Jetson AGX Xavier suddenly reboot issue
I used Jetson AGX Xavier(JetPack 4.4),when the electricity comes on, sometimes Jetson AGX Xavier suddenly reboot.
I do steps:
  1. open some debug:
    +CONFIG_PREEMPT=y
    +CONFIG_DEBUG_KERNEL=y
    +CONFIG_KLLSYMS=y
    +CONFIG_SPINLOCK_SLEEP=y
  2. echo “8 6 1 7” > /proc/sys/kernel/printk
3. echo 1 > /proc/sys/kernel/panic_on_oops
But I didn’t catch anything by console serial port,
here are some truncated logs:
[  200.210519] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  201.871557] tegra194-vi5 15c10000.vi: no reply from camera processor
[  201.871707] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  201.872136] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  201.875080] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  202.655747] tegra194-vi5 15c10000.vi: no reply from camera processor
[  202.655904] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  202.656172] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  202.658482] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[  202.727749] tegra194-vi5 15c10000.vi: no reply from camera processor
[  202.727914] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[  202.728128] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[  202.730406] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[0000.446] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.454] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.460] I> Boot-mode: Coldboot
[0000.463] I> Chip revision : A02P
[0000.466] I> Bootrom patch version : 15 (correctly patched)
[0000.471] I> ATE fuse revision : 0x200
[0000.474] I> Ram repair fuse : 0x0
[0000.477] I> Ram Code : 0x2
[0000.480] I> rst_source : 0x0
[0000.483] I> rst_level : 0x0
[0000.486] I> Boot-device: eMMC
[0000.501] I> sdmmc DDR50 mode
[0000.505] I> Active Boot chain : 0
[0000.508] I> Boot-device: eMMC
[0000.512] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.520] I> Temperature = 44500
[0000.523] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.527] W> Skipping boost for clk: BPMP_APB
[0000.531] W> Skipping boost for clk: AXI_CBB
[0000.535] W> Skipping boost for clk: AON_CPU_NIC
[0000.540] W> Skipping boost for clk: CAN1
[0000.543] W> Skipping boost for clk: CAN2
[0000.548] I> Boot-device: eMMC
[0000.550] I> Boot-device: eMMC
[0000.560] I> Sdmmc: HS400 mode enabled
[0000.564] I> ECC region[0]: Start:0x0, End:0x0
[0000.568] I> ECC region[1]: Start:0x0, End:0x0
[0000.573] I> ECC region[2]: Start:0x0, End:0x0
[0000.577] I> ECC region[3]: Start:0x0, End:0x0
[0000.581] I> ECC region[4]: Start:0x0, End:0x0
[0000.585] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.591] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.595] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.600] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.604] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.609] E> FAILED: Thermal config
[0000.617] E> FAILED: MEMIO rail config
[0000.635] I> Boot-device: eMMC
[0000.645] I> sdmmc bdev is already initialized
[0000.717] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [0000.726] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-389501e9)
[0000.727] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.727] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.728] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.734] W> device prod register failed
[0000.737] I> Boot-device: eMMC
[0000.740] I> Boot_device: SDMMC_BOOT instance: 3
[0000.746] I> sdmmc-3 params source = boot args
[0000.749] I> sdmmc bdev is already initialized
[0000.753] I> sdmmc-3 params source = boot args
[0000.760] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.767] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.769] I> Active Boot chain : 0
[0000.772] I> parsing oem signed section of bpmp-fw header done
[0000.777] I> bpmp-fw binary init read from storage
[0000.782] I> oem authentication of bpmp-fw header done
[0000.789] I> bpmp-fw binary done read from storage
[0000.792] I> bpmp-fw: Authentication init Done
[0000.796] I> parsing oem signed section of cpubl header done
[0000.802] I> cpubl binary init read from storage
[0000.806] I> bpmp-fw: Authentication Finalize Done
[0000.811] I> oem authentication of cpubl header done
[0000.815] I> cpubl binary done read from storage
[0000.820] I> cpubl: Authentication init Done
[0000.824] I> parsing oem signed section of rce header done
[0000.829] I> rce binary init read from storage
[0000.834] I> Relocating BR-BCT
[0000.837] I> cpubl: Authentication Finalize Done
[0000.841] I> oem authentication of rce header done
[0000.846] I> rce binary done read from storage
[0000.850] I> rce: Authentication init Done
[0000.856] I> parsing oem signed section of ape header done
[0000.859] I> ape binary init read from storage
[0000.864] I> rce: Authentication Finalize Done
[0000.868] I> oem authentication of ape header done
[0000.872] I> ape binary done read from storage
[0000.877] I> ape: Authentication init Done
[0000.881] I> parsing oem signed section of tos header done
[0000.886] I> tos binary init read from storage
[0000.890] I> ape: Authentication Finalize Done
[0000.895] I> oem authentication of tos header done
[0000.899] I> tos binary done read from storage
[0000.903] I> tos: Authentication init Done
[0000.909] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.913] I> bpmp-fw-dtb binary init read from storage
[0000.918] I> tos: Authentication Finalize Done
[0000.924] I> oem authentication of bpmp-fw-dtb header done
[0000.931] I> bpmp-fw-dtb binary done read from storage
[0000.933] I> bpmp-fw-dtb: Authentication init Done
[0000.939] I> parsing oem signed section of cpubl-dtb header done
[0000.944] I> cpubl-dtb binary init read from storage
[0000.948] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.986] I> oem authentication of cpubl-dtb header done
[0000.986] I> cpubl-dtb binary done read from storage
[0000.987] I> cpubl-dtb: Authentication init Done
[0000.989] I> parsing oem signed section of eks header done
[0000.989] I> eks binary init read from storage
[0000.990] I> cpubl-dtb: Authentication Finalize Done
[0000.991] I> oem authentication of eks header done
[0000.994] I> eks binary done read from storage
[0000.999] I> eks: Authentication init Done
[0001.003] I> eks: Authentication Finalize Done
[0001.007] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE:  BL31: v1.3(release):de895fd9e
NOTICE:  BL31: Built : 12:15:31, Oct 16 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing .......
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
  [0001.511] I> Welcome to Cboot
��fmon_post initialized
��[0001.511] I> Cboot Version: t194-aad9d75e
[0001.511] I> CPU-BL Params @ 0xf2820000
[0001.512] I>  0) Base:0x00000000 Size:0x00000000
[0001.515] I>  1) Base:0xf1100000 Size:0x00100000
[0001.520] I>  2) Base:0xf2000000 Size:0x00200000
[0001.524] I>  3) Base:0xf1200000 Size:0x00200000
��clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.528] I>  4) Base:0xf1000000 Size:0x00100000
[0001.633] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.638] I>  6) Base:0xf3800000 Size:0x00400000
[0001.642] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.647] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.651] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.656] I> 10) Base:0xf3000000 Size:0x00800000
[0001.660] I> 11) Base:0x40000000 Size:0x00040000
[0001.665] I> 12) Base:0xf0c00000 Size:0x00100000
��emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.669] I> 13) Base:0x40046000 Size:0x00002000
[0001.724] I> 14) Base:0x40048000 Size:0x00002000
[0001.728] I> 15) Base:0xac000000 Size:0x00004000
[0001.733] I> 16) Base:0x4004a000 Size:0x00002000
[0001.737] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.742] I> 18) Base:0x4004c000 Size:0x00002000
[0001.746] I> 19) Base:0xf2200000 Size:0x00600000
[0001.751] I> 20) Base:0x4004e000 Size:0x00002000
[0001.755] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.760] I> 22) Base:0x00000000 Size:0x00000000
[0001.764] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.769] I> 24) Base:0xf6000000 Size:0x02000000
[0001.773] I> 25) Base:0x40050000 Size:0x00002000
[0001.777] I> 26) Base:0x40040000 Size:0x00006000
[0001.782] I> 27) Base:0xf1800000 Size:0x00400000
[0001.786] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.791] I> 29) Base:0xf1400000 Size:0x00400000
[0001.795] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.800] I> 31) Base:0x00000000 Size:0x00000000
[0001.804] I> 32) Base:0xf8000000 Size:0x08000000
[0001.809] I> 33) Base:0x00000000 Size:0x00000000
[0001.813] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.818] I> 35) Base:0xab000000 Size:0x01000000
[0001.822] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.827] I> 37) Base:0xf2800000 Size:0x00800000
[0001.831] I> 38) Base:0x80000000 Size:0x20000000
[0001.835] I> 39) Base:0xb0000000 Size:0x08000000
[0001.840] I> 40) Base:0x00000000 Size:0x00000000
[0001.844] I> 41) Base:0x00000000 Size:0x00000000
[0001.849] I> 42) Base:0x00000000 Size:0x00000000
[0001.853] I> 43) Base:0x00000000 Size:0x00000000
[0001.858] I> 44) Base:0x00000000 Size:0x00000000
[0001.862] I> 45) Base:0x00000000 Size:0x00000000
[0001.867] GIC-SPI Target CPU: 0
[0001.870] Interrupts Init done
[0001.873] calling constructors
[0001.875] initializing heap
[0001.878] I> Heap: [0xa0691568 ... 0xab000000]
[0001.882] initializing threads
[0001.885] initializing timers
[0001.888] creating bootstrap completion thread
[0001.892] top of bootstrap2()
[0001.895] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.900] initializing platform
[0001.903] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.908] W> device prod register failed
[0001.912] I> Bl_dtb @0xaaf00000
[0001.918] W> "plugin-manager" doesn't exist, creating
[0001.920] W> "ids" doesn't exist, creating
[0001.924] W> "connection" doesn't exist, creating
[0001.928] W> "configs" doesn't exist, creating
[0001.938] I> Find /i2c@3160000's alias i2c0
[0001.939] I> Reading eeprom i2c=0 address=0x50
[0001.966] I> Device at /i2c@3160000:0x50
[0001.967] I> Reading eeprom i2c=0 address=0x56
[0001.991] I> Device at /i2c@3160000:0x56
[0001.993] I> Find /i2c@3180000's alias i2c2
[0001.993] I> Reading eeprom i2c=2 address=0x54
[0001.995] E> I2C: slave not found in slaves.
[0001.995] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.996] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.996] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0002.005] E> eeprom: Failed to read I2C slave device
[0002.010] I> Eeprom read failed 0x3526070d
[0002.014] I> Reading eeprom i2c=2 address=0x57
[0002.018] E> I2C: slave not found in slaves.
[0002.022] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.030] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.036] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0002.045] E> eeprom: Failed to read I2C slave device
[0002.050] I> Eeprom read failed 0x3526070d
[0002.054] I> Reading eeprom i2c=2 address=0x52
[0002.058] E> I2C: slave not found in slaves.
[0002.062] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.070] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.076] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0002.085] E> eeprom: Failed to read I2C slave device
[0002.090] I> Eeprom read failed 0x3526070d
[0002.095] I> Find /i2c@c240000's alias i2c1
[0002.098] I> Reading eeprom i2c=1 address=0x52
[0002.104] E> I2C: slave not found in slaves.
[0002.106] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.114] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.120] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.129] E> eeprom: Retry to read I2C slave device.
[0002.134] E> I2C: slave not found in slaves.
[0002.138] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.146] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.152] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.161] E> eeprom: Failed to read I2C slave device
[0002.166] I> Eeprom read failed 0x3526070d
[0002.170] I> Reading eeprom i2c=1 address=0x50
[0002.174] E> I2C: slave not found in slaves.
[0002.178] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.186] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.192] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.201] E> eeprom: Retry to read I2C slave device.
[0002.206] E> I2C: slave not found in slaves.
[0002.210] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.218] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.224] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.233] E> eeprom: Failed to read I2C slave device
[0002.238] I> Eeprom read failed 0x3526070d
[0002.242] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.247] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.258] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.263] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0002.274] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.282] W> "i2c@3160000" doesn't exist, creating
[0002.286] W> "module@0x50" doesn't exist, creating
[0002.291] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@3160000:module@0x56
[0002.298] W> "module@0x56" doesn't exist, creating
[0002.304] I> Adding plugin-manager/cvm
[0002.306] W> "chip-id" doesn't exist, creating
[0002.310] I> Adding plugin-manager/chip-id/A02P
[0002.315] I> Plugin-manager override starting
[0002.320] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.328] I> node /plugin-manager/fragement-soft-wdt matches
[0002.337] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.341] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.348] I> Disable plugin-manager status in FDT
[0002.348] I> Plugin-manager override finished successfully
[0002.352] I> gpio framework initialized
[0002.357] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.363] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.370] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.377] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.385] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.392] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.398] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.405] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.413] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.420] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.427] I> fixed regulator driver initialized
[0002.436] I> register 'maxim' power off handle
[0002.437] I> virtual i2c enabled
[0002.438] I> registered 'maxim,max20024' pmic
[0002.442] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.449] I> Boot-device: eMMC
[0002.451] I> Boot_device: SDMMC_BOOT instance: 3
[0002.460] I> sdmmc-3 params source = boot args
[0002.460] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.465] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.476] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.482] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0002.493] I> sdmmc bdev is already initialized
[0002.497] I> sdmmc-3 params source = boot args
[0002.527] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.540] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.548] I> enabling 'vdd-hdmi-5v0' regulator
[0002.552] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.553] I> hdmi cable connected
[0002.554] W> set volts not configured for 'vdd-1v0'
[0002.555] W> set volts not configured for 'vdd-1v8-hs'
[0002.559] E> invalid display type
[0002.562] E> invalid display type
[0002.563] E> cannot find any other nvdisp nodes
[0002.578] I> edid read success
[0002.590] I> edid read success
[0002.591] I> width = 640, height = 480, frequency = 25174825
[0002.592] I> width = 1920, height = 1080, frequency = 148500000
[0002.592] I> width = 1366, height = 768, frequency = 85750000
[0002.596] I> width = 1280, height = 720, frequency = 74250000
[0002.602] I> width = 1920, height = 540, frequency = 74250000
[0002.607] I> width = 720, height = 480, frequency = 27000000
[0002.613] I> width = 720, height = 576, frequency = 27000000
[0002.618] I> width = 1920, height = 1080, frequency = 148351648
[0002.624] I> width = 1920, height = 1080, frequency = 148351648
[0002.630] I> width = 1280, height = 720, frequency = 74175824
[0002.636] I> width = 1280, height = 720, frequency = 74175824
[0002.641] I> width = 720, height = 576, frequency = 26973026
[0002.647] I> width = 720, height = 576, frequency = 26973026
[0002.652] I> width = 720, height = 480, frequency = 26973026
[0002.658] I> width = 720, height = 480, frequency = 26973026
[0002.663] I> width = 640, height = 480, frequency = 25174825
[0002.669] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.679] I> hdmi_enable, starting HDMI initialisation
[0002.684] I> hdmi_enable, HDMI initialisation complete
[0002.695] I> Load in CBoot Boot Options partition and parse it
[0002.701] E> Error -9 when finding node with path /boot-configuration
[0002.702] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.704] I> Hit any key to stop autoboot:     4       3       2       1
[0004.712] initializing target
[0004.712] calling apps_init()
[0004.713] starting app kernel_boot_app
[0004.732] I> found decompressor handler: lz4-legacy
[0004.733] I> decompressing BMP blob ...
[0004.736] I> Kernel type = Normal
[0004.737] I> Loading kernel-bootctrl from partition
[0004.737] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.744] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.744] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.745] I> ########## SD boot ##########
[0004.749] I> No sdcard
[0004.751] I> -0 params source =
[0004.754] E> Blockdev open: exit error
[0004.757] E> SD boot failed, err: 724238353
[0004.761] I> ########## USB boot ##########
[0004.782] I> USB Firmware Version: 60.06 release
[0004.837] I> regulator of usb2-0 already enabled
[0004.842] I> regulator of usb2-1 already enabled
[0004.848] I> regulator of usb2-2 already enabled
[0004.855] I> enabling 'vdd-5v-sata' regulator
[0005.921] I> USB 2.0 port 1 new high-speed USB device detected
[0005.923] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0006.024] I> Start to enumerate device
[0006.025] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0006.030] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0006.032] I>
[0006.032] I> Enumerated USB Device 174c:55aa
[0006.032] I>
[0006.033] I> Max LUN = 0
[0006.038] I> Vendor Identification   :  TOSHIBA
[0006.038] I> Product Identification  :  MQ01ABD050
[0006.040] I> Product Revision Level  :  0
[0006.049] I> READ CAPACITY - last LBA = 976773168, 476940MB
[0006.050] I> -0 params source =
[0006.136] I> Found 3 partitions in USB_MS (instance 0)
[0006.137] I> Look for boot partition
[0006.137] I> Fallback: assuming 0th partition is boot partition
[0006.138] I> Detect filesystem
[0006.141] I> fs_detect:173: Unsupported or no filesystem present
[0006.141] I> Loading kernel ...
[0006.142] E> Cannot open partition kernel
[0006.142] E> USB boot failed, err: 202184205
[0006.145] I> ########## Fixed storage boot ##########
[0006.150] I> Already published: 00010003
[0006.154] I> Look for boot partition
[0006.157] I> Fallback: assuming 0th partition is boot partition
[0006.163] I> Detect filesystem
[0006.190] I> Loading extlinux.conf ...
[0006.191] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0006.221] I> L4T boot options
[0006.222] I> [1]: "primary kernel"
[0006.222] I> Enter choice:
[0009.223] I> Continuing with default option: 1
[0009.223] I> No kernel binary path
[0009.223] I> A/B: bin_type (37) slot 0
[0009.224] I> Loading kernel from partition
[0009.224] I> Loading partition kernel at 0xa4ac0000 from device(0x1)
[0009.706] I> Validate kernel ...
[0009.706] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.100] I> No kernel-dtb binary path
[0010.101] I> A/B: bin_type (38) slot 0
[0010.101] I> Loading kernel-dtb from partition
[0010.101] I> Loading partition kernel-dtb at 0x92000000 from device(0x1)
[0010.110] I> Validate kernel-dtb ...
[0010.110] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.114] I> Loading ramdisk from rootfs ...
[0010.114] I> rootfs path: /sdmmc_user/boot/initrd
[0010.169] I> Kernel hdr @0xa4ac0000
[0010.169] I> Kernel dtb @0x91000000
[0010.169] I> decompressor handler not found
[0010.170] I> Copying kernel image (34598920 bytes) from 0xa4ac0800 to 0x80080000 ... [0010.178] I> Done
[0010.178] I> Move ramdisk (len: 5565270) from 0xa6bc0000 to 0x97000000
[0010.181] I> Updated bpmp info to DTB
[0010.183] I> Ramdisk: Base: 0x97000000; Size: 0x54eb56
[0010.183] I> Updated initrd info to DTB
[0010.183] W> WARN: Fail to override "console=none" in commandline
[0010.188] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.196] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.203] I> Active slot suffix:
[0010.206] I> add_boot_slot_suffix: slot_suffix =
[0010.211] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbc
[0010.251] I> Updated bootarg info to DTB
[0010.255] W> MAC addr invalid!
[0010.258] E> Failed to get WIFI MAC address
[0010.262] W> MAC addr invalid!
[0010.265] E> Failed to get Bluetooth MAC address
[0010.269] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:b7:44
[0010.276] W> "plugin-manager" doesn't exist, creating
[0010.281] I> Adding /chosen/plugin-manager/cvm
[0010.285] W> "chip-id" doesn't exist, creating
[0010.289] I> Adding /chosen/plugin-manager/chip-id
[0010.294] W> "configs" doesn't exist, creating
[0010.298] I> Adding /chosen/plugin-manager/configs
[0010.302] W> "ids" doesn't exist, creating
[0010.306] I> Adding /chosen/plugin-manager/ids
[0010.311] W> "odm-data" doesn't exist, creating
[0010.315] I> Adding /chosen/plugin-manager/odm-data
[0010.323] W> "memory" doesn't exist, creating
[0010.324] I> [0] START: 0x80000000, END: 0xac000000
[0010.329] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.333] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.338] I> dram_block larger than 80000000
[0010.342] I> [3] START: 0x100000000, END: 0x880000000
[0010.347] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.353] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.359] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.366] I> Updated memory info to DTB
[0010.369] E> add_disp_param: failed to get display params for du=1
[0010.375] W> "reset" doesn't exist, creating
[0010.379] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.383] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.388] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.393] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.398] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.402] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.407] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.412] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.418] W> "misc-data" doesn't exist, creating
[0010.421] I> Boot-device: eMMC
[0010.424] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.429] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.434] W> Unknown storage device
[0010.438] I> Add serial number:1421920022204 as DT property
[0010.444] I> Plugin-manager override starting
[0010.448] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.455] I> node /plugin-manager/fragement-soft-wdt matches
[0010.461] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.466] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0010.474] I> Disable plugin-manager status in FDT
[0010.475] I> Plugin-manager override finished successfully
[0010.481] I> tegrabl_load_kernel_and_dtb: Done
[0010.533] I> Kernel EP: 0x80080000, DTB: 0x91000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (neolix@neolix) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef900650
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  780000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
<hit enter to activate fiq debugger>
[    2.027241] kversion kversion: kversion_probe entering...
[    2.027472] kversion kversion: kversion_probe leaving
[    2.028623] neolixgpio neolix-gpio: neolixgpio_probe entering...
[    2.087792] tegra-usb-cd usb_cd: failed to allocate extcon device
[    2.091838] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[    2.093077] ucsi_ccg 1-0008: read version failed
[    2.093232] ucsi_ccg 1-0008: get_fw_info fail,, err=-121
[    2.130725] tegradc 15210000.nvdisplay: typec extcon dev is NULL
[    2.131263] tegradc 15220000.nvdisplay: typec extcon dev is NULL
[    2.239229] max9271 2-0018: 960_P2_PWREN_GPIO15 max9271 is 446,value is 1
��WARNING: pll_d3 has no dyn ramp
��[    3.192765] max9286 2-003d: 960_P1_PWREN_GPIO16 is 445,value is 1
[    4.151988] max9286 2-003d: 960_P1_PWREN_GPIO16 enable gpio value is 1
[    4.152496] ##ti960:[ti960_hardware_preinit]  entering...
[    4.187387] max9286 2-003d: [MAX9296]: probing GMSL Deserializer
[    4.187393] max9286 2-003d: max9286_probe:  success
[    4.188349] ti964 2-0030: 960_P3_PWREN_GPIO21 is 288,value is 1
[    5.112053] ti964 2-0030: 960_P1_PWREN_GPIO16 enable gpio value is 1
[    5.112507] ##ti960:[ti964_hardware_preinit]  entering...
[    5.147381] ti964 2-0030: [TI964]: probing GMSL Deserializer
[    5.147589] ti964 2-0030: ti964_probe:  success
[    5.148065] ar231 2-005d: probing v4l2 sensor ar231.
[    5.148824] ar231 2-005d: gmsl deserializer register ar231 ok
[    5.279996] ##max9296[max9286_setup_control][515]
[    5.280336] ar231 2-005e: probing v4l2 sensor ar231.
[    5.280839] ar231 2-005e: gmsl deserializer register ar231 ok
[    5.384006] ##max9296[max9286_setup_control][515]
[    5.384366] ar231 2-005f: probing v4l2 sensor ar231.
[    5.384793] ar231 2-005f: gmsl deserializer register ar231 ok
[    5.487990] ##max9296[max9286_setup_control][515]
[    5.488363] ar231 2-0060: probing v4l2 sensor ar231.
hello nvidias,
did you had use-case to working with AR0231 camera sensor?
there’re last error messages before your device reboots.
may I also know what’s the use-case, or please share your pipelines to access the camera stream
thanks
hello JerryChang,
I’m sorry these CAMERA SENSOR logs are causing confusion,in fact, you’ll have these prints when you don’t reboot. The camera log can be ignored, that’s just a truncated version of the log.
Here are some typical restart logs:
HW Function test
Start Scheduler.
in late init
0000.376] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-389501e9)
[0000.376] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.377] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.378] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.383] W> device prod register failed
[0000.387] I> Boot-device: eMMC
[0000.390] I> Boot_device: SDMMC_BOOT instance: 3
[0000.396] I> sdmmc-3 params source = boot args
[0000.399] I> sdmmc bdev is already initialized
[0000.403] I> sdmmc-3 params source = boot args
[0000.411] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.418] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.419] I> Active Boot chain : 0
[0000.422] I> parsing oem signed section of bpmp-fw header done
[0000.427] I> bpmp-fw binary init read from storage
[0000.432] I> oem authentication of bpmp-fw header done
[0000.439] I> bpmp-fw binary done read from storage
[0000.442] I> bpmp-fw: Authentication init Done
[0000.447] I> parsing oem signed section of cpubl header done
[0000.451] I> cpubl binary init read from storage
[0000.456] I> bpmp-fw: Authentication Finalize Done
[0000.461] I> oem authentication of cpubl header done
[0000.465] I> cpubl binary done read from storage
[0000.470] I> cpubl: Authentication init Done
[0000.476] I> parsing oem signed section of rce header done
[0000.479] I> rce binary init read from storage
[0000.484] I> Relocating BR-BCT
[0000.487] I> cpubl: Authentication Finalize Done
[0000.491] I> oem authentication of rce header done
[0000.495] I> rce binary done read from storage
[0000.500] I> rce: Authentication init Done
[0000.505] I> parsing oem signed section of ape header done
[0000.509] I> ape binary init read from storage
[0000.514] I> rce: Authentication Finalize Done
[0000.518] I> oem authentication of ape header done
[0000.522] I> ape binary done read from storage
[0000.527] I> ape: Authentication init Done
[0000.531] I> parsing oem signed section of tos header done
[0000.536] I> tos binary init read from storage
[0000.540] I> ape: Authentication Finalize Done
[0000.545] I> oem authentication of tos header done
[0000.549] I> tos binary done read from storage
[0000.553] I> tos: Authentication init Done
[0000.559] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.563] I> bpmp-fw-dtb binary init read from storage
[0000.568] I> tos: Authentication Finalize Done
[0000.574] I> oem authentication of bpmp-fw-dtb header done
[0000.581] I> bpmp-fw-dtb binary done read from storage
[0000.583] I> bpmp-fw-dtb: Authentication init Done
[0000.589] I> parsing oem signed section of cpubl-dtb header done
[0000.593] I> cpubl-dtb binary init read from storage
[0000.598] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.636] I> oem authentication of cpubl-dtb header done
[0000.636] I> cpubl-dtb binary done read from storage
[0000.637] I> cpubl-dtb: Authentication init Done
[0000.639] I> parsing oem signed section of eks header done
[0000.639] I> eks binary init read from storage
[0000.640] I> cpubl-dtb: Authentication Finalize Done
[0000.641] I> oem authentication of eks header done
[0000.644] I> eks binary done read from storage
[0000.649] I> eks: Authentication init Done
[0000.652] I> eks: Authentication Finalize Done
[0000.657] I> EKB detected (length: 0x410) @ VA:0x5270a400
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
0001.160] I> Welcome to Cboot
on_post initialized
001.161] I> Cboot Version: t194-aad9d75e
[0001.161] I> CPU-BL Params @ 0xf2820000
[0001.161] I>  0) Base:0x00000000 Size:0x00000000
[0001.165] I>  1) Base:0xf1100000 Size:0x00100000
[0001.169] I>  2) Base:0xf2000000 Size:0x00200000
[0001.174] I>  3) Base:0xf1200000 Size:0x00200000
[0001.178] I>  4) Base:0xf1000000 Size:0x00100000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
001.183] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.288] I>  6) Base:0xf3800000 Size:0x00400000
[0001.292] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.297] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.301] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.306] I> 10) Base:0xf3000000 Size:0x00800000
[0001.310] I> 11) Base:0x40000000 Size:0x00040000
[0001.314] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.319] I> 13) Base:0x40046000 Size:0x00002000
[0001.323] I> 14) Base:0x40048000 Size:0x00002000
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] 001.328] I> 15) Base:0xac000000 Size:0x00004000
[0001.383] I> 16) Base:0x4004a000 Size:0x00002000
[0001.387] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.392] I> 18) Base:0x4004c000 Size:0x00002000
[0001.396] I> 19) Base:0xf2200000 Size:0x00600000
[0001.401] I> 20) Base:0x4004e000 Size:0x00002000
[0001.405] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.409] I> 22) Base:0x00000000 Size:0x00000000
[0001.414] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.418] I> 24) Base:0xf6000000 Size:0x02000000
[0001.423] I> 25) Base:0x40050000 Size:0x00002000
[0001.427] I> 26) Base:0x40040000 Size:0x00006000
[0001.432] I> 27) Base:0xf1800000 Size:0x00400000
[0001.436] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.441] I> 29) Base:0xf1400000 Size:0x00400000
[0001.445] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.450] I> 31) Base:0x00000000 Size:0x00000000
[0001.454] I> 32) Base:0xf8000000 Size:0x08000000
[0001.459] I> 33) Base:0x00000000 Size:0x00000000
[0001.463] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.467] I> 35) Base:0xab000000 Size:0x01000000
[0001.472] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.476] I> 37) Base:0xf2800000 Size:0x00800000
[0001.481] I> 38) Base:0x80000000 Size:0x20000000
[0001.485] I> 39) Base:0xb0000000 Size:0x08000000
[0001.490] I> 40) Base:0x00000000 Size:0x00000000
[0001.494] I> 41) Base:0x00000000 Size:0x00000000
[0001.499] I> 42) Base:0x00000000 Size:0x00000000
[0001.503] I> 43) Base:0x00000000 Size:0x00000000
[0001.508] I> 44) Base:0x00000000 Size:0x00000000
[0001.512] I> 45) Base:0x00000000 Size:0x00000000
[0001.517] GIC-SPI Target CPU: 0
[0001.520] Interrupts Init done
[0001.522] calling constructors
[0001.525] initializing heap
[0001.528] I> Heap: [0xa0691568 ... 0xab000000]
[0001.532] initializing threads
[0001.535] initializing timers
[0001.538] creating bootstrap completion thread
[0001.542] top of bootstrap2()
[0001.545] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.550] initializing platform
[0001.553] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.558] W> device prod register failed
[0001.562] I> Bl_dtb @0xaaf00000
[0001.567] W> "plugin-manager" doesn't exist, creating
[0001.570] W> "ids" doesn't exist, creating
[0001.574] W> "connection" doesn't exist, creating
[0001.578] W> "configs" doesn't exist, creating
[0001.588] I> Find /i2c@3160000's alias i2c0
[0001.589] I> Reading eeprom i2c=0 address=0x50
[0001.616] I> Device at /i2c@3160000:0x50
[0001.616] I> Reading eeprom i2c=0 address=0x56
[0001.641] I> Device at /i2c@3160000:0x56
[0001.643] I> Find /i2c@3180000's alias i2c2
[0001.643] I> Reading eeprom i2c=2 address=0x54
[0001.644] E> I2C: slave not found in slaves.
[0001.645] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.646] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.646] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.655] E> eeprom: Failed to read I2C slave device
[0001.660] I> Eeprom read failed 0x3526070d
[0001.664] I> Reading eeprom i2c=2 address=0x57
[0001.668] E> I2C: slave not found in slaves.
[0001.672] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.680] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.685] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.695] E> eeprom: Failed to read I2C slave device
[0001.700] I> Eeprom read failed 0x3526070d
[0001.704] I> Reading eeprom i2c=2 address=0x52
[0001.708] E> I2C: slave not found in slaves.
[0001.712] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.720] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.726] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.735] E> eeprom: Failed to read I2C slave device
[0001.740] I> Eeprom read failed 0x3526070d
[0001.745] I> Find /i2c@c240000's alias i2c1
[0001.748] I> Reading eeprom i2c=1 address=0x52
[0001.754] E> I2C: slave not found in slaves.
[0001.756] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.764] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.770] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.779] E> eeprom: Retry to read I2C slave device.
[0001.784] E> I2C: slave not found in slaves.
[0001.788] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.796] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.802] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.811] E> eeprom: Failed to read I2C slave device
[0001.816] I> Eeprom read failed 0x3526070d
[0001.820] I> Reading eeprom i2c=1 address=0x50
[0001.824] E> I2C: slave not found in slaves.
[0001.828] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.836] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.842] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.851] E> eeprom: Retry to read I2C slave device.
[0001.856] E> I2C: slave not found in slaves.
[0001.860] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.868] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.873] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.883] E> eeprom: Failed to read I2C slave device
[0001.888] I> Eeprom read failed 0x3526070d
[0001.892] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0001.897] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.908] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0001.913] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0001.924] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.932] W> "i2c@3160000" doesn't exist, creating
[0001.936] W> "module@0x50" doesn't exist, creating
[0001.941] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@3160000:module@0x56
[0001.948] W> "module@0x56" doesn't exist, creating
[0001.954] I> Adding plugin-manager/cvm
[0001.956] W> "chip-id" doesn't exist, creating
[0001.960] I> Adding plugin-manager/chip-id/A02P
[0001.964] I> Plugin-manager override starting
[0001.970] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.978] I> node /plugin-manager/fragement-soft-wdt matches
[0001.986] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.990] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.997] I> Disable plugin-manager status in FDT
[0001.997] I> Plugin-manager override finished successfully
[0002.001] I> gpio framework initialized
[0002.006] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.013] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.020] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.027] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.035] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.042] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.048] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.055] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.063] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.070] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.077] I> fixed regulator driver initialized
[0002.087] I> register 'maxim' power off handle
[0002.087] I> virtual i2c enabled
[0002.088] I> registered 'maxim,max20024' pmic
[0002.092] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.098] I> Boot-device: eMMC
[0002.101] I> Boot_device: SDMMC_BOOT instance: 3
[0002.110] I> sdmmc-3 params source = boot args
[0002.110] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.115] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.126] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.131] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0002.142] I> sdmmc bdev is already initialized
[0002.147] I> sdmmc-3 params source = boot args
[0002.177] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.190] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.199] I> enabling 'vdd-hdmi-5v0' regulator
[0002.204] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.204] I> hdmi cable connected
[0002.205] W> set volts not configured for 'vdd-1v0'
[0002.207] W> set volts not configured for 'vdd-1v8-hs'
[0002.210] E> invalid display type
[0002.213] E> invalid display type
[0002.214] E> cannot find any other nvdisp nodes
[0002.340] I> edid read success
[0002.341] E> tegrabl_display_unit_get_edid, get edid failed[0002.341] E> tegrabl_display_init: Initialize du 0 failed
[0002.341] W> display init failed
[0002.342] I> Load in CBoot Boot Options partition and parse it
[0002.348] E> Error -9 when finding node with path /boot-configuration
[0002.348] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.351] I> Hit any key to stop autoboot:     4       3       2       1
[0004.359] initializing target
[0004.359] calling apps_init()
[0004.360] starting app kernel_boot_app
[0004.379] I> found decompressor handler: lz4-legacy
[0004.380] I> decompressing BMP blob ...
[0004.383] I> Kernel type = Normal
[0004.383] I> Loading kernel-bootctrl from partition
[0004.384] I> Loading partition kernel-bootctrl at 0xa42b0000 from device(0x1)
[0004.390] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.391] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.392] I> ########## SD boot ##########
[0004.396] I> No sdcard
[0004.398] I> -0 params source =
[0004.401] E> Blockdev open: exit error
[0004.404] E> SD boot failed, err: 724238353
[0004.408] I> ########## USB boot ##########
[0004.429] I> USB Firmware Version: 60.06 release
[0004.484] I> regulator of usb2-0 already enabled
[0004.489] I> regulator of usb2-1 already enabled
[0004.494] I> regulator of usb2-2 already enabled
[0004.501] I> enabling 'vdd-5v-sata' regulator
[0005.568] I> USB 2.0 port 1 new full-speed USB device detected
[0005.569] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa069c300, cmd_ring.dma = 0xa069c380
[0005.670] I> Start to enumerate device
[0005.671] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa069c300, cmd_ring.dma = 0xa069c380
[0005.675] I> This device is non-MSD, skip enumeration
[0005.676] E> Failed to enumerate USB device
[0005.676] E> failed to start xhci controller
[0005.676] E> Error in init of XUSB host driver, err: 7979000d
[0005.677] E> Failed to initialize device 5-0
[0005.681] E> USB boot failed, err: 2037973005
[0005.685] I> ########## Fixed storage boot ##########
[0005.690] I> Already published: 00010003
[0005.694] I> Look for boot partition
[0005.697] I> Fallback: assuming 0th partition is boot partition
[0005.703] I> Detect filesystem
[0005.730] I> Loading extlinux.conf ...
[0005.730] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.761] I> L4T boot options
[0005.761] I> [1]: "primary kernel"
[0005.761] I> Enter choice:
[0008.763] I> Continuing with default option: 1
[0008.763] I> No kernel binary path
[0008.763] I> A/B: bin_type (37) slot 0
[0008.763] I> Loading kernel from partition
[0008.764] I> Loading partition kernel at 0xa42b0000 from device(0x1)
[0009.244] I> Validate kernel ...
[0009.244] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.641] I> No kernel-dtb binary path
[0009.642] I> A/B: bin_type (38) slot 0
[0009.642] I> Loading kernel-dtb from partition
[0009.642] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.651] I> Validate kernel-dtb ...
[0009.652] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.655] I> Loading ramdisk from rootfs ...
[0009.655] I> rootfs path: /sdmmc_user/boot/initrd
[0009.710] I> Kernel hdr @0xa42b0000
[0009.710] I> Kernel dtb @0x90000000
[0009.711] I> decompressor handler not found
[0009.711] I> Copying kernel image (34531336 bytes) from 0xa42b0800 to 0x80080000 ... [0009.719] I> Done
[0009.720] I> Move ramdisk (len: 5565270) from 0xa639f800 to 0x96000000
[0009.722] I> Updated bpmp info to DTB
[0009.724] I> Ramdisk: Base: 0x96000000; Size: 0x54eb56
[0009.724] I> Updated initrd info to DTB
[0009.724] W> WARN: Fail to override "console=none" in commandline
[0009.729] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.737] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.744] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.751] I> Active slot suffix:
[0009.754] I> add_boot_slot_suffix: slot_suffix =
[0009.759] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4  video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.795] I> Updated bootarg info to DTB
[0009.798] W> MAC addr invalid!
[0009.801] E> Failed to get WIFI MAC address
[0009.805] W> MAC addr invalid!
[0009.808] E> Failed to get Bluetooth MAC address
[0009.813] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:ae:90
[0009.819] W> "plugin-manager" doesn't exist, creating
[0009.824] I> Adding /chosen/plugin-manager/cvm
[0009.828] W> "chip-id" doesn't exist, creating
[0009.832] I> Adding /chosen/plugin-manager/chip-id
[0009.837] W> "configs" doesn't exist, creating
[0009.841] I> Adding /chosen/plugin-manager/configs
[0009.846] W> "ids" doesn't exist, creating
[0009.850] I> Adding /chosen/plugin-manager/ids
[0009.854] W> "odm-data" doesn't exist, creating
[0009.858] I> Adding /chosen/plugin-manager/odm-data
[0009.866] W> "memory" doesn't exist, creating
[0009.868] I> [0] START: 0x80000000, END: 0xac000000
[0009.872] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.877] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.881] I> dram_block larger than 80000000
[0009.886] I> [3] START: 0x100000000, END: 0x880000000
[0009.890] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.896] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.902] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.909] I> Updated memory info to DTB
[0009.912] E> add_disp_param: failed to get display params for du=0
[0009.918] W> "reset" doesn't exist, creating
[0009.923] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.927] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.932] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.936] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.941] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.946] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.950] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.955] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.961] W> "misc-data" doesn't exist, creating
[0009.964] I> Boot-device: eMMC
[0009.967] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.972] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.978] W> Unknown storage device
[0009.982] I> Add serial number:1421920068240 as DT property
[0009.987] I> Plugin-manager override starting
[0009.991] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.998] I> node /plugin-manager/fragement-soft-wdt matches
[0010.005] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.009] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0010.017] I> Disable plugin-manager status in FDT
[0010.018] I> Plugin-manager override finished successfully
[0010.024] I> tegrabl_load_kernel_and_dtb: Done
[0010.061] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Linux version 4.9.140-tegra (neolix@neolix-xavier-server) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #7 SMP PREEMPT RT Tue Nov 3 18:52:40 CST 2020
0`1&    5!TQIj  P,N]	J>@ME    L-)r4j)jMIa
[@ChZ
                                                      &5
                                                        [	]Jڕ) p B4VPL& J
        Q* VVk
[	J>@ref])0
        ] >@RJ/V,H[	:]J>@r.ױld2     >@BWk:*5&&      ]J>ڵHU$C
+ '	>Wk5`.S
5=j%)Wk֑$"
(J+j   P.4
           [@emQMj
                  00L&  šRK(3U9I5
                                   [S2#[	]kaJ5
                                                2.ʪWW.%U .14
                                                             0$&)UK(Jj
S5        00b2)>@B)Wk:*5
  [)@BWk5S5
]8St':6
[* 0&&)S MV)]J>*
W'Sх(.0[)>@E$
nS*)>@E$ ]:rt*04
W'*WC$&)]J>@N(k]:a.!J9M˫UE]'E$
                               W0X :)>@n-ocm*W0X : 8CrNY[4]'*W0 *0
        0&&)2'Te[)W*2%"i
VH1&)":*50`3J ,KJ+V& ]J>@MHPHmain enter
HW Function test
Start Scheduler.
in late init
0013.106] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-389501e9)
[0013.107] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0013.107] I> Default Heap @ [0xd486400 - 0xd48a400]
[0013.108] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0013.114] W> device prod register failed
[0013.117] I> Boot-device: eMMC
[0013.120] I> Boot_device: SDMMC_BOOT instance: 3
[0013.126] I> sdmmc-3 params source = boot args
[0013.129] I> sdmmc bdev is already initialized
[0013.133] I> sdmmc-3 params source = boot args
[0013.142] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0013.148] I> Found 42 partitions in SDMMC_USER (instance 3)
[0013.149] I> Active Boot chain : 0
In addition, I would like to ask what methods can be used to grab the restart log
hello nvidias,
please enable the commands, $ dmesg --follow to check the latest kernel status.
BTW, please use the code-block,
for example,
debug messages or codes
to include those logs, it’ll helps for reading this topic.
thanks
Hi JerryChang,
yes,I used the following command, but I didn’t catch anything.
echo 30 > /proc/sys/kernel/panic
echo "8 6 1 7" > /proc/sys/kernel/printk
dmesg --follow | tee -a reboot.log
Log before reboot:
  [   69.691619] max9286 2-003d: In max9286_setup_pipeline index = 0 g_stream->st_data_type = 30
[   69.691843] max9286 2-003d: In max9286_setup_pipeline index = 1 g_stream->st_data_type = 2C
[   69.693914] max9286 2-003d: priv->pipe[0].dt_type == 2C, st_data_type = 2C priv->pipe[0].st_count = 1, dst_csi_port = 2
[   69.694188] max9286 2-003d: priv->pipe[1].dt_type == 2C, st_data_type = 2C priv->pipe[1].st_count = 0, dst_csi_port = 2
[   69.737134] max9286 2-003d: In max9286_setup_pipeline g_ctx->num_streams = 2
[   69.744240] max9286 2-003d: In max9286_setup_pipeline index = 0 g_stream->st_data_type = 30
[   69.748457] max9286 2-003d: In max9286_setup_pipeline index = 1 g_stream->st_data_type = 2C
[   69.750673] max9286 2-003d: priv->pipe[0].dt_type == 2C, st_data_type = 2C priv->pipe[0].st_count = 1, dst_csi_port = 2
[   69.754114] max9286 2-003d: priv->pipe[1].dt_type == 2C, st_data_type = 2C priv->pipe[1].st_count = 1, dst_csi_port = 2
[   69.754496] max9286 2-003d: priv->pipe[2].dt_type == 2C, st_data_type = 2C priv->pipe[2].st_count = 0, dst_csi_port = 2
[   69.758380] max9286 2-003d: In max9286_setup_pipeline g_ctx->num_streams = 2
[   69.758619] max9286 2-003d: In max9286_setup_pipeline index = 0 g_stream->st_data_type = 30
[   69.758807] max9286 2-003d: In max9286_setup_pipeline index = 1 g_stream->st_data_type = 2C
[   69.759191] max9286 2-003d: priv->pipe[0].dt_type == 2C, st_data_type = 2C priv->pipe[0].st_count = 1, dst_csi_port = 2
[   69.759768] max9286 2-003d: priv->pipe[1].dt_type == 2C, st_data_type = 2C priv->pipe[1].st_count = 1, dst_csi_port = 2
[   69.760239] max9286 2-003d: priv->pipe[2].dt_type == 2C, st_data_type = 2C priv->pipe[2].st_count = 1, dst_csi_port = 2
[   69.770079] max9286 2-003d: priv->pipe[3].dt_type == 2C, st_data_type = 2C priv->pipe[3].st_count = 0, dst_csi_port = 2
[   70.188812] NOHZ: local_softirq_pending 80
[   70.189377] NOHZ: local_softirq_pending 80
[   70.189469] NOHZ: local_softirq_pending 80
[   70.189644] NOHZ: local_softirq_pending 80
Ubuntu 18.04.4 LTS xavier-neolix ttyTCU0
xavier-neolix login:
[   73.888116] NOHZ: local_softirq_pending 80
[   73.888147] NOHZ: local_softirq_pending 80
Log after reboot:
[0000.757] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.765] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.771] I> Boot-mode: Coldboot
[0000.774] I> Chip revision : A02P
[0000.777] I> Bootrom patch version : 15 (correctly patched)
[0000.782] I> ATE fuse revision : 0x200
[0000.785] I> Ram repair fuse : 0x0
[0000.789] I> Ram Code : 0x2
[0000.791] I> rst_source : 0x0
[0000.794] I> rst_level : 0x0
[0000.797] I> Boot-device: eMMC
[0000.812] I> sdmmc DDR50 mode
[0000.816] I> Active Boot chain : 0
[0000.820] I> Boot-device: eMMC
[0000.823] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.831] I> Temperature = 24000
[0000.834] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.838] W> Skipping boost for clk: BPMP_APB
[0000.842] W> Skipping boost for clk: AXI_CBB
[0000.846] W> Skipping boost for clk: AON_CPU_NIC
[0000.851] W> Skipping boost for clk: CAN1
[0000.854] W> Skipping boost for clk: CAN2
[0000.859] I> Boot-device: eMMC
[0000.862] I> Boot-device: eMMC
[0000.871] I> Sdmmc: HS400 mode enabled
[0000.875] I> ECC region[0]: Start:0x0, End:0x0
[0000.880] I> ECC region[1]: Start:0x0, End:0x0
[0000.884] I> ECC region[2]: Start:0x0, End:0x0
[0000.888] I> ECC region[3]: Start:0x0, End:0x0
[0000.892] I> ECC region[4]: Start:0x0, End:0x0
[0000.896] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.902] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.906] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.911] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.915] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.921] E> FAILED: Thermal config
[0000.928] E> FAILED: MEMIO rail config
[0000.946] I> Boot-device: eMMC
[0000.956] I> sdmmc bdev is already initialized
[0001.027] I> MB1 done
*�鄊ain enter
HW Function test
Start Scheduler.
in late init
[0001.036] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-389501e9)
[0001.037] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0001.037] I> Default Heap @ [0xd486400 - 0xd48a400]
[0001.038] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0001.044] W> device prod register failed
[0001.047] I> Boot-device: eMMC
[0001.050] I> Boot_device: SDMMC_BOOT instance: 3
[0001.056] I> sdmmc-3 params source = boot args
[0001.059] I> sdmmc bdev is already initialized
[0001.063] I> sdmmc-3 params source = boot args
[0001.070] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0001.077] I> Found 42 partitions in SDMMC_USER (instance 3)
[0001.079] I> Active Boot chain : 0
[0001.083] I> parsing oem signed section of bpmp-fw header done
[0001.088] I> bpmp-fw binary init read from storage
[0001.093] I> oem authentication of bpmp-fw header done
[0001.099] I> bpmp-fw binary done read from storage
[0001.102] I> bpmp-fw: Authentication init Done
[0001.106] I> parsing oem signed section of cpubl header done
[0001.112] I> cpubl binary init read from storage
[0001.116] I> bpmp-fw: Authentication Finalize Done
[0001.121] I> oem authentication of cpubl header done
[0001.125] I> cpubl binary done read from storage
[0001.130] I> cpubl: Authentication init Done
[0001.135] I> parsing oem signed section of rce header done
[0001.139] I> rce binary init read from storage
[0001.144] I> Relocating BR-BCT
[0001.147] I> cpubl: Authentication Finalize Done
[0001.151] I> oem authentication of rce header done
[0001.156] I> rce binary done read from storage
[0001.160] I> rce: Authentication init Done
[0001.165] I> parsing oem signed section of ape header done
[0001.169] I> ape binary init read from storage
[0001.174] I> rce: Authentication Finalize Done
[0001.178] I> oem authentication of ape header done
[0001.182] I> ape binary done read from storage
[0001.187] I> ape: Authentication init Done
[0001.193] I> parsing oem signed section of tos header done
[0001.196] I> tos binary init read from storage
[0001.200] I> ape: Authentication Finalize Done
[0001.205] I> oem authentication of tos header done
[0001.209] I> tos binary done read from storage
[0001.213] I> tos: Authentication init Done
[0001.218] I> parsing oem signed section of bpmp-fw-dtb header done
[0001.224] I> bpmp-fw-dtb binary init read from storage
[0001.228] I> tos: Authentication Finalize Done
[0001.234] I> oem authentication of bpmp-fw-dtb header done
[0001.241] I> bpmp-fw-dtb binary done read from storage
[0001.243] I> bpmp-fw-dtb: Authentication init Done
[0001.248] I> parsing oem signed section of cpubl-dtb header done
[0001.254] I> cpubl-dtb binary init read from storage
[0001.258] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.296] I> oem authentication of cpubl-dtb header done
[0001.296] I> cpubl-dtb binary done read from storage
[0001.297] I> cpubl-dtb: Authentication init Done
[0001.299] I> parsing oem signed section of eks header done
[0001.300] I> eks binary init read from storage
[0001.300] I> cpubl-dtb: Authentication Finalize Done
[0001.301] I> oem authentication of eks header done
[0001.304] I> eks binary done read from storage
[0001.309] I> eks: Authentication init Done
[0001.313] I> eks: Authentication Finalize Done
[0001.317] I> EKB detected (length: 0x410) @ VA:0x5270a400
銷OTICE: BL31: v1.3(release):de895fd9e
hwkey-agent: 182: key_mgnt_processing …
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
[0001.820] I> Welcome to Cboot鈌mon_post initialized
[0001.821] I> Cboot Version: t194-aad9d75e
[0001.821] I> CPU-BL Params @ 0xf2820000
[0001.821] I> 0) Base:0x00000000 Size:0x00000000
[0001.825] I> 1) Base:0xf1100000 Size:0x00100000
[0001.829] I> 2) Base:0xf2000000 Size:0x00200000
[0001.833] I> 3) Base:0xf1200000 Size:0x00200000
鈉lk_set_parent failed for clk can1, parent pll_aon (-22)
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
醄0001.838] I> 4) Base:0xf1000000 Size:0x00100000
[0001.943] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.947] I> 6) Base:0xf3800000 Size:0x00400000
[0001.952] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.956] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.961] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.965] I> 10) Base:0xf3000000 Size:0x00800000
[0001.970] I> 11) Base:0x40000000 Size:0x00040000
[0001.974] I> 12) Base:0xf0c00000 Size:0x00100000鈋mc_debugfs initialized
鈌mon_debugfs initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] 醄0001.983] I> 13) Base:0x40046000 Size:0x00002000
[0002.034] I> 14) Base:0x40048000 Size:0x00002000
[0002.038] I> 15) Base:0xac000000 Size:0x00004000
[0002.043] I> 16) Base:0x4004a000 Size:0x00002000
[0002.047] I> 17) Base:0xf0b00000 Size:0x00100000
[0002.052] I> 18) Base:0x4004c000 Size:0x00002000
[0002.056] I> 19) Base:0xf2200000 Size:0x00600000
[0002.061] I> 20) Base:0x4004e000 Size:0x00002000
[0002.065] I> 21) Base:0xf09d0000 Size:0x0000c000
[0002.069] I> 22) Base:0x00000000 Size:0x00000000
[0002.074] I> 23) Base:0xf09e0000 Size:0x00020000
[0002.078] I> 24) Base:0xf6000000 Size:0x02000000
[0002.083] I> 25) Base:0x40050000 Size:0x00002000
[0002.087] I> 26) Base:0x40040000 Size:0x00006000
[0002.092] I> 27) Base:0xf1800000 Size:0x00400000
[0002.096] I> 28) Base:0xf4c00000 Size:0x01400000
[0002.101] I> 29) Base:0xf1400000 Size:0x00400000
[0002.105] I> 30) Base:0xf0a00000 Size:0x00100000
[0002.110] I> 31) Base:0x00000000 Size:0x00000000
[0002.114] I> 32) Base:0xf8000000 Size:0x08000000
[0002.119] I> 33) Base:0x00000000 Size:0x00000000
[0002.123] I> 34) Base:0xf3c00000 Size:0x01000000
[0002.127] I> 35) Base:0xab000000 Size:0x01000000
[0002.132] I> 36) Base:0xa0000000 Size:0x0b000000
[0002.136] I> 37) Base:0xf2800000 Size:0x00800000
[0002.141] I> 38) Base:0x80000000 Size:0x20000000
[0002.145] I> 39) Base:0xb0000000 Size:0x08000000
[0002.150] I> 40) Base:0x00000000 Size:0x00000000
[0002.154] I> 41) Base:0x00000000 Size:0x00000000
[0002.159] I> 42) Base:0x00000000 Size:0x00000000
[0002.163] I> 43) Base:0x00000000 Size:0x00000000
[0002.168] I> 44) Base:0x00000000 Size:0x00000000
[0002.172] I> 45) Base:0x00000000 Size:0x00000000
[0002.177] GIC-SPI Target CPU: 0
[0002.180] Interrupts Init done
[0002.182] calling constructors
[0002.185] initializing heap
[0002.188] I> Heap: [0xa0691568 … 0xab000000]
[0002.192] initializing threads
[0002.195] initializing timers
[0002.198] creating bootstrap completion thread
[0002.202] top of bootstrap2()
[0002.205] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0002.210] initializing platform
[0002.213] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0002.218] W> device prod register failed
[0002.222] I> Bl_dtb @0xaaf00000
[0002.228] W> “plugin-manager” doesn’t exist, creating
[0002.230] W> “ids” doesn’t exist, creating
[0002.234] W> “connection” doesn’t exist, creating
[0002.238] W> “configs” doesn’t exist, creating
[0002.248] I> Find /i2c@3160000’s alias i2c0
[0002.249] I> Reading eeprom i2c=0 address=0x50
[0002.276] I> Device at /i2c@3160000:0x50
[0002.276] I> Reading eeprom i2c=0 address=0x56
[0002.301] I> Device at /i2c@3160000:0x56
[0002.303] I> Find /i2c@3180000’s alias i2c2
[0002.303] I> Reading eeprom i2c=2 address=0x54
[0002.305] E> I2C: slave not found in slaves.
[0002.305] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0002.306] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.306] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0002.315] E> eeprom: Failed to read I2C slave device
[0002.320] I> Eeprom read failed 0x3526070d
[0002.324] I> Reading eeprom i2c=2 address=0x57
[0002.328] E> I2C: slave not found in slaves.
[0002.332] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.340] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.345] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0002.355] E> eeprom: Failed to read I2C slave device
[0002.360] I> Eeprom read failed 0x3526070d
[0002.364] I> Reading eeprom i2c=2 address=0x52
[0002.368] E> I2C: slave not found in slaves.
[0002.372] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.380] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.386] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0002.395] E> eeprom: Failed to read I2C slave device
[0002.400] I> Eeprom read failed 0x3526070d
[0002.405] I> Find /i2c@c240000’s alias i2c1
[0002.408] I> Reading eeprom i2c=1 address=0x52
[0002.413] E> I2C: slave not found in slaves.
[0002.416] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.424] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.430] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.439] E> eeprom: Retry to read I2C slave device.
[0002.444] E> I2C: slave not found in slaves.
[0002.448] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.456] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.461] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.471] E> eeprom: Failed to read I2C slave device
[0002.476] I> Eeprom read failed 0x3526070d
[0002.480] I> Reading eeprom i2c=1 address=0x50
[0002.484] E> I2C: slave not found in slaves.
[0002.488] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.496] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.502] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.511] E> eeprom: Retry to read I2C slave device.
[0002.516] E> I2C: slave not found in slaves.
[0002.520] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.528] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.533] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.543] E> eeprom: Failed to read I2C slave device
[0002.548] I> Eeprom read failed 0x3526070d
[0002.552] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.557] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.568] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.573] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0002.584] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.592] W> “i2c@3160000” doesn’t exist, creating
[0002.596] W> “module@0x50” doesn’t exist, creating
[0002.601] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@3160000:module@0x56
[0002.607] W> “module@0x56” doesn’t exist, creating
[0002.614] I> Adding plugin-manager/cvm
[0002.616] W> “chip-id” doesn’t exist, creating
[0002.620] I> Adding plugin-manager/chip-id/A02P
[0002.624] I> Plugin-manager override starting
[0002.630] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.638] I> node /plugin-manager/fragement-soft-wdt matches
[0002.646] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.650] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.658] I> Disable plugin-manager status in FDT
[0002.658] I> Plugin-manager override finished successfully
[0002.661] I> gpio framework initialized
[0002.667] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0002.674] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.680] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.688] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.696] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.702] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.708] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.716] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.723] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.730] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.737] I> fixed regulator driver initialized
[0002.747] I> register ‘maxim’ power off handle
[0002.748] I> virtual i2c enabled
[0002.748] I> registered ‘maxim,max20024’ pmic
[0002.752] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.758] I> Boot-device: eMMC
[0002.761] I> Boot_device: SDMMC_BOOT instance: 3
[0002.770] I> sdmmc-3 params source = boot args
[0002.770] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.775] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.786] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.791] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0002.802] I> sdmmc bdev is already initialized
[0002.807] I> sdmmc-3 params source = boot args
[0002.838] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.850] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.859] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.863] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.864] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.864] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.868] E> invalid display type
[0002.872] E> invalid display type
[0002.873] E> cannot find any other nvdisp nodes
[0002.873] E> no valid display unit config found in dtb
[0002.875] W> display init failed
[0002.875] I> Load in CBoot Boot Options partition and parse it
[0002.886] E> Error -9 when finding node with path /boot-configuration
[0002.887] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.894] I> Hit any key to stop autoboot: 4 3
2
1
[0004.902] initializing target
[0004.902] calling apps_init()
[0004.903] starting app kernel_boot_app
[0004.922] I> found decompressor handler: lz4-legacy
[0004.923] I> decompressing BMP blob …
[0004.926] I> Kernel type = Normal
[0004.926] I> Loading kernel-bootctrl from partition
[0004.927] I> Loading partition kernel-bootctrl at 0xa42b0000 from device(0x1)
[0004.933] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.934] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.935] I> ########## SD boot ##########
[0004.939] I> No sdcard
[0004.941] I> -0 params source =
[0004.944] E> Blockdev open: exit error
[0004.947] E> SD boot failed, err: 724238353
[0004.951] I> ########## USB boot ##########
[0004.972] I> USB Firmware Version: 60.06 release
[0005.028] I> regulator of usb2-0 already enabled
[0005.034] I> regulator of usb2-1 already enabled
[0005.040] I> regulator of usb2-2 already enabled
[0005.048] I> enabling ‘vdd-5v-sata’ regulator
[0006.052] E> failed to initialize xhci controller
[0006.052] E> Error in init of XUSB host driver, err: 79790026
[0006.053] E> Failed to initialize device 5-0
[0006.053] E> USB boot failed, err: 2037973030
[0006.053] I> ########## Fixed storage boot ##########
[0006.054] I> Already published: 00010003
[0006.054] I> Look for boot partition
[0006.057] I> Fallback: assuming 0th partition is boot partition
[0006.063] I> Detect filesystem
[0006.090] I> Loading extlinux.conf …
[0006.090] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0006.121] I> L4T boot options
[0006.121] I> [1]: “primary kernel”
[0006.122] I> Enter choice:
[0009.123] I> Continuing with default option: 1
[0009.123] I> No kernel binary path
[0009.123] I> A/B: bin_type (37) slot 0
[0009.123] I> Loading kernel from partition
[0009.124] I> Loading partition kernel at 0xa42b0000 from device(0x1)
[0009.603] I> Validate kernel …
[0009.604] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.998] I> No kernel-dtb binary path
[0009.998] I> A/B: bin_type (38) slot 0
[0009.998] I> Loading kernel-dtb from partition
[0009.999] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0010.007] I> Validate kernel-dtb …
[0010.007] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.010] I> Loading ramdisk from rootfs …
[0010.011] I> rootfs path: /sdmmc_user/boot/initrd
[0010.065] I> Kernel hdr @0xa42b0000
[0010.066] I> Kernel dtb @0x90000000
[0010.066] I> decompressor handler not found
[0010.066] I> Copying kernel image (34600968 bytes) from 0xa42b0800 to 0x80080000 … [0010.072] I> Done
[0010.072] I> Move ramdisk (len: 5565270) from 0xa63b0800 to 0x96000000
[0010.074] I> Updated bpmp info to DTB
[0010.075] I> Ramdisk: Base: 0x96000000; Size: 0x54eb56
[0010.076] I> Updated initrd info to DTB
[0010.079] W> WARN: Fail to override “console=none” in commandline
[0010.085] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0010.092] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0010.099] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0010.107] I> Active slot suffix:
[0010.110] I> add_boot_slot_suffix: slot_suffix =
[0010.114] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0010.150] I> Updated bootarg info to DTB
[0010.154] W> MAC addr invalid!
[0010.157] E> Failed to get WIFI MAC address
[0010.161] W> MAC addr invalid!
[0010.164] E> Failed to get Bluetooth MAC address
[0010.168] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:b7:44
[0010.175] W> “plugin-manager” doesn’t exist, creating
[0010.179] I> Adding /chosen/plugin-manager/cvm
[0010.183] W> “chip-id” doesn’t exist, creating
[0010.188] I> Adding /chosen/plugin-manager/chip-id
[0010.192] W> “configs” doesn’t exist, creating
[0010.196] I> Adding /chosen/plugin-manager/configs
[0010.201] W> “ids” doesn’t exist, creating
[0010.205] I> Adding /chosen/plugin-manager/ids
[0010.210] W> “odm-data” doesn’t exist, creating
[0010.214] I> Adding /chosen/plugin-manager/odm-data
[0010.221] W> “memory” doesn’t exist, creating
[0010.223] I> [0] START: 0x80000000, END: 0xac000000
[0010.227] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.232] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.237] I> dram_block larger than 80000000
[0010.241] I> [3] START: 0x100000000, END: 0x880000000
[0010.246] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.252] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.258] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.264] I> Updated memory info to DTB
[0010.268] E> add_disp_param: failed to get display params for du=0
[0010.274] W> “reset” doesn’t exist, creating
[0010.278] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.282] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.287] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.292] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.296] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.301] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.306] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.310] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.316] W> “misc-data” doesn’t exist, creating
[0010.320] I> Boot-device: eMMC
[0010.323] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.328] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.333] W> Unknown storage device
[0010.337] I> Add serial number:1421920022204 as DT property
[0010.343] I> Plugin-manager override starting
[0010.346] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.354] I> node /plugin-manager/fragement-soft-wdt matches
[0010.360] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.365] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0010.372] I> Disable plugin-manager status in FDT
[0010.374] I> Plugin-manager override finished successfully
[0010.379] I> tegrabl_load_kernel_and_dtb: Done
[0010.383] E> tegrabl_display_clear: display is not initialized
[0010.389] W> Boot logo display failed…
[0010.424] I> Kernel EP: 0x80080000, DTB: 0x90000000
hello nvidias,
may I know what’s the power-supply of your Xavier platform.
could you please configure the power budget to maximum performance mode, i.e. Max-N for testing.
you should also check developer guide, Supported Modes and Power Efficiency for reference,
thanks
Hi JerryChang,
When we tested it, it was in max-n mode,the power supply of our platform is 12V battery power supply.
BTW,can you tell me what RESET triggers are available on the XAVIER platform?
In " Tegra Linux Driver " I found the following:
•Watchdog 5 expiry
•Watchdog 4 expiry
•SC7 exit
•SC8 exit
•SW-Reset
•AO-Tag/sensor reset
•VF Sensor reset
•HSM reset
Are these all up here?
Thanks,
BR,
you may refer to Jetson AGX Xavier Developer Kit User Guide, the power usage is maximum at 30W in the default configuration.
please also refer to Xavier Product Design Guide, you may check chapter-5 for power specifications.
thanks
Hi JerryChang,
I’m sure XAVIER is in the Maximum 30W power usage state,
and what should I do next?
Thanks,
BR,
hello nvidias,
due to you’re having battery power supply, please setup an oscilloscope to rule out there’s no power-supply shortage issue.
thanks
hello JerryChang,
We have measured 5V and 12V power supply with oscilloscope, both of which are stable and no shortage is found.
In addition, we found a strange phenomenon that we use metal objects to touch the ground to restart.
Instead of typing in the command “reboot,” this reboot acts like a hardware reboot, which starts right away, just like pressing the RESET button.
We use an oscilloscope to monitor the RESET pin at this time. The RESET pin does not change and is always at a high level.
In addition to the RESET button and the command Reboot, what other RESET trigger mode can be used to hard reboot?
Thanks,
BR,
hello nvidias,
you may exclude battery power supply for issue narrow down; please use a DC supply to observe the real input voltage and current to make sure if the shutdown caused by less power supply capability.
please also check the temperature and power consumption are showed by tegrastats utility.
thanks
hello JerryChang,
I’m sorry for replying you so late today!
We have tested the DC power supply, and the phenomenon remains the same,
most of the time there is no valid print message, just like a power outage.
One restart had the following log in dmesg:
[ 72.856547] NOHZ: local_softirq_pending 80
[ 72.856567] NOHZ: local_softirq_pending 80
[ 72.856720] NOHZ: local_softirq_pending 80
[ 72.856786] NOHZ: local_softirq_pending 80
[ 72.857199] NOHZ: local_softirq_pending 80
[ 72.857256] NOHZ: local_softirq_pending 80
[ 72.857386] NOHZ: local_softirq_pending 80
[ 3905.384311] bpmp: mrq 19 took 3999000 us
[ 3905.832005] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 6510416 has been capped to VI’s max BW 4000000
[ 3907.984085] bpmp: mrq 22 took 1115000 us
Can these logs represent the reason for the restart?
Please give me some advice, thank you!
BR,
hello nvidias,
is it a thermal shutdown?
you may also check the temperature and power consumption are showed by tegrastats utility.
thanks
Hello JerryChang,
I can’t confirm whether it is a thermal shutdown. What method can I use to confirm it?
Can I use command “tegrastats --interval 500 --logfile log.log &” ?
BR,
hello nvidias,
you may enable tegrastats utility to monitor the system usage and also thermal reports.
please also refer to Hardware Throttling session for hardware throttling levels and also thermal specifications for hw shutdown,
thanks
