never mind; I discovered the correct UART through trial and error. Here is the console log:
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x0
[0000.059] I> rst_source : 0x0
[0000.062] I> rst_level : 0x0
[0000.066] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] W> No valid slot number is found in scratch register
[0000.092] W> Return default slot: _a
[0000.095] I> Active Boot chain : 0
[0000.098] I> Boot-device: QSPI
[0000.101] I> Qspi flash params source = brbct
[0000.107] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.114] I> Temperature = 31500
[0000.117] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.122] W> Skipping boost for clk: BPMP_APB
[0000.126] W> Skipping boost for clk: AXI_CBB
[0000.130] W> Skipping boost for clk: AON_CPU_NIC
[0000.134] W> Skipping boost for clk: CAN1
[0000.138] W> Skipping boost for clk: CAN2
[0000.142] I> Boot-device: QSPI
[0000.145] I> Boot-device: QSPI
[0000.148] I> Qspi flash params source = mb1bct
[0000.152] I> Qspi using bpmp-dma
[0000.155] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.161] I> Qspi flash params source = mb1bct
[0000.167] I> ECC region[0]: Start:0x0, End:0x0
[0000.171] I> ECC region[1]: Start:0x0, End:0x0
[0000.175] I> ECC region[2]: Start:0x0, End:0x0
[0000.179] I> ECC region[3]: Start:0x0, End:0x0
[0000.183] I> ECC region[4]: Start:0x0, End:0x0
[0000.187] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.193] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.198] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.202] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.207] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.212] E> FAILED: Thermal config
[0000.219] E> FAILED: MEMIO rail config
[0000.229] I> Boot-device: QSPI
[0000.232] I> Qspi flash params source = mb1bct
[0000.241] I> Qspi flash params source = mb1bct
[0000.253] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.328] I> Qspi flash params source = mb1bct
[0000.357] I> Qspi flash params source = mb1bct
[0000.369] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.377] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.378] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.378] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.379] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.385] W> device prod register failed
[0000.389] I> Boot-device: QSPI
[0000.391] I> Boot_device: QSPI_FLASH instance: 0
[0000.397] I> QSPI Flash Size = 32 MB
[0000.402] I> Qspi initialized successfully
[0000.403] I> qspi flash-0 params source = boot args
[0000.788] I> sdmmc DDR50 mode
[0000.790] I> sdmmc-3 params source = safe params
[0000.795] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.797] W> Cannot find any partition table for 00000003
[0000.801] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.802] W> No valid slot number is found in scratch register
[0000.803] W> Return default slot: _a
[0000.803] I> Active Boot chain : 0
[0000.804] I> parsing oem signed section of bpmp-fw header done
[0000.805] I> bpmp-fw binary init read from storage
[0000.809] I> oem authentication of bpmp-fw header done
[0000.823] I> bpmp-fw binary done read from storage
[0000.824] I> bpmp-fw: Authentication init Done
[0000.825] I> parsing oem signed section of cpubl header done
[0000.828] I> cpubl binary init read from storage
[0000.833] I> bpmp-fw: Authentication Finalize Done
[0000.838] I> oem authentication of cpubl header done
[0000.845] I> cpubl binary done read from storage
[0000.847] I> cpubl: Authentication init Done
[0000.851] I> parsing oem signed section of rce header done
[0000.856] I> rce binary init read from storage
[0000.861] I> Relocating BR-BCT
[0000.863] I> cpubl: Authentication Finalize Done
[0000.868] I> oem authentication of rce header done
[0000.873] I> rce binary done read from storage
[0000.877] I> rce: Authentication init Done
[0000.881] I> parsing oem signed section of ape header done
[0000.886] I> ape binary init read from storage
[0000.890] I> rce: Authentication Finalize Done
[0000.895] I> oem authentication of ape header done
[0000.899] I> ape binary done read from storage
[0000.903] I> ape: Authentication init Done
[0000.908] I> parsing oem signed section of tos header done
[0000.913] I> tos binary init read from storage
[0000.917] I> ape: Authentication Finalize Done
[0000.922] I> oem authentication of tos header done
[0000.928] I> tos binary done read from storage
[0000.930] I> tos: Authentication init Done
[0000.934] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.940] I> bpmp-fw-dtb binary init read from storage
[0000.945] I> tos: Authentication Finalize Done
[0000.951] I> oem authentication of bpmp-fw-dtb header done
[0000.955] I> bpmp-fw-dtb binary done read from storage
[0000.960] I> bpmp-fw-dtb: Authentication init Done
[0000.965] I> parsing oem signed section of cpubl-dtb header done
[0000.970] I> cpubl-dtb binary init read from storage
[0000.975] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.027] I> oem authentication of cpubl-dtb header done
[0001.027] I> cpubl-dtb binary done read from storage
[0001.028] I> cpubl-dtb: Authentication init Done
[0001.029] I> parsing oem signed section of eks header done
[0001.030] I> eks binary init read from storage
[0001.030] I> cpubl-dtb: Authentication Finalize Done
[0001.031] I> oem authentication of eks header done
[0001.035] I> eks binary done read from storage
[0001.040] I> eks: Authentication init Done
[0001.044] I> eks: Authentication Finalize Done
[0001.048] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.405] I> Welcome to Cboot
��WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.406] I> Cboot Version: t194-cfa2bc91
[0001.408] I> CPU-BL Params @ 0xf2820000
[0001.411] I> 0) Base:0x00000000 Size:0x00000000
[0001.416] I> 1) Base:0xf1100000 Size:0x00100000
[0001.420] I> 2) Base:0xf2000000 Size:0x00200000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.425] I> 3) Base:0xf1200000 Size:0x00200000
[0001.579] I> 4) Base:0xf1000000 Size:0x00100000
[0001.583] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.588] I> 6) Base:0xf3800000 Size:0x00400000
[0001.592] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.597] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.601] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.606] I> 10) Base:0xf3000000 Size:0x00800000
[0001.610] I> 11) Base:0x40000000 Size:0x00040000
[0001.615] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.619] I> 13) Base:0x40046000 Size:0x00002000
[0001.623] I> 14) Base:0x40048000 Size:0x00002000
[0001.628] I> 15) Base:0xac000000 Size:0x00004000
[0001.632] I> 16) Base:0x4004a000 Size:0x00002000
[0001.637] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.641] I> 18) Base:0x4004c000 Size:0x00002000
[0001.646] I> 19) Base:0xf2200000 Size:0x00600000
[0001.650] I> 20) Base:0x4004e000 Size:0x00002000
[0001.655] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.659] I> 22) Base:0x00000000 Size:0x00000000
[0001.664] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.668] I> 24) Base:0xf6000000 Size:0x02000000
[0001.673] I> 25) Base:0x40050000 Size:0x00002000
[0001.677] I> 26) Base:0x40040000 Size:0x00006000
[0001.681] I> 27) Base:0xf1800000 Size:0x00400000
[0001.686] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.690] I> 29) Base:0xf1400000 Size:0x00400000
[0001.695] I> 30) Base:0x00000000 Size:0x00000000
[0001.699] I> 31) Base:0x00000000 Size:0x00000000
[0001.704] I> 32) Base:0xf8000000 Size:0x08000000
[0001.708] I> 33) Base:0x00000000 Size:0x00000000
[0001.713] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.717] I> 35) Base:0xab000000 Size:0x01000000
[0001.722] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.726] I> 37) Base:0xf2800000 Size:0x00800000
[0001.731] I> 38) Base:0x80000000 Size:0x20000000
[0001.735] I> 39) Base:0xb0000000 Size:0x08000000
[0001.739] I> 40) Base:0x00000000 Size:0x00000000
[0001.744] I> 41) Base:0x00000000 Size:0x00000000
[0001.748] I> 42) Base:0x00000000 Size:0x00000000
[0001.753] I> 43) Base:0x00000000 Size:0x00000000
[0001.757] I> 44) Base:0x00000000 Size:0x00000000
[0001.762] I> 45) Base:0x00000000 Size:0x00000000
[0001.766] GIC-SPI Target CPU: 0
[0001.769] Interrupts Init done
[0001.772] calling constructors
[0001.775] initializing heap
[0001.778] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.782] initializing threads
[0001.785] initializing timers
[0001.788] creating bootstrap completion thread
[0001.792] top of bootstrap2()
[0001.795] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.799] initializing platform
[0001.802] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.808] W> device prod register failed
[0001.812] I> Bl_dtb @0xaaf00000
[0001.817] W> "plugin-manager" doesn't exist, creating
[0001.819] W> "ids" doesn't exist, creating
[0001.824] W> "connection" doesn't exist, creating
[0001.828] W> "configs" doesn't exist, creating
[0001.839] E> failed to read label property for node 158736: 13
[0001.841] E> failed to read reg property for node 158800: 13
[0001.845] E> failed to read reg property for node 158852: 13
[0001.850] E> failed to read reg property for node 158936: 13
[0001.856] I> Find /i2c@3160000's alias i2c0
[0001.858] I> Reading eeprom i2c=0 address=0x50
[0001.888] I> Device at /i2c@3160000:0x50
[0001.888] I> Reading eeprom i2c=0 address=0x57
[0001.889] E> I2C: slave not found in slaves.
[0001.889] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.890] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.891] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.898] E> eeprom: Failed to read I2C slave device
[0001.903] I> Eeprom read failed 0x3526070d
[0001.908] I> Find /i2c@c240000's alias i2c1
[0001.911] I> Reading eeprom i2c=1 address=0x50
[0001.916] E> I2C: slave not found in slaves.
[0001.919] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.927] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.933] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.942] E> eeprom: Retry to read I2C slave device.
[0001.947] E> I2C: slave not found in slaves.
[0001.951] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.959] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.964] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.974] E> eeprom: Failed to read I2C slave device
[0001.979] I> Eeprom read failed 0x3526070d
[0001.983] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0001.988] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.999] I> Adding plugin-manager/ids/3668-0001-300=/i2c@3160000:module@0x50
[0002.007] W> "i2c@3160000" doesn't exist, creating
[0002.011] W> "module@0x50" doesn't exist, creating
[0002.016] I> Adding plugin-manager/cvm
[0002.019] W> "chip-id" doesn't exist, creating
[0002.023] I> Adding plugin-manager/chip-id/A02P
[0002.028] I> Plugin-manager override starting
[0002.032] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.040] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.045] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0002.053] I> Disable plugin-manager status in FDT
[0002.054] I> Plugin-manager override finished successfully
[0002.059] I> gpio framework initialized
[0002.064] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.071] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.078] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.085] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.093] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.100] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.106] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.113] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.121] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.128] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.135] I> fixed regulator driver initialized
[0002.142] I> register 'maxim' power off handle
[0002.143] I> virtual i2c enabled
[0002.146] I> registered 'maxim,max20024' pmic
[0002.150] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.156] I> Boot-device: QSPI
[0002.159] I> Boot_device: QSPI_FLASH instance: 0
[0002.164] I> QSPI source rate = 204000 Khz
[0002.168] I> Requested rate for QSPI clock = 34000 Khz
[0002.173] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.178] I> QSPI Flash Size = 32 MB
[0002.185] I> Qspi initialized successfully
[0002.186] I> qspi flash-0 params source = boot args
[0002.190] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0002.195] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.210] I> sdmmc-3 params source = safe params
[0002.212] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.232] W> Cannot find any partition table for 00000003
[0002.244] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.252] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.255] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.256] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.256] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.260] E> invalid display type
[0002.261] E> cannot find any other nvdisp nodes
[0002.261] E> no valid display unit config found in dtb
[0002.263] W> display init failed
[0002.265] I> Load in CBoot Boot Options partition and parse it
[0002.271] E> Error -9 when finding node with path /boot-configuration
[0002.277] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.284] I> Using default boot order
[0002.288] I> boot-dev-order :-
[0002.290] I> 1.sd
[0002.292] I> 2.usb
[0002.294] I> 3.nvme
[0002.296] I> 4.emmc
[0002.298] I> 5.net
[0002.300] I> Hit any key to stop autoboot: 4 3 2 1
[0004.307] initializing target
[0004.307] calling apps_init()
[0004.308] starting app kernel_boot_app
[0004.318] I> found decompressor handler: lz4-legacy
[0004.319] I> decompressing BMP blob ...
[0004.330] I> Kernel type = Normal
[0004.331] I> ########## SD (0) boot ##########
[0004.331] W> Error: failed to get sd-card params
[0004.332] I> -0 params source =
[0004.332] W> Failed to initialize device 6-0
[0004.332] E> SD boot failed, err: 252641293
[0004.333] I> ########## USB (0) boot ##########
[0004.338] W> No valid slot number is found in scratch register
[0004.338] W> Return default slot: _a
[0004.354] I> Validate XUSB-FW ...
[0004.354] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x30000
[0004.356] I> Encryption fuse is not ON
[0004.356] I> USB Firmware Version: 60.09 release
[0004.414] I> regulator of usb2-0 already enabled
[0004.418] I> regulator of usb2-1 already enabled
[0004.422] I> regulator of usb2-2 already enabled
[0005.488] I> USB 2.0 port 2 new high-speed USB device detected
[0005.490] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d3a00, cmd_ring.dma = 0xa42d3ac0
[0005.591] I> Start to enumerate device
[0005.592] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d3a00, cmd_ring.dma = 0xa42d3ac0
[0005.599] I>
[0005.599] I> Enumerated USB Device 0bda:5411
[0005.599] I>
[0005.600] I> Hub:
[0005.601] I> Downstream ports : 4
[0005.601] I> Power switching : Ganged
[0005.601] I> Compound device : No
[0005.601] I> Over-current protection : Global
[0005.604] I> Hub avg delay : 4 ns
[0005.608] I> Set interface = 1 (alt setting)
[0005.613] I> Enable hub ports
[0005.623] I> Device detected on port 4
[0006.638] I> Reset port 4
[0006.693] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d3a00, cmd_ring.dma = 0xa42d3ac0
[0006.794] I> Start to enumerate device
[0006.795] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d3a00, cmd_ring.dma = 0xa42d3ac0
[0006.800] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42d3b00, cmd_ring.dma = 0xa42d3ac0
[0006.802] I>
[0006.802] I> Enumerated USB Device 090c:1000
[0006.802] I>
[0006.925] I> Max LUN = 0
[0009.934] W> xusbh_wait_irq: Timed out! status = 0x00
[0010.060] E> Bad CSW SIG (0)!
[0010.161] E> USBMSD: Invalid value CSW SIG 53425355.
[0010.161] E> INQUIRY returned error 0x7c7c1102 ...
[0013.171] W> xusbh_wait_irq: Timed out! status = 0x00
[0013.171] E> Bad CSW SIG (0)!
[0013.272] E> USBMSD: Invalid value CSW SIG 0.
[0016.304] W> xusbh_wait_irq: Timed out! status = 0x00
[0016.304] E> Bad CSW SIG (0)!
[0016.405] E> USBMSD: Invalid value CSW SIG 0.
[0019.415] W> xusbh_wait_irq: Timed out! status = 0x00
[0019.415] E> Bad CSW SIG (0)!
[0019.516] E> USBMSD: Invalid value CSW SIG 0.
[0022.547] W> xusbh_wait_irq: Timed out! status = 0x00
[0022.548] E> Bad CSW SIG (0)!
[0022.649] E> USBMSD: Invalid value CSW SIG 0.
[0022.649] W> TEST UNIT READY returned error 0x7c7c1102, retries @ 5 ...
[0022.650] I> -0 params source =
[0022.650] E> Blockdev read block: exit error = e0e0104
[0022.651] E> Blockdev read block: exit error = e0e0104
[0022.651] W> Cannot find any partition table for 00050000
[0022.653] I> Detect filesystem
[0022.656] E> Either offset or requested data size from that offset is beyond device size
[0022.664] E> Blockdev read: exit error = e0e0004
[0022.668] I> fs_detect:160: Failed to read superblock
[0022.673] I> Loading kernel-bootctrl from partition
[0022.678] I> Loading partition kernel-bootctrl at 0xa4360000 from device(0x1)
[0022.692] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0022.693] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0022.699] E> USB boot failed, err: 724238349
[0022.703] I> ########## NVME (0) boot ##########
[0022.707] I> Initializing nvme device instance 0
[0022.712] I> Initializing nvme controller
[0022.716] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0022.722] I> vpcie3v3-supply not found
[0022.726] I> vpcie12v-supply not found
[0022.729] W> Failed to get nvidia,plat-gpios
[0022.733] I> tegrabl_pcie_soc_preinit: (0):
[0022.738] I> Unpowergate
[0022.740] I> tegrabl_car_clk_disable(0) ...
[0022.744] I> tegrabl_car_rst_set(CORE, 0) ...
[0022.748] I> tegrabl_car_rst_set(APB, 0) ...
[0022.752] I> tegrabl_car_clk_enable(0) ...
[0022.756] I> tegrabl_car_rst_clear(APB, 0) ...
[0022.760] I> tegrabl_set_ctrl_state(0)
[0022.764] I> CLR PCIE_APB:6
[0022.767] I> tegrabl_pcie_soc_init: (0):
[0022.770] I> APPL initialization ...
[0022.774] I> poweron phys
[0022.776] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0022.783] I> tegrabl_power_on_phy: controller 0 not available
[0022.788] E> Failed to power on phy on controller-0
[0022.793] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0022.798] I> Failed to initialize SoC Host PCIe controller
[0022.803] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x1
[0022.810] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0022.816] W> Failed to open NVME-0, err = 80800601
[0022.821] W> Failed to initialize device 10-0
[0022.825] E> NVME (0) boot failed, err: 0x80800601
[0022.830] I> ########## NVME (1) boot ##########
[0022.834] I> Initializing nvme device instance 1
[0022.839] I> Initializing nvme controller
[0022.843] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0022.849] I> vpcie3v3-supply not found
[0022.852] I> vpcie12v-supply not found
[0022.856] W> Failed to get nvidia,plat-gpios
[0022.860] I> tegrabl_pcie_soc_preinit: (1):
[0022.864] I> Unpowergate
[0022.867] I> tegrabl_car_clk_disable(1) ...
[0022.871] I> tegrabl_car_rst_set(CORE, 1) ...
[0022.875] I> tegrabl_car_rst_set(APB, 1) ...
[0022.879] I> tegrabl_car_clk_enable(1) ...
[0022.883] I> tegrabl_car_rst_clear(APB, 1) ...
[0022.887] I> tegrabl_set_ctrl_state(1)
[0022.891] I> CLR PCIE_APB:6
[0022.893] I> tegrabl_pcie_soc_init: (1):
[0022.897] I> APPL initialization ...
[0022.900] I> poweron phys
[0022.903] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0022.909] I> tegrabl_power_on_phy: controller 1 not available
[0022.915] E> Failed to power on phy on controller-1
[0022.920] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0022.925] I> Failed to initialize SoC Host PCIe controller
[0022.930] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(1); error=0x1
[0022.936] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0022.943] W> Failed to open NVME-1, err = 80800601
[0022.947] W> Failed to initialize device 10-1
[0022.952] E> NVME (1) boot failed, err: 0x80800601
[0022.956] I> ########## NVME (2) boot ##########
[0022.961] I> Initializing nvme device instance 2
[0022.965] I> Initializing nvme controller
[0022.969] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0022.975] I> vpcie3v3-supply not found
[0022.979] I> vpcie12v-supply not found
[0022.983] W> Failed to get nvidia,plat-gpios
[0022.987] I> tegrabl_pcie_soc_preinit: (2):
[0022.991] I> Unpowergate
[0022.993] I> tegrabl_car_clk_disable(2) ...
[0022.997] I> tegrabl_car_rst_set(CORE, 2) ...
[0023.001] I> tegrabl_car_rst_set(APB, 2) ...
[0023.005] I> tegrabl_car_clk_enable(2) ...
[0023.009] I> tegrabl_car_rst_clear(APB, 2) ...
[0023.014] I> tegrabl_set_ctrl_state(2)
[0023.017] I> CLR PCIE_APB:6
[0023.020] I> tegrabl_pcie_soc_init: (2):
[0023.024] I> APPL initialization ...
[0023.027] I> poweron phys
[0023.030] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0023.036] I> tegrabl_power_on_phy: controller 2 not available
[0023.041] E> Failed to power on phy on controller-2
[0023.047] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0023.051] I> Failed to initialize SoC Host PCIe controller
[0023.057] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0023.063] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0023.069] W> Failed to open NVME-2, err = 80800601
[0023.074] W> Failed to initialize device 10-2
[0023.078] E> NVME (2) boot failed, err: 0x80800601
[0023.083] I> ########## NVME (3) boot ##########
[0023.087] I> Initializing nvme device instance 3
[0023.092] I> Initializing nvme controller
[0023.096] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0023.102] I> vpcie3v3-supply not found
[0023.106] I> vpcie12v-supply not found
[0023.109] W> Failed to get nvidia,plat-gpios
[0023.113] I> tegrabl_pcie_soc_preinit: (3):
[0023.117] I> Unpowergate
[0023.120] I> tegrabl_car_clk_disable(3) ...
[0023.124] I> tegrabl_car_rst_set(CORE, 3) ...
[0023.128] I> tegrabl_car_rst_set(APB, 3) ...
[0023.132] I> tegrabl_car_clk_enable(3) ...
[0023.136] I> tegrabl_car_rst_clear(APB, 3) ...
[0023.140] I> tegrabl_set_ctrl_state(3)
[0023.144] I> CLR PCIE_APB:6
[0023.147] I> tegrabl_pcie_soc_init: (3):
[0023.150] I> APPL initialization ...
[0023.154] I> poweron phys
[0023.156] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0023.162] I> tegrabl_power_on_phy: controller 3 not available
[0023.168] E> Failed to power on phy on controller-3
[0023.173] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0023.178] I> Failed to initialize SoC Host PCIe controller
[0023.183] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x1
[0023.190] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0023.196] W> Failed to open NVME-3, err = 80800601
[0023.201] W> Failed to initialize device 10-3
[0023.205] E> NVME (3) boot failed, err: 0x80800601
[0023.209] I> ########## NVME (4) boot ##########
[0023.214] I> Initializing nvme device instance 4
[0023.218] I> Initializing nvme controller
[0023.223] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0023.229] I> vpcie3v3-supply not found
[0023.232] I> vpcie12v-supply not found
[0023.236] W> Failed to get nvidia,plat-gpios
[0023.240] I> tegrabl_pcie_soc_preinit: (4):
[0023.244] I> Unpowergate
[0023.247] I> tegrabl_car_clk_disable(4) ...
[0023.250] I> tegrabl_car_rst_set(CORE, 4) ...
[0023.255] I> tegrabl_car_rst_set(APB, 4) ...
[0023.259] I> tegrabl_car_clk_enable(4) ...
[0023.263] I> tegrabl_car_rst_clear(APB, 4) ...
[0023.267] I> tegrabl_set_ctrl_state(4)
[0023.271] I> CLR PCIE_APB:6
[0023.273] I> tegrabl_pcie_soc_init: (4):
[0023.277] I> APPL initialization ...
[0023.280] I> poweron phys
[0023.283] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0023.289] I> tegrabl_power_on_phy: power on phy @0x3f40000
[0024.395] C> Failed to link up controller-4
[0024.395] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0024.396] I> Failed to initialize SoC Host PCIe controller
[0024.396] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x12
[0024.397] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0024.397] W> Failed to open NVME-4, err = 80800612
[0024.402] W> Failed to initialize device 10-4
[0024.406] E> NVME (4) boot failed, err: 0x80800612
[0024.410] I> ########## NVME (5) boot ##########
[0024.415] I> Initializing nvme device instance 5
[0024.419] I> Initializing nvme controller
[0024.424] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0024.430] I> vpcie3v3-supply not found
[0024.433] I> vpcie12v-supply not found
[0024.437] W> Failed to get nvidia,plat-gpios
[0024.441] I> tegrabl_pcie_soc_preinit: (5):
[0024.445] I> Unpowergate
[0024.447] I> tegrabl_car_clk_disable(5) ...
[0024.451] I> tegrabl_car_rst_set(CORE, 5) ...
[0024.456] I> tegrabl_car_rst_set(APB, 5) ...
[0024.460] I> tegrabl_car_clk_enable(5) ...
[0024.464] I> tegrabl_car_rst_clear(APB, 5) ...
[0024.468] I> tegrabl_set_ctrl_state(5)
[0024.471] I> CLR PCIE_APB:6
[0024.474] I> tegrabl_pcie_soc_init: (5):
[0024.478] I> APPL initialization ...
[0024.481] I> poweron phys
[0024.484] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0024.490] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0024.495] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0024.501] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0024.506] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0024.512] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0024.517] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0024.522] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0024.528] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0025.633] C> Failed to link up controller-5
[0025.633] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0025.634] I> Failed to initialize SoC Host PCIe controller
[0025.634] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0025.635] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0025.635] W> Failed to open NVME-5, err = 80800612
[0025.640] W> Failed to initialize device 10-5
[0025.644] E> NVME (5) boot failed, err: 0x80800612
[0025.649] I> ########## Fixed storage boot ##########
[0025.654] I> Loading kernel-bootctrl from partition
[0025.658] I> Loading partition kernel-bootctrl at 0xa4360000 from device(0x1)
[0025.673] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0025.673] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0025.679] I> Already published: 00010003
[0025.683] I> Look for boot partition
[0025.686] I> Fallback: assuming 0th partition is boot partition
[0025.692] I> Detect filesystem
[0025.719] I> Loading extlinux.conf ...
[0025.720] I> Loading extlinux.conf binary from rootfs ...
[0025.720] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0025.769] I> Loading extlinux.conf sig file from rootfs ...
[0025.769] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf.sig
[0031.980] I> lookup_linear_dir:447: Invalid file block num
[0031.981] I> ext2_walk:142: 'extlinux.conf.sig' lookup failed
[0031.981] I> ext4_open_file:666: '/boot/extlinux/extlinux.conf.sig' lookup failed
[0031.982] E> file /sdmmc_user/boot/extlinux/extlinux.conf.sig open failed!!
[0031.982] W> Failed to load extlinux.conf sig file (err=202113041)
[0031.986] I> Validate extlinux.conf ...
[0031.990] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0031.997] E> Stage2Signature validation failed with SHA2!!
[0032.002] C> OEM authentication of extlinux.conf header failed!
[0032.008] W> Failed to validate extlinux.conf binary from rootfs (err=1077936152, fail=1)
[0032.016] W> Security fuse not burned, ignore validation failure
[0032.022] I> restore load_size to 1177
[0032.026] I> L4T boot options
[0032.028] I> [1]: "primary kernel"
[0032.032] I> [2]: "Custom Header Config: <HDR40 HX711 IIO and SPI for Olyns>"
[0032.039] I> Enter choice:
[0035.042] I> Continuing with default option: 2
[0035.042] I> Loading kernel ...
[0035.042] I> Loading kernel binary from rootfs ...
[0035.043] I> rootfs path: /sdmmc_user/boot/Image
[0035.449] I> Loading kernel sig file from rootfs ...
[0035.449] I> rootfs path: /sdmmc_user/boot/Image.sig
[0035.480] I> overload load_size to 34484232 (from 34484240)
[0035.480] I> Validate kernel ...
[0035.481] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0035.795] I> Encryption fuse is not ON
[0035.811] I> Loading kernel-dtb ...
[0035.811] I> Loading kernel-dtb binary from rootfs ...
[0035.812] I> rootfs path: /sdmmc_user/boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb
[0035.850] I> Loading kernel-dtb sig file from rootfs ...
[0035.851] I> rootfs path: /sdmmc_user/boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb.sig
[0035.875] I> ext2_walk:142: 'kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb.sig' lookup failed
[0035.876] I> ext4_open_file:666: '/boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb.sig' lookup failed
[0035.877] E> file /sdmmc_user/boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb.sig open failed!!
[0035.879] W> Failed to load kernel-dtb sig file (err=202113041)
[0035.885] I> Validate kernel-dtb ...
[0035.888] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0035.895] E> Stage2Signature validation failed with SHA2!!
[0035.900] C> OEM authentication of kernel-dtb header failed!
[0035.906] W> Failed to validate kernel-dtb binary from rootfs (err=1077936152, fail=1)
[0035.914] W> Security fuse not burned, ignore validation failure
[0035.919] I> restore load_size to 205319
[0035.923] I> Loading ramdisk from rootfs ...
[0035.927] I> Loading ramdisk binary from rootfs ...
[0035.932] I> rootfs path: /sdmmc_user/boot/initrd
[0036.045] I> Loading ramdisk sig file from rootfs ...
[0036.046] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0036.076] I> overload load_size to 7238344 (from 7238352)
[0036.077] I> Validate ramdisk ...
[0036.077] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0036.143] I> Encryption fuse is not ON
[0036.157] I> Kernel hdr @0xa4360000
[0036.157] I> Kernel dtb @0x90000000
[0036.157] I> decompressor handler not found
[0036.158] I> Copying kernel image (34484232 bytes) from 0xa4360000 to 0x80080000 ... [0036.168] I> Done
[0036.169] I> Updated bpmp info to DTB
[0036.170] I> Ramdisk: Base: 0x91000000; Size: 0x6e72c8
[0036.170] I> Updated initrd info to DTB
[0036.171] W> WARN: Fail to override "console=none" in commandline
[0036.171] I> Active rootfs suffix:
[0036.173] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0036.181] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0036.188] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0036.195] W> No valid slot number is found in scratch register
[0036.201] W> Return default slot: _a
[0036.204] I> Active slot suffix:
[0036.207] I> add_boot_slot_suffix: slot_suffix =
[0036.212] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0036.236] I> Updated bootarg info to DTB
[0036.240] W> MAC addr invalid!
[0036.243] E> Failed to get WIFI MAC address
[0036.247] W> MAC addr invalid!
[0036.250] E> Failed to get Bluetooth MAC address
[0036.254] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:51:0b:07
[0036.261] W> "plugin-manager" doesn't exist, creating
[0036.265] I> Adding /chosen/plugin-manager/cvm
[0036.270] W> "chip-id" doesn't exist, creating
[0036.274] I> Adding /chosen/plugin-manager/chip-id
[0036.279] W> "configs" doesn't exist, creating
[0036.283] I> Adding /chosen/plugin-manager/configs
[0036.287] W> "ids" doesn't exist, creating
[0036.291] I> Adding /chosen/plugin-manager/ids
[0036.296] W> "odm-data" doesn't exist, creating
[0036.300] I> Adding /chosen/plugin-manager/odm-data
[0036.307] W> "memory" doesn't exist, creating
[0036.309] I> [0] START: 0x80000000, END: 0xac000000
[0036.314] I> [1] START: 0xac004000, END: 0xf0ad0000
[0036.318] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0036.323] I> dram_block larger than 80000000
[0036.327] I> [3] START: 0x100000000, END: 0x280000000
[0036.332] I> added [base:0x80000000, size:0x2c000000] to /memory
[0036.338] I> added [base:0xac200000, size:0x44800000] to /memory
[0036.344] I> added [base:0x100000000, size:0x180000000] to /memory
[0036.350] I> Updated memory info to DTB
[0036.354] E> add_disp_param: failed to get display params for du=0
[0036.360] W> "reset" doesn't exist, creating
[0036.364] I> Adding ecid(00000001640560822000000003fd0140) to DT
[0036.370] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0036.374] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0036.379] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0036.384] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0036.388] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0036.393] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0036.398] I> Deleted cpu@6 node in DT
[0036.401] I> Deleted cpu@7 node in DT
[0036.405] I> Deleted cluster3 node in FDT
[0036.409] I> Update arm-pmu in FDT
[0036.412] I> - update property: interrupts
[0036.416] I> - update property: interrupt-affinity
[0036.421] W> "misc-data" doesn't exist, creating
[0036.425] I> Boot-device: QSPI
[0036.428] W> Unknown boot device
[0036.431] I> Add storage-qspi to plugin-manager/misc-data
[0036.436] W> Unknown storage device
[0036.440] I> Add serial number:1421821016474 as DT property
[0036.446] I> Plugin-manager override starting
[0036.450] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0036.456] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0036.462] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0036.470] I> Disable plugin-manager status in FDT
[0036.472] I> Plugin-manager override finished successfully
[0036.477] I> tegrabl_load_kernel_and_dtb: Done
[0036.481] E> tegrabl_display_clear: display is not initialized
[0036.487] W> Boot logo display failed...
[0036.491] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:19:28 PDT 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 1.934679] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.934973] imx219 9-0010: board setup failed
[ 1.958832] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.959070] imx219 10-0010: board setup failed
��WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
��[ 3.774458] cgroup: cgroup2: unknown option "nsdelegate"
��[ 5.017341] scsi 0:0:0:0: Direct-Access Samsung Flash Drive FIT 1100 PQ: 0 ANSI: 6
[ 5.018662] sd 0:0:0:0: [sda] 250626566 512-byte logical blocks: (128 GB/120 GiB)
[ 5.020406] sd 0:0:0:0: [sda] Write Protect is off
[ 5.020807] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.047456] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 5.283400] random: crng init done
[ 5.283517] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.428774] using random self ethernet address
[ 5.428906] using random host ethernet address
[ 6.158295] using random self ethernet address
[ 6.158425] using random host ethernet address
[ 6.362420] CPU4: shutdown
[ 6.407692] CPU5: shutdown
[ 7.180298] Bridge firewalling registered
Ubuntu 18.04.5 LTS jetson-xavier ttyTCU0
jetson-xavier login:
