Serial port log:
[0029.586] I> Welcome to MB2(TBoot-BPMP) Recovery (version: 00.00.2018.32-mobile-3047f1e7)
[0029.587] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0029.588] I> Default Heap @ [0xd486400 - 0xd48a400]
[0029.589] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0029.595] W> device prod register failed
[0029.599] I> parsing oem signed section of bpmp-fw header done
[0029.607] I> bpmp-fw binary copied from blob
[0029.609] I> oem authentication of bpmp-fw header done
[0029.613] I> bpmp-fw: Authentication init Done
[0029.618] I> parsing oem signed section of cpubl header done
[0029.624] I> cpubl binary copied from blob
[0029.627] I> bpmp-fw: Authentication Finalize Done
[0029.632] I> oem authentication of cpubl header done
[0029.637] I> cpubl: Authentication init Done
[0029.641] I> parsing oem signed section of tos header done
[0029.647] I> tos binary copied from blob
[0029.650] I> Relocating BR-BCT
[0029.653] I> cpubl: Authentication Finalize Done
[0029.657] I> oem authentication of tos header done
[0029.662] I> tos: Authentication init Done
[0029.666] I> parsing oem signed section of bpmp-fw-dtb header done
[0029.672] I> bpmp-fw-dtb binary copied from blob
[0029.676] I> tos: Authentication Finalize Done
[0029.682] I> oem authentication of bpmp-fw-dtb header done
[0029.686] I> bpmp-fw-dtb: Authentication init Done
[0029.691] I> parsing oem signed section of cpubl-dtb header done
[0029.697] I> cpubl-dtb binary copied from blob
[0029.701] I> bpmp-fw-dtb: Authentication Finalize Done
[0029.777] I> oem authentication of cpubl-dtb header done
[0029.778] I> cpubl-dtb: Authentication init Done
[0029.778] I> parsing oem signed section of eks header done
[0029.779] I> eks binary copied from blob
[0029.780] I> cpubl-dtb: Authentication Finalize Done
[0029.780] I> oem authentication of eks header done
[0029.781] I> eks: Authentication init Done
[0029.784] I> eks: Authentication Finalize Done
[0029.789] I> EKB detected (length: 0x410) @ VA:0x526fb600
??NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 14:42:47, Jan 15 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
/uphy is not enabled status = disabled
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0030.122] I> Welcome to TBoot-CPU Recovery
??WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
??[0030.123] I> Heap: [0xa4000000 ... 0xaa000000
[0030.133] I> gpio framework initialized
??clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ??[0030.143] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0030.297] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0030.302] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0030.311] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0030.319] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0030.323] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0030.330] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0030.339] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0030.347] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0030.351] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0030.360] I> fixed regulator driver initialized
[0030.372] I> CPU: Nvidia Carmel
[0030.372] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[0030.372] I> chip revision : A02P
[0030.373] I> Boot-device: QSPI
[0030.376] I> Boot_device: QSPI_FLASH instance: 0
[0030.381] I> QSPI source rate = 204000 Khz
[0030.384] I> Requested rate for QSPI clock = 34000 Khz
[0030.389] I> BPMP-set rate for QSPI clk = 34000 Khz
[0030.394] I> QSPI Flash Size = 32 MB
[0030.402] I> Qspi initialized successfully
[0030.402] I> qspi flash-0 params source = boot args
[0030.824] I> sdmmc DDR50 mode
[0030.835] I> sdmmc-3 params source = safe params
[0030.837] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0030.854] W> Cannot find any partition table for 00000003
[0030.866] I> Found 11 partitions in SDMMC_USER (instance 3)
[0030.867] I> Recovery boot_type: 0
[0030.867] I> Entering 3p server
[0030.867] I> USB configuration success
[0030.972] I> Populate storage info
[0030.984] I> Erasing device 3: 0
[0030.984] I> QSPI: Erasing entire device
[0085.990] I> Writing device 3: 0.
[0086.104] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0086.106] I> Erasing device 1: 3
[0086.754] I> Writing device 1: 3.
[0086.761] I> Writing device 1: 3.
[0086.781] I> Found 11 partitions in SDMMC_USER (instance 3)
[0086.783] I> Writing device 1: 3.
[0086.802] I> Found 11 partitions in SDMMC_USER (instance 3)
[0086.804] I> Writing mb1 partition.
[0088.399] I> Writing mb1_b partition.
[0089.993] I> Writing spe-fw partition.
[0090.608] I> Writing spe-fw_b partition.
[0091.223] I> Writing mb2 partition.
[0092.324] I> Writing mb2_b partition.
[0093.424] I> Writing mts-preboot partition.
[0093.588] I> Writing mts-preboot_b partition.
[0093.751] I> Writing mts-mce partition.
[0094.670] I> Writing mts-mce_b partition.
[0095.589] I> Writing mts-proper partition.
[0117.332] I> Writing mts-proper_b partition.
[0139.063] I> Writing sc7 partition.
[0139.488] I> Writing sc7_b partition.
[0139.913] I> Writing SMD partition.
[0139.930] I> Writing SMD_b partition.
[0139.940] I> Writing xusb-fw partition.
[0140.736] I> Writing xusb-fw_b partition.
[0141.531] I> Writing cpu-bootloader partition.
[0144.367] I> Writing cpu-bootloader_b partition.
[0147.203] I> Writing bootloader-dtb partition.
[0148.505] I> Writing bootloader-dtb_b partition.
[0149.807] I> Writing BMP partition.
[0150.773] I> Writing BMP_b partition.
[0151.732] I> Writing secure-os partition.
[0154.286] I> Writing secure-os_b partition.
[0156.840] I> Writing eks partition.
[0156.887] I> Writing eks_b partition.
[0156.933] I> Writing adsp-fw partition.
[0157.460] I> Writing adsp-fw_b partition.
[0157.986] I> Writing rce-fw partition.
[0159.726] I> Writing rce-fw_b partition.
[0161.467] I> Writing bpmp-fw partition.
[0166.892] I> Writing bpmp-fw_b partition.
[0172.318] I> Writing bpmp-fw-dtb partition.
[0173.767] I> Writing bpmp-fw-dtb_b partition.
[0175.216] I> Writing VER partition.
[0175.229] I> Writing VER_b partition.
[0175.239] I> Writing device 1: 3.
[0175.246] I> Writing APP partition.
[0177.860] I> Writing kernel partition.
[0180.200] I> Writing kernel_b partition.
[0182.344] I> Writing kernel-dtb partition.
[0182.374] I> Writing kernel-dtb_b partition.
[0182.403] I> Writing recovery partition.
[0185.077] I> Writing recovery-dtb partition.
[0185.107] I> Writing kernel-bootctrl partition.
[0185.128] I> Writing kernel-bootctrl_b partition.
[0185.147] I> Writing BCT partition.
[0185.300] I> Writing MB1_BCT partition.
[0185.514] I> Writing MB1_BCT_b partition.
[0185.729] I> Writing MEM_BCT partition.
[0186.999] I> Writing MEM_BCT_b partition.
[0188.303] I> Rebooting : reset-coldboot
????Shutdown state requested 1
Rebooting system ...
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0xb
[0000.061] I> rst_level : 0x1
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] W> No valid slot number is found in scratch register
[0000.091] W> Return default slot: _a
[0000.094] I> Active Boot chain : 0
[0000.097] I> Boot-device: QSPI
[0000.100] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.112] I> Temperature = 44500
[0000.115] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.119] W> Skipping boost for clk: BPMP_APB
[0000.123] W> Skipping boost for clk: AXI_CBB
[0000.127] W> Skipping boost for clk: AON_CPU_NIC
[0000.132] W> Skipping boost for clk: CAN1
[0000.135] W> Skipping boost for clk: CAN2
[0000.139] I> Boot-device: QSPI
[0000.142] I> Boot-device: QSPI
[0000.145] I> Qspi flash params source = mb1bct
[0000.149] I> Qspi using bpmp-dma
[0000.152] I> Qspi clock source : pllc_out0
[0000.156] I> Qspi reinitialized
[0000.159] I> Qspi flash params source = mb1bct
[0000.164] I> ECC region[0]: Start:0x0, End:0x0
[0000.168] I> ECC region[1]: Start:0x0, End:0x0
[0000.173] I> ECC region[2]: Start:0x0, End:0x0
[0000.177] I> ECC region[3]: Start:0x0, End:0x0
[0000.181] I> ECC region[4]: Start:0x0, End:0x0
[0000.185] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.191] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.195] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.200] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.204] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.209] E> FAILED: Thermal config
[0000.217] E> FAILED: MEMIO rail config
[0000.227] I> Boot-device: QSPI
[0000.230] I> Qspi flash params source = mb1bct
[0000.239] I> Qspi flash params source = mb1bct
[0000.250] I> Qspi flash params source = mb1bct
[0000.317] I> Qspi flash params source = mb1bct
[0000.326] I> Qspi flash params source = mb1bct
[0000.354] I> Qspi flash params source = mb1bct
[0000.366] I> MB1 done
????main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.374] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-feba5943)
[0000.375] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.375] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.376] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.382] W> device prod register failed
[0000.386] I> Boot-device: QSPI
[0000.389] I> Boot_device: QSPI_FLASH instance: 0
[0000.394] I> QSPI Flash Size = 32 MB
[0000.399] I> Qspi initialized successfully
[0000.400] I> qspi flash-0 params source = boot args
[0000.726] I> sdmmc DDR50 mode
[0000.728] I> sdmmc-3 params source = safe params
[0000.733] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.735] W> Cannot find any partition table for 00000003
[0000.739] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.740] W> No valid slot number is found in scratch register
[0000.740] W> Return default slot: _a
[0000.741] I> Active Boot chain : 0
[0000.742] I> parsing oem signed section of bpmp-fw header done
[0000.743] I> bpmp-fw binary init read from storage
[0000.747] I> oem authentication of bpmp-fw header done
[0000.761] I> bpmp-fw binary done read from storage
[0000.762] I> bpmp-fw: Authentication init Done
[0000.763] I> parsing oem signed section of cpubl header done
[0000.767] I> cpubl binary init read from storage
[0000.771] I> bpmp-fw: Authentication Finalize Done
[0000.776] I> oem authentication of cpubl header done
[0000.783] I> cpubl binary done read from storage
[0000.785] I> cpubl: Authentication init Done
[0000.789] I> parsing oem signed section of rce header done
[0000.794] I> rce binary init read from storage
[0000.799] I> Relocating BR-BCT
[0000.802] I> cpubl: Authentication Finalize Done
[0000.806] I> oem authentication of rce header done
[0000.811] I> rce binary done read from storage
[0000.815] I> rce: Authentication init Done
[0000.819] I> parsing oem signed section of ape header done
[0000.824] I> ape binary init read from storage
[0000.829] I> rce: Authentication Finalize Done
[0000.833] I> oem authentication of ape header done
[0000.837] I> ape binary done read from storage
[0000.842] I> ape: Authentication init Done
[0000.846] I> parsing oem signed section of tos header done
[0000.851] I> tos binary init read from storage
[0000.855] I> ape: Authentication Finalize Done
[0000.860] I> oem authentication of tos header done
[0000.866] I> tos binary done read from storage
[0000.868] I> tos: Authentication init Done
[0000.873] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.879] I> bpmp-fw-dtb binary init read from storage
[0000.883] I> tos: Authentication Finalize Done
[0000.889] I> oem authentication of bpmp-fw-dtb header done
[0000.893] I> bpmp-fw-dtb binary done read from storage
[0000.898] I> bpmp-fw-dtb: Authentication init Done
[0000.903] I> parsing oem signed section of cpubl-dtb header done
[0000.909] I> cpubl-dtb binary init read from storage
[0000.913] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.970] I> oem authentication of cpubl-dtb header done
[0000.971] I> cpubl-dtb binary done read from storage
[0000.971] I> cpubl-dtb: Authentication init Done
[0000.972] I> parsing oem signed section of eks header done
[0000.973] I> eks binary init read from storage
[0000.974] I> cpubl-dtb: Authentication Finalize Done
[0000.974] I> oem authentication of eks header done
[0000.979] I> eks binary done read from storage
[0000.983] I> eks: Authentication init Done
[0000.987] I> eks: Authentication Finalize Done
[0000.991] I> EKB detected (length: 0x410) @ VA:0x52714400
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
ec_late initialized
[0001.332] I> Welcome to Cboot
??mrq initialized
??[0001.332] I> Cboot Version: t194-9efcbc4f
[0001.334] I> CPU-BL Params @ 0xf2820000
[0001.338] I> 0) Base:0x00000000 Size:0x00000000
[0001.343] I> 1) Base:0xf1100000 Size:0x00100000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ??[0001.347] I> 2) Base:0xf2000000 Size:0x00200000
[0001.501] I> 3) Base:0xf1200000 Size:0x00200000
[0001.506] I> 4) Base:0xf1000000 Size:0x00100000
[0001.510] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.515] I> 6) Base:0xf3800000 Size:0x00400000
[0001.519] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.524] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.528] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.532] I> 10) Base:0xf3000000 Size:0x00800000
[0001.537] I> 11) Base:0x40000000 Size:0x00040000
[0001.541] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.546] I> 13) Base:0x40046000 Size:0x00002000
[0001.550] I> 14) Base:0x40048000 Size:0x00002000
[0001.555] I> 15) Base:0xac000000 Size:0x00004000
[0001.559] I> 16) Base:0x4004a000 Size:0x00002000
[0001.564] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.568] I> 18) Base:0x4004c000 Size:0x00002000
[0001.573] I> 19) Base:0xf2200000 Size:0x00600000
[0001.577] I> 20) Base:0x4004e000 Size:0x00002000
[0001.582] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.586] I> 22) Base:0x00000000 Size:0x00000000
[0001.590] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.595] I> 24) Base:0xf6000000 Size:0x02000000
[0001.599] I> 25) Base:0x40050000 Size:0x00002000
[0001.604] I> 26) Base:0x40040000 Size:0x00006000
[0001.608] I> 27) Base:0xf1800000 Size:0x00400000
[0001.613] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.617] I> 29) Base:0xf1400000 Size:0x00400000
[0001.622] I> 30) Base:0x00000000 Size:0x00000000
[0001.626] I> 31) Base:0x00000000 Size:0x00000000
[0001.631] I> 32) Base:0xf8000000 Size:0x08000000
[0001.635] I> 33) Base:0x00000000 Size:0x00000000
[0001.640] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.644] I> 35) Base:0xab000000 Size:0x01000000
[0001.648] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.653] I> 37) Base:0xf2800000 Size:0x00800000
[0001.657] I> 38) Base:0x80000000 Size:0x20000000
[0001.662] I> 39) Base:0xb0000000 Size:0x08000000
[0001.666] I> 40) Base:0x00000000 Size:0x00000000
[0001.671] I> 41) Base:0x00000000 Size:0x00000000
[0001.675] I> 42) Base:0x00000000 Size:0x00000000
[0001.680] I> 43) Base:0x00000000 Size:0x00000000
[0001.684] I> 44) Base:0x00000000 Size:0x00000000
[0001.689] I> 45) Base:0x00000000 Size:0x00000000
[0001.693] GIC-SPI Target CPU: 0
[0001.696] Interrupts Init done
[0001.699] calling constructors
[0001.702] initializing heap
[0001.704] I> Heap: [0xa06945e8 ... 0xab000000]
[0001.709] initializing threads
[0001.712] initializing timers
[0001.714] creating bootstrap completion thread
[0001.719] top of bootstrap2()
[0001.722] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.726] initializing platform
[0001.729] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.735] W> device prod register failed
[0001.738] I> Bl_dtb @0xaaf00000
[0001.744] W> "plugin-manager" doesn't exist, creating
[0001.746] W> "ids" doesn't exist, creating
[0001.751] W> "connection" doesn't exist, creating
[0001.755] W> "configs" doesn't exist, creating
[0001.767] I> Find /i2c@3160000's alias i2c0
[0001.768] I> Reading eeprom i2c=0 address=0x50
[0001.793] I> Device at /i2c@3160000:0x50
[0001.794] I> Reading eeprom i2c=0 address=0x57
[0001.818] I> Device at /i2c@3160000:0x57
[0001.819] I> Find /i2c@c240000's alias i2c1
[0001.820] I> Reading eeprom i2c=1 address=0x50
[0001.822] E> I2C: slave not found in slaves.
[0001.822] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.823] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.823] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via ins.
[0001.832] E> eeprom: Retry to read I2C slave device.
[0001.837] E> I2C: slave not found in slaves.
[0001.841] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.849] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.854] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via ins.
[0001.864] E> eeprom: Failed to read I2C slave device
[0001.869] I> Eeprom read failed 0x3526070d
[0001.873] I> create_pm_ids: id: 3668-0001-200-G, len: 15
[0001.878] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,di3
[0001.889] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0001.894] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,di3
[0001.905] I> Adding plugin-manager/ids/3668-0001-200=/i2c@3160000:module@0x50
[0001.912] W> "i2c@3160000" doesn't exist, creating
[0001.917] W> "module@0x50" doesn't exist, creating
[0001.921] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.928] W> "module@0x57" doesn't exist, creating
[0001.935] I> Adding plugin-manager/cvm
[0001.937] W> "chip-id" doesn't exist, creating
[0001.941] I> Adding plugin-manager/chip-id/A02P
[0001.945] I> Plugin-manager override starting
[0001.951] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.959] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.964] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0001.973] I> Disable plugin-manager status in FDT
[0001.973] I> Plugin-manager override finished successfully
[0001.977] I> gpio framework initialized
[0001.982] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.989] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.996] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.003] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.011] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.018] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.024] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.031] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.039] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.045] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.053] I> fixed regulator driver initialized
[0002.061] I> register 'maxim' power off handle
[0002.062] I> virtual i2c enabled
[0002.063] I> registered 'maxim,max20024' pmic
[0002.068] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.074] I> Boot-device: QSPI
[0002.077] I> Boot_device: QSPI_FLASH instance: 0
[0002.082] I> QSPI source rate = 204000 Khz
[0002.085] I> Requested rate for QSPI clock = 34000 Khz
[0002.091] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.095] I> QSPI Flash Size = 32 MB
[0002.103] I> Qspi initialized successfully
[0002.103] I> qspi flash-0 params source = boot args
[0002.107] I> create_pm_ids: id: 3668-0001-200-G, len: 15
[0002.112] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,di3
[0002.123] I> create_pm_ids: id: 3509-0000-100-G, len: 15
[0002.129] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,di3
[0002.144] I> sdmmc-3 params source = safe params
[0002.146] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.166] W> Cannot find any partition table for 00000003
[0002.178] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.187] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.191] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.191] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.192] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.195] E> invalid display type
[0002.196] E> cannot find any other nvdisp nodes
[0002.196] E> no valid display unit config found in dtb
[0002.198] W> display init failed
[0002.200] I> Load in CBoot Boot Options partition and parse it
[0002.206] E> Error -9 when finding node with path /boot-configuration
[0002.212] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.219] I> Using default boot order
[0002.223] I> boot-dev-order :-
[0002.226] I> 1.sd
[0002.228] I> 2.usb
[0002.229] I> 3.nvme
[0002.231] I> 4.emmc
[0002.233] I> 5.net
[0002.235] I> Hit any key to stop autoboot: 4 3 2 1
[0004.243] initializing target
[0004.243] calling apps_init()
[0004.244] starting app kernel_boot_app
[0004.254] I> found decompressor handler: lz4-legacy
[0004.255] I> decompressing BMP blob ...
[0004.266] I> Kernel type = Normal
[0004.267] I> Loading kernel-bootctrl from partition
[0004.267] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x1)
[0004.283] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.284] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.284] I> ########## SD (0) boot ##########
[0004.285] W> Error: failed to get sd-card params
[0004.285] I> -0 params source =
[0004.286] W> Failed to initialize device 6-0
[0004.288] E> SD boot failed, err: 252641293
[0004.292] I> ########## USB (0) boot ##########
[0004.301] W> No valid slot number is found in scratch register
[0004.302] W> Return default slot: _a
[0004.314] I> USB Firmware Version: 60.06 release
[0004.368] I> regulator of usb2-0 already enabled
[0004.373] I> regulator of usb2-1 already enabled
[0004.378] I> regulator of usb2-2 already enabled
[0005.445] I> USB 2.0 port 2 new high-speed USB device detected
[0005.446] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa92d0000, cmd_ring.dma = 0xa0
[0005.547] I> Start to enumerate device
[0005.549] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa92d0000, cmd_ring.dma = 0xa0
[0005.559] I>
[0005.559] I> Enumerated USB Device 0bda:5489
[0005.559] I>
[0005.560] I> Hub:
[0005.560] I> Downstream ports : 4
[0005.561] I> Power switching : Ganged
[0005.561] I> Compound device : No
[0005.561] I> Over-current protection : Global
[0005.562] I> Hub avg delay : 4 ns
[0005.565] I> Set interface = 1 (alt setting)
[0005.570] I> Enable hub ports
[0005.782] I> Device detected on port 2
[0005.783] I> Device detected on port 3
[0006.593] I> Reset port 2
[0006.648] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa92d0000, cmd_ring.dma = 0xa0
[0006.749] I> Start to enumerate device
[0006.750] W> handle_command_completion_event: WARNING: Command was not successfully completed (0x0)
[0007.754] W> xusbh_wait_irq: Timed out! status = 0x00
[0008.757] W> xusbh_wait_irq: Timed out! status = 0x00
[0008.758] E> Failed to enumerate USB device
[0008.760] I> Reset port 3
[0008.814] I> Port 3 device is low speed, skip enumeration
[0008.815] E> Enumerated device doesn't belong to MSD class or protocol is not bulk-only!!
[0008.815] E> Class = 9, Protocol = 1
[0008.816] E> USBMSD: Failed to initialize Enumerated USB device either not an MSD device or suppor.
[0008.820] E> Error opening USBMSD driver 0, err: 7c7c0312
[0008.826] W> Failed to initialize device 5-0
[0008.830] E> USB boot failed, err: 2088502034
[0008.834] I> ########## Fixed storage boot ##########
[0008.839] I> Already published: 00010003
[0008.843] I> Look for boot partition
[0008.846] I> Fallback: assuming 0th partition is boot partition
[0008.852] I> Detect filesystem
[0008.879] I> Loading extlinux.conf ...
[0008.879] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0008.910] I> L4T boot options
[0008.910] I> [1]: "primary kernel"
[0008.910] I> Enter choice:
[0011.912] I> Continuing with default option: 1
[0011.912] I> Loading kernel sig file from rootfs ...
[0011.912] I> rootfs path: /sdmmc_user/boot/Image.sig
[0018.115] I> lookup_linear_dir:447: Invalid file block num
[0018.115] I> ext2_walk:142: 'Image.sig' lookup failed
[0018.116] I> ext4_open_file:666: '/boot/Image.sig' lookup failed
[0018.116] E> file /sdmmc_user/boot/Image.sig open failed!!
[0018.117] W> Failed to load kernel sig file (err=202113041)
[0018.117] I> Loading kernel binary from rootfs ...
[0018.122] I> rootfs path: /sdmmc_user/boot/Image
[0018.553] I> Validate kernel ...
[0018.553] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0018.554] E> Stage2Signature validation failed with SHA2!!
[0018.554] C> OEM authentication of kernel header failed!
[0018.554] W> Failed to validate kernel binary (err=1077936152, fail=1)
[0018.555] W> Security fuse not burned, ignore validation failure
[0018.567] I> No kernel-dtb binary path
[0018.567] W> No valid slot number is found in scratch register
[0018.570] W> Return default slot: _a
[0018.573] I> A/B: bin_type (38) slot 0
[0018.577] I> Loading kernel-dtb from partition
[0018.581] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0018.598] I> Validate kernel-dtb ...
[0018.598] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0018.601] I> Encryption fuse is not ON
[0018.602] I> Loading ramdisk from rootfs ...
[0018.605] I> Loading initrd sig file from rootfs ...
[0018.610] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0024.811] I> lookup_linear_dir:447: Invalid file block num
[0024.811] I> ext2_walk:142: 'initrd.sig' lookup failed
[0024.811] I> ext4_open_file:666: '/boot/initrd.sig' lookup failed
[0024.812] E> file /sdmmc_user/boot/initrd.sig open failed!!
[0024.812] W> Failed to load initrd sig file (err=202113041)
[0024.813] I> Loading initrd binary from rootfs ...
[0024.817] I> rootfs path: /sdmmc_user/boot/initrd
[0024.921] I> Validate initrd ...
[0024.921] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0024.922] E> Stage2Signature validation failed with SHA2!!
[0024.922] C> OEM authentication of initrd header failed!
[0024.922] W> Failed to validate initrd binary (err=1077936152, fail=1)
[0024.923] W> Security fuse not burned, ignore validation failure
[0024.930] I> Kernel hdr @0xa42d0000
[0024.931] I> Kernel dtb @0x90000000
[0024.935] I> decompressor handler not found
[0024.939] I> Copying kernel image (34338824 bytes) from 0xa42d0000 to 0x80080000 ... [0024.956] I>e
[0024.957] I> Updated bpmp info to DTB
[0024.958] I> Ramdisk: Base: 0x92000000; Size: 0x6e6cb6
[0024.958] I> Updated initrd info to DTB
[0024.960] W> WARN: Fail to override "console=none" in commandline
[0024.966] I> Active rootfs suffix:
[0024.970] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0024.977] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0024.984] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0024.991] W> No valid slot number is found in scratch register
[0024.997] W> Return default slot: _a
[0025.000] I> Active slot suffix:
[0025.004] I> add_boot_slot_suffix: slot_suffix =
[0025.008] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=teg
[0025.034] I> Updated bootarg info to DTB
[0025.038] W> MAC addr invalid!
[0025.041] E> Failed to get WIFI MAC address
[0025.045] W> MAC addr invalid!
[0025.048] E> Failed to get Bluetooth MAC address
[0025.052] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:07:58:f2
[0025.059] W> "plugin-manager" doesn't exist, creating
[0025.064] I> Adding /chosen/plugin-manager/cvm
[0025.068] W> "chip-id" doesn't exist, creating
[0025.072] I> Adding /chosen/plugin-manager/chip-id
[0025.077] W> "configs" doesn't exist, creating
[0025.081] I> Adding /chosen/plugin-manager/configs
[0025.085] W> "ids" doesn't exist, creating
[0025.090] I> Adding /chosen/plugin-manager/ids
[0025.094] W> "odm-data" doesn't exist, creating
[0025.098] I> Adding /chosen/plugin-manager/odm-data
[0025.105] W> "memory" doesn't exist, creating
[0025.107] I> [0] START: 0x80000000, END: 0xac000000
[0025.112] I> [1] START: 0xac004000, END: 0xf0ad0000
[0025.116] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0025.121] I> dram_block larger than 80000000
[0025.125] I> [3] START: 0x100000000, END: 0x280000000
[0025.130] I> added [base:0x80000000, size:0x2c000000] to /memory
[0025.136] I> added [base:0xac200000, size:0x44800000] to /memory
[0025.142] I> added [base:0x100000000, size:0x180000000] to /memory
[0025.149] I> Updated memory info to DTB
[0025.152] E> add_disp_param: failed to get display params for du=0
[0025.158] W> "reset" doesn't exist, creating
[0025.162] I> Adding ecid(00000001647057062000000016000280) to DT
[0025.168] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0025.172] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0025.177] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0025.182] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0025.187] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0025.191] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0025.196] I> Deleted cpu@6 node in DT
[0025.200] I> Deleted cpu@7 node in DT
[0025.203] I> Deleted cluster3 node in FDT
[0025.207] I> Update arm-pmu in FDT
[0025.210] I> - update property: interrupts
[0025.214] I> - update property: interrupt-affinity
[0025.219] W> "misc-data" doesn't exist, creating
[0025.223] I> Boot-device: QSPI
[0025.226] W> Unknown boot device
[0025.229] I> Add storage-qspi to plugin-manager/misc-data
[0025.234] W> Unknown storage device
[0025.238] I> Add serial number:1422320054196 as DT property
[0025.244] I> Plugin-manager override starting
[0025.248] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0025.255] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0025.261] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0025.268] I> Disable plugin-manager status in FDT
[0025.270] I> Plugin-manager override finished successfully
[0025.275] I> tegrabl_load_kernel_and_dtb: Done
[0025.280] E> tegrabl_display_clear: display is not initialized
[0025.285] W> Boot logo display failed...
[0025.289] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-4551) (gcc version 7.3.1 201804251
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
??WARNING: pll_d has no dyn ramp
??[ 1.937519] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.937852] imx219 9-0010: board setup failed
[ 1.961907] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.962210] imx219 10-0010: board setup failed
??WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
