Black Screen Jetson Xavier NX
TLDR: Black screen on boot with SD card inserted. Nvidia logo showing if booted with SD card removed.
I tried decreasing my boot time on my Jetson Xavier NX. I edited the file /boot/extlinux/extlinux.conf by replacing the default APPEND with “APPEND ${cbootargs} quiet”, this caused a black screen on boot. I reversed the change by removing the SD card and editing the file back to default on another machine. However I am still getting black screen. Re-formatting the SD card is not an option.
Dump the serial console log for any issues about flashing/booting:
[0000.025rom HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.9-t194-41334769-73a9b7ef)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057 : 0x0
[0000.066] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] I> Active Boot chain : 1
[0000.089] I> B[0000.098] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.106] I> Temperature = 34000
[0000.109] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.113] W> Skipping boost for clk: BPMP_APB
[0000.117] W> Skipping boost for clk: AXI_CBB
[0000.121] W> Skipping boost for clk: AON_CPost for clk: CAN2
[0000.133] I> Boot-device: QSPI
[0000.136] I> Boot-device: QSPI
[0000.139] I> Qspi flash params source = mb1bct
[0000.143] I> Qspi using bpmp-dma
[0000.146] I> Qspi clock source : pllc_out0
[0000.150] I> Qspi reinitialized
[0000.153] I> Qspi flash params source = mb1bct
[00tart:0x0, End:0x0
[0000.166] I> ECC region[2]: Start:0x0, End:0x0
[0000.171] I> ECC region[3]: Start:0x0, End:0x0
[0000.175] I> ECC region[4]: Start:0x0, End:0x0
[0000.179] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.185] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.189] I>rt:0x0, End:0x0
[0000.198] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.203] E> FAILED: Thermal config
[0000.211] E> FAILED: MEMIO rail config
[0000.221] I> Boot-device: QSPI
[0000.224] I> Qspi flash params source = mb1bct
[0000.233] I> Qspi flash params source = mb1bct
[0000.244] I> Qspi f[0000.311] I> Qspi flash params source = mb1bct
[0000.320] I> Qspi flash params source = mb1bct
[0000.351] I> Qspi flash params source = mb1bct
[0000.363] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
��9e7054ca)
[0000.372] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.372] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.373] I> gpio framework initialized
[0000.377] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.384] I> tegrabl_gpio_driver_register: register 'nvi in mb1_bct
[0000.396] I> Boot-device: QSPI
[0000.399] I> Boot_device: QSPI_FLASH instance: 0
[0000.404] I> QSPI Flash Size = 32 MB
[0000.410] I> Qspi initialized successfully
[0000.411] I> qspi flash-0 params source = boot args
[0000.416] I> Found sdcard
[0000.481] I> sdmmc SDR mode
[0000.4s in QSPI_FLASH (instance 0)
[0000.511] I> Found 19 partitions in SDCARD (instance 0)
[0000.512] I> Active Boot chain : 1
[0000.517] I> parsing oem signed section of bpmp-fw header done
[0000.522] I> bpmp-fw binary init read from storage
[0000.523] I> oem authentication of bpmp-fw header done
[0000.601] I> bpmp-fw binary done read from storage
[0000.601] I> bpmp-fw: Authentication init Done
[0000.602] I> parsing oem signed section of cpubl header done
[0000.603] I> cpubl binary init read from storage
[0000.604] I> bpmp-fw: Authentication Finalize Done
[0000.605] I> oem authenticatio
[0000.611] I> cpubl: Authentication init Done
[0000.617] I> parsing oem signed section of rce header done
[0000.622] I> rce binary init read from storage
[0000.623] I> Relocating BR-BCT
[0000.625] I> cpubl: Authentication Finalize Done
[0000.630] I> oem authentication of rce header done
[000ation init Done
[0000.668] I> parsing oem signed section of ape header done
[0000.673] I> ape binary init read from storage
[0000.673] I> rce: Authentication Finalize Done
[0000.674] I> oem authentication of ape header done
[0000.702] I> ape binary done read from storage
[0000.703] I> ape: Autader done
[0000.712] I> tos binary init read from storage
[0000.713] I> ape: Authentication Finalize Done
[0000.715] I> oem authentication of tos header done
[0000.781] I> tos binary done read from storage
[0000.782] I> tos: Authentication init Done
[0000.787] I> parsing oem signed section of storage
[0000.792] I> tos: Authentication Finalize Done
[0000.796] I> oem authentication of bpmp-fw-dtb header done
[0000.796] I> bpmp-fw-dtb binary done read from storage
[0000.797] I> bpmp-fw-dtb: Authentication init Done
[0000.798] I> parsing oem signed section of cpubl-dtb header done
[000dtb: Authentication Finalize Done
[0000.811] I> found decompressor handler: lz4
[0000.994] I> oem authentication of cpubl-dtb header done
[0000.995] I> cpubl-dtb binary done read from storage
[0000.996] I> cpubl-dtb: Authentication init Done
[0001.001] I> parsing oem signed section of eks headeubl-dtb: Authentication Finalize Done
[0001.007] I> oem authentication of eks header done
[0001.007] I> eks binary done read from storage
[0001.008] I> eks: Authentication init Done
[0001.011] I> eks: Authentication Finalize Done
[0001.016] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOT 10 2022
ERROR:   MPIDR 0x80000000: exception reason=0 syndrome=0xbe000000
ERROR:   **************************************
ERROR:   RAS Error in JSR_MTS, ERRSELR_EL1=0x2:
ERROR:   	Status = 0xfc00230d
ERROR:   	IERR = MTS_CARVEOUT Access from ARM SW: 0x23
ERROR:   SERR = Illegal address (softw3.able
ER0OR:   	 n o rec able  this  s fat0a0)
ERRO0:   	MI0C0 = 0x91b508f5xbf e38
 E R R:    M SC1 = 0x3 302720fd701020
ERROR0   	ADDR 0 0x60x010 00000 0 0
 RRO :   *****************0***0*0*0***0***4****
ff
xER OR:   RAS error h n led
E ROR: 0 sd0i_dispatch_ev0nt returned -1
3              = 0x0000000040015dd8
x6             = 0x0000000000000000
x7             = 0x0000000000000000
x8             = 0x0000000040001b24
x9             = 0x00000000400001bc
x10            = 0x0000000040001c6c
x11            = 0x0000000000000000
x12            = 0x0000000000000000
x13            == 0x0000000000000000
x16            = 0x0000000000000000
x17            = 0x0000000040016620
x18            = 0x0000000040001124
x19            = 0x0000000040000150
x20            = 0x0000000000000000
x21            = 0x0000000000000000
x22            = 0x0000000000000000
x23            = 0xx0000000000000000
x26            = 0x0000000000000000
x27            = 0x0000000000000000
x28            = 0x000000000000000
x29            = 0x0000000000000000
scr_el3        = 0x0000000000000238
sctlr_el3      = 0x0000000030c5183a
cptr_el3       = 0x0000000000000000
tcr_el3        = 0x000000000004404ff
spsr_el3       = 0x00000000400002cc
elr_el3        = 0x0000000040001734
ttbr0_el3      = 0x000000004001dd81
esr_el3        = 0x00000000be000000
far_el3        = 0x0000000000000000
spsr_el1       = 0x0000000000000000
elr_el1        = 0x0000000000000000
spsr_abt       = 0x00000000000000000
spsr_fiq       = 0x0000000000000000
sctlr_el1      = 0x0000000030d50820
actlr_el1      = 0x0000000000000001
cpacr_el1      = 0x0000000000000000
csselr_el1     = 0x0000000000000000
sp_el1         = 0x0000000000000000
esr_el1        = 0x0000000000000000
ttbr0_el1      = 0x00000000000000000
amair_el1      = 0x0000000000000000
tcr_el1        = 0x0000000000000000
tpidr_el1      = 0x0000000000000000
tpidr_el0      = 0x0000000000000000
tpidrro_el0    = 0x0000000000000000
par_el1        = 0x0000000000000000
mpidr_el1      = 0x0000000080000100
afsr0_el1      = 0x00000000000000000
vbar_el1       = 0x0000000000000000
cntp_ctl_el0   = 0x0000000000000000
cntp_cval_el0  = 0x0000000000000000
cntv_ctl_el0   = 0x0000000000000000
cntv_cval_el0  = 0x0000000000000000
cntkctl_el1    = 0x0000000000000002
sp_el0         = 0x0000000040017400
isr_el1        = 0x00000000000000000
gicc_hppir     = 0x00000000000003ff
gicc_ahppir    = 0x00000000000003ff
gicc_ctlr      = 0x0000000000000000
gicd_ispendr regs (Offsets 0x200 - 0x278)
 Offset:			value
0000000000000200:		0x0000000000000000
0000000000000204:		0x0000000000000000
000000000000000000210:		0x0000000000000000
0000000000000214:		0x0000000000000000
0000000000000218:		0x0000000000000000
000000000000021c:		0x0000000000000000
0000000000000220:		0x0000000000000000
0000000000000224:		0x0000000000000000
0000000000000228:		0x0000000000000000
000000000000022c:		0x000000000000000000000
0000000000000238:		0x0000000000000000
000000000000023c:		0x0000000000000000
0000000000000240:		0x0000000000000000
0000000000000244:		0x0000000000000000
0000000000000248:		0x0000000000000000
000000000000024c:		0x0000000000000000
0000000000000250:		0x0000000000000000
00000000000002500025c:		0x0000000000000000
0000000000000260:		0x0000000000000000
0000000000000264:		0x0000000000000000
0000000000000268:		0x0000000000000000
000000000000026c:		0x0000000000000000
0000000000000270:		0x0000000000000000
0000000000000274:		0x0000000000000000
0000000000000278:		0x000000000000000031eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
clk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 mlized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmdvs initialized
pm initialized
suspealized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq ini
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs
I am now getting a different error:
tlized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.9-t194-vision : A02P
[0000.057] I> Ram Code : 0x0
[0000.059] I> rst_source : 0x0
[0000.062] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi I> Qspi clock source : pllp
[0000.089] I> Boot-device: QSPI
[0000.092] I> Qspi flash params source = brbct
[0000.098] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 Bipping boost for clk: BPMP_CPU_NIC
[0000.121] W> Skipping boost for clk: AON_CPU_NIC
[0000.125] W> Skipping boost for clk: CAN1
[0000.129] W> Skipping boost for clk: CAN2
[0000.133] I> Boot-device: QSP= mb1bct
[0000.158] I> ECC region[0]: Start:0x0, End:0x0
[0000.162] I> ECC region[1]: Start:0x0, End:0x0
[0000.166] I> ECC region[2]: 75] I> ECC region[4]: Start:0x0, End:0x0
[0000.184] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.189] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.193] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.198] I> Non-ECC region[4][0000.211] E> FAILED: MEMIO rail config
[0000.244] I> Qspi flash params source = mb1bct
[0000.320] I> Qspi flash param[0000.351] I> Qspi flash params source = mb1bct
����main enter
HW Function test
Start Scheduler.
in late init
[0000.371] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-9e7054ca)
[0000.372] I> 6400 - 0xd48a400]
[0000.376] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.384] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.391] I> sdcard_params [0, 55, 0, 50] in mb1_bct
[0000.396] I0000.404] I> QSPI Flash Size = 32 MB
[0000.533] I> sdmmc SDR mode
[0000.548] I> sdcard-0 params source = mb1 bct
[0000.552] I> Found 47 partitions in QSPI_FLASH (instance0000.563] I> Found 19 partitions in SDCARD (instance 0)
[0000.564] I> Active Boot chain : 1
[0000.569] I> parsing oem signed section of bpmp-fw header done
[0000.574] I> bpmp-fw binary init read from storage
[0000.575] I> oem authentication of bpmp-fw header done
[0000.653] I> bpmp-fw binary do000.654] I> parsing oem signed section of cpubl header done
[0000.655] I> cpubl binary init read from storage
[0000.656] I> bpmp-fw: Authentication Finalize Done
[0000.657] I> oem authentication of cpubl header done
[0000.663] I> cpubl binary done read from storage
[0000.663] I> cpubl: Authentidone
[0000.674] I> rce binary init read from storage
[0000.675] I> Relocating BR-BCT
[0000.677] I> cpubl: Authentication Finalize Done
[0000.682] I> oem authentication of rce header done
[0000.715] I> rce binary done read from storage
[0000.715] I> rce: Authentication init Done
[0000.720] I> nit read from storage
[0000.725] I> rce: Authentication Finalize Done
[0000.726] I> oem authentication of ape header done
[0000.754] I> ape binary done read from storage
[0000.755] I> ape: Authentication init Done
[0000.760] I> parsing oem signed section of tos header done
[0000.764] I> tos bione
[0000.767] I> oem authentication of tos header done
[0000.833] I> tos binary done read from storage
[0000.834] I> tos: Authentication init Done
[0000.839] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.843] I> bpmp-fw-dtb binary init read from storage
[0000.844] I> tos: Autb header done
[0000.848] I> bpmp-fw-dtb binary done read from storage
[0000.849] I> bpmp-fw-dtb: Authentication init Done
[0000.850] I> parsing oem signed section of cpubl-dtb header done
[0000.853] I> cpubl-dtb binary init read from storage
[0000.858] I> bpmp-fw-dtb: Authentication Finalize Do[0001.046] I> oem authentication of cpubl-dtb header done
[0001.047] I> cpubl-dtb binary done read from storage
[0001.047] I> cpubl-dtb: Authentication init Done
[0001.052] I> parsing oem signed section of eks header done
[0001.057] I> eks binary init read from storage
[0001.057] I> cpubl-dtb: der done
[0001.058] I> eks binary done read from storage
[0001.059] I> eks: Authentication init Done
[0001.063] I> eks: Authentication Finalize Done
[0001.067] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE:  BL31: v2.6(release):4fa405dbd
NOTICE:  BL31: Built : 20:16:55, Aug 10 2022
ERROR:   SERR = Illegal address (software fault): 0xd
ERROR:   nOvhralow (there may bxe mote eornrs) - Uncorr cEtable
fae38b
ERROR:   	MISC1 = 0x3338272afd70012e
ER0OR:0  	ADDR0= 00600000
000000000
ERROR:   ******************************0*******
404fERROR:   RAS error handled!
ERROR:   sdei_dispatch_event returned -1
8
x3             = 0x000000004001dd81
x4             = 0x0000000000000004
x5             == 0x0000000000000000
x13            = 0x0000000000000000
x14            = 0x0000000000000000
x15            = 0xx0000000040016620
x23            = 0x0000000000000000
x24            = x0000000000000000
x25            = 0x00000000000000000
tcr_el3        = 0x0000000080823518
daif           = 0x00000000000003c0
mair_el3       = 0x00000000040001734
spsr_und       = 0x0000000000000000
spsr_irq       = 0x00000000000d50820
ttbr1_el1      = 0x0000000000000000
mair_el1       = 0x00000000000000000
mpidr_el1      = 0x0000000080000200
afsr1_el1      = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
sp_el0         = 0x0000000040017c00
dacr32_el2     = 0x0000000000000000
ifsr32_el2     = 0x0000000000000000
acicc_ahppir    = 0x00000000000003ff
 Offset:			value
0000000000000208:		0x0000000000000000
000000000000020c:		0x0000000000000000
000000000000000000218:		0x0000000000000000
0000000000000230:		0x0000000000000000
0000000000000234:		0x000000000000000000000
0000000000000254:		0x0000000000000000
0000000000000258:		0x0000000000000000
000000000000025000264:		0x0000000000000000
000000000000027c:		0x0000000000000000
bpmp: init
bpmp: tag is 128431eec
fuse initialized
hwwdt initialized
ec initialized
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
mc initialized
reset initialized
nvhs initializedlk initialized
io_dpd initialized
thermal initialized
i2c initialized
vrmdvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initializezed
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
maiinitialized
mrq initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_platform_post initialized
cvc_late initialized
regulator_post initializ
Are you using a DevKit or a custom carrier board?
What L4T version?
DevKit. How do I find the L4T version?
# R35 (release), REVISION: 1.0, GCID: 31346300, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 25 18:41:45 UTC 2022
Can you please try if flashing only the QSPI bootloader fixes it?
sudo ./flash.sh jetson-xavier-nx-devkit-qspi internal
It will not modify anything on the SD card.
Or get another module for testing if you have one.
where can I get the flash.sh script and files?
Reflashed, looks good. However keyboard is not working.
Please file a new topic if the original issue is solved.
No its not solved. Its stuck on UEFI interactive shell, no keyboard input.
What do you mean with stuck?
Any log?
uefi interactive shell v2.2 with no keyboard
Get the full log, please.
You can always connect UART and use the keyboard on the host PC instead.
Then choose SD card in the boot order menu and see if it boots.
Thank you so much. I flashed the wrong version before. Now everything is fine and working perfectly. Thank you very much for your help Dave, Have a great weekend!
Sure!
Glad it helps.
贼拉拉6,给个赞你
