Xavier agv stuck in nvidia boot loop after flashing with sdkmanager
HOST OS: UBUNTU 18.04
running sdkmanager, finds xavier agv, flashes it, but after get’s stuck in boot loop - showing nvidia screen over and over again on monitor.
Thoughts?
Connected to serial monitor and this is the output:
[0002.322] I> Load in CBoot Boot Options partition and parse it
[0002.329] E> Error -9 when finding node with path /boot-configuration
[0002.329] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
anyone…
Moving this to the Xavier AGX forum for better visibility.
First, is this a true HDMI monitor, or is there some sort of adapter in the cable? You’ll need actual HDMI.
It is a direct hdmi.
Which JetPack/L4T/SDKM release version are you flashing? Is this the development kit, or a third party carrier board? On the host PC, what do you see from:
df -H ~/nvidia/nvidia_sdk
This is the Xavier agx development kit.
I am flashing the latest from the sdkmanager. 4.4
Filesystem      Size  Used Avail Use% Mounted on
/dev/nvme1n1p2  492G  105G  362G  23% /
[0002.329] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
Could you paste the full log?
[0001.402] I> 26) Base:0x40040000 Size:0x00006000
[0001.407] I> 27) Base:0xf1800000 Size:0x00400000
[0001.411] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.415] I> 29) Base:0xf1400000 Size:0x00400000
[0001.420] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.424] I> 31) Base:0x00000000 Size:0x00000000
[0001.429] I> 32) Base:0xf8000000 Size:0x08000000
[0001.433] I> 33) Base:0x00000000 Size:0x00000000
[0001.438] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.442] I> 35) Base:0xab000000 Size:0x01000000
[0001.447] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.451] I> 37) Base:0xf2800000 Size:0x00800000
[0001.456] I> 38) Base:0x80000000 Size:0x20000000
[0001.460] I> 39) Base:0xb0000000 Size:0x08000000
[0001.465] I> 40) Base:0x00000000 Size:0x00000000
[0001.469] I> 41) Base:0x00000000 Size:0x00000000
[0001.473] I> 42) Base:0x00000000 Size:0x00000000
[0001.478] I> 43) Base:0x00000000 Size:0x00000000
[0001.482] I> 44) Base:0x00000000 Size:0x00000000
[0001.487] I> 45) Base:0x00000000 Size:0x00000000
[0001.491] GIC-SPI Target CPU: 0
[0001.494] Interrupts Init done
[0001.497] calling constructors
[0001.500] initializing heap
[0001.503] I> Heap: [0xa06905a8 ... 0xab000000]
[0001.507] initializing threads
[0001.510] initializing timers
[0001.513] creating bootstrap completion thread
[0001.517] top of bootstrap2()
[0001.520] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.524] initializing platform
[0001.527] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.533] W> device prod register failed
[0001.537] I> Bl_dtb @0xaaf00000
[0001.543] W> "plugin-manager" doesn't exist, creating
[0001.545] W> "ids" doesn't exist, creating
[0001.549] W> "connection" doesn't exist, creating
[0001.553] W> "configs" doesn't exist, creating
[0001.565] I> Find /i2c@3160000's alias i2c0
[0001.565] I> Reading eeprom i2c=0 address=0x50
[0001.591] I> Device at /i2c@3160000:0x50
[0001.591] I> Reading eeprom i2c=0 address=0x56
[0001.615] I> Device at /i2c@3160000:0x56
[0001.617] I> Find /i2c@3180000's alias i2c2
[0001.618] I> Reading eeprom i2c=2 address=0x54
[0001.619] E> I2C: slave not found in slaves.
[0001.620] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.621] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.621] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.630] E> eeprom: Failed to read I2C slave device
[0001.634] I> Eeprom read failed 0x3526070d
[0001.638] I> Reading eeprom i2c=2 address=0x57
[0001.643] E> I2C: slave not found in slaves.
[0001.647] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.655] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.660] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.670] E> eeprom: Failed to read I2C slave device
[0001.674] I> Eeprom read failed 0x3526070d
[0001.678] I> Reading eeprom i2c=2 address=0x52
[0001.683] E> I2C: slave not found in slaves.
[0001.687] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.695] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.700] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.710] E> eeprom: Failed to read I2C slave device
[0001.715] I> Eeprom read failed 0x3526070d
[0001.720] I> Find /i2c@c240000's alias i2c1
[0001.723] I> Reading eeprom i2c=1 address=0x52
[0001.728] E> I2C: slave not found in slaves.
[0001.731] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.739] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.744] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.754] E> eeprom: Retry to read I2C slave device.
[0001.759] E> I2C: slave not found in slaves.
[0001.763] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.771] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.776] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.786] E> eeprom: Failed to read I2C slave device
[0001.791] I> Eeprom read failed 0x3526070d
[0001.794] I> Reading eeprom i2c=1 address=0x50
[0001.799] E> I2C: slave not found in slaves.
[0001.803] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.811] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.816] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.826] E> eeprom: Retry to read I2C slave device.
[0001.831] E> I2C: slave not found in slaves.
[0001.835] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.843] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.848] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.858] E> eeprom: Failed to read I2C slave device
[0001.862] I> Eeprom read failed 0x3526070d
[0001.866] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0001.872] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.883] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.888] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.899] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.907] W> "i2c@3160000" doesn't exist, creating
[0001.911] W> "module@0x50" doesn't exist, creating
[0001.915] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.922] W> "module@0x56" doesn't exist, creating
[0001.931] I> Adding plugin-manager/cvm
[0001.931] W> "chip-id" doesn't exist, creating
[0001.935] I> Adding plugin-manager/chip-id/A02P
[0001.939] I> Plugin-manager override starting
[0001.944] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.953] I> node /plugin-manager/fragement-soft-wdt matches
[0001.961] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.966] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.978] I> Disable plugin-manager status in FDT
[0001.978] I> Plugin-manager override finished successfully
[0001.979] I> gpio framework initialized
[0001.981] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.989] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.995] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.003] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.011] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.017] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.023] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.030] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.038] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.044] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.052] I> fixed regulator driver initialized
[0002.061] I> register 'maxim' power off handle
[0002.062] I> virtual i2c enabled
[0002.062] I> registered 'maxim,max20024' pmic
[0002.067] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.073] I> Boot-device: eMMC
[0002.076] I> Boot_device: SDMMC_BOOT instance: 3
[0002.085] I> sdmmc-3 params source = boot args
[0002.085] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.090] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.101] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.106] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.117] I> sdmmc bdev is already initialized
[0002.121] I> sdmmc-3 params source = boot args
[0002.152] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.165] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.175] I> enabling 'vdd-hdmi-5v0' regulator
[0002.180] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.181] I> hdmi cable connected
[0002.182] W> set volts not configured for 'vdd-1v0'
[0002.184] W> set volts not configured for 'vdd-1v8-hs'
[0002.188] E> invalid display type
[0002.192] E> invalid display type
[0002.193] E> cannot find any other nvdisp nodes
[0002.208] I> edid read success
[0002.221] I> edid read success
[0002.221] I> width = 640, height = 480, frequency = 25174825
[0002.222] I> width = 640, height = 480, frequency = 25174825
[0002.223] I> width = 3840, height = 2160, frequency = 533250000
[0002.226] I> width = 3840, height = 2160, frequency = 262750000
[0002.232] I> width = 1920, height = 1080, frequency = 148351648
[0002.238] I> width = 1280, height = 720, frequency = 74175824
[0002.243] I> width = 720, height = 480, frequency = 26973026
[0002.249] I> width = 1920, height = 1080, frequency = 148351648
[0002.255] I> width = 1280, height = 720, frequency = 74175824
[0002.260] I> width = 640, height = 480, frequency = 25174825
[0002.266] I> width = 720, height = 576, frequency = 26973026
[0002.271] I> width = 3840, height = 2160, frequency = 296703296
[0002.277] I> width = 3840, height = 2160, frequency = 593406593
[0002.283] I> width = 3840, height = 2160, frequency = 296703296
[0002.289] I> width = 3840, height = 2160, frequency = 296703296
[0002.294] I> width = 3840, height = 2160, frequency = 296703296
[0002.300] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.310] I> hdmi_enable, starting HDMI initialisation
[0002.315] I> hdmi_enable, HDMI initialisation complete
[0002.325] I> Load in CBoot Boot Options partition and parse it
[0002.332] E> Error -9 when finding node with path /boot-configuration
[0002.332] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
@WayneWWW
  [0002.341] I> Hit any key to stop autoboot:	4
    TEGRA194 # \00\00\00\FF\E2
    [0000.095] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
    [0000.103] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
    [0000.109] I> Boot-mode: Coldboot
    [0000.112] I> Chip revision : A02P
    [0000.115] I> Bootrom patch version : 15 (correctly patched)
    [0000.120] I> ATE fuse revision : 0x200
    [0000.123] I> Ram repair fuse : 0x0
    [0000.126] I> Ram Code : 0x2
    [0000.129] I> rst_source : 0x0
    [0000.132] I> rst_level : 0x0
    [0000.135] I> Boot-device: eMMC
    [0000.150] I> sdmmc DDR50 mode
    [0000.154] W> No valid slot number is found in scratch register
    [0000.160] W> Return default slot: _a
    [0000.163] I> Active Boot chain : 0
    [0000.166] I> Boot-device: eMMC
    [0000.170] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
    [0000.178] I> Temperature = 34500
    [0000.181] W> Skipping boost for clk: BPMP_CPU_NIC
    [0000.185] W> Skipping boost for clk: BPMP_APB
    [0000.189] W> Skipping boost for clk: AXI_CBB
    [0000.193] W> Skipping boost for clk: AON_CPU_NIC
    [0000.197] W> Skipping boost for clk: CAN1
    [0000.201] W> Skipping boost for clk: CAN2
    [0000.205] I> Boot-device: eMMC
    [0000.208] I> Boot-device: eMMC
    [0000.217] I> Sdmmc: HS400 mode enabled
    [0000.222] I> ECC region[0]: Start:0x0, End:0x0
    [0000.226] I> ECC region[1]: Start:0x0, End:0x0
    [0000.230] I> ECC region[2]: Start:0x0, End:0x0
    [0000.234] I> ECC region[3]: Start:0x0, End:0x0
    [0000.238] I> ECC region[4]: Start:0x0, End:0x0
    [0000.243] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
    [0000.248] I> Non-ECC region[1]: Start:0x0, End:0x0
    [0000.253] I> Non-ECC region[2]: Start:0x0, End:0x0
    [0000.257] I> Non-ECC region[3]: Start:0x0, End:0x0
    [0000.262] I> Non-ECC region[4]: Start:0x0, End:0x0
    [0000.267] E> FAILED: Thermal config
    [0000.274] E> FAILED: MEMIO rail config
    [0000.293] I> Boot-device: eMMC
    [0000.303] I> sdmmc bdev is already initialized
    [0000.375] I> MB1 done
    \00\FF\FD\FF\E0main enter
    SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
    HW Function test
    Start Scheduler.
    in late init
    \FF\E2
    [0000.384] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-2dfe4beb)
    [0000.384] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
    [0000.385] I> Default Heap @ [0xd486400 - 0xd48a400]
    [0000.385] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
    [0000.391] W> device prod register failed
    [0000.395] I> Boot-device: eMMC
    [0000.398] I> Boot_device: SDMMC_BOOT instance: 3
    [0000.404] I> sdmmc-3 params source = boot args
    [0000.407] I> sdmmc bdev is already initialized
    [0000.411] I> sdmmc-3 params source = boot args
    [0000.418] I> Found 17 partitions in SDMMC_BOOT (instance 3)
    [0000.424] I> Found 42 partitions in SDMMC_USER (instance 3)
    [0000.427] W> No valid slot number is found in scratch register
    [0000.432] W> Return default slot: _a
    [0000.435] I> Active Boot chain : 0
    [0000.439] I> parsing oem signed section of bpmp-fw header done
    [0000.444] I> bpmp-fw binary init read from storage
    [0000.449] I> oem authentication of bpmp-fw header done
    [0000.456] I> bpmp-fw binary done read from storage
    [0000.459] I> bpmp-fw: Authentication init Done
    [0000.464] I> parsing oem signed section of cpubl header done
    [0000.468] I> cpubl binary init read from storage
    [0000.473] I> bpmp-fw: Authentication Finalize Done
    [0000.478] I> oem authentication of cpubl header done
    [0000.482] I> cpubl binary done read from storage
    [0000.487] I> cpubl: Authentication init Done
    [0000.493] I> parsing oem signed section of rce header done
    [0000.496] I> rce binary init read from storage
    [0000.501] I> Relocating BR-BCT
    [0000.504] I> cpubl: Authentication Finalize Done
    [0000.508] I> oem authentication of rce header done
    [0000.512] I> rce binary done read from storage
    [0000.517] I> rce: Authentication init Done
    [0000.521] I> parsing oem signed section of ape header done
    [0000.526] I> ape binary init read from storage
    [0000.530] I> rce: Authentication Finalize Done
    [0000.535] I> oem authentication of ape header done
    [0000.539] I> ape binary done read from storage
    [0000.543] I> ape: Authentication init Done
    [0000.548] I> parsing oem signed section of tos header done
    [0000.553] I> tos binary init read from storage
    [0000.557] I> ape: Authentication Finalize Done
    [0000.562] I> oem authentication of tos header done
    [0000.566] I> tos binary done read from storage
    [0000.570] I> tos: Authentication init Done
    [0000.576] I> parsing oem signed section of bpmp-fw-dtb header done
    [0000.580] I> bpmp-fw-dtb binary init read from storage
    [0000.585] I> tos: Authentication Finalize Done
    [0000.591] I> oem authentication of bpmp-fw-dtb header done
    [0000.598] I> bpmp-fw-dtb binary done read from storage
    [0000.600] I> bpmp-fw-dtb: Authentication init Done
    [0000.605] I> parsing oem signed section of cpubl-dtb header done
    [0000.610] I> cpubl-dtb binary init read from storage
    [0000.615] I> bpmp-fw-dtb: Authentication Finalize Done
    [0000.652] I> oem authentication of cpubl-dtb header done
    [0000.653] I> cpubl-dtb binary done read from storage
    [0000.654] I> cpubl-dtb: Authentication init Done
    [0000.656] I> parsing oem signed section of eks header done
    [0000.656] I> eks binary init read from storage
    [0000.657] I> cpubl-dtb: Authentication Finalize Done
    [0000.658] I> oem authentication of eks header done
    [0000.661] I> eks binary done read from storage
    [0000.665] I> eks: Authentication init Done
    [0000.669] I> eks: Authentication Finalize Done
    [0000.674] I> EKB detected (length: 0x410) @ VA:0x5270a400
    \FF\E4NOTICE:  BL31: v1.3(release):41d46a9cf
    NOTICE:  BL31: Built : 21:14:52, Jun 25 2020
    ipc-unittest-main: 1519: Welcome to IPC unittest!!!
    ipc-unittest-main: 1531: waiting forever
    ipc-unittest-srv: 329: Init unittest services!!!
    hwkey-agent: 40: hwkey-agent is running!!
    hwkey-agent: 182: key_mgnt_processing .......
    hwkey-agent: 157: Init hweky-agent services!!
    platform_bootstrap_epilog: trusty bootstrap complete
    \FF\E2
    welcome to lk
    initializing heap
    top of bootstrap2()
    bpmp: platform_init
    tag is 57f8a77779f848bf2ecf21dabee5645f
    tag_show initialized
    dt initialized
    mail initialized
    chipid initialized
    fuse initialized
    sku initialized
    speedo initialized
    ec_get_ec_list: found 45 ecs
    ec initialized
    ec_mrq initialized
    vmon_populate_monitors: found 3 monitors
    vmon initialized
    adc initialized
    fmon_populate_monitors: found 73 monitors
    fmon initialized
    fmon_mrq initialized
    reset initialized
    nvhs initialized
    392 clocks registered
    WARNING: pll_c4 has no dyn ramp
    clk_mrq_init: mrq handler registered
    clk initialized
    nvlink initialized
    io_dpd initialized
    io_dpd initialized
    thermal initialized
    i2c5 controller initialized
    initialized i2c mrq handling
    i2c initialized
    regulator initialized
    avfs_clk_platform initialized
    soctherm initialized
    aotag initialized
    powergate initialized
    dvs initialized
    pm initialized
    pg_late initialized
    strap initialized
    tag initialized
    emc initialized
    clk_dt initialized
    avfs_ccplex_platform initialized
    tj_max: dt node not found
    tj_init initialized
    uphy_mrq_init: mrq handler registered
    uphy_dt initialized
    uphy initialized
    safereg_init: period 80 ms
    ec_late initialized
    mrq initialized
    \FF\E1
    [0001.177] I> Welcome to Cboot
    \FF\E2fmon_post initialized
    \FF\E1[0001.177] I> Cboot Version: t194-18fdfe28
    [0001.177] I> CPU-BL Params @ 0xf2820000
    [0001.178] I>  0) Base:0x00000000 Size:0x00000000
    [0001.181] I>  1) Base:0xf1100000 Size:0x00100000
    [0001.186] I>  2) Base:0xf2000000 Size:0x00200000
    [0001.190] I>  3) Base:0xf1200000 Size:0x00200000
    \FF\E2clk_set_parent failed for clk can1, parent pll_aon (-22)
    clk_set_parent failed for clk can2, parent pll_aon (-22)
    clk_set_parent failed for clk dmic5, parent pll_aon (-22)
    clk_set_parent failed for clk i2c2, parent pll_aon (-22)
    clk_set_parent failed for clk i2c8, parent pll_aon (-22)
    clk_set_parent failed for clk spi2, parent pll_aon (-22)
    clk_set_parent failed for clk pwm4, parent pll_aon (-22)
    clk_dt_late initialized
    machine_check initialized
    pm_post initialized
    dbells initialized
    avfs_clk_platform_post initialized
    dmce initialized
    cvc initialized
    ccplex_avfs_hw_init: nafll_cluster0: not monitored
    ccplex_avfs_hw_init: nafll_cluster1: not monitored
    ccplex_avfs_hw_init: nafll_cluster2: not monitored
    ccplex_avfs_hw_init: nafll_cluster3: not monitored
    avfs_clk_mach_post initialized
    regulator_post initialized
    rm initialized
    sc7_diag initialized
    thermal_test initialized
    serial_late initialized
    clk_post initialized
    clk_dt_post initialized
    mc_reg initialized
    pg_post initialized
    dyn_modules initialized
    sku_debugfs initialized
    speedo_debugfs initialized
    adc_debugfs initialized
    clk_debugfs initialized
    \FF\E1[0001.195] I>  4) Base:0xf1000000 Size:0x00100000
    [0001.299] I>  5) Base:0xf0f00000 Size:0x00100000
    [0001.304] I>  6) Base:0xf3800000 Size:0x00400000
    [0001.308] I>  7) Base:0xf1c00000 Size:0x00400000
    [0001.313] I>  8) Base:0xf0e00000 Size:0x00100000
    [0001.317] I>  9) Base:0xf0d00000 Size:0x00100000
    [0001.322] I> 10) Base:0xf3000000 Size:0x00800000
    [0001.326] I> 11) Base:0x40000000 Size:0x00040000
    [0001.331] I> 12) Base:0xf0c00000 Size:0x00100000\FF\E2emc_debugfs initialized
    dvs_debugfs initialized
    \FF\E1
    [0001.340] I> 13) Base:0x40046000 Size:0x00002000
    [0001.344] I> 14) Base:0x40048000 Size:0x00002000
    \FF\E2fmon_debugfs initialized
    vmon_debugfs initialized
    pg_debugfs initialized
    profile_fs initialized
    debugfs_cons initialized
    mail_fs initialized
    profile initialized
    cvc_debugfs initialized
    dmce_debugfs initialized
    ec_debugfs initialized
    rm_debugfs initialized
    soctherm_debug initialized
    gr_reader initialized
    mods initialized
    dt_fs initialized
    debugfs_mrq initialized
    debug_mrq initialized
    debug_safereg initialized
    initializing target
    calling apps_init()
    starting app shell
    entering main console loop
    ] \FF\E1[0001.349] I> 15) Base:0xac000000 Size:0x00004000
    [0001.399] I> 16) Base:0x4004a000 Size:0x00002000
    [0001.404] I> 17) Base:0xf0b00000 Size:0x00100000
    [0001.408] I> 18) Base:0x4004c000 Size:0x00002000
    [0001.413] I> 19) Base:0xf2200000 Size:0x00600000
    [0001.417] I> 20) Base:0x4004e000 Size:0x00002000
    [0001.422] I> 21) Base:0xf09d0000 Size:0x0000c000
    [0001.426] I> 22) Base:0x00000000 Size:0x00000000
    [0001.431] I> 23) Base:0xf09e0000 Size:0x00020000
    [0001.435] I> 24) Base:0xf6000000 Size:0x02000000
    [0001.439] I> 25) Base:0x40050000 Size:0x00002000
    [0001.444] I> 26) Base:0x40040000 Size:0x00006000
    [0001.448] I> 27) Base:0xf1800000 Size:0x00400000
    [0001.453] I> 28) Base:0xf4c00000 Size:0x01400000
    [0001.457] I> 29) Base:0xf1400000 Size:0x00400000
    [0001.462] I> 30) Base:0xf0a00000 Size:0x00100000
    [0001.466] I> 31) Base:0x00000000 Size:0x00000000
    [0001.471] I> 32) Base:0xf8000000 Size:0x08000000
    [0001.475] I> 33) Base:0x00000000 Size:0x00000000
    [0001.480] I> 34) Base:0xf3c00000 Size:0x01000000
    [0001.484] I> 35) Base:0xab000000 Size:0x01000000
    [0001.489] I> 36) Base:0xa0000000 Size:0x0b000000
    [0001.493] I> 37) Base:0xf2800000 Size:0x00800000
    [0001.497] I> 38) Base:0x80000000 Size:0x20000000
    [0001.502] I> 39) Base:0xb0000000 Size:0x08000000
    [0001.506] I> 40) Base:0x00000000 Size:0x00000000
    [0001.511] I> 41) Base:0x00000000 Size:0x00000000
    [0001.515] I> 42) Base:0x00000000 Size:0x00000000
    [0001.520] I> 43) Base:0x00000000 Size:0x00000000
    [0001.524] I> 44) Base:0x00000000 Size:0x00000000
    [0001.529] I> 45) Base:0x00000000 Size:0x00000000
    [0001.533] GIC-SPI Target CPU: 0
    [0001.536] Interrupts Init done
    [0001.539] calling constructors
    [0001.542] initializing heap
    [0001.545] I> Heap: [0xa06905a8 ... 0xab000000]
    [0001.549] initializing threads
    [0001.552] initializing timers
    [0001.555] creating bootstrap completion thread
    [0001.559] top of bootstrap2()
    [0001.562] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
    [0001.566] initializing platform
    [0001.569] E> DEVICE_PROD: Invalid value data = 0, size = 0.
    [0001.575] W> device prod register failed
    [0001.578] I> Bl_dtb @0xaaf00000
    [0001.585] W> "plugin-manager" doesn't exist, creating
    [0001.586] W> "ids" doesn't exist, creating
    [0001.591] W> "connection" doesn't exist, creating
    [0001.595] W> "configs" doesn't exist, creating
    [0001.607] I> Find /i2c@3160000's alias i2c0
    [0001.608] I> Reading eeprom i2c=0 address=0x50
    [0001.633] I> Device at /i2c@3160000:0x50
    [0001.634] I> Reading eeprom i2c=0 address=0x56
    [0001.658] I> Device at /i2c@3160000:0x56
    [0001.660] I> Find /i2c@3180000's alias i2c2
    [0001.660] I> Reading eeprom i2c=2 address=0x54
    [0001.662] E> I2C: slave not found in slaves.
    [0001.662] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
    [0001.663] E> I2C_DEV: Failed to send register address 0x00000000.
    [0001.663] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
    [0001.672] E> eeprom: Failed to read I2C slave device
    [0001.677] I> Eeprom read failed 0x3526070d
    [0001.681] I> Reading eeprom i2c=2 address=0x57
    [0001.685] E> I2C: slave not found in slaves.
    [0001.689] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
    [0001.697] E> I2C_DEV: Failed to send register address 0x00000000.
    [0001.703] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
    [0001.712] E> eeprom: Failed to read I2C slave device
    [0001.717] I> Eeprom read failed 0x3526070d
    [0001.721] I> Reading eeprom i2c=2 address=0x52
    [0001.725] E> I2C: slave not found in slaves.
    [0001.729] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
    [0001.737] E> I2C_DEV: Failed to send register address 0x00000000.
    [0001.743] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
    [0001.752] E> eeprom: Failed to read I2C slave device
    [0001.757] I> Eeprom read failed 0x3526070d
    [0001.762] I> Find /i2c@c240000's alias i2c1
    [0001.765] I> Reading eeprom i2c=1 address=0x52
    [0001.771] E> I2C: slave not found in slaves.
    [0001.773] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
    [0001.781] E> I2C_DEV: Failed to send register address 0x00000000.
    [0001.787] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
    [0001.796] E> eeprom: Retry to read I2C slave device.
    [0001.801] E> I2C: slave not found in slaves.
    [0001.805] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
    [0001.813] E> I2C_DEV: Failed to send register address 0x00000000.
    [0001.819] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
    [0001.828] E> eeprom: Failed to read I2C slave device
    [0001.833] I> Eeprom read failed 0x3526070d
    [0001.837] I> Reading eeprom i2c=1 address=0x50
    [0001.841] E> I2C: slave not found in slaves.
    [0001.845] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
    [0001.853] E> I2C_DEV: Failed to send register address 0x00000000.
    [0001.859] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
    [0001.868] E> eeprom: Retry to read I2C slave device.
    [0001.873] E> I2C: slave not found in slaves.
    [0001.877] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
    [0001.885] E> I2C_DEV: Failed to send register address 0x00000000.
    [0001.891] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
    [0001.900] E> eeprom: Failed to read I2C slave device
    [0001.905] I> Eeprom read failed 0x3526070d
    [0001.909] I> create_pm_ids: id: 2888-0004-400-L, len: 15
    [0001.914] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
    [0001.925] I> create_pm_ids: id: 2822-0000-700-K, len: 15
    [0001.930] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
    [0001.941] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
    [0001.949] W> "i2c@3160000" doesn't exist, creating
    [0001.953] W> "module@0x50" doesn't exist, creating
    [0001.958] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
    [0001.965] W> "module@0x56" doesn't exist, creating
    [0001.972] I> Adding plugin-manager/cvm
    [0001.973] W> "chip-id" doesn't exist, creating
    [0001.977] I> Adding plugin-manager/chip-id/A02P
    [0001.982] I> Plugin-manager override starting
    [0001.987] I> node /plugin-manager/fragement-tegra-wdt-en matches
    [0001.995] I> node /plugin-manager/fragement-soft-wdt matches
    [0002.005] I> node /plugin-manager/fragment-pcie-c5-rp matches
    [0002.009] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
    [0002.024] I> Disable plugin-manager status in FDT
    [0002.025] I> Plugin-manager override finished successfully
    [0002.025] I> gpio framework initialized
    [0002.027] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
    [0002.031] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
    [0002.037] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
    [0002.045] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
    [0002.053] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
    [0002.059] W> tegrabl_tca9539_init: failed to fetch phandle from dt
    [0002.065] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
    [0002.073] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
    [0002.081] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
    [0002.087] W> tegrabl_tca9539_init: failed to fetch phandle from dt
    [0002.095] I> fixed regulator driver initialized
    [0002.106] I> register 'maxim' power off handle
    [0002.106] I> virtual i2c enabled
    [0002.107] I> registered 'maxim,max20024' pmic
    [0002.109] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
    [0002.116] I> Boot-device: eMMC
    [0002.119] I> Boot_device: SDMMC_BOOT instance: 3
    [0002.127] I> sdmmc-3 params source = boot args
    [0002.128] I> create_pm_ids: id: 2888-0004-400-L, len: 15
    [0002.132] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
    [0002.144] I> create_pm_ids: id: 2822-0000-700-K, len: 15
    [0002.149] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
    [0002.160] I> sdmmc bdev is already initialized
    [0002.164] I> sdmmc-3 params source = boot args
    [0002.195] I> Found 17 partitions in SDMMC_BOOT (instance 3)
    [0002.207] I> Found 42 partitions in SDMMC_USER (instance 3)
    [0002.217] I> enabling 'vdd-hdmi-5v0' regulator
    [0002.223] I> regulator 'vdd-hdmi-5v0' already enabled
    [0002.224] I> hdmi cable connected
    [0002.226] W> set volts not configured for 'vdd-1v0'
    [0002.228] W> set volts not configured for 'vdd-1v8-hs'
    [0002.232] E> invalid display type
    [0002.237] E> invalid display type
    [0002.238] E> cannot find any other nvdisp nodes
    [0002.253] I> edid read success
    [0002.266] I> edid read success
    [0002.266] I> width = 640, height = 480, frequency = 25174825
    [0002.267] I> width = 640, height = 480, frequency = 25174825
    [0002.268] I> width = 3840, height = 2160, frequency = 533250000
    [0002.271] I> width = 3840, height = 2160, frequency = 262750000
    [0002.277] I> width = 1920, height = 1080, frequency = 148351648
    [0002.283] I> width = 1280, height = 720, frequency = 74175824
    [0002.289] I> width = 720, height = 480, frequency = 26973026
    [0002.294] I> width = 1920, height = 1080, frequency = 148351648
    [0002.300] I> width = 1280, height = 720, frequency = 74175824
    [0002.306] I> width = 640, height = 480, frequency = 25174825
    [0002.311] I> width = 720, height = 576, frequency = 26973026
    [0002.317] I> width = 3840, height = 2160, frequency = 296703296
    [0002.322] I> width = 3840, height = 2160, frequency = 593406593
    [0002.328] I> width = 3840, height = 2160, frequency = 296703296
     [0002.334] I> width = 3840, height = 2160, frequency = 296703296
    [0002.340] I> width = 3840, height = 2160, frequency = 296703296
    [0002.345] I> Best mode Width = 1920, Height = 1080, freq = 148351648
   [0002.355] I> hdmi_enable, starting HDMI initialisation
    [0002.361] I> hdmi_enable, HDMI initialisation complete
    [0002.371] I> Load in CBoot Boot Options partition and parse it
    [0002.378] E> Error -9 when finding node with path /boot-configuration
    [0002.378] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
    [0002.381] I> Hit any key to stop autoboot:	4	3	2	1
Is there still log after the
“Hit any key to stop auto boot” in the last line of your log?
[0004.389] initializing target
[0004.389] calling apps_init()
[0004.390] starting app kernel_boot_app
[0004.409] I> found decompressor handler: lz4-legacy
[0004.410] I> decompressing BMP blob ...
[0004.413] I> Kernel type = Normal
[0004.413] I> Loading kernel-bootctrl from partition
[0004.414] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.420] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.421] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.422] I> ########## SD boot ##########
[0004.426] I> Found sdcard
[0004.431] I> enabling 'vdd-sdmmc1-sw' regulator
[0004.437] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.464] I> sdmmc SDR mode
[0004.479] I> -0 params source =
[0004.487] I> Found 11 partitions in SDCARD (instance 0)
[0004.488] I> Look for boot partition
[0004.488] I> Fallback: assuming 0th partition is boot partition
[0004.488] I> Detect filesystem
[0004.493] I> fs_detect:173: Unsupported or no filesystem present
[0004.493] I> Loading kernel ...
[0009.949] I> Loading kernel-dtb ...
[0009.989] I> Validate kernel ...
[0009.989] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.381] I> Validate kernel-dtb ...
[0010.381] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.384] I> Checking boot.img header magic ... [0010.385] I> [OK]
[0010.385] I> Kernel hdr @0xa4ac0000
[0010.385] I> Kernel dtb @0x90000000
[0010.385] I> decompressor handler not found
[0010.386] I> Copying kernel image (34330632 bytes) from 0xa4ac0800 to 0x80080000 ... [0010.398] I> Done
[0010.398] I> Move ramdisk (len: 5565615) from 0xa6b7e800 to 0x91000000
[0010.401] I> Updated bpmp info to DTB
[0010.403] I> Ramdisk: Base: 0x91000000; Size: 0x54ecaf
[0010.407] I> Updated initrd info to DTB
[0010.411] W> WARN: Fail to override "console=none" in commandline
[0010.417] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.424] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.431] W> No valid slot number is found in scratch register
[0010.437] W> Return default slot: _a
[0010.440] I> Active slot suffix:
[0010.444] I> add_boot_slot_suffix: slot_suffix =
[0010.448] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0010.488] I> Updated bootarg info to DTB
[0010.491] W> MAC addr invalid!
[0010.494] E> Failed to get WIFI MAC address
[0010.498] W> MAC addr invalid!
[0010.501] E> Failed to get Bluetooth MAC address
[0010.506] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:18:58:18
[0010.512] W> "plugin-manager" doesn't exist, creating
[0010.517] I> Adding /chosen/plugin-manager/cvm
[0010.521] W> "chip-id" doesn't exist, creating
[0010.525] I> Adding /chosen/plugin-manager/chip-id
[0010.530] W> "configs" doesn't exist, creating
[0010.534] I> Adding /chosen/plugin-manager/configs
[0010.539] W> "ids" doesn't exist, creating
[0010.543] I> Adding /chosen/plugin-manager/ids
[0010.547] W> "odm-data" doesn't exist, creating
[0010.551] I> Adding /chosen/plugin-manager/odm-data
[0010.558] W> "memory" doesn't exist, creating
[0010.561] I> [0] START: 0x80000000, END: 0xac000000
[0010.565] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.570] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.574] I> dram_block larger than 80000000
[0010.578] I> [3] START: 0x100000000, END: 0x880000000
[0010.583] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.589] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.595] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.602] I> Updated memory info to DTB
[0010.605] E> add_disp_param: failed to get display params for du=1
[0010.611] W> "reset" doesn't exist, creating
[0010.615] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.620] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.624] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.629] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.634] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.639] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.643] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.648] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.654] W> "misc-data" doesn't exist, creating
[0010.657] I> Boot-device: eMMC
[0010.660] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.665] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.671] W> Unknown storage device
[0010.675] I> Add serial number:1422620012453 as DT property
[0010.680] I> Plugin-manager override starting
[0010.684] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.691] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.699] I> Disable plugin-manager status in FDT
[0010.699] I> Plugin-manager override finished successfully
[0010.705] I> tegrabl_load_kernel_and_dtb: Done
[0010.727] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3357) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:22:12 PDT 2020
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  780000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] Found tegra_fbmem: 00800000@a069c000
[    0.000000] Found lut_mem: 00002008@a0697000
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc7ffcd0000 s61656 r8192 d32552 u102400
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8192013
[    0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29172(89%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.000000] Memory: 31917716K/33288180K available (15294K kernel code, 2934K rwdata, 6640K rodata, 8576K init, 609K bss, 616800K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009600000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009600000 - 0xffffff8009e60000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e60000 - 0xffffff800a13d808   (  2935 KB)
[    0.000000]        .bss : 0xffffff800a13d808 - 0xffffff800a1d5f7c   (   610 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf20000000   (   512 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc800000000   ( 32768 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.008310] Console: colour dummy device 80x25
[    0.012452] console [tty0] enabled
[    0.015586] bootconsole [tegra_comb_uart0] disabled
\FF\E4\FF\E2Shutdown state requested 1
Rebooting system ...
\00\00\FF\E2
[0000.055] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.063] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.069] I> Boot-mode: Coldboot
[0000.071] I> Chip revision : A02P
[0000.075] I> Bootrom patch version : 15 (correctly patched)
[0000.080] I> ATE fuse revision : 0x200
[0000.083] I> Ram repair fuse : 0x0
[0000.086] I> Ram Code : 0x2
[0000.089] I> rst_source : 0xb
[0000.091] I> rst_level : 0x1
[0000.095] I> Boot-device: eMMC
[0000.110] I> sdmmc DDR50 mode
[0000.114] W> No valid slot number is found in scratch register
[0000.120] W> Return default slot: _a
[0000.123] I> Active Boot chain : 0
[0000.126] I> Boot-device: eMMC
[0000.130] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.136] I> Temperature = 37500
[0000.139] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.143] W> Skipping boost for clk: BPMP_APB
[0000.147] W> Skipping boost for clk: AXI_CBB
[0000.151] W> Skipping boost for clk: AON_CPU_NIC
[0000.156] W> Skipping boost for clk: CAN1
[0000.159] W> Skipping boost for clk: CAN2
[0000.164] I> Boot-device: eMMC
[0000.176] I> Sdmmc: HS400 mode enabled
[0000.180] I> ECC region[0]: Start:0x0, End:0x0
[0000.184] I> ECC region[1]: Start:0x0, End:0x0
[0000.189] I> ECC region[2]: Start:0x0, End:0x0
[0000.193] I> ECC region[3]: Start:0x0, End:0x0
[0000.197] I> ECC region[4]: Start:0x0, End:0x0
[0000.201] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.207] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.211] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.216] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.220] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.225] E> FAILED: Thermal config
[0000.233] E> FAILED: MEMIO rail config
[0000.252] I> Boot-device: eMMC
[0000.261] I> sdmmc bdev is already initialized
[0000.333] I> MB1 done
HW Function test
Start Scheduler.
in late init
\FF\E2
[0000.342] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-2dfe4beb)
[0000.342] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.343] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.343] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.349] W> device prod register failed
[0000.353] I> Boot-device: eMMC
[0000.356] I> Boot_device: SDMMC_BOOT instance: 3
[0000.362] I> sdmmc-3 params source = boot args
[0000.365] I> sdmmc bdev is already initialized
[0000.369] I> sdmmc-3 params source = boot args
[0000.376] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.382] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.385] W> No valid slot number is found in scratch register
[0000.390] W> Return default slot: _a
[0000.393] I> Active Boot chain : 0
[0000.397] I> parsing oem signed section of bpmp-fw header done
[0000.402] I> bpmp-fw binary init read from storage
[0000.407] I> oem authentication of bpmp-fw header done
[0000.414] I> bpmp-fw binary done read from storage
[0000.417] I> bpmp-fw: Authentication init Done
[0000.421] I> parsing oem signed section of cpubl header done
[0000.426] I> cpubl binary init read from storage
[0000.431] I> bpmp-fw: Authentication Finalize Done
[0000.436] I> oem authentication of cpubl header done
[0000.440] I> cpubl binary done read from storage
[0000.445] I> cpubl: Authentication init Done
[0000.449] I> parsing oem signed section of rce header done
[0000.454] I> rce binary init read from storage
[0000.459] I> Relocating BR-BCT
[0000.462] I> cpubl: Authentication Finalize Done
[0000.466] I> oem authentication of rce header done
[0000.470] I> rce binary done read from storage
[0000.475] I> rce: Authentication init Done
[0000.481] I> parsing oem signed section of ape header done
[0000.484] I> ape binary init read from storage
[0000.488] I> rce: Authentication Finalize Done
[0000.493] I> oem authentication of ape header done
[0000.497] I> ape binary done read from storage
[0000.501] I> ape: Authentication init Done
[0000.506] I> parsing oem signed section of tos header done
[0000.511] I> tos binary init read from storage
[0000.515] I> ape: Authentication Finalize Done
[0000.520] I> oem authentication of tos header done
[0000.524] I> tos binary done read from storage
[0000.528] I> tos: Authentication init Done
[0000.532] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.538] I> bpmp-fw-dtb binary init read from storage
[0000.543] I> tos: Authentication Finalize Done
[0000.549] I> oem authentication of bpmp-fw-dtb header done
[0000.556] I> bpmp-fw-dtb binary done read from storage
[0000.558] I> bpmp-fw-dtb: Authentication init Done
[0000.564] I> parsing oem signed section of cpubl-dtb header done
[0000.568] I> cpubl-dtb binary init read from storage
[0000.573] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.610] I> oem authentication of cpubl-dtb header done
[0000.611] I> cpubl-dtb binary done read from storage
[0000.612] I> cpubl-dtb: Authentication init Done
[0000.614] I> parsing oem signed section of eks header done
[0000.614] I> eks binary init read from storage
[0000.615] I> cpubl-dtb: Authentication Finalize Done
[0000.616] I> oem authentication of eks header done
[0000.619] I> eks binary done read from storage
[0000.623] I> eks: Authentication init Done
[0000.627] I> eks: Authentication Finalize Done
[0000.632] I> EKB detected (length: 0x410) @ VA:0x5270a400
\FF\E2
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
\FF\E1
[0001.135] I> Welcome to Cboot
\FF\E1[0001.135] I> Cboot Version: t194-18fdfe28
[0001.136] I> CPU-BL Params @ 0xf2820000
[0001.136] I>  0) Base:0x00000000 Size:0x00000000
[0001.140] I>  1) Base:0xf1100000 Size:0x00100000
[0001.144] I>  2) Base:0xf2000000 Size:0x00200000
[0001.149] I>  3) Base:0xf1200000 Size:0x00200000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
\FF\E1[0001.153] I>  4) Base:0xf1000000 Size:0x00100000
[0001.258] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.262] I>  6) Base:0xf3800000 Size:0x00400000
[0001.267] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.271] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.276] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.280] I> 10) Base:0xf3000000 Size:0x00800000
[0001.285] I> 11) Base:0x40000000 Size:0x00040000
[0001.289] I> 12) Base:0xf0c00000 Size:0x00100000
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] \FF\E1[0001.294] I> 13) Base:0x40046000 Size:0x00002000
[0001.349] I> 14) Base:0x40048000 Size:0x00002000
[0001.353] I> 15) Base:0xac000000 Size:0x00004000
[0001.357] I> 16) Base:0x4004a000 Size:0x00002000
[0001.362] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.366] I> 18) Base:0x4004c000 Size:0x00002000
[0001.371] I> 19) Base:0xf2200000 Size:0x00600000
[0001.375] I> 20) Base:0x4004e000 Size:0x00002000
[0001.380] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.384] I> 22) Base:0x00000000 Size:0x00000000
[0001.389] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.393] I> 24) Base:0xf6000000 Size:0x02000000
[0001.398] I> 25) Base:0x40050000 Size:0x00002000
[0001.544] W> "ids" doesn't exist, creating
[0001.564] I> Find /i2c@3160000's alias i2c0
[0001.564] I> Reading eeprom i2c=0 address=0x50
[0001.616] I> Device at /i2c@3160000:0x56
[0001.618] I> Find /i2c@3180000's alias i2c2
[0001.620] E> I2C: slave not found in slaves.
[0001.675] I> Eeprom read failed 0x3526070d
[0001.929] I> Adding plugin-manager/cvm
[0001.952] I> node /plugin-manager/fragement-soft-wdt matches
[0001.959] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.963] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.976] I> Disable plugin-manager status in FDT
[0001.976] I> Plugin-manager override finished successfully
[0001.977] I> gpio framework initialized
[0001.988] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.002] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.010] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.064] I> register 'maxim' power off handle
[0002.064] I> virtual i2c enabled
[0002.065] I> registered 'maxim,max20024' pmic
[0002.174] I> enabling 'vdd-hdmi-5v0' regulator
[0002.179] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.180] I> hdmi cable connected
[0002.181] W> set volts not configured for 'vdd-1v0'
[0002.183] W> set volts not configured for 'vdd-1v8-hs'
[0002.191] E> invalid display type
[0002.220] I> edid read success
[0002.222] I> width = 3840, height = 2160, frequency = 533250000
[0002.254] I> width = 1280, height = 720, frequency = 74175824
[0002.288] I> width = 3840, height = 2160, frequency = 296703296
[0002.335] I> Hit any key to stop autoboot:	4	3	2	1
[0004.343] initializing target
[0004.343] calling apps_init()
[0004.344] starting app kernel_boot_app
[0004.363] I> found decompressor handler: lz4-legacy
[0004.364] I> decompressing BMP blob ...
[0004.368] I> Kernel type = Normal
[0004.368] I> Loading kernel-bootctrl from partition
[0004.368] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.375] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.375] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.376] I> ########## SD boot ##########
[0004.380] I> Found sdcard
[0004.384] I> enabling 'vdd-sdmmc1-sw' regulator
[0004.391] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.418] I> sdmmc SDR mode
[0004.433] I> -0 params source =
[0004.441] I> Found 11 partitions in SDCARD (instance 0)
[0004.442] I> Look for boot partition
[0004.442] I> Fallback: assuming 0th partition is boot partition
[0004.442] I> Detect filesystem
[0004.447] I> fs_detect:173: Unsupported or no filesystem present
[0004.447] I> Loading kernel ...
According to your log, I notice the system boots into kernel but then it gets a rebooting signal.
This looks weird. Is it triggered by your or the device itself?
Also, you bettering checking every log by yourself first.
There is no fixed pattern on your side now. Even the error seems different in every log.
And your latest log is more like a truncated one again.
Please check what you filed on forum really matches serial console log or not.
the xavier auto-reboots. I am not touching it. I flashed it using sdkmanager as indicated, and then booted it… and it just goes through this process. I can post more logs and ensure they are linear. I just don 't understand why it might be like this if it is newly flashed using the tool, but it says it is missing boot partitions,etc…
Thoughts? It isn’t hardware right? I am grateful for your thoughts and assistance, but overall this process seems to be taking longer than expected. Maybe I did something wrong, but still seems like it should just boot, right?
I have the hardware connected:
  • SD Card inserted
  • power connected
  • ethernet cable connected
  • 2 USB’s connected (for debug and flashing) and keyboard and mouse.
    Anything missing?
#ntic��#R�+�##�˫VHh#���r����#J�#*���#
Uѡ��ѥ��ѥ���2�����镁"���5R�#���r����#J�#*�%
�V#W�,W##$%[Y�##-'HL��10) @ VA:0x5270a400
��NOTICE:  BL31: v1.3(release):41d46a9cf
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
[0001.134] I> Welcome to Cboot
��fmon_post initialized
��[0001.134] I> Cboot Version: t194-18fdfe28
[0001.134] I> CPU-BL Params @ 0xf2820000
[0001.135] I>  0) Base:0x00000000 Size:0x00000000
[0001.138] I>  1) Base:0xf1100000 Size:0x00100000
[0001.143] I>  2) Base:0xf2000000 Size:0x00200000
[0001.147] I>  3) Base:0xf1200000 Size:0x00200000
��clk_set_parent failed for clk can1, parent pll_aon (-22)
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
��[0001.152] I>  4) Base:0xf1000000 Size:0x00100000
[0001.256] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.261] I>  6) Base:0xf3800000 Size:0x00400000
[0001.265] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.270] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.274] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.279] I> 10) Base:0xf3000000 Size:0x00800000
[0001.283] I> 11) Base:0x40000000 Size:0x00040000
[0001.288] I> 12) Base:0xf0c00000 Size:0x00100000
��emc_debugfs initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ��[0001.292] I> 13) Base:0x40046000 Size:0x00002000
[0001.347] I> 14) Base:0x40048000 Size:0x00002000
[0001.351] I> 15) Base:0xac000000 Size:0x00004000
[0001.356] I> 16) Base:0x4004a000 Size:0x00002000
[0001.360] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.365] I> 18) Base:0x4004c000 Size:0x00002000
[0001.369] I> 19) Base:0xf2200000 Size:0x00600000
[0001.374] I> 20) Base:0x4004e000 Size:0x00002000
[0001.378] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.383] I> 22) Base:0x00000000 Size:0x00000000
[0001.387] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.392] I> 24) Base:0xf6000000 Size:0x02000000
[0001.396] I> 25) Base:0x40050000 Size:0x00002000
[0001.401] I> 26) Base:0x40040000 Size:0x00006000
[0001.405] I> 27) Base:0xf1800000 Size:0x00400000
[0001.409] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.414] I> 29) Base:0xf1400000 Size:0x00400000
[0001.418] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.423] I> 31) Base:0x00000000 Size:0x00000000
[0001.427] I> 32) Base:0xf8000000 Size:0x08000000
[0001.432] I> 33) Base:0x00000000 Size:0x00000000
[0001.436] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.441] I> 35) Base:0xab000000 Size:0x01000000
[0001.445] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.450] I> 37) Base:0xf2800000 Size:0x00800000
[0001.454] I> 38) Base:0x80000000 Size:0x20000000
[0001.459] I> 39) Base:0xb0000000 Size:0x08000000
[0001.463] I> 40) Base:0x00000000 Size:0x00000000
[0001.467] I> 41) Base:0x00000000 Size:0x00000000
[0001.472] I> 42) Base:0x00000000 Size:0x00000000
[0001.476] I> 43) Base:0x00000000 Size:0x00000000
[0001.481] I> 44) Base:0x00000000 Size:0x00000000
[0001.485] I> 45) Base:0x00000000 Size:0x00000000
[0001.490] GIC-SPI Target CPU: 0
[0001.493] Interrupts Init done
[0001.496] calling constructors
[0001.499] initializing heap
[0001.501] I> Heap: [0xa06905a8 ... 0xab000000]
[0001.505] initializing threads
[0001.508] initializing timers
[0001.511] creating bootstrap completion thread
[0001.515] top of bootstrap2()
[0001.518] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.523] initializing platform
[0001.526] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.531] W> device prod register failed
[0001.535] I> Bl_dtb @0xaaf00000
[0001.542] W> "plugin-manager" doesn't exist, creating
[0001.543] W> "ids" doesn't exist, creating
[0001.547] W> "connection" doesn't exist, creating
[0001.551] W> "configs" doesn't exist, creating
[0001.563] I> Find /i2c@3160000's alias i2c0
[0001.589] I> Device at /i2c@3160000:0x50
[0001.590] I> Reading eeprom i2c=0 address=0x56
[0001.614] I> Device at /i2c@3160000:0x56
[0001.616] I> Find /i2c@3180000's alias i2c2
[0001.617] I> Reading eeprom i2c=2 address=0x54
[0001.618] E> I2C: slave not found in slaves.
[0001.619] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.620] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.620] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.628] E> eeprom: Failed to read I2C slave device
[0001.633] I> Eeprom read failed 0x3526070d
[0001.637] I> Reading eeprom i2c=2 address=0x57
[0001.641] E> I2C: slave not found in slaves.
[0001.645] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.653] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.659] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.668] E> eeprom: Failed to read I2C slave device
[0001.673] I> Eeprom read failed 0x3526070d
[0001.677] I> Reading eeprom i2c=2 address=0x52
[0001.681] E> I2C: slave not found in slaves.
[0001.685] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.693] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.699] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.708] E> eeprom: Failed to read I2C slave device
[0001.713] I> Eeprom read failed 0x3526070d
[0001.718] I> Find /i2c@c240000's alias i2c1
[0001.721] I> Reading eeprom i2c=1 address=0x52
[0001.727] E> I2C: slave not found in slaves.
[0001.743] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.752] E> eeprom: Retry to read I2C slave device.
[0001.757] E> I2C: slave not found in slaves.
[0001.761] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.769] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.775] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.784] E> eeprom: Failed to read I2C slave device
[0001.789] I> Eeprom read failed 0x3526070d
[0001.793] I> Reading eeprom i2c=1 address=0x50
[0001.797] E> I2C: slave not found in slaves.
[0001.801] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.809] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.815] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.824] E> eeprom: Retry to read I2C slave device.
[0001.829] E> I2C: slave not found in slaves.
[0001.833] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.841] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.847] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.856] E> eeprom: Failed to read I2C slave device
[0001.861] I> Eeprom read failed 0x3526070d
[0001.865] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0001.870] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.881] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.886] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.897] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.905] W> "i2c@3160000" doesn't exist, creating
[0001.909] W> "module@0x50" doesn't exist, creating
[0001.914] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.921] W> "module@0x56" doesn't exist, creating
[0001.927] I> Adding plugin-manager/cvm
[0001.929] W> "chip-id" doesn't exist, creating
[0001.933] I> Adding plugin-manager/chip-id/A02P
[0001.938] I> Plugin-manager override starting
[0001.943] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.963] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.968] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.982] I> Disable plugin-manager status in FDT
[0001.983] I> Plugin-manager override finished successfully
[0001.983] I> gpio framework initialized
[0001.985] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.987] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.993] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.001] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.009] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.015] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.021] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.029] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.037] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.043] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.051] I> fixed regulator driver initialized
[0002.062] I> register 'maxim' power off handle
[0002.063] I> virtual i2c enabled
[0002.063] I> registered 'maxim,max20024' pmic
[0002.065] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.072] I> Boot-device: eMMC
[0002.075] I> Boot_device: SDMMC_BOOT instance: 3
[0002.083] I> sdmmc-3 params source = boot args
[0002.084] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.089] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.100] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.105] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.116] I> sdmmc bdev is already initialized
[0002.120] I> sdmmc-3 params source = boot args
[0002.151] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.163] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.181] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.182] I> hdmi cable connected
[0002.184] W> set volts not configured for 'vdd-1v0'
[0002.187] W> set volts not configured for 'vdd-1v8-hs'
[0002.197] E> invalid display type
[0002.198] E> cannot find any other nvdisp nodes
[0002.213] I> edid read success
[0002.226] I> edid read success
[0002.226] I> width = 640, height = 480, frequency = 25174825
[0002.227] I> width = 640, height = 480, frequency = 25174825
[0002.228] I> width = 3840, height = 2160, frequency = 533250000
[0002.232] I> width = 3840, height = 2160, frequency = 262750000
[0002.237] I> width = 1920, height = 1080, frequency = 148351648
[0002.243] I> width = 1280, height = 720, frequency = 74175824
[0002.249] I> width = 720, height = 480, frequency = 26973026
[0002.254] I> width = 1920, height = 1080, frequency = 148351648
[0002.260] I> width = 1280, height = 720, frequency = 74175824
[0002.271] I> width = 720, height = 576, frequency = 26973026
[0002.277] I> width = 3840, height = 2160, frequency = 296703296
[0002.282] I> width = 3840, height = 2160, frequency = 593406593
[0002.300] I> width = 3840, height = 2160, frequency = 296703296
[0002.305] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.315] I> hdmi_enable, starting HDMI initialisation
[0002.321] I> hdmi_enable, HDMI initialisation complete
[0002.331] I> Load in CBoot Boot Options partition and parse it
[0002.338] E> Error -9 when finding node with path /boot-configuration
[0002.338] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.341] I> Hit any key to stop autoboot:	4	3	2	1
[0004.349] initializing target
[0004.349] calling apps_init()
[0004.350] starting app kernel_boot_app
[0004.369] I> found decompressor handler: lz4-legacy
[0004.370] I> decompressing BMP blob ...
[0004.373] I> Kernel type = Normal
[0004.374] I> Loading kernel-bootctrl from partition
[0004.374] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.381] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.381] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.382] I> ########## SD boot ##########
[0004.386] I> Found sdcard
[0004.391] I> enabling 'vdd-sdmmc1-sw' regulator
[0004.398] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.425] I> sdmmc SDR mode
[0004.440] I> -0 params source =
[0004.448] I> Found 11 partitions in SDCARD (instance 0)
[0004.449] I> Look for boot partition
[0004.449] I> Fallback: assuming 0th partition is boot partition
[0004.449] I> Detect filesystem
[0004.454] I> fs_detect:173: Unsupported or no filesystem present
[0004.454] I> Loading kernel ...
[0009.911] I> Loading kernel-dtb ...
[0009.951] I> Validate kernel ...
[0009.951] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.347] I> Validate kernel-dtb ...
[0010.347] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.350] I> Checking boot.img header magic ... [0010.351] I> [OK]
[0010.351] I> Kernel hdr @0xa4ac0000
[0010.351] I> Kernel dtb @0x90000000
[0010.351] I> decompressor handler not found
[0010.352] I> Copying kernel image (34330632 bytes) from 0xa4ac0800 to 0x80080000 ... [0010.364] I> Done
[0010.364] I> Move ramdisk (len: 5565615) from 0xa6b7e800 to 0x91000000
[0010.367] I> Updated bpmp info to DTB
[0010.369] I> Ramdisk: Base: 0x91000000; Size: 0x54ecaf
[0010.373] I> Updated initrd info to DTB
[0010.377] W> WARN: Fail to override "console=none" in commandline
[0010.383] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.390] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.397] W> No valid slot number is found in scratch register
[0010.403] W> Return default slot: _a
[0010.406] I> Active slot suffix:
[0010.409] I> add_boot_slot_suffix: slot_suffix =
[0010.414] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0010.453] I> Updated bootarg info to DTB
[0010.457] W> MAC addr invalid!
[0010.460] E> Failed to get WIFI MAC address
[0010.464] W> MAC addr invalid!
[0010.467] E> Failed to get Bluetooth MAC address
[0010.471] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:18:58:18
[0010.478] W> "plugin-manager" doesn't exist, creating
[0010.483] I> Adding /chosen/plugin-manager/cvm
[0010.487] W> "chip-id" doesn't exist, creating
[0010.491] I> Adding /chosen/plugin-manager/chip-id
[0010.496] W> "configs" doesn't exist, creating
[0010.500] I> Adding /chosen/plugin-manager/configs
[0010.505] W> "ids" doesn't exist, creating
[0010.509] I> Adding /chosen/plugin-manager/ids
[0010.513] W> "odm-data" doesn't exist, creating
[0010.517] I> Adding /chosen/plugin-manager/odm-data
[0010.524] W> "memory" doesn't exist, creating
[0010.526] I> [0] START: 0x80000000, END: 0xac000000
[0010.531] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.535] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.540] I> dram_block larger than 80000000
[0010.544] I> [3] START: 0x100000000, END: 0x880000000
[0010.549] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.555] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.561] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.568] I> Updated memory info to DTB
[0010.571] E> add_disp_param: failed to get display params for du=1
[0010.577] W> "reset" doesn't exist, creating
[0010.581] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.586] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.590] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.595] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.600] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.604] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.609] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.614] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.620] W> "misc-data" doesn't exist, creating
[0010.623] I> Boot-device: eMMC
[0010.626] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.631] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.637] W> Unknown storage device
[0010.640] I> Add serial number:1422620012453 as DT property
[0010.646] I> Plugin-manager override starting
[0010.650] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.657] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.665] I> Disable plugin-manager status in FDT
[0010.665] I> Plugin-manager override finished successfully
[0010.671] I> tegrabl_load_kernel_and_dtb: Done
[0010.693] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.008591] Console: colour dummy device 80x25
[    0.012438] console [tty0] enabled
[    0.015611] bootconsole [tegra_comb_uart0] disabled
���Shutdown state requested 1
[0000.136] I> Temperature = 27500
[0000.332] I> MB1 done
#���main enter
HW Function test
Start Scheduler.
in late init
[0000.340] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-2dfe4beb)
[0000.341] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.342] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.342] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.348] W> device prod register failed
[0000.352] I> Boot-device: eMMC
[0000.355] I> Boot_device: SDMMC_BOOT instance: 3
[0000.361] I> sdmmc-3 params source = boot args
[0000.364] I> sdmmc bdev is already initialized
[0000.368] I> sdmmc-3 params source = boot args
[0000.374] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.381] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.384] W> No valid slot number is found in scratch register
[0000.389] W> Return default slot: _a
[0000.392] I> Active Boot chain : 0
[0000.396] I> parsing oem signed section of bpmp-fw header done
[0000.401] I> bpmp-fw binary init read from storage
[0000.406] I> oem authentication of bpmp-fw header done
[0000.413] I> bpmp-fw binary done read from storage
[0000.415] I> bpmp-fw: Authentication init Done
[0000.420] I> parsing oem signed section of cpubl header done
[0000.425] I> cpubl binary init read from storage
[0000.430] I> bpmp-fw: Authentication Finalize Done
[0000.434] I> oem authentication of cpubl header done
[0000.439] I> cpubl binary done read from storage
[0000.443] I> cpubl: Authentication init Done
[0000.448] I> parsing oem signed section of rce header done
[0000.453] I> rce binary init read from storage
[0000.458] I> Relocating BR-BCT
[0000.460] I> cpubl: Authentication Finalize Done
[0000.465] I> oem authentication of rce header done
[0000.469] I> rce binary done read from storage
[0000.474] I> rce: Authentication init Done
[0000.478] I> parsing oem signed section of ape header done
[0000.483] I> ape binary init read from storage
[0000.487] I> rce: Authentication Finalize Done
[0000.492] I> oem authentication of ape header done
[0000.496] I> ape binary done read from storage
[0000.500] I> ape: Authentication init Done
[0000.505] I> parsing oem signed section of tos header done
[0000.510] I> tos binary init read from storage
[0000.514] I> ape: Authentication Finalize Done
[0000.519] I> oem authentication of tos header done
[0000.523] I> tos binary done read from storage
[0000.527] I> tos: Authentication init Done
[0000.531] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.537] I> bpmp-fw-dtb binary init read from storage
[0000.542] I> tos: Authentication Finalize Done
[0000.548] I> oem authentication of bpmp-fw-dtb header done
[0000.555] I> bpmp-fw-dtb binary done read from storage
[0000.557] I> bpmp-fw-dtb: Authentication init Done
[0000.562] I> parsing oem signed section of cpubl-dtb header done
[0000.567] I> cpubl-dtb binary init read from storage
[0000.572] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.609] I> oem authentication of cpubl-dtb header done
[0000.610] I> cpubl-dtb binary done read from storage
[0000.611] I> cpubl-dtb: Authentication init Done
[0000.612] I> parsing oem signed section of eks header done
[0000.613] I> eks binary init read from storage
[0000.614] I> cpubl-dtb: Authentication Finalize Done
[0000.614] I> oem authentication of eks header done
[0000.618] I> eks binary done read from storage
[0000.622] I> eks: Authentication init Done
[0000.626] I> eks: Authentication Finalize Done
[0000.630] I> EKB detected (length: 0x410) @ VA:0x5270a400
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
��[0001.135] I> Cboot Version: t194-18fdfe28
[0001.135] I> CPU-BL Params @ 0xf2820000
[0001.139] I>  1) Base:0xf1100000 Size:0x00100000
[0001.148] I>  3) Base:0xf1200000 Size:0x00200000
[0001.157] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.161] I>  6) Base:0xf3800000 Size:0x00400000
[0001.165] I>  7) Base:0xf1c00000 Size:0x00400000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
��[0001.170] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.275] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.284] I> 11) Base:0x40000000 Size:0x00040000
[0001.293] I> 13) Base:0x40046000 Size:0x00002000
[0001.297] I> 14) Base:0x40048000 Size:0x00002000
[0001.302] I> 15) Base:0xac000000 Size:0x00004000
[0001.306] I> 16) Base:0x4004a000 Size:0x00002000��emc_debugfs initialized
��fmon_debugfs initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ��[0001.315] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.370] I> 19) Base:0xf2200000 Size:0x00600000
[0001.379] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.388] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.397] I> 25) Base:0x40050000 Size:0x00002000
[0001.406] I> 27) Base:0xf1800000 Size:0x00400000
[0001.410] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.415] I> 29) Base:0xf1400000 Size:0x00400000
[0001.419] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.424] I> 31) Base:0x00000000 Size:0x00000000
[0001.428] I> 32) Base:0xf8000000 Size:0x08000000
[0001.433] I> 33) Base:0x00000000 Size:0x00000000
[0001.437] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.442] I> 35) Base:0xab000000 Size:0x01000000
[0001.446] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.451] I> 37) Base:0xf2800000 Size:0x00800000
[0001.455] I> 38) Base:0x80000000 Size:0x20000000
[0001.464] I> 40) Base:0x00000000 Size:0x00000000
[0001.468] I> 41) Base:0x00000000 Size:0x00000000
[0001.473] I> 42) Base:0x00000000 Size:0x00000000
[0001.477] I> 43) Base:0x00000000 Size:0x00000000
[0001.482] I> 44) Base:0x00000000 Size:0x00000000
[0001.486] I> 45) Base:0x00000000 Size:0x00000000
[0001.491] GIC-SPI Target CPU: 0
[0001.494] Interrupts Init done
[0001.497] calling constructors
[0001.502] I> Heap: [0xa06905a8 ... 0xab000000]
[0001.506] initializing threads
[0001.509] initializing timers
[0001.512] creating bootstrap completion thread
[0001.516] top of bootstrap2()
[0001.519] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.524] initializing platform
[0001.527] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.532] W> device prod register failed
[0001.536] I> Bl_dtb @0xaaf00000
[0001.548] W> "connection" doesn't exist, creating
[0001.552] W> "configs" doesn't exist, creating
[0001.590] I> Device at /i2c@3160000:0x50
[0001.591] I> Reading eeprom i2c=0 address=0x56
[0001.615] I> Device at /i2c@3160000:0x56
[0001.617] I> Find /i2c@3180000's alias i2c2
[0001.619] E> I2C: slave not found in slaves.
[0001.621] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.629] E> eeprom: Failed to read I2C slave device
[0001.634] I> Eeprom read failed 0x3526070d
[0001.638] I> Reading eeprom i2c=2 address=0x57
[0001.642] E> I2C: slave not found in slaves.
[0001.646] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.654] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.660] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.669] E> eeprom: Failed to read I2C slave device
[0001.674] I> Eeprom read failed 0x3526070d
[0001.678] I> Reading eeprom i2c=2 address=0x52
[0001.682] E> I2C: slave not found in slaves.
[0001.686] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.694] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.700] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.709] E> eeprom: Failed to read I2C slave device
[0001.714] I> Eeprom read failed 0x3526070d
[0001.719] I> Find /i2c@c240000's alias i2c1
[0001.722] I> Reading eeprom i2c=1 address=0x52
[0001.728] E> I2C: slave not found in slaves.
[0001.730] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.738] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.744] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.753] E> eeprom: Retry to read I2C slave device.
[0001.758] E> I2C: slave not found in slaves.
[0001.762] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.770] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.776] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.785] E> eeprom: Failed to read I2C slave device
[0001.790] I> Eeprom read failed 0x3526070d
[0001.794] I> Reading eeprom i2c=1 address=0x50
[0001.798] E> I2C: slave not found in slaves.
[0001.802] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.810] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.816] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.825] E> eeprom: Retry to read I2C slave device.
[0001.830] E> I2C: slave not found in slaves.
[0001.834] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.842] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.848] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.857] E> eeprom: Failed to read I2C slave device
[0001.862] I> Eeprom read failed 0x3526070d
[0001.866] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0001.871] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.882] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.887] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.898] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.906] W> "i2c@3160000" doesn't exist, creating
[0001.910] W> "module@0x50" doesn't exist, creating
[0001.915] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.922] W> "module@0x56" doesn't exist, creating
[0001.930] W> "chip-id" doesn't exist, creating
[0001.934] I> Adding plugin-manager/chip-id/A02P
[0001.939] I> Plugin-manager override starting
[0001.944] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.951] I> node /plugin-manager/fragement-soft-wdt matches
[0001.980] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.994] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.016] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.022] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.030] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.038] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.044] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.052] I> fixed regulator driver initialized
[0002.065] I> virtual i2c enabled
[0002.066] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.073] I> Boot-device: eMMC
[0002.076] I> Boot_device: SDMMC_BOOT instance: 3
[0002.084] I> sdmmc-3 params source = boot args
[0002.085] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.101] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.106] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.117] I> sdmmc bdev is already initialized
[0002.121] I> sdmmc-3 params source = boot args
[0002.164] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.182] W> set volts not configured for 'vdd-1v0'
[0002.184] W> set volts not configured for 'vdd-1v8-hs'
[0002.188] E> invalid display type
[0002.192] E> invalid display type
[0002.193] E> cannot find any other nvdisp nodes
[0002.209] I> edid read success
[0002.221] I> edid read success
[0002.221] I> width = 640, height = 480, frequency = 25174825
[0002.222] I> width = 640, height = 480, frequency = 25174825
[0002.223] I> width = 640, height = 480, frequency = 25174825
[0002.223] I> width = 3840, height = 2160, frequency = 533250000
[0002.227] I> width = 3840, height = 2160, frequency = 262750000
[0002.233] I> width = 1920, height = 1080, frequency = 148351648
[0002.238] I> width = 1280, height = 720, frequency = 74175824
[0002.244] I> width = 720, height = 480, frequency = 26973026
[0002.249] I> width = 1920, height = 1080, frequency = 148351648
[0002.255] I> width = 1280, height = 720, frequency = 74175824
[0002.261] I> width = 640, height = 480, frequency = 25174825
[0002.266] I> width = 720, height = 576, frequency = 26973026
[0002.272] I> width = 3840, height = 2160, frequency = 296703296
[0002.278] I> width = 3840, height = 2160, frequency = 593406593
[0002.283] I> width = 3840, height = 2160, frequency = 296703296
[0002.289] I> width = 3840, height = 2160, frequency = 296703296
[0002.295] I> width = 3840, height = 2160, frequency = 296703296
[0002.301] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.311] I> hdmi_enable, starting HDMI initialisation
[0002.316] I> hdmi_enable, HDMI initialisation complete
[0002.326] I> Load in CBoot Boot Options partition and parse it
[0002.332] E> Error -9 when finding node with path /boot-configuration
[0002.333] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.336] I> Hit any key to stop autoboot:	4	3	2	1
[0004.344] initializing target
[0004.344] calling apps_init()
[0004.345] starting app kernel_boot_app
[0004.364] I> found decompressor handler: lz4-legacy
[0004.365] I> decompressing BMP blob ...
[0004.369] I> Loading kernel-bootctrl from partition
[0004.369] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.376] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.376] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.377] I> ########## SD boot ##########
[0004.381] I> Found sdcard
[0004.385] I> enabling 'vdd-sdmmc1-sw' regulator
[0004.392] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.419] I> sdmmc SDR mode
[0004.442] I> Found 11 partitions in SDCARD (instance 0)
[0004.443] I> Fallback: assuming 0th partition is boot partition
[0004.443] I> Detect filesystem
[0004.448] I> Loading kernel ...
[0009.904] I> Loading kernel-dtb ...
[0009.944] I> Validate kernel ...
[0009.944] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.336] I> Validate kernel-dtb ...
[0010.336] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.339] I> Checking boot.img header magic ... [0010.339] I> [OK]
[0010.340] I> Kernel hdr @0xa4ac0000
[0010.340] I> Kernel dtb @0x90000000
[0010.340] I> decompressor handler not found
[0010.340] I> Copying kernel image (34330632 bytes) from 0xa4ac0800 to 0x80080000 ... [0010.353] I> Done
[0010.353] I> Move ramdisk (len: 5565615) from 0xa6b7e800 to 0x91000000
[0010.355] I> Updated bpmp info to DTB
[0010.357] I> Ramdisk: Base: 0x91000000; Size: 0x54ecaf
[0010.362] I> Updated initrd info to DTB
[0010.365] W> WARN: Fail to override "console=none" in commandline
[0010.371] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.379] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.386] W> No valid slot number is found in scratch register
[0010.392] W> Return default slot: _a
[0010.395] I> Active slot suffix:
[0010.398] I> add_boot_slot_suffix: slot_suffix =
[0010.403] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0010.442] I> Updated bootarg info to DTB
[0010.446] W> MAC addr invalid!
[0010.449] E> Failed to get WIFI MAC address
[0010.453] W> MAC addr invalid!
[0010.456] E> Failed to get Bluetooth MAC address
[0010.460] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:18:58:18
[0010.467] W> "plugin-manager" doesn't exist, creating
[0010.471] I> Adding /chosen/plugin-manager/cvm
[0010.475] W> "chip-id" doesn't exist, creating
[0010.480] I> Adding /chosen/plugin-manager/chip-id
[0010.484] W> "configs" doesn't exist, creating
[0010.489] I> Adding /chosen/plugin-manager/configs
[0010.493] W> "ids" doesn't exist, creating
[0010.497] I> Adding /chosen/plugin-manager/ids
[0010.502] W> "odm-data" doesn't exist, creating
[0010.506] I> Adding /chosen/plugin-manager/odm-data
[0010.513] W> "memory" doesn't exist, creating
[0010.515] I> [0] START: 0x80000000, END: 0xac000000
[0010.520] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.524] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.529] I> dram_block larger than 80000000
[0010.533] I> [3] START: 0x100000000, END: 0x880000000
[0010.538] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.544] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.550] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.557] I> Updated memory info to DTB
[0010.560] E> add_disp_param: failed to get display params for du=1
[0010.566] W> "reset" doesn't exist, creating
[0010.570] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.574] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.579] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.584] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.588] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.593] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.598] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.603] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.608] W> "misc-data" doesn't exist, creating
[0010.612] I> Boot-device: eMMC
[0010.615] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.620] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.625] W> Unknown storage device
[0010.629] I> Add serial number:1422620012453 as DT property
[0010.635] I> Plugin-manager override starting
[0010.638] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.645] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.653] I> Disable plugin-manager status in FDT
[0010.654] I> Plugin-manager override finished successfully
[0010.659] I> tegrabl_load_kernel_and_dtb: Done
[0010.682] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.008842] Console: colour dummy device 80x25
[    0.012697] console [tty0] enabled
[    0.015875] bootconsole [tegra_comb_uart0] disabled
[0000.136] I> Temperature = 28000
[0000.166] I> Boot-device: eMMC
#���main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.341] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-2dfe4beb)
[0000.375] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.416] I> bpmp-fw: Authentication init Done
[0000.435] I> oem authentication of cpubl header done
[0000.444] I> cpubl: Authentication init Done
[0000.461] I> cpubl: Authentication Finalize Done
[0000.479] I> parsing oem signed section of ape header done
[0000.613] I> parsing oem signed section of eks header done
[0000.615] I> oem authentication of eks header done
[0000.631] I> EKB detected (length: 0x410) @ VA:0x5270a400
NOTICE:  BL31: Built : 21:14:52, Jun 25 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing .......
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.148] I>  3) Base:0xf1200000 Size:0x00200000��clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
[0001.253] I>  4) Base:0xf1000000 Size:0x00100000
[0001.257] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.266] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.288] I> 12) Base:0xf0c00000 Size:0x00100000��emc_debugfs initialized
dvs_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0001.343] I> 13) Base:0x40046000 Size:0x00002000
[0001.348] I> 14) Base:0x40048000 Size:0x00002000
[0001.352] I> 15) Base:0xac000000 Size:0x00004000
[0001.361] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.561] I> Find /i2c@3160000's alias i2c0
[0001.562] I> Reading eeprom i2c=0 address=0x50
[0001.618] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.619] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.928] I> Adding plugin-manager/cvm
[0001.967] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.981] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.061] I> register 'maxim' power off handle
[0002.062] I> virtual i2c enabled
[0002.062] I> registered 'maxim,max20024' pmic
[0002.173] I> enabling 'vdd-hdmi-5v0' regulator
[0002.178] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.178] I> hdmi cable connected
[0002.180] W> set volts not configured for 'vdd-1v0'
[0002.182] W> set volts not configured for 'vdd-1v8-hs'
[0002.186] E> invalid display type
[0002.190] E> invalid display type
[0002.191] E> cannot find any other nvdisp nodes
[0002.206] I> edid read success
[0002.219] I> edid read success
[0002.219] I> width = 640, height = 480, frequency = 25174825
[0002.220] I> width = 640, height = 480, frequency = 25174825
[0002.221] I> width = 3840, height = 2160, frequency = 533250000
[0002.224] I> width = 3840, height = 2160, frequency = 262750000
[0002.230] I> width = 1920, height = 1080, frequency = 148351648
[0002.236] I> width = 1280, height = 720, frequency = 74175824
[0002.242] I> width = 720, height = 480, frequency = 26973026
[0002.247] I> width = 1920, height = 1080, frequency = 148351648
[0002.253] I> width = 1280, height = 720, frequency = 74175824
[0002.258] I> width = 640, height = 480, frequency = 25174825
[0002.264] I> width = 720, height = 576, frequency = 26973026
[0002.269] I> width = 3840, height = 2160, frequency = 296703296
[0002.275] I> width = 3840, height = 2160, frequency = 593406593
[0002.281] I> width = 3840, height = 2160, frequency = 296703296
[0002.287] I> width = 3840, height = 2160, frequency = 296703296
[0002.293] I> width = 3840, height = 2160, frequency = 296703296
[0002.298] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.308] I> hdmi_enable, starting HDMI initialisation
[0002.313] I> hdmi_enable, HDMI initialisation complete
[0002.324] I> Load in CBoot Boot Options partition and parse it
[0002.330] E> Error -9 when finding node with path /boot-configuration
[0002.331] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.334] I> Hit any key to stop autoboot:	4	3	2	1
[0004.341] initializing target
[0004.341] calling apps_init()
[0004.342] starting app kernel_boot_app
[0004.361] I> found decompressor handler: lz4-legacy
[0004.362] I> decompressing BMP blob ...
[0004.365] I> Kernel type = Normal
[0004.366] I> Loading kernel-bootctrl from partition
[0004.366] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.373] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.373] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.374] I> ########## SD boot ##########
[0004.378] I> Found sdcard
[0004.382] I> enabling 'vdd-sdmmc1-sw' regulator
[0004.388] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.416] I> sdmmc SDR mode
[0004.430] I> -0 params source =
[0004.439] I> Found 11 partitions in SDCARD (instance 0)
[0004.439] I> Look for boot partition
[0004.440] I> Fallback: assuming 0th partition is boot partition
[0004.440] I> Detect filesystem
[0004.444] I> fs_detect:173: Unsupported or no filesystem present
[0004.445] I> Loading kernel ...
[0009.901] I> Loading kernel-dtb ...
[0009.941] I> Validate kernel ...
[0009.941] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.332] I> Validate kernel-dtb ...
[0010.332] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.336] I> Checking boot.img header magic ... [0010.336] I> [OK]
[0010.336] I> Kernel hdr @0xa4ac0000
[0010.336] I> Kernel dtb @0x90000000
[0010.337] I> decompressor handler not found
[0010.337] I> Copying kernel image (34330632 bytes) from 0xa4ac0800 to 0x80080000 ... [0010.349] I> Done
[0010.349] I> Move ramdisk (len: 5565615) from 0xa6b7e800 to 0x91000000
[0010.352] I> Updated bpmp info to DTB
[0010.354] I> Ramdisk: Base: 0x91000000; Size: 0x54ecaf
[0010.358] I> Updated initrd info to DTB
[0010.362] W> WARN: Fail to override "console=none" in commandline
[0010.368] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.375] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.382] W> No valid slot number is found in scratch register
[0010.388] W> Return default slot: _a
[0010.391] I> Active slot suffix:
[0010.395] I> add_boot_slot_suffix: slot_suffix =
[0010.399] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0010.439] I> Updated bootarg info to DTB
[0010.442] W> MAC addr invalid!
[0010.445] E> Failed to get WIFI MAC address
[0010.449] W> MAC addr invalid!
[0010.452] E> Failed to get Bluetooth MAC address
[0010.457] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:18:58:18
[0010.463] W> "plugin-manager" doesn't exist, creating
[0010.468] I> Adding /chosen/plugin-manager/cvm
[0010.472] W> "chip-id" doesn't exist, creating
[0010.476] I> Adding /chosen/plugin-manager/chip-id
[0010.481] W> "configs" doesn't exist, creating
[0010.485] I> Adding /chosen/plugin-manager/configs
[0010.490] W> "ids" doesn't exist, creating
[0010.494] I> Adding /chosen/plugin-manager/ids
[0010.498] W> "odm-data" doesn't exist, creating
[0010.502] I> Adding /chosen/plugin-manager/odm-data
[0010.509] W> "memory" doesn't exist, creating
[0010.511] I> [0] START: 0x80000000, END: 0xac000000
[0010.516] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.521] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.525] I> dram_block larger than 80000000
[0010.529] I> [3] START: 0x100000000, END: 0x880000000
[0010.534] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.540] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.546] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.553] I> Updated memory info to DTB
[0010.556] E> add_disp_param: failed to get display params for du=1
[0010.562] W> "reset" doesn't exist, creating
[0010.566] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.571] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.575] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.580] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.585] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.590] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.594] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.599] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.604] W> "misc-data" doesn't exist, creating
[0010.608] I> Boot-device: eMMC
[0010.611] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.616] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.622] W> Unknown storage device
[0010.625] I> Add serial number:1422620012453 as DT property
[0010.631] I> Plugin-manager override starting
[0010.635] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.642] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.649] I> Disable plugin-manager status in FDT
[0010.651] I> Plugin-manager override finished successfully
[0010.656] I> tegrabl_load_kernel_and_dtb: Done
[0010.678] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3357) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:22:12 PDT 2020
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  780000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] Found tegra_fbmem: 00800000@a069c000
[    0.000000] Found lut_mem: 00002008@a0697000
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc7ffcd0000 s61656 r8192 d32552 u102400
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8192013
[    0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29172(89%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.000000] Memory: 31917716K/33288180K available (15294K kernel code, 2934K rwdata, 6640K rodata, 8576K init, 609K bss, 616800K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009600000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009600000 - 0xffffff8009e60000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e60000 - 0xffffff800a13d808   (  2935 KB)
[    0.000000]        .bss : 0xffffff800a13d808 - 0xffffff800a1d5f7c   (   610 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf20000000   (   512 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc800000000   ( 32768 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.008704] Console: colour dummy device 80x25
[    0.012180] console [tty0] enabled
[    0.015876] bootconsole [tegra_comb_uart0] disabled
Rebooting system ...
[0000.055] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.063] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.069] I> Boot-mode: Coldboot
[0000.071] I> Chip revision : A02P
[0000.075] I> Bootrom patch version : 15 (correctly patched)
[0000.080] I> ATE fuse revision : 0x200
[0000.083] I> Ram repair fuse : 0x0
[0000.086] I> Ram Code : 0x2
[0000.089] I> rst_source : 0xb
[0000.091] I> rst_level : 0x1
[0000.095] I> Boot-device: eMMC
[0000.110] I> sdmmc DDR50 mode
[0000.114] W> No valid slot number is found in scratch register
[0000.120] W> Return default slot: _a
[0000.123] I> Active Boot chain : 0
[0000.126] I> Boot-device: eMMC
[0000.130] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.136] I> Temperature = 28500
[0000.139] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.143] W> Skipping boost for clk: BPMP_APB
[0000.147] W> Skipping boost for clk: AXI_CBB
[0000.151] W> Skipping boost for clk: AON_CPU_NIC
[0000.156] W> Skipping boost for clk: CAN1
[0000.159] W> Skipping boost for clk: CAN2
[0000.164] I> Boot-device: eMMC
[0000.176] I> Sdmmc: HS400 mode enabled
[0000.180] I> ECC region[0]: Start:0x0, End:0x0
[0000.184] I> ECC region[1]: Start:0x0, End:0x0
[0000.189] I> ECC region[2]: Start:0x0, End:0x0
[0000.193] I> ECC region[3]: Start:0x0, End:0x0
[0000.197] I> ECC region[4]: Start:0x0, End:0x0
[0000.201] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.207] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.211] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.216] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.220] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.225] E> FAILED: Thermal config
[0000.233] E> FAILED: MEMIO rail config
[0000.252] I> Boot-device: eMMC
[0000.261] I> sdmmc bdev is already initialized
#���main enter
HW Function test
Start Scheduler.
in late init
[0000.449] I> parsing oem signed section of rce header done
Try booting without any SD card. I wonder if perhaps it is having trouble finding the correct rootfs and extlinux.conf due to the SD.
HAHAHAHA!!! Where is the face palm emoji - for some reason I thought the OS was on the SD card.
I am running the NVIDIA XAVIER AGX.
Removed the SD Card, booted again, and Voila! I can login now and finish sdkmanager.
Thanks for your patience!
On some Jetsons the o/s is on the SD card. If you looked at the documents for one of the SD card models, then this would indeed be required. The reason the SD card was something I saw as significant is because no Xavier is sold without eMMC. One would possibly and purposely program it to put the rootfs on SD, but this would be the exception, and not the common use case.
Embarrassingly so, but this also alleviates one of my concerns. I would hope to not run from the sdcard, but would prefer to use emmc.
Glad you resolved the issue.
But what I am concerning is sdcard should not cause such problem. It sounds like an bug to me.
Actually, part of kernel log is get hidden because we turned off part of kernel log there.
Please go to Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf and remove the “quiet” inside this file.
Then, reflash the board and share us the log again.
It should print out something after bootconsole disabled line.
