Jetson Xavier NX Developer Kit will not start
I got my Jetson Xavier NX a few months ago and it was working perfectly fine until today. After powering on the Jetson, there was an LED light which meant that the Jetson was turned on. However, there was no start up or loading screen with the NVIDIA logo. I tried changing SD cards and reflashing it but to no avail. I even tried doing the Force Recovery Mode and still it will not load.
I tried with another Jetson Xavier NX in hand and it works perfectly fine. Could this be a hardware issue on my former Jetson Xavier NX?
hello ashh,
suggest you should setup serial console and gather the bootloader messages for reference,
thanks
Hi JerryChang,
I connected my kit to my computer (Windows 10) running puTTY and I do not get any output on the serial log. I connected my laptop to the jetson xavier nx serial pins using an FTDI module (RX/TX pins).
My apologies, I have now connected it to the J14 RXTX pins and gotten some output. It seems to keep running non stop but here is what I got.
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet leve        l 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0xb
[0000.061] I> rst_level : 0x1
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] E> LOADER: Failed to verify SMD.
[0000.089] I> Primary SMD copy is invalid, try with secondary copy..
[0000.095] E> LOADER: Failed to verify SMD.
[0000.099] E> LOADER: Failed to verify SMD & SMD_b.
[0000.103] E> Error: SMD: Load failed
[0000.107] E> Load SMD failed
[0000.109] E> LOADER: Failed to get slot for boot chain from SMD.
[0000.115] E> LOADER: Failed to get storage info for binary 0 from loader.
[0000.121] E> LOADER: Failed to get info for binary 0 from loader.
[0000.127] C> LOADER: Could not read binary 0.
[0000.131] C> Fail to load mb1-bct bin
[0000.134] E> Task 24 failed (err: 0x1d1d1318)
[0000.138] E> Top caller module: LOADER, error module: LOADER, reason: 0x18, aux        _info: 0x13
[0000.146] I> MB1(1.5.1.6-t194-41334769-1740dd39) BIT boot status dump :
00000000000111111111101110000000000000000000000000000000000000000000000000000000        00000000000000000000000000000000000000000000000000000000000000000000000000000000        00000000000000000000000000000000000000000000000000000000000000000000000000000000        0000000000000000
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.138] E> Top caller module: LOADER, error module: LOADER, reason: 0x18, aux_info: 0x13
0000000000011111111110111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
hello ashh,
here’s the root cause.
as I knew, there’s stability for SMD update on r32.5.
since there’s background service running for SMD update, abruptly shutdown may crash the service and cause such scenario.
may I know which JetPack release you’re using?
also, how did you reproduce this, had you ever power-off your Xavier NX as soon as it’s power-on?
could you please download SDK Manager | NVIDIA Developer and re-flash the latest JetPack release for confirmation.
thanks
I appreciate your fast reply. I believe the jetpack version that I was using was Jetpack 4.5.1. I always follow best practise by turning off the Jetson from the settings bar instead of directly cutting off power from my supply/outlet. I reproduced this by simply connecting the J14 UART pins to my laptop running puTTY on Windows 10. Afterwards, I simply power on my jetson xavier and open up a terminal session on puTTY. The error messages as shown above appears.
I have 2 questions regarding the flashing using NVIDIA SDK Manager:
  1. Can I use windows to flash the jetpack release or do I need to use an Ubuntu OS host?
  2. Do I need to have an empty SD card mounted or can I just use my current SD card with the image already flashed.
Apologies if the question seems silly but I am still learning about the Jetson system.
hello ashh,
NVIDIA SDK Manager | NVIDIA Developer it only supports ubuntuOS or CentOS.
you can have your SD-card mounted to re-flash the image entirely.
Do I just follow the steps in this link?
that’s correct. you may also refer to Step 4: Finalize Setup to [Export Debug Logs] if you’re having troubles.
I have the same problem with Jetson Xavier NX Developer Kit / Jetpack4.5.1(L4T 32.5.1).
Though I have succeeded in recovery by re-flashing, I want to know the details of this problem as a countermeasure.
So, I want to make clear the following.
  1. Does this problem occur at timings other than immediately after turning on the power?(other than during boot?)
  2. Does this problem only occur with specific versions of JetPack/L4T?
  3. Does this problem occur even if it is not a Developer Kit?
    (Does it not occur on Jetson NX Production Module?)
Thank you.
