I am working on a yocto distribution for jetson NX. I got the basic system working and now trying to work on secure boot.
I am working of R32.5.0. I tried secureboot with nvidia ubuntu distro and it boots. But using the same jetson NX with the same keys under yocto distribution after I got the signing working the board is stuck in boot loop.
I can’t see anything obvious in the logs. Any ideas would be highly appreciated :)
[0000.033] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.042] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.047] I> Boot-mode: Coldboot
[0000.050] I> Chip revision : A02P
[0000.053] I> Bootrom patch version : 15 (correctly patched)
[0000.058] I> ATE fuse revision : 0x200
[0000.062] I> Ram repair fuse : 0x0
[0000.065] I> Ram Code : 0x0
[0000.067] I> rst_source : 0x0
[0000.070] I> rst_level : 0x0
[0000.074] I> Boot-device: QSPI
[0000.076] I> Qspi flash params source = brbct
[0000.080] I> Qspi using bpmp-dma
[0000.083] I> Qspi clock source : pllp
[0000.087] I> QSPI Flash Size = 32 MB
[0000.090] I> Qspi initialized successfully
[0000.094] W> No valid slot number is found in scratch register
[0000.100] W> Return default slot: _a
[0000.103] I> Active Boot chain : 0
[0000.106] I> Boot-device: QSPI
[0000.109] I> Qspi flash params source = brbct
[0000.116] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.124] I> Temperature = 55000
[0000.127] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.131] W> Skipping boost for clk: BPMP_APB
[0000.135] W> Skipping boost for clk: AXI_CBB
[0000.139] W> Skipping boost for clk: AON_CPU_NIC
[0000.143] W> Skipping boost for clk: CAN1
[0000.147] W> Skipping boost for clk: CAN2
[0000.151] I> Boot-device: QSPI
[0000.154] I> Boot-device: QSPI
[0000.157] I> Qspi flash params source = mb1bct
[0000.161] I> Qspi using bpmp-dma
[0000.164] I> Qspi clock source : pllc_out0
[0000.168] I> Qspi reinitialized
[0000.171] I> Qspi flash params source = mb1bct
[0000.177] I> ECC region[0]: Start:0x0, End:0x0
[0000.181] I> ECC region[1]: Start:0x0, End:0x0
[0000.186] I> ECC region[2]: Start:0x0, End:0x0
[0000.190] I> ECC region[3]: Start:0x0, End:0x0
[0000.194] I> ECC region[4]: Start:0x0, End:0x0
[0000.198] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.204] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.208] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.213] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.217] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.222] E> FAILED: Thermal config
[0000.230] E> FAILED: MEMIO rail config
[0000.240] I> Boot-device: QSPI
[0000.243] I> Qspi flash params source = mb1bct
[0000.254] I> Qspi flash params source = mb1bct
[0000.268] I> Qspi flash params source = mb1bct
[0000.350] I> Qspi flash params source = mb1bct
[0000.361] I> Qspi flash params source = mb1bct
[0000.393] I> Qspi flash params source = mb1bct
[0000.407] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.415] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-7515048c)
[0000.416] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.417] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.417] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.423] W> device prod register failed
[0000.427] I> Boot-device: QSPI
[0000.430] I> Boot_device: QSPI_FLASH instance: 0
[0000.435] I> QSPI Flash Size = 32 MB
[0000.441] I> Qspi initialized successfully
[0000.442] I> qspi flash-0 params source = boot args
[0000.826] I> sdmmc DDR50 mode
[0000.828] I> sdmmc-3 params source = safe params
[0000.833] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.835] W> Cannot find any partition table for 00000003
[0000.844] I> Found 14 partitions in SDMMC_USER (instance 3)
[0000.845] W> No valid slot number is found in scratch register
[0000.846] W> Return default slot: _a
[0000.846] I> Active Boot chain : 0
[0000.847] I> parsing oem signed section of bpmp-fw header done
[0000.848] I> bpmp-fw binary init read from storage
[0000.851] I> RSA PSS signature check: OK
[0000.851] I> oem authentication of bpmp-fw header done
[0000.865] I> bpmp-fw binary done read from storage
[0000.866] I> bpmp-fw: Authentication init Done
[0000.867] I> parsing oem signed section of cpubl header done
[0000.870] I> cpubl binary init read from storage
[0000.879] I> bpmp-fw: Authentication Finalize Done
[0000.882] I> RSA PSS signature check: OK
[0000.883] I> oem authentication of cpubl header done
[0000.891] I> cpubl binary done read from storage
[0000.892] I> cpubl: Authentication init Done
[0000.897] I> parsing oem signed section of rce header done
[0000.902] I> rce binary init read from storage
[0000.906] I> Relocating BR-BCT
[0000.912] I> cpubl: Authentication Finalize Done
[0000.916] I> RSA PSS signature check: OK
[0000.917] I> oem authentication of rce header done
[0000.922] I> rce binary done read from storage
[0000.926] I> rce: Authentication init Done
[0000.931] I> parsing oem signed section of ape header done
[0000.936] I> ape binary init read from storage
[0000.942] I> rce: Authentication Finalize Done
[0000.946] I> RSA PSS signature check: OK
[0000.948] I> oem authentication of ape header done
[0000.953] I> ape binary done read from storage
[0000.957] I> ape: Authentication init Done
[0000.961] I> parsing oem signed section of tos header done
[0000.966] I> tos binary init read from storage
[0000.971] I> ape: Authentication Finalize Done
[0000.977] I> RSA PSS signature check: OK
[0000.978] I> oem authentication of tos header done
[0000.985] I> tos binary done read from storage
[0000.987] I> tos: Authentication init Done
[0000.992] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.997] I> bpmp-fw-dtb binary init read from storage
[0001.004] I> tos: Authentication Finalize Done
[0001.010] I> RSA PSS signature check: OK
[0001.011] I> oem authentication of bpmp-fw-dtb header done
[0001.016] I> bpmp-fw-dtb binary done read from storage
[0001.021] I> bpmp-fw-dtb: Authentication init Done
[0001.026] I> parsing oem signed section of cpubl-dtb header done
[0001.031] I> cpubl-dtb binary init read from storage
[0001.037] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.096] I> RSA PSS signature check: OK
[0001.096] I> oem authentication of cpubl-dtb header done
[0001.097] I> cpubl-dtb binary done read from storage
[0001.097] I> cpubl-dtb: Authentication init Done
[0001.098] I> parsing oem signed section of eks header done
[0001.099] I> eks binary init read from storage
[0001.101] I> cpubl-dtb: Authentication Finalize Done
[0001.106] I> RSA PSS signature check: OK
[0001.107] I> oem authentication of eks header done
[0001.112] I> eks binary done read from storage
[0001.116] I> eks: Authentication init Done
[0001.121] I> eks: Authentication Finalize Done
[0001.124] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:54:10, Jul 9 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 162: ekb_verification: EKB_CMAC verification is not match.
hwkey-agent: 240: key_mgnt_processing: failed (-7)
hwkey-agent: 44: main: Failed to verify or extract EKB (-7).
exit called, thread 0xffffffffea8a2d58, name trusty_app_2_92b92883-f96a-4177
luks-srv: 40: luks-srv is running!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
��mrq initialized
��[0001.466] I> Welcome to Cboot
��WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
��[0001.466] I> Cboot Version: 32.05.02-evologics-t194-a4996282
[0001.470] I> CPU-BL Params @ 0xf2820000
[0001.474] I> 0) Base:0x00000000 Size:0x00000000
[0001.478] I> 1) Base:0xf1100000 Size:0x00100000
[0001.483] I> 2) Base:0xf2000000 Size:0x00200000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.487] I> 3) Base:0xf1200000 Size:0x00200000
[0001.641] I> 4) Base:0xf1000000 Size:0x00100000
[0001.646] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.650] I> 6) Base:0xf3800000 Size:0x00400000
[0001.655] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.659] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.663] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.668] I> 10) Base:0xf3000000 Size:0x00800000
[0001.672] I> 11) Base:0x40000000 Size:0x00040000
[0001.677] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.681] I> 13) Base:0x40046000 Size:0x00002000
[0001.686] I> 14) Base:0x40048000 Size:0x00002000
[0001.690] I> 15) Base:0xac000000 Size:0x00004000
[0001.695] I> 16) Base:0x4004a000 Size:0x00002000
[0001.699] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.704] I> 18) Base:0x4004c000 Size:0x00002000
[0001.708] I> 19) Base:0xf2200000 Size:0x00600000
[0001.713] I> 20) Base:0x4004e000 Size:0x00002000
[0001.717] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.721] I> 22) Base:0x00000000 Size:0x00000000
[0001.726] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.730] I> 24) Base:0xf6000000 Size:0x02000000
[0001.735] I> 25) Base:0x40050000 Size:0x00002000
[0001.739] I> 26) Base:0x40040000 Size:0x00006000
[0001.744] I> 27) Base:0xf1800000 Size:0x00400000
[0001.748] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.753] I> 29) Base:0xf1400000 Size:0x00400000
[0001.757] I> 30) Base:0x00000000 Size:0x00000000
[0001.762] I> 31) Base:0x00000000 Size:0x00000000
[0001.766] I> 32) Base:0xf8000000 Size:0x08000000
[0001.771] I> 33) Base:0x00000000 Size:0x00000000
[0001.775] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.780] I> 35) Base:0xab000000 Size:0x01000000
[0001.784] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.788] I> 37) Base:0xf2800000 Size:0x00800000
[0001.793] I> 38) Base:0x80000000 Size:0x20000000
[0001.797] I> 39) Base:0xb0000000 Size:0x08000000
[0001.802] I> 40) Base:0x00000000 Size:0x00000000
[0001.806] I> 41) Base:0x00000000 Size:0x00000000
[0001.811] I> 42) Base:0x00000000 Size:0x00000000
[0001.815] I> 43) Base:0x00000000 Size:0x00000000
[0001.820] I> 44) Base:0x00000000 Size:0x00000000
[0001.824] I> 45) Base:0x00000000 Size:0x00000000
[0001.829] GIC-SPI Target CPU: 0
[0001.832] Interrupts Init done
[0001.834] calling constructors
[0001.837] initializing heap
[0001.840] I> Heap: [0xa0695618 ... 0xab000000]
[0001.844] initializing threads
[0001.847] initializing timers
[0001.850] creating bootstrap completion thread
[0001.854] top of bootstrap2()
[0001.857] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.862] initializing platform
[0001.865] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.870] W> device prod register failed
[0001.874] I> Bl_dtb @0xaaf00000
[0001.879] W> "plugin-manager" doesn't exist, creating
[0001.882] W> "ids" doesn't exist, creating
[0001.886] W> "connection" doesn't exist, creating
[0001.890] W> "configs" doesn't exist, creating
[0001.900] I> Find /i2c@3160000's alias i2c0
[0001.900] I> Reading eeprom i2c=0 address=0x50
[0001.928] I> Device at /i2c@3160000:0x50
[0001.928] I> Reading eeprom i2c=0 address=0x57
[0001.953] I> Device at /i2c@3160000:0x57
[0001.954] I> Find /i2c@c240000's alias i2c1
[0001.955] I> Reading eeprom i2c=1 address=0x50
[0001.956] E> I2C: slave not found in slaves.
[0001.957] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.958] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.958] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.967] E> eeprom: Retry to read I2C slave device.
[0001.972] E> I2C: slave not found in slaves.
[0001.976] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.984] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.989] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.999] E> eeprom: Failed to read I2C slave device
[0002.004] I> Eeprom read failed 0x3526070d
[0002.008] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0002.013] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.024] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0002.029] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.040] I> Adding plugin-manager/ids/3668-0001-300=/i2c@3160000:module@0x50
[0002.048] W> "i2c@3160000" doesn't exist, creating
[0002.052] W> "module@0x50" doesn't exist, creating
[0002.056] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0002.063] W> "module@0x57" doesn't exist, creating
[0002.069] I> Adding plugin-manager/cvm
[0002.072] W> "chip-id" doesn't exist, creating
[0002.076] I> Adding plugin-manager/chip-id/A02P
[0002.080] I> Plugin-manager override starting
[0002.085] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.096] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.100] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0002.105] I> Disable plugin-manager status in FDT
[0002.107] I> Plugin-manager override finished successfully
[0002.112] I> gpio framework initialized
[0002.117] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.124] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.131] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.138] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.146] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.153] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.159] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.165] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.173] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.180] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.187] I> fixed regulator driver initialized
[0002.194] I> register 'maxim' power off handle
[0002.195] I> virtual i2c enabled
[0002.198] I> registered 'maxim,max20024' pmic
[0002.202] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.209] I> Boot-device: QSPI
[0002.212] I> Boot_device: QSPI_FLASH instance: 0
[0002.217] I> QSPI source rate = 204000 Khz
[0002.220] I> Requested rate for QSPI clock = 34000 Khz
[0002.225] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.230] I> QSPI Flash Size = 32 MB
[0002.238] I> Qspi initialized successfully
[0002.238] I> qspi flash-0 params source = boot args
[0002.242] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0002.247] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.258] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0002.263] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.279] I> sdmmc-3 params source = safe params
[0002.281] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.300] W> Cannot find any partition table for 00000003
[0002.313] I> Found 14 partitions in SDMMC_USER (instance 3)
[0002.316] E> cannot find any other nvdisp nodes
[0002.317] E> no valid display unit config found in dtb
[0002.318] W> display init failed
[0002.318] I> Load in CBoot Boot Options partition and parse it
[0002.319] W> No valid slot number is found in scratch register
[0002.319] W> Return default slot: _a
[0002.322] I> Active slot suffix:
[0002.326] I> boot-order :-
[0002.328] I> 1.sd
[0002.330] I> 2.emmc
[0002.332] W> parse_ip_info: tftp-server-ip info not found in CBO options file
[0002.339] W> parse_ip_info: static-ip info not found in CBO options file
[0002.345] W> Failed to parse GUID
[0002.348] I> boot-dev-order :-
[0002.351] I> 1.sd
[0002.353] I> 2.emmc
[0002.355] I> Hit any key to stop autoboot: 4 3 2 1
[0004.363] initializing target
[0004.363] calling apps_init()
[0004.364] starting app kernel_boot_app
[0004.365] W> No valid slot number is found in scratch register
[0004.366] W> Return default slot: _a
[0004.375] I> found decompressor handler: lz4-legacy
[0004.376] I> decompressing BMP blob ...
[0004.388] I> Kernel type = Normal
[0004.388] I> Loading kernel-bootctrl from partition
[0004.389] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x1)
[0004.397] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.397] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.398] I> ########## SD (0) boot ##########
[0004.399] W> Error: failed to get sd-card params
[0004.402] I> -0 params source =
[0004.405] W> Failed to initialize device 6-0
[0004.409] E> SD boot failed, err: 252641293
[0004.413] I> ########## Fixed storage boot ##########
[0004.418] I> Already published: 00010003
[0004.422] I> Look for boot partition
[0004.425] I> Fallback: assuming 0th partition is boot partition
[0004.431] I> Detect filesystem
[0004.458] I> Loading extlinux.conf ...
[0004.459] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0004.568] I> ext4_read_file:720: not a file, mode: 0x41ed
[0004.568] E> file /sdmmc_user/boot/extlinux/extlinux.conf read failed!!
[0004.569] E> Failed to find/load /boot/extlinux/extlinux.conf
[0004.569] I> Fallback: Load binaries from partition
[0004.569] W> No valid slot number is found in scratch register
[0004.570] W> Return default slot: _a
[0004.574] I> A/B: bin_type (37) slot 0
[0004.577] I> Loading kernel from partition
[0004.581] I> Loading partition kernel at 0xa42d0000 from device(0x1)
[0005.329] I> Validate kernel ...
[0005.329] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0005.331] I> RSA PSS signature check: OK
[0005.690] W> keyslot 14 is zero
[0005.705] I> Checking boot.img header magic ... [0005.705] E> Invalid header magic
[0005.705] E> Storage boot failed, err: 724238360
[0000.068] I> rst_source : 0xb
[0000.070] I> rst_level : 0x1
[0000.081] I> Qspi using bpmp-dma
[0000.122] I> Temperature = 58500
[0000.125] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.130] W> Skipping boost for clk: BPMP_APB
[0000.134] W> Skipping boost for clk: AXI_CBB
[0000.138] W> Skipping boost for clk: AON_CPU_NIC
[0000.142] W> Skipping boost for clk: CAN1
[0000.146] W> Skipping boost for clk: CAN2
[0000.150] I> Boot-device: QSPI
[0000.153] I> Boot-device: QSPI
[0000.155] I> Qspi flash params source = mb1bct
[0000.160] I> Qspi using bpmp-dma
[0000.162] I> Qspi clock source : pllc_out0
[0000.166] I> Qspi reinitialized
[0000.169] I> Qspi flash params source = mb1bct
[0000.176] I> ECC region[0]: Start:0x0, End:0x0
[0000.180] I> ECC region[1]: Start:0x0, End:0x0
[0000.184] I> ECC region[2]: Start:0x0, End:0x0
[0000.188] I> ECC region[3]: Start:0x0, End:0x0
[0000.192] I> ECC region[4]: Start:0x0, End:0x0
[0000.196] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.202] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.207] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.211] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.216] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.221] E> FAILED: Thermal config
[0000.228] E> FAILED: MEMIO rail config
[0000.238] I> Boot-device: QSPI
[0000.241] I> Qspi flash params source = mb1bct
[0000.252] I> Qspi flash params source = mb1bct
[0000.267] I> Qspi flash params source = mb1bct
[0000.349] I> Qspi flash params source = mb1bct
[0000.360] I> Qspi flash params source = mb1bct
[0000.391] I> Qspi flash params source = mb1bct
[0000.406] I> MB1 done
����main enter
HW Function test
Start Scheduler.
in late init
[0000.414] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-7515048c)
[0000.415] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.415] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.416] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.422] W> device prod register failed
[0000.426] I> Boot-device: QSPI
[0000.429] I> Boot_device: QSPI_FLASH instance: 0
[0000.434] I> QSPI Flash Size = 32 MB
[0000.439] I> Qspi initialized successfully
[0000.440] I> qspi flash-0 params source = boot args
[0000.764] I> sdmmc DDR50 mode
[0000.766] I> sdmmc-3 params source = safe params
[0000.771] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.773] W> Cannot find any partition table for 00000003
[0000.780] I> Found 14 partitions in SDMMC_USER (instance 3)
[0000.781] W> No valid slot number is found in scratch register
[0000.781] W> Return default slot: _a
[0000.781] I> Active Boot chain : 0
[0000.782] I> parsing oem signed section of bpmp-fw header done
[0000.783] I> bpmp-fw binary init read from storage
[0000.788] I> RSA PSS signature check: OK
[0000.789] I> oem authentication of bpmp-fw header done
[0000.803] I> bpmp-fw binary done read from storage
[0000.804] I> bpmp-fw: Authentication init Done
[0000.805] I> parsing oem signed section of cpubl header done
[0000.809] I> cpubl binary init read from storage
[0000.817] I> bpmp-fw: Authentication Finalize Done
[0000.820] I> RSA PSS signature check: OK
[0000.821] I> oem authentication of cpubl header done
[0000.829] I> cpubl binary done read from storage
[0000.831] I> cpubl: Authentication init Done
[0000.835] I> parsing oem signed section of rce header done
[0000.840] I> rce binary init read from storage
[0000.845] I> Relocating BR-BCT
[0000.850] I> cpubl: Authentication Finalize Done
[0000.854] I> RSA PSS signature check: OK
[0000.855] I> oem authentication of rce header done
[0000.861] I> rce binary done read from storage
[0000.865] I> rce: Authentication init Done
[0000.869] I> parsing oem signed section of ape header done
[0000.874] I> ape binary init read from storage
[0000.880] I> rce: Authentication Finalize Done
[0000.885] I> RSA PSS signature check: OK
[0000.886] I> oem authentication of ape header done
[0000.891] I> ape binary done read from storage
[0000.895] I> ape: Authentication init Done
[0000.899] I> parsing oem signed section of tos header done
[0000.904] I> tos binary init read from storage
[0000.910] I> ape: Authentication Finalize Done
[0000.917] I> oem authentication of tos header done
[0000.924] I> tos binary done read from storage
[0000.926] I> tos: Authentication init Done
[0000.930] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.936] I> bpmp-fw-dtb binary init read from storage
[0000.943] I> tos: Authentication Finalize Done
[0000.949] I> RSA PSS signature check: OK
[0000.949] I> oem authentication of bpmp-fw-dtb header done
[0000.954] I> bpmp-fw-dtb binary done read from storage
[0000.959] I> bpmp-fw-dtb: Authentication init Done
[0000.964] I> parsing oem signed section of cpubl-dtb header done
[0000.970] I> cpubl-dtb binary init read from storage
[0000.976] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.033] I> RSA PSS signature check: OK
[0001.034] I> oem authentication of cpubl-dtb header done
[0001.034] I> cpubl-dtb binary done read from storage
[0001.035] I> cpubl-dtb: Authentication init Done
[0001.036] I> parsing oem signed section of eks header done
[0001.037] I> eks binary init read from storage
[0001.038] I> cpubl-dtb: Authentication Finalize Done
[0001.043] I> RSA PSS signature check: OK
[0001.045] I> oem authentication of eks header done
[0001.049] I> eks binary done read from storage
[0001.054] I> eks: Authentication init Done
[0001.058] I> eks: Authentication Finalize Done
[0001.062] I> EKB detected (length: 0x410) @ VA:0x5270a400
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
��mrq initialized
��[0001.403] I> Welcome to Cboot
��[0001.403] I> Cboot Version: 32.05.02-evologics-t194-a4996282
[0001.407] I> CPU-BL Params @ 0xf2820000
[0001.411] I> 0) Base:0x00000000 Size:0x00000000
[0001.415] I> 1) Base:0xf1100000 Size:0x00100000
[0001.420] I> 2) Base:0xf2000000 Size:0x00200000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ��[0001.424] I> 3) Base:0xf1200000 Size:0x00200000
[0001.578] I> 4) Base:0xf1000000 Size:0x00100000
[0001.583] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.587] I> 6) Base:0xf3800000 Size:0x00400000
[0001.592] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.596] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.601] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.605] I> 10) Base:0xf3000000 Size:0x00800000
[0001.610] I> 11) Base:0x40000000 Size:0x00040000
[0001.614] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.619] I> 13) Base:0x40046000 Size:0x00002000
[0001.623] I> 14) Base:0x40048000 Size:0x00002000
[0001.628] I> 15) Base:0xac000000 Size:0x00004000
[0001.632] I> 16) Base:0x4004a000 Size:0x00002000
[0001.636] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.641] I> 18) Base:0x4004c000 Size:0x00002000
[0001.645] I> 19) Base:0xf2200000 Size:0x00600000
[0001.650] I> 20) Base:0x4004e000 Size:0x00002000
[0001.654] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.659] I> 22) Base:0x00000000 Size:0x00000000
[0001.663] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.668] I> 24) Base:0xf6000000 Size:0x02000000
[0001.672] I> 25) Base:0x40050000 Size:0x00002000
[0001.677] I> 26) Base:0x40040000 Size:0x00006000
[0001.681] I> 27) Base:0xf1800000 Size:0x00400000
[0001.686] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.690] I> 29) Base:0xf1400000 Size:0x00400000
[0001.694] I> 30) Base:0x00000000 Size:0x00000000
[0001.699] I> 31) Base:0x00000000 Size:0x00000000
[0001.703] I> 32) Base:0xf8000000 Size:0x08000000
[0001.708] I> 33) Base:0x00000000 Size:0x00000000
[0001.712] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.717] I> 35) Base:0xab000000 Size:0x01000000
[0001.721] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.726] I> 37) Base:0xf2800000 Size:0x00800000
[0001.730] I> 38) Base:0x80000000 Size:0x20000000
[0001.735] I> 39) Base:0xb0000000 Size:0x08000000
[0001.739] I> 40) Base:0x00000000 Size:0x00000000
[0001.744] I> 41) Base:0x00000000 Size:0x00000000
[0001.748] I> 42) Base:0x00000000 Size:0x00000000
[0001.752] I> 43) Base:0x00000000 Size:0x00000000
[0001.757] I> 44) Base:0x00000000 Size:0x00000000
[0001.761] I> 45) Base:0x00000000 Size:0x00000000
[0001.766] GIC-SPI Target CPU: 0
[0001.769] Interrupts Init done
[0001.772] calling constructors
[0001.775] initializing heap
[0001.777] I> Heap: [0xa0695618 ... 0xab000000]
[0001.782] initializing threads
[0001.784] initializing timers
[0001.787] creating bootstrap completion thread
[0001.792] top of bootstrap2()
[0001.794] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.799] initializing platform
[0001.802] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.807] W> device prod register failed
[0001.811] I> Bl_dtb @0xaaf00000
[0001.816] W> "plugin-manager" doesn't exist, creating
[0001.819] W> "ids" doesn't exist, creating
[0001.823] W> "connection" doesn't exist, creating
[0001.827] W> "configs" doesn't exist, creating
[0001.836] I> Find /i2c@3160000's alias i2c0
[0001.836] I> Reading eeprom i2c=0 address=0x50
[0001.865] I> Device at /i2c@3160000:0x50
[0001.866] I> Reading eeprom i2c=0 address=0x57
[0001.890] I> Device at /i2c@3160000:0x57
[0001.892] I> Find /i2c@c240000's alias i2c1
[0001.892] I> Reading eeprom i2c=1 address=0x50
[0001.894] E> I2C: slave not found in slaves.
[0001.894] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.895] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.896] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.904] E> eeprom: Retry to read I2C slave device.
[0001.909] E> I2C: slave not found in slaves.
[0001.913] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.921] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.926] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.936] E> eeprom: Failed to read I2C slave device
[0001.941] I> Eeprom read failed 0x3526070d
[0001.945] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0001.950] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.961] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0001.966] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.977] I> Adding plugin-manager/ids/3668-0001-300=/i2c@3160000:module@0x50
[0001.985] W> "i2c@3160000" doesn't exist, creating
[0001.989] W> "module@0x50" doesn't exist, creating
[0001.994] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0002.001] W> "module@0x57" doesn't exist, creating
[0002.007] I> Adding plugin-manager/cvm
[0002.009] W> "chip-id" doesn't exist, creating
[0002.013] I> Adding plugin-manager/chip-id/A02P
[0002.017] I> Plugin-manager override starting
[0002.022] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.030] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.036] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0002.043] I> Disable plugin-manager status in FDT
[0002.044] I> Plugin-manager override finished successfully
[0002.049] I> gpio framework initialized
[0002.054] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.061] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.068] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.075] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
