After flashing the board with the real-time patch r32.5.1, it started normally for the first time, but when I executed
sudo apt update & & sudo apt upgrade
and restarted, it couldn’t start.
ᙰ000.368] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-7515048c)
[0000.369] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.370] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.370] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.376] W> device prod register failed
[0000.380] I> Boot-device: QSPI
[0000.383] I> Boot_device: QSPI_FLASH instance: 0
[0000.388] I> QSPI Flash Size = 32 MB
[0000.394] I> Qspi initialized successfully
[0000.395] I> qspi flash-0 params source = boot args
[0000.777] I> sdmmc DDR50 mode
[0000.779] I> sdmmc-3 params source = safe params
[0000.784] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.786] W> Cannot find any partition table for 00000003
[0000.790] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.791] I> Active Boot chain : 1
[0000.792] I> parsing oem signed section of bpmp-fw header done
[0000.793] I> bpmp-fw binary init read from storage
[0000.794] I> oem authentication of bpmp-fw header done
[0000.806] I> bpmp-fw binary done read from storage
[0000.807] I> bpmp-fw: Authentication init Done
[0000.808] I> parsing oem signed section of cpubl header done
[0000.809] I> cpubl binary init read from storage
[0000.813] I> bpmp-fw: Authentication Finalize Done
[0000.818] I> oem authentication of cpubl header done
[0000.825] I> cpubl binary done read from storage
[0000.827] I> cpubl: Authentication init Done
[0000.831] I> parsing oem signed section of rce header done
[0000.836] I> rce binary init read from storage
[0000.841] I> Relocating BR-BCT
[0000.844] I> cpubl: Authentication Finalize Done
[0000.848] I> oem authentication of rce header done
[0000.853] I> rce binary done read from storage
[0000.857] I> rce: Authentication init Done
[0000.861] I> parsing oem signed section of ape header done
[0000.866] I> ape binary init read from storage
[0000.870] I> rce: Authentication Finalize Done
[0000.875] I> oem authentication of ape header done
[0000.879] I> ape binary done read from storage
[0000.884] I> ape: Authentication init Done
[0000.888] I> parsing oem signed section of tos header done
[0000.893] I> tos binary init read from storage
[0000.897] I> ape: Authentication Finalize Done
[0000.902] I> oem authentication of tos header done
[0000.908] I> tos binary done read from storage
[0000.910] I> tos: Authentication init Done
[0000.915] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.920] I> bpmp-fw-dtb binary init read from storage
[0000.925] I> tos: Authentication Finalize Done
[0000.931] I> oem authentication of bpmp-fw-dtb header done
[0000.935] I> bpmp-fw-dtb binary done read from storage
[0000.940] I> bpmp-fw-dtb: Authentication init Done
[0000.945] I> parsing oem signed section of cpubl-dtb header done
[0000.951] I> cpubl-dtb binary init read from storage
[0000.955] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.002] I> oem authentication of cpubl-dtb header done
[0001.003] I> cpubl-dtb binary done read from storage
[0001.003] I> cpubl-dtb: Authentication init Done
[0001.004] I> parsing oem signed section of eks header done
[0001.005] I> eks binary init read from storage
[0001.005] I> cpubl-dtb: Authentication Finalize Done
[0001.006] I> oem authentication of eks header done
[0001.011] I> eks binary done read from storage
[0001.015] I> eks: Authentication init Done
[0001.019] I> eks: Authentication Finalize Done
[0001.023] I> EKB detected (length: 0x410) @ VA:0x5270a400
ÿ㍏TICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:54:10, Jul 9 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
ÿ
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
ÿ
ٰ001.364] I> Welcome to Cbootÿᬲq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
ÿ
[0001.365] I> Cboot Version: t194-f9317da2
[0001.366] I> CPU-BL Params @ 0xf2820000
[0001.370] I> 0) Base:0x00000000 Size:0x00000000
[0001.374] I> 1) Base:0xf1100000 Size:0x00100000
ÿk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ÿٰ001.379] I> 2) Base:0xf2000000 Size:0x00200000
[0001.533] I> 3) Base:0xf1200000 Size:0x00200000
[0001.537] I> 4) Base:0xf1000000 Size:0x00100000
[0001.542] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.546] I> 6) Base:0xf3800000 Size:0x00400000
[0001.551] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.555] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.560] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.564] I> 10) Base:0xf3000000 Size:0x00800000
[0001.569] I> 11) Base:0x40000000 Size:0x00040000
[0001.573] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.577] I> 13) Base:0x40046000 Size:0x00002000
[0001.582] I> 14) Base:0x40048000 Size:0x00002000
[0001.586] I> 15) Base:0xac000000 Size:0x00004000
[0001.591] I> 16) Base:0x4004a000 Size:0x00002000
[0001.595] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.600] I> 18) Base:0x4004c000 Size:0x00002000
[0001.604] I> 19) Base:0xf2200000 Size:0x00600000
[0001.609] I> 20) Base:0x4004e000 Size:0x00002000
[0001.613] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.618] I> 22) Base:0x00000000 Size:0x00000000
[0001.622] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.627] I> 24) Base:0xf6000000 Size:0x02000000
[0001.631] I> 25) Base:0x40050000 Size:0x00002000
[0001.635] I> 26) Base:0x40040000 Size:0x00006000
[0001.640] I> 27) Base:0xf1800000 Size:0x00400000
[0001.644] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.649] I> 29) Base:0xf1400000 Size:0x00400000
[0001.653] I> 30) Base:0x00000000 Size:0x00000000
[0001.658] I> 31) Base:0x00000000 Size:0x00000000
[0001.662] I> 32) Base:0xf8000000 Size:0x08000000
[0001.667] I> 33) Base:0x00000000 Size:0x00000000
[0001.671] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.676] I> 35) Base:0xab000000 Size:0x01000000
[0001.680] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.685] I> 37) Base:0xf2800000 Size:0x00800000
[0001.689] I> 38) Base:0x80000000 Size:0x20000000
[0001.693] I> 39) Base:0xb0000000 Size:0x08000000
[0001.698] I> 40) Base:0x00000000 Size:0x00000000
[0001.702] I> 41) Base:0x00000000 Size:0x00000000
[0001.707] I> 42) Base:0x00000000 Size:0x00000000
[0001.711] I> 43) Base:0x00000000 Size:0x00000000
[0001.716] I> 44) Base:0x00000000 Size:0x00000000
[0001.720] I> 45) Base:0x00000000 Size:0x00000000
[0001.725] GIC-SPI Target CPU: 0
[0001.728] Interrupts Init done
[0001.731] calling constructors
[0001.733] initializing heap
[0001.736] I> Heap: [0xa0694618 ... 0xab000000]
[0001.740] initializing threads
[0001.743] initializing timers
[0001.746] creating bootstrap completion thread
[0001.750] top of bootstrap2()
[0001.753] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.758] initializing platform
[0001.761] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.766] W> device prod register failed
[0001.770] I> Bl_dtb @0xaaf00000
[0001.775] W> "plugin-manager" doesn't exist, creating
[0001.778] W> "ids" doesn't exist, creating
[0001.782] W> "connection" doesn't exist, creating
[0001.786] W> "configs" doesn't exist, creating
[0001.798] I> Find /i2c@3160000's alias i2c0
[0001.798] I> Reading eeprom i2c=0 address=0x50
[0001.824] I> Device at /i2c@3160000:0x50
[0001.825] I> Reading eeprom i2c=0 address=0x57
[0001.849] I> Device at /i2c@3160000:0x57
[0001.851] I> Find /i2c@c240000's alias i2c1
[0001.851] I> Reading eeprom i2c=1 address=0x50
[0001.853] E> I2C: slave not found in slaves.
[0001.853] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.854] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.855] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.863] E> eeprom: Retry to read I2C slave device.
[0001.868] E> I2C: slave not found in slaves.
[0001.872] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.880] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.885] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.895] E> eeprom: Failed to read I2C slave device
[0001.900] I> Eeprom read failed 0x3526070d
[0001.904] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0001.909] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.920] I> create_pm_ids: id: 3509-0000-100-F, len: 15
[0001.925] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.936] I> Adding plugin-manager/ids/3668-0001-300=/i2c@3160000:module@0x50
[0001.943] W> "i2c@3160000" doesn't exist, creating
[0001.948] W> "module@0x50" doesn't exist, creating
[0001.952] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.959] W> "module@0x57" doesn't exist, creating
[0001.966] I> Adding plugin-manager/cvm
[0001.968] W> "chip-id" doesn't exist, creating
[0001.972] I> Adding plugin-manager/chip-id/A02P
[0001.976] I> Plugin-manager override starting
[0001.981] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.992] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.996] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0002.004] I> Disable plugin-manager status in FDT
[0002.004] I> Plugin-manager override finished successfully
[0002.008] I> gpio framework initialized
[0002.013] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.020] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.027] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.034] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.042] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.049] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.055] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.062] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.069] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.076] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.084] I> fixed regulator driver initialized
[0002.091] I> register 'maxim' power off handle
[0002.091] I> virtual i2c enabled
[0002.094] I> registered 'maxim,max20024' pmic
[0002.099] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.105] I> Boot-device: QSPI
[0002.108] I> Boot_device: QSPI_FLASH instance: 0
[0002.113] I> QSPI source rate = 204000 Khz
[0002.116] I> Requested rate for QSPI clock = 34000 Khz
[0002.122] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.126] I> QSPI Flash Size = 32 MB
[0002.134] I> Qspi initialized successfully
[0002.134] I> qspi flash-0 params source = boot args
[0002.138] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0002.143] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.154] I> create_pm_ids: id: 3509-0000-100-F, len: 15
[0002.160] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.175] I> sdmmc-3 params source = safe params
[0002.177] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.197] W> Cannot find any partition table for 00000003
[0002.209] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.218] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.222] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.222] I> hdmi cable connected
[0002.223] W> set volts not configured for 'vdd-1v0'
[0002.225] W> set volts not configured for 'vdd-1v8-hs'
[0002.228] E> invalid display type
[0002.229] E> cannot find any other nvdisp nodes
[0002.244] I> edid read success
[0002.256] I> edid read success
[0002.256] I> width = 640, height = 480, frequency = 25174825
[0002.257] I> width = 640, height = 480, frequency = 25174825
[0002.258] I> width = 640, height = 480, frequency = 25174825
[0002.258] I> width = 1920, height = 1080, frequency = 148500000
[0002.262] I> width = 1920, height = 1080, frequency = 148500000
[0002.267] I> width = 640, height = 480, frequency = 25174825
[0002.273] I> width = 720, height = 480, frequency = 26973026
[0002.278] I> width = 720, height = 480, frequency = 26973026
[0002.284] I> width = 1280, height = 720, frequency = 74175824
[0002.290] I> width = 1920, height = 1080, frequency = 148351648
[0002.295] I> width = 1920, height = 1080, frequency = 148351648
[0002.301] I> width = 1280, height = 720, frequency = 74175824
[0002.307] I> width = 720, height = 576, frequency = 26973026
[0002.312] I> width = 720, height = 576, frequency = 26973026
[0002.318] I> width = 1920, height = 1080, frequency = 74175824
[0002.323] I> width = 1920, height = 1080, frequency = 74175824
[0002.329] I> width = 1920, height = 1080, frequency = 74175824
[0002.335] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.345] I> hdmi_enable, starting HDMI initialisation
[0002.350] I> hdmi_enable, HDMI initialisation complete
[0002.361] I> Load in CBoot Boot Options partition and parse it
[0002.362] E> Error -9 when finding node with path /boot-configuration
[0002.363] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.370] I> Using default boot order
[0002.374] I> boot-dev-order :-
[0002.377] I> 1.sd
[0002.378] I> 2.usb
[0002.380] I> 3.nvme
[0002.382] I> 4.emmc
[0002.384] I> 5.net
[0002.386] I> Hit any key to stop autoboot: 4 3 2 1
[0004.394] initializing target
[0004.394] calling apps_init()
[0004.395] starting app kernel_boot_app
[0004.405] I> found decompressor handler: lz4-legacy
[0004.406] I> decompressing BMP blob ...
[0004.418] I> Kernel type = Normal
[0004.419] I> Loading kernel-bootctrl from partition
[0004.419] I> Loading partition kernel-bootctrl at 0xa4ae0000 from device(0x1)
[0004.427] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.427] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.428] I> ########## SD (0) boot ##########
[0004.429] W> Error: failed to get sd-card params
[0004.431] I> -0 params source =
[0004.434] W> Failed to initialize device 6-0
[0004.438] E> SD boot failed, err: 252641293
[0004.442] I> ########## USB (0) boot ##########
[0004.459] I> USB Firmware Version: 60.06 release
[0004.513] I> regulator of usb2-0 already enabled
[0004.518] I> regulator of usb2-1 already enabled
[0004.522] I> regulator of usb2-2 already enabled
[0005.588] I> USB 2.0 port 2 new high-speed USB device detected
[0005.590] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa9ae0000, cmd_ring.dma = 0xa9ae0040
[0005.691] I> Start to enumerate device
[0005.692] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa9ae0000, cmd_ring.dma = 0xa9ae0040
[0005.702] I>
[0005.702] I> Enumerated USB Device 0bda:5489
[0005.702] I>
[0005.705] I> Hub:
[0005.705] I> Downstream ports : 4
[0005.705] I> Power switching : Ganged
[0005.705] I> Compound device : No
[0005.706] I> Over-current protection : Global
[0005.706] I> Hub avg delay : 4 ns
[0005.708] I> Set interface = 1 (alt setting)
[0005.713] I> Enable hub ports
[0006.740] E> No device found on any of the hub ports
[0006.740] E> failed to start xhci controller
[0006.740] E> Error in init of XUSB host driver, err: 7979000d
[0006.741] W> Failed to initialize device 5-0
[0006.741] E> USB boot failed, err: 2037973005
[0006.741] I> ########## Fixed storage boot ##########
[0006.742] I> Already published: 00010003
[0006.746] I> Look for boot partition
[0006.749] I> Fallback: assuming 0th partition is boot partition
[0006.755] I> Detect filesystem
[0006.782] I> Loading extlinux.conf ...
[0006.783] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0006.837] I> L4T boot options
[0006.838] I> [1]: "primary kernel"
[0006.838] I> Enter choice:
[0007.167] I> Selected option: 1
[0007.167] I> Loading kernel sig file from rootfs ...
[0007.167] I> rootfs path: /sdmmc_user/boot/Image.sig
[0007.198] I> Loading kernel binary from rootfs ...
[0007.198] I> rootfs path: /sdmmc_user/boot/Image
[0007.597] I> overload load_size to 33366024 (from 34338824)
[0007.616] I> Validate kernel ...
[0007.616] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0007.920] E> digest on binary did not match!!
[0007.920] C> OEM authentication of kernel payload failed!
[0007.921] W> Failed to validate kernel binary (err=1077936152, fail=0)
[0007.921] W> Security fuse not burned, ignore validation failure
[0007.928] I> No kernel-dtb binary path
[0007.929] I> A/B: bin_type (38) slot 1
[0007.929] I> Loading kernel-dtb_b from partition
[0007.929] I> Loading partition kernel-dtb_b at 0x91000000 from device(0x1)
[0007.946] I> Validate kernel-dtb ...
[0007.946] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0007.948] I> Encryption fuse is not ON
[0007.950] I> Loading ramdisk from rootfs ...
[0007.953] I> Loading initrd sig file from rootfs ...
[0007.958] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0007.987] I> Loading initrd binary from rootfs ...
[0007.987] I> rootfs path: /sdmmc_user/boot/initrd
[0008.101] I> overload load_size to 7236840 (from 7237307)
[0008.105] I> Validate initrd ...
[0008.105] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0008.171] E> digest on binary did not match!!
[0008.172] C> OEM authentication of initrd payload failed!
[0008.172] W> Failed to validate initrd binary (err=1077936152, fail=0)
[0008.172] W> Security fuse not burned, ignore validation failure
[0008.174] I> Kernel hdr @0xa4ae0000
[0008.175] I> Kernel dtb @0x90000000
[0008.175] I> decompressor handler not found
[0008.179] I> Copying kernel image (33366024 bytes) from 0xa4ae0000 to 0x80080000 ... [0008.196] I> Done
[0008.196] I> Updated bpmp info to DTB
[0008.197] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ce8
[0008.198] I> Updated initrd info to DTB
[0008.200] W> WARN: Fail to override "console=none" in commandline
[0008.206] I> Active rootfs suffix:
[0008.209] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0008.217] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0008.224] I> Active slot suffix: _b
[0008.227] I> add_boot_slot_suffix: slot_suffix = _b
[0008.232] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06ac000 lut_mem=0x2008@0xa06a9000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0008.263] I> Updated bootarg info to DTB
[0008.267] W> MAC addr invalid!
[0008.270] E> Failed to get WIFI MAC address
[0008.274] W> MAC addr invalid!
[0008.277] E> Failed to get Bluetooth MAC address
[0008.281] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3a:3b:68
[0008.288] W> "plugin-manager" doesn't exist, creating
[0008.293] I> Adding /chosen/plugin-manager/cvm
[0008.297] W> "chip-id" doesn't exist, creating
[0008.301] I> Adding /chosen/plugin-manager/chip-id
[0008.306] W> "configs" doesn't exist, creating
[0008.310] I> Adding /chosen/plugin-manager/configs
[0008.314] W> "ids" doesn't exist, creating
[0008.318] I> Adding /chosen/plugin-manager/ids
[0008.323] W> "odm-data" doesn't exist, creating
[0008.327] I> Adding /chosen/plugin-manager/odm-data
[0008.334] W> "memory" doesn't exist, creating
[0008.336] I> [0] START: 0x80000000, END: 0xac000000
[0008.341] I> [1] START: 0xac004000, END: 0xf0ad0000
[0008.345] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0008.350] I> dram_block larger than 80000000
[0008.354] I> [3] START: 0x100000000, END: 0x280000000
[0008.359] I> added [base:0x80000000, size:0x2c000000] to /memory
[0008.365] I> added [base:0xac200000, size:0x44800000] to /memory
[0008.371] I> added [base:0x100000000, size:0x180000000] to /memory
[0008.377] I> Updated memory info to DTB
[0008.381] E> add_disp_param: failed to get display params for du=1
[0008.387] W> "reset" doesn't exist, creating
[0008.391] I> Adding ecid(000000016401b1402400000017000100) to DT
[0008.397] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0008.401] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0008.406] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0008.411] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0008.416] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0008.420] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0008.425] I> Deleted cpu@6 node in DT
[0008.428] I> Deleted cpu@7 node in DT
[0008.432] I> Deleted cluster3 node in FDT
[0008.436] I> Update arm-pmu in FDT
[0008.439] I> - update property: interrupts
[0008.443] I> - update property: interrupt-affinity
[0008.448] W> "misc-data" doesn't exist, creating
[0008.452] I> Boot-device: QSPI
[0008.455] W> Unknown boot device
[0008.458] I> Add storage-qspi to plugin-manager/misc-data
[0008.463] W> Unknown storage device
[0008.467] I> Add serial number:1421621046162 as DT property
[0008.473] I> Plugin-manager override starting
[0008.477] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0008.483] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0008.489] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0008.497] I> Disable plugin-manager status in FDT
[0008.499] I> Plugin-manager override finished successfully
[0008.504] I> tegrabl_load_kernel_and_dtb: Done
[0008.509] I> QSPI: erasing sectors from 176 - 176
[0008.513] I> QSPI: recoverying tail blocks from 22536 - 22656
[0009.164] I> QSPI: erasing sectors from 177 - 177
[0009.164] I> QSPI: recoverying tail blocks from 22664 - 22784
[0009.824] I> Kernel EP: 0x80080000, DTB: 0x90000000
These are the serial output. After outputting these, there will be no subsequent linux boot steps.
