabling ‘vdd-5v-sata’ regulator
[0005.555] E> failed to initialize xhci controller
[0005.556] E> Error in init of XUSB host driver, err: 79790026
[0005.556] W> Failed to initialize device 5-0
[0005.556] E> USB boot failed, err: 2037973030
[0005.557] I> ########## NVME (0) boot ##########
[0005.557] I> Initializing nvme device instance 0
[0005.558] I> Initializing nvme controller
[0005.562] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0005.568] I> vpcie3v3-supply not found
[0005.572] I> vpcie12v-supply not found
[0005.575] W> Failed to get nvidia,plat-gpios
[0005.579] I> tegrabl_pcie_soc_preinit: (0):
[0005.583] I> Unpowergate
[0005.586] I> tegrabl_car_clk_disable(0) …
[0005.590] I> tegrabl_car_rst_set(CORE, 0) …
[0005.594] I> tegrabl_car_rst_set(APB, 0) …
[0005.598] I> tegrabl_car_clk_enable(0) …
[0005.602] I> tegrabl_car_rst_clear(APB, 0) …
[0005.606] I> tegrabl_set_ctrl_state(0)
[0005.610] I> CLR PCIE_APB:6
[0005.613] I> tegrabl_pcie_soc_init: (0):
[0005.616] I> APPL initialization …
[0005.620] I> poweron phys
[0005.622] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0005.629] I> tegrabl_power_on_phy: power on phy @0x3e30000
[0005.634] I> tegrabl_power_on_phy: power on phy @0x3e40000
[0005.639] I> tegrabl_power_on_phy: power on phy @0x3e50000
[0005.645] I> tegrabl_power_on_phy: power on phy @0x3e60000
[0006.750] C> Failed to link up controller-0
[0006.751] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0006.751] I> Failed to initialize SoC Host PCIe controller
[0006.751] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x12
[0006.752] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0006.752] W> Failed to open NVME-0, err = 80800612
[0006.757] W> Failed to initialize device 10-0
[0006.761] E> NVME (0) boot failed, err: 0x80800612
[0006.766] I> ########## NVME (1) boot ##########
[0006.770] I> Initializing nvme device instance 1
[0006.775] I> Initializing nvme controller
[0006.779] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0006.785] I> vpcie3v3-supply not found
[0006.788] I> vpcie12v-supply not found
[0006.792] W> Failed to get nvidia,plat-gpios
[0006.796] I> tegrabl_pcie_soc_preinit: (1):
[0006.800] I> Unpowergate
[0006.803] I> tegrabl_car_clk_disable(1) …
[0006.807] I> tegrabl_car_rst_set(CORE, 1) …
[0006.811] I> tegrabl_car_rst_set(APB, 1) …
[0006.815] I> tegrabl_car_clk_enable(1) …
[0006.819] I> tegrabl_car_rst_clear(APB, 1) …
[0006.823] I> tegrabl_set_ctrl_state(1)
[0006.827] I> CLR PCIE_APB:6
[0006.829] I> tegrabl_pcie_soc_init: (1):
[0006.833] I> APPL initialization …
[0006.837] I> poweron phys
[0006.839] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0006.845] I> tegrabl_power_on_phy: power on phy @0x3e10000
[0006.952] I> PCIe controller-1 link is up
[0006.953] I> tegra_pcie_info[1].cfg0_base = 0x30000000
[0006.953] I> tegra_pcie_info[1].cfg1_base = 0x30020000
[0006.953] I> tegra_pcie_info[1].atu_dma_base = 0x30040000
[0006.954] I> tegra_pcie_bus[1].mem = 0x30200000
[0006.954] I> Scanning busnr: 0 devfn: 0
[0006.954] I> PCIe IDs: 0x1ad210de
[0006.958] I> PCIe RID_CC: 0x60400a1
[0006.961] I> Scanning busnr: 1 devfn: 0
[0006.965] I> PCIe IDs: 0x91711b4b
[0006.968] I> PCIe RID_CC: 0x1060113
[0006.971] I> PCI Config: I/O=0x30100000, Memory=0x30200000
[0006.976] I> IO bar_num=0 bar=0x30100000
[0006.980] I> IO bar_num=1 bar=0x30100008
[0006.984] I> IO bar_num=2 bar=0x30100010
[0006.988] I> IO bar_num=3 bar=0x30100018
[0006.991] I> IO bar_num=4 bar=0x30100020
[0006.995] I> MEM bar_num=5 bar=0x30200000
[0006.999] I> Number of PCIe devices detected: 2
[0007.003] E> tegrabl_nvme_init: Failed tegrabl_pcie_get_dev(1); error=0x0
[0007.010] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0007.017] W> Failed to open NVME-1, err = 80800612
[0007.021] W> Failed to initialize device 10-1
[0007.025] E> NVME (1) boot failed, err: 0x80800612
[0007.030] I> ########## NVME (2) boot ##########
[0007.034] I> Initializing nvme device instance 2
[0007.039] I> Initializing nvme controller
[0007.043] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0007.049] I> vpcie3v3-supply not found
[0007.053] I> vpcie12v-supply not found
[0007.056] W> Failed to get nvidia,plat-gpios
[0007.060] I> tegrabl_pcie_soc_preinit: (2):
[0007.065] I> Unpowergate
[0007.067] I> tegrabl_car_clk_disable(2) …
[0007.071] I> tegrabl_car_rst_set(CORE, 2) …
[0007.075] I> tegrabl_car_rst_set(APB, 2) …
[0007.079] I> tegrabl_car_clk_enable(2) …
[0007.083] I> tegrabl_car_rst_clear(APB, 2) …
[0007.087] I> tegrabl_set_ctrl_state(2)
[0007.091] I> CLR PCIE_APB:6
[0007.094] I> tegrabl_pcie_soc_init: (2):
[0007.097] I> APPL initialization …
[0007.101] I> poweron phys
[0007.104] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0007.110] I> tegrabl_power_on_phy: controller 2 not available
[0007.115] E> Failed to power on phy on controller-2
[0007.120] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0007.125] I> Failed to initialize SoC Host PCIe controller
[0007.130] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0007.137] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0007.143] W> Failed to open NVME-2, err = 80800601
[0007.148] W> Failed to initialize device 10-2
[0007.152] E> NVME (2) boot failed, err: 0x80800601
[0007.157] I> ########## NVME (3) boot ##########
[0007.161] I> Initializing nvme device instance 3
[0007.166] I> Initializing nvme controller
[0007.170] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0007.176] I> vpcie3v3-supply not found
[0007.179] I> vpcie12v-supply not found
[0007.183] W> Failed to get nvidia,plat-gpios
[0007.187] I> tegrabl_pcie_soc_preinit: (3):
[0007.191] I> Unpowergate
[0007.194] I> tegrabl_car_clk_disable(3) …
[0007.198] I> tegrabl_car_rst_set(CORE, 3) …
[0007.202] I> tegrabl_car_rst_set(APB, 3) …
[0007.206] I> tegrabl_car_clk_enable(3) …
[0007.210] I> tegrabl_car_rst_clear(APB, 3) …
[0007.214] I> tegrabl_set_ctrl_state(3)
[0007.218] I> CLR PCIE_APB:6
[0007.220] I> tegrabl_pcie_soc_init: (3):
[0007.224] I> APPL initialization …
[0007.227] I> poweron phys
[0007.230] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0007.236] I> tegrabl_power_on_phy: power on phy @0x3e80000
[0008.342] C> Failed to link up controller-3
[0008.342] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0008.343] I> Failed to initialize SoC Host PCIe controller
[0008.343] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x12
[0008.344] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0008.344] W> Failed to open NVME-3, err = 80800612
[0008.349] W> Failed to initialize device 10-3
[0008.353] E> NVME (3) boot failed, err: 0x80800612
[0008.358] I> ########## NVME (4) boot ##########
[0008.362] I> Initializing nvme device instance 4
[0008.366] I> Initializing nvme controller
[0008.371] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0008.377] I> vpcie3v3-supply not found
[0008.380] I> vpcie12v-supply not found
[0008.384] W> Failed to get nvidia,plat-gpios
[0008.388] I> tegrabl_pcie_soc_preinit: (4):
[0008.392] I> Unpowergate
[0008.395] I> tegrabl_car_clk_disable(4) …
[0008.398] I> tegrabl_car_rst_set(CORE, 4) …
[0008.403] I> tegrabl_car_rst_set(APB, 4) …
[0008.407] I> tegrabl_car_clk_enable(4) …
[0008.411] I> tegrabl_car_rst_clear(APB, 4) …
[0008.415] I> tegrabl_set_ctrl_state(4)
[0008.419] I> CLR PCIE_APB:6
[0008.421] I> tegrabl_pcie_soc_init: (4):
[0008.425] I> APPL initialization …
[0008.428] I> poweron phys
[0008.431] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0008.437] I> tegrabl_power_on_phy: controller 4 not available
[0008.443] E> Failed to power on phy on controller-4
[0008.448] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0008.452] I> Failed to initialize SoC Host PCIe controller
[0008.458] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x1
[0008.464] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0008.471] W> Failed to open NVME-4, err = 80800601
[0008.475] W> Failed to initialize device 10-4
[0008.480] E> NVME (4) boot failed, err: 0x80800601
[0008.484] I> ########## NVME (5) boot ##########
[0008.489] I> Initializing nvme device instance 5
[0008.493] I> Initializing nvme controller
[0008.498] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0008.503] I> i=0, reg_phandle=0x1b
[0008.509] I> reg_voltage=3300000
[0008.510] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1b, 33000)
[0008.521] I> enabling ‘vdd-3v3-pcie’ regulator
[0008.521] I> i=1, reg_phandle=0x1c
[0008.526] I> reg_voltage=1200000
[0008.528] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1c, 12000)
[0008.539] I> enabling ‘vdd-12v-pcie’ regulator
[0008.539] I> tegrabl_pcie_soc_preinit: (5):
[0008.543] I> Unpowergate
[0008.546] I> tegrabl_car_clk_disable(5) …
[0008.550] I> tegrabl_car_rst_set(CORE, 5) …
[0008.554] I> tegrabl_car_rst_set(APB, 5) …
[0008.558] I> tegrabl_car_clk_enable(5) …
[0008.562] I> tegrabl_car_rst_clear(APB, 5) …
[0008.566] I> tegrabl_set_ctrl_state(5)
[0008.570] I> CLR PCIE_APB:6
[0008.573] I> tegrabl_pcie_soc_init: (5):
[0008.576] I> APPL initialization …
[0008.580] I> poweron phys
[0008.583] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0008.589] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0008.594] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0008.599] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0008.605] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0008.610] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0008.615] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0008.621] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0008.626] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0009.731] C> Failed to link up controller-5
[0009.732] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0009.732] I> Failed to initialize SoC Host PCIe controller
[0009.733] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0009.733] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0009.734] W> Failed to open NVME-5, err = 80800612
[0009.738] W> Failed to initialize device 10-5
[0009.742] E> NVME (5) boot failed, err: 0x80800612
[0009.747] I> ########## Fixed storage boot ##########
[0009.752] I> Loading kernel-bootctrl from partition
[0009.757] I> Loading partition kernel-bootctrl at 0xa4ae0000 from device(0x1)
[0009.770] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0009.771] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0009.784] I> Already published: 00010003
[0009.785] I> Look for boot partition
[0009.785] I> Fallback: assuming 0th partition is boot partition
[0009.791] I> Detect filesystem
[0009.818] I> Loading extlinux.conf …
[0009.818] I> Loading extlinux.conf binary from rootfs …
[0009.818] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0009.873] I> Loading extlinux.conf sig file from rootfs …
[0009.874] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf.sig
[0009.910] I> Validate extlinux.conf …
[0009.911] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0009.911] I> Encryption fuse is not ON
[0009.912] I> L4T boot options
[0009.912] I> [1]: “primary kernel”
[0009.912] I> Enter choice:
[0012.913] I> Continuing with default option: 1
[0012.913] I> Loading kernel …
[0012.913] I> Loading kernel binary from rootfs …
[0012.914] I> rootfs path: /sdmmc_user/boot/Image
[0012.938] I> ext2_walk:142: ‘Image’ lookup failed
[0012.938] I> ext4_open_file:666: ‘/boot/Image’ lookup failed
[0012.939] E> file /sdmmc_user/boot/Image open failed!!
[0012.939] W> Failed to load kernel binary from rootfs (err=202113041)
[0012.940] I> Continue to load from partition …
[0012.940] W> No valid slot number is found in scratch register
[0012.945] W> Return default slot: _a
[0012.948] I> A/B: bin_type (37) slot 0
[0012.952] I> Loading kernel from partition
[0012.955] I> Loading partition kernel at 0xa4ae0000 from device(0x1)
[0013.451] I> Validate kernel …
[0013.451] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0013.452] E> Stage2Signature validation failed with SHA2!!
[0013.452] C> OEM authentication of kernel header failed!
[0013.452] E> Failed to validate kernel binary from partition (err=1077936152)
[0013.453] I> Checking boot.img header magic … [0013.457] E> Invalid header mc
[0013.460] E> Failed to load kernel, abort booting.
[0013.465] E> Failed extlinux boot.
[0013.488] I> Kernel EP: 0x0, DTB: 0x90000000
[0013.489]
[0013.489] -----------------------------------------------
[0013.491] Synchronous Exception: UNKNOWN EXCEPTION
[0013.493] -----------------------------------------------
[0013.495]
[0013.495] ESR 0x2000000: ec 0x0, il 0x1, iss 0x0
[0013.497] -----------------------------------------------
[0013.499] [Stack Trace]
[0013.502]
[0013.503] => pc:0x00000000, sp:0xA0EAD530
[0013.507] => pc:0xA060F790, sp:0xA0EAD760
[0013.511] => pc:0xA060F7A4, sp:0xA0EAD7B0
[0013.514] => pc:0xA060F58C, sp:0xA0EAD7E0
[0013.518] => pc:0xA060EB00, sp:0xA0EAD7F0
[0013.522] => pc:0xA060EAD4, sp:0xA0EAD800
[0013.526] -----------------------------------------------
[0013.531] iframe 0xa0ead440:
[0013.534] x0 0x 90000000 x1 0x 0 x2 0x 00
[0013.543] x4 0x 0 x5 0x 20 x6 0x b2001230
[0013.552] x8 0x 0 x9 0xffffffffffffffff x10 0x 62
[0013.561] x12 0x 1 x13 0x 40 x14 0x 10
[0013.570] x16 0x 1500 x17 0x 438 x18 0x 00
[0013.580] x20 0x 0 x21 0x 0 x22 0x 00
[0013.589] x24 0x 0 x25 0x 0 x26 0x 00
[0013.598] x28 0x 0 x29 0x a0ead760 lr 0x a060f7440
[0013.607] elr 0x 0
[0013.610] spsr 0x 400003c9
[0013.613] -----------------------------------------------
[0013.618] panic (caller 0xa0601238): die
[0013.622] HALT: spinning forever…
Once connected, you will see the boot log. This might provide some clue where it is getting stuck
