I always should power my jetson xavier nx many times so that it can startup normally.Why?
error.log (59.9 KB)
[BEGIN] 2021/5/21 11:03:00
bash-4.3# ?
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] I> Active Boot chain : 0
[0000.088] I> Boot-device: QSPI
[0000.091] I> Qspi flash params source = brbct
[0000.097] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.105] I> Temperature = 30000
[0000.108] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.112] W> Skipping boost for clk: BPMP_APB
[0000.116] W> Skipping boost for clk: AXI_CBB
[0000.120] W> Skipping boost for clk: AON_CPU_NIC
[0000.124] W> Skipping boost for clk: CAN1
[0000.128] W> Skipping boost for clk: CAN2
[0000.132] I> Boot-device: QSPI
[0000.135] I> Boot-device: QSPI
[0000.138] I> Qspi flash params source = mb1bct
[0000.142] I> Qspi using bpmp-dma
[0000.145] I> Qspi clock source : pllc_out0
[0000.149] I> Qspi reinitialized
[0000.152] I> Qspi flash params source = mb1bct
[0000.157] I> ECC region[0]: Start:0x0, End:0x0
[0000.161] I> ECC region[1]: Start:0x0, End:0x0
[0000.165] I> ECC region[2]: Start:0x0, End:0x0
[0000.170] I> ECC region[3]: Start:0x0, End:0x0
[0000.174] I> ECC region[4]: Start:0x0, End:0x0
[0000.178] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.184] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.188] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.192] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.197] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.202] E> FAILED: Thermal config
[0000.210] E> FAILED: MEMIO rail config
[0000.220] I> Boot-device: QSPI
[0000.223] I> Qspi flash params source = mb1bct
[0000.232] I> Qspi flash params source = mb1bct
[0000.243] I> Qspi flash params source = mb1bct
[0000.310] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.346] I> Qspi flash params source = mb1bct
[0000.358] I> MB1 done
??n enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
?000.366] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-aa987a31)
[0000.367] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.367] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.368] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.374] W> device prod register failed
[0000.378] I> Boot-device: QSPI
[0000.380] I> Boot_device: QSPI_FLASH instance: 0
[0000.386] I> QSPI Flash Size = 32 MB
[0000.388] I> Qspi initialized successfully
[0000.392] I> qspi flash-0 params source = boot args
[0000.774] I> sdmmc DDR50 mode
[0000.776] I> sdmmc-3 params source = safe params
[0000.780] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.781] W> Cannot find any partition table for 00000003
[0000.786] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.788] I> Active Boot chain : 0
[0000.789] I> parsing oem signed section of bpmp-fw header done
[0000.789] I> bpmp-fw binary init read from storage
[0000.790] I> oem authentication of bpmp-fw header done
[0000.803] I> bpmp-fw binary done read from storage
[0000.803] I> bpmp-fw: Authentication init Done
[0000.804] I> parsing oem signed section of cpubl header done
[0000.805] I> cpubl binary init read from storage
[0000.810] I> bpmp-fw: Authentication Finalize Done
[0000.815] I> oem authentication of cpubl header done
[0000.822] I> cpubl binary done read from storage
[0000.824] I> cpubl: Authentication init Done
[0000.828] I> parsing oem signed section of rce header done
[0000.833] I> rce binary init read from storage
[0000.838] I> Relocating BR-BCT
[0000.840] I> cpubl: Authentication Finalize Done
[0000.845] I> oem authentication of rce header done
[0000.850] I> rce binary done read from storage
[0000.854] I> rce: Authentication init Done
[0000.858] I> parsing oem signed section of ape header done
[0000.863] I> ape binary init read from storage
[0000.867] I> rce: Authentication Finalize Done
[0000.872] I> oem authentication of ape header done
[0000.876] I> ape binary done read from storage
[0000.880] I> ape: Authentication init Done
[0000.885] I> parsing oem signed section of tos header done
[0000.890] I> tos binary init read from storage
[0000.894] I> ape: Authentication Finalize Done
[0000.899] I> oem authentication of tos header done
[0000.905] I> tos binary done read from storage
[0000.907] I> tos: Authentication init Done
[0000.912] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.917] I> bpmp-fw-dtb binary init read from storage
[0000.922] I> tos: Authentication Finalize Done
[0000.928] I> oem authentication of bpmp-fw-dtb header done
[0000.932] I> bpmp-fw-dtb binary done read from storage
[0000.937] I> bpmp-fw-dtb: Authentication init Done
[0000.942] I> parsing oem signed section of cpubl-dtb header done
[0000.947] I> cpubl-dtb binary init read from storage
[0000.952] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.999] I> oem authentication of cpubl-dtb header done
[0001.000] I> cpubl-dtb binary done read from storage
[0001.000] I> cpubl-dtb: Authentication init Done
[0001.001] I> parsing oem signed section of eks header done
[0001.002] I> eks binary init read from storage
[0001.002] I> cpubl-dtb: Authentication Finalize Done
[0001.003] I> oem authentication of eks header done
[0001.008] I> eks binary done read from storage
[0001.012] I> eks: Authentication init Done
[0001.016] I> eks: Authentication Finalize Done
[0001.020] I> EKB detected (length: 0x410) @ VA:0x52714400
??TICE: BL31: v1.3(release):fe06da916
NOTICE: BL31: Built : 18:06:49, Apr 8 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
?001.361] I> Welcome to Cboot??q initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
[0001.362] I> Cboot Version: t194-d00c695c
[0001.364] I> CPU-BL Params @ 0xf2820000
[0001.367] I> 0) Base:0x00000000 Size:0x00000000
[0001.372] I> 1) Base:0xf1100000 Size:0x00100000
[0001.376] I> 2) Base:0xf2000000 Size:0x00200000
[0001.381] I> 3) Base:0xf1200000 Size:0x00200000
??k_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ??001.385] I> 4) Base:0xf1000000 Size:0x00100000
[0001.529] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.534] I> 6) Base:0xf3800000 Size:0x00400000
[0001.538] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.542] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.547] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.551] I> 10) Base:0xf3000000 Size:0x00800000
[0001.556] I> 11) Base:0x40000000 Size:0x00040000
[0001.560] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.565] I> 13) Base:0x40046000 Size:0x00002000
[0001.569] I> 14) Base:0x40048000 Size:0x00002000
[0001.574] I> 15) Base:0xac000000 Size:0x00004000
[0001.578] I> 16) Base:0x4004a000 Size:0x00002000
[0001.583] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.587] I> 18) Base:0x4004c000 Size:0x00002000
[0001.592] I> 19) Base:0xf2200000 Size:0x00600000
[0001.596] I> 20) Base:0x4004e000 Size:0x00002000
[0001.600] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.605] I> 22) Base:0x00000000 Size:0x00000000
[0001.609] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.614] I> 24) Base:0xf6000000 Size:0x02000000
[0001.618] I> 25) Base:0x40050000 Size:0x00002000
[0001.623] I> 26) Base:0x40040000 Size:0x00006000
[0001.627] I> 27) Base:0xf1800000 Size:0x00400000
[0001.632] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.636] I> 29) Base:0xf1400000 Size:0x00400000
[0001.641] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.645] I> 31) Base:0x00000000 Size:0x00000000
[0001.650] I> 32) Base:0xf8000000 Size:0x08000000
[0001.654] I> 33) Base:0x00000000 Size:0x00000000
[0001.659] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.663] I> 35) Base:0xab000000 Size:0x01000000
[0001.667] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.672] I> 37) Base:0xf2800000 Size:0x00800000
[0001.676] I> 38) Base:0x80000000 Size:0x20000000
[0001.681] I> 39) Base:0xb0000000 Size:0x08000000
[0001.685] I> 40) Base:0x00000000 Size:0x00000000
[0001.690] I> 41) Base:0x00000000 Size:0x00000000
[0001.694] I> 42) Base:0x00000000 Size:0x00000000
[0001.699] I> 43) Base:0x00000000 Size:0x00000000
[0001.703] I> 44) Base:0x00000000 Size:0x00000000
[0001.708] I> 45) Base:0x00000000 Size:0x00000000
[0001.712] GIC-SPI Target CPU: 0
[0001.715] Interrupts Init done
[0001.718] calling constructors
[0001.721] initializing heap
[0001.723] I> Heap: [0xa06905a8 … 0xab000000]
[0001.728] initializing threads
[0001.731] initializing timers
[0001.733] creating bootstrap completion thread
[0001.738] top of bootstrap2()
[0001.740] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.745] initializing platform
[0001.748] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.754] W> device prod register failed
[0001.757] I> Bl_dtb @0xaaf00000
[0001.763] E> “plugin-manager” doesn’t exist, creating
[0001.765] E> “ids” doesn’t exist, creating
[0001.769] E> “connection” doesn’t exist, creating
[0001.774] E> “configs” doesn’t exist, creating
[0001.782] I> Find /i2c@3160000’s alias i2c0
[0001.782] I> Reading eeprom i2c=0 address=0x50
[0001.812] I> Device at /i2c@3160000:0x50
[0001.812] I> Reading eeprom i2c=0 address=0x57
[0001.812] E> I2C: slave not found in slaves.
[0001.813] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.814] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.814] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.822] E> eeprom: Failed to read I2C slave device
[0001.826] I> Eeprom read failed 0x3526070d
[0001.832] I> Find /i2c@c240000’s alias i2c1
[0001.834] I> Reading eeprom i2c=1 address=0x50
[0001.840] E> I2C: slave not found in slaves.
[0001.843] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.851] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.856] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.866] E> eeprom: Retry to read I2C slave device.
[0001.871] E> I2C: slave not found in slaves.
[0001.875] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.883] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.888] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.898] E> eeprom: Failed to read I2C slave device
[0001.902] I> Eeprom read failed 0x3526070d
[0001.906] I> create_pm_ids: id: 3668-0001-200-G, len: 15
[0001.911] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.923] I> Adding plugin-manager/ids/3668-0001-200=/i2c@3160000:module@0x50
[0001.930] E> “i2c@3160000” doesn’t exist, creating
[0001.934] E> “module@0x50” doesn’t exist, creating
[0001.941] I> Adding plugin-manager/cvm
[0001.943] E> “chip-id” doesn’t exist, creating
[0001.947] I> Adding plugin-manager/chip-id/A02P
[0001.951] I> Plugin-manager override starting
[0001.957] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.965] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.970] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0001.978] I> Disable plugin-manager status in FDT
[0001.979] I> Plugin-manager override finished successfully
[0001.983] I> gpio framework initialized
[0001.987] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.995] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.002] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.009] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.016] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.023] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.030] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.036] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.044] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.051] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.058] I> fixed regulator driver initialized
[0002.066] I> register ‘maxim’ power off handle
[0002.066] I> virtual i2c enabled
[0002.069] I> registered ‘maxim,max20024’ pmic
[0002.074] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.080] I> Boot-device: QSPI
[0002.083] I> Boot_device: QSPI_FLASH instance: 0
[0002.088] I> QSPI source rate = 204000 Khz
[0002.091] I> Requested rate for QSPI clock = 34000 Khz
[0002.096] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.101] I> QSPI Flash Size = 32 MB
[0002.104] I> Qspi initialized successfully
[0002.108] I> qspi flash-0 params source = boot args
[0002.113] I> create_pm_ids: id: 3668-0001-200-G, len: 15
[0002.118] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.133] I> sdmmc-3 params source = safe params
[0002.135] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.155] W> Cannot find any partition table for 00000003
[0002.168] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.175] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.178] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.179] I> hdmi cable connected
[0002.180] E> set volts not configured for ‘vdd-1v0’
[0002.181] E> set volts not configured for ‘vdd-1v8-hs’
[0002.184] E> invalid display type
[0002.185] E> cannot find any other nvdisp nodes
[0002.200] I> edid read success
[0002.212] I> edid read success
[0002.213] I> width = 640, height = 480, frequency = 25174825
[0002.214] I> width = 640, height = 480, frequency = 25174825
[0002.214] I> width = 1366, height = 768, frequency = 85500000
[0002.218] I> width = 720, height = 576, frequency = 27000000
[0002.223] I> width = 720, height = 480, frequency = 26973026
[0002.229] I> width = 720, height = 480, frequency = 26973026
[0002.234] I> width = 720, height = 576, frequency = 26973026
[0002.240] I> width = 720, height = 576, frequency = 26973026
[0002.245] I> width = 1280, height = 720, frequency = 74175824
[0002.251] I> width = 1280, height = 720, frequency = 74175824
[0002.257] I> width = 1920, height = 1080, frequency = 148351648
[0002.262] I> width = 1920, height = 1080, frequency = 148351648
[0002.268] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.278] I> hdmi_enable, starting HDMI initialisation
[0002.283] I> hdmi_enable, HDMI initialisation complete
[0002.294] I> Load in CBoot Boot Options partition and parse it
[0002.296] E> Error -9 when finding node with path /boot-configuration
[0002.296] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.304] I> Hit any key to stop autoboot: 4 3 2 1
[0004.311] initializing target
[0004.311] calling apps_init()
[0004.312] starting app kernel_boot_app
[0004.318] I> found decompressor handler: lz4-legacy
[0004.318] I> decompressing BMP blob …
[0004.322] I> Kernel type = Normal
[0004.322] I> Loading kernel-bootctrl from partition
[0004.323] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.331] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.331] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.332] I> ########## SD boot ##########
[0004.337] I> Found sdcard
[0004.340] E> set volts not configured for ‘vddio-emmc-3v3’
[0004.349] E> Error in command_complete 18001 int_status
[0004.349] E> Sending CMD_SD_SEND_IF_COND failed
[0004.363] W> Error opening sdcard-2
[0004.364] I> -0 params source =
[0004.364] E> Failed to initialize device 6-0
[0004.364] E> SD boot failed, err: 252643078
[0004.368] I> ########## USB boot ##########
[0004.384] I> USB Firmware Version: 60.06 release
[0004.439] I> regulator of usb2-0 already enabled
[0004.443] I> regulator of usb2-1 already enabled
[0004.448] I> enabling ‘vdd-usb2-5v’ regulator
[0005.512] I> USB 2.0 port 2 new high-speed USB device detected
[0005.513] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.514] E> slot id is 1
[0005.515] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.522] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.524] I>
[0005.525] I> Enumerated USB Device 0bda:5411
[0005.529] I>
[0005.530] E> Enumerated device doesn’t belong to MSD class or protocol is not bulk-only!!
[0005.538] E> USBMSD: Failed to initialize Enumerated USB device either not an MSD device or supported protoco[0005.548] E> USBMSD: Failed to open usbmsd open, 0.
[0005.553] E> Error opening USBMSD driver 0, err: 7c7c0312
[0005.558] E> Failed to initialize device 5-0
[0005.562] E> USB boot failed, err: 2088502034
[0005.566] I> ########## Fixed storage boot ##########
[0005.571] I> Already published: 00010003
[0005.575] I> Look for boot partition
[0005.578] I> Fallback: assuming 0th partition is boot partition
[0005.584] I> Detect filesystem
[0005.611] I> Loading extlinux.conf …
[0005.611] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.648] I> L4T boot options
[0005.648] I> [1]: “primary kernel”
[0005.649] I> Enter choice:
[0008.650] I> Continuing with default option: 1
[0008.650] I> Loading kernel sig file from rootfs …
[0008.650] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.669] I> Loading kernel binary from rootfs …
[0008.669] I> rootfs path: /sdmmc_user/boot/Image
[0009.084] I> Validate kernel …
[0009.084] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.396] E> digest on binary did not match!!
[0009.397] C> OEM authentication of kernel payload failed!
[0009.397] W> Failed to validate kernel binary (err=1077936152, fail=0)
[0009.397] W> Security fuse not burned, ignore validation failure
[0009.405] I> No kernel-dtb binary path
[0009.405] I> A/B: bin_type (38) slot 0
[0009.405] I> Loading kernel-dtb from partition
[0009.406] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.423] I> Validate kernel-dtb …
[0009.423] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.426] I> Loading ramdisk from rootfs …
[0009.427] I> rootfs path: /sdmmc_user/boot/initrd
[0009.507] I> Kernel hdr @0xa4ac0000
[0009.507] I> Kernel dtb @0x90000000
[0009.508] I> decompressor handler not found
[0009.508] I> Copying kernel image (34408456 bytes) from 0xa4ac0000 to 0x80080000 … [0009.518] I> Done
[0009.519] I> Updated bpmp info to DTB
[0009.520] I> Ramdisk: Base: 0x92000000; Size: 0x54ec8f
[0009.520] I> Updated initrd info to DTB
[0009.521] W> WARN: Fail to override “console=none” in commandline
[0009.521] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.527] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.535] I> Active slot suffix:
[0009.538] I> add_boot_slot_suffix: slot_suffix =
0xa0696000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.580] I> Updated bootarg info to DTB
[0009.583] W> MAC addr invalid!
[0009.586] E> Failed to get WIFI MAC address
[0009.590] W> MAC addr invalid!
[0009.593] E> Failed to get Bluetooth MAC address
[0009.598] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:c5:d2
[0009.604] E> “plugin-manager” doesn’t exist, creating
[0009.609] I> Adding /chosen/plugin-manager/cvm
[0009.613] E> “chip-id” doesn’t exist, creating
[0009.617] I> Adding /chosen/plugin-manager/chip-id
[0009.622] E> “configs” doesn’t exist, creating
[0009.626] I> Adding /chosen/plugin-manager/configs
[0009.631] E> “ids” doesn’t exist, creating
[0009.635] I> Adding /chosen/plugin-manager/ids
[0009.639] E> “odm-data” doesn’t exist, creating
[0009.643] I> Adding /chosen/plugin-manager/odm-data
[0009.650] E> “memory” doesn’t exist, creating
[0009.653] I> [0] START: 0x80000000, END: 0xac000000
[0009.657] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.662] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.666] I> dram_block larger than 80000000
[0009.671] I> [3] START: 0x100000000, END: 0x280000000
[0009.675] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.681] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.687] I> added [base:0x100000000, size:0x180000000] to /memory
[0009.694] I> Updated memory info to DTB
[0009.697] E> add_disp_param: failed to get display params for du=1
[0009.703] E> “reset” doesn’t exist, creating
[0009.708] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.712] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.716] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.721] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.726] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.731] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.735] I> Deleted cpu@6 node in DT
[0009.739] I> Deleted cpu@7 node in DT
[0009.743] I> Deleted cluster3 node in FDT
[0009.747] I> Update arm-pmu in FDT
[0009.750] I> - update property: interrupts
[0009.753] I> - update property: interrupt-affinity
[0009.759] E> “misc-data” doesn’t exist, creating
[0009.763] I> Boot-device: QSPI
[0009.765] W> Unknown boot device
[0009.768] I> Add storage-qspi to plugin-manager/misc-data
[0009.774] W> Unknown storage device
[0009.777] I> Add serial number:1421720026747 as DT property
[0009.783] I> Plugin-manager override starting
[0009.787] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.794] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.800] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0009.807] I> Disable plugin-manager status in FDT
[0009.809] I> Plugin-manager override finished successfully
[0009.815] I> tegrabl_load_kernel_and_dtb: Done
[0009.837] I> QSPI: erasing sectors from 176 - 176
[0009.837] I> QSPI: recoverying tail blocks from 22536 - 22656
[0010.864] I> QSPI: erasing sectors from 177 - 177
[0010.865] I> QSPI: recoverying tail blocks from 22664 - 22784
[0011.897] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (root@lv) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #8 SMP PREEMPT Mon May 11 11:01:35 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069c000
[ 0.000000] Found lut_mem: 00002008@a0696000
??RNING: at platform/drivers/pg/pg-cv-t194.c:73
WARNING: at platform/drivers/pg/pg-cv-t194.c:73
WARNING: pll_d2 has no dyn ramp
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
?? 1.949893] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.949943] imx219 9-0010: board setup failed
[ 1.973821] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.973874] imx219 10-0010: board setup failed
[ 4.116003] cgroup: cgroup2: unknown option “nsdelegate”
??RNING: at platform/drivers/pg/pg-gpu-t194.c:185
?? 4.693555] random: crng init done
[ 4.693712] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.819036] mc-err: (255) csr_pcie5r: EMEM address decode error
[ 5.819227] mc-err: status = 0x200640e2; addr = 0xffffffff00; hi_adr_reg=ff08
[ 5.819395] mc-err: secure: yes, access-type: read
[ 5.819622] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000
[ 5.819646] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu1, iova=0x4ffe36000, fsynr=0x210003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=2610b5003, pte=0
[ 5.820277] mc-err: (255) csr_pcie5r: EMEM address decode error
[ 5.820431] mc-err: status = 0x200640e2; addr = 0xffffffff00; hi_adr_reg=ff08
[ 5.820599] mc-err: secure: yes, access-type: read
[ 5.820751] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000
[ 5.820770] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu1, iova=0x4ffe36000, fsynr=0x210003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=2610b5003, pte=0
[ 5.821728] mc-err: Too many MC errors; throttling prints
[ 5.822118] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu1, iova=0x4ffe36000, fsynr=0x210003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=2610b5003, pte=0
[ 5.837325] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu1, iova=0x4ffe36000, fsynr=0x210003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=2610b5003, pte=0
[ 5.854062] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu1, iova=0x4ffe36000, fsynr=0x210003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=2610b5003, pte=0
[ 5.870868] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu1, iova=0x4ffe36000, fsynr=0x210003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=2610b5003, pte=0
[ 5.956233] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu1, iova=0x4ffbd7000, fsynr=0x210003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=24ff44003, pte=0
[ 6.096454] systemd: 41 output lines suppressed due to ratelimiting
[ 8.112351] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 8.112783] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.260305] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got invalid poll event 16 on pipe (fd=61)
[ 8.260582] systemd[1]: proc-sys-fs-binfmt_misc.automount: Failed with result ‘resources’.
[ 9.094665] using random self ethernet address
Ubuntu 18.04.5 LTS nvidia-desktop ttyTCU0
nvidia-desktop login: [ 22.620935] mc-err: (255) csr_pcie5r1: EMEM address decode error
[ 22.621080] mc-err: status = 0x200640ef; addr = 0xffffffff00; hi_adr_reg=ff08
[ 22.621211] mc-err: secure: yes, access-type: read
[ 22.621311] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000
[ 22.621356] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu1, iova=0x4ffbdf000, fsynr=0x210003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=24ff44003, pte=0
[ 39.103687] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0x4fd93f000, fsynr=0x10003, cb=1, sid=91(0x5b - PCIE5), pgd=2610b4003, pud=2610b4003, pmd=203e16003, pte=0
[ 39.104454] mc-err: (255) csr_pcie5r: EMEM address decode error
[ 39.104582] mc-err: status = 0x200640e2; addr = 0xffffffff00; hi_adr_reg=ff08
[ 39.104745] mc-err: secure: yes, access-type: read
[ 39.104856] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000
nvidia-desktop login: NVIDIA
Password:
Login incorrect
nvidia-desktop login: nvidia
Password:
Last login: 四 5月 20 10:47:55 CST 2021 from 192.168.55.101 on pts/3
Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.9.140-tegra aarch64)
To restore this content, you can run the ‘unminimize’ command.
6 updates can be applied immediately.
1 of these updates is a standard security update.
To see these additional updates run: apt list --upgradable
*** System restart required ***
nvidia@nvidia-desktop:~$ sudo reboot
[ 354.803737] watchdog: watchdog0: watchdog did not stop!
[ 354.811556] systemd-shutdow: 20 output lines suppressed due to ratelimiting
?? 355.291448] reboot: Restarting system
?怢Shutdown state requested 1
Rebooting system …
[0000.058] I> rst_source : 0xb
[0000.061] I> rst_level : 0x1
[0000.085] I> Active Boot chain : 1
[0000.103] I> Temperature = 39000
[0000.106] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.111] W> Skipping boost for clk: BPMP_APB
[0000.115] W> Skipping boost for clk: AXI_CBB
[0000.119] W> Skipping boost for clk: AON_CPU_NIC
[0000.123] W> Skipping boost for clk: CAN1
[0000.127] W> Skipping boost for clk: CAN2
[0000.131] I> Boot-device: QSPI
[0000.134] I> Boot-device: QSPI
[0000.136] I> Qspi flash params source = mb1bct
[0000.141] I> Qspi using bpmp-dma
[0000.143] I> Qspi clock source : pllc_out0
[0000.147] I> Qspi reinitialized
[0000.150] I> Qspi flash params source = mb1bct
[0000.156] I> ECC region[0]: Start:0x0, End:0x0
[0000.160] I> ECC region[1]: Start:0x0, End:0x0
[0000.164] I> ECC region[2]: Start:0x0, End:0x0
[0000.168] I> ECC region[3]: Start:0x0, End:0x0
[0000.172] I> ECC region[4]: Start:0x0, End:0x0
[0000.176] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.182] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.186] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.191] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.195] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.201] E> FAILED: Thermal config
[0000.208] E> FAILED: MEMIO rail config
[0000.218] I> Boot-device: QSPI
[0000.221] I> Qspi flash params source = mb1bct
[0000.230] I> Qspi flash params source = mb1bct
[0000.242] I> Qspi flash params source = mb1bct
[0000.309] I> Qspi flash params source = mb1bct
[0000.318] I> Qspi flash params source = mb1bct
[0000.345] I> Qspi flash params source = mb1bct
[0000.356] I> MB1 done
??n enter
HW Function test
Start Scheduler.
in late init
?000.365] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-389501e9)
[0000.365] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.366] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.366] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.372] W> device prod register failed
[0000.376] I> Boot-device: QSPI
[0000.379] I> Boot_device: QSPI_FLASH instance: 0
[0000.384] I> QSPI Flash Size = 32 MB
[0000.390] I> Qspi initialized successfully
[0000.391] I> qspi flash-0 params source = boot args
[0000.717] I> sdmmc DDR50 mode
[0000.719] I> sdmmc-3 params source = safe params
[0000.723] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.725] W> Cannot find any partition table for 00000003
[0000.727] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.728] I> Active Boot chain : 1
[0000.729] I> parsing oem signed section of bpmp-fw header done
[0000.729] I> bpmp-fw binary init read from storage
[0000.730] I> oem authentication of bpmp-fw header done
[0000.744] I> bpmp-fw binary done read from storage
[0000.744] I> bpmp-fw: Authentication init Done
[0000.745] I> parsing oem signed section of cpubl header done
[0000.749] I> cpubl binary init read from storage
[0000.753] I> bpmp-fw: Authentication Finalize Done
[0000.758] I> oem authentication of cpubl header done
[0000.765] I> cpubl binary done read from storage
[0000.767] I> cpubl: Authentication init Done
[0000.772] I> parsing oem signed section of rce header done
[0000.777] I> rce binary init read from storage
[0000.781] I> Relocating BR-BCT
[0000.784] I> cpubl: Authentication Finalize Done
[0000.789] I> oem authentication of rce header done
[0000.793] I> rce binary done read from storage
[0000.797] I> rce: Authentication init Done
[0000.802] I> parsing oem signed section of ape header done
[0000.807] I> ape binary init read from storage
[0000.811] I> rce: Authentication Finalize Done
[0000.815] I> oem authentication of ape header done
[0000.820] I> ape binary done read from storage
[0000.824] I> ape: Authentication init Done
[0000.828] I> parsing oem signed section of tos header done
[0000.833] I> tos binary init read from storage
[0000.838] I> ape: Authentication Finalize Done
[0000.842] I> oem authentication of tos header done
[0000.848] I> tos binary done read from storage
[0000.851] I> tos: Authentication init Done
[0000.855] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.861] I> bpmp-fw-dtb binary init read from storage
[0000.866] I> tos: Authentication Finalize Done
[0000.872] I> oem authentication of bpmp-fw-dtb header done
[0000.875] I> bpmp-fw-dtb binary done read from storage
[0000.880] I> bpmp-fw-dtb: Authentication init Done
[0000.885] I> parsing oem signed section of cpubl-dtb header done
[0000.891] I> cpubl-dtb binary init read from storage
[0000.896] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.953] I> oem authentication of cpubl-dtb header done
[0000.954] I> cpubl-dtb binary done read from storage
[0000.955] I> cpubl-dtb: Authentication init Done
[0000.956] I> parsing oem signed section of eks header done
[0000.956] I> eks binary init read from storage
[0000.957] I> cpubl-dtb: Authentication Finalize Done
[0000.958] I> oem authentication of eks header done
[0000.962] I> eks binary done read from storage
[0000.966] I> eks: Authentication init Done
[0000.970] I> eks: Authentication Finalize Done
[0000.974] I> EKB detected (length: 0x410) @ VA:0x52714400
??TICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 20:51:20, Oct 27 2020
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
mrq initialized
?001.317] I> Welcome to Cboot
??RNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
??001.317] I> Cboot Version: t194-aad9d75e
[0001.319] I> CPU-BL Params @ 0xf2820000
[0001.323] I> 0) Base:0x00000000 Size:0x00000000
[0001.327] I> 1) Base:0xf1100000 Size:0x00100000
??k_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ??001.331] I> 2) Base:0xf2000000 Size:0x00200000
[0001.511] I> 3) Base:0xf1200000 Size:0x00200000
[0001.516] I> 4) Base:0xf1000000 Size:0x00100000
[0001.520] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.524] I> 6) Base:0xf3800000 Size:0x00400000
[0001.529] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.533] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.538] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.542] I> 10) Base:0xf3000000 Size:0x00800000
[0001.547] I> 11) Base:0x40000000 Size:0x00040000
[0001.551] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.556] I> 13) Base:0x40046000 Size:0x00002000
[0001.560] I> 14) Base:0x40048000 Size:0x00002000
[0001.565] I> 15) Base:0xac000000 Size:0x00004000
[0001.569] I> 16) Base:0x4004a000 Size:0x00002000
[0001.574] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.578] I> 18) Base:0x4004c000 Size:0x00002000
[0001.582] I> 19) Base:0xf2200000 Size:0x00600000
[0001.587] I> 20) Base:0x4004e000 Size:0x00002000
[0001.591] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.596] I> 22) Base:0x00000000 Size:0x00000000
[0001.600] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.605] I> 24) Base:0xf6000000 Size:0x02000000
[0001.609] I> 25) Base:0x40050000 Size:0x00002000
[0001.614] I> 26) Base:0x40040000 Size:0x00006000
[0001.618] I> 27) Base:0xf1800000 Size:0x00400000
[0001.623] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.627] I> 29) Base:0xf1400000 Size:0x00400000
[0001.632] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.636] I> 31) Base:0x00000000 Size:0x00000000
[0001.640] I> 32) Base:0xf8000000 Size:0x08000000
[0001.645] I> 33) Base:0x00000000 Size:0x00000000
[0001.649] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.654] I> 35) Base:0xab000000 Size:0x01000000
[0001.658] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.663] I> 37) Base:0xf2800000 Size:0x00800000
[0001.667] I> 38) Base:0x80000000 Size:0x20000000
[0001.672] I> 39) Base:0xb0000000 Size:0x08000000
[0001.676] I> 40) Base:0x00000000 Size:0x00000000
[0001.681] I> 41) Base:0x00000000 Size:0x00000000
[0001.685] I> 42) Base:0x00000000 Size:0x00000000
[0001.690] I> 43) Base:0x00000000 Size:0x00000000
[0001.694] I> 44) Base:0x00000000 Size:0x00000000
[0001.698] I> 45) Base:0x00000000 Size:0x00000000
[0001.703] GIC-SPI Target CPU: 0
[0001.706] Interrupts Init done
[0001.709] calling constructors
[0001.712] initializing heap
[0001.714] I> Heap: [0xa0691568 … 0xab000000]
[0001.719] initializing threads
[0001.722] initializing timers
[0001.724] creating bootstrap completion thread
[0001.729] top of bootstrap2()
[0001.731] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.736] initializing platform
[0001.739] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.744] W> device prod register failed
[0001.748] I> Bl_dtb @0xaaf00000
[0001.754] W> “plugin-manager” doesn’t exist, creating
[0001.756] W> “ids” doesn’t exist, creating
[0001.760] W> “connection” doesn’t exist, creating
[0001.765] W> “configs” doesn’t exist, creating
[0001.775] I> Find /i2c@3160000’s alias i2c0
[0001.775] I> Reading eeprom i2c=0 address=0x50
[0001.802] I> Device at /i2c@3160000:0x50
[0001.803] I> Reading eeprom i2c=0 address=0x57
[0001.803] E> I2C: slave not found in slaves.
[0001.804] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.805] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.805] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.812] E> eeprom: Failed to read I2C slave device
[0001.817] I> Eeprom read failed 0x3526070d
[0001.823] I> Find /i2c@c240000’s alias i2c1
[0001.825] I> Reading eeprom i2c=1 address=0x50
[0001.831] E> I2C: slave not found in slaves.
[0001.834] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.842] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.847] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.857] E> eeprom: Retry to read I2C slave device.
[0001.861] E> I2C: slave not found in slaves.
[0001.865] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.873] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.879] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.888] E> eeprom: Failed to read I2C slave device
[0001.893] I> Eeprom read failed 0x3526070d
[0001.897] I> create_pm_ids: id: 3668-0001-200-G, len: 15
[0001.902] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.913] I> Adding plugin-manager/ids/3668-0001-200=/i2c@3160000:module@0x50
[0001.921] W> “i2c@3160000” doesn’t exist, creating
[0001.925] W> “module@0x50” doesn’t exist, creating
[0001.932] I> Adding plugin-manager/cvm
[0001.933] W> “chip-id” doesn’t exist, creating
[0001.938] I> Adding plugin-manager/chip-id/A02P
[0001.942] I> Plugin-manager override starting
[0001.947] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.956] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.960] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0001.969] I> Disable plugin-manager status in FDT
[0001.969] I> Plugin-manager override finished successfully
[0001.974] I> gpio framework initialized
[0001.979] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.986] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0001.993] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.000] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.008] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.014] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.020] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.028] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.035] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.042] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.049] I> fixed regulator driver initialized
[0002.058] I> register ‘maxim’ power off handle
[0002.059] I> virtual i2c enabled
[0002.060] I> registered ‘maxim,max20024’ pmic
[0002.064] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.071] I> Boot-device: QSPI
[0002.074] I> Boot_device: QSPI_FLASH instance: 0
[0002.079] I> QSPI source rate = 204000 Khz
[0002.082] I> Requested rate for QSPI clock = 34000 Khz
[0002.087] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.092] I> QSPI Flash Size = 32 MB
[0002.100] I> Qspi initialized successfully
[0002.100] I> qspi flash-0 params source = boot args
[0002.104] I> create_pm_ids: id: 3668-0001-200-G, len: 15
[0002.109] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.124] I> sdmmc-3 params source = safe params
[0002.126] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.146] W> Cannot find any partition table for 00000003
[0002.159] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.167] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.172] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.172] I> hdmi cable connected
[0002.174] W> set volts not configured for ‘vdd-1v0’
[0002.175] W> set volts not configured for ‘vdd-1v8-hs’
[0002.178] E> invalid display type
[0002.179] E> cannot find any other nvdisp nodes
[0002.194] I> edid read success
[0002.207] I> edid read success
[0002.207] I> width = 640, height = 480, frequency = 25174825
[0002.208] I> width = 640, height = 480, frequency = 25174825
[0002.209] I> width = 1366, height = 768, frequency = 85500000
[0002.212] I> width = 720, height = 576, frequency = 27000000
[0002.218] I> width = 720, height = 480, frequency = 26973026
[0002.229] I> width = 720, height = 576, frequency = 26973026
[0002.240] I> width = 1280, height = 720, frequency = 74175824
[0002.246] I> width = 1280, height = 720, frequency = 74175824
[0002.251] I> width = 1920, height = 1080, frequency = 148351648
[0002.263] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.273] I> hdmi_enable, starting HDMI initialisation
[0002.278] I> hdmi_enable, HDMI initialisation complete
[0002.287] I> Load in CBoot Boot Options partition and parse it
[0002.288] E> Error -9 when finding node with path /boot-configuration
[0002.291] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.298] I> Hit any key to stop autoboot: 4 3 2 1
[0004.306] initializing target
[0004.306] calling apps_init()
[0004.307] starting app kernel_boot_app
[0004.313] I> found decompressor handler: lz4-legacy
[0004.313] I> decompressing BMP blob …
[0004.317] I> Kernel type = Normal
[0004.317] I> Loading kernel-bootctrl from partition
[0004.317] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.327] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.328] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.328] I> ########## SD boot ##########
[0004.332] W> Error: failed to get sd-card params
[0004.336] I> -0 params source =
[0004.339] E> Failed to initialize device 6-0
[0004.343] E> SD boot failed, err: 252641293
[0004.347] I> ########## USB boot ##########
[0004.363] I> USB Firmware Version: 60.06 release
[0004.418] I> regulator of usb2-0 already enabled
[0004.423] I> regulator of usb2-1 already enabled
[0004.427] I> regulator of usb2-2 already enabled
[0005.493] I> USB 2.0 port 2 new high-speed USB device detected
[0005.495] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.596] I> Start to enumerate device
[0005.597] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.604] I>
[0005.604] I> Enumerated USB Device 0bda:5411
[0005.604] I>
[0005.606] I> Hub:
[0005.606] I> Downstream ports : 4
[0005.606] I> Power switching : Ganged
[0005.606] I> Compound device : No
[0005.607] I> Over-current protection : Global
[0005.609] I> Hub avg delay : 4 ns
[0005.613] I> Set interface = 1 (alt setting)
[0005.618] I> Enable hub ports
[0005.627] I> Device detected on port 3
[0005.628] I> Device detected on port 4
[0006.139] I> Reset port 3
[0006.193] I> Port 3 device is low speed, skip enumeration
[0006.196] I> Reset port 4
[0006.250] I> Port 4 device is low speed, skip enumeration
[0006.251] E> Enumerated device doesn’t belong to MSD class or protocol is not bulk-only!!
[0006.251] E> USBMSD: Failed to initialize Enumerated USB device either not an MSD device or supported protoco[0006.252] E> USBMSD: Failed to open usbmsd open, 0.
[0006.253] E> Error opening USBMSD driver 0, err: 7c7c0312
[0006.258] E> Failed to initialize device 5-0
[0006.262] E> USB boot failed, err: 2088502034
[0006.266] I> ########## Fixed storage boot ##########
[0006.271] I> Already published: 00010003
[0006.275] I> Look for boot partition
[0006.278] I> Fallback: assuming 0th partition is boot partition
[0006.284] I> Detect filesystem
[0006.311] I> Loading extlinux.conf …
[0006.312] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0006.348] I> L4T boot options
[0006.349] I> [1]: “primary kernel”
[0006.349] I> Enter choice:
[0009.350] I> Continuing with default option: 1
[0009.350] I> Loading kernel sig file from rootfs …
[0009.350] I> rootfs path: /sdmmc_user/boot/Image.sig
[0009.369] I> Loading kernel binary from rootfs …
[0009.369] I> rootfs path: /sdmmc_user/boot/Image
[0009.784] I> Validate kernel …
[0009.785] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.097] E> digest on binary did not match!!
[0010.097] C> OEM authentication of kernel payload failed!
[0010.097] W> Failed to validate kernel binary (err=1077936152, fail=0)
[0010.098] W> Security fuse not burned, ignore validation failure
[0010.105] I> No kernel-dtb binary path
[0010.105] I> A/B: bin_type (38) slot 1
[0010.106] I> Loading kernel-dtb_b from partition
[0010.106] I> Loading partition kernel-dtb_b at 0x91000000 from device(0x1)
[0010.123] I> Validate kernel-dtb …
[0010.123] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.126] I> Loading ramdisk from rootfs …
[0010.127] I> rootfs path: /sdmmc_user/boot/initrd
[0010.208] I> Kernel hdr @0xa4ac0000
[0010.208] I> Kernel dtb @0x90000000
[0010.208] I> decompressor handler not found
[0010.208] I> Copying kernel image (34408456 bytes) from 0xa4ac0000 to 0x80080000 … [0010.219] I> Done
[0010.219] I> Updated bpmp info to DTB
[0010.220] I> Ramdisk: Base: 0x92000000; Size: 0x54ec8f
[0010.221] I> Updated initrd info to DTB
[0010.221] W> WARN: Fail to override “console=none” in commandline
[0010.222] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.228] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.235] I> Active slot suffix: _b
[0010.238] I> add_boot_slot_suffix: slot_suffix = _b
[0010.273] I> Updated bootarg info to DTB
[0010.277] W> MAC addr invalid!
[0010.280] E> Failed to get WIFI MAC address
[0010.284] W> MAC addr invalid!
[0010.286] E> Failed to get Bluetooth MAC address
[0010.291] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:c5:d2
[0010.297] W> “plugin-manager” doesn’t exist, creating
[0010.302] I> Adding /chosen/plugin-manager/cvm
[0010.306] W> “chip-id” doesn’t exist, creating
[0010.310] I> Adding /chosen/plugin-manager/chip-id
[0010.315] W> “configs” doesn’t exist, creating
[0010.319] I> Adding /chosen/plugin-manager/configs
[0010.324] W> “ids” doesn’t exist, creating
[0010.328] I> Adding /chosen/plugin-manager/ids
[0010.332] W> “odm-data” doesn’t exist, creating
[0010.337] I> Adding /chosen/plugin-manager/odm-data
[0010.344] W> “memory” doesn’t exist, creating
[0010.346] I> [0] START: 0x80000000, END: 0xac000000
[0010.350] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.355] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.360] I> dram_block larger than 80000000
[0010.364] I> [3] START: 0x100000000, END: 0x280000000
[0010.369] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.375] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.380] I> added [base:0x100000000, size:0x180000000] to /memory
[0010.387] I> Updated memory info to DTB
[0010.390] E> add_disp_param: failed to get display params for du=1
[0010.396] W> “reset” doesn’t exist, creating
[0010.401] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.405] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.410] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.414] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.419] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.424] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.429] I> Deleted cpu@6 node in DT
[0010.432] I> Deleted cpu@7 node in DT
[0010.436] I> Deleted cluster3 node in FDT
[0010.440] I> Update arm-pmu in FDT
[0010.443] I> - update property: interrupts
[0010.447] I> - update property: interrupt-affinity
[0010.452] W> “misc-data” doesn’t exist, creating
[0010.456] I> Boot-device: QSPI
[0010.459] W> Unknown boot device
[0010.462] I> Add storage-qspi to plugin-manager/misc-data
[0010.467] W> Unknown storage device
[0010.471] I> Add serial number:1421720026747 as DT property
[0010.477] I> Plugin-manager override starting
[0010.480] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.487] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.493] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0010.500] I> Disable plugin-manager status in FDT
[0010.502] I> Plugin-manager override finished successfully
[0010.508] I> tegrabl_load_kernel_and_dtb: Done
[0010.530] I> QSPI: erasing sectors from 176 - 176
[0010.530] I> QSPI: recoverying tail blocks from 22536 - 22656
[0011.175] I> QSPI: erasing sectors from 177 - 177
[0011.175] I> QSPI: recoverying tail blocks from 22664 - 22784
[0011.829] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Found lut_mem: 00002008@a0698000
?? 1.977911] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.977958] imx219 9-0010: board setup failed
[ 2.001887] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.001935] imx219 10-0010: board setup failed
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
[END] 2021/5/21 11:10:33
in this log, there are three power record. First time startup fail, Second time is success, Third time is fail
