Xavier nx blocked in kernel boot
I have a Jetson Xavier NX that gets stuck during the boot process on JetPack 4.6.4 (L4T32.7.4). I would like to understand what is happening without having to reflash the board.
Currently, the kernel is in quiet mode, so I don’t have many debug logs available. Do you have any suggestions on how I can diagnose why the boot process is getting stuck without resorting to a reflash? I understand that reflashing might potentially solve the problem, but I would prefer to understand the underlying issue.
Here are the logs:
[0000.808] I> sdmmc DDR50 mode
[0000.819] I> sdmmc-3 params source = safe params
[0000.824] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.841] W> Cannot find any partition table for 00000003
[0000.857] I> Found 14 partitions in SDMMC_USER (instance 3)
[0000.858] I> Active Boot chain : 0
[0000.859] I> parsing oem signed section of bpmp-fw header done
[0000.860] I> bpmp-fw binary init read from storage
[0000.861] I> oem authentication of bpmp-fw header done
[0000.873] I> bpmp-fw binary done read from storage
[0000.874] I> bpmp-fw: Authentication init Done
[0000.875] I> parsing oem signed section of cpubl header done
[0000.875] I> cpubl binary init read from storage
[0000.876] I> bpmp-fw: Authentication Finalize Done
[0000.880] I> oem authentication of cpubl header done
[0000.888] I> cpubl binary done read from storage
[0000.889] I> cpubl: Authentication init Done
[0000.893] I> parsing oem signed section of rce header done
[0000.898] I> rce binary init read from storage
[0000.903] I> Relocating BR-BCT
[0000.906] I> cpubl: Authentication Finalize Done
[0000.910] I> oem authentication of rce header done
[0000.915] I> rce binary done read from storage
[0000.919] I> rce: Authentication init Done
[0000.923] I> parsing oem signed section of ape header done
[0000.928] I> ape binary init read from storage
[0000.932] I> rce: Authentication Finalize Done
[0000.937] I> oem authentication of ape header done
[0000.941] I> ape binary done read from storage
[0000.946] I> ape: Authentication init Done
[0000.950] I> parsing oem signed section of tos header done
[0000.955] I> tos binary init read from storage
[0000.959] I> ape: Authentication Finalize Done
[0000.964] I> oem authentication of tos header done
[0000.970] I> tos binary done read from storage
[0000.972] I> tos: Authentication init Done
[0000.977] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.982] I> bpmp-fw-dtb binary init read from storage
[0000.987] I> tos: Authentication Finalize Done
[0000.993] I> oem authentication of bpmp-fw-dtb header done
[0000.997] I> bpmp-fw-dtb binary done read from storage
[0001.002] I> bpmp-fw-dtb: Authentication init Done
[0001.007] I> parsing oem signed section of cpubl-dtb header done
[0001.013] I> cpubl-dtb binary init read from storage
[0001.017] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.022] I> found decompressor handler: lz4
[0001.278] I> oem authentication of cpubl-dtb header done
[0001.279] I> cpubl-dtb binary done read from storage
[0001.280] I> cpubl-dtb: Authentication init Done
[0001.281] I> parsing oem signed section of eks header done
[0001.281] I> eks binary init read from storage
[0001.282] I> cpubl-dtb: Authentication Finalize Done
[0001.283] I> oem authentication of eks header done
[0001.287] I> eks binary done read from storage
[0001.291] I> eks: Authentication init Done
[0001.295] I> eks: Authentication Finalize Done
[0001.299] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE:  BL31: v1.3(release):f9bf1e1
NOTICE:  BL31: Built : 21:07:06, Jun  8 2023
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing .......
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
  [0001.657] I> Welcome to Cboot
��mrq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.658] I> Cboot Version: t194-79eb810b
[0001.660] I> CPU-BL Params @ 0xf2820000
[0001.663] I>  0) Base:0x00000000 Size:0x00000000
[0001.668] I>  1) Base:0xf1100000 Size:0x00100000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.672] I>  2) Base:0xf2000000 Size:0x00200000
[0001.827] I>  3) Base:0xf1200000 Size:0x00200000
[0001.831] I>  4) Base:0xf1000000 Size:0x00100000
[0001.835] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.840] I>  6) Base:0xf3800000 Size:0x00400000
[0001.844] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.849] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.853] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.858] I> 10) Base:0xf3000000 Size:0x00800000
[0001.862] I> 11) Base:0x40000000 Size:0x00040000
[0001.867] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.871] I> 13) Base:0x40046000 Size:0x00002000
[0001.876] I> 14) Base:0x40048000 Size:0x00002000
[0001.880] I> 15) Base:0xac000000 Size:0x00004000
[0001.885] I> 16) Base:0x4004a000 Size:0x00002000
[0001.889] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.893] I> 18) Base:0x4004c000 Size:0x00002000
[0001.898] I> 19) Base:0xf2200000 Size:0x00600000
[0001.902] I> 20) Base:0x4004e000 Size:0x00002000
[0001.907] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.911] I> 22) Base:0x00000000 Size:0x00000000
[0001.916] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.920] I> 24) Base:0xf6000000 Size:0x02000000
[0001.925] I> 25) Base:0x40050000 Size:0x00002000
[0001.929] I> 26) Base:0x40040000 Size:0x00006000
[0001.934] I> 27) Base:0xf1800000 Size:0x00400000
[0001.938] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.943] I> 29) Base:0xf1400000 Size:0x00400000
[0001.947] I> 30) Base:0x00000000 Size:0x00000000
[0001.951] I> 31) Base:0x00000000 Size:0x00000000
[0001.956] I> 32) Base:0xf8000000 Size:0x08000000
[0001.960] I> 33) Base:0x00000000 Size:0x00000000
[0001.965] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.969] I> 35) Base:0xab000000 Size:0x01000000
[0001.974] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.978] I> 37) Base:0xf2800000 Size:0x00800000
[0001.983] I> 38) Base:0x80000000 Size:0x20000000
[0001.987] I> 39) Base:0xb0000000 Size:0x08000000
[0001.992] I> 40) Base:0x00000000 Size:0x00000000
[0001.996] I> 41) Base:0x00000000 Size:0x00000000
[0002.001] I> 42) Base:0x00000000 Size:0x00000000
[0002.005] I> 43) Base:0x00000000 Size:0x00000000
[0002.009] I> 44) Base:0x00000000 Size:0x00000000
[0002.014] I> 45) Base:0x00000000 Size:0x00000000
[0002.018] GIC-SPI Target CPU: 0
[0002.021] Interrupts Init done
[0002.024] calling constructors
[0002.027] initializing heap
[0002.030] I> Heap: [0xa069ee08 ... 0xab000000]
[0002.034] initializing threads
[0002.037] initializing timers
[0002.040] creating bootstrap completion thread
[0002.044] top of bootstrap2()
[0002.047] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0002.051] initializing platform
[0002.054] W> device prod register failed
[0002.058] I> Bl_dtb @0xaaf00000
[0002.063] W> "plugin-manager" doesn't exist, creating
[0002.066] W> "ids" doesn't exist, creating
[0002.070] W> "connection" doesn't exist, creating
[0002.075] W> "configs" doesn't exist, creating
[0002.086] E> failed to read label property for node 149972: 13
[0002.088] E> failed to read reg property for node 150036: 13
[0002.091] E> failed to read reg property for node 150088: 13
[0002.097] E> failed to read reg property for node 150172: 13
[0002.103] I> Find /i2c@3160000's alias i2c0
[0002.105] I> Reading eeprom i2c=0 address=0x50
[0002.135] I> Device at /i2c@3160000:0x50
[0002.135] I> Reading eeprom i2c=0 address=0x57
[0002.136] E> I2C: slave not found in slaves.
[0002.136] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.137] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.137] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0002.145] E> eeprom: Failed to read I2C slave device
[0002.150] I> Eeprom read failed 0x3526070d
[0002.155] I> Find /i2c@c240000's alias i2c1
[0002.158] I> Reading eeprom i2c=1 address=0x50
[0002.163] E> I2C: slave not found in slaves.
[0002.166] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.174] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.179] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.189] E> eeprom: Retry to read I2C slave device.
[0002.194] E> I2C: slave not found in slaves.
[0002.198] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.206] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.211] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.221] E> eeprom: Failed to read I2C slave device
[0002.226] I> Eeprom read failed 0x3526070d
[0002.229] I> create_pm_ids: id: 3668-0001-301-L, len: 15
[0002.235] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.246] I> Adding plugin-manager/ids/3668-0001-301=/i2c@3160000:module@0x50
[0002.253] W> "i2c@3160000" doesn't exist, creating
[0002.257] W> "module@0x50" doesn't exist, creating
[0002.263] I> Adding plugin-manager/cvm
[0002.266] W> "chip-id" doesn't exist, creating
[0002.270] I> Adding plugin-manager/chip-id/A02P
[0002.274] I> Plugin-manager override starting
[0002.282] I> Disable plugin-manager status in FDT
[0002.283] I> Plugin-manager override finished successfully
[0002.288] I> gpio framework initialized
[0002.294] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.300] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.307] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.314] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.322] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.329] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.335] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.342] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.350] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.357] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.364] I> fixed regulator driver initialized
[0002.370] I> register 'maxim' power off handle
[0002.372] I> virtual i2c enabled
[0002.374] I> registered 'maxim,max20024' pmic
[0002.379] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.385] I> Boot-device: QSPI
[0002.388] I> Boot_device: QSPI_FLASH instance: 0
[0002.393] I> QSPI source rate = 204000 Khz
[0002.397] I> Requested rate for QSPI clock = 34000 Khz
[0002.402] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.407] I> QSPI Flash Size = 32 MB
[0002.414] I> Qspi initialized successfully
[0002.415] I> qspi flash-0 params source = boot args
[0002.418] I> create_pm_ids: id: 3668-0001-301-L, len: 15
[0002.424] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.439] I> sdmmc-3 params source = safe params
[0002.441] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.461] W> Cannot find any partition table for 00000003
[0002.473] I> Found 14 partitions in SDMMC_USER (instance 3)
[0002.477] E> cannot find any other nvdisp nodes
[0002.477] E> no valid display unit config found in dtb
[0002.478] W> display init failed
[0002.478] I> Load in CBoot Boot Options partition and parse it
[0002.479] E> Error -9 when finding node with path /boot-configuration
[0002.480] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.487] I> Using default boot order
[0002.490] I> boot-dev-order :-
[0002.493] I> 1.sd
[0002.495] I> 2.usb
[0002.497] I> 3.nvme
[0002.499] I> 4.emmc
[0002.501] I> 5.net
[0002.502] I> Hit any key to stop autoboot:	4	3	2	1
[0004.510] initializing target
[0004.510] calling apps_init()
[0004.511] starting app kernel_boot_app
[0004.522] I> found decompressor handler: lz4-legacy
[0004.522] I> decompressing BMP blob ...
[0004.590] I> Kernel type = Normal
[0004.590] I> ########## SD (0) boot ##########
[0004.591] I> No sdcard
[0004.591] I> sdcard-0 params source = DT-BL
[0004.591] E> Blockdev open: exit error
[0004.592] E> SD boot failed, err: 724238353
[0004.592] I> ########## USB (0) boot ##########
[0004.609] I> Validate XUSB-FW ...
[0004.609] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x30000
[0004.610] E> Stage2Signature validation failed with SHA2!!
[0004.610] C> OEM authentication of XUSB-FW header failed!
[0004.611] E> Failed to validate XUSB-FW binary (err=1077936152)
[0004.617] E> failed to initialize xhci controller
[0004.621] E> Error in init of XUSB host driver, err: 40400018
[0004.627] W> Failed to initialize device 5-0
[0004.631] E> USB boot failed, err: 1077936152
[0004.635] I> ########## NVME (0) boot ##########
[0004.640] I> Initializing nvme device instance 0
[0004.644] I> Initializing nvme controller
[0004.648] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0004.654] I> vpcie3v3-supply not found
[0004.658] I> vpcie12v-supply not found
[0004.662] W> Failed to get nvidia,plat-gpios
[0004.666] I> tegrabl_pcie_soc_preinit: (0):
[0004.670] I> Unpowergate
[0004.672] I> tegrabl_car_clk_disable(0) ...
[0004.676] I> tegrabl_car_rst_set(CORE, 0) ...
[0004.680] I> tegrabl_car_rst_set(APB, 0) ...
[0004.684] I> tegrabl_car_clk_enable(0) ...
[0004.688] I> tegrabl_car_rst_clear(APB, 0) ...
[0004.693] I> tegrabl_set_ctrl_state(0)
[0004.696] I> CLR PCIE_APB:6
[0004.699] I> tegrabl_pcie_soc_init: (0):
[0004.703] I> APPL initialization ...
[0004.706] I> poweron phys
[0004.709] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0004.715] I> tegrabl_power_on_phy: controller 0 not available
[0004.720] E> Failed to power on phy on controller-0
[0004.725] I> PCIe (0) Link is not UP
[0004.729] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0004.734] I> Failed to initialize SoC Host PCIe controller
[0004.739] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x1
[0004.745] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0004.752] W> Failed to open NVME-0, err = 80800601
[0004.756] W> Failed to initialize device 10-0
[0004.761] E> NVME (0) boot failed, err: 0x80800601
[0004.765] I> ########## NVME (1) boot ##########
[0004.770] I> Initializing nvme device instance 1
[0004.774] I> Initializing nvme controller
[0004.778] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0004.784] I> vpcie3v3-supply not found
[0004.788] I> vpcie12v-supply not found
[0004.792] W> Failed to get nvidia,plat-gpios
[0004.796] I> tegrabl_pcie_soc_preinit: (1):
[0004.800] I> Unpowergate
[0004.802] I> tegrabl_car_clk_disable(1) ...
[0004.806] I> tegrabl_car_rst_set(CORE, 1) ...
[0004.810] I> tegrabl_car_rst_set(APB, 1) ...
[0004.814] I> tegrabl_car_clk_enable(1) ...
[0004.818] I> tegrabl_car_rst_clear(APB, 1) ...
[0004.823] I> tegrabl_set_ctrl_state(1)
[0004.826] I> CLR PCIE_APB:6
[0004.829] I> tegrabl_pcie_soc_init: (1):
[0004.833] I> APPL initialization ...
[0004.836] I> poweron phys
[0004.839] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0004.845] I> tegrabl_power_on_phy: controller 1 not available
[0004.850] E> Failed to power on phy on controller-1
[0004.855] I> PCIe (1) Link is not UP
[0004.859] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0004.864] I> Failed to initialize SoC Host PCIe controller
[0004.869] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(1); error=0x1
[0004.875] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0004.882] W> Failed to open NVME-1, err = 80800601
[0004.886] W> Failed to initialize device 10-1
[0004.891] E> NVME (1) boot failed, err: 0x80800601
[0004.895] I> ########## NVME (2) boot ##########
[0004.900] I> Initializing nvme device instance 2
[0004.904] I> Initializing nvme controller
[0004.908] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0004.914] I> vpcie3v3-supply not found
[0004.918] I> vpcie12v-supply not found
[0004.922] W> Failed to get nvidia,plat-gpios
[0004.926] I> tegrabl_pcie_soc_preinit: (2):
[0004.930] I> Unpowergate
[0004.932] I> tegrabl_car_clk_disable(2) ...
[0004.936] I> tegrabl_car_rst_set(CORE, 2) ...
[0004.940] I> tegrabl_car_rst_set(APB, 2) ...
[0004.945] I> tegrabl_car_clk_enable(2) ...
[0004.948] I> tegrabl_car_rst_clear(APB, 2) ...
[0004.953] I> tegrabl_set_ctrl_state(2)
[0004.956] I> CLR PCIE_APB:6
[0004.959] I> tegrabl_pcie_soc_init: (2):
[0004.963] I> APPL initialization ...
[0004.966] I> poweron phys
[0004.969] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0004.975] I> tegrabl_power_on_phy: controller 2 not available
[0004.980] E> Failed to power on phy on controller-2
[0004.985] I> PCIe (2) Link is not UP
[0004.989] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0004.994] I> Failed to initialize SoC Host PCIe controller
[0004.999] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0005.005] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0005.012] W> Failed to open NVME-2, err = 80800601
[0005.016] W> Failed to initialize device 10-2
[0005.021] E> NVME (2) boot failed, err: 0x80800601
[0005.025] I> ########## NVME (3) boot ##########
[0005.030] I> Initializing nvme device instance 3
[0005.034] I> Initializing nvme controller
[0005.038] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0005.044] I> vpcie3v3-supply not found
[0005.048] I> vpcie12v-supply not found
[0005.052] W> Failed to get nvidia,plat-gpios
[0005.056] I> tegrabl_pcie_soc_preinit: (3):
[0005.060] I> Unpowergate
[0005.062] I> tegrabl_car_clk_disable(3) ...
[0005.066] I> tegrabl_car_rst_set(CORE, 3) ...
[0005.070] I> tegrabl_car_rst_set(APB, 3) ...
[0005.075] I> tegrabl_car_clk_enable(3) ...
[0005.078] I> tegrabl_car_rst_clear(APB, 3) ...
[0005.083] I> tegrabl_set_ctrl_state(3)
[0005.086] I> CLR PCIE_APB:6
[0005.089] I> tegrabl_pcie_soc_init: (3):
[0005.093] I> APPL initialization ...
[0005.096] I> poweron phys
[0005.099] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0005.105] I> tegrabl_power_on_phy: controller 3 not available
[0005.111] E> Failed to power on phy on controller-3
[0005.115] I> PCIe (3) Link is not UP
[0005.119] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0005.124] I> Failed to initialize SoC Host PCIe controller
[0005.129] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x1
[0005.135] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0005.142] W> Failed to open NVME-3, err = 80800601
[0005.146] W> Failed to initialize device 10-3
[0005.151] E> NVME (3) boot failed, err: 0x80800601
[0005.155] I> ########## NVME (4) boot ##########
[0005.160] I> Initializing nvme device instance 4
[0005.164] I> Initializing nvme controller
[0005.169] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0005.174] I> vpcie3v3-supply not found
[0005.178] I> vpcie12v-supply not found
[0005.182] W> Failed to get nvidia,plat-gpios
[0005.186] I> tegrabl_pcie_soc_preinit: (4):
[0005.190] I> Unpowergate
[0005.192] I> tegrabl_car_clk_disable(4) ...
[0005.196] I> tegrabl_car_rst_set(CORE, 4) ...
[0005.200] I> tegrabl_car_rst_set(APB, 4) ...
[0005.205] I> tegrabl_car_clk_enable(4) ...
[0005.208] I> tegrabl_car_rst_clear(APB, 4) ...
[0005.213] I> tegrabl_set_ctrl_state(4)
[0005.216] I> CLR PCIE_APB:6
[0005.219] I> tegrabl_pcie_soc_init: (4):
[0005.223] I> APPL initialization ...
[0005.226] I> poweron phys
[0005.229] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0005.235] I> tegrabl_power_on_phy: power on phy @0x3f40000
[0006.340] C> Failed to link up controller-4
[0006.341] I> PCIe (4) Link is not UP
[0006.341] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0006.342] I> Failed to initialize SoC Host PCIe controller
[0006.342] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x12
[0006.343] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0006.346] W> Failed to open NVME-4, err = 80800612
[0006.351] W> Failed to initialize device 10-4
[0006.355] E> NVME (4) boot failed, err: 0x80800612
[0006.360] I> ########## NVME (5) boot ##########
[0006.364] I> Initializing nvme device instance 5
[0006.369] I> Initializing nvme controller
[0006.373] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0006.379] I> vpcie3v3-supply not found
[0006.382] I> vpcie12v-supply not found
[0006.386] W> Failed to get nvidia,plat-gpios
[0006.390] I> tegrabl_pcie_soc_preinit: (5):
[0006.394] I> Unpowergate
[0006.397] I> tegrabl_car_clk_disable(5) ...
[0006.401] I> tegrabl_car_rst_set(CORE, 5) ...
[0006.405] I> tegrabl_car_rst_set(APB, 5) ...
[0006.409] I> tegrabl_car_clk_enable(5) ...
[0006.413] I> tegrabl_car_rst_clear(APB, 5) ...
[0006.417] I> tegrabl_set_ctrl_state(5)
[0006.421] I> CLR PCIE_APB:6
[0006.423] I> tegrabl_pcie_soc_init: (5):
[0006.427] I> APPL initialization ...
[0006.430] I> poweron phys
[0006.433] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0006.439] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0006.445] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0006.450] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0006.455] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0006.461] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0006.466] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0006.471] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0006.477] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0007.582] C> Failed to link up controller-5
[0007.582] I> PCIe (5) Link is not UP
[0007.583] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0007.583] I> Failed to initialize SoC Host PCIe controller
[0007.584] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0007.584] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0007.588] W> Failed to open NVME-5, err = 80800612
[0007.592] W> Failed to initialize device 10-5
[0007.597] E> NVME (5) boot failed, err: 0x80800612
[0007.601] I> ########## Fixed storage boot ##########
[0007.606] I> Loading kernel-bootctrl from partition
[0007.611] I> Loading partition kernel-bootctrl at 0xa4310000 from device(0x1)
[0007.625] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0007.626] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0007.632] I> Already published: 00010003
[0007.636] I> Look for boot partition
[0007.639] I> Fallback: assuming 0th partition is boot partition
[0007.645] I> Set 0th partition is boot partition
[0007.649] I> Detect filesystem
[0007.676] I> Loading extlinux.conf ...
[0007.677] I> Loading extlinux.conf binary from rootfs ...
[0007.677] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0007.720] I> Loading extlinux.conf sig file from rootfs ...
[0007.720] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf.sig
[0007.745] I> Validate extlinux.conf ...
[0007.745] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0007.746] I> Encryption fuse is not ON
[0007.746] I> L4T boot options
[0007.746] I> [1]: "primary kernel"
[0007.747] I> Enter choice:
[0010.748] I> Continuing with default option: 1
[0010.748] I> Loading kernel ...
[0010.748] I> Loading kernel binary from rootfs ...
[0010.749] I> rootfs path: /sdmmc_user/boot/Image
[0011.155] I> Loading kernel sig file from rootfs ...
[0011.156] I> rootfs path: /sdmmc_user/boot/Image.sig
[0011.174] I> overload load_size to 34707464 (from 34707472)
[0011.175] I> Validate kernel ...
[0011.175] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0011.491] I> Encryption fuse is not ON
[0011.500] I> Loading kernel-dtb ...
[0011.500] I> Loading kernel-dtb binary from rootfs ...
[0011.501] I> rootfs path: /sdmmc_user/boot/tegra194-p3668-all-p3509-0000.dtb
[0017.694] I> lookup_linear_dir:485: Invalid file block num
[0017.694] I> ext2_walk:142: 'tegra194-p3668-all-p3509-0000.dtb' lookup failed
[0017.695] I> ext4_open_file:704: '/boot/tegra194-p3668-all-p3509-0000.dtb' lookup failed
[0017.695] E> file /sdmmc_user/boot/tegra194-p3668-all-p3509-0000.dtb open failed!!
[0017.696] W> Failed to load kernel-dtb binary from rootfs (err=202113041)
[0017.703] I> Continue to load from partition ...
[0017.707] I> A/B: bin_type (38) slot 0
[0017.711] I> Loading kernel-dtb from partition
[0017.715] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0017.733] I> Validate kernel-dtb ...
[0017.733] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0017.735] I> Encryption fuse is not ON
[0017.736] I> Loading ramdisk from rootfs ...
[0017.740] I> Loading ramdisk binary from rootfs ...
[0017.745] I> rootfs path: /sdmmc_user/boot/initrd
[0017.845] I> Loading ramdisk sig file from rootfs ...
[0017.846] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0017.864] I> overload load_size to 7238484 (from 7238496)
[0017.865] I> Validate ramdisk ...
[0017.865] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0017.931] I> Encryption fuse is not ON
[0017.941] I> Kernel hdr @0xa4310000
[0017.942] I> Kernel dtb @0x90000000
[0017.942] I> decompressor handler not found
[0017.942] I> Copying kernel image (34707464 bytes) from 0xa4310000 to 0x80080000 ... [0017.948] I> Done
[0017.949] I> Updated bpmp info to DTB
[0017.950] I> Ramdisk: Base: 0x92000000; Size: 0x6e7354
[0017.950] I> Updated initrd info to DTB
[0017.951] W> WARN: Fail to override "console=none" in commandline
[0017.955] I> Active rootfs suffix:
[0017.958] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0017.965] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0017.972] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0017.980] I> Active slot suffix:
[0017.983] I> add_boot_slot_suffix: slot_suffix =
[0017.987] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0018.012] I> Updated bootarg info to DTB
[0018.016] W> MAC addr invalid!
[0018.018] E> Failed to get WIFI MAC address
[0018.022] W> MAC addr invalid!
[0018.025] E> Failed to get Bluetooth MAC address
[0018.030] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:88:61:9d
[0018.036] W> "plugin-manager" doesn't exist, creating
[0018.041] I> Adding /chosen/plugin-manager/cvm
[0018.045] W> "chip-id" doesn't exist, creating
[0018.049] I> Adding /chosen/plugin-manager/chip-id
[0018.054] W> "configs" doesn't exist, creating
[0018.058] I> Adding /chosen/plugin-manager/configs
[0018.063] W> "ids" doesn't exist, creating
[0018.067] I> Adding /chosen/plugin-manager/ids
[0018.071] W> "odm-data" doesn't exist, creating
[0018.076] I> Adding /chosen/plugin-manager/odm-data
[0018.082] W> "memory" doesn't exist, creating
[0018.085] I> [0] START: 0x80000000, END: 0xac000000
[0018.089] I> [1] START: 0xac004000, END: 0xf0ad0000
[0018.094] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0018.099] I> dram_block larger than 80000000
[0018.103] I> [3] START: 0x100000000, END: 0x280000000
[0018.108] I> added [base:0x80000000, size:0x2c000000] to /memory
[0018.113] I> added [base:0xac200000, size:0x44800000] to /memory
[0018.119] I> added [base:0x100000000, size:0x180000000] to /memory
[0018.126] I> Updated memory info to DTB
[0018.129] W> add_disp_param: failed to get display params for du=0
[0018.135] W> "reset" doesn't exist, creating
[0018.139] I> Adding ecid(00000001646e100218000000010102c0) to DT
[0018.145] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0018.150] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0018.154] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0018.159] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0018.164] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0018.169] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0018.173] I> Deleted cpu@6 node in DT
[0018.177] I> Deleted cpu@7 node in DT
[0018.181] I> Deleted cluster3 node in FDT
[0018.184] I> Update arm-pmu in FDT
[0018.187] I> - update property: interrupts
[0018.191] I> - update property: interrupt-affinity
[0018.197] W> "misc-data" doesn't exist, creating
[0018.201] I> Boot-device: QSPI
[0018.203] W> Unknown boot device
[0018.206] I> Add storage-qspi to plugin-manager/misc-data
[0018.212] W> Unknown storage device
[0018.215] I> Add serial number:1424123060764 as DT property
[0018.221] I> Plugin-manager override starting
[0018.226] I> Disable plugin-manager status in FDT
[0018.229] I> Plugin-manager override finished successfully
[0018.235] I> tegrabl_load_kernel_and_dtb: Done
[0018.239] W> tegrabl_display_clear: display is not initialized
[0018.245] W> Boot logo display failed...
[0018.248] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5418-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 8 21:09:35 PDT 2023
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44800000
[    0.000000] OF: fdt: - 100000000 ,  180000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
��WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
Best Regards,
It looks like a custom board.
How did you get into this situation?
Did this board work with 32.7.4 image before?
Incidentally, the big reason why it looks like a custom board is that it stops in the middle of loading a device tree (it looks like it loads the device tree then hits the “platform/drivers/pg/pg-gpu-t194.c” point…related to what the device tree told the driver there). Whenever non-plug-n-play hardware changes from the reference design of the dev kit carrier board the device tree also has to change. I could be wrong, but that’s what it looks like to me too…drivers halting upon receiving device tree data).
Yes the board works fine before
The device tree for your custom board works fine normaly and i also test to plug the Xavier nx on a éval kit and the résult is the same. Is there a way to know with driver is causing that ?
Are you able to answer this question?
Not realy as is was sent to a client, but as far as a know is was just running normal , and after a while the bug come.
The last thing we see:
That does not mean the driver associated with this is the issue. Warnings tend to not be a problem for completing boot, but you could investigate that file and line to see what is associated with the warning. We know it processed that, and we know the issue occurs after this; what we don’t know is if the very next think processed locks up the system, or if the next thing had no error and the one after it locked up. Odds are though that knowing what is in that file and the block of code the file refers to could offer a hint.
If you had another matching unit which does work, then you could get a similar serial console boot log and see what the working unit logs next. Compare.
I have another Log file when evrything is ok.
LOG_OK.txt (33.4 KB)
But as the kernel is on quiet mode i’m affraid that not evrything is log.
But i as you’re suggest i’ll check the next line of logs .
Thanks for your help.
The errors which show up after the old end of log are SPI. Do you have any SPI hardware attached? It isn’t a guarantee, but it seems very likely the issue is related to trying to communicate with the SPI device.
